[U-Boot] [RESEND PATCH v2 0/4] Big acceleration of Kbuild performance
--------------------------- No code change in Version 2 Only commit log fixed ---------------------------
Kbuild brought about many advantages for us but a significant performance regression was reported by Simon Glass.
After some discussions and analysis, it turned out its main cause is in $(call cc-option,...).
Historically, U-Boot parses all config.mk (arch/*/config.mk and board/*/config.mk) every time descending into subdirectories. That means cc-options are evaluated over and over again.
$(call cc-option,...) is useful but costly. So we want to evaluate them only in ./Makefile and spl/Makefile and export compiler flags.
1/4 through 3/4 are preparation for 4/4.
4/4 is what we really want to do. By applying it, I think Kbuild will get much faster.
How to apply this series ? --------------------------
This series depends on my other patches.
[1] "Kbuild: A collection of trivial refactoring" series
8/8 is not applicable any more. Please apply 1/8 thru 7/8.
[2] kbuild: consolidate PLATFORM_LIBS http://patchwork.ozlabs.org/patch/324808/
Please apply above beforehand.
Or you can also try my local branch for easy test.
I pushed my local branch to my GitHub page. Please try the following.
(1) git clone git://github.com/masahir0y/u-boot-kbuild.git (2) cd u-boot-kbuild (3) git checkout optimize_v1
How to test this series? ------------------------
This series is not big patches, but it might be difficult to understand if Kbuild can build the equivalent outputs.
Are compiler options really handled the same as before? The answer is Yes.
I examined ".*.cmd" files carefully.
And also I used md5sum to prove this series still produces the same result as before.
You can double-check it by following the below steps. Use my local branch.
(1) git clone git://github.com/masahir0y/u-boot-kbuild.git (2) cd u-boot-kbuild (3) git checkout before_optimize_v1 (4) Run "./MAKEALL" MD5SUM will be displayed. Dump all log to a file (5) git checkout optimize_v1 (6) Run "./MAKEALL" MD5SUM will be displayed. Dump all log to another file (7) Compare files between (4) and (6)
Please notice commit 4542e50 (MAKEALL: Display MD5SUM) This commit modifies MAKEALL to display MD5SUM of - ./u-boot.bin - spl/u-boot-spl.bin - tpl/u-boot-tpl.bin - examples/standalone/hello_world.bin
Changes in v2: - Fix the subject and commit description s/USE_PRIVATE_LIBS/USE_PRIVATE_LIBGCC/
Masahiro Yamada (4): kbuild,blackfin: Add CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED kbuild: add CONFIG_ prefix to USE_PRIVATE_LIBGCC config.mk: specify the exact path to standalone linker script kbuild: improve Kbuild speed
Makefile | 13 +++++++------ arch/arm/cpu/arm720t/tegra114/config.mk | 19 ------------------- arch/arm/cpu/arm720t/tegra124/config.mk | 7 ------- arch/arm/cpu/arm720t/tegra20/config.mk | 10 ---------- arch/arm/cpu/arm720t/tegra30/config.mk | 19 ------------------- arch/arm/lib/Makefile | 13 ++----------- arch/blackfin/config.mk | 1 + arch/mips/cpu/mips32/config.mk | 3 ++- arch/mips/cpu/mips64/config.mk | 3 ++- arch/mips/cpu/xburst/config.mk | 3 ++- arch/mips/lib/Makefile | 7 +------ arch/nds32/config.mk | 3 ++- arch/powerpc/lib/Makefile | 6 +----- arch/sh/lib/Makefile | 14 ++------------ arch/sparc/config.mk | 4 +++- arch/x86/config.mk | 2 +- board/bct-brettl2/config.mk | 13 ------------- board/bf518f-ezbrd/config.mk | 13 ------------- board/bf526-ezbrd/config.mk | 13 ------------- board/bf527-ad7160-eval/config.mk | 13 ------------- board/bf527-ezkit/config.mk | 13 ------------- board/bf527-sdp/config.mk | 5 ----- board/bf533-ezkit/config.mk | 5 ----- board/bf533-stamp/config.mk | 5 ----- board/bf537-stamp/config.mk | 5 ----- board/bf538f-ezkit/config.mk | 5 ----- board/bf548-ezkit/config.mk | 5 ----- board/bf561-acvilon/config.mk | 5 ----- board/bf561-ezkit/config.mk | 5 ----- board/br4/config.mk | 15 --------------- board/cm-bf527/config.mk | 13 ------------- board/cm-bf533/config.mk | 5 ----- board/cm-bf537e/config.mk | 5 ----- board/cm-bf537u/config.mk | 5 ----- board/cm-bf548/config.mk | 5 ----- board/cm-bf561/config.mk | 5 ----- board/ip04/config.mk | 5 ----- board/pr1/config.mk | 15 --------------- board/tcm-bf518/config.mk | 13 ------------- board/tcm-bf537/config.mk | 5 ----- config.mk | 28 ++++++++++++++++++++-------- examples/standalone/Makefile | 5 ++--- include/configs/bct-brettl2.h | 2 +- include/configs/bf518f-ezbrd.h | 2 +- include/configs/bf526-ezbrd.h | 1 + include/configs/bf527-ad7160-eval.h | 2 +- include/configs/bf527-ezkit.h | 2 +- include/configs/bf527-sdp.h | 2 +- include/configs/bf533-ezkit.h | 2 +- include/configs/bf533-stamp.h | 1 + include/configs/bf537-stamp.h | 1 + include/configs/bf538f-ezkit.h | 2 +- include/configs/bf548-ezkit.h | 1 + include/configs/bf561-acvilon.h | 2 +- include/configs/bf561-ezkit.h | 1 + include/configs/br4.h | 2 +- include/configs/cm-bf527.h | 2 +- include/configs/cm-bf533.h | 2 +- include/configs/cm-bf537e.h | 1 + include/configs/cm-bf537u.h | 2 +- include/configs/cm-bf548.h | 1 + include/configs/cm-bf561.h | 2 +- include/configs/ip04.h | 1 + include/configs/pr1.h | 2 +- include/configs/tcm-bf518.h | 2 +- include/configs/tcm-bf537.h | 2 +- include/configs/tegra-common.h | 4 ++++ lib/Makefile | 2 ++ scripts/Makefile.build | 10 +++++----- scripts/Makefile.lib | 7 +++---- spl/Makefile | 9 ++++----- 71 files changed, 90 insertions(+), 338 deletions(-) delete mode 100644 arch/arm/cpu/arm720t/tegra114/config.mk delete mode 100644 arch/arm/cpu/arm720t/tegra124/config.mk delete mode 100644 arch/arm/cpu/arm720t/tegra20/config.mk delete mode 100644 arch/arm/cpu/arm720t/tegra30/config.mk delete mode 100644 board/bct-brettl2/config.mk delete mode 100644 board/bf518f-ezbrd/config.mk delete mode 100644 board/bf526-ezbrd/config.mk delete mode 100644 board/bf527-ad7160-eval/config.mk delete mode 100644 board/bf527-ezkit/config.mk delete mode 100644 board/br4/config.mk delete mode 100644 board/cm-bf527/config.mk delete mode 100644 board/pr1/config.mk delete mode 100644 board/tcm-bf518/config.mk
Many (but not all) of Blackfin boards give -O2 option to compile under lib/ directory. That means lib/ should be speed-optimized, whereas other parts should be size-optimized.
