[PATCH 00/16] rockchip: Migrate RK3308, RK3328, RK356x and RK3588 to OF_UPSTREAM
This series migrate RK3308, RK3328, RK356x and RK3588 boards that exists in Linux kernel v6.8 to use OF_UPSTREAM.
The usbdp phy driver is also updated to work with the DT binding that is targeted for v6.10.
And the usb3 related nodes currently part of the SoC u-boot.dtsi is updated to match the soc/board DT that is targeted for v6.10 in order to avoid breaking changes in future when dts/upstream gets updated.
Following targets has not been migrated to use OF_UPSTREAM: - anbernic-rgxx3-rk3566: Multi device target - generic-rk3568: Generic target only meant for U-Boot use - generic-rk3588: Generic target only meant for U-Boot use - nanopi-m4-2gb-rk3399: DDR3 variant of nanopi-m4-rk3399 (LPDDR3) - pinetab2-rk3566: Merged in v6.9-rc1 - toybrick-rk3588: Merged in v6.9-rc1
This series depends on the following series: - rockchip: rk3399: Fix loading FIT from SD-card when booting from eMMC [1] - rockchip: rk3399: Sync DT with v6.8 and update defconfigs [2]
A copy of this series and its depends can also be found at [3].
[1] https://patchwork.ozlabs.org/cover/1929673/ [2] https://patchwork.ozlabs.org/cover/1930271/ [3] https://github.com/Kwiboo/u-boot-rockchip/commits/rk3xxx-of-upstream-v1
Jonas Karlman (16): rockchip: rk3308: Migrate to OF_UPSTREAM rockchip: rk3308: Remove redundant device tree files rockchip: rk3328: Migrate to OF_UPSTREAM rockchip: rk3328: Remove redundant device tree files rockchip: rk3399: Migrate to OF_UPSTREAM rockchip: rk3399: Remove redundant device tree files rockchip: rk356x: Add rk3568-u-boot.dtsi rockchip: rk356x: Migrate to OF_UPSTREAM rockchip: rk356x: Remove redundant device tree files phy: rockchip: usbdp: Find phy-id from the io address phy: rockchip: usbdp: Drop rockchip_u3phy_uboot_init() phy: rockchip: usbdp: Adopt driver to work with upstream DT rockchip: rk3588-rock-5b: Drop usb-typec node from u-boot.dtsi rockchip: rk3588: Update USB3 related nodes in u-boot.dtsi rockchip: rk3588: Migrate to OF_UPSTREAM rockchip: rk3588: Remove redundant device tree files
arch/arm/dts/Makefile | 84 - arch/arm/dts/rk3308-evb.dts | 230 -- arch/arm/dts/rk3308-roc-cc.dts | 190 - arch/arm/dts/rk3308-rock-pi-s.dts | 314 -- arch/arm/dts/rk3308.dtsi | 1888 --------- arch/arm/dts/rk3328-evb.dts | 289 -- arch/arm/dts/rk3328-nanopi-r2c-plus.dts | 33 - arch/arm/dts/rk3328-nanopi-r2c.dts | 40 - arch/arm/dts/rk3328-nanopi-r2s.dts | 410 -- arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts | 42 - arch/arm/dts/rk3328-orangepi-r1-plus.dts | 374 -- arch/arm/dts/rk3328-roc-cc.dts | 384 -- arch/arm/dts/rk3328-rock-pi-e.dts | 445 --- arch/arm/dts/rk3328-rock64.dts | 394 -- arch/arm/dts/rk3328.dtsi | 1944 ---------- arch/arm/dts/rk3399-eaidk-610.dts | 940 ----- arch/arm/dts/rk3399-evb.dts | 485 --- arch/arm/dts/rk3399-ficus.dts | 174 - arch/arm/dts/rk3399-firefly.dts | 944 ----- arch/arm/dts/rk3399-gru-bob.dts | 95 - arch/arm/dts/rk3399-gru-chromebook.dtsi | 590 --- arch/arm/dts/rk3399-gru-kevin.dts | 328 -- arch/arm/dts/rk3399-gru.dtsi | 865 ----- arch/arm/dts/rk3399-khadas-edge-captain.dts | 31 - arch/arm/dts/rk3399-khadas-edge-v.dts | 31 - arch/arm/dts/rk3399-khadas-edge.dts | 13 - arch/arm/dts/rk3399-khadas-edge.dtsi | 837 ---- arch/arm/dts/rk3399-leez-p710.dts | 653 ---- arch/arm/dts/rk3399-nanopc-t4.dts | 137 - arch/arm/dts/rk3399-nanopi-m4.dts | 66 - arch/arm/dts/rk3399-nanopi-m4b.dts | 52 - arch/arm/dts/rk3399-nanopi-neo4.dts | 50 - arch/arm/dts/rk3399-nanopi-r4s.dts | 133 - arch/arm/dts/rk3399-nanopi4.dtsi | 762 ---- arch/arm/dts/rk3399-op1-opp.dtsi | 166 - arch/arm/dts/rk3399-opp.dtsi | 133 - arch/arm/dts/rk3399-orangepi.dts | 896 ----- arch/arm/dts/rk3399-pinebook-pro.dts | 1111 ------ arch/arm/dts/rk3399-pinephone-pro.dts | 621 --- arch/arm/dts/rk3399-puma-haikou.dts | 306 -- arch/arm/dts/rk3399-puma.dtsi | 532 --- arch/arm/dts/rk3399-roc-pc-mezzanine.dts | 111 - arch/arm/dts/rk3399-roc-pc.dts | 12 - arch/arm/dts/rk3399-roc-pc.dtsi | 844 ---- arch/arm/dts/rk3399-rock-4c-plus.dts | 709 ---- arch/arm/dts/rk3399-rock-4se.dts | 65 - arch/arm/dts/rk3399-rock-pi-4.dtsi | 792 ---- arch/arm/dts/rk3399-rock-pi-4a.dts | 24 - arch/arm/dts/rk3399-rock-pi-4c.dts | 80 - arch/arm/dts/rk3399-rock960.dts | 156 - arch/arm/dts/rk3399-rock960.dtsi | 673 ---- arch/arm/dts/rk3399-rockpro64.dts | 30 - arch/arm/dts/rk3399-rockpro64.dtsi | 956 ----- arch/arm/dts/rk3399-t-opp.dtsi | 114 - arch/arm/dts/rk3399.dtsi | 2945 -------------- arch/arm/dts/rk3399pro-rock-pi-n10.dts | 22 - arch/arm/dts/rk3399pro-vmarc-som.dtsi | 477 --- arch/arm/dts/rk3399pro.dtsi | 22 - arch/arm/dts/rk3566-anbernic-rgxx3.dtsi | 788 ---- arch/arm/dts/rk3566-quartz64-a.dts | 838 ---- arch/arm/dts/rk3566-quartz64-b.dts | 737 ---- arch/arm/dts/rk3566-radxa-cm3-io.dts | 281 -- arch/arm/dts/rk3566-radxa-cm3.dtsi | 425 -- arch/arm/dts/rk3566-soquartz-blade.dts | 198 - arch/arm/dts/rk3566-soquartz-cm4.dts | 196 - arch/arm/dts/rk3566-soquartz-model-a.dts | 236 -- arch/arm/dts/rk3566-soquartz.dtsi | 684 ---- arch/arm/dts/rk3566.dtsi | 35 - arch/arm/dts/rk3568-bpi-r2-pro.dts | 852 ---- arch/arm/dts/rk3568-evb.dts | 689 ---- arch/arm/dts/rk3568-lubancat-2.dts | 730 ---- arch/arm/dts/rk3568-nanopi-r5c.dts | 112 - arch/arm/dts/rk3568-nanopi-r5s.dts | 136 - arch/arm/dts/rk3568-nanopi-r5s.dtsi | 587 --- arch/arm/dts/rk3568-odroid-m1.dts | 741 ---- arch/arm/dts/rk3568-pinctrl.dtsi | 3214 --------------- arch/arm/dts/rk3568-radxa-cm3i.dtsi | 412 -- arch/arm/dts/rk3568-radxa-e25.dts | 236 -- arch/arm/dts/rk3568-rock-3a.dts | 859 ---- arch/arm/dts/rk3568-u-boot.dtsi | 3 + arch/arm/dts/rk3568.dtsi | 267 -- arch/arm/dts/rk356x.dtsi | 1886 --------- arch/arm/dts/rk3588-coolpi-cm5-evb.dts | 216 -- arch/arm/dts/rk3588-coolpi-cm5.dtsi | 649 ---- arch/arm/dts/rk3588-edgeble-neu6a-io.dts | 23 - arch/arm/dts/rk3588-edgeble-neu6a.dtsi | 31 - arch/arm/dts/rk3588-edgeble-neu6b-io.dts | 89 - arch/arm/dts/rk3588-edgeble-neu6b.dtsi | 389 -- arch/arm/dts/rk3588-evb1-v10.dts | 1080 ------ arch/arm/dts/rk3588-generic-u-boot.dtsi | 4 - arch/arm/dts/rk3588-jaguar.dts | 803 ---- arch/arm/dts/rk3588-nanopc-t6.dts | 916 ----- arch/arm/dts/rk3588-orangepi-5-plus.dts | 847 ---- arch/arm/dts/rk3588-pinctrl.dtsi | 516 --- arch/arm/dts/rk3588-quartzpro64.dts | 1137 ------ arch/arm/dts/rk3588-rock-5b-u-boot.dtsi | 115 +- arch/arm/dts/rk3588-rock-5b.dts | 776 ---- arch/arm/dts/rk3588-turing-rk1.dts | 21 - arch/arm/dts/rk3588-turing-rk1.dtsi | 612 --- arch/arm/dts/rk3588-u-boot.dtsi | 36 +- arch/arm/dts/rk3588.dtsi | 341 -- arch/arm/dts/rk3588j.dtsi | 7 - arch/arm/dts/rk3588s-coolpi-4b.dts | 812 ---- arch/arm/dts/rk3588s-orangepi-5.dts | 667 ---- arch/arm/dts/rk3588s-pinctrl.dtsi | 3447 ----------------- arch/arm/dts/rk3588s-rock-5a.dts | 744 ---- arch/arm/dts/rk3588s-u-boot.dtsi | 34 +- arch/arm/dts/rk3588s.dtsi | 2485 ------------ arch/arm/mach-rockchip/Kconfig | 5 + configs/anbernic-rgxx3-rk3566_defconfig | 1 + configs/bpi-r2-pro-rk3568_defconfig | 2 +- configs/chromebook_bob_defconfig | 2 +- configs/chromebook_kevin_defconfig | 2 +- configs/coolpi-4b-rk3588s_defconfig | 2 +- configs/coolpi-cm5-evb-rk3588_defconfig | 2 +- configs/eaidk-610-rk3399_defconfig | 2 +- configs/evb-rk3308_defconfig | 2 +- configs/evb-rk3328_defconfig | 2 +- configs/evb-rk3399_defconfig | 2 +- configs/evb-rk3568_defconfig | 4 +- configs/evb-rk3588_defconfig | 2 +- configs/ficus-rk3399_defconfig | 2 +- configs/firefly-rk3399_defconfig | 2 +- configs/generic-rk3568_defconfig | 1 + configs/generic-rk3588_defconfig | 1 + configs/jaguar-rk3588_defconfig | 2 +- configs/khadas-edge-captain-rk3399_defconfig | 2 +- configs/khadas-edge-rk3399_defconfig | 2 +- configs/khadas-edge-v-rk3399_defconfig | 2 +- configs/leez-rk3399_defconfig | 2 +- configs/lubancat-2-rk3568_defconfig | 2 +- configs/nanopc-t4-rk3399_defconfig | 2 +- configs/nanopc-t6-rk3588_defconfig | 2 +- configs/nanopi-m4-2gb-rk3399_defconfig | 1 + configs/nanopi-m4-rk3399_defconfig | 2 +- configs/nanopi-m4b-rk3399_defconfig | 2 +- configs/nanopi-neo4-rk3399_defconfig | 2 +- configs/nanopi-r2c-plus-rk3328_defconfig | 2 +- configs/nanopi-r2c-rk3328_defconfig | 2 +- configs/nanopi-r2s-rk3328_defconfig | 2 +- configs/nanopi-r4s-rk3399_defconfig | 2 +- configs/nanopi-r5c-rk3568_defconfig | 2 +- configs/nanopi-r5s-rk3568_defconfig | 2 +- configs/neu6a-io-rk3588_defconfig | 2 +- configs/neu6b-io-rk3588_defconfig | 2 +- configs/odroid-m1-rk3568_defconfig | 2 +- configs/orangepi-5-plus-rk3588_defconfig | 2 +- configs/orangepi-5-rk3588s_defconfig | 2 +- configs/orangepi-r1-plus-lts-rk3328_defconfig | 2 +- configs/orangepi-r1-plus-rk3328_defconfig | 2 +- configs/orangepi-rk3399_defconfig | 2 +- configs/pinebook-pro-rk3399_defconfig | 2 +- configs/pinephone-pro-rk3399_defconfig | 2 +- configs/pinetab2-rk3566_defconfig | 1 + configs/puma-rk3399_defconfig | 2 +- configs/quartz64-a-rk3566_defconfig | 2 +- configs/quartz64-b-rk3566_defconfig | 2 +- configs/quartzpro64-rk3588_defconfig | 2 +- configs/radxa-cm3-io-rk3566_defconfig | 2 +- configs/radxa-e25-rk3568_defconfig | 2 +- configs/roc-cc-rk3308_defconfig | 2 +- configs/roc-cc-rk3328_defconfig | 2 +- configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-3a-rk3568_defconfig | 2 +- configs/rock-4c-plus-rk3399_defconfig | 2 +- configs/rock-4se-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rock-pi-e-rk3328_defconfig | 2 +- configs/rock-pi-n10-rk3399pro_defconfig | 2 +- configs/rock-pi-s-rk3308_defconfig | 2 +- configs/rock5a-rk3588s_defconfig | 2 +- configs/rock5b-rk3588_defconfig | 2 +- configs/rock64-rk3328_defconfig | 2 +- configs/rock960-rk3399_defconfig | 2 +- configs/rockpro64-rk3399_defconfig | 2 +- configs/soquartz-blade-rk3566_defconfig | 2 +- configs/soquartz-cm4-rk3566_defconfig | 2 +- configs/soquartz-model-a-rk3566_defconfig | 2 +- configs/toybrick-rk3588_defconfig | 1 + configs/turing-rk1-rk3588_defconfig | 2 +- .../clock/rockchip,rk3399-dmc.txt | 42 - drivers/phy/rockchip/phy-rockchip-usbdp.c | 126 +- include/dt-bindings/clock/rk3308-cru.h | 387 -- include/dt-bindings/clock/rk3328-cru.h | 393 -- include/dt-bindings/clock/rk3399-cru.h | 751 ---- include/dt-bindings/clock/rk3568-cru.h | 926 ----- .../dt-bindings/clock/rockchip,rk3588-cru.h | 766 ---- include/dt-bindings/power/rk3328-power.h | 19 - include/dt-bindings/power/rk3399-power.h | 53 - include/dt-bindings/power/rk3568-power.h | 32 - include/dt-bindings/power/rk3588-power.h | 69 - .../dt-bindings/reset/rockchip,rk3588-cru.h | 754 ---- 194 files changed, 161 insertions(+), 62287 deletions(-) delete mode 100644 arch/arm/dts/rk3308-evb.dts delete mode 100644 arch/arm/dts/rk3308-roc-cc.dts delete mode 100644 arch/arm/dts/rk3308-rock-pi-s.dts delete mode 100644 arch/arm/dts/rk3308.dtsi delete mode 100644 arch/arm/dts/rk3328-evb.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2c-plus.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2c.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2s.dts delete mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts delete mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus.dts delete mode 100644 arch/arm/dts/rk3328-roc-cc.dts delete mode 100644 arch/arm/dts/rk3328-rock-pi-e.dts delete mode 100644 arch/arm/dts/rk3328-rock64.dts delete mode 100644 arch/arm/dts/rk3328.dtsi delete mode 100644 arch/arm/dts/rk3399-eaidk-610.dts delete mode 100644 arch/arm/dts/rk3399-evb.dts delete mode 100644 arch/arm/dts/rk3399-ficus.dts delete mode 100644 arch/arm/dts/rk3399-firefly.dts delete mode 100644 arch/arm/dts/rk3399-gru-bob.dts delete mode 100644 arch/arm/dts/rk3399-gru-chromebook.dtsi delete mode 100644 arch/arm/dts/rk3399-gru-kevin.dts delete mode 100644 arch/arm/dts/rk3399-gru.dtsi delete mode 100644 arch/arm/dts/rk3399-khadas-edge-captain.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge-v.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge.dtsi delete mode 100644 arch/arm/dts/rk3399-leez-p710.dts delete mode 100644 arch/arm/dts/rk3399-nanopc-t4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-m4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-m4b.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-neo4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-r4s.dts delete mode 100644 arch/arm/dts/rk3399-nanopi4.dtsi delete mode 100644 arch/arm/dts/rk3399-op1-opp.dtsi delete mode 100644 arch/arm/dts/rk3399-opp.dtsi delete mode 100644 arch/arm/dts/rk3399-orangepi.dts delete mode 100644 arch/arm/dts/rk3399-pinebook-pro.dts delete mode 100644 arch/arm/dts/rk3399-pinephone-pro.dts delete mode 100644 arch/arm/dts/rk3399-puma-haikou.dts delete mode 100644 arch/arm/dts/rk3399-puma.dtsi delete mode 100644 arch/arm/dts/rk3399-roc-pc-mezzanine.dts delete mode 100644 arch/arm/dts/rk3399-roc-pc.dts delete mode 100644 arch/arm/dts/rk3399-roc-pc.dtsi delete mode 100644 arch/arm/dts/rk3399-rock-4c-plus.dts delete mode 100644 arch/arm/dts/rk3399-rock-4se.dts delete mode 100644 arch/arm/dts/rk3399-rock-pi-4.dtsi delete mode 100644 arch/arm/dts/rk3399-rock-pi-4a.dts delete mode 100644 arch/arm/dts/rk3399-rock-pi-4c.dts delete mode 100644 arch/arm/dts/rk3399-rock960.dts delete mode 100644 arch/arm/dts/rk3399-rock960.dtsi delete mode 100644 arch/arm/dts/rk3399-rockpro64.dts delete mode 100644 arch/arm/dts/rk3399-rockpro64.dtsi delete mode 100644 arch/arm/dts/rk3399-t-opp.dtsi delete mode 100644 arch/arm/dts/rk3399.dtsi delete mode 100644 arch/arm/dts/rk3399pro-rock-pi-n10.dts delete mode 100644 arch/arm/dts/rk3399pro-vmarc-som.dtsi delete mode 100644 arch/arm/dts/rk3399pro.dtsi delete mode 100644 arch/arm/dts/rk3566-anbernic-rgxx3.dtsi delete mode 100644 arch/arm/dts/rk3566-quartz64-a.dts delete mode 100644 arch/arm/dts/rk3566-quartz64-b.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3-io.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3.dtsi delete mode 100644 arch/arm/dts/rk3566-soquartz-blade.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-cm4.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-model-a.dts delete mode 100644 arch/arm/dts/rk3566-soquartz.dtsi delete mode 100644 arch/arm/dts/rk3566.dtsi delete mode 100644 arch/arm/dts/rk3568-bpi-r2-pro.dts delete mode 100644 arch/arm/dts/rk3568-evb.dts delete mode 100644 arch/arm/dts/rk3568-lubancat-2.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5c.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dtsi delete mode 100644 arch/arm/dts/rk3568-odroid-m1.dts delete mode 100644 arch/arm/dts/rk3568-pinctrl.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-cm3i.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-e25.dts delete mode 100644 arch/arm/dts/rk3568-rock-3a.dts create mode 100644 arch/arm/dts/rk3568-u-boot.dtsi delete mode 100644 arch/arm/dts/rk3568.dtsi delete mode 100644 arch/arm/dts/rk356x.dtsi delete mode 100644 arch/arm/dts/rk3588-coolpi-cm5-evb.dts delete mode 100644 arch/arm/dts/rk3588-coolpi-cm5.dtsi delete mode 100644 arch/arm/dts/rk3588-edgeble-neu6a-io.dts delete mode 100644 arch/arm/dts/rk3588-edgeble-neu6a.dtsi delete mode 100644 arch/arm/dts/rk3588-edgeble-neu6b-io.dts delete mode 100644 arch/arm/dts/rk3588-edgeble-neu6b.dtsi delete mode 100644 arch/arm/dts/rk3588-evb1-v10.dts delete mode 100644 arch/arm/dts/rk3588-jaguar.dts delete mode 100644 arch/arm/dts/rk3588-nanopc-t6.dts delete mode 100644 arch/arm/dts/rk3588-orangepi-5-plus.dts delete mode 100644 arch/arm/dts/rk3588-pinctrl.dtsi delete mode 100644 arch/arm/dts/rk3588-quartzpro64.dts delete mode 100644 arch/arm/dts/rk3588-rock-5b.dts delete mode 100644 arch/arm/dts/rk3588-turing-rk1.dts delete mode 100644 arch/arm/dts/rk3588-turing-rk1.dtsi delete mode 100644 arch/arm/dts/rk3588.dtsi delete mode 100644 arch/arm/dts/rk3588j.dtsi delete mode 100644 arch/arm/dts/rk3588s-coolpi-4b.dts delete mode 100644 arch/arm/dts/rk3588s-orangepi-5.dts delete mode 100644 arch/arm/dts/rk3588s-pinctrl.dtsi delete mode 100644 arch/arm/dts/rk3588s-rock-5a.dts delete mode 100644 arch/arm/dts/rk3588s.dtsi delete mode 100644 doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt delete mode 100644 include/dt-bindings/clock/rk3308-cru.h delete mode 100644 include/dt-bindings/clock/rk3328-cru.h delete mode 100644 include/dt-bindings/clock/rk3399-cru.h delete mode 100644 include/dt-bindings/clock/rk3568-cru.h delete mode 100644 include/dt-bindings/clock/rockchip,rk3588-cru.h delete mode 100644 include/dt-bindings/power/rk3328-power.h delete mode 100644 include/dt-bindings/power/rk3399-power.h delete mode 100644 include/dt-bindings/power/rk3568-power.h delete mode 100644 include/dt-bindings/power/rk3588-power.h delete mode 100644 include/dt-bindings/reset/rockchip,rk3588-cru.h
All RK3308 boards has now been synced to Linux kernel v6.8 DTs and can migrate to use OF_UPSTREAM.
Migrate all RK3308 boards to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/Makefile | 5 ----- arch/arm/mach-rockchip/Kconfig | 1 + configs/evb-rk3308_defconfig | 2 +- configs/roc-cc-rk3308_defconfig | 2 +- configs/rock-pi-s-rk3308_defconfig | 2 +- 5 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index c9f1b25ad647..319ec23a4fee 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -92,11 +92,6 @@ dtb-$(CONFIG_ROCKCHIP_RK3288) += \ rk3288-veyron-speedy.dtb \ rk3288-vyasa.dtb
-dtb-$(CONFIG_ROCKCHIP_RK3308) += \ - rk3308-evb.dtb \ - rk3308-roc-cc.dtb \ - rk3308-rock-pi-s.dtb - dtb-$(CONFIG_ROCKCHIP_RK3328) += \ rk3328-evb.dtb \ rk3328-nanopi-r2c.dtb \ diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index 262cb7cba3ea..f1caf4f3738b 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -166,6 +166,7 @@ config ROCKCHIP_RK3308 imply LEGACY_IMAGE_FORMAT imply MISC imply MISC_INIT_R + imply OF_UPSTREAM imply RNG_ROCKCHIP imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_OTP diff --git a/configs/evb-rk3308_defconfig b/configs/evb-rk3308_defconfig index 04a94e13a68a..f4c2ea12adaa 100644 --- a/configs/evb-rk3308_defconfig +++ b/configs/evb-rk3308_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3308-evb" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-evb" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y diff --git a/configs/roc-cc-rk3308_defconfig b/configs/roc-cc-rk3308_defconfig index ef58bd657532..862ea4301f25 100644 --- a/configs/roc-cc-rk3308_defconfig +++ b/configs/roc-cc-rk3308_defconfig @@ -3,7 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y -CONFIG_DEFAULT_DEVICE_TREE="rk3308-roc-cc" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-roc-cc" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y diff --git a/configs/rock-pi-s-rk3308_defconfig b/configs/rock-pi-s-rk3308_defconfig index 37a124eae181..c15ba3d8a451 100644 --- a/configs/rock-pi-s-rk3308_defconfig +++ b/configs/rock-pi-s-rk3308_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3308-rock-pi-s" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3308-rock-pi-s" CONFIG_OF_LIBFDT_OVERLAY=y CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3308=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- rk3308-evb.dtb \
- imply OF_UPSTREAM imply RNG_ROCKCHIP imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_OTP
Remove redundant device tree files now that RK3308 boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3308-evb.dts | 230 --- arch/arm/dts/rk3308-roc-cc.dts | 190 --- arch/arm/dts/rk3308-rock-pi-s.dts | 314 ---- arch/arm/dts/rk3308.dtsi | 1888 ------------------------ include/dt-bindings/clock/rk3308-cru.h | 387 ----- 5 files changed, 3009 deletions(-) delete mode 100644 arch/arm/dts/rk3308-evb.dts delete mode 100644 arch/arm/dts/rk3308-roc-cc.dts delete mode 100644 arch/arm/dts/rk3308-rock-pi-s.dts delete mode 100644 arch/arm/dts/rk3308.dtsi delete mode 100644 include/dt-bindings/clock/rk3308-cru.h
diff --git a/arch/arm/dts/rk3308-evb.dts b/arch/arm/dts/rk3308-evb.dts deleted file mode 100644 index 184b84fdde07..000000000000 --- a/arch/arm/dts/rk3308-evb.dts +++ /dev/null @@ -1,230 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * - */ - -/dts-v1/; -#include <dt-bindings/input/input.h> -#include "rk3308.dtsi" - -/ { - model = "Rockchip RK3308 EVB"; - compatible = "rockchip,rk3308-evb", "rockchip,rk3308"; - - chosen { - stdout-path = "serial4:1500000n8"; - }; - - adc-keys0 { - compatible = "adc-keys"; - io-channels = <&saradc 0>; - io-channel-names = "buttons"; - poll-interval = <100>; - keyup-threshold-microvolt = <1800000>; - - button-func { - linux,code = <KEY_FN>; - label = "function"; - press-threshold-microvolt = <18000>; - }; - }; - - adc-keys1 { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - poll-interval = <100>; - keyup-threshold-microvolt = <1800000>; - - button-esc { - linux,code = <KEY_MICMUTE>; - label = "micmute"; - press-threshold-microvolt = <1130000>; - }; - - button-home { - linux,code = <KEY_MODE>; - label = "mode"; - press-threshold-microvolt = <901000>; - }; - - button-menu { - linux,code = <KEY_PLAY>; - label = "play"; - press-threshold-microvolt = <624000>; - }; - - button-down { - linux,code = <KEY_VOLUMEDOWN>; - label = "volume down"; - press-threshold-microvolt = <300000>; - }; - - button-up { - linux,code = <KEY_VOLUMEUP>; - label = "volume up"; - press-threshold-microvolt = <18000>; - }; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - pinctrl-names = "default"; - pinctrl-0 = <&pwr_key>; - - key-power { - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; - linux,code = <KEY_POWER>; - label = "GPIO Key Power"; - debounce-interval = <100>; - wakeup-source; - }; - }; - - vcc12v_dcin: vcc12v-dcin { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc12v_dcin>; - }; - - vccio_sdio: vcc_1v8: vcc-1v8 { - compatible = "regulator-fixed"; - regulator-name = "vcc_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_io>; - }; - - vcc_ddr: vcc-ddr { - compatible = "regulator-fixed"; - regulator-name = "vcc_ddr"; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc_io: vcc-io { - compatible = "regulator-fixed"; - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; - - vccio_flash: vccio-flash { - compatible = "regulator-fixed"; - regulator-name = "vccio_flash"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_io>; - }; - - vcc5v0_host: vcc5v0-host { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; - enable-active-high; - pinctrl-names = "default"; - pinctrl-0 = <&usb_drv>; - regulator-name = "vbus_host"; - vin-supply = <&vcc5v0_sys>; - }; - - vdd_core: vdd-core { - compatible = "pwm-regulator"; - pwms = <&pwm0 0 5000 1>; - regulator-name = "vdd_core"; - regulator-min-microvolt = <827000>; - regulator-max-microvolt = <1340000>; - regulator-always-on; - regulator-boot-on; - regulator-settling-time-up-us = <250>; - pwm-supply = <&vcc5v0_sys>; - }; - - vdd_log: vdd-log { - compatible = "regulator-fixed"; - regulator-name = "vdd_log"; - regulator-min-microvolt = <1050000>; - regulator-max-microvolt = <1050000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; - - vdd_1v0: vdd-1v0 { - compatible = "regulator-fixed"; - regulator-name = "vdd_1v0"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_core>; -}; - -&saradc { - status = "okay"; - vref-supply = <&vcc_1v8>; -}; - -&pinctrl { - pinctrl-names = "default"; - pinctrl-0 = <&rtc_32k>; - - buttons { - pwr_key: pwr-key { - rockchip,pins = <0 RK_PA6 0 &pcfg_pull_up>; - }; - }; - - usb { - usb_drv: usb-drv { - rockchip,pins = <0 RK_PC5 0 &pcfg_pull_none>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PA2 0 &pcfg_pull_none>; - }; - }; -}; - -&pwm0 { - status = "okay"; - pinctrl-0 = <&pwm0_pin_pull_down>; -}; - -&uart4 { - pinctrl-names = "default"; - pinctrl-0 = <&uart4_xfer>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3308-roc-cc.dts b/arch/arm/dts/rk3308-roc-cc.dts deleted file mode 100644 index 9232357f4fec..000000000000 --- a/arch/arm/dts/rk3308-roc-cc.dts +++ /dev/null @@ -1,190 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - */ - -/dts-v1/; -#include "rk3308.dtsi" - -/ { - model = "Firefly ROC-RK3308-CC board"; - compatible = "firefly,roc-rk3308-cc", "rockchip,rk3308"; - - aliases { - mmc0 = &sdmmc; - mmc1 = &emmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_recv_pin>; - }; - - ir_tx { - compatible = "pwm-ir-tx"; - pwms = <&pwm5 0 25000 0>; - }; - - leds { - compatible = "gpio-leds"; - - power_led: led-0 { - label = "firefly:red:power"; - linux,default-trigger = "ir-power-click"; - default-state = "on"; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - }; - - user_led: led-1 { - label = "firefly:blue:user"; - linux,default-trigger = "ir-user-click"; - default-state = "off"; - gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_HIGH>; - }; - }; - - typec_vcc5v: typec-vcc5v { - compatible = "regulator-fixed"; - regulator-name = "typec_vcc5v"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&typec_vcc5v>; - }; - - vcc_io: vcc-io { - compatible = "regulator-fixed"; - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc_sdmmc: vcc-sdmmc { - compatible = "regulator-gpio"; - regulator-name = "vcc_sdmmc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_HIGH>; - states = <1800000 0x0>, - <3300000 0x1>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc_sd: vcc-sd { - compatible = "regulator-fixed"; - gpio = <&gpio4 RK_PD6 GPIO_ACTIVE_LOW>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_io>; - }; - - vdd_core: vdd-core { - compatible = "pwm-regulator"; - pwms = <&pwm0 0 5000 1>; - regulator-name = "vdd_core"; - regulator-min-microvolt = <827000>; - regulator-max-microvolt = <1340000>; - regulator-settling-time-up-us = <250>; - regulator-always-on; - regulator-boot-on; - pwm-supply = <&vcc5v0_sys>; - }; - - vdd_log: vdd-log { - compatible = "regulator-fixed"; - regulator-name = "vdd_log"; - regulator-min-microvolt = <1050000>; - regulator-max-microvolt = <1050000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_core>; -}; - -&emmc { - cap-mmc-highspeed; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&i2c1 { - clock-frequency = <400000>; - status = "okay"; - - rtc: rtc@51 { - compatible = "nxp,pcf8563"; - reg = <0x51>; - #clock-cells = <0>; - }; -}; - -&pwm5 { - status = "okay"; - pinctrl-names = "active"; - pinctrl-0 = <&pwm5_pin_pull_down>; -}; - -&pinctrl { - pinctrl-names = "default"; - pinctrl-0 = <&rtc_32k>; - - ir-receiver { - ir_recv_pin: ir-recv-pin { - rockchip,pins = <0 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - pwr_key: pwr-key { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&pwm0 { - status = "okay"; - pinctrl-0 = <&pwm0_pin_pull_down>; -}; - -&sdmmc { - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <300>; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vcc_sdmmc>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3308-rock-pi-s.dts b/arch/arm/dts/rk3308-rock-pi-s.dts deleted file mode 100644 index b47fe02c33fb..000000000000 --- a/arch/arm/dts/rk3308-rock-pi-s.dts +++ /dev/null @@ -1,314 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Akash Gajjar akash@openedev.com - * Copyright (c) 2019 Jagan Teki jagan@openedev.com - */ - -/dts-v1/; -#include "rk3308.dtsi" - -/ { - model = "Radxa ROCK Pi S"; - compatible = "radxa,rockpis", "rockchip,rk3308"; - - aliases { - ethernet0 = &gmac; - mmc0 = &emmc; - mmc1 = &sdmmc; - }; - - chosen { - stdout-path = "serial0:1500000n8"; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&green_led_gio>, <&heartbeat_led_gpio>; - - green-led { - default-state = "on"; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - label = "rockpis:green:power"; - linux,default-trigger = "default-on"; - }; - - blue-led { - default-state = "on"; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - label = "rockpis:blue:user"; - linux,default-trigger = "heartbeat"; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - pinctrl-0 = <&wifi_enable_h>; - pinctrl-names = "default"; - reset-gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_LOW>; - }; - - vcc_1v8: vcc-1v8 { - compatible = "regulator-fixed"; - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_io>; - }; - - vcc_io: vcc-io { - compatible = "regulator-fixed"; - regulator-name = "vcc_io"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc_ddr: vcc-ddr { - compatible = "regulator-fixed"; - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_otg: vcc5v0-otg { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&otg_vbus_drv>; - regulator-name = "vcc5v0_otg"; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vdd_core: vdd-core { - compatible = "pwm-regulator"; - pwms = <&pwm0 0 5000 1>; - pwm-supply = <&vcc5v0_sys>; - regulator-name = "vdd_core"; - regulator-min-microvolt = <827000>; - regulator-max-microvolt = <1340000>; - regulator-settling-time-up-us = <250>; - regulator-always-on; - regulator-boot-on; - }; - - vdd_log: vdd-log { - compatible = "regulator-fixed"; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1050000>; - regulator-max-microvolt = <1050000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_core>; -}; - -&emmc { - bus-width = <4>; - cap-mmc-highspeed; - mmc-hs200-1_8v; - non-removable; - vmmc-supply = <&vcc_io>; - status = "okay"; -}; - -&gmac { - clock_in_out = "output"; - phy-supply = <&vcc_io>; - snps,reset-gpio = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 50000 50000>; - status = "okay"; -}; - -&gpio0 { - gpio-line-names = - /* GPIO0_A0 - A7 */ - "", "", "", "", "", "", "", "", - /* GPIO0_B0 - B7 */ - "", "", "", "header1-pin3 [GPIO0_B3]", - "header1-pin5 [GPIO0_B4]", "", "", - "header1-pin11 [GPIO0_B7]", - /* GPIO0_C0 - C7 */ - "header1-pin13 [GPIO0_C0]", - "header1-pin15 [GPIO0_C1]", "", "", "", - "", "", "", - /* GPIO0_D0 - D7 */ - "", "", "", "", "", "", "", ""; -}; - -&gpio1 { - gpio-line-names = - /* GPIO1_A0 - A7 */ - "", "", "", "", "", "", "", "", - /* GPIO1_B0 - B7 */ - "", "", "", "", "", "", "", "", - /* GPIO1_C0 - C7 */ - "", "", "", "", "", "", "header1-pin21 [GPIO1_C6]", - "header1-pin19 [GPIO1_C7]", - /* GPIO1_D0 - D7 */ - "header1-pin23 [GPIO1_D0]", "header1-pin24 [GPIO1_D1]", - "", "", "", "", "", ""; -}; - -&gpio2 { - gpio-line-names = - /* GPIO2_A0 - A7 */ - "header1-pin10 [GPIO2_A0]", "header1-pin8 [GPIO2_A1]", - "", "", - "header1-pin7 [GPIO2_A4]", "header1-pin12 [GPIO2_A5]", - "header2-pin46 [GPIO2_A6]", "header1-pin22 [GPIO1_A7]", - /* GPIO2_B0 - B7 */ - "header2-pin45 [GPIO2_B0]", "header1-pin18 [GPIO2_B1]", - "header1-pin16 [GPIO2_B2]", "header2-pin44 [GPIO2_B3]", - "header2-pin43 [GPIO2_B4]", "header2-pin28 [GPIO2_B5]", - "header2-pin30 [GPIO2_B6]", "header2-pin32 [GPIO2_B7]", - /* GPIO2_C0 - C7 */ - "header2-pin34 [GPIO2_C0]", "", "", "", "", "", "", "", - /* GPIO2_D0 - D7 */ - "", "", "", "", "", "", "", ""; -}; - -&gpio3 { - gpio-line-names = - /* GPIO3_A0 - A7 */ - "", "", "", "", "", "", "", "", - /* GPIO3_B0 - B7 */ - "", "", "header2-pin42 [GPIO3_B2]", - "header2-pin41 [GPIO3_B3]", "header2-pin40 [GPIO3_B4]", - "header2-pin39 [GPIO3_B5]", "", "", - /* GPIO3_C0 - C7 */ - "", "", "", "", "", "", "", "", - /* GPIO3_D0 - D7 */ - "", "", "", "", "", "", "", ""; -}; - -&i2c1 { - status = "okay"; -}; - -&pinctrl { - pinctrl-names = "default"; - pinctrl-0 = <&rtc_32k>; - - leds { - green_led_gio: green-led-gpio { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - heartbeat_led_gpio: heartbeat-led-gpio { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - otg_vbus_drv: otg-vbus-drv { - rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wifi_host_wake: wifi-host-wake { - rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; -}; - -&pwm0 { - status = "okay"; - pinctrl-0 = <&pwm0_pin_pull_down>; -}; - -&saradc { - vref-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdio { - #address-cells = <1>; - #size-cells = <0>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - max-frequency = <1000000>; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdmmc { - cap-sd-highspeed; - status = "okay"; -}; - -&u2phy { - status = "okay"; - - u2phy_host: host-port { - phy-supply = <&vcc5v0_otg>; - status = "okay"; - }; - - u2phy_otg: otg-port { - phy-supply = <&vcc5v0_otg>; - status = "okay"; - }; -}; - -&uart0 { - status = "okay"; -}; - -&uart4 { - status = "okay"; - - bluetooth { - compatible = "realtek,rtl8723bs-bt"; - device-wake-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_HIGH>; - host-wake-gpios = <&gpio4 RK_PB4 GPIO_ACTIVE_HIGH>; - }; -}; - -&usb_host_ehci { - status = "okay"; -}; - -&usb_host_ohci { - status = "okay"; -}; - -&usb20_otg { - dr_mode = "peripheral"; - status = "okay"; -}; - -&wdt { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3308.dtsi b/arch/arm/dts/rk3308.dtsi deleted file mode 100644 index cfc0a87b5195..000000000000 --- a/arch/arm/dts/rk3308.dtsi +++ /dev/null @@ -1,1888 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * - */ - -#include <dt-bindings/clock/rk3308-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - compatible = "rockchip,rk3308"; - - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; - gpio4 = &gpio4; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; - serial4 = &uart4; - spi0 = &spi0; - spi1 = &spi1; - spi2 = &spi2; - }; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a35"; - reg = <0x0 0x0>; - enable-method = "psci"; - clocks = <&cru ARMCLK>; - #cooling-cells = <2>; - dynamic-power-coefficient = <90>; - operating-points-v2 = <&cpu0_opp_table>; - cpu-idle-states = <&CPU_SLEEP>; - next-level-cache = <&l2>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a35"; - reg = <0x0 0x1>; - enable-method = "psci"; - operating-points-v2 = <&cpu0_opp_table>; - cpu-idle-states = <&CPU_SLEEP>; - next-level-cache = <&l2>; - }; - - cpu2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a35"; - reg = <0x0 0x2>; - enable-method = "psci"; - operating-points-v2 = <&cpu0_opp_table>; - cpu-idle-states = <&CPU_SLEEP>; - next-level-cache = <&l2>; - }; - - cpu3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a35"; - reg = <0x0 0x3>; - enable-method = "psci"; - operating-points-v2 = <&cpu0_opp_table>; - cpu-idle-states = <&CPU_SLEEP>; - next-level-cache = <&l2>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP: cpu-sleep { - compatible = "arm,idle-state"; - local-timer-stop; - arm,psci-suspend-param = <0x0010000>; - entry-latency-us = <120>; - exit-latency-us = <250>; - min-residency-us = <900>; - }; - }; - - l2: l2-cache { - compatible = "cache"; - cache-level = <2>; - cache-unified; - }; - }; - - cpu0_opp_table: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-408000000 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <950000 950000 1340000>; - clock-latency-ns = <40000>; - opp-suspend; - }; - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <950000 950000 1340000>; - clock-latency-ns = <40000>; - }; - opp-816000000 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <1025000 1025000 1340000>; - clock-latency-ns = <40000>; - }; - opp-1008000000 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <1125000 1125000 1340000>; - clock-latency-ns = <40000>; - }; - }; - - arm-pmu { - compatible = "arm,cortex-a35-pmu"; - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - mac_clkin: external-mac-clock { - compatible = "fixed-clock"; - clock-frequency = <50000000>; - clock-output-names = "mac_clkin"; - #clock-cells = <0>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - }; - - xin24m: xin24m { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - clock-output-names = "xin24m"; - }; - - grf: grf@ff000000 { - compatible = "rockchip,rk3308-grf", "syscon", "simple-mfd"; - reg = <0x0 0xff000000 0x0 0x08000>; - - reboot-mode { - compatible = "syscon-reboot-mode"; - offset = <0x500>; - mode-bootloader = <BOOT_BL_DOWNLOAD>; - mode-loader = <BOOT_BL_DOWNLOAD>; - mode-normal = <BOOT_NORMAL>; - mode-recovery = <BOOT_RECOVERY>; - mode-fastboot = <BOOT_FASTBOOT>; - }; - }; - - usb2phy_grf: syscon@ff008000 { - compatible = "rockchip,rk3308-usb2phy-grf", "syscon", "simple-mfd"; - reg = <0x0 0xff008000 0x0 0x4000>; - #address-cells = <1>; - #size-cells = <1>; - - u2phy: usb2phy@100 { - compatible = "rockchip,rk3308-usb2phy"; - reg = <0x100 0x10>; - assigned-clocks = <&cru USB480M>; - assigned-clock-parents = <&u2phy>; - clocks = <&cru SCLK_USBPHY_REF>; - clock-names = "phyclk"; - clock-output-names = "usb480m_phy"; - #clock-cells = <0>; - status = "disabled"; - - u2phy_otg: otg-port { - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "otg-bvalid", "otg-id", - "linestate"; - #phy-cells = <0>; - status = "disabled"; - }; - - u2phy_host: host-port { - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "linestate"; - #phy-cells = <0>; - status = "disabled"; - }; - }; - }; - - detect_grf: syscon@ff00b000 { - compatible = "rockchip,rk3308-detect-grf", "syscon", "simple-mfd"; - reg = <0x0 0xff00b000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - }; - - core_grf: syscon@ff00c000 { - compatible = "rockchip,rk3308-core-grf", "syscon", "simple-mfd"; - reg = <0x0 0xff00c000 0x0 0x1000>; - #address-cells = <1>; - #size-cells = <1>; - }; - - i2c0: i2c@ff040000 { - compatible = "rockchip,rk3308-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff040000 0x0 0x1000>; - clocks = <&cru SCLK_I2C0>, <&cru PCLK_I2C0>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c1: i2c@ff050000 { - compatible = "rockchip,rk3308-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff050000 0x0 0x1000>; - clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@ff060000 { - compatible = "rockchip,rk3308-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff060000 0x0 0x1000>; - clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@ff070000 { - compatible = "rockchip,rk3308-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff070000 0x0 0x1000>; - clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c3m0_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - wdt: watchdog@ff080000 { - compatible = "rockchip,rk3308-wdt", "snps,dw-wdt"; - reg = <0x0 0xff080000 0x0 0x100>; - clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>; - status = "disabled"; - }; - - uart0: serial@ff0a0000 { - compatible = "rockchip,rk3308-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff0a0000 0x0 0x100>; - interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; - clock-names = "baudclk", "apb_pclk"; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "disabled"; - }; - - uart1: serial@ff0b0000 { - compatible = "rockchip,rk3308-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff0b0000 0x0 0x100>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; - clock-names = "baudclk", "apb_pclk"; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart1_xfer &uart1_cts &uart1_rts>; - status = "disabled"; - }; - - uart2: serial@ff0c0000 { - compatible = "rockchip,rk3308-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff0c0000 0x0 0x100>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; - clock-names = "baudclk", "apb_pclk"; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart2m0_xfer>; - status = "disabled"; - }; - - uart3: serial@ff0d0000 { - compatible = "rockchip,rk3308-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff0d0000 0x0 0x100>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; - clock-names = "baudclk", "apb_pclk"; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart3_xfer>; - status = "disabled"; - }; - - uart4: serial@ff0e0000 { - compatible = "rockchip,rk3308-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff0e0000 0x0 0x100>; - interrupts = <GIC_SPI 22 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; - clock-names = "baudclk", "apb_pclk"; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart4_xfer &uart4_cts &uart4_rts>; - status = "disabled"; - }; - - spi0: spi@ff120000 { - compatible = "rockchip,rk3308-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff120000 0x0 0x1000>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac0 0>, <&dmac0 1>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi0_clk &spi0_csn0 &spi0_miso &spi0_mosi>; - status = "disabled"; - }; - - spi1: spi@ff130000 { - compatible = "rockchip,rk3308-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff130000 0x0 0x1000>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac0 2>, <&dmac0 3>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi1_clk &spi1_csn0 &spi1_miso &spi1_mosi>; - status = "disabled"; - }; - - spi2: spi@ff140000 { - compatible = "rockchip,rk3308-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff140000 0x0 0x1000>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac1 16>, <&dmac1 17>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi2_clk &spi2_csn0 &spi2_miso &spi2_mosi>; - status = "disabled"; - }; - - pwm8: pwm@ff160000 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff160000 0x0 0x10>; - clocks = <&cru SCLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm8_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm9: pwm@ff160010 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff160010 0x0 0x10>; - clocks = <&cru SCLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm9_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm10: pwm@ff160020 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff160020 0x0 0x10>; - clocks = <&cru SCLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm10_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm11: pwm@ff160030 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff160030 0x0 0x10>; - clocks = <&cru SCLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm11_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm4: pwm@ff170000 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff170000 0x0 0x10>; - clocks = <&cru SCLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm4_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm5: pwm@ff170010 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff170010 0x0 0x10>; - clocks = <&cru SCLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm5_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm6: pwm@ff170020 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff170020 0x0 0x10>; - clocks = <&cru SCLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm6_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm7: pwm@ff170030 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff170030 0x0 0x10>; - clocks = <&cru SCLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm7_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm0: pwm@ff180000 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff180000 0x0 0x10>; - clocks = <&cru SCLK_PWM0>, <&cru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm1: pwm@ff180010 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff180010 0x0 0x10>; - clocks = <&cru SCLK_PWM0>, <&cru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm1_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm2: pwm@ff180020 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff180020 0x0 0x10>; - clocks = <&cru SCLK_PWM0>, <&cru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm2_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm3: pwm@ff180030 { - compatible = "rockchip,rk3308-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xff180030 0x0 0x10>; - clocks = <&cru SCLK_PWM0>, <&cru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm3_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - rktimer: rktimer@ff1a0000 { - compatible = "rockchip,rk3288-timer"; - reg = <0x0 0xff1a0000 0x0 0x20>; - interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_TIMER>, <&cru SCLK_TIMER0>; - clock-names = "pclk", "timer"; - }; - - saradc: saradc@ff1e0000 { - compatible = "rockchip,rk3308-saradc", "rockchip,rk3399-saradc"; - reg = <0x0 0xff1e0000 0x0 0x100>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; - clock-names = "saradc", "apb_pclk"; - #io-channel-cells = <1>; - resets = <&cru SRST_SARADC_P>; - reset-names = "saradc-apb"; - status = "disabled"; - }; - - dmac0: dma-controller@ff2c0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff2c0000 0x0 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC0>; - clock-names = "apb_pclk"; - #dma-cells = <1>; - }; - - dmac1: dma-controller@ff2d0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff2d0000 0x0 0x4000>; - interrupts = <GIC_SPI 2 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 3 IRQ_TYPE_LEVEL_HIGH>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC1>; - clock-names = "apb_pclk"; - #dma-cells = <1>; - }; - - i2s_2ch_0: i2s@ff350000 { - compatible = "rockchip,rk3308-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff350000 0x0 0x1000>; - interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_I2S0_2CH>, <&cru HCLK_I2S0_2CH>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac1 8>, <&dmac1 9>; - dma-names = "tx", "rx"; - resets = <&cru SRST_I2S0_2CH_M>, <&cru SRST_I2S0_2CH_H>; - reset-names = "reset-m", "reset-h"; - pinctrl-names = "default"; - pinctrl-0 = <&i2s_2ch_0_sclk - &i2s_2ch_0_lrck - &i2s_2ch_0_sdi - &i2s_2ch_0_sdo>; - status = "disabled"; - }; - - i2s_2ch_1: i2s@ff360000 { - compatible = "rockchip,rk3308-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff360000 0x0 0x1000>; - interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_I2S1_2CH>, <&cru HCLK_I2S1_2CH>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac1 11>; - dma-names = "rx"; - resets = <&cru SRST_I2S1_2CH_M>, <&cru SRST_I2S1_2CH_H>; - reset-names = "reset-m", "reset-h"; - status = "disabled"; - }; - - spdif_tx: spdif-tx@ff3a0000 { - compatible = "rockchip,rk3308-spdif", "rockchip,rk3066-spdif"; - reg = <0x0 0xff3a0000 0x0 0x1000>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_SPDIF_TX>, <&cru HCLK_SPDIFTX>; - clock-names = "mclk", "hclk"; - dmas = <&dmac1 13>; - dma-names = "tx"; - pinctrl-names = "default"; - pinctrl-0 = <&spdif_out>; - status = "disabled"; - }; - - usb20_otg: usb@ff400000 { - compatible = "rockchip,rk3308-usb", "rockchip,rk3066-usb", - "snps,dwc2"; - reg = <0x0 0xff400000 0x0 0x40000>; - interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_OTG>; - clock-names = "otg"; - dr_mode = "otg"; - g-np-tx-fifo-size = <16>; - g-rx-fifo-size = <280>; - g-tx-fifo-size = <256 128 128 64 32 16>; - phys = <&u2phy_otg>; - phy-names = "usb2-phy"; - status = "disabled"; - }; - - usb_host_ehci: usb@ff440000 { - compatible = "generic-ehci"; - reg = <0x0 0xff440000 0x0 0x10000>; - interrupts = <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST>, <&cru HCLK_HOST_ARB>, <&u2phy>; - phys = <&u2phy_host>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host_ohci: usb@ff450000 { - compatible = "generic-ohci"; - reg = <0x0 0xff450000 0x0 0x10000>; - interrupts = <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST>, <&cru HCLK_HOST_ARB>, <&u2phy>; - phys = <&u2phy_host>; - phy-names = "usb"; - status = "disabled"; - }; - - sdmmc: mmc@ff480000 { - compatible = "rockchip,rk3308-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xff480000 0x0 0x4000>; - interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; - bus-width = <4>; - clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, - <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_det &sdmmc_bus4>; - status = "disabled"; - }; - - emmc: mmc@ff490000 { - compatible = "rockchip,rk3308-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xff490000 0x0 0x4000>; - interrupts = <GIC_SPI 77 IRQ_TYPE_LEVEL_HIGH>; - bus-width = <8>; - clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, - <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - status = "disabled"; - }; - - sdio: mmc@ff4a0000 { - compatible = "rockchip,rk3308-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xff4a0000 0x0 0x4000>; - interrupts = <GIC_SPI 78 IRQ_TYPE_LEVEL_HIGH>; - bus-width = <4>; - clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, - <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdio_bus4 &sdio_cmd &sdio_clk>; - status = "disabled"; - }; - - nfc: nand-controller@ff4b0000 { - compatible = "rockchip,rk3308-nfc", - "rockchip,rv1108-nfc"; - reg = <0x0 0xff4b0000 0x0 0x4000>; - interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_NANDC>, <&cru SCLK_NANDC>; - clock-names = "ahb", "nfc"; - assigned-clocks = <&cru SCLK_NANDC>; - assigned-clock-rates = <150000000>; - pinctrl-0 = <&flash_ale &flash_bus8 &flash_cle &flash_csn0 - &flash_rdn &flash_rdy &flash_wrn>; - pinctrl-names = "default"; - status = "disabled"; - }; - - gmac: ethernet@ff4e0000 { - compatible = "rockchip,rk3308-gmac"; - reg = <0x0 0xff4e0000 0x0 0x10000>; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; - clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX_TX>, - <&cru SCLK_MAC_RX_TX>, <&cru SCLK_MAC_REF>, - <&cru SCLK_MAC>, <&cru ACLK_MAC>, - <&cru PCLK_MAC>, <&cru SCLK_MAC_RMII>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_ref", - "clk_mac_refout", "aclk_mac", - "pclk_mac", "clk_mac_speed"; - phy-mode = "rmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rmii_pins &mac_refclk_12ma>; - resets = <&cru SRST_MAC_A>; - reset-names = "stmmaceth"; - rockchip,grf = <&grf>; - status = "disabled"; - }; - - sfc: spi@ff4c0000 { - compatible = "rockchip,sfc"; - reg = <0x0 0xff4c0000 0x0 0x4000>; - interrupts = <GIC_SPI 82 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_SFC>, <&cru HCLK_SFC>; - clock-names = "clk_sfc", "hclk_sfc"; - pinctrl-0 = <&sfc_clk &sfc_cs0 &sfc_bus4>; - pinctrl-names = "default"; - status = "disabled"; - }; - - cru: clock-controller@ff500000 { - compatible = "rockchip,rk3308-cru"; - reg = <0x0 0xff500000 0x0 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - assigned-clocks = <&cru SCLK_RTC32K>; - assigned-clock-rates = <32768>; - }; - - gic: interrupt-controller@ff580000 { - compatible = "arm,gic-400"; - reg = <0x0 0xff581000 0x0 0x1000>, - <0x0 0xff582000 0x0 0x2000>, - <0x0 0xff584000 0x0 0x2000>, - <0x0 0xff586000 0x0 0x2000>; - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - #interrupt-cells = <3>; - interrupt-controller; - #address-cells = <0>; - }; - - sram: sram@fff80000 { - compatible = "mmio-sram"; - reg = <0x0 0xfff80000 0x0 0x40000>; - ranges = <0 0x0 0xfff80000 0x40000>; - #address-cells = <1>; - #size-cells = <1>; - - /* reserved for ddr dvfs and system suspend/resume */ - ddr-sram@0 { - reg = <0x0 0x8000>; - }; - - /* reserved for vad audio buffer */ - vad_sram: vad-sram@8000 { - reg = <0x8000 0x38000>; - }; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rk3308-pinctrl"; - rockchip,grf = <&grf>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio0: gpio@ff220000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff220000 0x0 0x100>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO0>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@ff230000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff230000 0x0 0x100>; - interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO1>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@ff240000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff240000 0x0 0x100>; - interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO2>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@ff250000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff250000 0x0 0x100>; - interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO3>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@ff260000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff260000 0x0 0x100>; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO4>; - gpio-controller; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - pcfg_pull_up: pcfg-pull-up { - bias-pull-up; - }; - - pcfg_pull_down: pcfg-pull-down { - bias-pull-down; - }; - - pcfg_pull_none: pcfg-pull-none { - bias-disable; - }; - - pcfg_pull_none_2ma: pcfg-pull-none-2ma { - bias-disable; - drive-strength = <2>; - }; - - pcfg_pull_up_2ma: pcfg-pull-up-2ma { - bias-pull-up; - drive-strength = <2>; - }; - - pcfg_pull_up_4ma: pcfg-pull-up-4ma { - bias-pull-up; - drive-strength = <4>; - }; - - pcfg_pull_none_4ma: pcfg-pull-none-4ma { - bias-disable; - drive-strength = <4>; - }; - - pcfg_pull_down_4ma: pcfg-pull-down-4ma { - bias-pull-down; - drive-strength = <4>; - }; - - pcfg_pull_none_8ma: pcfg-pull-none-8ma { - bias-disable; - drive-strength = <8>; - }; - - pcfg_pull_up_8ma: pcfg-pull-up-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - pcfg_pull_none_12ma: pcfg-pull-none-12ma { - bias-disable; - drive-strength = <12>; - }; - - pcfg_pull_up_12ma: pcfg-pull-up-12ma { - bias-pull-up; - drive-strength = <12>; - }; - - pcfg_pull_none_smt: pcfg-pull-none-smt { - bias-disable; - input-schmitt-enable; - }; - - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_input_high: pcfg-input-high { - bias-pull-up; - input-enable; - }; - - pcfg_input: pcfg-input { - input-enable; - }; - - emmc { - emmc_clk: emmc-clk { - rockchip,pins = - <3 RK_PB1 2 &pcfg_pull_none_8ma>; - }; - - emmc_cmd: emmc-cmd { - rockchip,pins = - <3 RK_PB0 2 &pcfg_pull_up_8ma>; - }; - - emmc_pwren: emmc-pwren { - rockchip,pins = - <3 RK_PB3 2 &pcfg_pull_none>; - }; - - emmc_rstn: emmc-rstn { - rockchip,pins = - <3 RK_PB2 2 &pcfg_pull_none>; - }; - - emmc_bus1: emmc-bus1 { - rockchip,pins = - <3 RK_PA0 2 &pcfg_pull_up_8ma>; - }; - - emmc_bus4: emmc-bus4 { - rockchip,pins = - <3 RK_PA0 2 &pcfg_pull_up_8ma>, - <3 RK_PA1 2 &pcfg_pull_up_8ma>, - <3 RK_PA2 2 &pcfg_pull_up_8ma>, - <3 RK_PA3 2 &pcfg_pull_up_8ma>; - }; - - emmc_bus8: emmc-bus8 { - rockchip,pins = - <3 RK_PA0 2 &pcfg_pull_up_8ma>, - <3 RK_PA1 2 &pcfg_pull_up_8ma>, - <3 RK_PA2 2 &pcfg_pull_up_8ma>, - <3 RK_PA3 2 &pcfg_pull_up_8ma>, - <3 RK_PA4 2 &pcfg_pull_up_8ma>, - <3 RK_PA5 2 &pcfg_pull_up_8ma>, - <3 RK_PA6 2 &pcfg_pull_up_8ma>, - <3 RK_PA7 2 &pcfg_pull_up_8ma>; - }; - }; - - flash { - flash_csn0: flash-csn0 { - rockchip,pins = - <3 RK_PB5 1 &pcfg_pull_none>; - }; - - flash_rdy: flash-rdy { - rockchip,pins = - <3 RK_PB4 1 &pcfg_pull_none>; - }; - - flash_ale: flash-ale { - rockchip,pins = - <3 RK_PB3 1 &pcfg_pull_none>; - }; - - flash_cle: flash-cle { - rockchip,pins = - <3 RK_PB1 1 &pcfg_pull_none>; - }; - - flash_wrn: flash-wrn { - rockchip,pins = - <3 RK_PB0 1 &pcfg_pull_none>; - }; - - flash_rdn: flash-rdn { - rockchip,pins = - <3 RK_PB2 1 &pcfg_pull_none>; - }; - - flash_bus8: flash-bus8 { - rockchip,pins = - <3 RK_PA0 1 &pcfg_pull_up_12ma>, - <3 RK_PA1 1 &pcfg_pull_up_12ma>, - <3 RK_PA2 1 &pcfg_pull_up_12ma>, - <3 RK_PA3 1 &pcfg_pull_up_12ma>, - <3 RK_PA4 1 &pcfg_pull_up_12ma>, - <3 RK_PA5 1 &pcfg_pull_up_12ma>, - <3 RK_PA6 1 &pcfg_pull_up_12ma>, - <3 RK_PA7 1 &pcfg_pull_up_12ma>; - }; - }; - - sfc { - sfc_bus4: sfc-bus4 { - rockchip,pins = - <3 RK_PA0 3 &pcfg_pull_none>, - <3 RK_PA1 3 &pcfg_pull_none>, - <3 RK_PA2 3 &pcfg_pull_none>, - <3 RK_PA3 3 &pcfg_pull_none>; - }; - - sfc_bus2: sfc-bus2 { - rockchip,pins = - <3 RK_PA0 3 &pcfg_pull_none>, - <3 RK_PA1 3 &pcfg_pull_none>; - }; - - sfc_cs0: sfc-cs0 { - rockchip,pins = - <3 RK_PA4 3 &pcfg_pull_none>; - }; - - sfc_clk: sfc-clk { - rockchip,pins = - <3 RK_PA5 3 &pcfg_pull_none>; - }; - }; - - gmac { - rmii_pins: rmii-pins { - rockchip,pins = - /* mac_txen */ - <1 RK_PC1 3 &pcfg_pull_none_12ma>, - /* mac_txd1 */ - <1 RK_PC3 3 &pcfg_pull_none_12ma>, - /* mac_txd0 */ - <1 RK_PC2 3 &pcfg_pull_none_12ma>, - /* mac_rxd0 */ - <1 RK_PC4 3 &pcfg_pull_none>, - /* mac_rxd1 */ - <1 RK_PC5 3 &pcfg_pull_none>, - /* mac_rxer */ - <1 RK_PB7 3 &pcfg_pull_none>, - /* mac_rxdv */ - <1 RK_PC0 3 &pcfg_pull_none>, - /* mac_mdio */ - <1 RK_PB6 3 &pcfg_pull_none>, - /* mac_mdc */ - <1 RK_PB5 3 &pcfg_pull_none>; - }; - - mac_refclk_12ma: mac-refclk-12ma { - rockchip,pins = - <1 RK_PB4 3 &pcfg_pull_none_12ma>; - }; - - mac_refclk: mac-refclk { - rockchip,pins = - <1 RK_PB4 3 &pcfg_pull_none>; - }; - }; - - gmac-m1 { - rmiim1_pins: rmiim1-pins { - rockchip,pins = - /* mac_txen */ - <4 RK_PB7 2 &pcfg_pull_none_12ma>, - /* mac_txd1 */ - <4 RK_PA5 2 &pcfg_pull_none_12ma>, - /* mac_txd0 */ - <4 RK_PA4 2 &pcfg_pull_none_12ma>, - /* mac_rxd0 */ - <4 RK_PA2 2 &pcfg_pull_none>, - /* mac_rxd1 */ - <4 RK_PA3 2 &pcfg_pull_none>, - /* mac_rxer */ - <4 RK_PA0 2 &pcfg_pull_none>, - /* mac_rxdv */ - <4 RK_PA1 2 &pcfg_pull_none>, - /* mac_mdio */ - <4 RK_PB6 2 &pcfg_pull_none>, - /* mac_mdc */ - <4 RK_PB5 2 &pcfg_pull_none>; - }; - - macm1_refclk_12ma: macm1-refclk-12ma { - rockchip,pins = - <4 RK_PB4 2 &pcfg_pull_none_12ma>; - }; - - macm1_refclk: macm1-refclk { - rockchip,pins = - <4 RK_PB4 2 &pcfg_pull_none>; - }; - }; - - i2c0 { - i2c0_xfer: i2c0-xfer { - rockchip,pins = - <1 RK_PD0 2 &pcfg_pull_none_smt>, - <1 RK_PD1 2 &pcfg_pull_none_smt>; - }; - }; - - i2c1 { - i2c1_xfer: i2c1-xfer { - rockchip,pins = - <0 RK_PB3 1 &pcfg_pull_none_smt>, - <0 RK_PB4 1 &pcfg_pull_none_smt>; - }; - }; - - i2c2 { - i2c2_xfer: i2c2-xfer { - rockchip,pins = - <2 RK_PA2 3 &pcfg_pull_none_smt>, - <2 RK_PA3 3 &pcfg_pull_none_smt>; - }; - }; - - i2c3-m0 { - i2c3m0_xfer: i2c3m0-xfer { - rockchip,pins = - <0 RK_PB7 2 &pcfg_pull_none_smt>, - <0 RK_PC0 2 &pcfg_pull_none_smt>; - }; - }; - - i2c3-m1 { - i2c3m1_xfer: i2c3m1-xfer { - rockchip,pins = - <3 RK_PB4 2 &pcfg_pull_none_smt>, - <3 RK_PB5 2 &pcfg_pull_none_smt>; - }; - }; - - i2c3-m2 { - i2c3m2_xfer: i2c3m2-xfer { - rockchip,pins = - <2 RK_PA1 3 &pcfg_pull_none_smt>, - <2 RK_PA0 3 &pcfg_pull_none_smt>; - }; - }; - - i2s_2ch_0 { - i2s_2ch_0_mclk: i2s-2ch-0-mclk { - rockchip,pins = - <4 RK_PB4 1 &pcfg_pull_none>; - }; - - i2s_2ch_0_sclk: i2s-2ch-0-sclk { - rockchip,pins = - <4 RK_PB5 1 &pcfg_pull_none>; - }; - - i2s_2ch_0_lrck: i2s-2ch-0-lrck { - rockchip,pins = - <4 RK_PB6 1 &pcfg_pull_none>; - }; - - i2s_2ch_0_sdo: i2s-2ch-0-sdo { - rockchip,pins = - <4 RK_PB7 1 &pcfg_pull_none>; - }; - - i2s_2ch_0_sdi: i2s-2ch-0-sdi { - rockchip,pins = - <4 RK_PC0 1 &pcfg_pull_none>; - }; - }; - - i2s_8ch_0 { - i2s_8ch_0_mclk: i2s-8ch-0-mclk { - rockchip,pins = - <2 RK_PA4 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sclktx: i2s-8ch-0-sclktx { - rockchip,pins = - <2 RK_PA5 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sclkrx: i2s-8ch-0-sclkrx { - rockchip,pins = - <2 RK_PA6 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_lrcktx: i2s-8ch-0-lrcktx { - rockchip,pins = - <2 RK_PA7 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_lrckrx: i2s-8ch-0-lrckrx { - rockchip,pins = - <2 RK_PB0 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdo0: i2s-8ch-0-sdo0 { - rockchip,pins = - <2 RK_PB1 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdo1: i2s-8ch-0-sdo1 { - rockchip,pins = - <2 RK_PB2 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdo2: i2s-8ch-0-sdo2 { - rockchip,pins = - <2 RK_PB3 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdo3: i2s-8ch-0-sdo3 { - rockchip,pins = - <2 RK_PB4 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdi0: i2s-8ch-0-sdi0 { - rockchip,pins = - <2 RK_PB5 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdi1: i2s-8ch-0-sdi1 { - rockchip,pins = - <2 RK_PB6 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdi2: i2s-8ch-0-sdi2 { - rockchip,pins = - <2 RK_PB7 1 &pcfg_pull_none>; - }; - - i2s_8ch_0_sdi3: i2s-8ch-0-sdi3 { - rockchip,pins = - <2 RK_PC0 1 &pcfg_pull_none>; - }; - }; - - i2s_8ch_1_m0 { - i2s_8ch_1_m0_mclk: i2s-8ch-1-m0-mclk { - rockchip,pins = - <1 RK_PA2 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_sclktx: i2s-8ch-1-m0-sclktx { - rockchip,pins = - <1 RK_PA3 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_sclkrx: i2s-8ch-1-m0-sclkrx { - rockchip,pins = - <1 RK_PA4 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_lrcktx: i2s-8ch-1-m0-lrcktx { - rockchip,pins = - <1 RK_PA5 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_lrckrx: i2s-8ch-1-m0-lrckrx { - rockchip,pins = - <1 RK_PA6 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_sdo0: i2s-8ch-1-m0-sdo0 { - rockchip,pins = - <1 RK_PA7 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_sdo1_sdi3: i2s-8ch-1-m0-sdo1-sdi3 { - rockchip,pins = - <1 RK_PB0 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_sdo2_sdi2: i2s-8ch-1-m0-sdo2-sdi2 { - rockchip,pins = - <1 RK_PB1 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_sdo3_sdi1: i2s-8ch-1-m0-sdo3_sdi1 { - rockchip,pins = - <1 RK_PB2 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m0_sdi0: i2s-8ch-1-m0-sdi0 { - rockchip,pins = - <1 RK_PB3 2 &pcfg_pull_none>; - }; - }; - - i2s_8ch_1_m1 { - i2s_8ch_1_m1_mclk: i2s-8ch-1-m1-mclk { - rockchip,pins = - <1 RK_PB4 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_sclktx: i2s-8ch-1-m1-sclktx { - rockchip,pins = - <1 RK_PB5 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_sclkrx: i2s-8ch-1-m1-sclkrx { - rockchip,pins = - <1 RK_PB6 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_lrcktx: i2s-8ch-1-m1-lrcktx { - rockchip,pins = - <1 RK_PB7 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_lrckrx: i2s-8ch-1-m1-lrckrx { - rockchip,pins = - <1 RK_PC0 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_sdo0: i2s-8ch-1-m1-sdo0 { - rockchip,pins = - <1 RK_PC1 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_sdo1_sdi3: i2s-8ch-1-m1-sdo1-sdi3 { - rockchip,pins = - <1 RK_PC2 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_sdo2_sdi2: i2s-8ch-1-m1-sdo2-sdi2 { - rockchip,pins = - <1 RK_PC3 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_sdo3_sdi1: i2s-8ch-1-m1-sdo3_sdi1 { - rockchip,pins = - <1 RK_PC4 2 &pcfg_pull_none>; - }; - - i2s_8ch_1_m1_sdi0: i2s-8ch-1-m1-sdi0 { - rockchip,pins = - <1 RK_PC5 2 &pcfg_pull_none>; - }; - }; - - pdm_m0 { - pdm_m0_clk: pdm-m0-clk { - rockchip,pins = - <1 RK_PA4 3 &pcfg_pull_none>; - }; - - pdm_m0_sdi0: pdm-m0-sdi0 { - rockchip,pins = - <1 RK_PB3 3 &pcfg_pull_none>; - }; - - pdm_m0_sdi1: pdm-m0-sdi1 { - rockchip,pins = - <1 RK_PB2 3 &pcfg_pull_none>; - }; - - pdm_m0_sdi2: pdm-m0-sdi2 { - rockchip,pins = - <1 RK_PB1 3 &pcfg_pull_none>; - }; - - pdm_m0_sdi3: pdm-m0-sdi3 { - rockchip,pins = - <1 RK_PB0 3 &pcfg_pull_none>; - }; - }; - - pdm_m1 { - pdm_m1_clk: pdm-m1-clk { - rockchip,pins = - <1 RK_PB6 4 &pcfg_pull_none>; - }; - - pdm_m1_sdi0: pdm-m1-sdi0 { - rockchip,pins = - <1 RK_PC5 4 &pcfg_pull_none>; - }; - - pdm_m1_sdi1: pdm-m1-sdi1 { - rockchip,pins = - <1 RK_PC4 4 &pcfg_pull_none>; - }; - - pdm_m1_sdi2: pdm-m1-sdi2 { - rockchip,pins = - <1 RK_PC3 4 &pcfg_pull_none>; - }; - - pdm_m1_sdi3: pdm-m1-sdi3 { - rockchip,pins = - <1 RK_PC2 4 &pcfg_pull_none>; - }; - }; - - pdm_m2 { - pdm_m2_clkm: pdm-m2-clkm { - rockchip,pins = - <2 RK_PA4 3 &pcfg_pull_none>; - }; - - pdm_m2_clk: pdm-m2-clk { - rockchip,pins = - <2 RK_PA6 2 &pcfg_pull_none>; - }; - - pdm_m2_sdi0: pdm-m2-sdi0 { - rockchip,pins = - <2 RK_PB5 2 &pcfg_pull_none>; - }; - - pdm_m2_sdi1: pdm-m2-sdi1 { - rockchip,pins = - <2 RK_PB6 2 &pcfg_pull_none>; - }; - - pdm_m2_sdi2: pdm-m2-sdi2 { - rockchip,pins = - <2 RK_PB7 2 &pcfg_pull_none>; - }; - - pdm_m2_sdi3: pdm-m2-sdi3 { - rockchip,pins = - <2 RK_PC0 2 &pcfg_pull_none>; - }; - }; - - pwm0 { - pwm0_pin: pwm0-pin { - rockchip,pins = - <0 RK_PB5 1 &pcfg_pull_none>; - }; - - pwm0_pin_pull_down: pwm0-pin-pull-down { - rockchip,pins = - <0 RK_PB5 1 &pcfg_pull_down>; - }; - }; - - pwm1 { - pwm1_pin: pwm1-pin { - rockchip,pins = - <0 RK_PB6 1 &pcfg_pull_none>; - }; - - pwm1_pin_pull_down: pwm1-pin-pull-down { - rockchip,pins = - <0 RK_PB6 1 &pcfg_pull_down>; - }; - }; - - pwm2 { - pwm2_pin: pwm2-pin { - rockchip,pins = - <0 RK_PB7 1 &pcfg_pull_none>; - }; - - pwm2_pin_pull_down: pwm2-pin-pull-down { - rockchip,pins = - <0 RK_PB7 1 &pcfg_pull_down>; - }; - }; - - pwm3 { - pwm3_pin: pwm3-pin { - rockchip,pins = - <0 RK_PC0 1 &pcfg_pull_none>; - }; - - pwm3_pin_pull_down: pwm3-pin-pull-down { - rockchip,pins = - <0 RK_PC0 1 &pcfg_pull_down>; - }; - }; - - pwm4 { - pwm4_pin: pwm4-pin { - rockchip,pins = - <0 RK_PA1 2 &pcfg_pull_none>; - }; - - pwm4_pin_pull_down: pwm4-pin-pull-down { - rockchip,pins = - <0 RK_PA1 2 &pcfg_pull_down>; - }; - }; - - pwm5 { - pwm5_pin: pwm5-pin { - rockchip,pins = - <0 RK_PC1 2 &pcfg_pull_none>; - }; - - pwm5_pin_pull_down: pwm5-pin-pull-down { - rockchip,pins = - <0 RK_PC1 2 &pcfg_pull_down>; - }; - }; - - pwm6 { - pwm6_pin: pwm6-pin { - rockchip,pins = - <0 RK_PC2 2 &pcfg_pull_none>; - }; - - pwm6_pin_pull_down: pwm6-pin-pull-down { - rockchip,pins = - <0 RK_PC2 2 &pcfg_pull_down>; - }; - }; - - pwm7 { - pwm7_pin: pwm7-pin { - rockchip,pins = - <2 RK_PB0 2 &pcfg_pull_none>; - }; - - pwm7_pin_pull_down: pwm7-pin-pull-down { - rockchip,pins = - <2 RK_PB0 2 &pcfg_pull_down>; - }; - }; - - pwm8 { - pwm8_pin: pwm8-pin { - rockchip,pins = - <2 RK_PB2 2 &pcfg_pull_none>; - }; - - pwm8_pin_pull_down: pwm8-pin-pull-down { - rockchip,pins = - <2 RK_PB2 2 &pcfg_pull_down>; - }; - }; - - pwm9 { - pwm9_pin: pwm9-pin { - rockchip,pins = - <2 RK_PB3 2 &pcfg_pull_none>; - }; - - pwm9_pin_pull_down: pwm9-pin-pull-down { - rockchip,pins = - <2 RK_PB3 2 &pcfg_pull_down>; - }; - }; - - pwm10 { - pwm10_pin: pwm10-pin { - rockchip,pins = - <2 RK_PB4 2 &pcfg_pull_none>; - }; - - pwm10_pin_pull_down: pwm10-pin-pull-down { - rockchip,pins = - <2 RK_PB4 2 &pcfg_pull_down>; - }; - }; - - pwm11 { - pwm11_pin: pwm11-pin { - rockchip,pins = - <2 RK_PC0 4 &pcfg_pull_none>; - }; - - pwm11_pin_pull_down: pwm11-pin-pull-down { - rockchip,pins = - <2 RK_PC0 4 &pcfg_pull_down>; - }; - }; - - rtc { - rtc_32k: rtc-32k { - rockchip,pins = - <0 RK_PC3 1 &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_clk: sdmmc-clk { - rockchip,pins = - <4 RK_PD5 1 &pcfg_pull_none_4ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = - <4 RK_PD4 1 &pcfg_pull_up_4ma>; - }; - - sdmmc_det: sdmmc-det { - rockchip,pins = - <0 RK_PA3 1 &pcfg_pull_up_4ma>; - }; - - sdmmc_pwren: sdmmc-pwren { - rockchip,pins = - <4 RK_PD6 1 &pcfg_pull_none_4ma>; - }; - - sdmmc_bus1: sdmmc-bus1 { - rockchip,pins = - <4 RK_PD0 1 &pcfg_pull_up_4ma>; - }; - - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = - <4 RK_PD0 1 &pcfg_pull_up_4ma>, - <4 RK_PD1 1 &pcfg_pull_up_4ma>, - <4 RK_PD2 1 &pcfg_pull_up_4ma>, - <4 RK_PD3 1 &pcfg_pull_up_4ma>; - }; - }; - - sdio { - sdio_clk: sdio-clk { - rockchip,pins = - <4 RK_PA5 1 &pcfg_pull_none_8ma>; - }; - - sdio_cmd: sdio-cmd { - rockchip,pins = - <4 RK_PA4 1 &pcfg_pull_up_8ma>; - }; - - sdio_pwren: sdio-pwren { - rockchip,pins = - <0 RK_PA2 1 &pcfg_pull_none_8ma>; - }; - - sdio_wrpt: sdio-wrpt { - rockchip,pins = - <0 RK_PA1 1 &pcfg_pull_none_8ma>; - }; - - sdio_intn: sdio-intn { - rockchip,pins = - <0 RK_PA0 1 &pcfg_pull_none_8ma>; - }; - - sdio_bus1: sdio-bus1 { - rockchip,pins = - <4 RK_PA0 1 &pcfg_pull_up_8ma>; - }; - - sdio_bus4: sdio-bus4 { - rockchip,pins = - <4 RK_PA0 1 &pcfg_pull_up_8ma>, - <4 RK_PA1 1 &pcfg_pull_up_8ma>, - <4 RK_PA2 1 &pcfg_pull_up_8ma>, - <4 RK_PA3 1 &pcfg_pull_up_8ma>; - }; - }; - - spdif_in { - spdif_in: spdif-in { - rockchip,pins = - <0 RK_PC2 1 &pcfg_pull_none>; - }; - }; - - spdif_out { - spdif_out: spdif-out { - rockchip,pins = - <0 RK_PC1 1 &pcfg_pull_none>; - }; - }; - - spi0 { - spi0_clk: spi0-clk { - rockchip,pins = - <2 RK_PA2 2 &pcfg_pull_up_4ma>; - }; - - spi0_csn0: spi0-csn0 { - rockchip,pins = - <2 RK_PA3 2 &pcfg_pull_up_4ma>; - }; - - spi0_miso: spi0-miso { - rockchip,pins = - <2 RK_PA0 2 &pcfg_pull_up_4ma>; - }; - - spi0_mosi: spi0-mosi { - rockchip,pins = - <2 RK_PA1 2 &pcfg_pull_up_4ma>; - }; - }; - - spi1 { - spi1_clk: spi1-clk { - rockchip,pins = - <3 RK_PB3 3 &pcfg_pull_up_4ma>; - }; - - spi1_csn0: spi1-csn0 { - rockchip,pins = - <3 RK_PB5 3 &pcfg_pull_up_4ma>; - }; - - spi1_miso: spi1-miso { - rockchip,pins = - <3 RK_PB2 3 &pcfg_pull_up_4ma>; - }; - - spi1_mosi: spi1-mosi { - rockchip,pins = - <3 RK_PB4 3 &pcfg_pull_up_4ma>; - }; - }; - - spi1-m1 { - spi1m1_miso: spi1m1-miso { - rockchip,pins = - <2 RK_PA4 2 &pcfg_pull_up_4ma>; - }; - - spi1m1_mosi: spi1m1-mosi { - rockchip,pins = - <2 RK_PA5 2 &pcfg_pull_up_4ma>; - }; - - spi1m1_clk: spi1m1-clk { - rockchip,pins = - <2 RK_PA7 2 &pcfg_pull_up_4ma>; - }; - - spi1m1_csn0: spi1m1-csn0 { - rockchip,pins = - <2 RK_PB1 2 &pcfg_pull_up_4ma>; - }; - }; - - spi2 { - spi2_clk: spi2-clk { - rockchip,pins = - <1 RK_PD0 3 &pcfg_pull_up_4ma>; - }; - - spi2_csn0: spi2-csn0 { - rockchip,pins = - <1 RK_PD1 3 &pcfg_pull_up_4ma>; - }; - - spi2_miso: spi2-miso { - rockchip,pins = - <1 RK_PC6 3 &pcfg_pull_up_4ma>; - }; - - spi2_mosi: spi2-mosi { - rockchip,pins = - <1 RK_PC7 3 &pcfg_pull_up_4ma>; - }; - }; - - tsadc { - tsadc_otp_pin: tsadc-otp-pin { - rockchip,pins = - <0 RK_PB2 0 &pcfg_pull_none>; - }; - - tsadc_otp_out: tsadc-otp-out { - rockchip,pins = - <0 RK_PB2 1 &pcfg_pull_none>; - }; - }; - - uart0 { - uart0_xfer: uart0-xfer { - rockchip,pins = - <2 RK_PA1 1 &pcfg_pull_up>, - <2 RK_PA0 1 &pcfg_pull_up>; - }; - - uart0_cts: uart0-cts { - rockchip,pins = - <2 RK_PA2 1 &pcfg_pull_none>; - }; - - uart0_rts: uart0-rts { - rockchip,pins = - <2 RK_PA3 1 &pcfg_pull_none>; - }; - - uart0_rts_pin: uart0-rts-pin { - rockchip,pins = - <2 RK_PA3 0 &pcfg_pull_none>; - }; - }; - - uart1 { - uart1_xfer: uart1-xfer { - rockchip,pins = - <1 RK_PD1 1 &pcfg_pull_up>, - <1 RK_PD0 1 &pcfg_pull_up>; - }; - - uart1_cts: uart1-cts { - rockchip,pins = - <1 RK_PC6 1 &pcfg_pull_none>; - }; - - uart1_rts: uart1-rts { - rockchip,pins = - <1 RK_PC7 1 &pcfg_pull_none>; - }; - }; - - uart2-m0 { - uart2m0_xfer: uart2m0-xfer { - rockchip,pins = - <1 RK_PC7 2 &pcfg_pull_up>, - <1 RK_PC6 2 &pcfg_pull_up>; - }; - }; - - uart2-m1 { - uart2m1_xfer: uart2m1-xfer { - rockchip,pins = - <4 RK_PD3 2 &pcfg_pull_up>, - <4 RK_PD2 2 &pcfg_pull_up>; - }; - }; - - uart3 { - uart3_xfer: uart3-xfer { - rockchip,pins = - <3 RK_PB5 4 &pcfg_pull_up>, - <3 RK_PB4 4 &pcfg_pull_up>; - }; - }; - - uart3-m1 { - uart3m1_xfer: uart3m1-xfer { - rockchip,pins = - <0 RK_PC2 3 &pcfg_pull_up>, - <0 RK_PC1 3 &pcfg_pull_up>; - }; - }; - - uart4 { - uart4_xfer: uart4-xfer { - rockchip,pins = - <4 RK_PB1 1 &pcfg_pull_up>, - <4 RK_PB0 1 &pcfg_pull_up>; - }; - - uart4_cts: uart4-cts { - rockchip,pins = - <4 RK_PA6 1 &pcfg_pull_none>; - }; - - uart4_rts: uart4-rts { - rockchip,pins = - <4 RK_PA7 1 &pcfg_pull_none>; - }; - - uart4_rts_pin: uart4-rts-pin { - rockchip,pins = - <4 RK_PA7 0 &pcfg_pull_none>; - }; - }; - }; -}; diff --git a/include/dt-bindings/clock/rk3308-cru.h b/include/dt-bindings/clock/rk3308-cru.h deleted file mode 100644 index d97840f9ee2e..000000000000 --- a/include/dt-bindings/clock/rk3308-cru.h +++ /dev/null @@ -1,387 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2019 Rockchip Electronics Co. Ltd. - * Author: Finley Xiao finley.xiao@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3308_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3308_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_VPLL0 3 -#define PLL_VPLL1 4 -#define ARMCLK 5 - -/* sclk (special clocks) */ -#define USB480M 14 -#define SCLK_RTC32K 15 -#define SCLK_PVTM_CORE 16 -#define SCLK_UART0 17 -#define SCLK_UART1 18 -#define SCLK_UART2 19 -#define SCLK_UART3 20 -#define SCLK_UART4 21 -#define SCLK_I2C0 22 -#define SCLK_I2C1 23 -#define SCLK_I2C2 24 -#define SCLK_I2C3 25 -#define SCLK_PWM0 26 -#define SCLK_SPI0 27 -#define SCLK_SPI1 28 -#define SCLK_SPI2 29 -#define SCLK_TIMER0 30 -#define SCLK_TIMER1 31 -#define SCLK_TIMER2 32 -#define SCLK_TIMER3 33 -#define SCLK_TIMER4 34 -#define SCLK_TIMER5 35 -#define SCLK_TSADC 36 -#define SCLK_SARADC 37 -#define SCLK_OTP 38 -#define SCLK_OTP_USR 39 -#define SCLK_CPU_BOOST 40 -#define SCLK_CRYPTO 41 -#define SCLK_CRYPTO_APK 42 -#define SCLK_NANDC_DIV 43 -#define SCLK_NANDC_DIV50 44 -#define SCLK_NANDC 45 -#define SCLK_SDMMC_DIV 46 -#define SCLK_SDMMC_DIV50 47 -#define SCLK_SDMMC 48 -#define SCLK_SDMMC_DRV 49 -#define SCLK_SDMMC_SAMPLE 50 -#define SCLK_SDIO_DIV 51 -#define SCLK_SDIO_DIV50 52 -#define SCLK_SDIO 53 -#define SCLK_SDIO_DRV 54 -#define SCLK_SDIO_SAMPLE 55 -#define SCLK_EMMC_DIV 56 -#define SCLK_EMMC_DIV50 57 -#define SCLK_EMMC 58 -#define SCLK_EMMC_DRV 59 -#define SCLK_EMMC_SAMPLE 60 -#define SCLK_SFC 61 -#define SCLK_OTG_ADP 62 -#define SCLK_MAC_SRC 63 -#define SCLK_MAC 64 -#define SCLK_MAC_REF 65 -#define SCLK_MAC_RX_TX 66 -#define SCLK_MAC_RMII 67 -#define SCLK_DDR_MON_TIMER 68 -#define SCLK_DDR_MON 69 -#define SCLK_DDRCLK 70 -#define SCLK_PMU 71 -#define SCLK_USBPHY_REF 72 -#define SCLK_WIFI 73 -#define SCLK_PVTM_PMU 74 -#define SCLK_PDM 75 -#define SCLK_I2S0_8CH_TX 76 -#define SCLK_I2S0_8CH_TX_OUT 77 -#define SCLK_I2S0_8CH_RX 78 -#define SCLK_I2S0_8CH_RX_OUT 79 -#define SCLK_I2S1_8CH_TX 80 -#define SCLK_I2S1_8CH_TX_OUT 81 -#define SCLK_I2S1_8CH_RX 82 -#define SCLK_I2S1_8CH_RX_OUT 83 -#define SCLK_I2S2_8CH_TX 84 -#define SCLK_I2S2_8CH_TX_OUT 85 -#define SCLK_I2S2_8CH_RX 86 -#define SCLK_I2S2_8CH_RX_OUT 87 -#define SCLK_I2S3_8CH_TX 88 -#define SCLK_I2S3_8CH_TX_OUT 89 -#define SCLK_I2S3_8CH_RX 90 -#define SCLK_I2S3_8CH_RX_OUT 91 -#define SCLK_I2S0_2CH 92 -#define SCLK_I2S0_2CH_OUT 93 -#define SCLK_I2S1_2CH 94 -#define SCLK_I2S1_2CH_OUT 95 -#define SCLK_SPDIF_TX_DIV 96 -#define SCLK_SPDIF_TX_DIV50 97 -#define SCLK_SPDIF_TX 98 -#define SCLK_SPDIF_RX_DIV 99 -#define SCLK_SPDIF_RX_DIV50 100 -#define SCLK_SPDIF_RX 101 -#define SCLK_I2S0_8CH_TX_MUX 102 -#define SCLK_I2S0_8CH_RX_MUX 103 -#define SCLK_I2S1_8CH_TX_MUX 104 -#define SCLK_I2S1_8CH_RX_MUX 105 -#define SCLK_I2S2_8CH_TX_MUX 106 -#define SCLK_I2S2_8CH_RX_MUX 107 -#define SCLK_I2S3_8CH_TX_MUX 108 -#define SCLK_I2S3_8CH_RX_MUX 109 -#define SCLK_I2S0_8CH_TX_SRC 110 -#define SCLK_I2S0_8CH_RX_SRC 111 -#define SCLK_I2S1_8CH_TX_SRC 112 -#define SCLK_I2S1_8CH_RX_SRC 113 -#define SCLK_I2S2_8CH_TX_SRC 114 -#define SCLK_I2S2_8CH_RX_SRC 115 -#define SCLK_I2S3_8CH_TX_SRC 116 -#define SCLK_I2S3_8CH_RX_SRC 117 -#define SCLK_I2S0_2CH_SRC 118 -#define SCLK_I2S1_2CH_SRC 119 -#define SCLK_PWM1 120 -#define SCLK_PWM2 121 -#define SCLK_OWIRE 122 - -/* dclk */ -#define DCLK_VOP 125 - -/* aclk */ -#define ACLK_BUS_SRC 130 -#define ACLK_BUS 131 -#define ACLK_PERI_SRC 132 -#define ACLK_PERI 133 -#define ACLK_MAC 134 -#define ACLK_CRYPTO 135 -#define ACLK_VOP 136 -#define ACLK_GIC 137 -#define ACLK_DMAC0 138 -#define ACLK_DMAC1 139 - -/* hclk */ -#define HCLK_BUS 150 -#define HCLK_PERI 151 -#define HCLK_AUDIO 152 -#define HCLK_NANDC 153 -#define HCLK_SDMMC 154 -#define HCLK_SDIO 155 -#define HCLK_EMMC 156 -#define HCLK_SFC 157 -#define HCLK_OTG 158 -#define HCLK_HOST 159 -#define HCLK_HOST_ARB 160 -#define HCLK_PDM 161 -#define HCLK_SPDIFTX 162 -#define HCLK_SPDIFRX 163 -#define HCLK_I2S0_8CH 164 -#define HCLK_I2S1_8CH 165 -#define HCLK_I2S2_8CH 166 -#define HCLK_I2S3_8CH 167 -#define HCLK_I2S0_2CH 168 -#define HCLK_I2S1_2CH 169 -#define HCLK_VAD 170 -#define HCLK_CRYPTO 171 -#define HCLK_VOP 172 - -/* pclk */ -#define PCLK_BUS 190 -#define PCLK_DDR 191 -#define PCLK_PERI 192 -#define PCLK_PMU 193 -#define PCLK_AUDIO 194 -#define PCLK_MAC 195 -#define PCLK_ACODEC 196 -#define PCLK_UART0 197 -#define PCLK_UART1 198 -#define PCLK_UART2 199 -#define PCLK_UART3 200 -#define PCLK_UART4 201 -#define PCLK_I2C0 202 -#define PCLK_I2C1 203 -#define PCLK_I2C2 204 -#define PCLK_I2C3 205 -#define PCLK_PWM0 206 -#define PCLK_SPI0 207 -#define PCLK_SPI1 208 -#define PCLK_SPI2 209 -#define PCLK_SARADC 210 -#define PCLK_TSADC 211 -#define PCLK_TIMER 212 -#define PCLK_OTP_NS 213 -#define PCLK_WDT 214 -#define PCLK_GPIO0 215 -#define PCLK_GPIO1 216 -#define PCLK_GPIO2 217 -#define PCLK_GPIO3 218 -#define PCLK_GPIO4 219 -#define PCLK_SGRF 220 -#define PCLK_GRF 221 -#define PCLK_USBSD_DET 222 -#define PCLK_DDR_UPCTL 223 -#define PCLK_DDR_MON 224 -#define PCLK_DDRPHY 225 -#define PCLK_DDR_STDBY 226 -#define PCLK_USB_GRF 227 -#define PCLK_CRU 228 -#define PCLK_OTP_PHY 229 -#define PCLK_CPU_BOOST 230 -#define PCLK_PWM1 231 -#define PCLK_PWM2 232 -#define PCLK_CAN 233 -#define PCLK_OWIRE 234 - -#define CLK_NR_CLKS (PCLK_OWIRE + 1) - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_CORE_NOC 13 -#define SRST_STRC_A 14 -#define SRST_L2C 15 - -/* cru_softrst_con1 */ -#define SRST_DAP 16 -#define SRST_CORE_PVTM 17 -#define SRST_CORE_PRF 18 -#define SRST_CORE_GRF 19 -#define SRST_DDRUPCTL 20 -#define SRST_DDRUPCTL_P 22 -#define SRST_MSCH 23 -#define SRST_DDRMON_P 25 -#define SRST_DDRSTDBY_P 26 -#define SRST_DDRSTDBY 27 -#define SRST_DDRPHY 28 -#define SRST_DDRPHY_DIV 29 -#define SRST_DDRPHY_P 30 - -/* cru_softrst_con2 */ -#define SRST_BUS_NIU_H 32 -#define SRST_USB_NIU_P 33 -#define SRST_CRYPTO_A 34 -#define SRST_CRYPTO_H 35 -#define SRST_CRYPTO 36 -#define SRST_CRYPTO_APK 37 -#define SRST_VOP_A 38 -#define SRST_VOP_H 39 -#define SRST_VOP_D 40 -#define SRST_INTMEM_A 41 -#define SRST_ROM_H 42 -#define SRST_GIC_A 43 -#define SRST_UART0_P 44 -#define SRST_UART0 45 -#define SRST_UART1_P 46 -#define SRST_UART1 47 - -/* cru_softrst_con3 */ -#define SRST_UART2_P 48 -#define SRST_UART2 49 -#define SRST_UART3_P 50 -#define SRST_UART3 51 -#define SRST_UART4_P 52 -#define SRST_UART4 53 -#define SRST_I2C0_P 54 -#define SRST_I2C0 55 -#define SRST_I2C1_P 56 -#define SRST_I2C1 57 -#define SRST_I2C2_P 58 -#define SRST_I2C2 59 -#define SRST_I2C3_P 60 -#define SRST_I2C3 61 -#define SRST_PWM0_P 62 -#define SRST_PWM0 63 - -/* cru_softrst_con4 */ -#define SRST_SPI0_P 64 -#define SRST_SPI0 65 -#define SRST_SPI1_P 66 -#define SRST_SPI1 67 -#define SRST_SPI2_P 68 -#define SRST_SPI2 69 -#define SRST_SARADC_P 70 -#define SRST_TSADC_P 71 -#define SRST_TSADC 72 -#define SRST_TIMER0_P 73 -#define SRST_TIMER0 74 -#define SRST_TIMER1 75 -#define SRST_TIMER2 76 -#define SRST_TIMER3 77 -#define SRST_TIMER4 78 -#define SRST_TIMER5 79 - -/* cru_softrst_con5 */ -#define SRST_OTP_NS_P 80 -#define SRST_OTP_NS_SBPI 81 -#define SRST_OTP_NS_USR 82 -#define SRST_OTP_PHY_P 83 -#define SRST_OTP_PHY 84 -#define SRST_GPIO0_P 86 -#define SRST_GPIO1_P 87 -#define SRST_GPIO2_P 88 -#define SRST_GPIO3_P 89 -#define SRST_GPIO4_P 90 -#define SRST_GRF_P 91 -#define SRST_USBSD_DET_P 92 -#define SRST_PMU 93 -#define SRST_PMU_PVTM 94 -#define SRST_USB_GRF_P 95 - -/* cru_softrst_con6 */ -#define SRST_CPU_BOOST 96 -#define SRST_CPU_BOOST_P 97 -#define SRST_PWM1_P 98 -#define SRST_PWM1 99 -#define SRST_PWM2_P 100 -#define SRST_PWM2 101 -#define SRST_PERI_NIU_A 104 -#define SRST_PERI_NIU_H 105 -#define SRST_PERI_NIU_p 106 -#define SRST_USB2OTG_H 107 -#define SRST_USB2OTG 108 -#define SRST_USB2OTG_ADP 109 -#define SRST_USB2HOST_H 110 -#define SRST_USB2HOST_ARB_H 111 - -/* cru_softrst_con7 */ -#define SRST_USB2HOST_AUX_H 112 -#define SRST_USB2HOST_EHCI 113 -#define SRST_USB2HOST 114 -#define SRST_USBPHYPOR 115 -#define SRST_UTMI0 116 -#define SRST_UTMI1 117 -#define SRST_SDIO_H 118 -#define SRST_EMMC_H 119 -#define SRST_SFC_H 120 -#define SRST_SFC 121 -#define SRST_SD_H 122 -#define SRST_NANDC_H 123 -#define SRST_NANDC_N 124 -#define SRST_MAC_A 125 -#define SRST_CAN_P 126 -#define SRST_OWIRE_P 127 - -/* cru_softrst_con8 */ -#define SRST_AUDIO_NIU_H 128 -#define SRST_AUDIO_NIU_P 129 -#define SRST_PDM_H 130 -#define SRST_PDM_M 131 -#define SRST_SPDIFTX_H 132 -#define SRST_SPDIFTX_M 133 -#define SRST_SPDIFRX_H 134 -#define SRST_SPDIFRX_M 135 -#define SRST_I2S0_8CH_H 136 -#define SRST_I2S0_8CH_TX_M 137 -#define SRST_I2S0_8CH_RX_M 138 -#define SRST_I2S1_8CH_H 139 -#define SRST_I2S1_8CH_TX_M 140 -#define SRST_I2S1_8CH_RX_M 141 -#define SRST_I2S2_8CH_H 142 -#define SRST_I2S2_8CH_TX_M 143 - -/* cru_softrst_con9 */ -#define SRST_I2S2_8CH_RX_M 144 -#define SRST_I2S3_8CH_H 145 -#define SRST_I2S3_8CH_TX_M 146 -#define SRST_I2S3_8CH_RX_M 147 -#define SRST_I2S0_2CH_H 148 -#define SRST_I2S0_2CH_M 149 -#define SRST_I2S1_2CH_H 150 -#define SRST_I2S1_2CH_M 151 -#define SRST_VAD_H 152 -#define SRST_ACODEC_P 153 - -#endif
On 2024/5/5 03:42, Jonas Karlman wrote:
Remove redundant device tree files now that RK3308 boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
arch/arm/dts/rk3308-evb.dts | 230 --- arch/arm/dts/rk3308-roc-cc.dts | 190 --- arch/arm/dts/rk3308-rock-pi-s.dts | 314 ---- arch/arm/dts/rk3308.dtsi | 1888 ------------------------ include/dt-bindings/clock/rk3308-cru.h | 387 ----- 5 files changed, 3009 deletions(-) delete mode 100644 arch/arm/dts/rk3308-evb.dts delete mode 100644 arch/arm/dts/rk3308-roc-cc.dts delete mode 100644 arch/arm/dts/rk3308-rock-pi-s.dts delete mode 100644 arch/arm/dts/rk3308.dtsi delete mode 100644 include/dt-bindings/clock/rk3308-cru.h
diff --git a/arch/arm/dts/rk3308-evb.dts b/arch/arm/dts/rk3308-evb.dts deleted file mode 100644 index 184b84fdde07..000000000000 --- a/arch/arm/dts/rk3308-evb.dts +++ /dev/null @@ -1,230 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd
-/dts-v1/; -#include <dt-bindings/input/input.h> -#include "rk3308.dtsi"
- model = "Rockchip RK3308 EVB";
- compatible = "rockchip,rk3308-evb", "rockchip,rk3308";
- chosen {
stdout-path = "serial4:1500000n8";
- adc-keys0 {
compatible = "adc-keys";
io-channels = <&saradc 0>;
io-channel-names = "buttons";
poll-interval = <100>;
keyup-threshold-microvolt = <1800000>;
button-func {
linux,code = <KEY_FN>;
label = "function";
press-threshold-microvolt = <18000>;
- adc-keys1 {
io-channels = <&saradc 1>;
button-esc {
linux,code = <KEY_MICMUTE>;
label = "micmute";
press-threshold-microvolt = <1130000>;
button-home {
linux,code = <KEY_MODE>;
label = "mode";
press-threshold-microvolt = <901000>;
button-menu {
linux,code = <KEY_PLAY>;
label = "play";
press-threshold-microvolt = <624000>;
button-down {
linux,code = <KEY_VOLUMEDOWN>;
label = "volume down";
press-threshold-microvolt = <300000>;
button-up {
linux,code = <KEY_VOLUMEUP>;
label = "volume up";
- gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-0 = <&pwr_key>;
key-power {
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>;
linux,code = <KEY_POWER>;
label = "GPIO Key Power";
debounce-interval = <100>;
wakeup-source;
- vcc12v_dcin: vcc12v-dcin {
regulator-name = "vcc12v_dcin";
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
regulator-boot-on;
regulator-boot-on;
vin-supply = <&vcc12v_dcin>;
- vccio_sdio: vcc_1v8: vcc-1v8 {
regulator-boot-on;
regulator-boot-on;
- vcc_io: vcc-io {
regulator-boot-on;
- vccio_flash: vccio-flash {
regulator-name = "vccio_flash";
regulator-boot-on;
- vcc5v0_host: vcc5v0-host {
enable-active-high;
pinctrl-0 = <&usb_drv>;
regulator-name = "vbus_host";
regulator-boot-on;
regulator-boot-on;
- vdd_1v0: vdd-1v0 {
regulator-name = "vdd_1v0";
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
-&cpu0 {
-&saradc {
- status = "okay";
-&pinctrl {
- buttons {
pwr_key: pwr-key {
rockchip,pins = <0 RK_PA6 0 &pcfg_pull_up>;
- usb {
usb_drv: usb-drv {
rockchip,pins = <0 RK_PC5 0 &pcfg_pull_none>;
- sdio-pwrseq {
rockchip,pins = <0 RK_PA2 0 &pcfg_pull_none>;
-&pwm0 {
- status = "okay";
-&uart4 {
- pinctrl-0 = <&uart4_xfer>;
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3308-roc-cc.dts b/arch/arm/dts/rk3308-roc-cc.dts deleted file mode 100644 index 9232357f4fec..000000000000 --- a/arch/arm/dts/rk3308-roc-cc.dts +++ /dev/null @@ -1,190 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-/dts-v1/; -#include "rk3308.dtsi"
- model = "Firefly ROC-RK3308-CC board";
- compatible = "firefly,roc-rk3308-cc", "rockchip,rk3308";
- aliases {
mmc0 = &sdmmc;
mmc1 = &emmc;
- chosen {
stdout-path = "serial2:1500000n8";
- ir-receiver {
compatible = "gpio-ir-receiver";
gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&ir_recv_pin>;
- ir_tx {
compatible = "pwm-ir-tx";
pwms = <&pwm5 0 25000 0>;
- leds {
compatible = "gpio-leds";
power_led: led-0 {
label = "firefly:red:power";
linux,default-trigger = "ir-power-click";
default-state = "on";
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
user_led: led-1 {
label = "firefly:blue:user";
linux,default-trigger = "ir-user-click";
default-state = "off";
gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_HIGH>;
- typec_vcc5v: typec-vcc5v {
compatible = "regulator-fixed";
regulator-name = "typec_vcc5v";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-always-on;
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys {
regulator-name = "vcc5v0_sys";
regulator-boot-on;
vin-supply = <&typec_vcc5v>;
- vcc_io: vcc-io {
regulator-name = "vcc_io";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-boot-on;
vin-supply = <&vcc5v0_sys>;
- vcc_sdmmc: vcc-sdmmc {
compatible = "regulator-gpio";
regulator-name = "vcc_sdmmc";
regulator-min-microvolt = <1800000>;
gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_HIGH>;
states = <1800000 0x0>,
<3300000 0x1>;
- vcc_sd: vcc-sd {
gpio = <&gpio4 RK_PD6 GPIO_ACTIVE_LOW>;
regulator-name = "vcc_sd";
regulator-boot-on;
vin-supply = <&vcc_io>;
- vdd_core: vdd-core {
compatible = "pwm-regulator";
pwms = <&pwm0 0 5000 1>;
regulator-name = "vdd_core";
regulator-min-microvolt = <827000>;
regulator-max-microvolt = <1340000>;
regulator-settling-time-up-us = <250>;
regulator-boot-on;
pwm-supply = <&vcc5v0_sys>;
- vdd_log: vdd-log {
regulator-name = "vdd_log";
regulator-min-microvolt = <1050000>;
regulator-max-microvolt = <1050000>;
regulator-boot-on;
-&cpu0 {
- cpu-supply = <&vdd_core>;
-&emmc {
- cap-mmc-highspeed;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&i2c1 {
- clock-frequency = <400000>;
- status = "okay";
- rtc: rtc@51 {
compatible = "nxp,pcf8563";
reg = <0x51>;
#clock-cells = <0>;
-&pwm5 {
- status = "okay";
- pinctrl-names = "active";
- pinctrl-0 = <&pwm5_pin_pull_down>;
-&pinctrl {
- ir-receiver {
ir_recv_pin: ir-recv-pin {
rockchip,pins = <0 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>;
- buttons {
pwr_key: pwr-key {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>;
-&pwm0 {
- status = "okay";
-&sdmmc {
- cap-sd-highspeed;
- card-detect-delay = <300>;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_sd>;
- vqmmc-supply = <&vcc_sdmmc>;
- status = "okay";
-&uart2 {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3308-rock-pi-s.dts b/arch/arm/dts/rk3308-rock-pi-s.dts deleted file mode 100644 index b47fe02c33fb..000000000000 --- a/arch/arm/dts/rk3308-rock-pi-s.dts +++ /dev/null @@ -1,314 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Akash Gajjar akash@openedev.com
- Copyright (c) 2019 Jagan Teki jagan@openedev.com
- model = "Radxa ROCK Pi S";
- compatible = "radxa,rockpis", "rockchip,rk3308";
- aliases {
ethernet0 = &gmac;
mmc0 = &emmc;
mmc1 = &sdmmc;
- chosen {
stdout-path = "serial0:1500000n8";
- leds {
pinctrl-0 = <&green_led_gio>, <&heartbeat_led_gpio>;
green-led {
label = "rockpis:green:power";
linux,default-trigger = "default-on";
blue-led {
gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>;
label = "rockpis:blue:user";
linux,default-trigger = "heartbeat";
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
pinctrl-0 = <&wifi_enable_h>;
reset-gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_LOW>;
- vcc_1v8: vcc-1v8 {
regulator-name = "vcc_1v8";
regulator-boot-on;
regulator-max-microvolt = <1800000>;
- vcc_io: vcc-io {
regulator-boot-on;
- vcc_ddr: vcc-ddr {
regulator-name = "vcc_ddr";
regulator-boot-on;
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
- vcc5v0_otg: vcc5v0-otg {
enable-active-high;
gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&otg_vbus_drv>;
regulator-name = "vcc5v0_otg";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&cpu0 {
-&emmc {
- bus-width = <4>;
- mmc-hs200-1_8v;
- non-removable;
- vmmc-supply = <&vcc_io>;
- status = "okay";
-&gmac {
- clock_in_out = "output";
- phy-supply = <&vcc_io>;
- snps,reset-gpio = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 50000 50000>;
- status = "okay";
-&gpio0 {
- gpio-line-names =
/* GPIO0_A0 - A7 */
/* GPIO0_B0 - B7 */
"", "", "", "header1-pin3 [GPIO0_B3]",
"header1-pin5 [GPIO0_B4]", "", "",
"header1-pin11 [GPIO0_B7]",
/* GPIO0_C0 - C7 */
"header1-pin13 [GPIO0_C0]",
"header1-pin15 [GPIO0_C1]", "", "", "",
/* GPIO0_D0 - D7 */
-&gpio1 {
- gpio-line-names =
/* GPIO1_A0 - A7 */
/* GPIO1_B0 - B7 */
/* GPIO1_C0 - C7 */
"", "", "", "", "", "", "header1-pin21 [GPIO1_C6]",
"header1-pin19 [GPIO1_C7]",
/* GPIO1_D0 - D7 */
"header1-pin23 [GPIO1_D0]", "header1-pin24 [GPIO1_D1]",
-&gpio2 {
- gpio-line-names =
/* GPIO2_A0 - A7 */
"header1-pin10 [GPIO2_A0]", "header1-pin8 [GPIO2_A1]",
"header1-pin7 [GPIO2_A4]", "header1-pin12 [GPIO2_A5]",
"header2-pin46 [GPIO2_A6]", "header1-pin22 [GPIO1_A7]",
/* GPIO2_B0 - B7 */
"header2-pin45 [GPIO2_B0]", "header1-pin18 [GPIO2_B1]",
"header1-pin16 [GPIO2_B2]", "header2-pin44 [GPIO2_B3]",
"header2-pin43 [GPIO2_B4]", "header2-pin28 [GPIO2_B5]",
"header2-pin30 [GPIO2_B6]", "header2-pin32 [GPIO2_B7]",
/* GPIO2_C0 - C7 */
"header2-pin34 [GPIO2_C0]", "", "", "", "", "", "", "",
/* GPIO2_D0 - D7 */
-&gpio3 {
- gpio-line-names =
/* GPIO3_A0 - A7 */
/* GPIO3_B0 - B7 */
"", "", "header2-pin42 [GPIO3_B2]",
"header2-pin41 [GPIO3_B3]", "header2-pin40 [GPIO3_B4]",
"header2-pin39 [GPIO3_B5]", "", "",
/* GPIO3_C0 - C7 */
/* GPIO3_D0 - D7 */
-&i2c1 {
- status = "okay";
-&pinctrl {
- pinctrl-0 = <&rtc_32k>;
- leds {
green_led_gio: green-led-gpio {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
heartbeat_led_gpio: heartbeat-led-gpio {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
- usb {
otg_vbus_drv: otg-vbus-drv {
rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
wifi_host_wake: wifi-host-wake {
rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_down>;
-&pwm0 {
- status = "okay";
- pinctrl-0 = <&pwm0_pin_pull_down>;
-&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
-&sdio {
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- max-frequency = <1000000>;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
-&sdmmc {
- cap-sd-highspeed;
- status = "okay";
-&u2phy {
- status = "okay";
phy-supply = <&vcc5v0_otg>;
status = "okay";
status = "okay";
-&uart0 {
- status = "okay";
-&uart4 {
- status = "okay";
- bluetooth {
compatible = "realtek,rtl8723bs-bt";
device-wake-gpios = <&gpio4 RK_PB3 GPIO_ACTIVE_HIGH>;
host-wake-gpios = <&gpio4 RK_PB4 GPIO_ACTIVE_HIGH>;
-&usb_host_ehci {
- status = "okay";
-&usb_host_ohci {
- status = "okay";
-&usb20_otg {
- dr_mode = "peripheral";
- status = "okay";
-&wdt {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3308.dtsi b/arch/arm/dts/rk3308.dtsi deleted file mode 100644 index cfc0a87b5195..000000000000 --- a/arch/arm/dts/rk3308.dtsi +++ /dev/null @@ -1,1888 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-#include <dt-bindings/clock/rk3308-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> -#include <dt-bindings/thermal/thermal.h>
- compatible = "rockchip,rk3308";
- interrupt-parent = <&gic>;
- aliases {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
gpio3 = &gpio3;
gpio4 = &gpio4;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a35";
reg = <0x0 0x0>;
enable-method = "psci";
clocks = <&cru ARMCLK>;
#cooling-cells = <2>;
dynamic-power-coefficient = <90>;
operating-points-v2 = <&cpu0_opp_table>;
cpu-idle-states = <&CPU_SLEEP>;
next-level-cache = <&l2>;
cpu1: cpu@1 {
reg = <0x0 0x1>;
cpu2: cpu@2 {
reg = <0x0 0x2>;
cpu3: cpu@3 {
reg = <0x0 0x3>;
idle-states {
entry-method = "psci";
CPU_SLEEP: cpu-sleep {
compatible = "arm,idle-state";
local-timer-stop;
arm,psci-suspend-param = <0x0010000>;
entry-latency-us = <120>;
exit-latency-us = <250>;
min-residency-us = <900>;
l2: l2-cache {
compatible = "cache";
cache-level = <2>;
cache-unified;
- cpu0_opp_table: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp-408000000 {
opp-hz = /bits/ 64 <408000000>;
opp-microvolt = <950000 950000 1340000>;
clock-latency-ns = <40000>;
opp-suspend;
opp-600000000 {
opp-hz = /bits/ 64 <600000000>;
opp-816000000 {
opp-hz = /bits/ 64 <816000000>;
opp-microvolt = <1025000 1025000 1340000>;
opp-1008000000 {
opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <1125000 1125000 1340000>;
- arm-pmu {
compatible = "arm,cortex-a35-pmu";
interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 84 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 85 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 86 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>;
- mac_clkin: external-mac-clock {
compatible = "fixed-clock";
clock-frequency = <50000000>;
clock-output-names = "mac_clkin";
#clock-cells = <0>;
- psci {
compatible = "arm,psci-1.0";
method = "smc";
- timer {
compatible = "arm,armv8-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
<GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>,
<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
- xin24m: xin24m {
#clock-cells = <0>;
clock-frequency = <24000000>;
clock-output-names = "xin24m";
- grf: grf@ff000000 {
compatible = "rockchip,rk3308-grf", "syscon", "simple-mfd";
reg = <0x0 0xff000000 0x0 0x08000>;
reboot-mode {
compatible = "syscon-reboot-mode";
offset = <0x500>;
mode-bootloader = <BOOT_BL_DOWNLOAD>;
mode-loader = <BOOT_BL_DOWNLOAD>;
mode-normal = <BOOT_NORMAL>;
mode-recovery = <BOOT_RECOVERY>;
mode-fastboot = <BOOT_FASTBOOT>;
- usb2phy_grf: syscon@ff008000 {
compatible = "rockchip,rk3308-usb2phy-grf", "syscon", "simple-mfd";
reg = <0x0 0xff008000 0x0 0x4000>;
#size-cells = <1>;
u2phy: usb2phy@100 {
compatible = "rockchip,rk3308-usb2phy";
reg = <0x100 0x10>;
assigned-clocks = <&cru USB480M>;
assigned-clock-parents = <&u2phy>;
clocks = <&cru SCLK_USBPHY_REF>;
clock-names = "phyclk";
clock-output-names = "usb480m_phy";
#clock-cells = <0>;
u2phy_otg: otg-port {
interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "otg-bvalid", "otg-id",
"linestate";
#phy-cells = <0>;
u2phy_host: host-port {
interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "linestate";
#phy-cells = <0>;
- detect_grf: syscon@ff00b000 {
compatible = "rockchip,rk3308-detect-grf", "syscon", "simple-mfd";
reg = <0x0 0xff00b000 0x0 0x1000>;
#size-cells = <1>;
- core_grf: syscon@ff00c000 {
compatible = "rockchip,rk3308-core-grf", "syscon", "simple-mfd";
reg = <0x0 0xff00c000 0x0 0x1000>;
#size-cells = <1>;
- i2c0: i2c@ff040000 {
reg = <0x0 0xff040000 0x0 0x1000>;
clocks = <&cru SCLK_I2C0>, <&cru PCLK_I2C0>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&i2c0_xfer>;
#size-cells = <0>;
- i2c1: i2c@ff050000 {
compatible = "rockchip,rk3308-i2c", "rockchip,rk3399-i2c";
reg = <0x0 0xff050000 0x0 0x1000>;
clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>;
clock-names = "i2c", "pclk";
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&i2c1_xfer>;
#size-cells = <0>;
- i2c2: i2c@ff060000 {
reg = <0x0 0xff060000 0x0 0x1000>;
clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>;
interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&i2c2_xfer>;
#size-cells = <0>;
- i2c3: i2c@ff070000 {
reg = <0x0 0xff070000 0x0 0x1000>;
clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&i2c3m0_xfer>;
#size-cells = <0>;
- wdt: watchdog@ff080000 {
compatible = "rockchip,rk3308-wdt", "snps,dw-wdt";
reg = <0x0 0xff080000 0x0 0x100>;
clocks = <&cru PCLK_WDT>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
- uart0: serial@ff0a0000 {
reg = <0x0 0xff0a0000 0x0 0x100>;
interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>;
reg-shift = <2>;
reg-io-width = <4>;
pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
- uart1: serial@ff0b0000 {
reg = <0x0 0xff0b0000 0x0 0x100>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
reg-shift = <2>;
reg-io-width = <4>;
#size-cells = <0>;
#size-cells = <0>;
#size-cells = <0>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#pwm-cells = <3>;
#dma-cells = <1>;
#dma-cells = <1>;
&i2s_2ch_0_lrck
&i2s_2ch_0_sdi
&i2s_2ch_0_sdo>;
dmas = <&dmac1 11>;
dma-names = "rx";
dmas = <&dmac1 13>;
dma-names = "tx";
"snps,dwc2";
dr_mode = "otg";
phy-names = "usb";
phy-names = "usb";
bus-width = <4>;
bus-width = <8>;
bus-width = <4>;
phy-mode = "rmii";
clocks = <&xin24m>;
#clock-cells = <1>;
#reset-cells = <1>;
#size-cells = <1>;
ddr-sram@0 {
reg = <0x0 0x8000>;
#size-cells = <2>;
ranges;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
gpio-controller;
#gpio-cells = <2>;
bias-pull-up;
bias-pull-down;
bias-disable;
bias-disable;
bias-pull-up;
bias-pull-up;
bias-disable;
bias-pull-down;
bias-disable;
bias-pull-up;
bias-disable;
bias-pull-up;
bias-disable;
output-high;
output-low;
bias-pull-up;
input-enable;
input-enable;
emmc {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
flash {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
sfc {
rockchip,pins =
rockchip,pins =
sfc_cs0: sfc-cs0 {
rockchip,pins =
sfc_clk: sfc-clk {
rockchip,pins =
gmac {
rockchip,pins =
/* mac_txen */
/* mac_txd1 */
/* mac_txd0 */
/* mac_rxd0 */
/* mac_rxd1 */
/* mac_rxer */
/* mac_rxdv */
/* mac_mdio */
/* mac_mdc */
rockchip,pins =
rockchip,pins =
gmac-m1 {
rockchip,pins =
/* mac_txen */
/* mac_txd1 */
/* mac_txd0 */
/* mac_rxd0 */
/* mac_rxd1 */
/* mac_rxer */
/* mac_rxdv */
/* mac_mdio */
/* mac_mdc */
rockchip,pins =
rockchip,pins =
i2c0 {
rockchip,pins =
i2c1 {
rockchip,pins =
i2c2 {
rockchip,pins =
i2c3-m0 {
rockchip,pins =
i2c3-m1 {
rockchip,pins =
i2c3-m2 {
rockchip,pins =
i2s_2ch_0 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
i2s_8ch_0 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
i2s_8ch_1_m0 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
i2s_8ch_1_m1 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
pdm_m0 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
pdm_m1 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
pdm_m2 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
pwm0 {
rockchip,pins =
rockchip,pins =
pwm1 {
rockchip,pins =
rockchip,pins =
pwm2 {
rockchip,pins =
rockchip,pins =
pwm3 {
rockchip,pins =
rockchip,pins =
pwm4 {
rockchip,pins =
rockchip,pins =
pwm5 {
rockchip,pins =
rockchip,pins =
pwm6 {
rockchip,pins =
rockchip,pins =
pwm7 {
rockchip,pins =
rockchip,pins =
pwm8 {
rockchip,pins =
rockchip,pins =
pwm9 {
rockchip,pins =
rockchip,pins =
pwm10 {
rockchip,pins =
rockchip,pins =
pwm11 {
rockchip,pins =
rockchip,pins =
rtc {
rtc_32k: rtc-32k {
rockchip,pins =
sdmmc {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
sdio {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
spdif_in {
rockchip,pins =
spdif_out {
rockchip,pins =
spi0 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
spi1 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
spi1-m1 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
spi2 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
tsadc {
rockchip,pins =
rockchip,pins =
uart0 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
uart1 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
uart2-m0 {
rockchip,pins =
uart2-m1 {
rockchip,pins =
uart3 {
rockchip,pins =
uart3-m1 {
rockchip,pins =
uart4 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
rockchip,pins =
- Copyright (c) 2019 Rockchip Electronics Co. Ltd.
