[U-Boot] arm, da850: Question about start point
Hi all,
I'm new to this mailing-list and to u-boot. I've to port the TI SDK_5.02 to a LogicPD_SOM_AM1808 -based application board. The SDK_5.02 is based on PSP_03.21.00.04, whose u-boot was developed on git u-boot 2010.12
The question is
What's the better, to start from SDK's u-boot or from git u-boot 2010.12 ?
Thanks a lot, Gabriele
Hi Gabriele,
On Friday, December 16, 2011, Gabriele Filosofi GabrieleF@cosmed.it wrote:
Hi all,
board.
git u-boot 2010.12
The question is
I recommend to use the most recent u-boot from git, it works fine on the am1808 som (as long as you use the da850evm_config and not da850_am18xx_config, the latter is broken). I started with u-boot from the SDK but switched later to git because I needed features that are only in newer u-boots. Christian
Christian Riesch
Gabriele Filosofi
