[U-Boot-Users] [PATCH 1/7] DaVinci: U-Boot board support
Add board support for TI DaVinci boards. Based on initial patch by Sergey Kubushyn ksi@koi8.net.
Signed-off-by: Dirk Behme dirk.behme@gmail.com
Index: uboot/board/davinci/config.mk =================================================================== --- /dev/null +++ uboot/board/davinci/config.mk @@ -0,0 +1,40 @@ +# +# (C) Copyright 2002 +# Gary Jennejohn, DENX Software Engineering, gj@denx.de +# David Mueller, ELSOFT AG, d.mueller@elsoft.ch +# +# (C) Copyright 2003 +# Texas Instruments, <www.ti.com> +# Swaminathan swami.iyer@ti.com +# +# Davinci EVM board (ARM925EJS) cpu +# see http://www.ti.com/ for more information on Texas Instruments +# +# Davinci EVM has 1 bank of 256 MB DDR RAM +# Physical Address: +# 8000'0000 to 9000'0000 +# +# (C) Copyright 2007 +# Sergey Kubushyn, himself, ksi@koi8.net +# +# Visioneering Corp. Sonata board (ARM926EJS) cpu +# +# Sonata board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Razorstream, LLC. SCHMOOGIE board (ARM926EJS) cpu +# +# Schmoogie board has 1 bank of 128 MB DDR RAM +# Physical Address: +# 8000'0000 to 8800'0000 +# +# Linux-Kernel is expected to be at 8000'8000, entry 8000'8000 +# (mem base + reserved) +# +# we load ourself to 8108 '0000 +# +# + +#Provide a atleast 16MB spacing between us and the Linux Kernel image +TEXT_BASE = 0x81080000 Index: uboot/board/davinci/davinci.c =================================================================== --- /dev/null +++ uboot/board/davinci/davinci.c @@ -0,0 +1,298 @@ +/* + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Parts are shamelessly stolen from various TI sources, original copyright + * follows: + * ----------------------------------------------------------------- + * + * Copyright (C) 2004 Texas Instruments. + * + * ---------------------------------------------------------------------------- + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 675 Mass Ave, Cambridge, MA 02139, USA. + * ---------------------------------------------------------------------------- + */ + +#include <common.h> +#include <i2c.h> +#include <asm/arch/hardware.h> +#include <asm/arch/emac_defs.h> + +extern void i2c_init(int speed, int slaveaddr); +extern void timer_init(void); +extern int eth_hw_init(void); +extern phy_t phy; + +#define MACH_TYPE_DAVINCI_EVM 901 +#define MACH_TYPE_SONATA 1254 +#define MACH_TYPE_SCHMOOGIE 1255 + +#define REG32(addr) (*(volatile u32 *)(addr)) +#define REG32P(addr) ((volatile u32 *)(addr)) + +/* Works on Always On power domain only (no PD argument) */ +void lpsc_on(unsigned int id) +{ + reg32p_t mdstat, mdctl; + + if (id >= DAVINCI_LPSC_GEM) + return; /* Don't work on DSP Power Domain */ + + mdstat = REG32P(PSC_MDSTAT_BASE + (id * 4)); + mdctl = REG32P(PSC_MDCTL_BASE + (id * 4)); + + while (REG32(PSC_PTSTAT) & 0x01) {;} + + if ((*mdstat & 0x1f) == 0x03) + return; /* Already on and enabled */ + + *mdctl |= 0x03; + + /* Special treatment for some modules as for sprue14 p.7.4.2 */ + if ( (id == DAVINCI_LPSC_VPSSSLV) || + (id == DAVINCI_LPSC_EMAC) || + (id == DAVINCI_LPSC_EMAC_WRAPPER) || + (id == DAVINCI_LPSC_MDIO) || + (id == DAVINCI_LPSC_USB) || + (id == DAVINCI_LPSC_ATA) || + (id == DAVINCI_LPSC_VLYNQ) || + (id == DAVINCI_LPSC_UHPI) || + (id == DAVINCI_LPSC_DDR_EMIF) || + (id == DAVINCI_LPSC_AEMIF) || + (id == DAVINCI_LPSC_MMC_SD) || + (id == DAVINCI_LPSC_MEMSTICK) || + (id == DAVINCI_LPSC_McBSP) || + (id == DAVINCI_LPSC_GPIO) + ) + *mdctl |= 0x200; + + REG32(PSC_PTCMD) = 0x01; + + while (REG32(PSC_PTSTAT) & 0x03) {;} + while ((*mdstat & 0x1f) != 0x03) {;} /* Probably an overkill... */ +} + +void