[U-Boot] [PATCH 0/4] Add network support for Ocelots SoCs
Hello,
this series allows to use the switch component of the Ocelots SoC as a network interface.
The binding used is exactly the same of the one already used by Linux.
There is also a patch adding a workaround needed on the Ocelot based boards: indeed the pin connected to the DDR reset is part of the switch subsystem. So we need ensure that the DDR is not reset during the switch reset.
Gregory
Gregory CLEMENT (4): MIPS: mscc: ocelot: Add ethernet nodes for Ocelot net: add MSCC Ocelot switch support MIPS: mscc: ocelot: add switch reset support configs: mscc_ocelot: add network support
MAINTAINERS | 1 + arch/mips/dts/mscc,ocelot.dtsi | 97 ++++ arch/mips/dts/ocelot_pcb123.dts | 20 + board/mscc/ocelot/ocelot.c | 28 ++ configs/mscc_ocelot_defconfig | 1 + drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/ocelot_switch.c | 837 ++++++++++++++++++++++++++++++++ 8 files changed, 992 insertions(+) create mode 100644 drivers/net/ocelot_switch.c
Import Ethernet related nodes from Linux
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- arch/mips/dts/mscc,ocelot.dtsi | 97 +++++++++++++++++++++++++++++++++ arch/mips/dts/ocelot_pcb123.dts | 20 +++++++ 2 files changed, 117 insertions(+)
diff --git a/arch/mips/dts/mscc,ocelot.dtsi b/arch/mips/dts/mscc,ocelot.dtsi index 2592003103..4f3fe356c4 100644 --- a/arch/mips/dts/mscc,ocelot.dtsi +++ b/arch/mips/dts/mscc,ocelot.dtsi @@ -112,6 +112,98 @@ status = "disabled"; };
+ switch@1010000 { + pinctrl-0 = <&miim1_pins>; + pinctrl-names = "default"; + + compatible = "mscc,vsc7514-switch"; + reg = <0x1010000 0x10000>, /* VTSS_TO_SYS */ + <0x1030000 0x10000>, /* VTSS_TO_REW */ + <0x1080000 0x100>, /* VTSS_TO_DEVCPU_QS */ + <0x10d0000 0x10000>, /* VTSS_TO_HSIO */ + <0x11e0000 0x100>, /* VTSS_TO_DEV_0 */ + <0x11f0000 0x100>, /* VTSS_TO_DEV_1 */ + <0x1200000 0x100>, /* VTSS_TO_DEV_2 */ + <0x1210000 0x100>, /* VTSS_TO_DEV_3 */ + <0x1220000 0x100>, /* VTSS_TO_DEV_4 */ + <0x1230000 0x100>, /* VTSS_TO_DEV_5 */ + <0x1240000 0x100>, /* VTSS_TO_DEV_6 */ + <0x1250000 0x100>, /* VTSS_TO_DEV_7 */ + <0x1260000 0x100>, /* VTSS_TO_DEV_8 */ + <0x1270000 0x100>, /* NA */ + <0x1280000 0x100>, /* NA */ + <0x1800000 0x80000>, /* VTSS_TO_QSYS */ + <0x1880000 0x10000>; /* VTSS_TO_ANA */ + reg-names = "sys", "rew", "qs", "hsio", "port0", + "port1", "port2", "port3", "port4", "port5", + "port6", "port7", "port8", "port9", + "port10", "qsys", "ana"; + interrupts = <21 22>; + interrupt-names = "xtr", "inj"; + status = "okay"; + + ethernet-ports { + #address-cells = <1>; + #size-cells = <0>; + + port0: port@0 { + reg = <0>; + }; + port1: port@1 { + reg = <1>; + }; + port2: port@2 { + reg = <2>; + }; + port3: port@3 { + reg = <3>; + }; + port4: port@4 { + reg = <4>; + }; + port5: port@5 { + reg = <5>; + }; + port6: port@6 { + reg = <6>; + }; + port7: port@7 { + reg = <7>; + }; + port8: port@8 { + reg = <8>; + }; + port9: port@9 { + reg = <9>; + }; + port10: port@10 { + reg = <10>; + }; + }; + }; + + mdio0: mdio@107009c { + #address-cells = <1>; + #size-cells = <0>; + compatible = "mscc,ocelot-miim"; + reg = <0x107009c 0x24>, <0x10700f0 0x8>; + interrupts = <14>; + status = "disabled"; + + phy0: ethernet-phy@0 { + reg = <0>; + }; + phy1: ethernet-phy@1 { + reg = <1>; + }; + phy2: ethernet-phy@2 { + reg = <2>; + }; + phy3: ethernet-phy@3 { + reg = <3>; + }; + }; + reset@1070008 { compatible = "mscc,ocelot-chip-reset"; reg = <0x1070008 0x4>; @@ -144,6 +236,11 @@ function = "si"; };