- Author: Finley Xiao finley.xiao@rock-chips.com
-#endif
All RK3328 boards has now been synced to Linux kernel v6.8 DTs and can migrate to use OF_UPSTREAM.
Migrate all RK3328 boards to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/Makefile | 11 ----------- arch/arm/mach-rockchip/Kconfig | 1 + configs/evb-rk3328_defconfig | 2 +- configs/nanopi-r2c-plus-rk3328_defconfig | 2 +- configs/nanopi-r2c-rk3328_defconfig | 2 +- configs/nanopi-r2s-rk3328_defconfig | 2 +- configs/orangepi-r1-plus-lts-rk3328_defconfig | 2 +- configs/orangepi-r1-plus-rk3328_defconfig | 2 +- configs/roc-cc-rk3328_defconfig | 2 +- configs/rock-pi-e-rk3328_defconfig | 2 +- configs/rock64-rk3328_defconfig | 2 +- 11 files changed, 10 insertions(+), 20 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 319ec23a4fee..b7ada58695be 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -92,17 +92,6 @@ dtb-$(CONFIG_ROCKCHIP_RK3288) += \ rk3288-veyron-speedy.dtb \ rk3288-vyasa.dtb
-dtb-$(CONFIG_ROCKCHIP_RK3328) += \ - rk3328-evb.dtb \ - rk3328-nanopi-r2c.dtb \ - rk3328-nanopi-r2c-plus.dtb \ - rk3328-nanopi-r2s.dtb \ - rk3328-orangepi-r1-plus.dtb \ - rk3328-orangepi-r1-plus-lts.dtb \ - rk3328-roc-cc.dtb \ - rk3328-rock64.dtb \ - rk3328-rock-pi-e.dtb - dtb-$(CONFIG_ROCKCHIP_RK3368) += \ rk3368-lion-haikou.dtb \ rk3368-sheep.dtb \ diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index f1caf4f3738b..a492b0885c03 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -197,6 +197,7 @@ config ROCKCHIP_RK3328 imply MISC imply MISC_INIT_R imply OF_LIVE + imply OF_UPSTREAM imply PRE_CONSOLE_BUFFER imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_EFUSE diff --git a/configs/evb-rk3328_defconfig b/configs/evb-rk3328_defconfig index 53ad6777ec50..bfb85223437d 100644 --- a/configs/evb-rk3328_defconfig +++ b/configs/evb-rk3328_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-evb" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-evb" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/nanopi-r2c-plus-rk3328_defconfig b/configs/nanopi-r2c-plus-rk3328_defconfig index beef682a582e..f311a0a80ba7 100644 --- a/configs/nanopi-r2c-plus-rk3328_defconfig +++ b/configs/nanopi-r2c-plus-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-nanopi-r2c-plus" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-nanopi-r2c-plus" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/nanopi-r2c-rk3328_defconfig b/configs/nanopi-r2c-rk3328_defconfig index 8960c1afaba5..533dc1029f73 100644 --- a/configs/nanopi-r2c-rk3328_defconfig +++ b/configs/nanopi-r2c-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-nanopi-r2c" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-nanopi-r2c" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/nanopi-r2s-rk3328_defconfig b/configs/nanopi-r2s-rk3328_defconfig index 96e67e248d32..2591a9cc8ab2 100644 --- a/configs/nanopi-r2s-rk3328_defconfig +++ b/configs/nanopi-r2s-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-nanopi-r2s" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-nanopi-r2s" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/orangepi-r1-plus-lts-rk3328_defconfig b/configs/orangepi-r1-plus-lts-rk3328_defconfig index 5fbbd5fc6558..14cdbd813c81 100644 --- a/configs/orangepi-r1-plus-lts-rk3328_defconfig +++ b/configs/orangepi-r1-plus-lts-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-orangepi-r1-plus-lts" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-orangepi-r1-plus-lts" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/orangepi-r1-plus-rk3328_defconfig b/configs/orangepi-r1-plus-rk3328_defconfig index c5afe5ea6e5c..7fe58e7a1467 100644 --- a/configs/orangepi-r1-plus-rk3328_defconfig +++ b/configs/orangepi-r1-plus-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-orangepi-r1-plus" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-orangepi-r1-plus" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/roc-cc-rk3328_defconfig b/configs/roc-cc-rk3328_defconfig index 1dbd39e6b5e7..91b9422e26fb 100644 --- a/configs/roc-cc-rk3328_defconfig +++ b/configs/roc-cc-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-roc-cc" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-roc-cc" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/rock-pi-e-rk3328_defconfig b/configs/rock-pi-e-rk3328_defconfig index 23029255bca2..5cc54af3ca56 100644 --- a/configs/rock-pi-e-rk3328_defconfig +++ b/configs/rock-pi-e-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-rock-pi-e" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-rock-pi-e" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_DEBUG_UART_BASE=0xFF130000 diff --git a/configs/rock64-rk3328_defconfig b/configs/rock64-rk3328_defconfig index b0be1d1d7633..9d77dfb7098a 100644 --- a/configs/rock64-rk3328_defconfig +++ b/configs/rock64-rk3328_defconfig @@ -6,7 +6,7 @@ CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3328-rock64" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3328-rock64" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3328=y CONFIG_ROCKCHIP_SPI_IMAGE=y
Thanks, - Kever
- rk3328-evb.dtb \
- imply OF_UPSTREAM imply PRE_CONSOLE_BUFFER imply ROCKCHIP_COMMON_BOARD imply ROCKCHIP_EFUSE
Remove redundant device tree files now that RK3328 boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3328-evb.dts | 289 --- arch/arm/dts/rk3328-nanopi-r2c-plus.dts | 33 - arch/arm/dts/rk3328-nanopi-r2c.dts | 40 - arch/arm/dts/rk3328-nanopi-r2s.dts | 410 ---- arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts | 42 - arch/arm/dts/rk3328-orangepi-r1-plus.dts | 374 ---- arch/arm/dts/rk3328-roc-cc.dts | 384 ---- arch/arm/dts/rk3328-rock-pi-e.dts | 445 ---- arch/arm/dts/rk3328-rock64.dts | 394 ---- arch/arm/dts/rk3328.dtsi | 1944 ------------------ include/dt-bindings/clock/rk3328-cru.h | 393 ---- include/dt-bindings/power/rk3328-power.h | 19 - 12 files changed, 4767 deletions(-) delete mode 100644 arch/arm/dts/rk3328-evb.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2c-plus.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2c.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2s.dts delete mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts delete mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus.dts delete mode 100644 arch/arm/dts/rk3328-roc-cc.dts delete mode 100644 arch/arm/dts/rk3328-rock-pi-e.dts delete mode 100644 arch/arm/dts/rk3328-rock64.dts delete mode 100644 arch/arm/dts/rk3328.dtsi delete mode 100644 include/dt-bindings/clock/rk3328-cru.h delete mode 100644 include/dt-bindings/power/rk3328-power.h
diff --git a/arch/arm/dts/rk3328-evb.dts b/arch/arm/dts/rk3328-evb.dts deleted file mode 100644 index 1eef5504445f..000000000000 --- a/arch/arm/dts/rk3328-evb.dts +++ /dev/null @@ -1,289 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd - */ - -/dts-v1/; -#include "rk3328.dtsi" - -/ { - model = "Rockchip RK3328 EVB"; - compatible = "rockchip,rk3328-evb", "rockchip,rk3328"; - - aliases { - ethernet0 = &gmac2phy; - mmc0 = &sdmmc; - mmc1 = &sdio; - mmc2 = &emmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - dc_12v: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio1 18 GPIO_ACTIVE_LOW>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 30 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_pin>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vcc_phy: vcc-phy-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; - regulator-always-on; - regulator-boot-on; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; - status = "okay"; -}; - -&gmac2phy { - phy-supply = <&vcc_phy>; - clock_in_out = "output"; - assigned-clock-rate = <50000000>; - assigned-clocks = <&cru SCLK_MAC2PHY>; - assigned-clock-parents = <&cru SCLK_MAC2PHY_SRC>; - status = "okay"; -}; - -&i2c1 { - status = "okay"; - - rk805: pmic@18 { - compatible = "rockchip,rk805"; - reg = <0x18>; - interrupt-parent = <&gpio2>; - interrupts = <6 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk805-clkout2"; - gpio-controller; - #gpio-cells = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_io>; - vcc6-supply = <&vcc_io>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <950000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_18: LDO_REG1 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_emmc: LDO_REG2 { - regulator-name = "vcc18_emmc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - }; - }; -}; - -&pinctrl { - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = - <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdio { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - max-frequency = <150000000>; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>; - vmmc-supply = <&vcc_sd>; - status = "okay"; -}; - -&tsadc { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&u2phy { - status = "okay"; -}; - -&u2phy_host { - status = "okay"; -}; - -&u2phy_otg { - status = "okay"; -}; - -&usb20_otg { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328-nanopi-r2c-plus.dts b/arch/arm/dts/rk3328-nanopi-r2c-plus.dts deleted file mode 100644 index 16a1958e4572..000000000000 --- a/arch/arm/dts/rk3328-nanopi-r2c-plus.dts +++ /dev/null @@ -1,33 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/* - * Copyright (c) 2021 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyarm.com) - * - * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com - */ - -/dts-v1/; -#include "rk3328-nanopi-r2c.dts" - -/ { - model = "FriendlyElec NanoPi R2C Plus"; - compatible = "friendlyarm,nanopi-r2c-plus", "rockchip,rk3328"; - - aliases { - mmc1 = &emmc; - }; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - max-frequency = <150000000>; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; - vmmc-supply = <&vcc_io_33>; - vqmmc-supply = <&vcc18_emmc>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328-nanopi-r2c.dts b/arch/arm/dts/rk3328-nanopi-r2c.dts deleted file mode 100644 index a07a26b944a0..000000000000 --- a/arch/arm/dts/rk3328-nanopi-r2c.dts +++ /dev/null @@ -1,40 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/* - * Copyright (c) 2021 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyarm.com) - * - * Copyright (c) 2021-2023 Tianling Shen cnsztl@gmail.com - */ - -/dts-v1/; -#include "rk3328-nanopi-r2s.dts" - -/ { - model = "FriendlyElec NanoPi R2C"; - compatible = "friendlyarm,nanopi-r2c", "rockchip,rk3328"; -}; - -&gmac2io { - phy-handle = <&yt8521s>; - tx_delay = <0x22>; - rx_delay = <0x12>; - - mdio { - /delete-node/ ethernet-phy@1; - - yt8521s: ethernet-phy@3 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <3>; - - motorcomm,clk-out-frequency-hz = <125000000>; - motorcomm,keep-pll-enabled; - motorcomm,auto-sleep-disabled; - - pinctrl-0 = <ð_phy_reset_pin>; - pinctrl-names = "default"; - reset-assert-us = <10000>; - reset-deassert-us = <50000>; - reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - }; - }; -}; diff --git a/arch/arm/dts/rk3328-nanopi-r2s.dts b/arch/arm/dts/rk3328-nanopi-r2s.dts deleted file mode 100644 index a4399da7d8b1..000000000000 --- a/arch/arm/dts/rk3328-nanopi-r2s.dts +++ /dev/null @@ -1,410 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 David Bauer mail@david-bauer.net - */ - -/dts-v1/; - -#include <dt-bindings/input/input.h> -#include <dt-bindings/gpio/gpio.h> -#include "rk3328.dtsi" - -/ { - model = "FriendlyElec NanoPi R2S"; - compatible = "friendlyarm,nanopi-r2s", "rockchip,rk3328"; - - aliases { - ethernet0 = &gmac2io; - ethernet1 = &rtl8153; - mmc0 = &sdmmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac_clk: gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac_clkin"; - #clock-cells = <0>; - }; - - keys { - compatible = "gpio-keys"; - pinctrl-0 = <&reset_button_pin>; - pinctrl-names = "default"; - - key-reset { - label = "reset"; - gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_LOW>; - linux,code = <KEY_RESTART>; - debounce-interval = <50>; - }; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>; - pinctrl-names = "default"; - - lan_led: led-0 { - gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; - label = "nanopi-r2s:green:lan"; - }; - - sys_led: led-1 { - gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; - label = "nanopi-r2s:red:sys"; - default-state = "on"; - }; - - wan_led: led-2 { - gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_HIGH>; - label = "nanopi-r2s:green:wan"; - }; - }; - - vcc_io_sdio: sdmmcio-regulator { - compatible = "regulator-gpio"; - enable-active-high; - gpios = <&gpio1 RK_PD4 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&sdio_vcc_pin>; - pinctrl-names = "default"; - regulator-name = "vcc_io_sdio"; - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-settling-time-us = <5000>; - regulator-type = "voltage"; - startup-delay-us = <2000>; - states = <1800000 0x1>, - <3300000 0x0>; - vin-supply = <&vcc_io_33>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; - pinctrl-0 = <&sdmmc0m1_pin>; - pinctrl-names = "default"; - regulator-name = "vcc_sd"; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_io_33>; - }; - - vdd_5v: vdd-5v { - compatible = "regulator-fixed"; - regulator-name = "vdd_5v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vdd_5v_lan: vdd-5v-lan { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PC6 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&lan_vdd_pin>; - pinctrl-names = "default"; - regulator-name = "vdd_5v_lan"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vdd_5v>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; - -&display_subsystem { - status = "disabled"; -}; - -&gmac2io { - assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; - assigned-clock-parents = <&gmac_clk>, <&gmac_clk>; - clock_in_out = "input"; - phy-handle = <&rtl8211e>; - phy-mode = "rgmii"; - phy-supply = <&vcc_io_33>; - pinctrl-0 = <&rgmiim1_pins>; - pinctrl-names = "default"; - rx_delay = <0x18>; - snps,aal; - tx_delay = <0x24>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - rtl8211e: ethernet-phy@1 { - reg = <1>; - pinctrl-0 = <ð_phy_reset_pin>; - pinctrl-names = "default"; - reset-assert-us = <10000>; - reset-deassert-us = <50000>; - reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&i2c1 { - status = "okay"; - - rk805: pmic@18 { - compatible = "rockchip,rk805"; - reg = <0x18>; - interrupt-parent = <&gpio1>; - interrupts = <24 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk805-clkout2"; - gpio-controller; - #gpio-cells = <2>; - pinctrl-0 = <&pmic_int_l>; - pinctrl-names = "default"; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vdd_5v>; - vcc2-supply = <&vdd_5v>; - vcc3-supply = <&vdd_5v>; - vcc4-supply = <&vdd_5v>; - vcc5-supply = <&vcc_io_33>; - vcc6-supply = <&vdd_5v>; - - regulators { - vdd_log: DCDC_REG1 { - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <950000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io_33: DCDC_REG4 { - regulator-name = "vcc_io_33"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_18: LDO_REG1 { - regulator-name = "vcc_18"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_emmc: LDO_REG2 { - regulator-name = "vcc18_emmc"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - }; - }; -}; - -&io_domains { - pmuio-supply = <&vcc_io_33>; - vccio1-supply = <&vcc_io_33>; - vccio2-supply = <&vcc18_emmc>; - vccio3-supply = <&vcc_io_sdio>; - vccio4-supply = <&vcc_18>; - vccio5-supply = <&vcc_io_33>; - vccio6-supply = <&vcc_io_33>; - status = "okay"; -}; - -&pinctrl { - button { - reset_button_pin: reset-button-pin { - rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - gmac2io { - eth_phy_reset_pin: eth-phy-reset-pin { - rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - leds { - lan_led_pin: lan-led-pin { - rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - sys_led_pin: sys-led-pin { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wan_led_pin: wan-led-pin { - rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lan { - lan_vdd_pin: lan-vdd-pin { - rockchip,pins = <2 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sd { - sdio_vcc_pin: sdio-vcc-pin { - rockchip,pins = <1 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&pwm2 { - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - disable-wp; - pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>; - pinctrl-names = "default"; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vcc_io_sdio>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&u2phy { - status = "okay"; -}; - -&u2phy_host { - status = "okay"; -}; - -&u2phy_otg { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb20_otg { - status = "okay"; - dr_mode = "host"; -}; - -&usbdrd3 { - dr_mode = "host"; - status = "okay"; - #address-cells = <1>; - #size-cells = <0>; - - /* Second port is for USB 3.0 */ - rtl8153: device@2 { - compatible = "usbbda,8153"; - reg = <2>; - }; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts b/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts deleted file mode 100644 index 4237f2ee8fee..000000000000 --- a/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts +++ /dev/null @@ -1,42 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/* - * Copyright (c) 2016 Xunlong Software. Co., Ltd. - * (http://www.orangepi.org) - * - * Copyright (c) 2021-2023 Tianling Shen cnsztl@gmail.com - */ - -/dts-v1/; -#include "rk3328-orangepi-r1-plus.dts" - -/ { - model = "Xunlong Orange Pi R1 Plus LTS"; - compatible = "xunlong,orangepi-r1-plus-lts", "rockchip,rk3328"; -}; - -&gmac2io { - phy-handle = <&yt8531c>; - tx_delay = <0x19>; - rx_delay = <0x05>; - - mdio { - /delete-node/ ethernet-phy@1; - - yt8531c: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - - motorcomm,auto-sleep-disabled; - motorcomm,clk-out-frequency-hz = <125000000>; - motorcomm,keep-pll-enabled; - motorcomm,rx-clk-drv-microamp = <5020>; - motorcomm,rx-data-drv-microamp = <5020>; - - pinctrl-0 = <ð_phy_reset_pin>; - pinctrl-names = "default"; - reset-assert-us = <15000>; - reset-deassert-us = <50000>; - reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - }; - }; -}; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus.dts b/arch/arm/dts/rk3328-orangepi-r1-plus.dts deleted file mode 100644 index f20662929c77..000000000000 --- a/arch/arm/dts/rk3328-orangepi-r1-plus.dts +++ /dev/null @@ -1,374 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Based on rk3328-nanopi-r2s.dts, which is: - * Copyright (c) 2020 David Bauer mail@david-bauer.net - */ - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include "rk3328.dtsi" - -/ { - model = "Xunlong Orange Pi R1 Plus"; - compatible = "xunlong,orangepi-r1-plus", "rockchip,rk3328"; - - aliases { - ethernet0 = &gmac2io; - ethernet1 = &rtl8153; - mmc0 = &sdmmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac_clk: gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac_clkin"; - #clock-cells = <0>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>; - pinctrl-names = "default"; - - led-0 { - function = LED_FUNCTION_LAN; - color = <LED_COLOR_ID_GREEN>; - gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; - }; - - led-1 { - function = LED_FUNCTION_STATUS; - color = <LED_COLOR_ID_RED>; - gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - }; - - led-2 { - function = LED_FUNCTION_WAN; - color = <LED_COLOR_ID_GREEN>; - gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_HIGH>; - }; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; - pinctrl-0 = <&sdmmc0m1_pin>; - pinctrl-names = "default"; - regulator-name = "vcc_sd"; - regulator-boot-on; - vin-supply = <&vcc_io>; - }; - - vcc_sys: vcc-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vdd_5v_lan: vdd-5v-lan-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PC6 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&lan_vdd_pin>; - pinctrl-names = "default"; - regulator-name = "vdd_5v_lan"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; - -&display_subsystem { - status = "disabled"; -}; - -&gmac2io { - assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; - assigned-clock-parents = <&gmac_clk>, <&gmac_clk>; - clock_in_out = "input"; - phy-handle = <&rtl8211e>; - phy-mode = "rgmii"; - phy-supply = <&vcc_io>; - pinctrl-0 = <&rgmiim1_pins>; - pinctrl-names = "default"; - snps,aal; - rx_delay = <0x18>; - tx_delay = <0x24>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - rtl8211e: ethernet-phy@1 { - reg = <1>; - pinctrl-0 = <ð_phy_reset_pin>; - pinctrl-names = "default"; - reset-assert-us = <10000>; - reset-deassert-us = <50000>; - reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&i2c1 { - status = "okay"; - - rk805: pmic@18 { - compatible = "rockchip,rk805"; - reg = <0x18>; - interrupt-parent = <&gpio1>; - interrupts = <24 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk805-clkout2"; - gpio-controller; - #gpio-cells = <2>; - pinctrl-0 = <&pmic_int_l>; - pinctrl-names = "default"; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_io>; - vcc6-supply = <&vcc_sys>; - - regulators { - vdd_log: DCDC_REG1 { - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <950000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_18: LDO_REG1 { - regulator-name = "vcc_18"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_emmc: LDO_REG2 { - regulator-name = "vcc18_emmc"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - }; - }; -}; - -&io_domains { - pmuio-supply = <&vcc_io>; - vccio1-supply = <&vcc_io>; - vccio2-supply = <&vcc18_emmc>; - vccio3-supply = <&vcc_io>; - vccio4-supply = <&vcc_io>; - vccio5-supply = <&vcc_io>; - vccio6-supply = <&vcc_io>; - status = "okay"; -}; - -&pinctrl { - gmac2io { - eth_phy_reset_pin: eth-phy-reset-pin { - rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - leds { - lan_led_pin: lan-led-pin { - rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - sys_led_pin: sys-led-pin { - rockchip,pins = <3 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wan_led_pin: wan-led-pin { - rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lan { - lan_vdd_pin: lan-vdd-pin { - rockchip,pins = <2 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&pwm2 { - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - disable-wp; - pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>; - pinctrl-names = "default"; - vmmc-supply = <&vcc_sd>; - status = "okay"; -}; - -&spi0 { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <50000000>; - }; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&u2phy { - status = "okay"; -}; - -&u2phy_host { - status = "okay"; -}; - -&u2phy_otg { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb20_otg { - dr_mode = "host"; - status = "okay"; -}; - -&usbdrd3 { - dr_mode = "host"; - status = "okay"; - #address-cells = <1>; - #size-cells = <0>; - - /* Second port is for USB 3.0 */ - rtl8153: device@2 { - compatible = "usbbda,8153"; - reg = <2>; - }; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328-roc-cc.dts b/arch/arm/dts/rk3328-roc-cc.dts deleted file mode 100644 index 414897a57e75..000000000000 --- a/arch/arm/dts/rk3328-roc-cc.dts +++ /dev/null @@ -1,384 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd - */ - -/dts-v1/; -#include "rk3328.dtsi" - -/ { - model = "Firefly roc-rk3328-cc"; - compatible = "firefly,roc-rk3328-cc", "rockchip,rk3328"; - - aliases { - ethernet0 = &gmac2io; - mmc0 = &sdmmc; - mmc1 = &emmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac_clkin: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac_clkin"; - #clock-cells = <0>; - }; - - dc_12v: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_pin>; - regulator-boot-on; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_io>; - }; - - vcc_sdio: sdmmcio-regulator { - compatible = "regulator-gpio"; - gpios = <&grf_gpio 0 GPIO_ACTIVE_HIGH>; - states = <1800000 0x1>, - <3300000 0x0>; - regulator-name = "vcc_sdio"; - regulator-type = "voltage"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc_host1_5v: vcc_otg_5v: vcc-host1-5v-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PD2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb20_host_drv>; - regulator-name = "vcc_host1_5v"; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vcc_phy: vcc-phy-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; - regulator-always-on; - regulator-boot-on; - }; - - leds { - compatible = "gpio-leds"; - - power_led: led-0 { - label = "firefly:blue:power"; - linux,default-trigger = "heartbeat"; - gpios = <&rk805 1 GPIO_ACTIVE_LOW>; - default-state = "on"; - }; - - user_led: led-1 { - label = "firefly:yellow:user"; - linux,default-trigger = "mmc1"; - gpios = <&rk805 0 GPIO_ACTIVE_LOW>; - default-state = "off"; - }; - }; -}; - -&analog_sound { - status = "okay"; -}; - -&codec { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - max-frequency = <150000000>; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc18_emmc>; - status = "okay"; -}; - -&gmac2io { - assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; - assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>; - clock_in_out = "input"; - phy-supply = <&vcc_phy>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmiim1_pins>; - snps,aal; - snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - snps,rxpbl = <0x4>; - snps,txpbl = <0x4>; - tx_delay = <0x24>; - rx_delay = <0x18>; - status = "okay"; -}; - -&hdmi { - status = "okay"; -}; - -&hdmiphy { - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c1 { - status = "okay"; - - rk805: pmic@18 { - compatible = "rockchip,rk805"; - reg = <0x18>; - interrupt-parent = <&gpio1>; - interrupts = <24 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk805-clkout2"; - gpio-controller; - #gpio-cells = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_io>; - vcc6-supply = <&vcc_io>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <950000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_18: LDO_REG1 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_emmc: LDO_REG2 { - regulator-name = "vcc18_emmc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - }; - }; -}; - -&i2s0 { - status = "okay"; -}; - -&i2s1 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - vccio1-supply = <&vcc_io>; - vccio2-supply = <&vcc18_emmc>; - vccio3-supply = <&vcc_sdio>; - vccio4-supply = <&vcc_18>; - vccio5-supply = <&vcc_io>; - vccio6-supply = <&vcc_io>; - pmuio-supply = <&vcc_io>; -}; - -&pinctrl { - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - usb20_host_drv: usb20-host-drv { - rockchip,pins = <1 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - vmmc-supply = <&vcc_sd>; - vqmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&tsadc { - status = "okay"; -}; - -&u2phy { - status = "okay"; -}; - -&u2phy_host { - status = "okay"; -}; - -&u2phy_otg { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb20_otg { - dr_mode = "host"; - status = "okay"; -}; - -&usbdrd3 { - dr_mode = "host"; - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&vop { - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328-rock-pi-e.dts b/arch/arm/dts/rk3328-rock-pi-e.dts deleted file mode 100644 index 3cda6c627b68..000000000000 --- a/arch/arm/dts/rk3328-rock-pi-e.dts +++ /dev/null @@ -1,445 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * (C) Copyright 2020 Chen-Yu Tsai wens@csie.org - * - * Based on ./rk3328-rock64.dts, which is - * - * Copyright (c) 2017 PINE64 - */ - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> - -#include "rk3328.dtsi" - -/ { - model = "Radxa ROCK Pi E"; - compatible = "radxa,rockpi-e", "rockchip,rk3328"; - - aliases { - ethernet0 = &gmac2io; - ethernet1 = &gmac2phy; - mmc0 = &sdmmc; - mmc1 = &emmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 0>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1750000>; - - /* This button is unpopulated out of the factory. */ - button-recovery { - label = "Recovery"; - linux,code = <KEY_VENDOR>; - press-threshold-microvolt = <10000>; - }; - }; - - gmac_clkin: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac_clkin"; - #clock-cells = <0>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-0 = <&led_pin>; - pinctrl-names = "default"; - - led-0 { - color = <LED_COLOR_ID_BLUE>; - gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_LOW>; - linux,default-trigger = "heartbeat"; - }; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_pin>; - regulator-name = "vcc_sd"; - regulator-boot-on; - vin-supply = <&vcc_io>; - }; - - vcc_host_5v: vcc-host-5v-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb30_host_drv>; - enable-active-high; - regulator-name = "vcc_host_5v"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc_wifi: vcc-wifi-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_en>; - regulator-name = "vcc_wifi"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_io>; - }; -}; - -&analog_sound { - status = "okay"; -}; - -&codec { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - mmc-ddr-1_8v; - mmc-hs200-1_8v; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc18_emmc>; - status = "okay"; -}; - -&gmac2io { - assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; - assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>; - clock_in_out = "input"; - phy-handle = <&rtl8211e>; - phy-mode = "rgmii"; - phy-supply = <&vcc_io>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmiim1_pins>; - snps,aal; - snps,rxpbl = <0x4>; - snps,txpbl = <0x4>; - tx_delay = <0x26>; - rx_delay = <0x11>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - rtl8211e: ethernet-phy@1 { - reg = <1>; - pinctrl-0 = <ð_phy_int_pin>, <ð_phy_reset_pin>; - pinctrl-names = "default"; - interrupt-parent = <&gpio1>; - interrupts = <24 IRQ_TYPE_LEVEL_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <50000>; - reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&gmac2phy { - status = "okay"; -}; - -&gpio0 { - gpio-line-names = - /* GPIO0_A0 - A7 */ - "", "", "", "", "", "", "", "", - /* GPIO0_B0 - B7 */ - "", "", "", "", "", "", "", "", - /* GPIO0_C0 - C7 */ - "", "", "", "", "", "", "", "", - /* GPIO0_D0 - D7 */ - "", "", "", "pin-15 [GPIO0_D3]", "", "", "", ""; -}; - -&gpio1 { - gpio-line-names = - /* GPIO1_A0 - A7 */ - "", "", "", "", "", "", "", "", - /* GPIO1_B0 - B7 */ - "", "", "", "", "", "", "", "", - /* GPIO1_C0 - C7 */ - "", "", "", "", "", "", "", "", - /* GPIO1_D0 - D7 */ - "", "", "", "", "pin-07 [GPIO1_D4]", "", "", ""; -}; - -&gpio2 { - gpio-line-names = - /* GPIO2_A0 - A7 */ - "pin-08 [GPIO2_A0]", "pin-10 [GPIO2_A1]", "pin-11 [GPIO2_A2]", - "pin-13 [GPIO2-A3]", "pin-27 [GPIO2_A4]", "pin-28 [GPIO2_A5]", - "pin-33 [GPIO2_A6]", "", - /* GPIO2_B0 - B7 */ - "", "", "", "", "pin-26 [GPIO2_B4]", "", "", "pin-36 [GPIO2_B7]", - /* GPIO2_C0 - C7 */ - "pin-32 [GPIO2_C0]", "pin-35 [GPIO2_C1]", "pin-12 [GPIO2_C2]", - "pin-38 [GPIO2_C3]", "pin-29 [GPIO2_C4]", "pin-31 [GPIO2_C5]", - "pin-37 [GPIO2_C6]", "pin-40 [GPIO2_C7]", - /* GPIO2_D0 - D7 */ - "", "", "", "", "", "", "", ""; -}; - -&gpio3 { - gpio-line-names = - /* GPIO3_A0 - A7 */ - "pin-23 [GPIO3_A0]", "pin-19 [GPIO3_A1]", "pin-21 [GPIO3_A2]", - "", "pin-03 [GPIO3_A4]", "", "pin-05 [GPIO3_A6]", "", - /* GPIO3_B0 - B7 */ - "pin-24 [GPIO3_B0]", "", "", "", "", "", "", "", - /* GPIO3_C0 - C7 */ - "", "", "", "", "", "", "", "", - /* GPIO3_D0 - D7 */ - "", "", "", "", "", "", "", ""; -}; - -&i2c1 { - status = "okay"; - - rk805: pmic@18 { - compatible = "rockchip,rk805"; - reg = <0x18>; - interrupt-parent = <&gpio2>; - interrupts = <6 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk805-clkout2"; - gpio-controller; - #gpio-cells = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_io>; - vcc6-supply = <&vcc_sys>; - - regulators { - vdd_log: DCDC_REG1 { - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <950000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_18: LDO_REG1 { - regulator-name = "vcc_18"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_emmc: LDO_REG2 { - regulator-name = "vcc18_emmc"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - }; - }; -}; - -&i2s1 { - status = "okay"; -}; - -&io_domains { - pmuio-supply = <&vcc_io>; - vccio1-supply = <&vcc_io>; - vccio2-supply = <&vcc18_emmc>; - vccio3-supply = <&vcc_io>; - vccio4-supply = <&vcc_io>; - vccio5-supply = <&vcc_io>; - vccio6-supply = <&vcc_io>; - status = "okay"; -}; - -&pinctrl { - ephy { - eth_phy_int_pin: eth-phy-int-pin { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - eth_phy_reset_pin: eth-phy-reset-pin { - rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - leds { - led_pin: led-pin { - rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb3 { - usb30_host_drv: usb30-host-drv { - rockchip,pins = <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_en: wifi-en { - rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>; - vmmc-supply = <&vcc_sd>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc_18>; - status = "okay"; -}; - -&tsadc { - status = "okay"; -}; - -&u2phy { - status = "okay"; -}; - -&u2phy_host { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usbdrd3 { - dr_mode = "host"; - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328-rock64.dts b/arch/arm/dts/rk3328-rock64.dts deleted file mode 100644 index 229fe9da9c2d..000000000000 --- a/arch/arm/dts/rk3328-rock64.dts +++ /dev/null @@ -1,394 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 PINE64 - */ - -/dts-v1/; -#include "rk3328.dtsi" - -/ { - model = "Pine64 Rock64"; - compatible = "pine64,rock64", "rockchip,rk3328"; - - aliases { - ethernet0 = &gmac2io; - mmc0 = &sdmmc; - mmc1 = &emmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac_clkin: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac_clkin"; - #clock-cells = <0>; - }; - - vcc_sd: sdmmc-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0m1_pin>; - regulator-name = "vcc_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_io>; - }; - - /* Common enable line for all of the rails mentioned in the labels */ - vcc_host_5v: vcc_host1_5v: vcc_otg_5v: vcc-host-5v-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&usb20_host_drv>; - regulator-name = "vcc_host_5v"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_LOW>; - pinctrl-0 = <&ir_int>; - pinctrl-names = "default"; - }; - - leds { - compatible = "gpio-leds"; - - power_led: led-0 { - gpios = <&rk805 1 GPIO_ACTIVE_LOW>; - linux,default-trigger = "mmc0"; - }; - - standby_led: led-1 { - gpios = <&rk805 0 GPIO_ACTIVE_LOW>; - linux,default-trigger = "heartbeat"; - }; - }; - - spdif_sound: spdif-sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "SPDIF"; - - simple-audio-card,cpu { - sound-dai = <&spdif>; - }; - - simple-audio-card,codec { - sound-dai = <&spdif_dit>; - }; - }; - - spdif_dit: spdif-dit { - compatible = "linux,spdif-dit"; - #sound-dai-cells = <0>; - }; -}; - -&analog_sound { - status = "okay"; -}; - -&codec { - mute-gpios = <&grf_gpio 0 GPIO_ACTIVE_LOW>; - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_arm>; -}; - -&cpu1 { - cpu-supply = <&vdd_arm>; -}; - -&cpu2 { - cpu-supply = <&vdd_arm>; -}; - -&cpu3 { - cpu-supply = <&vdd_arm>; -}; - -&emmc { - bus-width = <8>; - cap-mmc-highspeed; - mmc-hs200-1_8v; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>; - vmmc-supply = <&vcc_io>; - vqmmc-supply = <&vcc18_emmc>; - status = "okay"; -}; - -&gmac2io { - assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>; - assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>; - clock_in_out = "input"; - phy-supply = <&vcc_io>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmiim1_pins>; - snps,force_thresh_dma_mode; - snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x24>; - rx_delay = <0x18>; - status = "okay"; -}; - -&hdmi { - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&hdmiphy { - status = "okay"; -}; - -&i2c1 { - status = "okay"; - - rk805: pmic@18 { - compatible = "rockchip,rk805"; - reg = <0x18>; - interrupt-parent = <&gpio2>; - interrupts = <6 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk805-clkout2"; - gpio-controller; - #gpio-cells = <2>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_io>; - vcc6-supply = <&vcc_sys>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - - vdd_arm: DCDC_REG2 { - regulator-name = "vdd_arm"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1450000>; - regulator-ramp-delay = <12500>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <950000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_io: DCDC_REG4 { - regulator-name = "vcc_io"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_18: LDO_REG1 { - regulator-name = "vcc_18"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc18_emmc: LDO_REG2 { - regulator-name = "vcc18_emmc"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdd_10: LDO_REG3 { - regulator-name = "vdd_10"; - regulator-min-microvolt = <1000000>; - regulator-max-microvolt = <1000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1000000>; - }; - }; - }; - }; -}; - -&i2s0 { - status = "okay"; -}; - -&i2s1 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - vccio1-supply = <&vcc_io>; - vccio2-supply = <&vcc18_emmc>; - vccio3-supply = <&vcc_io>; - vccio4-supply = <&vcc_18>; - vccio5-supply = <&vcc_io>; - vccio6-supply = <&vcc_io>; - pmuio-supply = <&vcc_io>; -}; - -&pinctrl { - ir { - ir_int: ir-int { - rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - usb20_host_drv: usb20-host-drv { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>; - vmmc-supply = <&vcc_sd>; - status = "okay"; -}; - -&spdif { - pinctrl-0 = <&spdifm0_tx>; - status = "okay"; -}; - -&spi0 { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - - /* maximum speed for Rockchip SPI */ - spi-max-frequency = <50000000>; - }; -}; - -&tsadc { - rockchip,hw-tshut-mode = <0>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&u2phy { - status = "okay"; - - u2phy_host: host-port { - status = "okay"; - }; - - u2phy_otg: otg-port { - status = "okay"; - }; -}; - -&usb20_otg { - dr_mode = "host"; - status = "okay"; -}; - -&usbdrd3 { - dr_mode = "host"; - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&vop { - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3328.dtsi b/arch/arm/dts/rk3328.dtsi deleted file mode 100644 index fb5dcf6e9327..000000000000 --- a/arch/arm/dts/rk3328.dtsi +++ /dev/null @@ -1,1944 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd - */ - -#include <dt-bindings/clock/rk3328-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rk3328-power.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - compatible = "rockchip,rk3328"; - - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - }; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x0>; - clocks = <&cru ARMCLK>; - #cooling-cells = <2>; - cpu-idle-states = <&CPU_SLEEP>; - dynamic-power-coefficient = <120>; - enable-method = "psci"; - next-level-cache = <&l2>; - operating-points-v2 = <&cpu0_opp_table>; - }; - - cpu1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x1>; - clocks = <&cru ARMCLK>; - #cooling-cells = <2>; - cpu-idle-states = <&CPU_SLEEP>; - dynamic-power-coefficient = <120>; - enable-method = "psci"; - next-level-cache = <&l2>; - operating-points-v2 = <&cpu0_opp_table>; - }; - - cpu2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x2>; - clocks = <&cru ARMCLK>; - #cooling-cells = <2>; - cpu-idle-states = <&CPU_SLEEP>; - dynamic-power-coefficient = <120>; - enable-method = "psci"; - next-level-cache = <&l2>; - operating-points-v2 = <&cpu0_opp_table>; - }; - - cpu3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x3>; - clocks = <&cru ARMCLK>; - #cooling-cells = <2>; - cpu-idle-states = <&CPU_SLEEP>; - dynamic-power-coefficient = <120>; - enable-method = "psci"; - next-level-cache = <&l2>; - operating-points-v2 = <&cpu0_opp_table>; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP: cpu-sleep { - compatible = "arm,idle-state"; - local-timer-stop; - arm,psci-suspend-param = <0x0010000>; - entry-latency-us = <120>; - exit-latency-us = <250>; - min-residency-us = <900>; - }; - }; - - l2: l2-cache0 { - compatible = "cache"; - cache-level = <2>; - cache-unified; - }; - }; - - cpu0_opp_table: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-408000000 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <950000>; - clock-latency-ns = <40000>; - opp-suspend; - }; - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <950000>; - clock-latency-ns = <40000>; - }; - opp-816000000 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <1000000>; - clock-latency-ns = <40000>; - }; - opp-1008000000 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <1100000>; - clock-latency-ns = <40000>; - }; - opp-1200000000 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <1225000>; - clock-latency-ns = <40000>; - }; - opp-1296000000 { - opp-hz = /bits/ 64 <1296000000>; - opp-microvolt = <1300000>; - clock-latency-ns = <40000>; - }; - }; - - analog_sound: analog-sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - simple-audio-card,name = "Analog"; - status = "disabled"; - - simple-audio-card,cpu { - sound-dai = <&i2s1>; - }; - - simple-audio-card,codec { - sound-dai = <&codec>; - }; - }; - - arm-pmu { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - display_subsystem: display-subsystem { - compatible = "rockchip,display-subsystem"; - ports = <&vop_out>; - }; - - hdmi_sound: hdmi-sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <128>; - simple-audio-card,name = "HDMI"; - status = "disabled"; - - simple-audio-card,cpu { - sound-dai = <&i2s0>; - }; - - simple-audio-card,codec { - sound-dai = <&hdmi>; - }; - }; - - psci { - compatible = "arm,psci-1.0", "arm,psci-0.2"; - method = "smc"; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>, - <GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>; - }; - - xin24m: xin24m { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24000000>; - clock-output-names = "xin24m"; - }; - - i2s0: i2s@ff000000 { - compatible = "rockchip,rk3328-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff000000 0x0 0x1000>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0_8CH>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac 11>, <&dmac 12>; - dma-names = "tx", "rx"; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s1: i2s@ff010000 { - compatible = "rockchip,rk3328-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff010000 0x0 0x1000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac 14>, <&dmac 15>; - dma-names = "tx", "rx"; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s2: i2s@ff020000 { - compatible = "rockchip,rk3328-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff020000 0x0 0x1000>; - interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2_2CH>; - clock-names = "i2s_clk", "i2s_hclk"; - dmas = <&dmac 0>, <&dmac 1>; - dma-names = "tx", "rx"; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - spdif: spdif@ff030000 { - compatible = "rockchip,rk3328-spdif"; - reg = <0x0 0xff030000 0x0 0x1000>; - interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_SPDIF>, <&cru HCLK_SPDIF_8CH>; - clock-names = "mclk", "hclk"; - dmas = <&dmac 10>; - dma-names = "tx"; - pinctrl-names = "default"; - pinctrl-0 = <&spdifm2_tx>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - pdm: pdm@ff040000 { - compatible = "rockchip,pdm"; - reg = <0x0 0xff040000 0x0 0x1000>; - clocks = <&cru SCLK_PDM>, <&cru HCLK_PDM>; - clock-names = "pdm_clk", "pdm_hclk"; - dmas = <&dmac 16>; - dma-names = "rx"; - pinctrl-names = "default", "sleep"; - pinctrl-0 = <&pdmm0_clk - &pdmm0_sdi0 - &pdmm0_sdi1 - &pdmm0_sdi2 - &pdmm0_sdi3>; - pinctrl-1 = <&pdmm0_clk_sleep - &pdmm0_sdi0_sleep - &pdmm0_sdi1_sleep - &pdmm0_sdi2_sleep - &pdmm0_sdi3_sleep>; - status = "disabled"; - }; - - grf: syscon@ff100000 { - compatible = "rockchip,rk3328-grf", "syscon", "simple-mfd"; - reg = <0x0 0xff100000 0x0 0x1000>; - - io_domains: io-domains { - compatible = "rockchip,rk3328-io-voltage-domain"; - status = "disabled"; - }; - - grf_gpio: gpio { - compatible = "rockchip,rk3328-grf-gpio"; - gpio-controller; - #gpio-cells = <2>; - }; - - power: power-controller { - compatible = "rockchip,rk3328-power-controller"; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - power-domain@RK3328_PD_HEVC { - reg = <RK3328_PD_HEVC>; - #power-domain-cells = <0>; - }; - power-domain@RK3328_PD_VIDEO { - reg = <RK3328_PD_VIDEO>; - clocks = <&cru ACLK_RKVDEC>, - <&cru HCLK_RKVDEC>, - <&cru SCLK_VDEC_CABAC>, - <&cru SCLK_VDEC_CORE>; - #power-domain-cells = <0>; - }; - power-domain@RK3328_PD_VPU { - reg = <RK3328_PD_VPU>; - clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; - #power-domain-cells = <0>; - }; - }; - - reboot-mode { - compatible = "syscon-reboot-mode"; - offset = <0x5c8>; - mode-normal = <BOOT_NORMAL>; - mode-recovery = <BOOT_RECOVERY>; - mode-bootloader = <BOOT_FASTBOOT>; - mode-loader = <BOOT_BL_DOWNLOAD>; - }; - }; - - uart0: serial@ff110000 { - compatible = "rockchip,rk3328-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff110000 0x0 0x100>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 2>, <&dmac 3>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart1: serial@ff120000 { - compatible = "rockchip,rk3328-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff120000 0x0 0x100>; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 4>, <&dmac 5>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart1_xfer &uart1_cts &uart1_rts>; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart2: serial@ff130000 { - compatible = "rockchip,rk3328-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff130000 0x0 0x100>; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac 6>, <&dmac 7>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&uart2m1_xfer>; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - i2c0: i2c@ff150000 { - compatible = "rockchip,rk3328-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff150000 0x0 0x1000>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_I2C0>, <&cru PCLK_I2C0>; - clock-names = "i2c", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_xfer>; - status = "disabled"; - }; - - i2c1: i2c@ff160000 { - compatible = "rockchip,rk3328-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff160000 0x0 0x1000>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>; - clock-names = "i2c", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_xfer>; - status = "disabled"; - }; - - i2c2: i2c@ff170000 { - compatible = "rockchip,rk3328-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff170000 0x0 0x1000>; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>; - clock-names = "i2c", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_xfer>; - status = "disabled"; - }; - - i2c3: i2c@ff180000 { - compatible = "rockchip,rk3328-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xff180000 0x0 0x1000>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>; - clock-names = "i2c", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_xfer>; - status = "disabled"; - }; - - spi0: spi@ff190000 { - compatible = "rockchip,rk3328-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff190000 0x0 0x1000>; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; - #address-cells = <1>; - #size-cells = <0>; - clocks = <&cru SCLK_SPI>, <&cru PCLK_SPI>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac 8>, <&dmac 9>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi0m2_clk &spi0m2_tx &spi0m2_rx &spi0m2_cs0>; - status = "disabled"; - }; - - wdt: watchdog@ff1a0000 { - compatible = "rockchip,rk3328-wdt", "snps,dw-wdt"; - reg = <0x0 0xff1a0000 0x0 0x100>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_WDT>; - }; - - pwm0: pwm@ff1b0000 { - compatible = "rockchip,rk3328-pwm"; - reg = <0x0 0xff1b0000 0x0 0x10>; - clocks = <&cru SCLK_PWM>, <&cru PCLK_PWM>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm1: pwm@ff1b0010 { - compatible = "rockchip,rk3328-pwm"; - reg = <0x0 0xff1b0010 0x0 0x10>; - clocks = <&cru SCLK_PWM>, <&cru PCLK_PWM>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm1_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm2: pwm@ff1b0020 { - compatible = "rockchip,rk3328-pwm"; - reg = <0x0 0xff1b0020 0x0 0x10>; - clocks = <&cru SCLK_PWM>, <&cru PCLK_PWM>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwm2_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm3: pwm@ff1b0030 { - compatible = "rockchip,rk3328-pwm"; - reg = <0x0 0xff1b0030 0x0 0x10>; - interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_PWM>, <&cru PCLK_PWM>; - clock-names = "pwm", "pclk"; - pinctrl-names = "default"; - pinctrl-0 = <&pwmir_pin>; - #pwm-cells = <3>; - status = "disabled"; - }; - - dmac: dma-controller@ff1f0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff1f0000 0x0 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC>; - clock-names = "apb_pclk"; - #dma-cells = <1>; - }; - - thermal-zones { - soc_thermal: soc-thermal { - polling-delay-passive = <20>; - polling-delay = <1000>; - sustainable-power = <1000>; - - thermal-sensors = <&tsadc 0>; - - trips { - threshold: trip-point0 { - temperature = <70000>; - hysteresis = <2000>; - type = "passive"; - }; - target: trip-point1 { - temperature = <85000>; - hysteresis = <2000>; - type = "passive"; - }; - soc_crit: soc-crit { - temperature = <95000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&target>; - cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - contribution = <4096>; - }; - }; - }; - - }; - - tsadc: tsadc@ff250000 { - compatible = "rockchip,rk3328-tsadc"; - reg = <0x0 0xff250000 0x0 0x100>; - interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>; - assigned-clocks = <&cru SCLK_TSADC>; - assigned-clock-rates = <50000>; - clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; - clock-names = "tsadc", "apb_pclk"; - pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&otp_pin>; - pinctrl-1 = <&otp_out>; - pinctrl-2 = <&otp_pin>; - resets = <&cru SRST_TSADC>; - reset-names = "tsadc-apb"; - rockchip,grf = <&grf>; - rockchip,hw-tshut-temp = <100000>; - #thermal-sensor-cells = <1>; - status = "disabled"; - }; - - efuse: efuse@ff260000 { - compatible = "rockchip,rk3328-efuse"; - reg = <0x0 0xff260000 0x0 0x50>; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&cru SCLK_EFUSE>; - clock-names = "pclk_efuse"; - rockchip,efuse-size = <0x20>; - - /* Data cells */ - efuse_id: id@7 { - reg = <0x07 0x10>; - }; - cpu_leakage: cpu-leakage@17 { - reg = <0x17 0x1>; - }; - logic_leakage: logic-leakage@19 { - reg = <0x19 0x1>; - }; - efuse_cpu_version: cpu-version@1a { - reg = <0x1a 0x1>; - bits = <3 3>; - }; - }; - - saradc: adc@ff280000 { - compatible = "rockchip,rk3328-saradc", "rockchip,rk3399-saradc"; - reg = <0x0 0xff280000 0x0 0x100>; - interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>; - #io-channel-cells = <1>; - clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; - clock-names = "saradc", "apb_pclk"; - resets = <&cru SRST_SARADC_P>; - reset-names = "saradc-apb"; - status = "disabled"; - }; - - gpu: gpu@ff300000 { - compatible = "rockchip,rk3328-mali", "arm,mali-450"; - reg = <0x0 0xff300000 0x0 0x30000>; - interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "gp", - "gpmmu", - "pp", - "pp0", - "ppmmu0", - "pp1", - "ppmmu1"; - clocks = <&cru ACLK_GPU>, <&cru ACLK_GPU>; - clock-names = "bus", "core"; - resets = <&cru SRST_GPU_A>; - }; - - h265e_mmu: iommu@ff330200 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff330200 0 0x100>; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_H265>, <&cru PCLK_H265>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - status = "disabled"; - }; - - vepu_mmu: iommu@ff340800 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff340800 0x0 0x40>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - status = "disabled"; - }; - - vpu: video-codec@ff350000 { - compatible = "rockchip,rk3328-vpu"; - reg = <0x0 0xff350000 0x0 0x800>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "vdpu"; - clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; - clock-names = "aclk", "hclk"; - iommus = <&vpu_mmu>; - power-domains = <&power RK3328_PD_VPU>; - }; - - vpu_mmu: iommu@ff350800 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff350800 0x0 0x40>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - power-domains = <&power RK3328_PD_VPU>; - }; - - vdec: video-codec@ff360000 { - compatible = "rockchip,rk3328-vdec", "rockchip,rk3399-vdec"; - reg = <0x0 0xff360000 0x0 0x480>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>, - <&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>; - clock-names = "axi", "ahb", "cabac", "core"; - assigned-clocks = <&cru ACLK_RKVDEC>, <&cru SCLK_VDEC_CABAC>, - <&cru SCLK_VDEC_CORE>; - assigned-clock-rates = <400000000>, <400000000>, <300000000>; - iommus = <&vdec_mmu>; - power-domains = <&power RK3328_PD_VIDEO>; - }; - - vdec_mmu: iommu@ff360480 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff360480 0x0 0x40>, <0x0 0xff3604c0 0x0 0x40>; - interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - power-domains = <&power RK3328_PD_VIDEO>; - }; - - vop: vop@ff370000 { - compatible = "rockchip,rk3328-vop"; - reg = <0x0 0xff370000 0x0 0x3efc>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP>, <&cru DCLK_LCDC>, <&cru HCLK_VOP>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - resets = <&cru SRST_VOP_A>, <&cru SRST_VOP_H>, <&cru SRST_VOP_D>; - reset-names = "axi", "ahb", "dclk"; - iommus = <&vop_mmu>; - status = "disabled"; - - vop_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vop_out_hdmi: endpoint@0 { - reg = <0>; - remote-endpoint = <&hdmi_in_vop>; - }; - }; - }; - - vop_mmu: iommu@ff373f00 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff373f00 0x0 0x100>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - status = "disabled"; - }; - - hdmi: hdmi@ff3c0000 { - compatible = "rockchip,rk3328-dw-hdmi"; - reg = <0x0 0xff3c0000 0x0 0x20000>; - reg-io-width = <4>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_HDMI>, - <&cru SCLK_HDMI_SFC>, - <&cru SCLK_RTC32K>; - clock-names = "iahb", - "isfr", - "cec"; - phys = <&hdmiphy>; - phy-names = "hdmi"; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec &hdmii2c_xfer &hdmi_hpd>; - rockchip,grf = <&grf>; - #sound-dai-cells = <0>; - status = "disabled"; - - ports { - hdmi_in: port { - hdmi_in_vop: endpoint { - remote-endpoint = <&vop_out_hdmi>; - }; - }; - }; - }; - - codec: codec@ff410000 { - compatible = "rockchip,rk3328-codec"; - reg = <0x0 0xff410000 0x0 0x1000>; - clocks = <&cru PCLK_ACODECPHY>, <&cru SCLK_I2S1>; - clock-names = "pclk", "mclk"; - rockchip,grf = <&grf>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - hdmiphy: phy@ff430000 { - compatible = "rockchip,rk3328-hdmi-phy"; - reg = <0x0 0xff430000 0x0 0x10000>; - interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_HDMIPHY>, <&xin24m>, <&cru DCLK_HDMIPHY>; - clock-names = "sysclk", "refoclk", "refpclk"; - clock-output-names = "hdmi_phy"; - #clock-cells = <0>; - nvmem-cells = <&efuse_cpu_version>; - nvmem-cell-names = "cpu-version"; - #phy-cells = <0>; - status = "disabled"; - }; - - cru: clock-controller@ff440000 { - compatible = "rockchip,rk3328-cru", "rockchip,cru", "syscon"; - reg = <0x0 0xff440000 0x0 0x1000>; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - assigned-clocks = - /* - * CPLL should run at 1200, but that is to high for - * the initial dividers of most of its children. - * We need set cpll child clk div first, - * and then set the cpll frequency. - */ - <&cru DCLK_LCDC>, <&cru SCLK_PDM>, - <&cru SCLK_RTC32K>, <&cru SCLK_UART0>, - <&cru SCLK_UART1>, <&cru SCLK_UART2>, - <&cru ACLK_BUS_PRE>, <&cru ACLK_PERI_PRE>, - <&cru ACLK_VIO_PRE>, <&cru ACLK_RGA_PRE>, - <&cru ACLK_VOP_PRE>, <&cru ACLK_RKVDEC_PRE>, - <&cru ACLK_RKVENC>, <&cru ACLK_VPU_PRE>, - <&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>, - <&cru SCLK_VENC_CORE>, <&cru SCLK_VENC_DSP>, - <&cru SCLK_SDIO>, <&cru SCLK_TSP>, - <&cru SCLK_WIFI>, <&cru ARMCLK>, - <&cru PLL_GPLL>, <&cru PLL_CPLL>, - <&cru ACLK_BUS_PRE>, <&cru HCLK_BUS_PRE>, - <&cru PCLK_BUS_PRE>, <&cru ACLK_PERI_PRE>, - <&cru HCLK_PERI>, <&cru PCLK_PERI>, - <&cru SCLK_RTC32K>; - assigned-clock-parents = - <&cru HDMIPHY>, <&cru PLL_APLL>, - <&cru PLL_GPLL>, <&xin24m>, - <&xin24m>, <&xin24m>; - assigned-clock-rates = - <0>, <61440000>, - <0>, <24000000>, - <24000000>, <24000000>, - <15000000>, <15000000>, - <100000000>, <100000000>, - <100000000>, <100000000>, - <50000000>, <100000000>, - <100000000>, <100000000>, - <50000000>, <50000000>, - <50000000>, <50000000>, - <24000000>, <600000000>, - <491520000>, <1200000000>, - <150000000>, <75000000>, - <75000000>, <150000000>, - <75000000>, <75000000>, - <32768>; - }; - - usb2phy_grf: syscon@ff450000 { - compatible = "rockchip,rk3328-usb2phy-grf", "syscon", - "simple-mfd"; - reg = <0x0 0xff450000 0x0 0x10000>; - #address-cells = <1>; - #size-cells = <1>; - - u2phy: usb2phy@100 { - compatible = "rockchip,rk3328-usb2phy"; - reg = <0x100 0x10>; - clocks = <&xin24m>; - clock-names = "phyclk"; - clock-output-names = "usb480m_phy"; - #clock-cells = <0>; - assigned-clocks = <&cru USB480M>; - assigned-clock-parents = <&u2phy>; - status = "disabled"; - - u2phy_otg: otg-port { - #phy-cells = <0>; - interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "otg-bvalid", "otg-id", - "linestate"; - status = "disabled"; - }; - - u2phy_host: host-port { - #phy-cells = <0>; - interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "linestate"; - status = "disabled"; - }; - }; - }; - - sdmmc: mmc@ff500000 { - compatible = "rockchip,rk3328-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xff500000 0x0 0x4000>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, - <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - status = "disabled"; - }; - - sdio: mmc@ff510000 { - compatible = "rockchip,rk3328-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xff510000 0x0 0x4000>; - interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, - <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - status = "disabled"; - }; - - emmc: mmc@ff520000 { - compatible = "rockchip,rk3328-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xff520000 0x0 0x4000>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>, - <&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - status = "disabled"; - }; - - gmac2io: ethernet@ff540000 { - compatible = "rockchip,rk3328-gmac"; - reg = <0x0 0xff540000 0x0 0x10000>; - interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; - clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_RX>, - <&cru SCLK_MAC2IO_TX>, <&cru SCLK_MAC2IO_REF>, - <&cru SCLK_MAC2IO_REFOUT>, <&cru ACLK_MAC2IO>, - <&cru PCLK_MAC2IO>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_ref", - "clk_mac_refout", "aclk_mac", - "pclk_mac"; - resets = <&cru SRST_GMAC2IO_A>; - reset-names = "stmmaceth"; - rockchip,grf = <&grf>; - tx-fifo-depth = <2048>; - rx-fifo-depth = <4096>; - snps,txpbl = <0x4>; - status = "disabled"; - }; - - gmac2phy: ethernet@ff550000 { - compatible = "rockchip,rk3328-gmac"; - reg = <0x0 0xff550000 0x0 0x10000>; - rockchip,grf = <&grf>; - interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq"; - clocks = <&cru SCLK_MAC2PHY_SRC>, <&cru SCLK_MAC2PHY_RXTX>, - <&cru SCLK_MAC2PHY_RXTX>, <&cru SCLK_MAC2PHY_REF>, - <&cru ACLK_MAC2PHY>, <&cru PCLK_MAC2PHY>, - <&cru SCLK_MAC2PHY_OUT>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_ref", - "aclk_mac", "pclk_mac", - "clk_macphy"; - resets = <&cru SRST_GMAC2PHY_A>; - reset-names = "stmmaceth"; - phy-mode = "rmii"; - phy-handle = <&phy>; - tx-fifo-depth = <2048>; - rx-fifo-depth = <4096>; - snps,txpbl = <0x4>; - clock_in_out = "output"; - status = "disabled"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - phy: ethernet-phy@0 { - compatible = "ethernet-phy-id1234.d400", "ethernet-phy-ieee802.3-c22"; - reg = <0>; - clocks = <&cru SCLK_MAC2PHY_OUT>; - resets = <&cru SRST_MACPHY>; - pinctrl-names = "default"; - pinctrl-0 = <&fephyled_rxm1 &fephyled_linkm1>; - phy-is-integrated; - }; - }; - }; - - usb20_otg: usb@ff580000 { - compatible = "rockchip,rk3328-usb", "rockchip,rk3066-usb", - "snps,dwc2"; - reg = <0x0 0xff580000 0x0 0x40000>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_OTG>; - clock-names = "otg"; - dr_mode = "otg"; - g-np-tx-fifo-size = <16>; - g-rx-fifo-size = <280>; - g-tx-fifo-size = <256 128 128 64 32 16>; - phys = <&u2phy_otg>; - phy-names = "usb2-phy"; - status = "disabled"; - }; - - usb_host0_ehci: usb@ff5c0000 { - compatible = "generic-ehci"; - reg = <0x0 0xff5c0000 0x0 0x10000>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST0>, <&u2phy>; - phys = <&u2phy_host>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host0_ohci: usb@ff5d0000 { - compatible = "generic-ohci"; - reg = <0x0 0xff5d0000 0x0 0x10000>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_HOST0>, <&u2phy>; - phys = <&u2phy_host>; - phy-names = "usb"; - status = "disabled"; - }; - - usbdrd3: usb@ff600000 { - compatible = "rockchip,rk3328-dwc3", "snps,dwc3"; - reg = <0x0 0xff600000 0x0 0x100000>; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_USB3OTG_REF>, <&cru SCLK_USB3OTG_SUSPEND>, - <&cru ACLK_USB3OTG>; - clock-names = "ref_clk", "suspend_clk", - "bus_clk"; - dr_mode = "otg"; - phy_type = "utmi_wide"; - snps,dis-del-phy-power-chg-quirk; - snps,dis_enblslpm_quirk; - snps,dis-tx-ipgap-linecheck-quirk; - snps,dis-u2-freeclk-exists-quirk; - snps,dis_u2_susphy_quirk; - snps,dis_u3_susphy_quirk; - status = "disabled"; - }; - - gic: interrupt-controller@ff811000 { - compatible = "arm,gic-400"; - #interrupt-cells = <3>; - #address-cells = <0>; - interrupt-controller; - reg = <0x0 0xff811000 0 0x1000>, - <0x0 0xff812000 0 0x2000>, - <0x0 0xff814000 0 0x2000>, - <0x0 0xff816000 0 0x2000>; - interrupts = <GIC_PPI 9 - (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>; - }; - - crypto: crypto@ff060000 { - compatible = "rockchip,rk3328-crypto"; - reg = <0x0 0xff060000 0x0 0x4000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_CRYPTO_MST>, <&cru HCLK_CRYPTO_SLV>, - <&cru SCLK_CRYPTO>; - clock-names = "hclk_master", "hclk_slave", "sclk"; - resets = <&cru SRST_CRYPTO>; - reset-names = "crypto-rst"; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rk3328-pinctrl"; - rockchip,grf = <&grf>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio0: gpio@ff210000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff210000 0x0 0x100>; - interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO0>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@ff220000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff220000 0x0 0x100>; - interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO1>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@ff230000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff230000 0x0 0x100>; - interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO2>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@ff240000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff240000 0x0 0x100>; - interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO3>; - - gpio-controller; - #gpio-cells = <2>; - - interrupt-controller; - #interrupt-cells = <2>; - }; - - pcfg_pull_up: pcfg-pull-up { - bias-pull-up; - }; - - pcfg_pull_down: pcfg-pull-down { - bias-pull-down; - }; - - pcfg_pull_none: pcfg-pull-none { - bias-disable; - }; - - pcfg_pull_none_2ma: pcfg-pull-none-2ma { - bias-disable; - drive-strength = <2>; - }; - - pcfg_pull_up_2ma: pcfg-pull-up-2ma { - bias-pull-up; - drive-strength = <2>; - }; - - pcfg_pull_up_4ma: pcfg-pull-up-4ma { - bias-pull-up; - drive-strength = <4>; - }; - - pcfg_pull_none_4ma: pcfg-pull-none-4ma { - bias-disable; - drive-strength = <4>; - }; - - pcfg_pull_down_4ma: pcfg-pull-down-4ma { - bias-pull-down; - drive-strength = <4>; - }; - - pcfg_pull_none_8ma: pcfg-pull-none-8ma { - bias-disable; - drive-strength = <8>; - }; - - pcfg_pull_up_8ma: pcfg-pull-up-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - pcfg_pull_none_12ma: pcfg-pull-none-12ma { - bias-disable; - drive-strength = <12>; - }; - - pcfg_pull_up_12ma: pcfg-pull-up-12ma { - bias-pull-up; - drive-strength = <12>; - }; - - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_input_high: pcfg-input-high { - bias-pull-up; - input-enable; - }; - - pcfg_input: pcfg-input { - input-enable; - }; - - i2c0 { - i2c0_xfer: i2c0-xfer { - rockchip,pins = <2 RK_PD0 1 &pcfg_pull_none>, - <2 RK_PD1 1 &pcfg_pull_none>; - }; - }; - - i2c1 { - i2c1_xfer: i2c1-xfer { - rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>, - <2 RK_PA5 2 &pcfg_pull_none>; - }; - }; - - i2c2 { - i2c2_xfer: i2c2-xfer { - rockchip,pins = <2 RK_PB5 1 &pcfg_pull_none>, - <2 RK_PB6 1 &pcfg_pull_none>; - }; - }; - - i2c3 { - i2c3_xfer: i2c3-xfer { - rockchip,pins = <0 RK_PA5 2 &pcfg_pull_none>, - <0 RK_PA6 2 &pcfg_pull_none>; - }; - i2c3_pins: i2c3-pins { - rockchip,pins = - <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>, - <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - hdmi_i2c { - hdmii2c_xfer: hdmii2c-xfer { - rockchip,pins = <0 RK_PA5 1 &pcfg_pull_none>, - <0 RK_PA6 1 &pcfg_pull_none>; - }; - }; - - pdm-0 { - pdmm0_clk: pdmm0-clk { - rockchip,pins = <2 RK_PC2 2 &pcfg_pull_none>; - }; - - pdmm0_fsync: pdmm0-fsync { - rockchip,pins = <2 RK_PC7 2 &pcfg_pull_none>; - }; - - pdmm0_sdi0: pdmm0-sdi0 { - rockchip,pins = <2 RK_PC3 2 &pcfg_pull_none>; - }; - - pdmm0_sdi1: pdmm0-sdi1 { - rockchip,pins = <2 RK_PC4 2 &pcfg_pull_none>; - }; - - pdmm0_sdi2: pdmm0-sdi2 { - rockchip,pins = <2 RK_PC5 2 &pcfg_pull_none>; - }; - - pdmm0_sdi3: pdmm0-sdi3 { - rockchip,pins = <2 RK_PC6 2 &pcfg_pull_none>; - }; - - pdmm0_clk_sleep: pdmm0-clk-sleep { - rockchip,pins = - <2 RK_PC2 RK_FUNC_GPIO &pcfg_input_high>; - }; - - pdmm0_sdi0_sleep: pdmm0-sdi0-sleep { - rockchip,pins = - <2 RK_PC3 RK_FUNC_GPIO &pcfg_input_high>; - }; - - pdmm0_sdi1_sleep: pdmm0-sdi1-sleep { - rockchip,pins = - <2 RK_PC4 RK_FUNC_GPIO &pcfg_input_high>; - }; - - pdmm0_sdi2_sleep: pdmm0-sdi2-sleep { - rockchip,pins = - <2 RK_PC5 RK_FUNC_GPIO &pcfg_input_high>; - }; - - pdmm0_sdi3_sleep: pdmm0-sdi3-sleep { - rockchip,pins = - <2 RK_PC6 RK_FUNC_GPIO &pcfg_input_high>; - }; - - pdmm0_fsync_sleep: pdmm0-fsync-sleep { - rockchip,pins = - <2 RK_PC7 RK_FUNC_GPIO &pcfg_input_high>; - }; - }; - - tsadc { - otp_pin: otp-pin { - rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - otp_out: otp-out { - rockchip,pins = <2 RK_PB5 1 &pcfg_pull_none>; - }; - }; - - uart0 { - uart0_xfer: uart0-xfer { - rockchip,pins = <1 RK_PB1 1 &pcfg_pull_none>, - <1 RK_PB0 1 &pcfg_pull_up>; - }; - - uart0_cts: uart0-cts { - rockchip,pins = <1 RK_PB3 1 &pcfg_pull_none>; - }; - - uart0_rts: uart0-rts { - rockchip,pins = <1 RK_PB2 1 &pcfg_pull_none>; - }; - - uart0_rts_pin: uart0-rts-pin { - rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - uart1 { - uart1_xfer: uart1-xfer { - rockchip,pins = <3 RK_PA4 4 &pcfg_pull_none>, - <3 RK_PA6 4 &pcfg_pull_up>; - }; - - uart1_cts: uart1-cts { - rockchip,pins = <3 RK_PA7 4 &pcfg_pull_none>; - }; - - uart1_rts: uart1-rts { - rockchip,pins = <3 RK_PA5 4 &pcfg_pull_none>; - }; - - uart1_rts_pin: uart1-rts-pin { - rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - uart2-0 { - uart2m0_xfer: uart2m0-xfer { - rockchip,pins = <1 RK_PA0 2 &pcfg_pull_none>, - <1 RK_PA1 2 &pcfg_pull_up>; - }; - }; - - uart2-1 { - uart2m1_xfer: uart2m1-xfer { - rockchip,pins = <2 RK_PA0 1 &pcfg_pull_none>, - <2 RK_PA1 1 &pcfg_pull_up>; - }; - }; - - spi0-0 { - spi0m0_clk: spi0m0-clk { - rockchip,pins = <2 RK_PB0 1 &pcfg_pull_up>; - }; - - spi0m0_cs0: spi0m0-cs0 { - rockchip,pins = <2 RK_PB3 1 &pcfg_pull_up>; - }; - - spi0m0_tx: spi0m0-tx { - rockchip,pins = <2 RK_PB1 1 &pcfg_pull_up>; - }; - - spi0m0_rx: spi0m0-rx { - rockchip,pins = <2 RK_PB2 1 &pcfg_pull_up>; - }; - - spi0m0_cs1: spi0m0-cs1 { - rockchip,pins = <2 RK_PB4 1 &pcfg_pull_up>; - }; - }; - - spi0-1 { - spi0m1_clk: spi0m1-clk { - rockchip,pins = <3 RK_PC7 2 &pcfg_pull_up>; - }; - - spi0m1_cs0: spi0m1-cs0 { - rockchip,pins = <3 RK_PD2 2 &pcfg_pull_up>; - }; - - spi0m1_tx: spi0m1-tx { - rockchip,pins = <3 RK_PD1 2 &pcfg_pull_up>; - }; - - spi0m1_rx: spi0m1-rx { - rockchip,pins = <3 RK_PD0 2 &pcfg_pull_up>; - }; - - spi0m1_cs1: spi0m1-cs1 { - rockchip,pins = <3 RK_PD3 2 &pcfg_pull_up>; - }; - }; - - spi0-2 { - spi0m2_clk: spi0m2-clk { - rockchip,pins = <3 RK_PA0 4 &pcfg_pull_up>; - }; - - spi0m2_cs0: spi0m2-cs0 { - rockchip,pins = <3 RK_PB0 3 &pcfg_pull_up>; - }; - - spi0m2_tx: spi0m2-tx { - rockchip,pins = <3 RK_PA1 4 &pcfg_pull_up>; - }; - - spi0m2_rx: spi0m2-rx { - rockchip,pins = <3 RK_PA2 4 &pcfg_pull_up>; - }; - }; - - i2s1 { - i2s1_mclk: i2s1-mclk { - rockchip,pins = <2 RK_PB7 1 &pcfg_pull_none>; - }; - - i2s1_sclk: i2s1-sclk { - rockchip,pins = <2 RK_PC2 1 &pcfg_pull_none>; - }; - - i2s1_lrckrx: i2s1-lrckrx { - rockchip,pins = <2 RK_PC0 1 &pcfg_pull_none>; - }; - - i2s1_lrcktx: i2s1-lrcktx { - rockchip,pins = <2 RK_PC1 1 &pcfg_pull_none>; - }; - - i2s1_sdi: i2s1-sdi { - rockchip,pins = <2 RK_PC3 1 &pcfg_pull_none>; - }; - - i2s1_sdo: i2s1-sdo { - rockchip,pins = <2 RK_PC7 1 &pcfg_pull_none>; - }; - - i2s1_sdio1: i2s1-sdio1 { - rockchip,pins = <2 RK_PC4 1 &pcfg_pull_none>; - }; - - i2s1_sdio2: i2s1-sdio2 { - rockchip,pins = <2 RK_PC5 1 &pcfg_pull_none>; - }; - - i2s1_sdio3: i2s1-sdio3 { - rockchip,pins = <2 RK_PC6 1 &pcfg_pull_none>; - }; - - i2s1_sleep: i2s1-sleep { - rockchip,pins = - <2 RK_PB7 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC0 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC1 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC2 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC3 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC4 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC5 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC6 RK_FUNC_GPIO &pcfg_input_high>, - <2 RK_PC7 RK_FUNC_GPIO &pcfg_input_high>; - }; - }; - - i2s2-0 { - i2s2m0_mclk: i2s2m0-mclk { - rockchip,pins = <1 RK_PC5 1 &pcfg_pull_none>; - }; - - i2s2m0_sclk: i2s2m0-sclk { - rockchip,pins = <1 RK_PC6 1 &pcfg_pull_none>; - }; - - i2s2m0_lrckrx: i2s2m0-lrckrx { - rockchip,pins = <1 RK_PD2 1 &pcfg_pull_none>; - }; - - i2s2m0_lrcktx: i2s2m0-lrcktx { - rockchip,pins = <1 RK_PC7 1 &pcfg_pull_none>; - }; - - i2s2m0_sdi: i2s2m0-sdi { - rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>; - }; - - i2s2m0_sdo: i2s2m0-sdo { - rockchip,pins = <1 RK_PD1 1 &pcfg_pull_none>; - }; - - i2s2m0_sleep: i2s2m0-sleep { - rockchip,pins = - <1 RK_PC5 RK_FUNC_GPIO &pcfg_input_high>, - <1 RK_PC6 RK_FUNC_GPIO &pcfg_input_high>, - <1 RK_PD2 RK_FUNC_GPIO &pcfg_input_high>, - <1 RK_PC7 RK_FUNC_GPIO &pcfg_input_high>, - <1 RK_PD0 RK_FUNC_GPIO &pcfg_input_high>, - <1 RK_PD1 RK_FUNC_GPIO &pcfg_input_high>; - }; - }; - - i2s2-1 { - i2s2m1_mclk: i2s2m1-mclk { - rockchip,pins = <1 RK_PC5 1 &pcfg_pull_none>; - }; - - i2s2m1_sclk: i2s2m1-sclk { - rockchip,pins = <3 RK_PA0 6 &pcfg_pull_none>; - }; - - i2s2m1_lrckrx: i2sm1-lrckrx { - rockchip,pins = <3 RK_PB0 6 &pcfg_pull_none>; - }; - - i2s2m1_lrcktx: i2s2m1-lrcktx { - rockchip,pins = <3 RK_PB0 4 &pcfg_pull_none>; - }; - - i2s2m1_sdi: i2s2m1-sdi { - rockchip,pins = <3 RK_PA2 6 &pcfg_pull_none>; - }; - - i2s2m1_sdo: i2s2m1-sdo { - rockchip,pins = <3 RK_PA1 6 &pcfg_pull_none>; - }; - - i2s2m1_sleep: i2s2m1-sleep { - rockchip,pins = - <1 RK_PC5 RK_FUNC_GPIO &pcfg_input_high>, - <3 RK_PA0 RK_FUNC_GPIO &pcfg_input_high>, - <3 RK_PB0 RK_FUNC_GPIO &pcfg_input_high>, - <3 RK_PA2 RK_FUNC_GPIO &pcfg_input_high>, - <3 RK_PA1 RK_FUNC_GPIO &pcfg_input_high>; - }; - }; - - spdif-0 { - spdifm0_tx: spdifm0-tx { - rockchip,pins = <0 RK_PD3 1 &pcfg_pull_none>; - }; - }; - - spdif-1 { - spdifm1_tx: spdifm1-tx { - rockchip,pins = <2 RK_PC1 2 &pcfg_pull_none>; - }; - }; - - spdif-2 { - spdifm2_tx: spdifm2-tx { - rockchip,pins = <0 RK_PA2 2 &pcfg_pull_none>; - }; - }; - - sdmmc0-0 { - sdmmc0m0_pwren: sdmmc0m0-pwren { - rockchip,pins = <2 RK_PA7 1 &pcfg_pull_up_4ma>; - }; - - sdmmc0m0_pin: sdmmc0m0-pin { - rockchip,pins = <2 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up_4ma>; - }; - }; - - sdmmc0-1 { - sdmmc0m1_pwren: sdmmc0m1-pwren { - rockchip,pins = <0 RK_PD6 3 &pcfg_pull_up_4ma>; - }; - - sdmmc0m1_pin: sdmmc0m1-pin { - rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up_4ma>; - }; - }; - - sdmmc0 { - sdmmc0_clk: sdmmc0-clk { - rockchip,pins = <1 RK_PA6 1 &pcfg_pull_none_8ma>; - }; - - sdmmc0_cmd: sdmmc0-cmd { - rockchip,pins = <1 RK_PA4 1 &pcfg_pull_up_8ma>; - }; - - sdmmc0_dectn: sdmmc0-dectn { - rockchip,pins = <1 RK_PA5 1 &pcfg_pull_up_4ma>; - }; - - sdmmc0_wrprt: sdmmc0-wrprt { - rockchip,pins = <1 RK_PA7 1 &pcfg_pull_up_4ma>; - }; - - sdmmc0_bus1: sdmmc0-bus1 { - rockchip,pins = <1 RK_PA0 1 &pcfg_pull_up_8ma>; - }; - - sdmmc0_bus4: sdmmc0-bus4 { - rockchip,pins = <1 RK_PA0 1 &pcfg_pull_up_8ma>, - <1 RK_PA1 1 &pcfg_pull_up_8ma>, - <1 RK_PA2 1 &pcfg_pull_up_8ma>, - <1 RK_PA3 1 &pcfg_pull_up_8ma>; - }; - - sdmmc0_pins: sdmmc0-pins { - rockchip,pins = - <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up_4ma>; - }; - }; - - sdmmc0ext { - sdmmc0ext_clk: sdmmc0ext-clk { - rockchip,pins = <3 RK_PA2 3 &pcfg_pull_none_4ma>; - }; - - sdmmc0ext_cmd: sdmmc0ext-cmd { - rockchip,pins = <3 RK_PA0 3 &pcfg_pull_up_4ma>; - }; - - sdmmc0ext_wrprt: sdmmc0ext-wrprt { - rockchip,pins = <3 RK_PA3 3 &pcfg_pull_up_4ma>; - }; - - sdmmc0ext_dectn: sdmmc0ext-dectn { - rockchip,pins = <3 RK_PA1 3 &pcfg_pull_up_4ma>; - }; - - sdmmc0ext_bus1: sdmmc0ext-bus1 { - rockchip,pins = <3 RK_PA4 3 &pcfg_pull_up_4ma>; - }; - - sdmmc0ext_bus4: sdmmc0ext-bus4 { - rockchip,pins = - <3 RK_PA4 3 &pcfg_pull_up_4ma>, - <3 RK_PA5 3 &pcfg_pull_up_4ma>, - <3 RK_PA6 3 &pcfg_pull_up_4ma>, - <3 RK_PA7 3 &pcfg_pull_up_4ma>; - }; - - sdmmc0ext_pins: sdmmc0ext-pins { - rockchip,pins = - <3 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up_4ma>; - }; - }; - - sdmmc1 { - sdmmc1_clk: sdmmc1-clk { - rockchip,pins = <1 RK_PB4 1 &pcfg_pull_none_8ma>; - }; - - sdmmc1_cmd: sdmmc1-cmd { - rockchip,pins = <1 RK_PB5 1 &pcfg_pull_up_8ma>; - }; - - sdmmc1_pwren: sdmmc1-pwren { - rockchip,pins = <1 RK_PC2 1 &pcfg_pull_up_8ma>; - }; - - sdmmc1_wrprt: sdmmc1-wrprt { - rockchip,pins = <1 RK_PC4 1 &pcfg_pull_up_8ma>; - }; - - sdmmc1_dectn: sdmmc1-dectn { - rockchip,pins = <1 RK_PC3 1 &pcfg_pull_up_8ma>; - }; - - sdmmc1_bus1: sdmmc1-bus1 { - rockchip,pins = <1 RK_PB6 1 &pcfg_pull_up_8ma>; - }; - - sdmmc1_bus4: sdmmc1-bus4 { - rockchip,pins = <1 RK_PB6 1 &pcfg_pull_up_8ma>, - <1 RK_PB7 1 &pcfg_pull_up_8ma>, - <1 RK_PC0 1 &pcfg_pull_up_8ma>, - <1 RK_PC1 1 &pcfg_pull_up_8ma>; - }; - - sdmmc1_pins: sdmmc1-pins { - rockchip,pins = - <1 RK_PB4 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PB7 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PC0 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PC3 RK_FUNC_GPIO &pcfg_pull_up_4ma>, - <1 RK_PC4 RK_FUNC_GPIO &pcfg_pull_up_4ma>; - }; - }; - - emmc { - emmc_clk: emmc-clk { - rockchip,pins = <3 RK_PC5 2 &pcfg_pull_none_12ma>; - }; - - emmc_cmd: emmc-cmd { - rockchip,pins = <3 RK_PC3 2 &pcfg_pull_up_12ma>; - }; - - emmc_pwren: emmc-pwren { - rockchip,pins = <3 RK_PC6 2 &pcfg_pull_none>; - }; - - emmc_rstnout: emmc-rstnout { - rockchip,pins = <3 RK_PC4 2 &pcfg_pull_none>; - }; - - emmc_bus1: emmc-bus1 { - rockchip,pins = <0 RK_PA7 2 &pcfg_pull_up_12ma>; - }; - - emmc_bus4: emmc-bus4 { - rockchip,pins = - <0 RK_PA7 2 &pcfg_pull_up_12ma>, - <2 RK_PD4 2 &pcfg_pull_up_12ma>, - <2 RK_PD5 2 &pcfg_pull_up_12ma>, - <2 RK_PD6 2 &pcfg_pull_up_12ma>; - }; - - emmc_bus8: emmc-bus8 { - rockchip,pins = - <0 RK_PA7 2 &pcfg_pull_up_12ma>, - <2 RK_PD4 2 &pcfg_pull_up_12ma>, - <2 RK_PD5 2 &pcfg_pull_up_12ma>, - <2 RK_PD6 2 &pcfg_pull_up_12ma>, - <2 RK_PD7 2 &pcfg_pull_up_12ma>, - <3 RK_PC0 2 &pcfg_pull_up_12ma>, - <3 RK_PC1 2 &pcfg_pull_up_12ma>, - <3 RK_PC2 2 &pcfg_pull_up_12ma>; - }; - }; - - pwm0 { - pwm0_pin: pwm0-pin { - rockchip,pins = <2 RK_PA4 1 &pcfg_pull_none>; - }; - }; - - pwm1 { - pwm1_pin: pwm1-pin { - rockchip,pins = <2 RK_PA5 1 &pcfg_pull_none>; - }; - }; - - pwm2 { - pwm2_pin: pwm2-pin { - rockchip,pins = <2 RK_PA6 1 &pcfg_pull_none>; - }; - }; - - pwmir { - pwmir_pin: pwmir-pin { - rockchip,pins = <2 RK_PA2 1 &pcfg_pull_none>; - }; - }; - - gmac-1 { - rgmiim1_pins: rgmiim1-pins { - rockchip,pins = - /* mac_txclk */ - <1 RK_PB4 2 &pcfg_pull_none_8ma>, - /* mac_rxclk */ - <1 RK_PB5 2 &pcfg_pull_none_4ma>, - /* mac_mdio */ - <1 RK_PC3 2 &pcfg_pull_none_4ma>, - /* mac_txen */ - <1 RK_PD1 2 &pcfg_pull_none_8ma>, - /* mac_clk */ - <1 RK_PC5 2 &pcfg_pull_none_4ma>, - /* mac_rxdv */ - <1 RK_PC6 2 &pcfg_pull_none_4ma>, - /* mac_mdc */ - <1 RK_PC7 2 &pcfg_pull_none_4ma>, - /* mac_rxd1 */ - <1 RK_PB2 2 &pcfg_pull_none_4ma>, - /* mac_rxd0 */ - <1 RK_PB3 2 &pcfg_pull_none_4ma>, - /* mac_txd1 */ - <1 RK_PB0 2 &pcfg_pull_none_8ma>, - /* mac_txd0 */ - <1 RK_PB1 2 &pcfg_pull_none_8ma>, - /* mac_rxd3 */ - <1 RK_PB6 2 &pcfg_pull_none_4ma>, - /* mac_rxd2 */ - <1 RK_PB7 2 &pcfg_pull_none_4ma>, - /* mac_txd3 */ - <1 RK_PC0 2 &pcfg_pull_none_8ma>, - /* mac_txd2 */ - <1 RK_PC1 2 &pcfg_pull_none_8ma>, - - /* mac_txclk */ - <0 RK_PB0 1 &pcfg_pull_none_8ma>, - /* mac_txen */ - <0 RK_PB4 1 &pcfg_pull_none_8ma>, - /* mac_clk */ - <0 RK_PD0 1 &pcfg_pull_none_4ma>, - /* mac_txd1 */ - <0 RK_PC0 1 &pcfg_pull_none_8ma>, - /* mac_txd0 */ - <0 RK_PC1 1 &pcfg_pull_none_8ma>, - /* mac_txd3 */ - <0 RK_PC7 1 &pcfg_pull_none_8ma>, - /* mac_txd2 */ - <0 RK_PC6 1 &pcfg_pull_none_8ma>; - }; - - rmiim1_pins: rmiim1-pins { - rockchip,pins = - /* mac_mdio */ - <1 RK_PC3 2 &pcfg_pull_none_2ma>, - /* mac_txen */ - <1 RK_PD1 2 &pcfg_pull_none_12ma>, - /* mac_clk */ - <1 RK_PC5 2 &pcfg_pull_none_2ma>, - /* mac_rxer */ - <1 RK_PD0 2 &pcfg_pull_none_2ma>, - /* mac_rxdv */ - <1 RK_PC6 2 &pcfg_pull_none_2ma>, - /* mac_mdc */ - <1 RK_PC7 2 &pcfg_pull_none_2ma>, - /* mac_rxd1 */ - <1 RK_PB2 2 &pcfg_pull_none_2ma>, - /* mac_rxd0 */ - <1 RK_PB3 2 &pcfg_pull_none_2ma>, - /* mac_txd1 */ - <1 RK_PB0 2 &pcfg_pull_none_12ma>, - /* mac_txd0 */ - <1 RK_PB1 2 &pcfg_pull_none_12ma>, - - /* mac_mdio */ - <0 RK_PB3 1 &pcfg_pull_none>, - /* mac_txen */ - <0 RK_PB4 1 &pcfg_pull_none>, - /* mac_clk */ - <0 RK_PD0 1 &pcfg_pull_none>, - /* mac_mdc */ - <0 RK_PC3 1 &pcfg_pull_none>, - /* mac_txd1 */ - <0 RK_PC0 1 &pcfg_pull_none>, - /* mac_txd0 */ - <0 RK_PC1 1 &pcfg_pull_none>; - }; - }; - - gmac2phy { - fephyled_speed10: fephyled-speed10 { - rockchip,pins = <0 RK_PD6 1 &pcfg_pull_none>; - }; - - fephyled_duplex: fephyled-duplex { - rockchip,pins = <0 RK_PD6 2 &pcfg_pull_none>; - }; - - fephyled_rxm1: fephyled-rxm1 { - rockchip,pins = <2 RK_PD1 2 &pcfg_pull_none>; - }; - - fephyled_txm1: fephyled-txm1 { - rockchip,pins = <2 RK_PD1 3 &pcfg_pull_none>; - }; - - fephyled_linkm1: fephyled-linkm1 { - rockchip,pins = <2 RK_PD0 2 &pcfg_pull_none>; - }; - }; - - tsadc_pin { - tsadc_int: tsadc-int { - rockchip,pins = <2 RK_PB5 2 &pcfg_pull_none>; - }; - tsadc_pin: tsadc-pin { - rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - hdmi_pin { - hdmi_cec: hdmi-cec { - rockchip,pins = <0 RK_PA3 1 &pcfg_pull_none>; - }; - - hdmi_hpd: hdmi-hpd { - rockchip,pins = <0 RK_PA4 1 &pcfg_pull_down>; - }; - }; - - cif-0 { - dvp_d2d9_m0:dvp-d2d9-m0 { - rockchip,pins = - /* cif_d0 */ - <3 RK_PA4 2 &pcfg_pull_none>, - /* cif_d1 */ - <3 RK_PA5 2 &pcfg_pull_none>, - /* cif_d2 */ - <3 RK_PA6 2 &pcfg_pull_none>, - /* cif_d3 */ - <3 RK_PA7 2 &pcfg_pull_none>, - /* cif_d4 */ - <3 RK_PB0 2 &pcfg_pull_none>, - /* cif_d5m0 */ - <3 RK_PB1 2 &pcfg_pull_none>, - /* cif_d6m0 */ - <3 RK_PB2 2 &pcfg_pull_none>, - /* cif_d7m0 */ - <3 RK_PB3 2 &pcfg_pull_none>, - /* cif_href */ - <3 RK_PA1 2 &pcfg_pull_none>, - /* cif_vsync */ - <3 RK_PA0 2 &pcfg_pull_none>, - /* cif_clkoutm0 */ - <3 RK_PA3 2 &pcfg_pull_none>, - /* cif_clkin */ - <3 RK_PA2 2 &pcfg_pull_none>; - }; - }; - - cif-1 { - dvp_d2d9_m1:dvp-d2d9-m1 { - rockchip,pins = - /* cif_d0 */ - <3 RK_PA4 2 &pcfg_pull_none>, - /* cif_d1 */ - <3 RK_PA5 2 &pcfg_pull_none>, - /* cif_d2 */ - <3 RK_PA6 2 &pcfg_pull_none>, - /* cif_d3 */ - <3 RK_PA7 2 &pcfg_pull_none>, - /* cif_d4 */ - <3 RK_PB0 2 &pcfg_pull_none>, - /* cif_d5m1 */ - <2 RK_PC0 4 &pcfg_pull_none>, - /* cif_d6m1 */ - <2 RK_PC1 4 &pcfg_pull_none>, - /* cif_d7m1 */ - <2 RK_PC2 4 &pcfg_pull_none>, - /* cif_href */ - <3 RK_PA1 2 &pcfg_pull_none>, - /* cif_vsync */ - <3 RK_PA0 2 &pcfg_pull_none>, - /* cif_clkoutm1 */ - <2 RK_PB7 4 &pcfg_pull_none>, - /* cif_clkin */ - <3 RK_PA2 2 &pcfg_pull_none>; - }; - }; - }; -}; diff --git a/include/dt-bindings/clock/rk3328-cru.h b/include/dt-bindings/clock/rk3328-cru.h deleted file mode 100644 index 555b4ff660ae..000000000000 --- a/include/dt-bindings/clock/rk3328-cru.h +++ /dev/null @@ -1,393 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2016 Rockchip Electronics Co. Ltd. - * Author: Elaine zhangqing@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3328_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3328_H - -/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_NPLL 5 -#define ARMCLK 6 - -/* sclk gates (special clocks) */ -#define SCLK_RTC32K 30 -#define SCLK_SDMMC_EXT 31 -#define SCLK_SPI 32 -#define SCLK_SDMMC 33 -#define SCLK_SDIO 34 -#define SCLK_EMMC 35 -#define SCLK_TSADC 36 -#define SCLK_SARADC 37 -#define SCLK_UART0 38 -#define SCLK_UART1 39 -#define SCLK_UART2 40 -#define SCLK_I2S0 41 -#define SCLK_I2S1 42 -#define SCLK_I2S2 43 -#define SCLK_I2S1_OUT 44 -#define SCLK_I2S2_OUT 45 -#define SCLK_SPDIF 46 -#define SCLK_TIMER0 47 -#define SCLK_TIMER1 48 -#define SCLK_TIMER2 49 -#define SCLK_TIMER3 50 -#define SCLK_TIMER4 51 -#define SCLK_TIMER5 52 -#define SCLK_WIFI 53 -#define SCLK_CIF_OUT 54 -#define SCLK_I2C0 55 -#define SCLK_I2C1 56 -#define SCLK_I2C2 57 -#define SCLK_I2C3 58 -#define SCLK_CRYPTO 59 -#define SCLK_PWM 60 -#define SCLK_PDM 61 -#define SCLK_EFUSE 62 -#define SCLK_OTP 63 -#define SCLK_DDRCLK 64 -#define SCLK_VDEC_CABAC 65 -#define SCLK_VDEC_CORE 66 -#define SCLK_VENC_DSP 67 -#define SCLK_VENC_CORE 68 -#define SCLK_RGA 69 -#define SCLK_HDMI_SFC 70 -#define SCLK_HDMI_CEC 71 -#define SCLK_USB3_REF 72 -#define SCLK_USB3_SUSPEND 73 -#define SCLK_SDMMC_DRV 74 -#define SCLK_SDIO_DRV 75 -#define SCLK_EMMC_DRV 76 -#define SCLK_SDMMC_EXT_DRV 77 -#define SCLK_SDMMC_SAMPLE 78 -#define SCLK_SDIO_SAMPLE 79 -#define SCLK_EMMC_SAMPLE 80 -#define SCLK_SDMMC_EXT_SAMPLE 81 -#define SCLK_VOP 82 -#define SCLK_MAC2PHY_RXTX 83 -#define SCLK_MAC2PHY_SRC 84 -#define SCLK_MAC2PHY_REF 85 -#define SCLK_MAC2PHY_OUT 86 -#define SCLK_MAC2IO_RX 87 -#define SCLK_MAC2IO_TX 88 -#define SCLK_MAC2IO_REFOUT 89 -#define SCLK_MAC2IO_REF 90 -#define SCLK_MAC2IO_OUT 91 -#define SCLK_TSP 92 -#define SCLK_HSADC_TSP 93 -#define SCLK_USB3PHY_REF 94 -#define SCLK_REF_USB3OTG 95 -#define SCLK_USB3OTG_REF 96 -#define SCLK_USB3OTG_SUSPEND 97 -#define SCLK_REF_USB3OTG_SRC 98 -#define SCLK_MAC2IO_SRC 99 -#define SCLK_MAC2IO 100 -#define SCLK_MAC2PHY 101 -#define SCLK_MAC2IO_EXT 102 - -/* dclk gates */ -#define DCLK_LCDC 120 -#define DCLK_HDMIPHY 121 -#define HDMIPHY 122 -#define USB480M 123 -#define DCLK_LCDC_SRC 124 - -/* aclk gates */ -#define ACLK_AXISRAM 130 -#define ACLK_VOP_PRE 131 -#define ACLK_USB3OTG 132 -#define ACLK_RGA_PRE 133 -#define ACLK_DMAC 134 -#define ACLK_GPU 135 -#define ACLK_BUS_PRE 136 -#define ACLK_PERI_PRE 137 -#define ACLK_RKVDEC_PRE 138 -#define ACLK_RKVDEC 139 -#define ACLK_RKVENC 140 -#define ACLK_VPU_PRE 141 -#define ACLK_VIO_PRE 142 -#define ACLK_VPU 143 -#define ACLK_VIO 144 -#define ACLK_VOP 145 -#define ACLK_GMAC 146 -#define ACLK_H265 147 -#define ACLK_H264 148 -#define ACLK_MAC2PHY 149 -#define ACLK_MAC2IO 150 -#define ACLK_DCF 151 -#define ACLK_TSP 152 -#define ACLK_PERI 153 -#define ACLK_RGA 154 -#define ACLK_IEP 155 -#define ACLK_CIF 156 -#define ACLK_HDCP 157 - -/* pclk gates */ -#define PCLK_GPIO0 200 -#define PCLK_GPIO1 201 -#define PCLK_GPIO2 202 -#define PCLK_GPIO3 203 -#define PCLK_GRF 204 -#define PCLK_I2C0 205 -#define PCLK_I2C1 206 -#define PCLK_I2C2 207 -#define PCLK_I2C3 208 -#define PCLK_SPI 209 -#define PCLK_UART0 210 -#define PCLK_UART1 211 -#define PCLK_UART2 212 -#define PCLK_TSADC 213 -#define PCLK_PWM 214 -#define PCLK_TIMER 215 -#define PCLK_BUS_PRE 216 -#define PCLK_PERI_PRE 217 -#define PCLK_HDMI_CTRL 218 -#define PCLK_HDMI_PHY 219 -#define PCLK_GMAC 220 -#define PCLK_H265 221 -#define PCLK_MAC2PHY 222 -#define PCLK_MAC2IO 223 -#define PCLK_USB3PHY_OTG 224 -#define PCLK_USB3PHY_PIPE 225 -#define PCLK_USB3_GRF 226 -#define PCLK_USB2_GRF 227 -#define PCLK_HDMIPHY 228 -#define PCLK_DDR 229 -#define PCLK_PERI 230 -#define PCLK_HDMI 231 -#define PCLK_HDCP 232 -#define PCLK_DCF 233 -#define PCLK_SARADC 234 -#define PCLK_ACODECPHY 235 -#define PCLK_WDT 236 - -/* hclk gates */ -#define HCLK_PERI 308 -#define HCLK_TSP 309 -#define HCLK_GMAC 310 -#define HCLK_I2S0_8CH 311 -#define HCLK_I2S1_8CH 312 -#define HCLK_I2S2_2CH 313 -#define HCLK_SPDIF_8CH 314 -#define HCLK_VOP 315 -#define HCLK_NANDC 316 -#define HCLK_SDMMC 317 -#define HCLK_SDIO 318 -#define HCLK_EMMC 319 -#define HCLK_SDMMC_EXT 320 -#define HCLK_RKVDEC_PRE 321 -#define HCLK_RKVDEC 322 -#define HCLK_RKVENC 323 -#define HCLK_VPU_PRE 324 -#define HCLK_VIO_PRE 325 -#define HCLK_VPU 326 -#define HCLK_BUS_PRE 328 -#define HCLK_PERI_PRE 329 -#define HCLK_H264 330 -#define HCLK_CIF 331 -#define HCLK_OTG_PMU 332 -#define HCLK_OTG 333 -#define HCLK_HOST0 334 -#define HCLK_HOST0_ARB 335 -#define HCLK_CRYPTO_MST 336 -#define HCLK_CRYPTO_SLV 337 -#define HCLK_PDM 338 -#define HCLK_IEP 339 -#define HCLK_RGA 340 -#define HCLK_HDCP 341 - -#define CLK_NR_CLKS (HCLK_HDCP + 1) - -/* soft-reset indices */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_CORE_NIU 13 -#define SRST_STRC_A 14 -#define SRST_L2C 15 - -#define SRST_A53_GIC 18 -#define SRST_DAP 19 -#define SRST_PMU_P 21 -#define SRST_EFUSE 22 -#define SRST_BUSSYS_H 23 -#define SRST_BUSSYS_P 24 -#define SRST_SPDIF 25 -#define SRST_INTMEM 26 -#define SRST_ROM 27 -#define SRST_GPIO0 28 -#define SRST_GPIO1 29 -#define SRST_GPIO2 30 -#define SRST_GPIO3 31 - -#define SRST_I2S0 32 -#define SRST_I2S1 33 -#define SRST_I2S2 34 -#define SRST_I2S0_H 35 -#define SRST_I2S1_H 36 -#define SRST_I2S2_H 37 -#define SRST_UART0 38 -#define SRST_UART1 39 -#define SRST_UART2 40 -#define SRST_UART0_P 41 -#define SRST_UART1_P 42 -#define SRST_UART2_P 43 -#define SRST_I2C0 44 -#define SRST_I2C1 45 -#define SRST_I2C2 46 -#define SRST_I2C3 47 - -#define SRST_I2C0_P 48 -#define SRST_I2C1_P 49 -#define SRST_I2C2_P 50 -#define SRST_I2C3_P 51 -#define SRST_EFUSE_SE_P 52 -#define SRST_EFUSE_NS_P 53 -#define SRST_PWM0 54 -#define SRST_PWM0_P 55 -#define SRST_DMA 56 -#define SRST_TSP_A 57 -#define SRST_TSP_H 58 -#define SRST_TSP 59 -#define SRST_TSP_HSADC 60 -#define SRST_DCF_A 61 -#define SRST_DCF_P 62 - -#define SRST_SCR 64 -#define SRST_SPI 65 -#define SRST_TSADC 66 -#define SRST_TSADC_P 67 -#define SRST_CRYPTO 68 -#define SRST_SGRF 69 -#define SRST_GRF 70 -#define SRST_USB_GRF 71 -#define SRST_TIMER_6CH_P 72 -#define SRST_TIMER0 73 -#define SRST_TIMER1 74 -#define SRST_TIMER2 75 -#define SRST_TIMER3 76 -#define SRST_TIMER4 77 -#define SRST_TIMER5 78 -#define SRST_USB3GRF 79 - -#define SRST_PHYNIU 80 -#define SRST_HDMIPHY 81 -#define SRST_VDAC 82 -#define SRST_ACODEC_p 83 -#define SRST_SARADC 85 -#define SRST_SARADC_P 86 -#define SRST_GRF_DDR 87 -#define SRST_DFIMON 88 -#define SRST_MSCH 89 -#define SRST_DDRMSCH 91 -#define SRST_DDRCTRL 92 -#define SRST_DDRCTRL_P 93 -#define SRST_DDRPHY 94 -#define SRST_DDRPHY_P 95 - -#define SRST_GMAC_NIU_A 96 -#define SRST_GMAC_NIU_P 97 -#define SRST_GMAC2PHY_A 98 -#define SRST_GMAC2IO_A 99 -#define SRST_MACPHY 100 -#define SRST_OTP_PHY 101 -#define SRST_GPU_A 102 -#define SRST_GPU_NIU_A 103 -#define SRST_SDMMCEXT 104 -#define SRST_PERIPH_NIU_A 105 -#define SRST_PERIHP_NIU_H 106 -#define SRST_PERIHP_P 107 -#define SRST_PERIPHSYS_H 108 -#define SRST_MMC0 109 -#define SRST_SDIO 110 -#define SRST_EMMC 111 - -#define SRST_USB2OTG_H 112 -#define SRST_USB2OTG 113 -#define SRST_USB2OTG_ADP 114 -#define SRST_USB2HOST_H 115 -#define SRST_USB2HOST_ARB 116 -#define SRST_USB2HOST_AUX 117 -#define SRST_USB2HOST_EHCIPHY 118 -#define SRST_USB2HOST_UTMI 119 -#define SRST_USB3OTG 120 -#define SRST_USBPOR 121 -#define SRST_USB2OTG_UTMI 122 -#define SRST_USB2HOST_PHY_UTMI 123 -#define SRST_USB3OTG_UTMI 124 -#define SRST_USB3PHY_U2 125 -#define SRST_USB3PHY_U3 126 -#define SRST_USB3PHY_PIPE 127 - -#define SRST_VIO_A 128 -#define SRST_VIO_BUS_H 129 -#define SRST_VIO_H2P_H 130 -#define SRST_VIO_ARBI_H 131 -#define SRST_VOP_NIU_A 132 -#define SRST_VOP_A 133 -#define SRST_VOP_H 134 -#define SRST_VOP_D 135 -#define SRST_RGA 136 -#define SRST_RGA_NIU_A 137 -#define SRST_RGA_A 138 -#define SRST_RGA_H 139 -#define SRST_IEP_A 140 -#define SRST_IEP_H 141 -#define SRST_HDMI 142 -#define SRST_HDMI_P 143 - -#define SRST_HDCP_A 144 -#define SRST_HDCP 145 -#define SRST_HDCP_H 146 -#define SRST_CIF_A 147 -#define SRST_CIF_H 148 -#define SRST_CIF_P 149 -#define SRST_OTP_P 150 -#define SRST_OTP_SBPI 151 -#define SRST_OTP_USER 152 -#define SRST_DDRCTRL_A 153 -#define SRST_DDRSTDY_P 154 -#define SRST_DDRSTDY 155 -#define SRST_PDM_H 156 -#define SRST_PDM 157 -#define SRST_USB3PHY_OTG_P 158 -#define SRST_USB3PHY_PIPE_P 159 - -#define SRST_VCODEC_A 160 -#define SRST_VCODEC_NIU_A 161 -#define SRST_VCODEC_H 162 -#define SRST_VCODEC_NIU_H 163 -#define SRST_VDEC_A 164 -#define SRST_VDEC_NIU_A 165 -#define SRST_VDEC_H 166 -#define SRST_VDEC_NIU_H 167 -#define SRST_VDEC_CORE 168 -#define SRST_VDEC_CABAC 169 -#define SRST_DDRPHYDIV 175 - -#define SRST_RKVENC_NIU_A 176 -#define SRST_RKVENC_NIU_H 177 -#define SRST_RKVENC_H265_A 178 -#define SRST_RKVENC_H265_P 179 -#define SRST_RKVENC_H265_CORE 180 -#define SRST_RKVENC_H265_DSP 181 -#define SRST_RKVENC_H264_A 182 -#define SRST_RKVENC_H264_H 183 -#define SRST_RKVENC_INTMEM 184 - -#endif diff --git a/include/dt-bindings/power/rk3328-power.h b/include/dt-bindings/power/rk3328-power.h deleted file mode 100644 index 02e3d7fc1cce..000000000000 --- a/include/dt-bindings/power/rk3328-power.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3328_POWER_H__ -#define __DT_BINDINGS_POWER_RK3328_POWER_H__ - -/** - * RK3328 idle id Summary. - */ -#define RK3328_PD_CORE 0 -#define RK3328_PD_GPU 1 -#define RK3328_PD_BUS 2 -#define RK3328_PD_MSCH 3 -#define RK3328_PD_PERI 4 -#define RK3328_PD_VIDEO 5 -#define RK3328_PD_HEVC 6 -#define RK3328_PD_SYS 7 -#define RK3328_PD_VPU 8 -#define RK3328_PD_VIO 9 - -#endif
On 2024/5/5 03:42, Jonas Karlman wrote:
Remove redundant device tree files now that RK3328 boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
arch/arm/dts/rk3328-evb.dts | 289 --- arch/arm/dts/rk3328-nanopi-r2c-plus.dts | 33 - arch/arm/dts/rk3328-nanopi-r2c.dts | 40 - arch/arm/dts/rk3328-nanopi-r2s.dts | 410 ---- arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts | 42 - arch/arm/dts/rk3328-orangepi-r1-plus.dts | 374 ---- arch/arm/dts/rk3328-roc-cc.dts | 384 ---- arch/arm/dts/rk3328-rock-pi-e.dts | 445 ---- arch/arm/dts/rk3328-rock64.dts | 394 ---- arch/arm/dts/rk3328.dtsi | 1944 ------------------ include/dt-bindings/clock/rk3328-cru.h | 393 ---- include/dt-bindings/power/rk3328-power.h | 19 - 12 files changed, 4767 deletions(-) delete mode 100644 arch/arm/dts/rk3328-evb.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2c-plus.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2c.dts delete mode 100644 arch/arm/dts/rk3328-nanopi-r2s.dts delete mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts delete mode 100644 arch/arm/dts/rk3328-orangepi-r1-plus.dts delete mode 100644 arch/arm/dts/rk3328-roc-cc.dts delete mode 100644 arch/arm/dts/rk3328-rock-pi-e.dts delete mode 100644 arch/arm/dts/rk3328-rock64.dts delete mode 100644 arch/arm/dts/rk3328.dtsi delete mode 100644 include/dt-bindings/clock/rk3328-cru.h delete mode 100644 include/dt-bindings/power/rk3328-power.h
diff --git a/arch/arm/dts/rk3328-evb.dts b/arch/arm/dts/rk3328-evb.dts deleted file mode 100644 index 1eef5504445f..000000000000 --- a/arch/arm/dts/rk3328-evb.dts +++ /dev/null @@ -1,289 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd
-/dts-v1/; -#include "rk3328.dtsi"
- model = "Rockchip RK3328 EVB";
- compatible = "rockchip,rk3328-evb", "rockchip,rk3328";
- aliases {
ethernet0 = &gmac2phy;
mmc0 = &sdmmc;
mmc1 = &sdio;
mmc2 = &emmc;
- chosen {
stdout-path = "serial2:1500000n8";
- dc_12v: dc-12v {
compatible = "regulator-fixed";
regulator-name = "dc_12v";
regulator-always-on;
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
pinctrl-0 = <&wifi_enable_h>;
* On the module itself this is one of these (depending
* on the actual card populated):
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
reset-gpios = <&gpio1 18 GPIO_ACTIVE_LOW>;
- vcc_sd: sdmmc-regulator {
gpio = <&gpio0 30 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&sdmmc0m1_pin>;
regulator-name = "vcc_sd";
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&vcc_io>;
- vcc_sys: vcc-sys {
regulator-name = "vcc_sys";
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vin-supply = <&dc_12v>;
- vcc_phy: vcc-phy-regulator {
regulator-name = "vcc_phy";
regulator-boot-on;
-&cpu0 {
- cpu-supply = <&vdd_arm>;
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&emmc {
- bus-width = <8>;
- cap-mmc-highspeed;
- non-removable;
- pinctrl-0 = <&emmc_clk &emmc_cmd &emmc_bus8>;
- status = "okay";
-&gmac2phy {
- phy-supply = <&vcc_phy>;
- assigned-clock-rate = <50000000>;
- assigned-clocks = <&cru SCLK_MAC2PHY>;
- assigned-clock-parents = <&cru SCLK_MAC2PHY_SRC>;
- status = "okay";
-&i2c1 {
- status = "okay";
- rk805: pmic@18 {
compatible = "rockchip,rk805";
reg = <0x18>;
interrupt-parent = <&gpio2>;
interrupts = <6 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
clock-output-names = "xin32k", "rk805-clkout2";
gpio-controller;
#gpio-cells = <2>;
pinctrl-0 = <&pmic_int_l>;
rockchip,system-power-controller;
wakeup-source;
vcc1-supply = <&vcc_sys>;
vcc2-supply = <&vcc_sys>;
vcc3-supply = <&vcc_sys>;
vcc4-supply = <&vcc_sys>;
vcc5-supply = <&vcc_io>;
vcc6-supply = <&vcc_io>;
regulators {
vdd_logic: DCDC_REG1 {
regulator-name = "vdd_logic";
regulator-min-microvolt = <712500>;
regulator-max-microvolt = <1450000>;
regulator-boot-on;
regulator-state-mem {
regulator-on-in-suspend;
regulator-suspend-microvolt = <1000000>;
vdd_arm: DCDC_REG2 {
regulator-name = "vdd_arm";
regulator-boot-on;
regulator-suspend-microvolt = <950000>;
vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr";
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-name = "vcc_io";
regulator-boot-on;
regulator-suspend-microvolt = <3300000>;
vcc_18: LDO_REG1 {
regulator-name = "vcc_18";
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-boot-on;
regulator-suspend-microvolt = <1800000>;
vcc18_emmc: LDO_REG2 {
regulator-name = "vcc18_emmc";
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-name = "vdd_10";
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
-&pinctrl {
- pmic {
pmic_int_l: pmic-int-l {
rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>;
- sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
rockchip,pins =
<1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
-&sdio {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk>;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc0_clk &sdmmc0_cmd &sdmmc0_dectn &sdmmc0_bus4>;
- vmmc-supply = <&vcc_sd>;
- status = "okay";
-&tsadc {
- status = "okay";
-&uart2 {
- status = "okay";
-&u2phy {
- status = "okay";
-&u2phy_host {
- status = "okay";
-&u2phy_otg {
- status = "okay";
-&usb20_otg {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3328-nanopi-r2c-plus.dts b/arch/arm/dts/rk3328-nanopi-r2c-plus.dts deleted file mode 100644 index 16a1958e4572..000000000000 --- a/arch/arm/dts/rk3328-nanopi-r2c-plus.dts +++ /dev/null @@ -1,33 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/*
- Copyright (c) 2021 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2023 Tianling Shen cnsztl@gmail.com
-/dts-v1/; -#include "rk3328-nanopi-r2c.dts"
- model = "FriendlyElec NanoPi R2C Plus";
- compatible = "friendlyarm,nanopi-r2c-plus", "rockchip,rk3328";
- aliases {
mmc1 = &emmc;
-&emmc {
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- non-removable;
- vmmc-supply = <&vcc_io_33>;
- vqmmc-supply = <&vcc18_emmc>;
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3328-nanopi-r2c.dts b/arch/arm/dts/rk3328-nanopi-r2c.dts deleted file mode 100644 index a07a26b944a0..000000000000 --- a/arch/arm/dts/rk3328-nanopi-r2c.dts +++ /dev/null @@ -1,40 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/*
- Copyright (c) 2021-2023 Tianling Shen cnsztl@gmail.com
-/dts-v1/; -#include "rk3328-nanopi-r2s.dts"
- model = "FriendlyElec NanoPi R2C";
- compatible = "friendlyarm,nanopi-r2c", "rockchip,rk3328";
-&gmac2io {
- phy-handle = <&yt8521s>;
- tx_delay = <0x22>;
- rx_delay = <0x12>;
- mdio {
/delete-node/ ethernet-phy@1;
yt8521s: ethernet-phy@3 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <3>;
motorcomm,clk-out-frequency-hz = <125000000>;
motorcomm,keep-pll-enabled;
motorcomm,auto-sleep-disabled;
pinctrl-0 = <ð_phy_reset_pin>;
reset-assert-us = <10000>;
reset-deassert-us = <50000>;
reset-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>;
-}; diff --git a/arch/arm/dts/rk3328-nanopi-r2s.dts b/arch/arm/dts/rk3328-nanopi-r2s.dts deleted file mode 100644 index a4399da7d8b1..000000000000 --- a/arch/arm/dts/rk3328-nanopi-r2s.dts +++ /dev/null @@ -1,410 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2020 David Bauer mail@david-bauer.net
-/dts-v1/;
-#include <dt-bindings/input/input.h> -#include <dt-bindings/gpio/gpio.h> -#include "rk3328.dtsi"
- model = "FriendlyElec NanoPi R2S";
- compatible = "friendlyarm,nanopi-r2s", "rockchip,rk3328";
- aliases {
ethernet0 = &gmac2io;
ethernet1 = &rtl8153;
mmc0 = &sdmmc;
- chosen {
- gmac_clk: gmac-clock {
compatible = "fixed-clock";
clock-frequency = <125000000>;
clock-output-names = "gmac_clkin";
#clock-cells = <0>;
- keys {
compatible = "gpio-keys";
pinctrl-0 = <&reset_button_pin>;
key-reset {
label = "reset";
gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_LOW>;
linux,code = <KEY_RESTART>;
debounce-interval = <50>;
- leds {
compatible = "gpio-leds";
pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>;
lan_led: led-0 {
gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>;
label = "nanopi-r2s:green:lan";
sys_led: led-1 {
gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
label = "nanopi-r2s:red:sys";
default-state = "on";
wan_led: led-2 {
gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_HIGH>;
label = "nanopi-r2s:green:wan";
- vcc_io_sdio: sdmmcio-regulator {
compatible = "regulator-gpio";
enable-active-high;
gpios = <&gpio1 RK_PD4 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&sdio_vcc_pin>;
regulator-name = "vcc_io_sdio";
regulator-settling-time-us = <5000>;
regulator-type = "voltage";
startup-delay-us = <2000>;
states = <1800000 0x1>,
<3300000 0x0>;
vin-supply = <&vcc_io_33>;
gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_LOW>;
regulator-boot-on;
- vdd_5v: vdd-5v {
regulator-name = "vdd_5v";
regulator-boot-on;
- vdd_5v_lan: vdd-5v-lan {
enable-active-high;
gpio = <&gpio2 RK_PC6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&lan_vdd_pin>;
regulator-name = "vdd_5v_lan";
regulator-boot-on;
vin-supply = <&vdd_5v>;
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&display_subsystem {
-&gmac2io {
- assigned-clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_EXT>;
- assigned-clock-parents = <&gmac_clk>, <&gmac_clk>;
- clock_in_out = "input";
- phy-handle = <&rtl8211e>;
- phy-mode = "rgmii";
- phy-supply = <&vcc_io_33>;
- pinctrl-0 = <&rgmiim1_pins>;
- rx_delay = <0x18>;
- snps,aal;
- tx_delay = <0x24>;
- status = "okay";
- mdio {
#size-cells = <0>;
rtl8211e: ethernet-phy@1 {
reg = <1>;
-&i2c1 {
- status = "okay";
- rk805: pmic@18 {
reg = <0x18>;
interrupt-parent = <&gpio1>;
interrupts = <24 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
wakeup-source;
vcc1-supply = <&vdd_5v>;
vcc2-supply = <&vdd_5v>;
vcc3-supply = <&vdd_5v>;
vcc4-supply = <&vdd_5v>;
vcc5-supply = <&vcc_io_33>;
vcc6-supply = <&vdd_5v>;
regulators {
vdd_log: DCDC_REG1 {
regulator-name = "vdd_log";
regulator-boot-on;
regulator-ramp-delay = <12500>;
regulator-boot-on;
regulator-boot-on;
vcc_io_33: DCDC_REG4 {
regulator-name = "vcc_io_33";
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
-&io_domains {
- pmuio-supply = <&vcc_io_33>;
- vccio1-supply = <&vcc_io_33>;
- vccio2-supply = <&vcc18_emmc>;
- vccio3-supply = <&vcc_io_sdio>;
- vccio4-supply = <&vcc_18>;
- vccio5-supply = <&vcc_io_33>;
- vccio6-supply = <&vcc_io_33>;
- status = "okay";
-&pinctrl {
- button {
reset_button_pin: reset-button-pin {
rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
- gmac2io {
eth_phy_reset_pin: eth-phy-reset-pin {
rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>;
- leds {
lan_led_pin: lan-led-pin {
rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
sys_led_pin: sys-led-pin {
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
wan_led_pin: wan-led-pin {
rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
- lan {
lan_vdd_pin: lan-vdd-pin {
rockchip,pins = <2 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>;
- sd {
sdio_vcc_pin: sdio-vcc-pin {
rockchip,pins = <1 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>;
-&pwm2 {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc0_clk>, <&sdmmc0_cmd>, <&sdmmc0_dectn>, <&sdmmc0_bus4>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- vqmmc-supply = <&vcc_io_sdio>;
- status = "okay";
-&tsadc {
- rockchip,hw-tshut-mode = <0>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
-&u2phy {
- status = "okay";
-&u2phy_host {
- status = "okay";
-&u2phy_otg {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb20_otg {
- status = "okay";
- dr_mode = "host";
-&usbdrd3 {
- dr_mode = "host";
- status = "okay";
- /* Second port is for USB 3.0 */
- rtl8153: device@2 {
compatible = "usbbda,8153";
reg = <2>;
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts b/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts deleted file mode 100644 index 4237f2ee8fee..000000000000 --- a/arch/arm/dts/rk3328-orangepi-r1-plus-lts.dts +++ /dev/null @@ -1,42 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/*
- Copyright (c) 2016 Xunlong Software. Co., Ltd.
