[U-Boot] [PATCH] powerpc/t104xrdb: Update T1042RDB.h in config folder
-Add usb2 node entry in "hwconfig string"
-Remove controller interleaving from hwconfig string as T1040 has only one DDR conroller
-SPI related macros which were earlier under #ifdef CONFIG_SPIFLASH are move outside so that they are defined for all cases as these macros are also used by other u-boot code
-Add CONFIG_SYS_CSPR2_EXT to make cpld accessible in u-boot
Signed-off-by: Prabhakar Kushwaha prabhakar@freescale.com --- include/configs/T1042RDB_PI.h | 15 ++++++++------- 1 file changed, 8 insertions(+), 7 deletions(-)
diff --git a/include/configs/T1042RDB_PI.h b/include/configs/T1042RDB_PI.h index 104bb92..88f6924 100644 --- a/include/configs/T1042RDB_PI.h +++ b/include/configs/T1042RDB_PI.h @@ -80,10 +80,6 @@ #if defined(CONFIG_SPIFLASH) #define CONFIG_SYS_EXTRA_ENV_RELOC #define CONFIG_ENV_IS_IN_SPI_FLASH -#define CONFIG_ENV_SPI_BUS 0 -#define CONFIG_ENV_SPI_CS 0 -#define CONFIG_ENV_SPI_MAX_HZ 10000000 -#define CONFIG_ENV_SPI_MODE 0 #define CONFIG_ENV_SIZE 0x2000 /* 8KB */ #define CONFIG_ENV_OFFSET 0x100000 /* 1MB */ #define CONFIG_ENV_SECT_SIZE 0x10000 @@ -203,6 +199,7 @@ /* CPLD on IFC */ #define CONFIG_SYS_CPLD_BASE 0xffdf0000 #define CONFIG_SYS_CPLD_BASE_PHYS (0xf00000000ull | CONFIG_SYS_CPLD_BASE) +#define CONFIG_SYS_CSPR2_EXT (0xf) #define CONFIG_SYS_CSPR2 (CSPR_PHYS_ADDR(CONFIG_SYS_CPLD_BASE_PHYS) \ | CSPR_PORT_SIZE_8 \ | CSPR_MSEL_GPCM \ @@ -395,6 +392,10 @@ #define CONFIG_CMD_SF #define CONFIG_SF_DEFAULT_SPEED 10000000 #define CONFIG_SF_DEFAULT_MODE 0 +#define CONFIG_ENV_SPI_BUS 0 +#define CONFIG_ENV_SPI_CS 0 +#define CONFIG_ENV_SPI_MAX_HZ 10000000 +#define CONFIG_ENV_SPI_MODE 0
/* * General PCI @@ -632,9 +633,9 @@ #define __USB_PHY_TYPE utmi
#define CONFIG_EXTRA_ENV_SETTINGS \ - "hwconfig=fsl_ddr:ctlr_intlv=cacheline," \ - "bank_intlv=cs0_cs1;" \ - "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ + "hwconfig=fsl_ddr:bank_intlv=cs0_cs1;" \ + "usb1:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) \ + "usb2:dr_mode=host,phy_type=" __stringify(__USB_PHY_TYPE) "\0"\ "netdev=eth0\0" \ "uboot=" __stringify(CONFIG_UBOOTPATH) "\0" \ "ubootaddr=" __stringify(CONFIG_SYS_TEXT_BASE) "\0" \
Prabhakar Kushwaha