We want to keep the same behavior, but do not want to parse board/*/config.mk again and again. We've got no choice but to invent a new method.
CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED, if it is enabled, gives -O2 flag only for building under lib/ directory.
Dirty codes which I had marked as "FIX ME" in board/${BOARD}/config.mk have been deleted. Instead, CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED has been defined in include/configs/${BOARD}.h.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com ---
Changes in v2: None
board/bct-brettl2/config.mk | 13 ------------- board/bf518f-ezbrd/config.mk | 13 ------------- board/bf526-ezbrd/config.mk | 13 ------------- board/bf527-ad7160-eval/config.mk | 13 ------------- board/bf527-ezkit/config.mk | 13 ------------- board/bf527-sdp/config.mk | 5 ----- board/bf533-ezkit/config.mk | 5 ----- board/bf533-stamp/config.mk | 5 ----- board/bf537-stamp/config.mk | 5 ----- board/bf538f-ezkit/config.mk | 5 ----- board/bf548-ezkit/config.mk | 5 ----- board/bf561-acvilon/config.mk | 5 ----- board/bf561-ezkit/config.mk | 5 ----- board/br4/config.mk | 15 --------------- board/cm-bf527/config.mk | 13 ------------- board/cm-bf533/config.mk | 5 ----- board/cm-bf537e/config.mk | 5 ----- board/cm-bf537u/config.mk | 5 ----- board/cm-bf548/config.mk | 5 ----- board/cm-bf561/config.mk | 5 ----- board/ip04/config.mk | 5 ----- board/pr1/config.mk | 15 --------------- board/tcm-bf518/config.mk | 13 ------------- board/tcm-bf537/config.mk | 5 ----- include/configs/bct-brettl2.h | 2 +- include/configs/bf518f-ezbrd.h | 2 +- include/configs/bf526-ezbrd.h | 1 + include/configs/bf527-ad7160-eval.h | 2 +- include/configs/bf527-ezkit.h | 2 +- include/configs/bf527-sdp.h | 2 +- include/configs/bf533-ezkit.h | 2 +- include/configs/bf533-stamp.h | 1 + include/configs/bf537-stamp.h | 1 + include/configs/bf538f-ezkit.h | 2 +- include/configs/bf548-ezkit.h | 1 + include/configs/bf561-acvilon.h | 2 +- include/configs/bf561-ezkit.h | 1 + include/configs/br4.h | 2 +- include/configs/cm-bf527.h | 2 +- include/configs/cm-bf533.h | 2 +- include/configs/cm-bf537e.h | 1 + include/configs/cm-bf537u.h | 2 +- include/configs/cm-bf548.h | 1 + include/configs/cm-bf561.h | 2 +- include/configs/ip04.h | 1 + include/configs/pr1.h | 2 +- include/configs/tcm-bf518.h | 2 +- include/configs/tcm-bf537.h | 2 +- lib/Makefile | 2 ++ 49 files changed, 26 insertions(+), 212 deletions(-) delete mode 100644 board/bct-brettl2/config.mk delete mode 100644 board/bf518f-ezbrd/config.mk delete mode 100644 board/bf526-ezbrd/config.mk delete mode 100644 board/bf527-ad7160-eval/config.mk delete mode 100644 board/bf527-ezkit/config.mk delete mode 100644 board/br4/config.mk delete mode 100644 board/cm-bf527/config.mk delete mode 100644 board/pr1/config.mk delete mode 100644 board/tcm-bf518/config.mk
diff --git a/board/bct-brettl2/config.mk b/board/bct-brettl2/config.mk deleted file mode 100644 index 0d3df2d..0000000 --- a/board/bct-brettl2/config.mk +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/bf518f-ezbrd/config.mk b/board/bf518f-ezbrd/config.mk deleted file mode 100644 index 0d3df2d..0000000 --- a/board/bf518f-ezbrd/config.mk +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/bf526-ezbrd/config.mk b/board/bf526-ezbrd/config.mk deleted file mode 100644 index 0d3df2d..0000000 --- a/board/bf526-ezbrd/config.mk +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/bf527-ad7160-eval/config.mk b/board/bf527-ad7160-eval/config.mk deleted file mode 100644 index 0d3df2d..0000000 --- a/board/bf527-ad7160-eval/config.mk +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/bf527-ezkit/config.mk b/board/bf527-ezkit/config.mk deleted file mode 100644 index 0d3df2d..0000000 --- a/board/bf527-ezkit/config.mk +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/bf527-sdp/config.mk b/board/bf527-sdp/config.mk index af299f5..1d46cfc 100644 --- a/board/bf527-sdp/config.mk +++ b/board/bf527-sdp/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 6 diff --git a/board/bf533-ezkit/config.mk b/board/bf533-ezkit/config.mk index 97eaafe..7f9138b 100644 --- a/board/bf533-ezkit/config.mk +++ b/board/bf533-ezkit/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 diff --git a/board/bf533-stamp/config.mk b/board/bf533-stamp/config.mk index 97eaafe..7f9138b 100644 --- a/board/bf533-stamp/config.mk +++ b/board/bf533-stamp/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 diff --git a/board/bf537-stamp/config.mk b/board/bf537-stamp/config.mk index bc0e747..ab0fbec 100644 --- a/board/bf537-stamp/config.mk +++ b/board/bf537-stamp/config.mk @@ -7,11 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS-BFIN_BOOT_UART := --port g --gpio 6 diff --git a/board/bf538f-ezkit/config.mk b/board/bf538f-ezkit/config.mk index 97eaafe..7f9138b 100644 --- a/board/bf538f-ezkit/config.mk +++ b/board/bf538f-ezkit/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 diff --git a/board/bf548-ezkit/config.mk b/board/bf548-ezkit/config.mk index 8d2c60f..7bb8e9c 100644 --- a/board/bf548-ezkit/config.mk +++ b/board/bf548-ezkit/config.mk @@ -7,11 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --dma 6 LDR_FLAGS-BFIN_BOOT_FIFO := --dma 1 diff --git a/board/bf561-acvilon/config.mk b/board/bf561-acvilon/config.mk index ce94715..854d7db 100644 --- a/board/bf561-acvilon/config.mk +++ b/board/bf561-acvilon/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 diff --git a/board/bf561-ezkit/config.mk b/board/bf561-ezkit/config.mk index ce94715..854d7db 100644 --- a/board/bf561-ezkit/config.mk +++ b/board/bf561-ezkit/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 