-/dts-v1/; -#include "rk3328-orangepi-r1-plus.dts"
- model = "Xunlong Orange Pi R1 Plus LTS";
- compatible = "xunlong,orangepi-r1-plus-lts", "rockchip,rk3328";
-&gmac2io {
- phy-handle = <&yt8531c>;
- tx_delay = <0x19>;
- rx_delay = <0x05>;
- mdio {
yt8531c: ethernet-phy@0 {
reg = <0>;
motorcomm,rx-clk-drv-microamp = <5020>;
motorcomm,rx-data-drv-microamp = <5020>;
reset-assert-us = <15000>;
-}; diff --git a/arch/arm/dts/rk3328-orangepi-r1-plus.dts b/arch/arm/dts/rk3328-orangepi-r1-plus.dts deleted file mode 100644 index f20662929c77..000000000000 --- a/arch/arm/dts/rk3328-orangepi-r1-plus.dts +++ /dev/null @@ -1,374 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Based on rk3328-nanopi-r2s.dts, which is:
-/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include "rk3328.dtsi"
- model = "Xunlong Orange Pi R1 Plus";
- compatible = "xunlong,orangepi-r1-plus", "rockchip,rk3328";
- aliases {
mmc0 = &sdmmc;
- chosen {
#clock-cells = <0>;
- leds {
led-0 {
function = LED_FUNCTION_LAN;
color = <LED_COLOR_ID_GREEN>;
led-1 {
function = LED_FUNCTION_STATUS;
color = <LED_COLOR_ID_RED>;
gpios = <&gpio3 RK_PC5 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
led-2 {
function = LED_FUNCTION_WAN;
regulator-boot-on;
- vcc_sys: vcc-sys-regulator {
regulator-boot-on;
- vdd_5v_lan: vdd-5v-lan-regulator {
enable-active-high;
regulator-boot-on;
vin-supply = <&vcc_sys>;
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gmac2io {
- phy-supply = <&vcc_io>;
- snps,aal;
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <1>;
-&i2c1 {
- status = "okay";
- rk805: pmic@18 {
reg = <0x18>;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
wakeup-source;
vcc6-supply = <&vcc_sys>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
-&io_domains {
- pmuio-supply = <&vcc_io>;
- vccio1-supply = <&vcc_io>;
- vccio3-supply = <&vcc_io>;
- vccio4-supply = <&vcc_io>;
- vccio5-supply = <&vcc_io>;
- vccio6-supply = <&vcc_io>;
- status = "okay";
-&pinctrl {
- gmac2io {
- leds {
rockchip,pins = <3 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
- lan {
- pmic {
-&pwm2 {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
-&spi0 {
- status = "okay";
- flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <50000000>;
-&tsadc {
- status = "okay";
-&u2phy {
- status = "okay";
-&u2phy_host {
- status = "okay";
-&u2phy_otg {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb20_otg {
- dr_mode = "host";
- status = "okay";
-&usbdrd3 {
- dr_mode = "host";
- status = "okay";
reg = <2>;
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3328-roc-cc.dts b/arch/arm/dts/rk3328-roc-cc.dts deleted file mode 100644 index 414897a57e75..000000000000 --- a/arch/arm/dts/rk3328-roc-cc.dts +++ /dev/null @@ -1,384 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd
- model = "Firefly roc-rk3328-cc";
- compatible = "firefly,roc-rk3328-cc", "rockchip,rk3328";
- aliases {
mmc0 = &sdmmc;
mmc1 = &emmc;
- chosen {
- gmac_clkin: external-gmac-clock {
#clock-cells = <0>;
- dc_12v: dc-12v {
regulator-boot-on;
regulator-boot-on;
- vcc_sdio: sdmmcio-regulator {
gpios = <&grf_gpio 0 GPIO_ACTIVE_HIGH>;
<3300000 0x0>;
regulator-name = "vcc_sdio";
- vcc_host1_5v: vcc_otg_5v: vcc-host1-5v-regulator {
enable-active-high;
gpio = <&gpio1 RK_PD2 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&usb20_host_drv>;
regulator-name = "vcc_host1_5v";
regulator-boot-on;
regulator-boot-on;
- leds {
power_led: led-0 {
label = "firefly:blue:power";
gpios = <&rk805 1 GPIO_ACTIVE_LOW>;
user_led: led-1 {
label = "firefly:yellow:user";
linux,default-trigger = "mmc1";
gpios = <&rk805 0 GPIO_ACTIVE_LOW>;
default-state = "off";
-&analog_sound {
- status = "okay";
-&codec {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&emmc {
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- non-removable;
- vmmc-supply = <&vcc_io>;
- status = "okay";
-&gmac2io {
- assigned-clock-parents = <&gmac_clkin>, <&gmac_clkin>;
- snps,aal;
- snps,reset-gpio = <&gpio1 RK_PC2 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- snps,rxpbl = <0x4>;
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmiphy {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c1 {
- status = "okay";
- rk805: pmic@18 {
reg = <0x18>;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
-&i2s0 {
- status = "okay";
-&i2s1 {
- status = "okay";
-&io_domains {
- status = "okay";
- vccio3-supply = <&vcc_sdio>;
-&pinctrl {
- pmic {
- usb2 {
usb20_host_drv: usb20-host-drv {
rockchip,pins = <1 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- vqmmc-supply = <&vcc_sdio>;
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy {
- status = "okay";
-&u2phy_host {
- status = "okay";
-&u2phy_otg {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb20_otg {
- dr_mode = "host";
- status = "okay";
-&usbdrd3 {
- dr_mode = "host";
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3328-rock-pi-e.dts b/arch/arm/dts/rk3328-rock-pi-e.dts deleted file mode 100644 index 3cda6c627b68..000000000000 --- a/arch/arm/dts/rk3328-rock-pi-e.dts +++ /dev/null @@ -1,445 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- (C) Copyright 2020 Chen-Yu Tsai wens@csie.org
- Based on ./rk3328-rock64.dts, which is
- Copyright (c) 2017 PINE64
-/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h>
- model = "Radxa ROCK Pi E";
- compatible = "radxa,rockpi-e", "rockchip,rk3328";
- aliases {
ethernet1 = &gmac2phy;
mmc0 = &sdmmc;
mmc1 = &emmc;
- chosen {
- adc-keys {
compatible = "adc-keys";
io-channels = <&saradc 0>;
io-channel-names = "buttons";
keyup-threshold-microvolt = <1750000>;
/* This button is unpopulated out of the factory. */
button-recovery {
label = "Recovery";
linux,code = <KEY_VENDOR>;
press-threshold-microvolt = <10000>;
#clock-cells = <0>;
- leds {
pinctrl-0 = <&led_pin>;
led-0 {
color = <LED_COLOR_ID_BLUE>;
gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_LOW>;
regulator-boot-on;
- vcc_host_5v: vcc-host-5v-regulator {
gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&usb30_host_drv>;
enable-active-high;
regulator-name = "vcc_host_5v";
regulator-boot-on;
regulator-boot-on;
- vcc_wifi: vcc-wifi-regulator {
gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&wifi_en>;
regulator-name = "vcc_wifi";
regulator-boot-on;
-&analog_sound {
- status = "okay";
-&codec {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&emmc {
- bus-width = <8>;
- mmc-ddr-1_8v;
- mmc-hs200-1_8v;
- non-removable;
- pinctrl-0 = <&emmc_clk>, <&emmc_cmd>, <&emmc_bus8>;
- status = "okay";
-&gmac2io {
- snps,aal;
- tx_delay = <0x26>;
- rx_delay = <0x11>;
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <1>;
pinctrl-0 = <ð_phy_int_pin>, <ð_phy_reset_pin>;
-&gmac2phy {
- status = "okay";
-&gpio0 {
- gpio-line-names =
/* GPIO0_A0 - A7 */
/* GPIO0_B0 - B7 */
/* GPIO0_C0 - C7 */
/* GPIO0_D0 - D7 */
"", "", "", "pin-15 [GPIO0_D3]", "", "", "", "";
-&gpio1 {
- gpio-line-names =
/* GPIO1_A0 - A7 */
/* GPIO1_B0 - B7 */
/* GPIO1_C0 - C7 */
/* GPIO1_D0 - D7 */
"", "", "", "", "pin-07 [GPIO1_D4]", "", "", "";
-&gpio2 {
- gpio-line-names =
/* GPIO2_A0 - A7 */
"pin-08 [GPIO2_A0]", "pin-10 [GPIO2_A1]", "pin-11 [GPIO2_A2]",
"pin-13 [GPIO2-A3]", "pin-27 [GPIO2_A4]", "pin-28 [GPIO2_A5]",
"pin-33 [GPIO2_A6]", "",
/* GPIO2_B0 - B7 */
"", "", "", "", "pin-26 [GPIO2_B4]", "", "", "pin-36 [GPIO2_B7]",
/* GPIO2_C0 - C7 */
"pin-32 [GPIO2_C0]", "pin-35 [GPIO2_C1]", "pin-12 [GPIO2_C2]",
"pin-38 [GPIO2_C3]", "pin-29 [GPIO2_C4]", "pin-31 [GPIO2_C5]",
"pin-37 [GPIO2_C6]", "pin-40 [GPIO2_C7]",
/* GPIO2_D0 - D7 */
-&gpio3 {
- gpio-line-names =
/* GPIO3_A0 - A7 */
"pin-23 [GPIO3_A0]", "pin-19 [GPIO3_A1]", "pin-21 [GPIO3_A2]",
"", "pin-03 [GPIO3_A4]", "", "pin-05 [GPIO3_A6]", "",
/* GPIO3_B0 - B7 */
"pin-24 [GPIO3_B0]", "", "", "", "", "", "", "",
/* GPIO3_C0 - C7 */
/* GPIO3_D0 - D7 */
-&i2c1 {
- status = "okay";
- rk805: pmic@18 {
reg = <0x18>;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
-&i2s1 {
- status = "okay";
-&io_domains {
- status = "okay";
-&pinctrl {
- ephy {
eth_phy_int_pin: eth-phy-int-pin {
rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_down>;
- leds {
led_pin: led-pin {
- pmic {
- usb3 {
usb30_host_drv: usb30-host-drv {
rockchip,pins = <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>;
- wifi {
wifi_en: wifi-en {
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
-&saradc {
- vref-supply = <&vcc_18>;
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy {
- status = "okay";
-&u2phy_host {
- status = "okay";
-&uart2 {
- status = "okay";
-&usbdrd3 {
- dr_mode = "host";
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3328-rock64.dts b/arch/arm/dts/rk3328-rock64.dts deleted file mode 100644 index 229fe9da9c2d..000000000000 --- a/arch/arm/dts/rk3328-rock64.dts +++ /dev/null @@ -1,394 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- model = "Pine64 Rock64";
- compatible = "pine64,rock64", "rockchip,rk3328";
- aliases {
mmc0 = &sdmmc;
mmc1 = &emmc;
- chosen {
#clock-cells = <0>;
- /* Common enable line for all of the rails mentioned in the labels */
- vcc_host_5v: vcc_host1_5v: vcc_otg_5v: vcc-host-5v-regulator {
gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_LOW>;
regulator-boot-on;
regulator-boot-on;
- ir-receiver {
compatible = "gpio-ir-receiver";
gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&ir_int>;
- leds {
power_led: led-0 {
linux,default-trigger = "mmc0";
standby_led: led-1 {
- spdif_sound: spdif-sound {
compatible = "simple-audio-card";
simple-audio-card,name = "SPDIF";
simple-audio-card,cpu {
sound-dai = <&spdif>;
simple-audio-card,codec {
sound-dai = <&spdif_dit>;
- spdif_dit: spdif-dit {
compatible = "linux,spdif-dit";
#sound-dai-cells = <0>;
-&analog_sound {
- status = "okay";
-&codec {
- mute-gpios = <&grf_gpio 0 GPIO_ACTIVE_LOW>;
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&emmc {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&gmac2io {
- snps,force_thresh_dma_mode;
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&hdmiphy {
- status = "okay";
-&i2c1 {
- status = "okay";
- rk805: pmic@18 {
reg = <0x18>;
#clock-cells = <1>;
gpio-controller;
#gpio-cells = <2>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_io: DCDC_REG4 {
regulator-boot-on;
vcc_18: LDO_REG1 {
regulator-boot-on;
regulator-boot-on;
vdd_10: LDO_REG3 {
regulator-boot-on;
-&i2s0 {
- status = "okay";
-&i2s1 {
- status = "okay";
-&io_domains {
- status = "okay";
-&pinctrl {
- ir {
ir_int: ir-int {
rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
- usb2 {
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
-&spdif {
- pinctrl-0 = <&spdifm0_tx>;
- status = "okay";
-&spi0 {
- status = "okay";
- flash@0 {
reg = <0>;
/* maximum speed for Rockchip SPI */
-&tsadc {
- status = "okay";
-&uart2 {
- status = "okay";
-&u2phy {
- status = "okay";
status = "okay";
status = "okay";
-&usb20_otg {
- dr_mode = "host";
- status = "okay";
-&usbdrd3 {
- dr_mode = "host";
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3328.dtsi b/arch/arm/dts/rk3328.dtsi deleted file mode 100644 index fb5dcf6e9327..000000000000 --- a/arch/arm/dts/rk3328.dtsi +++ /dev/null @@ -1,1944 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-#include <dt-bindings/clock/rk3328-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rk3328-power.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> -#include <dt-bindings/thermal/thermal.h>
- compatible = "rockchip,rk3328";
- interrupt-parent = <&gic>;
- aliases {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
gpio3 = &gpio3;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a53";
reg = <0x0 0x0>;
clocks = <&cru ARMCLK>;
#cooling-cells = <2>;
cpu-idle-states = <&CPU_SLEEP>;
dynamic-power-coefficient = <120>;
enable-method = "psci";
next-level-cache = <&l2>;
operating-points-v2 = <&cpu0_opp_table>;
cpu1: cpu@1 {
reg = <0x0 0x1>;
cpu2: cpu@2 {
reg = <0x0 0x2>;
cpu3: cpu@3 {
reg = <0x0 0x3>;
idle-states {
entry-method = "psci";
CPU_SLEEP: cpu-sleep {
compatible = "arm,idle-state";
local-timer-stop;
arm,psci-suspend-param = <0x0010000>;
entry-latency-us = <120>;
exit-latency-us = <250>;
min-residency-us = <900>;
l2: l2-cache0 {
compatible = "cache";
cache-level = <2>;
cache-unified;
- cpu0_opp_table: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp-408000000 {
opp-hz = /bits/ 64 <408000000>;
opp-microvolt = <950000>;
clock-latency-ns = <40000>;
opp-suspend;
opp-600000000 {
opp-hz = /bits/ 64 <600000000>;
opp-816000000 {
opp-hz = /bits/ 64 <816000000>;
opp-microvolt = <1000000>;
opp-1008000000 {
opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <1100000>;
opp-1200000000 {
opp-hz = /bits/ 64 <1200000000>;
opp-microvolt = <1225000>;
opp-1296000000 {
opp-hz = /bits/ 64 <1296000000>;
opp-microvolt = <1300000>;
- analog_sound: analog-sound {
simple-audio-card,format = "i2s";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,name = "Analog";
sound-dai = <&i2s1>;
sound-dai = <&codec>;
- arm-pmu {
compatible = "arm,cortex-a53-pmu";
interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>;
- display_subsystem: display-subsystem {
compatible = "rockchip,display-subsystem";
ports = <&vop_out>;
- hdmi_sound: hdmi-sound {
simple-audio-card,mclk-fs = <128>;
simple-audio-card,name = "HDMI";
sound-dai = <&i2s0>;
sound-dai = <&hdmi>;
- psci {
compatible = "arm,psci-1.0", "arm,psci-0.2";
method = "smc";
- timer {
compatible = "arm,armv8-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>,
<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_LOW)>;
- xin24m: xin24m {
#clock-cells = <0>;
clock-frequency = <24000000>;
clock-output-names = "xin24m";
- i2s0: i2s@ff000000 {
compatible = "rockchip,rk3328-i2s", "rockchip,rk3066-i2s";
reg = <0x0 0xff000000 0x0 0x1000>;
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_I2S0>, <&cru HCLK_I2S0_8CH>;
clock-names = "i2s_clk", "i2s_hclk";
dmas = <&dmac 11>, <&dmac 12>;
dma-names = "tx", "rx";
- i2s1: i2s@ff010000 {
reg = <0x0 0xff010000 0x0 0x1000>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_I2S1>, <&cru HCLK_I2S1_8CH>;
dmas = <&dmac 14>, <&dmac 15>;
- i2s2: i2s@ff020000 {
reg = <0x0 0xff020000 0x0 0x1000>;
interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_I2S2>, <&cru HCLK_I2S2_2CH>;
dmas = <&dmac 0>, <&dmac 1>;
- spdif: spdif@ff030000 {
compatible = "rockchip,rk3328-spdif";
reg = <0x0 0xff030000 0x0 0x1000>;
interrupts = <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_SPDIF>, <&cru HCLK_SPDIF_8CH>;
clock-names = "mclk", "hclk";
dmas = <&dmac 10>;
dma-names = "tx";
pinctrl-names = "default";
pinctrl-0 = <&spdifm2_tx>;
- pdm: pdm@ff040000 {
compatible = "rockchip,pdm";
reg = <0x0 0xff040000 0x0 0x1000>;
clocks = <&cru SCLK_PDM>, <&cru HCLK_PDM>;
clock-names = "pdm_clk", "pdm_hclk";
dmas = <&dmac 16>;
dma-names = "rx";
pinctrl-names = "default", "sleep";
pinctrl-0 = <&pdmm0_clk
&pdmm0_sdi0
&pdmm0_sdi1
&pdmm0_sdi2
&pdmm0_sdi3>;
pinctrl-1 = <&pdmm0_clk_sleep
&pdmm0_sdi0_sleep
&pdmm0_sdi1_sleep
&pdmm0_sdi2_sleep
&pdmm0_sdi3_sleep>;
- grf: syscon@ff100000 {
compatible = "rockchip,rk3328-grf", "syscon", "simple-mfd";
reg = <0x0 0xff100000 0x0 0x1000>;
io_domains: io-domains {
compatible = "rockchip,rk3328-io-voltage-domain";
status = "disabled";
grf_gpio: gpio {
compatible = "rockchip,rk3328-grf-gpio";
gpio-controller;
#gpio-cells = <2>;
power: power-controller {
compatible = "rockchip,rk3328-power-controller";
#power-domain-cells = <1>;
#address-cells = <1>;
#size-cells = <0>;
power-domain@RK3328_PD_HEVC {
reg = <RK3328_PD_HEVC>;
#power-domain-cells = <0>;
power-domain@RK3328_PD_VIDEO {
reg = <RK3328_PD_VIDEO>;
clocks = <&cru ACLK_RKVDEC>,
<&cru HCLK_RKVDEC>,
<&cru SCLK_VDEC_CABAC>,
<&cru SCLK_VDEC_CORE>;
power-domain@RK3328_PD_VPU {
reg = <RK3328_PD_VPU>;
clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>;
reboot-mode {
compatible = "syscon-reboot-mode";
offset = <0x5c8>;
mode-normal = <BOOT_NORMAL>;
mode-recovery = <BOOT_RECOVERY>;
mode-bootloader = <BOOT_FASTBOOT>;
mode-loader = <BOOT_BL_DOWNLOAD>;
- uart0: serial@ff110000 {
compatible = "rockchip,rk3328-uart", "snps,dw-apb-uart";
reg = <0x0 0xff110000 0x0 0x100>;
interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>;
clock-names = "baudclk", "apb_pclk";
dmas = <&dmac 2>, <&dmac 3>;
pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
reg-io-width = <4>;
reg-shift = <2>;
- uart1: serial@ff120000 {
reg = <0x0 0xff120000 0x0 0x100>;
interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>;
dmas = <&dmac 4>, <&dmac 5>;
pinctrl-0 = <&uart1_xfer &uart1_cts &uart1_rts>;
reg-io-width = <4>;
reg-shift = <2>;
- uart2: serial@ff130000 {
reg = <0x0 0xff130000 0x0 0x100>;
interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>;
dmas = <&dmac 6>, <&dmac 7>;
pinctrl-0 = <&uart2m1_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- i2c0: i2c@ff150000 {
compatible = "rockchip,rk3328-i2c", "rockchip,rk3399-i2c";
reg = <0x0 0xff150000 0x0 0x1000>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&cru SCLK_I2C0>, <&cru PCLK_I2C0>;
clock-names = "i2c", "pclk";
pinctrl-0 = <&i2c0_xfer>;
- i2c1: i2c@ff160000 {
reg = <0x0 0xff160000 0x0 0x1000>;
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>;
pinctrl-0 = <&i2c1_xfer>;
- i2c2: i2c@ff170000 {
reg = <0x0 0xff170000 0x0 0x1000>;
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>;
pinctrl-0 = <&i2c2_xfer>;
- i2c3: i2c@ff180000 {
reg = <0x0 0xff180000 0x0 0x1000>;
interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>;
pinctrl-0 = <&i2c3_xfer>;
- spi0: spi@ff190000 {
compatible = "rockchip,rk3328-spi", "rockchip,rk3066-spi";
reg = <0x0 0xff190000 0x0 0x1000>;
interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>;
#size-cells = <0>;
clocks = <&cru SCLK_SPI>, <&cru PCLK_SPI>;
clock-names = "spiclk", "apb_pclk";
dmas = <&dmac 8>, <&dmac 9>;
pinctrl-0 = <&spi0m2_clk &spi0m2_tx &spi0m2_rx &spi0m2_cs0>;
- wdt: watchdog@ff1a0000 {
compatible = "rockchip,rk3328-wdt", "snps,dw-wdt";
reg = <0x0 0xff1a0000 0x0 0x100>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_WDT>;
- pwm0: pwm@ff1b0000 {
compatible = "rockchip,rk3328-pwm";
reg = <0x0 0xff1b0000 0x0 0x10>;
clocks = <&cru SCLK_PWM>, <&cru PCLK_PWM>;
clock-names = "pwm", "pclk";
pinctrl-0 = <&pwm0_pin>;
#pwm-cells = <3>;
- pwm1: pwm@ff1b0010 {
reg = <0x0 0xff1b0010 0x0 0x10>;
pinctrl-0 = <&pwm1_pin>;
#pwm-cells = <3>;
- pwm2: pwm@ff1b0020 {
reg = <0x0 0xff1b0020 0x0 0x10>;
pinctrl-0 = <&pwm2_pin>;
#pwm-cells = <3>;
- pwm3: pwm@ff1b0030 {
reg = <0x0 0xff1b0030 0x0 0x10>;
interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-0 = <&pwmir_pin>;
#pwm-cells = <3>;
- dmac: dma-controller@ff1f0000 {
compatible = "arm,pl330", "arm,primecell";
reg = <0x0 0xff1f0000 0x0 0x4000>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH>;
arm,pl330-periph-burst;
clocks = <&cru ACLK_DMAC>;
clock-names = "apb_pclk";
#dma-cells = <1>;
- thermal-zones {
soc_thermal: soc-thermal {
polling-delay-passive = <20>;
polling-delay = <1000>;
sustainable-power = <1000>;
thermal-sensors = <&tsadc 0>;
trips {
threshold: trip-point0 {
temperature = <70000>;
hysteresis = <2000>;
type = "passive";
target: trip-point1 {
temperature = <85000>;
type = "passive";
soc_crit: soc-crit {
temperature = <95000>;
type = "critical";
cooling-maps {
map0 {
trip = <&target>;
cooling-device = <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
contribution = <4096>;
- tsadc: tsadc@ff250000 {
compatible = "rockchip,rk3328-tsadc";
reg = <0x0 0xff250000 0x0 0x100>;
interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH>;
assigned-clocks = <&cru SCLK_TSADC>;
assigned-clock-rates = <50000>;
clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>;
clock-names = "tsadc", "apb_pclk";
pinctrl-names = "init", "default", "sleep";
pinctrl-0 = <&otp_pin>;
pinctrl-1 = <&otp_out>;
pinctrl-2 = <&otp_pin>;
resets = <&cru SRST_TSADC>;
reset-names = "tsadc-apb";
rockchip,grf = <&grf>;
rockchip,hw-tshut-temp = <100000>;
#thermal-sensor-cells = <1>;
- efuse: efuse@ff260000 {
compatible = "rockchip,rk3328-efuse";
reg = <0x0 0xff260000 0x0 0x50>;
#size-cells = <1>;
clocks = <&cru SCLK_EFUSE>;
clock-names = "pclk_efuse";
rockchip,efuse-size = <0x20>;
/* Data cells */
efuse_id: id@7 {
reg = <0x07 0x10>;
cpu_leakage: cpu-leakage@17 {
reg = <0x17 0x1>;
logic_leakage: logic-leakage@19 {
reg = <0x19 0x1>;
efuse_cpu_version: cpu-version@1a {
reg = <0x1a 0x1>;
bits = <3 3>;
- saradc: adc@ff280000 {
compatible = "rockchip,rk3328-saradc", "rockchip,rk3399-saradc";
reg = <0x0 0xff280000 0x0 0x100>;
interrupts = <GIC_SPI 80 IRQ_TYPE_LEVEL_HIGH>;
#io-channel-cells = <1>;
clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>;
clock-names = "saradc", "apb_pclk";
resets = <&cru SRST_SARADC_P>;
reset-names = "saradc-apb";
- gpu: gpu@ff300000 {
compatible = "rockchip,rk3328-mali", "arm,mali-450";
reg = <0x0 0xff300000 0x0 0x30000>;
interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 87 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 88 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 89 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 91 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 92 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "gp",
"gpmmu",
"pp",
"pp0",
"ppmmu0",
"pp1",
"ppmmu1";
clocks = <&cru ACLK_GPU>, <&cru ACLK_GPU>;
clock-names = "bus", "core";
resets = <&cru SRST_GPU_A>;
- h265e_mmu: iommu@ff330200 {
compatible = "rockchip,iommu";
reg = <0x0 0xff330200 0 0x100>;
interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_H265>, <&cru PCLK_H265>;
clock-names = "aclk", "iface";
#iommu-cells = <0>;
- vepu_mmu: iommu@ff340800 {
reg = <0x0 0xff340800 0x0 0x40>;
interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <0>;
- vpu: video-codec@ff350000 {
compatible = "rockchip,rk3328-vpu";
reg = <0x0 0xff350000 0x0 0x800>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "vdpu";
clock-names = "aclk", "hclk";
iommus = <&vpu_mmu>;
power-domains = <&power RK3328_PD_VPU>;
- vpu_mmu: iommu@ff350800 {
reg = <0x0 0xff350800 0x0 0x40>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <0>;
- vdec: video-codec@ff360000 {
compatible = "rockchip,rk3328-vdec", "rockchip,rk3399-vdec";
reg = <0x0 0xff360000 0x0 0x480>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>,
<&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>;
clock-names = "axi", "ahb", "cabac", "core";
assigned-clocks = <&cru ACLK_RKVDEC>, <&cru SCLK_VDEC_CABAC>,
assigned-clock-rates = <400000000>, <400000000>, <300000000>;
iommus = <&vdec_mmu>;
power-domains = <&power RK3328_PD_VIDEO>;
- vdec_mmu: iommu@ff360480 {
reg = <0x0 0xff360480 0x0 0x40>, <0x0 0xff3604c0 0x0 0x40>;
interrupts = <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_RKVDEC>, <&cru HCLK_RKVDEC>;
#iommu-cells = <0>;
- vop: vop@ff370000 {
compatible = "rockchip,rk3328-vop";
reg = <0x0 0xff370000 0x0 0x3efc>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_VOP>, <&cru DCLK_LCDC>, <&cru HCLK_VOP>;
clock-names = "aclk_vop", "dclk_vop", "hclk_vop";
resets = <&cru SRST_VOP_A>, <&cru SRST_VOP_H>, <&cru SRST_VOP_D>;
reset-names = "axi", "ahb", "dclk";
iommus = <&vop_mmu>;
vop_out: port {
#size-cells = <0>;
vop_out_hdmi: endpoint@0 {
reg = <0>;
remote-endpoint = <&hdmi_in_vop>;
- vop_mmu: iommu@ff373f00 {
reg = <0x0 0xff373f00 0x0 0x100>;
clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>;
#iommu-cells = <0>;
- hdmi: hdmi@ff3c0000 {
compatible = "rockchip,rk3328-dw-hdmi";
reg = <0x0 0xff3c0000 0x0 0x20000>;
reg-io-width = <4>;
interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_HDMI>,
<&cru SCLK_HDMI_SFC>,
<&cru SCLK_RTC32K>;
clock-names = "iahb",
"isfr",
"cec";
phys = <&hdmiphy>;
phy-names = "hdmi";
pinctrl-0 = <&hdmi_cec &hdmii2c_xfer &hdmi_hpd>;
ports {
hdmi_in: port {
hdmi_in_vop: endpoint {
remote-endpoint = <&vop_out_hdmi>;
- codec: codec@ff410000 {
compatible = "rockchip,rk3328-codec";
reg = <0x0 0xff410000 0x0 0x1000>;
clocks = <&cru PCLK_ACODECPHY>, <&cru SCLK_I2S1>;
clock-names = "pclk", "mclk";
- hdmiphy: phy@ff430000 {
compatible = "rockchip,rk3328-hdmi-phy";
reg = <0x0 0xff430000 0x0 0x10000>;
interrupts = <GIC_SPI 83 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_HDMIPHY>, <&xin24m>, <&cru DCLK_HDMIPHY>;
clock-names = "sysclk", "refoclk", "refpclk";
clock-output-names = "hdmi_phy";
#clock-cells = <0>;
nvmem-cells = <&efuse_cpu_version>;
nvmem-cell-names = "cpu-version";
#phy-cells = <0>;
- cru: clock-controller@ff440000 {
compatible = "rockchip,rk3328-cru", "rockchip,cru", "syscon";
reg = <0x0 0xff440000 0x0 0x1000>;
#clock-cells = <1>;
#reset-cells = <1>;
assigned-clocks =
* CPLL should run at 1200, but that is to high for
* the initial dividers of most of its children.
* We need set cpll child clk div first,
* and then set the cpll frequency.
<&cru DCLK_LCDC>, <&cru SCLK_PDM>,
<&cru SCLK_RTC32K>, <&cru SCLK_UART0>,
<&cru SCLK_UART1>, <&cru SCLK_UART2>,
<&cru ACLK_BUS_PRE>, <&cru ACLK_PERI_PRE>,
<&cru ACLK_VIO_PRE>, <&cru ACLK_RGA_PRE>,
<&cru ACLK_VOP_PRE>, <&cru ACLK_RKVDEC_PRE>,
<&cru ACLK_RKVENC>, <&cru ACLK_VPU_PRE>,
<&cru SCLK_VDEC_CABAC>, <&cru SCLK_VDEC_CORE>,
<&cru SCLK_VENC_CORE>, <&cru SCLK_VENC_DSP>,
<&cru SCLK_SDIO>, <&cru SCLK_TSP>,
<&cru SCLK_WIFI>, <&cru ARMCLK>,
<&cru PLL_GPLL>, <&cru PLL_CPLL>,
<&cru ACLK_BUS_PRE>, <&cru HCLK_BUS_PRE>,
<&cru PCLK_BUS_PRE>, <&cru ACLK_PERI_PRE>,
<&cru HCLK_PERI>, <&cru PCLK_PERI>,
<&cru SCLK_RTC32K>;
<&cru HDMIPHY>, <&cru PLL_APLL>,
<&cru PLL_GPLL>, <&xin24m>,
<&xin24m>, <&xin24m>;
<0>, <61440000>,
<0>, <24000000>,
<24000000>, <24000000>,
<15000000>, <15000000>,
<100000000>, <100000000>,
<50000000>, <100000000>,
<50000000>, <50000000>,
<24000000>, <600000000>,
<491520000>, <1200000000>,
<150000000>, <75000000>,
<75000000>, <150000000>,
<75000000>, <75000000>,
<32768>;
- usb2phy_grf: syscon@ff450000 {
compatible = "rockchip,rk3328-usb2phy-grf", "syscon",
"simple-mfd";
reg = <0x0 0xff450000 0x0 0x10000>;
#size-cells = <1>;
u2phy: usb2phy@100 {
compatible = "rockchip,rk3328-usb2phy";
reg = <0x100 0x10>;
clocks = <&xin24m>;
clock-names = "phyclk";
clock-output-names = "usb480m_phy";
#clock-cells = <0>;
assigned-clocks = <&cru USB480M>;
assigned-clock-parents = <&u2phy>;
u2phy_otg: otg-port {
#phy-cells = <0>;
interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 61 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "otg-bvalid", "otg-id",
"linestate";
u2phy_host: host-port {
#phy-cells = <0>;
interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "linestate";
- sdmmc: mmc@ff500000 {
compatible = "rockchip,rk3328-dw-mshc", "rockchip,rk3288-dw-mshc";
reg = <0x0 0xff500000 0x0 0x4000>;
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>,
<&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>;
clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
fifo-depth = <0x100>;
max-frequency = <150000000>;
- sdio: mmc@ff510000 {
reg = <0x0 0xff510000 0x0 0x4000>;
interrupts = <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>,
<&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>;
- emmc: mmc@ff520000 {
reg = <0x0 0xff520000 0x0 0x4000>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_EMMC>, <&cru SCLK_EMMC>,
<&cru SCLK_EMMC_DRV>, <&cru SCLK_EMMC_SAMPLE>;
- gmac2io: ethernet@ff540000 {
compatible = "rockchip,rk3328-gmac";
reg = <0x0 0xff540000 0x0 0x10000>;
interrupts = <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "macirq";
clocks = <&cru SCLK_MAC2IO>, <&cru SCLK_MAC2IO_RX>,
<&cru SCLK_MAC2IO_TX>, <&cru SCLK_MAC2IO_REF>,
<&cru SCLK_MAC2IO_REFOUT>, <&cru ACLK_MAC2IO>,
<&cru PCLK_MAC2IO>;
clock-names = "stmmaceth", "mac_clk_rx",
"mac_clk_tx", "clk_mac_ref",
"clk_mac_refout", "aclk_mac",
"pclk_mac";
resets = <&cru SRST_GMAC2IO_A>;
reset-names = "stmmaceth";
tx-fifo-depth = <2048>;
rx-fifo-depth = <4096>;
snps,txpbl = <0x4>;
- gmac2phy: ethernet@ff550000 {
reg = <0x0 0xff550000 0x0 0x10000>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_MAC2PHY_SRC>, <&cru SCLK_MAC2PHY_RXTX>,
<&cru SCLK_MAC2PHY_RXTX>, <&cru SCLK_MAC2PHY_REF>,
<&cru ACLK_MAC2PHY>, <&cru PCLK_MAC2PHY>,
<&cru SCLK_MAC2PHY_OUT>;
"aclk_mac", "pclk_mac",
"clk_macphy";
resets = <&cru SRST_GMAC2PHY_A>;
phy-mode = "rmii";
phy-handle = <&phy>;
snps,txpbl = <0x4>;
clock_in_out = "output";
mdio {
compatible = "snps,dwmac-mdio";
#size-cells = <0>;
phy: ethernet-phy@0 {
compatible = "ethernet-phy-id1234.d400", "ethernet-phy-ieee802.3-c22";
reg = <0>;
clocks = <&cru SCLK_MAC2PHY_OUT>;
resets = <&cru SRST_MACPHY>;
pinctrl-0 = <&fephyled_rxm1 &fephyled_linkm1>;
phy-is-integrated;
- usb20_otg: usb@ff580000 {
compatible = "rockchip,rk3328-usb", "rockchip,rk3066-usb",
"snps,dwc2";
reg = <0x0 0xff580000 0x0 0x40000>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_OTG>;
clock-names = "otg";
dr_mode = "otg";
g-np-tx-fifo-size = <16>;
g-rx-fifo-size = <280>;
g-tx-fifo-size = <256 128 128 64 32 16>;
phys = <&u2phy_otg>;
phy-names = "usb2-phy";
- usb_host0_ehci: usb@ff5c0000 {
compatible = "generic-ehci";
reg = <0x0 0xff5c0000 0x0 0x10000>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_HOST0>, <&u2phy>;
phys = <&u2phy_host>;
phy-names = "usb";
- usb_host0_ohci: usb@ff5d0000 {
compatible = "generic-ohci";
reg = <0x0 0xff5d0000 0x0 0x10000>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH>;
phy-names = "usb";
- usbdrd3: usb@ff600000 {
compatible = "rockchip,rk3328-dwc3", "snps,dwc3";
reg = <0x0 0xff600000 0x0 0x100000>;
interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_USB3OTG_REF>, <&cru SCLK_USB3OTG_SUSPEND>,
<&cru ACLK_USB3OTG>;
clock-names = "ref_clk", "suspend_clk",
"bus_clk";
dr_mode = "otg";
phy_type = "utmi_wide";
snps,dis-del-phy-power-chg-quirk;
snps,dis_enblslpm_quirk;
snps,dis-tx-ipgap-linecheck-quirk;
snps,dis-u2-freeclk-exists-quirk;
snps,dis_u2_susphy_quirk;
snps,dis_u3_susphy_quirk;
- gic: interrupt-controller@ff811000 {
compatible = "arm,gic-400";
#interrupt-cells = <3>;
#address-cells = <0>;
interrupt-controller;
reg = <0x0 0xff811000 0 0x1000>,
<0x0 0xff812000 0 0x2000>,
<0x0 0xff814000 0 0x2000>,
<0x0 0xff816000 0 0x2000>;
interrupts = <GIC_PPI 9
(GIC_CPU_MASK_SIMPLE(4) | IRQ_TYPE_LEVEL_HIGH)>;
- crypto: crypto@ff060000 {
compatible = "rockchip,rk3328-crypto";
reg = <0x0 0xff060000 0x0 0x4000>;
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_CRYPTO_MST>, <&cru HCLK_CRYPTO_SLV>,
<&cru SCLK_CRYPTO>;
clock-names = "hclk_master", "hclk_slave", "sclk";
resets = <&cru SRST_CRYPTO>;
reset-names = "crypto-rst";
- pinctrl: pinctrl {
compatible = "rockchip,rk3328-pinctrl";
#address-cells = <2>;
#size-cells = <2>;
ranges;
gpio0: gpio@ff210000 {
compatible = "rockchip,gpio-bank";
reg = <0x0 0xff210000 0x0 0x100>;
interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO0>;
gpio-controller;
#gpio-cells = <2>;
#interrupt-cells = <2>;
gpio1: gpio@ff220000 {
reg = <0x0 0xff220000 0x0 0x100>;
interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO1>;
gpio-controller;
#gpio-cells = <2>;
gpio2: gpio@ff230000 {
reg = <0x0 0xff230000 0x0 0x100>;
interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO2>;
gpio-controller;
#gpio-cells = <2>;
gpio3: gpio@ff240000 {
reg = <0x0 0xff240000 0x0 0x100>;
interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO3>;
gpio-controller;
#gpio-cells = <2>;
pcfg_pull_up: pcfg-pull-up {
bias-pull-up;
pcfg_pull_down: pcfg-pull-down {
bias-pull-down;
pcfg_pull_none: pcfg-pull-none {
bias-disable;
pcfg_pull_none_2ma: pcfg-pull-none-2ma {
bias-disable;
drive-strength = <2>;
pcfg_pull_up_2ma: pcfg-pull-up-2ma {
bias-pull-up;
pcfg_pull_up_4ma: pcfg-pull-up-4ma {
bias-pull-up;
drive-strength = <4>;
pcfg_pull_none_4ma: pcfg-pull-none-4ma {
bias-disable;
pcfg_pull_down_4ma: pcfg-pull-down-4ma {
bias-pull-down;
pcfg_pull_none_8ma: pcfg-pull-none-8ma {
bias-disable;
drive-strength = <8>;
pcfg_pull_up_8ma: pcfg-pull-up-8ma {
bias-pull-up;
pcfg_pull_none_12ma: pcfg-pull-none-12ma {
bias-disable;
drive-strength = <12>;
pcfg_pull_up_12ma: pcfg-pull-up-12ma {
bias-pull-up;
pcfg_output_high: pcfg-output-high {
output-high;
pcfg_output_low: pcfg-output-low {
output-low;
pcfg_input_high: pcfg-input-high {
bias-pull-up;
input-enable;
pcfg_input: pcfg-input {
input-enable;
i2c0 {
i2c0_xfer: i2c0-xfer {
rockchip,pins = <2 RK_PD0 1 &pcfg_pull_none>,
<2 RK_PD1 1 &pcfg_pull_none>;
i2c1 {
i2c1_xfer: i2c1-xfer {
rockchip,pins = <2 RK_PA4 2 &pcfg_pull_none>,
<2 RK_PA5 2 &pcfg_pull_none>;
i2c2 {
i2c2_xfer: i2c2-xfer {
rockchip,pins = <2 RK_PB5 1 &pcfg_pull_none>,
<2 RK_PB6 1 &pcfg_pull_none>;
i2c3 {
i2c3_xfer: i2c3-xfer {
rockchip,pins = <0 RK_PA5 2 &pcfg_pull_none>,
<0 RK_PA6 2 &pcfg_pull_none>;
i2c3_pins: i2c3-pins {
rockchip,pins =
<0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>,
<0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
hdmi_i2c {
hdmii2c_xfer: hdmii2c-xfer {
rockchip,pins = <0 RK_PA5 1 &pcfg_pull_none>,
<0 RK_PA6 1 &pcfg_pull_none>;
pdm-0 {
pdmm0_clk: pdmm0-clk {
rockchip,pins = <2 RK_PC2 2 &pcfg_pull_none>;
pdmm0_fsync: pdmm0-fsync {
rockchip,pins = <2 RK_PC7 2 &pcfg_pull_none>;
pdmm0_sdi0: pdmm0-sdi0 {
rockchip,pins = <2 RK_PC3 2 &pcfg_pull_none>;
pdmm0_sdi1: pdmm0-sdi1 {
rockchip,pins = <2 RK_PC4 2 &pcfg_pull_none>;
pdmm0_sdi2: pdmm0-sdi2 {
rockchip,pins = <2 RK_PC5 2 &pcfg_pull_none>;
pdmm0_sdi3: pdmm0-sdi3 {
rockchip,pins = <2 RK_PC6 2 &pcfg_pull_none>;
pdmm0_clk_sleep: pdmm0-clk-sleep {
rockchip,pins =
<2 RK_PC2 RK_FUNC_GPIO &pcfg_input_high>;
pdmm0_sdi0_sleep: pdmm0-sdi0-sleep {
rockchip,pins =
<2 RK_PC3 RK_FUNC_GPIO &pcfg_input_high>;
pdmm0_sdi1_sleep: pdmm0-sdi1-sleep {
rockchip,pins =
<2 RK_PC4 RK_FUNC_GPIO &pcfg_input_high>;
pdmm0_sdi2_sleep: pdmm0-sdi2-sleep {
rockchip,pins =
<2 RK_PC5 RK_FUNC_GPIO &pcfg_input_high>;
pdmm0_sdi3_sleep: pdmm0-sdi3-sleep {
rockchip,pins =
<2 RK_PC6 RK_FUNC_GPIO &pcfg_input_high>;
pdmm0_fsync_sleep: pdmm0-fsync-sleep {
rockchip,pins =
<2 RK_PC7 RK_FUNC_GPIO &pcfg_input_high>;
tsadc {
otp_pin: otp-pin {
rockchip,pins = <2 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
otp_out: otp-out {
rockchip,pins = <2 RK_PB5 1 &pcfg_pull_none>;
uart0 {
uart0_xfer: uart0-xfer {
rockchip,pins = <1 RK_PB1 1 &pcfg_pull_none>,
<1 RK_PB0 1 &pcfg_pull_up>;
uart0_cts: uart0-cts {
rockchip,pins = <1 RK_PB3 1 &pcfg_pull_none>;
uart0_rts: uart0-rts {
rockchip,pins = <1 RK_PB2 1 &pcfg_pull_none>;
uart0_rts_pin: uart0-rts-pin {
rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
uart1 {
uart1_xfer: uart1-xfer {
rockchip,pins = <3 RK_PA4 4 &pcfg_pull_none>,
<3 RK_PA6 4 &pcfg_pull_up>;
uart1_cts: uart1-cts {
rockchip,pins = <3 RK_PA7 4 &pcfg_pull_none>;
uart1_rts: uart1-rts {
rockchip,pins = <3 RK_PA5 4 &pcfg_pull_none>;
uart1_rts_pin: uart1-rts-pin {
rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
uart2-0 {
uart2m0_xfer: uart2m0-xfer {
rockchip,pins = <1 RK_PA0 2 &pcfg_pull_none>,
<1 RK_PA1 2 &pcfg_pull_up>;
uart2-1 {
uart2m1_xfer: uart2m1-xfer {
rockchip,pins = <2 RK_PA0 1 &pcfg_pull_none>,
<2 RK_PA1 1 &pcfg_pull_up>;
spi0-0 {
spi0m0_clk: spi0m0-clk {
rockchip,pins = <2 RK_PB0 1 &pcfg_pull_up>;
spi0m0_cs0: spi0m0-cs0 {
rockchip,pins = <2 RK_PB3 1 &pcfg_pull_up>;
spi0m0_tx: spi0m0-tx {
rockchip,pins = <2 RK_PB1 1 &pcfg_pull_up>;
spi0m0_rx: spi0m0-rx {
rockchip,pins = <2 RK_PB2 1 &pcfg_pull_up>;
spi0m0_cs1: spi0m0-cs1 {
rockchip,pins = <2 RK_PB4 1 &pcfg_pull_up>;
spi0-1 {
spi0m1_clk: spi0m1-clk {
rockchip,pins = <3 RK_PC7 2 &pcfg_pull_up>;
spi0m1_cs0: spi0m1-cs0 {
rockchip,pins = <3 RK_PD2 2 &pcfg_pull_up>;
spi0m1_tx: spi0m1-tx {
rockchip,pins = <3 RK_PD1 2 &pcfg_pull_up>;
spi0m1_rx: spi0m1-rx {
rockchip,pins = <3 RK_PD0 2 &pcfg_pull_up>;
spi0m1_cs1: spi0m1-cs1 {
rockchip,pins = <3 RK_PD3 2 &pcfg_pull_up>;
spi0-2 {
spi0m2_clk: spi0m2-clk {
rockchip,pins = <3 RK_PA0 4 &pcfg_pull_up>;
spi0m2_cs0: spi0m2-cs0 {
rockchip,pins = <3 RK_PB0 3 &pcfg_pull_up>;
spi0m2_tx: spi0m2-tx {
rockchip,pins = <3 RK_PA1 4 &pcfg_pull_up>;
spi0m2_rx: spi0m2-rx {
rockchip,pins = <3 RK_PA2 4 &pcfg_pull_up>;
i2s1 {
i2s1_mclk: i2s1-mclk {
rockchip,pins = <2 RK_PB7 1 &pcfg_pull_none>;
i2s1_sclk: i2s1-sclk {
rockchip,pins = <2 RK_PC2 1 &pcfg_pull_none>;
i2s1_lrckrx: i2s1-lrckrx {
rockchip,pins = <2 RK_PC0 1 &pcfg_pull_none>;
i2s1_lrcktx: i2s1-lrcktx {
rockchip,pins = <2 RK_PC1 1 &pcfg_pull_none>;
i2s1_sdi: i2s1-sdi {
rockchip,pins = <2 RK_PC3 1 &pcfg_pull_none>;
i2s1_sdo: i2s1-sdo {
rockchip,pins = <2 RK_PC7 1 &pcfg_pull_none>;
i2s1_sdio1: i2s1-sdio1 {
rockchip,pins = <2 RK_PC4 1 &pcfg_pull_none>;
i2s1_sdio2: i2s1-sdio2 {
rockchip,pins = <2 RK_PC5 1 &pcfg_pull_none>;
i2s1_sdio3: i2s1-sdio3 {
rockchip,pins = <2 RK_PC6 1 &pcfg_pull_none>;
i2s1_sleep: i2s1-sleep {
rockchip,pins =
<2 RK_PB7 RK_FUNC_GPIO &pcfg_input_high>,
<2 RK_PC0 RK_FUNC_GPIO &pcfg_input_high>,
<2 RK_PC1 RK_FUNC_GPIO &pcfg_input_high>,
<2 RK_PC2 RK_FUNC_GPIO &pcfg_input_high>,
<2 RK_PC3 RK_FUNC_GPIO &pcfg_input_high>,
<2 RK_PC4 RK_FUNC_GPIO &pcfg_input_high>,
<2 RK_PC5 RK_FUNC_GPIO &pcfg_input_high>,
<2 RK_PC6 RK_FUNC_GPIO &pcfg_input_high>,
i2s2-0 {
i2s2m0_mclk: i2s2m0-mclk {
rockchip,pins = <1 RK_PC5 1 &pcfg_pull_none>;
i2s2m0_sclk: i2s2m0-sclk {
rockchip,pins = <1 RK_PC6 1 &pcfg_pull_none>;
i2s2m0_lrckrx: i2s2m0-lrckrx {
rockchip,pins = <1 RK_PD2 1 &pcfg_pull_none>;
i2s2m0_lrcktx: i2s2m0-lrcktx {
rockchip,pins = <1 RK_PC7 1 &pcfg_pull_none>;
i2s2m0_sdi: i2s2m0-sdi {
rockchip,pins = <1 RK_PD0 1 &pcfg_pull_none>;
i2s2m0_sdo: i2s2m0-sdo {
rockchip,pins = <1 RK_PD1 1 &pcfg_pull_none>;
i2s2m0_sleep: i2s2m0-sleep {
rockchip,pins =
<1 RK_PC5 RK_FUNC_GPIO &pcfg_input_high>,
<1 RK_PC6 RK_FUNC_GPIO &pcfg_input_high>,
<1 RK_PD2 RK_FUNC_GPIO &pcfg_input_high>,
<1 RK_PC7 RK_FUNC_GPIO &pcfg_input_high>,
<1 RK_PD0 RK_FUNC_GPIO &pcfg_input_high>,
<1 RK_PD1 RK_FUNC_GPIO &pcfg_input_high>;
i2s2-1 {
i2s2m1_mclk: i2s2m1-mclk {
i2s2m1_sclk: i2s2m1-sclk {
rockchip,pins = <3 RK_PA0 6 &pcfg_pull_none>;
i2s2m1_lrckrx: i2sm1-lrckrx {
rockchip,pins = <3 RK_PB0 6 &pcfg_pull_none>;
i2s2m1_lrcktx: i2s2m1-lrcktx {
rockchip,pins = <3 RK_PB0 4 &pcfg_pull_none>;
i2s2m1_sdi: i2s2m1-sdi {
rockchip,pins = <3 RK_PA2 6 &pcfg_pull_none>;
i2s2m1_sdo: i2s2m1-sdo {
rockchip,pins = <3 RK_PA1 6 &pcfg_pull_none>;
i2s2m1_sleep: i2s2m1-sleep {
rockchip,pins =
<3 RK_PA0 RK_FUNC_GPIO &pcfg_input_high>,
<3 RK_PB0 RK_FUNC_GPIO &pcfg_input_high>,
<3 RK_PA2 RK_FUNC_GPIO &pcfg_input_high>,
<3 RK_PA1 RK_FUNC_GPIO &pcfg_input_high>;
spdif-0 {
spdifm0_tx: spdifm0-tx {
rockchip,pins = <0 RK_PD3 1 &pcfg_pull_none>;
spdif-1 {
spdifm1_tx: spdifm1-tx {
rockchip,pins = <2 RK_PC1 2 &pcfg_pull_none>;
spdif-2 {
spdifm2_tx: spdifm2-tx {
rockchip,pins = <0 RK_PA2 2 &pcfg_pull_none>;
sdmmc0-0 {
sdmmc0m0_pwren: sdmmc0m0-pwren {
rockchip,pins = <2 RK_PA7 1 &pcfg_pull_up_4ma>;
sdmmc0m0_pin: sdmmc0m0-pin {
rockchip,pins = <2 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up_4ma>;
sdmmc0-1 {
sdmmc0m1_pwren: sdmmc0m1-pwren {
rockchip,pins = <0 RK_PD6 3 &pcfg_pull_up_4ma>;
sdmmc0m1_pin: sdmmc0m1-pin {
rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up_4ma>;
sdmmc0 {
sdmmc0_clk: sdmmc0-clk {
rockchip,pins = <1 RK_PA6 1 &pcfg_pull_none_8ma>;
sdmmc0_cmd: sdmmc0-cmd {
rockchip,pins = <1 RK_PA4 1 &pcfg_pull_up_8ma>;
sdmmc0_dectn: sdmmc0-dectn {
rockchip,pins = <1 RK_PA5 1 &pcfg_pull_up_4ma>;
sdmmc0_wrprt: sdmmc0-wrprt {
rockchip,pins = <1 RK_PA7 1 &pcfg_pull_up_4ma>;
sdmmc0_bus1: sdmmc0-bus1 {
rockchip,pins = <1 RK_PA0 1 &pcfg_pull_up_8ma>;
sdmmc0_bus4: sdmmc0-bus4 {
rockchip,pins = <1 RK_PA0 1 &pcfg_pull_up_8ma>,
<1 RK_PA1 1 &pcfg_pull_up_8ma>,
<1 RK_PA2 1 &pcfg_pull_up_8ma>,
<1 RK_PA3 1 &pcfg_pull_up_8ma>;
sdmmc0_pins: sdmmc0-pins {
rockchip,pins =
<1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up_4ma>;
sdmmc0ext {
sdmmc0ext_clk: sdmmc0ext-clk {
rockchip,pins = <3 RK_PA2 3 &pcfg_pull_none_4ma>;
sdmmc0ext_cmd: sdmmc0ext-cmd {
rockchip,pins = <3 RK_PA0 3 &pcfg_pull_up_4ma>;
sdmmc0ext_wrprt: sdmmc0ext-wrprt {
rockchip,pins = <3 RK_PA3 3 &pcfg_pull_up_4ma>;
sdmmc0ext_dectn: sdmmc0ext-dectn {
rockchip,pins = <3 RK_PA1 3 &pcfg_pull_up_4ma>;
sdmmc0ext_bus1: sdmmc0ext-bus1 {
rockchip,pins = <3 RK_PA4 3 &pcfg_pull_up_4ma>;
sdmmc0ext_bus4: sdmmc0ext-bus4 {
rockchip,pins =
<3 RK_PA4 3 &pcfg_pull_up_4ma>,
<3 RK_PA5 3 &pcfg_pull_up_4ma>,
<3 RK_PA6 3 &pcfg_pull_up_4ma>,
<3 RK_PA7 3 &pcfg_pull_up_4ma>;
sdmmc0ext_pins: sdmmc0ext-pins {
rockchip,pins =
<3 RK_PA0 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up_4ma>;
sdmmc1 {
sdmmc1_clk: sdmmc1-clk {
rockchip,pins = <1 RK_PB4 1 &pcfg_pull_none_8ma>;
sdmmc1_cmd: sdmmc1-cmd {
rockchip,pins = <1 RK_PB5 1 &pcfg_pull_up_8ma>;
sdmmc1_pwren: sdmmc1-pwren {
rockchip,pins = <1 RK_PC2 1 &pcfg_pull_up_8ma>;
sdmmc1_wrprt: sdmmc1-wrprt {
rockchip,pins = <1 RK_PC4 1 &pcfg_pull_up_8ma>;
sdmmc1_dectn: sdmmc1-dectn {
rockchip,pins = <1 RK_PC3 1 &pcfg_pull_up_8ma>;
sdmmc1_bus1: sdmmc1-bus1 {
rockchip,pins = <1 RK_PB6 1 &pcfg_pull_up_8ma>;
sdmmc1_bus4: sdmmc1-bus4 {
rockchip,pins = <1 RK_PB6 1 &pcfg_pull_up_8ma>,
<1 RK_PB7 1 &pcfg_pull_up_8ma>,
<1 RK_PC0 1 &pcfg_pull_up_8ma>,
<1 RK_PC1 1 &pcfg_pull_up_8ma>;
sdmmc1_pins: sdmmc1-pins {
rockchip,pins =
<1 RK_PB4 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PB7 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PC0 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PC3 RK_FUNC_GPIO &pcfg_pull_up_4ma>,
<1 RK_PC4 RK_FUNC_GPIO &pcfg_pull_up_4ma>;
emmc {
emmc_clk: emmc-clk {
rockchip,pins = <3 RK_PC5 2 &pcfg_pull_none_12ma>;
emmc_cmd: emmc-cmd {
rockchip,pins = <3 RK_PC3 2 &pcfg_pull_up_12ma>;
emmc_pwren: emmc-pwren {
rockchip,pins = <3 RK_PC6 2 &pcfg_pull_none>;
emmc_rstnout: emmc-rstnout {
rockchip,pins = <3 RK_PC4 2 &pcfg_pull_none>;
emmc_bus1: emmc-bus1 {
rockchip,pins = <0 RK_PA7 2 &pcfg_pull_up_12ma>;
emmc_bus4: emmc-bus4 {
rockchip,pins =
<0 RK_PA7 2 &pcfg_pull_up_12ma>,
<2 RK_PD4 2 &pcfg_pull_up_12ma>,
<2 RK_PD5 2 &pcfg_pull_up_12ma>,
<2 RK_PD6 2 &pcfg_pull_up_12ma>;
emmc_bus8: emmc-bus8 {
rockchip,pins =
<2 RK_PD6 2 &pcfg_pull_up_12ma>,
<2 RK_PD7 2 &pcfg_pull_up_12ma>,
<3 RK_PC0 2 &pcfg_pull_up_12ma>,
<3 RK_PC1 2 &pcfg_pull_up_12ma>,
<3 RK_PC2 2 &pcfg_pull_up_12ma>;
pwm0 {
pwm0_pin: pwm0-pin {
rockchip,pins = <2 RK_PA4 1 &pcfg_pull_none>;
pwm1 {
pwm1_pin: pwm1-pin {
rockchip,pins = <2 RK_PA5 1 &pcfg_pull_none>;
pwm2 {
pwm2_pin: pwm2-pin {
rockchip,pins = <2 RK_PA6 1 &pcfg_pull_none>;
pwmir {
pwmir_pin: pwmir-pin {
rockchip,pins = <2 RK_PA2 1 &pcfg_pull_none>;
gmac-1 {
rgmiim1_pins: rgmiim1-pins {
rockchip,pins =
/* mac_txclk */
<1 RK_PB4 2 &pcfg_pull_none_8ma>,
/* mac_rxclk */
<1 RK_PB5 2 &pcfg_pull_none_4ma>,
/* mac_mdio */
<1 RK_PC3 2 &pcfg_pull_none_4ma>,
/* mac_txen */
<1 RK_PD1 2 &pcfg_pull_none_8ma>,
/* mac_clk */
<1 RK_PC5 2 &pcfg_pull_none_4ma>,
/* mac_rxdv */
<1 RK_PC6 2 &pcfg_pull_none_4ma>,
/* mac_mdc */
<1 RK_PC7 2 &pcfg_pull_none_4ma>,
/* mac_rxd1 */
<1 RK_PB2 2 &pcfg_pull_none_4ma>,
/* mac_rxd0 */
<1 RK_PB3 2 &pcfg_pull_none_4ma>,
/* mac_txd1 */
<1 RK_PB0 2 &pcfg_pull_none_8ma>,
/* mac_txd0 */
<1 RK_PB1 2 &pcfg_pull_none_8ma>,
/* mac_rxd3 */
<1 RK_PB6 2 &pcfg_pull_none_4ma>,
/* mac_rxd2 */
<1 RK_PB7 2 &pcfg_pull_none_4ma>,
/* mac_txd3 */
<1 RK_PC0 2 &pcfg_pull_none_8ma>,
/* mac_txd2 */
<1 RK_PC1 2 &pcfg_pull_none_8ma>,
/* mac_txclk */
<0 RK_PB0 1 &pcfg_pull_none_8ma>,
/* mac_txen */
<0 RK_PB4 1 &pcfg_pull_none_8ma>,
/* mac_clk */
<0 RK_PD0 1 &pcfg_pull_none_4ma>,
/* mac_txd1 */
<0 RK_PC0 1 &pcfg_pull_none_8ma>,
/* mac_txd0 */
<0 RK_PC1 1 &pcfg_pull_none_8ma>,
/* mac_txd3 */
<0 RK_PC7 1 &pcfg_pull_none_8ma>,
/* mac_txd2 */
<0 RK_PC6 1 &pcfg_pull_none_8ma>;
rmiim1_pins: rmiim1-pins {
rockchip,pins =
/* mac_mdio */
<1 RK_PC3 2 &pcfg_pull_none_2ma>,
/* mac_txen */
<1 RK_PD1 2 &pcfg_pull_none_12ma>,
/* mac_clk */
<1 RK_PC5 2 &pcfg_pull_none_2ma>,
/* mac_rxer */
<1 RK_PD0 2 &pcfg_pull_none_2ma>,
/* mac_rxdv */
<1 RK_PC6 2 &pcfg_pull_none_2ma>,
/* mac_mdc */
<1 RK_PC7 2 &pcfg_pull_none_2ma>,
/* mac_rxd1 */
<1 RK_PB2 2 &pcfg_pull_none_2ma>,
/* mac_rxd0 */
<1 RK_PB3 2 &pcfg_pull_none_2ma>,
/* mac_txd1 */
<1 RK_PB0 2 &pcfg_pull_none_12ma>,
/* mac_txd0 */
<1 RK_PB1 2 &pcfg_pull_none_12ma>,
/* mac_mdio */
<0 RK_PB3 1 &pcfg_pull_none>,
/* mac_txen */
<0 RK_PB4 1 &pcfg_pull_none>,
/* mac_clk */
<0 RK_PD0 1 &pcfg_pull_none>,
/* mac_mdc */
<0 RK_PC3 1 &pcfg_pull_none>,
/* mac_txd1 */
<0 RK_PC0 1 &pcfg_pull_none>,
/* mac_txd0 */
<0 RK_PC1 1 &pcfg_pull_none>;
gmac2phy {
fephyled_speed10: fephyled-speed10 {
rockchip,pins = <0 RK_PD6 1 &pcfg_pull_none>;
fephyled_duplex: fephyled-duplex {
rockchip,pins = <0 RK_PD6 2 &pcfg_pull_none>;
fephyled_rxm1: fephyled-rxm1 {
rockchip,pins = <2 RK_PD1 2 &pcfg_pull_none>;
fephyled_txm1: fephyled-txm1 {
rockchip,pins = <2 RK_PD1 3 &pcfg_pull_none>;
fephyled_linkm1: fephyled-linkm1 {
rockchip,pins = <2 RK_PD0 2 &pcfg_pull_none>;
tsadc_pin {
tsadc_int: tsadc-int {
rockchip,pins = <2 RK_PB5 2 &pcfg_pull_none>;
tsadc_pin: tsadc-pin {
hdmi_pin {
hdmi_cec: hdmi-cec {
rockchip,pins = <0 RK_PA3 1 &pcfg_pull_none>;
hdmi_hpd: hdmi-hpd {
rockchip,pins = <0 RK_PA4 1 &pcfg_pull_down>;
cif-0 {
dvp_d2d9_m0:dvp-d2d9-m0 {
rockchip,pins =
/* cif_d0 */
<3 RK_PA4 2 &pcfg_pull_none>,
/* cif_d1 */
<3 RK_PA5 2 &pcfg_pull_none>,
/* cif_d2 */
<3 RK_PA6 2 &pcfg_pull_none>,
/* cif_d3 */
<3 RK_PA7 2 &pcfg_pull_none>,
/* cif_d4 */
<3 RK_PB0 2 &pcfg_pull_none>,
/* cif_d5m0 */
<3 RK_PB1 2 &pcfg_pull_none>,
/* cif_d6m0 */
<3 RK_PB2 2 &pcfg_pull_none>,
/* cif_d7m0 */
<3 RK_PB3 2 &pcfg_pull_none>,
/* cif_href */
<3 RK_PA1 2 &pcfg_pull_none>,
/* cif_vsync */
<3 RK_PA0 2 &pcfg_pull_none>,
/* cif_clkoutm0 */
<3 RK_PA3 2 &pcfg_pull_none>,
/* cif_clkin */
<3 RK_PA2 2 &pcfg_pull_none>;
cif-1 {
dvp_d2d9_m1:dvp-d2d9-m1 {
rockchip,pins =
/* cif_d0 */
/* cif_d1 */
/* cif_d2 */
/* cif_d3 */
/* cif_d4 */
/* cif_d5m1 */
<2 RK_PC0 4 &pcfg_pull_none>,
/* cif_d6m1 */
<2 RK_PC1 4 &pcfg_pull_none>,
/* cif_d7m1 */
<2 RK_PC2 4 &pcfg_pull_none>,
/* cif_href */
/* cif_vsync */
/* cif_clkoutm1 */
<2 RK_PB7 4 &pcfg_pull_none>,
/* cif_clkin */
-}; diff --git a/include/dt-bindings/clock/rk3328-cru.h b/include/dt-bindings/clock/rk3328-cru.h deleted file mode 100644 index 555b4ff660ae..000000000000 --- a/include/dt-bindings/clock/rk3328-cru.h +++ /dev/null @@ -1,393 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/*
- Copyright (c) 2016 Rockchip Electronics Co. Ltd.
- Author: Elaine zhangqing@rock-chips.com
-#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3328_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3328_H
-/* core clocks */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_NPLL 5 -#define ARMCLK 6
-/* sclk gates (special clocks) */ -#define SCLK_RTC32K 30 -#define SCLK_SDMMC_EXT 31 -#define SCLK_SPI 32 -#define SCLK_SDMMC 33 -#define SCLK_SDIO 34 -#define SCLK_EMMC 35 -#define SCLK_TSADC 36 -#define SCLK_SARADC 37 -#define SCLK_UART0 38 -#define SCLK_UART1 39 -#define SCLK_UART2 40 -#define SCLK_I2S0 41 -#define SCLK_I2S1 42 -#define SCLK_I2S2 43 -#define SCLK_I2S1_OUT 44 -#define SCLK_I2S2_OUT 45 -#define SCLK_SPDIF 46 -#define SCLK_TIMER0 47 -#define SCLK_TIMER1 48 -#define SCLK_TIMER2 49 -#define SCLK_TIMER3 50 -#define SCLK_TIMER4 51 -#define SCLK_TIMER5 52 -#define SCLK_WIFI 53 -#define SCLK_CIF_OUT 54 -#define SCLK_I2C0 55 -#define SCLK_I2C1 56 -#define SCLK_I2C2 57 -#define SCLK_I2C3 58 -#define SCLK_CRYPTO 59 -#define SCLK_PWM 60 -#define SCLK_PDM 61 -#define SCLK_EFUSE 62 -#define SCLK_OTP 63 -#define SCLK_DDRCLK 64 -#define SCLK_VDEC_CABAC 65 -#define SCLK_VDEC_CORE 66 -#define SCLK_VENC_DSP 67 -#define SCLK_VENC_CORE 68 -#define SCLK_RGA 69 -#define SCLK_HDMI_SFC 70 -#define SCLK_HDMI_CEC 71 -#define SCLK_USB3_REF 72 -#define SCLK_USB3_SUSPEND 73 -#define SCLK_SDMMC_DRV 74 -#define SCLK_SDIO_DRV 75 -#define SCLK_EMMC_DRV 76 -#define SCLK_SDMMC_EXT_DRV 77 -#define SCLK_SDMMC_SAMPLE 78 -#define SCLK_SDIO_SAMPLE 79 -#define SCLK_EMMC_SAMPLE 80 -#define SCLK_SDMMC_EXT_SAMPLE 81 -#define SCLK_VOP 82 -#define SCLK_MAC2PHY_RXTX 83 -#define SCLK_MAC2PHY_SRC 84 -#define SCLK_MAC2PHY_REF 85 -#define SCLK_MAC2PHY_OUT 86 -#define SCLK_MAC2IO_RX 87 -#define SCLK_MAC2IO_TX 88 -#define SCLK_MAC2IO_REFOUT 89 -#define SCLK_MAC2IO_REF 90 -#define SCLK_MAC2IO_OUT 91 -#define SCLK_TSP 92 -#define SCLK_HSADC_TSP 93 -#define SCLK_USB3PHY_REF 94 -#define SCLK_REF_USB3OTG 95 -#define SCLK_USB3OTG_REF 96 -#define SCLK_USB3OTG_SUSPEND 97 -#define SCLK_REF_USB3OTG_SRC 98 -#define SCLK_MAC2IO_SRC 99 -#define SCLK_MAC2IO 100 -#define SCLK_MAC2PHY 101 -#define SCLK_MAC2IO_EXT 102
-/* dclk gates */ -#define DCLK_LCDC 120 -#define DCLK_HDMIPHY 121 -#define HDMIPHY 122 -#define USB480M 123 -#define DCLK_LCDC_SRC 124
-/* aclk gates */ -#define ACLK_AXISRAM 130 -#define ACLK_VOP_PRE 131 -#define ACLK_USB3OTG 132 -#define ACLK_RGA_PRE 133 -#define ACLK_DMAC 134 -#define ACLK_GPU 135 -#define ACLK_BUS_PRE 136 -#define ACLK_PERI_PRE 137 -#define ACLK_RKVDEC_PRE 138 -#define ACLK_RKVDEC 139 -#define ACLK_RKVENC 140 -#define ACLK_VPU_PRE 141 -#define ACLK_VIO_PRE 142 -#define ACLK_VPU 143 -#define ACLK_VIO 144 -#define ACLK_VOP 145 -#define ACLK_GMAC 146 -#define ACLK_H265 147 -#define ACLK_H264 148 -#define ACLK_MAC2PHY 149 -#define ACLK_MAC2IO 150 -#define ACLK_DCF 151 -#define ACLK_TSP 152 -#define ACLK_PERI 153 -#define ACLK_RGA 154 -#define ACLK_IEP 155 -#define ACLK_CIF 156 -#define ACLK_HDCP 157
-/* pclk gates */ -#define PCLK_GPIO0 200 -#define PCLK_GPIO1 201 -#define PCLK_GPIO2 202 -#define PCLK_GPIO3 203 -#define PCLK_GRF 204 -#define PCLK_I2C0 205 -#define PCLK_I2C1 206 -#define PCLK_I2C2 207 -#define PCLK_I2C3 208 -#define PCLK_SPI 209 -#define PCLK_UART0 210 -#define PCLK_UART1 211 -#define PCLK_UART2 212 -#define PCLK_TSADC 213 -#define PCLK_PWM 214 -#define PCLK_TIMER 215 -#define PCLK_BUS_PRE 216 -#define PCLK_PERI_PRE 217 -#define PCLK_HDMI_CTRL 218 -#define PCLK_HDMI_PHY 219 -#define PCLK_GMAC 220 -#define PCLK_H265 221 -#define PCLK_MAC2PHY 222 -#define PCLK_MAC2IO 223 -#define PCLK_USB3PHY_OTG 224 -#define PCLK_USB3PHY_PIPE 225 -#define PCLK_USB3_GRF 226 -#define PCLK_USB2_GRF 227 -#define PCLK_HDMIPHY 228 -#define PCLK_DDR 229 -#define PCLK_PERI 230 -#define PCLK_HDMI 231 -#define PCLK_HDCP 232 -#define PCLK_DCF 233 -#define PCLK_SARADC 234 -#define PCLK_ACODECPHY 235 -#define PCLK_WDT 236
-/* hclk gates */ -#define HCLK_PERI 308 -#define HCLK_TSP 309 -#define HCLK_GMAC 310 -#define HCLK_I2S0_8CH 311 -#define HCLK_I2S1_8CH 312 -#define HCLK_I2S2_2CH 313 -#define HCLK_SPDIF_8CH 314 -#define HCLK_VOP 315 -#define HCLK_NANDC 316 -#define HCLK_SDMMC 317 -#define HCLK_SDIO 318 -#define HCLK_EMMC 319 -#define HCLK_SDMMC_EXT 320 -#define HCLK_RKVDEC_PRE 321 -#define HCLK_RKVDEC 322 -#define HCLK_RKVENC 323 -#define HCLK_VPU_PRE 324 -#define HCLK_VIO_PRE 325 -#define HCLK_VPU 326 -#define HCLK_BUS_PRE 328 -#define HCLK_PERI_PRE 329 -#define HCLK_H264 330 -#define HCLK_CIF 331 -#define HCLK_OTG_PMU 332 -#define HCLK_OTG 333 -#define HCLK_HOST0 334 -#define HCLK_HOST0_ARB 335 -#define HCLK_CRYPTO_MST 336 -#define HCLK_CRYPTO_SLV 337 -#define HCLK_PDM 338 -#define HCLK_IEP 339 -#define HCLK_RGA 340 -#define HCLK_HDCP 341
-#define CLK_NR_CLKS (HCLK_HDCP + 1)
-/* soft-reset indices */ -#define SRST_CORE0_PO 0 -#define SRST_CORE1_PO 1 -#define SRST_CORE2_PO 2 -#define SRST_CORE3_PO 3 -#define SRST_CORE0 4 -#define SRST_CORE1 5 -#define SRST_CORE2 6 -#define SRST_CORE3 7 -#define SRST_CORE0_DBG 8 -#define SRST_CORE1_DBG 9 -#define SRST_CORE2_DBG 10 -#define SRST_CORE3_DBG 11 -#define SRST_TOPDBG 12 -#define SRST_CORE_NIU 13 -#define SRST_STRC_A 14 -#define SRST_L2C 15
-#define SRST_A53_GIC 18 -#define SRST_DAP 19 -#define SRST_PMU_P 21 -#define SRST_EFUSE 22 -#define SRST_BUSSYS_H 23 -#define SRST_BUSSYS_P 24 -#define SRST_SPDIF 25 -#define SRST_INTMEM 26 -#define SRST_ROM 27 -#define SRST_GPIO0 28 -#define SRST_GPIO1 29 -#define SRST_GPIO2 30 -#define SRST_GPIO3 31
-#define SRST_I2S0 32 -#define SRST_I2S1 33 -#define SRST_I2S2 34 -#define SRST_I2S0_H 35 -#define SRST_I2S1_H 36 -#define SRST_I2S2_H 37 -#define SRST_UART0 38 -#define SRST_UART1 39 -#define SRST_UART2 40 -#define SRST_UART0_P 41 -#define SRST_UART1_P 42 -#define SRST_UART2_P 43 -#define SRST_I2C0 44 -#define SRST_I2C1 45 -#define SRST_I2C2 46 -#define SRST_I2C3 47
-#define SRST_I2C0_P 48 -#define SRST_I2C1_P 49 -#define SRST_I2C2_P 50 -#define SRST_I2C3_P 51 -#define SRST_EFUSE_SE_P 52 -#define SRST_EFUSE_NS_P 53 -#define SRST_PWM0 54 -#define SRST_PWM0_P 55 -#define SRST_DMA 56 -#define SRST_TSP_A 57 -#define SRST_TSP_H 58 -#define SRST_TSP 59 -#define SRST_TSP_HSADC 60 -#define SRST_DCF_A 61 -#define SRST_DCF_P 62
-#define SRST_SCR 64 -#define SRST_SPI 65 -#define SRST_TSADC 66 -#define SRST_TSADC_P 67 -#define SRST_CRYPTO 68 -#define SRST_SGRF 69 -#define SRST_GRF 70 -#define SRST_USB_GRF 71 -#define SRST_TIMER_6CH_P 72 -#define SRST_TIMER0 73 -#define SRST_TIMER1 74 -#define SRST_TIMER2 75 -#define SRST_TIMER3 76 -#define SRST_TIMER4 77 -#define SRST_TIMER5 78 -#define SRST_USB3GRF 79
-#define SRST_PHYNIU 80 -#define SRST_HDMIPHY 81 -#define SRST_VDAC 82 -#define SRST_ACODEC_p 83 -#define SRST_SARADC 85 -#define SRST_SARADC_P 86 -#define SRST_GRF_DDR 87 -#define SRST_DFIMON 88 -#define SRST_MSCH 89 -#define SRST_DDRMSCH 91 -#define SRST_DDRCTRL 92 -#define SRST_DDRCTRL_P 93 -#define SRST_DDRPHY 94 -#define SRST_DDRPHY_P 95
-#define SRST_GMAC_NIU_A 96 -#define SRST_GMAC_NIU_P 97 -#define SRST_GMAC2PHY_A 98 -#define SRST_GMAC2IO_A 99 -#define SRST_MACPHY 100 -#define SRST_OTP_PHY 101 -#define SRST_GPU_A 102 -#define SRST_GPU_NIU_A 103 -#define SRST_SDMMCEXT 104 -#define SRST_PERIPH_NIU_A 105 -#define SRST_PERIHP_NIU_H 106 -#define SRST_PERIHP_P 107 -#define SRST_PERIPHSYS_H 108 -#define SRST_MMC0 109 -#define SRST_SDIO 110 -#define SRST_EMMC 111
-#define SRST_USB2OTG_H 112 -#define SRST_USB2OTG 113 -#define SRST_USB2OTG_ADP 114 -#define SRST_USB2HOST_H 115 -#define SRST_USB2HOST_ARB 116 -#define SRST_USB2HOST_AUX 117 -#define SRST_USB2HOST_EHCIPHY 118 -#define SRST_USB2HOST_UTMI 119 -#define SRST_USB3OTG 120 -#define SRST_USBPOR 121 -#define SRST_USB2OTG_UTMI 122 -#define SRST_USB2HOST_PHY_UTMI 123 -#define SRST_USB3OTG_UTMI 124 -#define SRST_USB3PHY_U2 125 -#define SRST_USB3PHY_U3 126 -#define SRST_USB3PHY_PIPE 127
-#define SRST_VIO_A 128 -#define SRST_VIO_BUS_H 129 -#define SRST_VIO_H2P_H 130 -#define SRST_VIO_ARBI_H 131 -#define SRST_VOP_NIU_A 132 -#define SRST_VOP_A 133 -#define SRST_VOP_H 134 -#define SRST_VOP_D 135 -#define SRST_RGA 136 -#define SRST_RGA_NIU_A 137 -#define SRST_RGA_A 138 -#define SRST_RGA_H 139 -#define SRST_IEP_A 140 -#define SRST_IEP_H 141 -#define SRST_HDMI 142 -#define SRST_HDMI_P 143
-#define SRST_HDCP_A 144 -#define SRST_HDCP 145 -#define SRST_HDCP_H 146 -#define SRST_CIF_A 147 -#define SRST_CIF_H 148 -#define SRST_CIF_P 149 -#define SRST_OTP_P 150 -#define SRST_OTP_SBPI 151 -#define SRST_OTP_USER 152 -#define SRST_DDRCTRL_A 153 -#define SRST_DDRSTDY_P 154 -#define SRST_DDRSTDY 155 -#define SRST_PDM_H 156 -#define SRST_PDM 157 -#define SRST_USB3PHY_OTG_P 158 -#define SRST_USB3PHY_PIPE_P 159
-#define SRST_VCODEC_A 160 -#define SRST_VCODEC_NIU_A 161 -#define SRST_VCODEC_H 162 -#define SRST_VCODEC_NIU_H 163 -#define SRST_VDEC_A 164 -#define SRST_VDEC_NIU_A 165 -#define SRST_VDEC_H 166 -#define SRST_VDEC_NIU_H 167 -#define SRST_VDEC_CORE 168 -#define SRST_VDEC_CABAC 169 -#define SRST_DDRPHYDIV 175
-#define SRST_RKVENC_NIU_A 176 -#define SRST_RKVENC_NIU_H 177 -#define SRST_RKVENC_H265_A 178 -#define SRST_RKVENC_H265_P 179 -#define SRST_RKVENC_H265_CORE 180 -#define SRST_RKVENC_H265_DSP 181 -#define SRST_RKVENC_H264_A 182 -#define SRST_RKVENC_H264_H 183 -#define SRST_RKVENC_INTMEM 184
-#endif diff --git a/include/dt-bindings/power/rk3328-power.h b/include/dt-bindings/power/rk3328-power.h deleted file mode 100644 index 02e3d7fc1cce..000000000000 --- a/include/dt-bindings/power/rk3328-power.h +++ /dev/null @@ -1,19 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3328_POWER_H__ -#define __DT_BINDINGS_POWER_RK3328_POWER_H__
- RK3328 idle id Summary.
