[U-Boot] [PATCH] armv8: fsl-layerscape: Fix early MMU table for nand boot
The early MMU table doesn't enable all addresses. Unused addresses are marked as invalid, as introduced by commit 9979922. An entry was missing for NAND flash space, causing nand boot failure.
Signed-off-by: York Sun yorksun@freescale.com CC: Alison Wang alison.wang@freescale.com CC: Prabhakar Kushwaha prabhakar@freescale.com
arch/arm/include/asm/arch-fsl-layerscape/cpu.h | 2 ++ 1 file changed, 2 insertions(+)
diff --git a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h index 727fd24..1012935 100644 --- a/arch/arm/include/asm/arch-fsl-layerscape/cpu.h +++ b/arch/arm/include/asm/arch-fsl-layerscape/cpu.h @@ -130,6 +130,8 @@ static const struct sys_mmu_table early_mmu_table[] = { CONFIG_SYS_FSL_IFC_SIZE1, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, { CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_BASE1, CONFIG_SYS_FSL_DRAM_SIZE1, MT_NORMAL, PMD_SECT_OUTER_SHARE }, + { CONFIG_SYS_FSL_IFC_BASE2, CONFIG_SYS_FSL_IFC_BASE2, + CONFIG_SYS_FSL_IFC_SIZE2, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE }, { CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_BASE, CONFIG_SYS_FSL_DCSR_SIZE, MT_DEVICE_NGNRNE, PMD_SECT_NON_SHARE | PMD_SECT_PXN | PMD_SECT_UXN },
York Sun
