[U-Boot] [PATCH] lib:crc32: Allow setting of the initial crc32 value
The current approach set the initial value of crc32 calculation to zero, which is correct for calculating checksum of the whole chunk of data.
It however, lacks the flexibility, when one wants to calculate CRC32 of a file comprised of many smaller parts received separately.
In the proposed approach the output value is used as a starting condition for the proper crc32 calculation at crc32_wd function. This behavior is identical to the one provided by crc32() method implementation.
Additionally, comments were appropriately updated.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Marek Vasut marex@denx.de Cc: Simon Glass sjg@chromium.org --- include/hash.h | 2 +- include/u-boot/crc.h | 3 ++- lib/crc32.c | 2 +- 3 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/include/hash.h b/include/hash.h index dc21678..abf704d 100644 --- a/include/hash.h +++ b/include/hash.h @@ -101,7 +101,7 @@ int hash_command(const char *algo_name, int flags, cmd_tbl_t *cmdtp, int flag, * @algo_name: Hash algorithm to use * @data: Data to hash * @len: Lengh of data to hash in bytes - * @output: Place to put hash value + * @output: Place to put hash value - also the initial value (crc32) * @output_size: On entry, pointer to the number of bytes available in * output. On exit, pointer to the number of bytes used. * If NULL, then it is assumed that the caller has diff --git a/include/u-boot/crc.h b/include/u-boot/crc.h index 754ac72..7a87911 100644 --- a/include/u-boot/crc.h +++ b/include/u-boot/crc.h @@ -19,7 +19,8 @@ uint32_t crc32_no_comp (uint32_t, const unsigned char *, uint); * * @input: Input buffer * @ilen: Input buffer length - * @output: Place to put checksum result (4 bytes) + * @output: Place to provide initial CRC32 value and afterwards + * put checksum result (4 bytes) * @chunk_sz: Trigger watchdog after processing this many bytes */ void crc32_wd_buf(const unsigned char *input, uint ilen, diff --git a/lib/crc32.c b/lib/crc32.c index 9759212..f6266c7 100644 --- a/lib/crc32.c +++ b/lib/crc32.c @@ -257,7 +257,7 @@ void crc32_wd_buf(const unsigned char *input, unsigned int ilen, { uint32_t crc;
- crc = crc32_wd(0, input, ilen, chunk_sz); + crc = crc32_wd(*(uint32_t *)output, input, ilen, chunk_sz); crc = htonl(crc); memcpy(output, &crc, sizeof(crc)); }
Dear Lukasz,
In message 1399295277-28334-1-git-send-email-l.majewski@samsung.com you wrote:
- @algo_name: Hash algorithm to use
- @data: Data to hash
- @len: Lengh of data to hash in bytes
- @output: Place to put hash value
- @output: Place to put hash value - also the initial value (crc32)
- @output_size: On entry, pointer to the number of bytes available in
- @input: Input buffer
- @ilen: Input buffer length
- @output: Place to put checksum result (4 bytes)
- @output: Place to provide initial CRC32 value and afterwards
- @chunk_sz: Trigger watchdog after processing this many bytes
- crc = crc32_wd(*(uint32_t *)output, input, ilen, chunk_sz); crc = htonl(crc); memcpy(output, &crc, sizeof(crc));
This looks wrong to me, in a number of ways.
First, the *(uint32_t *)output cast, is likely to trigger unaligned accesses with the resulting problems on some platforms. Never, never ever cast a character pointer into something that requires any alignment!
Seconds, where exactly do you now initialize the CRC vlaue to start with 0 ?
Finally we should keep in mind (this is nothing caused by your patch, but when touching this area we really should consider it) that we have a number of (slightly) different CRC implementations thare cry for cleanup / unification: in addition to lib/crc32.c we have disk/part_efi.c (which provides efi_crc32()), drivers/mtd/ubi/crc32.c (which provides crc32_le() and crc32_be()), net/eth.c (which uses ether_crc()), we have BZ2_crc32Table[256] in lib/bzlib_private.h / lib/bzlib_crctable.c (which appears to be unsued), and we have tools/pblimage.c (which provides pbl_crc32()).
