[U-Boot] ppc4xx:DDR SDRAM test
Dear ALL
I ported u-boot-2009-11 to my custom board using ppc440EP processor. I changed amcc/bamboo BSP to run u-boot on my board.
I have some Questions and any suggestion can help me: 1. Is mtest command is sufficient for DDR SDRAM testing? 2. what is data cache status in mtest? 3. for DDR SDRAM full test, I wrote a function to generate random data and address test patterns, using random()function in stdlib.h but there is a compilation error " stdlib.h: No such file or directory" when stdlib.h is included in bamboo.c
Thank for your consideration!
Hi Tim,
Hmmm. Already nearly one year old. I suggest to update to the latest release.
Autsch. You should never "change" an existing board port, but instead create your own custom board port. Of course an existing one can always be the basis for this. This way you can submit your changes to mainline U-Boot and your custom board port will be in sync with the U-Boot updates.
- Is mtest command is sufficient for DDR SDRAM testing?
No. SDRAM problems are hard to spot. Most memory testing routines can't spot all problems. One very good test-case is to run Linux on the board and compile a Linux kernel mounted via NFS. This has proven to show most SDRAM related problems.
- what is data cache status in mtest?
That's architecture specific. Currently most PPC4xx board (and bamboo as well) don't enable i-cache and d-cache in SDRAM locations.
- for DDR SDRAM full test, I wrote a function to generate random data
and
There is no stdlib.h in U-Boot.
Cheers, Stefan
-- DENX Software Engineering GmbH, MD: Wolfgang Denk & Detlev Zundel HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: (+49)-8142-66989-0 Fax: (+49)-8142-66989-80 Email: office@denx.de
Stefan Roese
Tim Rachman
