[U-Boot] [PATCH 1/3] misc:pmic: Support for voltage to register value conversion function
Support for voltage (in uV) to proper register value is added. The function tied to this callback is often PMIC dependent and shall be defined for each device.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- drivers/misc/pmic_core.c | 10 ++++++++++ include/pmic.h | 2 ++ 2 files changed, 12 insertions(+), 0 deletions(-)
diff --git a/drivers/misc/pmic_core.c b/drivers/misc/pmic_core.c index 5d62a56..4366bf0 100644 --- a/drivers/misc/pmic_core.c +++ b/drivers/misc/pmic_core.c @@ -89,6 +89,16 @@ struct pmic *get_pmic(void) return &pmic; }
+int pmic_vol_to_reg(struct pmic *p, int uV) +{ + if (p->voltage_to_reg_conv == NULL) { + puts("PMIC: Voltage to register value function not defined\n"); + return 0; + } + + return p->voltage_to_reg_conv(uV); +} + int do_pmic(cmd_tbl_t *cmdtp, int flag, int argc, char * const argv[]) { u32 ret, reg, val; diff --git a/include/pmic.h b/include/pmic.h index 52a1526..f8594a9 100644 --- a/include/pmic.h +++ b/include/pmic.h @@ -52,12 +52,14 @@ struct pmic { struct p_i2c i2c; struct p_spi spi; } hw; + int (*voltage_to_reg_conv) (int uV); };
int pmic_init(void); int check_reg(u32 reg); struct pmic *get_pmic(void); int pmic_probe(struct pmic *p); +int pmic_vol_to_reg(struct pmic *p, int uV); int pmic_reg_read(struct pmic *p, u32 reg, u32 *val); int pmic_reg_write(struct pmic *p, u32 reg, u32 val); int pmic_set_output(struct pmic *p, u32 reg, int ldo, int on);
This commit adds support for MAX8997 PMIC driver.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Stefano Babic sbabic@denx.de --- drivers/misc/Makefile | 1 + drivers/misc/pmic_max8997.c | 60 ++++++++++++++ include/max8997_pmic.h | 190 +++++++++++++++++++++++++++++++++++++++++++ 3 files changed, 251 insertions(+), 0 deletions(-) create mode 100644 drivers/misc/pmic_max8997.c create mode 100644 include/max8997_pmic.h
diff --git a/drivers/misc/Makefile b/drivers/misc/Makefile index a709707..30c7f8d 100644 --- a/drivers/misc/Makefile +++ b/drivers/misc/Makefile @@ -39,6 +39,7 @@ COBJS-$(CONFIG_PMIC_FSL) += pmic_fsl.o COBJS-$(CONFIG_PMIC_I2C) += pmic_i2c.o COBJS-$(CONFIG_PMIC_SPI) += pmic_spi.o COBJS-$(CONFIG_PMIC_MAX8998) += pmic_max8998.o +COBJS-$(CONFIG_PMIC_MAX8997) += pmic_max8997.o
COBJS := $(COBJS-y) SRCS := $(COBJS:.o=.c) diff --git a/drivers/misc/pmic_max8997.c b/drivers/misc/pmic_max8997.c new file mode 100644 index 0000000..506162f --- /dev/null +++ b/drivers/misc/pmic_max8997.c @@ -0,0 +1,60 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#include <common.h> +#include <pmic.h> +#include <max8997_pmic.h> + +int voltage_to_reg(int uV) +{ + unsigned char ret; + if (uV <= 800000) + return 0; + if (uV >= 3950000) + return 0x3f; + ret = (uV - 800000) / 50000; + if (ret > 0x3f) { + printf("MAX8997 LDO SETTING ERROR (%duV) -> %u\n", uV, ret); + ret = 0x3f; + } + + return ret; +} + +int pmic_init(void) +{ + struct pmic *p = get_pmic(); + static const char name[] = "MAX8997_PMIC"; + + puts("Board PMIC init\n"); + + p->name = name; + p->interface = PMIC_I2C; + p->number_of_regs = PMIC_NUM_OF_REGS; + p->hw.i2c.addr = MAX8997_I2C_ADDR; + p->hw.i2c.tx_num = 1; + p->bus = I2C_PMIC; + p->voltage_to_reg_conv = voltage_to_reg; + + return 0; +} diff --git a/include/max8997_pmic.h b/include/max8997_pmic.h new file mode 100644 index 0000000..17ae24e --- /dev/null +++ b/include/max8997_pmic.h @@ -0,0 +1,190 @@ +/* + * Copyright (C) 2011 Samsung Electronics + * Lukasz Majewski l.majewski@samsung.com + * + * See file CREDITS for list of people who contributed to this + * project. + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; either version 2 of + * the License, or (at your option) any later version. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 59 Temple Place, Suite 330, Boston, + * MA 02111-1307 USA + */ + +#ifndef __MAX8997_PMIC_H_ +#define __MAX8997_PMIC_H_ + +/* MAX 8997 registers */ +enum { + MAX8997_REG_PMIC_ID0 = 0x00, + MAX8997_REG_PMIC_ID1 = 0x01, + MAX8997_REG_INTSRC = 0x02, + MAX8997_REG_INT1 = 0x03, + MAX8997_REG_INT2 = 0x04, + MAX8997_REG_INT3 = 0x05, + MAX8997_REG_INT4 = 0x06, + + MAX8997_REG_INT1MSK = 0x08, + MAX8997_REG_INT2MSK = 0x09, + MAX8997_REG_INT3MSK = 0x0a, + MAX8997_REG_INT4MSK = 0x0b, + + MAX8997_REG_STATUS1 = 0x0d, + MAX8997_REG_STATUS2 = 0x0e, + MAX8997_REG_STATUS3 = 0x0f, + MAX8997_REG_STATUS4 = 0x10, + + MAX8997_REG_MAINCON1 = 0x13, + MAX8997_REG_MAINCON2 = 0x14, + MAX8997_REG_BUCKRAMP = 0x15, + + MAX8997_REG_BUCK1CTRL = 0x18, + MAX8997_REG_BUCK1DVS1 = 0x19, + MAX8997_REG_BUCK1DVS2 = 0x1a, + MAX8997_REG_BUCK1DVS3 = 0x1b, + MAX8997_REG_BUCK1DVS4 = 0x1c, + MAX8997_REG_BUCK1DVS5 = 0x1d, + MAX8997_REG_BUCK1DVS6 = 0x1e, + MAX8997_REG_BUCK1DVS7 = 0x1f, + MAX8997_REG_BUCK1DVS8 = 0x20, + MAX8997_REG_BUCK2CTRL = 0x21, + MAX8997_REG_BUCK2DVS1 = 0x22, + MAX8997_REG_BUCK2DVS2 = 0x23, + MAX8997_REG_BUCK2DVS3 = 0x24, + MAX8997_REG_BUCK2DVS4 = 0x25, + MAX8997_REG_BUCK2DVS5 = 0x26, + MAX8997_REG_BUCK2DVS6 = 0x27, + MAX8997_REG_BUCK2DVS7 = 0x28, + MAX8997_REG_BUCK2DVS8 = 0x29, + MAX8997_REG_BUCK3CTRL = 0x2a, + MAX8997_REG_BUCK3DVS = 0x2b, + MAX8997_REG_BUCK4CTRL = 0x2c, + MAX8997_REG_BUCK4DVS = 0x2d, + MAX8997_REG_BUCK5CTRL = 0x2e, + MAX8997_REG_BUCK5DVS1 = 0x2f, + MAX8997_REG_BUCK5DVS2 = 0x30, + MAX8997_REG_BUCK5DVS3 = 0x31, + MAX8997_REG_BUCK5DVS4 = 0x32, + MAX8997_REG_BUCK5DVS5 = 0x33, + MAX8997_REG_BUCK5DVS6 = 0x34, + MAX8997_REG_BUCK5DVS7 = 0x35, + MAX8997_REG_BUCK5DVS8 = 0x36, + MAX8997_REG_BUCK6CTRL = 0x37, + MAX8997_REG_BUCK6BPSKIPCTRL = 0x38, + MAX8997_REG_BUCK7CTRL = 0x39, + MAX8997_REG_BUCK7DVS = 0x3a, + MAX8997_REG_LDO1CTRL = 0x3b, + MAX8997_REG_LDO2CTRL = 0x3c, + MAX8997_REG_LDO3CTRL = 0x3d, + MAX8997_REG_LDO4CTRL = 0x3e, + MAX8997_REG_LDO5CTRL = 0x3f, + MAX8997_REG_LDO6CTRL = 0x40, + MAX8997_REG_LDO7CTRL = 0x41, + MAX8997_REG_LDO8CTRL = 0x42, + MAX8997_REG_LDO9CTRL = 0x43, + MAX8997_REG_LDO10CTRL = 0x44, + MAX8997_REG_LDO11CTRL = 0x45, + MAX8997_REG_LDO12CTRL = 0x46, + MAX8997_REG_LDO13CTRL = 0x47, + MAX8997_REG_LDO14CTRL = 0x48, + MAX8997_REG_LDO15CTRL = 0x49, + MAX8997_REG_LDO16CTRL = 0x4a, + MAX8997_REG_LDO17CTRL = 0x4b, + MAX8997_REG_LDO18CTRL = 0x4c, + MAX8997_REG_LDO21CTRL = 0x4d, + + MAX8997_REG_MBCCTRL1 = 0x50, + MAX8997_REG_MBCCTRL2 = 0x51, + MAX8997_REG_MBCCTRL3 = 0x52, + MAX8997_REG_MBCCTRL4 = 0x53, + MAX8997_REG_MBCCTRL5 = 0x54, + MAX8997_REG_MBCCTRL6 = 0x55, + MAX8997_REG_OTPCGHCVS = 0x56, + + MAX8997_REG_SAFEOUTCTRL = 0x5a, + + MAX8997_REG_LBCNFG1 = 0x5e, + MAX8997_REG_LBCNFG2 = 0x5f, + MAX8997_REG_BBCCTRL = 0x60, + + MAX8997_REG_FLASH1_CUR = 0x63, /* 0x63 ~ 0x6e for FLASH */ + MAX8997_REG_FLASH2_CUR = 0x64, + MAX8997_REG_MOVIE_CUR = 0x65, + MAX8997_REG_GSMB_CUR = 0x66, + MAX8997_REG_BOOST_CNTL = 0x67, + MAX8997_REG_LEN_CNTL = 0x68, + MAX8997_REG_FLASH_CNTL = 0x69, + MAX8997_REG_WDT_CNTL = 0x6a, + MAX8997_REG_MAXFLASH1 = 0x6b, + MAX8997_REG_MAXFLASH2 = 0x6c, + MAX8997_REG_FLASHSTATUS = 0x6d, + MAX8997_REG_FLASHSTATUSMASK = 0x6e, + + MAX8997_REG_GPIOCNTL1 = 0x70, + MAX8997_REG_GPIOCNTL2 = 0x71, + MAX8997_REG_GPIOCNTL3 = 0x72, + MAX8997_REG_GPIOCNTL4 = 0x73, + MAX8997_REG_GPIOCNTL5 = 0x74, + MAX8997_REG_GPIOCNTL6 = 0x75, + MAX8997_REG_GPIOCNTL7 = 0x76, + MAX8997_REG_GPIOCNTL8 = 0x77, + MAX8997_REG_GPIOCNTL9 = 0x78, + MAX8997_REG_GPIOCNTL10 = 0x79, + MAX8997_REG_GPIOCNTL11 = 0x7a, + MAX8997_REG_GPIOCNTL12 = 0x7b, + + MAX8997_REG_LDO1CONFIG = 0x80, + MAX8997_REG_LDO2CONFIG = 0x81, + MAX8997_REG_LDO3CONFIG = 0x82, + MAX8997_REG_LDO4CONFIG = 0x83, + MAX8997_REG_LDO5CONFIG = 0x84, + MAX8997_REG_LDO6CONFIG = 0x85, + MAX8997_REG_LDO7CONFIG = 0x86, + MAX8997_REG_LDO8CONFIG = 0x87, + MAX8997_REG_LDO9CONFIG = 0x88, + MAX8997_REG_LDO10CONFIG = 0x89, + MAX8997_REG_LDO11CONFIG = 0x8a, + MAX8997_REG_LDO12CONFIG = 0x8b, + MAX8997_REG_LDO13CONFIG = 0x8c, + MAX8997_REG_LDO14CONFIG = 0x8d, + MAX8997_REG_LDO15CONFIG = 0x8e, + MAX8997_REG_LDO16CONFIG = 0x8f, + MAX8997_REG_LDO17CONFIG = 0x90, + MAX8997_REG_LDO18CONFIG = 0x91, + MAX8997_REG_LDO21CONFIG = 0x92, + + MAX8997_REG_DVSOKTIMER1 = 0x97, + MAX8997_REG_DVSOKTIMER2 = 0x98, + MAX8997_REG_DVSOKTIMER4 = 0x99, + MAX8997_REG_DVSOKTIMER5 = 0x9a, + + PMIC_NUM_OF_REGS = 0x9b, +}; + +#define ENSAFEOUT1 (1 << 6) +#define ENSAFEOUT2 (1 << 7) + +#define MAX8997_I2C_ADDR (0xCC >> 1) +#define MAX8997_RTC_ADDR (0x0C >> 1) +#define MAX8997_MUIC_ADDR (0x4A >> 1) +#define MAX8997_FG_ADDR (0x6C >> 1) + +enum { + LDO_OFF = 0, + LDO_ON = 1, + + DIS_LDO = (0x00 << 6), + EN_LDO = (0x3 << 6), +}; + +#endif /* __MAX8997_PMIC_H_ */
TRATS target uses MAX8997 PMIC device instead of MAX8998.
