[PATCH v2 0/1] Add Radxa ROCK Pi S support in U-boot
ROCK Pi S is rk3308 soc based board from Radxa. Add board support in u-boot. Booting logs is accessible at https://paste.ubuntu.com/p/cJDRzBRdXq/
Akash Gajjar (1): arm64: dts: rockchip: rk3308: Add Radxa ROCK Pi S support
arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi | 17 ++ arch/arm/dts/rk3308-rock-pi-s.dts | 228 ++++++++++++++++++++++ board/rockchip/evb_rk3308/MAINTAINERS | 7 + configs/rock-pi-s-rk3308_defconfig | 89 +++++++++ 4 files changed, 341 insertions(+) create mode 100644 arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3308-rock-pi-s.dts create mode 100644 configs/rock-pi-s-rk3308_defconfig
Add Radxa ROCK 3 Model A support. sync rk3308-rock-pi-s.dts from Linux 6.2.0-rc7.
ROCK Pi S is RK3308 based SBC from radxa.com. ROCK Pi S has a, - 256MB/512MB DDR3 RAM - SD, NAND flash (optional on board 1/2/4/8Gb) - 100MB ethernet, PoE (optional) - Onboard 802.11 b/g/n wifi + Bluetooth 4.0 Module - USB2.0 Type-A HOST x1 - USB3.0 Type-C OTG x1 - 26-pin expansion header - USB Type-C DC 5V Power Supply
Linux commit commit for the same, <2e04c25b1320> ("arm64: dts: rockchip: add ROCK Pi S DTS support")
Signed-off-by: Akash Gajjar gajjar04akash@gmail.com --- Changes in v2: - Add MAINTAINER for the board --- arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi | 17 ++ arch/arm/dts/rk3308-rock-pi-s.dts | 228 ++++++++++++++++++++++ board/rockchip/evb_rk3308/MAINTAINERS | 7 + configs/rock-pi-s-rk3308_defconfig | 89 +++++++++ 4 files changed, 341 insertions(+) create mode 100644 arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi create mode 100644 arch/arm/dts/rk3308-rock-pi-s.dts create mode 100644 configs/rock-pi-s-rk3308_defconfig
diff --git a/arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi b/arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi new file mode 100644 index 0000000000..27735c49dd --- /dev/null +++ b/arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi @@ -0,0 +1,17 @@ +// SPDX-License-Identifier: GPL-2.0+ +/* + * (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd + */ +#include "rk3308-u-boot.dtsi" + +/ { + chosen { + u-boot,spl-boot-order = "same-as-spl", &emmc; + }; +}; + +&uart0 { + u-boot,dm-pre-reloc; + clock-frequency = <24000000>; + status = "okay"; +}; diff --git a/arch/arm/dts/rk3308-rock-pi-s.dts b/arch/arm/dts/rk3308-rock-pi-s.dts new file mode 100644 index 0000000000..b5a8691b3f --- /dev/null +++ b/arch/arm/dts/rk3308-rock-pi-s.dts @@ -0,0 +1,228 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) +/* + * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd + * Copyright (C) 2023 Akash Gajjar gajjar04akash@gmail.com + * Copyright (c) 2023 Jagan Teki jagan@openedev.com + */ + +/dts-v1/; +#include <dt-bindings/input/input.h> +#include "rk3308.dtsi" + +/ { + model = "Radxa ROCK Pi S"; + compatible = "radxa,rockpis", "rockchip,rk3308"; + + aliases { + ethernet0 = &mac; + mmc0 = &emmc; + mmc1 = &sdmmc; + }; + + chosen { + stdout-path = "serial0:1500000n8"; + }; + + leds { + compatible = "gpio-leds"; + pinctrl-names = "default"; + pinctrl-0 = <&green_led_gio>, <&heartbeat_led_gpio>; + + green-led { + default-state = "on"; + gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; + label = "rockpis:green:power"; + linux,default-trigger = "default-on"; + }; + + blue-led { + default-state = "on"; + gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; + label = "rockpis:blue:user"; + linux,default-trigger = "heartbeat"; + }; + }; + + sdio_pwrseq: sdio-pwrseq { + compatible = "mmc-pwrseq-simple"; + pinctrl-0 = <&wifi_enable_h>; + pinctrl-names = "default"; + reset-gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_LOW>; + }; + + vcc_1v8: vcc-1v8 { + compatible = "regulator-fixed"; + regulator-name = "vcc_1v8"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1800000>; + regulator-max-microvolt = <1800000>; + vin-supply = <&vcc_io>; + }; + + vcc_io: vcc-io { + compatible = "regulator-fixed"; + regulator-name = "vcc_io"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <3300000>; + regulator-max-microvolt = <3300000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc_ddr: vcc-ddr { + compatible = "regulator-fixed"; + regulator-name = "vcc_ddr"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1500000>; + regulator-max-microvolt = <1500000>; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_otg: vcc5v0-otg { + compatible = "regulator-fixed"; + enable-active-high; + gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; + pinctrl-names = "default"; + pinctrl-0 = <&otg_vbus_drv>; + regulator-name = "vcc5v0_otg"; + regulator-always-on; + vin-supply = <&vcc5v0_sys>; + }; + + vcc5v0_sys: vcc5v0-sys { + compatible = "regulator-fixed"; + regulator-name = "vcc5v0_sys"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <5000000>; + regulator-max-microvolt = <5000000>; + }; + + vdd_core: vdd-core { + compatible = "pwm-regulator"; + pwms = <&pwm0 0 5000 1>; + pwm-supply = <&vcc5v0_sys>; + regulator-name = "vdd_core"; + regulator-min-microvolt = <827000>; + regulator-max-microvolt = <1340000>; + regulator-init-microvolt = <1015000>; + regulator-settling-time-up-us = <250>; + regulator-always-on; + regulator-boot-on; + }; + + vdd_log: vdd-log { + compatible = "regulator-fixed"; + regulator-name = "vdd_log"; + regulator-always-on; + regulator-boot-on; + regulator-min-microvolt = <1050000>; + regulator-max-microvolt = <1050000>; + vin-supply = <&vcc5v0_sys>; + }; +}; + +&cpu0 { + cpu-supply = <&vdd_core>; +}; + +&emmc { + bus-width = <4>; + cap-mmc-highspeed; + mmc-hs200-1_8v; + non-removable; + vmmc-supply = <&vcc_io>; + status = "okay"; +}; + +&mac { + clock_in_out = "output"; + phy-supply = <&vcc_io>; + snps,reset-gpio = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; + snps,reset-active-low; + snps,reset-delays-us = <0 50000 50000>; + status = "okay"; +}; + +&i2c1 { + status = "okay"; +}; + +&pinctrl { + pinctrl-names = "default"; + pinctrl-0 = <&rtc_32k>; + + leds { + green_led_gio: green-led-gpio { + rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + heartbeat_led_gpio: heartbeat-led-gpio { + rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + usb { + otg_vbus_drv: otg-vbus-drv { + rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; + }; + }; + + sdio-pwrseq { + wifi_enable_h: wifi-enable-h { + rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; + }; + + wifi_host_wake: wifi-host-wake { + rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_down>; + }; + }; +}; + +&pwm0 { + status = "okay"; + pinctrl-0 = <&pwm0_pin_pull_down>; +}; + +&saradc { + vref-supply = <&vcc_1v8>; + status = "okay"; +}; + +&sdio { + #address-cells = <1>; + #size-cells = <0>; + cap-sd-highspeed; + cap-sdio-irq; + keep-power-in-suspend; + max-frequency = <1000000>; + mmc-pwrseq = <&sdio_pwrseq>; + non-removable; + sd-uhs-sdr104; + status = "okay"; +}; + +&sdmmc { + cap-sd-highspeed; + status = "okay"; +}; + +&uart0 { + status = "okay"; +}; + +&uart4 { + status = "okay"; + + bluetooth { + compatible = "realtek,rtl8723bs-bt"; + device-wake-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_HIGH>; + host-wake-gpios = <&gpio4 RK_PB4 GPIO_ACTIVE_HIGH>; + }; +}; + +&wdt { + status = "okay"; +}; diff --git a/board/rockchip/evb_rk3308/MAINTAINERS b/board/rockchip/evb_rk3308/MAINTAINERS index 0af119ae0a..fe2c5f004c 100644 --- a/board/rockchip/evb_rk3308/MAINTAINERS +++ b/board/rockchip/evb_rk3308/MAINTAINERS @@ -4,3 +4,10 @@ S: Maintained F: board/rockchip/evb_rk3308 F: include/configs/evb_rk3308.h F: configs/evb-rk3308_defconfig + +ROCK-PI-S +M: Akash Gajjar gajjar04akash@gmail.com +S: Maintained +F: configs/rock-pi-s-rk3308_defconfig +F: arch/arm/dts/rk3308-rock-pi-s.dts +F: arch/arm/dts/rk3308-rock-pi-s-u-boot.dtsi diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig new file mode 100644 index 0000000000..6c863381a7 --- /dev/null +++ b/configs/rock-pi-s-rk3308_defconfig @@ -0,0 +1,89 @@ +CONFIG_ARM=y +CONFIG_SKIP_LOWLEVEL_INIT=y +CONFIG_COUNTER_FREQUENCY=24000000 +CONFIG_ARCH_ROCKCHIP=y +CONFIG_TEXT_BASE=0x00600000 +CONFIG_SYS_MALLOC_F_LEN=0x2000 +CONFIG_SPL_LIBCOMMON_SUPPORT=y +CONFIG_SPL_LIBGENERIC_SUPPORT=y +CONFIG_DEFAULT_DEVICE_TREE="rk3308-rock-pi-s" +CONFIG_ROCKCHIP_RK3308=y +CONFIG_ROCKCHIP_SPL_RESERVE_IRAM=0x0 +CONFIG_SPL_DRIVERS_MISC=y +CONFIG_TARGET_EVB_RK3308=y +CONFIG_SPL_STACK_R_ADDR=0xc00000 +CONFIG_DEBUG_UART_BASE=0xFF0A0000 +CONFIG_DEBUG_UART_CLOCK=24000000 +CONFIG_SYS_LOAD_ADDR=0xc00800 +CONFIG_DEBUG_UART=y +CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y +CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x800000 +CONFIG_ANDROID_BOOT_IMAGE=y +CONFIG_FIT=y +CONFIG_FIT_VERBOSE=y +CONFIG_BOOTDELAY=0 +CONFIG_SYS_CONSOLE_INFO_QUIET=y +# CONFIG_DISPLAY_CPUINFO is not set +CONFIG_SPL_MAX_SIZE=0x20000 +CONFIG_SPL_PAD_TO=0x7f8000 +CONFIG_SPL_HAS_BSS_LINKER_SECTION=y +CONFIG_SPL_BSS_START_ADDR=0x400000 +CONFIG_SPL_BSS_MAX_SIZE=0x2000 +# CONFIG_SPL_SHARES_INIT_SP_ADDR is not set +CONFIG_SPL_STACK=0x400000 +CONFIG_SPL_STACK_R=y +# CONFIG_CMD_BDI is not set +# CONFIG_CMD_CONSOLE is not set +# CONFIG_CMD_ELF is not set +# CONFIG_CMD_IMI is not