[U-Boot] [PATCH v2] EXYNOS: Clock: Add common function for pll rate calculation
Moved the common code to calculate pll clock rate to new function exynos_get_pll_clk().
Signed-off-by: Chander Kashyap chander.kashyap@linaro.org --- Changes from v1: - Author name changed arch/arm/cpu/armv7/exynos/clock.c | 102 ++++++++++++++----------------------- 1 file changed, 38 insertions(+), 64 deletions(-)
diff --git a/arch/arm/cpu/armv7/exynos/clock.c b/arch/arm/cpu/armv7/exynos/clock.c index 4f3b451..a042423 100644 --- a/arch/arm/cpu/armv7/exynos/clock.c +++ b/arch/arm/cpu/armv7/exynos/clock.c @@ -26,41 +26,19 @@ #include <asm/arch/clock.h> #include <asm/arch/clk.h>
-/* exynos4: return pll clock frequency */ -static unsigned long exynos4_get_pll_clk(int pllreg) +/* exynos: return pll clock frequency */ +static int exynos_get_pll_clk(int pllreg, unsigned int r, unsigned int k) { - struct exynos4_clock *clk = - (struct exynos4_clock *)samsung_get_base_clock(); - unsigned long r, m, p, s, k = 0, mask, fout; + unsigned long m, p, s = 0, mask, fout; unsigned int freq; - - switch (pllreg) { - case APLL: - r = readl(&clk->apll_con0); - break; - case MPLL: - r = readl(&clk->mpll_con0); - break; - case EPLL: - r = readl(&clk->epll_con0); - k = readl(&clk->epll_con1); - break; - case VPLL: - r = readl(&clk->vpll_con0); - k = readl(&clk->vpll_con1); - break; - default: - printf("Unsupported PLL (%d)\n", pllreg); - return 0; - } - /* * APLL_CON: MIDV [25:16] * MPLL_CON: MIDV [25:16] * EPLL_CON: MIDV [24:16] * VPLL_CON: MIDV [24:16] + * BPLL_CON: MIDV [25:16]: Exynos5 */ - if (pllreg == APLL || pllreg == MPLL) + if (pllreg == APLL || pllreg == MPLL || pllreg == BPLL) mask = 0x3ff; else mask = 0x1ff; @@ -92,13 +70,43 @@ static unsigned long exynos4_get_pll_clk(int pllreg) return fout; }
+/* exynos4: return pll clock frequency */ +static unsigned long exynos4_get_pll_clk(int pllreg) +{ + struct exynos4_clock *clk = + (struct exynos4_clock *)samsung_get_base_clock(); + unsigned long r, k = 0; + + switch (pllreg) { + case APLL: + r = readl(&clk->apll_con0); + break; + case MPLL: + r = readl(&clk->mpll_con0); + break; + case EPLL: + r = readl(&clk->epll_con0); + k = readl(&clk->epll_con1); + break; + case VPLL: + r = readl(&clk->vpll_con0); + k = readl(&clk->vpll_con1); + break; + default: + printf("Unsupported PLL (%d)\n", pllreg); + return 0; + } + + return exynos_get_pll_clk(pllreg, r, k); +} + /* exynos5: return pll clock frequency */ static unsigned long exynos5_get_pll_clk(int pllreg) { struct exynos5_clock *clk = (struct exynos5_clock *)samsung_get_base_clock(); - unsigned long r, m, p, s, k = 0, mask, fout; - unsigned int freq, pll_div2_sel, fout_sel; + unsigned long r, k = 0, fout; + unsigned int pll_div2_sel, fout_sel;
switch (pllreg) { case APLL: @@ -123,41 +131,7 @@ static unsigned long exynos5_get_pll_clk(int pllreg) return 0; }
- /* - * APLL_CON: MIDV [25:16] - * MPLL_CON: MIDV [25:16] - * EPLL_CON: MIDV [24:16] - * VPLL_CON: MIDV [24:16] - * BPLL_CON: MIDV [25:16] - */ - if (pllreg == APLL || pllreg == MPLL || pllreg == BPLL) - mask = 0x3ff; - else - mask = 0x1ff; - - m = (r >> 16) & mask; - - /* PDIV [13:8] */ - p = (r >> 8) & 0x3f; - /* SDIV [2:0] */ - s = r & 0x7; - - freq = CONFIG_SYS_CLK_FREQ; - - if (pllreg == EPLL) { - k = k & 0xffff; - /* FOUT = (MDIV + K / 65536) * FIN / (PDIV * 2^SDIV) */ - fout = (m + k / 65536) * (freq / (p * (1 << s))); - } else if (pllreg == VPLL) { - k = k & 0xfff; - /* FOUT = (MDIV + K / 1024) * FIN / (PDIV * 2^SDIV) */ - fout = (m + k / 1024) * (freq / (p * (1 << s))); - } else { - if (s < 1) - s = 1; - /* FOUT = MDIV * FIN / (PDIV * 2^(SDIV - 1)) */ - fout = m * (freq / (p * (1 << (s - 1)))); - } + fout = exynos_get_pll_clk(pllreg, r, k);
/* According to the user manual, in EVT1 MPLL and BPLL always gives * 1.6GHz clock, so divide by 2 to get 800MHz MPLL clock.*/
applied to u-boot-samsung
Chander Kashyap
Minkyu Kang