+ miim1_pins: miim1-pins { + pins = "GPIO_14", "GPIO_15"; + function = "miim1"; + }; + spi_cs2_pin: spi-cs2-pin { pins = "GPIO_9"; function = "si"; diff --git a/arch/mips/dts/ocelot_pcb123.dts b/arch/mips/dts/ocelot_pcb123.dts index c4cb7a1194..a4fa37001f 100644 --- a/arch/mips/dts/ocelot_pcb123.dts +++ b/arch/mips/dts/ocelot_pcb123.dts @@ -35,3 +35,23 @@ status = "okay"; mscc,sgpio-ports = <0x00FFFFFF>; }; + +&mdio0 { + status = "okay"; +}; + +&port0 { + phy-handle = <&phy0>; +}; + +&port1 { + phy-handle = <&phy1>; +}; + +&port2 { + phy-handle = <&phy2>; +}; + +&port3 { + phy-handle = <&phy3>; +};
This patch adds support for the Microsemi Ethernet switch present on Ocelot SoCs.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- MAINTAINERS | 1 + drivers/net/Kconfig | 7 + drivers/net/Makefile | 1 + drivers/net/ocelot_switch.c | 837 ++++++++++++++++++++++++++++++++++++ 4 files changed, 846 insertions(+) create mode 100644 drivers/net/ocelot_switch.c
diff --git a/MAINTAINERS b/MAINTAINERS index 3fa5d3e96f..af44e19eae 100644 --- a/MAINTAINERS +++ b/MAINTAINERS @@ -529,6 +529,7 @@ F: drivers/gpio/mscc_sgpio.c F: drivers/spi/mscc_bb_spi.c F: include/configs/vcoreiii.h F: drivers/pinctrl/mscc/ +F: drivers/net/ocelot_switch.c
MIPS JZ4780 M: Ezequiel Garcia ezequiel@collabora.com diff --git a/drivers/net/Kconfig b/drivers/net/Kconfig index 7044c6adf3..10ac15cc6c 100644 --- a/drivers/net/Kconfig +++ b/drivers/net/Kconfig @@ -432,6 +432,13 @@ config SNI_AVE This driver implements support for the Socionext AVE Ethernet controller, as found on the Socionext UniPhier family.
+config MSCC_OCELOT_SWITCH + bool "Ocelot switch driver" + depends on DM_ETH && ARCH_MSCC + select PHYLIB + help + This driver supports the Ocelot network switch device. + config ETHER_ON_FEC1 bool "FEC1" depends on MPC8XX_FEC diff --git a/drivers/net/Makefile b/drivers/net/Makefile index 0dbfa03306..bd108c21d1 100644 --- a/drivers/net/Makefile +++ b/drivers/net/Makefile @@ -74,3 +74,4 @@ obj-$(CONFIG_DWC_ETH_QOS) += dwc_eth_qos.o obj-$(CONFIG_FSL_PFE) += pfe_eth/ obj-$(CONFIG_SNI_AVE) += sni_ave.o obj-y += ti/ +obj-$(CONFIG_MSCC_OCELOT_SWITCH) += ocelot_switch.o diff --git a/drivers/net/ocelot_switch.c b/drivers/net/ocelot_switch.c new file mode 100644 index 0000000000..7ad0538b76 --- /dev/null +++ b/drivers/net/ocelot_switch.c @@ -0,0 +1,837 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2018 Microsemi Corporation + */ + +#include <common.h> +#include <config.h> +#include <dm.h> +#include <dm/of_access.h> +#include <dm/of_addr.h> +#include <fdt_support.h> +#include <linux/io.h> +#include <linux/ioport.h> +#include <miiphy.h> +#include <net.h> + +#define MIIM_STATUS 0x0 +#define MIIM_STAT_BUSY BIT(3) +#define MIIM_CMD 0x8 +#define MIIM_CMD_SCAN BIT(0) +#define MIIM_CMD_OPR_WRITE BIT(1) +#define MIIM_CMD_OPR_READ BIT(2) +#define MIIM_CMD_SINGLE_SCAN BIT(3) +#define MIIM_CMD_WRDATA(x) ((x) << 4) +#define MIIM_CMD_REGAD(x) ((x) << 20) +#define MIIM_CMD_PHYAD(x) ((x) << 25) +#define MIIM_CMD_VLD BIT(31) +#define MIIM_DATA 0xC +#define MIIM_DATA_ERROR (0x2 << 16) + +#define PHY_CFG 0x0 +#define PHY_CFG_ENA 0xF +#define PHY_CFG_COMMON_RST BIT(4) +#define PHY_CFG_RST (0xF << 5) +#define PHY_STAT 0x4 +#define PHY_STAT_SUPERVISOR_COMPLETE BIT(0) + +#define ANA_PORT_VLAN_CFG(x) (0x7000 + 0x100 * (x)) +#define ANA_PORT_VLAN_CFG_AWARE_ENA BIT(20) +#define ANA_PORT_VLAN_CFG_POP_CNT(x) ((x) << 18) +#define ANA_PORT_PORT_CFG(x) (0x7070 + 0x100 * (x)) +#define ANA_PORT_PORT_CFG_RECV_ENA BIT(6) +#define ANA_TABLES_MACHDATA 0x8b34 +#define ANA_TABLES_MACLDATA 0x8b38 +#define ANA_TABLES_MACACCESS 0x8b3c +#define ANA_TABLES_MACACCESS_VALID BIT(11) +#define ANA_TABLES_MACACCESS_ENTRYTYPE(x) ((x) << 9) +#define ANA_TABLES_MACACCESS_DEST_IDX(x) ((x) << 3) +#define ANA_TABLES_MACACCESS_MAC_TABLE_CMD(x) (x) +#define ANA_TABLES_MACACCESS_MAC_TABLE_CMD_M GENMASK(2, 0) +#define MACACCESS_CMD_IDLE 0 +#define MACACCESS_CMD_LEARN 1 +#define MACACCESS_CMD_GET_NEXT 4 +#define ANA_PGID(x) (0x8c00 + 4 * (x)) + +#define SYS_FRM_AGING 0x574 +#define SYS_FRM_AGING_ENA BIT(20) + +#define SYS_SYSTEM_RST_CFG 0x508 +#define SYS_SYSTEM_RST_MEM_INIT BIT(0) +#define SYS_SYSTEM_RST_MEM_ENA BIT(1) +#define SYS_SYSTEM_RST_CORE_ENA BIT(2) +#define SYS_PORT_MODE(x) (0x514 + 0x4 * (x)) +#define SYS_PORT_MODE_INCL_INJ_HDR(x) ((x) << 3) +#define SYS_PORT_MODE_INCL_INJ_HDR_M GENMASK(4, 3) +#define SYS_PORT_MODE_INCL_XTR_HDR(x) ((x) << 1) +#define SYS_PORT_MODE_INCL_XTR_HDR_M GENMASK(2, 1) +#define SYS_PAUSE_CFG(x) (0x608 + 0x4 * (x)) +#define SYS_PAUSE_CFG_PAUSE_ENA BIT(0) + +#define QSYS_SWITCH_PORT_MODE(x) (0x11234 + 0x4 * (x)) +#define QSYS_SWITCH_PORT_MODE_PORT_ENA BIT(14) +#define QSYS_QMAP 0x112d8 +#define QSYS_EGR_NO_SHARING 0x1129c + +/* Port registers */ +#define DEV_CLOCK_CFG 0x0 +#define DEV_CLOCK_CFG_LINK_SPEED_1000 1 +#define DEV_MAC_ENA_CFG 0x1c +#define DEV_MAC_ENA_CFG_RX_ENA BIT(4) +#define DEV_MAC_ENA_CFG_TX_ENA BIT(0) + +#define DEV_MAC_IFG_CFG 0x30 +#define DEV_MAC_IFG_CFG_TX_IFG(x) ((x) << 8) +#define DEV_MAC_IFG_CFG_RX_IFG2(x) ((x) << 4) +#define DEV_MAC_IFG_CFG_RX_IFG1(x) (x) + +#define PCS1G_CFG 0x48 +#define PCS1G_MODE_CFG_SGMII_MODE_ENA BIT(0) +#define PCS1G_MODE_CFG 0x4c +#define PCS1G_MODE_CFG_UNIDIR_MODE_ENA BIT(4) +#define PCS1G_MODE_CFG_SGMII_MODE_ENA BIT(0) +#define PCS1G_SD_CFG 0x50 +#define PCS1G_ANEG_CFG 0x54 +#define PCS1G_ANEG_CFG_ADV_ABILITY(x) ((x) << 16) + +#define QS_XTR_GRP_CFG(x) (4 * (x)) +#define QS_XTR_GRP_CFG_MODE(x) ((x) << 2) +#define QS_XTR_GRP_CFG_STATUS_WORD_POS BIT(1) +#define QS_XTR_GRP_CFG_BYTE_SWAP BIT(0) +#define QS_XTR_RD(x) (0x8 + 4 * (x)) +#define QS_XTR_FLUSH 0x18 +#define QS_XTR_FLUSH_FLUSH GENMASK(1, 0) +#define QS_XTR_DATA_PRESENT 0x1c +#define QS_INJ_GRP_CFG(x) (0x24 + (x) * 4) +#define QS_INJ_GRP_CFG_MODE(x) ((x) << 2) +#define QS_INJ_GRP_CFG_BYTE_SWAP BIT(0) +#define QS_INJ_WR(x) (0x2c + 4 * (x)) +#define QS_INJ_CTRL(x) (0x34 + 4 * (x)) +#define QS_INJ_CTRL_GAP_SIZE(x) ((x) << 21) +#define QS_INJ_CTRL_EOF BIT(19) +#define QS_INJ_CTRL_SOF BIT(18) +#define QS_INJ_CTRL_VLD_BYTES(x) ((x) << 16) + +#define XTR_EOF_0 ntohl(0x80000000u) +#define XTR_EOF_1 ntohl(0x80000001u) +#define XTR_EOF_2 ntohl(0x80000002u) +#define XTR_EOF_3 ntohl(0x80000003u) +#define XTR_PRUNED ntohl(0x80000004u) +#define XTR_ABORT ntohl(0x80000005u) +#define XTR_ESCAPE ntohl(0x80000006u) +#define XTR_NOT_READY ntohl(0x80000007u) + +#define IFH_INJ_BYPASS BIT(31) +#define IFH_TAG_TYPE_C 0 +#define XTR_VALID_BYTES(x) (4 - ((x) & 3)) +#define MAC_VID 1 +#define CPU_PORT 11 +#define INTERNAL_PORT_MSK 0xF +#define IFH_LEN 4 +#define OCELOT_BUF_CELL_SZ 60 +#define ETH_ALEN 6 +#define PGID_BROADCAST 13 +#define PGID_UNICAST 14 +#define PGID_SRC 80 + +enum ocelot_target { + ANA, + QS, + QSYS, + REW, + SYS, + HSIO, + PORT0, + PORT1, + PORT2, + PORT3, + TARGET_MAX, +}; + +#define MAX_PORT (PORT3 - PORT0) + +/* MAC table entry types. + * ENTRYTYPE_NORMAL is subject to aging. + * ENTRYTYPE_LOCKED is not subject to aging. + * ENTRYTYPE_MACv4 is not subject to aging. For IPv4 multicast. + * ENTRYTYPE_MACv6 is not subject to aging. For IPv6 multicast. + */ +enum macaccess_entry_type { + ENTRYTYPE_NORMAL = 0, + ENTRYTYPE_LOCKED, + ENTRYTYPE_MACv4, + ENTRYTYPE_MACv6, +}; + +enum ocelot_mdio_target { + MIIM, + PHY, + TARGET_MDIO_MAX, +}; + +enum ocelot_phy_id { + INTERNAL, + EXTERNAL, + NUM_PHY, +}; + +struct ocelot_private { + void __iomem *regs[TARGET_MAX]; + + struct mii_dev *bus[NUM_PHY]; + struct phy_device *phydev; + int phy_mode; + int max_speed; + + int rx_pos; + int rx_siz; + int rx_off; + int tx_num; + + u8 tx_adj_packetbuf[PKTSIZE_ALIGN + PKTALIGN]; + void *tx_adj_buf; + + struct ocelot_soc_data *data; +}; + +struct ocelot_soc_data { + phys_addr_t base[TARGET_MAX]; + unsigned long size[TARGET_MAX]; + + phys_addr_t phy_base[NUM_PHY][TARGET_MAX]; + unsigned long phy_size[NUM_PHY][TARGET_MAX]; +}; + +struct mscc_miim_dev { + void __iomem *regs; + void __iomem *phy_regs; +}; + +struct mscc_miim_dev miim[NUM_PHY]; + +static int mscc_miim_wait_ready(struct mscc_miim_dev *miim) +{ + unsigned long deadline; + u32 val; + + deadline = timer_get_us() + 250000; + + do { + val = readl(miim->regs + MIIM_STATUS); + } while (timer_get_us() <= deadline && (val & MIIM_STAT_BUSY)); + + if (val & MIIM_STAT_BUSY) + return -ETIMEDOUT; + + return 0; +} + +static int mscc_miim_reset(struct mii_dev *bus) +{ + struct mscc_miim_dev *miim = (struct mscc_miim_dev *)bus->priv; + + if (miim->phy_regs) { + writel(0, miim->phy_regs + PHY_CFG); + writel(PHY_CFG_RST | PHY_CFG_COMMON_RST + | PHY_CFG_ENA, miim->phy_regs + PHY_CFG); + mdelay(500); + } + + return 0; +} + +static int mscc_miim_read(struct mii_dev *bus, int addr, int devad, int reg) +{ + struct mscc_miim_dev *miim = (struct mscc_miim_dev *)bus->priv; + u32 val; + int ret; + + ret = mscc_miim_wait_ready(miim); + if (ret) + goto out; + + writel(MIIM_CMD_VLD | MIIM_CMD_PHYAD(addr) | + MIIM_CMD_REGAD(reg) | MIIM_CMD_OPR_READ, + miim->regs + MIIM_CMD); + + ret = mscc_miim_wait_ready(miim); + if (ret) + goto out; + + val = readl(miim->regs + MIIM_DATA); + if (val & MIIM_DATA_ERROR) { + ret = -EIO; + goto out; + } + + ret = val & 0xFFFF; + out: + return ret; +} + +static int mscc_miim_write(struct mii_dev *bus, int addr, int devad, int reg, + u16 val) +{ + struct mscc_miim_dev *miim = (struct mscc_miim_dev *)bus->priv; + int ret; + + ret = mscc_miim_wait_ready(miim); + if (ret < 0) + goto out; + + writel(MIIM_CMD_VLD | MIIM_CMD_PHYAD(addr) | + MIIM_CMD_REGAD(reg) | MIIM_CMD_WRDATA(val) | + MIIM_CMD_OPR_WRITE, miim->regs + MIIM_CMD); + out: + return ret; +} + +static struct mii_dev *ocelot_mdiobus_init(struct ocelot_private *priv, + int mdiobus_id) +{ + struct ocelot_soc_data *pdata = priv->data; + struct mii_dev *bus; + int plat_id; + + bus = mdio_alloc(); + + if (!bus) + return NULL; + + if (mdiobus_id == INTERNAL) { + strcpy(bus->name, "miim-internal"); + for (plat_id = 0; plat_id < NUM_PHY; plat_id++) + /* only internal mdio has a PHY regsier */ + if (pdata->phy_base[plat_id][PHY]) + break; + miim[mdiobus_id].phy_regs = + ioremap(pdata->phy_base[plat_id][PHY], + pdata->phy_size[plat_id][PHY]); + bus->reset = mscc_miim_reset; + } else { + for (plat_id = 0; plat_id < NUM_PHY; plat_id++) + /* external mdio has not a PHY regsier */ + if (!pdata->phy_base[plat_id][PHY]) + break; + strcpy(bus->name, "miim-external"); + } + + miim[mdiobus_id].regs = + ioremap(pdata->phy_base[plat_id][MIIM], + pdata->phy_size[plat_id][MIIM]); + bus->priv = &miim[mdiobus_id]; + bus->read = mscc_miim_read; + bus->write = mscc_miim_write; + + if (mdio_register(bus)) + return NULL; + else + return bus; +} + +__weak void mscc_switch_reset(void) +{ +} + +static void ocelot_stop(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + int i; + + mscc_switch_reset(); + for (i = 0; i < NUM_PHY; i++) + if (priv->bus[i]) + mscc_miim_reset(priv->bus[i]); +} + +static void ocelot_cpu_capture_setup(struct ocelot_private *priv) +{ + int i; + + /* map the 8 CPU extraction queues to CPU port 11 */ + writel(0, priv->regs[QSYS] + QSYS_QMAP); + + for (i = 0; i <= 1; i++) { + /* + * Do byte-swap and expect status after last data word + * Extraction: Mode: manual extraction) | Byte_swap + */ + writel(QS_XTR_GRP_CFG_MODE(1) | QS_XTR_GRP_CFG_BYTE_SWAP, + priv->regs[QS] + QS_XTR_GRP_CFG(i)); + /* + * Injection: Mode: manual extraction | Byte_swap + */ + writel(QS_INJ_GRP_CFG_MODE(1) | QS_INJ_GRP_CFG_BYTE_SWAP, + priv->regs[QS] + QS_INJ_GRP_CFG(i)); + } + + for (i = 0; i <= 1; i++) + /* Enable IFH insertion/parsing on CPU ports */ + writel(SYS_PORT_MODE_INCL_INJ_HDR(1) | + SYS_PORT_MODE_INCL_XTR_HDR(1), + priv->regs[SYS] + SYS_PORT_MODE(CPU_PORT + i)); + /* + * Setup the CPU port as VLAN aware to support switching frames + * based on tags + */ + writel(ANA_PORT_VLAN_CFG_AWARE_ENA | ANA_PORT_VLAN_CFG_POP_CNT(1) | + MAC_VID, priv->regs[ANA] + ANA_PORT_VLAN_CFG(CPU_PORT)); + + /* Disable learning (only RECV_ENA must be set) */ + writel(ANA_PORT_PORT_CFG_RECV_ENA, + priv->regs[ANA] + ANA_PORT_PORT_CFG(CPU_PORT)); + + /* Enable switching to/from cpu port */ + setbits_le32(priv->regs[QSYS] + QSYS_SWITCH_PORT_MODE(CPU_PORT), + QSYS_SWITCH_PORT_MODE_PORT_ENA); + + /* No pause on CPU port - not needed (off by default) */ + clrbits_le32(priv->regs[SYS] + SYS_PAUSE_CFG(CPU_PORT), + SYS_PAUSE_CFG_PAUSE_ENA); + + setbits_le32(priv->regs[QSYS] + QSYS_EGR_NO_SHARING, BIT(CPU_PORT)); +} + +static void ocelot_port_init(struct ocelot_private *priv, int port) +{ + void __iomem *regs = priv->regs[port]; + + /* Enable PCS */ + writel(PCS1G_MODE_CFG_SGMII_MODE_ENA, regs + PCS1G_CFG); + + /* Disable Signal Detect */ + writel(0, regs + PCS1G_SD_CFG); + + /* Enable MAC RX and TX */ + writel(DEV_MAC_ENA_CFG_RX_ENA | DEV_MAC_ENA_CFG_TX_ENA, + regs + DEV_MAC_ENA_CFG); + + /* Clear sgmii_mode_ena */ + writel(0, regs + PCS1G_MODE_CFG); + + /* + * Clear sw_resolve_ena(bit 0) and set adv_ability to + * something meaningful just in case + */ + writel(PCS1G_ANEG_CFG_ADV_ABILITY(0x20), regs + PCS1G_ANEG_CFG); + + /* Set MAC IFG Gaps */ + writel(DEV_MAC_IFG_CFG_TX_IFG(5) | DEV_MAC_IFG_CFG_RX_IFG1(5) | + DEV_MAC_IFG_CFG_RX_IFG2(1), regs + DEV_MAC_IFG_CFG); + + /* Set link speed and release all resets */ + writel(DEV_CLOCK_CFG_LINK_SPEED_1000, regs + DEV_CLOCK_CFG); + + /* Make VLAN aware for CPU traffic */ + writel(ANA_PORT_VLAN_CFG_AWARE_ENA | ANA_PORT_VLAN_CFG_POP_CNT(1) | + MAC_VID, priv->regs[ANA] + ANA_PORT_VLAN_CFG(port - PORT0)); + + /* Enable the port in the core */ + setbits_le32(priv->regs[QSYS] + QSYS_SWITCH_PORT_MODE(port - PORT0), + QSYS_SWITCH_PORT_MODE_PORT_ENA); +} + +static int ocelot_switch_init(struct ocelot_private *priv) +{ + unsigned long deadline; + u32 val = 0; + + /* Reset switch & memories */ + writel(SYS_SYSTEM_RST_MEM_ENA | SYS_SYSTEM_RST_MEM_INIT, + priv->regs[SYS] + SYS_SYSTEM_RST_CFG); + + /* Wait to complete */ + deadline = timer_get_us() + 2000000; + do { + if (time_after(timer_get_us(), deadline)) { + printf("Timeout in memory reset, reg = 0x%08x\n", val); + return -EIO; + } + val = readl(priv->regs[SYS] + SYS_SYSTEM_RST_CFG); + + } while (val & SYS_SYSTEM_RST_MEM_INIT); + + debug("SwC init done - reg = 0x%08x\n", val); + + /* Enable switch core */ + setbits_le32(priv->regs[SYS] + SYS_SYSTEM_RST_CFG, + SYS_SYSTEM_RST_CORE_ENA); + + return 0; +} + +static void ocelot_switch_flush(struct ocelot_private *priv) +{ + /* All Queues flush */ + setbits_le32(priv->regs[QS] + QS_XTR_FLUSH, QS_XTR_FLUSH_FLUSH); + /* Allow to drain */ + mdelay(1); + /* All Queues normal */ + clrbits_le32(priv->regs[QS] + QS_XTR_FLUSH, QS_XTR_FLUSH_FLUSH); +} + +static int ocelot_initialize(struct ocelot_private *priv) +{ + int ret, i; + + /* Initialize switch memories, enable core */ + ret = ocelot_switch_init(priv); + if (ret) + return ret; + /* + * Disable port-to-port by switching + * Put fron ports in "port isolation modes" - i.e. they cant send + * to other ports - via the PGID sorce masks. + */ + for (i = 0; i <= MAX_PORT; i++) + writel(0, priv->regs[ANA] + ANA_PGID(PGID_SRC + i)); + + /* Flush queues */ + ocelot_switch_flush(priv); + + /* Setup frame ageing - "2 sec" - The unit is 6.5us on Ocelot */ + writel(SYS_FRM_AGING_ENA | (20000000 / 65), + priv->regs[SYS] + SYS_FRM_AGING); + + for (i = PORT0; i <= PORT3; i++) + ocelot_port_init(priv, i); + + ocelot_cpu_capture_setup(priv); + + debug("Ports enabled\n"); + + return 0; +} + +static inline int ocelot_vlant_wait_for_completion(struct ocelot_private *priv) +{ + unsigned int val, timeout = 10; + + /* Wait for the issued mac table command to be completed, or timeout. + * When the command read from ANA_TABLES_MACACCESS is + * MACACCESS_CMD_IDLE, the issued command completed successfully. + */ + do { + val = readl(priv->regs[ANA] + ANA_TABLES_MACACCESS); + val &= ANA_TABLES_MACACCESS_MAC_TABLE_CMD_M; + } while (val != MACACCESS_CMD_IDLE && timeout--); + + if (!timeout) + return -ETIMEDOUT; + + return 0; +} + +static int ocelot_mac_table_add(struct ocelot_private *priv, + const unsigned char mac[ETH_ALEN], int pgid) +{ + u32 macl = 0, mach = 0; + int ret; + + /* Set the MAC address to handle and the vlan associated in a format + * understood by the hardware. + */ + mach |= MAC_VID << 16; + mach |= ((u32)mac[0]) << 8; + mach |= ((u32)mac[1]) << 0; + macl |= ((u32)mac[2]) << 24; + macl |= ((u32)mac[3]) << 16; + macl |= ((u32)mac[4]) << 8; + macl |= ((u32)mac[5]) << 0; + + writel(macl, priv->regs[ANA] + ANA_TABLES_MACLDATA); + writel(mach, priv->regs[ANA] + ANA_TABLES_MACHDATA); + + writel(ANA_TABLES_MACACCESS_VALID | + ANA_TABLES_MACACCESS_DEST_IDX(pgid) | + ANA_TABLES_MACACCESS_ENTRYTYPE(ENTRYTYPE_LOCKED) | + ANA_TABLES_MACACCESS_MAC_TABLE_CMD(MACACCESS_CMD_LEARN), + priv->regs[ANA] + ANA_TABLES_MACACCESS); + + ret = ocelot_vlant_wait_for_completion(priv); + + return ret; +} + +static int ocelot_write_hwaddr(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + + ocelot_mac_table_add(priv, pdata->enetaddr, PGID_UNICAST); + + writel(BIT(CPU_PORT), priv->regs[ANA] + ANA_PGID(PGID_UNICAST)); + + return 0; +} + +static int ocelot_start(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + struct eth_pdata *pdata = dev_get_platdata(dev); + const unsigned char mac[ETH_ALEN] = { 0xff, 0xff, 0xff, 0xff, 0xff, + 0xff }; + int ret; + + ret = ocelot_initialize(priv); + if (ret) + return ret; + + /* Set MAC address tables entries for CPU redirection */ + ocelot_mac_table_add(priv, mac, PGID_BROADCAST); + + writel(BIT(CPU_PORT) | INTERNAL_PORT_MSK, + priv->regs[ANA] + ANA_PGID(PGID_BROADCAST)); + + /* It should be setup latter in ocelot_write_hwaddr */ + ocelot_mac_table_add(priv, pdata->enetaddr, PGID_UNICAST); + + writel(BIT(CPU_PORT), priv->regs[ANA] + ANA_PGID(PGID_UNICAST)); + + return 0; +} + +static int ocelot_send(struct udevice *dev, void *packet, int length) +{ + struct ocelot_private *priv = dev_get_priv(dev); + u32 ifh[IFH_LEN]; + int port = BIT(0); /* use port 0 */ + u8 grp = 0; /* Send everything on CPU group 0 */ + int i, count = (length + 3) / 4, last = length % 4; + u32 *buf = packet; + + writel(QS_INJ_CTRL_GAP_SIZE(1) | QS_INJ_CTRL_SOF, + priv->regs[QS] + QS_INJ_CTRL(grp)); + + /* + * Generate the IFH for frame injection + * + * The IFH is a 128bit-value + * bit 127: bypass the analyzer processing + * bit 56-67: destination mask + * bit 28-29: pop_cnt: 3 disables all rewriting of the frame + * bit 20-27: cpu extraction queue mask + * bit 16: tag type 0: C-tag, 1: S-tag + * bit 0-11: VID + */ + ifh[0] = IFH_INJ_BYPASS; + ifh[1] = (0xf00 & port) >> 8; + ifh[2] = (0xff & port) << 24; + ifh[3] = (IFH_TAG_TYPE_C << 16); + + for (i = 0; i < IFH_LEN; i++) + writel(ifh[i], priv->regs[QS] + QS_INJ_WR(grp)); + + for (i = 0; i < count; i++) + writel(buf[i], priv->regs[QS] + QS_INJ_WR(grp)); + + /* Add padding */ + while (i < (OCELOT_BUF_CELL_SZ / 4)) { + writel(0, priv->regs[QS] + QS_INJ_WR(grp)); + i++; + } + + /* Indicate EOF and valid bytes in last word */ + writel(QS_INJ_CTRL_GAP_SIZE(1) | + QS_INJ_CTRL_VLD_BYTES(length < OCELOT_BUF_CELL_SZ ? 