[U-Boot] [PATCH 1/8] Prepare for TI816X : reuse existing code from TI814X
Rename some CONFIG_TI814X to a more generic CONFIG_81XX --- Makefile | 2 +- arch/arm/cpu/armv7/Makefile | 2 +- arch/arm/cpu/armv7/omap-common/Makefile | 2 +- arch/arm/include/asm/arch-am33xx/cpu.h | 2 +- arch/arm/include/asm/arch-am33xx/omap.h | 2 +- drivers/serial/ns16550.c | 4 ++-- spl/Makefile | 2 +- 7 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/Makefile b/Makefile index 7273fa4..811e7b6 100644 --- a/Makefile +++ b/Makefile @@ -330,7 +330,7 @@ LIBS-y += api/libapi.o LIBS-y += post/libpost.o LIBS-y += test/libtest.o
-ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP34XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TI814X),) +ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP34XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TI81XX),) LIBS-y += $(CPUDIR)/omap-common/libomap-common.o endif
diff --git a/arch/arm/cpu/armv7/Makefile b/arch/arm/cpu/armv7/Makefile index c961247..9bb2837 100644 --- a/arch/arm/cpu/armv7/Makefile +++ b/arch/arm/cpu/armv7/Makefile @@ -32,7 +32,7 @@ COBJS += cache_v7.o COBJS += cpu.o COBJS += syslib.o
-ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_TI814X),) +ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TEGRA)$(CONFIG_TI81XX),) SOBJS += lowlevel_init.o endif
diff --git a/arch/arm/cpu/armv7/omap-common/Makefile b/arch/arm/cpu/armv7/omap-common/Makefile index 55e82ba..8da8f91 100644 --- a/arch/arm/cpu/armv7/omap-common/Makefile +++ b/arch/arm/cpu/armv7/omap-common/Makefile @@ -36,7 +36,7 @@ COBJS += emif-common.o COBJS += vc.o endif
-ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TI814X),) +ifneq ($(CONFIG_AM33XX)$(CONFIG_OMAP44XX)$(CONFIG_OMAP54XX)$(CONFIG_TI81XX),) COBJS += boot-common.o SOBJS += lowlevel_init.o endif diff --git a/arch/arm/include/asm/arch-am33xx/cpu.h b/arch/arm/include/asm/arch-am33xx/cpu.h index 3d3a7c8..13c0667 100644 --- a/arch/arm/include/asm/arch-am33xx/cpu.h +++ b/arch/arm/include/asm/arch-am33xx/cpu.h @@ -54,7 +54,7 @@ /* Reset control */ #ifdef CONFIG_AM33XX #define PRM_RSTCTRL (PRCM_BASE + 0x0F00) -#elif defined(CONFIG_TI814X) +#elif defined(CONFIG_TI81XX) #define PRM_RSTCTRL (PRCM_BASE + 0x00A0) #endif #define PRM_RSTST (PRM_RSTCTRL + 8) diff --git a/arch/arm/include/asm/arch-am33xx/omap.h b/arch/arm/include/asm/arch-am33xx/omap.h index d28f9a8..1a1cc18 100644 --- a/arch/arm/include/asm/arch-am33xx/omap.h +++ b/arch/arm/include/asm/arch-am33xx/omap.h @@ -31,7 +31,7 @@ #ifdef CONFIG_AM33XX #define NON_SECURE_SRAM_START 0x40304000 #define NON_SECURE_SRAM_END 0x4030E000 -#elif defined(CONFIG_TI814X) +#elif defined(CONFIG_TI81XX) #define NON_SECURE_SRAM_START 0x40300000 #define NON_SECURE_SRAM_END 0x40320000 #endif diff --git a/drivers/serial/ns16550.c b/drivers/serial/ns16550.c index 02bc85b..c949423 100644 --- a/drivers/serial/ns16550.c +++ b/drivers/serial/ns16550.c @@ -43,7 +43,7 @@ void NS16550_init(NS16550_t com_port, int baud_divisor)
serial_out(CONFIG_SYS_NS16550_IER, &com_port->ier); #if (defined(CONFIG_OMAP) && !defined(CONFIG_OMAP3_ZOOM2)) || \ - defined(CONFIG_AM33XX) || defined(CONFIG_TI814X) + defined(CONFIG_AM33XX) || defined(CONFIG_TI81XX) serial_out(0x7, &com_port->mdr1); /* mode select reset TL16C750*/ #endif serial_out(UART_LCR_BKSE | UART_LCRVAL, (ulong)&com_port->lcr); @@ -58,7 +58,7 @@ void NS16550_init(NS16550_t com_port, int baud_divisor) serial_out(UART_LCRVAL, &com_port->lcr); #if (defined(CONFIG_OMAP) && !defined(CONFIG_OMAP3_ZOOM2)) || \ defined(CONFIG_AM33XX) || defined(CONFIG_SOC_DA8XX) || \ - defined(CONFIG_TI814X) + defined(CONFIG_TI81XX)
#if defined(CONFIG_APTIX) /* /13 mode so Aptix 6MHz can hit 115200 */ diff --git a/spl/Makefile b/spl/Makefile index c398a5f..8692f30 100644 --- a/spl/Makefile +++ b/spl/Makefile @@ -82,7 +82,7 @@ LIBS-$(CONFIG_SPL_NET_SUPPORT) += net/libnet.o LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/libnet.o LIBS-$(CONFIG_SPL_ETH_SUPPORT) += drivers/net/phy/libphy.o
"TENART" == TENART Antoine atenart@adeneo-embedded.com writes:
TENART> Rename some CONFIG_TI814X to a more generic CONFIG_81XX
Acked-by: Peter Korsgaard jacmet@Sunsite.dk
This is fine except it breaks bisectability, you need to also add CONFIG_TI81XX to ti814x_evm.h at this point.
"Tom" == Tom Rini trini@ti.com writes:
Tom> This is fine except it breaks bisectability, you need to also add Tom> CONFIG_TI81XX to ti814x_evm.h at this point.
It afaik already has it.
Yes, it was introduced by Matt Porter in "ti814x_evm: add ti814x evm board support" patch : +#define CONFIG_TI81XX +#define CONFIG_TI814X
OK, thanks, forgot Matt already set the symbol.
Peter Korsgaard
TENART Antoine
