[PATCH 0/2] board/freescale/vid: rework of VID support
The VID code does not properly set the voltages on all chips. It does not properly reports voltage changes. For IR, the read accuracy was incorrect and for the LTC the step width was too wide.
- This patchset rework the vid driver and make LTC channel use configurable to deal properly with single and dual channel setups. - Add support for LTC7132
Wasim Khan (2): board/freescale/vid: rework of VID support board/freescale/vid: Add support for LTC7132 voltage regulator
.../include/asm/arch-fsl-layerscape/immap_lsch3.h | 19 +- board/freescale/common/vid.c | 685 +++++++++++---------- board/freescale/common/vid.h | 42 +- 3 files changed, 423 insertions(+), 323 deletions(-)
This patchset fix above problems and also make LTC channel use configurable to deal properly with single and dual channel setups.
Signed-off-by: Dan Nica dan.nica@nxp.com Signed-off-by: Heinz Wrobel Heinz.Wrobel@nxp.com Signed-off-by: Wasim Khan wasim.khan@nxp.com --- .../include/asm/arch-fsl-layerscape/immap_lsch3.h | 19 +- board/freescale/common/vid.c | 662 +++++++++++---------- board/freescale/common/vid.h | 42 +- 3 files changed, 403 insertions(+), 320 deletions(-)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h index baa9fa8..6147fad 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/immap_lsch3.h @@ -2,7 +2,7 @@ /* * LayerScape Internal Memory Map * - * Copyright 2017-2019 NXP + * Copyright 2017-2020 NXP * Copyright 2014 Freescale Semiconductor, Inc. */
@@ -324,15 +324,14 @@ struct ccsr_gur { u32 gpporcr3; u32 gpporcr4; u8 res_030[0x60-0x30]; -#define FSL_CHASSIS3_DCFG_FUSESR_VID_MASK 0x1F -#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK 0x1F -#if defined(CONFIG_ARCH_LS1088A) -#define FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT 25 -#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT 20 -#else -#define FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT 2 -#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT 7 -#endif +#define FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT 25 +#define FSL_CHASSIS3_DCFG_FUSESR_VID_MASK 0x1F +#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT 20 +#define FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK 0x1F +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_SHIFT 2 +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_MASK 0x1F +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_SHIFT 7 +#define FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_MASK 0x1F u32 dcfg_fusesr; /* Fuse status register */ u8 res_064[0x70-0x64]; u32 devdisr; /* Device disable control 1 */ diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index ed0d9b4..0ba672d 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -1,6 +1,7 @@ // SPDX-License-Identifier: GPL-2.0+ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2020 NXP */
#include <common.h> @@ -20,6 +21,8 @@ #include <linux/delay.h> #include "vid.h"
+DECLARE_GLOBAL_DATA_PTR; + int __weak i2c_multiplexer_select_vid_channel(u8 channel) { return 0; @@ -42,10 +45,8 @@ int __weak board_adjust_vdd(int vdd) return 0; }
-#if defined(CONFIG_VOL_MONITOR_IR36021_SET) || \ - defined(CONFIG_VOL_MONITOR_IR36021_READ) /* - * Get the i2c address configuration for the IR regulator chip + * Get the i2c address configuration for the regulator chip * * There are some variance in the RDB HW regarding the I2C address configuration * for the IR regulator chip, which is likely a problem of external resistor @@ -56,9 +57,14 @@ int __weak board_adjust_vdd(int vdd) * 0x08 (Verified on T1040RDB-PA,T4240RDB-PB,X-T4240RDB-16GPA) * 0x09 (Verified on T1040RDB-PA) * 0x38 (Verified on T2080QDS, T2081QDS, T4240RDB) + * + * For other types of regulator chips, we check the IDs before we + * return the address to avoid making damaging mistakes */ -static int find_ir_chip_on_i2c(void) +static int find_vid_chip_on_i2c(void) { +#if defined(CONFIG_VOL_MONITOR_IR36021_READ) || \ + defined(CONFIG_VOL_MONITOR_IR36021_SET) int i2caddress; int ret; u8 byte; @@ -81,33 +87,75 @@ static int find_ir_chip_on_i2c(void) ret = dm_i2c_read(dev, IR36021_MFR_ID_OFFSET, (void *)&byte, sizeof(byte)); #endif - if ((ret >= 0) && (byte == IR36021_MFR_ID)) + if (!ret && byte == IR36021_MFR_ID) + return i2caddress; + } +#endif +#if defined(CONFIG_VOL_MONITOR_LTC3882_READ) || \ + defined(CONFIG_VOL_MONITOR_LTC3882_SET) + int i2caddress = I2C_VOL_MONITOR_ADDR; + int ret; + u8 buf[8]; +#ifdef CONFIG_DM_I2C + struct udevice *dev; +#endif + +#ifndef CONFIG_DM_I2C + ret = i2c_read(i2caddress, + LTC3882_MFR_ID, 1, (void *)&buf[0], + 4); +#else + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); + if (!ret) + ret = dm_i2c_read(dev, LTC3882_MFR_ID, + (void *)&buf[0], 4); +#endif + if (!ret && memcmp(buf, "\3LTC", 4) == 0) { +#ifndef CONFIG_DM_I2C + ret = i2c_read(i2caddress, + LTC3882_MFR_MODEL, 1, (void *)&buf[0], + 8); +#else + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); + if (!ret) + ret = dm_i2c_read(dev, LTC3882_MFR_MODEL, + (void *)&buf[0], 8); +#endif + if (!ret && memcmp(buf, "\7LTC3882", 8) == 0) return i2caddress; } +#endif return -1; } -#endif
/* Maximum loop count waiting for new voltage to take effect */ -#define MAX_LOOP_WAIT_NEW_VOL 100 +#define MAX_LOOP_WAIT_NEW_VOL 100 /* ms due to udelay(1000) */ /* Maximum loop count waiting for the voltage to be stable */ -#define MAX_LOOP_WAIT_VOL_STABLE 100 +#define MAX_LOOP_WAIT_VOL_STABLE 100 /* ms due to udelay(1000) */ /* - * read_voltage from sensor on I2C bus - * We use average of 4 readings, waiting for WAIT_FOR_ADC before - * another reading - */ -#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ - -/* If an INA220 chip is available, we can use it to read back the voltage + * If an INA220 chip is available, we can use it to read back the voltage * as it may have a higher accuracy than the IR chip for the same purpose */ #ifdef CONFIG_VOL_MONITOR_INA220 +#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ #define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ -#define ADC_MIN_ACCURACY 4 -#else +#define ADC_MIN_ACCURACY 4 /* mV */ +#endif +#ifdef CONFIG_VOL_MONITOR_IR36021_READ +#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ #define WAIT_FOR_ADC 138 /* wait for 138 microseconds for ADC */ -#define ADC_MIN_ACCURACY 4 +#define ADC_MIN_ACCURACY IR_ADC_MIN_ACCURACY +#define VDD_STEP_UP IR_VDD_STEP_UP +#define VDD_STEP_DOWN IR_VDD_STEP_DOWN +#endif +#ifdef CONFIG_VOL_MONITOR_LTC3882_READ +#define WAIT_FOR_ADC 0 +#define ADC_MIN_ACCURACY LTC_ADC_MIN_ACCURACY +#define VDD_STEP_UP LTC_VDD_STEP_UP +#define VDD_STEP_DOWN LTC_VDD_STEP_DOWN +#endif +#if VDD_STEP_UP < 1 || VDD_STEP_DOWN < 1 +#error VDD_STEP values must be > 0! #endif