0 : last) | + QS_INJ_CTRL_EOF, priv->regs[QS] + QS_INJ_CTRL(grp)); + + /* Add dummy CRC */ + writel(0, priv->regs[QS] + QS_INJ_WR(grp)); + + return 0; +} + +static int ocelot_recv(struct udevice *dev, int flags, uchar **packetp) +{ + struct ocelot_private *priv = dev_get_priv(dev); + u8 grp = 0; /* Send everything on CPU group 0 */ + u32 *rxbuf = (u32 *)net_rx_packets[0]; + int i, byte_cnt = 0; + bool eof_flag = false, pruned_flag = false, abort_flag = false; + + if (!(readl(priv->regs[QS] + QS_XTR_DATA_PRESENT) & BIT(grp))) + return -EAGAIN; + + /* skip IFH */ + for (i = 0; i < IFH_LEN; i++) + readl(priv->regs[QS] + QS_XTR_RD(grp)); + + while (!eof_flag) { + u32 val = readl(priv->regs[QS] + QS_XTR_RD(grp)); + + switch (val) { + case XTR_NOT_READY: + debug("%d NOT_READY...?\n", byte_cnt); + break; + case XTR_ABORT: + /* really nedeed?? not done in linux */ + *rxbuf = readl(priv->regs[QS] + QS_XTR_RD(grp)); + abort_flag = true; + eof_flag = true; + debug("XTR_ABORT\n"); + break; + case XTR_EOF_0: + case XTR_EOF_1: + case XTR_EOF_2: + case XTR_EOF_3: + byte_cnt += XTR_VALID_BYTES(val); + *rxbuf = readl(priv->regs[QS] + QS_XTR_RD(grp)); + eof_flag = true; + debug("EOF\n"); + break; + case XTR_PRUNED: + /* But get the last 4 bytes as well */ + eof_flag = true; + pruned_flag = true; + debug("PRUNED\n"); + /* fallthrough */ + case XTR_ESCAPE: + *rxbuf = readl(priv->regs[QS] + QS_XTR_RD(grp)); + byte_cnt += 4; + rxbuf++; + debug("ESCAPED\n"); + break; + default: + *rxbuf = val; + byte_cnt += 4; + rxbuf++; + } + } + + if (abort_flag || pruned_flag || !eof_flag) { + debug("Discarded frame: abort:%d pruned:%d eof:%d\n", + abort_flag, pruned_flag, eof_flag); + return -EAGAIN; + } + + *packetp = net_rx_packets[0]; + + return byte_cnt; +} + +static int ocelot_ofdata_to_platdata(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + struct ofnode_phandle_args phandle; + struct ocelot_soc_data *plat; + ofnode eth_node, node, mdio_node; + struct resource res; + fdt32_t faddr; + int ret, i; + + struct { + enum ocelot_target id; + char *name; + } reg[] = { + { SYS, "sys" }, + { REW, "rew" }, + { QSYS, "qsys" }, + { ANA, "ana" }, + { QS, "qs" }, + { HSIO, "hsio" }, + { PORT0, "port0" }, + { PORT1, "port1" }, + { PORT2, "port2" }, + { PORT3, "port3" }, + }; + + priv->data = (struct ocelot_soc_data *)dev_get_platdata(dev); + if (!priv->data) + return -EINVAL; + + plat = priv->data; + for (i = 0; i < ARRAY_SIZE(reg); i++) { + ret = dev_read_resource_byname(dev, reg[i].name, &res); + if (ret) { + debug + ("Error %d: can't get regs base addresses for %s\n", + ret, reg[i].name); + return -ENOMEM; + } + + faddr = cpu_to_fdt32(res.start); + plat->base[reg[i].id] = dev_translate_address(dev, &faddr); + if (plat->base[reg[i].id] == OF_BAD_ADDR) + return -ENOMEM; + plat->size[reg[i].id] = res.end - res.start; + } + + /* gathered only the first mdio bus */ + eth_node = dev_read_first_subnode(dev); + node = ofnode_first_subnode(eth_node); + ofnode_parse_phandle_with_args(node, "phy-handle", NULL, 0, 0, + &phandle); + mdio_node = ofnode_get_parent(phandle.node); + + for (i = 0; i < TARGET_MDIO_MAX; i++) { + if (ofnode_read_resource(mdio_node, i, &res)) + return -ENOMEM; + faddr = cpu_to_fdt32(res.start); + plat->phy_base[INTERNAL][i] = + ofnode_translate_address(mdio_node, &faddr); + plat->phy_size[INTERNAL][i] = res.end - res.start; + } + + return 0; +} + +static int