-#define RK3328_PD_CORE 0 -#define RK3328_PD_GPU 1 -#define RK3328_PD_BUS 2 -#define RK3328_PD_MSCH 3 -#define RK3328_PD_PERI 4 -#define RK3328_PD_VIDEO 5 -#define RK3328_PD_HEVC 6 -#define RK3328_PD_SYS 7 -#define RK3328_PD_VPU 8 -#define RK3328_PD_VIO 9
-#endif
All RK3399 boards has now been synced to Linux kernel v6.8 DTs and can migrate to use OF_UPSTREAM.
Migrate RK3399 boards that exists in Linux v6.8 to use OF_UPSTREAM.
Following target is not migrated to use OF_UPSTREAM: - nanopi-m4-2gb-rk3399: DDR3 variant of nanopi-m4-rk3399 (LPDDR3)
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/Makefile | 31 -------------------- arch/arm/mach-rockchip/Kconfig | 1 + configs/chromebook_bob_defconfig | 2 +- configs/chromebook_kevin_defconfig | 2 +- configs/eaidk-610-rk3399_defconfig | 2 +- configs/evb-rk3399_defconfig | 2 +- configs/ficus-rk3399_defconfig | 2 +- configs/firefly-rk3399_defconfig | 2 +- configs/khadas-edge-captain-rk3399_defconfig | 2 +- configs/khadas-edge-rk3399_defconfig | 2 +- configs/khadas-edge-v-rk3399_defconfig | 2 +- configs/leez-rk3399_defconfig | 2 +- configs/nanopc-t4-rk3399_defconfig | 2 +- configs/nanopi-m4-2gb-rk3399_defconfig | 1 + configs/nanopi-m4-rk3399_defconfig | 2 +- configs/nanopi-m4b-rk3399_defconfig | 2 +- configs/nanopi-neo4-rk3399_defconfig | 2 +- configs/nanopi-r4s-rk3399_defconfig | 2 +- configs/orangepi-rk3399_defconfig | 2 +- configs/pinebook-pro-rk3399_defconfig | 2 +- configs/pinephone-pro-rk3399_defconfig | 2 +- configs/puma-rk3399_defconfig | 2 +- configs/roc-pc-mezzanine-rk3399_defconfig | 2 +- configs/roc-pc-rk3399_defconfig | 2 +- configs/rock-4c-plus-rk3399_defconfig | 2 +- configs/rock-4se-rk3399_defconfig | 2 +- configs/rock-pi-4-rk3399_defconfig | 2 +- configs/rock-pi-4c-rk3399_defconfig | 2 +- configs/rock-pi-n10-rk3399pro_defconfig | 2 +- configs/rock960-rk3399_defconfig | 2 +- configs/rockpro64-rk3399_defconfig | 2 +- 31 files changed, 30 insertions(+), 59 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index b7ada58695be..7a65d98635ae 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -98,37 +98,6 @@ dtb-$(CONFIG_ROCKCHIP_RK3368) += \ rk3368-geekbox.dtb \ rk3368-px5-evb.dtb \
-dtb-$(CONFIG_ROCKCHIP_RK3399) += \ - rk3399-evb.dtb \ - rk3399-eaidk-610.dtb \ - rk3399-ficus.dtb \ - rk3399-firefly.dtb \ - rk3399-gru-bob.dtb \ - rk3399-gru-kevin.dtb \ - rk3399-khadas-edge.dtb \ - rk3399-khadas-edge-captain.dtb \ - rk3399-khadas-edge-v.dtb \ - rk3399-leez-p710.dtb \ - rk3399-nanopc-t4.dtb \ - rk3399-nanopi-m4.dtb \ - rk3399-nanopi-m4-2gb.dtb \ - rk3399-nanopi-m4b.dtb \ - rk3399-nanopi-neo4.dtb \ - rk3399-nanopi-r4s.dtb \ - rk3399-orangepi.dtb \ - rk3399-pinebook-pro.dtb \ - rk3399-pinephone-pro.dtb \ - rk3399-puma-haikou.dtb \ - rk3399-roc-pc.dtb \ - rk3399-roc-pc-mezzanine.dtb \ - rk3399-rock-4c-plus.dtb \ - rk3399-rock-4se.dtb \ - rk3399-rock-pi-4a.dtb \ - rk3399-rock-pi-4c.dtb \ - rk3399-rock960.dtb \ - rk3399-rockpro64.dtb \ - rk3399pro-rock-pi-n10.dtb - dtb-$(CONFIG_ROCKCHIP_RK3568) += \ rk3566-anbernic-rgxx3.dtb \ rk3566-pinetab2-v0.1.dtb \ diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index a492b0885c03..a2c81489452e 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -272,6 +272,7 @@ config ROCKCHIP_RK3399 imply MISC_INIT_R imply OF_LIBFDT_OVERLAY imply OF_LIVE + imply OF_UPSTREAM imply PARTITION_TYPE_GUID imply PHY_GIGE if GMAC_ROCKCHIP imply PRE_CONSOLE_BUFFER diff --git a/configs/chromebook_bob_defconfig b/configs/chromebook_bob_defconfig index 9e15d9e3b8f6..acfe3934104f 100644 --- a/configs/chromebook_bob_defconfig +++ b/configs/chromebook_bob_defconfig @@ -9,7 +9,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-gru-bob" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-gru-bob" CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y diff --git a/configs/chromebook_kevin_defconfig b/configs/chromebook_kevin_defconfig index a79703c0a138..95fdb418d82b 100644 --- a/configs/chromebook_kevin_defconfig +++ b/configs/chromebook_kevin_defconfig @@ -9,7 +9,7 @@ CONFIG_HAS_CUSTOM_SYS_INIT_SP_ADDR=y CONFIG_CUSTOM_SYS_INIT_SP_ADDR=0x300000 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-gru-kevin" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-gru-kevin" CONFIG_SPL_TEXT_BASE=0xff8c2000 CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y diff --git a/configs/eaidk-610-rk3399_defconfig b/configs/eaidk-610-rk3399_defconfig index d9cde9ecced5..aedb4570ef8a 100644 --- a/configs/eaidk-610-rk3399_defconfig +++ b/configs/eaidk-610-rk3399_defconfig @@ -4,7 +4,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-eaidk-610" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-eaidk-610" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/evb-rk3399_defconfig b/configs/evb-rk3399_defconfig index 334259f73eb2..756d6952de1f 100644 --- a/configs/evb-rk3399_defconfig +++ b/configs/evb-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-evb" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-evb" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/ficus-rk3399_defconfig b/configs/ficus-rk3399_defconfig index 0d97b7ecb3c7..dce8093376d6 100644 --- a/configs/ficus-rk3399_defconfig +++ b/configs/ficus-rk3399_defconfig @@ -4,7 +4,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-ficus" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-ficus" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROCK960_RK3399=y diff --git a/configs/firefly-rk3399_defconfig b/configs/firefly-rk3399_defconfig index 9c94ac2f3012..edacef29edfc 100644 --- a/configs/firefly-rk3399_defconfig +++ b/configs/firefly-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-firefly" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-firefly" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/khadas-edge-captain-rk3399_defconfig b/configs/khadas-edge-captain-rk3399_defconfig index 67086d9f2fc2..60d4770cb0e4 100644 --- a/configs/khadas-edge-captain-rk3399_defconfig +++ b/configs/khadas-edge-captain-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-khadas-edge-captain" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-khadas-edge-captain" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/khadas-edge-rk3399_defconfig b/configs/khadas-edge-rk3399_defconfig index f752731dec01..1321ca1ea59e 100644 --- a/configs/khadas-edge-rk3399_defconfig +++ b/configs/khadas-edge-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-khadas-edge" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-khadas-edge" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/khadas-edge-v-rk3399_defconfig b/configs/khadas-edge-v-rk3399_defconfig index cb05a47f812b..3898142c5c7c 100644 --- a/configs/khadas-edge-v-rk3399_defconfig +++ b/configs/khadas-edge-v-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-khadas-edge-v" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-khadas-edge-v" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/leez-rk3399_defconfig b/configs/leez-rk3399_defconfig index 903125aa5c1d..ea96e1ef758f 100644 --- a/configs/leez-rk3399_defconfig +++ b/configs/leez-rk3399_defconfig @@ -4,7 +4,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-leez-p710" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-leez-p710" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/nanopc-t4-rk3399_defconfig b/configs/nanopc-t4-rk3399_defconfig index 3e89f3dcabd0..c63f4c076d55 100644 --- a/configs/nanopc-t4-rk3399_defconfig +++ b/configs/nanopc-t4-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopc-t4" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-nanopc-t4" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/nanopi-m4-2gb-rk3399_defconfig b/configs/nanopi-m4-2gb-rk3399_defconfig index 10bd9fba5388..08c21ee6e5d2 100644 --- a/configs/nanopi-m4-2gb-rk3399_defconfig +++ b/configs/nanopi-m4-2gb-rk3399_defconfig @@ -30,6 +30,7 @@ CONFIG_CMD_USB=y # CONFIG_CMD_SETEXPR is not set CONFIG_CMD_TIME=y CONFIG_SPL_OF_CONTROL=y +# CONFIG_OF_UPSTREAM is not set CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_IS_IN_MMC=y CONFIG_SYS_RELOC_GD_ENV_ADDR=y diff --git a/configs/nanopi-m4-rk3399_defconfig b/configs/nanopi-m4-rk3399_defconfig index f5305549716c..ad01431cc3ae 100644 --- a/configs/nanopi-m4-rk3399_defconfig +++ b/configs/nanopi-m4-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-m4" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-nanopi-m4" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/nanopi-m4b-rk3399_defconfig b/configs/nanopi-m4b-rk3399_defconfig index 70de7e0a6d7f..34f892d5d3c1 100644 --- a/configs/nanopi-m4b-rk3399_defconfig +++ b/configs/nanopi-m4b-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-m4b" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-nanopi-m4b" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/nanopi-neo4-rk3399_defconfig b/configs/nanopi-neo4-rk3399_defconfig index 7f936636d419..f38235489ff7 100644 --- a/configs/nanopi-neo4-rk3399_defconfig +++ b/configs/nanopi-neo4-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-neo4" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-nanopi-neo4" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/nanopi-r4s-rk3399_defconfig b/configs/nanopi-r4s-rk3399_defconfig index ef74628fb284..ada04b46cb16 100644 --- a/configs/nanopi-r4s-rk3399_defconfig +++ b/configs/nanopi-r4s-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-nanopi-r4s" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-nanopi-r4s" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/orangepi-rk3399_defconfig b/configs/orangepi-rk3399_defconfig index 2d0c9b77e584..5dfbdeaf17f5 100644 --- a/configs/orangepi-rk3399_defconfig +++ b/configs/orangepi-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-orangepi" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-orangepi" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/pinebook-pro-rk3399_defconfig b/configs/pinebook-pro-rk3399_defconfig index 8ac6ddd49dea..5d3e32f9108e 100644 --- a/configs/pinebook-pro-rk3399_defconfig +++ b/configs/pinebook-pro-rk3399_defconfig @@ -7,7 +7,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-pinebook-pro" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-pinebook-pro" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/pinephone-pro-rk3399_defconfig b/configs/pinephone-pro-rk3399_defconfig index 1bb7b35a255c..0eade88068f4 100644 --- a/configs/pinephone-pro-rk3399_defconfig +++ b/configs/pinephone-pro-rk3399_defconfig @@ -6,7 +6,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-pinephone-pro" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-pinephone-pro" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/puma-rk3399_defconfig b/configs/puma-rk3399_defconfig index 5edba19e6ce8..34a0b575991e 100644 --- a/configs/puma-rk3399_defconfig +++ b/configs/puma-rk3399_defconfig @@ -7,7 +7,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=20000000 CONFIG_ENV_SIZE=0x3000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-puma-haikou" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-puma-haikou" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_BOOT_MODE_REG=0x0 diff --git a/configs/roc-pc-mezzanine-rk3399_defconfig b/configs/roc-pc-mezzanine-rk3399_defconfig index 8141f803cf3b..a57899bfdfa0 100644 --- a/configs/roc-pc-mezzanine-rk3399_defconfig +++ b/configs/roc-pc-mezzanine-rk3399_defconfig @@ -8,7 +8,7 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-roc-pc-mezzanine" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-roc-pc-mezzanine" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/roc-pc-rk3399_defconfig b/configs/roc-pc-rk3399_defconfig index b8adf430e9ea..b45f0e0a8994 100644 --- a/configs/roc-pc-rk3399_defconfig +++ b/configs/roc-pc-rk3399_defconfig @@ -8,7 +8,7 @@ CONFIG_SF_DEFAULT_SPEED=30000000 CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 CONFIG_ENV_SECT_SIZE=0x1000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-roc-pc" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-roc-pc" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/rock-4c-plus-rk3399_defconfig b/configs/rock-4c-plus-rk3399_defconfig index e97fde17acc2..80dc44986e71 100644 --- a/configs/rock-4c-plus-rk3399_defconfig +++ b/configs/rock-4c-plus-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-4c-plus" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-rock-4c-plus" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/rock-4se-rk3399_defconfig b/configs/rock-4se-rk3399_defconfig index 13f5f84b9836..f52d4bf9913b 100644 --- a/configs/rock-4se-rk3399_defconfig +++ b/configs/rock-4se-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-4se" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-rock-4se" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/rock-pi-4-rk3399_defconfig b/configs/rock-pi-4-rk3399_defconfig index d474d91053c1..e71c4588b942 100644 --- a/configs/rock-pi-4-rk3399_defconfig +++ b/configs/rock-pi-4-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4a" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-rock-pi-4a" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/rock-pi-4c-rk3399_defconfig b/configs/rock-pi-4c-rk3399_defconfig index 50c6755246f2..14373933a34f 100644 --- a/configs/rock-pi-4c-rk3399_defconfig +++ b/configs/rock-pi-4c-rk3399_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock-pi-4c" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-rock-pi-4c" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y diff --git a/configs/rock-pi-n10-rk3399pro_defconfig b/configs/rock-pi-n10-rk3399pro_defconfig index 6d93b9e58003..ec995a54a0ee 100644 --- a/configs/rock-pi-n10-rk3399pro_defconfig +++ b/configs/rock-pi-n10-rk3399pro_defconfig @@ -4,7 +4,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_NR_DRAM_BANKS=1 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399pro-rock-pi-n10" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399pro-rock-pi-n10" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_EVB_RK3399=y diff --git a/configs/rock960-rk3399_defconfig b/configs/rock960-rk3399_defconfig index 3ea872a2ca3e..8fff3ed17c24 100644 --- a/configs/rock960-rk3399_defconfig +++ b/configs/rock960-rk3399_defconfig @@ -3,7 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-rock960" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-rock960" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_TARGET_ROCK960_RK3399=y diff --git a/configs/rockpro64-rk3399_defconfig b/configs/rockpro64-rk3399_defconfig index 4e1af37a1559..fc0804a0b80d 100644 --- a/configs/rockpro64-rk3399_defconfig +++ b/configs/rockpro64-rk3399_defconfig @@ -7,7 +7,7 @@ CONFIG_NR_DRAM_BANKS=1 CONFIG_SF_DEFAULT_SPEED=10000000 CONFIG_ENV_SIZE=0x8000 CONFIG_ENV_OFFSET=0x3F8000 -CONFIG_DEFAULT_DEVICE_TREE="rk3399-rockpro64" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3399-rockpro64" CONFIG_DM_RESET=y CONFIG_ROCKCHIP_RK3399=y CONFIG_ROCKCHIP_SPI_IMAGE=y
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
- rk3399-evb.dtb \
- imply OF_UPSTREAM imply PARTITION_TYPE_GUID imply PHY_GIGE if GMAC_ROCKCHIP imply PRE_CONSOLE_BUFFER
Remove redundant device tree files now that RK3399 boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3399-eaidk-610.dts | 940 ------ arch/arm/dts/rk3399-evb.dts | 485 --- arch/arm/dts/rk3399-ficus.dts | 174 - arch/arm/dts/rk3399-firefly.dts | 944 ------ arch/arm/dts/rk3399-gru-bob.dts | 95 - arch/arm/dts/rk3399-gru-chromebook.dtsi | 590 ---- arch/arm/dts/rk3399-gru-kevin.dts | 328 -- arch/arm/dts/rk3399-gru.dtsi | 865 ----- arch/arm/dts/rk3399-khadas-edge-captain.dts | 31 - arch/arm/dts/rk3399-khadas-edge-v.dts | 31 - arch/arm/dts/rk3399-khadas-edge.dts | 13 - arch/arm/dts/rk3399-khadas-edge.dtsi | 837 ----- arch/arm/dts/rk3399-leez-p710.dts | 653 ---- arch/arm/dts/rk3399-nanopc-t4.dts | 137 - arch/arm/dts/rk3399-nanopi-m4.dts | 66 - arch/arm/dts/rk3399-nanopi-m4b.dts | 52 - arch/arm/dts/rk3399-nanopi-neo4.dts | 50 - arch/arm/dts/rk3399-nanopi-r4s.dts | 133 - arch/arm/dts/rk3399-nanopi4.dtsi | 762 ----- arch/arm/dts/rk3399-op1-opp.dtsi | 166 - arch/arm/dts/rk3399-opp.dtsi | 133 - arch/arm/dts/rk3399-orangepi.dts | 896 ----- arch/arm/dts/rk3399-pinebook-pro.dts | 1111 ------- arch/arm/dts/rk3399-pinephone-pro.dts | 621 ---- arch/arm/dts/rk3399-puma-haikou.dts | 306 -- arch/arm/dts/rk3399-puma.dtsi | 532 --- arch/arm/dts/rk3399-roc-pc-mezzanine.dts | 111 - arch/arm/dts/rk3399-roc-pc.dts | 12 - arch/arm/dts/rk3399-roc-pc.dtsi | 844 ----- arch/arm/dts/rk3399-rock-4c-plus.dts | 709 ---- arch/arm/dts/rk3399-rock-4se.dts | 65 - arch/arm/dts/rk3399-rock-pi-4.dtsi | 792 ----- arch/arm/dts/rk3399-rock-pi-4a.dts | 24 - arch/arm/dts/rk3399-rock-pi-4c.dts | 80 - arch/arm/dts/rk3399-rock960.dts | 156 - arch/arm/dts/rk3399-rock960.dtsi | 673 ---- arch/arm/dts/rk3399-rockpro64.dts | 30 - arch/arm/dts/rk3399-rockpro64.dtsi | 956 ------ arch/arm/dts/rk3399-t-opp.dtsi | 114 - arch/arm/dts/rk3399.dtsi | 2945 ----------------- arch/arm/dts/rk3399pro-rock-pi-n10.dts | 22 - arch/arm/dts/rk3399pro-vmarc-som.dtsi | 477 --- arch/arm/dts/rk3399pro.dtsi | 22 - .../clock/rockchip,rk3399-dmc.txt | 42 - include/dt-bindings/clock/rk3399-cru.h | 751 ----- include/dt-bindings/power/rk3399-power.h | 53 - 46 files changed, 19829 deletions(-) delete mode 100644 arch/arm/dts/rk3399-eaidk-610.dts delete mode 100644 arch/arm/dts/rk3399-evb.dts delete mode 100644 arch/arm/dts/rk3399-ficus.dts delete mode 100644 arch/arm/dts/rk3399-firefly.dts delete mode 100644 arch/arm/dts/rk3399-gru-bob.dts delete mode 100644 arch/arm/dts/rk3399-gru-chromebook.dtsi delete mode 100644 arch/arm/dts/rk3399-gru-kevin.dts delete mode 100644 arch/arm/dts/rk3399-gru.dtsi delete mode 100644 arch/arm/dts/rk3399-khadas-edge-captain.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge-v.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge.dtsi delete mode 100644 arch/arm/dts/rk3399-leez-p710.dts delete mode 100644 arch/arm/dts/rk3399-nanopc-t4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-m4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-m4b.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-neo4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-r4s.dts delete mode 100644 arch/arm/dts/rk3399-nanopi4.dtsi delete mode 100644 arch/arm/dts/rk3399-op1-opp.dtsi delete mode 100644 arch/arm/dts/rk3399-opp.dtsi delete mode 100644 arch/arm/dts/rk3399-orangepi.dts delete mode 100644 arch/arm/dts/rk3399-pinebook-pro.dts delete mode 100644 arch/arm/dts/rk3399-pinephone-pro.dts delete mode 100644 arch/arm/dts/rk3399-puma-haikou.dts delete mode 100644 arch/arm/dts/rk3399-puma.dtsi delete mode 100644 arch/arm/dts/rk3399-roc-pc-mezzanine.dts delete mode 100644 arch/arm/dts/rk3399-roc-pc.dts delete mode 100644 arch/arm/dts/rk3399-roc-pc.dtsi delete mode 100644 arch/arm/dts/rk3399-rock-4c-plus.dts delete mode 100644 arch/arm/dts/rk3399-rock-4se.dts delete mode 100644 arch/arm/dts/rk3399-rock-pi-4.dtsi delete mode 100644 arch/arm/dts/rk3399-rock-pi-4a.dts delete mode 100644 arch/arm/dts/rk3399-rock-pi-4c.dts delete mode 100644 arch/arm/dts/rk3399-rock960.dts delete mode 100644 arch/arm/dts/rk3399-rock960.dtsi delete mode 100644 arch/arm/dts/rk3399-rockpro64.dts delete mode 100644 arch/arm/dts/rk3399-rockpro64.dtsi delete mode 100644 arch/arm/dts/rk3399-t-opp.dtsi delete mode 100644 arch/arm/dts/rk3399.dtsi delete mode 100644 arch/arm/dts/rk3399pro-rock-pi-n10.dts delete mode 100644 arch/arm/dts/rk3399pro-vmarc-som.dtsi delete mode 100644 arch/arm/dts/rk3399pro.dtsi delete mode 100644 doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt delete mode 100644 include/dt-bindings/clock/rk3399-cru.h delete mode 100644 include/dt-bindings/power/rk3399-power.h
diff --git a/arch/arm/dts/rk3399-eaidk-610.dts b/arch/arm/dts/rk3399-eaidk-610.dts deleted file mode 100644 index 173da81fc231..000000000000 --- a/arch/arm/dts/rk3399-eaidk-610.dts +++ /dev/null @@ -1,940 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2022 Fuzhou Rockchip Electronics Co., Ltd. - */ - -/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/usb/pd.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "OPEN AI LAB EAIDK-610"; - compatible = "openailab,eaidk-610", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - pwms = <&pwm0 0 25000 0>; - brightness-levels = < - 0 1 2 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - default-brightness-level = <200>; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - dc_12v: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - key-power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&work_led_pin>, <&user_led_pin>, - <&heartbeat_led_pin>, <&wlan_active_led_pin>, - <&bt_active_led_pin>; - - work_led: led-0 { - label = "blue:work"; - default-state = "on"; - gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; - }; - - user_led: led-1 { - label = "read:user"; - default-state = "off"; - gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; - }; - - heartbeat_led: led-2 { - label = "green:heartbeat"; - linux,default-trigger = "heartbeat"; - gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; - }; - - wlan_active_led: led-3 { - label = "yellow:wlan"; - gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "phy0tx"; - default-state = "off"; - }; - - bt_active_led: led-4 { - label = "blue:bt"; - gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "hci0-power"; - default-state = "off"; - }; - }; - - rt5651-sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "realtek,rt5651-codec"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - simple-audio-card,widgets = - "Microphone", "Mic Jack", - "Headphone", "Headphone Jack"; - simple-audio-card,routing = - "Mic Jack", "MICBIAS1", - "IN1P", "Mic Jack", - "Headphone Jack", "HPOL", - "Headphone Jack", "HPOR"; - simple-audio-card,cpu { - sound-dai = <&i2s1>; - }; - simple-audio-card,codec { - sound-dai = <&rt5651>; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - /* For USB3.0 Port1/2 */ - vcc5v0_host1: vcc5v0-host1-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host1_en>; - regulator-name = "vcc5v0_host1"; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - /* For USB2.0 Port1/2 */ - vcc5v0_host3: vcc5v0-host3-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host3_en>; - regulator-name = "vcc5v0_host3"; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_typec: vcc5v0-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PC5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec_en>; - regulator-name = "vcc5v0_typec"; - regulator-always-on; - vin-supply = <&vcc3v3_sys>; - }; - - vdd_log: vdd-log { - compatible = "regulator-fixed"; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - vcc10-supply = <&vcc3v3_sys>; - vcc11-supply = <&vcc3v3_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_3v0>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc2v8_dvp: LDO_REG2 { - regulator-name = "vcc2v8_dvp"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmu: LDO_REG3 { - regulator-name = "vcc1v8_pmu"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-name = "vcca1v8_codec"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: vcc_lan: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu_b"; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_pin>; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_gpu"; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_pin>; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - i2c-scl-rising-time-ns = <300>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; - - rt5651: audio-codec@1a { - compatible = "rockchip,rt5651"; - reg = <0x1a>; - clocks = <&cru SCLK_I2S_8CH_OUT>; - clock-names = "mclk"; - hp-det-gpio = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>; - spk-con-gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; - #sound-dai-cells = <0>; - }; - -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - - fusb0: typec-portc@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int>; - vbus-supply = <&vcc5v0_typec>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - usbc0_role_sw: endpoint@0 { - remote-endpoint = <&dwc3_0_role_switch>; - }; - }; - }; - - connector { - compatible = "usb-c-connector"; - data-role = "dual"; - label = "USB-C"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - usbc_hs: endpoint { - remote-endpoint = <&u2phy0_typec_hs>; - }; - }; - - port@1 { - reg = <1>; - - usbc_ss: endpoint { - remote-endpoint = <&tcphy0_typec_ss>; - }; - }; - }; - }; - }; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - audio-supply = <&vcca1v8_codec>; - bt656-supply = <&vcc_3v0>; - gpio1830-supply = <&vcc_3v0>; - sdmmc-supply = <&vcc_sdio>; -}; - -&pmu_io_domains { - status = "okay"; - - pmu1830-supply = <&vcc_3v0>; -}; - -&pinctrl { - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - fusb302x { - fusb0_int: fusb0-int { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - lcd-panel { - lcd_panel_reset: lcd-panel-reset { - rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - work_led_pin: work-led-pin { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led_pin: user-led-pin { - rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - heartbeat_led_pin: heartbeat-led-pin { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wlan_active_led_pin: wlan-led-pin { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_active_led_pin: bt-led-pin { - rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - rt5651 { - rt5651_hpcon: rt5640-hpcon { - rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb-typec { - vcc5v0_typec_en: vcc5v0_typec_en { - rockchip,pins = <4 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host3_en: vcc5v0-host3-en { - rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_host1_en: vcc5v0-host1-en { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdio0 { - /* WiFi & BT combo module AMPAK AP6255 */ - #address-cells = <1>; - #size-cells = <0>; - bus-width = <4>; - clock-frequency = <50000000>; - cap-sdio-irq; - cap-sd-highspeed; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - status = "okay"; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy0_usb3 { - orientation-switch; - port { - tcphy0_typec_ss: endpoint { - remote-endpoint = <&usbc_ss>; - }; - }; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host3>; - status = "okay"; - }; - - port { - u2phy0_typec_hs: endpoint { - remote-endpoint = <&usbc_hs>; - }; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host3>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - max-speed = <1500000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - usb-role-switch; - - port { - #address-cells = <1>; - #size-cells = <0>; - dwc3_0_role_switch: endpoint@0 { - reg = <0>; - remote-endpoint = <&usbc0_role_sw>; - }; - }; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts deleted file mode 100644 index 55eca7a50a1f..000000000000 --- a/arch/arm/dts/rk3399-evb.dts +++ /dev/null @@ -1,485 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd - */ - -/dts-v1/; -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" - -/ { - model = "Rockchip RK3399 Evaluation Board"; - compatible = "rockchip,rk3399-evb", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdhci; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - brightness-levels = < - 0 1 2 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - default-brightness-level = <200>; - pwms = <&pwm0 0 25000 0>; - }; - - edp_panel: edp-panel { - compatible = "lg,lp079qx1-sp0v"; - backlight = <&backlight>; - enable-gpios = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; - power-supply = <&vcc3v3_s0>; - - port { - panel_in_edp: endpoint { - remote-endpoint = <&edp_out_panel>; - }; - }; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - vdd_center: vdd-center { - compatible = "pwm-regulator"; - pwms = <&pwm3 0 25000 0>; - regulator-name = "vdd_center"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-always-on; - regulator-boot-on; - status = "okay"; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - vin-supply = <&vcc5v0_sys>; - }; - - vcc_phy: vcc-phy-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; - regulator-always-on; - regulator-boot-on; - }; - - vcc_phy: vcc-phy-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_phy"; - regulator-always-on; - regulator-boot-on; - }; - -}; - -&edp { - status = "okay"; - force-hpd; - - ports { - edp_out: port@1 { - reg = <1>; - #address-cells = <1>; - #size-cells = <0>; - - edp_out_panel: endpoint@0 { - reg = <0>; - remote-endpoint = <&panel_in_edp>; - }; - }; - }; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc_phy>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - vcc10-supply = <&vcc3v3_sys>; - vcc11-supply = <&vcc3v3_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc1v8_pmu>; - - regulators { - vdd_log: DCDC_REG1 { - regulator-name = "vdd_log"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v0_tp: LDO_REG2 { - regulator-name = "vcc3v0_tp"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmu: LDO_REG3 { - regulator-name = "vcc1v8_pmu"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sd: LDO_REG4 { - regulator-name = "vcc_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-name = "vcca1v8_codec"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&pwm3 { - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&pcie_phy { - status = "disabled"; -}; - -&pcie0 { - ep-gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn_cpm>; - status = "disabled"; -}; - -&u2phy0 { - status = "okay"; -}; - -&u2phy0_host { - phy-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&u2phy1 { - status = "okay"; -}; - -&u2phy1_host { - phy-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&pinctrl { - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = - <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = - <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts deleted file mode 100644 index 30e4879f322c..000000000000 --- a/arch/arm/dts/rk3399-ficus.dts +++ /dev/null @@ -1,174 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2018 Collabora Ltd. - * Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd. - * - * Schematics available at https://dl.vamrs.com/products/ficus/docs/hw - */ - -/dts-v1/; -#include "rk3399-rock960.dtsi" - -/ { - model = "96boards RK3399 Ficus"; - compatible = "vamrs,ficus", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>, - <&user_led3_pin>, <&user_led4_pin>, - <&wlan_led_pin>, <&bt_led_pin>; - - user_led1: led-1 { - label = "red:user1"; - gpios = <&gpio4 25 0>; - linux,default-trigger = "heartbeat"; - }; - - user_led2: led-2 { - label = "red:user2"; - gpios = <&gpio4 26 0>; - linux,default-trigger = "mmc0"; - }; - - user_led3: led-3 { - label = "red:user3"; - gpios = <&gpio4 30 0>; - linux,default-trigger = "mmc1"; - }; - - user_led4: led-4 { - label = "red:user4"; - gpios = <&gpio1 0 0>; - panic-indicator; - linux,default-trigger = "none"; - }; - - wlan_active_led: led-5 { - label = "red:wlan"; - gpios = <&gpio1 1 0>; - linux,default-trigger = "phy0tx"; - default-state = "off"; - }; - - bt_active_led: led-6 { - label = "red:bt"; - gpios = <&gpio1 4 0>; - linux,default-trigger = "hci0-power"; - default-state = "off"; - }; - }; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc3v3_sys>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_HIGH>; -}; - -&pinctrl { - gmac { - rgmii_sleep_pins: rgmii-sleep-pins { - rockchip,pins = - <3 RK_PB7 RK_FUNC_GPIO &pcfg_output_low>; - }; - }; - - pcie { - pcie_drv: pcie-drv { - rockchip,pins = - <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb2 { - host_vbus_drv: host-vbus-drv { - rockchip,pins = - <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - user_led1_pin: user-led1-pin { - rockchip,pins = - <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led2_pin: user-led2-pin { - rockchip,pins = - <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led3_pin: user-led3-pin { - rockchip,pins = - <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led4_pin: user-led4-pin { - rockchip,pins = - <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wlan_led_pin: wlan-led-pin { - rockchip,pins = - <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_led_pin: bt-led-pin { - rockchip,pins = - <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&spi1 { - /* On both Low speed and High speed expansion */ - cs-gpios = <0>, <&gpio4 RK_PA6 0>, <&gpio4 RK_PA7 0>; - status = "okay"; -}; - -&usbdrd_dwc3_0 { - dr_mode = "host"; -}; - -&usbdrd_dwc3_1 { - dr_mode = "host"; -}; - -&vcc3v3_pcie { - gpio = <&gpio1 24 GPIO_ACTIVE_HIGH>; -}; - -&vcc5v0_host { - gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>; -}; diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts deleted file mode 100644 index 260415d99aeb..000000000000 --- a/arch/arm/dts/rk3399-firefly.dts +++ /dev/null @@ -1,944 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - */ - -/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/usb/pd.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Firefly-RK3399 Board"; - compatible = "firefly,firefly-rk3399", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - enable-gpios = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; - pwms = <&pwm0 0 25000 0>; - brightness-levels = < - 0 1 2 3 4 5 6 7 - 8 9 10 11 12 13 14 15 - 16 17 18 19 20 21 22 23 - 24 25 26 27 28 29 30 31 - 32 33 34 35 36 37 38 39 - 40 41 42 43 44 45 46 47 - 48 49 50 51 52 53 54 55 - 56 57 58 59 60 61 62 63 - 64 65 66 67 68 69 70 71 - 72 73 74 75 76 77 78 79 - 80 81 82 83 84 85 86 87 - 88 89 90 91 92 93 94 95 - 96 97 98 99 100 101 102 103 - 104 105 106 107 108 109 110 111 - 112 113 114 115 116 117 118 119 - 120 121 122 123 124 125 126 127 - 128 129 130 131 132 133 134 135 - 136 137 138 139 140 141 142 143 - 144 145 146 147 148 149 150 151 - 152 153 154 155 156 157 158 159 - 160 161 162 163 164 165 166 167 - 168 169 170 171 172 173 174 175 - 176 177 178 179 180 181 182 183 - 184 185 186 187 188 189 190 191 - 192 193 194 195 196 197 198 199 - 200 201 202 203 204 205 206 207 - 208 209 210 211 212 213 214 215 - 216 217 218 219 220 221 222 223 - 224 225 226 227 228 229 230 231 - 232 233 234 235 236 237 238 239 - 240 241 242 243 244 245 246 247 - 248 249 250 251 252 253 254 255>; - default-brightness-level = <200>; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - dc_12v: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - key-power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; - pinctrl-0 = <&ir_int>; - pinctrl-names = "default"; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&work_led_pin>, <&diy_led_pin>; - - work_led: led-0 { - label = "work"; - default-state = "on"; - gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - }; - - diy_led: led-1 { - label = "diy"; - default-state = "off"; - gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; - }; - }; - - rt5640-sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "rockchip,rt5640-codec"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - simple-audio-card,widgets = - "Microphone", "Mic Jack", - "Headphone", "Headphone Jack"; - simple-audio-card,routing = - "Mic Jack", "MICBIAS1", - "IN1P", "Mic Jack", - "Headphone Jack", "HPOL", - "Headphone Jack", "HPOR"; - - simple-audio-card,cpu { - sound-dai = <&i2s1>; - }; - - simple-audio-card,codec { - sound-dai = <&rt5640>; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - sound-dit { - compatible = "audio-graph-card"; - label = "SPDIF"; - dais = <&spdif_p0>; - }; - - spdif-dit { - compatible = "linux,spdif-dit"; - #sound-dai-cells = <0>; - - port { - dit_p0_0: endpoint { - remote-endpoint = <&spdif_p0_0>; - }; - }; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_pwr_en>; - regulator-name = "vcc3v3_pcie"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&dc_12v>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_sys>; - }; - - /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc5v0_typec: vcc5v0-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec_en>; - regulator-name = "vcc5v0_typec"; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vcc_sys>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <430000>; - regulator-max-microvolt = <1400000>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc_sys>; - vcc10-supply = <&vcc_sys>; - vcc11-supply = <&vcc_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc1v8_pmu>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc2v8_dvp: LDO_REG2 { - regulator-name = "vcc2v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmu: LDO_REG3 { - regulator-name = "vcc1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-name = "vcca1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: vcc_lan: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <0>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - i2c-scl-rising-time-ns = <300>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; - - rt5640: rt5640@1c { - compatible = "realtek,rt5640"; - reg = <0x1c>; - clocks = <&cru SCLK_I2S_8CH_OUT>; - clock-names = "mclk"; - realtek,in1-differential; - #sound-dai-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&rt5640_hpcon>; - }; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - - fusb0: typec-portc@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int>; - vbus-supply = <&vcc5v0_typec>; - status = "okay"; - - connector { - compatible = "usb-c-connector"; - data-role = "host"; - label = "USB-C"; - op-sink-microwatt = <1000000>; - power-role = "dual"; - sink-pdos = - <PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>; - source-pdos = - <PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>; - try-power-role = "sink"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - usbc_hs: endpoint { - remote-endpoint = - <&u2phy0_typec_hs>; - }; - }; - - port@1 { - reg = <1>; - - usbc_ss: endpoint { - remote-endpoint = - <&tcphy0_typec_ss>; - }; - }; - }; - }; - }; - - accelerometer@68 { - compatible = "invensense,mpu6500"; - reg = <0x68>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PC6 IRQ_TYPE_EDGE_RISING>; - }; -}; - -&i2s0 { - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; - status = "okay"; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - bt656-supply = <&vcc1v8_dvp>; - audio-supply = <&vcca1v8_codec>; - sdmmc-supply = <&vcc_sdio>; - gpio1830-supply = <&vcc_3v0>; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn_cpm>; - status = "okay"; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pinctrl { - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - fusb302x { - fusb0_int: fusb0-int { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - ir { - ir_int: ir-int { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd-panel { - lcd_panel_reset: lcd-panel-reset { - rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - work_led_pin: work-led-pin { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - diy_led_pin: diy-led-pin { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_pwr_en: pcie-pwr-en { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_3g_drv: pcie-3g-drv { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - rt5640 { - rt5640_hpcon: rt5640-hpcon { - rockchip,pins = <4 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb-typec { - vcc5v0_typec_en: vcc5v0_typec_en { - rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdio0 { - /* WiFi & BT combo module Ampak AP6356S */ - bus-width = <4>; - cap-sdio-irq; - cap-sd-highspeed; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - - /* Power supply */ - vqmmc-supply = <&vcc1v8_s3>; /* IO line */ - vmmc-supply = <&vcc_sdio>; /* card's power */ - - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - brcmf: wifi@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - brcm,drive-strength = <5>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&spdif { - pinctrl-0 = <&spdif_bus_1>; - status = "okay"; - - spdif_p0: port { - spdif_p0_0: endpoint { - remote-endpoint = <&dit_p0_0>; - }; - }; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy0_usb3 { - port { - tcphy0_typec_ss: endpoint { - remote-endpoint = <&usbc_ss>; - }; - }; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; - - port { - u2phy0_typec_hs: endpoint { - remote-endpoint = <&usbc_hs>; - }; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "otg"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-gru-bob.dts b/arch/arm/dts/rk3399-gru-bob.dts deleted file mode 100644 index 1cba1d857c96..000000000000 --- a/arch/arm/dts/rk3399-gru-bob.dts +++ /dev/null @@ -1,95 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Google Gru-Bob Rev 4+ board device tree source - * - * Copyright 2018 Google, Inc - */ - -/dts-v1/; -#include "rk3399-gru-chromebook.dtsi" - -/ { - model = "Google Bob"; - compatible = "google,bob-rev13", "google,bob-rev12", - "google,bob-rev11", "google,bob-rev10", - "google,bob-rev9", "google,bob-rev8", - "google,bob-rev7", "google,bob-rev6", - "google,bob-rev5", "google,bob-rev4", - "google,bob", "google,gru", "rockchip,rk3399"; - chassis-type = "convertible"; - - edp_panel: edp-panel { - compatible = "boe,nv101wxmn51"; - backlight = <&backlight>; - power-supply = <&pp3300_disp>; - - port { - panel_in_edp: endpoint { - remote-endpoint = <&edp_out_panel>; - }; - }; - }; -}; - -&ap_i2c_ts { - touchscreen: touchscreen@10 { - compatible = "elan,ekth3500"; - reg = <0x10>; - interrupt-parent = <&gpio3>; - interrupts = <13 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&touch_int_l &touch_reset_l>; - reset-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>; - }; -}; - -&ap_i2c_tp { - trackpad: trackpad@15 { - compatible = "elan,ekth3000"; - reg = <0x15>; - interrupt-parent = <&gpio1>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&trackpad_int_l>; - wakeup-source; - }; -}; - -&backlight { - pwms = <&cros_ec_pwm 0>; -}; - -&cpu_alert0 { - temperature = <65000>; -}; - -&cpu_alert1 { - temperature = <70000>; -}; - -&spi0 { - status = "okay"; - - tpm@0 { - compatible = "google,cr50"; - reg = <0>; - interrupt-parent = <&gpio0>; - interrupts = <5 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&h1_int_od_l>; - spi-max-frequency = <800000>; - }; -}; - -&pinctrl { - tpm { - h1_int_od_l: h1-int-od-l { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&wlan_host_wake_l { - /* Kevin has an external pull up, but Bob does not. */ - rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; -}; diff --git a/arch/arm/dts/rk3399-gru-chromebook.dtsi b/arch/arm/dts/rk3399-gru-chromebook.dtsi deleted file mode 100644 index cacbad35cfc8..000000000000 --- a/arch/arm/dts/rk3399-gru-chromebook.dtsi +++ /dev/null @@ -1,590 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Google Gru-Chromebook shared properties - * - * Copyright 2018 Google, Inc - */ - -#include "rk3399-gru.dtsi" - -/ { - pp900_ap: pp900-ap { - compatible = "regulator-fixed"; - regulator-name = "pp900_ap"; - - /* EC turns on w/ pp900_ap_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - vin-supply = <&ppvar_sys>; - }; - - /* EC turns on w/ pp900_usb_en */ - pp900_usb: pp900-ap { - }; - - /* EC turns on w/ pp900_pcie_en */ - pp900_pcie: pp900-ap { - }; - - pp3000: pp3000 { - compatible = "regulator-fixed"; - regulator-name = "pp3000"; - pinctrl-names = "default"; - pinctrl-0 = <&pp3000_en>; - - enable-active-high; - gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>; - - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - - vin-supply = <&ppvar_sys>; - }; - - ppvar_centerlogic_pwm: ppvar-centerlogic-pwm { - compatible = "pwm-regulator"; - regulator-name = "ppvar_centerlogic_pwm"; - - pwms = <&pwm3 0 3337 0>; - pwm-supply = <&ppvar_sys>; - pwm-dutycycle-range = <100 0>; - pwm-dutycycle-unit = <100>; - - /* EC turns on w/ ppvar_centerlogic_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <799434>; - regulator-max-microvolt = <1049925>; - }; - - ppvar_centerlogic: ppvar-centerlogic { - compatible = "vctrl-regulator"; - regulator-name = "ppvar_centerlogic"; - - regulator-min-microvolt = <799434>; - regulator-max-microvolt = <1049925>; - - ctrl-supply = <&ppvar_centerlogic_pwm>; - ctrl-voltage-range = <799434 1049925>; - - regulator-settling-time-up-us = <378>; - min-slew-down-rate = <225>; - ovp-threshold-percent = <16>; - }; - - /* Schematics call this PPVAR even though it's fixed */ - ppvar_logic: ppvar-logic { - compatible = "regulator-fixed"; - regulator-name = "ppvar_logic"; - - /* EC turns on w/ ppvar_logic_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - vin-supply = <&ppvar_sys>; - }; - - pp1800_audio: pp1800-audio { - compatible = "regulator-fixed"; - regulator-name = "pp1800_audio"; - pinctrl-names = "default"; - pinctrl-0 = <&pp1800_audio_en>; - - enable-active-high; - gpio = <&gpio0 2 GPIO_ACTIVE_HIGH>; - - regulator-always-on; - regulator-boot-on; - - vin-supply = <&pp1800>; - }; - - /* gpio is shared with pp3300_wifi_bt */ - pp1800_pcie: pp1800-pcie { - compatible = "regulator-fixed"; - regulator-name = "pp1800_pcie"; - pinctrl-names = "default"; - pinctrl-0 = <&wlan_module_pd_l>; - - enable-active-high; - gpio = <&gpio0 4 GPIO_ACTIVE_HIGH>; - - /* - * Need to wait 1ms + ramp-up time before we can power on WiFi. - * This has been approximated as 8ms total. - */ - regulator-enable-ramp-delay = <8000>; - - vin-supply = <&pp1800>; - }; - - /* Always on; plain and simple */ - pp3000_ap: pp3000_emmc: pp3000 { - }; - - pp1500_ap_io: pp1500-ap-io { - compatible = "regulator-fixed"; - regulator-name = "pp1500_ap_io"; - pinctrl-names = "default"; - pinctrl-0 = <&pp1500_en>; - - enable-active-high; - gpio = <&gpio0 10 GPIO_ACTIVE_HIGH>; - - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - - vin-supply = <&pp1800>; - }; - - pp3300_disp: pp3300-disp { - compatible = "regulator-fixed"; - regulator-name = "pp3300_disp"; - pinctrl-names = "default"; - pinctrl-0 = <&pp3300_disp_en>; - - enable-active-high; - gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>; - - startup-delay-us = <2000>; - vin-supply = <&pp3300>; - }; - - /* EC turns on w/ pp3300_usb_en_l */ - pp3300_usb: pp3300 { - }; - - /* gpio is shared with pp1800_pcie and pinctrl is set there */ - pp3300_wifi_bt: pp3300-wifi-bt { - compatible = "regulator-fixed"; - regulator-name = "pp3300_wifi_bt"; - - enable-active-high; - gpio = <&gpio0 4 GPIO_ACTIVE_HIGH>; - - vin-supply = <&pp3300>; - }; - - /* - * This is a bit of a hack. The WiFi module should be reset at least - * 1ms after its regulators have ramped up (max rampup time is ~7ms). - * With some stretching of the imagination, we can call the 1.8V - * regulator a supply. - */ - wlan_pd_n: wlan-pd-n { - compatible = "regulator-fixed"; - regulator-name = "wlan_pd_n"; - pinctrl-names = "default"; - pinctrl-0 = <&wlan_module_reset_l>; - - enable-active-high; - gpio = <&gpio1 11 GPIO_ACTIVE_HIGH>; - - vin-supply = <&pp1800_pcie>; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - enable-gpios = <&gpio1 17 GPIO_ACTIVE_HIGH>; - power-supply = <&pp3300_disp>; - pinctrl-names = "default"; - pinctrl-0 = <&bl_en>; - }; - - gpio_keys: gpio-keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l>; - - wake_on_bt: key-wake-on-bt { - label = "Wake-on-Bluetooth"; - gpios = <&gpio0 3 GPIO_ACTIVE_LOW>; - linux,code = <KEY_WAKEUP>; - wakeup-source; - }; - }; -}; - -&ppvar_bigcpu { - min-slew-down-rate = <225>; - ovp-threshold-percent = <16>; -}; - -&ppvar_litcpu { - min-slew-down-rate = <225>; - ovp-threshold-percent = <16>; -}; - -&ppvar_gpu { - min-slew-down-rate = <225>; - ovp-threshold-percent = <16>; -}; - -&cdn_dp { - extcon = <&usbc_extcon0>, <&usbc_extcon1>; -}; - -&dmc { - center-supply = <&ppvar_centerlogic>; - rockchip,pd-idle-dis-freq-hz = <800000000>; - rockchip,sr-idle-dis-freq-hz = <800000000>; - rockchip,sr-mc-gate-idle-dis-freq-hz = <800000000>; -}; - -&edp { - status = "okay"; - - /* - * eDP PHY/clk don't sync reliably at anything other than 24 MHz. Only - * set this here, because rk3399-gru.dtsi ensures we can generate this - * off GPLL=600MHz, whereas some other RK3399 boards may not. - */ - assigned-clocks = <&cru PCLK_EDP>; - assigned-clock-rates = <24000000>; - - ports { - edp_out: port@1 { - reg = <1>; - #address-cells = <1>; - #size-cells = <0>; - - edp_out_panel: endpoint@0 { - reg = <0>; - remote-endpoint = <&panel_in_edp>; - }; - }; - }; -}; - -&gpio0 { - gpio-line-names = /* GPIO0 A 0-7 */ - "AP_RTC_CLK_IN", - "EC_AP_INT_L", - "PP1800_AUDIO_EN", - "BT_HOST_WAKE_L", - "WLAN_MODULE_PD_L", - "H1_INT_OD_L", - "CENTERLOGIC_DVS_PWM", - "", - - /* GPIO0 B 0-4 */ - "WIFI_HOST_WAKE_L", - "PMUIO2_33_18_L", - "PP1500_EN", - "AP_EC_WARM_RESET_REQ", - "PP3000_EN"; -}; - -&gpio1 { - gpio-line-names = /* GPIO1 A 0-7 */ - "", - "", - "SPK_PA_EN", - "", - "TRACKPAD_INT_L", - "AP_EC_S3_S0_L", - "AP_EC_OVERTEMP", - "AP_SPI_FLASH_MISO", - - /* GPIO1 B 0-7 */ - "AP_SPI_FLASH_MOSI_R", - "AP_SPI_FLASH_CLK_R", - "AP_SPI_FLASH_CS_L_R", - "WLAN_MODULE_RESET_L", - "WIFI_DISABLE_L", - "MIC_INT", - "", - "AP_I2C_DVS_SDA", - - /* GPIO1 C 0-7 */ - "AP_I2C_DVS_SCL", - "AP_BL_EN", - /* - * AP_FLASH_WP is crossystem ABI. Schematics call it - * AP_FW_WP or CPU1_FW_WP, depending on the variant. - */ - "AP_FLASH_WP", - "LITCPU_DVS_PWM", - "AP_I2C_AUDIO_SDA", - "AP_I2C_AUDIO_SCL", - "", - "HEADSET_INT_L"; -}; - -&gpio2 { - gpio-line-names = /* GPIO2 A 0-7 */ - "", - "", - "SD_IO_PWR_EN", - "", - "", - "", - "", - "", - - /* GPIO2 B 0-7 */ - "", - "", - "", - "", - "", - "", - "", - "", - - /* GPIO2 C 0-7 */ - "", - "", - "", - "", - "AP_SPI_EC_MISO", - "AP_SPI_EC_MOSI", - "AP_SPI_EC_CLK", - "AP_SPI_EC_CS_L", - - /* GPIO2 D 0-4 */ - "BT_DEV_WAKE_L", - "", - "WIFI_PCIE_CLKREQ_L", - "WIFI_PERST_L", - "SD_PWR_3000_1800_L"; -}; - -&gpio3 { - gpio-line-names = /* GPIO3 A 0-7 */ - "", - "", - "", - "", - "AP_SPI_TPM_MISO", - "AP_SPI_TPM_MOSI_R", - "AP_SPI_TPM_CLK_R", - "AP_SPI_TPM_CS_L_R", - - /* GPIO3 B 0-7 */ - "EC_IN_RW", - "", - "AP_I2C_TP_SDA", - "AP_I2C_TP_SCL", - "AP_I2C_TP_PU_EN", - "TOUCH_INT_L", - "", - "", - - /* GPIO3 C 0-7 */ - "", - "", - "", - "", - "", - "", - "", - "", - - /* GPIO3 D 0-7 */ - "I2S0_SCLK", - "I2S0_LRCK_RX", - "I2S0_LRCK_TX", - "I2S0_SDI_0", - "I2S0_SDI_1", - "", - "I2S0_SDO_1", - "I2S0_SDO_0"; -}; - -&gpio4 { - gpio-line-names = /* GPIO4 A 0-7 */ - "I2S_MCLK", - "AP_I2C_MIC_SDA", - "AP_I2C_MIC_SCL", - "", - "", - "", - "", - "", - - /* GPIO4 B 0-7 */ - "", - "", - "", - "", - "", - "", - "", - "", - - /* GPIO4 C 0-7 */ - "AP_I2C_TS_SDA", - "AP_I2C_TS_SCL", - "GPU_DVS_PWM", - "UART_DBG_TX_AP_RX", - "UART_AP_TX_DBG_RX", - "", - "BIGCPU_DVS_PWM", - "EDP_HPD_3V0", - - /* GPIO4 D 0-5 */ - "SD_CARD_DET_L", - "USB_DP_HPD", - "TOUCH_RESET_L", - "PP3300_DISP_EN", - "", - "SD_SLOT_PWR_EN"; -}; - -ap_i2c_mic: &i2c1 { - status = "okay"; - - clock-frequency = <400000>; - - /* These are relatively safe rise/fall times */ - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; - - headsetcodec: rt5514@57 { - compatible = "realtek,rt5514"; - reg = <0x57>; - realtek,dmic-init-delay-ms = <20>; - }; -}; - -ap_i2c_tp: &i2c5 { - status = "okay"; - - clock-frequency = <400000>; - - /* These are relatively safe rise/fall times */ - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; - - /* - * Note strange pullup enable. Apparently this avoids leakage but - * still allows us to get nice 4.7K pullups for high speed i2c - * transfers. Basically we want the pullup on whenever the ap is - * alive, so the "en" pin just gets set to output high. - */ - pinctrl-0 = <&i2c5_xfer &ap_i2c_tp_pu_en>; -}; - -&cros_ec { - cros_ec_pwm: pwm { - compatible = "google,cros-ec-pwm"; - #pwm-cells = <1>; - }; - - usbc_extcon1: extcon1 { - compatible = "google,extcon-usbc-cros-ec"; - google,usb-port-id = <1>; - }; -}; - -&sound { - rockchip,codec = <&max98357a &headsetcodec - &codec &wacky_spi_audio &cdn_dp>; -}; - -&spi2 { - wacky_spi_audio: spi2@0 { - compatible = "realtek,rt5514"; - reg = <0>; - interrupt-parent = <&gpio1>; - interrupts = <13 IRQ_TYPE_LEVEL_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&mic_int>; - /* May run faster once verified. */ - spi-max-frequency = <10000000>; - wakeup-source; - }; -}; - -&pci_rootport { - mvl_wifi: wifi@0,0 { - compatible = "pci1b4b,2b42"; - reg = <0x0000 0x0 0x0 0x0 0x0>; - interrupt-parent = <&gpio0>; - interrupts = <8 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&wlan_host_wake_l>; - wakeup-source; - }; -}; - -&tcphy1 { - status = "okay"; - extcon = <&usbc_extcon1>; -}; - -&u2phy1 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_1 { - status = "okay"; - extcon = <&usbc_extcon1>; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&pinctrl { - discrete-regulators { - pp1500_en: pp1500-en { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO - &pcfg_pull_none>; - }; - - pp1800_audio_en: pp1800-audio-en { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO - &pcfg_pull_down>; - }; - - pp3000_en: pp3000-en { - rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO - &pcfg_pull_none>; - }; - - pp3300_disp_en: pp3300-disp-en { - rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO - &pcfg_pull_none>; - }; - - wlan_module_pd_l: wlan-module-pd-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO - &pcfg_pull_down>; - }; - }; -}; - -&wifi { - wifi_perst_l: wifi-perst-l { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wlan_host_wake_l: wlan-host-wake-l { - /* Kevin has an external pull up, but Bob does not */ - rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; - }; -}; diff --git a/arch/arm/dts/rk3399-gru-kevin.dts b/arch/arm/dts/rk3399-gru-kevin.dts deleted file mode 100644 index 2cc9b3386c16..000000000000 --- a/arch/arm/dts/rk3399-gru-kevin.dts +++ /dev/null @@ -1,328 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Google Gru-Kevin Rev 6+ board device tree source - * - * Copyright 2016-2017 Google, Inc - */ - -/dts-v1/; -#include "rk3399-gru-chromebook.dtsi" -#include <dt-bindings/input/linux-event-codes.h> - -/* - * Kevin-specific things - * - * Things in this section should use names from Kevin schematic since no - * equivalent exists in Gru schematic. If referring to signals that exist - * in Gru we use the Gru names, though. Confusing enough for you? - */ -/ { - model = "Google Kevin"; - compatible = "google,kevin-rev15", "google,kevin-rev14", - "google,kevin-rev13", "google,kevin-rev12", - "google,kevin-rev11", "google,kevin-rev10", - "google,kevin-rev9", "google,kevin-rev8", - "google,kevin-rev7", "google,kevin-rev6", - "google,kevin", "google,gru", "rockchip,rk3399"; - chassis-type = "convertible"; - - /* Power tree */ - - p3_3v_dig: p3-3v-dig { - compatible = "regulator-fixed"; - regulator-name = "p3.3v_dig"; - pinctrl-names = "default"; - pinctrl-0 = <&cpu3_pen_pwr_en>; - - enable-active-high; - gpio = <&gpio4 30 GPIO_ACTIVE_HIGH>; - vin-supply = <&pp3300>; - }; - - edp_panel: edp-panel { - compatible = "sharp,lq123p1jx31"; - backlight = <&backlight>; - power-supply = <&pp3300_disp>; - - panel-timing { - clock-frequency = <266666667>; - hactive = <2400>; - hfront-porch = <48>; - hback-porch = <84>; - hsync-len = <32>; - hsync-active = <0>; - vactive = <1600>; - vfront-porch = <3>; - vback-porch = <120>; - vsync-len = <10>; - vsync-active = <0>; - }; - - port { - panel_in_edp: endpoint { - remote-endpoint = <&edp_out_panel>; - }; - }; - }; - - thermistor_ppvar_bigcpu: thermistor-ppvar-bigcpu { - compatible = "murata,ncp15wb473"; - pullup-uv = <1800000>; - pullup-ohm = <25500>; - pulldown-ohm = <0>; - io-channels = <&saradc 2>; - #thermal-sensor-cells = <0>; - }; - - thermistor_ppvar_litcpu: thermistor-ppvar-litcpu { - compatible = "murata,ncp15wb473"; - pullup-uv = <1800000>; - pullup-ohm = <25500>; - pulldown-ohm = <0>; - io-channels = <&saradc 3>; - #thermal-sensor-cells = <0>; - }; -}; - -&backlight { - pwms = <&cros_ec_pwm 1>; -}; - -&gpio_keys { - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l>, <&cpu1_pen_eject>; - - switch-pen-insert { - label = "Pen Insert"; - /* Insert = low, eject = high */ - gpios = <&gpio0 13 GPIO_ACTIVE_LOW>; - linux,code = <SW_PEN_INSERTED>; - linux,input-type = <EV_SW>; - wakeup-source; - }; -}; - -&thermal_zones { - bigcpu_reg_thermal: bigcpu-reg-thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <1000>; /* milliseconds */ - thermal-sensors = <&thermistor_ppvar_bigcpu 0>; - sustainable-power = <4000>; - - ppvar_bigcpu_trips: trips { - ppvar_bigcpu_on: ppvar-bigcpu-on { - temperature = <40000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - - ppvar_bigcpu_alert: ppvar-bigcpu-alert { - temperature = <50000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - - ppvar_bigcpu_crit: ppvar-bigcpu-crit { - temperature = <90000>; /* millicelsius */ - hysteresis = <0>; /* millicelsius */ - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&ppvar_bigcpu_alert>; - cooling-device = - <&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_l1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_l2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - contribution = <4096>; - }; - map1 { - trip = <&ppvar_bigcpu_alert>; - cooling-device = - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - contribution = <1024>; - }; - }; - }; - - litcpu_reg_thermal: litcpu-reg-thermal { - polling-delay-passive = <100>; /* milliseconds */ - polling-delay = <1000>; /* milliseconds */ - thermal-sensors = <&thermistor_ppvar_litcpu 0>; - sustainable-power = <4000>; - - ppvar_litcpu_trips: trips { - ppvar_litcpu_on: ppvar-litcpu-on { - temperature = <40000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - - ppvar_litcpu_alert: ppvar-litcpu-alert { - temperature = <50000>; /* millicelsius */ - hysteresis = <2000>; /* millicelsius */ - type = "passive"; - }; - - ppvar_litcpu_crit: ppvar-litcpu-crit { - temperature = <90000>; /* millicelsius */ - hysteresis = <0>; /* millicelsius */ - type = "critical"; - }; - }; - }; -}; - -ap_i2c_tpm: &i2c0 { - status = "okay"; - - clock-frequency = <400000>; - - /* These are relatively safe rise/fall times. */ - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; - - tpm: tpm@20 { - compatible = "infineon,slb9645tt"; - reg = <0x20>; - powered-while-suspended; - }; -}; - -ap_i2c_dig: &i2c2 { - status = "okay"; - - clock-frequency = <400000>; - - /* These are relatively safe rise/fall times. */ - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; - - digitizer: digitizer@9 { - /* wacom,w9013 */ - compatible = "hid-over-i2c"; - reg = <0x9>; - pinctrl-names = "default"; - pinctrl-0 = <&cpu1_dig_irq_l &cpu1_dig_pdct_l>; - - vdd-supply = <&p3_3v_dig>; - post-power-on-delay-ms = <100>; - - interrupt-parent = <&gpio2>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - - hid-descr-addr = <0x1>; - }; -}; - -/* Adjustments to things in the gru baseboard */ - -&ap_i2c_tp { - trackpad@4a { - compatible = "atmel,maxtouch"; - reg = <0x4a>; - pinctrl-names = "default"; - pinctrl-0 = <&trackpad_int_l>; - interrupt-parent = <&gpio1>; - interrupts = <4 IRQ_TYPE_LEVEL_LOW>; - linux,gpio-keymap = <KEY_RESERVED - KEY_RESERVED - KEY_RESERVED - BTN_LEFT>; - wakeup-source; - }; -}; - -&ap_i2c_ts { - touchscreen@4b { - compatible = "atmel,maxtouch"; - reg = <0x4b>; - pinctrl-names = "default"; - pinctrl-0 = <&touch_int_l>; - interrupt-parent = <&gpio3>; - interrupts = <13 IRQ_TYPE_LEVEL_LOW>; - }; -}; - -&ppvar_bigcpu_pwm { - regulator-min-microvolt = <798674>; - regulator-max-microvolt = <1302172>; -}; - -&ppvar_bigcpu { - regulator-min-microvolt = <798674>; - regulator-max-microvolt = <1302172>; - ctrl-voltage-range = <798674 1302172>; -}; - -&ppvar_litcpu_pwm { - regulator-min-microvolt = <799065>; - regulator-max-microvolt = <1303738>; -}; - -&ppvar_litcpu { - regulator-min-microvolt = <799065>; - regulator-max-microvolt = <1303738>; - ctrl-voltage-range = <799065 1303738>; -}; - -&ppvar_gpu_pwm { - regulator-min-microvolt = <785782>; - regulator-max-microvolt = <1217729>; -}; - -&ppvar_gpu { - regulator-min-microvolt = <785782>; - regulator-max-microvolt = <1217729>; - ctrl-voltage-range = <785782 1217729>; -}; - -&ppvar_centerlogic_pwm { - regulator-min-microvolt = <800069>; - regulator-max-microvolt = <1049692>; -}; - -&ppvar_centerlogic { - regulator-min-microvolt = <800069>; - regulator-max-microvolt = <1049692>; - ctrl-voltage-range = <800069 1049692>; -}; - -&saradc { - status = "okay"; - vref-supply = <&pp1800_ap_io>; -}; - -&mvl_wifi { - marvell,wakeup-pin = <14>; /* GPIO_14 on Marvell */ -}; - -&pinctrl { - digitizer { - /* Has external pullup */ - cpu1_dig_irq_l: cpu1-dig-irq-l { - rockchip,pins = <2 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - /* Has external pullup */ - cpu1_dig_pdct_l: cpu1-dig-pdct-l { - rockchip,pins = <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - discrete-regulators { - cpu3_pen_pwr_en: cpu3-pen-pwr-en { - rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pen { - cpu1_pen_eject: cpu1-pen-eject { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi deleted file mode 100644 index d90fe4d40d48..000000000000 --- a/arch/arm/dts/rk3399-gru.dtsi +++ /dev/null @@ -1,865 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Google Gru (and derivatives) board device tree source - * - * Copyright 2016-2017 Google, Inc - */ - -#include <dt-bindings/input/input.h> -#include "rk3399.dtsi" -#include "rk3399-op1-opp.dtsi" - -/ { - aliases { - mmc0 = &sdmmc; - mmc1 = &sdhci; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - /* - * Power Tree - * - * In general an attempt is made to include all rails called out by - * the schematic as long as those rails interact in some way with - * the AP. AKA: - * - Rails that only connect to the EC (or devices that the EC talks to) - * are not included. - * - Rails _are_ included if the rails go to the AP even if the AP - * doesn't currently care about them / they are always on. The idea - * here is that it makes it easier to map to the schematic or extend - * later. - * - * If two rails are substantially the same from the AP's point of - * view, though, we won't create a full fixed regulator. We'll just - * put the child rail as an alias of the parent rail. Sometimes rails - * look the same to the AP because one of these is true: - * - The EC controls the enable and the EC always enables a rail as - * long as the AP is running. - * - The rails are actually connected to each other by a jumper and - * the distinction is just there to add clarity/flexibility to the - * schematic. - */ - - ppvar_sys: ppvar-sys { - compatible = "regulator-fixed"; - regulator-name = "ppvar_sys"; - regulator-always-on; - regulator-boot-on; - }; - - pp1200_lpddr: pp1200-lpddr { - compatible = "regulator-fixed"; - regulator-name = "pp1200_lpddr"; - - /* EC turns on w/ lpddr_pwr_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - - vin-supply = <&ppvar_sys>; - }; - - pp1800: pp1800 { - compatible = "regulator-fixed"; - regulator-name = "pp1800"; - - /* Always on when ppvar_sys shows power good */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - vin-supply = <&ppvar_sys>; - }; - - pp3300: pp3300 { - compatible = "regulator-fixed"; - regulator-name = "pp3300"; - - /* Always on; plain and simple */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - vin-supply = <&ppvar_sys>; - }; - - pp5000: pp5000 { - compatible = "regulator-fixed"; - regulator-name = "pp5000"; - - /* EC turns on w/ pp5000_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - - vin-supply = <&ppvar_sys>; - }; - - ppvar_bigcpu_pwm: ppvar-bigcpu-pwm { - compatible = "pwm-regulator"; - regulator-name = "ppvar_bigcpu_pwm"; - - pwms = <&pwm1 0 3337 0>; - pwm-supply = <&ppvar_sys>; - pwm-dutycycle-range = <100 0>; - pwm-dutycycle-unit = <100>; - - /* EC turns on w/ ap_core_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800107>; - regulator-max-microvolt = <1302232>; - }; - - ppvar_bigcpu: ppvar-bigcpu { - compatible = "vctrl-regulator"; - regulator-name = "ppvar_bigcpu"; - - regulator-min-microvolt = <800107>; - regulator-max-microvolt = <1302232>; - - ctrl-supply = <&ppvar_bigcpu_pwm>; - ctrl-voltage-range = <800107 1302232>; - - regulator-settling-time-up-us = <322>; - }; - - ppvar_litcpu_pwm: ppvar-litcpu-pwm { - compatible = "pwm-regulator"; - regulator-name = "ppvar_litcpu_pwm"; - - pwms = <&pwm2 0 3337 0>; - pwm-supply = <&ppvar_sys>; - pwm-dutycycle-range = <100 0>; - pwm-dutycycle-unit = <100>; - - /* EC turns on w/ ap_core_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <797743>; - regulator-max-microvolt = <1307837>; - }; - - ppvar_litcpu: ppvar-litcpu { - compatible = "vctrl-regulator"; - regulator-name = "ppvar_litcpu"; - - regulator-min-microvolt = <797743>; - regulator-max-microvolt = <1307837>; - - ctrl-supply = <&ppvar_litcpu_pwm>; - ctrl-voltage-range = <797743 1307837>; - - regulator-settling-time-up-us = <384>; - }; - - ppvar_gpu_pwm: ppvar-gpu-pwm { - compatible = "pwm-regulator"; - regulator-name = "ppvar_gpu_pwm"; - - pwms = <&pwm0 0 3337 0>; - pwm-supply = <&ppvar_sys>; - pwm-dutycycle-range = <100 0>; - pwm-dutycycle-unit = <100>; - - /* EC turns on w/ ap_core_en; always on for AP */ - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <786384>; - regulator-max-microvolt = <1217747>; - }; - - ppvar_gpu: ppvar-gpu { - compatible = "vctrl-regulator"; - regulator-name = "ppvar_gpu"; - - regulator-min-microvolt = <786384>; - regulator-max-microvolt = <1217747>; - - ctrl-supply = <&ppvar_gpu_pwm>; - ctrl-voltage-range = <786384 1217747>; - - regulator-settling-time-up-us = <390>; - }; - - /* EC turns on w/ pp900_ddrpll_en */ - pp900_ddrpll: pp900-ap { - }; - - /* EC turns on w/ pp900_pll_en */ - pp900_pll: pp900-ap { - }; - - /* EC turns on w/ pp900_pmu_en */ - pp900_pmu: pp900-ap { - }; - - /* EC turns on w/ pp1800_s0_en_l */ - pp1800_ap_io: pp1800_emmc: pp1800_nfc: pp1800_s0: pp1800 { - }; - - /* EC turns on w/ pp1800_avdd_en_l */ - pp1800_avdd: pp1800 { - }; - - /* EC turns on w/ pp1800_lid_en_l */ - pp1800_lid: pp1800_mic: pp1800 { - }; - - /* EC turns on w/ lpddr_pwr_en */ - pp1800_lpddr: pp1800 { - }; - - /* EC turns on w/ pp1800_pmu_en_l */ - pp1800_pmu: pp1800 { - }; - - /* EC turns on w/ pp1800_usb_en_l */ - pp1800_usb: pp1800 { - }; - - pp3000_sd_slot: pp3000-sd-slot { - compatible = "regulator-fixed"; - regulator-name = "pp3000_sd_slot"; - pinctrl-names = "default"; - pinctrl-0 = <&sd_slot_pwr_en>; - - enable-active-high; - gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>; - - vin-supply = <&pp3000>; - }; - - /* - * Technically, this is a small abuse of 'regulator-gpio'; this - * regulator is a mux between pp1800 and pp3300. pp1800 and pp3300 are - * always on though, so it is sufficient to simply control the mux - * here. - */ - ppvar_sd_card_io: ppvar-sd-card-io { - compatible = "regulator-gpio"; - regulator-name = "ppvar_sd_card_io"; - pinctrl-names = "default"; - pinctrl-0 = <&sd_io_pwr_en &sd_pwr_1800_sel>; - - enable-active-high; - enable-gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>; - gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>; - states = <1800000 0x1>, - <3000000 0x0>; - - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - }; - - /* EC turns on w/ pp3300_trackpad_en_l */ - pp3300_trackpad: pp3300-trackpad { - }; - - /* EC turns on w/ usb_a_en */ - pp5000_usb_a_vbus: pp5000 { - }; - - ap_rtc_clk: ap-rtc-clk { - compatible = "fixed-clock"; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - #clock-cells = <0>; - }; - - max98357a: max98357a { - compatible = "maxim,max98357a"; - pinctrl-names = "default"; - pinctrl-0 = <&sdmode_en>; - sdmode-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>; - sdmode-delay = <2>; - #sound-dai-cells = <0>; - status = "okay"; - }; - - sound: sound { - compatible = "rockchip,rk3399-gru-sound"; - rockchip,cpu = <&i2s0 &spdif>; - }; -}; - -&cdn_dp { - status = "okay"; -}; - -/* - * Set some suspend operating points to avoid OVP in suspend - * - * When we go into S3 ARM Trusted Firmware will transition our PWM regulators - * from wherever they're at back to the "default" operating point (whatever - * voltage we get when we set the PWM pins to "input"). - * - * This quick transition under light load has the possibility to trigger the - * regulator "over voltage protection" (OVP). - * - * To make extra certain that we don't hit this OVP at suspend time, we'll - * transition to a voltage that's much closer to the default (~1.0 V) so that - * there will not be a big jump. Technically we only need to get within 200 mV - * of the default voltage, but the speed here should be fast enough and we need - * suspend/resume to be rock solid. - */ - -&cluster0_opp { - opp05 { - opp-suspend; - }; -}; - -&cluster1_opp { - opp06 { - opp-suspend; - }; -}; - -&cpu_l0 { - cpu-supply = <&ppvar_litcpu>; -}; - -&cpu_l1 { - cpu-supply = <&ppvar_litcpu>; -}; - -&cpu_l2 { - cpu-supply = <&ppvar_litcpu>; -}; - -&cpu_l3 { - cpu-supply = <&ppvar_litcpu>; -}; - -&cpu_b0 { - cpu-supply = <&ppvar_bigcpu>; -}; - -&cpu_b1 { - cpu-supply = <&ppvar_bigcpu>; -}; - - -&cru { - assigned-clocks = - <&cru PLL_GPLL>, <&cru PLL_CPLL>, - <&cru PLL_NPLL>, - <&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>, - <&cru PCLK_PERIHP>, - <&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>, - <&cru PCLK_PERILP0>, <&cru ACLK_CCI>, - <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>, - <&cru ACLK_VIO>, <&cru ACLK_HDCP>, - <&cru ACLK_GIC_PRE>, - <&cru PCLK_DDR>; - assigned-clock-rates = - <600000000>, <800000000>, - <1000000000>, - <150000000>, <75000000>, - <37500000>, - <100000000>, <100000000>, - <50000000>, <800000000>, - <100000000>, <50000000>, - <400000000>, <400000000>, - <200000000>, - <200000000>; -}; - -&dfi { - status = "okay"; -}; - -&dmc { - status = "okay"; - - rockchip,pd-idle-ns = <160>; - rockchip,sr-idle-ns = <10240>; - rockchip,sr-mc-gate-idle-ns = <40960>; - rockchip,srpd-lite-idle-ns = <61440>; - rockchip,standby-idle-ns = <81920>; - - rockchip,ddr3_odt_dis_freq = <666000000>; - rockchip,lpddr3_odt_dis_freq = <666000000>; - rockchip,lpddr4_odt_dis_freq = <666000000>; - - rockchip,sr-mc-gate-idle-dis-freq-hz = <1000000000>; - rockchip,srpd-lite-idle-dis-freq-hz = <0>; - rockchip,standby-idle-dis-freq-hz = <928000000>; -}; - -&dmc_opp_table { - opp03 { - opp-suspend; - }; -}; - -&emmc_phy { - status = "okay"; -}; - -&gpu { - mali-supply = <&ppvar_gpu>; - status = "okay"; -}; - -ap_i2c_ts: &i2c3 { - status = "okay"; - - clock-frequency = <400000>; - - /* These are relatively safe rise/fall times */ - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; -}; - -ap_i2c_audio: &i2c8 { - status = "okay"; - - clock-frequency = <400000>; - - /* These are relatively safe rise/fall times */ - i2c-scl-falling-time-ns = <50>; - i2c-scl-rising-time-ns = <300>; - - codec: da7219@1a { - compatible = "dlg,da7219"; - reg = <0x1a>; - interrupt-parent = <&gpio1>; - interrupts = <23 IRQ_TYPE_LEVEL_LOW>; - clocks = <&cru SCLK_I2S_8CH_OUT>; - clock-names = "mclk"; - dlg,micbias-lvl = <2600>; - dlg,mic-amp-in-sel = "diff"; - pinctrl-names = "default"; - pinctrl-0 = <&headset_int_l>; - VDD-supply = <&pp1800>; - VDDMIC-supply = <&pp3300>; - VDDIO-supply = <&pp1800>; - - da7219_aad { - dlg,adc-1bit-rpt = <1>; - dlg,btn-avg = <4>; - dlg,btn-cfg = <50>; - dlg,mic-det-thr = <500>; - dlg,jack-ins-deb = <20>; - dlg,jack-det-rate = "32ms_64ms"; - dlg,jack-rem-deb = <1>; - - dlg,a-d-btn-thr = <0xa>; - dlg,d-b-btn-thr = <0x16>; - dlg,b-c-btn-thr = <0x21>; - dlg,c-mic-btn-thr = <0x3E>; - }; - }; -}; - -&i2s0 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - audio-supply = <&pp1800_audio>; /* APIO5_VDD; 3d 4a */ - bt656-supply = <&pp1800_ap_io>; /* APIO2_VDD; 2a 2b */ - gpio1830-supply = <&pp3000_ap>; /* APIO4_VDD; 4c 4d */ - sdmmc-supply = <&ppvar_sd_card_io>; /* SDMMC0_VDD; 4b */ -}; - -&pcie0 { - status = "okay"; - - ep-gpios = <&gpio2 27 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn_cpm>, <&wifi_perst_l>; - vpcie3v3-supply = <&pp3300_wifi_bt>; - vpcie1v8-supply = <&wlan_pd_n>; /* HACK: see &wlan_pd_n */ - vpcie0v9-supply = <&pp900_pcie>; - - pci_rootport: pcie@0,0 { - reg = <0x0000 0 0 0 0>; - #address-cells = <3>; - #size-cells = <2>; - ranges; - device_type = "pci"; - }; -}; - -&pcie_phy { - status = "okay"; -}; - -&pmu_io_domains { - status = "okay"; - - pmu1830-supply = <&pp1800_pmu>; /* PMUIO2_VDD */ -}; - -&pwm0 { - status = "okay"; -}; - -&pwm1 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&pwm3 { - status = "okay"; -}; - -&sdhci { - /* - * Signal integrity isn't great at 200 MHz and 150 MHz (DDR) gives the - * same (or nearly the same) performance for all eMMC that are intended - * to be used. - */ - assigned-clock-rates = <150000000>; - - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&sdmmc { - status = "okay"; - - /* - * Note: configure "sdmmc_cd" as card detect even though it's actually - * hooked to ground. Because we specified "cd-gpios" below dw_mmc - * should be ignoring card detect anyway. Specifying the pin as - * sdmmc_cd means that even if you've got GRF_SOC_CON7[12] (force_jtag) - * turned on that the system will still make sure the port is - * configured as SDMMC and not JTAG. - */ - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_cd_pin - &sdmmc_bus4>; - - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio4 24 GPIO_ACTIVE_LOW>; - disable-wp; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - vmmc-supply = <&pp3000_sd_slot>; - vqmmc-supply = <&ppvar_sd_card_io>; -}; - -&spdif { - status = "okay"; - - /* - * SPDIF is routed internally to DP; we either don't use these pins, or - * mux them to something else. - */ - /delete-property/ pinctrl-0; - /delete-property/ pinctrl-names; -}; - -&spi1 { - status = "okay"; - - pinctrl-names = "default", "sleep"; - pinctrl-1 = <&spi1_sleep>; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - - /* May run faster once verified. */ - spi-max-frequency = <10000000>; - }; -}; - -&spi2 { - status = "okay"; -}; - -&spi5 { - status = "okay"; - - cros_ec: ec@0 { - compatible = "google,cros-ec-spi"; - reg = <0>; - interrupt-parent = <&gpio0>; - interrupts = <1 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ec_ap_int_l>; - spi-max-frequency = <3000000>; - - i2c_tunnel: i2c-tunnel { - compatible = "google,cros-ec-i2c-tunnel"; - google,remote-bus = <4>; - #address-cells = <1>; - #size-cells = <0>; - }; - - usbc_extcon0: extcon0 { - compatible = "google,extcon-usbc-cros-ec"; - google,usb-port-id = <0>; - }; - }; -}; - -&tsadc { - status = "okay"; - - rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */ -}; - -&tcphy0 { - status = "okay"; - extcon = <&usbc_extcon0>; -}; - -&u2phy0 { - status = "okay"; -}; - -&u2phy0_host { - status = "okay"; -}; - -&u2phy1_host { - status = "okay"; -}; - -&u2phy0_otg { - status = "okay"; -}; - -&u2phy1_otg { - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; - extcon = <&usbc_extcon0>; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; - -#include <cros-ec-keyboard.dtsi> -#include <cros-ec-sbs.dtsi> - -&pinctrl { - /* - * pinctrl settings for pins that have no real owners. - * - * At the moment settings are identical for S0 and S3, but if we later - * need to configure things differently for S3 we'll adjust here. - */ - pinctrl-names = "default"; - pinctrl-0 = < - &ap_pwroff /* AP will auto-assert this when in S3 */ - &clk_32k /* This pin is always 32k on gru boards */ - >; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_pull_none_8ma: pcfg-pull-none-8ma { - bias-disable; - drive-strength = <8>; - }; - - backlight-enable { - bl_en: bl-en { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - cros-ec { - ec_ap_int_l: ec-ap-int-l { - rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - discrete-regulators { - sd_io_pwr_en: sd-io-pwr-en { - rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO - &pcfg_pull_none>; - }; - - sd_pwr_1800_sel: sd-pwr-1800-sel { - rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO - &pcfg_pull_none>; - }; - - sd_slot_pwr_en: sd-slot-pwr-en { - rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO - &pcfg_pull_none>; - }; - }; - - codec { - /* Has external pullup */ - headset_int_l: headset-int-l { - rockchip,pins = <1 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - mic_int: mic-int { - rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - max98357a { - sdmode_en: sdmode-en { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - pcie { - pcie_clkreqn_cpm: pci-clkreqn-cpm { - /* - * Since our pcie doesn't support ClockPM(CPM), we want - * to hack this as gpio, so the EP could be able to - * de-assert it along and make ClockPM(CPM) work. - */ - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - /* - * We run sdmmc at max speed; bump up drive strength. - * We also have external pulls, so disable the internal ones. - */ - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = - <4 RK_PB0 1 &pcfg_pull_none_8ma>, - <4 RK_PB1 1 &pcfg_pull_none_8ma>, - <4 RK_PB2 1 &pcfg_pull_none_8ma>, - <4 RK_PB3 1 &pcfg_pull_none_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = - <4 RK_PB4 1 &pcfg_pull_none_8ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = - <4 RK_PB5 1 &pcfg_pull_none_8ma>; - }; - - /* - * In our case the official card detect is hooked to ground - * to avoid getting access to JTAG just by sticking something - * in the SD card slot (see the force_jtag bit in the TRM). - * - * We still configure it as card detect because it doesn't - * hurt and dw_mmc will ignore it. We make sure to disable - * the pull though so we don't burn needless power. - */ - sdmmc_cd: sdmmc-cd { - rockchip,pins = - <0 RK_PA7 1 &pcfg_pull_none>; - }; - - /* This is where we actually hook up CD; has external pull */ - sdmmc_cd_pin: sdmmc-cd-pin { - rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - spi1 { - spi1_sleep: spi1-sleep { - /* - * Pull down SPI1 CLK/CS/RX/TX during suspend, to - * prevent leakage. - */ - rockchip,pins = <1 RK_PB1 RK_FUNC_GPIO &pcfg_pull_down>, - <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_down>, - <1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_down>, - <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - touchscreen { - touch_int_l: touch-int-l { - rockchip,pins = <3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - touch_reset_l: touch-reset-l { - rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - trackpad { - ap_i2c_tp_pu_en: ap-i2c-tp-pu-en { - rockchip,pins = <3 RK_PB4 RK_FUNC_GPIO &pcfg_output_high>; - }; - - trackpad_int_l: trackpad-int-l { - rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - wifi: wifi { - wlan_module_reset_l: wlan-module-reset-l { - rockchip,pins = <1 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - /* Kevin has an external pull up, but Gru does not */ - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - write-protect { - ap_fw_wp: ap-fw-wp { - rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; diff --git a/arch/arm/dts/rk3399-khadas-edge-captain.dts b/arch/arm/dts/rk3399-khadas-edge-captain.dts deleted file mode 100644 index 99ac4ed0f13f..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge-captain.dts +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Shenzhen Wesion Technology Co., Ltd. - * (https://www.khadas.com) - */ - -/dts-v1/; -#include "rk3399-khadas-edge.dtsi" - -/ { - model = "Khadas Edge-Captain"; - compatible = "khadas,edge-captain", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - }; -}; - -&gmac { - status = "okay"; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-khadas-edge-v.dts b/arch/arm/dts/rk3399-khadas-edge-v.dts deleted file mode 100644 index e12e7b4d64ca..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge-v.dts +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Shenzhen Wesion Technology Co., Ltd. - * (https://www.khadas.com) - */ - -/dts-v1/; -#include "rk3399-khadas-edge.dtsi" - -/ { - model = "Khadas Edge-V"; - compatible = "khadas,edge-v", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - }; -}; - -&gmac { - status = "okay"; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-khadas-edge.dts b/arch/arm/dts/rk3399-khadas-edge.dts deleted file mode 100644 index 31616e7ad89d..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge.dts +++ /dev/null @@ -1,13 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Shenzhen Wesion Technology Co., Ltd. - * (https://www.khadas.com) - */ - -/dts-v1/; -#include "rk3399-khadas-edge.dtsi" - -/ { - model = "Khadas Edge"; - compatible = "khadas,edge", "rockchip,rk3399"; -}; diff --git a/arch/arm/dts/rk3399-khadas-edge.dtsi b/arch/arm/dts/rk3399-khadas-edge.dtsi deleted file mode 100644 index 9d9297bc5f04..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge.dtsi +++ /dev/null @@ -1,837 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Shenzhen Wesion Technology Co., Ltd. - * (https://www.khadas.com) - */ - -/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - aliases { - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_LOW>; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pcie"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vsys_3v3>; - }; - - /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-always-on; - vin-supply = <&vsys_5v0>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vsys_3v3>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - }; - - vsys: vsys { - compatible = "regulator-fixed"; - regulator-name = "vsys"; - regulator-always-on; - regulator-boot-on; - }; - - vsys_3v3: vsys-3v3 { - compatible = "regulator-fixed"; - regulator-name = "vsys_3v3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vsys>; - }; - - vsys_5v0: vsys-5v0 { - compatible = "regulator-fixed"; - regulator-name = "vsys_5v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vsys>; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - poll-interval = <100>; - - button-recovery { - label = "Recovery"; - linux,code = <KEY_VENDOR>; - press-threshold-microvolt = <18000>; - }; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - key-power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_LOW>; - linux,rc-map-name = "rc-khadas"; - pinctrl-names = "default"; - pinctrl-0 = <&ir_rx>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&sys_led_pin>, <&user_led_pin>; - - sys_led: led-0 { - label = "sys_led"; - linux,default-trigger = "heartbeat"; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - }; - - user_led: led-1 { - label = "user_led"; - default-state = "off"; - gpios = <&gpio4 RK_PD0 GPIO_ACTIVE_HIGH>; - }; - }; - - fan: pwm-fan { - compatible = "pwm-fan"; - cooling-levels = <0 150 200 255>; - #cooling-cells = <2>; - fan-supply = <&vsys_5v0>; - pwms = <&pwm0 0 40000 0>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_thermal { - trips { - cpu_warm: cpu_warm { - temperature = <55000>; - hysteresis = <2000>; - type = "active"; - }; - - cpu_hot: cpu_hot { - temperature = <65000>; - hysteresis = <2000>; - type = "active"; - }; - }; - - cooling-maps { - map2 { - trip = <&cpu_warm>; - cooling-device = <&fan THERMAL_NO_LIMIT 1>; - }; - - map3 { - trip = <&cpu_hot>; - cooling-device = <&fan 2 THERMAL_NO_LIMIT>; - }; - }; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&gpu_thermal { - trips { - gpu_warm: gpu_warm { - temperature = <55000>; - hysteresis = <2000>; - type = "active"; - }; - - gpu_hot: gpu_hot { - temperature = <65000>; - hysteresis = <2000>; - type = "active"; - }; - }; - - cooling-maps { - map1 { - trip = <&gpu_warm>; - cooling-device = <&fan THERMAL_NO_LIMIT 1>; - }; - - map2 { - trip = <&gpu_hot>; - cooling-device = <&fan 2 THERMAL_NO_LIMIT>; - }; - }; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PC6 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vsys_3v3>; - vcc2-supply = <&vsys_3v3>; - vcc3-supply = <&vsys_3v3>; - vcc4-supply = <&vsys_3v3>; - vcc6-supply = <&vsys_3v3>; - vcc7-supply = <&vsys_3v3>; - vcc8-supply = <&vsys_3v3>; - vcc9-supply = <&vsys_3v3>; - vcc10-supply = <&vsys_3v3>; - vcc11-supply = <&vsys_3v3>; - vcc12-supply = <&vsys_3v3>; - vddio-supply = <&vcc_1v8>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_apio2: LDO_REG1 { - regulator-name = "vcc1v8_apio2"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_vldo2: LDO_REG2 { - regulator-name = "vcc_vldo2"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmupll: LDO_REG3 { - regulator-name = "vcc1v8_pmupll"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vccio_sd: LDO_REG4 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc_vldo5: LDO_REG5 { - regulator-name = "vcc_vldo5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcc1v8_codec: LDO_REG7 { - regulator-name = "vcc1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: vcc_lan: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&cpu_b_sleep>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vsys_3v3>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&gpu_sleep>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vsys_3v3>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c8 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <160>; - i2c-scl-falling-time-ns = <30>; - status = "okay"; -}; - -&i2s0 { - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; - status = "okay"; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - bt656-supply = <&vcc1v8_apio2>; - audio-supply = <&vcc1v8_codec>; - sdmmc-supply = <&vccio_sd>; - gpio1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_1v8>; - status = "okay"; -}; - -&pinctrl { - bt { - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_reg_on_h: bt-reg-on-h { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - ir { - ir_rx: ir-rx { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - sys_led_pin: sys-led-pin { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led_pin: user-led-pin { - rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - cpu_b_sleep: cpu-b-sleep { - rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - gpu_sleep: gpu-sleep { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdio0 { - /* WiFi & BT combo module Ampak AP6356S */ - bus-width = <4>; - cap-sdio-irq; - cap-sd-highspeed; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - vqmmc-supply = <&vcc1v8_s3>; - vmmc-supply = <&vccio_sd>; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - brcmf: wifi@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - brcm,drive-strength = <5>; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - non-removable; - status = "okay"; -}; - -&spi1 { - status = "okay"; - - spiflash: flash@0 { - compatible = "winbond,w25q128fw", "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <104000000>; - }; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_rts &uart0_cts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - max-speed = <4000000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_reg_on_h &bt_host_wake_l &bt_wake_l>; - vbat-supply = <&vsys_3v3>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "otg"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-leez-p710.dts b/arch/arm/dts/rk3399-leez-p710.dts deleted file mode 100644 index cb69e2145fa9..000000000000 --- a/arch/arm/dts/rk3399-leez-p710.dts +++ /dev/null @@ -1,653 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Andy Yan andy.yan@gmail.com - */ - -/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Leez RK3399 P710"; - compatible = "leez,p710", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_reg_on_h>; - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - dc5v_adp: dc5v-adp { - compatible = "regulator-fixed"; - regulator-name = "dc5v_adapter"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc3v3_lan: vcc3v3-lan { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_lan"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_host0: vcc5v0_host1: vcc5v0-host { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_host"; - regulator-boot-on; - regulator-always-on; - regulator-min-microvolt = <5500000>; - regulator-max-microvolt = <5500000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_host3: vcc5v0-host3 { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_host3"; - enable-active-high; - gpio = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host3_en>; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc5v_adp>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vcc5v0_sys>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc3v3_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c7>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc5v0_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_hdmi: LDO_REG2 { - regulator-name = "vcc1v8_hdmi"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca_1v8: LDO_REG3 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vccio_sd: LDO_REG4 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcc0v9_hdmi: LDO_REG7 { - regulator-name = "vcc0v9_hdmi"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_pin>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_pin>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - i2c-scl-rising-time-ns = <300>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; -}; - -&i2c7 { - status = "okay"; -}; - -&i2s0 { - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; - status = "okay"; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - bt656-supply = <&vcc1v8_dvp>; - audio-supply = <&vcc_1v8>; - sdmmc-supply = <&vccio_sd>; - gpio1830-supply = <&vcc_3v0>; -}; - -&pmu_io_domains { - status = "okay"; - pmu1830-supply = <&vcc_3v0>; -}; - -&pinctrl { - bt { - bt_reg_on_h: bt-reg-on-h { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - usb2 { - vcc5v0_host3_en: vcc5v0-host3-en { - rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_reg_on_h: wifi-reg-on-h { - rockchip,pins = - <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - status = "okay"; - - vref-supply = <&vcc_1v8>; -}; - -&sdio0 { - #address-cells = <1>; - #size-cells = <0>; - bus-width = <4>; - clock-frequency = <50000000>; - cap-sdio-irq; - cap-sd-highspeed; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - status = "okay"; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cd &sdmmc_cmd &sdmmc_bus4>; - status = "okay"; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - status = "okay"; - - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host0>; - status = "okay"; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host1>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_reg_on_h>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "otg"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-nanopc-t4.dts b/arch/arm/dts/rk3399-nanopc-t4.dts deleted file mode 100644 index 3bf8f959e42c..000000000000 --- a/arch/arm/dts/rk3399-nanopc-t4.dts +++ /dev/null @@ -1,137 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * FriendlyElec NanoPC-T4 board device tree source - * - * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyarm.com) - * - * Copyright (c) 2018 Collabora Ltd. - */ - -/dts-v1/; -#include "rk3399-nanopi4.dtsi" - -/ { - model = "FriendlyElec NanoPC-T4"; - compatible = "friendlyarm,nanopc-t4", "rockchip,rk3399"; - - vcc12v0_sys: vcc12v0-sys { - compatible = "regulator-fixed"; - regulator-always-on; - regulator-boot-on; - regulator-max-microvolt = <12000000>; - regulator-min-microvolt = <12000000>; - regulator-name = "vcc12v0_sys"; - }; - - vcc5v0_host0: vcc5v0-host0 { - compatible = "regulator-fixed"; - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc5v0_host0"; - vin-supply = <&vcc5v0_sys>; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - poll-interval = <100>; - - button-recovery { - label = "Recovery"; - linux,code = <KEY_VENDOR>; - press-threshold-microvolt = <18000>; - }; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_rx>; - }; - - fan: pwm-fan { - compatible = "pwm-fan"; - /* - * With 20KHz PWM and an EVERCOOL EC4007H12SA fan, these levels - * work out to 0, ~1200, ~3000, and 5000RPM respectively. - */ - cooling-levels = <0 12 18 255>; - #cooling-cells = <2>; - fan-supply = <&vcc12v0_sys>; - pwms = <&pwm1 0 50000 0>; - }; -}; - -&cpu_thermal { - trips { - cpu_warm: cpu_warm { - temperature = <55000>; - hysteresis = <2000>; - type = "active"; - }; - - cpu_hot: cpu_hot { - temperature = <65000>; - hysteresis = <2000>; - type = "active"; - }; - }; - - cooling-maps { - map2 { - trip = <&cpu_warm>; - cooling-device = <&fan THERMAL_NO_LIMIT 1>; - }; - - map3 { - trip = <&cpu_hot>; - cooling-device = <&fan 2 THERMAL_NO_LIMIT>; - }; - }; -}; - -&pcie0 { - ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - vpcie3v3-supply = <&vcc3v3_sys>; -}; - -&pinctrl { - ir { - ir_rx: ir-rx { - /* external pullup to VCC3V3_SYS, despite being 1.8V :/ */ - rockchip,pins = <0 RK_PA6 1 &pcfg_pull_none>; - }; - }; -}; - -&sdhci { - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; -}; - -&u2phy0_host { - phy-supply = <&vcc5v0_host0>; -}; - -&u2phy1_host { - phy-supply = <&vcc5v0_host0>; -}; - -&vcc5v0_sys { - vin-supply = <&vcc12v0_sys>; -}; - -&vcc3v3_sys { - vin-supply = <&vcc12v0_sys>; -}; - -&vbus_typec { - enable-active-high; - gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; - vin-supply = <&vcc5v0_sys>; -}; diff --git a/arch/arm/dts/rk3399-nanopi-m4.dts b/arch/arm/dts/rk3399-nanopi-m4.dts deleted file mode 100644 index 60358ab8c7df..000000000000 --- a/arch/arm/dts/rk3399-nanopi-m4.dts +++ /dev/null @@ -1,66 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * FriendlyElec NanoPi M4 board device tree source - * - * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyarm.com) - * - * Copyright (c) 2018 Collabora Ltd. - * Copyright (c) 2019 Arm Ltd. - */ - -/dts-v1/; -#include "rk3399-nanopi4.dtsi" - -/ { - model = "FriendlyElec NanoPi M4"; - compatible = "friendlyarm,nanopi-m4", "rockchip,rk3399"; - - vdd_5v: vdd-5v { - compatible = "regulator-fixed"; - regulator-name = "vdd_5v"; - regulator-always-on; - regulator-boot-on; - }; - - vcc5v0_core: vcc5v0-core { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_core"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vdd_5v>; - }; - - vcc5v0_usb1: vcc5v0-usb1 { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb1"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_usb2: vcc5v0-usb2 { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb2"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&vcc3v3_sys { - vin-supply = <&vcc5v0_core>; -}; - -&u2phy0_host { - phy-supply = <&vcc5v0_usb1>; -}; - -&u2phy1_host { - phy-supply = <&vcc5v0_usb2>; -}; - -&vbus_typec { - regulator-always-on; - vin-supply = <&vdd_5v>; -}; diff --git a/arch/arm/dts/rk3399-nanopi-m4b.dts b/arch/arm/dts/rk3399-nanopi-m4b.dts deleted file mode 100644 index 65cb21837b0c..000000000000 --- a/arch/arm/dts/rk3399-nanopi-m4b.dts +++ /dev/null @@ -1,52 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * FriendlyElec NanoPi M4B board device tree source - * - * Copyright (c) 2020 Chen-Yu Tsai wens@csie.org - */ - -/dts-v1/; -#include "rk3399-nanopi-m4.dts" - -/ { - model = "FriendlyElec NanoPi M4B"; - compatible = "friendlyarm,nanopi-m4b", "rockchip,rk3399"; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1500000>; - poll-interval = <100>; - - button-recovery { - label = "Recovery"; - linux,code = <KEY_VENDOR>; - press-threshold-microvolt = <18000>; - }; - }; -}; - -/* No USB type-C PD power manager */ -/delete-node/ &fusb0; - -&i2c4 { - status = "disabled"; -}; - -&u2phy0_host { - phy-supply = <&vcc5v0_usb2>; -}; - -&u2phy0_otg { - phy-supply = <&vbus_typec>; -}; - -&u2phy1_otg { - phy-supply = <&vcc5v0_usb1>; -}; - -&vbus_typec { - enable-active-high; - gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; -}; diff --git a/arch/arm/dts/rk3399-nanopi-neo4.dts b/arch/arm/dts/rk3399-nanopi-neo4.dts deleted file mode 100644 index 195410b089b9..000000000000 --- a/arch/arm/dts/rk3399-nanopi-neo4.dts +++ /dev/null @@ -1,50 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (C) 2019 Amarula Solutions B.V. - * Author: Jagan Teki jagan@amarulasolutions.com - */ - -/dts-v1/; - -#include "rk3399-nanopi4.dtsi" - -/ { - model = "FriendlyARM NanoPi NEO4"; - compatible = "friendlyarm,nanopi-neo4", "rockchip,rk3399"; - - vdd_5v: vdd-5v { - compatible = "regulator-fixed"; - regulator-name = "vdd_5v"; - regulator-always-on; - regulator-boot-on; - }; - - vcc5v0_core: vcc5v0-core { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_core"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vdd_5v>; - }; - - vcc5v0_usb1: vcc5v0-usb1 { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb1"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&vcc3v3_sys { - vin-supply = <&vcc5v0_core>; -}; - -&u2phy0_host { - phy-supply = <&vcc5v0_usb1>; -}; - -&vbus_typec { - regulator-always-on; - vin-supply = <&vdd_5v>; -}; diff --git a/arch/arm/dts/rk3399-nanopi-r4s.dts b/arch/arm/dts/rk3399-nanopi-r4s.dts deleted file mode 100644 index fe5b52610010..000000000000 --- a/arch/arm/dts/rk3399-nanopi-r4s.dts +++ /dev/null @@ -1,133 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * FriendlyElec NanoPC-T4 board device tree source - * - * Copyright (c) 2020 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyarm.com) - * - * Copyright (c) 2018 Collabora Ltd. - * - * Copyright (c) 2020 Jensen Huang jensenhuang@friendlyarm.com - * Copyright (c) 2020 Marty Jones mj8263788@gmail.com - * Copyright (c) 2021 Tianling Shen cnsztl@gmail.com - */ - -/dts-v1/; -#include "rk3399-nanopi4.dtsi" - -/ { - model = "FriendlyElec NanoPi R4S"; - compatible = "friendlyarm,nanopi-r4s", "rockchip,rk3399"; - - /delete-node/ display-subsystem; - - gpio-leds { - pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>; - - /delete-node/ led-0; - - lan_led: led-lan { - gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>; - label = "green:lan"; - }; - - sys_led: led-sys { - gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; - label = "red:power"; - default-state = "on"; - }; - - wan_led: led-wan { - gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; - label = "green:wan"; - }; - }; - - gpio-keys { - pinctrl-0 = <&reset_button_pin>; - - /delete-node/ key-power; - - key-reset { - debounce-interval = <50>; - gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_LOW>; - label = "reset"; - linux,code = <KEY_RESTART>; - }; - }; - - vdd_5v: vdd-5v { - compatible = "regulator-fixed"; - regulator-name = "vdd_5v"; - regulator-always-on; - regulator-boot-on; - }; -}; - -&emmc_phy { - status = "disabled"; -}; - -&i2c4 { - status = "disabled"; -}; - -&pcie0 { - max-link-speed = <1>; - num-lanes = <1>; - vpcie3v3-supply = <&vcc3v3_sys>; -}; - -&pinctrl { - gpio-leds { - /delete-node/ status-led-pin; - - lan_led_pin: lan-led-pin { - rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - sys_led_pin: sys-led-pin { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wan_led_pin: wan-led-pin { - rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - rockchip-key { - /delete-node/ power-key; - - reset_button_pin: reset-button-pin { - rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&sdhci { - status = "disabled"; -}; - -&sdio0 { - status = "disabled"; -}; - -&u2phy0_host { - phy-supply = <&vdd_5v>; -}; - -&u2phy1_host { - status = "disabled"; -}; - -&uart0 { - status = "disabled"; -}; - -&usbdrd_dwc3_0 { - dr_mode = "host"; -}; - -&vcc3v3_sys { - vin-supply = <&vcc5v0_sys>; -}; diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi deleted file mode 100644 index b7f1e47978a6..000000000000 --- a/arch/arm/dts/rk3399-nanopi4.dtsi +++ /dev/null @@ -1,762 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * RK3399-based FriendlyElec boards device tree source - * - * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd - * - * Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyarm.com) - * - * Copyright (c) 2018 Collabora Ltd. - * Copyright (c) 2019 Arm Ltd. - */ - -/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - aliases { - ethernet0 = &gmac; - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc3v3_sys"; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-name = "vcc5v0_sys"; - vin-supply = <&vdd_5v>; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc1v8_s3"; - vin-supply = <&vcc_1v8>; - }; - - vcc3v0_sd: vcc3v0-sd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_pwr_h>; - regulator-always-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc3v0_sd"; - vin-supply = <&vcc3v3_sys>; - }; - - /* - * Really, this is supplied by vcc_1v8, and vcc1v8_s3 only - * drives the enable pin, but we can't quite model that. - */ - vcca0v9_s3: vcca0v9-s3 { - compatible = "regulator-fixed"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vcca0v9_s3"; - vin-supply = <&vcc1v8_s3>; - }; - - /* As above, actually supplied by vcc3v3_sys */ - vcca1v8_s3: vcca1v8-s3 { - compatible = "regulator-fixed"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca1v8_s3"; - vin-supply = <&vcc1v8_s3>; - }; - - vbus_typec: vbus-typec { - compatible = "regulator-fixed"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-name = "vbus_typec"; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&power_key>; - - key-power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - leds: gpio-leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&status_led_pin>; - - status_led: led-0 { - gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; - label = "status_led"; - linux,default-trigger = "heartbeat"; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_reg_on_h>; - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&emmc_phy { - rockchip,enable-strobe-pulldown; - status = "okay"; -}; - -&gmac { - assigned-clock-parents = <&clkin_gmac>; - assigned-clocks = <&cru SCLK_RMII_SRC>; - clock_in_out = "input"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>, <&phy_intb>, <&phy_rstb>; - phy-handle = <&rtl8211e>; - phy-mode = "rgmii"; - phy-supply = <&vcc3v3_s3>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - rtl8211e: ethernet-phy@1 { - reg = <1>; - interrupt-parent = <&gpio3>; - interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <30000>; - reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c7>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <160>; - i2c-scl-falling-time-ns = <30>; - status = "okay"; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&cpu_b_sleep>; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-name = "vdd_cpu_b"; - regulator-ramp-delay = <1000>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&gpu_sleep>; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-name = "vdd_gpu"; - regulator-ramp-delay = <1000>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - clock-output-names = "xin32k", "rtc_clko_wifi"; - #clock-cells = <1>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>, <&ap_pwroff>, <&clk_32k>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - vcc10-supply = <&vcc3v3_sys>; - vcc11-supply = <&vcc3v3_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_3v0>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_center"; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-name = "vdd_cpu_l"; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_ddr"; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_1v8"; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_cam: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc1v8_cam"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v0_touch: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc3v0_touch"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmupll: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc1v8_pmupll"; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_sdio"; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcca3v0_codec"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-name = "vcc_1v5"; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca1v8_codec"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc_3v0"; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc3v3_s3"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc3v3_s0"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&i2c1 { - clock-frequency = <200000>; - i2c-scl-rising-time-ns = <150>; - i2c-scl-falling-time-ns = <30>; - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c4 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <160>; - i2c-scl-falling-time-ns = <30>; - status = "okay"; - - fusb0: typec-portc@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int>; - vbus-supply = <&vbus_typec>; - }; -}; - -&i2c7 { - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - bt656-supply = <&vcc_1v8>; - audio-supply = <&vcca1v8_codec>; - sdmmc-supply = <&vcc_sdio>; - gpio1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pcie_phy { - assigned-clock-parents = <&cru SCLK_PCIEPHY_REF100M>; - assigned-clock-rates = <100000000>; - assigned-clocks = <&cru SCLK_PCIEPHY_REF>; - status = "okay"; -}; - -&pcie0 { - num-lanes = <2>; - vpcie0v9-supply = <&vcca0v9_s3>; - vpcie1v8-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&pinctrl { - fusb30x { - fusb0_int: fusb0-int { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - gpio-leds { - status_led_pin: status-led-pin { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - gmac { - phy_intb: phy-intb { - rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_rstb: phy-rstb { - rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - cpu_b_sleep: cpu-b-sleep { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - gpu_sleep: gpu-sleep { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - rockchip-key { - power_key: power-key { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdio { - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_reg_on_h: bt-reg-on-h { - /* external pullup to VCC1V8_PMUPLL */ - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wifi_reg_on_h: wifi-reg_on-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc0_det_l: sdmmc0-det-l { - rockchip,pins = <0 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - sdmmc0_pwr_h: sdmmc0-pwr-h { - rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm1 { - status = "okay"; -}; - -&pwm2 { - pinctrl-names = "active"; - pinctrl-0 = <&pwm2_pin_pull_down>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&sdio0 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - cap-mmc-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_bus4 &sdmmc_clk &sdmmc_cmd &sdmmc0_det_l>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v0_sd>; - vqmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; -}; - -&u2phy0_host { - status = "okay"; -}; - -&u2phy0_otg { - status = "okay"; -}; - -&u2phy1 { - status = "okay"; -}; - -&u2phy1_host { - status = "okay"; -}; - -&u2phy1_otg { - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_rts &uart0_cts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - max-speed = <4000000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_reg_on_h &bt_host_wake_l &bt_wake_l>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - dr_mode = "host"; - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-op1-opp.dtsi b/arch/arm/dts/rk3399-op1-opp.dtsi deleted file mode 100644 index 783120e9cebe..000000000000 --- a/arch/arm/dts/rk3399-op1-opp.dtsi +++ /dev/null @@ -1,166 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd - */ - -/ { - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp00 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <800000>; - clock-latency-ns = <40000>; - }; - opp01 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <825000>; - }; - opp02 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <850000>; - }; - opp03 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <900000>; - }; - opp04 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <975000>; - }; - opp05 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1100000>; - }; - opp06 { - opp-hz = /bits/ 64 <1512000000>; - opp-microvolt = <1150000>; - }; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp00 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <800000>; - clock-latency-ns = <40000>; - }; - opp01 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <800000>; - }; - opp02 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <825000>; - }; - opp03 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <850000>; - }; - opp04 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <900000>; - }; - opp05 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <975000>; - }; - opp06 { - opp-hz = /bits/ 64 <1608000000>; - opp-microvolt = <1050000>; - }; - opp07 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <1150000>; - }; - opp08 { - opp-hz = /bits/ 64 <2016000000>; - opp-microvolt = <1250000>; - }; - }; - - gpu_opp_table: opp-table-2 { - compatible = "operating-points-v2"; - - opp00 { - opp-hz = /bits/ 64 <200000000>; - opp-microvolt = <800000>; - }; - opp01 { - opp-hz = /bits/ 64 <297000000>; - opp-microvolt = <800000>; - }; - opp02 { - opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <825000>; - }; - opp03 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <850000>; - }; - opp04 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <925000>; - }; - opp05 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <1075000>; - }; - }; - - dmc_opp_table: opp-table-3 { - compatible = "operating-points-v2"; - - opp00 { - opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <900000>; - }; - opp01 { - opp-hz = /bits/ 64 <666000000>; - opp-microvolt = <900000>; - }; - opp02 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <900000>; - }; - opp03 { - opp-hz = /bits/ 64 <928000000>; - opp-microvolt = <925000>; - }; - }; -}; - -&cpu_l0 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l1 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l2 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l3 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_b0 { - operating-points-v2 = <&cluster1_opp>; -}; - -&cpu_b1 { - operating-points-v2 = <&cluster1_opp>; -}; - -&dmc { - operating-points-v2 = <&dmc_opp_table>; -}; - -&gpu { - operating-points-v2 = <&gpu_opp_table>; -}; diff --git a/arch/arm/dts/rk3399-opp.dtsi b/arch/arm/dts/rk3399-opp.dtsi deleted file mode 100644 index fee5e7111279..000000000000 --- a/arch/arm/dts/rk3399-opp.dtsi +++ /dev/null @@ -1,133 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd - */ - -/ { - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp00 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <825000 825000 1250000>; - clock-latency-ns = <40000>; - }; - opp01 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <825000 825000 1250000>; - }; - opp02 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <850000 850000 1250000>; - }; - opp03 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <925000 925000 1250000>; - }; - opp04 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <1000000 1000000 1250000>; - }; - opp05 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1125000 1125000 1250000>; - }; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp00 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <825000 825000 1250000>; - clock-latency-ns = <40000>; - }; - opp01 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <825000 825000 1250000>; - }; - opp02 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <825000 825000 1250000>; - }; - opp03 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <875000 875000 1250000>; - }; - opp04 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <950000 950000 1250000>; - }; - opp05 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1025000 1025000 1250000>; - }; - opp06 { - opp-hz = /bits/ 64 <1608000000>; - opp-microvolt = <1100000 1100000 1250000>; - }; - opp07 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <1200000 1200000 1250000>; - }; - }; - - gpu_opp_table: opp-table-2 { - compatible = "operating-points-v2"; - - opp00 { - opp-hz = /bits/ 64 <200000000>; - opp-microvolt = <825000 825000 1150000>; - }; - opp01 { - opp-hz = /bits/ 64 <297000000>; - opp-microvolt = <825000 825000 1150000>; - }; - opp02 { - opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <825000 825000 1150000>; - }; - opp03 { - opp-hz = /bits/ 64 <500000000>; - opp-microvolt = <875000 875000 1150000>; - }; - opp04 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <925000 925000 1150000>; - }; - opp05 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <1100000 1100000 1150000>; - }; - }; -}; - -&cpu_l0 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l1 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l2 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l3 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_b0 { - operating-points-v2 = <&cluster1_opp>; -}; - -&cpu_b1 { - operating-points-v2 = <&cluster1_opp>; -}; - -&gpu { - operating-points-v2 = <&gpu_opp_table>; -}; diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts deleted file mode 100644 index e7551449e718..000000000000 --- a/arch/arm/dts/rk3399-orangepi.dts +++ /dev/null @@ -1,896 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - */ - -/dts-v1/; - -#include "dt-bindings/pwm/pwm.h" -#include "dt-bindings/input/input.h" -#include <dt-bindings/interrupt-controller/irq.h> -#include "dt-bindings/usb/pd.h" -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Orange Pi RK3399 Board"; - compatible = "rockchip,rk3399-orangepi", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - poll-interval = <100>; - - button-up { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - press-threshold-microvolt = <100000>; - }; - - button-down { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - press-threshold-microvolt = <300000>; - }; - - button-back { - label = "Back"; - linux,code = <KEY_BACK>; - press-threshold-microvolt = <985000>; - }; - - button-menu { - label = "Menu"; - linux,code = <KEY_MENU>; - press-threshold-microvolt = <1314000>; - }; - }; - - dc_12v: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - keys: gpio-keys { - compatible = "gpio-keys"; - autorepeat; - - key-power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Power"; - linux,code = <KEY_POWER>; - linux,input-type = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_btn>; - wakeup-source; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_reg_on_h>; - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8>; - }; - - vcc3v0_sd: vcc3v0-sd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_pwr_h>; - regulator-boot-on; - regulator-max-microvolt = <3000000>; - regulator-min-microvolt = <3000000>; - regulator-name = "vcc3v0_sd"; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_sys>; - }; - - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vbus_typec: vbus-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec_en>; - regulator-name = "vbus_typec"; - vin-supply = <&vcc_sys>; - }; - - vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vcc_sys>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc3v3_s3>; - phy-mode = "rgmii"; - phy-handle = <&rtl8211e>; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>, <&phy_intb>, <&phy_rstb>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; - - mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <1>; - #size-cells = <0>; - - rtl8211e: ethernet-phy@1 { - reg = <1>; - interrupt-parent = <&gpio3>; - interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>; - reset-assert-us = <10000>; - reset-deassert-us = <30000>; - reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - }; - }; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "rtc_clko_soc", "rtc_clko_wifi"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - vcc10-supply = <&vcc3v3_sys>; - vcc11-supply = <&vcc3v3_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_3v0>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <700000>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3400000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v0_tp: LDO_REG2 { - regulator-name = "vcc3v0_tp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3400000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmupll: LDO_REG3 { - regulator-name = "vcc1v8_pmupll"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <2500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3400000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3400000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <2500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-name = "vcca1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <2500000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3400000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&cpu_b_sleep>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&gpu_sleep>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; - - ak09911@c { - compatible = "asahi-kasei,ak09911"; - reg = <0x0c>; - vdd-supply = <&vcc3v3_s3>; - vid-supply = <&vcc3v3_s3>; - }; - - mpu6500@68 { - compatible = "invensense,mpu6500"; - reg = <0x68>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PC6 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&gsensor_int_l>; - vddio-supply = <&vcc3v3_s3>; - }; - - lsm6ds3@6a { - compatible = "st,lsm6ds3"; - reg = <0x6a>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PD0 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&gyr_int_l>; - vdd-supply = <&vcc3v3_s3>; - vddio-supply = <&vcc3v3_s3>; - }; - - cm32181@10 { - compatible = "capella,cm32181"; - reg = <0x10>; - interrupt-parent = <&gpio4>; - interrupts = <RK_PD0 IRQ_TYPE_EDGE_RISING>; - pinctrl-names = "default"; - pinctrl-0 = <&light_int_l>; - vdd-supply = <&vcc3v3_s3>; - }; - - fusb302@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&chg_cc_int_l>; - vbus-supply = <&vbus_typec>; - - typec_con: connector { - compatible = "usb-c-connector"; - data-role = "host"; - label = "USB-C"; - op-sink-microwatt = <1000000>; - power-role = "dual"; - sink-pdos = - <PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>; - source-pdos = - <PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>; - try-power-role = "sink"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - typec_hs: endpoint { - remote-endpoint = <&u2phy0_typec_hs>; - }; - }; - port@1 { - reg = <1>; - typec_ss: endpoint { - remote-endpoint = <&tcphy0_typec_ss>; - }; - }; - port@2 { - reg = <2>; - typec_dp: endpoint { - remote-endpoint = <&tcphy0_typec_dp>; - }; - }; - }; - }; - }; -}; - -&io_domains { - status = "okay"; - bt656-supply = <&vcc_3v0>; - audio-supply = <&vcca1v8_codec>; - sdmmc-supply = <&vcc_sdio>; - gpio1830-supply = <&vcc_3v0>; -}; - -&pmu_io_domains { - status = "okay"; - pmu1830-supply = <&vcc_3v0>; -}; - -&pinctrl { - buttons { - pwr_btn: pwr-btn { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - gmac { - phy_intb: phy-intb { - rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - phy_rstb: phy-rstb { - rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - cpu_b_sleep: cpu-b-sleep { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - gpu_sleep: gpu-sleep { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - pmic_int_l: pmic-int-l { - rockchip,pins = - <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sd { - sdmmc0_pwr_h: sdmmc0-pwr-h { - rockchip,pins = - <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = - <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_typec_en: vcc5v0-typec-en { - rockchip,pins = - <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdio-pwrseq { - wifi_reg_on_h: wifi-reg-on-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - bluetooth { - bt_reg_on_h: bt-enable-h { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - mpu6500 { - gsensor_int_l: gsensor-int-l { - rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lsm6ds3 { - gyr_int_l: gyr-int-l { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - cm32181 { - light_int_l: light-int-l { - rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - fusb302 { - chg_cc_int_l: chg-cc-int-l { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&sdio0 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - clock-frequency = <50000000>; - disable-wp; - keep-power-in-suspend; - max-frequency = <50000000>; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - brcmf: wifi@1 { - reg = <1>; - compatible = "brcm,bcm4329-fmac"; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - clock-frequency = <150000000>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vcc3v0_sd>; - vqmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy0_dp { - port { - tcphy0_typec_dp: endpoint { - remote-endpoint = <&typec_dp>; - }; - }; -}; - -&tcphy0_usb3 { - port { - tcphy0_typec_ss: endpoint { - remote-endpoint = <&typec_ss>; - }; - }; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - phy-supply = <&vbus_typec>; - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; - - port { - u2phy0_typec_hs: endpoint { - remote-endpoint = <&typec_hs>; - }; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_reg_on_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "host"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-pinebook-pro.dts b/arch/arm/dts/rk3399-pinebook-pro.dts deleted file mode 100644 index 054c6a4d1a45..000000000000 --- a/arch/arm/dts/rk3399-pinebook-pro.dts +++ /dev/null @@ -1,1111 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - * Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com - * Copyright (c) 2020 Tobias Schramm t.schramm@manjaro.org - */ - -/dts-v1/; -#include <dt-bindings/input/gpio-keys.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/usb/pd.h> -#include <dt-bindings/leds/common.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Pine64 Pinebook Pro"; - compatible = "pine64,pinebook-pro", "rockchip,rk3399"; - chassis-type = "laptop"; - - aliases { - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - backlight: edp-backlight { - compatible = "pwm-backlight"; - power-supply = <&vcc_12v>; - pwms = <&pwm0 0 740740 0>; - }; - - bat: battery { - compatible = "simple-battery"; - charge-full-design-microamp-hours = <9800000>; - voltage-max-design-microvolt = <4350000>; - voltage-min-design-microvolt = <3000000>; - }; - - edp_panel: edp-panel { - compatible = "boe,nv140fhmn49"; - backlight = <&backlight>; - enable-gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&panel_en_pin>; - power-supply = <&vcc3v3_panel>; - - port { - panel_in_edp: endpoint { - remote-endpoint = <&edp_out_panel>; - }; - }; - }; - - /* - * Use separate nodes for gpio-keys to allow for selective deactivation - * of wakeup sources via sysfs without disabling the whole key - */ - gpio-key-lid { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&lidbtn_pin>; - - switch-lid { - debounce-interval = <20>; - gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_LOW>; - label = "Lid"; - linux,code = <SW_LID>; - linux,input-type = <EV_SW>; - wakeup-event-action = <EV_ACT_DEASSERTED>; - wakeup-source; - }; - }; - - gpio-key-power { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn_pin>; - - key-power { - debounce-interval = <20>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_led_pin &slp_led_pin>; - - green_led: led-0 { - color = <LED_COLOR_ID_GREEN>; - default-state = "on"; - function = LED_FUNCTION_POWER; - gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; - label = "green:power"; - }; - - red_led: led-1 { - color = <LED_COLOR_ID_RED>; - default-state = "off"; - function = LED_FUNCTION_STANDBY; - gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; - label = "red:standby"; - panic-indicator; - retain-state-suspended; - }; - }; - - /* Power sequence for SDIO WiFi module */ - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h_pin>; - post-power-on-delay-ms = <100>; - power-off-delay-us = <500000>; - - /* WL_REG_ON on module */ - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - /* Audio components */ - es8316-sound { - compatible = "simple-audio-card"; - pinctrl-names = "default"; - pinctrl-0 = <&hp_det_pin>; - simple-audio-card,name = "rockchip,es8316-codec"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - - simple-audio-card,widgets = - "Microphone", "Mic Jack", - "Headphone", "Headphones", - "Speaker", "Speaker"; - simple-audio-card,routing = - "MIC1", "Mic Jack", - "Headphones", "HPOL", - "Headphones", "HPOR", - "Speaker Amplifier INL", "HPOL", - "Speaker Amplifier INR", "HPOR", - "Speaker", "Speaker Amplifier OUTL", - "Speaker", "Speaker Amplifier OUTR"; - - simple-audio-card,hp-det-gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; - simple-audio-card,aux-devs = <&speaker_amp>; - simple-audio-card,pin-switches = "Speaker"; - - simple-audio-card,cpu { - sound-dai = <&i2s1>; - }; - - simple-audio-card,codec { - sound-dai = <&es8316>; - }; - }; - - speaker_amp: speaker-amplifier { - compatible = "simple-audio-amplifier"; - enable-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; - sound-name-prefix = "Speaker Amplifier"; - VCC-supply = <&pa_5v>; - }; - - /* Power tree */ - /* Root power source */ - vcc_sysin: vcc-sysin { - compatible = "regulator-fixed"; - regulator-name = "vcc_sysin"; - regulator-always-on; - regulator-boot-on; - }; - - /* Regulators supplied by vcc_sysin */ - /* LCD backlight supply */ - vcc_12v: vcc-12v { - compatible = "regulator-fixed"; - regulator-name = "vcc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - vin-supply = <&vcc_sysin>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - /* Main 3.3 V supply */ - vcc3v3_sys: wifi_bat: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_sysin>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - /* 5 V USB power supply */ - vcc5v0_usb: pa_5v: vcc5v0-usb-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_5v_pin>; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc_sysin>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - /* RK3399 logic supply */ - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vcc_sysin>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - /* Regulators supplied by vcc3v3_sys */ - /* 0.9 V supply, always on */ - vcc_0v9: vcc-0v9 { - compatible = "regulator-fixed"; - regulator-name = "vcc_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; - - /* S3 1.8 V supply, switched by vcc1v8_s3 */ - vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcca1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - }; - - /* micro SD card power */ - vcc3v0_sd: vcc3v0-sd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_pwr_h_pin>; - regulator-name = "vcc3v0_sd"; - regulator-always-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - /* LCD panel power, called VCC3V3_S0 in schematic */ - vcc3v3_panel: vcc3v3-panel { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&lcdvcc_en_pin>; - regulator-name = "vcc3v3_panel"; - regulator-always-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-enable-ramp-delay = <100000>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - /* M.2 adapter power, switched by vcc1v8_s3 */ - vcc3v3_ssd: vcc3v3-ssd { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_ssd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - /* Regulators supplied by vcc5v0_usb */ - /* USB 3 port power supply regulator */ - vcc5v0_otg: vcc5v0-otg { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en_pin>; - regulator-name = "vcc5v0_otg"; - regulator-always-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - /* Regulators supplied by vcc5v0_usb */ - /* Type C port power supply regulator */ - vbus_5vout: vbus_typec: vbus-5vout { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec0_en_pin>; - regulator-name = "vbus_5vout"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - /* Regulators supplied by vcc_1v8 */ - /* Primary 0.9 V LDO */ - vcca0v9_s3: vcca0v9-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc0v9_s3"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc_1v8>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - mains_charger: dc-charger { - compatible = "gpio-charger"; - charger-type = "mains"; - gpios = <&gpio4 RK_PD0 GPIO_ACTIVE_LOW>; - - /* Also triggered by USB charger */ - pinctrl-names = "default"; - pinctrl-0 = <&dc_det_pin>; - }; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&edp { - force-hpd; - pinctrl-names = "default"; - pinctrl-0 = <&edp_hpd>; - status = "okay"; - - ports { - edp_out: port@1 { - reg = <1>; - #address-cells = <1>; - #size-cells = <0>; - - edp_out_panel: endpoint@0 { - reg = <0>; - remote-endpoint = <&panel_in_edp>; - }; - }; - }; -}; - -&emmc_phy { - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <4>; - i2c-scl-rising-time-ns = <168>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - interrupt-parent = <&gpio3>; - interrupts = <10 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l_pin>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sysin>; - vcc2-supply = <&vcc_sysin>; - vcc3-supply = <&vcc_sysin>; - vcc4-supply = <&vcc_sysin>; - vcc6-supply = <&vcc_sysin>; - vcc7-supply = <&vcc_sysin>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc_sysin>; - vcc10-supply = <&vcc_sysin>; - vcc11-supply = <&vcc_sysin>; - vcc12-supply = <&vcc3v3_sys>; - - regulators { - /* rk3399 center logic supply */ - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: vcc_wl: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - /* not used */ - LDO_REG1 { - }; - - /* not used */ - LDO_REG2 { - }; - - vcc1v8_pmupll: LDO_REG3 { - regulator-name = "vcc1v8_pmupll"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-name = "vcca1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_pin>; - regulator-name = "vdd_cpu_b"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - vin-supply = <&vcc_1v8>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_pin>; - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - vin-supply = <&vcc_1v8>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - clock-frequency = <100000>; - i2c-scl-falling-time-ns = <4>; - i2c-scl-rising-time-ns = <168>; - status = "okay"; - - es8316: audio-codec@11 { - compatible = "everest,es8316"; - reg = <0x11>; - clocks = <&cru SCLK_I2S_8CH_OUT>; - clock-names = "mclk"; - #sound-dai-cells = <0>; - }; -}; - -&i2c3 { - i2c-scl-falling-time-ns = <15>; - i2c-scl-rising-time-ns = <450>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-falling-time-ns = <20>; - i2c-scl-rising-time-ns = <600>; - status = "okay"; - - fusb0: fusb30x@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int_pin>; - vbus-supply = <&vbus_typec>; - - connector { - compatible = "usb-c-connector"; - data-role = "dual"; - label = "USB-C"; - op-sink-microwatt = <1000000>; - power-role = "dual"; - sink-pdos = - <PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>; - source-pdos = - <PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>; - try-power-role = "sink"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - - usbc_hs: endpoint { - remote-endpoint = - <&u2phy0_typec_hs>; - }; - }; - - port@1 { - reg = <1>; - - usbc_ss: endpoint { - remote-endpoint = - <&tcphy0_typec_ss>; - }; - }; - - port@2 { - reg = <2>; - - usbc_dp: endpoint { - remote-endpoint = - <&tcphy0_typec_dp>; - }; - }; - }; - }; - }; - - cw2015@62 { - compatible = "cellwise,cw2015"; - reg = <0x62>; - cellwise,battery-profile = /bits/ 8 < - 0x17 0x67 0x80 0x73 0x6E 0x6C 0x6B 0x63 - 0x77 0x51 0x5C 0x58 0x50 0x4C 0x48 0x36 - 0x15 0x0C 0x0C 0x19 0x5B 0x7D 0x6F 0x69 - 0x69 0x5B 0x0C 0x29 0x20 0x40 0x52 0x59 - 0x57 0x56 0x54 0x4F 0x3B 0x1F 0x7F 0x17 - 0x06 0x1A 0x30 0x5A 0x85 0x93 0x96 0x2D - 0x48 0x77 0x9C 0xB3 0x80 0x52 0x94 0xCB - 0x2F 0x00 0x64 0xA5 0xB5 0x11 0xF0 0x11 - >; - cellwise,monitor-interval-ms = <5000>; - monitored-battery = <&bat>; - power-supplies = <&mains_charger>, <&fusb0>; - }; -}; - -&i2s1 { - pinctrl-names = "default"; - pinctrl-0 = <&i2s_8ch_mclk_pin>, <&i2s1_2ch_bus>; - rockchip,capture-channels = <8>; - rockchip,playback-channels = <8>; - status = "okay"; -}; - -&io_domains { - audio-supply = <&vcc_3v0>; - gpio1830-supply = <&vcc_3v0>; - sdmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - bus-scan-delay-ms = <1000>; - ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn_cpm>; - vpcie0v9-supply = <&vcca0v9_s3>; - vpcie1v8-supply = <&vcca1v8_s3>; - vpcie3v3-supply = <&vcc3v3_ssd>; - status = "okay"; -}; - -&pinctrl { - buttons { - pwrbtn_pin: pwrbtn-pin { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - lidbtn_pin: lidbtn-pin { - rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - dc-charger { - dc_det_pin: dc-det-pin { - rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - es8316 { - hp_det_pin: hp-det-pin { - rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - fusb302x { - fusb0_int_pin: fusb0-int-pin { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - i2s1 { - i2s_8ch_mclk_pin: i2s-8ch-mclk-pin { - rockchip,pins = <4 RK_PA0 1 &pcfg_pull_none>; - }; - }; - - lcd-panel { - lcdvcc_en_pin: lcdvcc-en-pin { - rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - panel_en_pin: panel-en-pin { - rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - lcd_panel_reset_pin: lcd-panel-reset-pin { - rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - pwr_led_pin: pwr-led-pin { - rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - slp_led_pin: slp-led-pin { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l_pin: pmic-int-l-pin { - rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdcard { - sdmmc0_pwr_h_pin: sdmmc0-pwr-h-pin { - rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - }; - - sdio-pwrseq { - wifi_enable_h_pin: wifi-enable-h-pin { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb-typec { - vcc5v0_typec0_en_pin: vcc5v0-typec0-en-pin { - rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - pwr_5v_pin: pwr-5v-pin { - rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_host_en_pin: vcc5v0-host-en-pin { - rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wireless-bluetooth { - bt_wake_pin: bt-wake-pin { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_pin: bt-host-wake-pin { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_reset_pin: bt-reset-pin { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - sd-uhs-sdr50; - vmmc-supply = <&vcc3v0_sd>; - vqmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&sdio0 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&spi1 { - max-freq = <10000000>; - status = "okay"; - - spiflash: flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - m25p,fast-read; - spi-max-frequency = <10000000>; - }; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy0_dp { - port { - tcphy0_typec_dp: endpoint { - remote-endpoint = <&usbc_dp>; - }; - }; -}; - -&tcphy0_usb3 { - port { - tcphy0_typec_ss: endpoint { - remote-endpoint = <&usbc_ss>; - }; - }; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_otg>; - status = "okay"; - }; - - port { - u2phy0_typec_hs: endpoint { - remote-endpoint = <&usbc_hs>; - }; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_otg>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - uart-has-rtscts; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - max-speed = <1500000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_pin &bt_wake_pin &bt_reset_pin>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - vbat-supply = <&wifi_bat>; - vddio-supply = <&vcc_wl>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - dr_mode = "host"; - status = "okay"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - dr_mode = "host"; - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-pinephone-pro.dts b/arch/arm/dts/rk3399-pinephone-pro.dts deleted file mode 100644 index 61f3fec5a8b1..000000000000 --- a/arch/arm/dts/rk3399-pinephone-pro.dts +++ /dev/null @@ -1,621 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2020 Martijn Braam martijn@brixit.nl - * Copyright (c) 2021 Kamil Trzciński ayufan@ayufan.eu - */ - -/* - * PinePhone Pro datasheet: - * https://files.pine64.org/doc/PinePhonePro/PinephonePro-Schematic-V1.0-202111... - */ - -/dts-v1/; -#include <dt-bindings/input/gpio-keys.h> -#include <dt-bindings/input/linux-event-codes.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Pine64 PinePhonePro"; - compatible = "pine64,pinephone-pro", "rockchip,rk3399"; - chassis-type = "handset"; - - aliases { - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1600000>; - poll-interval = <100>; - - button-up { - label = "Volume Up"; - linux,code = <KEY_VOLUMEUP>; - press-threshold-microvolt = <100000>; - }; - - button-down { - label = "Volume Down"; - linux,code = <KEY_VOLUMEDOWN>; - press-threshold-microvolt = <600000>; - }; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - pwms = <&pwm0 0 50000 0>; - }; - - gpio-keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn_pin>; - - key-power { - debounce-interval = <20>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - vcc_sys: vcc-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_sys>; - }; - - vcca1v8_s3: vcc1v8-s3-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcca1v8_s3"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - regulator-always-on; - regulator-boot-on; - }; - - vcc1v8_codec: vcc1v8-codec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio3 RK_PA4 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc1v8_codec_en>; - regulator-name = "vcc1v8_codec"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - }; - - wifi_pwrseq: sdio-wifi-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk818 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h_pin>; - /* - * Wait between power-on and SDIO access for CYP43455 - * POR circuit. - */ - post-power-on-delay-ms = <110>; - /* - * Wait between consecutive toggles for CYP43455 CBUCK - * regulator discharge. - */ - power-off-delay-us = <10000>; - - /* WL_REG_ON on module */ - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - /* MIPI DSI panel 1.8v supply */ - vcc1v8_lcd: vcc1v8-lcd { - compatible = "regulator-fixed"; - enable-active-high; - regulator-name = "vcc1v8_lcd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - gpio = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - }; - - /* MIPI DSI panel 2.8v supply */ - vcc2v8_lcd: vcc2v8-lcd { - compatible = "regulator-fixed"; - enable-active-high; - regulator-name = "vcc2v8_lcd"; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - vin-supply = <&vcc3v3_sys>; - gpio = <&gpio3 RK_PA1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - }; -}; - -&cpu_alert0 { - temperature = <65000>; -}; -&cpu_alert1 { - temperature = <68000>; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk818: pmic@1c { - compatible = "rockchip,rk818"; - reg = <0x1c>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PC5 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc_sys>; - vcc9-supply = <&vcc3v3_sys>; - - regulators { - vdd_cpu_l: DCDC_REG1 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <875000>; - regulator-max-microvolt = <975000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_center: DCDC_REG2 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1000000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcca3v0_codec: LDO_REG1 { - regulator-name = "vcca3v0_codec"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - }; - - vcc3v0_touch: LDO_REG2 { - regulator-name = "vcc3v0_touch"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - }; - - vcca1v8_codec: LDO_REG3 { - regulator-name = "vcca1v8_codec"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - rk818_pwr_on: LDO_REG4 { - regulator-name = "rk818_pwr_on"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_3v0: LDO_REG5 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc1v8_dvp: LDO_REG7 { - regulator-name = "vcc1v8_dvp"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - }; - - vcc3v3_s3: LDO_REG8 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG9 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - }; - - vcc3v3_s0: SWITCH_REG { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_pin>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <875000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_pin>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <875000>; - regulator-max-microvolt = <975000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; - - touchscreen@14 { - compatible = "goodix,gt1158"; - reg = <0x14>; - interrupt-parent = <&gpio3>; - interrupts = <RK_PB5 IRQ_TYPE_EDGE_RISING>; - irq-gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_HIGH>; - reset-gpios = <&gpio3 RK_PB4 GPIO_ACTIVE_HIGH>; - AVDD28-supply = <&vcc3v0_touch>; - VDDIO-supply = <&vcc3v0_touch>; - touchscreen-size-x = <720>; - touchscreen-size-y = <1440>; - }; -}; - -&cluster0_opp { - opp04 { - status = "disabled"; - }; - - opp05 { - status = "disabled"; - }; -}; - -&cluster1_opp { - opp06 { - opp-hz = /bits/ 64 <1500000000>; - opp-microvolt = <1100000 1100000 1150000>; - }; - - opp07 { - status = "disabled"; - }; -}; - -&io_domains { - bt656-supply = <&vcc1v8_dvp>; - audio-supply = <&vcca1v8_codec>; - sdmmc-supply = <&vccio_sd>; - gpio1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&mipi_dsi { - status = "okay"; - clock-master; - - ports { - mipi_out: port@1 { - #address-cells = <0>; - #size-cells = <0>; - reg = <1>; - - mipi_out_panel: endpoint { - remote-endpoint = <&mipi_in_panel>; - }; - }; - }; - - panel@0 { - compatible = "hannstar,hsd060bhw4"; - reg = <0>; - backlight = <&backlight>; - reset-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_LOW>; - vcc-supply = <&vcc2v8_lcd>; - iovcc-supply = <&vcc1v8_lcd>; - pinctrl-names = "default"; - - port { - mipi_in_panel: endpoint { - remote-endpoint = <&mipi_out_panel>; - }; - }; - }; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_1v8>; - status = "okay"; -}; - -&pinctrl { - buttons { - pwrbtn_pin: pwrbtn-pin { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdio-pwrseq { - wifi_enable_h_pin: wifi-enable-h-pin { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sound { - vcc1v8_codec_en: vcc1v8-codec-en { - rockchip,pins = <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - wireless-bluetooth { - bt_wake_pin: bt-wake-pin { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_pin: bt-host-wake-pin { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_reset_pin: bt-reset-pin { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdio0 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - disable-wp; - keep-power-in-suspend; - mmc-pwrseq = <&wifi_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - status = "okay"; -}; - -&pwm0 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vcc3v3_sys>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - uart-has-rtscts; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk818 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - max-speed = <1500000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_pin &bt_wake_pin &bt_reset_pin>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&vopb { - status = "okay"; - assigned-clocks = <&cru DCLK_VOP0_DIV>, <&cru DCLK_VOP0>, - <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; - assigned-clock-rates = <0>, <0>, <400000000>, <100000000>; - assigned-clock-parents = <&cru PLL_GPLL>, <&cru DCLK_VOP0_DIV>; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; - assigned-clocks = <&cru DCLK_VOP1_DIV>, <&cru DCLK_VOP1>, - <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; - assigned-clock-rates = <0>, <0>, <400000000>, <100000000>; - assigned-clock-parents = <&cru PLL_GPLL>, <&cru DCLK_VOP1_DIV>; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-puma-haikou.dts b/arch/arm/dts/rk3399-puma-haikou.dts deleted file mode 100644 index 18a98c4648ea..000000000000 --- a/arch/arm/dts/rk3399-puma-haikou.dts +++ /dev/null @@ -1,306 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH - */ - -/dts-v1/; -#include "rk3399-puma.dtsi" -#include <dt-bindings/input/input.h> - -/ { - model = "Theobroma Systems RK3399-Q7 SoM"; - compatible = "tsd,rk3399-puma-haikou", "rockchip,rk3399"; - - aliases { - mmc1 = &sdmmc; - }; - - chosen { - stdout-path = "serial0:115200n8"; - }; - - gpio-keys { - compatible = "gpio-keys"; - pinctrl-0 = <&haikou_keys_pin>; - pinctrl-names = "default"; - - button-batlow-n { - gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - label = "BATLOW#"; - linux,code = <KEY_BATTERY>; - }; - - button-slp-btn-n { - gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_LOW>; - label = "SLP_BTN#"; - linux,code = <KEY_SLEEP>; - }; - - button-wake-n { - gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_LOW>; - label = "WAKE#"; - linux,code = <KEY_WAKEUP>; - wakeup-source; - }; - - switch-lid-btn-n { - gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - label = "LID_BTN#"; - linux,code = <SW_LID>; - linux,input-type = <EV_SW>; - }; - }; - - leds { - pinctrl-0 = <&module_led_pin>, <&sd_card_led_pin>; - - sd_card_led: led-1 { - label = "sd_card_led"; - gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "mmc0"; - }; - }; - - i2s0-sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,name = "Haikou,I2S-codec"; - simple-audio-card,mclk-fs = <512>; - - simple-audio-card,codec { - clocks = <&sgtl5000_clk>; - sound-dai = <&sgtl5000>; - }; - - simple-audio-card,cpu { - bitclock-master; - frame-master; - sound-dai = <&i2s0>; - }; - }; - - sgtl5000_clk: sgtl5000-oscillator { - compatible = "fixed-clock"; - #clock-cells = <0>; - clock-frequency = <24576000>; - }; - - dc_12v: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc3v3_baseboard: vcc3v3-baseboard { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_baseboard"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_baseboard: vcc5v0-baseboard { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_baseboard"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_otg: vcc5v0-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&otg_vbus_drv>; - regulator-name = "vcc5v0_otg"; - regulator-always-on; - }; - - vdda_codec: vdda-codec { - compatible = "regulator-fixed"; - regulator-name = "vdda_codec"; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_baseboard>; - }; - - vddd_codec: vddd-codec { - compatible = "regulator-fixed"; - regulator-name = "vddd_codec"; - regulator-boot-on; - regulator-min-microvolt = <1600000>; - regulator-max-microvolt = <1600000>; - vin-supply = <&vcc5v0_baseboard>; - }; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - status = "okay"; -}; - -&i2c1 { - status = "okay"; - clock-frequency = <400000>; -}; - -&i2c2 { - status = "okay"; - clock-frequency = <400000>; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - status = "okay"; - clock-frequency = <400000>; - - sgtl5000: codec@a { - compatible = "fsl,sgtl5000"; - reg = <0x0a>; - clocks = <&sgtl5000_clk>; - #sound-dai-cells = <0>; - VDDA-supply = <&vdda_codec>; - VDDIO-supply = <&vdda_codec>; - VDDD-supply = <&vddd_codec>; - status = "okay"; - }; -}; - -&i2c6 { - status = "okay"; - clock-frequency = <400000>; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn_cpm>; - status = "okay"; -}; - -&pinctrl { - buttons { - haikou_keys_pin: haikou-keys-pin { - rockchip,pins = - /* LID_BTN */ - <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>, - /* BATLOW# */ - <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>, - /* SLP_BTN# */ - <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>, - /* WAKE# */ - <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - sd_card_led_pin: sd-card-led-pin { - rockchip,pins = - <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb2 { - otg_vbus_drv: otg-vbus-drv { - rockchip,pins = - <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <40000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - vmmc-supply = <&vcc3v3_baseboard>; - status = "okay"; -}; - -&spi5 { - status = "okay"; -}; - -&tcphy0 { - status = "okay"; -}; - -&u2phy0 { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - dr_mode = "otg"; - extcon = <&extcon_usb3>; - status = "okay"; -}; - -&u2phy0_host { - phy-supply = <&vcc5v0_otg>; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi deleted file mode 100644 index c08e69391c01..000000000000 --- a/arch/arm/dts/rk3399-puma.dtsi +++ /dev/null @@ -1,532 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH - */ - -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - aliases { - ethernet0 = &gmac; - mmc0 = &sdhci; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&module_led_pin>; - - module_led: led-0 { - label = "module_led"; - gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - panic-indicator; - }; - }; - - extcon_usb3: extcon-usb3 { - compatible = "linux,extcon-usb-gpio"; - id-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&usb3_id>; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - vcc1v2_phy: vcc1v2-phy { - compatible = "regulator-fixed"; - regulator-name = "vcc1v2_phy"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1200000>; - regulator-max-microvolt = <1200000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vcc5v0_sys>; - regulator-name = "vdd_log"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - regulator-always-on; - regulator-boot-on; - }; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&emmc_phy { - status = "okay"; - drive-impedance-ohm = <33>; -}; - -&gpio0 { - /* - * The BIOS_DISABLE hog is a feedback pin for the actual status of the - * signal. This usually represents the state of a switch on the baseboard. - * The pin has a 10k pull-up resistor connected, so no pull-up setting is needed. - */ - bios-disable-hog { - gpios = <RK_PB0 GPIO_ACTIVE_HIGH>; - gpio-hog; - input; - line-name = "bios_disable"; - }; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc1v2_phy>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x10>; - rx_delay = <0x10>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - clock-frequency = <400000>; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <22 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc5v0_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc1v8_pmu>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_ldo1: LDO_REG1 { - regulator-name = "vcc_ldo1"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_hdmi: LDO_REG2 { - regulator-name = "vcc1v8_hdmi"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmu: LDO_REG3 { - regulator-name = "vcc1v8_pmu"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sd: LDO_REG4 { - regulator-name = "vcc_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc_ldo5: LDO_REG5 { - regulator-name = "vcc_ldo5"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ldo6: LDO_REG6 { - regulator-name = "vcc_ldo6"; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc0v9_hdmi: LDO_REG7 { - regulator-name = "vcc0v9_hdmi"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_efuse: LDO_REG8 { - regulator-name = "vcc_efuse"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s3: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_gpu: regulator@60 { - compatible = "fcs,fan53555"; - reg = <0x60>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <1230000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&i2c7 { - status = "okay"; - clock-frequency = <400000>; - - fan: fan@18 { - compatible = "ti,amc6821"; - reg = <0x18>; - #cooling-cells = <2>; - }; - - rtc_twi: rtc@6f { - compatible = "isil,isl1208"; - reg = <0x6f>; - }; -}; - -&i2c8 { - status = "okay"; - clock-frequency = <400000>; - - vdd_cpu_b: regulator@60 { - compatible = "fcs,fan53555"; - reg = <0x60>; - vin-supply = <&vcc5v0_sys>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <600000>; - regulator-max-microvolt = <1230000>; - regulator-ramp-delay = <1000>; - fcs,suspend-voltage-selector = <1>; - regulator-always-on; - regulator-boot-on; - }; -}; - -&i2s0 { - pinctrl-0 = <&i2s0_2ch_bus>; - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; -}; - -/* - * As Q7 does not specify neither a global nor a RX clock for I2S these - * signals are not used. Furthermore I2S0_LRCK_RX is used as GPIO. - * Therefore we have to redefine the i2s0_2ch_bus definition to prevent - * conflicts. - */ -&i2s0_2ch_bus { - rockchip,pins = - <3 RK_PD0 1 &pcfg_pull_none>, - <3 RK_PD2 1 &pcfg_pull_none>, - <3 RK_PD3 1 &pcfg_pull_none>, - <3 RK_PD7 1 &pcfg_pull_none>; -}; - -&io_domains { - status = "okay"; - bt656-supply = <&vcc_1v8>; - audio-supply = <&vcc_1v8>; - sdmmc-supply = <&vcc_sd>; - gpio1830-supply = <&vcc_1v8>; -}; - -&pmu_io_domains { - status = "okay"; - pmu1830-supply = <&vcc_1v8>; -}; - -&pwm2 { - status = "okay"; -}; - -&pinctrl { - i2c8 { - i2c8_xfer_a: i2c8-xfer { - rockchip,pins = - <1 RK_PC4 1 &pcfg_pull_up>, - <1 RK_PC5 1 &pcfg_pull_up>; - }; - }; - - leds { - module_led_pin: module-led-pin { - rockchip,pins = - <2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = - <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = - <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb3 { - usb3_id: usb3-id { - rockchip,pins = - <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdhci { - /* - * Signal integrity isn't great at 200MHz but 100MHz has proven stable - * enough. - */ - max-frequency = <100000000>; - - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&sdmmc { - vqmmc-supply = <&vcc_sd>; -}; - -&spi1 { - status = "okay"; - - norflash: flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <50000000>; - }; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts deleted file mode 100644 index 9447c8724b65..000000000000 --- a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts +++ /dev/null @@ -1,111 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd - * Copyright (c) 2019 Markus Reichl m.reichl@fivetechno.de - */ - -/dts-v1/; -#include "rk3399-roc-pc.dtsi" - -/ { - model = "Firefly ROC-RK3399-PC Mezzanine Board"; - compatible = "firefly,roc-rk3399-pc-mezzanine", "rockchip,rk3399"; - - aliases { - mmc2 = &sdio0; - }; - - /* MP8009 PoE PD */ - poe_12v: poe-12v { - compatible = "regulator-fixed"; - regulator-name = "poe_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc3v3_ngff: vcc3v3-ngff { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_ngff"; - enable-active-high; - gpio = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc3v3_ngff_en>; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&sys_12v>; - }; - - vcc3v3_pcie: vcc3v3-pcie { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pcie"; - enable-active-high; - gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc3v3_pcie_en>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&sys_12v>; - }; -}; - -&sys_12v { - vin-supply = <&poe_12v>; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_perst>; - vpcie3v3-supply = <&vcc3v3_pcie>; - vpcie1v8-supply = <&vcc1v8_pmu>; - vpcie0v9-supply = <&vcca_0v9>; - status = "okay"; -}; - -&pinctrl { - ngff { - vcc3v3_ngff_en: vcc3v3-ngff-en { - rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - vcc3v3_pcie_en: vcc3v3-pcie-en { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_perst: pcie-perst { - rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdio0 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_ngff>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-roc-pc.dts b/arch/arm/dts/rk3399-roc-pc.dts deleted file mode 100644 index cd4195425309..000000000000 --- a/arch/arm/dts/rk3399-roc-pc.dts +++ /dev/null @@ -1,12 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd - */ - -/dts-v1/; -#include "rk3399-roc-pc.dtsi" - -/ { - model = "Firefly ROC-RK3399-PC Board"; - compatible = "firefly,roc-rk3399-pc", "rockchip,rk3399"; -}; diff --git a/arch/arm/dts/rk3399-roc-pc.dtsi b/arch/arm/dts/rk3399-roc-pc.dtsi deleted file mode 100644 index ca7a446b6568..000000000000 --- a/arch/arm/dts/rk3399-roc-pc.dtsi +++ /dev/null @@ -1,844 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd - */ - -/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Firefly ROC-RK3399-PC Board"; - compatible = "firefly,roc-rk3399-pc", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdmmc; - mmc1 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - backlight: backlight { - compatible = "pwm-backlight"; - pwms = <&pwm0 0 25000 0>; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 1>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1500000>; - poll-interval = <100>; - - button-recovery { - label = "Recovery"; - linux,code = <KEY_VENDOR>; - press-threshold-microvolt = <18000>; - }; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&pwr_key_l>; - - key-power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_int>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&work_led_pin>, <&diy_led_pin>, <&yellow_led_pin>; - - work_led: led-0 { - label = "green:work"; - gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - default-state = "on"; - linux,default-trigger = "heartbeat"; - }; - - diy_led: led-1 { - label = "red:diy"; - gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; - default-state = "off"; - linux,default-trigger = "mmc2"; - }; - - yellow_led: led-2 { - label = "yellow:yellow-led"; - gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; - default-state = "off"; - linux,default-trigger = "mmc1"; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - vcc_vbus_typec0: vcc-vbus-typec0 { - compatible = "regulator-fixed"; - regulator-name = "vcc_vbus_typec0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - sys_12v: sys-12v { - compatible = "regulator-fixed"; - regulator-name = "sys_12v"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&dc_12v>; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8>; - }; - - vcc3v0_sd: vcc3v0-sd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc3v0_sd_en>; - regulator-name = "vcc3v0_sd"; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&sys_12v>; - }; - - vcca_0v9: vcca-0v9 { - compatible = "regulator-fixed"; - regulator-name = "vcca_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; - - /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en &hub_rst>; - regulator-name = "vcc5v0_host"; - vin-supply = <&vcc_sys>; - }; - - vcc_vbus_typec1: vcc-vbus-typec1 { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc_vbus_typec1_en>; - regulator-name = "vcc_vbus_typec1"; - regulator-always-on; - vin-supply = <&vcc_sys>; - }; - - vcc_sys: vcc-sys { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc_sys_en>; - regulator-name = "vcc_sys"; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&sys_12v>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <450000>; - regulator-max-microvolt = <1400000>; - pwm-supply = <&vcc3v3_sys>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vcca0v9_hdmi>; - avdd-1v8-supply = <&vcca1v8_hdmi>; - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - vcc10-supply = <&vcc3v3_sys>; - vcc11-supply = <&vcc3v3_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_3v0>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_codec: LDO_REG1 { - regulator-name = "vcca1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_hdmi: LDO_REG2 { - regulator-name = "vcca1v8_hdmi"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_pmu: LDO_REG3 { - regulator-name = "vcc1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca0v9_hdmi: LDO_REG7 { - regulator-name = "vcca0v9_hdmi"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: vcc_lan: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_pin>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_pin>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - i2c-scl-rising-time-ns = <300>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - - fusb1: usb-typec@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <1 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb1_int>; - vbus-supply = <&vcc_vbus_typec1>; - status = "okay"; - }; -}; - -&i2c7 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - - fusb0: usb-typec@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int>; - vbus-supply = <&vcc_vbus_typec0>; - status = "okay"; - }; - - mp8859: regulator@66 { - compatible = "mps,mp8859"; - reg = <0x66>; - dc_12v: mp8859_dcdc { - regulator-name = "dc_12v"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_vbus_typec0>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <12000000>; - }; - }; - }; -}; - -&i2s0 { - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; - status = "okay"; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - audio-supply = <&vcca1v8_codec>; - bt656-supply = <&vcc_3v0>; - gpio1830-supply = <&vcc_3v0>; - sdmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pinctrl { - buttons { - pwr_key_l: pwr-key-l { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - ir { - ir_int: ir-int { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - lcd-panel { - lcd_panel_reset: lcd-panel-reset { - rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - diy_led_pin: diy-led-pin { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - work_led_pin: work-led-pin { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - yellow_led_pin: yellow-led-pin { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - vcc3v0_sd_en: vcc3v0-sd-en { - rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc_sys_en: vcc-sys-en { - rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - hub_rst: hub-rst { - rockchip,pins = <2 RK_PA4 RK_FUNC_GPIO &pcfg_output_high>; - }; - }; - - usb-typec { - vcc_vbus_typec1_en: vcc-vbus-typec1-en { - rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - fusb30x { - fusb0_int: fusb0-int { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - fusb1_int: fusb1-int { - rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v0_sd>; - vqmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - non-removable; - status = "okay"; -}; - -&spi1 { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <30000000>; - }; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - phy-supply = <&vcc_vbus_typec0>; - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - phy-supply = <&vcc_vbus_typec1>; - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-rock-4c-plus.dts b/arch/arm/dts/rk3399-rock-4c-plus.dts deleted file mode 100644 index 7baf9d1b22fd..000000000000 --- a/arch/arm/dts/rk3399-rock-4c-plus.dts +++ /dev/null @@ -1,709 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * Copyright (c) 2019 Radxa Limited - * Copyright (c) 2022 Amarula Solutions(India) - */ - -/dts-v1/; -#include <dt-bindings/leds/common.h> -#include "rk3399.dtsi" -#include "rk3399-t-opp.dtsi" - -/ { - model = "Radxa ROCK 4C+"; - compatible = "radxa,rock-4c-plus", "rockchip,rk3399"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdhci; - mmc1 = &sdmmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&user_led1 &user_led2>; - - /* USER_LED1 */ - led-0 { - function = LED_FUNCTION_POWER; - color = <LED_COLOR_ID_GREEN>; - gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_LOW>; - linux,default-trigger = "default-on"; - }; - - /* USER_LED2 */ - led-1 { - function = LED_FUNCTION_STATUS; - color = <LED_COLOR_ID_BLUE>; - gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk809 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - vcc_3v3: vcc-3v3-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_phy1: vcc3v3-phy1-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_phy1"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_3v3>; - }; - - vcc5v0_host1: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host1"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_host0_s0>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc5v0_typec: vcc5v0-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec0_en>; - regulator-name = "vcc5v0_typec"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; - - vdd_log: vdd-log-regulator { - compatible = "regulator-fixed"; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <950000>; - regulator-max-microvolt = <950000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc3v3_phy1>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x2a>; - rx_delay = <0x21>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vcc_0v9_s0>; - avdd-1v8-supply = <&vcc_1v8_s0>; - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - i2c-scl-falling-time-ns = <30>; - i2c-scl-rising-time-ns = <180>; - clock-frequency = <400000>; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PC5 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc5-supply = <&vcc_buck5_s3>; - vcc6-supply = <&vcc_buck5_s3>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_center"; - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_cpu_l"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc_ddr"; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_sys: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-initial-mode = <0x2>; - regulator-name = "vcc3v3_sys"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_buck5_s3: DCDC_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_buck5_s3"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_0v9_s3: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vcc_0v9_s3"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8_s3: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_1v8_s3"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_0v9_s0: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vcc_0v9_s0"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vcc_1v8_s0: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_1v8_s0"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_mipi: LDO_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc_mipi"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5_s0: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-name = "vcc_1v5_s0"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0_s0: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-name = "vcc_3v0_s0"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_sdio_s0: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_sdio_s0"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_cam: LDO_REG9 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_cam"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc5v0_host0_s0: SWITCH_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-name = "vcc5v0_host0_s0"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - lcd_3v3: SWITCH_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-name = "lcd_3v3"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - regulator-compatible = "fan53555-reg"; - pinctrl-0 = <&vsel1_gpio>; - vsel-gpios = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - regulator-compatible = "fan53555-reg"; - pinctrl-0 = <&vsel2_gpio>; - vsel-gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_HIGH>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - regulator-initial-mode = <1>; /* 1:force PWM 2:auto */ - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - audio-supply = <&vcc_1v8_s0>; - bt656-supply = <&vcc_3v0_s0>; - gpio1830-supply = <&vcc_3v0_s0>; - sdmmc-supply = <&vcc_sdio_s0>; - status = "okay"; -}; - -&pinctrl { - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - user_led1: user-led1 { - rockchip,pins = <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led2: user-led2 { - rockchip,pins = <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_gpio: vsel1-gpio { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_gpio: vsel2-gpio { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdmmc { - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = <4 8 1 &pcfg_pull_up_8ma>, - <4 9 1 &pcfg_pull_up_8ma>, - <4 10 1 &pcfg_pull_up_8ma>, - <4 11 1 &pcfg_pull_up_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = <4 12 1 &pcfg_pull_none_18ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = <4 13 1 &pcfg_pull_up_8ma>; - }; - }; - - usb-typec { - vcc5v0_typec0_en: vcc5v0-typec-en { - rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - wifi { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0_s0>; - status = "okay"; -}; - -&saradc { - status = "okay"; - vref-supply = <&vcc_1v8_s3>; -}; - -&sdhci { - max-frequency = <150000000>; - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&sdio0 { - #address-cells = <1>; - #size-cells = <0>; - bus-width = <4>; - clock-frequency = <50000000>; - cap-sdio-irq; - cap-sd-highspeed; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - status = "okay"; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - card-detect-delay = <800>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - vqmmc-supply = <&vcc_sdio_s0>; - status = "okay"; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host1>; - status = "okay"; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host1>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk809 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - max-speed = <1500000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8_s3>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - extcon = <&u2phy0>; - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "host"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-rock-4se.dts b/arch/arm/dts/rk3399-rock-4se.dts deleted file mode 100644 index 7cfc198bbae7..000000000000 --- a/arch/arm/dts/rk3399-rock-4se.dts +++ /dev/null @@ -1,65 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Akash Gajjar Akash_Gajjar@mentor.com - * Copyright (c) 2019 Pragnesh Patel Pragnesh_Patel@mentor.com - */ - -/dts-v1/; -#include "rk3399-rock-pi-4.dtsi" -#include "rk3399-t-opp.dtsi" - -/ { - model = "Radxa ROCK 4SE"; - compatible = "radxa,rock-4se", "rockchip,rk3399"; - - aliases { - mmc2 = &sdio0; - }; -}; - -&pinctrl { - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdio0 { - status = "okay"; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&uart0 { - status = "okay"; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - max-speed = <1500000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&vcc5v0_host { - enable-active-high; - gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; -}; diff --git a/arch/arm/dts/rk3399-rock-pi-4.dtsi b/arch/arm/dts/rk3399-rock-pi-4.dtsi deleted file mode 100644 index 281a12180703..000000000000 --- a/arch/arm/dts/rk3399-rock-pi-4.dtsi +++ /dev/null @@ -1,792 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Akash Gajjar Akash_Gajjar@mentor.com - * Copyright (c) 2019 Pragnesh Patel Pragnesh_Patel@mentor.com - */ - -/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" - -/ { - aliases { - ethernet0 = &gmac; - mmc0 = &sdhci; - mmc1 = &sdmmc; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&user_led2>; - - /* USER_LED2 */ - led-0 { - function = LED_FUNCTION_STATUS; - color = <LED_COLOR_ID_BLUE>; - gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "lpo"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - sound: sound { - compatible = "audio-graph-card"; - label = "Analog"; - dais = <&i2s0_p0>; - }; - - sound-dit { - compatible = "audio-graph-card"; - label = "SPDIF"; - dais = <&spdif_p0>; - }; - - spdif-dit { - compatible = "linux,spdif-dit"; - #sound-dai-cells = <0>; - - port { - dit_p0_0: endpoint { - remote-endpoint = <&spdif_p0_0>; - }; - }; - }; - - vbus_typec: vbus-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec_en>; - regulator-name = "vbus_typec"; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc12v_dcin: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc3v3_lan: vcc3v3-lan-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_lan"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_pwr_en>; - regulator-name = "vcc3v3_pcie"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_sys: vcc-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc_0v9: vcc-0v9 { - compatible = "regulator-fixed"; - regulator-name = "vcc_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vcc5v0_sys>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1400000>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc3v3_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vcca0v9_hdmi>; - avdd-1v8-supply = <&vcca1v8_hdmi>; - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc5v0_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_codec: LDO_REG1 { - regulator-name = "vcca1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_hdmi: LDO_REG2 { - regulator-name = "vcca1v8_hdmi"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca_1v8: LDO_REG3 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca0v9_hdmi: LDO_REG7 { - regulator-name = "vcca0v9_hdmi"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc_cam: SWITCH_REG1 { - regulator-name = "vcc_cam"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_mipi: SWITCH_REG2 { - regulator-name = "vcc_mipi"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_pin>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_pin>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - i2c-scl-rising-time-ns = <300>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; - - es8316: codec@11 { - compatible = "everest,es8316"; - reg = <0x11>; - clocks = <&cru SCLK_I2S_8CH_OUT>; - clock-names = "mclk"; - #sound-dai-cells = <0>; - - port { - es8316_p0_0: endpoint { - remote-endpoint = <&i2s0_p0_0>; - }; - }; - }; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; -}; - -&i2s0 { - pinctrl-0 = <&i2s0_2ch_bus>; - pinctrl-1 = <&i2s0_2ch_bus_bclk_off>; - rockchip,capture-channels = <2>; - rockchip,playback-channels = <2>; - status = "okay"; - - i2s0_p0: port { - i2s0_p0_0: endpoint { - dai-format = "i2s"; - mclk-fs = <256>; - remote-endpoint = <&es8316_p0_0>; - }; - }; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - audio-supply = <&vcca1v8_codec>; - bt656-supply = <&vcc_3v0>; - gpio1830-supply = <&vcc_3v0>; - sdmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-0 = <&pcie_clkreqnb_cpm>; - pinctrl-names = "default"; - vpcie0v9-supply = <&vcc_0v9>; - vpcie1v8-supply = <&vcc_1v8>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pcie_phy { - status = "okay"; -}; - -&pinctrl { - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - es8316 { - hp_detect: hp-detect { - rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - hp_int: hp-int { - rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - user_led2: user-led2 { - rockchip,pins = <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_pwr_en: pcie-pwr-en { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdio0 { - sdio0_bus4: sdio0-bus4 { - rockchip,pins = <2 RK_PC4 1 &pcfg_pull_up_20ma>, - <2 RK_PC5 1 &pcfg_pull_up_20ma>, - <2 RK_PC6 1 &pcfg_pull_up_20ma>, - <2 RK_PC7 1 &pcfg_pull_up_20ma>; - }; - - sdio0_cmd: sdio0-cmd { - rockchip,pins = <2 RK_PD0 1 &pcfg_pull_up_20ma>; - }; - - sdio0_clk: sdio0-clk { - rockchip,pins = <2 RK_PD1 1 &pcfg_pull_none_20ma>; - }; - }; - - usb-typec { - vcc5v0_typec_en: vcc5v0-typec-en { - rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - status = "okay"; - - vref-supply = <&vcc_1v8>; -}; - -&sdhci { - max-frequency = <150000000>; - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&sdio0 { - #address-cells = <1>; - #size-cells = <0>; - bus-width = <4>; - clock-frequency = <50000000>; - cap-sdio-irq; - cap-sd-highspeed; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cd &sdmmc_cmd &sdmmc_bus4>; - status = "okay"; -}; - -&spdif { - - spdif_p0: port { - spdif_p0_0: endpoint { - remote-endpoint = <&dit_p0_0>; - }; - }; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - status = "okay"; - - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "host"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-rock-pi-4a.dts b/arch/arm/dts/rk3399-rock-pi-4a.dts deleted file mode 100644 index d5df8939a658..000000000000 --- a/arch/arm/dts/rk3399-rock-pi-4a.dts +++ /dev/null @@ -1,24 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Akash Gajjar Akash_Gajjar@mentor.com - * Copyright (c) 2019 Pragnesh Patel Pragnesh_Patel@mentor.com - */ - -/dts-v1/; -#include "rk3399-rock-pi-4.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Radxa ROCK Pi 4A"; - compatible = "radxa,rockpi4a", "radxa,rockpi4", "rockchip,rk3399"; -}; - -&spi1 { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <10000000>; - }; -}; diff --git a/arch/arm/dts/rk3399-rock-pi-4c.dts b/arch/arm/dts/rk3399-rock-pi-4c.dts deleted file mode 100644 index de2ebe4cb4f3..000000000000 --- a/arch/arm/dts/rk3399-rock-pi-4c.dts +++ /dev/null @@ -1,80 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * Copyright (c) 2019 Radxa Limited - * Copyright (c) 2019 Amarula Solutions(India) - */ - -/dts-v1/; -#include "rk3399-rock-pi-4.dtsi" -#include "rk3399-opp.dtsi" - -/ { - model = "Radxa ROCK Pi 4C"; - compatible = "radxa,rockpi4c", "radxa,rockpi4", "rockchip,rk3399"; - - aliases { - mmc2 = &sdio0; - }; -}; - -&es8316 { - pinctrl-0 = <&hp_detect &hp_int>; - pinctrl-names = "default"; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA1 IRQ_TYPE_LEVEL_HIGH>; -}; - -&sdio0 { - status = "okay"; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sound { - hp-det-gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>; -}; - -&spi1 { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <10000000>; - }; -}; - -&uart0 { - status = "okay"; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - max-speed = <1500000>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&vcc5v0_host { - gpio = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>; -}; - -&vcc5v0_host_en { - rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; -}; diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts deleted file mode 100644 index 1a23e8f3cdf6..000000000000 --- a/arch/arm/dts/rk3399-rock960.dts +++ /dev/null @@ -1,156 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2018 Linaro Ltd. - */ - -/dts-v1/; -#include "rk3399-rock960.dtsi" - -/ { - model = "96boards Rock960"; - compatible = "vamrs,rock960", "rockchip,rk3399"; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>, - <&user_led3_pin>, <&user_led4_pin>, - <&wlan_led_pin>, <&bt_led_pin>; - - user_led1: led-1 { - label = "green:user1"; - gpios = <&gpio4 RK_PC2 0>; - linux,default-trigger = "heartbeat"; - }; - - user_led2: led-2 { - label = "green:user2"; - gpios = <&gpio4 RK_PC6 0>; - linux,default-trigger = "mmc0"; - }; - - user_led3: led-3 { - label = "green:user3"; - gpios = <&gpio4 RK_PD0 0>; - linux,default-trigger = "mmc1"; - }; - - user_led4: led-4 { - label = "green:user4"; - gpios = <&gpio4 RK_PD4 0>; - panic-indicator; - linux,default-trigger = "none"; - }; - - wlan_active_led: led-5 { - label = "yellow:wlan"; - gpios = <&gpio4 RK_PD5 0>; - linux,default-trigger = "phy0tx"; - default-state = "off"; - }; - - bt_active_led: led-6 { - label = "blue:bt"; - gpios = <&gpio4 RK_PD6 0>; - linux,default-trigger = "hci0-power"; - default-state = "off"; - }; - }; - -}; - -&cpu_alert0 { - temperature = <65000>; -}; - -&cpu_thermal { - sustainable-power = <1550>; - - cooling-maps { - map0 { - trip = <&cpu_alert1>; - }; - }; -}; - -&pcie0 { - ep-gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>; -}; - -&pinctrl { - leds { - user_led1_pin: user-led1-pin { - rockchip,pins = - <4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led2_pin: user-led2-pin { - rockchip,pins = - <4 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led3_pin: user-led3-pin { - rockchip,pins = - <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - user_led4_pin: user-led4-pin { - rockchip,pins = - <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wlan_led_pin: wlan-led-pin { - rockchip,pins = - <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_led_pin: bt-led-pin { - rockchip,pins = - <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_drv: pcie-drv { - rockchip,pins = - <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb2 { - host_vbus_drv: host-vbus-drv { - rockchip,pins = - <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&spi0 { - /* On Low speed expansion (LS-SPI0) */ - status = "okay"; -}; - -&spi4 { - /* On High speed expansion (HS-SPI1) */ - status = "okay"; -}; - -&usbdrd_dwc3_0 { - dr_mode = "otg"; -}; - -&usbdrd_dwc3_1 { - dr_mode = "host"; -}; - -&vcc3v3_pcie { - gpio = <&gpio2 5 GPIO_ACTIVE_HIGH>; -}; - -&vcc5v0_host { - gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>; -}; diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi deleted file mode 100644 index c920ddf44baf..000000000000 --- a/arch/arm/dts/rk3399-rock960.dtsi +++ /dev/null @@ -1,673 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2018 Collabora Ltd. - * Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd. - * Copyright (c) 2018 Linaro Ltd. - */ - -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" -#include <dt-bindings/interrupt-controller/irq.h> - -/ { - aliases { - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - vcc12v_dcin: vcc12v-dcin { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - regulator-always-on; - regulator-boot-on; - }; - - vcc1v8_s0: vcc1v8-s0 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s0"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc12v_dcin>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_drv>; - regulator-boot-on; - regulator-name = "vcc3v3_pcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - pinctrl-names = "default"; - pinctrl-0 = <&host_vbus_drv>; - regulator-name = "vcc5v0_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc_0v9: vcc-0v9 { - compatible = "regulator-fixed"; - regulator-name = "vcc_0v9"; - regulator-always-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vcca0v9_hdmi>; - avdd-1v8-supply = <&vcca1v8_hdmi>; - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - status = "okay"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio1>; - interrupts = <21 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc5v0_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_hdmi: LDO_REG2 { - regulator-name = "vcca1v8_hdmi"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca_1v8: LDO_REG3 { - regulator-name = "vcca_1v8"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sd: LDO_REG4 { - regulator-name = "vcc_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc3v0_sd: LDO_REG5 { - regulator-name = "vcc3v0_sd"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca0v9_hdmi: LDO_REG7 { - regulator-name = "vcca0v9_hdmi"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - }; - }; -}; - -&i2c1 { - status = "okay"; -}; - -&i2c2 { - status = "okay"; -}; - -&i2c3 { - status = "okay"; -}; - -&i2c4 { - status = "okay"; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - bt656-supply = <&vcc1v8_s0>; /* bt656_gpio2ab_ms */ - audio-supply = <&vcc1v8_s0>; /* audio_gpio3d4a_ms */ - sdmmc-supply = <&vcc_sd>; /* sdmmc_gpio4b_ms */ - gpio1830-supply = <&vcc_3v0>; /* gpio1833_gpio4cd_ms */ - status = "okay"; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn_cpm>; - vpcie0v9-supply = <&vcc_0v9>; - vpcie1v8-supply = <&vcca_1v8>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_1v8>; - status = "okay"; -}; - -&pinctrl { - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdmmc { - sdmmc_bus1: sdmmc-bus1 { - rockchip,pins = - <4 RK_PB0 1 &pcfg_pull_up_8ma>; - }; - - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = - <4 RK_PB0 1 &pcfg_pull_up_8ma>, - <4 RK_PB1 1 &pcfg_pull_up_8ma>, - <4 RK_PB2 1 &pcfg_pull_up_8ma>, - <4 RK_PB3 1 &pcfg_pull_up_8ma>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = - <4 RK_PB4 1 &pcfg_pull_none_18ma>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = - <4 RK_PB5 1 &pcfg_pull_up_8ma>; - }; - }; - - sdio0 { - sdio0_bus4: sdio0-bus4 { - rockchip,pins = - <2 RK_PC4 1 &pcfg_pull_up_20ma>, - <2 RK_PC5 1 &pcfg_pull_up_20ma>, - <2 RK_PC6 1 &pcfg_pull_up_20ma>, - <2 RK_PC7 1 &pcfg_pull_up_20ma>; - }; - - sdio0_cmd: sdio0-cmd { - rockchip,pins = - <2 RK_PD0 1 &pcfg_pull_up_20ma>; - }; - - sdio0_clk: sdio0-clk { - rockchip,pins = - <2 RK_PD1 1 &pcfg_pull_none_20ma>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = - <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = - <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = - <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = - <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_host_wake_l: wifi-host-wake-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm2 { - status = "okay"; -}; - -&pwm3 { - status = "okay"; -}; - -&sdio0 { - bus-width = <4>; - clock-frequency = <50000000>; - cap-sdio-irq; - cap-sd-highspeed; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - brcmf: wifi@1 { - compatible = "brcm,bcm4329-fmac"; - reg = <1>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_l>; - }; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - clock-frequency = <100000000>; - max-frequency = <100000000>; - cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; - disable-wp; - sd-uhs-sdr104; - vqmmc-supply = <&vcc_sd>; - card-detect-delay = <800>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <1>; - rockchip,hw-tshut-temp = <110000>; - status = "okay"; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&u2phy0 { - status = "okay"; -}; - -&u2phy1 { - status = "okay"; -}; - -&u2phy0_host { - phy-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&u2phy1_host { - phy-supply = <&vcc5v0_host>; - status = "okay"; -}; - -&u2phy0_otg { - status = "okay"; -}; - -&u2phy1_otg { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-rockpro64.dts b/arch/arm/dts/rk3399-rockpro64.dts deleted file mode 100644 index 4b42717800f7..000000000000 --- a/arch/arm/dts/rk3399-rockpro64.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - * Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com - * Copyright (c) 2019 Katsuhiro Suzuki katsuhiro@katsuster.net - */ - -/dts-v1/; -#include "rk3399-rockpro64.dtsi" - -/ { - model = "Pine64 RockPro64 v2.1"; - compatible = "pine64,rockpro64-v2.1", "pine64,rockpro64", "rockchip,rk3399"; -}; - -&i2c1 { - es8316: codec@11 { - compatible = "everest,es8316"; - reg = <0x11>; - clocks = <&cru SCLK_I2S_8CH_OUT>; - clock-names = "mclk"; - #sound-dai-cells = <0>; - - port { - es8316_p0_0: endpoint { - remote-endpoint = <&i2s1_p0_0>; - }; - }; - }; -}; diff --git a/arch/arm/dts/rk3399-rockpro64.dtsi b/arch/arm/dts/rk3399-rockpro64.dtsi deleted file mode 100644 index f30b82a10ca3..000000000000 --- a/arch/arm/dts/rk3399-rockpro64.dtsi +++ /dev/null @@ -1,956 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd. - * Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com - */ - -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" - -/ { - aliases { - ethernet0 = &gmac; - mmc0 = &sdio0; - mmc1 = &sdmmc; - mmc2 = &sdhci; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - /* enable for panel backlight support */ - backlight: backlight { - compatible = "pwm-backlight"; - brightness-levels = <0 4 8 16 32 64 128 255>; - default-brightness-level = <5>; - pwms = <&pwm0 0 1000000 0>; - status = "disabled"; - }; - - clkin_gmac: external-gmac-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "clkin_gmac"; - #clock-cells = <0>; - }; - - gpio-keys { - compatible = "gpio-keys"; - autorepeat; - pinctrl-names = "default"; - pinctrl-0 = <&pwrbtn>; - - key-power { - debounce-interval = <100>; - gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - label = "GPIO Key Power"; - linux,code = <KEY_POWER>; - wakeup-source; - }; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>; - pinctrl-0 = <&ir_int>; - pinctrl-names = "default"; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&work_led_pin>, <&diy_led_pin>; - - work_led: led-0 { - label = "work"; - default-state = "on"; - gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; - }; - - diy_led: led-1 { - label = "diy"; - default-state = "off"; - gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>; - }; - }; - - fan: pwm-fan { - compatible = "pwm-fan"; - cooling-levels = <0 100 150 200 255>; - #cooling-cells = <2>; - fan-supply = <&vcc12v_dcin>; - pwms = <&pwm1 0 50000 0>; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk808 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>; - }; - - sound { - compatible = "audio-graph-card"; - label = "Analog"; - dais = <&i2s1_p0>; - }; - - sound-dit { - compatible = "audio-graph-card"; - label = "SPDIF"; - dais = <&spdif_p0>; - }; - - spdif-dit { - compatible = "linux,spdif-dit"; - #sound-dai-cells = <0>; - - port { - dit_p0_0: endpoint { - remote-endpoint = <&spdif_p0_0>; - }; - }; - }; - - avdd: avdd-regulator { - compatible = "regulator-fixed"; - regulator-name = "avdd"; - regulator-min-microvolt = <11000000>; - regulator-max-microvolt = <11000000>; - vin-supply = <&vcc3v3_s0>; - }; - - vcc12v_dcin: vcc12v-dcin { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - /* switched by pmic_sleep */ - vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 { - compatible = "regulator-fixed"; - regulator-name = "vcc1v8_s3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8>; - }; - - /* micro SD card power */ - vcc3v0_sd: vcc3v0-sd { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_pwr_h>; - regulator-name = "vcc3v0_sd"; - regulator-always-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_pwr_en>; - regulator-name = "vcc3v3_pcie"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc12v_dcin>; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */ - vcc5v0_host: vcc5v0-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_host_en>; - regulator-name = "vcc5v0_host"; - regulator-always-on; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_typec: vcc5v0-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_typec_en>; - regulator-name = "vcc5v0_typec"; - regulator-always-on; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc5v0_usb: vcc5v0-usb { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vdd_log: vdd-log { - compatible = "pwm-regulator"; - pwms = <&pwm2 0 25000 1>; - pwm-supply = <&vcc5v0_sys>; - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1700000>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_b0 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_b1 { - cpu-supply = <&vdd_cpu_b>; -}; - -&cpu_thermal { - trips { - cpu_warm: cpu_warm { - temperature = <55000>; - hysteresis = <2000>; - type = "active"; - }; - - cpu_hot: cpu_hot { - temperature = <65000>; - hysteresis = <2000>; - type = "active"; - }; - }; - - cooling-maps { - map2 { - trip = <&cpu_warm>; - cooling-device = <&fan THERMAL_NO_LIMIT 1>; - }; - - map3 { - trip = <&cpu_hot>; - cooling-device = <&fan 2 THERMAL_NO_LIMIT>; - }; - }; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - assigned-clock-parents = <&clkin_gmac>; - clock_in_out = "input"; - phy-supply = <&vcc_lan>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&rgmii_pins>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - snps,reset-delays-us = <0 10000 50000>; - tx_delay = <0x28>; - rx_delay = <0x11>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; - status = "okay"; -}; - -&hdmi_sound { - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-rising-time-ns = <168>; - i2c-scl-falling-time-ns = <4>; - status = "okay"; - - rk808: pmic@1b { - compatible = "rockchip,rk808"; - reg = <0x1b>; - interrupt-parent = <&gpio3>; - interrupts = <10 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "xin32k", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc6-supply = <&vcc5v0_sys>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - vcc10-supply = <&vcc5v0_sys>; - vcc11-supply = <&vcc5v0_sys>; - vcc12-supply = <&vcc3v3_sys>; - vddio-supply = <&vcca_1v8>; - - regulators { - vdd_center: DCDC_REG1 { - regulator-name = "vdd_center"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG4 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc1v8_dvp: LDO_REG1 { - regulator-name = "vcc1v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v0_touch: LDO_REG2 { - regulator-name = "vcc3v0_touch"; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca_1v8: LDO_REG3 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_sdio: LDO_REG4 { - regulator-name = "vcc_sdio"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcca3v0_codec: LDO_REG5 { - regulator-name = "vcca3v0_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1500000>; - }; - }; - - vcca1v8_codec: LDO_REG7 { - regulator-name = "vcca1v8_codec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v0: LDO_REG8 { - regulator-name = "vcc_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3000000>; - }; - }; - - vcc3v3_s3: vcc_lan: SWITCH_REG1 { - regulator-name = "vcc3v3_s3"; - regulator-always-on; - regulator-boot-on; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_s0: SWITCH_REG2 { - regulator-name = "vcc3v3_s0"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu_b: regulator@40 { - compatible = "silergy,syr827"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel1_pin>; - regulator-name = "vdd_cpu_b"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: regulator@41 { - compatible = "silergy,syr828"; - reg = <0x41>; - fcs,suspend-voltage-selector = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&vsel2_pin>; - regulator-name = "vdd_gpu"; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1500000>; - regulator-ramp-delay = <1000>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - i2c-scl-rising-time-ns = <300>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&i2c4 { - i2c-scl-rising-time-ns = <600>; - i2c-scl-falling-time-ns = <20>; - status = "okay"; - - fusb0: typec-portc@22 { - compatible = "fcs,fusb302"; - reg = <0x22>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&fusb0_int>; - vbus-supply = <&vcc5v0_typec>; - status = "okay"; - }; - - /* enable for pine64 touch screen support */ - touch: touchscreen@5d { - compatible = "goodix,gt911"; - reg = <0x5d>; - interrupt-parent = <&gpio4>; - interrupts = <RK_PD5 IRQ_TYPE_EDGE_FALLING>; - AVDD28-supply = <&vcc3v0_touch>; - VDDIO-supply = <&vcc3v0_touch>; - irq-gpios = <&gpio4 RK_PD5 GPIO_ACTIVE_HIGH>; - reset-gpios = <&gpio4 RK_PD6 GPIO_ACTIVE_HIGH>; - status = "disabled"; - }; -}; - -&i2s0 { - rockchip,playback-channels = <8>; - rockchip,capture-channels = <8>; - status = "okay"; -}; - -&i2s1 { - rockchip,playback-channels = <2>; - rockchip,capture-channels = <2>; - status = "okay"; - - i2s1_p0: port { - i2s1_p0_0: endpoint { - dai-format = "i2s"; - mclk-fs = <256>; - remote-endpoint = <&es8316_p0_0>; - }; - }; -}; - -&i2s2 { - status = "okay"; -}; - -&io_domains { - status = "okay"; - - bt656-supply = <&vcc1v8_dvp>; - audio-supply = <&vcc_3v0>; - sdmmc-supply = <&vcc_sdio>; - gpio1830-supply = <&vcc_3v0>; -}; - -/* enable for pine64 panel display support */ -&mipi_dsi { - clock-master; - status = "disabled"; - - ports { - mipi_out: port@1 { - reg = <1>; - - mipi_out_panel: endpoint { - remote-endpoint = <&mipi_in_panel>; - }; - }; - }; - - mipi_panel: panel@0 { - compatible = "feiyang,fy07024di26a30d"; - reg = <0>; - avdd-supply = <&avdd>; - backlight = <&backlight>; - dvdd-supply = <&vcc3v3_s0>; - - port { - mipi_in_panel: endpoint { - remote-endpoint = <&mipi_out_panel>; - }; - }; - }; -}; - -&pcie0 { - ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_perst>; - vpcie12v-supply = <&vcc12v_dcin>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pcie_phy { - status = "okay"; -}; - -&pmu_io_domains { - pmu1830-supply = <&vcc_3v0>; - status = "okay"; -}; - -&pinctrl { - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - buttons { - pwrbtn: pwrbtn { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - fusb302x { - fusb0_int: fusb0-int { - rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - ir { - ir_int: ir-int { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - work_led_pin: work-led-pin { - rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - diy_led_pin: diy-led-pin { - rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_perst: pcie-perst { - rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_pwr_en: pcie-pwr-en { - rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - vsel1_pin: vsel1-pin { - rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - vsel2_pin: vsel2-pin { - rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>; - }; - }; - - sdcard { - sdmmc0_pwr_h: sdmmc0-pwr-h { - rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb-typec { - vcc5v0_typec_en: vcc5v0_typec_en { - rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_host_en: vcc5v0-host-en { - rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm0 { - status = "okay"; -}; - -&pwm1 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca1v8_s3>; - status = "okay"; -}; - -&sdio0 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - disable-wp; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>; - sd-uhs-sdr104; - status = "okay"; -}; - -&sdmmc { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>; - disable-wp; - max-frequency = <150000000>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>; - vmmc-supply = <&vcc3v0_sd>; - vqmmc-supply = <&vcc_sdio>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - status = "okay"; -}; - -&spdif { - pinctrl-0 = <&spdif_bus_1>; - - spdif_p0: port { - spdif_p0_0: endpoint { - remote-endpoint = <&dit_p0_0>; - }; - }; -}; - -&spi1 { - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <10000000>; - }; -}; - -&tcphy0 { - status = "okay"; -}; - -&tcphy1 { - status = "okay"; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&u2phy1 { - status = "okay"; - - u2phy1_otg: otg-port { - status = "okay"; - }; - - u2phy1_host: host-port { - phy-supply = <&vcc5v0_host>; - status = "okay"; - }; -}; - -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk808 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; - dr_mode = "host"; -}; - -&usbdrd3_1 { - status = "okay"; -}; - -&usbdrd_dwc3_1 { - status = "okay"; - dr_mode = "host"; -}; - -&vopb { - status = "okay"; -}; - -&vopb_mmu { - status = "okay"; -}; - -&vopl { - status = "okay"; -}; - -&vopl_mmu { - status = "okay"; -}; diff --git a/arch/arm/dts/rk3399-t-opp.dtsi b/arch/arm/dts/rk3399-t-opp.dtsi deleted file mode 100644 index 1ababadda9df..000000000000 --- a/arch/arm/dts/rk3399-t-opp.dtsi +++ /dev/null @@ -1,114 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd - * Copyright (c) 2022 Radxa Limited - */ - -/ { - cluster0_opp: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp00 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <875000 875000 1250000>; - clock-latency-ns = <40000>; - }; - opp01 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <875000 875000 1250000>; - }; - opp02 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <900000 900000 1250000>; - }; - opp03 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <975000 975000 1250000>; - }; - }; - - cluster1_opp: opp-table-1 { - compatible = "operating-points-v2"; - opp-shared; - - opp00 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <875000 875000 1250000>; - clock-latency-ns = <40000>; - }; - opp01 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <875000 875000 1250000>; - }; - opp02 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <875000 875000 1250000>; - }; - opp03 { - opp-hz = /bits/ 64 <1008000000>; - opp-microvolt = <925000 925000 1250000>; - }; - opp04 { - opp-hz = /bits/ 64 <1200000000>; - opp-microvolt = <1000000 1000000 1250000>; - }; - opp05 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <1075000 1075000 1250000>; - }; - opp06 { - opp-hz = /bits/ 64 <1512000000>; - opp-microvolt = <1150000 1150000 1250000>; - }; - }; - - gpu_opp_table: opp-table-2 { - compatible = "operating-points-v2"; - - opp00 { - opp-hz = /bits/ 64 <200000000>; - opp-microvolt = <875000 875000 1150000>; - }; - opp01 { - opp-hz = /bits/ 64 <300000000>; - opp-microvolt = <875000 875000 1150000>; - }; - opp02 { - opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <875000 875000 1150000>; - }; - opp03 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <975000 975000 1150000>; - }; - }; -}; - -&cpu_l0 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l1 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l2 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_l3 { - operating-points-v2 = <&cluster0_opp>; -}; - -&cpu_b0 { - operating-points-v2 = <&cluster1_opp>; -}; - -&cpu_b1 { - operating-points-v2 = <&cluster1_opp>; -}; - -&gpu { - operating-points-v2 = <&gpu_opp_table>; -}; diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi deleted file mode 100644 index 6e12c5a920ca..000000000000 --- a/arch/arm/dts/rk3399.dtsi +++ /dev/null @@ -1,2945 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd - */ - -#include <dt-bindings/clock/rk3399-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rk3399-power.