[PATCH 0/4] ARM: ti: AM64x: Clean up Ethernet boot support on AM64x SK
This series is follow up to [1]
First patch cleans up err msg in CPSW-NUSS driver Second patch disable cpsw_port1 at SPL stage Third patch increases SPL BSS size in anticipation of enabling network stack Last patch enables all configs needed to support ethboot
[1] https://lore.kernel.org/u-boot/20211224072536.270251-1-vigneshr@ti.com/T/#t
Vignesh Raghavendra (4): net: ti: am65-cpsw-nuss: Fix err msg for port bind failures ARM: dts: k3-am642-sk: Disable cpsw_port1 in SPL configs: am64xx_evm: Increase BSS max size to 16K configs: am64x_evm_r5/a53_defconfig: Enable configs required for Ethboot
arch/arm/dts/k3-am642-r5-sk.dts | 11 ----------- arch/arm/dts/k3-am642-sk-u-boot.dtsi | 8 -------- configs/am64x_evm_a53_defconfig | 4 ++++ configs/am64x_evm_r5_defconfig | 12 ++++++++++++ drivers/net/ti/am65-cpsw-nuss.c | 2 +- include/configs/am64x_evm.h | 2 +- 6 files changed, 18 insertions(+), 21 deletions(-)
Replace error case print with meaning full message.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- drivers/net/ti/am65-cpsw-nuss.c | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ti/am65-cpsw-nuss.c b/drivers/net/ti/am65-cpsw-nuss.c index 6ae69b51c7..454986ff15 100644 --- a/drivers/net/ti/am65-cpsw-nuss.c +++ b/drivers/net/ti/am65-cpsw-nuss.c @@ -752,7 +752,7 @@ static int am65_cpsw_probe_nuss(struct udevice *dev)
ret = device_bind_driver_to_node(dev, "am65_cpsw_nuss_port", ofnode_get_name(node), node, &port_dev); if (ret) - printf("SCREEEM\n"); + dev_err(dev, "Failed to bind to %s node\n", ofnode_get_name(node)); }
for (i = 0; i < AM65_CPSW_CPSWNU_MAX_PORTS; i++) {
ROM supports cpsw_port2 for Ethernet boot and SPL stages continue to download images on the same port, therefore there is no need to enable cpsw_port1. Disable the same.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- arch/arm/dts/k3-am642-r5-sk.dts | 11 ----------- arch/arm/dts/k3-am642-sk-u-boot.dtsi | 8 -------- 2 files changed, 19 deletions(-)
diff --git a/arch/arm/dts/k3-am642-r5-sk.dts b/arch/arm/dts/k3-am642-r5-sk.dts index 3a17448ca0..7d1cb85615 100644 --- a/arch/arm/dts/k3-am642-r5-sk.dts +++ b/arch/arm/dts/k3-am642-r5-sk.dts @@ -231,23 +231,12 @@ &rgmii2_pins_default>; };
-&cpsw_port1 { - phy-mode = "rgmii-rxid"; - phy-handle = <&cpsw3g_phy0>; -}; - &cpsw_port2 { phy-mode = "rgmii-rxid"; phy-handle = <&cpsw3g_phy1>; };
&cpsw3g_mdio { - cpsw3g_phy0: ethernet-phy@0 { - reg = <0>; - ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; - ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_4_B_NIB>; - }; - cpsw3g_phy1: ethernet-phy@1 { reg = <1>; ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_00_NS>; diff --git a/arch/arm/dts/k3-am642-sk-u-boot.dtsi b/arch/arm/dts/k3-am642-sk-u-boot.dtsi index 2f5cfaa04f..e5c26b8326 100644 --- a/arch/arm/dts/k3-am642-sk-u-boot.dtsi +++ b/arch/arm/dts/k3-am642-sk-u-boot.dtsi @@ -117,10 +117,6 @@ u-boot,dm-spl; };
-&cpsw_port1 { - u-boot,dm-spl; -}; - &main_bcdma { u-boot,dm-spl; }; @@ -141,10 +137,6 @@ u-boot,dm-spl; };
-&cpsw3g_phy0 { - u-boot,dm-spl; -}; - &cpsw3g_phy1 { u-boot,dm-spl; };
With Ethboot support in SPL, network stack requires more BSS area, so increase BSS max size to 16K
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- include/configs/am64x_evm.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/include/configs/am64x_evm.h b/include/configs/am64x_evm.h index 99624081c3..135cb3c2ee 100644 --- a/include/configs/am64x_evm.h +++ b/include/configs/am64x_evm.h @@ -33,7 +33,7 @@ * our memory footprint. The less we use for BSS the more we have available * for everything else. */ -#define CONFIG_SPL_BSS_MAX_SIZE 0x1000 +#define CONFIG_SPL_BSS_MAX_SIZE 0x4000 /* * Link BSS to be within SPL in a dedicated region located near the top of * the MCU SRAM, this way making it available also before relocation. Note
Enable config options needed to support Ethernet boot on AM64x SK.
