[PATCH v5 0/3] Add octal DTR support for Macronix flash
This series add support for Macronix octal DTR flash, add flag for Softreset with "INVERT" command extension type on boot and follow linux kernel to enable 4byte opcode when possible.
v5: Replace SPI_FLASH_MACRONIX_OCTAL with SPI_FLASH_MACRONIX. Remove patch of set_4byte opcode.
v4: Add flag SPI_NOR_BOOT_SOFT_RESET_EXT_INVERT to seperate command extension types. Replace ifdef with CONFIG_IS_ENABLED and modify uncorrect descriptions.
v3: Add flag SPI_NOR_CMD_EXT_INVERT to seperate command extension types. replace CONFIG_SPI_FLASH_MACRONIX with SPI_FLASH_MACRONIX_OCTAL for spi_nor_macronix_octal_dtr_enable function. v2: add ret checking for write enable in spi_nor_macronix_octal_dtr_enable function.
JaimeLiao (3): mtd: spi-nor: macronix: add support for Macronix Octal mtd: spi-nor-core: Adding different type of command extension in Soft Reset mtd: spi-nor-core: Add support for Macronix Octal flash
drivers/mtd/spi/Kconfig | 7 +++ drivers/mtd/spi/spi-nor-core.c | 90 +++++++++++++++++++++++++++++++++- drivers/mtd/spi/spi-nor-ids.c | 22 ++++++++- include/linux/mtd/spi-nor.h | 12 ++++- 4 files changed, 127 insertions(+), 4 deletions(-)
Follow patch "f6adec1af4b2f5d3012480c6cdce7743b74a6156" for adding Macronix flash in Octal DTR mode.
Enable Octal DTR mode with 20 dummy cycles to allow running at the maximum supported frequency. -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7841/MX25LM51245G,%203V,...
Signed-off-by: JaimeLiao jaimeliao.tw@gmail.com --- drivers/mtd/spi/spi-nor-core.c | 83 ++++++++++++++++++++++++++++++++++ include/linux/mtd/spi-nor.h | 12 ++++- 2 files changed, 93 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index d5d905fa5a..0a6550984b 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3489,6 +3489,85 @@ static struct spi_nor_fixups mt35xu512aba_fixups = { }; #endif /* CONFIG_SPI_FLASH_MT35XU */
+#if CONFIG_IS_ENABLED(SPI_FLASH_MACRONIX) +/** + * spi_nor_macronix_octal_dtr_enable() - set DTR OPI Enable bit in Configuration Register 2. + * @nor: pointer to a 'struct spi_nor' + * + * Set the DTR OPI Enable (DOPI) bit in Configuration Register 2. + * Bit 2 of Configuration Register 2 is the DOPI bit for Macronix like OPI memories. + * + * Return: 0 on success, -errno otherwise. + */ +static int spi_nor_macronix_octal_dtr_enable(struct spi_nor *nor) +{ + struct spi_mem_op op; + int ret; + u8 buf; + + ret = write_enable(nor); + if (ret) + return ret; + + buf = SPINOR_REG_MXIC_DC_20; + op = (struct spi_mem_op) + SPI_MEM_OP(SPI_MEM_OP_CMD(SPINOR_OP_WR_CR2, 1), + SPI_MEM_OP_ADDR(4, SPINOR_REG_MXIC_CR2_DC, 1), + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_OUT(1, &buf, 1)); + + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) + return ret; + + ret = spi_nor_wait_till_ready(nor); + if (ret) + return ret; + + nor->read_dummy = MXIC_MAX_DC; + ret = write_enable(nor); + if (ret) + return ret; + + buf = SPINOR_REG_MXIC_OPI_DTR_EN; + op = (struct spi_mem_op) + SPI_MEM_OP(SPI_MEM_OP_CMD(SPINOR_OP_WR_CR2, 1), + SPI_MEM_OP_ADDR(4, SPINOR_REG_MXIC_CR2_MODE, 1), + SPI_MEM_OP_NO_DUMMY, + SPI_MEM_OP_DATA_OUT(1, &buf, 1)); + + ret = spi_mem_exec_op(nor->spi, &op); + if (ret) { + dev_err(nor->dev, "Failed to enable octal DTR mode\n"); + return ret; + } + nor->reg_proto = SNOR_PROTO_8_8_8_DTR; + + return 0; +} + +static void