What a mess :-(
On Monday, May 05, 2014 at 07:47:30 PM, Wolfgang Denk wrote:
Dear Lukasz,
(crc32)
uint32_t crc;
Just an addition ... All those different implementations should use the hash_*() calls and this one central implementation.
Thanks for pointing this part out.
Hi Wolfgang,
Dear Lukasz,
available in
of bytes used.
afterwards
I admit that I was thinking about my (particular) platform.
Instead, I should memcpy the output to crc variable, which is defined as uint32_t, and pass it to the crc32_wd.
The proposed approach (with setting initial value of CRC32) is working fine with crc32() function at least in the DFU. Zeroing out of relevant variable is performed there.
The venerable crc32() implementation allows passing initial value of crc. As it is now, the hash_block() doesn't.
As Marek pointed out, we shall start using hash_block (from #include <hash.h>).
However, as I pointed out in this patch hash_block (at least for crc32) needs to be modified to preserve the functionality of bare metal crc32() function.
To unify, we also may be forced to introduce some flags - like output crc endianess (big, little). But this may wait for the moment.
What a mess :-(
+1
I sense alignment fault here. [...]
Best regards, Marek Vasut
Additionally comments were appropriately updated.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Marek Vasut marex@denx.de --- Changes for v2: - Replace casting from (u8*) to (u32*) with memcpy --- include/hash.h | 2 +- include/u-boot/crc.h | 3 ++- lib/crc32.c | 7 +++++-- 3 files changed, 8 insertions(+), 4 deletions(-)
diff --git a/include/hash.h b/include/hash.h index dc21678..abf704d 100644 --- a/include/hash.h +++ b/include/hash.h @@ -101,7 +101,7 @@ int hash_command(const char *algo_name, int flags, cmd_tbl_t *cmdtp, int flag, * @algo_name: Hash algorithm to use * @data: Data to hash * @len: Lengh of data to hash in bytes - * @output: Place to put hash value + * @output: Place to put hash value - also the initial value (crc32) * @output_size: On entry, pointer to the number of bytes available in * output. On exit, pointer to the number of bytes used. * If NULL, then it is assumed that the caller has diff --git a/include/u-boot/crc.h b/include/u-boot/crc.h index 754ac72..7a87911 100644 --- a/include/u-boot/crc.h +++ b/include/u-boot/crc.h @@ -19,7 +19,8 @@ uint32_t crc32_no_comp (uint32_t, const unsigned char *, uint); * * @input: Input buffer * @ilen: Input buffer length - * @output: Place to put checksum result (4 bytes) + * @output: Place to provide initial CRC32 value and afterwards + * put checksum result (4 bytes) * @chunk_sz: Trigger watchdog after processing this many bytes */ void crc32_wd_buf(const unsigned char *input, uint ilen, diff --git a/lib/crc32.c b/lib/crc32.c index 9759212..80e078f 100644 --- a/lib/crc32.c +++ b/lib/crc32.c @@ -255,9 +255,12 @@ uint32_t ZEXPORT crc32_wd (uint32_t crc, void crc32_wd_buf(const unsigned char *input, unsigned int ilen, unsigned char *output, unsigned int chunk_sz) { - uint32_t crc; + uint32_t crc = 0;
- crc = crc32_wd(0, input, ilen, chunk_sz); + if (*output) + memcpy(&crc, output, sizeof(crc)); + + crc = crc32_wd(crc, input, ilen, chunk_sz); crc = htonl(crc); memcpy(output, &crc, sizeof(crc)); }
- uint32_t crc;
- uint32_t crc = 0;
- if (*output)
Won't some sort of put_unaligned() work here ? The $crc is uint32_t afterall, so it might be a jiff faster. Please correct me if I'm wrong.
- crc = crc32_wd(crc, input, ilen, chunk_sz); crc = htonl(crc); memcpy(output, &crc, sizeof(crc));
Hi Marek,
- uint32_t crc;
- uint32_t crc = 0;
- if (*output)
We are concerned here with the use case of copying 4 bytes from unaligned buffer defined on some architectures.
I suppose, that the performance would be the same for both. However, since memcpy() is already used in this function, I would prefer to use it here.