ocelot_probe(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + int i; + + if (!priv) + return -EINVAL; + + for (i = 0; i < TARGET_MAX; i++) + priv->regs[i] = ioremap(priv->data->base[i], + priv->data->size[i]); + + priv->bus[INTERNAL] = ocelot_mdiobus_init(priv, INTERNAL); + + for (i = 0; i < 4; i++) { + phy_connect(priv->bus[INTERNAL], i, dev, + PHY_INTERFACE_MODE_NONE); + } + + return 0; +} + +static int ocelot_remove(struct udevice *dev) +{ + struct ocelot_private *priv = dev_get_priv(dev); + int i; + + for (i = 0; i < NUM_PHY; i++) { + mdio_unregister(priv->bus[i]); + mdio_free(priv->bus[i]); + } + + return 0; +} + +static const struct eth_ops ocelot_ops = { + .start = ocelot_start, + .stop = ocelot_stop, + .send = ocelot_send, + .recv = ocelot_recv, + .write_hwaddr = ocelot_write_hwaddr, +}; + +static const struct udevice_id mscc_ocelot_ids[] = { + {.compatible = "mscc,vsc7514-switch"}, + { /* Sentinel */ } +}; + +U_BOOT_DRIVER(ocelot) = { + .name = "ocelot-switch", + .id = UCLASS_ETH, + .of_match = mscc_ocelot_ids, + .probe = ocelot_probe, + .remove = ocelot_remove, + .ofdata_to_platdata = ocelot_ofdata_to_platdata, + .ops = &ocelot_ops, + .priv_auto_alloc_size = sizeof(struct ocelot_private), + .platdata_auto_alloc_size = sizeof(struct ocelot_soc_data), +};
On some ocelots platform a workaround is needed in order to be able to reset the switch without resetting the DDR.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- board/mscc/ocelot/ocelot.c | 28 ++++++++++++++++++++++++++++ 1 file changed, 28 insertions(+)
diff --git a/board/mscc/ocelot/ocelot.c b/board/mscc/ocelot/ocelot.c index 0f7a532158..88f59e8044 100644 --- a/board/mscc/ocelot/ocelot.c +++ b/board/mscc/ocelot/ocelot.c @@ -18,6 +18,34 @@ enum { BOARD_TYPE_PCB123, };
+void mscc_switch_reset(bool enter) +{ + u32 reg, count = 0; + + /* Nasty workaround to avoid GPIO19 (DDR!) being reset */ + mscc_gpio_set_alternate(19, 2); + + printf("applying SwC reset\n"); + + writel(ICPU_RESET_CORE_RST_PROTECT, BASE_CFG + ICPU_RESET); + writel(PERF_SOFT_RST_SOFT_CHIP_RST, BASE_DEVCPU_GCB + PERF_SOFT_RST); + + do { + reg = readl(BASE_DEVCPU_GCB + PERF_SOFT_RST); + count++; + } while (reg & PERF_SOFT_RST_SOFT_CHIP_RST); + + printf("SwC reset done - reg = 0x%08x, count %u\n", reg, count); + + /* + * Reset GPIO19 mode back as regular GPIO, output, high (DDR + * not reset) (Order is important) + */ + setbits_le32(BASE_DEVCPU_GCB + PERF_GPIO_OE, BIT(19)); + writel(BIT(19), BASE_DEVCPU_GCB + PERF_GPIO_OUT_SET); + mscc_gpio_set_alternate(19, 0); +} + void board_debug_uart_init(void) { /* too early for the pinctrl driver, so configure the UART pins here */
- u32 reg, count = 0;
- /* Nasty workaround to avoid GPIO19 (DDR!) being reset */
- mscc_gpio_set_alternate(19, 2);
- printf("applying SwC reset\n");
- writel(ICPU_RESET_CORE_RST_PROTECT, BASE_CFG + ICPU_RESET);
- writel(PERF_SOFT_RST_SOFT_CHIP_RST, BASE_DEVCPU_GCB + PERF_SOFT_RST);
- do {
count++;
- } while (reg & PERF_SOFT_RST_SOFT_CHIP_RST);
Perhaps use wait_for_bit_XX() to add some timeout handling as well?
Thanks, Stefan
Now that network support is added for the ocelot platform, let's add it in the default configuration.
Signed-off-by: Gregory CLEMENT gregory.clement@bootlin.com --- configs/mscc_ocelot_defconfig | 1 + 1 file changed, 1 insertion(+)
diff --git a/configs/mscc_ocelot_defconfig b/configs/mscc_ocelot_defconfig index fb6a5bdc31..792d00e646 100644 --- a/configs/mscc_ocelot_defconfig +++ b/configs/mscc_ocelot_defconfig @@ -60,6 +60,7 @@ CONFIG_SPI_FLASH_SPANSION=y CONFIG_SPI_FLASH_WINBOND=y CONFIG_SPI_FLASH_MTD=y CONFIG_DM_ETH=y +CONFIG_MSCC_OCELOT_SWITCH=y CONFIG_PINCTRL=y CONFIG_PINCONF=y CONFIG_DM_SERIAL=y
Gregory CLEMENT
Stefan Roese