dsp_on(void) +{ + int i; + + if (REG32(PSC_PDSTAT1) & 0x1f) + return; /* Already on */ + + REG32(PSC_GBLCTL) |= 0x01; + REG32(PSC_PDCTL1) |= 0x01; + REG32(PSC_PDCTL1) &= ~0x100; + REG32(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) |= 0x03; + REG32(PSC_MDCTL_BASE + (DAVINCI_LPSC_GEM * 4)) &= 0xfffffeff; + REG32(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) |= 0x03; + REG32(PSC_MDCTL_BASE + (DAVINCI_LPSC_IMCOP * 4)) &= 0xfffffeff; + REG32(PSC_PTCMD) = 0x02; + + for (i = 0; i < 100; i++) { + if (REG32(PSC_EPCPR) & 0x02) + break; + } + + REG32(PSC_CHP_SHRTSW) = 0x01; + REG32(PSC_PDCTL1) |= 0x100; + REG32(PSC_EPCCR) = 0x02; + + for (i = 0; i < 100; i++) { + if (!(REG32(PSC_PTSTAT) & 0x02)) + break; + } + + REG32(PSC_GBLCTL) &= ~0x1f; +} + + +int board_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + /* arch number of the board */ +#ifdef DV_EVM + gd->bd->bi_arch_number = MACH_TYPE_DAVINCI_EVM; +#elif defined(SONATA_BOARD) + gd->bd->bi_arch_number = MACH_TYPE_SONATA; +#elif defined(SCHMOOGIE) + gd->bd->bi_arch_number = MACH_TYPE_SCHMOOGIE; +#else +#error "No known DaVinci board configured !!!" +#endif + /* adress of boot parameters */ + gd->bd->bi_boot_params = LINUX_BOOT_PARAM_ADDR; + + /* Workaround for TMS320DM6446 errata 1.3.22 */ + REG32(PSC_SILVER_BULLET) = 0; + + /* Power on required peripherals */ + lpsc_on(DAVINCI_LPSC_EMAC); + lpsc_on(DAVINCI_LPSC_EMAC_WRAPPER); + lpsc_on(DAVINCI_LPSC_MDIO); + lpsc_on(DAVINCI_LPSC_I2C); + lpsc_on(DAVINCI_LPSC_UART0); + lpsc_on(DAVINCI_LPSC_TIMER1); + lpsc_on(DAVINCI_LPSC_GPIO); + + /* Powerup the DSP */ + dsp_on(); + + /* Bringup UART0 out of reset */ + REG32(UART0_PWREMU_MGMT) = 0x0000e003; + + /* Enable GIO3.3V cells used for EMAC */ + REG32(VDD3P3V_PWDN) = 0; + + /* Enable UART0 MUX lines */ + REG32(PINMUX1) |= 1; + + /* Enable EMAC and AEMIF pins */ + REG32(PINMUX0) = 0x80000c1f; + + /* Enable I2C pin Mux */ + REG32(PINMUX1) |= (1 << 7); + + /* Set the Bus Priority Register to appropriate value */ + REG32(VBPR) = 0x20; + + timer_init(); + + return(0); +} + +int misc_init_r (void) +{ + char tmp[20]; + u_int8_t buf[10]; + int i = 0; + int clk = 0; + +#ifdef CONFIG_HAS_UID + /* Set serial number from UID chip */ +#ifdef CONFIG_UID_DS28CM00 + char crc_tbl[256] = { + 0x00, 0x5e, 0xbc, 0xe2, 0x61, 0x3f, 0xdd, 0x83, + 0xc2, 0x9c, 0x7e, 0x20, 0xa3, 0xfd, 0x1f, 0x41, + 0x9d, 0xc3, 0x21, 0x7f, 0xfc, 0xa2, 0x40, 0x1e, + 0x5f, 0x01, 0xe3, 0xbd, 0x3e, 0x60, 0x82, 0xdc, + 0x23, 0x7d, 0x9f, 0xc1, 0x42, 0x1c, 0xfe, 0xa0, + 0xe1, 0xbf, 0x5d, 0x03, 0x80, 0xde, 0x3c, 0x62, + 0xbe, 0xe0, 0x02, 0x5c, 0xdf, 0x81, 0x63, 0x3d, + 0x7c, 0x22, 0xc0, 0x9e, 0x1d, 0x43, 0xa1, 0xff, + 0x46, 0x18, 0xfa, 0xa4, 0x27, 0x79, 0x9b, 0xc5, + 0x84, 0xda, 0x38, 0x66, 0xe5, 0xbb, 0x59, 0x07, + 0xdb, 0x85, 0x67, 0x39, 0xba, 0xe4, 0x06, 0x58, + 0x19, 0x47, 0xa5, 0xfb, 0x78, 0x26, 0xc4, 0x9a, + 0x65, 0x3b, 0xd9, 0x87, 0x04, 0x5a, 0xb8, 0xe6, + 0xa7, 0xf9, 0x1b, 0x45, 0xc6, 0x98, 0x7a, 0x24, + 0xf8, 0xa6, 0x44, 0x1a, 0x99, 0xc7, 0x25, 0x7b, + 0x3a, 0x64, 0x86, 0xd8, 0x5b, 0x05, 0xe7, 0xb9, + 0x8c, 0xd2, 0x30, 0x6e, 0xed, 0xb3, 0x51, 0x0f, + 0x4e, 0x10, 0xf2, 0xac, 0x2f, 0x71, 0x93, 0xcd, + 0x11, 0x4f, 0xad, 0xf3, 0x70, 0x2e, 0xcc, 0x92, + 0xd3, 0x8d, 0x6f, 0x31, 0xb2, 0xec, 0x0e, 0x50, + 0xaf, 0xf1, 0x13, 0x4d, 0xce, 0x90, 0x72, 0x2c, + 0x6d, 0x33, 0xd1, 0x8f, 0x0c, 0x52, 0xb0, 0xee, + 0x32, 0x6c, 0x8e, 0xd0, 0x53, 0x0d, 0xef, 0xb1, + 0xf0, 0xae, 0x4c, 0x12, 0x91, 0xcf, 0x2d, 0x73, + 0xca, 0x94, 0x76, 0x28, 0xab, 0xf5, 0x17, 0x49, + 0x08, 0x56, 0xb4, 0xea, 0x69, 0x37, 0xd5, 0x8b, + 0x57, 0x09, 0xeb, 0xb5, 0x36, 0x68, 0x8a, 0xd4, + 0x95, 0xcb, 