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - compatible = "rockchip,rk3399"; - - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; - gpio4 = &gpio4; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - i2c6 = &i2c6; - i2c7 = &i2c7; - i2c8 = &i2c8; - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; - serial4 = &uart4; - }; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - cpu-map { - cluster0 { - core0 { - cpu = <&cpu_l0>; - }; - core1 { - cpu = <&cpu_l1>; - }; - core2 { - cpu = <&cpu_l2>; - }; - core3 { - cpu = <&cpu_l3>; - }; - }; - - cluster1 { - core0 { - cpu = <&cpu_b0>; - }; - core1 { - cpu = <&cpu_b1>; - }; - }; - }; - - cpu_l0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x0>; - enable-method = "psci"; - capacity-dmips-mhz = <485>; - clocks = <&cru ARMCLKL>; - #cooling-cells = <2>; /* min followed by max */ - dynamic-power-coefficient = <100>; - cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; - }; - - cpu_l1: cpu@1 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x1>; - enable-method = "psci"; - capacity-dmips-mhz = <485>; - clocks = <&cru ARMCLKL>; - #cooling-cells = <2>; /* min followed by max */ - dynamic-power-coefficient = <100>; - cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; - }; - - cpu_l2: cpu@2 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x2>; - enable-method = "psci"; - capacity-dmips-mhz = <485>; - clocks = <&cru ARMCLKL>; - #cooling-cells = <2>; /* min followed by max */ - dynamic-power-coefficient = <100>; - cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; - }; - - cpu_l3: cpu@3 { - device_type = "cpu"; - compatible = "arm,cortex-a53"; - reg = <0x0 0x3>; - enable-method = "psci"; - capacity-dmips-mhz = <485>; - clocks = <&cru ARMCLKL>; - #cooling-cells = <2>; /* min followed by max */ - dynamic-power-coefficient = <100>; - cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; - }; - - cpu_b0: cpu@100 { - device_type = "cpu"; - compatible = "arm,cortex-a72"; - reg = <0x0 0x100>; - enable-method = "psci"; - capacity-dmips-mhz = <1024>; - clocks = <&cru ARMCLKB>; - #cooling-cells = <2>; /* min followed by max */ - dynamic-power-coefficient = <436>; - cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; - - thermal-idle { - #cooling-cells = <2>; - duration-us = <10000>; - exit-latency-us = <500>; - }; - }; - - cpu_b1: cpu@101 { - device_type = "cpu"; - compatible = "arm,cortex-a72"; - reg = <0x0 0x101>; - enable-method = "psci"; - capacity-dmips-mhz = <1024>; - clocks = <&cru ARMCLKB>; - #cooling-cells = <2>; /* min followed by max */ - dynamic-power-coefficient = <436>; - cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>; - - thermal-idle { - #cooling-cells = <2>; - duration-us = <10000>; - exit-latency-us = <500>; - }; - }; - - idle-states { - entry-method = "psci"; - - CPU_SLEEP: cpu-sleep { - compatible = "arm,idle-state"; - local-timer-stop; - arm,psci-suspend-param = <0x0010000>; - entry-latency-us = <120>; - exit-latency-us = <250>; - min-residency-us = <900>; - }; - - CLUSTER_SLEEP: cluster-sleep { - compatible = "arm,idle-state"; - local-timer-stop; - arm,psci-suspend-param = <0x1010000>; - entry-latency-us = <400>; - exit-latency-us = <500>; - min-residency-us = <2000>; - }; - }; - }; - - display-subsystem { - compatible = "rockchip,display-subsystem"; - ports = <&vopl_out>, <&vopb_out>; - }; - - dmc: memory-controller { - compatible = "rockchip,rk3399-dmc"; - rockchip,pmu = <&pmugrf>; - devfreq-events = <&dfi>; - clocks = <&cru SCLK_DDRC>; - clock-names = "dmc_clk"; - status = "disabled"; - }; - - pmu_a53 { - compatible = "arm,cortex-a53-pmu"; - interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster0>; - }; - - pmu_a72 { - compatible = "arm,cortex-a72-pmu"; - interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster1>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW 0>, - <GIC_PPI 14 IRQ_TYPE_LEVEL_LOW 0>, - <GIC_PPI 11 IRQ_TYPE_LEVEL_LOW 0>, - <GIC_PPI 10 IRQ_TYPE_LEVEL_LOW 0>; - arm,no-tick-in-suspend; - }; - - xin24m: xin24m { - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "xin24m"; - #clock-cells = <0>; - }; - - pcie0: pcie@f8000000 { - compatible = "rockchip,rk3399-pcie"; - reg = <0x0 0xf8000000 0x0 0x2000000>, - <0x0 0xfd000000 0x0 0x1000000>; - reg-names = "axi-base", "apb-base"; - device_type = "pci"; - #address-cells = <3>; - #size-cells = <2>; - #interrupt-cells = <1>; - aspm-no-l0s; - bus-range = <0x0 0x1f>; - clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>, - <&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>; - clock-names = "aclk", "aclk-perf", - "hclk", "pm"; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "sys", "legacy", "client"; - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pcie0_intc 0>, - <0 0 0 2 &pcie0_intc 1>, - <0 0 0 3 &pcie0_intc 2>, - <0 0 0 4 &pcie0_intc 3>; - max-link-speed = <1>; - msi-map = <0x0 &its 0x0 0x1000>; - phys = <&pcie_phy 0>, <&pcie_phy 1>, - <&pcie_phy 2>, <&pcie_phy 3>; - phy-names = "pcie-phy-0", "pcie-phy-1", - "pcie-phy-2", "pcie-phy-3"; - ranges = <0x82000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000>, - <0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>; - resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, - <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, - <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>, - <&cru SRST_A_PCIE>; - reset-names = "core", "mgmt", "mgmt-sticky", "pipe", - "pm", "pclk", "aclk"; - status = "disabled"; - - pcie0_intc: interrupt-controller { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <1>; - }; - }; - - pcie0_ep: pcie-ep@f8000000 { - compatible = "rockchip,rk3399-pcie-ep"; - reg = <0x0 0xfd000000 0x0 0x1000000>, - <0x0 0xfa000000 0x0 0x2000000>; - reg-names = "apb-base", "mem-base"; - clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>, - <&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>; - clock-names = "aclk", "aclk-perf", - "hclk", "pm"; - max-functions = /bits/ 8 <8>; - num-lanes = <4>; - resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>, - <&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>, - <&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>, - <&cru SRST_A_PCIE>; - reset-names = "core", "mgmt", "mgmt-sticky", "pipe", - "pm", "pclk", "aclk"; - phys = <&pcie_phy 0>, <&pcie_phy 1>, - <&pcie_phy 2>, <&pcie_phy 3>; - phy-names = "pcie-phy-0", "pcie-phy-1", - "pcie-phy-2", "pcie-phy-3"; - rockchip,max-outbound-regions = <32>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqnb_cpm>; - status = "disabled"; - }; - - gmac: ethernet@fe300000 { - compatible = "rockchip,rk3399-gmac"; - reg = <0x0 0xfe300000 0x0 0x10000>; - interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "macirq"; - clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>, - <&cru SCLK_MAC_TX>, <&cru SCLK_MACREF>, - <&cru SCLK_MACREF_OUT>, <&cru ACLK_GMAC>, - <&cru PCLK_GMAC>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_ref", - "clk_mac_refout", "aclk_mac", - "pclk_mac"; - power-domains = <&power RK3399_PD_GMAC>; - resets = <&cru SRST_A_GMAC>; - reset-names = "stmmaceth"; - rockchip,grf = <&grf>; - snps,txpbl = <0x4>; - status = "disabled"; - }; - - sdio0: mmc@fe310000 { - compatible = "rockchip,rk3399-dw-mshc", - "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xfe310000 0x0 0x4000>; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH 0>; - max-frequency = <150000000>; - clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>, - <&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - power-domains = <&power RK3399_PD_SDIOAUDIO>; - resets = <&cru SRST_SDIO0>; - reset-names = "reset"; - status = "disabled"; - }; - - sdmmc: mmc@fe320000 { - compatible = "rockchip,rk3399-dw-mshc", - "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xfe320000 0x0 0x4000>; - interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH 0>; - max-frequency = <150000000>; - assigned-clocks = <&cru HCLK_SD>; - assigned-clock-rates = <200000000>; - clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>, - <&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - power-domains = <&power RK3399_PD_SD>; - resets = <&cru SRST_SDMMC>; - reset-names = "reset"; - status = "disabled"; - }; - - sdhci: mmc@fe330000 { - compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1"; - reg = <0x0 0xfe330000 0x0 0x10000>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>; - arasan,soc-ctl-syscon = <&grf>; - assigned-clocks = <&cru SCLK_EMMC>; - assigned-clock-rates = <200000000>; - clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>; - clock-names = "clk_xin", "clk_ahb"; - clock-output-names = "emmc_cardclock"; - #clock-cells = <0>; - phys = <&emmc_phy>; - phy-names = "phy_arasan"; - power-domains = <&power RK3399_PD_EMMC>; - disable-cqe-dcmd; - status = "disabled"; - }; - - usb_host0_ehci: usb@fe380000 { - compatible = "generic-ehci"; - reg = <0x0 0xfe380000 0x0 0x20000>; - interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, - <&u2phy0>; - phys = <&u2phy0_host>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host0_ohci: usb@fe3a0000 { - compatible = "generic-ohci"; - reg = <0x0 0xfe3a0000 0x0 0x20000>; - interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>, - <&u2phy0>; - phys = <&u2phy0_host>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host1_ehci: usb@fe3c0000 { - compatible = "generic-ehci"; - reg = <0x0 0xfe3c0000 0x0 0x20000>; - interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, - <&u2phy1>; - phys = <&u2phy1_host>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host1_ohci: usb@fe3e0000 { - compatible = "generic-ohci"; - reg = <0x0 0xfe3e0000 0x0 0x20000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>, - <&u2phy1>; - phys = <&u2phy1_host>; - phy-names = "usb"; - status = "disabled"; - }; - - debug@fe430000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0 0xfe430000 0 0x1000>; - clocks = <&cru PCLK_COREDBG_L>; - clock-names = "apb_pclk"; - cpu = <&cpu_l0>; - }; - - debug@fe432000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0 0xfe432000 0 0x1000>; - clocks = <&cru PCLK_COREDBG_L>; - clock-names = "apb_pclk"; - cpu = <&cpu_l1>; - }; - - debug@fe434000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0 0xfe434000 0 0x1000>; - clocks = <&cru PCLK_COREDBG_L>; - clock-names = "apb_pclk"; - cpu = <&cpu_l2>; - }; - - debug@fe436000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0 0xfe436000 0 0x1000>; - clocks = <&cru PCLK_COREDBG_L>; - clock-names = "apb_pclk"; - cpu = <&cpu_l3>; - }; - - debug@fe610000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0 0xfe610000 0 0x1000>; - clocks = <&cru PCLK_COREDBG_B>; - clock-names = "apb_pclk"; - cpu = <&cpu_b0>; - }; - - debug@fe710000 { - compatible = "arm,coresight-cpu-debug", "arm,primecell"; - reg = <0 0xfe710000 0 0x1000>; - clocks = <&cru PCLK_COREDBG_B>; - clock-names = "apb_pclk"; - cpu = <&cpu_b1>; - }; - - usbdrd3_0: usb@fe800000 { - compatible = "rockchip,rk3399-dwc3"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - clocks = <&cru SCLK_USB3OTG0_REF>, <&cru SCLK_USB3OTG0_SUSPEND>, - <&cru ACLK_USB3OTG0>, <&cru ACLK_USB3_RKSOC_AXI_PERF>, - <&cru ACLK_USB3>, <&cru ACLK_USB3_GRF>; - clock-names = "ref_clk", "suspend_clk", - "bus_clk", "aclk_usb3_rksoc_axi_perf", - "aclk_usb3", "grf_clk"; - resets = <&cru SRST_A_USB3_OTG0>; - reset-names = "usb3-otg"; - status = "disabled"; - - usbdrd_dwc3_0: usb@fe800000 { - compatible = "snps,dwc3"; - reg = <0x0 0xfe800000 0x0 0x100000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_USB3OTG0_REF>, <&cru ACLK_USB3OTG0>, - <&cru SCLK_USB3OTG0_SUSPEND>; - clock-names = "ref", "bus_early", "suspend"; - dr_mode = "otg"; - phys = <&u2phy0_otg>, <&tcphy0_usb3>; - phy-names = "usb2-phy", "usb3-phy"; - phy_type = "utmi_wide"; - snps,dis_enblslpm_quirk; - snps,dis-u2-freeclk-exists-quirk; - snps,dis_u2_susphy_quirk; - snps,dis-del-phy-power-chg-quirk; - snps,dis-tx-ipgap-linecheck-quirk; - power-domains = <&power RK3399_PD_USB3>; - status = "disabled"; - }; - }; - - usbdrd3_1: usb@fe900000 { - compatible = "rockchip,rk3399-dwc3"; - #address-cells = <2>; - #size-cells = <2>; - ranges; - clocks = <&cru SCLK_USB3OTG1_REF>, <&cru SCLK_USB3OTG1_SUSPEND>, - <&cru ACLK_USB3OTG1>, <&cru ACLK_USB3_RKSOC_AXI_PERF>, - <&cru ACLK_USB3>, <&cru ACLK_USB3_GRF>; - clock-names = "ref_clk", "suspend_clk", - "bus_clk", "aclk_usb3_rksoc_axi_perf", - "aclk_usb3", "grf_clk"; - resets = <&cru SRST_A_USB3_OTG1>; - reset-names = "usb3-otg"; - status = "disabled"; - - usbdrd_dwc3_1: usb@fe900000 { - compatible = "snps,dwc3"; - reg = <0x0 0xfe900000 0x0 0x100000>; - interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_USB3OTG1_REF>, <&cru ACLK_USB3OTG1>, - <&cru SCLK_USB3OTG1_SUSPEND>; - clock-names = "ref", "bus_early", "suspend"; - dr_mode = "otg"; - phys = <&u2phy1_otg>, <&tcphy1_usb3>; - phy-names = "usb2-phy", "usb3-phy"; - phy_type = "utmi_wide"; - snps,dis_enblslpm_quirk; - snps,dis-u2-freeclk-exists-quirk; - snps,dis_u2_susphy_quirk; - snps,dis-del-phy-power-chg-quirk; - snps,dis-tx-ipgap-linecheck-quirk; - power-domains = <&power RK3399_PD_USB3>; - status = "disabled"; - }; - }; - - cdn_dp: dp@fec00000 { - compatible = "rockchip,rk3399-cdn-dp"; - reg = <0x0 0xfec00000 0x0 0x100000>; - interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH 0>; - assigned-clocks = <&cru SCLK_DP_CORE>, <&cru SCLK_SPDIF_REC_DPTX>; - assigned-clock-rates = <100000000>, <200000000>; - clocks = <&cru SCLK_DP_CORE>, <&cru PCLK_DP_CTRL>, - <&cru SCLK_SPDIF_REC_DPTX>, <&cru PCLK_VIO_GRF>; - clock-names = "core-clk", "pclk", "spdif", "grf"; - phys = <&tcphy0_dp>, <&tcphy1_dp>; - power-domains = <&power RK3399_PD_HDCP>; - resets = <&cru SRST_DPTX_SPDIF_REC>, <&cru SRST_P_UPHY0_DPTX>, - <&cru SRST_P_UPHY0_APB>, <&cru SRST_DP_CORE>; - reset-names = "spdif", "dptx", "apb", "core"; - rockchip,grf = <&grf>; - #sound-dai-cells = <1>; - status = "disabled"; - - ports { - dp_in: port { - #address-cells = <1>; - #size-cells = <0>; - - dp_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_dp>; - }; - - dp_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_dp>; - }; - }; - }; - }; - - gic: interrupt-controller@fee00000 { - compatible = "arm,gic-v3"; - #interrupt-cells = <4>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - interrupt-controller; - - reg = <0x0 0xfee00000 0 0x10000>, /* GICD */ - <0x0 0xfef00000 0 0xc0000>, /* GICR */ - <0x0 0xfff00000 0 0x10000>, /* GICC */ - <0x0 0xfff10000 0 0x10000>, /* GICH */ - <0x0 0xfff20000 0 0x10000>; /* GICV */ - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>; - its: msi-controller@fee20000 { - compatible = "arm,gic-v3-its"; - msi-controller; - #msi-cells = <1>; - reg = <0x0 0xfee20000 0x0 0x20000>; - }; - - ppi-partitions { - ppi_cluster0: interrupt-partition-0 { - affinity = <&cpu_l0 &cpu_l1 &cpu_l2 &cpu_l3>; - }; - - ppi_cluster1: interrupt-partition-1 { - affinity = <&cpu_b0 &cpu_b1>; - }; - }; - }; - - saradc: saradc@ff100000 { - compatible = "rockchip,rk3399-saradc"; - reg = <0x0 0xff100000 0x0 0x100>; - interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH 0>; - #io-channel-cells = <1>; - clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>; - clock-names = "saradc", "apb_pclk"; - resets = <&cru SRST_P_SARADC>; - reset-names = "saradc-apb"; - status = "disabled"; - }; - - crypto0: crypto@ff8b0000 { - compatible = "rockchip,rk3399-crypto"; - reg = <0x0 0xff8b0000 0x0 0x4000>; - interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru HCLK_M_CRYPTO0>, <&cru HCLK_S_CRYPTO0>, <&cru SCLK_CRYPTO0>; - clock-names = "hclk_master", "hclk_slave", "sclk"; - resets = <&cru SRST_CRYPTO0>, <&cru SRST_CRYPTO0_S>, <&cru SRST_CRYPTO0_M>; - reset-names = "master", "slave", "crypto-rst"; - }; - - crypto1: crypto@ff8b8000 { - compatible = "rockchip,rk3399-crypto"; - reg = <0x0 0xff8b8000 0x0 0x4000>; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru HCLK_M_CRYPTO1>, <&cru HCLK_S_CRYPTO1>, <&cru SCLK_CRYPTO1>; - clock-names = "hclk_master", "hclk_slave", "sclk"; - resets = <&cru SRST_CRYPTO1>, <&cru SRST_CRYPTO1_S>, <&cru SRST_CRYPTO1_M>; - reset-names = "master", "slave", "crypto-rst"; - }; - - i2c1: i2c@ff110000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff110000 0x0 0x1000>; - assigned-clocks = <&cru SCLK_I2C1>; - assigned-clock-rates = <200000000>; - clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c1_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@ff120000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff120000 0x0 0x1000>; - assigned-clocks = <&cru SCLK_I2C2>; - assigned-clock-rates = <200000000>; - clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c2_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@ff130000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff130000 0x0 0x1000>; - assigned-clocks = <&cru SCLK_I2C3>; - assigned-clock-rates = <200000000>; - clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c3_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c5: i2c@ff140000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff140000 0x0 0x1000>; - assigned-clocks = <&cru SCLK_I2C5>; - assigned-clock-rates = <200000000>; - clocks = <&cru SCLK_I2C5>, <&cru PCLK_I2C5>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c5_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c6: i2c@ff150000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff150000 0x0 0x1000>; - assigned-clocks = <&cru SCLK_I2C6>; - assigned-clock-rates = <200000000>; - clocks = <&cru SCLK_I2C6>, <&cru PCLK_I2C6>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c6_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c7: i2c@ff160000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff160000 0x0 0x1000>; - assigned-clocks = <&cru SCLK_I2C7>; - assigned-clock-rates = <200000000>; - clocks = <&cru SCLK_I2C7>, <&cru PCLK_I2C7>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c7_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - uart0: serial@ff180000 { - compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff180000 0x0 0x100>; - clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>; - clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH 0>; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>; - status = "disabled"; - }; - - uart1: serial@ff190000 { - compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff190000 0x0 0x100>; - clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; - clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH 0>; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart1_xfer>; - status = "disabled"; - }; - - uart2: serial@ff1a0000 { - compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff1a0000 0x0 0x100>; - clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; - clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH 0>; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart2c_xfer>; - status = "disabled"; - }; - - uart3: serial@ff1b0000 { - compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff1b0000 0x0 0x100>; - clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; - clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH 0>; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart3_xfer>; - status = "disabled"; - }; - - spi0: spi@ff1c0000 { - compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff1c0000 0x0 0x1000>; - clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_peri 10>, <&dmac_peri 11>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi1: spi@ff1d0000 { - compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff1d0000 0x0 0x1000>; - clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_peri 12>, <&dmac_peri 13>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi2: spi@ff1e0000 { - compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff1e0000 0x0 0x1000>; - clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_peri 14>, <&dmac_peri 15>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi4: spi@ff1f0000 { - compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff1f0000 0x0 0x1000>; - clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_peri 18>, <&dmac_peri 19>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi5: spi@ff200000 { - compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff200000 0x0 0x1000>; - clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_bus 8>, <&dmac_bus 9>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>; - power-domains = <&power RK3399_PD_SDIOAUDIO>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - thermal_zones: thermal-zones { - cpu_thermal: cpu-thermal { - polling-delay-passive = <100>; - polling-delay = <1000>; - - thermal-sensors = <&tsadc 0>; - - trips { - cpu_alert0: cpu_alert0 { - temperature = <70000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu_alert1: cpu_alert1 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu_crit: cpu_crit { - temperature = <95000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu_alert0>; - cooling-device = - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - map1 { - trip = <&cpu_alert1>; - cooling-device = - <&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_l1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_l2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - gpu_thermal: gpu-thermal { - polling-delay-passive = <100>; - polling-delay = <1000>; - - thermal-sensors = <&tsadc 1>; - - trips { - gpu_alert0: gpu_alert0 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - gpu_crit: gpu_crit { - temperature = <95000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&gpu_alert0>; - cooling-device = - <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - }; - - tsadc: tsadc@ff260000 { - compatible = "rockchip,rk3399-tsadc"; - reg = <0x0 0xff260000 0x0 0x100>; - interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH 0>; - assigned-clocks = <&cru SCLK_TSADC>; - assigned-clock-rates = <750000>; - clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>; - clock-names = "tsadc", "apb_pclk"; - resets = <&cru SRST_TSADC>; - reset-names = "tsadc-apb"; - rockchip,grf = <&grf>; - rockchip,hw-tshut-temp = <95000>; - pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&otp_pin>; - pinctrl-1 = <&otp_out>; - pinctrl-2 = <&otp_pin>; - #thermal-sensor-cells = <1>; - status = "disabled"; - }; - - qos_emmc: qos@ffa58000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa58000 0x0 0x20>; - }; - - qos_gmac: qos@ffa5c000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa5c000 0x0 0x20>; - }; - - qos_pcie: qos@ffa60080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa60080 0x0 0x20>; - }; - - qos_usb_host0: qos@ffa60100 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa60100 0x0 0x20>; - }; - - qos_usb_host1: qos@ffa60180 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa60180 0x0 0x20>; - }; - - qos_usb_otg0: qos@ffa70000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa70000 0x0 0x20>; - }; - - qos_usb_otg1: qos@ffa70080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa70080 0x0 0x20>; - }; - - qos_sd: qos@ffa74000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa74000 0x0 0x20>; - }; - - qos_sdioaudio: qos@ffa76000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa76000 0x0 0x20>; - }; - - qos_hdcp: qos@ffa90000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa90000 0x0 0x20>; - }; - - qos_iep: qos@ffa98000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffa98000 0x0 0x20>; - }; - - qos_isp0_m0: qos@ffaa0000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffaa0000 0x0 0x20>; - }; - - qos_isp0_m1: qos@ffaa0080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffaa0080 0x0 0x20>; - }; - - qos_isp1_m0: qos@ffaa8000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffaa8000 0x0 0x20>; - }; - - qos_isp1_m1: qos@ffaa8080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffaa8080 0x0 0x20>; - }; - - qos_rga_r: qos@ffab0000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffab0000 0x0 0x20>; - }; - - qos_rga_w: qos@ffab0080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffab0080 0x0 0x20>; - }; - - qos_video_m0: qos@ffab8000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffab8000 0x0 0x20>; - }; - - qos_video_m1_r: qos@ffac0000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffac0000 0x0 0x20>; - }; - - qos_video_m1_w: qos@ffac0080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffac0080 0x0 0x20>; - }; - - qos_vop_big_r: qos@ffac8000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffac8000 0x0 0x20>; - }; - - qos_vop_big_w: qos@ffac8080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffac8080 0x0 0x20>; - }; - - qos_vop_little: qos@ffad0000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffad0000 0x0 0x20>; - }; - - qos_perihp: qos@ffad8080 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffad8080 0x0 0x20>; - }; - - qos_gpu: qos@ffae0000 { - compatible = "rockchip,rk3399-qos", "syscon"; - reg = <0x0 0xffae0000 0x0 0x20>; - }; - - pmu: power-management@ff310000 { - compatible = "rockchip,rk3399-pmu", "syscon", "simple-mfd"; - reg = <0x0 0xff310000 0x0 0x1000>; - - /* - * Note: RK3399 supports 6 voltage domains including VD_CORE_L, - * VD_CORE_B, VD_CENTER, VD_GPU, VD_LOGIC and VD_PMU. - * Some of the power domains are grouped together for every - * voltage domain. - * The detail contents as below. - */ - power: power-controller { - compatible = "rockchip,rk3399-power-controller"; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - /* These power domains are grouped by VD_CENTER */ - power-domain@RK3399_PD_IEP { - reg = <RK3399_PD_IEP>; - clocks = <&cru ACLK_IEP>, - <&cru HCLK_IEP>; - pm_qos = <&qos_iep>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_RGA { - reg = <RK3399_PD_RGA>; - clocks = <&cru ACLK_RGA>, - <&cru HCLK_RGA>; - pm_qos = <&qos_rga_r>, - <&qos_rga_w>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_VCODEC { - reg = <RK3399_PD_VCODEC>; - clocks = <&cru ACLK_VCODEC>, - <&cru HCLK_VCODEC>; - pm_qos = <&qos_video_m0>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_VDU { - reg = <RK3399_PD_VDU>; - clocks = <&cru ACLK_VDU>, - <&cru HCLK_VDU>, - <&cru SCLK_VDU_CA>, - <&cru SCLK_VDU_CORE>; - pm_qos = <&qos_video_m1_r>, - <&qos_video_m1_w>; - #power-domain-cells = <0>; - }; - - /* These power domains are grouped by VD_GPU */ - power-domain@RK3399_PD_GPU { - reg = <RK3399_PD_GPU>; - clocks = <&cru ACLK_GPU>; - pm_qos = <&qos_gpu>; - #power-domain-cells = <0>; - }; - - /* These power domains are grouped by VD_LOGIC */ - power-domain@RK3399_PD_EDP { - reg = <RK3399_PD_EDP>; - clocks = <&cru PCLK_EDP_CTRL>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_EMMC { - reg = <RK3399_PD_EMMC>; - clocks = <&cru ACLK_EMMC>; - pm_qos = <&qos_emmc>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_GMAC { - reg = <RK3399_PD_GMAC>; - clocks = <&cru ACLK_GMAC>, - <&cru PCLK_GMAC>; - pm_qos = <&qos_gmac>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_SD { - reg = <RK3399_PD_SD>; - clocks = <&cru HCLK_SDMMC>, - <&cru SCLK_SDMMC>; - pm_qos = <&qos_sd>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_SDIOAUDIO { - reg = <RK3399_PD_SDIOAUDIO>; - clocks = <&cru HCLK_SDIO>; - pm_qos = <&qos_sdioaudio>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_TCPD0 { - reg = <RK3399_PD_TCPD0>; - clocks = <&cru SCLK_UPHY0_TCPDCORE>, - <&cru SCLK_UPHY0_TCPDPHY_REF>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_TCPD1 { - reg = <RK3399_PD_TCPD1>; - clocks = <&cru SCLK_UPHY1_TCPDCORE>, - <&cru SCLK_UPHY1_TCPDPHY_REF>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_USB3 { - reg = <RK3399_PD_USB3>; - clocks = <&cru ACLK_USB3>; - pm_qos = <&qos_usb_otg0>, - <&qos_usb_otg1>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_VIO { - reg = <RK3399_PD_VIO>; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - power-domain@RK3399_PD_HDCP { - reg = <RK3399_PD_HDCP>; - clocks = <&cru ACLK_HDCP>, - <&cru HCLK_HDCP>, - <&cru PCLK_HDCP>; - pm_qos = <&qos_hdcp>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_ISP0 { - reg = <RK3399_PD_ISP0>; - clocks = <&cru ACLK_ISP0>, - <&cru HCLK_ISP0>; - pm_qos = <&qos_isp0_m0>, - <&qos_isp0_m1>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_ISP1 { - reg = <RK3399_PD_ISP1>; - clocks = <&cru ACLK_ISP1>, - <&cru HCLK_ISP1>; - pm_qos = <&qos_isp1_m0>, - <&qos_isp1_m1>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_VO { - reg = <RK3399_PD_VO>; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - power-domain@RK3399_PD_VOPB { - reg = <RK3399_PD_VOPB>; - clocks = <&cru ACLK_VOP0>, - <&cru HCLK_VOP0>; - pm_qos = <&qos_vop_big_r>, - <&qos_vop_big_w>; - #power-domain-cells = <0>; - }; - power-domain@RK3399_PD_VOPL { - reg = <RK3399_PD_VOPL>; - clocks = <&cru ACLK_VOP1>, - <&cru HCLK_VOP1>; - pm_qos = <&qos_vop_little>; - #power-domain-cells = <0>; - }; - }; - }; - }; - }; - - pmugrf: syscon@ff320000 { - compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd"; - reg = <0x0 0xff320000 0x0 0x1000>; - - pmu_io_domains: io-domains { - compatible = "rockchip,rk3399-pmu-io-voltage-domain"; - status = "disabled"; - }; - }; - - spi3: spi@ff350000 { - compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xff350000 0x0 0x1000>; - clocks = <&pmucru SCLK_SPI3_PMU>, <&pmucru PCLK_SPI3_PMU>; - clock-names = "spiclk", "apb_pclk"; - interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&spi3_clk &spi3_tx &spi3_rx &spi3_cs0>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - uart4: serial@ff370000 { - compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart"; - reg = <0x0 0xff370000 0x0 0x100>; - clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>; - clock-names = "baudclk", "apb_pclk"; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH 0>; - reg-shift = <2>; - reg-io-width = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&uart4_xfer>; - status = "disabled"; - }; - - i2c0: i2c@ff3c0000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff3c0000 0x0 0x1000>; - assigned-clocks = <&pmucru SCLK_I2C0_PMU>; - assigned-clock-rates = <200000000>; - clocks = <&pmucru SCLK_I2C0_PMU>, <&pmucru PCLK_I2C0_PMU>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c0_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@ff3d0000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff3d0000 0x0 0x1000>; - assigned-clocks = <&pmucru SCLK_I2C4_PMU>; - assigned-clock-rates = <200000000>; - clocks = <&pmucru SCLK_I2C4_PMU>, <&pmucru PCLK_I2C4_PMU>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c4_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c8: i2c@ff3e0000 { - compatible = "rockchip,rk3399-i2c"; - reg = <0x0 0xff3e0000 0x0 0x1000>; - assigned-clocks = <&pmucru SCLK_I2C8_PMU>; - assigned-clock-rates = <200000000>; - clocks = <&pmucru SCLK_I2C8_PMU>, <&pmucru PCLK_I2C8_PMU>; - clock-names = "i2c", "pclk"; - interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH 0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2c8_xfer>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - pwm0: pwm@ff420000 { - compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; - reg = <0x0 0xff420000 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm0_pin>; - clocks = <&pmucru PCLK_RKPWM_PMU>; - status = "disabled"; - }; - - pwm1: pwm@ff420010 { - compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; - reg = <0x0 0xff420010 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm1_pin>; - clocks = <&pmucru PCLK_RKPWM_PMU>; - status = "disabled"; - }; - - pwm2: pwm@ff420020 { - compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; - reg = <0x0 0xff420020 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm2_pin>; - clocks = <&pmucru PCLK_RKPWM_PMU>; - status = "disabled"; - }; - - pwm3: pwm@ff420030 { - compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm"; - reg = <0x0 0xff420030 0x0 0x10>; - #pwm-cells = <3>; - pinctrl-names = "default"; - pinctrl-0 = <&pwm3a_pin>; - clocks = <&pmucru PCLK_RKPWM_PMU>; - status = "disabled"; - }; - - dfi: dfi@ff630000 { - reg = <0x00 0xff630000 0x00 0x4000>; - compatible = "rockchip,rk3399-dfi"; - rockchip,pmu = <&pmugrf>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru PCLK_DDR_MON>; - clock-names = "pclk_ddr_mon"; - }; - - vpu: video-codec@ff650000 { - compatible = "rockchip,rk3399-vpu"; - reg = <0x0 0xff650000 0x0 0x800>; - interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "vepu", "vdpu"; - clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; - clock-names = "aclk", "hclk"; - iommus = <&vpu_mmu>; - power-domains = <&power RK3399_PD_VCODEC>; - }; - - vpu_mmu: iommu@ff650800 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff650800 0x0 0x40>; - interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - power-domains = <&power RK3399_PD_VCODEC>; - }; - - vdec: video-codec@ff660000 { - compatible = "rockchip,rk3399-vdec"; - reg = <0x0 0xff660000 0x0 0x480>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>, - <&cru SCLK_VDU_CA>, <&cru SCLK_VDU_CORE>; - clock-names = "axi", "ahb", "cabac", "core"; - iommus = <&vdec_mmu>; - power-domains = <&power RK3399_PD_VDU>; - }; - - vdec_mmu: iommu@ff660480 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>; - interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>; - clock-names = "aclk", "iface"; - power-domains = <&power RK3399_PD_VDU>; - #iommu-cells = <0>; - }; - - iep_mmu: iommu@ff670800 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff670800 0x0 0x40>; - interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - status = "disabled"; - }; - - rga: rga@ff680000 { - compatible = "rockchip,rk3399-rga"; - reg = <0x0 0xff680000 0x0 0x10000>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA_CORE>; - clock-names = "aclk", "hclk", "sclk"; - resets = <&cru SRST_RGA_CORE>, <&cru SRST_A_RGA>, <&cru SRST_H_RGA>; - reset-names = "core", "axi", "ahb"; - power-domains = <&power RK3399_PD_RGA>; - }; - - efuse0: efuse@ff690000 { - compatible = "rockchip,rk3399-efuse"; - reg = <0x0 0xff690000 0x0 0x80>; - #address-cells = <1>; - #size-cells = <1>; - clocks = <&cru PCLK_EFUSE1024NS>; - clock-names = "pclk_efuse"; - - /* Data cells */ - cpu_id: cpu-id@7 { - reg = <0x07 0x10>; - }; - cpub_leakage: cpu-leakage@17 { - reg = <0x17 0x1>; - }; - gpu_leakage: gpu-leakage@18 { - reg = <0x18 0x1>; - }; - center_leakage: center-leakage@19 { - reg = <0x19 0x1>; - }; - cpul_leakage: cpu-leakage@1a { - reg = <0x1a 0x1>; - }; - logic_leakage: logic-leakage@1b { - reg = <0x1b 0x1>; - }; - wafer_info: wafer-info@1c { - reg = <0x1c 0x1>; - }; - }; - - dmac_bus: dma-controller@ff6d0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff6d0000 0x0 0x4000>; - interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>; - #dma-cells = <1>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC0_PERILP>; - clock-names = "apb_pclk"; - }; - - dmac_peri: dma-controller@ff6e0000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xff6e0000 0x0 0x4000>; - interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>; - #dma-cells = <1>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_DMAC1_PERILP>; - clock-names = "apb_pclk"; - }; - - pmucru: clock-controller@ff750000 { - compatible = "rockchip,rk3399-pmucru"; - reg = <0x0 0xff750000 0x0 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - rockchip,grf = <&pmugrf>; - #clock-cells = <1>; - #reset-cells = <1>; - assigned-clocks = <&pmucru PLL_PPLL>; - assigned-clock-rates = <676000000>; - }; - - cru: clock-controller@ff760000 { - compatible = "rockchip,rk3399-cru"; - reg = <0x0 0xff760000 0x0 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - rockchip,grf = <&grf>; - #clock-cells = <1>; - #reset-cells = <1>; - assigned-clocks = - <&cru PLL_GPLL>, <&cru PLL_CPLL>, - <&cru PLL_NPLL>, - <&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>, - <&cru PCLK_PERIHP>, - <&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>, - <&cru PCLK_PERILP0>, <&cru ACLK_CCI>, - <&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>, - <&cru ACLK_VIO>, <&cru ACLK_HDCP>, - <&cru ACLK_GIC_PRE>, - <&cru PCLK_DDR>, - <&cru ACLK_VDU>; - assigned-clock-rates = - <594000000>, <800000000>, - <1000000000>, - <150000000>, <75000000>, - <37500000>, - <100000000>, <100000000>, - <50000000>, <600000000>, - <100000000>, <50000000>, - <400000000>, <400000000>, - <200000000>, - <200000000>, - <400000000>; - }; - - grf: syscon@ff770000 { - compatible = "rockchip,rk3399-grf", "syscon", "simple-mfd"; - reg = <0x0 0xff770000 0x0 0x10000>; - #address-cells = <1>; - #size-cells = <1>; - - io_domains: io-domains { - compatible = "rockchip,rk3399-io-voltage-domain"; - status = "disabled"; - }; - - mipi_dphy_rx0: mipi-dphy-rx0 { - compatible = "rockchip,rk3399-mipi-dphy-rx0"; - clocks = <&cru SCLK_MIPIDPHY_REF>, - <&cru SCLK_DPHY_RX0_CFG>, - <&cru PCLK_VIO_GRF>; - clock-names = "dphy-ref", "dphy-cfg", "grf"; - power-domains = <&power RK3399_PD_VIO>; - #phy-cells = <0>; - status = "disabled"; - }; - - u2phy0: usb2phy@e450 { - compatible = "rockchip,rk3399-usb2phy"; - reg = <0xe450 0x10>; - clocks = <&cru SCLK_USB2PHY0_REF>; - clock-names = "phyclk"; - #clock-cells = <0>; - clock-output-names = "clk_usbphy0_480m"; - status = "disabled"; - - u2phy0_host: host-port { - #phy-cells = <0>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "linestate"; - status = "disabled"; - }; - - u2phy0_otg: otg-port { - #phy-cells = <0>; - interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "otg-bvalid", "otg-id", - "linestate"; - status = "disabled"; - }; - }; - - u2phy1: usb2phy@e460 { - compatible = "rockchip,rk3399-usb2phy"; - reg = <0xe460 0x10>; - clocks = <&cru SCLK_USB2PHY1_REF>; - clock-names = "phyclk"; - #clock-cells = <0>; - clock-output-names = "clk_usbphy1_480m"; - status = "disabled"; - - u2phy1_host: host-port { - #phy-cells = <0>; - interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "linestate"; - status = "disabled"; - }; - - u2phy1_otg: otg-port { - #phy-cells = <0>; - interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "otg-bvalid", "otg-id", - "linestate"; - status = "disabled"; - }; - }; - - emmc_phy: phy@f780 { - compatible = "rockchip,rk3399-emmc-phy"; - reg = <0xf780 0x24>; - clocks = <&sdhci>; - clock-names = "emmcclk"; - drive-impedance-ohm = <50>; - #phy-cells = <0>; - status = "disabled"; - }; - - pcie_phy: pcie-phy { - compatible = "rockchip,rk3399-pcie-phy"; - clocks = <&cru SCLK_PCIEPHY_REF>; - clock-names = "refclk"; - #phy-cells = <1>; - resets = <&cru SRST_PCIEPHY>; - reset-names = "phy"; - status = "disabled"; - }; - }; - - tcphy0: phy@ff7c0000 { - compatible = "rockchip,rk3399-typec-phy"; - reg = <0x0 0xff7c0000 0x0 0x40000>; - clocks = <&cru SCLK_UPHY0_TCPDCORE>, - <&cru SCLK_UPHY0_TCPDPHY_REF>; - clock-names = "tcpdcore", "tcpdphy-ref"; - assigned-clocks = <&cru SCLK_UPHY0_TCPDCORE>; - assigned-clock-rates = <50000000>; - power-domains = <&power RK3399_PD_TCPD0>; - resets = <&cru SRST_UPHY0>, - <&cru SRST_UPHY0_PIPE_L00>, - <&cru SRST_P_UPHY0_TCPHY>; - reset-names = "uphy", "uphy-pipe", "uphy-tcphy"; - rockchip,grf = <&grf>; - status = "disabled"; - - tcphy0_dp: dp-port { - #phy-cells = <0>; - }; - - tcphy0_usb3: usb3-port { - #phy-cells = <0>; - }; - }; - - tcphy1: phy@ff800000 { - compatible = "rockchip,rk3399-typec-phy"; - reg = <0x0 0xff800000 0x0 0x40000>; - clocks = <&cru SCLK_UPHY1_TCPDCORE>, - <&cru SCLK_UPHY1_TCPDPHY_REF>; - clock-names = "tcpdcore", "tcpdphy-ref"; - assigned-clocks = <&cru SCLK_UPHY1_TCPDCORE>; - assigned-clock-rates = <50000000>; - power-domains = <&power RK3399_PD_TCPD1>; - resets = <&cru SRST_UPHY1>, - <&cru SRST_UPHY1_PIPE_L00>, - <&cru SRST_P_UPHY1_TCPHY>; - reset-names = "uphy", "uphy-pipe", "uphy-tcphy"; - rockchip,grf = <&grf>; - status = "disabled"; - - tcphy1_dp: dp-port { - #phy-cells = <0>; - }; - - tcphy1_usb3: usb3-port { - #phy-cells = <0>; - }; - }; - - watchdog@ff848000 { - compatible = "rockchip,rk3399-wdt", "snps,dw-wdt"; - reg = <0x0 0xff848000 0x0 0x100>; - clocks = <&cru PCLK_WDT>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>; - }; - - rktimer: rktimer@ff850000 { - compatible = "rockchip,rk3399-timer"; - reg = <0x0 0xff850000 0x0 0x1000>; - interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru PCLK_TIMER0>, <&cru SCLK_TIMER00>; - clock-names = "pclk", "timer"; - }; - - spdif: spdif@ff870000 { - compatible = "rockchip,rk3399-spdif"; - reg = <0x0 0xff870000 0x0 0x1000>; - interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_bus 7>; - dma-names = "tx"; - clock-names = "mclk", "hclk"; - clocks = <&cru SCLK_SPDIF_8CH>, <&cru HCLK_SPDIF>; - pinctrl-names = "default"; - pinctrl-0 = <&spdif_bus>; - power-domains = <&power RK3399_PD_SDIOAUDIO>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s0: i2s@ff880000 { - compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff880000 0x0 0x1000>; - rockchip,grf = <&grf>; - interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_bus 0>, <&dmac_bus 1>; - dma-names = "tx", "rx"; - clock-names = "i2s_clk", "i2s_hclk"; - clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>; - pinctrl-names = "bclk_on", "bclk_off"; - pinctrl-0 = <&i2s0_8ch_bus>; - pinctrl-1 = <&i2s0_8ch_bus_bclk_off>; - power-domains = <&power RK3399_PD_SDIOAUDIO>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s1: i2s@ff890000 { - compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff890000 0x0 0x1000>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_bus 2>, <&dmac_bus 3>; - dma-names = "tx", "rx"; - clock-names = "i2s_clk", "i2s_hclk"; - clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s1_2ch_bus>; - power-domains = <&power RK3399_PD_SDIOAUDIO>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s2: i2s@ff8a0000 { - compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s"; - reg = <0x0 0xff8a0000 0x0 0x1000>; - interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH 0>; - dmas = <&dmac_bus 4>, <&dmac_bus 5>; - dma-names = "tx", "rx"; - clock-names = "i2s_clk", "i2s_hclk"; - clocks = <&cru SCLK_I2S2_8CH>, <&cru HCLK_I2S2_8CH>; - power-domains = <&power RK3399_PD_SDIOAUDIO>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - vopl: vop@ff8f0000 { - compatible = "rockchip,rk3399-vop-lit"; - reg = <0x0 0xff8f0000 0x0 0x2000>, <0x0 0xff8f2000 0x0 0x400>; - interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>; - assigned-clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; - assigned-clock-rates = <400000000>, <100000000>; - clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - iommus = <&vopl_mmu>; - power-domains = <&power RK3399_PD_VOPL>; - resets = <&cru SRST_A_VOP1>, <&cru SRST_H_VOP1>, <&cru SRST_D_VOP1>; - reset-names = "axi", "ahb", "dclk"; - status = "disabled"; - - vopl_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vopl_out_mipi: endpoint@0 { - reg = <0>; - remote-endpoint = <&mipi_in_vopl>; - }; - - vopl_out_edp: endpoint@1 { - reg = <1>; - remote-endpoint = <&edp_in_vopl>; - }; - - vopl_out_hdmi: endpoint@2 { - reg = <2>; - remote-endpoint = <&hdmi_in_vopl>; - }; - - vopl_out_mipi1: endpoint@3 { - reg = <3>; - remote-endpoint = <&mipi1_in_vopl>; - }; - - vopl_out_dp: endpoint@4 { - reg = <4>; - remote-endpoint = <&dp_in_vopl>; - }; - }; - }; - - vopl_mmu: iommu@ff8f3f00 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff8f3f00 0x0 0x100>; - interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>; - clock-names = "aclk", "iface"; - power-domains = <&power RK3399_PD_VOPL>; - #iommu-cells = <0>; - status = "disabled"; - }; - - vopb: vop@ff900000 { - compatible = "rockchip,rk3399-vop-big"; - reg = <0x0 0xff900000 0x0 0x2000>, <0x0 0xff902000 0x0 0x1000>; - interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>; - assigned-clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; - assigned-clock-rates = <400000000>, <100000000>; - clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>; - clock-names = "aclk_vop", "dclk_vop", "hclk_vop"; - iommus = <&vopb_mmu>; - power-domains = <&power RK3399_PD_VOPB>; - resets = <&cru SRST_A_VOP0>, <&cru SRST_H_VOP0>, <&cru SRST_D_VOP0>; - reset-names = "axi", "ahb", "dclk"; - status = "disabled"; - - vopb_out: port { - #address-cells = <1>; - #size-cells = <0>; - - vopb_out_edp: endpoint@0 { - reg = <0>; - remote-endpoint = <&edp_in_vopb>; - }; - - vopb_out_mipi: endpoint@1 { - reg = <1>; - remote-endpoint = <&mipi_in_vopb>; - }; - - vopb_out_hdmi: endpoint@2 { - reg = <2>; - remote-endpoint = <&hdmi_in_vopb>; - }; - - vopb_out_mipi1: endpoint@3 { - reg = <3>; - remote-endpoint = <&mipi1_in_vopb>; - }; - - vopb_out_dp: endpoint@4 { - reg = <4>; - remote-endpoint = <&dp_in_vopb>; - }; - }; - }; - - vopb_mmu: iommu@ff903f00 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff903f00 0x0 0x100>; - interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>; - clock-names = "aclk", "iface"; - power-domains = <&power RK3399_PD_VOPB>; - #iommu-cells = <0>; - status = "disabled"; - }; - - isp0: isp0@ff910000 { - compatible = "rockchip,rk3399-cif-isp"; - reg = <0x0 0xff910000 0x0 0x4000>; - interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_ISP0>, - <&cru ACLK_ISP0_WRAPPER>, - <&cru HCLK_ISP0_WRAPPER>; - clock-names = "isp", "aclk", "hclk"; - iommus = <&isp0_mmu>; - phys = <&mipi_dphy_rx0>; - phy-names = "dphy"; - power-domains = <&power RK3399_PD_ISP0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - }; - - isp0_mmu: iommu@ff914000 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>; - interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_ISP0_WRAPPER>, <&cru HCLK_ISP0_WRAPPER>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - power-domains = <&power RK3399_PD_ISP0>; - rockchip,disable-mmu-reset; - }; - - isp1: isp1@ff920000 { - compatible = "rockchip,rk3399-cif-isp"; - reg = <0x0 0xff920000 0x0 0x4000>; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_ISP1>, - <&cru ACLK_ISP1_WRAPPER>, - <&cru HCLK_ISP1_WRAPPER>; - clock-names = "isp", "aclk", "hclk"; - iommus = <&isp1_mmu>; - phys = <&mipi_dsi1>; - phy-names = "dphy"; - power-domains = <&power RK3399_PD_ISP1>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - }; - - isp1_mmu: iommu@ff924000 { - compatible = "rockchip,iommu"; - reg = <0x0 0xff924000 0x0 0x100>, <0x0 0xff925000 0x0 0x100>; - interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru ACLK_ISP1_WRAPPER>, <&cru HCLK_ISP1_WRAPPER>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - power-domains = <&power RK3399_PD_ISP1>; - rockchip,disable-mmu-reset; - }; - - hdmi_sound: hdmi-sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - simple-audio-card,name = "hdmi-sound"; - status = "disabled"; - - simple-audio-card,cpu { - sound-dai = <&i2s2>; - }; - simple-audio-card,codec { - sound-dai = <&hdmi>; - }; - }; - - hdmi: hdmi@ff940000 { - compatible = "rockchip,rk3399-dw-hdmi"; - reg = <0x0 0xff940000 0x0 0x20000>; - interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru PCLK_HDMI_CTRL>, - <&cru SCLK_HDMI_SFR>, - <&cru SCLK_HDMI_CEC>, - <&cru PCLK_VIO_GRF>, - <&cru PLL_VPLL>; - clock-names = "iahb", "isfr", "cec", "grf", "ref"; - power-domains = <&power RK3399_PD_HDCP>; - reg-io-width = <4>; - rockchip,grf = <&grf>; - #sound-dai-cells = <0>; - status = "disabled"; - - ports { - hdmi_in: port { - #address-cells = <1>; - #size-cells = <0>; - - hdmi_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_hdmi>; - }; - hdmi_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_hdmi>; - }; - }; - }; - }; - - mipi_dsi: dsi@ff960000 { - compatible = "rockchip,rk3399-mipi-dsi", "snps,dw-mipi-dsi"; - reg = <0x0 0xff960000 0x0 0x8000>; - interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_DPHY_PLL>, <&cru PCLK_MIPI_DSI0>, - <&cru SCLK_DPHY_TX0_CFG>, <&cru PCLK_VIO_GRF>; - clock-names = "ref", "pclk", "phy_cfg", "grf"; - power-domains = <&power RK3399_PD_VIO>; - resets = <&cru SRST_P_MIPI_DSI0>; - reset-names = "apb"; - rockchip,grf = <&grf>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - mipi_in: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - - mipi_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_mipi>; - }; - - mipi_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_mipi>; - }; - }; - - mipi_out: port@1 { - reg = <1>; - }; - }; - }; - - mipi_dsi1: dsi@ff968000 { - compatible = "rockchip,rk3399-mipi-dsi", "snps,dw-mipi-dsi"; - reg = <0x0 0xff968000 0x0 0x8000>; - interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_DPHY_PLL>, <&cru PCLK_MIPI_DSI1>, - <&cru SCLK_DPHY_TX1RX1_CFG>, <&cru PCLK_VIO_GRF>; - clock-names = "ref", "pclk", "phy_cfg", "grf"; - power-domains = <&power RK3399_PD_VIO>; - resets = <&cru SRST_P_MIPI_DSI1>; - reset-names = "apb"; - rockchip,grf = <&grf>; - #address-cells = <1>; - #size-cells = <0>; - #phy-cells = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - mipi1_in: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - - mipi1_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_mipi1>; - }; - - mipi1_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_mipi1>; - }; - }; - - mipi1_out: port@1 { - reg = <1>; - }; - }; - }; - - edp: dp@ff970000 { - compatible = "rockchip,rk3399-edp"; - reg = <0x0 0xff970000 0x0 0x8000>; - interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru PCLK_EDP>, <&cru PCLK_EDP_CTRL>, <&cru PCLK_VIO_GRF>; - clock-names = "dp", "pclk", "grf"; - pinctrl-names = "default"; - pinctrl-0 = <&edp_hpd>; - power-domains = <&power RK3399_PD_EDP>; - resets = <&cru SRST_P_EDP_CTRL>; - reset-names = "dp"; - rockchip,grf = <&grf>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - edp_in: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - - edp_in_vopb: endpoint@0 { - reg = <0>; - remote-endpoint = <&vopb_out_edp>; - }; - - edp_in_vopl: endpoint@1 { - reg = <1>; - remote-endpoint = <&vopl_out_edp>; - }; - }; - - edp_out: port@1 { - reg = <1>; - }; - }; - }; - - gpu: gpu@ff9a0000 { - compatible = "rockchip,rk3399-mali", "arm,mali-t860"; - reg = <0x0 0xff9a0000 0x0 0x10000>; - interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>, - <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH 0>; - interrupt-names = "job", "mmu", "gpu"; - clocks = <&cru ACLK_GPU>; - #cooling-cells = <2>; - dynamic-power-coefficient = <2640>; - power-domains = <&power RK3399_PD_GPU>; - status = "disabled"; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rk3399-pinctrl"; - rockchip,grf = <&grf>; - rockchip,pmu = <&pmugrf>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio0: gpio@ff720000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff720000 0x0 0x100>; - clocks = <&pmucru PCLK_GPIO0_PMU>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH 0>; - - gpio-controller; - #gpio-cells = <0x2>; - - interrupt-controller; - #interrupt-cells = <0x2>; - }; - - gpio1: gpio@ff730000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff730000 0x0 0x100>; - clocks = <&pmucru PCLK_GPIO1_PMU>; - interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH 0>; - - gpio-controller; - #gpio-cells = <0x2>; - - interrupt-controller; - #interrupt-cells = <0x2>; - }; - - gpio2: gpio@ff780000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff780000 0x0 0x100>; - clocks = <&cru PCLK_GPIO2>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH 0>; - - gpio-controller; - #gpio-cells = <0x2>; - - interrupt-controller; - #interrupt-cells = <0x2>; - }; - - gpio3: gpio@ff788000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff788000 0x0 0x100>; - clocks = <&cru PCLK_GPIO3>; - interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH 0>; - - gpio-controller; - #gpio-cells = <0x2>; - - interrupt-controller; - #interrupt-cells = <0x2>; - }; - - gpio4: gpio@ff790000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xff790000 0x0 0x100>; - clocks = <&cru PCLK_GPIO4>; - interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH 0>; - - gpio-controller; - #gpio-cells = <0x2>; - - interrupt-controller; - #interrupt-cells = <0x2>; - }; - - pcfg_pull_up: pcfg-pull-up { - bias-pull-up; - }; - - pcfg_pull_down: pcfg-pull-down { - bias-pull-down; - }; - - pcfg_pull_none: pcfg-pull-none { - bias-disable; - }; - - pcfg_pull_none_12ma: pcfg-pull-none-12ma { - bias-disable; - drive-strength = <12>; - }; - - pcfg_pull_none_13ma: pcfg-pull-none-13ma { - bias-disable; - drive-strength = <13>; - }; - - pcfg_pull_none_18ma: pcfg-pull-none-18ma { - bias-disable; - drive-strength = <18>; - }; - - pcfg_pull_none_20ma: pcfg-pull-none-20ma { - bias-disable; - drive-strength = <20>; - }; - - pcfg_pull_up_2ma: pcfg-pull-up-2ma { - bias-pull-up; - drive-strength = <2>; - }; - - pcfg_pull_up_8ma: pcfg-pull-up-8ma { - bias-pull-up; - drive-strength = <8>; - }; - - pcfg_pull_up_18ma: pcfg-pull-up-18ma { - bias-pull-up; - drive-strength = <18>; - }; - - pcfg_pull_up_20ma: pcfg-pull-up-20ma { - bias-pull-up; - drive-strength = <20>; - }; - - pcfg_pull_down_4ma: pcfg-pull-down-4ma { - bias-pull-down; - drive-strength = <4>; - }; - - pcfg_pull_down_8ma: pcfg-pull-down-8ma { - bias-pull-down; - drive-strength = <8>; - }; - - pcfg_pull_down_12ma: pcfg-pull-down-12ma { - bias-pull-down; - drive-strength = <12>; - }; - - pcfg_pull_down_18ma: pcfg-pull-down-18ma { - bias-pull-down; - drive-strength = <18>; - }; - - pcfg_pull_down_20ma: pcfg-pull-down-20ma { - bias-pull-down; - drive-strength = <20>; - }; - - pcfg_output_high: pcfg-output-high { - output-high; - }; - - pcfg_output_low: pcfg-output-low { - output-low; - }; - - pcfg_input_enable: pcfg-input-enable { - input-enable; - }; - - pcfg_input_pull_up: pcfg-input-pull-up { - input-enable; - bias-pull-up; - }; - - pcfg_input_pull_down: pcfg-input-pull-down { - input-enable; - bias-pull-down; - }; - - clock { - clk_32k: clk-32k { - rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>; - }; - }; - - cif { - cif_clkin: cif-clkin { - rockchip,pins = - <2 RK_PB2 3 &pcfg_pull_none>; - }; - - cif_clkouta: cif-clkouta { - rockchip,pins = - <2 RK_PB3 3 &pcfg_pull_none>; - }; - }; - - edp { - edp_hpd: edp-hpd { - rockchip,pins = - <4 RK_PC7 2 &pcfg_pull_none>; - }; - }; - - gmac { - rgmii_pins: rgmii-pins { - rockchip,pins = - /* mac_txclk */ - <3 RK_PC1 1 &pcfg_pull_none_13ma>, - /* mac_rxclk */ - <3 RK_PB6 1 &pcfg_pull_none>, - /* mac_mdio */ - <3 RK_PB5 1 &pcfg_pull_none>, - /* mac_txen */ - <3 RK_PB4 1 &pcfg_pull_none_13ma>, - /* mac_clk */ - <3 RK_PB3 1 &pcfg_pull_none>, - /* mac_rxdv */ - <3 RK_PB1 1 &pcfg_pull_none>, - /* mac_mdc */ - <3 RK_PB0 1 &pcfg_pull_none>, - /* mac_rxd1 */ - <3 RK_PA7 1 &pcfg_pull_none>, - /* mac_rxd0 */ - <3 RK_PA6 1 &pcfg_pull_none>, - /* mac_txd1 */ - <3 RK_PA5 1 &pcfg_pull_none_13ma>, - /* mac_txd0 */ - <3 RK_PA4 1 &pcfg_pull_none_13ma>, - /* mac_rxd3 */ - <3 RK_PA3 1 &pcfg_pull_none>, - /* mac_rxd2 */ - <3 RK_PA2 1 &pcfg_pull_none>, - /* mac_txd3 */ - <3 RK_PA1 1 &pcfg_pull_none_13ma>, - /* mac_txd2 */ - <3 RK_PA0 1 &pcfg_pull_none_13ma>; - }; - - rmii_pins: rmii-pins { - rockchip,pins = - /* mac_mdio */ - <3 RK_PB5 1 &pcfg_pull_none>, - /* mac_txen */ - <3 RK_PB4 1 &pcfg_pull_none_13ma>, - /* mac_clk */ - <3 RK_PB3 1 &pcfg_pull_none>, - /* mac_rxer */ - <3 RK_PB2 1 &pcfg_pull_none>, - /* mac_rxdv */ - <3 RK_PB1 1 &pcfg_pull_none>, - /* mac_mdc */ - <3 RK_PB0 1 &pcfg_pull_none>, - /* mac_rxd1 */ - <3 RK_PA7 1 &pcfg_pull_none>, - /* mac_rxd0 */ - <3 RK_PA6 1 &pcfg_pull_none>, - /* mac_txd1 */ - <3 RK_PA5 1 &pcfg_pull_none_13ma>, - /* mac_txd0 */ - <3 RK_PA4 1 &pcfg_pull_none_13ma>; - }; - }; - - i2c0 { - i2c0_xfer: i2c0-xfer { - rockchip,pins = - <1 RK_PB7 2 &pcfg_pull_none>, - <1 RK_PC0 2 &pcfg_pull_none>; - }; - }; - - i2c1 { - i2c1_xfer: i2c1-xfer { - rockchip,pins = - <4 RK_PA2 1 &pcfg_pull_none>, - <4 RK_PA1 1 &pcfg_pull_none>; - }; - }; - - i2c2 { - i2c2_xfer: i2c2-xfer { - rockchip,pins = - <2 RK_PA1 2 &pcfg_pull_none_12ma>, - <2 RK_PA0 2 &pcfg_pull_none_12ma>; - }; - }; - - i2c3 { - i2c3_xfer: i2c3-xfer { - rockchip,pins = - <4 RK_PC1 1 &pcfg_pull_none>, - <4 RK_PC0 1 &pcfg_pull_none>; - }; - }; - - i2c4 { - i2c4_xfer: i2c4-xfer { - rockchip,pins = - <1 RK_PB4 1 &pcfg_pull_none>, - <1 RK_PB3 1 &pcfg_pull_none>; - }; - }; - - i2c5 { - i2c5_xfer: i2c5-xfer { - rockchip,pins = - <3 RK_PB3 2 &pcfg_pull_none>, - <3 RK_PB2 2 &pcfg_pull_none>; - }; - }; - - i2c6 { - i2c6_xfer: i2c6-xfer { - rockchip,pins = - <2 RK_PB2 2 &pcfg_pull_none>, - <2 RK_PB1 2 &pcfg_pull_none>; - }; - }; - - i2c7 { - i2c7_xfer: i2c7-xfer { - rockchip,pins = - <2 RK_PB0 2 &pcfg_pull_none>, - <2 RK_PA7 2 &pcfg_pull_none>; - }; - }; - - i2c8 { - i2c8_xfer: i2c8-xfer { - rockchip,pins = - <1 RK_PC5 1 &pcfg_pull_none>, - <1 RK_PC4 1 &pcfg_pull_none>; - }; - }; - - i2s0 { - i2s0_2ch_bus: i2s0-2ch-bus { - rockchip,pins = - <3 RK_PD0 1 &pcfg_pull_none>, - <3 RK_PD1 1 &pcfg_pull_none>, - <3 RK_PD2 1 &pcfg_pull_none>, - <3 RK_PD3 1 &pcfg_pull_none>, - <3 RK_PD7 1 &pcfg_pull_none>, - <4 RK_PA0 1 &pcfg_pull_none>; - }; - - i2s0_2ch_bus_bclk_off: i2s0-2ch-bus-bclk-off { - rockchip,pins = - <3 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>, - <3 RK_PD1 1 &pcfg_pull_none>, - <3 RK_PD2 1 &pcfg_pull_none>, - <3 RK_PD3 1 &pcfg_pull_none>, - <3 RK_PD7 1 &pcfg_pull_none>, - <4 RK_PA0 1 &pcfg_pull_none>; - }; - - i2s0_8ch_bus: i2s0-8ch-bus { - rockchip,pins = - <3 RK_PD0 1 &pcfg_pull_none>, - <3 RK_PD1 1 &pcfg_pull_none>, - <3 RK_PD2 1 &pcfg_pull_none>, - <3 RK_PD3 1 &pcfg_pull_none>, - <3 RK_PD4 1 &pcfg_pull_none>, - <3 RK_PD5 1 &pcfg_pull_none>, - <3 RK_PD6 1 &pcfg_pull_none>, - <3 RK_PD7 1 &pcfg_pull_none>, - <4 RK_PA0 1 &pcfg_pull_none>; - }; - - i2s0_8ch_bus_bclk_off: i2s0-8ch-bus-bclk-off { - rockchip,pins = - <3 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>, - <3 RK_PD1 1 &pcfg_pull_none>, - <3 RK_PD2 1 &pcfg_pull_none>, - <3 RK_PD3 1 &pcfg_pull_none>, - <3 RK_PD4 1 &pcfg_pull_none>, - <3 RK_PD5 1 &pcfg_pull_none>, - <3 RK_PD6 1 &pcfg_pull_none>, - <3 RK_PD7 1 &pcfg_pull_none>, - <4 RK_PA0 1 &pcfg_pull_none>; - }; - }; - - i2s1 { - i2s1_2ch_bus: i2s1-2ch-bus { - rockchip,pins = - <4 RK_PA3 1 &pcfg_pull_none>, - <4 RK_PA4 1 &pcfg_pull_none>, - <4 RK_PA5 1 &pcfg_pull_none>, - <4 RK_PA6 1 &pcfg_pull_none>, - <4 RK_PA7 1 &pcfg_pull_none>; - }; - - i2s1_2ch_bus_bclk_off: i2s1-2ch-bus-bclk-off { - rockchip,pins = - <4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>, - <4 RK_PA4 1 &pcfg_pull_none>, - <4 RK_PA5 1 &pcfg_pull_none>, - <4 RK_PA6 1 &pcfg_pull_none>, - <4 RK_PA7 1 &pcfg_pull_none>; - }; - }; - - sdio0 { - sdio0_bus1: sdio0-bus1 { - rockchip,pins = - <2 RK_PC4 1 &pcfg_pull_up>; - }; - - sdio0_bus4: sdio0-bus4 { - rockchip,pins = - <2 RK_PC4 1 &pcfg_pull_up>, - <2 RK_PC5 1 &pcfg_pull_up>, - <2 RK_PC6 1 &pcfg_pull_up>, - <2 RK_PC7 1 &pcfg_pull_up>; - }; - - sdio0_cmd: sdio0-cmd { - rockchip,pins = - <2 RK_PD0 1 &pcfg_pull_up>; - }; - - sdio0_clk: sdio0-clk { - rockchip,pins = - <2 RK_PD1 1 &pcfg_pull_none>; - }; - - sdio0_cd: sdio0-cd { - rockchip,pins = - <2 RK_PD2 1 &pcfg_pull_up>; - }; - - sdio0_pwr: sdio0-pwr { - rockchip,pins = - <2 RK_PD3 1 &pcfg_pull_up>; - }; - - sdio0_bkpwr: sdio0-bkpwr { - rockchip,pins = - <2 RK_PD4 1 &pcfg_pull_up>; - }; - - sdio0_wp: sdio0-wp { - rockchip,pins = - <0 RK_PA3 1 &pcfg_pull_up>; - }; - - sdio0_int: sdio0-int { - rockchip,pins = - <0 RK_PA4 1 &pcfg_pull_up>; - }; - }; - - sdmmc { - sdmmc_bus1: sdmmc-bus1 { - rockchip,pins = - <4 RK_PB0 1 &pcfg_pull_up>; - }; - - sdmmc_bus4: sdmmc-bus4 { - rockchip,pins = - <4 RK_PB0 1 &pcfg_pull_up>, - <4 RK_PB1 1 &pcfg_pull_up>, - <4 RK_PB2 1 &pcfg_pull_up>, - <4 RK_PB3 1 &pcfg_pull_up>; - }; - - sdmmc_clk: sdmmc-clk { - rockchip,pins = - <4 RK_PB4 1 &pcfg_pull_none>; - }; - - sdmmc_cmd: sdmmc-cmd { - rockchip,pins = - <4 RK_PB5 1 &pcfg_pull_up>; - }; - - sdmmc_cd: sdmmc-cd { - rockchip,pins = - <0 RK_PA7 1 &pcfg_pull_up>; - }; - - sdmmc_wp: sdmmc-wp { - rockchip,pins = - <0 RK_PB0 1 &pcfg_pull_up>; - }; - }; - - suspend { - ap_pwroff: ap-pwroff { - rockchip,pins = <1 RK_PA5 1 &pcfg_pull_none>; - }; - - ddrio_pwroff: ddrio-pwroff { - rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>; - }; - }; - - spdif { - spdif_bus: spdif-bus { - rockchip,pins = - <4 RK_PC5 1 &pcfg_pull_none>; - }; - - spdif_bus_1: spdif-bus-1 { - rockchip,pins = - <3 RK_PC0 3 &pcfg_pull_none>; - }; - }; - - spi0 { - spi0_clk: spi0-clk { - rockchip,pins = - <3 RK_PA6 2 &pcfg_pull_up>; - }; - spi0_cs0: spi0-cs0 { - rockchip,pins = - <3 RK_PA7 2 &pcfg_pull_up>; - }; - spi0_cs1: spi0-cs1 { - rockchip,pins = - <3 RK_PB0 2 &pcfg_pull_up>; - }; - spi0_tx: spi0-tx { - rockchip,pins = - <3 RK_PA5 2 &pcfg_pull_up>; - }; - spi0_rx: spi0-rx { - rockchip,pins = - <3 RK_PA4 2 &pcfg_pull_up>; - }; - }; - - spi1 { - spi1_clk: spi1-clk { - rockchip,pins = - <1 RK_PB1 2 &pcfg_pull_up>; - }; - spi1_cs0: spi1-cs0 { - rockchip,pins = - <1 RK_PB2 2 &pcfg_pull_up>; - }; - spi1_rx: spi1-rx { - rockchip,pins = - <1 RK_PA7 2 &pcfg_pull_up>; - }; - spi1_tx: spi1-tx { - rockchip,pins = - <1 RK_PB0 2 &pcfg_pull_up>; - }; - }; - - spi2 { - spi2_clk: spi2-clk { - rockchip,pins = - <2 RK_PB3 1 &pcfg_pull_up>; - }; - spi2_cs0: spi2-cs0 { - rockchip,pins = - <2 RK_PB4 1 &pcfg_pull_up>; - }; - spi2_rx: spi2-rx { - rockchip,pins = - <2 RK_PB1 1 &pcfg_pull_up>; - }; - spi2_tx: spi2-tx { - rockchip,pins = - <2 RK_PB2 1 &pcfg_pull_up>; - }; - }; - - spi3 { - spi3_clk: spi3-clk { - rockchip,pins = - <1 RK_PC1 1 &pcfg_pull_up>; - }; - spi3_cs0: spi3-cs0 { - rockchip,pins = - <1 RK_PC2 1 &pcfg_pull_up>; - }; - spi3_rx: spi3-rx { - rockchip,pins = - <1 RK_PB7 1 &pcfg_pull_up>; - }; - spi3_tx: spi3-tx { - rockchip,pins = - <1 RK_PC0 1 &pcfg_pull_up>; - }; - }; - - spi4 { - spi4_clk: spi4-clk { - rockchip,pins = - <3 RK_PA2 2 &pcfg_pull_up>; - }; - spi4_cs0: spi4-cs0 { - rockchip,pins = - <3 RK_PA3 2 &pcfg_pull_up>; - }; - spi4_rx: spi4-rx { - rockchip,pins = - <3 RK_PA0 2 &pcfg_pull_up>; - }; - spi4_tx: spi4-tx { - rockchip,pins = - <3 RK_PA1 2 &pcfg_pull_up>; - }; - }; - - spi5 { - spi5_clk: spi5-clk { - rockchip,pins = - <2 RK_PC6 2 &pcfg_pull_up>; - }; - spi5_cs0: spi5-cs0 { - rockchip,pins = - <2 RK_PC7 2 &pcfg_pull_up>; - }; - spi5_rx: spi5-rx { - rockchip,pins = - <2 RK_PC4 2 &pcfg_pull_up>; - }; - spi5_tx: spi5-tx { - rockchip,pins = - <2 RK_PC5 2 &pcfg_pull_up>; - }; - }; - - testclk { - test_clkout0: test-clkout0 { - rockchip,pins = - <0 RK_PA0 1 &pcfg_pull_none>; - }; - - test_clkout1: test-clkout1 { - rockchip,pins = - <2 RK_PD1 2 &pcfg_pull_none>; - }; - - test_clkout2: test-clkout2 { - rockchip,pins = - <0 RK_PB0 3 &pcfg_pull_none>; - }; - }; - - tsadc { - otp_pin: otp-pin { - rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - otp_out: otp-out { - rockchip,pins = <1 RK_PA6 1 &pcfg_pull_none>; - }; - }; - - uart0 { - uart0_xfer: uart0-xfer { - rockchip,pins = - <2 RK_PC0 1 &pcfg_pull_up>, - <2 RK_PC1 1 &pcfg_pull_none>; - }; - - uart0_cts: uart0-cts { - rockchip,pins = - <2 RK_PC2 1 &pcfg_pull_none>; - }; - - uart0_rts: uart0-rts { - rockchip,pins = - <2 RK_PC3 1 &pcfg_pull_none>; - }; - }; - - uart1 { - uart1_xfer: uart1-xfer { - rockchip,pins = - <3 RK_PB4 2 &pcfg_pull_up>, - <3 RK_PB5 2 &pcfg_pull_none>; - }; - }; - - uart2a { - uart2a_xfer: uart2a-xfer { - rockchip,pins = - <4 RK_PB0 2 &pcfg_pull_up>, - <4 RK_PB1 2 &pcfg_pull_none>; - }; - }; - - uart2b { - uart2b_xfer: uart2b-xfer { - rockchip,pins = - <4 RK_PC0 2 &pcfg_pull_up>, - <4 RK_PC1 2 &pcfg_pull_none>; - }; - }; - - uart2c { - uart2c_xfer: uart2c-xfer { - rockchip,pins = - <4 RK_PC3 1 &pcfg_pull_up>, - <4 RK_PC4 1 &pcfg_pull_none>; - }; - }; - - uart3 { - uart3_xfer: uart3-xfer { - rockchip,pins = - <3 RK_PB6 2 &pcfg_pull_up>, - <3 RK_PB7 2 &pcfg_pull_none>; - }; - - uart3_cts: uart3-cts { - rockchip,pins = - <3 RK_PC0 2 &pcfg_pull_none>; - }; - - uart3_rts: uart3-rts { - rockchip,pins = - <3 RK_PC1 2 &pcfg_pull_none>; - }; - }; - - uart4 { - uart4_xfer: uart4-xfer { - rockchip,pins = - <1 RK_PA7 1 &pcfg_pull_up>, - <1 RK_PB0 1 &pcfg_pull_none>; - }; - }; - - uarthdcp { - uarthdcp_xfer: uarthdcp-xfer { - rockchip,pins = - <4 RK_PC5 2 &pcfg_pull_up>, - <4 RK_PC6 2 &pcfg_pull_none>; - }; - }; - - pwm0 { - pwm0_pin: pwm0-pin { - rockchip,pins = - <4 RK_PC2 1 &pcfg_pull_none>; - }; - - pwm0_pin_pull_down: pwm0-pin-pull-down { - rockchip,pins = - <4 RK_PC2 1 &pcfg_pull_down>; - }; - - vop0_pwm_pin: vop0-pwm-pin { - rockchip,pins = - <4 RK_PC2 2 &pcfg_pull_none>; - }; - - vop1_pwm_pin: vop1-pwm-pin { - rockchip,pins = - <4 RK_PC2 3 &pcfg_pull_none>; - }; - }; - - pwm1 { - pwm1_pin: pwm1-pin { - rockchip,pins = - <4 RK_PC6 1 &pcfg_pull_none>; - }; - - pwm1_pin_pull_down: pwm1-pin-pull-down { - rockchip,pins = - <4 RK_PC6 1 &pcfg_pull_down>; - }; - }; - - pwm2 { - pwm2_pin: pwm2-pin { - rockchip,pins = - <1 RK_PC3 1 &pcfg_pull_none>; - }; - - pwm2_pin_pull_down: pwm2-pin-pull-down { - rockchip,pins = - <1 RK_PC3 1 &pcfg_pull_down>; - }; - }; - - pwm3a { - pwm3a_pin: pwm3a-pin { - rockchip,pins = - <0 RK_PA6 1 &pcfg_pull_none>; - }; - }; - - pwm3b { - pwm3b_pin: pwm3b-pin { - rockchip,pins = - <1 RK_PB6 1 &pcfg_pull_none>; - }; - }; - - hdmi { - hdmi_i2c_xfer: hdmi-i2c-xfer { - rockchip,pins = - <4 RK_PC1 3 &pcfg_pull_none>, - <4 RK_PC0 3 &pcfg_pull_none>; - }; - - hdmi_cec: hdmi-cec { - rockchip,pins = - <4 RK_PC7 1 &pcfg_pull_none>; - }; - }; - - pcie { - pcie_clkreqn_cpm: pci-clkreqn-cpm { - rockchip,pins = - <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_clkreqnb_cpm: pci-clkreqnb-cpm { - rockchip,pins = - <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - }; -}; diff --git a/arch/arm/dts/rk3399pro-rock-pi-n10.dts b/arch/arm/dts/rk3399pro-rock-pi-n10.dts deleted file mode 100644 index bf026786fa92..000000000000 --- a/arch/arm/dts/rk3399pro-rock-pi-n10.dts +++ /dev/null @@ -1,22 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * Copyright (c) 2019 Radxa Limited - * Copyright (c) 2019 Amarula Solutions(India) - */ - -/dts-v1/; -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" -#include <rockchip-radxa-dalang-carrier.dtsi> -#include "rk3399pro-vmarc-som.dtsi" - -/ { - model = "Radxa ROCK Pi N10"; - compatible = "radxa,rockpi-n10", "vamrs,rk3399pro-vmarc-som", - "rockchip,rk3399pro"; - - chosen { - stdout-path = "serial2:1500000n8"; - }; -}; diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi deleted file mode 100644 index 8823c924dc1d..000000000000 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ /dev/null @@ -1,477 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd - * Copyright (c) 2019 Vamrs Limited - * Copyright (c) 2019 Amarula Solutions(India) - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/pwm/pwm.h> - -/ { - compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro"; - - aliases { - ethernet0 = &gmac; - mmc0 = &sdhci; - mmc1 = &sdmmc; - }; - - vcc3v3_pcie: vcc-pcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PD4 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_pwr>; - regulator-name = "vcc3v3_pcie"; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&cpu_l0 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l1 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l2 { - cpu-supply = <&vdd_cpu_l>; -}; - -&cpu_l3 { - cpu-supply = <&vdd_cpu_l>; -}; - -&emmc_phy { - status = "okay"; -}; - -&gmac { - assigned-clocks = <&cru SCLK_RMII_SRC>; - phy-supply = <&vcc_lan>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; -}; - -&hdmi { - ddc-i2c-bus = <&i2c3>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmi_cec>; -}; - -&i2c0 { - clock-frequency = <400000>; - i2c-scl-falling-time-ns = <30>; - i2c-scl-rising-time-ns = <180>; - status = "okay"; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio1>; - interrupts = <RK_PC2 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc5v0_sys>; - vcc2-supply = <&vcc5v0_sys>; - vcc3-supply = <&vcc5v0_sys>; - vcc4-supply = <&vcc5v0_sys>; - vcc5-supply = <&vcc_buck5>; - vcc6-supply = <&vcc_buck5>; - vcc7-supply = <&vcc5v0_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc5v0_sys>; - - regulators { - vdd_log: DCDC_REG1 { - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_cpu_l: DCDC_REG2 { - regulator-name = "vdd_cpu_l"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <750000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_sys: DCDC_REG4 { - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_buck5: DCDC_REG5 { - regulator-name = "vcc_buck5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2200000>; - regulator-max-microvolt = <2200000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <2200000>; - }; - }; - - vcca_0v9: LDO_REG1 { - regulator-name = "vcca_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vcc_1v8: LDO_REG2 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_0v9: LDO_REG3 { - regulator-name = "vcc_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vcca_1v8: LDO_REG4 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1850000>; - regulator-max-microvolt = <1850000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1850000>; - }; - }; - - /* - * As per BSP, but schematic not showing any regulator - * pin for LD05. - */ - vdd1v5_dvp: LDO_REG5 { - regulator-name = "vdd1v5_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v5: LDO_REG6 { - regulator-name = "vcc_1v5"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1500000>; - regulator-max-microvolt = <1500000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_3v0: LDO_REG7 { - regulator-name = "vccio_3v0"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3000000>; - regulator-max-microvolt = <3000000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG8 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - /* - * As per BSP, but schematic not showing any regulator - * pin for LD09. - */ - vcc_sd: LDO_REG9 { - regulator-name = "vcc_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc5v0_usb2: SWITCH_REG1 { - regulator-name = "vcc5v0_usb2"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <5000000>; - }; - }; - - vccio_3v3: vcc_lan: SWITCH_REG2 { - regulator-name = "vccio_3v3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&i2c1 { - i2c-scl-falling-time-ns = <30>; - i2c-scl-rising-time-ns = <140>; - status = "okay"; -}; - -&i2c2 { - clock-frequency = <400000>; - status = "okay"; - - hym8563: rtc@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - #clock-cells = <0>; - clock-output-names = "hym8563"; - pinctrl-names = "default"; - pinctrl-0 = <&hym8563_int>; - interrupt-parent = <&gpio4>; - interrupts = <RK_PD6 IRQ_TYPE_LEVEL_LOW>; - }; -}; - -&i2c3 { - i2c-scl-rising-time-ns = <450>; - i2c-scl-falling-time-ns = <15>; - status = "okay"; -}; - -&io_domains { - status = "okay"; - bt656-supply = <&vcca_1v8>; - gpio1830-supply = <&vccio_3v0>; - sdmmc-supply = <&vccio_sd>; -}; - -&pcie_phy { - status = "okay"; -}; - -&pcie0 { - ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-0 = <&pcie_clkreqnb_cpm>; - pinctrl-names = "default"; - vpcie0v9-supply = <&vcca_0v9>; /* VCC_0V9_S0 */ - vpcie1v8-supply = <&vcca_1v8>; /* VCC_1V8_S0 */ - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pinctrl { - hym8563 { - hym8563_int: hym8563-int { - rockchip,pins = <4 RK_PD6 0 &pcfg_pull_up>; - }; - }; - - pcie { - pcie_pwr: pcie-pwr { - rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <1 RK_PC2 0 &pcfg_pull_up>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - vbus_host { - usb1_en_oc: usb1-en-oc { - rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - vbus_typec { - usb0_en_oc: usb0-en-oc { - rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&pmu_io_domains { - status = "okay"; - pmu1830-supply = <&vcc_1v8>; -}; - -&sdio_pwrseq { - /* - * On the module itself this is one of these (depending - * on the actual card populated): - * - SDIO_RESET_L_WL_REG_ON - * - PDN (power down when low) - */ - reset-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>; -}; - -&sdhci { - bus-width = <8>; - mmc-hs400-1_8v; - mmc-hs400-enhanced-strobe; - non-removable; - status = "okay"; -}; - -&sdmmc { - cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>; - max-frequency = <150000000>; -}; - -&tcphy0 { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <1>; - status = "okay"; -}; - -&u2phy0 { - status = "okay"; - - u2phy0_otg: otg-port { - phy-supply = <&vbus_typec>; - status = "okay"; - }; - - u2phy0_host: host-port { - phy-supply = <&vbus_host>; - status = "okay"; - }; -}; - - -&u2phy1 { - status = "okay"; - - u2phy1_host: host-port { - phy-supply = <&vbus_host>; - status = "okay"; - }; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usbdrd3_0 { - status = "okay"; -}; - -&usbdrd_dwc3_0 { - status = "okay"; -}; - -&vbus_host { - enable-active-high; - gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; /* USB1_EN_OC# */ - pinctrl-names = "default"; - pinctrl-0 = <&usb1_en_oc>; -}; - -&vbus_typec { - enable-active-high; - gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; /* USB0_EN_OC# */ - pinctrl-names = "default"; - pinctrl-0 = <&usb0_en_oc>; -}; diff --git a/arch/arm/dts/rk3399pro.dtsi b/arch/arm/dts/rk3399pro.dtsi deleted file mode 100644 index bb5ebf6608b9..000000000000 --- a/arch/arm/dts/rk3399pro.dtsi +++ /dev/null @@ -1,22 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -// Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd. - -#include "rk3399.dtsi" - -/ { - compatible = "rockchip,rk3399pro"; -}; - -/* Default to enabled since AP talk to NPU part over pcie */ -&pcie_phy { - status = "okay"; -}; - -/* Default to enabled since AP talk to NPU part over pcie */ -&pcie0 { - ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; - num-lanes = <4>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_clkreqn_cpm>; - status = "okay"; -}; diff --git a/doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt b/doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt deleted file mode 100644 index 4a56f78f555b..000000000000 --- a/doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt +++ /dev/null @@ -1,42 +0,0 @@ -Rockchip Dynamic Memory Controller Driver -Required properties: -- compatible: "rockchip,rk3399-dmc", "syscon" -- rockchip,cru: this driver should access cru regs, so need get cru here -- rockchip,pmucru: this driver should access pmucru regs, so need get pmucru here -- rockchip,pmugrf: this driver should access pmugrf regs, so need get pmugrf here -- rockchip,pmusgrf: this driver should access pmusgrf regs, so need get pmusgrf here -- rockchip,cic: this driver should access cic regs, so need get cic here -- reg: dynamic ram protocol controller(PCTL) address, PHY Independent(PI) address, phy controller(PHYCTL) address and memory schedule(MSCH) address -- clock: must include clock specifiers corresponding to entries in the clock-names property. - Must contain - dmc_clk: for ddr working frequency -- rockchip,sdram-params: SDRAM parameters, including all the information by ddr driver: - Must contain - Genarate by vendor tool and adjust for U-Boot dtsi. - -Example: - dmc: dmc { - bootph-all; - compatible = "rockchip,rk3399-dmc"; - devfreq-events = <&dfi>; - interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH 0>; - clocks = <&cru SCLK_DDRCLK>; - clock-names = "dmc_clk"; - reg = <0x0 0xffa80000 0x0 0x0800 - 0x0 0xffa80800 0x0 0x1800 - 0x0 0xffa82000 0x0 0x2000 - 0x0 0xffa84000 0x0 0x1000 - 0x0 0xffa88000 0x0 0x0800 - 0x0 0xffa88800 0x0 0x1800 - 0x0 0xffa8a000 0x0 0x2000 - 0x0 0xffa8c000 0x0 0x1000>; - }; - - &dmc { - rockchip,sdram-params = < - 0x2 - 0xa - 0x3 - ... - >; - }; diff --git a/include/dt-bindings/clock/rk3399-cru.h b/include/dt-bindings/clock/rk3399-cru.h deleted file mode 100644 index 39169d94a44e..000000000000 --- a/include/dt-bindings/clock/rk3399-cru.h +++ /dev/null @@ -1,751 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/* - * Copyright (c) 2016 Rockchip Electronics Co. Ltd. - * Author: Xing Zheng zhengxing@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H - -/* core clocks */ -#define PLL_APLLL 1 -#define PLL_APLLB 2 -#define PLL_DPLL 3 -#define PLL_CPLL 4 -#define PLL_GPLL 5 -#define PLL_NPLL 6 -#define PLL_VPLL 7 -#define ARMCLKL 8 -#define ARMCLKB 9 - -/* sclk gates (special clocks) */ -#define SCLK_I2C1 65 -#define SCLK_I2C2 66 -#define SCLK_I2C3 67 -#define SCLK_I2C5 68 -#define SCLK_I2C6 69 -#define SCLK_I2C7 70 -#define SCLK_SPI0 71 -#define SCLK_SPI1 72 -#define SCLK_SPI2 73 -#define SCLK_SPI4 74 -#define SCLK_SPI5 75 -#define SCLK_SDMMC 76 -#define SCLK_SDIO 77 -#define SCLK_EMMC 78 -#define SCLK_TSADC 79 -#define SCLK_SARADC 80 -#define SCLK_UART0 81 -#define SCLK_UART1 82 -#define SCLK_UART2 83 -#define SCLK_UART3 84 -#define SCLK_SPDIF_8CH 85 -#define SCLK_I2S0_8CH 86 -#define SCLK_I2S1_8CH 87 -#define SCLK_I2S2_8CH 88 -#define SCLK_I2S_8CH_OUT 89 -#define SCLK_TIMER00 90 -#define SCLK_TIMER01 91 -#define SCLK_TIMER02 92 -#define SCLK_TIMER03 93 -#define SCLK_TIMER04 94 -#define SCLK_TIMER05 95 -#define SCLK_TIMER06 96 -#define SCLK_TIMER07 97 -#define SCLK_TIMER08 98 -#define SCLK_TIMER09 99 -#define SCLK_TIMER10 100 -#define SCLK_TIMER11 101 -#define SCLK_MACREF 102 -#define SCLK_MAC_RX 103 -#define SCLK_MAC_TX 104 -#define SCLK_MAC 105 -#define SCLK_MACREF_OUT 106 -#define SCLK_VOP0_PWM 107 -#define SCLK_VOP1_PWM 108 -#define SCLK_RGA_CORE 109 -#define SCLK_ISP0 110 -#define SCLK_ISP1 111 -#define SCLK_HDMI_CEC 112 -#define SCLK_HDMI_SFR 113 -#define SCLK_DP_CORE 114 -#define SCLK_PVTM_CORE_L 115 -#define SCLK_PVTM_CORE_B 116 -#define SCLK_PVTM_GPU 117 -#define SCLK_PVTM_DDR 118 -#define SCLK_MIPIDPHY_REF 119 -#define SCLK_MIPIDPHY_CFG 120 -#define SCLK_HSICPHY 121 -#define SCLK_USBPHY480M 122 -#define SCLK_USB2PHY0_REF 123 -#define SCLK_USB2PHY1_REF 124 -#define SCLK_UPHY0_TCPDPHY_REF 125 -#define SCLK_UPHY0_TCPDCORE 126 -#define SCLK_UPHY1_TCPDPHY_REF 127 -#define SCLK_UPHY1_TCPDCORE 128 -#define SCLK_USB3OTG0_REF 129 -#define SCLK_USB3OTG1_REF 130 -#define SCLK_USB3OTG0_SUSPEND 131 -#define SCLK_USB3OTG1_SUSPEND 132 -#define SCLK_CRYPTO0 133 -#define SCLK_CRYPTO1 134 -#define SCLK_CCI_TRACE 135 -#define SCLK_CS 136 -#define SCLK_CIF_OUT 137 -#define SCLK_PCIEPHY_REF 138 -#define SCLK_PCIE_CORE 139 -#define SCLK_M0_PERILP 140 -#define SCLK_M0_PERILP_DEC 141 -#define SCLK_CM0S 142 -#define SCLK_DBG_NOC 143 -#define SCLK_DBG_PD_CORE_B 144 -#define SCLK_DBG_PD_CORE_L 145 -#define SCLK_DFIMON0_TIMER 146 -#define SCLK_DFIMON1_TIMER 147 -#define SCLK_INTMEM0 148 -#define SCLK_INTMEM1 149 -#define SCLK_INTMEM2 150 -#define SCLK_INTMEM3 151 -#define SCLK_INTMEM4 152 -#define SCLK_INTMEM5 153 -#define SCLK_SDMMC_DRV 154 -#define SCLK_SDMMC_SAMPLE 155 -#define SCLK_SDIO_DRV 156 -#define SCLK_SDIO_SAMPLE 157 -#define SCLK_VDU_CORE 158 -#define SCLK_VDU_CA 159 -#define SCLK_PCIE_PM 160 -#define SCLK_SPDIF_REC_DPTX 161 -#define SCLK_DPHY_PLL 162 -#define SCLK_DPHY_TX0_CFG 163 -#define SCLK_DPHY_TX1RX1_CFG 164 -#define SCLK_DPHY_RX0_CFG 165 -#define SCLK_RMII_SRC 166 -#define SCLK_PCIEPHY_REF100M 167 -#define SCLK_DDRC 168 -#define SCLK_TESTCLKOUT1 169 -#define SCLK_TESTCLKOUT2 170 - -#define DCLK_VOP0 180 -#define DCLK_VOP1 181 -#define DCLK_VOP0_DIV 182 -#define DCLK_VOP1_DIV 183 -#define DCLK_M0_PERILP 184 -#define DCLK_VOP0_FRAC 185 -#define DCLK_VOP1_FRAC 186 - -#define FCLK_CM0S 190 - -/* aclk gates */ -#define ACLK_PERIHP 192 -#define ACLK_PERIHP_NOC 193 -#define ACLK_PERILP0 194 -#define ACLK_PERILP0_NOC 195 -#define ACLK_PERF_PCIE 196 -#define ACLK_PCIE 197 -#define ACLK_INTMEM 198 -#define ACLK_TZMA 199 -#define ACLK_DCF 200 -#define ACLK_CCI 201 -#define ACLK_CCI_NOC0 202 -#define ACLK_CCI_NOC1 203 -#define ACLK_CCI_GRF 204 -#define ACLK_CENTER 205 -#define ACLK_CENTER_MAIN_NOC 206 -#define ACLK_CENTER_PERI_NOC 207 -#define ACLK_GPU 208 -#define ACLK_PERF_GPU 209 -#define ACLK_GPU_GRF 210 -#define ACLK_DMAC0_PERILP 211 -#define ACLK_DMAC1_PERILP 212 -#define ACLK_GMAC 213 -#define ACLK_GMAC_NOC 214 -#define ACLK_PERF_GMAC 215 -#define ACLK_VOP0_NOC 216 -#define ACLK_VOP0 217 -#define ACLK_VOP1_NOC 218 -#define ACLK_VOP1 219 -#define ACLK_RGA 220 -#define ACLK_RGA_NOC 221 -#define ACLK_HDCP 222 -#define ACLK_HDCP_NOC 223 -#define ACLK_HDCP22 224 -#define ACLK_IEP 225 -#define ACLK_IEP_NOC 226 -#define ACLK_VIO 227 -#define ACLK_VIO_NOC 228 -#define ACLK_ISP0 229 -#define ACLK_ISP1 230 -#define ACLK_ISP0_NOC 231 -#define ACLK_ISP1_NOC 232 -#define ACLK_ISP0_WRAPPER 233 -#define ACLK_ISP1_WRAPPER 234 -#define ACLK_VCODEC 235 -#define ACLK_VCODEC_NOC 236 -#define ACLK_VDU 237 -#define ACLK_VDU_NOC 238 -#define ACLK_PERI 239 -#define ACLK_EMMC 240 -#define ACLK_EMMC_CORE 241 -#define ACLK_EMMC_NOC 242 -#define ACLK_EMMC_GRF 243 -#define ACLK_USB3 244 -#define ACLK_USB3_NOC 245 -#define ACLK_USB3OTG0 246 -#define ACLK_USB3OTG1 247 -#define ACLK_USB3_RKSOC_AXI_PERF 248 -#define ACLK_USB3_GRF 249 -#define ACLK_GIC 250 -#define ACLK_GIC_NOC 251 -#define ACLK_GIC_ADB400_CORE_L_2_GIC 252 -#define ACLK_GIC_ADB400_CORE_B_2_GIC 253 -#define ACLK_GIC_ADB400_GIC_2_CORE_L 254 -#define ACLK_GIC_ADB400_GIC_2_CORE_B 255 -#define ACLK_CORE_ADB400_CORE_L_2_CCI500 256 -#define ACLK_CORE_ADB400_CORE_B_2_CCI500 257 -#define ACLK_ADB400M_PD_CORE_L 258 -#define ACLK_ADB400M_PD_CORE_B 259 -#define ACLK_PERF_CORE_L 260 -#define ACLK_PERF_CORE_B 261 -#define ACLK_GIC_PRE 262 -#define ACLK_VOP0_PRE 263 -#define ACLK_VOP1_PRE 264 - -/* pclk gates */ -#define PCLK_PERIHP 320 -#define PCLK_PERIHP_NOC 321 -#define PCLK_PERILP0 322 -#define PCLK_PERILP1 323 -#define PCLK_PERILP1_NOC 324 -#define PCLK_PERILP_SGRF 325 -#define PCLK_PERIHP_GRF 326 -#define PCLK_PCIE 327 -#define PCLK_SGRF 328 -#define PCLK_INTR_ARB 329 -#define PCLK_CENTER_MAIN_NOC 330 -#define PCLK_CIC 331 -#define PCLK_COREDBG_B 332 -#define PCLK_COREDBG_L 333 -#define PCLK_DBG_CXCS_PD_CORE_B 334 -#define PCLK_DCF 335 -#define PCLK_GPIO2 336 -#define PCLK_GPIO3 337 -#define PCLK_GPIO4 338 -#define PCLK_GRF 339 -#define PCLK_HSICPHY 340 -#define PCLK_I2C1 341 -#define PCLK_I2C2 342 -#define PCLK_I2C3 343 -#define PCLK_I2C5 344 -#define PCLK_I2C6 345 -#define PCLK_I2C7 346 -#define PCLK_SPI0 347 -#define PCLK_SPI1 348 -#define PCLK_SPI2 349 -#define PCLK_SPI4 350 -#define PCLK_SPI5 351 -#define PCLK_UART0 352 -#define PCLK_UART1 353 -#define PCLK_UART2 354 -#define PCLK_UART3 355 -#define PCLK_TSADC 356 -#define PCLK_SARADC 357 -#define PCLK_GMAC 358 -#define PCLK_GMAC_NOC 359 -#define PCLK_TIMER0 360 -#define PCLK_TIMER1 361 -#define PCLK_EDP 362 -#define PCLK_EDP_NOC 363 -#define PCLK_EDP_CTRL 364 -#define PCLK_VIO 365 -#define PCLK_VIO_NOC 366 -#define PCLK_VIO_GRF 367 -#define PCLK_MIPI_DSI0 368 -#define PCLK_MIPI_DSI1 369 -#define PCLK_HDCP 370 -#define PCLK_HDCP_NOC 371 -#define PCLK_HDMI_CTRL 372 -#define PCLK_DP_CTRL 373 -#define PCLK_HDCP22 374 -#define PCLK_GASKET 375 -#define PCLK_DDR 376 -#define PCLK_DDR_MON 377 -#define PCLK_DDR_SGRF 378 -#define PCLK_ISP1_WRAPPER 379 -#define PCLK_WDT 380 -#define PCLK_EFUSE1024NS 381 -#define PCLK_EFUSE1024S 382 -#define PCLK_PMU_INTR_ARB 383 -#define PCLK_MAILBOX0 384 -#define PCLK_USBPHY_MUX_G 385 -#define PCLK_UPHY0_TCPHY_G 386 -#define PCLK_UPHY0_TCPD_G 387 -#define PCLK_UPHY1_TCPHY_G 388 -#define PCLK_UPHY1_TCPD_G 389 -#define PCLK_ALIVE 390 - -/* hclk gates */ -#define HCLK_PERIHP 448 -#define HCLK_PERILP0 449 -#define HCLK_PERILP1 450 -#define HCLK_PERILP0_NOC 451 -#define HCLK_PERILP1_NOC 452 -#define HCLK_M0_PERILP 453 -#define HCLK_M0_PERILP_NOC 454 -#define HCLK_AHB1TOM 455 -#define HCLK_HOST0 456 -#define HCLK_HOST0_ARB 457 -#define HCLK_HOST1 458 -#define HCLK_HOST1_ARB 459 -#define HCLK_HSIC 460 -#define HCLK_SD 461 -#define HCLK_SDMMC 462 -#define HCLK_SDMMC_NOC 463 -#define HCLK_M_CRYPTO0 464 -#define HCLK_M_CRYPTO1 465 -#define HCLK_S_CRYPTO0 466 -#define HCLK_S_CRYPTO1 467 -#define HCLK_I2S0_8CH 468 -#define HCLK_I2S1_8CH 469 -#define HCLK_I2S2_8CH 470 -#define HCLK_SPDIF 471 -#define HCLK_VOP0_NOC 472 -#define HCLK_VOP0 473 -#define HCLK_VOP1_NOC 474 -#define HCLK_VOP1 475 -#define HCLK_ROM 476 -#define HCLK_IEP 477 -#define HCLK_IEP_NOC 478 -#define HCLK_ISP0 479 -#define HCLK_ISP1 480 -#define HCLK_ISP0_NOC 481 -#define HCLK_ISP1_NOC 482 -#define HCLK_ISP0_WRAPPER 483 -#define HCLK_ISP1_WRAPPER 484 -#define HCLK_RGA 485 -#define HCLK_RGA_NOC 486 -#define HCLK_HDCP 487 -#define HCLK_HDCP_NOC 488 -#define HCLK_HDCP22 489 -#define HCLK_VCODEC 490 -#define HCLK_VCODEC_NOC 491 -#define HCLK_VDU 492 -#define HCLK_VDU_NOC 493 -#define HCLK_SDIO 494 -#define HCLK_SDIO_NOC 495 -#define HCLK_SDIOAUDIO_NOC 496 - -#define CLK_NR_CLKS (HCLK_SDIOAUDIO_NOC + 1) - -/* pmu-clocks indices */ - -#define PLL_PPLL 1 - -#define SCLK_32K_SUSPEND_PMU 2 -#define SCLK_SPI3_PMU 3 -#define SCLK_TIMER12_PMU 4 -#define SCLK_TIMER13_PMU 5 -#define SCLK_UART4_PMU 6 -#define SCLK_PVTM_PMU 7 -#define SCLK_WIFI_PMU 8 -#define SCLK_I2C0_PMU 9 -#define SCLK_I2C4_PMU 10 -#define SCLK_I2C8_PMU 11 - -#define PCLK_SRC_PMU 19 -#define PCLK_PMU 20 -#define PCLK_PMUGRF_PMU 21 -#define PCLK_INTMEM1_PMU 22 -#define PCLK_GPIO0_PMU 23 -#define PCLK_GPIO1_PMU 24 -#define PCLK_SGRF_PMU 25 -#define PCLK_NOC_PMU 26 -#define PCLK_I2C0_PMU 27 -#define PCLK_I2C4_PMU 28 -#define PCLK_I2C8_PMU 29 -#define PCLK_RKPWM_PMU 30 -#define PCLK_SPI3_PMU 31 -#define PCLK_TIMER_PMU 32 -#define PCLK_MAILBOX_PMU 33 -#define PCLK_UART4_PMU 34 -#define PCLK_WDT_M0_PMU 35 - -#define FCLK_CM0S_SRC_PMU 44 -#define FCLK_CM0S_PMU 45 -#define SCLK_CM0S_PMU 46 -#define HCLK_CM0S_PMU 47 -#define DCLK_CM0S_PMU 48 -#define PCLK_INTR_ARB_PMU 49 -#define HCLK_NOC_PMU 50 - -#define CLKPMU_NR_CLKS (HCLK_NOC_PMU + 1) - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_CORE_L0 0 -#define SRST_CORE_B0 1 -#define SRST_CORE_PO_L0 2 -#define SRST_CORE_PO_B0 3 -#define SRST_L2_L 4 -#define SRST_L2_B 5 -#define SRST_ADB_L 6 -#define SRST_ADB_B 7 -#define SRST_A_CCI 8 -#define SRST_A_CCIM0_NOC 9 -#define SRST_A_CCIM1_NOC 10 -#define SRST_DBG_NOC 11 - -/* cru_softrst_con1 */ -#define SRST_CORE_L0_T 16 -#define SRST_CORE_L1 17 -#define SRST_CORE_L2 18 -#define SRST_CORE_L3 19 -#define SRST_CORE_PO_L0_T 20 -#define SRST_CORE_PO_L1 21 -#define SRST_CORE_PO_L2 22 -#define SRST_CORE_PO_L3 23 -#define SRST_A_ADB400_GIC2COREL 24 -#define SRST_A_ADB400_COREL2GIC 25 -#define SRST_P_DBG_L 26 -#define SRST_L2_L_T 28 -#define SRST_ADB_L_T 29 -#define SRST_A_RKPERF_L 30 -#define SRST_PVTM_CORE_L 31 - -/* cru_softrst_con2 */ -#define SRST_CORE_B0_T 32 -#define SRST_CORE_B1 33 -#define SRST_CORE_PO_B0_T 36 -#define SRST_CORE_PO_B1 37 -#define SRST_A_ADB400_GIC2COREB 40 -#define SRST_A_ADB400_COREB2GIC 41 -#define SRST_P_DBG_B 42 -#define SRST_L2_B_T 43 -#define SRST_ADB_B_T 45 -#define SRST_A_RKPERF_B 46 -#define SRST_PVTM_CORE_B 47 - -/* cru_softrst_con3 */ -#define SRST_A_CCI_T 50 -#define SRST_A_CCIM0_NOC_T 51 -#define SRST_A_CCIM1_NOC_T 52 -#define SRST_A_ADB400M_PD_CORE_B_T 53 -#define SRST_A_ADB400M_PD_CORE_L_T 54 -#define SRST_DBG_NOC_T 55 -#define SRST_DBG_CXCS 56 -#define SRST_CCI_TRACE 57 -#define SRST_P_CCI_GRF 58 - -/* cru_softrst_con4 */ -#define SRST_A_CENTER_MAIN_NOC 64 -#define SRST_A_CENTER_PERI_NOC 65 -#define SRST_P_CENTER_MAIN 66 -#define SRST_P_DDRMON 67 -#define SRST_P_CIC 68 -#define SRST_P_CENTER_SGRF 69 -#define SRST_DDR0_MSCH 70 -#define SRST_DDRCFG0_MSCH 71 -#define SRST_DDR0 72 -#define SRST_DDRPHY0 73 -#define SRST_DDR1_MSCH 74 -#define SRST_DDRCFG1_MSCH 75 -#define SRST_DDR1 76 -#define SRST_DDRPHY1 77 -#define SRST_DDR_CIC 78 -#define SRST_PVTM_DDR 79 - -/* cru_softrst_con5 */ -#define SRST_A_VCODEC_NOC 80 -#define SRST_A_VCODEC 81 -#define SRST_H_VCODEC_NOC 82 -#define SRST_H_VCODEC 83 -#define SRST_A_VDU_NOC 88 -#define SRST_A_VDU 89 -#define SRST_H_VDU_NOC 90 -#define SRST_H_VDU 91 -#define SRST_VDU_CORE 92 -#define SRST_VDU_CA 93 - -/* cru_softrst_con6 */ -#define SRST_A_IEP_NOC 96 -#define SRST_A_VOP_IEP 97 -#define SRST_A_IEP 98 -#define SRST_H_IEP_NOC 99 -#define SRST_H_IEP 100 -#define SRST_A_RGA_NOC 102 -#define SRST_A_RGA 103 -#define SRST_H_RGA_NOC 104 -#define SRST_H_RGA 105 -#define SRST_RGA_CORE 106 -#define SRST_EMMC_NOC 108 -#define SRST_EMMC 109 -#define SRST_EMMC_GRF 110 - -/* cru_softrst_con7 */ -#define SRST_A_PERIHP_NOC 112 -#define SRST_P_PERIHP_GRF 113 -#define SRST_H_PERIHP_NOC 114 -#define SRST_USBHOST0 115 -#define SRST_HOSTC0_AUX 116 -#define SRST_HOST0_ARB 117 -#define SRST_USBHOST1 118 -#define SRST_HOSTC1_AUX 119 -#define SRST_HOST1_ARB 120 -#define SRST_SDIO0 121 -#define SRST_SDMMC 122 -#define SRST_HSIC 123 -#define SRST_HSIC_AUX 124 -#define SRST_AHB1TOM 125 -#define SRST_P_PERIHP_NOC 126 -#define SRST_HSICPHY 127 - -/* cru_softrst_con8 */ -#define SRST_A_PCIE 128 -#define SRST_P_PCIE 129 -#define SRST_PCIE_CORE 130 -#define SRST_PCIE_MGMT 131 -#define SRST_PCIE_MGMT_STICKY 132 -#define SRST_PCIE_PIPE 133 -#define SRST_PCIE_PM 134 -#define SRST_PCIEPHY 135 -#define SRST_A_GMAC_NOC 136 -#define SRST_A_GMAC 137 -#define SRST_P_GMAC_NOC 138 -#define SRST_P_GMAC_GRF 140 -#define SRST_HSICPHY_POR 142 -#define SRST_HSICPHY_UTMI 143 - -/* cru_softrst_con9 */ -#define SRST_USB2PHY0_POR 144 -#define SRST_USB2PHY0_UTMI_PORT0 145 -#define SRST_USB2PHY0_UTMI_PORT1 146 -#define SRST_USB2PHY0_EHCIPHY 147 -#define SRST_UPHY0_PIPE_L00 148 -#define SRST_UPHY0 149 -#define SRST_UPHY0_TCPDPWRUP 150 -#define SRST_USB2PHY1_POR 152 -#define SRST_USB2PHY1_UTMI_PORT0 153 -#define SRST_USB2PHY1_UTMI_PORT1 154 -#define SRST_USB2PHY1_EHCIPHY 155 -#define SRST_UPHY1_PIPE_L00 156 -#define SRST_UPHY1 157 -#define SRST_UPHY1_TCPDPWRUP 158 - -/* cru_softrst_con10 */ -#define SRST_A_PERILP0_NOC 160 -#define SRST_A_DCF 161 -#define SRST_GIC500 162 -#define SRST_DMAC0_PERILP0 163 -#define SRST_DMAC1_PERILP0 164 -#define SRST_TZMA 165 -#define SRST_INTMEM 166 -#define SRST_ADB400_MST0 167 -#define SRST_ADB400_MST1 168 -#define SRST_ADB400_SLV0 169 -#define SRST_ADB400_SLV1 170 -#define SRST_H_PERILP0 171 -#define SRST_H_PERILP0_NOC 172 -#define SRST_ROM 173 -#define SRST_CRYPTO0_S 174 -#define SRST_CRYPTO0_M 175 - -/* cru_softrst_con11 */ -#define SRST_P_DCF 176 -#define SRST_CM0S_NOC 177 -#define SRST_CM0S 178 -#define SRST_CM0S_DBG 179 -#define SRST_CM0S_PO 180 -#define SRST_CRYPTO0 181 -#define SRST_P_PERILP1_SGRF 182 -#define SRST_P_PERILP1_GRF 183 -#define SRST_CRYPTO1_S 184 -#define SRST_CRYPTO1_M 185 -#define SRST_CRYPTO1 186 -#define SRST_GIC_NOC 188 -#define SRST_SD_NOC 189 -#define SRST_SDIOAUDIO_BRG 190 - -/* cru_softrst_con12 */ -#define SRST_H_PERILP1 192 -#define SRST_H_PERILP1_NOC 193 -#define SRST_H_I2S0_8CH 194 -#define SRST_H_I2S1_8CH 195 -#define SRST_H_I2S2_8CH 196 -#define SRST_H_SPDIF_8CH 197 -#define SRST_P_PERILP1_NOC 198 -#define SRST_P_EFUSE_1024 199 -#define SRST_P_EFUSE_1024S 200 -#define SRST_P_I2C0 201 -#define SRST_P_I2C1 202 -#define SRST_P_I2C2 203 -#define SRST_P_I2C3 204 -#define SRST_P_I2C4 205 -#define SRST_P_I2C5 206 -#define SRST_P_MAILBOX0 207 - -/* cru_softrst_con13 */ -#define SRST_P_UART0 208 -#define SRST_P_UART1 209 -#define SRST_P_UART2 210 -#define SRST_P_UART3 211 -#define SRST_P_SARADC 212 -#define SRST_P_TSADC 213 -#define SRST_P_SPI0 214 -#define SRST_P_SPI1 215 -#define SRST_P_SPI2 216 -#define SRST_P_SPI3 217 -#define SRST_P_SPI4 218 -#define SRST_SPI0 219 -#define SRST_SPI1 220 -#define SRST_SPI2 221 -#define SRST_SPI3 222 -#define SRST_SPI4 223 - -/* cru_softrst_con14 */ -#define SRST_I2S0_8CH 224 -#define SRST_I2S1_8CH 225 -#define SRST_I2S2_8CH 226 -#define SRST_SPDIF_8CH 227 -#define SRST_UART0 228 -#define SRST_UART1 229 -#define SRST_UART2 230 -#define SRST_UART3 231 -#define SRST_TSADC 232 -#define SRST_I2C0 233 -#define SRST_I2C1 234 -#define SRST_I2C2 235 -#define SRST_I2C3 236 -#define SRST_I2C4 237 -#define SRST_I2C5 238 -#define SRST_SDIOAUDIO_NOC 239 - -/* cru_softrst_con15 */ -#define SRST_A_VIO_NOC 240 -#define SRST_A_HDCP_NOC 241 -#define SRST_A_HDCP 242 -#define SRST_H_HDCP_NOC 243 -#define SRST_H_HDCP 244 -#define SRST_P_HDCP_NOC 245 -#define SRST_P_HDCP 246 -#define SRST_P_HDMI_CTRL 247 -#define SRST_P_DP_CTRL 248 -#define SRST_S_DP_CTRL 249 -#define SRST_C_DP_CTRL 250 -#define SRST_P_MIPI_DSI0 251 -#define SRST_P_MIPI_DSI1 252 -#define SRST_DP_CORE 253 -#define SRST_DP_I2S 254 - -/* cru_softrst_con16 */ -#define SRST_GASKET 256 -#define SRST_VIO_GRF 258 -#define SRST_DPTX_SPDIF_REC 259 -#define SRST_HDMI_CTRL 260 -#define SRST_HDCP_CTRL 261 -#define SRST_A_ISP0_NOC 262 -#define SRST_A_ISP1_NOC 263 -#define SRST_H_ISP0_NOC 266 -#define SRST_H_ISP1_NOC 267 -#define SRST_H_ISP0 268 -#define SRST_H_ISP1 269 -#define SRST_ISP0 270 -#define SRST_ISP1 271 - -/* cru_softrst_con17 */ -#define SRST_A_VOP0_NOC 272 -#define SRST_A_VOP1_NOC 273 -#define SRST_A_VOP0 274 -#define SRST_A_VOP1 275 -#define SRST_H_VOP0_NOC 276 -#define SRST_H_VOP1_NOC 277 -#define SRST_H_VOP0 278 -#define SRST_H_VOP1 279 -#define SRST_D_VOP0 280 -#define SRST_D_VOP1 281 -#define SRST_VOP0_PWM 282 -#define SRST_VOP1_PWM 283 -#define SRST_P_EDP_NOC 284 -#define SRST_P_EDP_CTRL 285 - -/* cru_softrst_con18 */ -#define SRST_A_GPU 288 -#define SRST_A_GPU_NOC 289 -#define SRST_A_GPU_GRF 290 -#define SRST_PVTM_GPU 291 -#define SRST_A_USB3_NOC 292 -#define SRST_A_USB3_OTG0 293 -#define SRST_A_USB3_OTG1 294 -#define SRST_A_USB3_GRF 295 -#define SRST_PMU 296 - -/* cru_softrst_con19 */ -#define SRST_P_TIMER0_5 304 -#define SRST_TIMER0 305 -#define SRST_TIMER1 306 -#define SRST_TIMER2 307 -#define SRST_TIMER3 308 -#define SRST_TIMER4 309 -#define SRST_TIMER5 310 -#define SRST_P_TIMER6_11 311 -#define SRST_TIMER6 312 -#define SRST_TIMER7 313 -#define SRST_TIMER8 314 -#define SRST_TIMER9 315 -#define SRST_TIMER10 316 -#define SRST_TIMER11 317 -#define SRST_P_INTR_ARB_PMU 318 -#define SRST_P_ALIVE_SGRF 319 - -/* cru_softrst_con20 */ -#define SRST_P_GPIO2 320 -#define SRST_P_GPIO3 321 -#define SRST_P_GPIO4 322 -#define SRST_P_GRF 323 -#define SRST_P_ALIVE_NOC 324 -#define SRST_P_WDT0 325 -#define SRST_P_WDT1 326 -#define SRST_P_INTR_ARB 327 -#define SRST_P_UPHY0_DPTX 328 -#define SRST_P_UPHY0_APB 330 -#define SRST_P_UPHY0_TCPHY 332 -#define SRST_P_UPHY1_TCPHY 333 -#define SRST_P_UPHY0_TCPDCTRL 334 -#define SRST_P_UPHY1_TCPDCTRL 335 - -/* pmu soft-reset indices */ - -/* pmu_cru_softrst_con0 */ -#define SRST_P_NOC 0 -#define SRST_P_INTMEM 1 -#define SRST_H_CM0S 2 -#define SRST_H_CM0S_NOC 3 -#define SRST_DBG_CM0S 4 -#define SRST_PO_CM0S 5 -#define SRST_P_SPI6 6 -#define SRST_SPI6 7 -#define SRST_P_TIMER_0_1 8 -#define SRST_P_TIMER_0 9 -#define SRST_P_TIMER_1 10 -#define SRST_P_UART4 11 -#define SRST_UART4 12 -#define SRST_P_WDT 13 - -/* pmu_cru_softrst_con1 */ -#define SRST_P_I2C6 16 -#define SRST_P_I2C7 17 -#define SRST_P_I2C8 18 -#define SRST_P_MAILBOX 19 -#define SRST_P_RKPWM 20 -#define SRST_P_PMUGRF 21 -#define SRST_P_SGRF 22 -#define SRST_P_GPIO0 23 -#define SRST_P_GPIO1 24 -#define SRST_P_CRU 25 -#define SRST_P_INTR 26 -#define SRST_PVTM 27 -#define SRST_I2C6 28 -#define SRST_I2C7 29 -#define SRST_I2C8 30 - -#endif diff --git a/include/dt-bindings/power/rk3399-power.h b/include/dt-bindings/power/rk3399-power.h deleted file mode 100644 index 168b3bfbd6f5..000000000000 --- a/include/dt-bindings/power/rk3399-power.h +++ /dev/null @@ -1,53 +0,0 @@ -#ifndef __DT_BINDINGS_POWER_RK3399_POWER_H__ -#define __DT_BINDINGS_POWER_RK3399_POWER_H__ - -/* VD_CORE_L */ -#define RK3399_PD_A53_L0 0 -#define RK3399_PD_A53_L1 1 -#define RK3399_PD_A53_L2 2 -#define RK3399_PD_A53_L3 3 -#define RK3399_PD_SCU_L 4 - -/* VD_CORE_B */ -#define RK3399_PD_A72_B0 5 -#define RK3399_PD_A72_B1 6 -#define RK3399_PD_SCU_B 7 - -/* VD_LOGIC */ -#define RK3399_PD_TCPD0 8 -#define RK3399_PD_TCPD1 9 -#define RK3399_PD_CCI 10 -#define RK3399_PD_CCI0 11 -#define RK3399_PD_CCI1 12 -#define RK3399_PD_PERILP 13 -#define RK3399_PD_PERIHP 14 -#define RK3399_PD_VIO 15 -#define RK3399_PD_VO 16 -#define RK3399_PD_VOPB 17 -#define RK3399_PD_VOPL 18 -#define RK3399_PD_ISP0 19 -#define RK3399_PD_ISP1 20 -#define RK3399_PD_HDCP 21 -#define RK3399_PD_GMAC 22 -#define RK3399_PD_EMMC 23 -#define RK3399_PD_USB3 24 -#define RK3399_PD_EDP 25 -#define RK3399_PD_GIC 26 -#define RK3399_PD_SD 27 -#define RK3399_PD_SDIOAUDIO 28 -#define RK3399_PD_ALIVE 29 - -/* VD_CENTER */ -#define RK3399_PD_CENTER 30 -#define RK3399_PD_VCODEC 31 -#define RK3399_PD_VDU 32 -#define RK3399_PD_RGA 33 -#define RK3399_PD_IEP 34 - -/* VD_GPU */ -#define RK3399_PD_GPU 35 - -/* VD_PMU */ -#define RK3399_PD_PMU 36 - -#endif
On 2024/5/5 03:42, Jonas Karlman wrote:
Remove redundant device tree files now that RK3399 boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
arch/arm/dts/rk3399-eaidk-610.dts | 940 ------ arch/arm/dts/rk3399-evb.dts | 485 --- arch/arm/dts/rk3399-ficus.dts | 174 - arch/arm/dts/rk3399-firefly.dts | 944 ------ arch/arm/dts/rk3399-gru-bob.dts | 95 - arch/arm/dts/rk3399-gru-chromebook.dtsi | 590 ---- arch/arm/dts/rk3399-gru-kevin.dts | 328 -- arch/arm/dts/rk3399-gru.dtsi | 865 ----- arch/arm/dts/rk3399-khadas-edge-captain.dts | 31 - arch/arm/dts/rk3399-khadas-edge-v.dts | 31 - arch/arm/dts/rk3399-khadas-edge.dts | 13 - arch/arm/dts/rk3399-khadas-edge.dtsi | 837 ----- arch/arm/dts/rk3399-leez-p710.dts | 653 ---- arch/arm/dts/rk3399-nanopc-t4.dts | 137 - arch/arm/dts/rk3399-nanopi-m4.dts | 66 - arch/arm/dts/rk3399-nanopi-m4b.dts | 52 - arch/arm/dts/rk3399-nanopi-neo4.dts | 50 - arch/arm/dts/rk3399-nanopi-r4s.dts | 133 - arch/arm/dts/rk3399-nanopi4.dtsi | 762 ----- arch/arm/dts/rk3399-op1-opp.dtsi | 166 - arch/arm/dts/rk3399-opp.dtsi | 133 - arch/arm/dts/rk3399-orangepi.dts | 896 ----- arch/arm/dts/rk3399-pinebook-pro.dts | 1111 ------- arch/arm/dts/rk3399-pinephone-pro.dts | 621 ---- arch/arm/dts/rk3399-puma-haikou.dts | 306 -- arch/arm/dts/rk3399-puma.dtsi | 532 --- arch/arm/dts/rk3399-roc-pc-mezzanine.dts | 111 - arch/arm/dts/rk3399-roc-pc.dts | 12 - arch/arm/dts/rk3399-roc-pc.dtsi | 844 ----- arch/arm/dts/rk3399-rock-4c-plus.dts | 709 ---- arch/arm/dts/rk3399-rock-4se.dts | 65 - arch/arm/dts/rk3399-rock-pi-4.dtsi | 792 ----- arch/arm/dts/rk3399-rock-pi-4a.dts | 24 - arch/arm/dts/rk3399-rock-pi-4c.dts | 80 - arch/arm/dts/rk3399-rock960.dts | 156 - arch/arm/dts/rk3399-rock960.dtsi | 673 ---- arch/arm/dts/rk3399-rockpro64.dts | 30 - arch/arm/dts/rk3399-rockpro64.dtsi | 956 ------ arch/arm/dts/rk3399-t-opp.dtsi | 114 - arch/arm/dts/rk3399.dtsi | 2945 ----------------- arch/arm/dts/rk3399pro-rock-pi-n10.dts | 22 - arch/arm/dts/rk3399pro-vmarc-som.dtsi | 477 --- arch/arm/dts/rk3399pro.dtsi | 22 - .../clock/rockchip,rk3399-dmc.txt | 42 - include/dt-bindings/clock/rk3399-cru.h | 751 ----- include/dt-bindings/power/rk3399-power.h | 53 - 46 files changed, 19829 deletions(-) delete mode 100644 arch/arm/dts/rk3399-eaidk-610.dts delete mode 100644 arch/arm/dts/rk3399-evb.dts delete mode 100644 arch/arm/dts/rk3399-ficus.dts delete mode 100644 arch/arm/dts/rk3399-firefly.dts delete mode 100644 arch/arm/dts/rk3399-gru-bob.dts delete mode 100644 arch/arm/dts/rk3399-gru-chromebook.dtsi delete mode 100644 arch/arm/dts/rk3399-gru-kevin.dts delete mode 100644 arch/arm/dts/rk3399-gru.dtsi delete mode 100644 arch/arm/dts/rk3399-khadas-edge-captain.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge-v.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge.dts delete mode 100644 arch/arm/dts/rk3399-khadas-edge.dtsi delete mode 100644 arch/arm/dts/rk3399-leez-p710.dts delete mode 100644 arch/arm/dts/rk3399-nanopc-t4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-m4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-m4b.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-neo4.dts delete mode 100644 arch/arm/dts/rk3399-nanopi-r4s.dts delete mode 100644 arch/arm/dts/rk3399-nanopi4.dtsi delete mode 100644 arch/arm/dts/rk3399-op1-opp.dtsi delete mode 100644 arch/arm/dts/rk3399-opp.dtsi delete mode 100644 arch/arm/dts/rk3399-orangepi.dts delete mode 100644 arch/arm/dts/rk3399-pinebook-pro.dts delete mode 100644 arch/arm/dts/rk3399-pinephone-pro.dts delete mode 100644 arch/arm/dts/rk3399-puma-haikou.dts delete mode 100644 arch/arm/dts/rk3399-puma.dtsi delete mode 100644 arch/arm/dts/rk3399-roc-pc-mezzanine.dts delete mode 100644 arch/arm/dts/rk3399-roc-pc.dts delete mode 100644 arch/arm/dts/rk3399-roc-pc.dtsi delete mode 100644 arch/arm/dts/rk3399-rock-4c-plus.dts delete mode 100644 arch/arm/dts/rk3399-rock-4se.dts delete mode 100644 arch/arm/dts/rk3399-rock-pi-4.dtsi delete mode 100644 arch/arm/dts/rk3399-rock-pi-4a.dts delete mode 100644 arch/arm/dts/rk3399-rock-pi-4c.dts delete mode 100644 arch/arm/dts/rk3399-rock960.dts delete mode 100644 arch/arm/dts/rk3399-rock960.dtsi delete mode 100644 arch/arm/dts/rk3399-rockpro64.dts delete mode 100644 arch/arm/dts/rk3399-rockpro64.dtsi delete mode 100644 arch/arm/dts/rk3399-t-opp.dtsi delete mode 100644 arch/arm/dts/rk3399.dtsi delete mode 100644 arch/arm/dts/rk3399pro-rock-pi-n10.dts delete mode 100644 arch/arm/dts/rk3399pro-vmarc-som.dtsi delete mode 100644 arch/arm/dts/rk3399pro.dtsi delete mode 100644 doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt delete mode 100644 include/dt-bindings/clock/rk3399-cru.h delete mode 100644 include/dt-bindings/power/rk3399-power.h
diff --git a/arch/arm/dts/rk3399-eaidk-610.dts b/arch/arm/dts/rk3399-eaidk-610.dts deleted file mode 100644 index 173da81fc231..000000000000 --- a/arch/arm/dts/rk3399-eaidk-610.dts +++ /dev/null @@ -1,940 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2022 Fuzhou Rockchip Electronics Co., Ltd.