diff --git a/board/br4/config.mk b/board/br4/config.mk deleted file mode 100644 index 2436ec0..0000000 --- a/board/br4/config.mk +++ /dev/null @@ -1,15 +0,0 @@ -# -# Copyright (c) Switchfin Org. dpn@switchfin.org -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/cm-bf527/config.mk b/board/cm-bf527/config.mk deleted file mode 100644 index 0d3df2d..0000000 --- a/board/cm-bf527/config.mk +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/cm-bf533/config.mk b/board/cm-bf533/config.mk index 97eaafe..7f9138b 100644 --- a/board/cm-bf533/config.mk +++ b/board/cm-bf533/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 diff --git a/board/cm-bf537e/config.mk b/board/cm-bf537e/config.mk index 97eaafe..7f9138b 100644 --- a/board/cm-bf537e/config.mk +++ b/board/cm-bf537e/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 diff --git a/board/cm-bf537u/config.mk b/board/cm-bf537u/config.mk index 97eaafe..7f9138b 100644 --- a/board/cm-bf537u/config.mk +++ b/board/cm-bf537u/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 diff --git a/board/cm-bf548/config.mk b/board/cm-bf548/config.mk index 289c8a4..beb9834 100644 --- a/board/cm-bf548/config.mk +++ b/board/cm-bf548/config.mk @@ -7,11 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --dma 6 LDR_FLAGS-BFIN_BOOT_FIFO := --dma 1 diff --git a/board/cm-bf561/config.mk b/board/cm-bf561/config.mk index ce94715..854d7db 100644 --- a/board/cm-bf561/config.mk +++ b/board/cm-bf561/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 diff --git a/board/ip04/config.mk b/board/ip04/config.mk index bc0e747..ab0fbec 100644 --- a/board/ip04/config.mk +++ b/board/ip04/config.mk @@ -7,11 +7,6 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 LDR_FLAGS-BFIN_BOOT_UART := --port g --gpio 6 diff --git a/board/pr1/config.mk b/board/pr1/config.mk deleted file mode 100644 index 2436ec0..0000000 --- a/board/pr1/config.mk +++ /dev/null @@ -1,15 +0,0 @@ -# -# Copyright (c) Switchfin Org. dpn@switchfin.org -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/tcm-bf518/config.mk b/board/tcm-bf518/config.mk deleted file mode 100644 index 0d3df2d..0000000 --- a/board/tcm-bf518/config.mk +++ /dev/null @@ -1,13 +0,0 @@ -# -# Copyright (c) 2005-2008 Analog Device Inc. -# -# (C) Copyright 2001 -# Wolfgang Denk, DENX Software Engineering, wd@denx.de. -# -# SPDX-License-Identifier: GPL-2.0+ -# - -# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif diff --git a/board/tcm-bf537/config.mk b/board/tcm-bf537/config.mk index 97eaafe..7f9138b 100644 --- a/board/tcm-bf537/config.mk +++ b/board/tcm-bf537/config.mk @@ -7,10 +7,5 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# FIX ME -ifneq ($(filter lib lib/lzma lib/zlib, $(obj)),) -ccflags-y := -O2 -endif - # Set some default LDR flags based on boot mode. LDR_FLAGS-BFIN_BOOT_PARA := --bits 16 --dma 8 diff --git a/include/configs/bct-brettl2.h b/include/configs/bct-brettl2.h index 5b09b45..06f095c 100644 --- a/include/configs/bct-brettl2.h +++ b/include/configs/bct-brettl2.h @@ -136,7 +136,7 @@ #define CONFIG_MTD_DEVICE #define CONFIG_MTD_PARTITIONS #define CONFIG_SYS_HUSH_PARSER - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf518f-ezbrd.h b/include/configs/bf518f-ezbrd.h index a97972b..9eb85eb 100644 --- a/include/configs/bf518f-ezbrd.h +++ b/include/configs/bf518f-ezbrd.h @@ -155,7 +155,7 @@ #define CONFIG_MISC_INIT_R #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf526-ezbrd.h b/include/configs/bf526-ezbrd.h index 0031093..3065d22 100644 --- a/include/configs/bf526-ezbrd.h +++ b/include/configs/bf526-ezbrd.h @@ -153,6 +153,7 @@ #define CONFIG_MISC_INIT_R #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 1 +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* define to enable run status via led */ /* #define CONFIG_STATUS_LED */ diff --git a/include/configs/bf527-ad7160-eval.h b/include/configs/bf527-ad7160-eval.h index fa05103..c0dfe26 100644 --- a/include/configs/bf527-ad7160-eval.h +++ b/include/configs/bf527-ad7160-eval.h @@ -136,7 +136,7 @@ */ #define CONFIG_MISC_INIT_R #define CONFIG_UART_CONSOLE 0 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf527-ezkit.h b/include/configs/bf527-ezkit.h index db1b613..748ddb3 100644 --- a/include/configs/bf527-ezkit.h +++ b/include/configs/bf527-ezkit.h @@ -179,7 +179,7 @@ #define CONFIG_MISC_INIT_R #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 1 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf527-sdp.h b/include/configs/bf527-sdp.h index c0e8b5a..458868a 100644 --- a/include/configs/bf527-sdp.h +++ b/include/configs/bf527-sdp.h @@ -112,7 +112,7 @@ */ #define CONFIG_MISC_INIT_R #define CONFIG_UART_CONSOLE 0 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf533-ezkit.h b/include/configs/bf533-ezkit.h index beab127..b503528 100644 --- a/include/configs/bf533-ezkit.h +++ b/include/configs/bf533-ezkit.h @@ -110,7 +110,7 @@ #define CONFIG_MISC_INIT_R #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf533-stamp.h b/include/configs/bf533-stamp.h index f5b9658..d82c5b2 100644 --- a/include/configs/bf533-stamp.h +++ b/include/configs/bf533-stamp.h @@ -185,6 +185,7 @@ */ #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* FLASH/ETHERNET uses the same async bank */ #define SHARED_RESOURCES 1 diff --git a/include/configs/bf537-stamp.h b/include/configs/bf537-stamp.h index 02945be..e1705ca 100644 --- a/include/configs/bf537-stamp.h +++ b/include/configs/bf537-stamp.h @@ -254,6 +254,7 @@ #define CONFIG_MISC_INIT_R #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* Define if want to do post memory test */ #undef CONFIG_POST diff --git a/include/configs/bf538f-ezkit.h b/include/configs/bf538f-ezkit.h index ffb0caf..742c299 100644 --- a/include/configs/bf538f-ezkit.h +++ b/include/configs/bf538f-ezkit.h @@ -134,7 +134,7 @@ */ #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 0 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf548-ezkit.h b/include/configs/bf548-ezkit.h index da5f029..1a245a2 100644 --- a/include/configs/bf548-ezkit.h +++ b/include/configs/bf548-ezkit.h @@ -181,6 +181,7 @@ #define CONFIG_RTC_BFIN #define CONFIG_UART_CONSOLE 1 #define CONFIG_BFIN_SPI_IMG_SIZE 0x50000 +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