Signed-off-by: Vignesh Raghavendra vigneshr@ti.com --- configs/am64x_evm_a53_defconfig | 4 ++++ configs/am64x_evm_r5_defconfig | 12 ++++++++++++ 2 files changed, 16 insertions(+)
diff --git a/configs/am64x_evm_a53_defconfig b/configs/am64x_evm_a53_defconfig index 3ce2129e49..77010a3ef1 100644 --- a/configs/am64x_evm_a53_defconfig +++ b/configs/am64x_evm_a53_defconfig @@ -30,6 +30,7 @@ CONFIG_SPL_LOAD_FIT=y CONFIG_SPL_LOAD_FIT_ADDRESS=0x81000000 CONFIG_BOOTCOMMAND="run findfdt; run envboot; run init_${boot}; run get_kern_${boot}; run get_fdt_${boot}; run run_kern" CONFIG_BOARD_LATE_INIT=y +CONFIG_SPL_BOARD_INIT=y CONFIG_SPL_SYS_MALLOC_SIMPLE=y CONFIG_SPL_STACK_R=y CONFIG_SPL_SEPARATE_BSS=y @@ -38,8 +39,11 @@ CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x1400 CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y +CONFIG_SPL_ETH=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM64X U-Boot A53 SPL" CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_RAM_SUPPORT=y CONFIG_SPL_RAM_DEVICE=y diff --git a/configs/am64x_evm_r5_defconfig b/configs/am64x_evm_r5_defconfig index 2b609ad9ac..e51a2511d0 100644 --- a/configs/am64x_evm_r5_defconfig +++ b/configs/am64x_evm_r5_defconfig @@ -38,10 +38,14 @@ CONFIG_SPL_SEPARATE_BSS=y CONFIG_SPL_EARLY_BSS=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR=y CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR=0x400 +CONFIG_SPL_DMA=y CONFIG_SPL_ENV_SUPPORT=y CONFIG_SPL_I2C=y +CONFIG_SPL_ETH=y CONFIG_SPL_DM_MAILBOX=y CONFIG_SPL_DM_SPI_FLASH=y +CONFIG_SPL_NET=y +CONFIG_SPL_NET_VCI_STRING="AM64X U-Boot R5 SPL" CONFIG_SPL_DM_RESET=y CONFIG_SPL_POWER_DOMAIN=y CONFIG_SPL_RAM_SUPPORT=y @@ -63,6 +67,7 @@ CONFIG_CMD_REMOTEPROC=y CONFIG_CMD_USB=y CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_CMD_SETEXPR is not set +CONFIG_CMD_DHCP=y CONFIG_CMD_TIME=y CONFIG_CMD_FAT=y CONFIG_OF_CONTROL=y @@ -90,12 +95,15 @@ CONFIG_DFU_MMC=y CONFIG_DFU_RAM=y CONFIG_DFU_SF=y CONFIG_SYS_DFU_DATA_BUF_SIZE=0x5000 +CONFIG_DMA_CHANNELS=y +CONFIG_TI_K3_NAVSS_UDMA=y CONFIG_TI_SCI_PROTOCOL=y CONFIG_DA8XX_GPIO=y CONFIG_DM_I2C=y CONFIG_SYS_I2C_OMAP24XX=y CONFIG_DM_MAILBOX=y CONFIG_K3_SEC_PROXY=y +CONFIG_SPL_MISC=y CONFIG_MMC_SDHCI=y CONFIG_MMC_SDHCI_ADMA=y CONFIG_SPL_MMC_SDHCI_ADMA=y @@ -108,6 +116,9 @@ CONFIG_SPL_PHY=y CONFIG_PHY_CADENCE_SIERRA=y CONFIG_PHY_CADENCE_TORRENT=y CONFIG_PHY_J721E_WIZ=y +CONFIG_PHY_TI_DP83867=y +CONFIG_DM_ETH=y +CONFIG_TI_AM65_CPSW_NUSS=y CONFIG_PINCTRL=y # CONFIG_PINCTRL_GENERIC is not set CONFIG_SPL_PINCTRL=y @@ -125,6 +136,7 @@ CONFIG_DM_RESET=y CONFIG_RESET_TI_SCI=y CONFIG_SPECIFY_CONSOLE_INDEX=y CONFIG_DM_SERIAL=y +CONFIG_SOC_TI=y CONFIG_SPI=y CONFIG_DM_SPI=y CONFIG_CADENCE_QSPI=y
Vignesh Raghavendra