set +# CONFIG_CMD_XIMG is not set +CONFIG_CMD_GPT=y +# CONFIG_CMD_LOADB is not set +# CONFIG_CMD_LOADS is not set +CONFIG_CMD_MMC=y +CONFIG_CMD_USB=y +CONFIG_CMD_USB_MASS_STORAGE=y +# CONFIG_CMD_ITEST is not set +# CONFIG_CMD_SETEXPR is not set +# CONFIG_CMD_SLEEP is not set +# CONFIG_DOS_PARTITION is not set +# CONFIG_ISO_PARTITION is not set +CONFIG_EFI_PARTITION_ENTRIES_NUMBERS=64 +CONFIG_SPL_OF_CONTROL=y +CONFIG_OF_LIVE=y +CONFIG_OF_SPL_REMOVE_PROPS="pinctrl-0 pinctrl-names clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" +CONFIG_SYS_RELOC_GD_ENV_ADDR=y +CONFIG_REGMAP=y +CONFIG_SYSCON=y +CONFIG_CLK=y +# CONFIG_USB_FUNCTION_FASTBOOT is not set +CONFIG_ROCKCHIP_GPIO=y +CONFIG_SYS_I2C_ROCKCHIP=y +CONFIG_SUPPORT_EMMC_RPMB=y +CONFIG_MMC_DW=y +CONFIG_MMC_DW_ROCKCHIP=y +CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y +CONFIG_PHY=y +CONFIG_PINCTRL=y +CONFIG_REGULATOR_PWM=y +CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_ROCKCHIP=y +CONFIG_RAM=y +CONFIG_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_LZO=y +CONFIG_ERRNO_STR=y +# CONFIG_EFI_LOADER is not set
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Changes in v2:
- (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd
- chosen {
+&uart0 {
- u-boot,dm-pre-reloc;
- clock-frequency = <24000000>;
- status = "okay";
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (C) 2023 Akash Gajjar gajjar04akash@gmail.com
- Copyright (c) 2023 Jagan Teki jagan@openedev.com
- model = "Radxa ROCK Pi S";
- compatible = "radxa,rockpis", "rockchip,rk3308";
- aliases {
ethernet0 = &mac;
mmc0 = &emmc;
mmc1 = &sdmmc;
- chosen {
- leds {
green-led {
blue-led {
- sdio_pwrseq: sdio-pwrseq {
- vcc_1v8: vcc-1v8 {
regulator-boot-on;
- vcc_io: vcc-io {
regulator-boot-on;
- vcc_ddr: vcc-ddr {
regulator-boot-on;
- vcc5v0_otg: vcc5v0-otg {
enable-active-high;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
- vdd_core: vdd-core {
regulator-boot-on;
- vdd_log: vdd-log {
regulator-boot-on;
+&cpu0 {
- cpu-supply = <&vdd_core>;
+&emmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
- non-removable;
- vmmc-supply = <&vcc_io>;
- status = "okay";
+&mac {
- clock_in_out = "output";
- phy-supply = <&vcc_io>;
- snps,reset-gpio = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 50000 50000>;
- status = "okay";
+&i2c1 {
- status = "okay";
+&pinctrl {
- pinctrl-names = "default";
- pinctrl-0 = <&rtc_32k>;
- leds {
- usb {
- sdio-pwrseq {
+&pwm0 {
- status = "okay";
- pinctrl-0 = <&pwm0_pin_pull_down>;
+&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
+&sdio {
- #address-cells = <1>;
- #size-cells = <0>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- max-frequency = <1000000>;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
+&sdmmc {
- cap-sd-highspeed;
- status = "okay";
+&uart0 {
- status = "okay";
+&uart4 {
- status = "okay";
- bluetooth {
+&wdt {
- status = "okay";
I've tried to build u-boot for Rock Pi S, but without success. With master and 2023.04, too.
Could you clarify which is the support provided with this commit?
