Raspberry Pi won’t boot from compressed subvolume (BTRFS)
Hello u-boot team,
I’ve been experimenting for about a year with a NixOS-based Raspberry Pi image, with the end goal of a zstd-compressed image that uses BTRFS subvolumes, having the root filesystem at @ and boot at @boot (with several other subvolumes). The NixOS Raspberry Pi images use u-boot by default. I’ve started a few discussions in the NixOS community as I learn and iterate: https://discourse.nixos.org/t/raspberry-pi-nixos-on-btrfs-root/14081 and I’ve made my code available at: https://github.com/n8henrie/nixos-btrfs-pi . I’m sure it’s obvious (or will be soon) that I’m a hobbyist, a novice with NixOS, and that I understand very little about u-boot and bootloaders in general, so I hope you can be patient as I humbly ask for someone to point me in the right direction.
For reference, the official NixOS code for generating u-boot images is here: https://github.com/NixOS/nixpkgs/blob/3d4e586313d292c9e764a8e88a1fdccb16ffb2...
I’ve made a lot of progress, including an image that reliably boots from @boot to the @ root subvolume with the u-boot configuration:
CONFIG_CMD_BTRFS=y CONFIG_ZSTD=y CONFIG_BOOTCOMMAND="setenv boot_prefixes / /boot/ /@/ /@boot/; run distro_bootcmd;"
with kernel params: "root=LABEL=NIXOS_SD" "rootfstype=btrfs" "rootflags=subvol=@"
Unfortunately, after the initial boot and going through the initial OS installation steps, if I have compression enabled, it reboots into a boot loop with the following error messages:
Scanning mmc 0:2... Found /@boot/extlinux/extlinux.conf Retrieving file: /@boot/extlinux/extlinux.conf 2938 bytes read in 27 ms (105.5 KiB/s)
1 NixOS Default 2 NixOS Configuration 4 (2022-02-24 21:34 22.05pre356135.7f9b6c2babf) 3 NixOS Configuration 3 (2022-02-25 03:59 22.05pre356435.7/9b6eZbabf) 4: NixOS Configuration 2 (2022-02-24 21:34 22.05pre356435.7/9b6c2babr) 5: NixOS Enter choice: 1: NixOS - Default Retrieving file: /@boot/extlinux/..nixos/zhbharzhzqga617uc37uk0g6q1bx891u-initrd-linux-5.10.101-initrd 20588420 bytes read in 1910 ms (10.3 MiB/s) Retrieving file: /@boot/extlinux/..nixos/6c1m6j0k1gmjrmikOyyizariiry?Zlqr-linux-5.10.101-Image 50629120 bytes read in 6863 ms (7 MiB/s) append: init-mix/store/pikl8ju4077iaix36n8mifzu6l6rcajz-nixos-system-nixpi-22.05p re356435-7/9b6eZbabf/init console=tty1 console=ttyAMAO console=ttyS0, 1115200 root= LABEL=-NIXOS_SD rootfstype=btrfs rootflags=subvol=@ loglevel=4 Retrieving file: /@boot/extlinux/../nixos/6c16j0k1gmjrmikOyyizari1ry72lqr-linux-5.10.101-dtbs/broadcon/bcn2837-rpi-3-b.dtb 14310 bytes read in 66 ms (210.9 KiB/s) Moving Image from 0x80000 to 0x200000, end=32f0000 ## Flattened Device Tree blob at 03700000 Booting using the fdt blob at 0x3700000 Using Device Tree in place at 0000000003700000 end 00000000037067e5 fdt_find_or_add_subnode: memory: FDT_ERR_BADSTRUCTURE ERROR: arch-specific fdt fixup failed - must RESET the board to recover.
FDT creation failed! resetting ...
This happens even though I have CONFIG_ZSTD=y. If I do *not* enable compression (in my BTRFS mount options), it reboots normally and everything works!
I may have made some OCR / C&P errors above; I’ve posted some pictures of the error messages (and similar discussion to this email, with no responses) here: https://discourse.nixos.org/t/btrfs-pi-wont-boot-from-compressed-subvolume/1...
I’m not currently using BTRFS RAID, just a single device. One of my other (x86_64) machines uses a similar setup with @, @boot, and zstd-compression with grub and works well, so I’m hoping this is also possible with u-boot.
Seeing that the errors mention the FDT and fixup, I tried CONFIG_ARCH_FIXUP_FDT_MEMORY with both =y and =n without interesting changes to the error messages.
What I’m assuming, based on the above, is that re-writing the @boot subvolume with compression is moving the location of the device tree files and that u-boot is no longer able to find the necessary files (some of which I think may also be in the nix store in the @nix subvolume).
Does that sound like a reasonable guess as to what is going on? If so, are there config options or settings that I might be able to use to help u-boot find the necessary files after things are re-written with compression?
Many thanks in advance for your time and attention, and thanks for your hard work on u-boot!
On 22/05/2022 17:36, Nathan Henrie wrote:
Hello u-boot team,
Just a random guess, but bcn2837-rpi-3-b.dtb does look right, the DTB should be called bcm2837-rpi-3-b.dtb
Then you try to fixup that address which has no valid DTB and fails.
Anyway to me that sounds like a nixOS problem rather then a U-Boot problem. I'm not even sure which version of U-Boot you are using and if it has any patches on top of the upstream version.
Regards, Matthias
Hi Matthias, thanks for your time and response.
Sorry, that was an OCR error (wasn't sure how to screenshot or log to a file in this context, so pictures -> OCR seemed like my best option, pictures available here: https://discourse.nixos.org/t/btrfs-pi-wont-boot-from-compressed-subvolume/1...). It is indeed `bc*m*`... in the actual output.
Sorry, I included the link to the relevant code (https://github.com/NixOS/nixpkgs/blob/3d4e586313d292c9e764a8e88a1fdccb16ffb2...) but should have included those details:
``` defaultSrc = fetchurl { url = "ftp://ftp.denx.de/pub/u-boot/u-boot-${defaultVersion}.tar.bz2"; hash = "sha256-gbRUMifbIowD+KG/XdvIE7C7j2VVzkYGTvchpvxoBBM="; defaultVersion = "2022.01"; ```
By default it will have two patches: - https://github.com/NixOS/nixpkgs/blob/master/pkgs/misc/uboot/0001-configs-rp... - https://github.com/NixOS/nixpkgs/blob/master/pkgs/misc/uboot/0001-rpi-Copy-p...
The latter looks like it might be relevant.
I was suspicious about it being a u-boot issue because everything works fine by default, it's only when I enable zstd compression that I get the above errors. However I'm pretty new to NixOS and obviously know little about u-boot, so you may well be correct!
Nate
On Wed, May 25, 2022 at 2:58 AM Matthias Brugger matthias.bgg@gmail.com wrote:
Hello u-boot team,
Regards, Matthias
Matthias Brugger
Nathan Henrie
