[PATCH] mmc:Remove the legacy mode clock setting operation
Due to the need to read the register value before switching to hs mode, the standard protocol does not explicitly specify that the setting before switching to hs mode is in legacy mode. Therefore, the code at this point may cause communication abnormalities between the host and card
Signed-off-by: xiefei xf_hqu@163.com --- drivers/mmc/mmc.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/drivers/mmc/mmc.c b/drivers/mmc/mmc.c index 1af6af82e6..915f446973 100644 --- a/drivers/mmc/mmc.c +++ b/drivers/mmc/mmc.c @@ -2138,7 +2138,6 @@ static int mmc_select_mode_and_width(struct mmc *mmc, uint card_caps) mmc_set_card_speed(mmc, MMC_HS, true); else #endif - mmc_set_clock(mmc, mmc->legacy_speed, MMC_CLK_ENABLE);
for_each_mmc_mode_by_pref(card_caps, mwt) { for_each_supported_width(card_caps & mwt->widths,
On 6/21/2023 11:11 AM, xf_hqu@163.com wrote:
Caution: This is an external email. Please take care when clicking links or opening attachments. When in doubt, report the message using the 'Report this email' button
Has you meet any issues without removing this line? or this is just code inpsection?
BTW the upper "else" will met issue if you directly remove this line.
Regards, Peng.
-- 2.17.1
NACK.
Even except your intention, your patch didn't consider #ifdef ~ #endif.
Best Regards, Jaehoon Chung
Jaehoon Chung
Peng Fan
xf_hqu@163.com