0x29, 0x77, 0xf4, 0xaa, 0x48, 0x16, + 0xe9, 0xb7, 0x55, 0x0b, 0x88, 0xd6, 0x34, 0x6a, + 0x2b, 0x75, 0x97, 0xc9, 0x4a, 0x14, 0xf6, 0xa8, + 0x74, 0x2a, 0xc8, 0x96, 0x15, 0x4b, 0xa9, 0xf7, + 0xb6, 0xe8, 0x0a, 0x54, 0xd7, 0x89, 0x6b, 0x35 + }; +#endif +#endif + + clk = ((REG32(PLL2_PLLM) + 1) * 27) / ((REG32(PLL2_DIV2) & 0x1f) + 1); + + printf ("ARM Clock : %dMHz\n", ((REG32(PLL1_PLLM) + 1) * 27 ) / 2); + printf ("DDR Clock : %dMHz\n", (clk / 2)); + +#if defined(DV_EVM) || defined(SONATA_BOARD) + /* Set Ethernet MAC address from EEPROM */ + if (i2c_read(CFG_I2C_EEPROM_ADDR, 0x7f00, CFG_I2C_EEPROM_ADDR_LEN, buf, 6)) { + printf("\nEEPROM @ 0x%02x read FAILED!!!\n", CFG_I2C_EEPROM_ADDR); + } else { + tmp[0] = 0xff; + for (i = 0; i < 6; i++) + tmp[0] &= buf[i]; + + if ((tmp[0] != 0xff) && (getenv("ethaddr") == NULL)) { + sprintf(tmp, "%02x:%02x:%02x:%02x:%02x:%02x", + buf[0], buf[1], buf[2], buf[3], buf[4], buf[5]); + setenv("ethaddr", tmp); + } + } +#endif + +#ifdef CONFIG_HAS_UID + /* Set serial number from UID chip */ +#ifdef CONFIG_UID_DS28CM00 + if (i2c_read(CFG_UID_ADDR, 0, 1, buf, 8)) { + printf("\nUID @ 0x%02x read FAILED!!!\n", CFG_UID_ADDR); + forceenv("serial#", "FAILED"); + } else { + if (buf[0] != 0x70) { /* Device Family Code */ + printf("\nUID @ 0x%02x read FAILED!!!\n", CFG_UID_ADDR); + forceenv("serial#", "FAILED"); + } + } + /* Now check CRC */ + tmp[0] = 0; + for (i = 0; i < 8; i++) + tmp[0] = crc_tbl[tmp[0] ^ buf[i]]; + + if (tmp[0] != 0) { + printf("\nUID @ 0x%02x - BAD CRC!!!\n", CFG_UID_ADDR); + forceenv("serial#", "FAILED"); + } else { + /* CRC OK, set "serial" env variable */ + sprintf(tmp, "%02x%02x%02x%02x%02x%02x", + buf[6], buf[5], buf[4], buf[3], buf[2], buf[1]); + forceenv("serial#", tmp); + } +#else +#error "Unknown UID chip !!!" +#endif +#endif + + if (!eth_hw_init()) { + printf("ethernet init failed!\n"); + } else { + printf("ETH PHY : %s\n", phy.name); + } + +#ifdef DV_EVM + i2c_read (0x39, 0x00, 1, (u_int8_t *)&i, 1); + + setenv ("videostd", ((i & 0x80) ? "pal" : "ntsc")); +#endif + + return (0); +} + +int dram_init(void) +{ + DECLARE_GLOBAL_DATA_PTR; + + gd->bd->bi_dram[0].start = PHYS_SDRAM_1; + gd->bd->bi_dram[0].size = PHYS_SDRAM_1_SIZE; + + return 0; +} Index: uboot/board/davinci/lowlevel_init.S =================================================================== --- /dev/null +++ uboot/board/davinci/lowlevel_init.S @@ -0,0 +1,885 @@ +/* + * Low-level board setup code for TI DaVinci SoC based boards. + * + * Copyright (C) 2007 Sergey Kubushyn ksi@koi8.net + * + * Partially based on TI sources, original copyrights follow: + * Board specific setup info + * + * (C) Copyright 2003 + * Texas Instruments, <www.ti.com> + * Kshitij Gupta Kshitij@ti.com + * + * Modified for OMAP 1610 H2 board by Nishant Kamat, Jan 2004 + * + * Modified for OMAP 5912 OSK board by Rishi Bhattacharya, Apr 2004 + * See file CREDITS for list of people who contributed to this + * project. + * + * Modified for DV-EVM board by Rishi Bhattacharya, Apr 2005 + * See file CREDITS for list of people who contributed to this + * project. + * + * Modified for DV-EVM board by Swaminathan S, Nov 2005 + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <config.h> + +.globl lowlevel_init +lowlevel_init: + + /*------------------------------------------------------* + * mask all IRQs by setting all bits in the EINT default* + *------------------------------------------------------*/ + mov r1, $0 + ldr r0, =EINT_ENABLE0 + str r1, [r0] + ldr r0, =EINT_ENABLE1 + str r1, [r0] + + /*------------------------------------------------------* + * Put the GEM in reset * + *------------------------------------------------------*/ + + /* Put the GEM in reset */ + ldr r8, PSC_GEM_FLAG_CLEAR + ldr r6, MDCTL_GEM + ldr r7, [r6] + and r7, r7, r8 + str r7, [r6] + + /* Enable the Power Domain Transition Command */ + ldr r6, PTCMD_0 + ldr r7, [r6] + orr r7, r7, $0x02 + str r7, [r6] + + /* Check for Transition Complete(PTSTAT) */ +checkStatClkStopGem: + ldr r6, PTSTAT_0 + ldr r7, [r6] + ands r7, r7, $0x02 + bne checkStatClkStopGem + + /* Check for GEM Reset Completion */ +checkGemStatClkStop: + ldr r6, MDSTAT_GEM + ldr r7, [r6] + ands r7, r7, $0x100 + bne checkGemStatClkStop + + /* Do this for enabling a WDT initiated reset this is a workaround + for a chip bug. Not required under normal situations */ + ldr r6, P1394 + mov r10, $0 + str r10, [r6] + + /*------------------------------------------------------* + * Enable L1 & L2 Memories in Fast mode * + *------------------------------------------------------*/ + ldr r6, DFT_ENABLE + mov r10, $0x01 + str r10, [r6] + + ldr r6, MMARG_BRF0 + ldr r10, MMARG_BRF0_VAL + str r10, [r6] + + ldr r6, DFT_ENABLE + mov r10, $0 + str r10, [r6] + /*------------------------------------------------------* + * DDR2 PLL Intialization * + *------------------------------------------------------*/ + + /* Select the Clock Mode Depending on the Value written + in the Boot Table by the run script */ + mov r10, $0 + ldr r6, PLL2_CTL + ldr r7, PLL_CLKSRC_MASK + ldr r8, [r6] + and r8, r8, r7 + mov r9, r10, lsl $8 + orr r8, r8, r9 + str r8, [r6] + + /* Select the PLLEN source */ + ldr r7, PLL_ENSRC_MASK + and r8, r8, r7 + str r8, [r6] + + /* Bypass the PLL */ + ldr r7, PLL_BYPASS_MASK + and r8, r8, r7 + str r8, [r6] + + /* Wait for few cycles to allow PLLEN Mux switch properly + to bypass Clock */ + mov r10, $0x20 +WaitPPL2Loop: + subs r10, r10, $1 + bne WaitPPL2Loop + + /* Reset the PLL */ + ldr r7, PLL_RESET_MASK + and r8, r8, r7 + str r8, [r6] + + /* Power up the PLL */ + ldr r7, PLL_PWRUP_MASK + and r8, r8, r7 + str r8, [r6] + + /* Enable the PLL from Disable Mode */ + ldr r7, PLL_DISABLE_ENABLE_MASK + and r8, r8, r7 + str r8, [r6] + + /* Program the PLL Multiplier */ + ldr r6, PLL2_PLLM + mov r2, $0x17 /* 162 MHz */ + str r2, [r6] + + /* Program the PLL2 Divisor Value */ + ldr r6, PLL2_DIV2 + mov r3, $0x01 + str r3, [r6] + + /* Program the PLL2 Divisor Value */ + ldr r6, PLL2_DIV1 + mov r4, $0x0b /* 54 MHz */ + str r4, [r6] + + /* PLL2 DIV2 MMR */ + ldr r8, PLL2_DIV_MASK + ldr r6, PLL2_DIV2 + ldr r9, [r6] + and r8, r8, r9 + mov r9, $0x01 + mov r9, r9, lsl $15 + orr r8, r8, r9 + str r8, [r6] + + /* Program the GOSET bit to take new divider values */ + ldr r6, PLL2_PLLCMD + ldr r7, [r6] + orr r7, r7, $0x01 + str r7, [r6] + + /* Wait for Done */ + ldr r6, PLL2_PLLSTAT +doneLoop_0: + ldr r7, [r6] + ands r7, r7, $0x01 + bne doneLoop_0 + + /* PLL2 DIV1 MMR */ + ldr r8, PLL2_DIV_MASK + ldr r6, PLL2_DIV1 + ldr r9, [r6] + and r8, r8, r9 + mov r9, $0x01 + mov r9, r9, lsl $15 + orr r8, r8, r9 + str r8, [r6] + + /* Program the GOSET bit to take new divider values */ + ldr r6, PLL2_PLLCMD + ldr r7, [r6] + orr r7, r7, $0x01 + str r7, [r6] + + /* Wait for Done */ + ldr r6, PLL2_PLLSTAT +doneLoop: + ldr r7, [r6] + ands r7, r7, $0x01 + bne doneLoop + + /* Wait for PLL to Reset Properly */ + mov r10, $0x218 +ResetPPL2Loop: + subs r10, r10, $1 + bne ResetPPL2Loop + + /* Bring PLL out of Reset */ + ldr r6, PLL2_CTL + ldr r8, [r6] + orr r8, r8, $0x08 + str r8, [r6] + + /* Wait for PLL to Lock */ + ldr r10, PLL_LOCK_COUNT +PLL2Lock: + subs r10, r10, $1 + bne PLL2Lock + + /* Enable the PLL */ + ldr r6, PLL2_CTL + ldr r8, [r6] + orr r8, r8, $0x01 + str