-/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/usb/pd.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- model = "OPEN AI LAB EAIDK-610";
- compatible = "openailab,eaidk-610", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- backlight: backlight {
compatible = "pwm-backlight";
pwms = <&pwm0 0 25000 0>;
brightness-levels = <
0 1 2 3 4 5 6 7
8 9 10 11 12 13 14 15
16 17 18 19 20 21 22 23
24 25 26 27 28 29 30 31
32 33 34 35 36 37 38 39
40 41 42 43 44 45 46 47
48 49 50 51 52 53 54 55
56 57 58 59 60 61 62 63
64 65 66 67 68 69 70 71
72 73 74 75 76 77 78 79
80 81 82 83 84 85 86 87
88 89 90 91 92 93 94 95
96 97 98 99 100 101 102 103
104 105 106 107 108 109 110 111
112 113 114 115 116 117 118 119
120 121 122 123 124 125 126 127
128 129 130 131 132 133 134 135
136 137 138 139 140 141 142 143
144 145 146 147 148 149 150 151
152 153 154 155 156 157 158 159
160 161 162 163 164 165 166 167
168 169 170 171 172 173 174 175
176 177 178 179 180 181 182 183
184 185 186 187 188 189 190 191
192 193 194 195 196 197 198 199
200 201 202 203 204 205 206 207
208 209 210 211 212 213 214 215
216 217 218 219 220 221 222 223
224 225 226 227 228 229 230 231
232 233 234 235 236 237 238 239
240 241 242 243 244 245 246 247
248 249 250 251 252 253 254 255>;
default-brightness-level = <200>;
- clkin_gmac: external-gmac-clock {
compatible = "fixed-clock";
clock-frequency = <125000000>;
clock-output-names = "clkin_gmac";
#clock-cells = <0>;
- dc_12v: dc-12v {
regulator-name = "dc_12v";
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
- gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-0 = <&pwrbtn>;
key-power {
debounce-interval = <100>;
gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
label = "GPIO Key Power";
linux,code = <KEY_POWER>;
wakeup-source;
- leds {
compatible = "gpio-leds";
pinctrl-0 = <&work_led_pin>, <&user_led_pin>,
<&heartbeat_led_pin>, <&wlan_active_led_pin>,
<&bt_active_led_pin>;
work_led: led-0 {
label = "blue:work";
default-state = "on";
gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
user_led: led-1 {
label = "read:user";
default-state = "off";
heartbeat_led: led-2 {
label = "green:heartbeat";
linux,default-trigger = "heartbeat";
gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>;
wlan_active_led: led-3 {
label = "yellow:wlan";
gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "phy0tx";
bt_active_led: led-4 {
label = "blue:bt";
gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "hci0-power";
- rt5651-sound {
compatible = "simple-audio-card";
simple-audio-card,name = "realtek,rt5651-codec";
simple-audio-card,format = "i2s";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,widgets =
"Microphone", "Mic Jack",
"Headphone", "Headphone Jack";
simple-audio-card,routing =
"Mic Jack", "MICBIAS1",
"IN1P", "Mic Jack",
"Headphone Jack", "HPOL",
"Headphone Jack", "HPOR";
simple-audio-card,cpu {
sound-dai = <&i2s1>;
simple-audio-card,codec {
sound-dai = <&rt5651>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk808 1>;
clock-names = "ext_clock";
pinctrl-0 = <&wifi_enable_h>;
reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>;
- /* switched by pmic_sleep */
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-name = "vcc1v8_s3";
regulator-boot-on;
vin-supply = <&vcc_1v8>;
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
vin-supply = <&dc_12v>;
- vcc5v0_sys: vcc5v0-sys {
regulator-name = "vcc5v0_sys";
regulator-boot-on;
- /* For USB3.0 Port1/2 */
- vcc5v0_host1: vcc5v0-host1-regulator {
enable-active-high;
gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_host1_en>;
regulator-name = "vcc5v0_host1";
- /* For USB2.0 Port1/2 */
- vcc5v0_host3: vcc5v0-host3-regulator {
enable-active-high;
gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_host3_en>;
regulator-name = "vcc5v0_host3";
- vcc5v0_typec: vcc5v0-typec-regulator {
enable-active-high;
gpio = <&gpio4 RK_PC5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_typec_en>;
regulator-name = "vcc5v0_typec";
vin-supply = <&vcc3v3_sys>;
- vdd_log: vdd-log {
regulator-boot-on;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-mode = "rgmii";
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x28>;
- rx_delay = <0x11>;
- status = "okay";
-&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
-&hdmi {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk808: pmic@1b {
compatible = "rockchip,rk808";
reg = <0x1b>;
interrupts = <21 IRQ_TYPE_LEVEL_LOW>;
wakeup-source;
#clock-cells = <1>;
clock-output-names = "xin32k", "rk808-clkout2";
vcc1-supply = <&vcc3v3_sys>;
vcc2-supply = <&vcc3v3_sys>;
vcc3-supply = <&vcc3v3_sys>;
vcc4-supply = <&vcc3v3_sys>;
vcc6-supply = <&vcc3v3_sys>;
vcc7-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc3v3_sys>;
vcc10-supply = <&vcc3v3_sys>;
vcc11-supply = <&vcc3v3_sys>;
vcc12-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc_3v0>;
regulators {
vdd_center: DCDC_REG1 {
regulator-name = "vdd_center";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: DCDC_REG4 {
regulator-boot-on;
vcc1v8_dvp: LDO_REG1 {
regulator-name = "vcc1v8_dvp";
regulator-boot-on;
vcc2v8_dvp: LDO_REG2 {
regulator-name = "vcc2v8_dvp";
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
regulator-boot-on;
vcc1v8_pmu: LDO_REG3 {
regulator-name = "vcc1v8_pmu";
regulator-boot-on;
vcc_sdio: LDO_REG4 {
regulator-name = "vcc_sdio";
regulator-boot-on;
regulator-suspend-microvolt = <3000000>;
vcca3v0_codec: LDO_REG5 {
regulator-name = "vcca3v0_codec";
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-suspend-microvolt = <1500000>;
vcca1v8_codec: LDO_REG7 {
regulator-name = "vcca1v8_codec";
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-name = "vcc_3v0";
regulator-boot-on;
vcc3v3_s3: vcc_lan: SWITCH_REG1 {
regulator-name = "vcc3v3_s3";
regulator-boot-on;
vcc3v3_s0: SWITCH_REG2 {
regulator-name = "vcc3v3_s0";
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
compatible = "silergy,syr827";
reg = <0x40>;
fcs,suspend-voltage-selector = <1>;
regulator-name = "vdd_cpu_b";
pinctrl-0 = <&vsel1_pin>;
regulator-min-microvolt = <712500>;
regulator-ramp-delay = <1000>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
compatible = "silergy,syr828";
reg = <0x41>;
regulator-name = "vdd_gpu";
pinctrl-0 = <&vsel2_pin>;
regulator-boot-on;
-&i2c1 {
- i2c-scl-rising-time-ns = <300>;
- status = "okay";
- rt5651: audio-codec@1a {
compatible = "rockchip,rt5651";
reg = <0x1a>;
clocks = <&cru SCLK_I2S_8CH_OUT>;
clock-names = "mclk";
hp-det-gpio = <&gpio4 RK_PD4 GPIO_ACTIVE_LOW>;
spk-con-gpio = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
#sound-dai-cells = <0>;
-&i2c3 {
- status = "okay";
-&i2c4 {
- i2c-scl-rising-time-ns = <600>;
- i2c-scl-falling-time-ns = <20>;
- status = "okay";
- fusb0: typec-portc@22 {
compatible = "fcs,fusb302";
reg = <0x22>;
interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&fusb0_int>;
vbus-supply = <&vcc5v0_typec>;
ports {
#address-cells = <1>;
#size-cells = <0>;
port@0 {
reg = <0>;
usbc0_role_sw: endpoint@0 {
remote-endpoint = <&dwc3_0_role_switch>;
connector {
compatible = "usb-c-connector";
data-role = "dual";
label = "USB-C";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usbc_hs: endpoint {
remote-endpoint = <&u2phy0_typec_hs>;
port@1 {
reg = <1>;
usbc_ss: endpoint {
remote-endpoint = <&tcphy0_typec_ss>;
-&i2s1 {
- rockchip,playback-channels = <2>;
- rockchip,capture-channels = <2>;
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- status = "okay";
- audio-supply = <&vcca1v8_codec>;
- bt656-supply = <&vcc_3v0>;
- gpio1830-supply = <&vcc_3v0>;
- sdmmc-supply = <&vcc_sdio>;
-&pmu_io_domains {
- status = "okay";
- pmu1830-supply = <&vcc_3v0>;
-&pinctrl {
- buttons {
pwrbtn: pwrbtn {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>;
- bt {
bt_enable_h: bt-enable-h {
rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake_l: bt-host-wake-l {
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
bt_wake_l: bt-wake-l {
rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
- fusb302x {
fusb0_int: fusb0-int {
rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>;
- lcd-panel {
lcd_panel_reset: lcd-panel-reset {
rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>;
- leds {
work_led_pin: work-led-pin {
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
user_led_pin: user-led-pin {
rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
heartbeat_led_pin: heartbeat-led-pin {
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
wlan_active_led_pin: wlan-led-pin {
bt_active_led_pin: bt-led-pin {
rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
vsel1_pin: vsel1-pin {
rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>;
vsel2_pin: vsel2-pin {
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
- rt5651 {
rt5651_hpcon: rt5640-hpcon {
rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
- usb-typec {
vcc5v0_typec_en: vcc5v0_typec_en {
rockchip,pins = <4 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
- usb2 {
vcc5v0_host3_en: vcc5v0-host3-en {
rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
vcc5v0_host1_en: vcc5v0-host1-en {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
- wifi {
wifi_host_wake_l: wifi-host-wake-l {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
-&pwm0 {
- status = "okay";
-&saradc {
- vref-supply = <&vcca1v8_s3>;
- status = "okay";
-&sdio0 {
- /* WiFi & BT combo module AMPAK AP6255 */
- #address-cells = <1>;
- #size-cells = <0>;
- bus-width = <4>;
- clock-frequency = <50000000>;
- cap-sdio-irq;
- cap-sd-highspeed;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- status = "okay";
- brcmf: wifi@1 {
compatible = "brcm,bcm4329-fmac";
reg = <1>;
interrupt-parent = <&gpio0>;
interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "host-wake";
pinctrl-0 = <&wifi_host_wake_l>;
-&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- non-removable;
- status = "okay";
-&tcphy0 {
- status = "okay";
-&tcphy0_usb3 {
- orientation-switch;
- port {
tcphy0_typec_ss: endpoint {
remote-endpoint = <&usbc_ss>;
-&tcphy1 {
- status = "okay";
-&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- /* tshut polarity 0:LOW 1:HIGH */
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
phy-supply = <&vcc5v0_host3>;
status = "okay";
- port {
u2phy0_typec_hs: endpoint {
remote-endpoint = <&usbc_hs>;
-&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
- status = "okay";
- bluetooth {
compatible = "brcm,bcm4345c5";
clock-names = "lpo";
device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>;
host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>;
shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>;
max-speed = <1500000>;
pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>;
vbat-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc_1v8>;
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- usb-role-switch;
- port {
#size-cells = <0>;
dwc3_0_role_switch: endpoint@0 {
reg = <0>;
remote-endpoint = <&usbc0_role_sw>;
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-evb.dts b/arch/arm/dts/rk3399-evb.dts deleted file mode 100644 index 55eca7a50a1f..000000000000 --- a/arch/arm/dts/rk3399-evb.dts +++ /dev/null @@ -1,485 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
-/dts-v1/; -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi"
- model = "Rockchip RK3399 Evaluation Board";
- compatible = "rockchip,rk3399-evb", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
mmc0 = &sdhci;
0 1 2 3 4 5 6 7
- edp_panel: edp-panel {
compatible = "lg,lp079qx1-sp0v";
backlight = <&backlight>;
enable-gpios = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>;
power-supply = <&vcc3v3_s0>;
port {
panel_in_edp: endpoint {
remote-endpoint = <&edp_out_panel>;
#clock-cells = <0>;
- vdd_center: vdd-center {
compatible = "pwm-regulator";
pwms = <&pwm3 0 25000 0>;
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1400000>;
regulator-boot-on;
status = "okay";
regulator-boot-on;
regulator-boot-on;
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
pinctrl-0 = <&vcc5v0_host_en>;
regulator-name = "vcc5v0_host";
- vcc_phy: vcc-phy-regulator {
regulator-name = "vcc_phy";
regulator-boot-on;
regulator-boot-on;
-&edp {
- status = "okay";
- force-hpd;
- ports {
edp_out: port@1 {
reg = <1>;
#size-cells = <0>;
edp_out_panel: endpoint@0 {
reg = <0>;
remote-endpoint = <&panel_in_edp>;
-&emmc_phy {
- status = "okay";
-&gmac {
- phy-supply = <&vcc_phy>;
- status = "okay";
-&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
wakeup-source;
#clock-cells = <1>;
vddio-supply = <&vcc1v8_pmu>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc3v0_tp: LDO_REG2 {
regulator-name = "vcc3v0_tp";
regulator-boot-on;
regulator-boot-on;
vcc_sd: LDO_REG4 {
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
vcc3v3_s3: SWITCH_REG1 {
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
-&pwm0 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&pwm3 {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
-&pcie_phy {
- status = "disabled";
-&pcie0 {
- ep-gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
-&u2phy0 {
- status = "okay";
-&u2phy0_host {
- phy-supply = <&vcc5v0_host>;
- status = "okay";
-&u2phy1 {
- status = "okay";
-&u2phy1_host {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&pinctrl {
- pmic {
rockchip,pins =
- usb2 {
vcc5v0_host_en: vcc5v0-host-en {
rockchip,pins =
<4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-ficus.dts b/arch/arm/dts/rk3399-ficus.dts deleted file mode 100644 index 30e4879f322c..000000000000 --- a/arch/arm/dts/rk3399-ficus.dts +++ /dev/null @@ -1,174 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2018 Collabora Ltd.
- Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd.
- Schematics available at https://dl.vamrs.com/products/ficus/docs/hw
-/dts-v1/; -#include "rk3399-rock960.dtsi"
- model = "96boards RK3399 Ficus";
- compatible = "vamrs,ficus", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
- chosen {
#clock-cells = <0>;
- leds {
pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>,
<&user_led3_pin>, <&user_led4_pin>,
<&wlan_led_pin>, <&bt_led_pin>;
user_led1: led-1 {
label = "red:user1";
gpios = <&gpio4 25 0>;
user_led2: led-2 {
label = "red:user2";
gpios = <&gpio4 26 0>;
linux,default-trigger = "mmc0";
user_led3: led-3 {
label = "red:user3";
gpios = <&gpio4 30 0>;
linux,default-trigger = "mmc1";
user_led4: led-4 {
label = "red:user4";
gpios = <&gpio1 0 0>;
panic-indicator;
linux,default-trigger = "none";
wlan_active_led: led-5 {
label = "red:wlan";
gpios = <&gpio1 1 0>;
bt_active_led: led-6 {
label = "red:bt";
gpios = <&gpio1 4 0>;
-&gmac {
- phy-supply = <&vcc3v3_sys>;
- status = "okay";
-&pcie0 {
- ep-gpios = <&gpio4 RK_PD4 GPIO_ACTIVE_HIGH>;
-&pinctrl {
- gmac {
rgmii_sleep_pins: rgmii-sleep-pins {
rockchip,pins =
<3 RK_PB7 RK_FUNC_GPIO &pcfg_output_low>;
- pcie {
pcie_drv: pcie-drv {
rockchip,pins =
<1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
- usb2 {
host_vbus_drv: host-vbus-drv {
rockchip,pins =
<4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
- leds {
user_led1_pin: user-led1-pin {
rockchip,pins =
user_led2_pin: user-led2-pin {
rockchip,pins =
<4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
user_led3_pin: user-led3-pin {
rockchip,pins =
<4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
user_led4_pin: user-led4-pin {
rockchip,pins =
<1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
wlan_led_pin: wlan-led-pin {
rockchip,pins =
<1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
bt_led_pin: bt-led-pin {
rockchip,pins =
<1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
-&spi1 {
- /* On both Low speed and High speed expansion */
- cs-gpios = <0>, <&gpio4 RK_PA6 0>, <&gpio4 RK_PA7 0>;
- status = "okay";
-&usbdrd_dwc3_0 {
- dr_mode = "host";
-&usbdrd_dwc3_1 {
- dr_mode = "host";
-&vcc3v3_pcie {
- gpio = <&gpio1 24 GPIO_ACTIVE_HIGH>;
-&vcc5v0_host {
- gpio = <&gpio4 27 GPIO_ACTIVE_HIGH>;
-}; diff --git a/arch/arm/dts/rk3399-firefly.dts b/arch/arm/dts/rk3399-firefly.dts deleted file mode 100644 index 260415d99aeb..000000000000 --- a/arch/arm/dts/rk3399-firefly.dts +++ /dev/null @@ -1,944 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
-/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/usb/pd.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- model = "Firefly-RK3399 Board";
- compatible = "firefly,firefly-rk3399", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
0 1 2 3 4 5 6 7
#clock-cells = <0>;
- dc_12v: dc-12v {
regulator-boot-on;
- gpio-keys {
autorepeat;
key-power {
wakeup-source;
- ir-receiver {
compatible = "gpio-ir-receiver";
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&ir_int>;
- leds {
pinctrl-0 = <&work_led_pin>, <&diy_led_pin>;
work_led: led-0 {
label = "work";
diy_led: led-1 {
label = "diy";
- rt5640-sound {
simple-audio-card,name = "rockchip,rt5640-codec";
"IN1P", "Mic Jack",
sound-dai = <&rt5640>;
- sound-dit {
compatible = "audio-graph-card";
label = "SPDIF";
dais = <&spdif_p0>;
- spdif-dit {
compatible = "linux,spdif-dit";
port {
dit_p0_0: endpoint {
remote-endpoint = <&spdif_p0_0>;
regulator-boot-on;
- vcc3v3_pcie: vcc3v3-pcie-regulator {
enable-active-high;
gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie_pwr_en>;
regulator-boot-on;
regulator-boot-on;
vin-supply = <&vcc_sys>;
- /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */
enable-active-high;
gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>;
- vcc_sys: vcc-sys {
regulator-name = "vcc_sys";
regulator-boot-on;
pwms = <&pwm2 0 25000 1>;
pwm-supply = <&vcc_sys>;
regulator-boot-on;
regulator-min-microvolt = <430000>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&i2c0 {
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
vcc1-supply = <&vcc_sys>;
vcc2-supply = <&vcc_sys>;
vcc3-supply = <&vcc_sys>;
vcc4-supply = <&vcc_sys>;
vcc6-supply = <&vcc_sys>;
vcc7-supply = <&vcc_sys>;
vcc9-supply = <&vcc_sys>;
vcc10-supply = <&vcc_sys>;
vcc11-supply = <&vcc_sys>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
fcs,suspend-voltage-selector = <0>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
-&i2c1 {
- status = "okay";
- rt5640: rt5640@1c {
compatible = "realtek,rt5640";
reg = <0x1c>;
realtek,in1-differential;
pinctrl-0 = <&rt5640_hpcon>;
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
reg = <0x22>;
status = "okay";
connector {
data-role = "host";
label = "USB-C";
op-sink-microwatt = <1000000>;
power-role = "dual";
sink-pdos =
<PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>;
source-pdos =
<PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>;
try-power-role = "sink";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usbc_hs: endpoint {
remote-endpoint =
<&u2phy0_typec_hs>;
port@1 {
reg = <1>;
usbc_ss: endpoint {
remote-endpoint =
<&tcphy0_typec_ss>;
- accelerometer@68 {
compatible = "invensense,mpu6500";
reg = <0x68>;
interrupts = <RK_PC6 IRQ_TYPE_EDGE_RISING>;
-&i2s0 {
- rockchip,playback-channels = <8>;
- rockchip,capture-channels = <8>;
- status = "okay";
-&i2s1 {
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- status = "okay";
- bt656-supply = <&vcc1v8_dvp>;
-&pcie_phy {
- status = "okay";
-&pcie0 {
- ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- status = "okay";
-&pmu_io_domains {
- status = "okay";
-&pinctrl {
- buttons {
pwrbtn: pwrbtn {
- fusb302x {
- ir {
ir_int: ir-int {
- lcd-panel {
- leds {
diy_led_pin: diy-led-pin {
- pcie {
pcie_pwr_en: pcie-pwr-en {
rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_3g_drv: pcie-3g-drv {
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>;
- pmic {
rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>;
- rt5640 {
rt5640_hpcon: rt5640-hpcon {
rockchip,pins = <4 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
- usb-typec {
rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- usb2 {
rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
- wifi {
-&pwm0 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdio0 {
- /* WiFi & BT combo module Ampak AP6356S */
- bus-width = <4>;
- cap-sdio-irq;
- cap-sd-highspeed;
- non-removable;
- sd-uhs-sdr104;
- /* Power supply */
- vqmmc-supply = <&vcc1v8_s3>; /* IO line */
- vmmc-supply = <&vcc_sdio>; /* card's power */
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
brcm,drive-strength = <5>;
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
- disable-wp;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
-&spdif {
- pinctrl-0 = <&spdif_bus_1>;
- status = "okay";
- spdif_p0: port {
spdif_p0_0: endpoint {
remote-endpoint = <&dit_p0_0>;
-&tcphy0 {
- status = "okay";
-&tcphy0_usb3 {
- port {
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
status = "okay";
- port {
-&u2phy1 {
- status = "okay";
status = "okay";
status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts>;
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-gru-bob.dts b/arch/arm/dts/rk3399-gru-bob.dts deleted file mode 100644 index 1cba1d857c96..000000000000 --- a/arch/arm/dts/rk3399-gru-bob.dts +++ /dev/null @@ -1,95 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Google Gru-Bob Rev 4+ board device tree source
- Copyright 2018 Google, Inc
-/dts-v1/; -#include "rk3399-gru-chromebook.dtsi"
- model = "Google Bob";
- compatible = "google,bob-rev13", "google,bob-rev12",
"google,bob-rev11", "google,bob-rev10",
"google,bob-rev9", "google,bob-rev8",
"google,bob-rev7", "google,bob-rev6",
"google,bob-rev5", "google,bob-rev4",
"google,bob", "google,gru", "rockchip,rk3399";
- chassis-type = "convertible";
compatible = "boe,nv101wxmn51";
power-supply = <&pp3300_disp>;
port {
-&ap_i2c_ts {
- touchscreen: touchscreen@10 {
compatible = "elan,ekth3500";
reg = <0x10>;
interrupt-parent = <&gpio3>;
interrupts = <13 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&touch_int_l &touch_reset_l>;
reset-gpios = <&gpio4 26 GPIO_ACTIVE_LOW>;
-&ap_i2c_tp {
- trackpad: trackpad@15 {
compatible = "elan,ekth3000";
reg = <0x15>;
interrupt-parent = <&gpio1>;
interrupts = <4 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&trackpad_int_l>;
wakeup-source;
-&backlight {
- pwms = <&cros_ec_pwm 0>;
-&cpu_alert0 {
- temperature = <65000>;
-&cpu_alert1 {
- temperature = <70000>;
-&spi0 {
- status = "okay";
- tpm@0 {
compatible = "google,cr50";
reg = <0>;
interrupts = <5 IRQ_TYPE_EDGE_RISING>;
pinctrl-0 = <&h1_int_od_l>;
spi-max-frequency = <800000>;
-&pinctrl {
- tpm {
h1_int_od_l: h1-int-od-l {
-&wlan_host_wake_l {
- /* Kevin has an external pull up, but Bob does not. */
- rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
-}; diff --git a/arch/arm/dts/rk3399-gru-chromebook.dtsi b/arch/arm/dts/rk3399-gru-chromebook.dtsi deleted file mode 100644 index cacbad35cfc8..000000000000 --- a/arch/arm/dts/rk3399-gru-chromebook.dtsi +++ /dev/null @@ -1,590 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Google Gru-Chromebook shared properties
-#include "rk3399-gru.dtsi"
- pp900_ap: pp900-ap {
compatible = "regulator-fixed";
regulator-name = "pp900_ap";
/* EC turns on w/ pp900_ap_en; always on for AP */
regulator-boot-on;
vin-supply = <&ppvar_sys>;
- /* EC turns on w/ pp900_usb_en */
- pp900_usb: pp900-ap {
- /* EC turns on w/ pp900_pcie_en */
- pp900_pcie: pp900-ap {
- pp3000: pp3000 {
regulator-name = "pp3000";
pinctrl-0 = <&pp3000_en>;
enable-active-high;
gpio = <&gpio0 12 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
- ppvar_centerlogic_pwm: ppvar-centerlogic-pwm {
regulator-name = "ppvar_centerlogic_pwm";
pwms = <&pwm3 0 3337 0>;
pwm-supply = <&ppvar_sys>;
pwm-dutycycle-range = <100 0>;
pwm-dutycycle-unit = <100>;
/* EC turns on w/ ppvar_centerlogic_en; always on for AP */
regulator-boot-on;
regulator-min-microvolt = <799434>;
regulator-max-microvolt = <1049925>;
- ppvar_centerlogic: ppvar-centerlogic {
compatible = "vctrl-regulator";
regulator-name = "ppvar_centerlogic";
ctrl-supply = <&ppvar_centerlogic_pwm>;
ctrl-voltage-range = <799434 1049925>;
regulator-settling-time-up-us = <378>;
min-slew-down-rate = <225>;
ovp-threshold-percent = <16>;
- /* Schematics call this PPVAR even though it's fixed */
- ppvar_logic: ppvar-logic {
regulator-name = "ppvar_logic";
/* EC turns on w/ ppvar_logic_en; always on for AP */
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
- pp1800_audio: pp1800-audio {
regulator-name = "pp1800_audio";
pinctrl-0 = <&pp1800_audio_en>;
enable-active-high;
gpio = <&gpio0 2 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
vin-supply = <&pp1800>;
- /* gpio is shared with pp3300_wifi_bt */
- pp1800_pcie: pp1800-pcie {
regulator-name = "pp1800_pcie";
pinctrl-0 = <&wlan_module_pd_l>;
enable-active-high;
gpio = <&gpio0 4 GPIO_ACTIVE_HIGH>;
* Need to wait 1ms + ramp-up time before we can power on WiFi.
* This has been approximated as 8ms total.
regulator-enable-ramp-delay = <8000>;
- /* Always on; plain and simple */
- pp3000_ap: pp3000_emmc: pp3000 {
- pp1500_ap_io: pp1500-ap-io {
regulator-name = "pp1500_ap_io";
pinctrl-0 = <&pp1500_en>;
enable-active-high;
gpio = <&gpio0 10 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
- pp3300_disp: pp3300-disp {
regulator-name = "pp3300_disp";
pinctrl-0 = <&pp3300_disp_en>;
enable-active-high;
startup-delay-us = <2000>;
vin-supply = <&pp3300>;
- /* EC turns on w/ pp3300_usb_en_l */
- pp3300_usb: pp3300 {
- /* gpio is shared with pp1800_pcie and pinctrl is set there */
- pp3300_wifi_bt: pp3300-wifi-bt {
regulator-name = "pp3300_wifi_bt";
enable-active-high;
* This is a bit of a hack. The WiFi module should be reset at least
* 1ms after its regulators have ramped up (max rampup time is ~7ms).
* With some stretching of the imagination, we can call the 1.8V
* regulator a supply.
- wlan_pd_n: wlan-pd-n {
regulator-name = "wlan_pd_n";
pinctrl-0 = <&wlan_module_reset_l>;
enable-active-high;
gpio = <&gpio1 11 GPIO_ACTIVE_HIGH>;
vin-supply = <&pp1800_pcie>;
enable-gpios = <&gpio1 17 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&bl_en>;
- gpio_keys: gpio-keys {
pinctrl-0 = <&bt_host_wake_l>;
wake_on_bt: key-wake-on-bt {
label = "Wake-on-Bluetooth";
gpios = <&gpio0 3 GPIO_ACTIVE_LOW>;
linux,code = <KEY_WAKEUP>;
wakeup-source;
-&ppvar_bigcpu {
- min-slew-down-rate = <225>;
- ovp-threshold-percent = <16>;
-&ppvar_litcpu {
-&ppvar_gpu {
-&cdn_dp {
- extcon = <&usbc_extcon0>, <&usbc_extcon1>;
-&dmc {
- center-supply = <&ppvar_centerlogic>;
- rockchip,pd-idle-dis-freq-hz = <800000000>;
- rockchip,sr-idle-dis-freq-hz = <800000000>;
- rockchip,sr-mc-gate-idle-dis-freq-hz = <800000000>;
-&edp {
- status = "okay";
* eDP PHY/clk don't sync reliably at anything other than 24 MHz. Only
* set this here, because rk3399-gru.dtsi ensures we can generate this
* off GPLL=600MHz, whereas some other RK3399 boards may not.
- assigned-clocks = <&cru PCLK_EDP>;
- assigned-clock-rates = <24000000>;
- ports {
edp_out: port@1 {
reg = <1>;
#size-cells = <0>;
reg = <0>;
-&gpio0 {
- gpio-line-names = /* GPIO0 A 0-7 */
"AP_RTC_CLK_IN",
"EC_AP_INT_L",
"PP1800_AUDIO_EN",
"BT_HOST_WAKE_L",
"WLAN_MODULE_PD_L",
"H1_INT_OD_L",
"CENTERLOGIC_DVS_PWM",
/* GPIO0 B 0-4 */
"WIFI_HOST_WAKE_L",
"PMUIO2_33_18_L",
"PP1500_EN",
"AP_EC_WARM_RESET_REQ",
"PP3000_EN";
-&gpio1 {
- gpio-line-names = /* GPIO1 A 0-7 */
"SPK_PA_EN",
"TRACKPAD_INT_L",
"AP_EC_S3_S0_L",
"AP_EC_OVERTEMP",
"AP_SPI_FLASH_MISO",
/* GPIO1 B 0-7 */
"AP_SPI_FLASH_MOSI_R",
"AP_SPI_FLASH_CLK_R",
"AP_SPI_FLASH_CS_L_R",
"WLAN_MODULE_RESET_L",
"WIFI_DISABLE_L",
"MIC_INT",
"AP_I2C_DVS_SDA",
/* GPIO1 C 0-7 */
"AP_I2C_DVS_SCL",
"AP_BL_EN",
* AP_FLASH_WP is crossystem ABI. Schematics call it
* AP_FW_WP or CPU1_FW_WP, depending on the variant.
"AP_FLASH_WP",
"LITCPU_DVS_PWM",
"AP_I2C_AUDIO_SDA",
"AP_I2C_AUDIO_SCL",
"HEADSET_INT_L";
-&gpio2 {
- gpio-line-names = /* GPIO2 A 0-7 */
"SD_IO_PWR_EN",
/* GPIO2 B 0-7 */
/* GPIO2 C 0-7 */
"AP_SPI_EC_MISO",
"AP_SPI_EC_MOSI",
"AP_SPI_EC_CLK",
"AP_SPI_EC_CS_L",
/* GPIO2 D 0-4 */
"BT_DEV_WAKE_L",
"WIFI_PCIE_CLKREQ_L",
"WIFI_PERST_L",
"SD_PWR_3000_1800_L";
-&gpio3 {
- gpio-line-names = /* GPIO3 A 0-7 */
"AP_SPI_TPM_MISO",
"AP_SPI_TPM_MOSI_R",
"AP_SPI_TPM_CLK_R",
"AP_SPI_TPM_CS_L_R",
/* GPIO3 B 0-7 */
"EC_IN_RW",
"AP_I2C_TP_SDA",
"AP_I2C_TP_SCL",
"AP_I2C_TP_PU_EN",
"TOUCH_INT_L",
/* GPIO3 C 0-7 */
/* GPIO3 D 0-7 */
"I2S0_SCLK",
"I2S0_LRCK_RX",
"I2S0_LRCK_TX",
"I2S0_SDI_0",
"I2S0_SDI_1",
"I2S0_SDO_1",
"I2S0_SDO_0";
-&gpio4 {
- gpio-line-names = /* GPIO4 A 0-7 */
"I2S_MCLK",
"AP_I2C_MIC_SDA",
"AP_I2C_MIC_SCL",
/* GPIO4 B 0-7 */
/* GPIO4 C 0-7 */
"AP_I2C_TS_SDA",
"AP_I2C_TS_SCL",
"GPU_DVS_PWM",
"UART_DBG_TX_AP_RX",
"UART_AP_TX_DBG_RX",
"BIGCPU_DVS_PWM",
"EDP_HPD_3V0",
/* GPIO4 D 0-5 */
"SD_CARD_DET_L",
"USB_DP_HPD",
"TOUCH_RESET_L",
"PP3300_DISP_EN",
"SD_SLOT_PWR_EN";
-ap_i2c_mic: &i2c1 {
- status = "okay";
- clock-frequency = <400000>;
- /* These are relatively safe rise/fall times */
- i2c-scl-falling-time-ns = <50>;
- headsetcodec: rt5514@57 {
compatible = "realtek,rt5514";
reg = <0x57>;
realtek,dmic-init-delay-ms = <20>;
-ap_i2c_tp: &i2c5 {
- status = "okay";
* Note strange pullup enable. Apparently this avoids leakage but
* still allows us to get nice 4.7K pullups for high speed i2c
* transfers. Basically we want the pullup on whenever the ap is
* alive, so the "en" pin just gets set to output high.
- pinctrl-0 = <&i2c5_xfer &ap_i2c_tp_pu_en>;
-&cros_ec {
- cros_ec_pwm: pwm {
compatible = "google,cros-ec-pwm";
#pwm-cells = <1>;
- usbc_extcon1: extcon1 {
compatible = "google,extcon-usbc-cros-ec";
google,usb-port-id = <1>;
-&sound {
- rockchip,codec = <&max98357a &headsetcodec
&codec &wacky_spi_audio &cdn_dp>;
-&spi2 {
- wacky_spi_audio: spi2@0 {
reg = <0>;
interrupts = <13 IRQ_TYPE_LEVEL_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&mic_int>;
/* May run faster once verified. */
spi-max-frequency = <10000000>;
wakeup-source;
-&pci_rootport {
- mvl_wifi: wifi@0,0 {
compatible = "pci1b4b,2b42";
reg = <0x0000 0x0 0x0 0x0 0x0>;
interrupts = <8 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&wlan_host_wake_l>;
wakeup-source;
-&tcphy1 {
- status = "okay";
- extcon = <&usbc_extcon1>;
-&u2phy1 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&pinctrl {
- discrete-regulators {
pp1500_en: pp1500-en {
&pcfg_pull_none>;
pp1800_audio_en: pp1800-audio-en {
&pcfg_pull_down>;
pp3000_en: pp3000-en {
&pcfg_pull_none>;
pp3300_disp_en: pp3300-disp-en {
rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO
&pcfg_pull_none>;
wlan_module_pd_l: wlan-module-pd-l {
&pcfg_pull_down>;
-&wifi {
- wifi_perst_l: wifi-perst-l {
rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
- wlan_host_wake_l: wlan-host-wake-l {
/* Kevin has an external pull up, but Bob does not */
-}; diff --git a/arch/arm/dts/rk3399-gru-kevin.dts b/arch/arm/dts/rk3399-gru-kevin.dts deleted file mode 100644 index 2cc9b3386c16..000000000000 --- a/arch/arm/dts/rk3399-gru-kevin.dts +++ /dev/null @@ -1,328 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Google Gru-Kevin Rev 6+ board device tree source
- Copyright 2016-2017 Google, Inc
-/dts-v1/; -#include "rk3399-gru-chromebook.dtsi" -#include <dt-bindings/input/linux-event-codes.h>
- Kevin-specific things
- Things in this section should use names from Kevin schematic since no
- equivalent exists in Gru schematic. If referring to signals that exist
- in Gru we use the Gru names, though. Confusing enough for you?
- model = "Google Kevin";
- compatible = "google,kevin-rev15", "google,kevin-rev14",
"google,kevin-rev13", "google,kevin-rev12",
"google,kevin-rev11", "google,kevin-rev10",
"google,kevin-rev9", "google,kevin-rev8",
"google,kevin-rev7", "google,kevin-rev6",
"google,kevin", "google,gru", "rockchip,rk3399";
- /* Power tree */
- p3_3v_dig: p3-3v-dig {
regulator-name = "p3.3v_dig";
pinctrl-0 = <&cpu3_pen_pwr_en>;
enable-active-high;
gpio = <&gpio4 30 GPIO_ACTIVE_HIGH>;
compatible = "sharp,lq123p1jx31";
panel-timing {
clock-frequency = <266666667>;
hactive = <2400>;
hfront-porch = <48>;
hback-porch = <84>;
hsync-len = <32>;
hsync-active = <0>;
vactive = <1600>;
vfront-porch = <3>;
vback-porch = <120>;
vsync-len = <10>;
vsync-active = <0>;
port {
- thermistor_ppvar_bigcpu: thermistor-ppvar-bigcpu {
compatible = "murata,ncp15wb473";
pullup-uv = <1800000>;
pullup-ohm = <25500>;
pulldown-ohm = <0>;
io-channels = <&saradc 2>;
#thermal-sensor-cells = <0>;
- thermistor_ppvar_litcpu: thermistor-ppvar-litcpu {
pulldown-ohm = <0>;
io-channels = <&saradc 3>;
-&backlight {
- pwms = <&cros_ec_pwm 1>;
-&gpio_keys {
- pinctrl-names = "default";
- pinctrl-0 = <&bt_host_wake_l>, <&cpu1_pen_eject>;
- switch-pen-insert {
label = "Pen Insert";
/* Insert = low, eject = high */
gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
linux,code = <SW_PEN_INSERTED>;
linux,input-type = <EV_SW>;
wakeup-source;
-&thermal_zones {
- bigcpu_reg_thermal: bigcpu-reg-thermal {
polling-delay-passive = <100>; /* milliseconds */
polling-delay = <1000>; /* milliseconds */
thermal-sensors = <&thermistor_ppvar_bigcpu 0>;
sustainable-power = <4000>;
ppvar_bigcpu_trips: trips {
ppvar_bigcpu_on: ppvar-bigcpu-on {
temperature = <40000>; /* millicelsius */
hysteresis = <2000>; /* millicelsius */
type = "passive";
ppvar_bigcpu_alert: ppvar-bigcpu-alert {
temperature = <50000>; /* millicelsius */
type = "passive";
ppvar_bigcpu_crit: ppvar-bigcpu-crit {
temperature = <90000>; /* millicelsius */
hysteresis = <0>; /* millicelsius */
type = "critical";
cooling-maps {
map0 {
trip = <&ppvar_bigcpu_alert>;
cooling-device =
<&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
contribution = <4096>;
map1 {
cooling-device =
<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
contribution = <1024>;
- litcpu_reg_thermal: litcpu-reg-thermal {
thermal-sensors = <&thermistor_ppvar_litcpu 0>;
ppvar_litcpu_trips: trips {
ppvar_litcpu_on: ppvar-litcpu-on {
type = "passive";
ppvar_litcpu_alert: ppvar-litcpu-alert {
type = "passive";
ppvar_litcpu_crit: ppvar-litcpu-crit {
type = "critical";
-ap_i2c_tpm: &i2c0 {
- status = "okay";
- /* These are relatively safe rise/fall times. */
- tpm: tpm@20 {
compatible = "infineon,slb9645tt";
reg = <0x20>;
powered-while-suspended;
-ap_i2c_dig: &i2c2 {
- status = "okay";
- digitizer: digitizer@9 {
/* wacom,w9013 */
compatible = "hid-over-i2c";
reg = <0x9>;
pinctrl-0 = <&cpu1_dig_irq_l &cpu1_dig_pdct_l>;
vdd-supply = <&p3_3v_dig>;
post-power-on-delay-ms = <100>;
interrupt-parent = <&gpio2>;
hid-descr-addr = <0x1>;
-/* Adjustments to things in the gru baseboard */
-&ap_i2c_tp {
- trackpad@4a {
compatible = "atmel,maxtouch";
reg = <0x4a>;
linux,gpio-keymap = <KEY_RESERVED
KEY_RESERVED
KEY_RESERVED
BTN_LEFT>;
wakeup-source;
-&ap_i2c_ts {
- touchscreen@4b {
reg = <0x4b>;
pinctrl-0 = <&touch_int_l>;
-&ppvar_bigcpu_pwm {
- regulator-min-microvolt = <798674>;
- regulator-max-microvolt = <1302172>;
-&ppvar_bigcpu {
- ctrl-voltage-range = <798674 1302172>;
-&ppvar_litcpu_pwm {
- regulator-min-microvolt = <799065>;
- regulator-max-microvolt = <1303738>;
-&ppvar_litcpu {
- ctrl-voltage-range = <799065 1303738>;
-&ppvar_gpu_pwm {
- regulator-min-microvolt = <785782>;
- regulator-max-microvolt = <1217729>;
-&ppvar_gpu {
- ctrl-voltage-range = <785782 1217729>;
-&ppvar_centerlogic_pwm {
- regulator-min-microvolt = <800069>;
- regulator-max-microvolt = <1049692>;
-&ppvar_centerlogic {
- ctrl-voltage-range = <800069 1049692>;
-&saradc {
- status = "okay";
- vref-supply = <&pp1800_ap_io>;
-&mvl_wifi {
- marvell,wakeup-pin = <14>; /* GPIO_14 on Marvell */
-&pinctrl {
- digitizer {
/* Has external pullup */
cpu1_dig_irq_l: cpu1-dig-irq-l {
rockchip,pins = <2 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
cpu1_dig_pdct_l: cpu1-dig-pdct-l {
rockchip,pins = <2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
cpu3_pen_pwr_en: cpu3-pen-pwr-en {
rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
- pen {
cpu1_pen_eject: cpu1-pen-eject {
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>;
-}; diff --git a/arch/arm/dts/rk3399-gru.dtsi b/arch/arm/dts/rk3399-gru.dtsi deleted file mode 100644 index d90fe4d40d48..000000000000 --- a/arch/arm/dts/rk3399-gru.dtsi +++ /dev/null @@ -1,865 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Google Gru (and derivatives) board device tree source
-#include <dt-bindings/input/input.h> -#include "rk3399.dtsi" -#include "rk3399-op1-opp.dtsi"
- aliases {
mmc0 = &sdmmc;
mmc1 = &sdhci;
- chosen {
stdout-path = "serial2:115200n8";
* Power Tree
* In general an attempt is made to include all rails called out by
* the schematic as long as those rails interact in some way with
* the AP. AKA:
* - Rails that only connect to the EC (or devices that the EC talks to)
* are not included.
* - Rails _are_ included if the rails go to the AP even if the AP
* doesn't currently care about them / they are always on. The idea
* here is that it makes it easier to map to the schematic or extend
* later.
* If two rails are substantially the same from the AP's point of
* view, though, we won't create a full fixed regulator. We'll just
* put the child rail as an alias of the parent rail. Sometimes rails
* look the same to the AP because one of these is true:
* - The EC controls the enable and the EC always enables a rail as
* long as the AP is running.
* - The rails are actually connected to each other by a jumper and
* the distinction is just there to add clarity/flexibility to the
* schematic.
- ppvar_sys: ppvar-sys {
regulator-name = "ppvar_sys";
regulator-always-on;
regulator-boot-on;
- pp1200_lpddr: pp1200-lpddr {
regulator-name = "pp1200_lpddr";
/* EC turns on w/ lpddr_pwr_en; always on for AP */
regulator-boot-on;
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
- pp1800: pp1800 {
regulator-name = "pp1800";
/* Always on when ppvar_sys shows power good */
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
- pp3300: pp3300 {
regulator-name = "pp3300";
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
- pp5000: pp5000 {
regulator-name = "pp5000";
/* EC turns on w/ pp5000_en; always on for AP */
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
- ppvar_bigcpu_pwm: ppvar-bigcpu-pwm {
regulator-name = "ppvar_bigcpu_pwm";
pwms = <&pwm1 0 3337 0>;
/* EC turns on w/ ap_core_en; always on for AP */
regulator-boot-on;
regulator-min-microvolt = <800107>;
regulator-max-microvolt = <1302232>;
- ppvar_bigcpu: ppvar-bigcpu {
regulator-name = "ppvar_bigcpu";
ctrl-supply = <&ppvar_bigcpu_pwm>;
ctrl-voltage-range = <800107 1302232>;
regulator-settling-time-up-us = <322>;
- ppvar_litcpu_pwm: ppvar-litcpu-pwm {
regulator-name = "ppvar_litcpu_pwm";
pwms = <&pwm2 0 3337 0>;
regulator-boot-on;
regulator-min-microvolt = <797743>;
regulator-max-microvolt = <1307837>;
- ppvar_litcpu: ppvar-litcpu {
regulator-name = "ppvar_litcpu";
ctrl-supply = <&ppvar_litcpu_pwm>;
ctrl-voltage-range = <797743 1307837>;
regulator-settling-time-up-us = <384>;
- ppvar_gpu_pwm: ppvar-gpu-pwm {
regulator-name = "ppvar_gpu_pwm";
pwms = <&pwm0 0 3337 0>;
regulator-boot-on;
regulator-min-microvolt = <786384>;
regulator-max-microvolt = <1217747>;
- ppvar_gpu: ppvar-gpu {
regulator-name = "ppvar_gpu";
ctrl-supply = <&ppvar_gpu_pwm>;
ctrl-voltage-range = <786384 1217747>;
regulator-settling-time-up-us = <390>;
- /* EC turns on w/ pp900_ddrpll_en */
- pp900_ddrpll: pp900-ap {
- /* EC turns on w/ pp900_pll_en */
- pp900_pll: pp900-ap {
- /* EC turns on w/ pp900_pmu_en */
- pp900_pmu: pp900-ap {
- /* EC turns on w/ pp1800_s0_en_l */
- pp1800_ap_io: pp1800_emmc: pp1800_nfc: pp1800_s0: pp1800 {
- /* EC turns on w/ pp1800_avdd_en_l */
- pp1800_avdd: pp1800 {
- /* EC turns on w/ pp1800_lid_en_l */
- pp1800_lid: pp1800_mic: pp1800 {
- /* EC turns on w/ lpddr_pwr_en */
- pp1800_lpddr: pp1800 {
- /* EC turns on w/ pp1800_pmu_en_l */
- pp1800_pmu: pp1800 {
- /* EC turns on w/ pp1800_usb_en_l */
- pp1800_usb: pp1800 {
- pp3000_sd_slot: pp3000-sd-slot {
regulator-name = "pp3000_sd_slot";
pinctrl-0 = <&sd_slot_pwr_en>;
enable-active-high;
gpio = <&gpio4 29 GPIO_ACTIVE_HIGH>;
vin-supply = <&pp3000>;
* Technically, this is a small abuse of 'regulator-gpio'; this
* regulator is a mux between pp1800 and pp3300. pp1800 and pp3300 are
* always on though, so it is sufficient to simply control the mux
* here.
- ppvar_sd_card_io: ppvar-sd-card-io {
compatible = "regulator-gpio";
regulator-name = "ppvar_sd_card_io";
pinctrl-0 = <&sd_io_pwr_en &sd_pwr_1800_sel>;
enable-active-high;
enable-gpios = <&gpio2 2 GPIO_ACTIVE_HIGH>;
gpios = <&gpio2 28 GPIO_ACTIVE_HIGH>;
states = <1800000 0x1>,
<3000000 0x0>;
regulator-max-microvolt = <3000000>;
- /* EC turns on w/ pp3300_trackpad_en_l */
- pp3300_trackpad: pp3300-trackpad {
- /* EC turns on w/ usb_a_en */
- pp5000_usb_a_vbus: pp5000 {
- ap_rtc_clk: ap-rtc-clk {
clock-frequency = <32768>;
clock-output-names = "xin32k";
#clock-cells = <0>;
- max98357a: max98357a {
compatible = "maxim,max98357a";
pinctrl-0 = <&sdmode_en>;
sdmode-gpios = <&gpio1 2 GPIO_ACTIVE_HIGH>;
sdmode-delay = <2>;
status = "okay";
- sound: sound {
compatible = "rockchip,rk3399-gru-sound";
rockchip,cpu = <&i2s0 &spdif>;
-&cdn_dp {
- status = "okay";
- Set some suspend operating points to avoid OVP in suspend
- When we go into S3 ARM Trusted Firmware will transition our PWM regulators
- from wherever they're at back to the "default" operating point (whatever
- voltage we get when we set the PWM pins to "input").
- This quick transition under light load has the possibility to trigger the
- regulator "over voltage protection" (OVP).
- To make extra certain that we don't hit this OVP at suspend time, we'll
- transition to a voltage that's much closer to the default (~1.0 V) so that
- there will not be a big jump. Technically we only need to get within 200 mV
- of the default voltage, but the speed here should be fast enough and we need
- suspend/resume to be rock solid.
-&cluster0_opp {
- opp05 {
opp-suspend;
-&cluster1_opp {
- opp06 {
opp-suspend;
-&cpu_l0 {
- cpu-supply = <&ppvar_litcpu>;
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
- cpu-supply = <&ppvar_bigcpu>;
-&cpu_b1 {
-&cru {
- assigned-clocks =
<&cru PLL_GPLL>, <&cru PLL_CPLL>,
<&cru PLL_NPLL>,
<&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>,
<&cru PCLK_PERIHP>,
<&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>,
<&cru PCLK_PERILP0>, <&cru ACLK_CCI>,
<&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>,
<&cru ACLK_VIO>, <&cru ACLK_HDCP>,
<&cru ACLK_GIC_PRE>,
<&cru PCLK_DDR>;
<600000000>, <800000000>,
<1000000000>,
<150000000>, <75000000>,
<37500000>,
<100000000>, <100000000>,
<50000000>, <800000000>,
<100000000>, <50000000>,
<400000000>, <400000000>,
<200000000>,
<200000000>;
-&dfi {
- status = "okay";
-&dmc {
- status = "okay";
- rockchip,pd-idle-ns = <160>;
- rockchip,sr-idle-ns = <10240>;
- rockchip,sr-mc-gate-idle-ns = <40960>;
- rockchip,srpd-lite-idle-ns = <61440>;
- rockchip,standby-idle-ns = <81920>;
- rockchip,ddr3_odt_dis_freq = <666000000>;
- rockchip,lpddr3_odt_dis_freq = <666000000>;
- rockchip,lpddr4_odt_dis_freq = <666000000>;
- rockchip,sr-mc-gate-idle-dis-freq-hz = <1000000000>;
- rockchip,srpd-lite-idle-dis-freq-hz = <0>;
- rockchip,standby-idle-dis-freq-hz = <928000000>;
-&dmc_opp_table {
- opp03 {
opp-suspend;
-&emmc_phy {
- status = "okay";
-&gpu {
- mali-supply = <&ppvar_gpu>;
- status = "okay";
-ap_i2c_ts: &i2c3 {
- status = "okay";
-ap_i2c_audio: &i2c8 {
- status = "okay";
- codec: da7219@1a {
compatible = "dlg,da7219";
reg = <0x1a>;
interrupts = <23 IRQ_TYPE_LEVEL_LOW>;
dlg,micbias-lvl = <2600>;
dlg,mic-amp-in-sel = "diff";
pinctrl-0 = <&headset_int_l>;
VDD-supply = <&pp1800>;
VDDMIC-supply = <&pp3300>;
VDDIO-supply = <&pp1800>;
da7219_aad {
dlg,adc-1bit-rpt = <1>;
dlg,btn-avg = <4>;
dlg,btn-cfg = <50>;
dlg,mic-det-thr = <500>;
dlg,jack-ins-deb = <20>;
dlg,jack-det-rate = "32ms_64ms";
dlg,jack-rem-deb = <1>;
dlg,a-d-btn-thr = <0xa>;
dlg,d-b-btn-thr = <0x16>;
dlg,b-c-btn-thr = <0x21>;
dlg,c-mic-btn-thr = <0x3E>;
-&i2s0 {
- status = "okay";
-&io_domains {
- status = "okay";
- audio-supply = <&pp1800_audio>; /* APIO5_VDD; 3d 4a */
- bt656-supply = <&pp1800_ap_io>; /* APIO2_VDD; 2a 2b */
- gpio1830-supply = <&pp3000_ap>; /* APIO4_VDD; 4c 4d */
- sdmmc-supply = <&ppvar_sd_card_io>; /* SDMMC0_VDD; 4b */
-&pcie0 {
- status = "okay";
- ep-gpios = <&gpio2 27 GPIO_ACTIVE_HIGH>;
- pinctrl-0 = <&pcie_clkreqn_cpm>, <&wifi_perst_l>;
- vpcie3v3-supply = <&pp3300_wifi_bt>;
- vpcie1v8-supply = <&wlan_pd_n>; /* HACK: see &wlan_pd_n */
- vpcie0v9-supply = <&pp900_pcie>;
- pci_rootport: pcie@0,0 {
reg = <0x0000 0 0 0 0>;
#address-cells = <3>;
#size-cells = <2>;
ranges;
device_type = "pci";
-&pcie_phy {
- status = "okay";
-&pmu_io_domains {
- status = "okay";
- pmu1830-supply = <&pp1800_pmu>; /* PMUIO2_VDD */
-&pwm0 {
- status = "okay";
-&pwm1 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&pwm3 {
- status = "okay";
-&sdhci {
* Signal integrity isn't great at 200 MHz and 150 MHz (DDR) gives the
* same (or nearly the same) performance for all eMMC that are intended
* to be used.
- assigned-clock-rates = <150000000>;
- bus-width = <8>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- non-removable;
- status = "okay";
-&sdmmc {
- status = "okay";
* Note: configure "sdmmc_cd" as card detect even though it's actually
* hooked to ground. Because we specified "cd-gpios" below dw_mmc
* should be ignoring card detect anyway. Specifying the pin as
* sdmmc_cd means that even if you've got GRF_SOC_CON7[12] (force_jtag)
* turned on that the system will still make sure the port is
* configured as SDMMC and not JTAG.
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_cd_pin
&sdmmc_bus4>;
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio4 24 GPIO_ACTIVE_LOW>;
- disable-wp;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- vmmc-supply = <&pp3000_sd_slot>;
- vqmmc-supply = <&ppvar_sd_card_io>;
-&spdif {
- status = "okay";
* SPDIF is routed internally to DP; we either don't use these pins, or
* mux them to something else.
- /delete-property/ pinctrl-0;
- /delete-property/ pinctrl-names;
-&spi1 {
- status = "okay";
- pinctrl-names = "default", "sleep";
- pinctrl-1 = <&spi1_sleep>;
- flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
-&spi2 {
- status = "okay";
-&spi5 {
- status = "okay";
- cros_ec: ec@0 {
compatible = "google,cros-ec-spi";
reg = <0>;
interrupts = <1 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&ec_ap_int_l>;
spi-max-frequency = <3000000>;
i2c_tunnel: i2c-tunnel {
compatible = "google,cros-ec-i2c-tunnel";
google,remote-bus = <4>;
#size-cells = <0>;
usbc_extcon0: extcon0 {
google,usb-port-id = <0>;
-&tsadc {
- status = "okay";
- rockchip,hw-tshut-mode = <1>; /* tshut mode 0:CRU 1:GPIO */
- rockchip,hw-tshut-polarity = <1>; /* tshut polarity 0:LOW 1:HIGH */
-&tcphy0 {
- status = "okay";
- extcon = <&usbc_extcon0>;
-&u2phy0 {
- status = "okay";
-&u2phy0_host {
- status = "okay";
-&u2phy1_host {
- status = "okay";
-&u2phy0_otg {
- status = "okay";
-&u2phy1_otg {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-#include <cros-ec-keyboard.dtsi> -#include <cros-ec-sbs.dtsi>
-&pinctrl {
* pinctrl settings for pins that have no real owners.
* At the moment settings are identical for S0 and S3, but if we later
* need to configure things differently for S3 we'll adjust here.
- pinctrl-0 = <
&ap_pwroff /* AP will auto-assert this when in S3 */
&clk_32k /* This pin is always 32k on gru boards */
;- pcfg_output_low: pcfg-output-low {
output-low;
- pcfg_output_high: pcfg-output-high {
output-high;
- pcfg_pull_none_8ma: pcfg-pull-none-8ma {
bias-disable;
drive-strength = <8>;
- backlight-enable {
bl_en: bl-en {
- cros-ec {
ec_ap_int_l: ec-ap-int-l {
rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>;
sd_io_pwr_en: sd-io-pwr-en {
rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO
&pcfg_pull_none>;
sd_pwr_1800_sel: sd-pwr-1800-sel {
&pcfg_pull_none>;
sd_slot_pwr_en: sd-slot-pwr-en {
rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO
&pcfg_pull_none>;
- codec {
headset_int_l: headset-int-l {
rockchip,pins = <1 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>;
mic_int: mic-int {
rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>;
- max98357a {
sdmode_en: sdmode-en {
rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_down>;
- pcie {
pcie_clkreqn_cpm: pci-clkreqn-cpm {
* Since our pcie doesn't support ClockPM(CPM), we want
* to hack this as gpio, so the EP could be able to
* de-assert it along and make ClockPM(CPM) work.
- sdmmc {
* We run sdmmc at max speed; bump up drive strength.
* We also have external pulls, so disable the internal ones.
sdmmc_bus4: sdmmc-bus4 {
rockchip,pins =
<4 RK_PB0 1 &pcfg_pull_none_8ma>,
<4 RK_PB1 1 &pcfg_pull_none_8ma>,
<4 RK_PB2 1 &pcfg_pull_none_8ma>,
<4 RK_PB3 1 &pcfg_pull_none_8ma>;
sdmmc_clk: sdmmc-clk {
rockchip,pins =
<4 RK_PB4 1 &pcfg_pull_none_8ma>;
sdmmc_cmd: sdmmc-cmd {
rockchip,pins =
<4 RK_PB5 1 &pcfg_pull_none_8ma>;
* In our case the official card detect is hooked to ground
* to avoid getting access to JTAG just by sticking something
* in the SD card slot (see the force_jtag bit in the TRM).
* We still configure it as card detect because it doesn't
* hurt and dw_mmc will ignore it. We make sure to disable
* the pull though so we don't burn needless power.
sdmmc_cd: sdmmc-cd {
rockchip,pins =
<0 RK_PA7 1 &pcfg_pull_none>;
/* This is where we actually hook up CD; has external pull */
sdmmc_cd_pin: sdmmc-cd-pin {
rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
- spi1 {
spi1_sleep: spi1-sleep {
* Pull down SPI1 CLK/CS/RX/TX during suspend, to
* prevent leakage.
rockchip,pins = <1 RK_PB1 RK_FUNC_GPIO &pcfg_pull_down>,
<1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_down>,
<1 RK_PA7 RK_FUNC_GPIO &pcfg_pull_down>,
<1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_down>;
- touchscreen {
touch_int_l: touch-int-l {
rockchip,pins = <3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>;
touch_reset_l: touch-reset-l {
rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
- trackpad {
ap_i2c_tp_pu_en: ap-i2c-tp-pu-en {
rockchip,pins = <3 RK_PB4 RK_FUNC_GPIO &pcfg_output_high>;
trackpad_int_l: trackpad-int-l {
rockchip,pins = <1 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>;
- wifi: wifi {
wlan_module_reset_l: wlan-module-reset-l {
rockchip,pins = <1 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
/* Kevin has an external pull up, but Gru does not */
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- write-protect {
ap_fw_wp: ap-fw-wp {
rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>;
-}; diff --git a/arch/arm/dts/rk3399-khadas-edge-captain.dts b/arch/arm/dts/rk3399-khadas-edge-captain.dts deleted file mode 100644 index 99ac4ed0f13f..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge-captain.dts +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Shenzhen Wesion Technology Co., Ltd.
-/dts-v1/; -#include "rk3399-khadas-edge.dtsi"
- model = "Khadas Edge-Captain";
- compatible = "khadas,edge-captain", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
-&gmac {
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pcie0 {
- ep-gpios = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-khadas-edge-v.dts b/arch/arm/dts/rk3399-khadas-edge-v.dts deleted file mode 100644 index e12e7b4d64ca..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge-v.dts +++ /dev/null @@ -1,31 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- model = "Khadas Edge-V";
- compatible = "khadas,edge-v", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
-&gmac {
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pcie0 {
- num-lanes = <4>;
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-khadas-edge.dts b/arch/arm/dts/rk3399-khadas-edge.dts deleted file mode 100644 index 31616e7ad89d..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge.dts +++ /dev/null @@ -1,13 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- model = "Khadas Edge";
- compatible = "khadas,edge", "rockchip,rk3399";
-}; diff --git a/arch/arm/dts/rk3399-khadas-edge.dtsi b/arch/arm/dts/rk3399-khadas-edge.dtsi deleted file mode 100644 index 9d9297bc5f04..000000000000 --- a/arch/arm/dts/rk3399-khadas-edge.dtsi +++ /dev/null @@ -1,837 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
stdout-path = "serial2:1500000n8";
#clock-cells = <0>;
* On the module itself this is one of these (depending
* on the actual card populated):
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
reset-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_LOW>;
regulator-boot-on;
regulator-name = "vcc3v3_pcie";
regulator-boot-on;
vin-supply = <&vsys_3v3>;
enable-active-high;
gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>;
vin-supply = <&vsys_5v0>;
pwm-supply = <&vsys_3v3>;
regulator-name = "vdd_log";
regulator-boot-on;
- vsys: vsys {
regulator-name = "vsys";
regulator-boot-on;
- vsys_3v3: vsys-3v3 {
regulator-name = "vsys_3v3";
regulator-boot-on;
vin-supply = <&vsys>;
- vsys_5v0: vsys-5v0 {
regulator-name = "vsys_5v0";
regulator-boot-on;
- adc-keys {
compatible = "adc-keys";
io-channels = <&saradc 1>;
io-channel-names = "buttons";
keyup-threshold-microvolt = <1800000>;
poll-interval = <100>;
button-recovery {
label = "Recovery";
linux,code = <KEY_VENDOR>;
press-threshold-microvolt = <18000>;
- gpio-keys {
autorepeat;
key-power {
wakeup-source;
- ir-receiver {
gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_LOW>;
linux,rc-map-name = "rc-khadas";
pinctrl-0 = <&ir_rx>;
- leds {
pinctrl-0 = <&sys_led_pin>, <&user_led_pin>;
sys_led: led-0 {
label = "sys_led";
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
user_led: led-1 {
label = "user_led";
gpios = <&gpio4 RK_PD0 GPIO_ACTIVE_HIGH>;
- fan: pwm-fan {
compatible = "pwm-fan";
cooling-levels = <0 150 200 255>;
#cooling-cells = <2>;
fan-supply = <&vsys_5v0>;
pwms = <&pwm0 0 40000 0>;
-&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&cpu_thermal {
- trips {
cpu_warm: cpu_warm {
temperature = <55000>;
type = "active";
cpu_hot: cpu_hot {
type = "active";
- cooling-maps {
map2 {
trip = <&cpu_warm>;
cooling-device = <&fan THERMAL_NO_LIMIT 1>;
map3 {
trip = <&cpu_hot>;
cooling-device = <&fan 2 THERMAL_NO_LIMIT>;
-&emmc_phy {
- status = "okay";
-&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- phy-supply = <&vcc_lan>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
-&gpu {
- status = "okay";
-&gpu_thermal {
- trips {
gpu_warm: gpu_warm {
type = "active";
gpu_hot: gpu_hot {
type = "active";
- cooling-maps {
map1 {
trip = <&gpu_warm>;
map2 {
trip = <&gpu_hot>;
-&hdmi {
- ddc-i2c-bus = <&i2c3>;
- pinctrl-0 = <&hdmi_cec>;
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c3 {
- i2c-scl-rising-time-ns = <450>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
-&i2c4 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
interrupts = <RK_PC6 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
pinctrl-0 = <&pmic_int_l>;
rockchip,system-power-controller;
wakeup-source;
vcc1-supply = <&vsys_3v3>;
vcc2-supply = <&vsys_3v3>;
vcc3-supply = <&vsys_3v3>;
vcc4-supply = <&vsys_3v3>;
vcc6-supply = <&vsys_3v3>;
vcc7-supply = <&vsys_3v3>;
vcc8-supply = <&vsys_3v3>;
vcc9-supply = <&vsys_3v3>;
vcc10-supply = <&vsys_3v3>;
vcc11-supply = <&vsys_3v3>;
vcc12-supply = <&vsys_3v3>;
regulators {
regulator-boot-on;
regulator-min-microvolt = <750000>;
regulator-max-microvolt = <1350000>;
regulator-ramp-delay = <6001>;
regulator-state-mem {
regulator-off-in-suspend;
vdd_cpu_l: DCDC_REG2 {
regulator-name = "vdd_cpu_l";
regulator-boot-on;
vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr";
regulator-boot-on;
regulator-on-in-suspend;
regulator-name = "vcc_1v8";
regulator-boot-on;
regulator-suspend-microvolt = <1800000>;
vcc1v8_apio2: LDO_REG1 {
regulator-name = "vcc1v8_apio2";
regulator-boot-on;
vcc_vldo2: LDO_REG2 {
regulator-name = "vcc_vldo2";
regulator-boot-on;
regulator-min-microvolt = <3000000>;
vcc1v8_pmupll: LDO_REG3 {
regulator-name = "vcc1v8_pmupll";
regulator-boot-on;
vccio_sd: LDO_REG4 {
regulator-name = "vccio_sd";
regulator-boot-on;
vcc_vldo5: LDO_REG5 {
regulator-name = "vcc_vldo5";
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-name = "vcc_1v5";
regulator-boot-on;
vcc1v8_codec: LDO_REG7 {
regulator-name = "vcc1v8_codec";
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
pinctrl-0 = <&cpu_b_sleep>;
regulator-boot-on;
reg = <0x41>;
pinctrl-0 = <&gpu_sleep>;
regulator-boot-on;
-&i2c8 {
- i2c-scl-rising-time-ns = <160>;
- i2c-scl-falling-time-ns = <30>;
- status = "okay";
-&i2s0 {
- status = "okay";
-&i2s1 {
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- bt656-supply = <&vcc1v8_apio2>;
- audio-supply = <&vcc1v8_codec>;
- sdmmc-supply = <&vccio_sd>;
- status = "okay";
-&pmu_io_domains {
- pmu1830-supply = <&vcc_1v8>;
- status = "okay";
-&pinctrl {
- bt {
bt_reg_on_h: bt-reg-on-h {
- buttons {
pwrbtn: pwrbtn {
- ir {
ir_rx: ir-rx {
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>;
- leds {
sys_led_pin: sys-led-pin {
- pmic {
pmic_int_l: pmic-int-l {
rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_up>;
cpu_b_sleep: cpu-b-sleep {
gpu_sleep: gpu-sleep {
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_down>;
- sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
- usb2 {
rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
- wifi {
-&pwm0 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sdio-irq;
- cap-sd-highspeed;
- non-removable;
- sd-uhs-sdr104;
- vmmc-supply = <&vccio_sd>;
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- disable-wp;
- max-frequency = <150000000>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
-&spi1 {
- status = "okay";
- spiflash: flash@0 {
compatible = "winbond,w25q128fw", "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <104000000>;
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
status = "okay";
- u2phy0_host: host-port {
status = "okay";
-&u2phy1 {
- status = "okay";
status = "okay";
- u2phy1_host: host-port {
status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_rts &uart0_cts>;
- status = "okay";
- bluetooth {
compatible = "brcm,bcm43438-bt";
shutdown-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>;
max-speed = <4000000>;
pinctrl-0 = <&bt_reg_on_h &bt_host_wake_l &bt_wake_l>;
vbat-supply = <&vsys_3v3>;
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-leez-p710.dts b/arch/arm/dts/rk3399-leez-p710.dts deleted file mode 100644 index cb69e2145fa9..000000000000 --- a/arch/arm/dts/rk3399-leez-p710.dts +++ /dev/null @@ -1,653 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Andy Yan andy.yan@gmail.com
- model = "Leez RK3399 P710";
- compatible = "leez,p710", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
- clkin_gmac: external-gmac-clock {
compatible = "fixed-clock";
clock-frequency = <125000000>;
clock-output-names = "clkin_gmac";
#clock-cells = <0>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk808 1>;
clock-names = "ext_clock";
pinctrl-0 = <&wifi_reg_on_h>;
reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>;
- dc5v_adp: dc5v-adp {
regulator-name = "dc5v_adapter";
regulator-boot-on;
- vcc3v3_lan: vcc3v3-lan {
regulator-name = "vcc3v3_lan";
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys {
regulator-name = "vcc3v3_sys";
regulator-boot-on;
vin-supply = <&vcc5v0_sys>;
- vcc5v0_host0: vcc5v0_host1: vcc5v0-host {
regulator-boot-on;
regulator-min-microvolt = <5500000>;
regulator-max-microvolt = <5500000>;
- vcc5v0_host3: vcc5v0-host3 {
enable-active-high;
gpio = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>;
- vcc5v0_sys: vcc5v0-sys {
regulator-name = "vcc5v0_sys";
regulator-boot-on;
vin-supply = <&dc5v_adp>;
pwm-supply = <&vcc5v0_sys>;
regulator-boot-on;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- phy-supply = <&vcc3v3_lan>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- ddc-i2c-bus = <&i2c7>;
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
vcc1-supply = <&vcc5v0_sys>;
vcc2-supply = <&vcc5v0_sys>;
vcc3-supply = <&vcc5v0_sys>;
vcc4-supply = <&vcc5v0_sys>;
vcc6-supply = <&vcc5v0_sys>;
vcc7-supply = <&vcc5v0_sys>;
vcc8-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc5v0_sys>;
vcc10-supply = <&vcc5v0_sys>;
vcc11-supply = <&vcc5v0_sys>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc1v8_hdmi: LDO_REG2 {
regulator-name = "vcc1v8_hdmi";
regulator-boot-on;
vcca_1v8: LDO_REG3 {
regulator-name = "vcca_1v8";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
vcc0v9_hdmi: LDO_REG7 {
regulator-name = "vcc0v9_hdmi";
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
-&i2c1 {
- status = "okay";
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
-&i2c7 {
- status = "okay";
-&i2s0 {
- status = "okay";
-&i2s1 {
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- status = "okay";
- audio-supply = <&vcc_1v8>;
-&pmu_io_domains {
- status = "okay";
-&pinctrl {
- bt {
- pmic {
- usb2 {
rockchip,pins = <2 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- wifi {
wifi_reg_on_h: wifi-reg-on-h {
rockchip,pins =
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
- vref-supply = <&vcc_1v8>;
-&sdio0 {
- bus-width = <4>;
- cap-sdio-irq;
- cap-sd-highspeed;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cd &sdmmc_cmd &sdmmc_bus4>;
- status = "okay";
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
phy-supply = <&vcc5v0_host0>;
status = "okay";
-&u2phy1 {
- status = "okay";
status = "okay";
phy-supply = <&vcc5v0_host1>;
status = "okay";
-&uart0 {
- status = "okay";
- bluetooth {
pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_reg_on_h>;
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "otg";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-nanopc-t4.dts b/arch/arm/dts/rk3399-nanopc-t4.dts deleted file mode 100644 index 3bf8f959e42c..000000000000 --- a/arch/arm/dts/rk3399-nanopc-t4.dts +++ /dev/null @@ -1,137 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- FriendlyElec NanoPC-T4 board device tree source
- Copyright (c) 2018 FriendlyElec Computer Tech. Co., Ltd.
-/dts-v1/; -#include "rk3399-nanopi4.dtsi"
- model = "FriendlyElec NanoPC-T4";
- compatible = "friendlyarm,nanopc-t4", "rockchip,rk3399";
- vcc12v0_sys: vcc12v0-sys {
regulator-boot-on;
regulator-max-microvolt = <12000000>;
regulator-min-microvolt = <12000000>;
regulator-name = "vcc12v0_sys";
- vcc5v0_host0: vcc5v0-host0 {
regulator-boot-on;
regulator-name = "vcc5v0_host0";
- adc-keys {
button-recovery {
label = "Recovery";
- ir-receiver {
- fan: pwm-fan {
* With 20KHz PWM and an EVERCOOL EC4007H12SA fan, these levels
* work out to 0, ~1200, ~3000, and 5000RPM respectively.
cooling-levels = <0 12 18 255>;
fan-supply = <&vcc12v0_sys>;
pwms = <&pwm1 0 50000 0>;
-&cpu_thermal {
- trips {
type = "active";
cpu_hot: cpu_hot {
type = "active";
- cooling-maps {
map2 {
trip = <&cpu_warm>;
map3 {
trip = <&cpu_hot>;
-&pcie0 {
- ep-gpios = <&gpio2 RK_PA4 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- vpcie3v3-supply = <&vcc3v3_sys>;
-&pinctrl {
- ir {
ir_rx: ir-rx {
/* external pullup to VCC3V3_SYS, despite being 1.8V :/ */
rockchip,pins = <0 RK_PA6 1 &pcfg_pull_none>;
-&sdhci {
- mmc-hs400-1_8v;
-&u2phy0_host {
- phy-supply = <&vcc5v0_host0>;
-&u2phy1_host {
-&vcc5v0_sys {
- vin-supply = <&vcc12v0_sys>;
-&vcc3v3_sys {
-&vbus_typec {
- enable-active-high;
- gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
- vin-supply = <&vcc5v0_sys>;
-}; diff --git a/arch/arm/dts/rk3399-nanopi-m4.dts b/arch/arm/dts/rk3399-nanopi-m4.dts deleted file mode 100644 index 60358ab8c7df..000000000000 --- a/arch/arm/dts/rk3399-nanopi-m4.dts +++ /dev/null @@ -1,66 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- FriendlyElec NanoPi M4 board device tree source
- Copyright (c) 2019 Arm Ltd.
- model = "FriendlyElec NanoPi M4";
- compatible = "friendlyarm,nanopi-m4", "rockchip,rk3399";
- vdd_5v: vdd-5v {
regulator-name = "vdd_5v";
regulator-boot-on;
- vcc5v0_core: vcc5v0-core {
regulator-name = "vcc5v0_core";
regulator-boot-on;
vin-supply = <&vdd_5v>;
- vcc5v0_usb1: vcc5v0-usb1 {
regulator-name = "vcc5v0_usb1";
regulator-boot-on;
- vcc5v0_usb2: vcc5v0-usb2 {
regulator-name = "vcc5v0_usb2";
regulator-boot-on;
-&vcc3v3_sys {
- vin-supply = <&vcc5v0_core>;
-&u2phy0_host {
- phy-supply = <&vcc5v0_usb1>;
-&u2phy1_host {
- phy-supply = <&vcc5v0_usb2>;
-&vbus_typec {
- regulator-always-on;
- vin-supply = <&vdd_5v>;
-}; diff --git a/arch/arm/dts/rk3399-nanopi-m4b.dts b/arch/arm/dts/rk3399-nanopi-m4b.dts deleted file mode 100644 index 65cb21837b0c..000000000000 --- a/arch/arm/dts/rk3399-nanopi-m4b.dts +++ /dev/null @@ -1,52 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- FriendlyElec NanoPi M4B board device tree source
- Copyright (c) 2020 Chen-Yu Tsai wens@csie.org
-/dts-v1/; -#include "rk3399-nanopi-m4.dts"
- model = "FriendlyElec NanoPi M4B";
- compatible = "friendlyarm,nanopi-m4b", "rockchip,rk3399";
- adc-keys {
keyup-threshold-microvolt = <1500000>;
button-recovery {
label = "Recovery";
-/* No USB type-C PD power manager */ -/delete-node/ &fusb0;
-&i2c4 {
-&u2phy0_host {
-&u2phy0_otg {
- phy-supply = <&vbus_typec>;
-&u2phy1_otg {
-&vbus_typec {
-}; diff --git a/arch/arm/dts/rk3399-nanopi-neo4.dts b/arch/arm/dts/rk3399-nanopi-neo4.dts deleted file mode 100644 index 195410b089b9..000000000000 --- a/arch/arm/dts/rk3399-nanopi-neo4.dts +++ /dev/null @@ -1,50 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (C) 2019 Amarula Solutions B.V.
- Author: Jagan Teki jagan@amarulasolutions.com
-/dts-v1/;
- model = "FriendlyARM NanoPi NEO4";
- compatible = "friendlyarm,nanopi-neo4", "rockchip,rk3399";
- vdd_5v: vdd-5v {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&vcc3v3_sys {
-&u2phy0_host {
-&vbus_typec {
-}; diff --git a/arch/arm/dts/rk3399-nanopi-r4s.dts b/arch/arm/dts/rk3399-nanopi-r4s.dts deleted file mode 100644 index fe5b52610010..000000000000 --- a/arch/arm/dts/rk3399-nanopi-r4s.dts +++ /dev/null @@ -1,133 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2020 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2020 Jensen Huang jensenhuang@friendlyarm.com
- Copyright (c) 2020 Marty Jones mj8263788@gmail.com
- Copyright (c) 2021 Tianling Shen cnsztl@gmail.com
- model = "FriendlyElec NanoPi R4S";
- compatible = "friendlyarm,nanopi-r4s", "rockchip,rk3399";
- /delete-node/ display-subsystem;
- gpio-leds {
pinctrl-0 = <&lan_led_pin>, <&sys_led_pin>, <&wan_led_pin>;
/delete-node/ led-0;
lan_led: led-lan {
gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_HIGH>;
label = "green:lan";
sys_led: led-sys {
gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>;
label = "red:power";
default-state = "on";
wan_led: led-wan {
gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
label = "green:wan";
- gpio-keys {
pinctrl-0 = <&reset_button_pin>;
/delete-node/ key-power;
key-reset {
debounce-interval = <50>;
gpios = <&gpio1 RK_PC6 GPIO_ACTIVE_LOW>;
label = "reset";
linux,code = <KEY_RESTART>;
- vdd_5v: vdd-5v {
regulator-boot-on;
-&emmc_phy {
-&i2c4 {
-&pcie0 {
- max-link-speed = <1>;
- num-lanes = <1>;
-&pinctrl {
- gpio-leds {
/delete-node/ status-led-pin;
lan_led_pin: lan-led-pin {
rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
wan_led_pin: wan-led-pin {
- rockchip-key {
/delete-node/ power-key;
reset_button_pin: reset-button-pin {
-&sdhci {
-&sdio0 {
-&u2phy0_host {
- phy-supply = <&vdd_5v>;
-&u2phy1_host {
-&uart0 {
-&usbdrd_dwc3_0 {
- dr_mode = "host";
-&vcc3v3_sys {
-}; diff --git a/arch/arm/dts/rk3399-nanopi4.dtsi b/arch/arm/dts/rk3399-nanopi4.dtsi deleted file mode 100644 index b7f1e47978a6..000000000000 --- a/arch/arm/dts/rk3399-nanopi4.dtsi +++ /dev/null @@ -1,762 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- RK3399-based FriendlyElec boards device tree source
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
-/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- aliases {
ethernet0 = &gmac;
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
#clock-cells = <0>;
regulator-boot-on;
regulator-boot-on;
- /* switched by pmic_sleep */
- vcc1v8_s3: vcc1v8-s3 {
regulator-boot-on;
regulator-name = "vcc1v8_s3";
vin-supply = <&vcc_1v8>;
- vcc3v0_sd: vcc3v0-sd {
enable-active-high;
gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&sdmmc0_pwr_h>;
regulator-name = "vcc3v0_sd";
vin-supply = <&vcc3v3_sys>;
* Really, this is supplied by vcc_1v8, and vcc1v8_s3 only
* drives the enable pin, but we can't quite model that.
- vcca0v9_s3: vcca0v9-s3 {
regulator-name = "vcca0v9_s3";
vin-supply = <&vcc1v8_s3>;
- /* As above, actually supplied by vcc3v3_sys */
- vcca1v8_s3: vcca1v8-s3 {
regulator-name = "vcca1v8_s3";
- vbus_typec: vbus-typec {
regulator-name = "vbus_typec";
- gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-0 = <&power_key>;
key-power {
debounce-interval = <100>;
gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
label = "GPIO Key Power";
linux,code = <KEY_POWER>;
wakeup-source;
- leds: gpio-leds {
compatible = "gpio-leds";
pinctrl-0 = <&status_led_pin>;
status_led: led-0 {
label = "status_led";
linux,default-trigger = "heartbeat";
-&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
-&cpu_b1 {
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&emmc_phy {
- rockchip,enable-strobe-pulldown;
- status = "okay";
-&gmac {
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- pinctrl-0 = <&rgmii_pins>, <&phy_intb>, <&phy_rstb>;
- phy-handle = <&rtl8211e>;
- phy-mode = "rgmii";
- phy-supply = <&vcc3v3_s3>;
- tx_delay = <0x28>;
- rx_delay = <0x11>;
- status = "okay";
- mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <1>;
#size-cells = <0>;
rtl8211e: ethernet-phy@1 {
reg = <1>;
interrupts = <RK_PB2 IRQ_TYPE_LEVEL_LOW>;
reset-assert-us = <10000>;
reset-deassert-us = <30000>;
reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
-&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- vdd_cpu_b: regulator@40 {
compatible = "silergy,syr827";
reg = <0x40>;
fcs,suspend-voltage-selector = <1>;
regulator-boot-on;
regulator-min-microvolt = <712500>;
regulator-name = "vdd_cpu_b";
regulator-ramp-delay = <1000>;
- vdd_gpu: regulator@41 {
compatible = "silergy,syr828";
reg = <0x41>;
regulator-boot-on;
regulator-name = "vdd_gpu";
- rk808: pmic@1b {
compatible = "rockchip,rk808";
reg = <0x1b>;
clock-output-names = "xin32k", "rtc_clko_wifi";
#clock-cells = <1>;
interrupts = <21 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&pmic_int_l>, <&ap_pwroff>, <&clk_32k>;
wakeup-source;
vcc1-supply = <&vcc3v3_sys>;
vcc2-supply = <&vcc3v3_sys>;
vcc3-supply = <&vcc3v3_sys>;
vcc4-supply = <&vcc3v3_sys>;
vcc6-supply = <&vcc3v3_sys>;
vcc7-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc3v3_sys>;
vcc10-supply = <&vcc3v3_sys>;
vcc11-supply = <&vcc3v3_sys>;
vcc12-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc_3v0>;
regulators {
vdd_center: DCDC_REG1 {
regulator-boot-on;
regulator-name = "vdd_center";
regulator-boot-on;
regulator-boot-on;
vcc_1v8: DCDC_REG4 {
regulator-boot-on;
vcc1v8_cam: LDO_REG1 {
regulator-boot-on;
regulator-name = "vcc1v8_cam";
vcc3v0_touch: LDO_REG2 {
regulator-boot-on;
regulator-name = "vcc3v0_touch";
regulator-boot-on;
vcc_sdio: LDO_REG4 {
regulator-boot-on;
regulator-name = "vcc_sdio";
regulator-suspend-microvolt = <3000000>;
vcca3v0_codec: LDO_REG5 {
regulator-boot-on;
regulator-name = "vcca3v0_codec";
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-suspend-microvolt = <1500000>;
vcca1v8_codec: LDO_REG7 {
regulator-boot-on;
regulator-name = "vcca1v8_codec";
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-name = "vcc_3v0";
vcc3v3_s3: SWITCH_REG1 {
regulator-boot-on;
regulator-name = "vcc3v3_s3";
vcc3v3_s0: SWITCH_REG2 {
regulator-boot-on;
regulator-name = "vcc3v3_s0";
-&i2c1 {
- clock-frequency = <200000>;
- i2c-scl-rising-time-ns = <150>;
- status = "okay";
-&i2c2 {
- status = "okay";
-&i2c4 {
- status = "okay";
- fusb0: typec-portc@22 {
compatible = "fcs,fusb302";
reg = <0x22>;
interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&fusb0_int>;
vbus-supply = <&vbus_typec>;
-&i2c7 {
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- bt656-supply = <&vcc_1v8>;
- audio-supply = <&vcca1v8_codec>;
- sdmmc-supply = <&vcc_sdio>;
- gpio1830-supply = <&vcc_3v0>;
- status = "okay";
-&pcie_phy {
- assigned-clock-parents = <&cru SCLK_PCIEPHY_REF100M>;
- assigned-clock-rates = <100000000>;
- assigned-clocks = <&cru SCLK_PCIEPHY_REF>;
- status = "okay";
-&pcie0 {
- num-lanes = <2>;
- vpcie0v9-supply = <&vcca0v9_s3>;
- vpcie1v8-supply = <&vcca1v8_s3>;
- status = "okay";
-&pinctrl {
- fusb30x {
fusb0_int: fusb0-int {
rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>;
- gpio-leds {
status_led_pin: status-led-pin {
- gmac {
phy_intb: phy-intb {
rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>;
phy_rstb: phy-rstb {
rockchip,pins = <3 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins = <1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
- rockchip-key {
power_key: power-key {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>;
- sdio {
bt_host_wake_l: bt-host-wake-l {
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
/* external pullup to VCC1V8_PMUPLL */
rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
bt_wake_l: bt-wake-l {
rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
wifi_reg_on_h: wifi-reg_on-h {
rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
- sdmmc {
sdmmc0_det_l: sdmmc0-det-l {
rockchip,pins = <0 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>;
sdmmc0_pwr_h: sdmmc0-pwr-h {
rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
-&pmu_io_domains {
- pmu1830-supply = <&vcc_3v0>;
- status = "okay";
-&pwm0 {
- status = "okay";
-&pwm1 {
- status = "okay";
-&pwm2 {
- pinctrl-names = "active";
- pinctrl-0 = <&pwm2_pin_pull_down>;
- status = "okay";
-&saradc {
- vref-supply = <&vcca1v8_s3>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-mmc-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc_bus4 &sdmmc_clk &sdmmc_cmd &sdmmc0_det_l>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v0_sd>;
- vqmmc-supply = <&vcc_sdio>;
- status = "okay";
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- /* tshut polarity 0:LOW 1:HIGH */
- status = "okay";
-&u2phy0 {
- status = "okay";
-&u2phy0_host {
- status = "okay";
-&u2phy0_otg {
- status = "okay";
-&u2phy1 {
- status = "okay";
-&u2phy1_host {
- status = "okay";
-&u2phy1_otg {
- status = "okay";
-&uart0 {
- status = "okay";
- bluetooth {
clock-names = "lpo";
device-wakeup-gpios = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>;
host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>;
shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>;
vbat-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc_1v8>;
-&uart2 {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
-&usbdrd_dwc3_1 {
- dr_mode = "host";
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-op1-opp.dtsi b/arch/arm/dts/rk3399-op1-opp.dtsi deleted file mode 100644 index 783120e9cebe..000000000000 --- a/arch/arm/dts/rk3399-op1-opp.dtsi +++ /dev/null @@ -1,166 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd
- cluster0_opp: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp00 {
opp-hz = /bits/ 64 <408000000>;
opp-microvolt = <800000>;
clock-latency-ns = <40000>;
opp01 {
opp-hz = /bits/ 64 <600000000>;
opp-microvolt = <825000>;
opp02 {
opp-hz = /bits/ 64 <816000000>;
opp-microvolt = <850000>;
opp03 {
opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <900000>;
opp04 {
opp-hz = /bits/ 64 <1200000000>;
opp-microvolt = <975000>;
opp05 {
opp-hz = /bits/ 64 <1416000000>;
opp-microvolt = <1100000>;
opp06 {
opp-hz = /bits/ 64 <1512000000>;
opp-microvolt = <1150000>;
- cluster1_opp: opp-table-1 {
opp-shared;
opp00 {
opp01 {
opp02 {
opp03 {
opp04 {
opp05 {
opp06 {
opp-hz = /bits/ 64 <1608000000>;
opp-microvolt = <1050000>;
opp07 {
opp-hz = /bits/ 64 <1800000000>;
opp08 {
opp-hz = /bits/ 64 <2016000000>;
opp-microvolt = <1250000>;
- gpu_opp_table: opp-table-2 {
opp00 {
opp-hz = /bits/ 64 <200000000>;
opp01 {
opp-hz = /bits/ 64 <297000000>;
opp02 {
opp-hz = /bits/ 64 <400000000>;
opp03 {
opp-hz = /bits/ 64 <500000000>;
opp04 {
opp-microvolt = <925000>;
opp05 {
opp-hz = /bits/ 64 <800000000>;
opp-microvolt = <1075000>;
- dmc_opp_table: opp-table-3 {
opp00 {
opp01 {
opp-hz = /bits/ 64 <666000000>;
opp02 {
opp03 {
opp-hz = /bits/ 64 <928000000>;
-&cpu_l0 {
- operating-points-v2 = <&cluster0_opp>;
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
- operating-points-v2 = <&cluster1_opp>;
-&cpu_b1 {
-&dmc {
- operating-points-v2 = <&dmc_opp_table>;
-&gpu {
- operating-points-v2 = <&gpu_opp_table>;
-}; diff --git a/arch/arm/dts/rk3399-opp.dtsi b/arch/arm/dts/rk3399-opp.dtsi deleted file mode 100644 index fee5e7111279..000000000000 --- a/arch/arm/dts/rk3399-opp.dtsi +++ /dev/null @@ -1,133 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
opp-shared;
opp00 {
opp-microvolt = <825000 825000 1250000>;
opp01 {
opp02 {
opp-microvolt = <850000 850000 1250000>;
opp03 {
opp-microvolt = <925000 925000 1250000>;
opp04 {
opp-microvolt = <1000000 1000000 1250000>;
opp05 {
opp-microvolt = <1125000 1125000 1250000>;
opp-shared;
opp00 {
opp01 {
opp02 {
opp03 {
opp-microvolt = <875000 875000 1250000>;
opp04 {
opp-microvolt = <950000 950000 1250000>;
opp05 {
opp-microvolt = <1025000 1025000 1250000>;
opp06 {
opp-microvolt = <1100000 1100000 1250000>;
opp07 {
opp-microvolt = <1200000 1200000 1250000>;
opp00 {
opp-microvolt = <825000 825000 1150000>;
opp01 {
opp02 {
opp03 {
opp-microvolt = <875000 875000 1150000>;
opp04 {
opp-microvolt = <925000 925000 1150000>;
opp05 {
opp-microvolt = <1100000 1100000 1150000>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&gpu {
-}; diff --git a/arch/arm/dts/rk3399-orangepi.dts b/arch/arm/dts/rk3399-orangepi.dts deleted file mode 100644 index e7551449e718..000000000000 --- a/arch/arm/dts/rk3399-orangepi.dts +++ /dev/null @@ -1,896 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
-/dts-v1/;
-#include "dt-bindings/pwm/pwm.h" -#include "dt-bindings/input/input.h" -#include <dt-bindings/interrupt-controller/irq.h> -#include "dt-bindings/usb/pd.h" -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- model = "Orange Pi RK3399 Board";
- compatible = "rockchip,rk3399-orangepi", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
#clock-cells = <0>;
- adc-keys {
button-up {
label = "Volume Up";
linux,code = <KEY_VOLUMEUP>;
press-threshold-microvolt = <100000>;
button-down {
label = "Volume Down";
linux,code = <KEY_VOLUMEDOWN>;
press-threshold-microvolt = <300000>;
button-back {
label = "Back";
linux,code = <KEY_BACK>;
press-threshold-microvolt = <985000>;
button-menu {
label = "Menu";
linux,code = <KEY_MENU>;
press-threshold-microvolt = <1314000>;
- dc_12v: dc-12v {
regulator-name = "dc_12v";
regulator-boot-on;
- keys: gpio-keys {
autorepeat;
key-power {
label = "GPIO Power";
linux,input-type = <1>;
pinctrl-0 = <&pwr_btn>;
wakeup-source;
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
vin-supply = <&vcc_sys>;
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
pinctrl-0 = <&vcc5v0_host_en>;
regulator-name = "vcc5v0_host";
- vbus_typec: vbus-typec-regulator {
enable-active-high;
gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_typec_en>;
- vcc_sys: vcc-sys {
regulator-name = "vcc_sys";
regulator-boot-on;
vin-supply = <&dc_12v>;
- vdd_log: vdd-log {
compatible = "pwm-regulator";
pwms = <&pwm2 0 25000 1>;
pwm-supply = <&vcc_sys>;
regulator-boot-on;
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1400000>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- status = "okay";
- mdio {
#size-cells = <0>;
reg = <1>;
interrupt-parent = <&gpio3>;
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
interrupt-parent = <&gpio1>;
#clock-cells = <1>;
clock-output-names = "rtc_clko_soc", "rtc_clko_wifi";
wakeup-source;
regulators {
regulator-boot-on;
regulator-min-microvolt = <700000>;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc1v8_dvp: LDO_REG1 {
regulator-name = "vcc1v8_dvp";
regulator-boot-on;
regulator-max-microvolt = <3400000>;
vcc3v0_tp: LDO_REG2 {
regulator-name = "vcc3v0_tp";
regulator-boot-on;
regulator-boot-on;
regulator-max-microvolt = <2500000>;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
-&i2c1 {
- status = "okay";
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
- ak09911@c {
compatible = "asahi-kasei,ak09911";
reg = <0x0c>;
vdd-supply = <&vcc3v3_s3>;
vid-supply = <&vcc3v3_s3>;
- mpu6500@68 {
compatible = "invensense,mpu6500";
reg = <0x68>;
interrupts = <RK_PC6 IRQ_TYPE_EDGE_RISING>;
pinctrl-0 = <&gsensor_int_l>;
vddio-supply = <&vcc3v3_s3>;
- lsm6ds3@6a {
compatible = "st,lsm6ds3";
reg = <0x6a>;
interrupts = <RK_PD0 IRQ_TYPE_EDGE_RISING>;
pinctrl-0 = <&gyr_int_l>;
- cm32181@10 {
compatible = "capella,cm32181";
reg = <0x10>;
interrupt-parent = <&gpio4>;
pinctrl-0 = <&light_int_l>;
- fusb302@22 {
reg = <0x22>;
pinctrl-0 = <&chg_cc_int_l>;
typec_con: connector {
compatible = "usb-c-connector";
data-role = "host";
label = "USB-C";
op-sink-microwatt = <1000000>;
power-role = "dual";
sink-pdos =
<PDO_FIXED(5000, 2500, PDO_FIXED_USB_COMM)>;
source-pdos =
<PDO_FIXED(5000, 1400, PDO_FIXED_USB_COMM)>;
try-power-role = "sink";
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
typec_hs: endpoint {
remote-endpoint = <&u2phy0_typec_hs>;
port@1 {
reg = <1>;
typec_ss: endpoint {
remote-endpoint = <&tcphy0_typec_ss>;
port@2 {
reg = <2>;
typec_dp: endpoint {
remote-endpoint = <&tcphy0_typec_dp>;
-&io_domains {
- status = "okay";
- bt656-supply = <&vcc_3v0>;
-&pmu_io_domains {
- status = "okay";
-&pinctrl {
- buttons {
pwr_btn: pwr-btn {
- gmac {
- pmic {
rockchip,pins =
- sd {
rockchip,pins =
- usb2 {
vcc5v0_host_en: vcc5v0-host-en {
rockchip,pins =
vcc5v0_typec_en: vcc5v0-typec-en {
rockchip,pins =
<1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
- wifi {
wifi_host_wake_l: wifi-host-wake-l {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
- bluetooth {
bt_reg_on_h: bt-enable-h {
- mpu6500 {
gsensor_int_l: gsensor-int-l {
rockchip,pins = <1 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
- lsm6ds3 {
gyr_int_l: gyr-int-l {
rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
- cm32181 {
light_int_l: light-int-l {
- fusb302 {
chg_cc_int_l: chg-cc-int-l {
-&pwm0 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- clock-frequency = <50000000>;
- disable-wp;
- max-frequency = <50000000>;
- non-removable;
- sd-uhs-sdr104;
- #address-cells = <1>;
- #size-cells = <0>;
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
interrupt-parent = <&gpio0>;
interrupts = <RK_PA3 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "host-wake";
pinctrl-0 = <&wifi_host_wake_l>;
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- clock-frequency = <150000000>;
- disable-wp;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_cd &sdmmc_bus4>;
- status = "okay";
-&tcphy0 {
- status = "okay";
-&tcphy0_dp {
- port {
tcphy0_typec_dp: endpoint {
remote-endpoint = <&typec_dp>;
-&tcphy0_usb3 {
- port {
tcphy0_typec_ss: endpoint {
remote-endpoint = <&typec_ss>;
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
phy-supply = <&vcc5v0_host>;
status = "okay";
- port {
u2phy0_typec_hs: endpoint {
remote-endpoint = <&typec_hs>;
-&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
- status = "okay";
- bluetooth {
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "host";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-pinebook-pro.dts b/arch/arm/dts/rk3399-pinebook-pro.dts deleted file mode 100644 index 054c6a4d1a45..000000000000 --- a/arch/arm/dts/rk3399-pinebook-pro.dts +++ /dev/null @@ -1,1111 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2018 Akash Gajjar Akash_Gajjar@mentor.com
- Copyright (c) 2020 Tobias Schramm t.schramm@manjaro.org
-/dts-v1/; -#include <dt-bindings/input/gpio-keys.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include <dt-bindings/usb/pd.h> -#include <dt-bindings/leds/common.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- model = "Pine64 Pinebook Pro";
- compatible = "pine64,pinebook-pro", "rockchip,rk3399";
- chassis-type = "laptop";
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
- backlight: edp-backlight {
compatible = "pwm-backlight";
power-supply = <&vcc_12v>;
pwms = <&pwm0 0 740740 0>;
- bat: battery {
compatible = "simple-battery";
charge-full-design-microamp-hours = <9800000>;
voltage-max-design-microvolt = <4350000>;
voltage-min-design-microvolt = <3000000>;
- edp_panel: edp-panel {
compatible = "boe,nv140fhmn49";
backlight = <&backlight>;
enable-gpios = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&panel_en_pin>;
power-supply = <&vcc3v3_panel>;
port {
panel_in_edp: endpoint {
remote-endpoint = <&edp_out_panel>;
* Use separate nodes for gpio-keys to allow for selective deactivation
* of wakeup sources via sysfs without disabling the whole key
- gpio-key-lid {
pinctrl-0 = <&lidbtn_pin>;
switch-lid {
debounce-interval = <20>;
gpios = <&gpio1 RK_PA1 GPIO_ACTIVE_LOW>;
label = "Lid";
linux,code = <SW_LID>;
wakeup-event-action = <EV_ACT_DEASSERTED>;
wakeup-source;
- gpio-key-power {
pinctrl-0 = <&pwrbtn_pin>;
key-power {
label = "Power";
wakeup-source;
- leds {
pinctrl-0 = <&pwr_led_pin &slp_led_pin>;
green_led: led-0 {
color = <LED_COLOR_ID_GREEN>;
function = LED_FUNCTION_POWER;
gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
label = "green:power";
red_led: led-1 {
color = <LED_COLOR_ID_RED>;
default-state = "off";
function = LED_FUNCTION_STANDBY;
gpios = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
label = "red:standby";
panic-indicator;
retain-state-suspended;
- /* Power sequence for SDIO WiFi module */
pinctrl-0 = <&wifi_enable_h_pin>;
power-off-delay-us = <500000>;
/* WL_REG_ON on module */
- /* Audio components */
- es8316-sound {
compatible = "simple-audio-card";
pinctrl-0 = <&hp_det_pin>;
simple-audio-card,name = "rockchip,es8316-codec";
simple-audio-card,format = "i2s";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,widgets =
"Microphone", "Mic Jack",
"Headphone", "Headphones",
"Speaker", "Speaker";
simple-audio-card,routing =
"MIC1", "Mic Jack",
"Headphones", "HPOL",
"Headphones", "HPOR",
"Speaker Amplifier INL", "HPOL",
"Speaker Amplifier INR", "HPOR",
"Speaker", "Speaker Amplifier OUTL",
"Speaker", "Speaker Amplifier OUTR";
simple-audio-card,hp-det-gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>;
simple-audio-card,aux-devs = <&speaker_amp>;
simple-audio-card,pin-switches = "Speaker";
simple-audio-card,cpu {
sound-dai = <&i2s1>;
simple-audio-card,codec {
sound-dai = <&es8316>;
- speaker_amp: speaker-amplifier {
compatible = "simple-audio-amplifier";
enable-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>;
sound-name-prefix = "Speaker Amplifier";
VCC-supply = <&pa_5v>;
- /* Power tree */
- /* Root power source */
- vcc_sysin: vcc-sysin {
compatible = "regulator-fixed";
regulator-name = "vcc_sysin";
regulator-boot-on;
- /* Regulators supplied by vcc_sysin */
- /* LCD backlight supply */
- vcc_12v: vcc-12v {
regulator-name = "vcc_12v";
regulator-boot-on;
vin-supply = <&vcc_sysin>;
- /* Main 3.3 V supply */
- vcc3v3_sys: wifi_bat: vcc3v3-sys {
regulator-boot-on;
- /* 5 V USB power supply */
- vcc5v0_usb: pa_5v: vcc5v0-usb-regulator {
enable-active-high;
gpio = <&gpio1 RK_PB5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pwr_5v_pin>;
regulator-name = "vcc5v0_usb";
- /* RK3399 logic supply */
pwm-supply = <&vcc_sysin>;
regulator-boot-on;
- /* Regulators supplied by vcc3v3_sys */
- /* 0.9 V supply, always on */
- vcc_0v9: vcc-0v9 {
regulator-name = "vcc_0v9";
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
- /* S3 1.8 V supply, switched by vcc1v8_s3 */
- vcca1v8_s3: vcc1v8-s3 {
regulator-boot-on;
- /* micro SD card power */
enable-active-high;
pinctrl-0 = <&sdmmc0_pwr_h_pin>;
- /* LCD panel power, called VCC3V3_S0 in schematic */
- vcc3v3_panel: vcc3v3-panel {
enable-active-high;
gpio = <&gpio1 RK_PC6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&lcdvcc_en_pin>;
regulator-name = "vcc3v3_panel";
regulator-enable-ramp-delay = <100000>;
- /* M.2 adapter power, switched by vcc1v8_s3 */
- vcc3v3_ssd: vcc3v3-ssd {
regulator-name = "vcc3v3_ssd";
- /* Regulators supplied by vcc5v0_usb */
- /* USB 3 port power supply regulator */
- vcc5v0_otg: vcc5v0-otg {
enable-active-high;
gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&vcc5v0_host_en_pin>;
regulator-name = "vcc5v0_otg";
vin-supply = <&vcc5v0_usb>;
- /* Type C port power supply regulator */
- vbus_5vout: vbus_typec: vbus-5vout {
enable-active-high;
pinctrl-0 = <&vcc5v0_typec0_en_pin>;
regulator-name = "vbus_5vout";
- /* Regulators supplied by vcc_1v8 */
- /* Primary 0.9 V LDO */
regulator-name = "vcc0v9_s3";
- mains_charger: dc-charger {
compatible = "gpio-charger";
charger-type = "mains";
gpios = <&gpio4 RK_PD0 GPIO_ACTIVE_LOW>;
/* Also triggered by USB charger */
pinctrl-0 = <&dc_det_pin>;
-&cpu_b0 {
-&cpu_b1 {
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&edp {
- force-hpd;
- pinctrl-names = "default";
- pinctrl-0 = <&edp_hpd>;
- status = "okay";
- ports {
edp_out: port@1 {
reg = <1>;
#size-cells = <0>;
edp_out_panel: endpoint@0 {
reg = <0>;
remote-endpoint = <&panel_in_edp>;
-&emmc_phy {
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- clock-frequency = <400000>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
clock-output-names = "xin32k", "rk808-clkout2";
interrupts = <10 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&pmic_int_l_pin>;
wakeup-source;
vcc1-supply = <&vcc_sysin>;
vcc2-supply = <&vcc_sysin>;
vcc3-supply = <&vcc_sysin>;
vcc4-supply = <&vcc_sysin>;
vcc6-supply = <&vcc_sysin>;
vcc7-supply = <&vcc_sysin>;
vcc9-supply = <&vcc_sysin>;
vcc10-supply = <&vcc_sysin>;
vcc11-supply = <&vcc_sysin>;
regulators {
/* rk3399 center logic supply */
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: vcc_wl: DCDC_REG4 {
regulator-boot-on;
/* not used */
LDO_REG1 {
/* not used */
LDO_REG2 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
pinctrl-0 = <&vsel1_pin>;
regulator-boot-on;
reg = <0x41>;
pinctrl-0 = <&vsel2_pin>;
regulator-boot-on;
-&i2c1 {
- clock-frequency = <100000>;
- status = "okay";
- es8316: audio-codec@11 {
compatible = "everest,es8316";
reg = <0x11>;
clocks = <&cru SCLK_I2S_8CH_OUT>;
clock-names = "mclk";
#sound-dai-cells = <0>;
-&i2c3 {
- status = "okay";
-&i2c4 {
- i2c-scl-falling-time-ns = <20>;
- i2c-scl-rising-time-ns = <600>;
- status = "okay";
- fusb0: fusb30x@22 {
reg = <0x22>;
pinctrl-0 = <&fusb0_int_pin>;
connector {
data-role = "dual";
label = "USB-C";
sink-pdos =
source-pdos =
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
usbc_hs: endpoint {
remote-endpoint =
<&u2phy0_typec_hs>;
port@1 {
reg = <1>;
usbc_ss: endpoint {
remote-endpoint =
<&tcphy0_typec_ss>;
port@2 {
reg = <2>;
usbc_dp: endpoint {
remote-endpoint =
<&tcphy0_typec_dp>;
- cw2015@62 {
compatible = "cellwise,cw2015";
reg = <0x62>;
cellwise,battery-profile = /bits/ 8 <
0x17 0x67 0x80 0x73 0x6E 0x6C 0x6B 0x63
0x77 0x51 0x5C 0x58 0x50 0x4C 0x48 0x36
0x15 0x0C 0x0C 0x19 0x5B 0x7D 0x6F 0x69
0x69 0x5B 0x0C 0x29 0x20 0x40 0x52 0x59
0x57 0x56 0x54 0x4F 0x3B 0x1F 0x7F 0x17
0x06 0x1A 0x30 0x5A 0x85 0x93 0x96 0x2D
0x48 0x77 0x9C 0xB3 0x80 0x52 0x94 0xCB
0x2F 0x00 0x64 0xA5 0xB5 0x11 0xF0 0x11
cellwise,monitor-interval-ms = <5000>;
monitored-battery = <&bat>;
power-supplies = <&mains_charger>, <&fusb0>;
-&i2s1 {
- pinctrl-0 = <&i2s_8ch_mclk_pin>, <&i2s1_2ch_bus>;
- rockchip,capture-channels = <8>;
- rockchip,playback-channels = <8>;
- status = "okay";
-&io_domains {
- audio-supply = <&vcc_3v0>;
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pcie0 {
- bus-scan-delay-ms = <1000>;
- ep-gpios = <&gpio2 RK_PD4 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-0 = <&pcie_clkreqn_cpm>;
- vpcie3v3-supply = <&vcc3v3_ssd>;
- status = "okay";
-&pinctrl {
- buttons {
pwrbtn_pin: pwrbtn-pin {
lidbtn_pin: lidbtn-pin {
rockchip,pins = <1 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>;
- dc-charger {
dc_det_pin: dc-det-pin {
rockchip,pins = <4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_up>;
- es8316 {
hp_det_pin: hp-det-pin {
rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
- fusb302x {
fusb0_int_pin: fusb0-int-pin {
- i2s1 {
i2s_8ch_mclk_pin: i2s-8ch-mclk-pin {
rockchip,pins = <4 RK_PA0 1 &pcfg_pull_none>;
- lcd-panel {
lcdvcc_en_pin: lcdvcc-en-pin {
panel_en_pin: panel-en-pin {
rockchip,pins = <1 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
lcd_panel_reset_pin: lcd-panel-reset-pin {
rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>;
- leds {
pwr_led_pin: pwr-led-pin {
rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_none>;
slp_led_pin: slp-led-pin {
rockchip,pins = <0 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
pmic_int_l_pin: pmic-int-l-pin {
vsel1_pin: vsel1-pin {
vsel2_pin: vsel2-pin {
- sdcard {
sdmmc0_pwr_h_pin: sdmmc0-pwr-h-pin {
- sdio-pwrseq {
wifi_enable_h_pin: wifi-enable-h-pin {
- usb-typec {
vcc5v0_typec0_en_pin: vcc5v0-typec0-en-pin {
rockchip,pins = <1 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- usb2 {
pwr_5v_pin: pwr-5v-pin {
rockchip,pins = <1 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
vcc5v0_host_en_pin: vcc5v0-host-en-pin {
- wireless-bluetooth {
bt_wake_pin: bt-wake-pin {
rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake_pin: bt-host-wake-pin {
bt_reset_pin: bt-reset-pin {
-&pmu_io_domains {
- status = "okay";
-&pwm0 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cmd &sdmmc_bus4>;
- sd-uhs-sdr50;
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&spi1 {
- max-freq = <10000000>;
- status = "okay";
reg = <0>;
m25p,fast-read;
spi-max-frequency = <10000000>;
-&tcphy0 {
- status = "okay";
-&tcphy0_dp {
- port {
remote-endpoint = <&usbc_dp>;
-&tcphy0_usb3 {
- port {
remote-endpoint = <&usbc_ss>;
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
phy-supply = <&vcc5v0_otg>;
status = "okay";
- port {
remote-endpoint = <&usbc_hs>;
-&u2phy1 {
- status = "okay";
status = "okay";
status = "okay";
-&uart0 {
- uart-has-rtscts;
- status = "okay";
- bluetooth {
compatible = "brcm,bcm4345c5";
device-wakeup-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_HIGH>;
max-speed = <1500000>;
pinctrl-0 = <&bt_host_wake_pin &bt_wake_pin &bt_reset_pin>;
vbat-supply = <&wifi_bat>;
vddio-supply = <&vcc_wl>;
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- dr_mode = "host";
- status = "okay";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- dr_mode = "host";
- status = "okay";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-pinephone-pro.dts b/arch/arm/dts/rk3399-pinephone-pro.dts deleted file mode 100644 index 61f3fec5a8b1..000000000000 --- a/arch/arm/dts/rk3399-pinephone-pro.dts +++ /dev/null @@ -1,621 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2020 Martijn Braam martijn@brixit.nl
- Copyright (c) 2021 Kamil Trzciński ayufan@ayufan.eu
- PinePhone Pro datasheet:
-/dts-v1/; -#include <dt-bindings/input/gpio-keys.h> -#include <dt-bindings/input/linux-event-codes.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- model = "Pine64 PinePhonePro";
- compatible = "pine64,pinephone-pro", "rockchip,rk3399";
- chassis-type = "handset";
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
stdout-path = "serial2:115200n8";
- adc-keys {
keyup-threshold-microvolt = <1600000>;
button-up {
button-down {
press-threshold-microvolt = <600000>;
- backlight: backlight {
pwms = <&pwm0 0 50000 0>;
- gpio-keys {
key-power {
label = "Power";
wakeup-source;
- vcc_sys: vcc-sys-regulator {
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
- vcca1v8_s3: vcc1v8-s3-regulator {
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-boot-on;
- vcc1v8_codec: vcc1v8-codec-regulator {
enable-active-high;
gpio = <&gpio3 RK_PA4 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc1v8_codec_en>;
- wifi_pwrseq: sdio-wifi-pwrseq {
clocks = <&rk818 1>;
* Wait between power-on and SDIO access for CYP43455
* POR circuit.