Dear Lukasz Majewski,
In message 1399443021-11748-1-git-send-email-l.majewski@samsung.com you wrote:
- if (*output)
You can actually remove the "if (*output)" because output has always to be a non-null pointer, as we're going to store the result there.
Which means that you cannot use this to implicitly initialize crc =0, whichin turn means you MUST add porper initialization to all callers of that function.
Hi Wolfgang,
- if (*output)
I think, that the above statement would be correct if I had checked the if (output).
The problem here is that *output refers to uint8 and only first/last byte is checked. This is obviously wrong.
You are right that this check is not needed.
Ok.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Cc: Marek Vasut marex@denx.de --- Changes for v2: - Replace casting from (u8*) to (u32*) with memcpy Changes for v3: - Remove check on the output pointer - As precaution, zero out the output buffer --- common/hash.c | 6 ++++++ include/hash.h | 2 +- include/u-boot/crc.h | 3 ++- lib/crc32.c | 3 ++- 4 files changed, 11 insertions(+), 3 deletions(-)
diff --git a/common/hash.c b/common/hash.c index 7627b84..84c0a78 100644 --- a/common/hash.c +++ b/common/hash.c @@ -360,6 +360,12 @@ int hash_command(const char *algo_name, int flags, cmd_tbl_t *cmdtp, int flag, u8 vsum[HASH_MAX_DIGEST_SIZE]; void *buf;
+ /* + * This is a precaution for crc32, which allows output to be + * overloaded to provide initial value of crc32. + */ + memset(output, 0, sizeof(output)); + if (hash_lookup_algo(algo_name, &algo)) { printf("Unknown hash algorithm '%s'\n", algo_name); return CMD_RET_USAGE; diff --git a/include/hash.h b/include/hash.h index dc21678..abf704d 100644 --- a/include/hash.h +++ b/include/hash.h @@ -101,7 +101,7 @@ int hash_command(const char *algo_name, int flags, cmd_tbl_t *cmdtp, int flag, * @algo_name: Hash algorithm to use * @data: Data to hash * @len: Lengh of data to hash in bytes - * @output: Place to put hash value + * @output: Place to put hash value - also the initial value (crc32) * @output_size: On entry, pointer to the number of bytes available in * output. On exit, pointer to the number of bytes used. * If NULL, then it is assumed that the caller has diff --git a/include/u-boot/crc.h b/include/u-boot/crc.h index 754ac72..7a87911 100644 --- a/include/u-boot/crc.h +++ b/include/u-boot/crc.h @@ -19,7 +19,8 @@ uint32_t crc32_no_comp (uint32_t, const unsigned char *, uint); * * @input: Input buffer * @ilen: Input buffer length - * @output: Place to put checksum result (4 bytes) + * @output: Place to provide initial CRC32 value and afterwards + * put checksum result (4 bytes) * @chunk_sz: Trigger watchdog after processing this many bytes */ void crc32_wd_buf(const unsigned char *input, uint ilen, diff --git a/lib/crc32.c b/lib/crc32.c index 9759212..f57eb87 100644 --- a/lib/crc32.c +++ b/lib/crc32.c @@ -257,7 +257,8 @@ void crc32_wd_buf(const unsigned char *input, unsigned int ilen, { uint32_t crc;
- crc = crc32_wd(0, input, ilen, chunk_sz); + memcpy(&crc, output, sizeof(crc)); + crc = crc32_wd(crc, input, ilen, chunk_sz); crc = htonl(crc); memcpy(output, &crc, sizeof(crc)); }
Hi Lukasz,
Maybe I am missing something, but this doesn't seem necessary. In hash.h we have
hash_init() hash_update() hash_finish()
which permits you to pass more data through a hash function. Doesn't this already do what you want?
What is missing is probably command-line access to this API. Something like:
hash init <envvar>, <algo> hash update <envvar>, <data>, <size> hash finish <envvar>, [*]<result>
or similar.
Hi Simon,
Hi Lukasz,
I thought, that I would get away with replacing crc32() function call with similar one - hash_block(). As it was pointed out it doesn't itself provide the same functionality.
However, I will try to implement the solution you suggested. Thanks for tip.
or similar.
Lukasz Majewski