#ifdef CONFIG_VOL_MONITOR_INA220 @@ -122,14 +170,14 @@ static int read_voltage_from_INA220(int i2caddress)
for (i = 0; i < NUM_READINGS; i++) { #ifndef CONFIG_DM_I2C - ret = i2c_read(I2C_VOL_MONITOR_ADDR, + ret = i2c_read(i2caddress, I2C_VOL_MONITOR_BUS_V_OFFSET, 1, - (void *)&buf, 2); + (void *)&buf[0], 2); #else - ret = i2c_get_chip_for_busnum(0, I2C_VOL_MONITOR_ADDR, 1, &dev); + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) ret = dm_i2c_read(dev, I2C_VOL_MONITOR_BUS_V_OFFSET, - (void *)&buf, 2); + (void *)&buf[0], 2); #endif if (ret) { printf("VID: failed to read core voltage\n"); @@ -197,7 +245,7 @@ static int read_voltage_from_IR(int i2caddress) voltage_read /= NUM_READINGS;
/* Compensate for a board specific voltage drop between regulator and - * SoC before converting into an IR VID value + * SoC before converting into a VID value */ voltage_read -= board_vdd_drop_compensation();
@@ -206,43 +254,47 @@ static int read_voltage_from_IR(int i2caddress) #endif
#ifdef CONFIG_VOL_MONITOR_LTC3882_READ -/* read the current value of the LTC Regulator Voltage */ +/* read the current value of the LTC Regulator Voltage. + * This will only read the first channel for dual channel setups + */ static int read_voltage_from_LTC(int i2caddress) { int ret, vcode = 0; - u8 chan = PWM_CHANNEL0; + u8 chan = LTC3882_VID_CHANNEL; + u8 buf[2]; +#ifdef CONFIG_DM_I2C + struct udevice *dev; +#endif
-#ifndef CONFIG_DM_I2C /* select the PAGE 0 using PMBus commands PAGE for VDD*/ - ret = i2c_write(I2C_VOL_MONITOR_ADDR, - PMBUS_CMD_PAGE, 1, &chan, 1); +#ifndef CONFIG_DM_I2C + ret = i2c_write(i2caddress, + LTC3882_PAGE, 1, &chan, 1); #else - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(0, I2C_VOL_MONITOR_ADDR, 1, &dev); + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) - ret = dm_i2c_write(dev, PMBUS_CMD_PAGE, &chan, 1); + ret = dm_i2c_write(dev, LTC3882_PAGE, &chan, 1); #endif if (ret) { - printf("VID: failed to select VDD Page 0\n"); + printf("VID: failed to select VDD Page\n"); return ret; }
-#ifndef CONFIG_DM_I2C /*read the output voltage using PMBus command READ_VOUT*/ - ret = i2c_read(I2C_VOL_MONITOR_ADDR, - PMBUS_CMD_READ_VOUT, 1, (void *)&vcode, 2); +#ifndef CONFIG_DM_I2C + ret = i2c_read(i2caddress, + LTC3882_READ_VOUT, 1, (void *)&buf[0], 2); #else - ret = dm_i2c_read(dev, PMBUS_CMD_READ_VOUT, (void *)&vcode, 2); - if (ret) { - printf("VID: failed to read the volatge\n"); - return ret; - } + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); + if (!ret) + ret = dm_i2c_read(dev, LTC3882_READ_VOUT, + (void *)&buf[0], 2); #endif if (ret) { - printf("VID: failed to read the volatge\n"); + printf("VID: failed to read the voltage\n"); return ret; } + vcode = (buf[1] << 8) | buf[0];
/* Scale down to the real mV as LTC resolution is 1/4096V,rounding up */ vcode = DIV_ROUND_UP(vcode * 1000, 4096); @@ -255,18 +307,24 @@ static int read_voltage(int i2caddress) { int voltage_read; #ifdef CONFIG_VOL_MONITOR_INA220 - voltage_read = read_voltage_from_INA220(i2caddress); + voltage_read = read_voltage_from_INA220(I2C_VOL_MONITOR_ADDR); #elif defined CONFIG_VOL_MONITOR_IR36021_READ voltage_read = read_voltage_from_IR(i2caddress); #elif defined CONFIG_VOL_MONITOR_LTC3882_READ voltage_read = read_voltage_from_LTC(i2caddress); #else - return -1; + voltage_read = -1; #endif + if (voltage_read >= 0) { + /* Compensate for a board specific voltage drop between + * regulator and SoC before converting into an IR VID value + */ + voltage_read -= board_vdd_drop_compensation(); + } + return voltage_read; }
-#ifdef CONFIG_VOL_MONITOR_IR36021_SET /* * We need to calculate how long before the voltage stops to drop * or increase. It returns with the loop count. Each loop takes @@ -287,8 +345,9 @@ static int wait_for_new_voltage(int vdd, int i2caddress) * point to a serious failure in the regulator system. */ for (timeout = 0; - abs(vdd - vdd_current) > (IR_VDD_STEP_UP + IR_VDD_STEP_DOWN) && + abs(vdd - vdd_current) > ADC_MIN_ACCURACY && timeout < MAX_LOOP_WAIT_NEW_VOL; timeout++) { + udelay(1000); vdd_current = read_voltage(i2caddress); } if (timeout >= MAX_LOOP_WAIT_NEW_VOL) { @@ -307,18 +366,18 @@ static int wait_for_voltage_stable(int i2caddress) int timeout, vdd_current, vdd;
vdd = read_voltage(i2caddress); - udelay(NUM_READINGS * WAIT_FOR_ADC); + udelay(1000);
/* wait until voltage is stable */ vdd_current = read_voltage(i2caddress); /* The maximum timeout is - * MAX_LOOP_WAIT_VOL_STABLE * NUM_READINGS * WAIT_FOR_ADC + * MAX_LOOP_WAIT_VOL_STABLE * (1000µs + NUM_READINGS * WAIT_FOR_ADC) */ for (timeout = MAX_LOOP_WAIT_VOL_STABLE; abs(vdd - vdd_current) > ADC_MIN_ACCURACY && timeout > 0; timeout--) { vdd = vdd_current; - udelay(NUM_READINGS * WAIT_FOR_ADC); + udelay(1000); vdd_current = read_voltage(i2caddress); } if (timeout == 0) @@ -326,29 +385,49 @@ static int wait_for_voltage_stable(int i2caddress) return vdd_current; }
+#ifdef CONFIG_VOL_MONITOR_IR36021_SET /* Set the voltage to the IR chip */ static int set_voltage_to_IR(int i2caddress, int vdd) { int wait, vdd_last; int ret; u8 vid; + u8 buf; +#ifdef CONFIG_DM_I2C + struct udevice *dev; +#endif
- /* Compensate for a board specific voltage drop between regulator and - * SoC before converting into an IR VID value - */ - vdd += board_vdd_drop_compensation(); -#ifdef CONFIG_FSL_LSCH2 - vid = DIV_ROUND_UP(vdd - 265, 5); + /* check if IR chip works in Intel mode*/ +#ifndef CONFIG_DM_I2C + ret = i2c_read(i2caddress, + IR36021_INTEL_MODE_OFFSET, + 1, (void *)&buf, 1); #else - vid = DIV_ROUND_UP(vdd - 245, 5); + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); + if (!ret) + ret = dm_i2c_read(dev, IR36021_INTEL_MODE_OFFSET, + (void *)&buf, 1); #endif + if (ret) { + printf("VID: failed to read IR chip mode.\n"); + return -1; + } + if ((buf & IR36021_MODE_MASK) != IR36021_INTEL_MODE) { + /* AMD SVI2 mode. */ + /* An increase by 5 in the VID value causes a decrease + * by 4/128V in the output rail, -6.25mV per step. + * The scale appears to be 0V based starting from 0xf8. + */ + vid = 248 - DIV_ROUND_UP(vdd * 4, 25); + } else { + /* Intel mode */ + vid = DIV_ROUND_UP(vdd - 245, 5); + }