macronix_octal_default_init(struct spi_nor *nor) +{ + nor->octal_dtr_enable = spi_nor_macronix_octal_dtr_enable; +} + +static void macronix_octal_post_sfdp_fixup(struct spi_nor *nor, + struct spi_nor_flash_parameter *params) +{ + /* + * Adding SNOR_HWCAPS_PP_8_8_8_DTR in hwcaps.mask when + * SPI_NOR_OCTAL_DTR_READ flag exists. + */ + if (params->hwcaps.mask & SNOR_HWCAPS_READ_8_8_8_DTR) + params->hwcaps.mask |= SNOR_HWCAPS_PP_8_8_8_DTR; +} + +static struct spi_nor_fixups macronix_octal_fixups = { + .default_init = macronix_octal_default_init, + .post_sfdp = macronix_octal_post_sfdp_fixup, +}; +#endif /* CONFIG_SPI_FLASH_MACRONIX */ + /** spi_nor_octal_dtr_enable() - enable Octal DTR I/O if needed * @nor: pointer to a 'struct spi_nor' * @@ -3655,6 +3734,10 @@ void spi_nor_set_fixups(struct spi_nor *nor) if (!strcmp(nor->info->name, "mt35xu512aba")) nor->fixups = &mt35xu512aba_fixups; #endif + +#if CONFIG_IS_ENABLED(SPI_FLASH_MACRONIX) + nor->fixups = ¯onix_octal_fixups; +#endif /* SPI_FLASH_MACRONIX */ }
int spi_nor_scan(struct spi_nor *nor) diff --git a/include/linux/mtd/spi-nor.h b/include/linux/mtd/spi-nor.h index 7ddc4ba2bf..8682368f2f 100644 --- a/include/linux/mtd/spi-nor.h +++ b/include/linux/mtd/spi-nor.h @@ -116,8 +116,16 @@ #define XSR_RDY BIT(7) /* Ready */
/* Used for Macronix and Winbond flashes. */ -#define SPINOR_OP_EN4B 0xb7 /* Enter 4-byte mode */ -#define SPINOR_OP_EX4B 0xe9 /* Exit 4-byte mode */ +#define SPINOR_OP_EN4B 0xb7 /* Enter 4-byte mode */ +#define SPINOR_OP_EX4B 0xe9 /* Exit 4-byte mode */ +#define SPINOR_OP_RD_CR2 0x71 /* Read configuration register 2 */ +#define SPINOR_OP_WR_CR2 0x72 /* Write configuration register 2 */ +#define SPINOR_OP_MXIC_DTR_RD 0xee /* Fast Read opcode in DTR mode */ +#define SPINOR_REG_MXIC_CR2_MODE 0x00000000 /* For setting octal DTR mode */ +#define SPINOR_REG_MXIC_OPI_DTR_EN 0x2 /* Enable Octal DTR */ +#define SPINOR_REG_MXIC_CR2_DC 0x00000300 /* For setting dummy cycles */ +#define SPINOR_REG_MXIC_DC_20 0x0 /* Setting dummy cycles to 20 */ +#define MXIC_MAX_DC 20 /* Maximum value of dummy cycles */
/* Used for Spansion flashes only. */ #define SPINOR_OP_BRWR 0x17 /* Bank register write */
On 11/18/21 12:13 PM, JaimeLiao wrote:
EXTERNAL EMAIL: Do not click links or open attachments unless you know the content is safe
Hi, Jaime,
I have submitted a similar patch at https://lore.kernel.org/all/20211103162454.179191-2-tudor.ambarus@microchip....
but I think yours has precedence, you're already at v5.
- spi_nor_macronix_octal_dtr_enable() - set DTR OPI Enable bit in Configuration Register 2.
- @nor: pointer to a 'struct spi_nor'
- Set the DTR OPI Enable (DOPI) bit in Configuration Register 2.
- Bit 2 of Configuration Register 2 is the DOPI bit for Macronix like OPI memories.
- Return: 0 on success, -errno otherwise.
int ret;
u8 buf;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret) {
return ret;
Can't we determine the octal dtr method by parsing SFDP?
Cheers, ta
2.17.1
Hi Tudor
Hi, Jaime,
int ret;
u8 buf;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret) {
return ret;
It is a good idea for getting flash parameters by checking SFDP. Your patchwork is on-going to solve the ID collision issues in Linux kernel. I think U-boot should follow the method after ID collision patchwork finish in Linux kenel. So that octal dtr method follow the configuration for now.
