[PATCH 1/4] arm: davinci: Migrate da850-evm to OF_UPSTREAM
The da850-evm can remove the U-Boot device trees if migrated to OF_UPSTREAM. This means pointing the device trees to the ti/davinci directory.
Signed-off-by: Adam Ford aford173@gmail.com
diff --git a/arch/arm/dts/da850-evm.dts b/arch/arm/dts/da850-evm.dts deleted file mode 100644 index 378af9f344..0000000000 --- a/arch/arm/dts/da850-evm.dts +++ /dev/null @@ -1,453 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Device Tree for DA850 EVM board - * - * Copyright (C) 2012 Texas Instruments Incorporated - https://www.ti.com/ - */ -/dts-v1/; -#include "da850.dtsi" -#include <dt-bindings/gpio/gpio.h> - -/ { - compatible = "ti,da850-evm", "ti,da850"; - model = "DA850/AM1808/OMAP-L138 EVM"; - - chosen { - stdout-path = &serial2; - }; - - aliases { - serial0 = &serial0; - serial1 = &serial1; - serial2 = &serial2; - ethernet0 = ð0; - spi0 = &spi1; - }; - - backlight: backlight-pwm { - pinctrl-names = "default"; - pinctrl-0 = <&ecap2_pins>; - power-supply = <&backlight_lcd>; - compatible = "pwm-backlight"; - /* - * The PWM here corresponds to production hardware. The - * schematic needs to be 1015171 (15 March 2010), Rev A - * or newer. - */ - pwms = <&ecap2 0 50000 0>; - brightness-levels = <0 10 20 30 40 50 60 70 80 90 99>; - default-brightness-level = <7>; - }; - - panel { - compatible = "ti,tilcdc,panel"; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_pins>; - /* - * The vpif and the LCD are mutually exclusive. - * To enable VPIF, change the status below to 'disabled' then - * then change the status of the vpif below to 'okay' - */ - status = "okay"; - enable-gpios = <&gpio 40 GPIO_ACTIVE_HIGH>; /* lcd_panel_pwr */ - - panel-info { - ac-bias = <255>; - ac-bias-intrpt = <0>; - dma-burst-sz = <16>; - bpp = <16>; - fdd = <0x80>; - sync-edge = <0>; - sync-ctrl = <1>; - raster-order = <0>; - fifo-th = <0>; - }; - - display-timings { - native-mode = <&timing0>; - timing0: 480x272 { - clock-frequency = <9000000>; - hactive = <480>; - vactive = <272>; - hfront-porch = <3>; - hback-porch = <2>; - hsync-len = <42>; - vback-porch = <3>; - vfront-porch = <4>; - vsync-len = <11>; - hsync-active = <0>; - vsync-active = <0>; - de-active = <1>; - pixelclk-active = <1>; - }; - }; - }; - - vbat: fixedregulator0 { - compatible = "regulator-fixed"; - regulator-name = "vbat"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-boot-on; - }; - - baseboard_3v3: fixedregulator-3v3 { - /* TPS73701DCQ */ - compatible = "regulator-fixed"; - regulator-name = "baseboard_3v3"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vbat>; - regulator-always-on; - regulator-boot-on; - }; - - baseboard_1v8: fixedregulator-1v8 { - /* TPS73701DCQ */ - compatible = "regulator-fixed"; - regulator-name = "baseboard_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vbat>; - regulator-always-on; - regulator-boot-on; - }; - - backlight_lcd: backlight-regulator { - compatible = "regulator-fixed"; - regulator-name = "lcd_backlight_pwr"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio 47 GPIO_ACTIVE_HIGH>; /* lcd_backlight_pwr */ - enable-active-high; - }; - - sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "DA850-OMAPL138 EVM"; - simple-audio-card,widgets = - "Line", "Line In", - "Line", "Line Out"; - simple-audio-card,routing = - "LINE1L", "Line In", - "LINE1R", "Line In", - "Line Out", "LLOUT", - "Line Out", "RLOUT"; - simple-audio-card,format = "dsp_b"; - simple-audio-card,bitclock-master = <&link0_codec>; - simple-audio-card,frame-master = <&link0_codec>; - simple-audio-card,bitclock-inversion; - - simple-audio-card,cpu { - sound-dai = <&mcasp0>; - system-clock-frequency = <24576000>; - }; - - link0_codec: simple-audio-card,codec { - sound-dai = <&tlv320aic3106>; - system-clock-frequency = <24576000>; - }; - }; -}; - -&ecap2 { - status = "okay"; -}; - -&ref_clk { - clock-frequency = <24000000>; -}; - -&pmx_core { - status = "okay"; - - mcasp0_pins: pinmux_mcasp0_pins { - pinctrl-single,bits = < - /* - * AHCLKX, ACLKX, AFSX, AHCLKR, ACLKR, - * AFSR, AMUTE - */ - 0x00 0x11111111 0xffffffff - /* AXR11, AXR12 */ - 0x04 0x00011000 0x000ff000 - >; - }; - nand_pins: nand_pins { - pinctrl-single,bits = < - /* EMA_WAIT[0], EMA_OE, EMA_WE, EMA_CS[4], EMA_CS[3] */ - 0x1c 0x10110110 0xf0ff0ff0 - /* - * EMA_D[0], EMA_D[1], EMA_D[2], - * EMA_D[3], EMA_D[4], EMA_D[5], - * EMA_D[6], EMA_D[7] - */ - 0x24 0x11111111 0xffffffff - /* EMA_A[1], EMA_A[2] */ - 0x30 0x01100000 0x0ff00000 - >; - }; -}; - -&sata { - status = "okay"; -}; - -&serial0 { - status = "okay"; -}; - -&serial1 { - status = "okay"; -}; - -&serial2 { - status = "okay"; -}; - -&rtc0 { - status = "okay"; -}; - -&lcdc { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - clock-frequency = <100000>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_pins>; - - tps: tps@48 { - reg = <0x48>; - }; - tlv320aic3106: tlv320aic3106@18 { - #sound-dai-cells = <0>; - compatible = "ti,tlv320aic3106"; - reg = <0x18>; - status = "okay"; - - /* Regulators */ - IOVDD-supply = <&vdcdc2_reg>; - AVDD-supply = <&baseboard_3v3>; - DRVDD-supply = <&baseboard_3v3>; - DVDD-supply = <&baseboard_1v8>; - }; - tca6416: gpio@20 { - compatible = "ti,tca6416"; - reg = <0x20>; - gpio-controller; - #gpio-cells = <2>; - }; - tca6416_bb: gpio@21 { - compatible = "ti,tca6416"; - reg = <0x21>; - gpio-controller; - #gpio-cells = <2>; - }; -}; - -&wdt { - status = "okay"; -}; - -&mmc0 { - max-frequency = <50000000>; - bus-width = <4>; - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mmc0_pins>; - cd-gpios = <&gpio 64 GPIO_ACTIVE_LOW>; - wp-gpios = <&gpio 65 GPIO_ACTIVE_HIGH>; -}; - -&spi1 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&spi1_pins &spi1_cs0_pin>; - flash: flash@0 { - #address-cells = <1>; - #size-cells = <1>; - compatible = "m25p64"; - spi-max-frequency = <30000000>; - m25p,fast-read; - reg = <0>; - partition@0 { - label = "U-Boot-SPL"; - reg = <0x00000000 0x00010000>; - read-only; - }; - partition@1 { - label = "U-Boot"; - reg = <0x00010000 0x00080000>; - read-only; - }; - partition@2 { - label = "U-Boot-Env"; - reg = <0x00090000 0x00010000>; - read-only; - }; - partition@3 { - label = "Kernel"; - reg = <0x000a0000 0x00280000>; - }; - partition@4 { - label = "Filesystem"; - reg = <0x00320000 0x00400000>; - }; - partition@5 { - label = "MAC-Address"; - reg = <0x007f0000 0x00010000>; - read-only; - }; - }; -}; - -&mdio { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mdio_pins>; - bus_freq = <2200000>; -}; - -ð0 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mii_pins>; -}; - -&gpio { - status = "okay"; -}; - -/include/ "tps6507x.dtsi" - -&tps { - vdcdc1_2-supply = <&vbat>; - vdcdc3-supply = <&vbat>; - vldo1_2-supply = <&vbat>; - - regulators { - vdcdc1_reg: regulator@0 { - regulator-name = "VDCDC1_3.3V"; - regulator-min-microvolt = <3150000>; - regulator-max-microvolt = <3450000>; - regulator-always-on; - regulator-boot-on; - }; - - vdcdc2_reg: regulator@1 { - regulator-name = "VDCDC2_3.3V"; - regulator-min-microvolt = <1710000>; - regulator-max-microvolt = <3450000>; - regulator-always-on; - regulator-boot-on; - ti,defdcdc_default = <1>; - }; - - vdcdc3_reg: regulator@2 { - regulator-name = "VDCDC3_1.2V"; - regulator-min-microvolt = <950000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - ti,defdcdc_default = <1>; - }; - - ldo1_reg: regulator@3 { - regulator-name = "LDO1_1.8V"; - regulator-min-microvolt = <1710000>; - regulator-max-microvolt = <1890000>; - regulator-always-on; - regulator-boot-on; - }; - - ldo2_reg: regulator@4 { - regulator-name = "LDO2_1.2V"; - regulator-min-microvolt = <1140000>; - regulator-max-microvolt = <1320000>; - regulator-always-on; - regulator-boot-on; - }; - }; -}; - -&mcasp0 { - #sound-dai-cells = <0>; - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcasp0_pins>; - - op-mode = <0>; /* MCASP_IIS_MODE */ - tdm-slots = <2>; - /* 4 serializer */ - serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */ - 0 0 0 0 - 0 0 0 0 - 0 0 0 1 - 2 0 0 0 - >; - tx-num-evt = <32>; - rx-num-evt = <32>; -}; - -&edma0 { - ti,edma-reserved-slot-ranges = <32 50>; -}; - -&edma1 { - ti,edma-reserved-slot-ranges = <32 90>; -}; - -&aemif { - pinctrl-names = "default"; - pinctrl-0 = <&nand_pins>; - status = "okay"; - cs3 { - #address-cells = <2>; - #size-cells = <1>; - clock-ranges; - ranges; - - ti,cs-chipselect = <3>; - - nand@2000000,0 { - compatible = "ti,davinci-nand"; - #address-cells = <1>; - #size-cells = <1>; - reg = <0 0x02000000 0x02000000 - 1 0x00000000 0x00008000>; - - ti,davinci-chipselect = <1>; - ti,davinci-mask-ale = <0>; - ti,davinci-mask-cle = <0>; - ti,davinci-mask-chipsel = <0>; - ti,davinci-ecc-mode = "hw"; - ti,davinci-ecc-bits = <4>; - ti,davinci-nand-use-bbt; - }; - }; -}; - -&usb_phy { - status = "okay"; -}; - -&usb0 { - status = "okay"; -}; - -&usb1 { - status = "okay"; -}; - -&vpif { - pinctrl-names = "default"; - pinctrl-0 = <&vpif_capture_pins>, <&vpif_display_pins>; - /* - * The vpif and the LCD are mutually exclusive. - * To enable VPIF, disable the ti,tilcdc,panel then - * change the status below to 'okay' - */ - status = "disabled"; -}; diff --git a/arch/arm/mach-davinci/Kconfig b/arch/arm/mach-davinci/Kconfig index 25c5db4991..8fa2660a0c 100644 --- a/arch/arm/mach-davinci/Kconfig +++ b/arch/arm/mach-davinci/Kconfig @@ -9,6 +9,7 @@ config TARGET_DA850EVM select MACH_DAVINCI_DA850_EVM select SOC_DA850 select SUPPORT_SPL + imply OF_UPSTREAM
config TARGET_OMAPL138_LCDK bool "OMAPL138 LCDK" diff --git a/configs/da850evm_defconfig b/configs/da850evm_defconfig index 8130575926..05f29337dc 100644 --- a/configs/da850evm_defconfig +++ b/configs/da850evm_defconfig @@ -18,7 +18,7 @@ CONFIG_ENV_SIZE=0x10000 CONFIG_ENV_OFFSET=0x80000 CONFIG_ENV_SECT_SIZE=0x10000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="da850-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/davinci/da850-evm" CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0x8001ff00 diff --git a/configs/da850evm_direct_nor_defconfig b/configs/da850evm_direct_nor_defconfig index 4d6efbebf3..936de61071 100644 --- a/configs/da850evm_direct_nor_defconfig +++ b/configs/da850evm_direct_nor_defconfig @@ -14,7 +14,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x8001ff00 CONFIG_ENV_SIZE=0x2800 CONFIG_ENV_SECT_SIZE=0x20000 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="da850-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/davinci/da850-evm" CONFIG_SYS_LOAD_ADDR=0xc0700000 CONFIG_ENV_ADDR=0x60100000 CONFIG_LTO=y diff --git a/configs/da850evm_nand_defconfig b/configs/da850evm_nand_defconfig index 330f88183c..2a4ea808f4 100644 --- a/configs/da850evm_nand_defconfig +++ b/configs/da850evm_nand_defconfig @@ -15,7 +15,7 @@ CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0xc0000f20 CONFIG_ENV_SIZE=0x20000 CONFIG_ENV_OFFSET=0x0 CONFIG_DM_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="da850-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/davinci/da850-evm" CONFIG_SPL_TEXT_BASE=0x80000000 CONFIG_SPL_SERIAL=y CONFIG_SPL_STACK=0x8001ff00
With the feature of OF_UPSTREAM now available, the device trees for the SOM and baseboard can now deleted and the device tree locations need to point to the ti/omap directory.