#ifndef CONFIG_DM_I2C ret = i2c_write(i2caddress, IR36021_LOOP1_MANUAL_ID_OFFSET, 1, (void *)&vid, sizeof(vid)); #else - struct udevice *dev; - ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) ret = dm_i2c_write(dev, IR36021_LOOP1_MANUAL_ID_OFFSET, @@ -362,7 +441,8 @@ static int set_voltage_to_IR(int i2caddress, int vdd) wait = wait_for_new_voltage(vdd, i2caddress); if (wait < 0) return -1; - debug("VID: Waited %d us\n", wait * NUM_READINGS * WAIT_FOR_ADC); + debug("VID: Waited %d us\n", + wait * (1000 + NUM_READINGS * WAIT_FOR_ADC));
vdd_last = wait_for_voltage_stable(i2caddress); if (vdd_last < 0) @@ -370,53 +450,87 @@ static int set_voltage_to_IR(int i2caddress, int vdd) debug("VID: Current voltage is %d mV\n", vdd_last); return vdd_last; } - #endif
-#ifdef CONFIG_VOL_MONITOR_LTC3882_SET -/* this function sets the VDD and returns the value set */ -static int set_voltage_to_LTC(int i2caddress, int vdd) +#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) +/* Helper function to write a mV value as LTC L16 into the chip, + * returning a boolean for success + */ +static int write_l16_mV_LTC3882(int i2caddress, int cmd, int mv) { - int ret, vdd_last, vdd_target = vdd; - int count = 100, temp = 0; - - /* Scale up to the LTC resolution is 1/4096V */ - vdd = (vdd * 4096) / 1000; + int l16; + int ret; + u8 buf[5]; +#ifdef CONFIG_DM_I2C + struct udevice *dev; +#endif
- /* 5-byte buffer which needs to be sent following the - * PMBus command PAGE_PLUS_WRITE. + /* Scale mV to L16 */ + l16 = mv; + l16 <<= 12; + l16 /= 1000; + debug("VID: cmd 0x%02x voltage write 0x%04x\n", cmd, l16); + buf[0] = 4; + buf[1] = LTC3882_VID_CHANNEL; + buf[2] = cmd; + buf[3] = (l16 & 0xff); + buf[4] = (l16 >> 8); + + /* This code assumes that both channels run the very + * SAME voltage. This is likely true for LS2 style + * devices. For any other configuration, all hell will + * break loose! */ - u8 buff[5] = {0x04, PWM_CHANNEL0, PMBUS_CMD_VOUT_COMMAND, - vdd & 0xFF, (vdd & 0xFF00) >> 8}; - - /* Write the desired voltage code to the regulator */ #ifndef CONFIG_DM_I2C - ret = i2c_write(I2C_VOL_MONITOR_ADDR, - PMBUS_CMD_PAGE_PLUS_WRITE, 1, (void *)&buff, 5); + ret = i2c_write(i2caddress, + LTC3882_PAGE_PLUS_WRITE, 1, (void *)&buf, 5); #else - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(0, I2C_VOL_MONITOR_ADDR, 1, &dev); + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) - ret = dm_i2c_write(dev, PMBUS_CMD_PAGE_PLUS_WRITE, - (void *)&buff, 5); + ret = dm_i2c_write(dev, + LTC3882_PAGE_PLUS_WRITE, (void *)&buf, 5); +#endif +#ifdef LTC3882_VID_CHANNEL2 + if (!ret) { + buf[1] = LTC3882_VID_CHANNEL2; +#ifndef CONFIG_DM_I2C + ret = i2c_write(i2caddress, + LTC3882_PAGE_PLUS_WRITE, 1, (void *)&buf, 5); +#else + ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); + if (!ret) + ret = dm_i2c_write(dev, LTC3882_PAGE_PLUS_WRITE, + (void *)&buf, 5); +#endif + } +#endif + return ret; +} #endif + +#ifdef CONFIG_VOL_MONITOR_LTC3882_SET +/* this function sets the VDD and returns the value set */ +static int set_voltage_to_LTC(int i2caddress, int vdd) +{ + int wait, ret, vdd_last; + + /* Write the desired voltage code to the regulator */ + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_COMMAND, + vdd); if (ret) { - printf("VID: I2C failed to write to the volatge regulator\n"); + printf("VID: I2C failed to write to the voltage regulator\n"); return -1; }
- /* Wait for the volatge to get to the desired value */ - do { - vdd_last = read_voltage_from_LTC(i2caddress); - if (vdd_last < 0) { - printf("VID: Couldn't read sensor abort VID adjust\n"); - return -1; - } - count--; - temp = vdd_last - vdd_target; - } while ((abs(temp) > 2) && (count > 0)); + /* Wait for the voltage to get to the desired value */ + wait = wait_for_new_voltage(vdd, i2caddress); + if (wait < 0) + return -1;
+ vdd_last = wait_for_voltage_stable(i2caddress); + if (vdd_last < 0) + return -1; return vdd_last; } #endif @@ -425,6 +539,10 @@ static int set_voltage(int i2caddress, int vdd) { int vdd_last = -1;
+ /* Compensate for a board specific voltage drop between regulator and + * SoC before converting into a VID value + */ + vdd += board_vdd_drop_compensation(); #ifdef CONFIG_VOL_MONITOR_IR36021_SET vdd_last = set_voltage_to_IR(i2caddress, vdd); #elif defined CONFIG_VOL_MONITOR_LTC3882_SET @@ -435,22 +553,113 @@ static int set_voltage(int i2caddress, int vdd) return vdd_last; }
-#ifdef CONFIG_FSL_LSCH3 +#if defined(CONFIG_FSL_LSCH3) +static bool soc_has_lowbitsinfusesr(struct ccsr_gur *gur) +{ + u32 svr = in_le32(&gur->svr); + + /* LS2088A derivatives have different FUSESR */ + switch (SVR_SOC_VER(svr)) { + case SVR_LS2088A: + case SVR_LS2048A: + case SVR_LS2084A: + case SVR_LS2044A: + case SVR_LX2160A: + case SVR_LX2120A: + case SVR_LX2080A: + return true; + } + + return false; +} +#endif /* CONFIG_FSL_LSCH3 */ + +int vid_set_mv_limits(int absmax, + int marginhigh, int marginlow, + int ovfault, int ovwarn, + int uvwarn, int uvfault) +{ + int ret; + int i2caddress; + + ret = i2c_multiplexer_select_vid_channel(I2C_MUX_CH_VOL_MONITOR); + if (ret) { + debug("VID: I2C failed to switch channel\n"); + return ret; + } + i2caddress = find_vid_chip_on_i2c(); + +#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) + if (i2caddress >= 0) { + /* We need to program the voltage limits + * properly, or the chip may freak out on + * VID changes. + */ + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_MAX, + absmax); + if (!ret) { + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_MARGIN_HIGH, + marginhigh); + } + if (!ret) { + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_MARGIN_LOW, + marginlow); + } + if (!ret) { + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_OV_FAULT_LIMIT, + ovfault); + } + if (!ret) { + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_OV_WARN_LIMIT, + ovwarn); + } + if (!ret) { + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_UV_WARN_LIMIT, + uvwarn); + } + if (!ret) { + ret = write_l16_mV_LTC3882(i2caddress, + LTC3882_VOUT_UV_FAULT_LIMIT, + uvfault); + } + } else { + ret = -1; + } +#endif /* CONFIG_VOL_MONITOR_LTC3882_SET */ + if (ret) + printf("VID: Setting voltage limits failed! VID regulation may not be stable!