[PATCH v5] phy: phy-imx8mq-usb: add vbus regulator support
Add support for enabling and disabling vbus-supply regulator found on several imx8mp boards in the usb3_phy0 and usb3_phy1 nodes.
While we are at it replace '#if CONFIG_IS_ENABLED(CLK)' with 'if (CONFIG_IS_ENABLED(CLK))' as a cleanup.
Signed-off-by: Tim Harvey tharvey@gateworks.com Reviewed-by: Adam Ford aford173@gmail.com Reviewed-by: Marek Vasut marex@denx.de --- v5: - remove #if CONFIG_IS_ENABLED around struct members (you can not conditionally include if using if (CONFIG_IS_ENABLED(foo)) ) - replace clk '#if CONFIG_IS_ENABLED(CLK)' with 'if (CONFIG_IS_ENABLED(CLK))'
v4: - use regulator_set_enable_if_allowed to handle regulator reference counting errors - added Marek's rb tag
v3: - change pr_err to dev_err - add #if CONFIG_IS_ENABLED around vbus_supply in struct - add fail path to disable clock if regulator enable failed
v2: - protect ret with __maybe_unused in case CONFIG_CLK and CONFIG_DM_REGULATOR not defined - add error prints on failures - add Adam's rb tag --- drivers/phy/phy-imx8mq-usb.c | 68 +++++++++++++++++++++++++----------- 1 file changed, 48 insertions(+), 20 deletions(-)
diff --git a/drivers/phy/phy-imx8mq-usb.c b/drivers/phy/phy-imx8mq-usb.c index 69f01de55538..532b0235e2bc 100644 --- a/drivers/phy/phy-imx8mq-usb.c +++ b/drivers/phy/phy-imx8mq-usb.c @@ -14,6 +14,8 @@ #include <linux/delay.h> #include <linux/err.h> #include <clk.h> +#include <dm/device_compat.h> +#include <power/regulator.h>
#define PHY_CTRL0 0x0 #define PHY_CTRL0_REF_SSP_EN BIT(2) @@ -76,11 +78,10 @@ enum imx8mpq_phy_type { };
struct imx8mq_usb_phy { -#if CONFIG_IS_ENABLED(CLK) struct clk phy_clk; -#endif void __iomem *base; enum imx8mpq_phy_type type; + struct udevice *vbus_supply; };
static const struct udevice_id imx8mq_usb_phy_of_match[] = { @@ -172,16 +173,24 @@ static int imx8mq_usb_phy_power_on(struct phy *usb_phy) { struct udevice *dev = usb_phy->dev; struct imx8mq_usb_phy *imx_phy = dev_get_priv(dev); + int ret; u32 value;
-#if CONFIG_IS_ENABLED(CLK) - int ret; - ret = clk_enable(&imx_phy->phy_clk); - if (ret) { - printf("Failed to enable usb phy clock\n"); - return ret; + if (CONFIG_IS_ENABLED(CLK)) { + ret = clk_enable(&imx_phy->phy_clk); + if (ret) { + printf("Failed to enable usb phy clock\n"); + return ret; + } + } + + if (CONFIG_IS_ENABLED(DM_REGULATOR) && imx_phy->vbus_supply) { + ret = regulator_set_enable_if_allowed(imx_phy->vbus_supply, true); + if (ret && ret != -ENOSYS) { + dev_err(dev, "Failed to enable VBUS regulator: %d\n", ret); + goto err; + } } -#endif
/* Disable rx term override */ value = readl(imx_phy->base + PHY_CTRL6); @@ -189,12 +198,17 @@ static int imx8mq_usb_phy_power_on(struct phy *usb_phy) writel(value, imx_phy->base + PHY_CTRL6);
return 0; + +err: + clk_disable(&imx_phy->phy_clk); + return ret; }
