[U-Boot-Users] [PATCH] PPC: Some PCI generalization in the global_data structure.
The global_data structure has no well defined method of the PCI clocks and other PCI related variables declaration. This patch adds initial support for the generalized method based on CONFIG_PCI usage. At present it only affects when CONFIG_MPC8272 or CONFIG_MPC8272_FAMILY defined.
Signed-off-by: Matvejchikov Ilya matvejchikov@gmail.com --- include/asm-ppc/global_data.h | 5 +++++ 1 files changed, 5 insertions(+), 0 deletions(-)
diff --git a/include/asm-ppc/global_data.h b/include/asm-ppc/global_data.h index c5ac658..ac3e719 100644 --- a/include/asm-ppc/global_data.h +++ b/include/asm-ppc/global_data.h @@ -42,6 +42,11 @@ typedef struct global_data { unsigned long baudrate; unsigned long cpu_clk; /* CPU clock in Hz! */ unsigned long bus_clk; +#ifdef CONFIG_PCI +#if defined(CONFIG_MPC8272) || defined(CONFIG_MPC8272_FAMILY) + u32 pci_clk; +#endif +#endif #if defined(CONFIG_8xx) unsigned long brg_clk; #endif
In message 8496f91a0807130506q329cc35h7934d756fee6b027@mail.gmail.com you wrote:
- u32 pci_clk;
This makes no sense to me.
Please keep in mind that the global_data stuff is intended for, and only for, holding global information while we are still running from flash (i. e. before relocation) so that we have neiter a writabel data segment nor a valid bss segment.
PCI initialization always happens *after* relocation to RAM, therefore no PCI related variables are ever needed in the global_data structure.
Rejected.
Yes, I know it. But I only meant pci_clk for some cpus and other PCI related things (pciexp1_clk, pciexp2_clk for MPC837x etc)... At this moment we have in the global_data such things as:
struct global_data { ... #ifdef some_cpu1 u32 pci_clk; ... #enif ... #ifdef some_cpu2 unsigned long pci_clk; ... #endif
#ifdef some_cpu3 u32 pci_clk; ... #endif }
Does it is right approach? What do I do to use pci_clk for the mpc8272? May be it is more correctly to use the next form of declaration:
struct global_data { #ifdef CONFIG_PCI u32 pci_clk; #ifdef some_cpu1 /* cpu1 specific pci variables */ #endif #endif
Thanks.
Hm... I should have checked the code first before replying.
So we already have this in the current code. What a crap.
Kim, Grant, John, can you please try and prepare patches (for the next release, then) to get rid of PCI related information from gd_t ?
Hm... looking closer there is a lot of other stuff there which most probably does not belong there either: TSEC Clocks? PCIe Clocks? board_type? Please check and comment...
- u32 pci_clk;
This looks kind of broken to me.
I think you should add this in the "if defined(CONFIG_CPM2)" branch and just make it depend on "ifdef CONFIG_PCI".
Matvejchikov Ilya
