[U-Boot] [PATCH] board: gaisler: delete unnecessary include path
The same outputs are generated with or without -I$(TOPDIR)/board. I cannot understand why it is necessary. Remove.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Daniel Hellstrom daniel@gaisler.com --- board/gaisler/gr_cpci_ax2000/config.mk | 2 -- board/gaisler/gr_ep2s60/config.mk | 2 -- board/gaisler/gr_xc3s_1500/config.mk | 2 -- board/gaisler/grsim/config.mk | 2 -- board/gaisler/grsim_leon2/config.mk | 2 -- 5 files changed, 10 deletions(-)
diff --git a/board/gaisler/gr_cpci_ax2000/config.mk b/board/gaisler/gr_cpci_ax2000/config.mk index 309c879..731a539 100644 --- a/board/gaisler/gr_cpci_ax2000/config.mk +++ b/board/gaisler/gr_cpci_ax2000/config.mk @@ -17,5 +17,3 @@ CONFIG_SYS_TEXT_BASE = 0x00000000
# U-BOOT IN SDRAM #CONFIG_SYS_TEXT_BASE = 0x60000000 - -PLATFORM_CPPFLAGS += -I$(TOPDIR)/board diff --git a/board/gaisler/gr_ep2s60/config.mk b/board/gaisler/gr_ep2s60/config.mk index d57efae..6e01f07 100644 --- a/board/gaisler/gr_ep2s60/config.mk +++ b/board/gaisler/gr_ep2s60/config.mk @@ -15,5 +15,3 @@ CONFIG_SYS_TEXT_BASE = 0x00000000
# U-BOOT IN SDRAM #CONFIG_SYS_TEXT_BASE = 0x40000000 - -PLATFORM_CPPFLAGS += -I$(TOPDIR)/board diff --git a/board/gaisler/gr_xc3s_1500/config.mk b/board/gaisler/gr_xc3s_1500/config.mk index e87320b..e4a66cb 100644 --- a/board/gaisler/gr_xc3s_1500/config.mk +++ b/board/gaisler/gr_xc3s_1500/config.mk @@ -14,5 +14,3 @@ CONFIG_SYS_TEXT_BASE = 0x00000000
# U-BOOT IN RAM #CONFIG_SYS_TEXT_BASE = 0x40000000 - -PLATFORM_CPPFLAGS += -I$(TOPDIR)/board diff --git a/board/gaisler/grsim/config.mk b/board/gaisler/grsim/config.mk index df26f82..d1f61da 100644 --- a/board/gaisler/grsim/config.mk +++ b/board/gaisler/grsim/config.mk @@ -14,5 +14,3 @@ CONFIG_SYS_TEXT_BASE = 0x00000000
# U-BOOT IN RAM #CONFIG_SYS_TEXT_BASE = 0x40000000 - -PLATFORM_CPPFLAGS += -I$(TOPDIR)/board diff --git a/board/gaisler/grsim_leon2/config.mk b/board/gaisler/grsim_leon2/config.mk index 99f9a68..f98b23b 100644 --- a/board/gaisler/grsim_leon2/config.mk +++ b/board/gaisler/grsim_leon2/config.mk @@ -14,5 +14,3 @@ CONFIG_SYS_TEXT_BASE = 0x00000000
# RUN U-BOOT FROM RAM #CONFIG_SYS_TEXT_BASE = 0x40000000 - -PLATFORM_CPPFLAGS += -I$(TOPDIR)/board
Masahiro Yamada
