[PATCH] arm: socfpga: n5x: Update DDR init progress bit
The bit[30] of boot scratch cold 8 register is used as DDR init progress tracking by SDM when watchdog is triggered due to ddr init hang, so that SDM can run a clean reset to DDR subsystem.
Signed-off-by: Tien Fong Chee tien.fong.chee@intel.com Signed-off-by: Jit Loon Lim jit.loon.lim@intel.com --- drivers/ddr/altera/sdram_n5x.c | 17 +++++++++++++++++ 1 file changed, 17 insertions(+)
diff --git a/drivers/ddr/altera/sdram_n5x.c b/drivers/ddr/altera/sdram_n5x.c index 135bc8fd7d..d707bba862 100644 --- a/drivers/ddr/altera/sdram_n5x.c +++ b/drivers/ddr/altera/sdram_n5x.c @@ -428,6 +428,18 @@ enum data_process { LOADING };
+void ddr_init_inprogress(bool start) +{ + if (start) + setbits_le32(socfpga_get_sysmgr_addr() + + SYSMGR_SOC64_BOOT_SCRATCH_COLD8, + ALT_SYSMGR_SCRATCH_REG_8_DDR_PROGRESS_MASK); + else + clrbits_le32(socfpga_get_sysmgr_addr() + + SYSMGR_SOC64_BOOT_SCRATCH_COLD8, + ALT_SYSMGR_SCRATCH_REG_8_DDR_PROGRESS_MASK); +} + bool is_ddr_retention_enabled(u32 reg) { if (reg & ALT_SYSMGR_SCRATCH_REG_0_DDR_RETENTION_MASK) @@ -2848,6 +2860,7 @@ int sdram_mmr_init_full(struct udevice *dev)
if (!is_ddr_init_skipped(reg)) { printf("SDRAM init in progress ...\n"); + ddr_init_inprogress(true);
/* * Polling reset complete, must be high to ensure DDR @@ -2994,6 +3007,10 @@ int sdram_mmr_init_full(struct udevice *dev) priv->info.size = gd->ram_size;
sdram_size_check(&bd); + + /* Marking end of ddr init with passing basic memory test */ + ddr_init_inprogress(false); + sdram_set_firewall(&bd);
ddr_offset = simple_strtoul(offset, &endptr, 16);
Jit Loon Lim
