[U-Boot-Users] S29GLxxxM Flash write buffer programming
8 Apr
2005
8 Apr
'05
12:42 p.m.
Hi all,
I am using Spansion S29GL128M / AMD Am29LV128M flash in 8-Bit mode on our Board. Older Versions of this Flash supported a "Byte Program" mode to write a single byte into flash. Newer versions don't support this command. According to Datasheet you should use "Write Buffer Programming" in X8 (8-Bit) mode. My question is, if anyone has experience in using this Flash in X8 mode with U-Boot and/or Linux?
Thanks Sebastian
7333
Sebastian Schau