#define CONFIG_ADI_GPIO2
diff --git a/include/configs/bf561-acvilon.h b/include/configs/bf561-acvilon.h index 15ca1af..3db917e 100644 --- a/include/configs/bf561-acvilon.h +++ b/include/configs/bf561-acvilon.h @@ -160,7 +160,7 @@ #define CONFIG_UART_CONSOLE 0 #define CONFIG_BAUDRATE 57600 #define CONFIG_SYS_PROMPT "Acvilon> " - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/bf561-ezkit.h b/include/configs/bf561-ezkit.h index fb6f948..0a309d9 100644 --- a/include/configs/bf561-ezkit.h +++ b/include/configs/bf561-ezkit.h @@ -102,6 +102,7 @@ * Misc Settings */ #define CONFIG_UART_CONSOLE 0 +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Run core 1 from L1 SRAM start address when init uboot on core 0 diff --git a/include/configs/br4.h b/include/configs/br4.h index ef3752d..f8d3158 100644 --- a/include/configs/br4.h +++ b/include/configs/br4.h @@ -135,7 +135,7 @@ #define CONFIG_BOOTCOMMAND "run nandboot" #define CONFIG_BOOTDELAY 2 #define CONFIG_LOADADDR 0x2000000 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/cm-bf527.h b/include/configs/cm-bf527.h index b15a1eb..384d871 100644 --- a/include/configs/cm-bf527.h +++ b/include/configs/cm-bf527.h @@ -128,7 +128,7 @@ #define FLASHBOOT_ENV_SETTINGS \ "flashboot=flread 20040000 1000000 300000;" \ "bootm 0x1000000\0" - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/cm-bf533.h b/include/configs/cm-bf533.h index e2b954c..8bd499a 100644 --- a/include/configs/cm-bf533.h +++ b/include/configs/cm-bf533.h @@ -97,7 +97,7 @@ #define CONFIG_UART_CONSOLE 0 #define CONFIG_BOOTCOMMAND "run flashboot" #define FLASHBOOT_ENV_SETTINGS "flashboot=bootm 0x20040000\0" - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/cm-bf537e.h b/include/configs/cm-bf537e.h index 2838012..67cf801 100644 --- a/include/configs/cm-bf537e.h +++ b/include/configs/cm-bf537e.h @@ -146,6 +146,7 @@ "flashboot=flread 20040000 1000000 3c0000;" \ "bootm 0x1000000\0" #define CONFIG_BOARD_SIZE_LIMIT $$((384 * 1024)) +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/cm-bf537u.h b/include/configs/cm-bf537u.h index da4cc67..34ce75b 100644 --- a/include/configs/cm-bf537u.h +++ b/include/configs/cm-bf537u.h @@ -143,7 +143,7 @@ "flashboot=flread 20040000 1000000 300000;" \ "bootm 0x1000000\0" #define CONFIG_BOARD_SIZE_LIMIT $$((384 * 1024)) - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/cm-bf548.h b/include/configs/cm-bf548.h index 7f27eda..346e27f 100644 --- a/include/configs/cm-bf548.h +++ b/include/configs/cm-bf548.h @@ -117,6 +117,7 @@ #define CONFIG_UART_CONSOLE 1 #define CONFIG_BOOTCOMMAND "run flashboot" #define FLASHBOOT_ENV_SETTINGS "flashboot=bootm 0x20040000\0" +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
diff --git a/include/configs/cm-bf561.h b/include/configs/cm-bf561.h index 93e3c86..5265e5f 100644 --- a/include/configs/cm-bf561.h +++ b/include/configs/cm-bf561.h @@ -99,7 +99,7 @@ #define CONFIG_UART_CONSOLE 0 #define CONFIG_BOOTCOMMAND "run flashboot" #define FLASHBOOT_ENV_SETTINGS "flashboot=bootm 0x20040000\0" - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/ip04.h b/include/configs/ip04.h index d36ae43..0efa2b7 100644 --- a/include/configs/ip04.h +++ b/include/configs/ip04.h @@ -132,6 +132,7 @@ #define CONFIG_BAUDRATE 115200 #define CONFIG_MISC_INIT_R /* needed for MAC address */ #define CONFIG_UART_CONSOLE 0 +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
#undef CONFIG_SHOW_BOOT_PROGRESS /* Enable this if bootretry required; currently it's disabled */ diff --git a/include/configs/pr1.h b/include/configs/pr1.h index 03d4269..e96ed4b 100644 --- a/include/configs/pr1.h +++ b/include/configs/pr1.h @@ -135,7 +135,7 @@ #define CONFIG_BOOTCOMMAND "run nandboot" #define CONFIG_BOOTDELAY 2 #define CONFIG_LOADADDR 0x2000000 - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/tcm-bf518.h b/include/configs/tcm-bf518.h index 241f210..1ff34d5 100644 --- a/include/configs/tcm-bf518.h +++ b/include/configs/tcm-bf518.h @@ -116,7 +116,7 @@ #define CONFIG_UART_CONSOLE 0 #define CONFIG_BOOTCOMMAND "run flashboot" #define FLASHBOOT_ENV_SETTINGS "flashboot=bootm 0x20040000\0" - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/include/configs/tcm-bf537.h b/include/configs/tcm-bf537.h index 58bcdc8..370d97f 100644 --- a/include/configs/tcm-bf537.h +++ b/include/configs/tcm-bf537.h @@ -145,7 +145,7 @@ "flashboot=flread 20040000 1000000 300000;" \ "bootm 0x1000000\0" #define CONFIG_BOARD_SIZE_LIMIT $$((384 * 1024)) - +#define CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED
/* * Pull in common ADI header for remaining command/environment setup diff --git a/lib/Makefile b/lib/Makefile index dedb97b..8814ff9 100644 --- a/lib/Makefile +++ b/lib/Makefile @@ -65,3 +65,5 @@ obj-y += vsprintf.o obj-$(CONFIG_RANDOM_MACADDR) += rand.o obj-$(CONFIG_BOOTP_RANDOM_DELAY) += rand.o obj-$(CONFIG_CMD_LINK_LOCAL) += rand.o + +subdir-ccflags-$(CONFIG_CC_OPTIMIZE_LIBS_FOR_SPEED) += -O2
Before this commit, USE_PRIVATE_LIBGCC was defined in arch-specific config.mk and referenced in arch/$(ARCH)/lib/Makefile.
