[U-Boot] [PATCH] arm: mvebu: db-88f6820: Drop obsolete binary.0 placeholder
It has been superseded in kwbimage.cfg in favor of an SPL in commit 9e30b31d20f0b793465d07f056b3d9885f578c0d (arm: mvebu: db-88f6820: Add SPL support with DDR init code). Found via code review.
Cc: Stefan Roese sr@denx.de Signed-off-by: Andreas Färber afaerber@suse.de --- board/Marvell/db-88f6820-gp/binary.0 | 16 ---------------- 1 file changed, 16 deletions(-) delete mode 100644 board/Marvell/db-88f6820-gp/binary.0
diff --git a/board/Marvell/db-88f6820-gp/binary.0 b/board/Marvell/db-88f6820-gp/binary.0 deleted file mode 100644 index 57a4cbf..0000000 --- a/board/Marvell/db-88f6820-gp/binary.0 +++ /dev/null @@ -1,16 +0,0 @@ --------- -WARNING: --------- -This file should contain the bin_hdr generated by the original Marvell -U-Boot implementation. As this is currently not included in this -U-Boot version, we have added this placeholder, so that the U-Boot -image can be generated without errors. - -If you have a known to be working bin_hdr for your board, then you -just need to replace this text file here with the binary header -and recompile U-Boot. - -In a few weeks, mainline U-Boot will get support to generate the -bin_hdr with the DDR training code itself. By implementing this code -as SPL U-Boot. Then this file will not be needed any more and will -get removed.
Applied to u-boot-marvell/master.
Thanks, Stefan
Andreas Färber
Stefan Roese