diff --git a/arch/arm/dts/am3517-evm.dts b/arch/arm/dts/am3517-evm.dts deleted file mode 100644 index d21bb2ccd0..0000000000 --- a/arch/arm/dts/am3517-evm.dts +++ /dev/null @@ -1,339 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Copyright (C) 2011 Texas Instruments Incorporated - https://www.ti.com/ - */ -/dts-v1/; - -#include "am3517.dtsi" -#include "am3517-som.dtsi" -#include "am3517-evm-ui.dtsi" -#include <dt-bindings/input/input.h> - -/ { - model = "TI AM3517 EVM (AM3517/05 TMDSEVM3517)"; - compatible = "ti,am3517-evm", "ti,am3517", "ti,omap3"; - - aliases { - display0 = &lcd0; - }; - - chosen { - stdout-path = &uart3; - }; - - memory@80000000 { - device_type = "memory"; - reg = <0x80000000 0x10000000>; /* 256 MB */ - }; - - vmmc_fixed: vmmc { - compatible = "regulator-fixed"; - regulator-name = "vmmc_fixed"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - gpio-keys { - compatible = "gpio-keys-polled"; - poll-interval = <100>; - - button-user { - label = "User Push Button"; - linux,code = <BTN_0>; - gpios = <&tca6416 5 GPIO_ACTIVE_LOW>; - }; - - switch-1 { - label = "User Switch 1"; - linux,code = <BTN_1>; - gpios = <&tca6416 8 GPIO_ACTIVE_LOW>; - }; - - switch-2 { - label = "User Switch 2"; - linux,code = <BTN_2>; - gpios = <&tca6416 9 GPIO_ACTIVE_LOW>; - }; - - switch-3 { - label = "User Switch 3"; - linux,code = <BTN_3>; - gpios = <&tca6416 10 GPIO_ACTIVE_LOW>; - }; - - switch-4 { - label = "User Switch 4"; - linux,code = <BTN_4>; - gpios = <&tca6416 11 GPIO_ACTIVE_LOW>; - }; - - switch-5 { - label = "User Switch 5"; - linux,code = <BTN_5>; - gpios = <&tca6416 12 GPIO_ACTIVE_LOW>; - }; - - switch-6 { - label = "User Switch 6"; - linux,code = <BTN_6>; - gpios = <&tca6416 13 GPIO_ACTIVE_LOW>; - }; - - switch-7 { - label = "User Switch 7"; - linux,code = <BTN_7>; - gpios = <&tca6416 14 GPIO_ACTIVE_LOW>; - }; - - switch-8 { - label = "User Switch 8"; - linux,code = <BTN_8>; - gpios = <&tca6416 15 GPIO_ACTIVE_LOW>; - }; - }; - - gpio-leds { - compatible = "gpio-leds"; - - pinctrl-names = "default"; - pinctrl-0 = <&leds_pins>; - - user_led_1 { - label = "am3517evm:green:user_led_1"; - gpios = <&tca6416 7 GPIO_ACTIVE_LOW>; - default-state = "on"; - }; - - user_led_2 { - label = "am3517evm:green:user_led_2"; - gpios = <&tca6416 6 GPIO_ACTIVE_LOW>; - default-state = "on"; - }; - - user_led_3 { - label = "am3517evm:green:user_led_3"; - gpios = <&gpio1 11 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc0"; /* SD/MMC card activity */ - }; - - user_led_4 { - label = "am3517evm:green:user_led_4"; - gpios = <&gpio1 31 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - }; - }; - - lcd0: display@0 { - /* This isn't the exact LCD, but the timings meet spec */ - /* To make it work, set CONFIG_OMAP2_DSS_MIN_FCK_PER_PCK=4 */ - compatible = "newhaven,nhd-4.3-480272ef-atxl"; - label = "15"; - backlight = <&bl>; - enable-gpios = <&gpio6 16 GPIO_ACTIVE_HIGH>; /* gpio176, lcd INI */ - vcc-supply = <&vdd_io_reg>; - - port { - lcd_in: endpoint { - remote-endpoint = <&dpi_out>; - }; - }; - }; - - bl: backlight { - compatible = "pwm-backlight"; - pinctrl-names = "default"; - power-supply = <&vdd_io_reg>; - pinctrl-0 = <&backlight_pins>; - pwms = <&pwm11 0 5000000 0>; - brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; - default-brightness-level = <7>; - enable-gpios = <&gpio6 22 GPIO_ACTIVE_HIGH>; /* gpio_182 */ - }; - - pwm11: pwm-11 { - compatible = "ti,omap-dmtimer-pwm"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm_pins>; - ti,timers = <&timer11>; - #pwm-cells = <3>; - ti,clock-source = <0x01>; - }; - - /* HS USB Host PHY on PORT 1 */ - hsusb1_phy: hsusb1_phy { - pinctrl-names = "default"; - pinctrl-0 = <&hsusb1_rst_pins>; - compatible = "usb-nop-xceiv"; - reset-gpios = <&gpio2 25 GPIO_ACTIVE_LOW>; /* gpio_57 */ - #phy-cells = <0>; - }; -}; - -&davinci_emac { - pinctrl-names = "default"; - pinctrl-0 = <ðernet_pins>; - status = "okay"; -}; - -&davinci_mdio { - status = "okay"; -}; - -&dss { - status = "okay"; - - pinctrl-names = "default"; - pinctrl-0 = <&dss_dpi_pins>; - - vdds_dsi-supply = <&vdd_io_reg>; - vdda_video-supply = <&vdd_io_reg>; - - port { - dpi_out: endpoint { - remote-endpoint = <&lcd_in>; - data-lines = <16>; - }; - }; -}; - -&i2c2 { - clock-frequency = <400000>; - /* User DIP swithes [1:8] / User LEDS [1:2] */ - tca6416: gpio@21 { - compatible = "ti,tca6416"; - reg = <0x21>; - gpio-controller; - #gpio-cells = <2>; - vcc-supply = <&vdd_io_reg>; - }; -}; - -&i2c3 { - clock-frequency = <400000>; -}; - -&mmc1 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mmc1_pins>; - vmmc-supply = <&vmmc_fixed>; - bus-width = <4>; - wp-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>; /* gpio_126 */ - cd-gpios = <&gpio4 31 GPIO_ACTIVE_LOW>; /* gpio_127 */ -}; - -&mmc3 { - status = "disabled"; -}; - -&usbhshost { - pinctrl-names = "default"; - pinctrl-0 = <&hsusb1_pins>; - port1-mode = "ehci-phy"; -}; - -&usbhsehci { - phys = <&hsusb1_phy>; -}; - -&omap3_pmx_core { - - ethernet_pins: pinmux_ethernet_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21fe, PIN_INPUT | MUX_MODE0) /* rmii_mdio_data */ - OMAP3_CORE1_IOPAD(0x2200, MUX_MODE0) /* rmii_mdio_clk */ - OMAP3_CORE1_IOPAD(0x2202, PIN_INPUT_PULLDOWN | MUX_MODE0) /* rmii_rxd0 */ - OMAP3_CORE1_IOPAD(0x2204, PIN_INPUT_PULLDOWN | MUX_MODE0) /* rmii_rxd1 */ - OMAP3_CORE1_IOPAD(0x2206, PIN_INPUT_PULLDOWN | MUX_MODE0) /* rmii_crs_dv */ - OMAP3_CORE1_IOPAD(0x2208, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* rmii_rxer */ - OMAP3_CORE1_IOPAD(0x220a, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* rmii_txd0 */ - OMAP3_CORE1_IOPAD(0x220c, PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* rmii_txd1 */ - OMAP3_CORE1_IOPAD(0x220e, PIN_OUTPUT_PULLDOWN |MUX_MODE0) /* rmii_txen */ - OMAP3_CORE1_IOPAD(0x2210, PIN_INPUT_PULLDOWN | MUX_MODE0) /* rmii_50mhz_clk */ - >; - }; - - leds_pins: pinmux_leds_pins { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a24, PIN_OUTPUT_PULLUP | MUX_MODE4) /* jtag_emu0.gpio_11 */ - OMAP3_WKUP_IOPAD(0x2a26, PIN_OUTPUT_PULLUP | MUX_MODE4) /* jtag_emu1.gpio_31 */ - >; - }; - - mmc1_pins: pinmux_mmc1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2144, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_clk.sdmmc1_clk */ - OMAP3_CORE1_IOPAD(0x2146, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_cmd.sdmmc1_cmd */ - OMAP3_CORE1_IOPAD(0x2148, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat0.sdmmc1_dat0 */ - OMAP3_CORE1_IOPAD(0x214a, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat1.sdmmc1_dat1 */ - OMAP3_CORE1_IOPAD(0x214c, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat2.sdmmc1_dat2 */ - OMAP3_CORE1_IOPAD(0x214e, PIN_INPUT_PULLUP | MUX_MODE0) /* sdmmc1_dat3.sdmmc1_dat3 */ - OMAP3_CORE1_IOPAD(0x2150, PIN_INPUT_PULLUP | MUX_MODE4) /* sdmmc1_dat4.gpio_126 */ - OMAP3_CORE1_IOPAD(0x2152, PIN_INPUT_PULLUP | MUX_MODE4) /* sdmmc1_dat5.gpio_127 */ - >; - }; - - pwm_pins: pinmux_pwm_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21dc, PIN_OUTPUT | MUX_MODE1) /* mcspi2_cs0.gpt11_pwm */ - >; - }; - - backlight_pins: pinmux_backlight_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21de, PIN_OUTPUT | MUX_MODE4) /* mcspi2_cs1.gpio_182 */ - >; - }; - - dss_dpi_pins: pinmux_dss_dpi_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21d2, PIN_OUTPUT | MUX_MODE4) /* mcspi1_cs2.gpio_176 */ - OMAP3_CORE1_IOPAD(0x20d4, PIN_OUTPUT | MUX_MODE0) /* dss_pclk.dss_pclk */ - OMAP3_CORE1_IOPAD(0x20d6, PIN_OUTPUT | MUX_MODE0) /* dss_hsync.dss_hsync */ - OMAP3_CORE1_IOPAD(0x20d8, PIN_OUTPUT | MUX_MODE0) /* dss_vsync.dss_vsync */ - OMAP3_CORE1_IOPAD(0x20da, PIN_OUTPUT | MUX_MODE0) /* dss_acbias.dss_acbias */ - OMAP3_CORE1_IOPAD(0x20dc, PIN_OUTPUT | MUX_MODE0) /* dss_data0.dss_data0 */ - OMAP3_CORE1_IOPAD(0x20de, PIN_OUTPUT | MUX_MODE0) /* dss_data1.dss_data1 */ - OMAP3_CORE1_IOPAD(0x20e0, PIN_OUTPUT | MUX_MODE0) /* dss_data2.dss_data2 */ - OMAP3_CORE1_IOPAD(0x20e2, PIN_OUTPUT | MUX_MODE0) /* dss_data3.dss_data3 */ - OMAP3_CORE1_IOPAD(0x20e4, PIN_OUTPUT | MUX_MODE0) /* dss_data4.dss_data4 */ - OMAP3_CORE1_IOPAD(0x20e6, PIN_OUTPUT | MUX_MODE0) /* dss_data5.dss_data5 */ - OMAP3_CORE1_IOPAD(0x20e8, PIN_OUTPUT | MUX_MODE0) /* dss_data6.dss_data6 */ - OMAP3_CORE1_IOPAD(0x20ea, PIN_OUTPUT | MUX_MODE0) /* dss_data7.dss_data7 */ - OMAP3_CORE1_IOPAD(0x20ec, PIN_OUTPUT | MUX_MODE0) /* dss_data8.dss_data8 */ - OMAP3_CORE1_IOPAD(0x20ee, PIN_OUTPUT | MUX_MODE0) /* dss_data9.dss_data9 */ - OMAP3_CORE1_IOPAD(0x20f0, PIN_OUTPUT | MUX_MODE0) /* dss_data10.dss_data10 */ - OMAP3_CORE1_IOPAD(0x20f2, PIN_OUTPUT | MUX_MODE0) /* dss_data11.dss_data11 */ - OMAP3_CORE1_IOPAD(0x20f4, PIN_OUTPUT | MUX_MODE0) /* dss_data12.dss_data12 */ - OMAP3_CORE1_IOPAD(0x20f6, PIN_OUTPUT | MUX_MODE0) /* dss_data13.dss_data13 */ - OMAP3_CORE1_IOPAD(0x20f8, PIN_OUTPUT | MUX_MODE0) /* dss_data14.dss_data14 */ - OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT | MUX_MODE0) /* dss_data15.dss_data15 */ - >; - }; - - hsusb1_rst_pins: pinmux_hsusb1_rst_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x20ba, PIN_OUTPUT | MUX_MODE4) /* gpmc_ncs6.gpio_57 */ - >; - }; -}; - -&omap3_pmx_core2 { - - hsusb1_pins: pinmux_hsusb1_pins { - pinctrl-single,pins = < - OMAP3430_CORE2_IOPAD(0x25d8, PIN_OUTPUT | MUX_MODE3) /* etk_clk.hsusb1_stp */ - OMAP3430_CORE2_IOPAD(0x25da, PIN_OUTPUT | MUX_MODE3) /* etk_ctl.hsusb1_clk */ - OMAP3430_CORE2_IOPAD(0x25ec, PIN_INPUT | MUX_MODE3) /* etk_d8.hsusb1_dir */ - OMAP3430_CORE2_IOPAD(0x25ee, PIN_INPUT | MUX_MODE3) /* etk_d9.hsusb1_nxt */ - OMAP3430_CORE2_IOPAD(0x25dc, PIN_INPUT | MUX_MODE3) /* etk_d0.hsusb1_data0 */ - OMAP3430_CORE2_IOPAD(0x25de, PIN_INPUT | MUX_MODE3) /* etk_d1.hsusb1_data1 */ - OMAP3430_CORE2_IOPAD(0x25e0, PIN_INPUT | MUX_MODE3) /* etk_d2.hsusb1_data2 */ - OMAP3430_CORE2_IOPAD(0x25ea, PIN_INPUT | MUX_MODE3) /* etk_d7.hsusb1_data3 */ - OMAP3430_CORE2_IOPAD(0x25e4, PIN_INPUT | MUX_MODE3) /* etk_d4.hsusb1_data4 */ - OMAP3430_CORE2_IOPAD(0x25e6, PIN_INPUT | MUX_MODE3) /* etk_d5.hsusb1_data5 */ - OMAP3430_CORE2_IOPAD(0x25e8, PIN_INPUT | MUX_MODE3) /* etk_d6.hsusb1_data6 */ - OMAP3430_CORE2_IOPAD(0x25e2, PIN_INPUT | MUX_MODE3) /* etk_d3.hsusb1_data7 */ - >; - }; -}; diff --git a/arch/arm/dts/am3517-som.dtsi b/arch/arm/dts/am3517-som.dtsi deleted file mode 100644 index 8b669e2eaf..0000000000 --- a/arch/arm/dts/am3517-som.dtsi +++ /dev/null @@ -1,234 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Copyright (C) 2016 Derald D. Woods woods.technical@gmail.com - * - * Based on am3517-evm.dts - */ - -/ { - cpus { - cpu@0 { - cpu0-supply = <&vdd_core_reg>; - }; - }; - - wl12xx_buffer: wl12xx_buf { - compatible = "regulator-fixed"; - regulator-name = "wl1271_buf"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - pinctrl-names = "default"; - pinctrl-0 = <&wl12xx_buffer_pins>; - gpio = <&gpio5 1 GPIO_ACTIVE_LOW>; /* gpio 129 */ - regulator-always-on; - vin-supply = <&vdd_1v8_reg>; - }; - - wl12xx_vmmc2: wl12xx_vmmc2 { - compatible = "regulator-fixed"; - regulator-name = "vwl1271"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - pinctrl-names = "default"; - pinctrl-0 = <&wl12xx_wkup_pins>; - gpio = <&gpio1 3 GPIO_ACTIVE_HIGH >; /* gpio 3 */ - startup-delay-us = <70000>; - enable-active-high; - regulator-always-on; - vin-supply = <&wl12xx_buffer>; - }; -}; - -&gpmc { - ranges = <0 0 0x30000000 0x1000000>; /* CS0: 16MB for NAND */ - - nand@0,0 { - compatible = "ti,omap2-nand"; - linux,mtd-name = "micron,mt29f4g16abchch"; - reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ - nand-bus-width = <16>; - ti,nand-ecc-opt = "bch8"; - gpmc,sync-clk-ps = <0>; - gpmc,cs-on-ns = <0>; - gpmc,cs-rd-off-ns = <44>; - gpmc,cs-wr-off-ns = <44>; - gpmc,adv-on-ns = <6>; - gpmc,adv-rd-off-ns = <34>; - gpmc,adv-wr-off-ns = <44>; - gpmc,we-off-ns = <40>; - gpmc,oe-off-ns = <54>; - gpmc,access-ns = <64>; - gpmc,rd-cycle-ns = <82>; - gpmc,wr-cycle-ns = <82>; - gpmc,wr-access-ns = <40>; - gpmc,wr-data-mux-bus-ns = <0>; - gpmc,device-width = <2>; - #address-cells = <1>; - #size-cells = <1>; - }; -}; - -&i2c1 { - clock-frequency = <400000>; - - s35390a: s35390a@30 { - compatible = "sii,s35390a"; - reg = <0x30>; - - pinctrl-names = "default"; - pinctrl-0 = <&rtc_pins>; - interrupts-extended = <&gpio2 23 IRQ_TYPE_EDGE_FALLING>; /* gpio_55 */ - }; - - tps: tps65023@48 { - compatible = "ti,tps65023"; - reg = <0x48>; - - regulators { - vdd_core_reg: VDCDC1 { - regulator-name = "vdd_core"; - regulator-always-on; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - }; - - vdd_io_reg: VDCDC2 { - regulator-name = "vdd_io"; - regulator-always-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vdd_1v8_reg: VDCDC3 { - regulator-name = "vdd_1v8"; - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vdd_usb18_reg: LDO1 { - regulator-name = "vdd_usb18"; - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vdd_usb33_reg: LDO2 { - regulator-name = "vdd_usb33"; - regulator-always-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - }; - }; - - touchscreen: tsc2004@4b { - compatible = "ti,tsc2004"; - reg = <0x4b>; - - vio-supply = <&vdd_io_reg>; - - pinctrl-names = "default"; - pinctrl-0 = <&tsc2004_pins>; - interrupts-extended = <&gpio3 1 IRQ_TYPE_EDGE_RISING>; /* gpio_65 */ - - touchscreen-fuzz-x = <4>; - touchscreen-fuzz-y = <7>; - touchscreen-fuzz-pressure = <2>; - touchscreen-size-x = <480>; - touchscreen-size-y = <272>; - touchscreen-max-pressure = <2048>; - - ti,x-plate-ohms = <280>; - ti,esd-recovery-timeout-ms = <8000>; - }; -}; - -&mmc2 { - interrupts-extended = <&intc 86 /* &omap3_pmx_core 0x12c */>; - - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mmc2_pins>; - vmmc-supply = <&wl12xx_vmmc2>; - non-removable; - bus-width = <4>; - cap-power-off-card; - #address-cells = <1>; - #size-cells = <0>; - wlcore: wlcore@2 { - compatible = "ti,wl1271"; - reg = <2>; - interrupt-parent = <&gpio6>; - interrupts = <10 IRQ_TYPE_EDGE_RISING>; /* gpio_170 */ - ref-clock-frequency = <26000000>; - tcxo-clock-frequency = <26000000>; - }; -}; - -&uart2 { - pinctrl-names = "default"; - pinctrl-0 = <&uart2_pins>; - - bluetooth { - compatible = "ti,wl1271-st"; - enable-gpios = <&gpio2 24 GPIO_ACTIVE_HIGH>; /* gpio 56 */ - max-speed = <3000000>; - }; -}; - -&omap3_pmx_core { - - wl12xx_buffer_pins: pinmux_wl12xx_buffer_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2156, PIN_OUTPUT | MUX_MODE4) /* mmc1_dat7.gpio_129 */ - >; - }; - - mmc2_pins: pinmux_mmc2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2158, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_clk.mmc2_clk */ - OMAP3_CORE1_IOPAD(0x215a, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_cmd.mmc2_cmd */ - OMAP3_CORE1_IOPAD(0x215c, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat0.mmc2_dat0 */ - OMAP3_CORE1_IOPAD(0x215e, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat1.mmc2_dat1 */ - OMAP3_CORE1_IOPAD(0x2160, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat2.mmc2_dat2 */ - OMAP3_CORE1_IOPAD(0x2162, PIN_INPUT_PULLUP | MUX_MODE0) /* mmc2_dat3.mmc2_dat3 */ - OMAP3_CORE1_IOPAD(0x2164, PIN_OUTPUT | MUX_MODE1) /* mmc2_dat4.mmc2_dir_dat0 */ - OMAP3_CORE1_IOPAD(0x2166, PIN_OUTPUT | MUX_MODE1) /* mmc2_dat5.mmc2_dir_dat1 */ - OMAP3_CORE1_IOPAD(0x2168, PIN_OUTPUT | MUX_MODE1) /* mmc2_dat6.mmc2_dir_cmd */ - OMAP3_CORE1_IOPAD(0x216a, PIN_INPUT | MUX_MODE1) /* mmc2_dat7.mmc2_clkin */ - OMAP3_CORE1_IOPAD(0x21c6, PIN_INPUT_PULLUP | MUX_MODE4) /* hdq_sio.gpio_170 */ - >; - }; - - rtc_pins: pinmux_rtc_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x20b6, PIN_INPUT_PULLUP | MUX_MODE4) /* gpmc_ncs4.gpio_55 */ - >; - }; - - tsc2004_pins: pinmux_tsc2004_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x20d2, PIN_INPUT | MUX_MODE4) /* gpmc_wait3.gpio_65 */ - >; - }; - - uart2_pins: pinmux_uart2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2174, PIN_INPUT_PULLUP | MUX_MODE0) /* uart2_cts */ - OMAP3_CORE1_IOPAD(0x2176, PIN_OUTPUT_PULLUP | MUX_MODE0) /* uart2_rts */ - OMAP3_CORE1_IOPAD(0x2178, PIN_OUTPUT | MUX_MODE0) /* uart2_tx */ - OMAP3_CORE1_IOPAD(0x217a, PIN_INPUT | MUX_MODE0) /* uart2_rx */ - OMAP3_CORE1_IOPAD(0x20b8, PIN_INPUT | MUX_MODE0) /* gpio_56 */ - >; - }; -}; - -&omap3_pmx_wkup { - - wl12xx_wkup_pins: pinmux_wl12xx_wkup_pins { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a0c, PIN_OUTPUT | MUX_MODE4) /* sys_boot1.gpio_3 */ - >; - }; -}; diff --git a/arch/arm/dts/am3517.dtsi b/arch/arm/dts/am3517.dtsi deleted file mode 100644 index 2633fae14b..0000000000 --- a/arch/arm/dts/am3517.dtsi +++ /dev/null @@ -1,109 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Device Tree Source for am3517 SoC - * - * Copyright (C) 2013 Texas Instruments Incorporated - https://www.ti.com/ - */ - -#include "omap3.dtsi" - -/ { - aliases { - serial3 = &uart4; - can = &hecc; - }; - - ocp@68000000 { - am35x_otg_hs: am35x_otg_hs@5c040000 { - compatible = "ti,omap3-musb"; - ti,hwmods = "am35x_otg_hs"; - status = "disabled"; - reg = <0x5c040000 0x1000>; - interrupts = <71>; - interrupt-names = "mc"; - }; - - davinci_emac: ethernet@5c000000 { - compatible = "ti,am3517-emac"; - ti,hwmods = "davinci_emac"; - status = "disabled"; - reg = <0x5c000000 0x30000>; - interrupts = <67 68 69 70>; - syscon = <&scm_conf>; - ti,davinci-ctrl-reg-offset = <0x10000>; - ti,davinci-ctrl-mod-reg-offset = <0>; - ti,davinci-ctrl-ram-offset = <0x20000>; - ti,davinci-ctrl-ram-size = <0x2000>; - ti,davinci-rmii-en = /bits/ 8 <1>; - local-mac-address = [ 00 00 00 00 00 00 ]; - clocks = <&emac_ick>; - clock-names = "ick"; - }; - - davinci_mdio: mdio@5c030000 { - compatible = "ti,davinci_mdio"; - ti,hwmods = "davinci_mdio"; - status = "disabled"; - reg = <0x5c030000 0x1000>; - bus_freq = <1000000>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&emac_fck>; - clock-names = "fck"; - }; - - uart4: serial@4809e000 { - compatible = "ti,omap3-uart"; - ti,hwmods = "uart4"; - status = "disabled"; - reg = <0x4809e000 0x400>; - interrupts = <84>; - dmas = <&sdma 55 &sdma 54>; - dma-names = "tx", "rx"; - clock-frequency = <48000000>; - }; - - omap3_pmx_core2: pinmux@480025d8 { - compatible = "ti,omap3-padconf", "pinctrl-single"; - reg = <0x480025d8 0x24>; - #address-cells = <1>; - #size-cells = <0>; - #pinctrl-cells = <1>; - #interrupt-cells = <1>; - interrupt-controller; - pinctrl-single,register-width = <16>; - pinctrl-single,function-mask = <0xff1f>; - }; - - hecc: can@5c050000 { - compatible = "ti,am3517-hecc"; - status = "disabled"; - reg = <0x5c050000 0x80>, - <0x5c053000 0x180>, - <0x5c052000 0x200>; - reg-names = "hecc", "hecc-ram", "mbx"; - interrupts = <24>; - clocks = <&hecc_ck>; - }; - }; -}; - -/* Table Table 5-79 of the TRM shows 480ab000 is reserved */ -&usb_otg_hs { - status = "disabled"; -}; - -&iva { - status = "disabled"; -}; - -&mailbox { - status = "disabled"; -}; - -&mmu_isp { - status = "disabled"; -}; - -/include/ "am35xx-clocks.dtsi" -/include/ "omap36xx-am35xx-omap3430es2plus-clocks.dtsi" diff --git a/arch/arm/dts/am35xx-clocks.dtsi b/arch/arm/dts/am35xx-clocks.dtsi deleted file mode 100644 index 220d0a5279..0000000000 --- a/arch/arm/dts/am35xx-clocks.dtsi +++ /dev/null @@ -1,125 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only -/* - * Device Tree Source for OMAP3 clock data - * - * Copyright (C) 2013 Texas Instruments, Inc. - */ -&scm_clocks { - emac_ick: emac_ick@32c { - #clock-cells = <0>; - compatible = "ti,am35xx-gate-clock"; - clocks = <&ipss_ick>; - reg = <0x032c>; - ti,bit-shift = <1>; - }; - - emac_fck: emac_fck@32c { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&rmii_ck>; - reg = <0x032c>; - ti,bit-shift = <9>; - }; - - vpfe_ick: vpfe_ick@32c { - #clock-cells = <0>; - compatible = "ti,am35xx-gate-clock"; - clocks = <&ipss_ick>; - reg = <0x032c>; - ti,bit-shift = <2>; - }; - - vpfe_fck: vpfe_fck@32c { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&pclk_ck>; - reg = <0x032c>; - ti,bit-shift = <10>; - }; - - hsotgusb_ick_am35xx: hsotgusb_ick_am35xx@32c { - #clock-cells = <0>; - compatible = "ti,am35xx-gate-clock"; - clocks = <&ipss_ick>; - reg = <0x032c>; - ti,bit-shift = <0>; - }; - - hsotgusb_fck_am35xx: hsotgusb_fck_am35xx@32c { - #clock-cells = <0>; - compatible = "ti,gate-clock"; - clocks = <&sys_ck>; - reg = <0x032c>; - ti,bit-shift = <8>; - }; - - hecc_ck: hecc_ck@32c { - #clock-cells = <0>; - compatible = "ti,am35xx-gate-clock"; - clocks = <&sys_ck>; - reg = <0x032c>; - ti,bit-shift = <3>; - }; -}; -&cm_clocks { - ipss_ick: ipss_ick@a10 { - #clock-cells = <0>; - compatible = "ti,am35xx-interface-clock"; - clocks = <&core_l3_ick>; - reg = <0x0a10>; - ti,bit-shift = <4>; - }; - - rmii_ck: rmii_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <50000000>; - }; - - pclk_ck: pclk_ck { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <27000000>; - }; - - uart4_ick_am35xx: uart4_ick_am35xx@a10 { - #clock-cells = <0>; - compatible = "ti,omap3-interface-clock"; - clocks = <&core_l4_ick>; - reg = <0x0a10>; - ti,bit-shift = <23>; - }; - - uart4_fck_am35xx: uart4_fck_am35xx@a00 { - #clock-cells = <0>; - compatible = "ti,wait-gate-clock"; - clocks = <&core_48m_fck>; - reg = <0x0a00>; - ti,bit-shift = <23>; - }; -}; - -&cm_clockdomains { - core_l3_clkdm: core_l3_clkdm { - compatible = "ti,clockdomain"; - clocks = <&sdrc_ick>, <&ipss_ick>, <&emac_ick>, <&vpfe_ick>, - <&hsotgusb_ick_am35xx>, <&hsotgusb_fck_am35xx>, - <&hecc_ck>; - }; - - core_l4_clkdm: core_l4_clkdm { - compatible = "ti,clockdomain"; - clocks = <&cpefuse_fck>, <&ts_fck>, <&usbtll_fck>, - <&usbtll_ick>, <&mmchs3_ick>, <&mmchs3_fck>, - <&mmchs2_fck>, <&mmchs1_fck>, <&i2c3_fck>, <&i2c2_fck>, - <&i2c1_fck>, <&mcspi4_fck>, <&mcspi3_fck>, - <&mcspi2_fck>, <&mcspi1_fck>, <&uart2_fck>, - <&uart1_fck>, <&hdq_fck>, <&mmchs2_ick>, <&mmchs1_ick>, - <&hdq_ick>, <&mcspi4_ick>, <&mcspi3_ick>, - <&mcspi2_ick>, <&mcspi1_ick>, <&i2c3_ick>, <&i2c2_ick>, - <&i2c1_ick>, <&uart2_ick>, <&uart1_ick>, <&gpt11_ick>, - <&gpt10_ick>, <&mcbsp5_ick>, <&mcbsp1_ick>, - <&omapctrl_ick>, <&aes2_ick>, <&sha12_ick>, - <&uart4_ick_am35xx>, <&uart4_fck_am35xx>; - }; -}; diff --git a/configs/am3517_evm_defconfig b/configs/am3517_evm_defconfig index 66bb4f6371..70498ca7fb 100644 --- a/configs/am3517_evm_defconfig +++ b/configs/am3517_evm_defconfig @@ -8,7 +8,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 -CONFIG_DEFAULT_DEVICE_TREE="am3517-evm" +CONFIG_DEFAULT_DEVICE_TREE="ti/omap/am3517-evm" CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_AM3517_EVM=y CONFIG_EMIF4=y @@ -58,6 +58,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1920k(u-boot),256k(u-bo CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_OVERWRITE=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y
The DM37 and OMAP35 Torpedo share a few files, but both of them can be migrated to OF_UPSTREAM with a small update to their respective u-boot.dtsi files to address changes made the aliases. Both defconfigs need to properly point to the upstream directory structure for the device trees. With those updated, the U-Boot device tree files can be deleted.
diff --git a/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi index 4744872f7c..d14d68e458 100644 --- a/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-torpedo-35xx-devkit-u-boot.dtsi @@ -14,6 +14,8 @@ aliases { /delete-property/ serial1; /delete-property/ serial2; + /delete-property/ mmc1; + /delete-property/ mmc2; };
ethernet@08000000 { diff --git a/arch/arm/dts/logicpd-torpedo-35xx-devkit.dts b/arch/arm/dts/logicpd-torpedo-35xx-devkit.dts deleted file mode 100644 index cb08aa62d9..0000000000 --- a/arch/arm/dts/logicpd-torpedo-35xx-devkit.dts +++ /dev/null @@ -1,21 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -/dts-v1/; - -#include "omap34xx.dtsi" -#include "logicpd-torpedo-som.dtsi" -#include "logicpd-torpedo-baseboard.dtsi" -#include "omap-gpmc-smsc9221.dtsi" - -/ { - model = "LogicPD Zoom OMAP35xx Torpedo Development Kit"; - compatible = "logicpd,dm3730-torpedo-devkit", "ti,omap3430", "ti,omap3"; -}; - -&omap3_pmx_core { - isp1763_pins: pinmux_isp1763_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2154, PIN_INPUT_PULLUP | MUX_MODE4) /* sdmmc1_dat6.gpio_128 */ - >; - }; -}; diff --git a/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi index 2c34344504..8e8e2e4096 100644 --- a/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-torpedo-37xx-devkit-u-boot.dtsi @@ -10,6 +10,8 @@ aliases { /delete-property/ serial1; /delete-property/ serial2; + /delete-property/ mmc1; + /delete-property/ mmc2; };
ethernet@08000000 { diff --git a/arch/arm/dts/logicpd-torpedo-37xx-devkit.dts b/arch/arm/dts/logicpd-torpedo-37xx-devkit.dts deleted file mode 100644 index 07ea822fe4..0000000000 --- a/arch/arm/dts/logicpd-torpedo-37xx-devkit.dts +++ /dev/null @@ -1,96 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -/dts-v1/; - -#include "omap36xx.dtsi" -#include "logicpd-torpedo-som.dtsi" -#include "omap-gpmc-smsc9221.dtsi" -#include "logicpd-torpedo-baseboard.dtsi" - -/ { - model = "LogicPD Zoom DM3730 Torpedo + Wireless Development Kit"; - compatible = "logicpd,dm3730-torpedo-devkit", "ti,omap3630", "ti,omap3"; - - wl12xx_vmmc: wl12xx_vmmc { - compatible = "regulator-fixed"; - regulator-name = "vwl1271"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - gpio = <&gpio5 29 0>; /* gpio157 */ - startup-delay-us = <70000>; - enable-active-high; - vin-supply = <&vmmc2>; - }; -}; - -/* - * Only found on the wireless SOM. For the SOM without wireless, the pins for - * MMC3 can be routed with jumpers to the second MMC slot on the devkit and - * gpio157 is not connected. So this should be OK to keep common for now, - * probably device tree overlays is the way to go with the various SOM and - * jumpering combinations for the long run. - */ -&mmc3 { - interrupts-extended = <&intc 94 &omap3_pmx_core 0x136>; - pinctrl-0 = <&mmc3_pins &mmc3_core2_pins>; - pinctrl-names = "default"; - vmmc-supply = <&wl12xx_vmmc>; - non-removable; - bus-width = <4>; - cap-power-off-card; - #address-cells = <1>; - #size-cells = <0>; - wlcore: wlcore@2 { - compatible = "ti,wl1283"; - reg = <2>; - interrupt-parent = <&gpio5>; - interrupts = <24 IRQ_TYPE_EDGE_RISING>; /* gpio 152 */ - ref-clock-frequency = <26000000>; - tcxo-clock-frequency = <26000000>; - }; -}; - -&uart2 { - /delete-property/dma-names; - bluetooth { - compatible = "ti,wl1283-st"; - enable-gpios = <&gpio6 2 GPIO_ACTIVE_HIGH>; /* gpio 162 */ - max-speed = <3000000>; - }; -}; - -/* The DM3730 has a faster L3 than OMAP35, so increase pixel clock */ -&mt9p031_out { - pixel-clock-frequency = <90000000>; -}; - -&omap3_pmx_core { - mmc3_pins: pinmux_mm3_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2164, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat4.sdmmc3_dat0 */ - OMAP3_CORE1_IOPAD(0x2166, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat5.sdmmc3_dat1 */ - OMAP3_CORE1_IOPAD(0x2168, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat6.sdmmc3_dat2 */ - OMAP3_CORE1_IOPAD(0x216a, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat6.sdmmc3_dat3 */ - OMAP3_CORE1_IOPAD(0x2184, PIN_INPUT_PULLUP | MUX_MODE4) /* mcbsp4_clkx.gpio_152 */ - OMAP3_CORE1_IOPAD(0x218e, PIN_OUTPUT | MUX_MODE4) /* mcbsp1_fsr.gpio_157 */ - >; - }; -}; - -&omap3_pmx_core2 { - mmc3_core2_pins: pinmux_mmc3_core2_pins { - pinctrl-single,pins = < - OMAP3630_CORE2_IOPAD(0x25d8, PIN_INPUT_PULLUP | MUX_MODE2) /* etk_clk.sdmmc3_clk */ - OMAP3630_CORE2_IOPAD(0x25da, PIN_INPUT_PULLUP | MUX_MODE2) /* etk_ctl.sdmmc3_cmd */ - >; - }; -}; - -/* The gpio muxing between omap3530 and dm3730 is different for GPIO_128 */ -&omap3_pmx_wkup { - isp1763_pins: pinmux_isp1763_pins { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a58, PIN_INPUT_PULLUP | MUX_MODE4) /* reserved.gpio_128 */ - >; - }; -}; diff --git a/arch/arm/dts/logicpd-torpedo-baseboard.dtsi b/arch/arm/dts/logicpd-torpedo-baseboard.dtsi deleted file mode 100644 index b4664ab002..0000000000 --- a/arch/arm/dts/logicpd-torpedo-baseboard.dtsi +++ /dev/null @@ -1,420 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -/ { - gpio_keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&gpio_key_pins &gpio_key_pins_wkup>; - - sysboot2 { - label = "sysboot2"; - gpios = <&gpio1 2 GPIO_ACTIVE_LOW>; /* gpio2 */ - linux,code = <BTN_0>; - wakeup-source; - }; - - sysboot5 { - label = "sysboot5"; - gpios = <&gpio1 7 GPIO_ACTIVE_LOW>; /* gpio7 */ - linux,code = <BTN_1>; - wakeup-source; - }; - - gpio1 { - label = "gpio1"; - gpios = <&gpio6 21 GPIO_ACTIVE_LOW>; /* gpio181 */ - linux,code = <BTN_2>; - wakeup-source; - }; - - gpio2 { - label = "gpio2"; - gpios = <&gpio6 18 GPIO_ACTIVE_LOW>; /* gpio178 */ - linux,code = <BTN_3>; - wakeup-source; - }; - }; - - sound { - compatible = "ti,omap-twl4030"; - ti,model = "omap3logic"; - ti,mcbsp = <&mcbsp2>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins>; - - led1 { - label = "led1"; - gpios = <&gpio6 20 GPIO_ACTIVE_HIGH>; /* gpio180 */ - linux,default-trigger = "cpu0"; - }; - - led2 { - label = "led2"; - gpios = <&gpio6 19 GPIO_ACTIVE_HIGH>; /* gpio179 */ - linux,default-trigger = "none"; - }; - }; - - pwm10: dmtimer-pwm { - compatible = "ti,omap-dmtimer-pwm"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm_pins>; - ti,timers = <&timer10>; - #pwm-cells = <3>; - ti,clock-source = <0x01>; - }; - -}; - -&vaux1 { - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; -}; - -&vaux4 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; -}; - -&mcbsp2 { - pinctrl-names = "default"; - pinctrl-0 = <&mcbsp2_pins>; - status = "okay"; -}; - -&charger { - ti,bb-uvolt = <3200000>; - ti,bb-uamp = <150>; -}; - -&gpmc { - ranges = <0 0 0x30000000 0x1000000 /* CS0: 16MB for NAND */ - 1 0 0x2c000000 0x1000000 /* CS1: 16MB for LAN9221 */ - 6 0 0x28000000 0x1000000>; /* CS6: 16MB for ISP1763 */ - - ethernet@gpmc { - pinctrl-names = "default"; - pinctrl-0 = <&lan9221_pins>; - interrupt-parent = <&gpio5>; - interrupts = <1 IRQ_TYPE_LEVEL_LOW>; /* gpio129 */ - reg = <1 0 0xff>; - }; - - usb@6,0 { - pinctrl-names = "default"; - pinctrl-0 = <&isp1763_pins>; - compatible = "nxp,usb-isp1763"; - reg = <0x6 0x0 0xff>; - interrupt-parent = <&gpio5>; - interrupts = <0 IRQ_TYPE_LEVEL_LOW>; - interrupt-names = "host"; - bus-width = <16>; - dr_mode = "host"; - gpmc,mux-add-data = <0>; - gpmc,device-width = <2>; - gpmc,wait-pin = <0>; - gpmc,burst-length = <4>; - gpmc,cycle2cycle-samecsen = <1>; - gpmc,cycle2cycle-diffcsen = <1>; - gpmc,cs-on-ns = <0>; - gpmc,cs-rd-off-ns = <45>; - gpmc,cs-wr-off-ns = <45>; - gpmc,adv-on-ns = <0>; - gpmc,adv-rd-off-ns = <0>; - gpmc,adv-wr-off-ns = <0>; - gpmc,oe-on-ns = <0>; - gpmc,oe-off-ns = <45>; - gpmc,we-on-ns = <0>; - gpmc,we-off-ns = <25>; - gpmc,rd-cycle-ns = <60>; - gpmc,wr-cycle-ns = <45>; - gpmc,access-ns = <35>; - gpmc,page-burst-access-ns = <0>; - gpmc,bus-turnaround-ns = <0>; - gpmc,cycle2cycle-delay-ns = <60>; - gpmc,wait-monitoring-ns = <0>; - gpmc,clk-activation-ns = <0>; - gpmc,wr-data-mux-bus-ns = <5>; - gpmc,wr-access-ns = <20>; - }; -}; - -&hdqw1w { - pinctrl-names = "default"; - pinctrl-0 = <&hdq_pins>; -}; - - -&vpll2 { - regulator-always-on; -}; - -&dss { - status = "okay"; - vdds_dsi-supply = <&vpll2>; - vdda_video-supply = <&vpll2>; - pinctrl-names = "default"; - pinctrl-0 = <&dss_dpi_pins1>; - port { - dpi_out: endpoint { - remote-endpoint = <&lcd_in>; - data-lines = <16>; - }; - }; -}; - -/ { - aliases { - display0 = &lcd0; - }; - - lcd0: display { - /* This isn't the exact LCD, but the timings meet spec */ - compatible = "newhaven,nhd-4.3-480272ef-atxl"; - label = "15"; - pinctrl-names = "default"; - pinctrl-0 = <&panel_pwr_pins>; - backlight = <&bl>; - enable-gpios = <&gpio5 27 GPIO_ACTIVE_HIGH>; - port { - lcd_in: endpoint { - remote-endpoint = <&dpi_out>; - }; - }; - }; - - bl: backlight { - compatible = "pwm-backlight"; - pinctrl-names = "default"; - pinctrl-0 = <&backlight_pins>; - pwms = <&pwm10 0 5000000 0>; - brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; - default-brightness-level = <7>; - enable-gpios = <&gpio5 26 GPIO_ACTIVE_HIGH>; /* gpio_154 */ - }; -}; - -&mmc1 { - interrupts-extended = <&intc 83 &omap3_pmx_core 0x11a>; - pinctrl-names = "default"; - pinctrl-0 = <&mmc1_pins &mmc1_cd>; - cd-gpios = <&gpio4 31 GPIO_ACTIVE_LOW>; /* gpio127 */ - vmmc-supply = <&vmmc1>; - bus-width = <4>; - cap-power-off-card; -}; - -&omap3_pmx_core { - gpio_key_pins: pinmux_gpio_key_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21d6, PIN_INPUT_PULLUP | MUX_MODE4) /* mcspi2_clk.gpio_178 */ - OMAP3_CORE1_IOPAD(0x21dc, PIN_INPUT_PULLUP | MUX_MODE4) /* mcspi2_cs0.gpio_181 */ - >; - }; - - hdq_pins: hdq_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21c6, PIN_INPUT_PULLUP | MUX_MODE0) /* hdq_sio */ - >; - }; - - pwm_pins: pinmux_pwm_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x20B8, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE3) /* gpmc_ncs5.gpt_10_pwm_evt */ - >; - }; - - led_pins: pinmux_led_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21d8, PIN_OUTPUT | MUX_MODE4) /* gpio_179 */ - OMAP3_CORE1_IOPAD(0x21da, PIN_OUTPUT | MUX_MODE4) /* gpio_180 */ - >; - }; - - mmc1_pins: pinmux_mmc1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2144, PIN_OUTPUT | MUX_MODE0) /* sdmmc1_clk.sdmmc1_clk */ - OMAP3_CORE1_IOPAD(0x2146, PIN_INPUT | MUX_MODE0) /* sdmmc1_cmd.sdmmc1_cmd */ - OMAP3_CORE1_IOPAD(0x2148, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat0.sdmmc1_dat0 */ - OMAP3_CORE1_IOPAD(0x214a, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat1.sdmmc1_dat1 */ - OMAP3_CORE1_IOPAD(0x214c, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat2.sdmmc1_dat2 */ - OMAP3_CORE1_IOPAD(0x214e, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat3.sdmmc1_dat3 */ - >; - }; - - tsc2004_pins: pinmux_tsc2004_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2186, PIN_INPUT | MUX_MODE4) /* mcbsp4_dr.gpio_153 */ - >; - }; - - backlight_pins: pinmux_backlight_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2188, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* mcbsp4_dx.gpio_154 */ - >; - }; - - isp_pins: pinmux_isp_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x210c, PIN_INPUT | MUX_MODE0) /* cam_hs.cam_hs */ - OMAP3_CORE1_IOPAD(0x210e, PIN_INPUT | MUX_MODE0) /* cam_vs.cam_vs */ - OMAP3_CORE1_IOPAD(0x2110, PIN_INPUT | MUX_MODE0) /* cam_xclka.cam_xclka */ - OMAP3_CORE1_IOPAD(0x2112, PIN_INPUT | MUX_MODE0) /* cam_pclk.cam_pclk */ - - OMAP3_CORE1_IOPAD(0x2116, PIN_INPUT | MUX_MODE0) /* cam_d0.cam_d0 */ - OMAP3_CORE1_IOPAD(0x2118, PIN_INPUT | MUX_MODE0) /* cam_d1.cam_d1 */ - OMAP3_CORE1_IOPAD(0x211a, PIN_INPUT | MUX_MODE0) /* cam_d2.cam_d2 */ - OMAP3_CORE1_IOPAD(0x211c, PIN_INPUT | MUX_MODE0) /* cam_d3.cam_d3 */ - OMAP3_CORE1_IOPAD(0x211e, PIN_INPUT | MUX_MODE0) /* cam_d4.cam_d4 */ - OMAP3_CORE1_IOPAD(0x2120, PIN_INPUT | MUX_MODE0) /* cam_d5.cam_d5 */ - OMAP3_CORE1_IOPAD(0x2122, PIN_INPUT | MUX_MODE0) /* cam_d6.cam_d6 */ - OMAP3_CORE1_IOPAD(0x2124, PIN_INPUT | MUX_MODE0) /* cam_d7.cam_d7 */ - >; - }; - - panel_pwr_pins: pinmux_panel_pwr_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x218a, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* mcbsp4_fs.gpio_155 */ - >; - }; - - dss_dpi_pins1: pinmux_dss_dpi_pins1 { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x20d4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_pclk.dss_pclk */ - OMAP3_CORE1_IOPAD(0x20d6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_hsync.dss_hsync */ - OMAP3_CORE1_IOPAD(0x20d8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_vsync.dss_vsync */ - OMAP3_CORE1_IOPAD(0x20da, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_acbias.dss_acbias */ - - OMAP3_CORE1_IOPAD(0x20e8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data6.dss_data6 */ - OMAP3_CORE1_IOPAD(0x20ea, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data7.dss_data7 */ - OMAP3_CORE1_IOPAD(0x20ec, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data8.dss_data8 */ - OMAP3_CORE1_IOPAD(0x20ee, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data9.dss_data9 */ - OMAP3_CORE1_IOPAD(0x20f0, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data10.dss_data10 */ - OMAP3_CORE1_IOPAD(0x20f2, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data11.dss_data11 */ - OMAP3_CORE1_IOPAD(0x20f4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data12.dss_data12 */ - OMAP3_CORE1_IOPAD(0x20f6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data13.dss_data13 */ - OMAP3_CORE1_IOPAD(0x20f8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data14.dss_data14 */ - OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data15.dss_data15 */ - OMAP3_CORE1_IOPAD(0x20fc, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data16.dss_data16 */ - OMAP3_CORE1_IOPAD(0x20fe, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data17.dss_data17 */ - - OMAP3_CORE1_IOPAD(0x2100, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE3) /* dss_data18.dss_data0 */ - OMAP3_CORE1_IOPAD(0x2102, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE3) /* dss_data19.dss_data1 */ - OMAP3_CORE1_IOPAD(0x2104, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE3) /* dss_data20.dss_data2 */ - OMAP3_CORE1_IOPAD(0x2106, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE3) /* dss_data21.dss_data3 */ - OMAP3_CORE1_IOPAD(0x2108, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE3) /* dss_data22.dss_data4 */ - OMAP3_CORE1_IOPAD(0x210a, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE3) /* dss_data23.dss_data5 */ - >; - }; -}; - -&omap3_pmx_wkup { - gpio_key_pins_wkup: pinmux_gpio_key_pins_wkup { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a0a, PIN_INPUT_PULLUP | MUX_MODE4) /* sys_boot0.gpio_2 */ - OMAP3_WKUP_IOPAD(0x2a14, PIN_INPUT_PULLUP | MUX_MODE4) /* sys_boot5.gpio_7 */ - >; - }; - - lan9221_pins: pinmux_lan9221_pins { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a5a, PIN_INPUT | MUX_MODE4) /* reserved.gpio_129 */ - >; - }; - - mmc1_cd: pinmux_mmc1_cd { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a54, PIN_INPUT_PULLUP | MUX_MODE4) /* reserved.gpio_127 */ - >; - }; -}; - -&i2c2 { - mt9p031@48 { - compatible = "aptina,mt9p031"; - reg = <0x48>; - clocks = <&isp 0>; - vaa-supply = <&vaux4>; - vdd-supply = <&vaux4>; - vdd_io-supply = <&vaux4>; - port { - mt9p031_out: endpoint { - input-clock-frequency = <24000000>; - pixel-clock-frequency = <72000000>; - remote-endpoint = <&ccdc_ep>; - }; - }; - }; -}; - -&i2c3 { - touchscreen: tsc2004@48 { - compatible = "ti,tsc2004"; - reg = <0x48>; - vio-supply = <&vaux1>; - pinctrl-names = "default"; - pinctrl-0 = <&tsc2004_pins>; - interrupts-extended = <&gpio5 25 IRQ_TYPE_EDGE_RISING>; /* gpio 153 */ - - touchscreen-fuzz-x = <4>; - touchscreen-fuzz-y = <7>; - touchscreen-fuzz-pressure = <2>; - touchscreen-size-x = <4096>; - touchscreen-size-y = <4096>; - touchscreen-max-pressure = <2048>; - - ti,x-plate-ohms = <280>; - ti,esd-recovery-timeout-ms = <8000>; - }; -}; - -&mcspi1 { - at25@0 { - compatible = "atmel,at25"; - reg = <0>; - spi-max-frequency = <5000000>; - spi-cpha; - spi-cpol; - - pagesize = <64>; - size = <32768>; - address-width = <16>; - }; -}; - -&isp { - pinctrl-names = "default"; - pinctrl-0 = <&isp_pins>; - ports { - port@0 { - reg = <0>; - ccdc_ep: endpoint { - remote-endpoint = <&mt9p031_out>; - bus-width = <8>; - hsync-active = <1>; - vsync-active = <1>; - pclk-sample = <0>; - }; - }; - }; -}; - -&uart1 { - interrupts-extended = <&intc 72 &omap3_pmx_core OMAP3_UART1_RX>; -}; - -/* Wired to the tps65950 on the SOM, only the USB connector is on the devkit */ -&usb_otg_hs { - pinctrl-names = "default"; - pinctrl-0 = <&hsusb_otg_pins>; - interface-type = <0>; - usb-phy = <&usb2_phy>; - phys = <&usb2_phy>; - phy-names = "usb2-phy"; - mode = <3>; - power = <50>; -}; diff --git a/arch/arm/dts/logicpd-torpedo-som.dtsi b/arch/arm/dts/logicpd-torpedo-som.dtsi deleted file mode 100644 index 3a5228562b..0000000000 --- a/arch/arm/dts/logicpd-torpedo-som.dtsi +++ /dev/null @@ -1,203 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -#include <dt-bindings/input/input.h> - -/ { - chosen { - stdout-path = &uart1; - }; - - cpus { - cpu@0 { - cpu0-supply = <&vcc>; - }; - }; - - memory@80000000 { - device_type = "memory"; - reg = <0x80000000 0>; - }; - - leds { - compatible = "gpio-leds"; - user0 { - label = "user0"; - gpios = <&twl_gpio 18 GPIO_ACTIVE_LOW>; /* LEDA */ - linux,default-trigger = "none"; - }; - }; - - /* fixed 26MHz oscillator */ - hfclk_26m: oscillator { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <26000000>; - }; -}; - -/* The Torpedo doesn't route the USB host pins */ -&usbhshost { - status = "disabled"; -}; - -&gpmc { - ranges = <0 0 0x30000000 0x1000000>; /* CS0: 16MB for NAND */ - - nand@0,0 { - compatible = "ti,omap2-nand"; - reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ - interrupt-parent = <&gpmc>; - interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ - <1 IRQ_TYPE_NONE>; /* termcount */ - linux,mtd-name = "micron,mt29f4g16abbda3w"; - nand-bus-width = <16>; - ti,nand-ecc-opt = "bch8"; - rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */ - gpmc,sync-clk-ps = <0>; - gpmc,cs-on-ns = <0>; - gpmc,cs-rd-off-ns = <44>; - gpmc,cs-wr-off-ns = <44>; - gpmc,adv-on-ns = <6>; - gpmc,adv-rd-off-ns = <34>; - gpmc,adv-wr-off-ns = <44>; - gpmc,we-off-ns = <40>; - gpmc,oe-off-ns = <54>; - gpmc,access-ns = <64>; - gpmc,rd-cycle-ns = <82>; - gpmc,wr-cycle-ns = <82>; - gpmc,wr-access-ns = <40>; - gpmc,wr-data-mux-bus-ns = <0>; - gpmc,device-width = <2>; - #address-cells = <1>; - #size-cells = <1>; - }; -}; - -&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins>; - clock-frequency = <2600000>; - - twl: twl@48 { - reg = <0x48>; - interrupts = <7>; /* SYS_NIRQ cascaded to intc */ - interrupt-parent = <&intc>; - clocks = <&hfclk_26m>; - clock-names = "fck"; - - twl_audio: audio { - compatible = "ti,twl4030-audio"; - codec { - }; - }; - }; -}; - -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins>; - clock-frequency = <400000>; -}; - -&i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_pins>; - clock-frequency = <400000>; - at24@50 { - compatible = "atmel,24c64"; - readonly; - reg = <0x50>; - }; -}; - -&omap3_pmx_core { - mcbsp2_pins: pinmux_mcbsp2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x213c, PIN_INPUT | MUX_MODE0) /* mcbsp2_fsx */ - OMAP3_CORE1_IOPAD(0x213e, PIN_INPUT | MUX_MODE0) /* mcbsp2_clkx */ - OMAP3_CORE1_IOPAD(0x2140, PIN_INPUT | MUX_MODE0) /* mcbsp2_dr */ - OMAP3_CORE1_IOPAD(0x2142, PIN_OUTPUT | MUX_MODE0) /* mcbsp2_dx */ - >; - }; - uart2_pins: pinmux_uart2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2174, PIN_INPUT | MUX_MODE0) /* uart2_cts.uart2_cts */ - OMAP3_CORE1_IOPAD(0x2176, PIN_OUTPUT | MUX_MODE0) /* uart2_rts .uart2_rts*/ - OMAP3_CORE1_IOPAD(0x2178, PIN_OUTPUT | MUX_MODE0) /* uart2_tx.uart2_tx */ - OMAP3_CORE1_IOPAD(0x217a, PIN_INPUT | MUX_MODE0) /* uart2_rx.uart2_rx */ - OMAP3_CORE1_IOPAD(0x2198, PIN_OUTPUT | MUX_MODE4) /* GPIO_162,BT_EN */ - >; - }; - mcspi1_pins: pinmux_mcspi1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21c8, PIN_INPUT | MUX_MODE0) /* mcspi1_clk.mcspi1_clk */ - OMAP3_CORE1_IOPAD(0x21ca, PIN_OUTPUT | MUX_MODE0) /* mcspi1_simo.mcspi1_simo */ - OMAP3_CORE1_IOPAD(0x21cc, PIN_INPUT_PULLUP | MUX_MODE0) /* mcspi1_somi.mcspi1_somi */ - OMAP3_CORE1_IOPAD(0x21ce, PIN_OUTPUT | MUX_MODE0) /* mcspi1_cs0.mcspi1_cs0 */ - >; - }; - hsusb_otg_pins: pinmux_hsusb_otg_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21a2, PIN_INPUT | MUX_MODE0) /* hsusb0_clk.hsusb0_clk */ - OMAP3_CORE1_IOPAD(0x21a4, PIN_OUTPUT | MUX_MODE0) /* hsusb0_stp.hsusb0_stp */ - OMAP3_CORE1_IOPAD(0x21a6, PIN_INPUT | MUX_MODE0) /* hsusb0_dir.hsusb0_dir */ - OMAP3_CORE1_IOPAD(0x21a8, PIN_INPUT | MUX_MODE0) /* hsusb0_nxt.hsusb0_nxt */ - - OMAP3_CORE1_IOPAD(0x21aa, PIN_INPUT | MUX_MODE0) /* hsusb0_data0.hsusb0_data0 */ - OMAP3_CORE1_IOPAD(0x21ac, PIN_INPUT | MUX_MODE0) /* hsusb0_data1.hsusb0_data1 */ - OMAP3_CORE1_IOPAD(0x21ae, PIN_INPUT | MUX_MODE0) /* hsusb0_data2.hsusb0_data2 */ - OMAP3_CORE1_IOPAD(0x21b0, PIN_INPUT | MUX_MODE0) /* hsusb0_data3.hsusb0_data3 */ - OMAP3_CORE1_IOPAD(0x21b2, PIN_INPUT | MUX_MODE0) /* hsusb0_data4.hsusb0_data4 */ - OMAP3_CORE1_IOPAD(0x21b4, PIN_INPUT | MUX_MODE0) /* hsusb0_data5.hsusb0_data5 */ - OMAP3_CORE1_IOPAD(0x21b6, PIN_INPUT | MUX_MODE0) /* hsusb0_data6.hsusb0_data6 */ - OMAP3_CORE1_IOPAD(0x21b8, PIN_INPUT | MUX_MODE0) /* hsusb0_data7.hsusb0_data7 */ - >; - }; - i2c1_pins: pinmux_i2c1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21ba, PIN_INPUT | MUX_MODE0) /* i2c1_scl.i2c1_scl */ - OMAP3_CORE1_IOPAD(0x21bc, PIN_INPUT | MUX_MODE0) /* i2c1_sda.i2c1_sda */ - >; - }; - i2c2_pins: pinmux_i2c2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21be, PIN_INPUT | MUX_MODE0) /* i2c2_scl */ - OMAP3_CORE1_IOPAD(0x21c0, PIN_INPUT | MUX_MODE0) /* i2c2_sda */ - >; - }; - i2c3_pins: pinmux_i2c3_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21c2, PIN_INPUT | MUX_MODE0) /* i2c3_scl */ - OMAP3_CORE1_IOPAD(0x21c4, PIN_INPUT | MUX_MODE0) /* i2c3_sda */ - >; - }; -}; - -&uart2 { - interrupts-extended = <&intc 73 &omap3_pmx_core OMAP3_UART2_RX>; - pinctrl-names = "default"; - pinctrl-0 = <&uart2_pins>; -}; - -&mcspi1 { - pinctrl-names = "default"; - pinctrl-0 = <&mcspi1_pins>; -}; - -#include "twl4030.dtsi" -#include "twl4030_omap3.dtsi" - -&twl { - twl_power: power { - compatible = "ti,twl4030-power-idle-osc-off", "ti,twl4030-power-idle"; - ti,use_poweroff; - }; -}; - -&twl_gpio { - ti,use-leds; -}; - -&twl_keypad { - status = "disabled"; -}; diff --git a/configs/omap35_logic_defconfig b/configs/omap35_logic_defconfig index f9b8ac5c07..23b2e50338 100644 --- a/configs/omap35_logic_defconfig +++ b/configs/omap35_logic_defconfig @@ -9,7 +9,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 -CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-35xx-devkit" +CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-35xx-devkit" CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set @@ -59,6 +59,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1792k(u-boot),128k(spl- CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_OVERWRITE=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/omap3_logic_defconfig b/configs/omap3_logic_defconfig index 00c4d847d2..d081d4e0fb 100644 --- a/configs/omap3_logic_defconfig +++ b/configs/omap3_logic_defconfig @@ -9,7 +9,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 -CONFIG_DEFAULT_DEVICE_TREE="logicpd-torpedo-37xx-devkit" +CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-torpedo-37xx-devkit" CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set @@ -58,6 +58,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1792k(u-boot),128k(spl- CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_OVERWRITE=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y
The DM37 and OMAP35 SOM-LV share a few files, but both of them can be migrated to OF_UPSTREAM with a small update to their respective u-boot.dtsi files to address changes made the aliases. Both defconfigs need to properly point to the upstream directory structure for the device trees. With those updated, the U-Boot device tree files can be deleted.