We are not happy about parsing config.mk again and again. We have to keep the same behavior with a different way.
By adding "CONFIG_" prefix, this macro appears in include/autoconf.mk, include/spl-autoconf.mk. (And treating USE_PRIVATE_LIBGCC as CONFIG macro is reasonable enough.)
Tegra SoC family defined USE_PRIVATE_LIBGCC as "yes" in arch/arm/cpu/arm720t/tegra*/config.mk, whereas did not define it in arch/arm/cpu/armv7/tegra*/config.mk.
It means Tegra enables PRIVATE_LIBGCC only for SPL. We can describe the same behavior by adding
#ifdef CONFIG_SPL_BUILD # define CONFIG_USE_PRIVATE_LIBGCC #endif
to include/configs/tegra-common.h.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Tom Warren twarren@nvidia.com Cc: Simon Glass sjg@chromium.org Acked-by: Stephen Warren swarren@nvidia.com ---
Makefile | 6 +++--- arch/arm/cpu/arm720t/tegra114/config.mk | 19 ------------------- arch/arm/cpu/arm720t/tegra124/config.mk | 7 ------- arch/arm/cpu/arm720t/tegra20/config.mk | 10 ---------- arch/arm/cpu/arm720t/tegra30/config.mk | 19 ------------------- arch/arm/lib/Makefile | 13 ++----------- arch/mips/lib/Makefile | 7 +------ arch/powerpc/lib/Makefile | 6 +----- arch/sh/lib/Makefile | 14 ++------------ arch/x86/config.mk | 2 +- include/configs/tegra-common.h | 4 ++++ spl/Makefile | 2 +- 12 files changed, 15 insertions(+), 94 deletions(-) delete mode 100644 arch/arm/cpu/arm720t/tegra114/config.mk delete mode 100644 arch/arm/cpu/arm720t/tegra124/config.mk delete mode 100644 arch/arm/cpu/arm720t/tegra20/config.mk delete mode 100644 arch/arm/cpu/arm720t/tegra30/config.mk
diff --git a/Makefile b/Makefile index 89f1226..56ba1ef 100644 --- a/Makefile +++ b/Makefile @@ -648,11 +648,11 @@ u-boot-main := $(libs-y)
# Add GCC lib -ifdef USE_PRIVATE_LIBGCC -ifeq ("$(USE_PRIVATE_LIBGCC)", "yes") +ifdef CONFIG_USE_PRIVATE_LIBGCC +ifeq ($(CONFIG_USE_PRIVATE_LIBGCC),y) PLATFORM_LIBGCC = arch/$(ARCH)/lib/lib.a else -PLATFORM_LIBGCC = -L $(USE_PRIVATE_LIBGCC) -lgcc +PLATFORM_LIBGCC = -L $(CONFIG_USE_PRIVATE_LIBGCC) -lgcc endif else PLATFORM_LIBGCC := -L $(shell dirname `$(CC) $(c_flags) -print-libgcc-file-name`) -lgcc diff --git a/arch/arm/cpu/arm720t/tegra114/config.mk b/arch/arm/cpu/arm720t/tegra114/config.mk deleted file mode 100644 index 7947b50..0000000 --- a/arch/arm/cpu/arm720t/tegra114/config.mk +++ /dev/null @@ -1,19 +0,0 @@ -# -# Copyright (c) 2010-2013, NVIDIA CORPORATION. All rights reserved. -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, garyj@denx.de -# -# This program is free software; you can redistribute it and/or modify it -# under the terms and conditions of the GNU General Public License, -# version 2, as published by the Free Software Foundation. -# -# This program is distributed in the hope it will be useful, but WITHOUT -# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or -# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for -# more details. -# -# You should have received a copy of the GNU General Public License -# along with this program. If not, see http://www.gnu.org/licenses/. -# -USE_PRIVATE_LIBGCC = yes diff --git a/arch/arm/cpu/arm720t/tegra124/config.mk b/arch/arm/cpu/arm720t/tegra124/config.mk deleted file mode 100644 index 5e10701..0000000 --- a/arch/arm/cpu/arm720t/tegra124/config.mk +++ /dev/null @@ -1,7 +0,0 @@ -# -# (C) Copyright 2010-2013 -# NVIDIA Corporation <www.nvidia.com> -# -# SPDX-License-Identifier: GPL-2.0+ -#/ -USE_PRIVATE_LIBGCC = yes diff --git a/arch/arm/cpu/arm720t/tegra20/config.mk b/arch/arm/cpu/arm720t/tegra20/config.mk deleted file mode 100644 index e073345..0000000 --- a/arch/arm/cpu/arm720t/tegra20/config.mk +++ /dev/null @@ -1,10 +0,0 @@ -# -# (C) Copyright 2010,2011 -# NVIDIA Corporation <www.nvidia.com> -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, garyj@denx.de -# -# SPDX-License-Identifier: GPL-2.0+ -# -USE_PRIVATE_LIBGCC = yes diff --git a/arch/arm/cpu/arm720t/tegra30/config.mk b/arch/arm/cpu/arm720t/tegra30/config.mk deleted file mode 100644 index 2388c56..0000000 --- a/arch/arm/cpu/arm720t/tegra30/config.mk +++ /dev/null @@ -1,19 +0,0 @@ -# -# Copyright (c) 2010-2012, NVIDIA CORPORATION. All rights reserved. -# -# (C) Copyright 2002 -# Gary Jennejohn, DENX Software Engineering, garyj@denx.de -# -# This program is free software; you can redistribute it and/or modify it -# under the terms and conditions of the GNU General Public License, -# version 2, as published by the Free Software Foundation. -# -# This program is distributed in the hope it will be useful, but WITHOUT -# ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or -# FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for -# more details. -# -# You should have received a copy of the GNU General Public License -# along with this program. If not, see http://www.gnu.org/licenses/. -# -USE_PRIVATE_LIBGCC = yes diff --git a/arch/arm/lib/Makefile b/arch/arm/lib/Makefile index 45febcf..9fc81cd 100644 --- a/arch/arm/lib/Makefile +++ b/arch/arm/lib/Makefile @@ -5,17 +5,8 @@ # SPDX-License-Identifier: GPL-2.0+ #
-# Build private libgcc only when asked for -ifdef USE_PRIVATE_LIBGCC -lib-y += _ashldi3.o -lib-y += _ashrdi3.o -lib-y += _divsi3.o -lib-y += _lshrdi3.o -lib-y += _modsi3.o -lib-y += _udivsi3.o -lib-y += _umodsi3.o -lib-y += div0.o -endif +lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _divsi3.o \ + _lshrdi3.o _modsi3.o _udivsi3.o _umodsi3.o div0.o