Thanks Jaime
Cheers, ta
2.17.1
Hi Tudor
Hi, Jaime,
int ret;
u8 buf;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret) {
return ret;
What I meant was that if we can determine the octal dtr method from SFDP, we should use that. If we can't determine the octal dtr method from SFDP, or SFDP is skipped intentionally, then we can define explicit methods, as you did. But we'll need to differentiate between the two methods, otherwise maintaining the flash entries will become a burden.
Cheers, ta
Thanks Jaime
Cheers, ta
2.17.1
Hi Tudor
Hi Tudor
Hi, Jaime,
int ret;
u8 buf;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret)
return ret;
if (ret) {
return ret;
Sure, I prefer to parsing information from SFDP but not got according to configuration and differentiate methods via configuration "SPI_NOR_SKIP_SFDP". Hook corresponding function on .post_sfdp and .post_bfdp if configuration SPI_NOR_SKIP_SFDP existing. I need add the changes for v6 patch if you have any other idea. But I hope that we can seperate octal dtr support by two patches.
Cheers, ta
Thanks Jaime
Cheers, ta
2.17.1
Power-on-Reset is a method to restore flash back to 1S-1S-1S mode from 8D-8D-8D in the begging of probe.
Command extension type is not standardized across flash vendors in DTR mode.
For suiting different vendor flash devices, adding a flag to seperate types for soft reset on boot.
Signed-off-by: JaimeLiao jaimeliao.tw@gmail.com --- drivers/mtd/spi/Kconfig | 7 +++++++ drivers/mtd/spi/spi-nor-core.c | 7 ++++++- 2 files changed, 13 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/Kconfig b/drivers/mtd/spi/Kconfig index 1b2ef37e92..9b7d195770 100644 --- a/drivers/mtd/spi/Kconfig +++ b/drivers/mtd/spi/Kconfig @@ -97,6 +97,13 @@ config SPI_FLASH_SMART_HWCAPS can support a type of operation in a much more refined way compared to using flags like SPI_RX_DUAL, SPI_TX_QUAD, etc.
+config SPI_NOR_BOOT_SOFT_RESET_EXT_INVERT + bool "Command extension type is INVERT for Software Reset on boot" + default n + help + Because of SFDP information can not be get before boot. + So define command extension type is INVERT when Software Reset on boot only. + config SPI_FLASH_SOFT_RESET bool "Software Reset support for SPI NOR flashes" default n diff --git a/drivers/mtd/spi/spi-nor-core.c b/drivers/mtd/spi/spi-nor-core.c index 0a6550984b..2b6947cefc 100644 --- a/drivers/mtd/spi/spi-nor-core.c +++ b/drivers/mtd/spi/spi-nor-core.c @@ -3661,7 +3661,12 @@ static int spi_nor_soft_reset(struct spi_nor *nor) enum spi_nor_cmd_ext ext;
ext = nor->cmd_ext_type; - nor->cmd_ext_type = SPI_NOR_EXT_REPEAT; + if (nor->cmd_ext_type == SPI_NOR_EXT_NONE) { + nor->cmd_ext_type = SPI_NOR_EXT_REPEAT; +#if CONFIG_IS_ENABLED(SPI_NOR_BOOT_SOFT_RESET_EXT_INVERT) + nor->cmd_ext_type = SPI_NOR_EXT_INVERT; +#endif /* SPI_NOR_BOOT_SOFT_RESET_EXT_INVERT */ + }
op = (struct spi_mem_op)SPI_MEM_OP(SPI_MEM_OP_CMD(SPINOR_OP_SRSTEN, 0), SPI_MEM_OP_NO_DUMMY,
There will be many combinations of reset types and cmd_ext types, better to introduce a way to select the reset type and then to select the cmd_ext type so that we avoid introducing so many configs/dt props.
I think Pratyush is working to fix this, would you sync with him? Check the discussion at https://lore.kernel.org/all/20211103234950.202289-4-tudor.ambarus@microchip....
Cheers, ta
default n
help
} op = (struct spi_mem_op)SPI_MEM_OP(SPI_MEM_OP_CMD(SPINOR_OP_SRSTEN, 0), SPI_MEM_OP_NO_DUMMY,
-- 2.17.1
Hi Tudor
Sure, this configuration is according Pratyush suggestion.
Cheers, ta
default n
help
-- 2.17.1
Adding Macronix Octal flash for Octal DTR support.