\n"); + + i2c_multiplexer_select_vid_channel(I2C_MUX_CH_DEFAULT); + + return ret; +} + int adjust_vdd(ulong vdd_override) { - int re_enable = disable_interrupts(); +#if defined(CONFIG_FSL_LSCH2) || defined(CONFIG_FSL_LSCH3) struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); - u32 fusesr; -#if defined(CONFIG_VOL_MONITOR_IR36021_SET) || \ - defined(CONFIG_VOL_MONITOR_IR36021_READ) - u8 vid, buf; #else - u8 vid; + ccsr_gur_t __iomem *gur = + (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); #endif + u32 fusesr; + u8 vid; int vdd_target, vdd_current, vdd_last; int ret, i2caddress; unsigned long vdd_string_override; char *vdd_string; + /* Note that these are all possible values for the FUSESR + * register. Specific SoCs will only ever reference their + * own subset. Manual overrides can be used for settings + * outside the specification and need to be used carefully. + */ +#ifdef CONFIG_FSL_LSCH3 #ifdef CONFIG_ARCH_LX2160A static const u16 vdd[32] = { 8250, @@ -486,9 +695,8 @@ int adjust_vdd(ulong vdd_override) 0, /* reserved */ 0, /* reserved */ }; -#else -#ifdef CONFIG_ARCH_LS1088A - static const uint16_t vdd[32] = { +#elif defined(CONFIG_ARCH_LS1088A) + static const u16 vdd[32] = { 10250, 9875, 9750, @@ -522,9 +730,8 @@ int adjust_vdd(ulong vdd_override) 0, /* reserved */ 0, /* reserved */ }; - #else - static const uint16_t vdd[32] = { + static const u16 vdd[32] = { 10500, 0, /* reserved */ 9750, @@ -559,162 +766,8 @@ int adjust_vdd(ulong vdd_override) 0, /* reserved */ }; #endif -#endif - struct vdd_drive { - u8 vid; - unsigned voltage; - }; - - ret = i2c_multiplexer_select_vid_channel(I2C_MUX_CH_VOL_MONITOR); - if (ret) { - debug("VID: I2C failed to switch channel\n"); - ret = -1; - goto exit; - } -#if defined(CONFIG_VOL_MONITOR_IR36021_SET) || \ - defined(CONFIG_VOL_MONITOR_IR36021_READ) - ret = find_ir_chip_on_i2c(); - if (ret < 0) { - printf("VID: Could not find voltage regulator on I2C.\n"); - ret = -1; - goto exit; - } else { - i2caddress = ret; - debug("VID: IR Chip found on I2C address 0x%02x\n", i2caddress); - } - - /* check IR chip work on Intel mode*/ -#ifndef CONFIG_DM_I2C - ret = i2c_read(i2caddress, - IR36021_INTEL_MODE_OOFSET, - 1, (void *)&buf, 1); -#else - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); - if (!ret) - ret = dm_i2c_read(dev, IR36021_INTEL_MODE_OOFSET, - (void *)&buf, 1); -#endif - if (ret) { - printf("VID: failed to read IR chip mode.\n"); - ret = -1; - goto exit; - } - - if ((buf & IR36021_MODE_MASK) != IR36021_INTEL_MODE) { - printf("VID: IR Chip is not used in Intel mode.\n"); - ret = -1; - goto exit; - } -#endif - - /* get the voltage ID from fuse status register */ - fusesr = in_le32(&gur->dcfg_fusesr); - vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT) & - FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK; - if ((vid == 0) || (vid == FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK)) { - vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT) & - FSL_CHASSIS3_DCFG_FUSESR_VID_MASK; - } - vdd_target = vdd[vid]; - - /* check override variable for overriding VDD */ - vdd_string = env_get(CONFIG_VID_FLS_ENV); - if (vdd_override == 0 && vdd_string && - !strict_strtoul(vdd_string, 10, &vdd_string_override)) - vdd_override = vdd_string_override; - - if (vdd_override >= VDD_MV_MIN && vdd_override <= VDD_MV_MAX) { - vdd_target = vdd_override * 10; /* convert to 1/10 mV */ - debug("VDD override is %lu\n", vdd_override); - } else if (vdd_override != 0) { - printf("Invalid value.\n"); - } - - /* divide and round up by 10 to get a value in mV */ - vdd_target = DIV_ROUND_UP(vdd_target, 10); - if (vdd_target == 0) { - debug("VID: VID not used\n"); - ret = 0; - goto exit; - } else if (vdd_target < VDD_MV_MIN || vdd_target > VDD_MV_MAX) { - /* Check vdd_target is in valid range */ - printf("VID: Target VID %d mV is not in range.\n", - vdd_target); - ret = -1; - goto exit; - } else { - debug("VID: vid = %d mV\n", vdd_target); - } - - /* - * Read voltage monitor to check real voltage. - */ - vdd_last = read_voltage(i2caddress); - if (vdd_last < 0) { - printf("VID: Couldn't read sensor abort VID adjustment\n"); - ret = -1; - goto exit; - } - vdd_current = vdd_last; - debug("VID: Core voltage is currently at %d mV\n", vdd_last); - -#ifdef CONFIG_VOL_MONITOR_LTC3882_SET - /* Set the target voltage */ - vdd_last = vdd_current = set_voltage(i2caddress, vdd_target); -#else - /* - * Adjust voltage to at or one step above target. - * As measurements are less precise than setting the values - * we may run through dummy steps that cancel each other - * when stepping up and then down. - */ - while (vdd_last > 0 && - vdd_last < vdd_target) { - vdd_current += IR_VDD_STEP_UP; - vdd_last = set_voltage(i2caddress, vdd_current); - } - while (vdd_last > 0 && - vdd_last > vdd_target + (IR_VDD_STEP_DOWN - 1)) { - vdd_current -= IR_VDD_STEP_DOWN; - vdd_last = set_voltage(i2caddress, vdd_current); - } - -#endif - if (board_adjust_vdd(vdd_target) < 0) { - ret = -1; - goto exit; - } - - if (vdd_last > 0) - printf("VID: Core voltage after adjustment is at %d mV\n", - vdd_last); - else - ret = -1; -exit: - if (re_enable) - enable_interrupts(); - i2c_multiplexer_select_vid_channel(I2C_MUX_CH_DEFAULT); - return ret; -} #else /* !CONFIG_FSL_LSCH3 */ -int adjust_vdd(ulong vdd_override) -{ - int re_enable = disable_interrupts(); -#if defined(CONFIG_FSL_LSCH2) - struct ccsr_gur *gur = (void *)(CONFIG_SYS_FSL_GUTS_ADDR); -#else - ccsr_gur_t __iomem *gur = - (void __iomem *)(CONFIG_SYS_MPC85xx_GUTS_ADDR); -#endif - u32 fusesr; - u8 vid, buf; - int vdd_target, vdd_current, vdd_last; - int ret, i2caddress; - unsigned long vdd_string_override; - char *vdd_string; - static const uint16_t vdd[32] = { + static const u16 vdd[32] = { 0, /* unused */ 9875, /* 0.9875V */ 9750, @@ -742,6 +795,7 @@ int adjust_vdd(ulong vdd_override) 11000, 0, /* reserved */ }; +#endif struct vdd_drive { u8 vid; unsigned voltage; @@ -753,45 +807,23 @@ int adjust_vdd(ulong vdd_override) ret = -1; goto exit; } -#if defined(CONFIG_VOL_MONITOR_IR36021_SET) || \ - defined(CONFIG_VOL_MONITOR_IR36021_READ) - ret = find_ir_chip_on_i2c(); + ret = find_vid_chip_on_i2c(); if (ret < 0) { printf("VID: Could not find voltage regulator on I2C.\n"); ret = -1; goto exit; } else { i2caddress = ret; - debug("VID: IR Chip found on I2C address 0x%02x\n", i2caddress); + debug("VID: Voltage regulator found on I2C address 0x%02x\n", + i2caddress); }
