[U-Boot] [PULL] u-boot-usb/master
The following changes since commit 40a808f173008729a0c631ab84693b6a2b0dcfc9:
ARCv2: SLC: Make sure busy bit is set properly on SLC flushing (2017-04-11 17:54:31 +0300)
git://git.denx.de/u-boot-usb.git master
for you to fetch changes up to ca717a97ea65f9d205097582654040f03263bef6:
usb: dwc2: invalidate the dcache before starting the DMA (2017-04-14 14:07:57 +0200)
---------------------------------------------------------------- Alexey Brodkin (1): drivers/usb/ehci: Use platform-specific accessors
Eddie Cai (1): usb: dwc2: invalidate the dcache before starting the DMA
Felipe Balbi (3): usb: gadget: g_dnl: hold maximum string descriptor usb: gadget: g_dnl: only set iSerialNumber if we have a serial# usb: gadget: g_dnl: don't set iProduct nor iSerialNumber
Kever Yang (1): usb: dwc2: add support for external vbus supply
Philipp Tomsich (2): usb: dwc3: ensure consistent types for dwc3_flush_cache usb: dwc3: gadget: make cache-maintenance on event buffers more robust
drivers/usb/dwc3/core.c | 2 ++ drivers/usb/dwc3/ep0.c | 10 +++++----- drivers/usb/dwc3/gadget.c | 15 ++++++++------- drivers/usb/dwc3/io.h | 2 +- drivers/usb/gadget/g_dnl.c | 18 ++++++++++-------- drivers/usb/host/dwc2.c | 62 +++++++++++++++++++++++++++++++++++++++++++++++++++----------- drivers/usb/host/ehci.h | 10 ++++------ 7 files changed, 81 insertions(+), 38 deletions(-)
for you to fetch changes up to 1e5eca7d422563df91a54e270c297b0c465f2659:
usb: return 0 from usb_stor_get_info even if removable media (2017-04-14 16:44:17 +0200)
V2: Drop patch from Alex which breaks lwmon5 Add patch from Troy to fix bug in USB storage
---------------------------------------------------------------- Eddie Cai (1): usb: dwc2: invalidate the dcache before starting the DMA
Troy Kisky (1): usb: return 0 from usb_stor_get_info even if removable media
common/usb_storage.c | 4 +--- drivers/usb/dwc3/core.c | 2 ++ drivers/usb/dwc3/ep0.c | 10 +++++----- drivers/usb/dwc3/gadget.c | 15 ++++++++------- drivers/usb/dwc3/io.h | 2 +- drivers/usb/gadget/g_dnl.c | 18 ++++++++++-------- drivers/usb/host/dwc2.c | 62 +++++++++++++++++++++++++++++++++++++++++++++++++++----------- 7 files changed, 78 insertions(+), 35 deletions(-)
