[U-Boot] Please pull u-boot-rockchip
Hi Tom,
Here's a rebased version of the last pull request.
The following changes since commit 6523dbf7cce8d8c903346f756e0e41e46ce6d6b9:
Merge branch 'master' of git://git.denx.de/u-boot-mips (2016-05-25 20:22:48 -0400)
git://git.denx.de/u-boot-rockchip.git
for you to fetch changes up to 2ed6dc83380ea2f49ec09556c14c6eddd3f5c27a:
rockchip: rock2: dts: use status = "okay" not ok (2016-05-27 09:00:48 -0600)
---------------------------------------------------------------- Sjoerd Simons (6): net: designware: support phy reset device-tree bindings rockchip: rk3288: pinctrl: support more pins rockchip: rk3288: Add clock support for the gmac ethernet interface rockchip: rk3288: grf: Define GRF_SOC_CON1 and GRF_SOC_CON3 rockchip: rk3288-firefly: Add gmac definition rockchip: rock2: dts: use status = "okay" not ok
arch/arm/dts/rk3288-firefly.dtsi | 16 ++++++++++++++ arch/arm/dts/rk3288-rock2-square.dts | 2 +- arch/arm/include/asm/arch-rockchip/cru_rk3288.h | 17 +++++++++++++++ arch/arm/include/asm/arch-rockchip/grf_rk3288.h | 53 +++++++++++++++++++++++++++++++++++++++++++++ drivers/clk/clk_rk3288.c | 14 ++++++++++++ drivers/net/designware.c | 76 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++++------ drivers/net/designware.h | 10 +++++++++ drivers/pinctrl/rockchip/pinctrl_rk3288.c | 2 +- 8 files changed, 182 insertions(+), 8 deletions(-)
On Fri, May 27, 2016 at 10:19:48AM -0600, Simon Glass wrote:
Hi Tom,