The octaflash series can be divided into the following types:
MX25 series : Serial NOR Flash. MX66 series : Serial NOR Flash with stacked die.(Size larger than 1Gb) LM/UM series : Up to 250MHz clock frequency with both DTR/STR operation. LW/UW series : Support simultaneous Read-while-Write operation in multiple bank architecture. Read-while-write feature which means read data one bank while another bank is programing or erasing.
MX25LM : 3.0V Octal I/O -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7841/MX25LM51245G,%203V,...
MX25UM : 1.8V Octal I/O -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7525/MX25UM51245G%20Extr...
MX66LM : 3.0V Octal I/O with stacked die -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7929/MX66LM1G45G,%203V,%...
MX66UM : 1.8V Octal I/O with stacked die -https://www.mxic.com.tw/Lists/Datasheet/Attachments/7721/MX66UM1G45G,%201.8V...
MX25LW : 3.0V Octal I/O with Read-while-Write MX25UW : 1.8V Octal I/O with Read-while-Write MX66LW : 3.0V Octal I/O with Read-while-Write and stack die MX66UW : 1.8V Octal I/O with Read-while-Write and stack die
About LW/UW series, please contact us freely if you have any questions. For adding Octal NOR Flash IDs, we have validated each Flash on plateform zynq-picozed.
Signed-off-by: JaimeLiao jaimeliao.tw@gmail.com --- drivers/mtd/spi/spi-nor-ids.c | 22 +++++++++++++++++++++- 1 file changed, 21 insertions(+), 1 deletion(-)
diff --git a/drivers/mtd/spi/spi-nor-ids.c b/drivers/mtd/spi/spi-nor-ids.c index cb3a08872d..5c13ea3a78 100644 --- a/drivers/mtd/spi/spi-nor-ids.c +++ b/drivers/mtd/spi/spi-nor-ids.c @@ -169,7 +169,27 @@ const struct flash_info spi_nor_ids[] = { { INFO("mx66l1g45g", 0xc2201b, 0, 64 * 1024, 2048, SECT_4K | SPI_NOR_DUAL_READ | SPI_NOR_QUAD_READ) }, { INFO("mx25l1633e", 0xc22415, 0, 64 * 1024, 32, SPI_NOR_QUAD_READ | SPI_NOR_4B_OPCODES | SECT_4K) }, { INFO("mx25r6435f", 0xc22817, 0, 64 * 1024, 128, SECT_4K) }, - { INFO("mx66uw2g345g", 0xc2943c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66uw2g345gx0", 0xc2943c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66lm1g45g", 0xc2853b, 0, 32 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25lm51245g", 0xc2853a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25lw51245g", 0xc2863a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25lm25645g", 0xc28539, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66um2g45g", 0xc2803c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66uw2g345g", 0xc2843c, 0, 64 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66um1g45g", 0xc2803b, 0, 32 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx66uw1g45g", 0xc2813b, 0, 32 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25um51245g", 0xc2803a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw51245g", 0xc2813a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw51345g", 0xc2843a, 0, 16 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25um25645g", 0xc28039, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw25645g", 0xc28139, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25um25345g", 0xc28339, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw25345g", 0xc28439, 0, 8 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw12845g", 0xc28138, 0, 4 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw12a45g", 0xc28938, 0, 4 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw12345g", 0xc28438, 0, 4 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw6445g", 0xc28137, 0, 2 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, + { INFO("mx25uw6345g", 0xc28437, 0, 2 * 1024, 4096, SECT_4K | SPI_NOR_OCTAL_DTR_READ | SPI_NOR_4B_OPCODES) }, #endif
#ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */
which one of all these flashes (including the ones from below) support SFDP and which not? Which can discover the octal dtr method by parsing SFDP and which not? Depending on these those flash_info flags may change. Why do you need SPI_NOR_4B_OPCODES, can't this support be discovered when parsing SFDP? How about SECT_4K?
I know for sure there are variants of mx66lm1g45g that do not support SFDP, and flavors that do support SFDP. How you'll differentiate between the two flavors of the same flash?
I chose to SKIP SFDP parsing for mx66lm1g45g as there's no infrastructure to handle its case, neither in linux, nor u-boot. Here's what I proposed for now: https://lore.kernel.org/all/20211103234950.202289-3-tudor.ambarus@microchip....
Cheers, ta
#endif
2.17.1
Hi Tudor
I agree that we need a method for octal dtr support on flash which didn't include SFDP but the patch of method is separate with Octal DTR patch.
Cheers, ta
#endif
2.17.1
JaimeLiao
liao jaime
Tudor.Ambarus@microchip.com