static int imx8mq_usb_phy_power_off(struct phy *usb_phy) { struct udevice *dev = usb_phy->dev; struct imx8mq_usb_phy *imx_phy = dev_get_priv(dev); + int ret; u32 value;
/* Override rx term to be 0 */ @@ -202,9 +216,16 @@ static int imx8mq_usb_phy_power_off(struct phy *usb_phy) value |= PHY_CTRL6_RXTERM_OVERRIDE_SEL; writel(value, imx_phy->base + PHY_CTRL6);
-#if CONFIG_IS_ENABLED(CLK) - clk_disable(&imx_phy->phy_clk); -#endif + if (CONFIG_IS_ENABLED(CLK)) + clk_disable(&imx_phy->phy_clk); + + if (CONFIG_IS_ENABLED(DM_REGULATOR) && imx_phy->vbus_supply) { + ret = regulator_set_enable_if_allowed(imx_phy->vbus_supply, false); + if (ret && ret != -ENOSYS) { + dev_err(dev, "Failed to disable VBUS regulator: %d\n", ret); + return ret; + } + }
return 0; } @@ -224,6 +245,7 @@ struct phy_ops imx8mq_usb_phy_ops = { int imx8mq_usb_phy_probe(struct udevice *dev) { struct imx8mq_usb_phy *priv = dev_get_priv(dev); + int ret;
priv->type = dev_get_driver_data(dev); priv->base = dev_read_addr_ptr(dev); @@ -231,16 +253,22 @@ int imx8mq_usb_phy_probe(struct udevice *dev) if (!priv->base) return -EINVAL;
-#if CONFIG_IS_ENABLED(CLK) - int ret; + if (CONFIG_IS_ENABLED(CLK)) { + ret = clk_get_by_name(dev, "phy", &priv->phy_clk); + if (ret) { + printf("Failed to get usb phy clock\n"); + return ret; + } + }
- /* Assigned clock already set clock */ - ret = clk_get_by_name(dev, "phy", &priv->phy_clk); - if (ret) { - printf("Failed to get usb phy clock\n"); - return ret; + if (CONFIG_IS_ENABLED(DM_REGULATOR)) { + ret = device_get_supply_regulator(dev, "vbus-supply", + &priv->vbus_supply); + if (ret && ret != -ENOENT) { + dev_err(dev, "Failed to get VBUS regulator: %d\n", ret); + return ret; + } } -#endif
return 0; }
v5:
v4:
counting errors
v3:
v2:
- add Adam's rb tag
- int ret; u32 value;
int ret; goes below u32 value (nitpick)
- int ret;
- if (ret) {
return ret;
- if (CONFIG_IS_ENABLED(CLK)) {
if (ret) {
return ret;
- if (CONFIG_IS_ENABLED(DM_REGULATOR) && imx_phy->vbus_supply) {
goto err;
-#endif
+err:
return ret; }
int ret; u32 value;
DTTO
-#endif
It would really be good to have this in two patches, i.e. the clock clean up first, and the regulator addition second.
v5:
v4:
counting errors
v3:
v2:
- add Adam's rb tag
int ret; u32 value;
int ret;
if (ret) {
return ret;
if (ret) {
return ret;
goto err;
-#endif
+err:
return ret;
int ret; u32 value;
DTTO
-#endif
ok, I'll submit a v5 with 2 patches then.
Note that the __maybe_unused from previous revisions will not be there as is not needed as if (CONFIG_IS_ENABLED(foo)) is always compiled in. All of these changes from '#ifdef' to 'if (CONFIG_IS_ENABLED)' is not shrinking code.... I hope everyone understands that.
best regards,
Tim
v5:
v4:
counting errors
v3:
v2:
- add Adam's rb tag
int ret; u32 value;
int ret;
if (ret) {
return ret;
if (ret) {
return ret;
goto err;
-#endif
+err:
return ret;
int ret; u32 value;
DTTO
-#endif
I believe we are all in agreement, yes.
Tim Harvey