- /* check IR chip work on Intel mode*/ -#ifndef CONFIG_DM_I2C - ret = i2c_read(i2caddress, - IR36021_INTEL_MODE_OOFSET, - 1, (void *)&buf, 1); -#else - struct udevice *dev; - - ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); - if (!ret) - ret = dm_i2c_read(dev, IR36021_INTEL_MODE_OOFSET, - (void *)&buf, 1); -#endif - if (ret) { - printf("VID: failed to read IR chip mode.\n"); - ret = -1; - goto exit; - } - if ((buf & IR36021_MODE_MASK) != IR36021_INTEL_MODE) { - printf("VID: IR Chip is not used in Intel mode.\n"); - ret = -1; - goto exit; - } -#endif - /* get the voltage ID from fuse status register */ +#ifdef CONFIG_FSL_LSCH3 + fusesr = in_le32(&gur->dcfg_fusesr); +#else fusesr = in_be32(&gur->dcfg_fusesr); +#endif /* * VID is used according to the table below * --------------------------------------- @@ -816,6 +848,26 @@ int adjust_vdd(ulong vdd_override) vid = (fusesr >> FSL_CHASSIS2_DCFG_FUSESR_VID_SHIFT) & FSL_CHASSIS2_DCFG_FUSESR_VID_MASK; } +#elif defined(CONFIG_FSL_LSCH3) + if (soc_has_lowbitsinfusesr(gur)) { + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_MASK; + if (vid == 0 || + vid == FSL_CHASSIS3_DCFG_FUSESR_LOW_ALTVID_MASK) { + vid = (fusesr >> + FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_MASK; + } + } else { + vid = (fusesr >> FSL_CHASSIS3_DCFG_FUSESR_ALTVID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK; + if (vid == 0 || + vid == FSL_CHASSIS3_DCFG_FUSESR_ALTVID_MASK) { + vid = (fusesr >> + FSL_CHASSIS3_DCFG_FUSESR_VID_SHIFT) & + FSL_CHASSIS3_DCFG_FUSESR_VID_MASK; + } + } #else vid = (fusesr >> FSL_CORENET_DCFG_FUSESR_ALTVID_SHIFT) & FSL_CORENET_DCFG_FUSESR_ALTVID_MASK; @@ -835,7 +887,7 @@ int adjust_vdd(ulong vdd_override) vdd_target = vdd_override * 10; /* convert to 1/10 mV */ debug("VDD override is %lu\n", vdd_override); } else if (vdd_override != 0) { - printf("Invalid value.\n"); + printf("VID: Invalid override value %lu mV.\n", vdd_override); } if (vdd_target == 0) { debug("VID: VID not used\n"); @@ -844,7 +896,7 @@ int adjust_vdd(ulong vdd_override) } else { /* divide and round up by 10 to get a value in mV */ vdd_target = DIV_ROUND_UP(vdd_target, 10); - debug("VID: vid = %d mV\n", vdd_target); + printf("VID: SoC target voltage = %d mV\n", vdd_target); }
/* @@ -865,30 +917,31 @@ int adjust_vdd(ulong vdd_override) * when stepping up and then down. */ while (vdd_last > 0 && - vdd_last < vdd_target) { - vdd_current += IR_VDD_STEP_UP; + vdd_last < vdd_target && + vdd_current < vdd_target) { + vdd_current += min(VDD_STEP_UP, + vdd_target - vdd_current + ADC_MIN_ACCURACY); vdd_last = set_voltage(i2caddress, vdd_current); } while (vdd_last > 0 && - vdd_last > vdd_target + (IR_VDD_STEP_DOWN - 1)) { - vdd_current -= IR_VDD_STEP_DOWN; + vdd_last >= vdd_target + ADC_MIN_ACCURACY && + vdd_current >= vdd_target + ADC_MIN_ACCURACY) { + vdd_current -= min(VDD_STEP_DOWN, vdd_current - vdd_target); vdd_last = set_voltage(i2caddress, vdd_current); }
- if (vdd_last > 0) + if (vdd_last > 0) { printf("VID: Core voltage after adjustment is at %d mV\n", vdd_last); - else + ret = 0; + } else { ret = -1; + } exit: - if (re_enable) - enable_interrupts(); - i2c_multiplexer_select_vid_channel(I2C_MUX_CH_DEFAULT);
return ret; } -#endif
static int print_vdd(void) { @@ -896,20 +949,17 @@ static int print_vdd(void)
ret = i2c_multiplexer_select_vid_channel(I2C_MUX_CH_VOL_MONITOR); if (ret) { - debug("VID : I2c failed to switch channel\n"); + debug("VID : I2C failed to switch channel\n"); return -1; } -#if defined(CONFIG_VOL_MONITOR_IR36021_SET) || \ - defined(CONFIG_VOL_MONITOR_IR36021_READ) - ret = find_ir_chip_on_i2c(); + ret = find_vid_chip_on_i2c(); if (ret < 0) { printf("VID: Could not find voltage regulator on I2C.\n"); goto exit; } else { i2caddress = ret; - debug("VID: IR Chip found on I2C address 0x%02x\n", i2caddress); + debug("VID: Chip found on I2C address 0x%02x\n", i2caddress); } -#endif
/* * Read voltage monitor to check real voltage. diff --git a/board/freescale/common/vid.h b/board/freescale/common/vid.h index 99778e9..09dca78 100644 --- a/board/freescale/common/vid.h +++ b/board/freescale/common/vid.h @@ -1,23 +1,57 @@ /* SPDX-License-Identifier: GPL-2.0+ */ /* * Copyright 2014 Freescale Semiconductor, Inc. + * Copyright 2020 NXP */
#ifndef __VID_H_ #define __VID_H_
+/* Declarations for the IR36021 */ #define IR36021_LOOP1_MANUAL_ID_OFFSET 0x6A #define IR36021_LOOP1_VOUT_OFFSET 0x9A #define IR36021_MFR_ID_OFFSET 0x92 #define IR36021_MFR_ID 0x43 -#define IR36021_INTEL_MODE_OOFSET 0x14 +#define IR36021_INTEL_MODE_OFFSET 0x14 #define IR36021_MODE_MASK 0x20 #define IR36021_INTEL_MODE 0x00 #define IR36021_AMD_MODE 0x20
/* step the IR regulator in 5mV increments */ -#define IR_VDD_STEP_DOWN 5 -#define IR_VDD_STEP_UP 5 -int adjust_vdd(ulong vdd_override); +#define IR_VDD_STEP_DOWN 5 /* mV */ +#define IR_VDD_STEP_UP 5 /* mV */ +#define IR_ADC_MIN_ACCURACY 8 /* mV */ + +/* Declarations for the LTC3882 */ +#define LTC3882_PAGE 0x00 +#define LTC3882_PAGE_PLUS_WRITE 0x05 +#define LTC3882_PAGE_PLUS_READ 0x06 +#define LTC3882_VOUT_COMMAND 0x21 +#define LTC3882_VOUT_MAX 0x24 +#define LTC3882_VOUT_MARGIN_HIGH 0x25 +#define LTC3882_VOUT_MARGIN_LOW 0x26 +#define LTC3882_VOUT_OV_FAULT_LIMIT 0x40 +#define LTC3882_VOUT_OV_WARN_LIMIT 0x42 +#define LTC3882_VOUT_UV_WARN_LIMIT 0x43 +#define LTC3882_VOUT_UV_FAULT_LIMIT 0x44 +#define LTC3882_READ_VOUT 0x8B +#define LTC3882_MFR_ID 0x99 +#define LTC3882_MFR_MODEL 0x9A + +/* step the LTC regulator in 1mV increments */ +#define LTC_VDD_STEP_DOWN 1 /* mV */ +#define LTC_VDD_STEP_UP 1 /* mV */ +#define LTC_ADC_MIN_ACCURACY 1 /* mV */
+/* This is a compatibility setting for existing board configs */ +#ifdef PWM_CHANNEL0 +#define LTC3882_VID_CHANNEL PWM_CHANNEL0 +#endif + +int vid_set_mv_limits(int absmax, + int marginhigh, int marginlow, + int ovfault, int ovwarn, + int uvwarn, int uvfault); + +int adjust_vdd(ulong vdd_override); #endif /* __VID_H_ */
-----Original Message----- From: Wasim Khan wasim.khan@nxp.com Sent: Thursday, August 13, 2020 2:12 AM To: Priyanka Jain priyanka.jain@nxp.com; Varun Sethi V.Sethi@nxp.com Cc: u-boot@lists.denx.de; Wasim Khan wasim.khan@nxp.com; Dan Nica dan.nica@nxp.com; Heinz Wrobel heinz.wrobel@nxp.com Subject: [PATCH 1/2] board/freescale/vid: rework of VID support
I understand the patch is trying to address some problems. But the patch description should talked more about code changes. How you are addressing the problems?
