[GIT PULL] TI changes for v2020.04-rc2
Hi Tom,
Please find the pull request for v2020.04-rc2 containing TI specific changes. This PR is a re spin of previous PR[0] without mmc changes and fetched few dt changes and watchdog fixes.
[0] https://patchwork.ozlabs.org/patch/1230709/
Travis-CI build: https://travis-ci.org/lokeshvutla/u-boot/builds/645566110
Thanks and regards, Lokesh
The following changes since commit 31a790bee939e227dfc7e6a6a323b2b13180707f:
Merge branch 'master' of git://git.denx.de/u-boot-usb (2020-02-02 15:26:53 -0500)
https://gitlab.denx.de/u-boot/custodians/u-boot-ti.git tags/ti-v2020.04-rc2
for you to fetch changes up to 4dd05933989f01bb38813f4a5f043b7dfa24e218:
watchdog: omap_wdt: Fix WDT coding style (2020-02-04 09:07:25 +0530)
---------------------------------------------------------------- Below are the major changes in this PR: - DFU boot support for J721e - I2C support for J721e - GPIO support for J721e - Android boot image updates on AM57XX - OMAP watchdog fixes ---------------------------------------------------------------- Faiz Abbas (3): configs: j721e_evm_a72: Fix redundant environment offset arm: dts: k3-j721e-main: Add Support for gpio0 configs: j721e_evm_a72: Add GPIO support
Marek Vasut (3): watchdog: omap_wdt: Fix WDT timeout configuration watchdog: omap_wdt: Fix WDT reloading watchdog: omap_wdt: Fix WDT coding style
Sam Protsenko (10): image: android: Add functions for handling dtb field image: android: Add routine to get dtbo params cmd: abootimg: Add abootimg command doc: android: Add documentation for Android Boot Image doc: android: Convert to Sphinx format test/py: android: Add test for abootimg configs: am57xx_evm: Enable Android commands env: ti: boot: Respect slot_suffix in AVB commands env: ti: boot: Boot Android with dynamic partitions arm: ti: boot: Use correct dtb and dtbo on Android boot
Vignesh Raghavendra (14): arm: mach-k3: j721e: Rename BOOT_DEVICE_USB to BOOT_DEVICE_DFU arm: mach-k3: sysfw-loader: Add support to download SYSFW via DFU arm: dts: k3-j721e-common-proc-board: Enable USB0 in peripheral mode configs: j721e_evm: Add DFU related variables configs: j721e_evm_r5_defconfig: Increase early malloc size configs: j721e_evm_r5/a72_defconfig: Enable USB Gadget related configs configs: j721e_evm_r5/a72_defconfig: Enable DFU related configs gpio: pca953x_gpio: Add support for 24 bit IO expander arm: dts: k3-j721e: Add I2C nodes arm: dts: k3-j721e-common-proc-board: Add I2C GPIO expander arm: dts: k3-j721e-common-proc-board: Enable I2C expander for SPL configs: j721e_evm_defconfig: Enable PCA953x IO expander gpio: da8xx_gpio: Fix compiler warning gpio: da8xx_gpio: Add "ti,keystone-gpio" compatible
MAINTAINERS | 4 +- .../arm/dts/k3-j721e-common-proc-board-u-boot.dtsi | 12 + arch/arm/dts/k3-j721e-common-proc-board.dts | 27 ++ arch/arm/dts/k3-j721e-main.dtsi | 99 ++++++++ arch/arm/dts/k3-j721e-mcu-wakeup.dtsi | 22 ++ arch/arm/dts/k3-j721e-r5-common-proc-board.dts | 45 ++++ arch/arm/dts/k3-j721e.dtsi | 10 + arch/arm/mach-k3/include/mach/j721e_spl.h | 2 +- arch/arm/mach-k3/sysfw-loader.c | 30 +++ cmd/Kconfig | 12 +- cmd/Makefile | 1 + cmd/abootimg.c | 258 +++++++++++++++++++ common/Makefile | 2 +- common/image-android.c | 282 +++++++++++++++++++++ configs/am57xx_evm_defconfig | 6 + configs/am57xx_hs_evm_defconfig | 6 + configs/am57xx_hs_evm_usb_defconfig | 6 + configs/j721e_evm_a72_defconfig | 13 +- configs/j721e_evm_r5_defconfig | 18 +- configs/sandbox_defconfig | 1 + doc/android/{ab.txt => ab.rst} | 39 +-- doc/android/avb2.rst | 133 ++++++++++ doc/android/avb2.txt | 115 --------- doc/android/bcb.rst | 100 ++++++++ doc/android/bcb.txt | 89 ------- doc/android/boot-image.rst | 154 +++++++++++ ...fastboot-protocol.txt => fastboot-protocol.rst} | 45 ++-- doc/android/{fastboot.txt => fastboot.rst} | 92 +++---- doc/android/index.rst | 14 + doc/index.rst | 12 + drivers/gpio/da8xx_gpio.c | 3 +- drivers/gpio/pca953x_gpio.c | 11 +- drivers/watchdog/omap_wdt.c | 56 ++-- include/configs/j721e_evm.h | 4 + include/configs/ti_armv7_common.h | 7 + include/environment/ti/boot.h | 154 ++++++----- include/image.h | 6 + test/py/tests/test_android/test_abootimg.py | 159 ++++++++++++ test/py/tests/test_android/test_avb.py | 2 +- 39 files changed, 1658 insertions(+), 393 deletions(-) create mode 100644 cmd/abootimg.c rename doc/android/{ab.txt => ab.rst} (52%) create mode 100644 doc/android/avb2.rst delete mode 100644 doc/android/avb2.txt create mode 100644 doc/android/bcb.rst delete mode 100644 doc/android/bcb.txt create mode 100644 doc/android/boot-image.rst rename doc/android/{fastboot-protocol.txt => fastboot-protocol.rst} (82%) rename doc/android/{fastboot.txt => fastboot.rst} (79%) create mode 100644 doc/android/index.rst create mode 100644 test/py/tests/test_android/test_abootimg.py
On Tue, Feb 04, 2020 at 09:28:38AM +0530, Lokesh Vutla wrote:
Hi Tom,
Lokesh Vutla