r8, [r6] + + /*------------------------------------------------------* + * Issue Soft Reset to DDR Module * + *------------------------------------------------------*/ + + /* Shut down the DDR2 LPSC Module */ + ldr r8, PSC_FLAG_CLEAR + ldr r6, MDCTL_DDR2 + ldr r7, [r6] + and r7, r7, r8 + orr r7, r7, $0x03 + str r7, [r6] + + /* Enable the Power Domain Transition Command */ + ldr r6, PTCMD_0 + ldr r7, [r6] + orr r7, r7, $0x01 + str r7, [r6] + + /* Check for Transition Complete(PTSTAT) */ +checkStatClkStop: + ldr r6, PTSTAT_0 + ldr r7, [r6] + ands r7, r7, $0x01 + bne checkStatClkStop + + /* Check for DDR2 Controller Enable Completion */ +checkDDRStatClkStop: + ldr r6, MDSTAT_DDR2 + ldr r7, [r6] + and r7, r7, $0x1f + cmp r7, $0x03 + bne checkDDRStatClkStop + + /*------------------------------------------------------* + * Program DDR2 MMRs for 162MHz Setting * + *------------------------------------------------------*/ + + /* Program PHY Control Register */ + ldr r6, DDRCTL + ldr r7, DDRCTL_VAL + str r7, [r6] + + /* Program SDRAM Bank Config Register */ + ldr r6, SDCFG + ldr r7, SDCFG_VAL + str r7, [r6] + + /* Program SDRAM TIM-0 Config Register */ + ldr r6, SDTIM0 + ldr r7, SDTIM0_VAL_162MHz + str r7, [r6] + + /* Program SDRAM TIM-1 Config Register */ + ldr r6, SDTIM1 + ldr r7, SDTIM1_VAL_162MHz + str r7, [r6] + + /* Program the SDRAM Bank Config Control Register */ + ldr r10, MASK_VAL + ldr r8, SDCFG + ldr r9, SDCFG_VAL + and r9, r9, r10 + str r9, [r8] + + /* Program SDRAM TIM-1 Config Register */ + ldr r6, SDREF + ldr r7, SDREF_VAL + str r7, [r6] + + /*------------------------------------------------------* + * Issue Soft Reset to DDR Module * + *------------------------------------------------------*/ + + /* Issue a Dummy DDR2 read/write */ + ldr r8, DDR2_VAL + ldr r7, DUMMY_VAL + str r7, [r8] + ldr r7, [r8] + + /* Shut down the DDR2 LPSC Module */ + ldr r8, PSC_FLAG_CLEAR + ldr r6, MDCTL_DDR2 + ldr r7, [r6] + and r7, r7, r8 + orr r7, r7, $0x01 + str r7, [r6] + + /* Enable the Power Domain Transition Command */ + ldr r6, PTCMD_0 + ldr r7, [r6] + orr r7, r7, $0x01 + str r7, [r6] + + /* Check for Transition Complete(PTSTAT) */ +checkStatClkStop2: + ldr r6, PTSTAT_0 + ldr r7, [r6] + ands r7, r7, $0x01 + bne checkStatClkStop2 + + /* Check for DDR2 Controller Enable Completion */ +checkDDRStatClkStop2: + ldr r6, MDSTAT_DDR2 + ldr r7, [r6] + and r7, r7, $0x1f + cmp r7, $0x01 + bne checkDDRStatClkStop2 + + /*------------------------------------------------------* + * Turn DDR2 Controller Clocks On * + *------------------------------------------------------*/ + + /* Enable the DDR2 LPSC Module */ + ldr r6, MDCTL_DDR2 + ldr r7, [r6] + orr r7, r7, $0x03 + str r7, [r6] + + /* Enable the Power Domain Transition Command */ + ldr r6, PTCMD_0 + ldr r7, [r6] + orr r7, r7, $0x01 + str r7, [r6] + + /* Check for Transition Complete(PTSTAT) */ +checkStatClkEn2: + ldr r6, PTSTAT_0 + ldr r7, [r6] + ands r7, r7, $0x01 + bne checkStatClkEn2 + + /* Check for DDR2 Controller Enable Completion */ +checkDDRStatClkEn2: + ldr r6, MDSTAT_DDR2 + ldr r7, [r6] + and r7, r7, $0x1f + cmp r7, $0x03 + bne checkDDRStatClkEn2 + + /* DDR Writes and Reads */ + ldr r6, CFGTEST + mov r3, $0x01 + str r3, [r6] + + /*------------------------------------------------------* + * System PLL Intialization * + *------------------------------------------------------*/ + + /* Select the Clock Mode Depending on the Value written + in the Boot Table by the run script */ + mov r2, $0 + ldr r6, PLL1_CTL + ldr r7, PLL_CLKSRC_MASK + ldr r8, [r6] + and r8, r8, r7 + mov r9, r2, lsl $8 + orr r8, r8, r9 + str r8, [r6] + + /* Select