ifdef CONFIG_ARM64 obj-y += crt0_64.o diff --git a/arch/mips/lib/Makefile b/arch/mips/lib/Makefile index 3705926..fabeb83 100644 --- a/arch/mips/lib/Makefile +++ b/arch/mips/lib/Makefile @@ -8,9 +8,4 @@ obj-y += board.o obj-$(CONFIG_CMD_BOOTM) += bootm.o
-# Build private libgcc only when asked for -ifdef USE_PRIVATE_LIBGCC -lib-y += ashldi3.o -lib-y += ashrdi3.o -lib-y += lshrdi3.o -endif +lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashldi3.o ashrdi3.o lshrdi3.o diff --git a/arch/powerpc/lib/Makefile b/arch/powerpc/lib/Makefile index e6d8be5..0f62982 100644 --- a/arch/powerpc/lib/Makefile +++ b/arch/powerpc/lib/Makefile @@ -7,11 +7,7 @@
## Build a couple of necessary functions into a private libgcc ## if the user asked for it -ifdef USE_PRIVATE_LIBGCC -lib-y += _ashldi3.o -lib-y += _ashrdi3.o -lib-y += _lshrdi3.o -endif +lib-$(CONFIG_USE_PRIVATE_LIBGCC) += _ashldi3.o _ashrdi3.o _lshrdi3.o
MINIMAL=
diff --git a/arch/sh/lib/Makefile b/arch/sh/lib/Makefile index 5fc9d9d..8a84b24 100644 --- a/arch/sh/lib/Makefile +++ b/arch/sh/lib/Makefile @@ -15,15 +15,5 @@ obj-y += time.o endif obj-$(CONFIG_CMD_SH_ZIMAGEBOOT) += zimageboot.o
- - -# Build private libgcc only when asked for -ifdef USE_PRIVATE_LIBGCC -lib-y += ashiftrt.o -lib-y += ashiftlt.o -lib-y += lshiftrt.o -lib-y += ashldi3.o -lib-y += ashrsi3.o -lib-y += lshrdi3.o -lib-y += movmem.o -endif +lib-$(CONFIG_USE_PRIVATE_LIBGCC) += ashiftrt.o ashiftlt.o lshiftrt.o \ + ashldi3.o ashrsi3.o lshrdi3.o movmem.o diff --git a/arch/x86/config.mk b/arch/x86/config.mk index 58dff14..1e52a5e 100644 --- a/arch/x86/config.mk +++ b/arch/x86/config.mk @@ -31,4 +31,4 @@ LDFLAGS_FINAL += --wrap=__moddi3 --wrap=__umoddi3 export NORMAL_LIBGCC = $(shell $(CC) $(CFLAGS) -print-libgcc-file-name) PREFIXED_LIBGCC = $(OBJTREE)/arch/$(ARCH)/lib/$(shell basename $(NORMAL_LIBGCC))
-export USE_PRIVATE_LIBGCC=$(shell dirname $(PREFIXED_LIBGCC)) +CONFIG_USE_PRIVATE_LIBGCC=$(shell dirname $(PREFIXED_LIBGCC)) diff --git a/include/configs/tegra-common.h b/include/configs/tegra-common.h index 522cd41..0a07e30 100644 --- a/include/configs/tegra-common.h +++ b/include/configs/tegra-common.h @@ -151,6 +151,10 @@ #define CONFIG_SPL_SERIAL_SUPPORT #define CONFIG_SPL_GPIO_SUPPORT
+#ifdef CONFIG_SPL_BUILD +# define CONFIG_USE_PRIVATE_LIBGCC +#endif + #define CONFIG_SYS_GENERIC_BOARD
/* Misc utility code */ diff --git a/spl/Makefile b/spl/Makefile index 57bd43b..e1a0601 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -132,7 +132,7 @@ u-boot-spl-dirs := $(patsubst %/,%,$(filter %/, $(libs-y))) libs-y := $(patsubst %/, %/built-in.o, $(libs-y))
# Add GCC lib -ifeq ("$(USE_PRIVATE_LIBGCC)", "yes") +ifeq ($(CONFIG_USE_PRIVATE_LIBGCC),y) PLATFORM_LIBGCC = arch/$(ARCH)/lib/lib.a PLATFORM_LIBS := $(filter-out %/lib.a, $(filter-out -lgcc, $(PLATFORM_LIBS))) $(PLATFORM_LIBGCC) endif
We want to change the build system to include config.mk only from ./Makefile and spl/Makefile. We must prepare for that in this commit.
$(src) is a moving target and not handy for our purpose. We must replace it with a fixed path.
Changes in v2: None
arch/mips/cpu/mips32/config.mk | 3 ++- arch/mips/cpu/mips64/config.mk | 3 ++- arch/mips/cpu/xburst/config.mk | 3 ++- arch/nds32/config.mk | 3 ++- arch/sparc/config.mk | 2 +- 5 files changed, 9 insertions(+), 5 deletions(-)
diff --git a/arch/mips/cpu/mips32/config.mk b/arch/mips/cpu/mips32/config.mk index 7ee7faa..cd4ce7a 100644 --- a/arch/mips/cpu/mips32/config.mk +++ b/arch/mips/cpu/mips32/config.mk @@ -21,4 +21,5 @@ else PLATFORM_LDFLAGS += -m elf32ltsmip endif
-CONFIG_STANDALONE_LOAD_ADDR ?= 0x80200000 -T $(srctree)/$(src)/mips.lds +CONFIG_STANDALONE_LOAD_ADDR ?= 0x80200000 \ + -T $(srctree)/examples/standalone/mips.lds diff --git a/arch/mips/cpu/mips64/config.mk b/arch/mips/cpu/mips64/config.mk index 02113a1..3c01136 100644 --- a/arch/mips/cpu/mips64/config.mk +++ b/arch/mips/cpu/mips64/config.mk @@ -21,4 +21,5 @@ else PLATFORM_LDFLAGS += -m elf64ltsmip endif
-CONFIG_STANDALONE_LOAD_ADDR ?= 0xffffffff80200000 -T $(srctree)/$(src)/mips64.lds +CONFIG_STANDALONE_LOAD_ADDR ?= 0xffffffff80200000 \ + -T $(srctree)/examples/standalone/mips64.lds diff --git a/arch/mips/cpu/xburst/config.mk b/arch/mips/cpu/xburst/config.mk index 00b0fd9..b8e53e5 100644 --- a/arch/mips/cpu/xburst/config.mk +++ b/arch/mips/cpu/xburst/config.mk @@ -12,4 +12,5 @@ else PLATFORM_LDFLAGS += -m elf32ltsmip endif
-CONFIG_STANDALONE_LOAD_ADDR ?= 0x80200000 -T $(srctree)/$(src)/mips.lds +CONFIG_STANDALONE_LOAD_ADDR ?= 0x80200000 \ + -T $(srctree)/examples/standalone/mips.lds diff --git a/arch/nds32/config.mk b/arch/nds32/config.mk index 550f8a4..d0434a9 100644 --- a/arch/nds32/config.mk +++ b/arch/nds32/config.mk @@ -10,7 +10,8 @@
CROSS_COMPILE ?= nds32le-linux-
-CONFIG_STANDALONE_LOAD_ADDR = 0x300000 -T $(srctree)/$(src)/nds32.lds +CONFIG_STANDALONE_LOAD_ADDR = 0x300000 \ + -T $(srctree)/examples/standalone/nds32.lds
PLATFORM_RELFLAGS += -fno-strict-aliasing -fno-common -mrelax PLATFORM_RELFLAGS += -gdwarf-2 diff --git a/arch/sparc/config.mk b/arch/sparc/config.mk index 9bb3724..154d00e 100644 --- a/arch/sparc/config.mk +++ b/arch/sparc/config.mk @@ -8,6 +8,6 @@ CROSS_COMPILE ?= sparc-elf-
CONFIG_STANDALONE_LOAD_ADDR ?= 0x00000000 -L $(gcclibdir) \ - -T $(srctree)/$(src)/sparc.lds + -T $(srctree)/examples/standalone/sparc.lds
PLATFORM_CPPFLAGS += -DCONFIG_SPARC -D__sparc__
This commit changes the build system as follows:
- Modify scripts/Makefile.build to not include config.mk Instead, add $(PLATFORM_CPPFLAGS) to asflags-y, ccflags-y, cppflags-y.
