[U-Boot-Users] Variable bootfile can't be modified
Hi all,
I'm experiencing a weird problem with current U-Boot sources. Variable bootfile can't be modified as expected. When the board boots, bootfile looks like this:
bootfile=parsy/prelk/uImage
If I change it, the new value is appended to the env but old value in not deleted:
parsy> setenv bootfile abc parsy> print bootfile bootfile=parsy/prelk/uImage parsy> print bootdelay=3 baudrate=115200 ... bootfile=parsy/prelk/uImage ... stdin=serial stdout=serial stderr=serial bootfile=abc
Environment size: 1381/131067 bytes parsy>
Then If I issue manually setenv bootfile the first occurrence is deleted. If I issue the same command again the second occurrence (abc) is deleted.
Anybody experienced similar problems?
TIA llandre
DAVE Electronics System House - R&D Department web: http://www.dave-tech.it email: r&d2@dave-tech.it
CONFIG_EXTRA_ENV_SETTINGS erroneously defined bootfile twice.
Regards, llandre
Hi all,
TIA llandre
This SF.net email is sponsored by DB2 Express Download DB2 Express C - the FREE version of DB2 express and take control of your XML. No limits. Just data. Click to get it now. http://sourceforge.net/powerbar/db2/ _______________________________________________ U-Boot-Users mailing list U-Boot-Users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/u-boot-users
llandre