the PLLEN source */ + ldr r7, PLL_ENSRC_MASK + and r8, r8, r7 + str r8, [r6] + + /* Bypass the PLL */ + ldr r7, PLL_BYPASS_MASK + and r8, r8, r7 + str r8, [r6] + + /* Wait for few cycles to allow PLLEN Mux switch properly + to bypass Clock */ + mov r10, $0x20 + +WaitLoop: + subs r10, r10, $1 + bne WaitLoop + + /* Reset the PLL */ + ldr r7, PLL_RESET_MASK + and r8, r8, r7 + str r8, [r6] + + /* Disable the PLL */ + orr r8, r8, $0x10 + str r8, [r6] + + /* Power up the PLL */ + ldr r7, PLL_PWRUP_MASK + and r8, r8, r7 + str r8, [r6] + + /* Enable the PLL from Disable Mode */ + ldr r7, PLL_DISABLE_ENABLE_MASK + and r8, r8, r7 + str r8, [r6] + + /* Program the PLL Multiplier */ + ldr r6, PLL1_PLLM + mov r3, $0x15 /* For 594MHz */ + str r3, [r6] + + /* Wait for PLL to Reset Properly */ + mov r10, $0xff + +ResetLoop: + subs r10, r10, $1 + bne ResetLoop + + /* Bring PLL out of Reset */ + ldr r6, PLL1_CTL + orr r8, r8, $0x08 + str r8, [r6] + + /* Wait for PLL to Lock */ + ldr r10, PLL_LOCK_COUNT + +PLL1Lock: + subs r10, r10, $1 + bne PLL1Lock + + /* Enable the PLL */ + orr r8, r8, $0x01 + str r8, [r6] + + nop + nop + nop + nop + + /*------------------------------------------------------* + * AEMIF configuration for NOR Flash (double check) * + *------------------------------------------------------*/ + ldr r0, _PINMUX0 + ldr r1, _DEV_SETTING + str r1, [r0] + + ldr r0, WAITCFG + ldr r1, WAITCFG_VAL + ldr r2, [r0] + orr r2, r2, r1 + str r2, [r0] + + ldr r0, ACFG3 + ldr r1, ACFG3_VAL + ldr r2, [r0] + and r1, r2, r1 + str r1, [r0] + + ldr r0, ACFG4 + ldr r1, ACFG4_VAL + ldr r2, [r0] + and r1, r2, r1 + str r1, [r0] + + ldr r0, ACFG5 + ldr r1, ACFG5_VAL + ldr r2, [r0] + and r1, r2, r1 + str r1, [r0] + + /*--------------------------------------* + * VTP manual Calibration * + *--------------------------------------*/ + ldr r0, VTPIOCR + ldr r1, VTP_MMR0 + str r1, [r0] + + ldr r0, VTPIOCR + ldr r1, VTP_MMR1 + str r1, [r0] + + /* Wait for 33 VTP CLK cycles. VRP operates at 27 MHz */ + ldr r10, VTP_LOCK_COUNT +VTPLock: + subs r10, r10, $1 + bne VTPLock + + ldr r6, DFT_ENABLE + mov r10, $0x01 + str r10, [r6] + + ldr r6, DDRVTPR + ldr r7, [r6] + and r7, r7, $0x1f + and r8, r7, $0x3e0 + orr r8, r7, r8 + ldr r7, VTP_RECAL + orr r8, r7, r8 + ldr r7, VTP_EN + orr r8, r7, r8 + str r8, [r0] + + + /* Wait for 33 VTP CLK cycles. VRP operates at 27 MHz */ + ldr r10, VTP_LOCK_COUNT +VTP1Lock: + subs r10, r10, $1 + bne VTP1Lock + + ldr r1, [r0] + ldr r2, VTP_MASK + and r2, r1, r2 + str r2, [r0] + + ldr r6, DFT_ENABLE + mov r10, $0 + str r10, [r6] + +#ifdef SONATA_BOARD + /* Set PINMUX0 to enable GPIO4 */ + ldr r0, _PINMUX0 + ldr r1, GPIO4_EN_MASK + ldr r2, [r0] + and r2, r2, r1 + str r2, [r0] + + /* Enable GPIO LPSC module */ + ldr r0, PTSTAT + +gpio_ptstat_loop1: + ldr r2, [r0] + tst r2, $0x00000001 + bne gpio_ptstat_loop1 + + ldr r1, MDCTL_GPIO + ldr r2, [r1] + and r2, r2, $0xfffffff8 + orr r2, r2, $0x00000003 + str r2, [r1] + + orr r2, r2, $0x00000200 + str r2, [r1] + + ldr r1, PTCMD + mov r2, $0x00000001 + str r2, [r1] + +gpio_ptstat_loop2: + ldr r2, [r0] + tst r2, $0x00000001 + bne gpio_ptstat_loop2 + + ldr r0, MDSTAT_GPIO +gpio_mdstat_loop: + ldr r2, [r0] + and r2, r2, $0x0000001f + teq r2, $0x00000003 + bne gpio_mdstat_loop + + /* GPIO4 -> output */ + ldr r0, GPIO_DIR01 + mov r1, $0x10 + ldr r2, [r0] + bic r2, r2, r0 + str r2, [r0] + + /* Set it to 0 (Write Protect) */ + ldr r0, GPIO_CLR_DATA01 + str r1, [r0] +#endif + + /* back to arch calling code */ + mov pc, lr + +.ltorg + +REG_TC_EMIFS_CONFIG: /* 32 bits */ + .word 0xfffecc0c +REG_TC_EMIFS_CS0_CONFIG: /* 32 bits */ + .word 0xfffecc10 +REG_TC_EMIFS_CS1_CONFIG: /* 32 bits */ + .word 0xfffecc14 +REG_TC_EMIFS_CS2_CONFIG: /* 32 bits */ + .word 0xfffecc18 +REG_TC_EMIFS_CS3_CONFIG: /* 32 bits */ + .word 0xfffecc1c + +_PINMUX0: + .word 0x01c40000 /* Device Configuration Registers */ +_PINMUX1: + .word 0x01c40004 /* Device Configuration Registers */ + +_DEV_SETTING: + .word 0x00000c1f + +#ifdef SONATA_BOARD +GPIO4_EN_MASK: + .word 0xf77fffff +#endif + +AEMIF_BASE_ADDR: + .word 0x01e00000 +WAITCFG: + .word 0x01e00004 +ACFG2: + .word 0x01e00010 +ACFG3: + .word 0x01e00014 +ACFG4: + .word 0x01e00018 +ACFG5: + .word 0x01e0001c + +WAITCFG_VAL: + .word 0 +ACFG2_VAL: + .word 0x3ffffffd +ACFG3_VAL: + .word 0x3ffffffd +ACFG4_VAL: + .word 0x3ffffffd +ACFG5_VAL: + .word 0x3ffffffd + +MDCTL_GPIO: + .word 0x01c41a68 +MDSTAT_GPIO: + .word 0x01c41868 + +MDCTL_DDR2: + .word 0x01c41a34 +PTCMD: + .word 0x01c41120 +PTSTAT: + .word 0x01c41128 +MDSTAT_DDR2: + .word 0x01c41834 + +MDCTL_TPCC: + .word 0x01c41a08 +MDSTAT_TPCC: + .word 0x01c41808 + +MDCTL_TPTC0: + .word 0x01c41a0c +MDSTAT_TPTC0: + .word 0x01c4180c + +MDCTL_TPTC1: + .word 0x01c41a10 +MDSTAT_TPTC1: + .word 0x01c41810 + +DDR2DEBUG: + .word 0x8ffff000 + +/* EINT0 register */ +EINT_ENABLE0: + .word 0x01c48018 + +/* EINT1 register */ +EINT_ENABLE1: + .word 0x01c4801c + +CLEAR_FLAG: + .word 0xffffffff +EDMA_PARAM0_D_S_BIDX_VAL: + .word 0x00010001 +PSC_FLAG_CLEAR: + .word 0xffffffe0 +PSC_GEM_FLAG_CLEAR: + .word 0xfffffeff +MDCTL_TPCC_SYNC: + .word 0x01c41a08 +MDSTAT_TPCC_SYNC: + .word 0x01c41808 + +MDCTL_TPTC0_SYNC: + .word 0x01c41a0c +MDSTAT_TPTC0_SYNC: + .word 0x01c4180c + +MDCTL_TPTC1_SYNC: + .word 0x01c41a10 +MDSTAT_TPTC1_SYNC: + .word 0x01c41810 + +PTCMD_SYNC: + .word 0x01c41120 +PTSTAT_SYNC: + .word 0x01c41128 +DATA_MAX: + .word 0x0000ffff +SPIN_ADDR: + .word 0x00003ffc /* ARM PC value(B $) for the DSP Test cases */ +SPIN_OPCODE: + .word 0xeafffffe + +/* Interrupt Clear Register */ +FIQ0_CLEAR: + .word 0x01c48000 +FIQ1_CLEAR: + .word 0x01c48004 +IRQ0_CLEAR: + .word 0x01c48008 +IRQ1_CLEAR: + .word 0x01c4800c + +/* DDR2 MMR & CONFIGURATION VALUES for 75 MHZ */ +DDRCTL: + .word 0x200000e4 +SDREF: + .word 0x2000000c +SDCFG: + .word 0x20000008 +SDTIM0: + .word 0x20000010 +SDTIM1: + .word 0x20000014 +SDSTAT: + .word 0x20000004 +VTPIOCR: + .word 0x200000f0 /* VTP IO Control register */ +DDRVTPR: + .word 0x01c42030 /* DDR VPTR MMR */ +DFT_ENABLE: + .word 0x01c4004c +VTP_MMR0: + .word 0x201f +VTP_MMR1: + .word 0xa01f +PCH_MASK: + .word 0x3e0 +VTP_LOCK_COUNT: + .word 0x5b0 +VTP_MASK: + .word 0xffffdfff +VTP_RECAL: + .word 0x40000 +VTP_EN: + .word 0x02000 + + +CFGTEST: + .word 0x80010000 + +DDRCTL_VAL: + .word 0x50006405 +SDCFG_VAL: +#ifdef DDR_4BANKS + .word 0x00178622 +#elif defined DDR_8BANKS + .word 0x00178632 +#else +#error "Unknown DDR configuration!!!" +#endif +MASK_VAL: + .word 0x00000fff +SDTIM0_VAL_162MHz: + .word 0x28923211 +SDTIM1_VAL_162MHz: + .word 0x0016c722 +SDREF_VAL: + .word 0x000005c3 + +/* GEM Power Up & LPSC Control Register */ +CHP_SHRTSW: + .word 0x01c40038 + +PD1_CTL: + .word 0x01c41304 +EPCPR: + .word 0x01c41070 +EPCCR: + .word 0x01c41078 +MDCTL_GEM: + .word 0x01c41a9c +MDSTAT_GEM: + .word 0x01c4189c +MDCTL_IMCOP: + .word 0x01c41aa0 +MDSTAT_IMCOP: + .word 0x01c418a0 + +PTCMD_0: + .word 0x01c41120 +PTSTAT_0: + .word 0x01c41128 +P1394: + .word 0x01c41a20 + +PLL_CLKSRC_MASK: + .word 0xfffffeff /* Mask the Clock Mode bit and it is + programmble through the run script */ +PLL_ENSRC_MASK: + .word 0xffffffdf /* Select the PLLEN source */ +PLL_BYPASS_MASK: + .word 0xfffffffe /* Put the PLL in BYPASS, eventhough the + device */ +PLL_RESET_MASK: + .word 