And if the description is too much, please add a README.
I see too many changes in this patch.(adding LTC code, generalizing code,..) I tried to review and provided some comments for the half of the patch, but the patch is too difficult to review. Please split the patch
- LayerScape Internal Memory Map
- Copyright 2017-2019 NXP
- Copyright 2017-2020 NXP
- Copyright 2014 Freescale Semiconductor, Inc.
Please add inline-comments : what does ...LOW.. stands for?
- Copyright 2020 NXP
- Get the i2c address configuration for the IR regulator chip
- Get the i2c address configuration for the regulator chip
- There are some variance in the RDB HW regarding the I2C address
configuration
- for the IR regulator chip, which is likely a problem of external resistor @@ -
- 0x08 (Verified on T1040RDB-PA,T4240RDB-PB,X-T4240RDB-16GPA)
- 0x09 (Verified on T1040RDB-PA)
- 0x38 (Verified on T2080QDS, T2081QDS, T4240RDB)
- For other types of regulator chips, we check the IDs before we
- return the address to avoid making damaging mistakes
- defined(CONFIG_VOL_MONITOR_IR36021_SET) int i2caddress; int ret; u8 byte;
return i2caddress;
- defined(CONFIG_VOL_MONITOR_LTC3882_SET)
- int i2caddress = I2C_VOL_MONITOR_ADDR;
- int ret;
- u8 buf[8];
4);
+#else
- if (!ret)
- if (!ret && memcmp(buf, "\3LTC", 4) == 0) { #ifndef CONFIG_DM_I2C
8);
+#else
if (!ret)
Please create two different functions for IR and LTC for better readability.
}if (!ret && memcmp(buf, "\7LTC3882", 8) == 0) return i2caddress;
We should avoid adding comments at the end of line. There is one comment already above the define. Update that of required.
- read_voltage from sensor on I2C bus
- We use average of 4 readings, waiting for WAIT_FOR_ADC before
- another reading
- If an INA220 chip is available, we can use it to read back the
- voltage
- as it may have a higher accuracy than the IR chip for the same purpose
*/ #ifdef CONFIG_VOL_MONITOR_INA220 +#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ #define WAIT_FOR_ADC 532 /* wait for 532 microseconds for ADC */ -#define ADC_MIN_ACCURACY 4 -#else +#define ADC_MIN_ACCURACY 4 /* mV */ +#endif +#ifdef CONFIG_VOL_MONITOR_IR36021_READ +#define NUM_READINGS 4 /* prefer to be power of 2 for efficiency */ #define WAIT_FOR_ADC 138 /* wait for 138 microseconds for ADC */ -#define ADC_MIN_ACCURACY 4 +#define ADC_MIN_ACCURACY IR_ADC_MIN_ACCURACY +#define VDD_STEP_UP IR_VDD_STEP_UP +#define VDD_STEP_DOWN IR_VDD_STEP_DOWN +#endif +#ifdef CONFIG_VOL_MONITOR_LTC3882_READ +#define WAIT_FOR_ADC 0 +#define ADC_MIN_ACCURACY LTC_ADC_MIN_ACCURACY +#define VDD_STEP_UP LTC_VDD_STEP_UP +#define VDD_STEP_DOWN LTC_VDD_STEP_DOWN +#endif +#if VDD_STEP_UP < 1 || VDD_STEP_DOWN < 1 #error VDD_STEP values must be +> 0! #endif
(void *)&buf, 2);
#else
1, &dev);
if (!ret) ret = dm_i2c_read(dev,ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev);
(void *)&buf, 2);
*/ voltage_read -= board_vdd_drop_compensation();* SoC before converting into a VID value
- This will only read the first channel for dual channel setups */
- u8 chan = LTC3882_VID_CHANNEL;
- u8 buf[2];
- ret = i2c_write(i2caddress,
#else
&dev);
#endif if (ret) {
return ret; }printf("VID: failed to select VDD Page\n");
#else
2);
- if (ret) {
return ret;
- if (!ret)
#endif if (ret) {
return ret; }
Please create different functions for different devices.
- voltage_read =
- return -1;
- voltage_read = -1;
#endif
- if (voltage_read >= 0) {
- return voltage_read;
- We need to calculate how long before the voltage stops to drop
- or increase. It returns with the loop count. Each loop takes @@ -287,8
udelay(1000);
Use macro. Avoid magic value.
- udelay(1000);
WAIT_FOR_ADC
WAIT_FOR_ADC)
udelay(1000);
- u8 buf;
and
- /* check if IR chip works in Intel mode*/ #ifndef CONFIG_DM_I2C
#else
- if (!ret)
(void *)&buf, 1);
#endif
- if (ret) {
return -1;
- } else {
/* Intel mode */
WAIT_FOR_ADC);
#endif
- returning a boolean for success
- int l16;
- int ret;
- u8 buf[5];
- /* Scale mV to L16 */
- l16 = mv;
- l16 <<= 12;
- l16 /= 1000;
- debug("VID: cmd 0x%02x voltage write 0x%04x\n", cmd, l16);
- buf[0] = 4;
- buf[1] = LTC3882_VID_CHANNEL;
- buf[2] = cmd;
- buf[3] = (l16 & 0xff);
- buf[4] = (l16 >> 8);
- /* This code assumes that both channels run the very
*/* break loose!
#else
&dev);
(void *)&buff, 5);
5); #endif #ifdef +LTC3882_VID_CHANNEL2
- if (!ret) {
5); #else
if (!ret)
(void *)&buf, 5);
- return ret;
+} #endif
+#ifdef CONFIG_VOL_MONITOR_LTC3882_SET +/* this function sets the VDD and returns the value set */ static int +set_voltage_to_LTC(int i2caddress, int vdd) {
- int wait, ret, vdd_last;
- ret = write_l16_mV_LTC3882(i2caddress,
if (ret) {vdd);
return -1; }printf("VID: I2C failed to write to the voltage regulator\n");
- do {
if (vdd_last < 0) {
return -1;
count--;
if (wait < 0)
return -1;
if (vdd_last < 0)
return -1;
return vdd_last;
and
-#ifdef CONFIG_FSL_LSCH3 +#if defined(CONFIG_FSL_LSCH3) +static bool soc_has_lowbitsinfusesr(struct ccsr_gur *gur) {
- u32 svr = in_le32(&gur->svr);
- /* LS2088A derivatives have different FUSESR */
- switch (SVR_SOC_VER(svr)) {
- case SVR_LS2088A:
- case SVR_LS2048A:
- case SVR_LS2084A:
- case SVR_LS2044A:
- case SVR_LX2160A:
- case SVR_LX2120A:
- case SVR_LX2080A:
- return true;
- return false;
- int ret;
- int i2caddress;
- ret =
- if (ret) {
return ret;
- i2caddress = find_vid_chip_on_i2c();
- if (i2caddress >= 0) {
* VID changes.