- Export many variables Going forward, Kbuild will not parse config.mk files when it descends into subdirectories. If we want to set variables in config.mk and use them in subdirectories, they must be exported.
This is the list of variables to get exported: PLATFORM_CPPFLAGS CPUDIR BOARDDIR OBJCOPYFLAGS LDFLAGS LDFLAGS_FINAL (used in nand_spl/board/*/*/Makefile) CONFIG_STANDALONE_LOAD_ADDR (used in examples/standalone/Makefile) SYM_PREFIX (used in examples/standalone/Makefile) RELFLAGS (used in examples/standalone/Makefile)
- Delete CPPFLAGS This variable has been replaced with PLATFORM_CPPFLAGS
- Copy gcclibdir from example/standalone/Makefile to arch/sparc/config.mk The reference in CONFIG_STANDALONE_LOAD_ADDR must be resolved before it is exported.
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Reported-by: Simon Glass sjg@chromium.org Tested-by: Stephen Warren swarren@nvidia.com ---
Changes in v2: None
Makefile | 7 ++++--- arch/blackfin/config.mk | 1 + arch/sparc/config.mk | 2 ++ config.mk | 28 ++++++++++++++++++++-------- examples/standalone/Makefile | 5 ++--- scripts/Makefile.build | 10 +++++----- scripts/Makefile.lib | 7 +++---- spl/Makefile | 7 +++---- 8 files changed, 40 insertions(+), 27 deletions(-)
diff --git a/Makefile b/Makefile index 56ba1ef..e49a240 100644 --- a/Makefile +++ b/Makefile @@ -358,13 +358,13 @@ UBOOTRELEASE = $(shell cat include/config/uboot.release 2> /dev/null) UBOOTVERSION = $(VERSION)$(if $(PATCHLEVEL),.$(PATCHLEVEL)$(if $(SUBLEVEL),.$(SUBLEVEL)))$(EXTRAVERSION)
export VERSION PATCHLEVEL SUBLEVEL UBOOTRELEASE UBOOTVERSION -export ARCH CPU BOARD VENDOR SOC +export ARCH CPU BOARD VENDOR SOC CPUDIR BOARDDIR export CONFIG_SHELL HOSTCC HOSTCFLAGS HOSTLDFLAGS CROSS_COMPILE AS LD CC export CPP AR NM LDR STRIP OBJCOPY OBJDUMP export MAKE AWK export DTC CHECK CHECKFLAGS
-export KBUILD_CPPFLAGS NOSTDINC_FLAGS UBOOTINCLUDE +export KBUILD_CPPFLAGS NOSTDINC_FLAGS UBOOTINCLUDE OBJCOPYFLAGS LDFLAGS export KBUILD_CFLAGS KBUILD_AFLAGS
# When compiling out-of-tree modules, put MODVERDIR in the module @@ -567,7 +567,8 @@ NOSTDINC_FLAGS += -nostdinc -isystem $(shell $(CC) -print-file-name=include) CHECKFLAGS += $(NOSTDINC_FLAGS)
# FIX ME -cpp_flags := $(KBUILD_CPPFLAGS) $(CPPFLAGS) $(UBOOTINCLUDE) $(NOSTDINC_FLAGS) +cpp_flags := $(KBUILD_CPPFLAGS) $(PLATFORM_CPPFLAGS) $(UBOOTINCLUDE) \ + $(NOSTDINC_FLAGS) c_flags := $(KBUILD_CFLAGS) $(cpp_flags)
######################################################################### diff --git a/arch/blackfin/config.mk b/arch/blackfin/config.mk index c752025..8510e1c 100644 --- a/arch/blackfin/config.mk +++ b/arch/blackfin/config.mk @@ -41,6 +41,7 @@ CREATE_LDR_ENV = endif
SYM_PREFIX = _ +export SYM_PREFIX
LDR_FLAGS-y := LDR_FLAGS-$(CONFIG_BFIN_BOOTROM_USES_EVT1) += -J diff --git a/arch/sparc/config.mk b/arch/sparc/config.mk index 154d00e..7daf4ef 100644 --- a/arch/sparc/config.mk +++ b/arch/sparc/config.mk @@ -7,6 +7,8 @@
+gcclibdir := $(shell dirname `$(CC) -print-libgcc-file-name`) + CONFIG_STANDALONE_LOAD_ADDR ?= 0x00000000 -L $(gcclibdir) \ -T $(srctree)/examples/standalone/sparc.lds
diff --git a/config.mk b/config.mk index e59697f..bb3da0d 100644 --- a/config.mk +++ b/config.mk @@ -6,11 +6,18 @@ # #########################################################################
-# clean the slate ... -PLATFORM_RELFLAGS = -PLATFORM_CPPFLAGS = -PLATFORM_LDFLAGS = - +# This file is included from ./Makefile and spl/Makefile. +# Clean the state to avoid the same flags added twice. +# +# (Tegra needs different flags for SPL. +# That's the reason why this file must be included from spl/Makefile too. +# If we did not have Tegra SoCs, build system would be much simpler...) +PLATFORM_RELFLAGS := +PLATFORM_CPPFLAGS := +PLATFORM_LDFLAGS := +LDFLAGS := +LDFLAGS_FINAL := +OBJCOPYFLAGS := #########################################################################
# Some architecture config.mk files need to know what CPUDIR is set to, @@ -39,12 +46,17 @@ endif
-RELFLAGS= $(PLATFORM_RELFLAGS) +RELFLAGS := $(PLATFORM_RELFLAGS)
OBJCOPYFLAGS += --gap-fill=0xff