diff --git a/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi index 6f11852a33..d77fa38746 100644 --- a/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-som-lv-35xx-devkit-u-boot.dtsi @@ -14,6 +14,8 @@ aliases { /delete-property/ serial1; /delete-property/ serial2; + /delete-property/ mmc1; + /delete-property/ mmc2; };
ethernet@08000000 { diff --git a/arch/arm/dts/logicpd-som-lv-35xx-devkit.dts b/arch/arm/dts/logicpd-som-lv-35xx-devkit.dts deleted file mode 100644 index f690bc83bf..0000000000 --- a/arch/arm/dts/logicpd-som-lv-35xx-devkit.dts +++ /dev/null @@ -1,27 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -/dts-v1/; - -#include "omap34xx.dtsi" -#include "logicpd-som-lv.dtsi" -#include "logicpd-som-lv-baseboard.dtsi" -#include "omap-gpmc-smsc9221.dtsi" - -/ { - model = "LogicPD Zoom OMAP35xx SOM-LV Development Kit"; - compatible = "logicpd,dm3730-som-lv-devkit", "ti,omap3430", "ti,omap3"; -}; - -&omap3_pmx_core2 { - - hsusb2_2_pins: pinmux_hsusb2_2_pins { - pinctrl-single,pins = < - OMAP3430_CORE2_IOPAD(0x25f0, PIN_OUTPUT | MUX_MODE3) /* etk_d10.hsusb2_clk */ - OMAP3430_CORE2_IOPAD(0x25f2, PIN_OUTPUT | MUX_MODE3) /* etk_d11.hsusb2_stp */ - OMAP3430_CORE2_IOPAD(0x25f4, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d12.hsusb2_dir */ - OMAP3430_CORE2_IOPAD(0x25f6, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d13.hsusb2_nxt */ - OMAP3430_CORE2_IOPAD(0x25f8, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d14.hsusb2_data0 */ - OMAP3430_CORE2_IOPAD(0x25fa, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d15.hsusb2_data1 */ - >; - }; -}; diff --git a/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi b/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi index 6f11852a33..d77fa38746 100644 --- a/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi +++ b/arch/arm/dts/logicpd-som-lv-37xx-devkit-u-boot.dtsi @@ -14,6 +14,8 @@ aliases { /delete-property/ serial1; /delete-property/ serial2; + /delete-property/ mmc1; + /delete-property/ mmc2; };
ethernet@08000000 { diff --git a/arch/arm/dts/logicpd-som-lv-37xx-devkit.dts b/arch/arm/dts/logicpd-som-lv-37xx-devkit.dts deleted file mode 100644 index e28e9625be..0000000000 --- a/arch/arm/dts/logicpd-som-lv-37xx-devkit.dts +++ /dev/null @@ -1,27 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -/dts-v1/; - -#include "omap36xx.dtsi" -#include "logicpd-som-lv.dtsi" -#include "logicpd-som-lv-baseboard.dtsi" -#include "omap-gpmc-smsc9221.dtsi" - -/ { - model = "LogicPD Zoom DM3730 SOM-LV Development Kit"; - compatible = "logicpd,dm3730-som-lv-devkit", "ti,omap3630", "ti,omap3"; -}; - -&omap3_pmx_core2 { - - hsusb2_2_pins: pinmux_hsusb2_2_pins { - pinctrl-single,pins = < - OMAP3630_CORE2_IOPAD(0x25f0, PIN_OUTPUT | MUX_MODE3) /* etk_d10.hsusb2_clk */ - OMAP3630_CORE2_IOPAD(0x25f2, PIN_OUTPUT | MUX_MODE3) /* etk_d11.hsusb2_stp */ - OMAP3630_CORE2_IOPAD(0x25f4, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d12.hsusb2_dir */ - OMAP3630_CORE2_IOPAD(0x25f6, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d13.hsusb2_nxt */ - OMAP3630_CORE2_IOPAD(0x25f8, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d14.hsusb2_data0 */ - OMAP3630_CORE2_IOPAD(0x25fa, PIN_INPUT_PULLDOWN | MUX_MODE3) /* etk_d15.hsusb2_data1 */ - >; - }; -}; diff --git a/arch/arm/dts/logicpd-som-lv-baseboard.dtsi b/arch/arm/dts/logicpd-som-lv-baseboard.dtsi deleted file mode 100644 index 7d0468a237..0000000000 --- a/arch/arm/dts/logicpd-som-lv-baseboard.dtsi +++ /dev/null @@ -1,237 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -/ { - gpio_keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&gpio_key_pins>; - - sysboot2 { - label = "gpio3"; - gpios = <&gpio4 15 GPIO_ACTIVE_LOW>; /* gpio_111 / uP_GPIO_3 */ - linux,code = <BTN_0>; - wakeup-source; - }; - }; - - sound { - compatible = "ti,omap-twl4030"; - ti,model = "omap3logic"; - ti,mcbsp = <&mcbsp2>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&led_pins &led_pins_wkup>; - - led1 { - label = "led1"; - gpios = <&gpio5 5 GPIO_ACTIVE_LOW>; /* gpio133 */ - linux,default-trigger = "cpu0"; - }; - - led2 { - label = "led2"; - gpios = <&gpio1 11 GPIO_ACTIVE_LOW>; /* gpio11 */ - linux,default-trigger = "none"; - }; - }; -}; - -&vaux1 { - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; -}; - -&vaux4 { - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; -}; - -&mcbsp2 { - status = "okay"; - pinctrl-names = "default"; - pinctrl-0 = <&mcbsp2_pins>; -}; - -&charger { - ti,bb-uvolt = <3200000>; - ti,bb-uamp = <150>; -}; - -&gpmc { - ranges = <0 0 0x30000000 0x1000000 /* CS0: 16MB for NAND */ - 1 0 0x2c000000 0x1000000 /* CS1: 16MB for LAN9221 */ - 2 0 0x10000000 0x2000000>; /* CS2: 32MB for NOR */ - - ethernet@gpmc { - pinctrl-names = "default"; - pinctrl-0 = <&lan9221_pins>; - interrupt-parent = <&gpio5>; - interrupts = <24 IRQ_TYPE_LEVEL_LOW>; /* gpio_152 */ - reg = <1 0 0xff>; - }; -}; - -&vpll2 { - regulator-always-on; -}; - -&dss { - status = "okay"; - vdds_dsi-supply = <&vpll2>; - vdda_video-supply = <&video_reg>; - pinctrl-names = "default"; - pinctrl-0 = <&dss_dpi_pins1>; - port { - dpi_out: endpoint { - remote-endpoint = <&lcd_in>; - data-lines = <16>; - }; - }; -}; - -/ { - aliases { - display0 = &lcd0; - }; - - video_reg: video_reg { - compatible = "regulator-fixed"; - regulator-name = "fixed-supply"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - lcd0: display { - /* This isn't the exact LCD, but the timings meet spec */ - compatible = "logicpd,type28"; - pinctrl-names = "default"; - pinctrl-0 = <&lcd_enable_pin>; - backlight = <&bl>; - enable-gpios = <&gpio5 27 GPIO_ACTIVE_HIGH>; - port { - lcd_in: endpoint { - remote-endpoint = <&dpi_out>; - }; - }; - }; - - bl: backlight { - compatible = "pwm-backlight"; - pinctrl-names = "default"; - pinctrl-0 = <&backlight_pins>; - pwms = <&twl_pwm 0 5000000>; - brightness-levels = <0 10 20 30 40 50 60 70 80 90 100>; - default-brightness-level = <7>; - enable-gpios = <&gpio1 8 GPIO_ACTIVE_HIGH>; /* gpio_8 */ - }; -}; - -&mmc1 { - interrupts-extended = <&intc 83 &omap3_pmx_core 0x11a>; - pinctrl-names = "default"; - pinctrl-0 = <&mmc1_pins>; - wp-gpios = <&gpio4 30 GPIO_ACTIVE_HIGH>; /* gpio_126 */ - cd-gpios = <&gpio4 14 GPIO_ACTIVE_LOW>; /* gpio_110 */ - vmmc-supply = <&vmmc1>; - bus-width = <4>; - cap-power-off-card; -}; - -&omap3_pmx_core { - gpio_key_pins: pinmux_gpio_key_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x212e, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_xclkb.gpio_111 / uP_GPIO_3*/ - >; - }; - - led_pins: pinmux_led_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x215e, PIN_OUTPUT_PULLUP | MUX_MODE4) /* sdmmc2_dat1.gpio_133 / uP_GPIO_0 */ - >; - }; - - lan9221_pins: pinmux_lan9221_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2184, PIN_INPUT_PULLUP | MUX_MODE4) /* mcbsp4_clkx.gpio_152 */ - >; - }; - - mmc1_pins: pinmux_mmc1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2144, PIN_OUTPUT | MUX_MODE0) /* sdmmc1_clk.sdmmc1_clk */ - OMAP3_CORE1_IOPAD(0x2146, PIN_INPUT | MUX_MODE0) /* sdmmc1_cmd.sdmmc1_cmd */ - OMAP3_CORE1_IOPAD(0x2148, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat0.sdmmc1_dat0 */ - OMAP3_CORE1_IOPAD(0x214a, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat1.sdmmc1_dat1 */ - OMAP3_CORE1_IOPAD(0x214c, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat2.sdmmc1_dat2 */ - OMAP3_CORE1_IOPAD(0x214e, PIN_INPUT | MUX_MODE0) /* sdmmc1_dat3.sdmmc1_dat3 */ - OMAP3_CORE1_IOPAD(0x2132, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_strobe.gpio_126 */ - OMAP3_CORE1_IOPAD(0x212c, PIN_INPUT_PULLUP | MUX_MODE4) /* cam_d11.gpio_110 */ - >; - }; - - lcd_enable_pin: pinmux_lcd_enable_pin { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x218a, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* mcbsp4_fs.gpio_155 */ - >; - }; - - dss_dpi_pins1: pinmux_dss_dpi_pins1 { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x20d4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_pclk.dss_pclk */ - OMAP3_CORE1_IOPAD(0x20d6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_hsync.dss_hsync */ - OMAP3_CORE1_IOPAD(0x20d8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_vsync.dss_vsync */ - OMAP3_CORE1_IOPAD(0x20da, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_acbias.dss_acbias */ - - OMAP3_CORE1_IOPAD(0x20dc, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data0.dss_data0 */ - OMAP3_CORE1_IOPAD(0x20de, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data1.dss_data1 */ - OMAP3_CORE1_IOPAD(0x20e0, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data2.dss_data2 */ - OMAP3_CORE1_IOPAD(0x20e2, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data3.dss_data3 */ - OMAP3_CORE1_IOPAD(0x20e4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data4.dss_data4 */ - OMAP3_CORE1_IOPAD(0x20e6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data5.dss_data5 */ - OMAP3_CORE1_IOPAD(0x20e8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data6.dss_data6 */ - OMAP3_CORE1_IOPAD(0x20ea, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data7.dss_data7 */ - OMAP3_CORE1_IOPAD(0x20ec, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data8.dss_data8 */ - OMAP3_CORE1_IOPAD(0x20ee, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data9.dss_data9 */ - OMAP3_CORE1_IOPAD(0x20f0, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data10.dss_data10 */ - OMAP3_CORE1_IOPAD(0x20f2, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data11.dss_data11 */ - OMAP3_CORE1_IOPAD(0x20f4, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data12.dss_data12 */ - OMAP3_CORE1_IOPAD(0x20f6, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data13.dss_data13 */ - OMAP3_CORE1_IOPAD(0x20f8, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data14.dss_data14 */ - OMAP3_CORE1_IOPAD(0x20fa, PIN_OUTPUT_PULLDOWN | PIN_OFF_OUTPUT_LOW | MUX_MODE0) /* dss_data15.dss_data15 */ - >; - }; -}; - -&omap3_pmx_wkup { - led_pins_wkup: pinmux_led_pins_wkup { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a24, PIN_OUTPUT_PULLUP | MUX_MODE4) /* jtag_emu0.gpio_11 / uP_GPIO_1 */ - >; - }; - - backlight_pins: pinmux_backlight_pins { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a16, PIN_OUTPUT | PIN_OFF_OUTPUT_LOW | MUX_MODE4) /* sys_boot6.gpio_8 */ - >; - }; -}; - - -&uart1 { - interrupts-extended = <&intc 72 &omap3_pmx_core OMAP3_UART1_RX>; -}; - -/* Wired to the tps65950 on the SOM, only the USB connector is on the devkit */ -&usb_otg_hs { - pinctrl-names = "default"; - pinctrl-0 = <&hsusb_otg_pins>; - interface-type = <0>; - usb-phy = <&usb2_phy>; - phys = <&usb2_phy>; - phy-names = "usb2-phy"; - mode = <3>; - power = <50>; -}; diff --git a/arch/arm/dts/logicpd-som-lv.dtsi b/arch/arm/dts/logicpd-som-lv.dtsi deleted file mode 100644 index 385bc8d793..0000000000 --- a/arch/arm/dts/logicpd-som-lv.dtsi +++ /dev/null @@ -1,300 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-only - -#include <dt-bindings/input/input.h> - -/ { - cpus { - cpu@0 { - cpu0-supply = <&vcc>; - }; - }; - - memory@80000000 { - device_type = "memory"; - reg = <0x80000000 0>; - }; - - wl12xx_vmmc: wl12xx_vmmc { - compatible = "regulator-fixed"; - regulator-name = "vwl1271"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - gpio = <&gpio1 3 0>; /* gpio_3 */ - startup-delay-us = <70000>; - enable-active-high; - vin-supply = <&vaux3>; - }; - - /* HS USB Host PHY on PORT 1 */ - hsusb2_phy: hsusb2_phy { - pinctrl-names = "default"; - pinctrl-0 = <&hsusb2_reset_pin>; - compatible = "usb-nop-xceiv"; - reset-gpios = <&gpio1 4 GPIO_ACTIVE_LOW>; /* gpio_4 */ - #phy-cells = <0>; - }; - - /* fixed 26MHz oscillator */ - hfclk_26m: oscillator { - #clock-cells = <0>; - compatible = "fixed-clock"; - clock-frequency = <26000000>; - }; -}; - -&gpmc { - ranges = <0 0 0x30000000 0x1000000>; /* CS0: 16MB for NAND */ - - nand@0,0 { - compatible = "ti,omap2-nand"; - reg = <0 0 4>; /* CS0, offset 0, IO size 4 */ - interrupt-parent = <&gpmc>; - interrupts = <0 IRQ_TYPE_NONE>, /* fifoevent */ - <1 IRQ_TYPE_NONE>; /* termcount */ - linux,mtd-name = "micron,mt29f4g16abbda3w"; - nand-bus-width = <16>; - ti,nand-ecc-opt = "bch8"; - rb-gpios = <&gpmc 0 GPIO_ACTIVE_HIGH>; /* gpmc_wait0 */ - gpmc,sync-clk-ps = <0>; - gpmc,cs-on-ns = <0>; - gpmc,cs-rd-off-ns = <44>; - gpmc,cs-wr-off-ns = <44>; - gpmc,adv-on-ns = <6>; - gpmc,adv-rd-off-ns = <34>; - gpmc,adv-wr-off-ns = <44>; - gpmc,we-off-ns = <40>; - gpmc,oe-off-ns = <54>; - gpmc,access-ns = <64>; - gpmc,rd-cycle-ns = <82>; - gpmc,wr-cycle-ns = <82>; - gpmc,wr-access-ns = <40>; - gpmc,wr-data-mux-bus-ns = <0>; - gpmc,device-width = <2>; - #address-cells = <1>; - #size-cells = <1>; - }; -}; - -&i2c1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_pins>; - clock-frequency = <2600000>; - - twl: twl@48 { - reg = <0x48>; - interrupts = <7>; /* SYS_NIRQ cascaded to intc */ - interrupt-parent = <&intc>; - clocks = <&hfclk_26m>; - clock-names = "fck"; - twl_audio: audio { - compatible = "ti,twl4030-audio"; - codec { - ti,hs_extmute_gpio = <&gpio2 25 GPIO_ACTIVE_HIGH>; - }; - }; - }; -}; - -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_pins>; - clock-frequency = <400000>; -}; - -&i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_pins>; - clock-frequency = <400000>; - - touchscreen: tsc2004@48 { - compatible = "ti,tsc2004"; - reg = <0x48>; - vio-supply = <&vaux1>; - pinctrl-names = "default"; - pinctrl-0 = <&tsc2004_pins>; - interrupts-extended = <&gpio5 25 IRQ_TYPE_EDGE_RISING>; /* gpio 153 */ - - touchscreen-fuzz-x = <4>; - touchscreen-fuzz-y = <7>; - touchscreen-fuzz-pressure = <2>; - touchscreen-size-x = <4096>; - touchscreen-size-y = <4096>; - touchscreen-max-pressure = <2048>; - - ti,x-plate-ohms = <280>; - ti,esd-recovery-timeout-ms = <8000>; - }; -}; - -&mmc3 { - interrupts-extended = <&intc 94 &omap3_pmx_core 0x136>; - pinctrl-0 = <&mmc3_pins &wl127x_gpio>; - pinctrl-names = "default"; - vmmc-supply = <&wl12xx_vmmc>; - non-removable; - bus-width = <4>; - cap-power-off-card; - #address-cells = <1>; - #size-cells = <0>; - wlcore: wlcore@2 { - compatible = "ti,wl1273"; - reg = <2>; - interrupt-parent = <&gpio1>; - interrupts = <2 IRQ_TYPE_EDGE_RISING>; /* gpio 2 */ - ref-clock-frequency = <26000000>; - }; -}; - -&usbhshost { - pinctrl-names = "default"; - pinctrl-0 = <&hsusb2_pins>, <&hsusb2_2_pins>; - port2-mode = "ehci-phy"; -}; - -&usbhsehci { - phys = <0 &hsusb2_phy>; -}; - - -&omap3_pmx_core { - - mmc3_pins: pinmux_mm3_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2164, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat4.sdmmc3_dat0 */ - OMAP3_CORE1_IOPAD(0x2166, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat5.sdmmc3_dat1 */ - OMAP3_CORE1_IOPAD(0x2168, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat6.sdmmc3_dat2 */ - OMAP3_CORE1_IOPAD(0x216a, PIN_INPUT_PULLUP | MUX_MODE3) /* sdmmc2_dat6.sdmmc3_dat3 */ - OMAP3_CORE1_IOPAD(0x21d0, PIN_INPUT_PULLUP | MUX_MODE3) /* mcspi1_cs1.sdmmc3_cmd */ - OMAP3_CORE1_IOPAD(0x21d2, PIN_INPUT_PULLUP | MUX_MODE3) /* mcspi1_cs2.sdmmc_clk */ - >; - }; - - mcbsp2_pins: pinmux_mcbsp2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x213c, PIN_INPUT | MUX_MODE0) /* mcbsp2_fsx */ - OMAP3_CORE1_IOPAD(0x213e, PIN_INPUT | MUX_MODE0) /* mcbsp2_clkx */ - OMAP3_CORE1_IOPAD(0x2140, PIN_INPUT | MUX_MODE0) /* mcbsp2_dr */ - OMAP3_CORE1_IOPAD(0x2142, PIN_OUTPUT | MUX_MODE0) /* mcbsp2_dx */ - >; - }; - uart2_pins: pinmux_uart2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2174, PIN_INPUT | MUX_MODE0) /* uart2_cts.uart2_cts */ - OMAP3_CORE1_IOPAD(0x2176, PIN_OUTPUT | MUX_MODE0) /* uart2_rts .uart2_rts*/ - OMAP3_CORE1_IOPAD(0x2178, PIN_OUTPUT | MUX_MODE0) /* uart2_tx.uart2_tx */ - OMAP3_CORE1_IOPAD(0x217a, PIN_INPUT | MUX_MODE0) /* uart2_rx.uart2_rx */ - OMAP3_CORE1_IOPAD(0x2198, PIN_OUTPUT | MUX_MODE4) /* GPIO_162,BT_EN */ - >; - }; - - mcspi1_pins: pinmux_mcspi1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21c8, PIN_INPUT | MUX_MODE0) /* mcspi1_clk.mcspi1_clk */ - OMAP3_CORE1_IOPAD(0x21ca, PIN_OUTPUT | MUX_MODE0) /* mcspi1_simo.mcspi1_simo */ - OMAP3_CORE1_IOPAD(0x21cc, PIN_INPUT_PULLUP | MUX_MODE0) /* mcspi1_somi.mcspi1_somi */ - OMAP3_CORE1_IOPAD(0x21ce, PIN_OUTPUT | MUX_MODE0) /* mcspi1_cs0.mcspi1_cs0 */ - >; - }; - - hsusb2_pins: pinmux_hsusb2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21d4, PIN_INPUT_PULLDOWN | MUX_MODE3) /* mcspi1_cs3.hsusb2_data2 */ - OMAP3_CORE1_IOPAD(0x21d6, PIN_INPUT_PULLDOWN | MUX_MODE3) /* mcspi2_clk.hsusb2_data7 */ - OMAP3_CORE1_IOPAD(0x21d8, PIN_INPUT_PULLDOWN | MUX_MODE3) /* mcspi2_simo.hsusb2_data4 */ - OMAP3_CORE1_IOPAD(0x21da, PIN_INPUT_PULLDOWN | MUX_MODE3) /* mcspi2_somi.hsusb2_data5 */ - OMAP3_CORE1_IOPAD(0x21dc, PIN_INPUT_PULLDOWN | MUX_MODE3) /* mcspi2_cs0.hsusb2_data6 */ - OMAP3_CORE1_IOPAD(0x21de, PIN_INPUT_PULLDOWN | MUX_MODE3) /* mcspi2_cs1.hsusb2_data3 */ - >; - }; - - hsusb_otg_pins: pinmux_hsusb_otg_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21a2, PIN_INPUT | MUX_MODE0) /* hsusb0_clk.hsusb0_clk */ - OMAP3_CORE1_IOPAD(0x21a4, PIN_OUTPUT | MUX_MODE0) /* hsusb0_stp.hsusb0_stp */ - OMAP3_CORE1_IOPAD(0x21a6, PIN_INPUT | MUX_MODE0) /* hsusb0_dir.hsusb0_dir */ - OMAP3_CORE1_IOPAD(0x21a8, PIN_INPUT | MUX_MODE0) /* hsusb0_nxt.hsusb0_nxt */ - OMAP3_CORE1_IOPAD(0x21aa, PIN_INPUT | MUX_MODE0) /* hsusb0_data0.hsusb0_data0 */ - OMAP3_CORE1_IOPAD(0x21ac, PIN_INPUT | MUX_MODE0) /* hsusb0_data1.hsusb0_data1 */ - OMAP3_CORE1_IOPAD(0x21ae, PIN_INPUT | MUX_MODE0) /* hsusb0_data2.hsusb0_data2 */ - OMAP3_CORE1_IOPAD(0x21b0, PIN_INPUT | MUX_MODE0) /* hsusb0_data3.hsusb0_data3 */ - OMAP3_CORE1_IOPAD(0x21b2, PIN_INPUT | MUX_MODE0) /* hsusb0_data4.hsusb0_data4 */ - OMAP3_CORE1_IOPAD(0x21b4, PIN_INPUT | MUX_MODE0) /* hsusb0_data5.hsusb0_data5 */ - OMAP3_CORE1_IOPAD(0x21b6, PIN_INPUT | MUX_MODE0) /* hsusb0_data6.hsusb0_data6 */ - OMAP3_CORE1_IOPAD(0x21b8, PIN_INPUT | MUX_MODE0) /* hsusb0_data7.hsusb0_data7 */ - >; - }; - - i2c1_pins: pinmux_i2c1_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21ba, PIN_INPUT | MUX_MODE0) /* i2c1_scl.i2c1_scl */ - OMAP3_CORE1_IOPAD(0x21bc, PIN_INPUT | MUX_MODE0) /* i2c1_sda.i2c1_sda */ - OMAP3_CORE1_IOPAD(0x20ba, PIN_OUTPUT | MUX_MODE4) /* gpmc_ncs6.gpio_57 */ - >; - }; - - i2c2_pins: pinmux_i2c2_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21be, PIN_INPUT | MUX_MODE0) /* i2c2_scl */ - OMAP3_CORE1_IOPAD(0x21c0, PIN_INPUT | MUX_MODE0) /* i2c2_sda */ - >; - }; - - i2c3_pins: pinmux_i2c3_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x21c2, PIN_INPUT | MUX_MODE0) /* i2c3_scl */ - OMAP3_CORE1_IOPAD(0x21c4, PIN_INPUT | MUX_MODE0) /* i2c3_sda */ - >; - }; - - tsc2004_pins: pinmux_tsc2004_pins { - pinctrl-single,pins = < - OMAP3_CORE1_IOPAD(0x2186, PIN_INPUT | MUX_MODE4) /* mcbsp4_dr.gpio_153 */ - >; - }; -}; - -&omap3_pmx_wkup { - - hsusb2_reset_pin: pinmux_hsusb1_reset_pin { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a0e, PIN_OUTPUT | MUX_MODE4) /* sys_boot2.gpio_4 */ - >; - }; - - wl127x_gpio: pinmux_wl127x_gpio_pin { - pinctrl-single,pins = < - OMAP3_WKUP_IOPAD(0x2a0a, PIN_INPUT | MUX_MODE4) /* sys_boot0.gpio_2 */ - OMAP3_WKUP_IOPAD(0x2a0c, PIN_OUTPUT | MUX_MODE4) /* sys_boot1.gpio_3 */ - >; - }; -}; - -&uart2 { - interrupts-extended = <&intc 73 &omap3_pmx_core OMAP3_UART2_RX>; - pinctrl-names = "default"; - pinctrl-0 = <&uart2_pins>; -}; - -&mcspi1 { - pinctrl-names = "default"; - pinctrl-0 = <&mcspi1_pins>; -}; - -#include "twl4030.dtsi" -#include "twl4030_omap3.dtsi" - -&vaux3 { - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; -}; - -&twl { - twl_power: power { - compatible = "ti,twl4030-power-idle-osc-off", "ti,twl4030-power-idle"; - ti,use_poweroff; - }; -}; - -&twl_gpio { - ti,use-leds; -}; diff --git a/configs/omap35_logic_somlv_defconfig b/configs/omap35_logic_somlv_defconfig index 256ca9921d..a5f242ff40 100644 --- a/configs/omap35_logic_somlv_defconfig +++ b/configs/omap35_logic_somlv_defconfig @@ -9,7 +9,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 -CONFIG_DEFAULT_DEVICE_TREE="logicpd-som-lv-35xx-devkit" +CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-35xx-devkit" CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set @@ -61,6 +61,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1792k(u-boot),128k(spl- CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_OVERWRITE=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y diff --git a/configs/omap3_logic_somlv_defconfig b/configs/omap3_logic_somlv_defconfig index 04ba40111e..68e89d245e 100644 --- a/configs/omap3_logic_somlv_defconfig +++ b/configs/omap3_logic_somlv_defconfig @@ -9,7 +9,7 @@ CONFIG_TI_COMMON_CMD_OPTIONS=y CONFIG_NR_DRAM_BANKS=2 CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x4020ff00 -CONFIG_DEFAULT_DEVICE_TREE="logicpd-som-lv-37xx-devkit" +CONFIG_DEFAULT_DEVICE_TREE="ti/omap/logicpd-som-lv-37xx-devkit" CONFIG_SPL_TEXT_BASE=0x40200000 CONFIG_TARGET_OMAP3_LOGIC=y # CONFIG_SPL_OMAP3_ID_NAND is not set @@ -61,6 +61,7 @@ CONFIG_MTDPARTS_DEFAULT="mtdparts=omap2-nand.0:512k(MLO),1792k(u-boot),128k(spl- CONFIG_CMD_UBI=y CONFIG_OF_CONTROL=y CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_UPSTREAM=y CONFIG_ENV_OVERWRITE=y # CONFIG_ENV_IS_IN_FAT is not set CONFIG_ENV_IS_IN_NAND=y
On Wed, Apr 03, 2024 at 10:00:09PM -0500, Adam Ford wrote:
The da850-evm can remove the U-Boot device trees if migrated to OF_UPSTREAM. This means pointing the device trees to the ti/davinci directory.
Signed-off-by: Adam Ford aford173@gmail.com
This series leads to failure to build for omapl138_lcdk and lego_ev3 or was I supposed to bring in something else first? Thanks.
I just got back from 10 days in Europe for the Embedded World Conference. It should have been based on [1], but I haven't checked to see if it was applied. I (maybe wrongly) assumed [1] would have been applied before this patch was.
Once I get caught up, I'll look to see what's going one.
adam
[1] - https://www.mail-archive.com/u-boot@lists.denx.de/msg505123.html
-- Tom
Tom -
Can you point me to a failing log for this, so I can try to replicate it?
adam
adam
-- Tom
Tom -
Applying the series to top of tree and trying to build omapl138_lcdk results in: arm: + omapl138_lcdk +(omapl138_lcdk) make[3]: *** No rule to make target 'arch/arm/dts/da850-evm.dtb', needed by 'dtbs'. Stop. +(omapl138_lcdk) make[2]: *** [dts/Makefile:54: arch-dtbs] Error 2 +(omapl138_lcdk) make[1]: *** [Makefile:1166: dts/dt.dtb] Error 2 +(omapl138_lcdk) make: *** [Makefile:177: sub-make] Error 2
For me right now.
Adam Ford