LTC3882_VOUT_MAX,
absmax);
if (!ret) {
marginhigh);
if (!ret) {
marginlow);
if (!ret) {
ovfault);
if (!ret) {
ovwarn);
if (!ret) {
uvwarn);
if (!ret) {
uvfault);
- } else {
ret = -1;
- if (ret)
not be +stable!\n");
- return ret;
- u32 fusesr;
- u8 vid, buf;
#else
- u8 vid;
#endif
- u32 fusesr;
- u8 vid; int vdd_target, vdd_current, vdd_last; int ret, i2caddress; unsigned long vdd_string_override; char *vdd_string;
- /* Note that these are all possible values for the FUSESR
- static const u16 vdd[32] = { 10250, 9875, 9750,
#else
- static const u16 vdd[32] = { 10500, 0, /* reserved */ 9750,
u8 vid;
unsigned voltage;
- ret =
- if (ret) {
ret = -1;
goto exit;
- if (ret < 0) {
ret = -1;
goto exit;
- } else {
i2caddress = ret;
i2caddress);
-#else
- if (!ret)
(void *)&buf, 1);
-#endif
- if (ret) {
ret = -1;
goto exit;
ret = -1;
goto exit;
-#endif
VDD_MV_MAX) {
ret = 0;
goto exit;
vdd_target);
ret = -1;
goto exit;
- } else {
ret = -1;
goto exit;
-#else
-#endif
ret = -1;
goto exit;
- if (vdd_last > 0)
vdd_last);
- else
ret = -1;
-exit:
- if (re_enable)
- return ret;
-#else
-#endif
- u32 fusesr;
- u8 vid, buf;
- char *vdd_string;
- static const u16 vdd[32] = { 0, /* unused */ 9875, /* 0.9875V */ 9750,
- ret = find_vid_chip_on_i2c(); if (ret < 0) { printf("VID: Could not find voltage regulator on I2C.\n"); ret = -1; goto exit; } else { i2caddress = ret;
i2caddress);
0x%02x\n",
}i2caddress);
-#else
- if (!ret)
(void *)&buf, 1);
-#endif
- if (ret) {
ret = -1;
goto exit;
ret = -1;
goto exit;
-#endif
- if (soc_has_lowbitsinfusesr(gur)) {
vid = (fusesr >>
if (vid == 0 ||
vid = (fusesr >>
- FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_SHIFT) &
- FSL_CHASSIS3_DCFG_FUSESR_LOW_VID_MASK;
- } else {
if (vid == 0 ||
vid = (fusesr >>
} if (vdd_target == 0) { debug("VID: VID not used\n");printf("VID: Invalid override value %lu mV.\n", vdd_override);
- if (vdd_last > 0)
- if (vdd_last > 0) { printf("VID: Core voltage after adjustment is at %d mV\n", vdd_last);
- else
ret = 0;
- } else { ret = -1;
exit:
if (re_enable)
return ret;
} -#endif
return -1; }debug("VID : I2C failed to switch channel\n");
- ret = find_vid_chip_on_i2c(); if (ret < 0) { printf("VID: Could not find voltage regulator on I2C.\n"); goto exit; } else { i2caddress = ret;
i2caddress);
+/* This is a compatibility setting for existing board configs */ #ifdef +PWM_CHANNEL0 +#define LTC3882_VID_CHANNEL PWM_CHANNEL0 +#endif
2.7.4
Regards Priyanka
Signed-off-by: Wasim Khan wasim.khan@nxp.com Reviewed-by: Heinz Wrobel Heinz.Wrobel@nxp.com --- board/freescale/common/vid.c | 121 ++++++++++++++++++++++++------------------- board/freescale/common/vid.h | 32 ++++++------ 2 files changed, 85 insertions(+), 68 deletions(-)
diff --git a/board/freescale/common/vid.c b/board/freescale/common/vid.c index 0ba672d..095781f 100644 --- a/board/freescale/common/vid.c +++ b/board/freescale/common/vid.c @@ -92,7 +92,9 @@ static int find_vid_chip_on_i2c(void) } #endif #if defined(CONFIG_VOL_MONITOR_LTC3882_READ) || \ - defined(CONFIG_VOL_MONITOR_LTC3882_SET) + defined(CONFIG_VOL_MONITOR_LTC7132_READ) || \ + defined(CONFIG_VOL_MONITOR_LTC3882_SET) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_SET) int i2caddress = I2C_VOL_MONITOR_ADDR; int ret; u8 buf[8]; @@ -102,27 +104,35 @@ static int find_vid_chip_on_i2c(void)
#ifndef CONFIG_DM_I2C ret = i2c_read(i2caddress, - LTC3882_MFR_ID, 1, (void *)&buf[0], + LTC_MFR_ID, 1, (void *)&buf[0], 4); #else ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) - ret = dm_i2c_read(dev, LTC3882_MFR_ID, + ret = dm_i2c_read(dev, LTC_MFR_ID, (void *)&buf[0], 4); #endif if (!ret && memcmp(buf, "\3LTC", 4) == 0) { #ifndef CONFIG_DM_I2C ret = i2c_read(i2caddress, - LTC3882_MFR_MODEL, 1, (void *)&buf[0], + LTC_MFR_MODEL, 1, (void *)&buf[0], 8); #else ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) - ret = dm_i2c_read(dev, LTC3882_MFR_MODEL, + ret = dm_i2c_read(dev, LTC_MFR_MODEL, (void *)&buf[0], 8); #endif - if (!ret && memcmp(buf, "\7LTC3882", 8) == 0) - return i2caddress; + if (!ret) { +#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) || \ + defined(CONFIG_VOL_MONITOR_LTC3882_READ) + if (memcmp(buf, "\7LTC3882", 8) == 0) +#elif defined(CONFIG_VOL_MONITOR_LTC7132_SET) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_READ) + if (memcmp(buf, "\7LTC7132", 8) == 0) +#endif + return i2caddress; + } } #endif return -1; @@ -148,7 +158,8 @@ static int find_vid_chip_on_i2c(void) #define VDD_STEP_UP IR_VDD_STEP_UP #define VDD_STEP_DOWN IR_VDD_STEP_DOWN #endif -#ifdef CONFIG_VOL_MONITOR_LTC3882_READ +#if defined(CONFIG_VOL_MONITOR_LTC3882_READ) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_READ) #define WAIT_FOR_ADC 0 #define ADC_MIN_ACCURACY LTC_ADC_MIN_ACCURACY #define VDD_STEP_UP LTC_VDD_STEP_UP @@ -253,14 +264,15 @@ static int read_voltage_from_IR(int i2caddress) } #endif
-#ifdef CONFIG_VOL_MONITOR_LTC3882_READ +#if defined(CONFIG_VOL_MONITOR_LTC3882_READ) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_READ) /* read the current value of the LTC Regulator Voltage. * This will only read the first channel for dual channel setups */ static int read_voltage_from_LTC(int i2caddress) { int ret, vcode = 0; - u8 chan = LTC3882_VID_CHANNEL; + u8 chan = LTC_VID_CHANNEL; u8 buf[2]; #ifdef CONFIG_DM_I2C struct udevice *dev; @@ -269,11 +281,11 @@ static int read_voltage_from_LTC(int i2caddress) /* select the PAGE 0 using PMBus commands PAGE for VDD*/ #ifndef CONFIG_DM_I2C ret = i2c_write(i2caddress, - LTC3882_PAGE, 1, &chan, 1); + LTC_PAGE, 1, &chan, 1); #else ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) - ret = dm_i2c_write(dev, LTC3882_PAGE, &chan, 1); + ret = dm_i2c_write(dev, LTC_PAGE, &chan, 1); #endif if (ret) { printf("VID: failed to select VDD Page\n"); @@ -283,11 +295,11 @@ static int read_voltage_from_LTC(int i2caddress) /*read the output voltage using PMBus command READ_VOUT*/ #ifndef CONFIG_DM_I2C ret = i2c_read(i2caddress, - LTC3882_READ_VOUT, 1, (void *)&buf[0], 2); + LTC_READ_VOUT, 1, (void *)&buf[0], 2); #else ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) - ret = dm_i2c_read(dev, LTC3882_READ_VOUT, + ret = dm_i2c_read(dev, LTC_READ_VOUT, (void *)&buf[0], 2); #endif if (ret) { @@ -310,7 +322,8 @@ static int read_voltage(int i2caddress) voltage_read = read_voltage_from_INA220(I2C_VOL_MONITOR_ADDR); #elif defined CONFIG_VOL_MONITOR_IR36021_READ voltage_read = read_voltage_from_IR(i2caddress); -#elif defined CONFIG_VOL_MONITOR_LTC3882_READ +#elif defined(CONFIG_VOL_MONITOR_LTC3882_READ) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_READ) voltage_read = read_voltage_from_LTC(i2caddress); #else voltage_read = -1; @@ -452,11 +465,12 @@ static int set_voltage_to_IR(int i2caddress, int vdd) } #endif
