[U-Boot-Users] AT91 Dataflash support.
12 Feb
2007
12 Feb
'07
9:08 a.m.
The plan to remove the memory mapping of dataflash will likely change the environment handling. The environment is currently inside the dataflash on most AT91 boards.
Also don't forget that code for parallel flash is not wanted in dataflash only designs and should be consistently ifdef'ed away in all memory commands.
Best Regards, Ulf Samuelsson
6659
Ulf Samuelsson