-CPPFLAGS = $(RELFLAGS) -CPPFLAGS += -pipe $(PLATFORM_CPPFLAGS) +PLATFORM_CPPFLAGS += $(RELFLAGS) +PLATFORM_CPPFLAGS += -pipe
LDFLAGS += $(PLATFORM_LDFLAGS) LDFLAGS_FINAL += -Bstatic + +export PLATFORM_CPPFLAGS +export RELFLAGS +export LDFLAGS_FINAL +export CONFIG_STANDALONE_LOAD_ADDR diff --git a/examples/standalone/Makefile b/examples/standalone/Makefile index 5b227cd..7e0e5b7 100644 --- a/examples/standalone/Makefile +++ b/examples/standalone/Makefile @@ -44,9 +44,8 @@ gcclibdir := $(shell dirname `$(CC) -print-libgcc-file-name`) # relocatable executable. The relocation data is not needed, and # also causes the entry point of the standalone application to be # inconsistent. -ifeq ($(ARCH),powerpc) -# FIX ME -CPPFLAGS := $(filter-out $(RELFLAGS), $(CPPFLAGS)) +ifeq ($(CONFIG_PPC),y) +PLATFORM_CPPFLAGS := $(filter-out $(RELFLAGS),$(PLATFORM_CPPFLAGS)) endif
# We don't want gcc reordering functions if possible. This ensures that an diff --git a/scripts/Makefile.build b/scripts/Makefile.build index 59361f4..36346fd 100644 --- a/scripts/Makefile.build +++ b/scripts/Makefile.build @@ -55,11 +55,6 @@ endif
include scripts/Kbuild.include
-# Added for U-Boot -# We must include config.mk after Kbuild.include -# so that some config.mk can use cc-option. -include config.mk - # For backward compatibility check that these variables do not change save-cflags := $(CFLAGS)
@@ -68,6 +63,11 @@ kbuild-dir := $(if $(filter /%,$(src)),$(src),$(srctree)/$(src)) kbuild-file := $(if $(wildcard $(kbuild-dir)/Kbuild),$(kbuild-dir)/Kbuild,$(kbuild-dir)/Makefile) include $(kbuild-file)
+# Added for U-Boot +asflags-y += $(PLATFORM_CPPFLAGS) +ccflags-y += $(PLATFORM_CPPFLAGS) +cppflags-y += $(PLATFORM_CPPFLAGS) + # If the save-* variables changed error out ifeq ($(KBUILD_NOPEDANTIC),) ifneq ("$(save-cflags)","$(CFLAGS)") diff --git a/scripts/Makefile.lib b/scripts/Makefile.lib index 02b17b1..d568fde 100644 --- a/scripts/Makefile.lib +++ b/scripts/Makefile.lib @@ -101,13 +101,12 @@ basename_flags = -D"KBUILD_BASENAME=KBUILD_STR($(call name-fix,$(basetarget)))" modname_flags = $(if $(filter 1,$(words $(modname))),\ -D"KBUILD_MODNAME=KBUILD_STR($(call name-fix,$(modname)))")
-# U-Boot also uses $(CPPFLAGS) -orig_c_flags = $(KBUILD_CPPFLAGS) $(CPPFLAGS) $(KBUILD_CFLAGS) $(KBUILD_SUBDIR_CCFLAGS) \ +orig_c_flags = $(KBUILD_CPPFLAGS) $(KBUILD_CFLAGS) $(KBUILD_SUBDIR_CCFLAGS) \ $(ccflags-y) $(CFLAGS_$(basetarget).o) _c_flags = $(filter-out $(CFLAGS_REMOVE_$(basetarget).o), $(orig_c_flags)) -_a_flags = $(KBUILD_CPPFLAGS) $(CPPFLAGS) $(KBUILD_AFLAGS) $(KBUILD_SUBDIR_ASFLAGS) \ +_a_flags = $(KBUILD_CPPFLAGS) $(KBUILD_AFLAGS) $(KBUILD_SUBDIR_ASFLAGS) \ $(asflags-y) $(AFLAGS_$(basetarget).o) -_cpp_flags = $(KBUILD_CPPFLAGS) $(CPPFLAGS) $(cppflags-y) $(CPPFLAGS_$(@F)) +_cpp_flags = $(KBUILD_CPPFLAGS) $(cppflags-y) $(CPPFLAGS_$(@F))
# # Enable gcov profiling flags for a file, directory or for all files depending diff --git a/spl/Makefile b/spl/Makefile index e1a0601..781abf6 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -51,7 +51,9 @@ endif include $(TOPDIR)/config.mk
# FIX ME -c_flags := $(KBUILD_CFLAGS) $(KBUILD_CPPFLAGS) $(CPPFLAGS) $(UBOOTINCLUDE) $(NOSTDINC_FLAGS) +cpp_flags := $(KBUILD_CPPFLAGS) $(PLATFORM_CPPFLAGS) $(UBOOTINCLUDE) \ + $(NOSTDINC_FLAGS) +c_flags := $(KBUILD_CFLAGS) $(cpp_flags)
# Auto-generate the spl-autoconf.mk file (which is included by all makefiles for SPL) quiet_cmd_autoconf = GEN $@ @@ -228,9 +230,6 @@ PHONY += $(u-boot-spl-dirs) $(u-boot-spl-dirs): $(Q)$(MAKE) $(build)=$@
-# FIX ME -cpp_flags := $(KBUILD_CPPFLAGS) $(CPPFLAGS) $(UBOOTINCLUDE) $(NOSTDINC_FLAGS) - quiet_cmd_cpp_lds = LDS $@ cmd_cpp_lds = $(CPP) $(cpp_flags) $(LDPPFLAGS) -ansi -D__ASSEMBLY__ \ -x assembler-with-cpp -P -o $@ $<
Hello Tom,
Please hold applying this patch. I have found a bug in this patch.
microblaze-generic board will be broken with this patch. ( microblaze-linux-gcc fails in building this board, so I missed this bug when I tested this series.)
I will post version 3 tomorrow.
Best Regards Masahiro Yamada
Masahiro Yamada
