[U-Boot] [PATCH] x86: tsc: add support for reading CPU freq from cpuid
Starting with cpuid level 0x16 (Skylake-based processors) it is possible to get CPU base freq via cpuid.
This fixes booting on a skylake based system.
Signed-off-by: Christian Gmeiner christian.gmeiner@gmail.com --- drivers/timer/tsc_timer.c | 31 +++++++++++++++++++++++++------ 1 file changed, 25 insertions(+), 6 deletions(-)
diff --git a/drivers/timer/tsc_timer.c b/drivers/timer/tsc_timer.c index c7fefd2031..96a3e55513 100644 --- a/drivers/timer/tsc_timer.c +++ b/drivers/timer/tsc_timer.c @@ -21,6 +21,17 @@
DECLARE_GLOBAL_DATA_PTR;
+static unsigned long cpu_mhz_from_cpuid(void) +{ + if (gd->arch.x86_vendor != X86_VENDOR_INTEL) + return 0; + + if (cpuid_eax(0) < 0x16) + return 0; + + return cpuid_eax(0x16); +} + /* * According to Intel 64 and IA-32 System Programming Guide, * if MSR_PERF_STAT[31] is set, the maximum resolved bus ratio can be @@ -343,14 +354,22 @@ static void tsc_timer_ensure_setup(void) if (!gd->arch.clock_rate) { unsigned long fast_calibrate;
+ fast_calibrate = cpu_mhz_from_cpuid(); + if (fast_calibrate) + goto done; + fast_calibrate = cpu_mhz_from_msr(); - if (!fast_calibrate) { - fast_calibrate = quick_pit_calibrate(); - if (!fast_calibrate) - panic("TSC frequency is ZERO"); - } + if (fast_calibrate) + goto done; + + fast_calibrate = quick_pit_calibrate(); + if (fast_calibrate) + goto done; + + panic("TSC frequency is ZERO");
- gd->arch.clock_rate = fast_calibrate * 1000000; + done: + gd->arch.clock_rate = fast_calibrate * 1000000; } }
ping
Am Mo., 14. Mai 2018 um 11:32 Uhr schrieb Christian Gmeiner < christian.gmeiner@gmail.com>:
- According to Intel 64 and IA-32 System Programming Guide,
- if MSR_PERF_STAT[31] is set, the maximum resolved bus ratio can be
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
done:
}gd->arch.clock_rate = fast_calibrate * 1000000; }
-- 2.17.0
On Mon, May 14, 2018 at 5:32 PM, Christian Gmeiner christian.gmeiner@gmail.com wrote:
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
done:
nits: this indention is wrong, and will cause checkpatch warnings.
I can fix the nits when applying.
Regards, Bin
Am Mi., 23. Mai 2018 um 11:48 Uhr schrieb Bin Meng bmeng.cn@gmail.com:
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
done:
Oops.
That would be great - thanks!
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
if (fast_calibrate)
goto done;
done:
Fixed the nits and applied to u-boot-x86, thanks!
Bin Meng
Christian Gmeiner