0xfffffff7 /* Put the PLL in Reset Mode */ +PLL_PWRUP_MASK: + .word 0xfffffffd /* PLL Power up Mask Bit */ +PLL_DISABLE_ENABLE_MASK: + .word 0xffffffef /* Enable the PLL from Disable */ +PLL_LOCK_COUNT: + .word 0x2000 + +/* PLL1-SYSTEM PLL MMRs */ +PLL1_CTL: + .word 0x01c40900 +PLL1_PLLM: + .word 0x01c40910 + +/* PLL2-SYSTEM PLL MMRs */ +PLL2_CTL: + .word 0x01c40d00 +PLL2_PLLM: + .word 0x01c40d10 +PLL2_DIV1: + .word 0x01c40d18 +PLL2_DIV2: + .word 0x01c40d1c +PLL2_PLLCMD: + .word 0x01c40d38 +PLL2_PLLSTAT: + .word 0x01c40d3c +PLL2_BPDIV: + .word 0x01c40d2c +PLL2_DIV_MASK: + .word 0xffff7fff + +DLLPWRUPMASK: + .word 0xffffffef +DDR2_ADDR: + .word 0x80000000 + +DFT_BASEADDR: + .word 0x01c42000 +MMARG_BRF0: + .word 0x01c42010 /* BRF margin mode 0 (Read / write) */ +MMARG_G10: + .word 0x01c42018 /* GL margin mode 0 (Read / write) */ +MMARG_BRF0_VAL: + .word 0x00444400 +DDR2_VAL: + .word 0x80000000 +DUMMY_VAL: + .word 0xa55aa55a + +GPIO_DIR01: + .word 0x01c67010 +GPIO_SET_DATA01: + .word 0x01c67018 +GPIO_CLR_DATA01: + .word 0x01c6701c Index: uboot/board/davinci/Makefile =================================================================== --- /dev/null +++ uboot/board/davinci/Makefile @@ -0,0 +1,53 @@ +# +# (C) Copyright 2000, 2001, 2002 +# Wolfgang Denk, DENX Software Engineering, wd@denx.de. +# +# (C) Copyright 2007 +# Sergey Kubushyn, himself, ksi@koi8.net +# +# See file CREDITS for list of people who contributed to this +# project. +# +# This program is free software; you can redistribute it and/or +# modify it under the terms of the GNU General Public License as +# published by the Free Software Foundation; either version 2 of +# the License, or (at your option) any later version. +# +# This program is distributed in the hope that it will be useful, +# but WITHOUT ANY WARRANTY; without even the implied warranty of +# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +# GNU General Public License for more details. +# +# You should have received a copy of the GNU General Public License +# along with this program; if not, write to the Free Software +# Foundation, Inc., 59 Temple Place, Suite 330, Boston, +# MA 02111-1307 USA +# + +include $(TOPDIR)/config.mk + +LIB = $(obj)lib$(BOARD).a + +COBJS := davinci.o nand.o +SOBJS := lowlevel_init.o + +SRCS := $(SOBJS:.o=.S) $(COBJS:.o=.c) +OBJS := $(addprefix $(obj),$(COBJS)) +SOBJS := $(addprefix $(obj),$(SOBJS)) + +$(LIB): $(obj).depend $(OBJS) $(SOBJS) + $(AR) $(ARFLAGS) $@ $(OBJS) $(SOBJS) + +clean: + rm -f $(SOBJS) $(OBJS) + +distclean: clean + rm -f $(LIB) core *.bak *~ .depend + +######################################################################### +# This is for $(obj).depend target +include $(SRCTREE)/rules.mk + +sinclude $(obj).depend + +######################################################################### Index: uboot/board/davinci/u-boot.lds =================================================================== --- /dev/null +++ uboot/board/davinci/u-boot.lds @@ -0,0 +1,52 @@ +/* + * (C) Copyright 2002 + * Gary Jennejohn, DENX Software Engineering, gj@denx.de + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +OUTPUT_FORMAT("elf32-littlearm", "elf32-littlearm", "elf32-littlearm") +OUTPUT_ARCH(arm) +ENTRY(_start) +SECTIONS +{ + . = 0x00000000; + . = ALIGN(4); + .text : + { + cpu/arm926ejs/start.o (.text) + *(.text) + } + . = ALIGN(4); + .rodata : { *(.rodata) } + . = ALIGN(4); + .data : { *(.data) } + . = ALIGN(4); + .got : { *(.got) } + + . = .; + __u_boot_cmd_start = .; + .u_boot_cmd : { *(.u_boot_cmd) } + __u_boot_cmd_end = .; + + . = ALIGN(4); + __bss_start = .; + .bss : { *(.bss) } + _end = .; +}
Dirk Behme