I had a look at doc/board/rockchip/rockchip.rst where Rock Pi S is not listed. Anyway, looking at what is described in doc/README.rockchip for roc-cc-rk3308 board, it seems U-Boot source code is not enough to build an SPL as complete idbloader for RK3308, but instead it needs an external TPL: isn't it? Therefore I would have expected a CONFIG_ROCKCHIP_EXTERNAL_TPL in the defconfig. Which one of the ddr binaries provided in the rkbin Rockchip repository need to be used as TPL?
And which binary to be used as BL31? As far as I know TF-A code is not available as open source for RK3308.
Is there any difference (in TPL and BL31 binaries selection) if Rock Pi S is equipped with RK3308B or RK3308B-S chip?
A few lines in the documentation would really help. Thanks in advance.
Best regards, Massimo
-----Messaggio originale----- Da: U-Boot u-boot-bounces@lists.denx.de Per conto di Kever Yang Inviato: giovedì 16 febbraio 2023 09:41 A: Akash Gajjar gajjar04akash@gmail.com; naoki@radxa.com Cc: Simon Glass sjg@chromium.org; Philipp Tomsich philipp.tomsich@vrull.eu; Andy Yan andy.yan@rock-chips.com; u- boot@lists.denx.de Oggetto: Re: [PATCH v2 1/1] arm64: dts: rockchip: rk3308: Add Radxa ROCK Pi S support
Thanks,
- Kever
Changes in v2:
- (C) Copyright 2018-2019 Rockchip Electronics Co., Ltd */ #include
+"rk3308-u-boot.dtsi"
- chosen {
+&uart0 {
- status = "okay";
- Copyright (c) 2023 Jagan Teki jagan@openedev.com */
- aliases {
ethernet0 = &mac;
mmc0 = &emmc;
mmc1 = &sdmmc;
- chosen {
- leds {
green-led {
blue-led {
regulator-boot-on;
- vcc_io: vcc-io {
regulator-boot-on;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
+&cpu0 {
+&emmc {
- bus-width = <4>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
+&mac {
- status = "okay";
+&i2c1 {
- status = "okay";
+&pinctrl {
- leds {
&pcfg_pull_none>;
&pcfg_pull_none>;
- usb {
&pcfg_pull_none>;
- sdio-pwrseq {
&pcfg_pull_none>;
&pcfg_pull_down>;
+&pwm0 {
- status = "okay";
+&saradc {
- status = "okay";
+&sdio {
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
+&sdmmc {
- cap-sd-highspeed;
- status = "okay";
+&uart0 {
- status = "okay";
+&uart4 {
- status = "okay";
- bluetooth {
+&wdt {
- status = "okay";
+CONFIG_SYS_I2C_ROCKCHIP=y CONFIG_SUPPORT_EMMC_RPMB=y
CONFIG_MMC_DW=y
+CONFIG_MMC_DW_ROCKCHIP=y CONFIG_ETH_DESIGNWARE=y +CONFIG_GMAC_ROCKCHIP=y CONFIG_PHY=y CONFIG_PINCTRL=y +CONFIG_REGULATOR_PWM=y CONFIG_DM_REGULATOR_FIXED=y +CONFIG_PWM_ROCKCHIP=y CONFIG_RAM=y CONFIG_DM_RESET=y +CONFIG_BAUDRATE=1500000 +CONFIG_DEBUG_UART_SHIFT=2 +CONFIG_DEBUG_UART_SKIP_INIT=y +CONFIG_SYS_NS16550_MEM32=y +CONFIG_SYSRESET=y +CONFIG_USB=y +CONFIG_USB_EHCI_HCD=y +CONFIG_USB_EHCI_GENERIC=y +CONFIG_USB_DWC2=y +CONFIG_USB_GADGET=y +CONFIG_USB_GADGET_DWC2_OTG=y +CONFIG_USB_GADGET_DOWNLOAD=y +CONFIG_SPL_TINY_MEMSET=y +CONFIG_LZO=y +CONFIG_ERRNO_STR=y +# CONFIG_EFI_LOADER is not set
Akash Gajjar
Kever Yang
Pegorer Massimo