-#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) +#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_SET) /* Helper function to write a mV value as LTC L16 into the chip, * returning a boolean for success */ -static int write_l16_mV_LTC3882(int i2caddress, int cmd, int mv) +static int write_l16_mV_LTC(int i2caddress, int cmd, int mv) { int l16; int ret; @@ -471,7 +485,7 @@ static int write_l16_mV_LTC3882(int i2caddress, int cmd, int mv) l16 /= 1000; debug("VID: cmd 0x%02x voltage write 0x%04x\n", cmd, l16); buf[0] = 4; - buf[1] = LTC3882_VID_CHANNEL; + buf[1] = LTC_VID_CHANNEL; buf[2] = cmd; buf[3] = (l16 & 0xff); buf[4] = (l16 >> 8); @@ -483,23 +497,23 @@ static int write_l16_mV_LTC3882(int i2caddress, int cmd, int mv) */ #ifndef CONFIG_DM_I2C ret = i2c_write(i2caddress, - LTC3882_PAGE_PLUS_WRITE, 1, (void *)&buf, 5); + LTC_PAGE_PLUS_WRITE, 1, (void *)&buf, 5); #else ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) ret = dm_i2c_write(dev, - LTC3882_PAGE_PLUS_WRITE, (void *)&buf, 5); + LTC_PAGE_PLUS_WRITE, (void *)&buf, 5); #endif -#ifdef LTC3882_VID_CHANNEL2 +#ifdef LTC_VID_CHANNEL2 if (!ret) { - buf[1] = LTC3882_VID_CHANNEL2; + buf[1] = LTC_VID_CHANNEL2; #ifndef CONFIG_DM_I2C ret = i2c_write(i2caddress, - LTC3882_PAGE_PLUS_WRITE, 1, (void *)&buf, 5); + LTC_PAGE_PLUS_WRITE, 1, (void *)&buf, 5); #else ret = i2c_get_chip_for_busnum(0, i2caddress, 1, &dev); if (!ret) - ret = dm_i2c_write(dev, LTC3882_PAGE_PLUS_WRITE, + ret = dm_i2c_write(dev, LTC_PAGE_PLUS_WRITE, (void *)&buf, 5); #endif } @@ -508,16 +522,17 @@ static int write_l16_mV_LTC3882(int i2caddress, int cmd, int mv) } #endif
-#ifdef CONFIG_VOL_MONITOR_LTC3882_SET +#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_SET) /* this function sets the VDD and returns the value set */ static int set_voltage_to_LTC(int i2caddress, int vdd) { int wait, ret, vdd_last;
/* Write the desired voltage code to the regulator */ - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_COMMAND, - vdd); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_COMMAND, + vdd); if (ret) { printf("VID: I2C failed to write to the voltage regulator\n"); return -1; @@ -545,7 +560,8 @@ static int set_voltage(int i2caddress, int vdd) vdd += board_vdd_drop_compensation(); #ifdef CONFIG_VOL_MONITOR_IR36021_SET vdd_last = set_voltage_to_IR(i2caddress, vdd); -#elif defined CONFIG_VOL_MONITOR_LTC3882_SET +#elif defined(CONFIG_VOL_MONITOR_LTC3882_SET) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_SET) vdd_last = set_voltage_to_LTC(i2caddress, vdd); #else #error Specific voltage monitor must be defined @@ -589,49 +605,50 @@ int vid_set_mv_limits(int absmax, } i2caddress = find_vid_chip_on_i2c();
-#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) +#if defined(CONFIG_VOL_MONITOR_LTC3882_SET) || \ + defined(CONFIG_VOL_MONITOR_LTC7132_SET) if (i2caddress >= 0) { /* We need to program the voltage limits * properly, or the chip may freak out on * VID changes. */ - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_MAX, - absmax); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_MAX, + absmax); if (!ret) { - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_MARGIN_HIGH, - marginhigh); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_MARGIN_HIGH, + marginhigh); } if (!ret) { - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_MARGIN_LOW, - marginlow); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_MARGIN_LOW, + marginlow); } if (!ret) { - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_OV_FAULT_LIMIT, - ovfault); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_OV_FAULT_LIMIT, + ovfault); } if (!ret) { - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_OV_WARN_LIMIT, - ovwarn); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_OV_WARN_LIMIT, + ovwarn); } if (!ret) { - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_UV_WARN_LIMIT, - uvwarn); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_UV_WARN_LIMIT, + uvwarn); } if (!ret) { - ret = write_l16_mV_LTC3882(i2caddress, - LTC3882_VOUT_UV_FAULT_LIMIT, - uvfault); + ret = write_l16_mV_LTC(i2caddress, + LTC_VOUT_UV_FAULT_LIMIT, + uvfault); } } else { ret = -1; } -#endif /* CONFIG_VOL_MONITOR_LTC3882_SET */ +#endif /* CONFIG_VOL_MONITOR_LTC3882_SET || CONFIG_VOL_MONITOR_LTC7132_SET*/ if (ret) printf("VID: Setting voltage limits failed! VID regulation may not be stable!\n");
diff --git a/board/freescale/common/vid.h b/board/freescale/common/vid.h index 09dca78..d506e7f 100644 --- a/board/freescale/common/vid.h +++ b/board/freescale/common/vid.h @@ -22,21 +22,21 @@ #define IR_VDD_STEP_UP 5 /* mV */ #define IR_ADC_MIN_ACCURACY 8 /* mV */
-/* Declarations for the LTC3882 */ -#define LTC3882_PAGE 0x00 -#define LTC3882_PAGE_PLUS_WRITE 0x05 -#define LTC3882_PAGE_PLUS_READ 0x06 -#define LTC3882_VOUT_COMMAND 0x21 -#define LTC3882_VOUT_MAX 0x24 -#define LTC3882_VOUT_MARGIN_HIGH 0x25 -#define LTC3882_VOUT_MARGIN_LOW 0x26 -#define LTC3882_VOUT_OV_FAULT_LIMIT 0x40 -#define LTC3882_VOUT_OV_WARN_LIMIT 0x42 -#define LTC3882_VOUT_UV_WARN_LIMIT 0x43 -#define LTC3882_VOUT_UV_FAULT_LIMIT 0x44 -#define LTC3882_READ_VOUT 0x8B -#define LTC3882_MFR_ID 0x99 -#define LTC3882_MFR_MODEL 0x9A +/* Declarations for the LTC regulator */ +#define LTC_PAGE 0x00 +#define LTC_PAGE_PLUS_WRITE 0x05 +#define LTC_PAGE_PLUS_READ 0x06 +#define LTC_VOUT_COMMAND 0x21 +#define LTC_VOUT_MAX 0x24 +#define LTC_VOUT_MARGIN_HIGH 0x25 +#define LTC_VOUT_MARGIN_LOW 0x26 +#define LTC_VOUT_OV_FAULT_LIMIT 0x40 +#define LTC_VOUT_OV_WARN_LIMIT 0x42 +#define LTC_VOUT_UV_WARN_LIMIT 0x43 +#define LTC_VOUT_UV_FAULT_LIMIT 0x44 +#define LTC_READ_VOUT 0x8B +#define LTC_MFR_ID 0x99 +#define LTC_MFR_MODEL 0x9A
/* step the LTC regulator in 1mV increments */ #define LTC_VDD_STEP_DOWN 1 /* mV */ @@ -45,7 +45,7 @@
/* This is a compatibility setting for existing board configs */ #ifdef PWM_CHANNEL0 -#define LTC3882_VID_CHANNEL PWM_CHANNEL0 +#define LTC_VID_CHANNEL PWM_CHANNEL0 #endif
Priyanka Jain
Wasim Khan