Signed-off-by: Lukasz Majewski l.majewski@samsung.com Signed-off-by: Kyungmin Park kyungmin.park@samsung.com Cc: Minkyu Kang mk7.kang@samsung.com Cc: Stefano Babic sbabic@denx.de --- board/samsung/trats/trats.c | 27 ++++++++++----------------- include/configs/trats.h | 2 +- 2 files changed, 11 insertions(+), 18 deletions(-)
diff --git a/board/samsung/trats/trats.c b/board/samsung/trats/trats.c index aa4291d..a7b4e4a 100644 --- a/board/samsung/trats/trats.c +++ b/board/samsung/trats/trats.c @@ -32,7 +32,7 @@ #include <asm/arch/power.h> #include <pmic.h> #include <usb/s3c_udc.h> -#include <max8998_pmic.h> +#include <max8997_pmic.h>
#include "setup.h"
@@ -216,26 +216,19 @@ static int s5pc210_phy_control(int on) return -1;
if (on) { - ret |= pmic_set_output(p, - MAX8998_REG_BUCK_ACTIVE_DISCHARGE3, - MAX8998_SAFEOUT1, LDO_ON); - ret |= pmic_set_output(p, MAX8998_REG_ONOFF1, - MAX8998_LDO3, LDO_ON); - ret |= pmic_set_output(p, MAX8998_REG_ONOFF2, - MAX8998_LDO8, LDO_ON); - + ret |= pmic_set_output(p, MAX8997_REG_SAFEOUTCTRL, + ENSAFEOUT1, LDO_ON); + ret |= pmic_reg_write(p, MAX8997_REG_LDO3CTRL, EN_LDO); + ret |= pmic_reg_write(p, MAX8997_REG_LDO8CTRL, EN_LDO); } else { - ret |= pmic_set_output(p, MAX8998_REG_ONOFF2, - MAX8998_LDO8, LDO_OFF); - ret |= pmic_set_output(p, MAX8998_REG_ONOFF1, - MAX8998_LDO3, LDO_OFF); - ret |= pmic_set_output(p, - MAX8998_REG_BUCK_ACTIVE_DISCHARGE3, - MAX8998_SAFEOUT1, LDO_OFF); + ret |= pmic_reg_write(p, MAX8997_REG_LDO8CTRL, DIS_LDO); + ret |= pmic_reg_write(p, MAX8997_REG_LDO3CTRL, DIS_LDO); + ret |= pmic_set_output(p, MAX8997_REG_SAFEOUTCTRL, + ENSAFEOUT1, LDO_OFF); }
if (ret) { - puts("MAX8998 LDO setting error!\n"); + puts("MAX8997 LDO setting error!\n"); return -1; }
diff --git a/include/configs/trats.h b/include/configs/trats.h index 10f11d9..585fd71 100644 --- a/include/configs/trats.h +++ b/include/configs/trats.h @@ -208,7 +208,7 @@
#define CONFIG_PMIC #define CONFIG_PMIC_I2C -#define CONFIG_PMIC_MAX8998 +#define CONFIG_PMIC_MAX8997
#define CONFIG_USB_GADGET #define CONFIG_USB_GADGET_S3C_UDC_OTG
Acked-by: Minkyu Kang mk7.kang@samsung.com
Hi Lukasz,
You added a new entry point to pmic, but you do not use it...I have not found in your patchset why it is necessary for you.
I am not sure if we require to add this to the PMIC API or hide in the pmic specific code. Other PMICs has not a a register for different voltages, but only a bit inside the same register (this is the case for the Freescale's PMICs we currently support in u-boot).
Best regards, Stefano Babic
Hi Stefano,
Hi Lukasz,
Rationale for this change is in commits following this one. For trats Samsung target it is necessary to change the default voltage.
I think, that providing access to such a function as a pointer is the best possible solution.
For example the MAX8997 and MAX8998 PMICs have different way of calculating the value, which represents the LDO output value.
I think, that it is easier to define function pointer in the pmic structure, than separate functions and handling them in target platform data.
On 28/03/2012 13:26, Lukasz Majewski wrote:
Hi Lukasz,
Yes, I was expecting that you call pmic_vol_to_reg() in your following patches, but I cannot find it. Am I missing something ?
Ok, understood.
Lukasz Majewski
Minkyu Kang
Stefano Babic
