[U-Boot] pull request: u-boot-uniphier/master
Hi Tom,
This pull request fixes three boards that have been broken since the recent nand-flash pull-req. Some other fixes, OF_CONTROL on SPL, and new SoC code, too.
The following changes since commit a679cc0118f6bec16c82d2c44f8a980f6f319bde:
tools/atmelimage.c: Fix warning when debug is enabled (2015-08-28 14:01:11 -0400)
git://git.denx.de/u-boot-uniphier.git master
for you to fetch changes up to f875bbb49111c308b90b9ca74d1b79f69498b278:
ARM: dts: uniphier: add ProXstream2 and PH1-LD6b SoC/board support (2015-08-31 00:29:23 +0900)
---------------------------------------------------------------- Masahiro Yamada (9): mtd: denali_spl: do not allocate page_buffer in .bss section ARM: uniphier: fix build error when CONFIG_DEBUG_LL is defined ARM: uniphier: remove unused macro ARM: uniphier: select SPL_DM rather than default in defconfig ARM: uniphier: enable SPL_OF_CONTROL serial: uniphier: drop platform data support ARM: dts: uniphier: sync with Linux ARM: dts: uniphier: add PH1-Pro5 SoC support ARM: dts: uniphier: add ProXstream2 and PH1-LD6b SoC/board support
arch/arm/Kconfig | 2 + arch/arm/dts/Makefile | 5 +- arch/arm/dts/uniphier-ph1-ld4-ref.dts | 29 +++--- arch/arm/dts/uniphier-ph1-ld4.dtsi | 95 +++++++++++++++---- arch/arm/dts/uniphier-ph1-ld6b-ref.dts | 59 ++++++++++++ arch/arm/dts/uniphier-ph1-ld6b.dtsi | 31 +++++++ arch/arm/dts/uniphier-ph1-pro4-ref.dts | 37 +++++--- arch/arm/dts/uniphier-ph1-pro4.dtsi | 108 ++++++++++++++++++---- arch/arm/dts/uniphier-ph1-pro5.dtsi | 216 +++++++++++++++++++++++++++++++++++++++++++ arch/arm/dts/uniphier-ph1-sld3-ref.dts | 39 +++++--- arch/arm/dts/uniphier-ph1-sld3.dtsi | 66 +++++++++---- arch/arm/dts/uniphier-ph1-sld8-ref.dts | 33 ++++--- arch/arm/dts/uniphier-ph1-sld8.dtsi | 95 +++++++++++++++---- arch/arm/dts/uniphier-pinctrl.dtsi | 105 +++++++++++++++++++++ arch/arm/dts/uniphier-proxstream2.dtsi | 241 ++++++++++++++++++++++++++++++++++++++++++++++++ arch/arm/mach-uniphier/ph1-ld4/Makefile | 1 - arch/arm/mach-uniphier/ph1-ld4/platdevice.c | 15 --- arch/arm/mach-uniphier/ph1-pro4/Makefile | 1 - arch/arm/mach-uniphier/ph1-pro4/platdevice.c | 15 --- arch/arm/mach-uniphier/ph1-sld3/Makefile | 1 - arch/arm/mach-uniphier/ph1-sld3/lowlevel_debug.S | 2 + arch/arm/mach-uniphier/ph1-sld3/platdevice.c | 1 - arch/arm/mach-uniphier/ph1-sld8/platdevice.c | 15 --- configs/ph1_ld4_defconfig | 1 - configs/ph1_pro4_defconfig | 1 - configs/ph1_sld3_defconfig | 1 - configs/ph1_sld8_defconfig | 1 - doc/README.uniphier | 10 +- drivers/mtd/nand/denali_spl.c | 32 +++---- drivers/serial/serial_uniphier.c | 41 +++----- include/configs/uniphier.h | 4 +- include/dm/platform_data/serial-uniphier.h | 18 ---- 32 files changed, 1079 insertions(+), 242 deletions(-) create mode 100644 arch/arm/dts/uniphier-ph1-ld6b-ref.dts create mode 100644 arch/arm/dts/uniphier-ph1-ld6b.dtsi create mode 100644 arch/arm/dts/uniphier-ph1-pro5.dtsi create mode 100644 arch/arm/dts/uniphier-pinctrl.dtsi create mode 100644 arch/arm/dts/uniphier-proxstream2.dtsi delete mode 100644 arch/arm/mach-uniphier/ph1-ld4/platdevice.c delete mode 100644 arch/arm/mach-uniphier/ph1-pro4/platdevice.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld3/platdevice.c delete mode 100644 arch/arm/mach-uniphier/ph1-sld8/platdevice.c delete mode 100644 include/dm/platform_data/serial-uniphier.h
On Mon, Aug 31, 2015 at 12:53:41AM +0900, Masahiro Yamada wrote:
Hi Tom,
Masahiro Yamada