post-power-on-delay-ms = <110>;
* Wait between consecutive toggles for CYP43455 CBUCK
* regulator discharge.
power-off-delay-us = <10000>;
- /* MIPI DSI panel 1.8v supply */
- vcc1v8_lcd: vcc1v8-lcd {
enable-active-high;
regulator-name = "vcc1v8_lcd";
gpio = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>;
- /* MIPI DSI panel 2.8v supply */
- vcc2v8_lcd: vcc2v8-lcd {
enable-active-high;
regulator-name = "vcc2v8_lcd";
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
gpio = <&gpio3 RK_PA1 GPIO_ACTIVE_HIGH>;
-&cpu_alert0 {
- temperature = <65000>;
-}; -&cpu_alert1 {
- temperature = <68000>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gpu {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk818: pmic@1c {
compatible = "rockchip,rk818";
reg = <0x1c>;
interrupts = <RK_PC5 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
wakeup-source;
vcc1-supply = <&vcc_sys>;
vcc2-supply = <&vcc_sys>;
vcc3-supply = <&vcc_sys>;
vcc4-supply = <&vcc_sys>;
vcc6-supply = <&vcc_sys>;
vcc8-supply = <&vcc_sys>;
regulators {
vdd_cpu_l: DCDC_REG1 {
regulator-boot-on;
regulator-min-microvolt = <875000>;
regulator-max-microvolt = <975000>;
vdd_center: DCDC_REG2 {
regulator-boot-on;
regulator-max-microvolt = <1000000>;
regulator-boot-on;
regulator-boot-on;
vcca3v0_codec: LDO_REG1 {
regulator-max-microvolt = <3000000>;
vcca1v8_codec: LDO_REG3 {
rk818_pwr_on: LDO_REG4 {
regulator-name = "rk818_pwr_on";
regulator-boot-on;
vcc_3v0: LDO_REG5 {
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
vcc1v8_dvp: LDO_REG7 {
vcc3v3_s3: LDO_REG8 {
regulator-boot-on;
vccio_sd: LDO_REG9 {
vcc3v3_s0: SWITCH_REG {
regulator-boot-on;
reg = <0x40>;
regulator-max-microvolt = <1150000>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
-&i2c3 {
- status = "okay";
- touchscreen@14 {
compatible = "goodix,gt1158";
reg = <0x14>;
interrupts = <RK_PB5 IRQ_TYPE_EDGE_RISING>;
irq-gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio3 RK_PB4 GPIO_ACTIVE_HIGH>;
AVDD28-supply = <&vcc3v0_touch>;
VDDIO-supply = <&vcc3v0_touch>;
touchscreen-size-x = <720>;
touchscreen-size-y = <1440>;
-&cluster0_opp {
- opp04 {
status = "disabled";
- opp05 {
-&cluster1_opp {
- opp06 {
opp-hz = /bits/ 64 <1500000000>;
- opp07 {
-&io_domains {
- bt656-supply = <&vcc1v8_dvp>;
- status = "okay";
-&mipi_dsi {
- status = "okay";
- clock-master;
- ports {
mipi_out: port@1 {
#address-cells = <0>;
#size-cells = <0>;
reg = <1>;
mipi_out_panel: endpoint {
remote-endpoint = <&mipi_in_panel>;
- panel@0 {
compatible = "hannstar,hsd060bhw4";
reg = <0>;
reset-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_LOW>;
vcc-supply = <&vcc2v8_lcd>;
iovcc-supply = <&vcc1v8_lcd>;
port {
mipi_in_panel: endpoint {
remote-endpoint = <&mipi_out_panel>;
-&pmu_io_domains {
- status = "okay";
-&pinctrl {
- buttons {
- pmic {
- sdio-pwrseq {
- sound {
vcc1v8_codec_en: vcc1v8-codec-en {
rockchip,pins = <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>;
-&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- disable-wp;
- mmc-pwrseq = <&wifi_pwrseq>;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
-&pwm0 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- vmmc-supply = <&vcc3v3_sys>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&tsadc {
- status = "okay";
-&uart0 {
- uart-has-rtscts;
- status = "okay";
- bluetooth {
-&uart2 {
- status = "okay";
-&vopb {
- status = "okay";
- assigned-clocks = <&cru DCLK_VOP0_DIV>, <&cru DCLK_VOP0>,
<&cru ACLK_VOP0>, <&cru HCLK_VOP0>;
- assigned-clock-rates = <0>, <0>, <400000000>, <100000000>;
- assigned-clock-parents = <&cru PLL_GPLL>, <&cru DCLK_VOP0_DIV>;
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
- assigned-clocks = <&cru DCLK_VOP1_DIV>, <&cru DCLK_VOP1>,
<&cru ACLK_VOP1>, <&cru HCLK_VOP1>;
- assigned-clock-parents = <&cru PLL_GPLL>, <&cru DCLK_VOP1_DIV>;
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-puma-haikou.dts b/arch/arm/dts/rk3399-puma-haikou.dts deleted file mode 100644 index 18a98c4648ea..000000000000 --- a/arch/arm/dts/rk3399-puma-haikou.dts +++ /dev/null @@ -1,306 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2017 Theobroma Systems Design und Consulting GmbH
-/dts-v1/; -#include "rk3399-puma.dtsi" -#include <dt-bindings/input/input.h>
- model = "Theobroma Systems RK3399-Q7 SoM";
- compatible = "tsd,rk3399-puma-haikou", "rockchip,rk3399";
- aliases {
mmc1 = &sdmmc;
- chosen {
stdout-path = "serial0:115200n8";
- gpio-keys {
pinctrl-0 = <&haikou_keys_pin>;
button-batlow-n {
label = "BATLOW#";
linux,code = <KEY_BATTERY>;
button-slp-btn-n {
gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_LOW>;
label = "SLP_BTN#";
linux,code = <KEY_SLEEP>;
button-wake-n {
gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_LOW>;
label = "WAKE#";
linux,code = <KEY_WAKEUP>;
wakeup-source;
switch-lid-btn-n {
gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
label = "LID_BTN#";
linux,input-type = <EV_SW>;
- leds {
pinctrl-0 = <&module_led_pin>, <&sd_card_led_pin>;
sd_card_led: led-1 {
label = "sd_card_led";
gpios = <&gpio1 RK_PA2 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "mmc0";
- i2s0-sound {
simple-audio-card,name = "Haikou,I2S-codec";
simple-audio-card,mclk-fs = <512>;
clocks = <&sgtl5000_clk>;
sound-dai = <&sgtl5000>;
bitclock-master;
frame-master;
sound-dai = <&i2s0>;
- sgtl5000_clk: sgtl5000-oscillator {
#clock-cells = <0>;
clock-frequency = <24576000>;
- dc_12v: dc-12v {
regulator-boot-on;
- vcc3v3_baseboard: vcc3v3-baseboard {
regulator-name = "vcc3v3_baseboard";
regulator-boot-on;
- vcc5v0_baseboard: vcc5v0-baseboard {
regulator-name = "vcc5v0_baseboard";
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
- vcc5v0_otg: vcc5v0-otg-regulator {
enable-active-high;
gpio = <&gpio0 RK_PA2 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&otg_vbus_drv>;
- vdda_codec: vdda-codec {
regulator-name = "vdda_codec";
regulator-boot-on;
vin-supply = <&vcc5v0_baseboard>;
- vddd_codec: vddd-codec {
regulator-name = "vddd_codec";
regulator-boot-on;
regulator-min-microvolt = <1600000>;
regulator-max-microvolt = <1600000>;
-&hdmi {
- status = "okay";
-&i2c1 {
- status = "okay";
-&i2c2 {
- status = "okay";
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
- sgtl5000: codec@a {
compatible = "fsl,sgtl5000";
reg = <0x0a>;
VDDA-supply = <&vdda_codec>;
VDDIO-supply = <&vdda_codec>;
VDDD-supply = <&vddd_codec>;
status = "okay";
-&i2c6 {
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pcie0 {
- ep-gpios = <&gpio4 RK_PC6 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- status = "okay";
-&pinctrl {
- buttons {
haikou_keys_pin: haikou-keys-pin {
rockchip,pins =
/* LID_BTN */
<0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>,
/* BATLOW# */
<0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>,
/* SLP_BTN# */
<0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>,
/* WAKE# */
<0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>;
- leds {
sd_card_led_pin: sd-card-led-pin {
rockchip,pins =
<1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- usb2 {
otg_vbus_drv: otg-vbus-drv {
rockchip,pins =
-&pwm0 {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- max-frequency = <40000000>;
- vmmc-supply = <&vcc3v3_baseboard>;
- status = "okay";
-&spi5 {
- status = "okay";
-&tcphy0 {
- status = "okay";
-&u2phy0 {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- dr_mode = "otg";
- extcon = <&extcon_usb3>;
- status = "okay";
-&u2phy0_host {
- phy-supply = <&vcc5v0_otg>;
- status = "okay";
-&uart0 {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-puma.dtsi b/arch/arm/dts/rk3399-puma.dtsi deleted file mode 100644 index c08e69391c01..000000000000 --- a/arch/arm/dts/rk3399-puma.dtsi +++ /dev/null @@ -1,532 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- aliases {
ethernet0 = &gmac;
mmc0 = &sdhci;
- leds {
pinctrl-0 = <&module_led_pin>;
module_led: led-0 {
label = "module_led";
gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_HIGH>;
panic-indicator;
- extcon_usb3: extcon-usb3 {
compatible = "linux,extcon-usb-gpio";
id-gpios = <&gpio1 RK_PC2 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&usb3_id>;
#clock-cells = <0>;
- vcc1v2_phy: vcc1v2-phy {
regulator-name = "vcc1v2_phy";
regulator-boot-on;
regulator-min-microvolt = <1200000>;
regulator-max-microvolt = <1200000>;
regulator-boot-on;
gpio = <&gpio4 RK_PA3 GPIO_ACTIVE_LOW>;
regulator-boot-on;
regulator-boot-on;
-&cpu_b0 {
-&cpu_b1 {
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&emmc_phy {
- status = "okay";
- drive-impedance-ohm = <33>;
-&gpio0 {
* The BIOS_DISABLE hog is a feedback pin for the actual status of the
* signal. This usually represents the state of a switch on the baseboard.
* The pin has a 10k pull-up resistor connected, so no pull-up setting is needed.
- bios-disable-hog {
gpios = <RK_PB0 GPIO_ACTIVE_HIGH>;
gpio-hog;
input;
line-name = "bios_disable";
-&gmac {
- phy-supply = <&vcc1v2_phy>;
- pinctrl-0 = <&rgmii_pins>;
- snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- snps,reset-delays-us = <0 10000 50000>;
- tx_delay = <0x10>;
- rx_delay = <0x10>;
- status = "okay";
-&gpu {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
interrupts = <22 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
wakeup-source;
vddio-supply = <&vcc1v8_pmu>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_ldo1: LDO_REG1 {
regulator-name = "vcc_ldo1";
regulator-boot-on;
regulator-boot-on;
vcc1v8_pmu: LDO_REG3 {
regulator-name = "vcc1v8_pmu";
regulator-boot-on;
vcc_sd: LDO_REG4 {
regulator-name = "vcc_sd";
regulator-boot-on;
vcc_ldo5: LDO_REG5 {
regulator-name = "vcc_ldo5";
regulator-boot-on;
vcc_ldo6: LDO_REG6 {
regulator-name = "vcc_ldo6";
regulator-boot-on;
regulator-boot-on;
vcc_efuse: LDO_REG8 {
regulator-name = "vcc_efuse";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- vdd_gpu: regulator@60 {
compatible = "fcs,fan53555";
reg = <0x60>;
regulator-min-microvolt = <600000>;
regulator-max-microvolt = <1230000>;
regulator-boot-on;
-&i2c7 {
- status = "okay";
- fan: fan@18 {
compatible = "ti,amc6821";
reg = <0x18>;
- rtc_twi: rtc@6f {
compatible = "isil,isl1208";
reg = <0x6f>;
-&i2c8 {
- status = "okay";
- vdd_cpu_b: regulator@60 {
reg = <0x60>;
regulator-boot-on;
-&i2s0 {
- pinctrl-0 = <&i2s0_2ch_bus>;
- rockchip,playback-channels = <2>;
- rockchip,capture-channels = <2>;
- status = "okay";
- As Q7 does not specify neither a global nor a RX clock for I2S these
- signals are not used. Furthermore I2S0_LRCK_RX is used as GPIO.
- Therefore we have to redefine the i2s0_2ch_bus definition to prevent
- conflicts.
-&i2s0_2ch_bus {
- rockchip,pins =
<3 RK_PD0 1 &pcfg_pull_none>,
<3 RK_PD2 1 &pcfg_pull_none>,
<3 RK_PD3 1 &pcfg_pull_none>,
<3 RK_PD7 1 &pcfg_pull_none>;
-&io_domains {
- status = "okay";
- sdmmc-supply = <&vcc_sd>;
- gpio1830-supply = <&vcc_1v8>;
-&pmu_io_domains {
- status = "okay";
-&pwm2 {
- status = "okay";
-&pinctrl {
- i2c8 {
i2c8_xfer_a: i2c8-xfer {
rockchip,pins =
<1 RK_PC4 1 &pcfg_pull_up>,
<1 RK_PC5 1 &pcfg_pull_up>;
- leds {
module_led_pin: module-led-pin {
rockchip,pins =
<2 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins =
- usb2 {
rockchip,pins =
<4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
- usb3 {
usb3_id: usb3-id {
rockchip,pins =
<1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
-&sdhci {
* Signal integrity isn't great at 200MHz but 100MHz has proven stable
* enough.
- max-frequency = <100000000>;
- bus-width = <8>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- non-removable;
- status = "okay";
-&sdmmc {
- vqmmc-supply = <&vcc_sd>;
-&spi1 {
- status = "okay";
- norflash: flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <50000000>;
-&tcphy1 {
- status = "okay";
-&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <1>;
- status = "okay";
-&u2phy1 {
- status = "okay";
status = "okay";
status = "okay";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts b/arch/arm/dts/rk3399-roc-pc-mezzanine.dts deleted file mode 100644 index 9447c8724b65..000000000000 --- a/arch/arm/dts/rk3399-roc-pc-mezzanine.dts +++ /dev/null @@ -1,111 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2017 T-Chip Intelligent Technology Co., Ltd
- Copyright (c) 2019 Markus Reichl m.reichl@fivetechno.de
-/dts-v1/; -#include "rk3399-roc-pc.dtsi"
- model = "Firefly ROC-RK3399-PC Mezzanine Board";
- compatible = "firefly,roc-rk3399-pc-mezzanine", "rockchip,rk3399";
- aliases {
mmc2 = &sdio0;
- /* MP8009 PoE PD */
- poe_12v: poe-12v {
regulator-name = "poe_12v";
regulator-boot-on;
- vcc3v3_ngff: vcc3v3-ngff {
regulator-name = "vcc3v3_ngff";
enable-active-high;
gpio = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc3v3_ngff_en>;
regulator-boot-on;
vin-supply = <&sys_12v>;
- vcc3v3_pcie: vcc3v3-pcie {
regulator-name = "vcc3v3_pcie";
enable-active-high;
gpio = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc3v3_pcie_en>;
-&sys_12v {
- vin-supply = <&poe_12v>;
-&pcie_phy {
- status = "okay";
-&pcie0 {
- ep-gpios = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-0 = <&pcie_perst>;
- vpcie3v3-supply = <&vcc3v3_pcie>;
- vpcie1v8-supply = <&vcc1v8_pmu>;
- vpcie0v9-supply = <&vcca_0v9>;
- status = "okay";
-&pinctrl {
- ngff {
vcc3v3_ngff_en: vcc3v3-ngff-en {
rockchip,pins = <4 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
vcc3v3_pcie_en: vcc3v3-pcie-en {
rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_perst: pcie-perst {
-&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v3_ngff>;
- vqmmc-supply = <&vcc_1v8>;
- status = "okay";
-&uart0 {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-roc-pc.dts b/arch/arm/dts/rk3399-roc-pc.dts deleted file mode 100644 index cd4195425309..000000000000 --- a/arch/arm/dts/rk3399-roc-pc.dts +++ /dev/null @@ -1,12 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- model = "Firefly ROC-RK3399-PC Board";
- compatible = "firefly,roc-rk3399-pc", "rockchip,rk3399";
-}; diff --git a/arch/arm/dts/rk3399-roc-pc.dtsi b/arch/arm/dts/rk3399-roc-pc.dtsi deleted file mode 100644 index ca7a446b6568..000000000000 --- a/arch/arm/dts/rk3399-roc-pc.dtsi +++ /dev/null @@ -1,844 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi"
- aliases {
ethernet0 = &gmac;
mmc0 = &sdmmc;
mmc1 = &sdhci;
- chosen {
stdout-path = "serial2:1500000n8";
pwms = <&pwm0 0 25000 0>;
#clock-cells = <0>;
- adc-keys {
compatible = "adc-keys";
io-channels = <&saradc 1>;
io-channel-names = "buttons";
poll-interval = <100>;
button-recovery {
label = "Recovery";
linux,code = <KEY_VENDOR>;
press-threshold-microvolt = <18000>;
- gpio-keys {
autorepeat;
pinctrl-0 = <&pwr_key_l>;
key-power {
wakeup-source;
- ir-receiver {
compatible = "gpio-ir-receiver";
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&ir_int>;
- leds {
pinctrl-0 = <&work_led_pin>, <&diy_led_pin>, <&yellow_led_pin>;
work_led: led-0 {
label = "green:work";
diy_led: led-1 {
label = "red:diy";
linux,default-trigger = "mmc2";
yellow_led: led-2 {
label = "yellow:yellow-led";
linux,default-trigger = "mmc1";
pinctrl-0 = <&wifi_enable_h>;
* On the module itself this is one of these (depending
* on the actual card populated):
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
- vcc_vbus_typec0: vcc-vbus-typec0 {
regulator-name = "vcc_vbus_typec0";
regulator-boot-on;
- sys_12v: sys-12v {
regulator-name = "sys_12v";
regulator-boot-on;
regulator-boot-on;
enable-active-high;
gpio = <&gpio4 RK_PD6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc3v0_sd_en>;
regulator-boot-on;
regulator-min-microvolt = <3000000>;
regulator-boot-on;
- vcca_0v9: vcca-0v9 {
regulator-name = "vcca_0v9";
regulator-boot-on;
- /* Actually 3 regulators (host0, 1, 2) controlled by the same gpio */
enable-active-high;
gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_host_en &hub_rst>;
- vcc_vbus_typec1: vcc-vbus-typec1 {
enable-active-high;
pinctrl-0 = <&vcc_vbus_typec1_en>;
regulator-name = "vcc_vbus_typec1";
enable-active-high;
gpio = <&gpio2 RK_PA6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc_sys_en>;
regulator-boot-on;
regulator-name = "vdd_log";
regulator-boot-on;
regulator-min-microvolt = <450000>;
pwm-supply = <&vcc3v3_sys>;
-&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- phy-supply = <&vcc_lan>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- avdd-0v9-supply = <&vcca0v9_hdmi>;
- avdd-1v8-supply = <&vcca1v8_hdmi>;
- ddc-i2c-bus = <&i2c3>;
- pinctrl-0 = <&hdmi_cec>;
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
pinctrl-0 = <&pmic_int_l>;
rockchip,system-power-controller;
wakeup-source;
regulators {
regulator-boot-on;
regulator-min-microvolt = <750000>;
regulator-max-microvolt = <1350000>;
regulator-ramp-delay = <6001>;
regulator-state-mem {
regulator-off-in-suspend;
vdd_cpu_l: DCDC_REG2 {
regulator-name = "vdd_cpu_l";
regulator-boot-on;
vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr";
regulator-boot-on;
regulator-on-in-suspend;
regulator-name = "vcc_1v8";
regulator-boot-on;
regulator-suspend-microvolt = <1800000>;
vcca1v8_codec: LDO_REG1 {
regulator-boot-on;
vcca1v8_hdmi: LDO_REG2 {
regulator-name = "vcca1v8_hdmi";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-name = "vcc_1v5";
regulator-boot-on;
vcca0v9_hdmi: LDO_REG7 {
regulator-name = "vcca0v9_hdmi";
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
vcc3v3_s3: vcc_lan: SWITCH_REG1 {
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
-&i2c1 {
- i2c-scl-rising-time-ns = <300>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
-&i2c3 {
- i2c-scl-rising-time-ns = <450>;
- status = "okay";
-&i2c4 {
- status = "okay";
- fusb1: usb-typec@22 {
reg = <0x22>;
interrupts = <1 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&fusb1_int>;
vbus-supply = <&vcc_vbus_typec1>;
status = "okay";
-&i2c7 {
- status = "okay";
- fusb0: usb-typec@22 {
reg = <0x22>;
interrupts = <2 IRQ_TYPE_LEVEL_LOW>;
vbus-supply = <&vcc_vbus_typec0>;
status = "okay";
- mp8859: regulator@66 {
compatible = "mps,mp8859";
reg = <0x66>;
dc_12v: mp8859_dcdc {
regulator-boot-on;
vin-supply = <&vcc_vbus_typec0>;
regulator-suspend-microvolt = <12000000>;
-&i2s0 {
- status = "okay";
-&i2s1 {
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- status = "okay";
-&pmu_io_domains {
- status = "okay";
-&pinctrl {
- buttons {
pwr_key_l: pwr-key-l {
- ir {
ir_int: ir-int {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
- lcd-panel {
lcd_panel_reset: lcd-panel-reset {
rockchip,pins = <4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_up>;
- leds {
diy_led_pin: diy-led-pin {
work_led_pin: work-led-pin {
yellow_led_pin: yellow-led-pin {
- pmic {
rockchip,pins = <1 RK_PC2 RK_FUNC_GPIO &pcfg_pull_down>;
- sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
- sdmmc {
vcc3v0_sd_en: vcc3v0-sd-en {
rockchip,pins = <4 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
pmic_int_l: pmic-int-l {
- usb2 {
vcc_sys_en: vcc-sys-en {
rockchip,pins = <2 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
hub_rst: hub-rst {
rockchip,pins = <2 RK_PA4 RK_FUNC_GPIO &pcfg_output_high>;
- usb-typec {
vcc_vbus_typec1_en: vcc-vbus-typec1-en {
- fusb30x {
fusb1_int: fusb1-int {
-&pwm0 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- disable-wp;
- max-frequency = <150000000>;
- sd-uhs-sdr104;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- non-removable;
- status = "okay";
-&spi1 {
- status = "okay";
- flash@0 {
reg = <0>;
spi-max-frequency = <30000000>;
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
phy-supply = <&vcc_vbus_typec0>;
status = "okay";
- u2phy0_host: host-port {
status = "okay";
-&u2phy1 {
- status = "okay";
phy-supply = <&vcc_vbus_typec1>;
status = "okay";
- u2phy1_host: host-port {
status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts>;
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-rock-4c-plus.dts b/arch/arm/dts/rk3399-rock-4c-plus.dts deleted file mode 100644 index 7baf9d1b22fd..000000000000 --- a/arch/arm/dts/rk3399-rock-4c-plus.dts +++ /dev/null @@ -1,709 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2019 Radxa Limited
- Copyright (c) 2022 Amarula Solutions(India)
-/dts-v1/; -#include <dt-bindings/leds/common.h> -#include "rk3399.dtsi" -#include "rk3399-t-opp.dtsi"
- model = "Radxa ROCK 4C+";
- compatible = "radxa,rock-4c-plus", "rockchip,rk3399";
- aliases {
ethernet0 = &gmac;
mmc0 = &sdhci;
mmc1 = &sdmmc;
- chosen {
- clkin_gmac: external-gmac-clock {
compatible = "fixed-clock";
clock-frequency = <125000000>;
clock-output-names = "clkin_gmac";
#clock-cells = <0>;
- leds {
pinctrl-0 = <&user_led1 &user_led2>;
/* USER_LED1 */
led-0 {
gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_LOW>;
linux,default-trigger = "default-on";
/* USER_LED2 */
led-1 {
function = LED_FUNCTION_STATUS;
color = <LED_COLOR_ID_BLUE>;
gpios = <&gpio3 RK_PD5 GPIO_ACTIVE_HIGH>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk809 1>;
clock-names = "ext_clock";
reset-gpios = <&gpio0 RK_PB2 GPIO_ACTIVE_LOW>;
- vcc_3v3: vcc-3v3-regulator {
regulator-name = "vcc_3v3";
regulator-boot-on;
- vcc3v3_phy1: vcc3v3-phy1-regulator {
regulator-name = "vcc3v3_phy1";
regulator-boot-on;
vin-supply = <&vcc_3v3>;
- vcc5v0_host1: vcc5v0-host-regulator {
enable-active-high;
gpio = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>;
regulator-name = "vcc5v0_host1";
regulator-boot-on;
vin-supply = <&vcc5v0_host0_s0>;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-name = "vcc5v0_sys";
regulator-boot-on;
- vcc5v0_typec: vcc5v0-typec-regulator {
enable-active-high;
pinctrl-0 = <&vcc5v0_typec0_en>;
regulator-name = "vcc5v0_typec";
regulator-boot-on;
- vdd_log: vdd-log-regulator {
regulator-boot-on;
regulator-min-microvolt = <950000>;
regulator-max-microvolt = <950000>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- phy-supply = <&vcc3v3_phy1>;
- tx_delay = <0x2a>;
- rx_delay = <0x21>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- avdd-0v9-supply = <&vcc_0v9_s0>;
- avdd-1v8-supply = <&vcc_1v8_s0>;
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- i2c-scl-falling-time-ns = <30>;
- i2c-scl-rising-time-ns = <180>;
- rk809: pmic@20 {
compatible = "rockchip,rk809";
reg = <0x20>;
#clock-cells = <1>;
clock-output-names = "rk808-clkout1", "rk808-clkout2";
wakeup-source;
vcc1-supply = <&vcc5v0_sys>;
vcc2-supply = <&vcc5v0_sys>;
vcc3-supply = <&vcc5v0_sys>;
vcc4-supply = <&vcc5v0_sys>;
vcc5-supply = <&vcc_buck5_s3>;
vcc6-supply = <&vcc_buck5_s3>;
vcc7-supply = <&vcc5v0_sys>;
vcc8-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc5v0_sys>;
regulators {
regulator-boot-on;
regulator-initial-mode = <0x2>;
regulator-suspend-microvolt = <900000>;
regulator-boot-on;
regulator-boot-on;
vcc3v3_sys: DCDC_REG4 {
regulator-boot-on;
regulator-name = "vcc3v3_sys";
regulator-suspend-microvolt = <3300000>;
vcc_buck5_s3: DCDC_REG5 {
regulator-boot-on;
regulator-name = "vcc_buck5_s3";
vcc_0v9_s3: LDO_REG1 {
regulator-boot-on;
regulator-name = "vcc_0v9_s3";
vcc_1v8_s3: LDO_REG2 {
regulator-boot-on;
regulator-name = "vcc_1v8_s3";
vcc_0v9_s0: LDO_REG3 {
regulator-boot-on;
regulator-name = "vcc_0v9_s0";
vcc_1v8_s0: LDO_REG4 {
regulator-boot-on;
regulator-name = "vcc_1v8_s0";
vcc_mipi: LDO_REG5 {
regulator-boot-on;
regulator-name = "vcc_mipi";
vcc_1v5_s0: LDO_REG6 {
regulator-boot-on;
regulator-name = "vcc_1v5_s0";
vcc_3v0_s0: LDO_REG7 {
regulator-boot-on;
regulator-name = "vcc_3v0_s0";
vcc_sdio_s0: LDO_REG8 {
regulator-boot-on;
regulator-name = "vcc_sdio_s0";
vcc_cam: LDO_REG9 {
regulator-boot-on;
regulator-name = "vcc_cam";
vcc5v0_host0_s0: SWITCH_REG1 {
regulator-always-on;
regulator-boot-on;
regulator-name = "vcc5v0_host0_s0";
lcd_3v3: SWITCH_REG2 {
regulator-boot-on;
regulator-name = "lcd_3v3";
reg = <0x40>;
regulator-compatible = "fan53555-reg";
pinctrl-0 = <&vsel1_gpio>;
vsel-gpios = <&gpio1 RK_PC1 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
vin-supply = <&vcc5v0_sys>;
reg = <0x41>;
pinctrl-0 = <&vsel2_gpio>;
vsel-gpios = <&gpio1 RK_PB6 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
regulator-initial-mode = <1>; /* 1:force PWM 2:auto */
-&i2c3 {
- status = "okay";
-&i2s2 {
- status = "okay";
-&io_domains {
- audio-supply = <&vcc_1v8_s0>;
- bt656-supply = <&vcc_3v0_s0>;
- gpio1830-supply = <&vcc_3v0_s0>;
- sdmmc-supply = <&vcc_sdio_s0>;
- status = "okay";
-&pinctrl {
- bt {
bt_enable_h: bt-enable-h {
- leds {
user_led1: user-led1 {
rockchip,pins = <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
user_led2: user-led2 {
rockchip,pins = <3 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
vsel1_gpio: vsel1-gpio {
vsel2_gpio: vsel2-gpio {
- sdmmc {
sdmmc_bus4: sdmmc-bus4 {
rockchip,pins = <4 8 1 &pcfg_pull_up_8ma>,
<4 9 1 &pcfg_pull_up_8ma>,
<4 10 1 &pcfg_pull_up_8ma>,
<4 11 1 &pcfg_pull_up_8ma>;
sdmmc_clk: sdmmc-clk {
rockchip,pins = <4 12 1 &pcfg_pull_none_18ma>;
sdmmc_cmd: sdmmc-cmd {
rockchip,pins = <4 13 1 &pcfg_pull_up_8ma>;
- usb-typec {
vcc5v0_typec0_en: vcc5v0-typec-en {
- usb2 {
rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_up>;
- wifi {
-&pmu_io_domains {
- pmu1830-supply = <&vcc_3v0_s0>;
- status = "okay";
-&saradc {
- status = "okay";
- vref-supply = <&vcc_1v8_s3>;
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sdio-irq;
- cap-sd-highspeed;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- card-detect-delay = <800>;
- disable-wp;
- vqmmc-supply = <&vcc_sdio_s0>;
- status = "okay";
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
phy-supply = <&vcc5v0_host1>;
status = "okay";
-&u2phy1 {
- status = "okay";
status = "okay";
status = "okay";
-&uart0 {
- status = "okay";
- bluetooth {
pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>;
vddio-supply = <&vcc_1v8_s3>;
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- extcon = <&u2phy0>;
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "host";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-rock-4se.dts b/arch/arm/dts/rk3399-rock-4se.dts deleted file mode 100644 index 7cfc198bbae7..000000000000 --- a/arch/arm/dts/rk3399-rock-4se.dts +++ /dev/null @@ -1,65 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Akash Gajjar Akash_Gajjar@mentor.com
- Copyright (c) 2019 Pragnesh Patel Pragnesh_Patel@mentor.com
-/dts-v1/; -#include "rk3399-rock-pi-4.dtsi" -#include "rk3399-t-opp.dtsi"
- model = "Radxa ROCK 4SE";
- compatible = "radxa,rock-4se", "rockchip,rk3399";
- aliases {
mmc2 = &sdio0;
-&pinctrl {
- usb2 {
rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_none>;
-&sdio0 {
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
-&uart0 {
- status = "okay";
- bluetooth {
clocks = <&rk808 1>;
-&vcc5v0_host {
- enable-active-high;
- gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>;
- pinctrl-0 = <&vcc5v0_host_en>;
-}; diff --git a/arch/arm/dts/rk3399-rock-pi-4.dtsi b/arch/arm/dts/rk3399-rock-pi-4.dtsi deleted file mode 100644 index 281a12180703..000000000000 --- a/arch/arm/dts/rk3399-rock-pi-4.dtsi +++ /dev/null @@ -1,792 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-/dts-v1/; -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pwm/pwm.h> -#include "rk3399.dtsi"
- aliases {
ethernet0 = &gmac;
mmc0 = &sdhci;
mmc1 = &sdmmc;
- chosen {
#clock-cells = <0>;
- leds {
pinctrl-0 = <&user_led2>;
/* USER_LED2 */
led-0 {
- sound: sound {
compatible = "audio-graph-card";
label = "Analog";
dais = <&i2s0_p0>;
- sound-dit {
label = "SPDIF";
dais = <&spdif_p0>;
- spdif-dit {
compatible = "linux,spdif-dit";
port {
dit_p0_0: endpoint {
remote-endpoint = <&spdif_p0_0>;
enable-active-high;
regulator-name = "vbus_typec";
- vcc12v_dcin: dc-12v {
regulator-name = "vcc12v_dcin";
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
- vcc3v3_lan: vcc3v3-lan-regulator {
regulator-name = "vcc3v3_lan";
regulator-boot-on;
vin-supply = <&vcc3v3_sys>;
- vcc3v3_pcie: vcc3v3-pcie-regulator {
enable-active-high;
gpio = <&gpio2 RK_PD2 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie_pwr_en>;
regulator-boot-on;
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
enable-active-high;
- vcc5v0_sys: vcc-sys {
regulator-boot-on;
vin-supply = <&vcc12v_dcin>;
regulator-boot-on;
pwm-supply = <&vcc5v0_sys>;
regulator-boot-on;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
- cpu-supply = <&vdd_cpu_b>;
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gmac {
- assigned-clock-parents = <&clkin_gmac>;
- clock_in_out = "input";
- phy-supply = <&vcc3v3_lan>;
- phy-mode = "rgmii";
- tx_delay = <0x28>;
- rx_delay = <0x11>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
#clock-cells = <1>;
wakeup-source;
vcc6-supply = <&vcc5v0_sys>;
vcc10-supply = <&vcc5v0_sys>;
vcc11-supply = <&vcc5v0_sys>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcca_1v8: LDO_REG3 {
regulator-name = "vcca_1v8";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
vcc_cam: SWITCH_REG1 {
regulator-boot-on;
vcc_mipi: SWITCH_REG2 {
regulator-boot-on;
- vdd_cpu_b: regulator@40 {
compatible = "silergy,syr827";
reg = <0x40>;
fcs,suspend-voltage-selector = <1>;
regulator-name = "vdd_cpu_b";
regulator-min-microvolt = <712500>;
regulator-ramp-delay = <1000>;
regulator-boot-on;
- vdd_gpu: regulator@41 {
compatible = "silergy,syr828";
reg = <0x41>;
regulator-name = "vdd_gpu";
regulator-boot-on;
-&i2c1 {
- status = "okay";
- es8316: codec@11 {
reg = <0x11>;
port {
es8316_p0_0: endpoint {
remote-endpoint = <&i2s0_p0_0>;
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
-&i2s0 {
- pinctrl-1 = <&i2s0_2ch_bus_bclk_off>;
- status = "okay";
- i2s0_p0: port {
i2s0_p0_0: endpoint {
dai-format = "i2s";
mclk-fs = <256>;
remote-endpoint = <&es8316_p0_0>;
-&i2s1 {
-&i2s2 {
- status = "okay";
-&io_domains {
- status = "okay";
-&pcie0 {
- ep-gpios = <&gpio4 RK_PD3 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-0 = <&pcie_clkreqnb_cpm>;
- vpcie0v9-supply = <&vcc_0v9>;
- vpcie1v8-supply = <&vcc_1v8>;
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pinctrl {
- bt {
- es8316 {
hp_detect: hp-detect {
hp_int: hp-int {
- leds {
- pcie {
pcie_pwr_en: pcie-pwr-en {
- pmic {
- sdio0 {
sdio0_bus4: sdio0-bus4 {
rockchip,pins = <2 RK_PC4 1 &pcfg_pull_up_20ma>,
<2 RK_PC5 1 &pcfg_pull_up_20ma>,
<2 RK_PC6 1 &pcfg_pull_up_20ma>,
<2 RK_PC7 1 &pcfg_pull_up_20ma>;
sdio0_cmd: sdio0-cmd {
rockchip,pins = <2 RK_PD0 1 &pcfg_pull_up_20ma>;
sdio0_clk: sdio0-clk {
rockchip,pins = <2 RK_PD1 1 &pcfg_pull_none_20ma>;
- usb-typec {
- usb2 {
- wifi {
-&pmu_io_domains {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- status = "okay";
- vref-supply = <&vcc_1v8>;
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sdio-irq;
- cap-sd-highspeed;
- non-removable;
- sd-uhs-sdr104;
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc_clk &sdmmc_cd &sdmmc_cmd &sdmmc_bus4>;
- status = "okay";
-&spdif {
- spdif_p0: port {
spdif_p0_0: endpoint {
remote-endpoint = <&dit_p0_0>;
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
status = "okay";
-&u2phy1 {
- status = "okay";
status = "okay";
status = "okay";
-&uart0 {
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "host";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-rock-pi-4a.dts b/arch/arm/dts/rk3399-rock-pi-4a.dts deleted file mode 100644 index d5df8939a658..000000000000 --- a/arch/arm/dts/rk3399-rock-pi-4a.dts +++ /dev/null @@ -1,24 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-/dts-v1/; -#include "rk3399-rock-pi-4.dtsi" -#include "rk3399-opp.dtsi"
- model = "Radxa ROCK Pi 4A";
- compatible = "radxa,rockpi4a", "radxa,rockpi4", "rockchip,rk3399";
-&spi1 {
- status = "okay";
- flash@0 {
reg = <0>;
-}; diff --git a/arch/arm/dts/rk3399-rock-pi-4c.dts b/arch/arm/dts/rk3399-rock-pi-4c.dts deleted file mode 100644 index de2ebe4cb4f3..000000000000 --- a/arch/arm/dts/rk3399-rock-pi-4c.dts +++ /dev/null @@ -1,80 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Amarula Solutions(India)
- model = "Radxa ROCK Pi 4C";
- compatible = "radxa,rockpi4c", "radxa,rockpi4", "rockchip,rk3399";
- aliases {
mmc2 = &sdio0;
-&es8316 {
- pinctrl-0 = <&hp_detect &hp_int>;
- interrupt-parent = <&gpio1>;
- interrupts = <RK_PA1 IRQ_TYPE_LEVEL_HIGH>;
-&sdio0 {
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
-&sound {
- hp-det-gpio = <&gpio1 RK_PA0 GPIO_ACTIVE_HIGH>;
-&spi1 {
- status = "okay";
- flash@0 {
reg = <0>;
-&uart0 {
- status = "okay";
- bluetooth {
-&vcc5v0_host {
- gpio = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>;
-&vcc5v0_host_en {
- rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
-}; diff --git a/arch/arm/dts/rk3399-rock960.dts b/arch/arm/dts/rk3399-rock960.dts deleted file mode 100644 index 1a23e8f3cdf6..000000000000 --- a/arch/arm/dts/rk3399-rock960.dts +++ /dev/null @@ -1,156 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2018 Linaro Ltd.
-/dts-v1/; -#include "rk3399-rock960.dtsi"
- model = "96boards Rock960";
- compatible = "vamrs,rock960", "rockchip,rk3399";
- chosen {
- leds {
compatible = "gpio-leds";
pinctrl-0 = <&user_led1_pin>, <&user_led2_pin>,
<&user_led3_pin>, <&user_led4_pin>,
<&wlan_led_pin>, <&bt_led_pin>;
user_led1: led-1 {
label = "green:user1";
gpios = <&gpio4 RK_PC2 0>;
linux,default-trigger = "heartbeat";
user_led2: led-2 {
label = "green:user2";
gpios = <&gpio4 RK_PC6 0>;
user_led3: led-3 {
label = "green:user3";
gpios = <&gpio4 RK_PD0 0>;
user_led4: led-4 {
label = "green:user4";
gpios = <&gpio4 RK_PD4 0>;
panic-indicator;
linux,default-trigger = "none";
wlan_active_led: led-5 {
label = "yellow:wlan";
gpios = <&gpio4 RK_PD5 0>;
linux,default-trigger = "phy0tx";
bt_active_led: led-6 {
label = "blue:bt";
gpios = <&gpio4 RK_PD6 0>;
linux,default-trigger = "hci0-power";
-&cpu_alert0 {
-&cpu_thermal {
- sustainable-power = <1550>;
- cooling-maps {
map0 {
trip = <&cpu_alert1>;
-&pcie0 {
- ep-gpios = <&gpio2 RK_PA2 GPIO_ACTIVE_HIGH>;
-&pinctrl {
- leds {
user_led1_pin: user-led1-pin {
rockchip,pins =
<4 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
user_led2_pin: user-led2-pin {
rockchip,pins =
<4 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
user_led3_pin: user-led3-pin {
rockchip,pins =
<4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
user_led4_pin: user-led4-pin {
rockchip,pins =
<4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
wlan_led_pin: wlan-led-pin {
rockchip,pins =
<4 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
bt_led_pin: bt-led-pin {
rockchip,pins =
- pcie {
pcie_drv: pcie-drv {
rockchip,pins =
<2 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
- usb2 {
host_vbus_drv: host-vbus-drv {
rockchip,pins =
-&spi0 {
- /* On Low speed expansion (LS-SPI0) */
- status = "okay";
-&spi4 {
- /* On High speed expansion (HS-SPI1) */
- status = "okay";
-&usbdrd_dwc3_0 {
- dr_mode = "otg";
-&usbdrd_dwc3_1 {
- dr_mode = "host";
-&vcc3v3_pcie {
- gpio = <&gpio2 5 GPIO_ACTIVE_HIGH>;
-&vcc5v0_host {
- gpio = <&gpio4 25 GPIO_ACTIVE_HIGH>;
-}; diff --git a/arch/arm/dts/rk3399-rock960.dtsi b/arch/arm/dts/rk3399-rock960.dtsi deleted file mode 100644 index c920ddf44baf..000000000000 --- a/arch/arm/dts/rk3399-rock960.dtsi +++ /dev/null @@ -1,673 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2018 Collabora Ltd.
- Copyright (c) 2018 Fuzhou Rockchip Electronics Co., Ltd.
-#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" -#include <dt-bindings/interrupt-controller/irq.h>
- aliases {
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- vcc12v_dcin: vcc12v-dcin {
regulator-boot-on;
- vcc1v8_s0: vcc1v8-s0 {
regulator-name = "vcc1v8_s0";
- vcc5v0_sys: vcc5v0-sys {
enable-active-high;
pinctrl-0 = <&pcie_drv>;
regulator-boot-on;
enable-active-high;
pinctrl-0 = <&host_vbus_drv>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&emmc_phy {
- status = "okay";
-&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x40>;
regulator-boot-on;
status = "okay";
reg = <0x41>;
regulator-boot-on;
- rk808: pmic@1b {
compatible = "rockchip,rk808";
reg = <0x1b>;
interrupts = <21 IRQ_TYPE_LEVEL_LOW>;
wakeup-source;
#clock-cells = <1>;
vcc12-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc_1v8>;
regulators {
vdd_center: DCDC_REG1 {
regulator-name = "vdd_center";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: DCDC_REG4 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_sd: LDO_REG4 {
regulator-boot-on;
vcc3v0_sd: LDO_REG5 {
regulator-name = "vcc3v0_sd";
regulator-boot-on;
regulator-suspend-microvolt = <3000000>;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
regulator-suspend-microvolt = <1500000>;
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-name = "vcc_3v0";
regulator-boot-on;
vcc3v3_s3: SWITCH_REG1 {
regulator-name = "vcc3v3_s3";
regulator-boot-on;
vcc3v3_s0: SWITCH_REG2 {
regulator-name = "vcc3v3_s0";
regulator-boot-on;
-&i2c1 {
- status = "okay";
-&i2c2 {
- status = "okay";
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
-&i2s2 {
status = "okay";
-&io_domains {
- bt656-supply = <&vcc1v8_s0>; /* bt656_gpio2ab_ms */
- audio-supply = <&vcc1v8_s0>; /* audio_gpio3d4a_ms */
- sdmmc-supply = <&vcc_sd>; /* sdmmc_gpio4b_ms */
- gpio1830-supply = <&vcc_3v0>; /* gpio1833_gpio4cd_ms */
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pcie0 {
- num-lanes = <4>;
- vpcie1v8-supply = <&vcca_1v8>;
- status = "okay";
-&pmu_io_domains {
- pmu1830-supply = <&vcc_1v8>;
- status = "okay";
-&pinctrl {
- bt {
rockchip,pins = <0 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake_l: bt-host-wake-l {
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
bt_wake_l: bt-wake-l {
- sdmmc {
sdmmc_bus1: sdmmc-bus1 {
rockchip,pins =
<4 RK_PB0 1 &pcfg_pull_up_8ma>;
rockchip,pins =
<4 RK_PB0 1 &pcfg_pull_up_8ma>,
<4 RK_PB1 1 &pcfg_pull_up_8ma>,
<4 RK_PB2 1 &pcfg_pull_up_8ma>,
<4 RK_PB3 1 &pcfg_pull_up_8ma>;
rockchip,pins =
<4 RK_PB4 1 &pcfg_pull_none_18ma>;
rockchip,pins =
<4 RK_PB5 1 &pcfg_pull_up_8ma>;
- sdio0 {
rockchip,pins =
rockchip,pins =
rockchip,pins =
- pmic {
rockchip,pins =
<1 RK_PC5 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins =
<1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins =
<1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
- sdio-pwrseq {
rockchip,pins =
<0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
- wifi {
-&pwm2 {
- status = "okay";
-&pwm3 {
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sdio-irq;
- cap-sd-highspeed;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdio0_bus4 &sdio0_cmd &sdio0_clk>;
- sd-uhs-sdr104;
- status = "okay";
- brcmf: wifi@1 {
reg = <1>;
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- non-removable;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- clock-frequency = <100000000>;
- cd-gpios = <&gpio0 7 GPIO_ACTIVE_LOW>;
- disable-wp;
- sd-uhs-sdr104;
- status = "okay";
-&tsadc {
- rockchip,hw-tshut-temp = <110000>;
- status = "okay";
-&uart0 {
- status = "okay";
- bluetooth {
compatible = "brcm,bcm43438-bt";
host-wakeup-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_HIGH>;
shutdown-gpios = <&gpio0 RK_PB1 GPIO_ACTIVE_HIGH>;
-&uart2 {
- status = "okay";
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&u2phy0 {
- status = "okay";
-&u2phy1 {
- status = "okay";
-&u2phy0_host {
- phy-supply = <&vcc5v0_host>;
- status = "okay";
-&u2phy1_host {
- status = "okay";
-&u2phy0_otg {
- status = "okay";
-&u2phy1_otg {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-rockpro64.dts b/arch/arm/dts/rk3399-rockpro64.dts deleted file mode 100644 index 4b42717800f7..000000000000 --- a/arch/arm/dts/rk3399-rockpro64.dts +++ /dev/null @@ -1,30 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2017 Fuzhou Rockchip Electronics Co., Ltd.
- Copyright (c) 2019 Katsuhiro Suzuki katsuhiro@katsuster.net
-/dts-v1/; -#include "rk3399-rockpro64.dtsi"
- model = "Pine64 RockPro64 v2.1";
- compatible = "pine64,rockpro64-v2.1", "pine64,rockpro64", "rockchip,rk3399";
-&i2c1 {
reg = <0x11>;
port {
remote-endpoint = <&i2s1_p0_0>;
-}; diff --git a/arch/arm/dts/rk3399-rockpro64.dtsi b/arch/arm/dts/rk3399-rockpro64.dtsi deleted file mode 100644 index f30b82a10ca3..000000000000 --- a/arch/arm/dts/rk3399-rockpro64.dtsi +++ /dev/null @@ -1,956 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- aliases {
ethernet0 = &gmac;
mmc0 = &sdio0;
mmc1 = &sdmmc;
mmc2 = &sdhci;
- chosen {
- /* enable for panel backlight support */
brightness-levels = <0 4 8 16 32 64 128 255>;
default-brightness-level = <5>;
pwms = <&pwm0 0 1000000 0>;
#clock-cells = <0>;
- gpio-keys {
compatible = "gpio-keys";
autorepeat;
pinctrl-0 = <&pwrbtn>;
key-power {
debounce-interval = <100>;
gpios = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
label = "GPIO Key Power";
linux,code = <KEY_POWER>;
wakeup-source;
- ir-receiver {
- leds {
pinctrl-0 = <&work_led_pin>, <&diy_led_pin>;
work_led: led-0 {
label = "work";
default-state = "on";
diy_led: led-1 {
label = "diy";
- fan: pwm-fan {
compatible = "pwm-fan";
cooling-levels = <0 100 150 200 255>;
#cooling-cells = <2>;
fan-supply = <&vcc12v_dcin>;
pwms = <&pwm1 0 50000 0>;
- sound {
label = "Analog";
dais = <&i2s1_p0>;
- sound-dit {
label = "SPDIF";
dais = <&spdif_p0>;
- spdif-dit {
port {
- avdd: avdd-regulator {
regulator-name = "avdd";
regulator-min-microvolt = <11000000>;
regulator-max-microvolt = <11000000>;
vin-supply = <&vcc3v3_s0>;
regulator-boot-on;
- /* switched by pmic_sleep */
- vcc1v8_s3: vcca1v8_s3: vcc1v8-s3 {
regulator-name = "vcc1v8_s3";
regulator-boot-on;
vin-supply = <&vcc_1v8>;
- vcc3v0_sd: vcc3v0-sd {
enable-active-high;
gpio = <&gpio0 RK_PA1 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&sdmmc0_pwr_h>;
enable-active-high;
gpio = <&gpio1 RK_PD0 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
regulator-boot-on;
- vcc5v0_host: vcc5v0-host-regulator {
enable-active-high;
regulator-name = "vcc5v0_host";
enable-active-high;
gpio = <&gpio1 RK_PA3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_typec_en>;
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb {
regulator-boot-on;
- vdd_log: vdd-log {
compatible = "pwm-regulator";
pwms = <&pwm2 0 25000 1>;
regulator-boot-on;
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1700000>;
-&cpu_l0 {
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
-&cpu_b1 {
-&cpu_thermal {
- trips {
cpu_warm: cpu_warm {
temperature = <55000>;
hysteresis = <2000>;
type = "active";
cpu_hot: cpu_hot {
type = "active";
- cooling-maps {
map2 {
trip = <&cpu_warm>;
cooling-device = <&fan THERMAL_NO_LIMIT 1>;
map3 {
trip = <&cpu_hot>;
cooling-device = <&fan 2 THERMAL_NO_LIMIT>;
-&emmc_phy {
- status = "okay";
-&gmac {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_sound {
- status = "okay";
-&gpu {
- status = "okay";
-&i2c0 {
- i2c-scl-rising-time-ns = <168>;
- i2c-scl-falling-time-ns = <4>;
- status = "okay";
- rk808: pmic@1b {
reg = <0x1b>;
interrupt-parent = <&gpio3>;
#clock-cells = <1>;
wakeup-source;
vddio-supply = <&vcca_1v8>;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc1v8_dvp: LDO_REG1 {
regulator-name = "vcc1v8_dvp";
regulator-boot-on;
vcc3v0_touch: LDO_REG2 {
regulator-name = "vcc3v0_touch";
regulator-boot-on;
vcc_sdio: LDO_REG4 {
regulator-name = "vcc_sdio";
regulator-boot-on;
vcca3v0_codec: LDO_REG5 {
regulator-name = "vcca3v0_codec";
regulator-boot-on;
vcc_1v5: LDO_REG6 {
regulator-boot-on;
vcca1v8_codec: LDO_REG7 {
regulator-name = "vcca1v8_codec";
regulator-boot-on;
vcc_3v0: LDO_REG8 {
regulator-boot-on;
regulator-boot-on;
reg = <0x40>;
regulator-boot-on;
reg = <0x41>;
regulator-boot-on;
-&i2c1 {
- status = "okay";
-&i2c3 {
- status = "okay";
-&i2c4 {
- status = "okay";
- fusb0: typec-portc@22 {
compatible = "fcs,fusb302";
reg = <0x22>;
interrupts = <RK_PA2 IRQ_TYPE_LEVEL_LOW>;
pinctrl-0 = <&fusb0_int>;
vbus-supply = <&vcc5v0_typec>;
status = "okay";
- /* enable for pine64 touch screen support */
- touch: touchscreen@5d {
compatible = "goodix,gt911";
reg = <0x5d>;
interrupt-parent = <&gpio4>;
interrupts = <RK_PD5 IRQ_TYPE_EDGE_FALLING>;
irq-gpios = <&gpio4 RK_PD5 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio4 RK_PD6 GPIO_ACTIVE_HIGH>;
-&i2s0 {
- status = "okay";
-&i2s1 {
- status = "okay";
- i2s1_p0: port {
i2s1_p0_0: endpoint {
dai-format = "i2s";
mclk-fs = <256>;
-&i2s2 {
- status = "okay";
-&io_domains {
- status = "okay";
- sdmmc-supply = <&vcc_sdio>;
-/* enable for pine64 panel display support */ -&mipi_dsi {
- clock-master;
- status = "disabled";
- ports {
mipi_out: port@1 {
reg = <1>;
- mipi_panel: panel@0 {
compatible = "feiyang,fy07024di26a30d";
reg = <0>;
avdd-supply = <&avdd>;
backlight = <&backlight>;
dvdd-supply = <&vcc3v3_s0>;
port {
-&pcie0 {
- num-lanes = <4>;
- vpcie12v-supply = <&vcc12v_dcin>;
- status = "okay";
-&pcie_phy {
- status = "okay";
-&pmu_io_domains {
- pmu1830-supply = <&vcc_3v0>;
- status = "okay";
-&pinctrl {
- bt {
rockchip,pins = <0 RK_PA4 RK_FUNC_GPIO &pcfg_pull_down>;
- buttons {
pwrbtn: pwrbtn {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>;
- fusb302x {
fusb0_int: fusb0-int {
rockchip,pins = <1 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>;
- ir {
ir_int: ir-int {
- leds {
- pcie {
rockchip,pins = <2 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <1 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins = <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>;
rockchip,pins = <1 RK_PC1 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins = <1 RK_PB6 RK_FUNC_GPIO &pcfg_pull_down>;
- sdcard {
sdmmc0_pwr_h: sdmmc0-pwr-h {
rockchip,pins = <0 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
rockchip,pins = <0 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
- usb-typec {
vcc5v0_typec_en: vcc5v0_typec_en {
- usb2 {
vcc5v0_host_en: vcc5v0-host-en {
rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
-&pwm0 {
- status = "okay";
-&pwm1 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&saradc {
- vref-supply = <&vcca1v8_s3>;
- status = "okay";
-&sdio0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- disable-wp;
- non-removable;
- sd-uhs-sdr104;
- status = "okay";
-&sdmmc {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- vmmc-supply = <&vcc3v0_sd>;
- vqmmc-supply = <&vcc_sdio>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&spdif {
- pinctrl-0 = <&spdif_bus_1>;
- spdif_p0: port {
-&spi1 {
- status = "okay";
- flash@0 {
reg = <0>;
-&tcphy0 {
- status = "okay";
-&tcphy1 {
- status = "okay";
-&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- /* tshut polarity 0:LOW 1:HIGH */
- status = "okay";
-&u2phy0 {
- status = "okay";
status = "okay";
status = "okay";
-&u2phy1 {
- status = "okay";
- u2phy1_otg: otg-port {
status = "okay";
status = "okay";
-&uart0 {
- pinctrl-0 = <&uart0_xfer &uart0_cts &uart0_rts>;
- status = "okay";
- bluetooth {
clock-names = "lpo";
vbat-supply = <&vcc3v3_sys>;
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
- dr_mode = "host";
-&usbdrd3_1 {
- status = "okay";
-&usbdrd_dwc3_1 {
- status = "okay";
- dr_mode = "host";
-&vopb {
- status = "okay";
-&vopb_mmu {
- status = "okay";
-&vopl {
- status = "okay";
-&vopl_mmu {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3399-t-opp.dtsi b/arch/arm/dts/rk3399-t-opp.dtsi deleted file mode 100644 index 1ababadda9df..000000000000 --- a/arch/arm/dts/rk3399-t-opp.dtsi +++ /dev/null @@ -1,114 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2016-2017 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2022 Radxa Limited
- cluster0_opp: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp00 {
opp-hz = /bits/ 64 <408000000>;
opp-microvolt = <875000 875000 1250000>;
clock-latency-ns = <40000>;
opp01 {
opp-hz = /bits/ 64 <600000000>;
opp02 {
opp-hz = /bits/ 64 <816000000>;
opp-microvolt = <900000 900000 1250000>;
opp03 {
opp-hz = /bits/ 64 <1008000000>;
opp-microvolt = <975000 975000 1250000>;
- cluster1_opp: opp-table-1 {
opp-shared;
opp00 {
opp01 {
opp02 {
opp03 {
opp-microvolt = <925000 925000 1250000>;
opp04 {
opp-hz = /bits/ 64 <1200000000>;
opp-microvolt = <1000000 1000000 1250000>;
opp05 {
opp-hz = /bits/ 64 <1416000000>;
opp-microvolt = <1075000 1075000 1250000>;
opp06 {
opp-hz = /bits/ 64 <1512000000>;
opp-microvolt = <1150000 1150000 1250000>;
- gpu_opp_table: opp-table-2 {
opp00 {
opp-hz = /bits/ 64 <200000000>;
opp-microvolt = <875000 875000 1150000>;
opp01 {
opp-hz = /bits/ 64 <300000000>;
opp02 {
opp-hz = /bits/ 64 <400000000>;
opp03 {
opp-microvolt = <975000 975000 1150000>;
-&cpu_l0 {
- operating-points-v2 = <&cluster0_opp>;
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&cpu_b0 {
- operating-points-v2 = <&cluster1_opp>;
-&cpu_b1 {
-&gpu {
- operating-points-v2 = <&gpu_opp_table>;
-}; diff --git a/arch/arm/dts/rk3399.dtsi b/arch/arm/dts/rk3399.dtsi deleted file mode 100644 index 6e12c5a920ca..000000000000 --- a/arch/arm/dts/rk3399.dtsi +++ /dev/null @@ -1,2945 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2016 Fuzhou Rockchip Electronics Co., Ltd
-#include <dt-bindings/clock/rk3399-cru.h> -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rk3399-power.h> -#include <dt-bindings/thermal/thermal.h>
- compatible = "rockchip,rk3399";
- interrupt-parent = <&gic>;
- #address-cells = <2>;
- #size-cells = <2>;
- aliases {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
gpio3 = &gpio3;
gpio4 = &gpio4;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
i2c6 = &i2c6;
i2c7 = &i2c7;
i2c8 = &i2c8;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
- cpus {
#size-cells = <0>;
cpu-map {
cluster0 {
core0 {
cpu = <&cpu_l0>;
core1 {
cpu = <&cpu_l1>;
core2 {
cpu = <&cpu_l2>;
core3 {
cpu = <&cpu_l3>;
cluster1 {
core0 {
cpu = <&cpu_b0>;
core1 {
cpu = <&cpu_b1>;
cpu_l0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a53";
reg = <0x0 0x0>;
enable-method = "psci";
capacity-dmips-mhz = <485>;
clocks = <&cru ARMCLKL>;
#cooling-cells = <2>; /* min followed by max */
dynamic-power-coefficient = <100>;
cpu-idle-states = <&CPU_SLEEP &CLUSTER_SLEEP>;
cpu_l1: cpu@1 {
reg = <0x0 0x1>;
cpu_l2: cpu@2 {
reg = <0x0 0x2>;
cpu_l3: cpu@3 {
reg = <0x0 0x3>;
cpu_b0: cpu@100 {
compatible = "arm,cortex-a72";
reg = <0x0 0x100>;
capacity-dmips-mhz = <1024>;
clocks = <&cru ARMCLKB>;
dynamic-power-coefficient = <436>;
thermal-idle {
duration-us = <10000>;
exit-latency-us = <500>;
cpu_b1: cpu@101 {
reg = <0x0 0x101>;
thermal-idle {
idle-states {
entry-method = "psci";
CPU_SLEEP: cpu-sleep {
compatible = "arm,idle-state";
local-timer-stop;
arm,psci-suspend-param = <0x0010000>;
entry-latency-us = <120>;
exit-latency-us = <250>;
min-residency-us = <900>;
CLUSTER_SLEEP: cluster-sleep {
local-timer-stop;
arm,psci-suspend-param = <0x1010000>;
entry-latency-us = <400>;
min-residency-us = <2000>;
- display-subsystem {
compatible = "rockchip,display-subsystem";
ports = <&vopl_out>, <&vopb_out>;
- dmc: memory-controller {
compatible = "rockchip,rk3399-dmc";
rockchip,pmu = <&pmugrf>;
devfreq-events = <&dfi>;
clocks = <&cru SCLK_DDRC>;
clock-names = "dmc_clk";
- pmu_a53 {
compatible = "arm,cortex-a53-pmu";
interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster0>;
- pmu_a72 {
compatible = "arm,cortex-a72-pmu";
interrupts = <GIC_PPI 7 IRQ_TYPE_LEVEL_LOW &ppi_cluster1>;
- psci {
compatible = "arm,psci-1.0";
method = "smc";
- timer {
compatible = "arm,armv8-timer";
interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_LOW 0>,
<GIC_PPI 14 IRQ_TYPE_LEVEL_LOW 0>,
<GIC_PPI 11 IRQ_TYPE_LEVEL_LOW 0>,
<GIC_PPI 10 IRQ_TYPE_LEVEL_LOW 0>;
arm,no-tick-in-suspend;
- xin24m: xin24m {
clock-frequency = <24000000>;
clock-output-names = "xin24m";
#clock-cells = <0>;
- pcie0: pcie@f8000000 {
compatible = "rockchip,rk3399-pcie";
reg = <0x0 0xf8000000 0x0 0x2000000>,
<0x0 0xfd000000 0x0 0x1000000>;
reg-names = "axi-base", "apb-base";
device_type = "pci";
#address-cells = <3>;
#size-cells = <2>;
#interrupt-cells = <1>;
aspm-no-l0s;
bus-range = <0x0 0x1f>;
clocks = <&cru ACLK_PCIE>, <&cru ACLK_PERF_PCIE>,
<&cru PCLK_PCIE>, <&cru SCLK_PCIE_PM>;
clock-names = "aclk", "aclk-perf",
"hclk", "pm";
interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "sys", "legacy", "client";
interrupt-map-mask = <0 0 0 7>;
interrupt-map = <0 0 0 1 &pcie0_intc 0>,
<0 0 0 2 &pcie0_intc 1>,
<0 0 0 3 &pcie0_intc 2>,
<0 0 0 4 &pcie0_intc 3>;
max-link-speed = <1>;
msi-map = <0x0 &its 0x0 0x1000>;
phys = <&pcie_phy 0>, <&pcie_phy 1>,
<&pcie_phy 2>, <&pcie_phy 3>;
phy-names = "pcie-phy-0", "pcie-phy-1",
"pcie-phy-2", "pcie-phy-3";
ranges = <0x82000000 0x0 0xfa000000 0x0 0xfa000000 0x0 0x1e00000>,
<0x81000000 0x0 0xfbe00000 0x0 0xfbe00000 0x0 0x100000>;
resets = <&cru SRST_PCIE_CORE>, <&cru SRST_PCIE_MGMT>,
<&cru SRST_PCIE_MGMT_STICKY>, <&cru SRST_PCIE_PIPE>,
<&cru SRST_PCIE_PM>, <&cru SRST_P_PCIE>,
<&cru SRST_A_PCIE>;
reset-names = "core", "mgmt", "mgmt-sticky", "pipe",
"pm", "pclk", "aclk";
pcie0_intc: interrupt-controller {
interrupt-controller;
- pcie0_ep: pcie-ep@f8000000 {
compatible = "rockchip,rk3399-pcie-ep";
reg = <0x0 0xfd000000 0x0 0x1000000>,
<0x0 0xfa000000 0x0 0x2000000>;
reg-names = "apb-base", "mem-base";
"hclk", "pm";
max-functions = /bits/ 8 <8>;
num-lanes = <4>;
<&cru SRST_A_PCIE>;
rockchip,max-outbound-regions = <32>;
pinctrl-names = "default";
- gmac: ethernet@fe300000 {
compatible = "rockchip,rk3399-gmac";
reg = <0x0 0xfe300000 0x0 0x10000>;
interrupts = <GIC_SPI 12 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "macirq";
clocks = <&cru SCLK_MAC>, <&cru SCLK_MAC_RX>,
<&cru SCLK_MAC_TX>, <&cru SCLK_MACREF>,
<&cru SCLK_MACREF_OUT>, <&cru ACLK_GMAC>,
<&cru PCLK_GMAC>;
clock-names = "stmmaceth", "mac_clk_rx",
"mac_clk_tx", "clk_mac_ref",
"clk_mac_refout", "aclk_mac",
"pclk_mac";
power-domains = <&power RK3399_PD_GMAC>;
resets = <&cru SRST_A_GMAC>;
reset-names = "stmmaceth";
rockchip,grf = <&grf>;
snps,txpbl = <0x4>;
- sdio0: mmc@fe310000 {
compatible = "rockchip,rk3399-dw-mshc",
"rockchip,rk3288-dw-mshc";
reg = <0x0 0xfe310000 0x0 0x4000>;
interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_SDIO>, <&cru SCLK_SDIO>,
<&cru SCLK_SDIO_DRV>, <&cru SCLK_SDIO_SAMPLE>;
clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
fifo-depth = <0x100>;
power-domains = <&power RK3399_PD_SDIOAUDIO>;
resets = <&cru SRST_SDIO0>;
reset-names = "reset";
- sdmmc: mmc@fe320000 {
reg = <0x0 0xfe320000 0x0 0x4000>;
interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH 0>;
assigned-clocks = <&cru HCLK_SD>;
assigned-clock-rates = <200000000>;
clocks = <&cru HCLK_SDMMC>, <&cru SCLK_SDMMC>,
<&cru SCLK_SDMMC_DRV>, <&cru SCLK_SDMMC_SAMPLE>;
power-domains = <&power RK3399_PD_SD>;
resets = <&cru SRST_SDMMC>;
- sdhci: mmc@fe330000 {
compatible = "rockchip,rk3399-sdhci-5.1", "arasan,sdhci-5.1";
reg = <0x0 0xfe330000 0x0 0x10000>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH 0>;
arasan,soc-ctl-syscon = <&grf>;
assigned-clocks = <&cru SCLK_EMMC>;
clocks = <&cru SCLK_EMMC>, <&cru ACLK_EMMC>;
clock-names = "clk_xin", "clk_ahb";
clock-output-names = "emmc_cardclock";
#clock-cells = <0>;
phys = <&emmc_phy>;
phy-names = "phy_arasan";
power-domains = <&power RK3399_PD_EMMC>;
disable-cqe-dcmd;
- usb_host0_ehci: usb@fe380000 {
compatible = "generic-ehci";
reg = <0x0 0xfe380000 0x0 0x20000>;
interrupts = <GIC_SPI 26 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_HOST0>, <&cru HCLK_HOST0_ARB>,
<&u2phy0>;
phys = <&u2phy0_host>;
phy-names = "usb";
- usb_host0_ohci: usb@fe3a0000 {
compatible = "generic-ohci";
reg = <0x0 0xfe3a0000 0x0 0x20000>;
interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH 0>;
<&u2phy0>;
phy-names = "usb";
- usb_host1_ehci: usb@fe3c0000 {
reg = <0x0 0xfe3c0000 0x0 0x20000>;
interrupts = <GIC_SPI 30 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_HOST1>, <&cru HCLK_HOST1_ARB>,
<&u2phy1>;
phys = <&u2phy1_host>;
phy-names = "usb";
- usb_host1_ohci: usb@fe3e0000 {
reg = <0x0 0xfe3e0000 0x0 0x20000>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH 0>;
<&u2phy1>;
phy-names = "usb";
- debug@fe430000 {
compatible = "arm,coresight-cpu-debug", "arm,primecell";
reg = <0 0xfe430000 0 0x1000>;
clocks = <&cru PCLK_COREDBG_L>;
clock-names = "apb_pclk";
cpu = <&cpu_l0>;
- debug@fe432000 {
reg = <0 0xfe432000 0 0x1000>;
cpu = <&cpu_l1>;
- debug@fe434000 {
reg = <0 0xfe434000 0 0x1000>;
cpu = <&cpu_l2>;
- debug@fe436000 {
reg = <0 0xfe436000 0 0x1000>;
cpu = <&cpu_l3>;
- debug@fe610000 {
reg = <0 0xfe610000 0 0x1000>;
clocks = <&cru PCLK_COREDBG_B>;
cpu = <&cpu_b0>;
- debug@fe710000 {
reg = <0 0xfe710000 0 0x1000>;
cpu = <&cpu_b1>;
- usbdrd3_0: usb@fe800000 {
compatible = "rockchip,rk3399-dwc3";
#size-cells = <2>;
ranges;
clocks = <&cru SCLK_USB3OTG0_REF>, <&cru SCLK_USB3OTG0_SUSPEND>,
<&cru ACLK_USB3OTG0>, <&cru ACLK_USB3_RKSOC_AXI_PERF>,
<&cru ACLK_USB3>, <&cru ACLK_USB3_GRF>;
clock-names = "ref_clk", "suspend_clk",
"bus_clk", "aclk_usb3_rksoc_axi_perf",
"aclk_usb3", "grf_clk";
resets = <&cru SRST_A_USB3_OTG0>;
reset-names = "usb3-otg";
usbdrd_dwc3_0: usb@fe800000 {
compatible = "snps,dwc3";
reg = <0x0 0xfe800000 0x0 0x100000>;
interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_USB3OTG0_REF>, <&cru ACLK_USB3OTG0>,
<&cru SCLK_USB3OTG0_SUSPEND>;
clock-names = "ref", "bus_early", "suspend";
dr_mode = "otg";
phys = <&u2phy0_otg>, <&tcphy0_usb3>;
phy-names = "usb2-phy", "usb3-phy";
phy_type = "utmi_wide";
snps,dis_enblslpm_quirk;
snps,dis-u2-freeclk-exists-quirk;
snps,dis_u2_susphy_quirk;
snps,dis-del-phy-power-chg-quirk;
snps,dis-tx-ipgap-linecheck-quirk;
power-domains = <&power RK3399_PD_USB3>;
- usbdrd3_1: usb@fe900000 {
#size-cells = <2>;
ranges;
clocks = <&cru SCLK_USB3OTG1_REF>, <&cru SCLK_USB3OTG1_SUSPEND>,
<&cru ACLK_USB3OTG1>, <&cru ACLK_USB3_RKSOC_AXI_PERF>,
resets = <&cru SRST_A_USB3_OTG1>;
usbdrd_dwc3_1: usb@fe900000 {
reg = <0x0 0xfe900000 0x0 0x100000>;
interrupts = <GIC_SPI 110 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_USB3OTG1_REF>, <&cru ACLK_USB3OTG1>,
<&cru SCLK_USB3OTG1_SUSPEND>;
dr_mode = "otg";
phys = <&u2phy1_otg>, <&tcphy1_usb3>;
- cdn_dp: dp@fec00000 {
compatible = "rockchip,rk3399-cdn-dp";
reg = <0x0 0xfec00000 0x0 0x100000>;
interrupts = <GIC_SPI 9 IRQ_TYPE_LEVEL_HIGH 0>;
assigned-clocks = <&cru SCLK_DP_CORE>, <&cru SCLK_SPDIF_REC_DPTX>;
assigned-clock-rates = <100000000>, <200000000>;
clocks = <&cru SCLK_DP_CORE>, <&cru PCLK_DP_CTRL>,
<&cru SCLK_SPDIF_REC_DPTX>, <&cru PCLK_VIO_GRF>;
clock-names = "core-clk", "pclk", "spdif", "grf";
phys = <&tcphy0_dp>, <&tcphy1_dp>;
power-domains = <&power RK3399_PD_HDCP>;
resets = <&cru SRST_DPTX_SPDIF_REC>, <&cru SRST_P_UPHY0_DPTX>,
<&cru SRST_P_UPHY0_APB>, <&cru SRST_DP_CORE>;
reset-names = "spdif", "dptx", "apb", "core";
#sound-dai-cells = <1>;
ports {
dp_in: port {
#address-cells = <1>;
#size-cells = <0>;
dp_in_vopb: endpoint@0 {
reg = <0>;
remote-endpoint = <&vopb_out_dp>;
dp_in_vopl: endpoint@1 {
reg = <1>;
remote-endpoint = <&vopl_out_dp>;
- gic: interrupt-controller@fee00000 {
compatible = "arm,gic-v3";
#interrupt-cells = <4>;
#size-cells = <2>;
ranges;
reg = <0x0 0xfee00000 0 0x10000>, /* GICD */
<0x0 0xfef00000 0 0xc0000>, /* GICR */
<0x0 0xfff00000 0 0x10000>, /* GICC */
<0x0 0xfff10000 0 0x10000>, /* GICH */
<0x0 0xfff20000 0 0x10000>; /* GICV */
interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH 0>;
its: msi-controller@fee20000 {
compatible = "arm,gic-v3-its";
msi-controller;
#msi-cells = <1>;
reg = <0x0 0xfee20000 0x0 0x20000>;
ppi-partitions {
ppi_cluster0: interrupt-partition-0 {
affinity = <&cpu_l0 &cpu_l1 &cpu_l2 &cpu_l3>;
ppi_cluster1: interrupt-partition-1 {
affinity = <&cpu_b0 &cpu_b1>;
- saradc: saradc@ff100000 {
compatible = "rockchip,rk3399-saradc";
reg = <0x0 0xff100000 0x0 0x100>;
interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH 0>;
#io-channel-cells = <1>;
clocks = <&cru SCLK_SARADC>, <&cru PCLK_SARADC>;
clock-names = "saradc", "apb_pclk";
resets = <&cru SRST_P_SARADC>;
reset-names = "saradc-apb";
- crypto0: crypto@ff8b0000 {
compatible = "rockchip,rk3399-crypto";
reg = <0x0 0xff8b0000 0x0 0x4000>;
interrupts = <GIC_SPI 0 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_M_CRYPTO0>, <&cru HCLK_S_CRYPTO0>, <&cru SCLK_CRYPTO0>;
clock-names = "hclk_master", "hclk_slave", "sclk";
resets = <&cru SRST_CRYPTO0>, <&cru SRST_CRYPTO0_S>, <&cru SRST_CRYPTO0_M>;
reset-names = "master", "slave", "crypto-rst";
- crypto1: crypto@ff8b8000 {
reg = <0x0 0xff8b8000 0x0 0x4000>;
interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru HCLK_M_CRYPTO1>, <&cru HCLK_S_CRYPTO1>, <&cru SCLK_CRYPTO1>;
resets = <&cru SRST_CRYPTO1>, <&cru SRST_CRYPTO1_S>, <&cru SRST_CRYPTO1_M>;
- i2c1: i2c@ff110000 {
compatible = "rockchip,rk3399-i2c";
reg = <0x0 0xff110000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C1>;
clocks = <&cru SCLK_I2C1>, <&cru PCLK_I2C1>;
clock-names = "i2c", "pclk";
interrupts = <GIC_SPI 59 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c1_xfer>;
#size-cells = <0>;
- i2c2: i2c@ff120000 {
reg = <0x0 0xff120000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C2>;
clocks = <&cru SCLK_I2C2>, <&cru PCLK_I2C2>;
interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c2_xfer>;
#size-cells = <0>;
- i2c3: i2c@ff130000 {
reg = <0x0 0xff130000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C3>;
clocks = <&cru SCLK_I2C3>, <&cru PCLK_I2C3>;
interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c3_xfer>;
#size-cells = <0>;
- i2c5: i2c@ff140000 {
reg = <0x0 0xff140000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C5>;
clocks = <&cru SCLK_I2C5>, <&cru PCLK_I2C5>;
interrupts = <GIC_SPI 38 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c5_xfer>;
#size-cells = <0>;
- i2c6: i2c@ff150000 {
reg = <0x0 0xff150000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C6>;
clocks = <&cru SCLK_I2C6>, <&cru PCLK_I2C6>;
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c6_xfer>;
#size-cells = <0>;
- i2c7: i2c@ff160000 {
reg = <0x0 0xff160000 0x0 0x1000>;
assigned-clocks = <&cru SCLK_I2C7>;
clocks = <&cru SCLK_I2C7>, <&cru PCLK_I2C7>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c7_xfer>;
#size-cells = <0>;
- uart0: serial@ff180000 {
compatible = "rockchip,rk3399-uart", "snps,dw-apb-uart";
reg = <0x0 0xff180000 0x0 0x100>;
clocks = <&cru SCLK_UART0>, <&cru PCLK_UART0>;
clock-names = "baudclk", "apb_pclk";
interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH 0>;
reg-shift = <2>;
reg-io-width = <4>;
pinctrl-0 = <&uart0_xfer>;
- uart1: serial@ff190000 {
reg = <0x0 0xff190000 0x0 0x100>;
clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>;
interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH 0>;
reg-shift = <2>;
reg-io-width = <4>;
pinctrl-0 = <&uart1_xfer>;
- uart2: serial@ff1a0000 {
reg = <0x0 0xff1a0000 0x0 0x100>;
clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>;
interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH 0>;
reg-shift = <2>;
reg-io-width = <4>;
pinctrl-0 = <&uart2c_xfer>;
- uart3: serial@ff1b0000 {
reg = <0x0 0xff1b0000 0x0 0x100>;
clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>;
interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH 0>;
reg-shift = <2>;
reg-io-width = <4>;
pinctrl-0 = <&uart3_xfer>;
- spi0: spi@ff1c0000 {
compatible = "rockchip,rk3399-spi", "rockchip,rk3066-spi";
reg = <0x0 0xff1c0000 0x0 0x1000>;
clocks = <&cru SCLK_SPI0>, <&cru PCLK_SPI0>;
clock-names = "spiclk", "apb_pclk";
interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 10>, <&dmac_peri 11>;
dma-names = "tx", "rx";
pinctrl-0 = <&spi0_clk &spi0_tx &spi0_rx &spi0_cs0>;
#size-cells = <0>;
- spi1: spi@ff1d0000 {
reg = <0x0 0xff1d0000 0x0 0x1000>;
clocks = <&cru SCLK_SPI1>, <&cru PCLK_SPI1>;
interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 12>, <&dmac_peri 13>;
pinctrl-0 = <&spi1_clk &spi1_tx &spi1_rx &spi1_cs0>;
#size-cells = <0>;
- spi2: spi@ff1e0000 {
reg = <0x0 0xff1e0000 0x0 0x1000>;
clocks = <&cru SCLK_SPI2>, <&cru PCLK_SPI2>;
interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 14>, <&dmac_peri 15>;
pinctrl-0 = <&spi2_clk &spi2_tx &spi2_rx &spi2_cs0>;
#size-cells = <0>;
- spi4: spi@ff1f0000 {
reg = <0x0 0xff1f0000 0x0 0x1000>;
clocks = <&cru SCLK_SPI4>, <&cru PCLK_SPI4>;
interrupts = <GIC_SPI 67 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_peri 18>, <&dmac_peri 19>;
pinctrl-0 = <&spi4_clk &spi4_tx &spi4_rx &spi4_cs0>;
#size-cells = <0>;
- spi5: spi@ff200000 {
reg = <0x0 0xff200000 0x0 0x1000>;
clocks = <&cru SCLK_SPI5>, <&cru PCLK_SPI5>;
interrupts = <GIC_SPI 132 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 8>, <&dmac_bus 9>;
pinctrl-0 = <&spi5_clk &spi5_tx &spi5_rx &spi5_cs0>;
#size-cells = <0>;
- thermal_zones: thermal-zones {
cpu_thermal: cpu-thermal {
polling-delay-passive = <100>;
polling-delay = <1000>;
thermal-sensors = <&tsadc 0>;
trips {
cpu_alert0: cpu_alert0 {
temperature = <70000>;
type = "passive";
cpu_alert1: cpu_alert1 {
temperature = <75000>;
type = "passive";
cpu_crit: cpu_crit {
temperature = <95000>;
type = "critical";
cooling-maps {
map0 {
trip = <&cpu_alert0>;
cooling-device =
<&cpu_b0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_b1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
map1 {
cooling-device =
<&cpu_l0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu_l3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
gpu_thermal: gpu-thermal {
thermal-sensors = <&tsadc 1>;
trips {
gpu_alert0: gpu_alert0 {
type = "passive";
gpu_crit: gpu_crit {
type = "critical";
cooling-maps {
map0 {
trip = <&gpu_alert0>;
cooling-device =
<&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
- tsadc: tsadc@ff260000 {
compatible = "rockchip,rk3399-tsadc";
reg = <0x0 0xff260000 0x0 0x100>;
interrupts = <GIC_SPI 97 IRQ_TYPE_LEVEL_HIGH 0>;
assigned-clocks = <&cru SCLK_TSADC>;
assigned-clock-rates = <750000>;
clocks = <&cru SCLK_TSADC>, <&cru PCLK_TSADC>;
clock-names = "tsadc", "apb_pclk";
resets = <&cru SRST_TSADC>;
reset-names = "tsadc-apb";
rockchip,hw-tshut-temp = <95000>;
pinctrl-names = "init", "default", "sleep";
pinctrl-0 = <&otp_pin>;
pinctrl-1 = <&otp_out>;
pinctrl-2 = <&otp_pin>;
#thermal-sensor-cells = <1>;
- qos_emmc: qos@ffa58000 {
compatible = "rockchip,rk3399-qos", "syscon";
reg = <0x0 0xffa58000 0x0 0x20>;
- qos_gmac: qos@ffa5c000 {
reg = <0x0 0xffa5c000 0x0 0x20>;
- qos_pcie: qos@ffa60080 {
reg = <0x0 0xffa60080 0x0 0x20>;
- qos_usb_host0: qos@ffa60100 {
reg = <0x0 0xffa60100 0x0 0x20>;
- qos_usb_host1: qos@ffa60180 {
reg = <0x0 0xffa60180 0x0 0x20>;
- qos_usb_otg0: qos@ffa70000 {
reg = <0x0 0xffa70000 0x0 0x20>;
- qos_usb_otg1: qos@ffa70080 {
reg = <0x0 0xffa70080 0x0 0x20>;
- qos_sd: qos@ffa74000 {
reg = <0x0 0xffa74000 0x0 0x20>;
- qos_sdioaudio: qos@ffa76000 {
reg = <0x0 0xffa76000 0x0 0x20>;
- qos_hdcp: qos@ffa90000 {
reg = <0x0 0xffa90000 0x0 0x20>;
- qos_iep: qos@ffa98000 {
reg = <0x0 0xffa98000 0x0 0x20>;
- qos_isp0_m0: qos@ffaa0000 {
reg = <0x0 0xffaa0000 0x0 0x20>;
- qos_isp0_m1: qos@ffaa0080 {
reg = <0x0 0xffaa0080 0x0 0x20>;
- qos_isp1_m0: qos@ffaa8000 {
reg = <0x0 0xffaa8000 0x0 0x20>;
- qos_isp1_m1: qos@ffaa8080 {
reg = <0x0 0xffaa8080 0x0 0x20>;
- qos_rga_r: qos@ffab0000 {
reg = <0x0 0xffab0000 0x0 0x20>;
- qos_rga_w: qos@ffab0080 {
reg = <0x0 0xffab0080 0x0 0x20>;
- qos_video_m0: qos@ffab8000 {
reg = <0x0 0xffab8000 0x0 0x20>;
- qos_video_m1_r: qos@ffac0000 {
reg = <0x0 0xffac0000 0x0 0x20>;
- qos_video_m1_w: qos@ffac0080 {
reg = <0x0 0xffac0080 0x0 0x20>;
- qos_vop_big_r: qos@ffac8000 {
reg = <0x0 0xffac8000 0x0 0x20>;
- qos_vop_big_w: qos@ffac8080 {
reg = <0x0 0xffac8080 0x0 0x20>;
- qos_vop_little: qos@ffad0000 {
reg = <0x0 0xffad0000 0x0 0x20>;
- qos_perihp: qos@ffad8080 {
reg = <0x0 0xffad8080 0x0 0x20>;
- qos_gpu: qos@ffae0000 {
reg = <0x0 0xffae0000 0x0 0x20>;
- pmu: power-management@ff310000 {
compatible = "rockchip,rk3399-pmu", "syscon", "simple-mfd";
reg = <0x0 0xff310000 0x0 0x1000>;
* Note: RK3399 supports 6 voltage domains including VD_CORE_L,
* VD_CORE_B, VD_CENTER, VD_GPU, VD_LOGIC and VD_PMU.
* Some of the power domains are grouped together for every
* voltage domain.
* The detail contents as below.
power: power-controller {
compatible = "rockchip,rk3399-power-controller";
#power-domain-cells = <1>;
#size-cells = <0>;
/* These power domains are grouped by VD_CENTER */
power-domain@RK3399_PD_IEP {
reg = <RK3399_PD_IEP>;
clocks = <&cru ACLK_IEP>,
<&cru HCLK_IEP>;
pm_qos = <&qos_iep>;
#power-domain-cells = <0>;
power-domain@RK3399_PD_RGA {
reg = <RK3399_PD_RGA>;
clocks = <&cru ACLK_RGA>,
<&cru HCLK_RGA>;
pm_qos = <&qos_rga_r>,
<&qos_rga_w>;
power-domain@RK3399_PD_VCODEC {
reg = <RK3399_PD_VCODEC>;
clocks = <&cru ACLK_VCODEC>,
<&cru HCLK_VCODEC>;
pm_qos = <&qos_video_m0>;
power-domain@RK3399_PD_VDU {
reg = <RK3399_PD_VDU>;
clocks = <&cru ACLK_VDU>,
<&cru HCLK_VDU>,
<&cru SCLK_VDU_CA>,
<&cru SCLK_VDU_CORE>;
pm_qos = <&qos_video_m1_r>,
<&qos_video_m1_w>;
/* These power domains are grouped by VD_GPU */
power-domain@RK3399_PD_GPU {
reg = <RK3399_PD_GPU>;
clocks = <&cru ACLK_GPU>;
pm_qos = <&qos_gpu>;
/* These power domains are grouped by VD_LOGIC */
power-domain@RK3399_PD_EDP {
reg = <RK3399_PD_EDP>;
clocks = <&cru PCLK_EDP_CTRL>;
power-domain@RK3399_PD_EMMC {
reg = <RK3399_PD_EMMC>;
clocks = <&cru ACLK_EMMC>;
pm_qos = <&qos_emmc>;
power-domain@RK3399_PD_GMAC {
reg = <RK3399_PD_GMAC>;
clocks = <&cru ACLK_GMAC>,
<&cru PCLK_GMAC>;
pm_qos = <&qos_gmac>;
power-domain@RK3399_PD_SD {
reg = <RK3399_PD_SD>;
<&cru SCLK_SDMMC>;
pm_qos = <&qos_sd>;
power-domain@RK3399_PD_SDIOAUDIO {
reg = <RK3399_PD_SDIOAUDIO>;
clocks = <&cru HCLK_SDIO>;
pm_qos = <&qos_sdioaudio>;
power-domain@RK3399_PD_TCPD0 {
reg = <RK3399_PD_TCPD0>;
clocks = <&cru SCLK_UPHY0_TCPDCORE>,
<&cru SCLK_UPHY0_TCPDPHY_REF>;
power-domain@RK3399_PD_TCPD1 {
reg = <RK3399_PD_TCPD1>;
clocks = <&cru SCLK_UPHY1_TCPDCORE>,
<&cru SCLK_UPHY1_TCPDPHY_REF>;
power-domain@RK3399_PD_USB3 {
reg = <RK3399_PD_USB3>;
clocks = <&cru ACLK_USB3>;
pm_qos = <&qos_usb_otg0>,
<&qos_usb_otg1>;
power-domain@RK3399_PD_VIO {
reg = <RK3399_PD_VIO>;
#size-cells = <0>;
power-domain@RK3399_PD_HDCP {
reg = <RK3399_PD_HDCP>;
clocks = <&cru ACLK_HDCP>,
<&cru HCLK_HDCP>,
<&cru PCLK_HDCP>;
pm_qos = <&qos_hdcp>;
power-domain@RK3399_PD_ISP0 {
reg = <RK3399_PD_ISP0>;
clocks = <&cru ACLK_ISP0>,
<&cru HCLK_ISP0>;
pm_qos = <&qos_isp0_m0>,
<&qos_isp0_m1>;
power-domain@RK3399_PD_ISP1 {
reg = <RK3399_PD_ISP1>;
clocks = <&cru ACLK_ISP1>,
<&cru HCLK_ISP1>;
pm_qos = <&qos_isp1_m0>,
<&qos_isp1_m1>;
power-domain@RK3399_PD_VO {
reg = <RK3399_PD_VO>;
#size-cells = <0>;
power-domain@RK3399_PD_VOPB {
reg = <RK3399_PD_VOPB>;
clocks = <&cru ACLK_VOP0>,
<&cru HCLK_VOP0>;
pm_qos = <&qos_vop_big_r>,
<&qos_vop_big_w>;
power-domain@RK3399_PD_VOPL {
reg = <RK3399_PD_VOPL>;
clocks = <&cru ACLK_VOP1>,
<&cru HCLK_VOP1>;
pm_qos = <&qos_vop_little>;
- pmugrf: syscon@ff320000 {
compatible = "rockchip,rk3399-pmugrf", "syscon", "simple-mfd";
reg = <0x0 0xff320000 0x0 0x1000>;
pmu_io_domains: io-domains {
compatible = "rockchip,rk3399-pmu-io-voltage-domain";
- spi3: spi@ff350000 {
reg = <0x0 0xff350000 0x0 0x1000>;
clocks = <&pmucru SCLK_SPI3_PMU>, <&pmucru PCLK_SPI3_PMU>;
interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&spi3_clk &spi3_tx &spi3_rx &spi3_cs0>;
#size-cells = <0>;
- uart4: serial@ff370000 {
reg = <0x0 0xff370000 0x0 0x100>;
clocks = <&pmucru SCLK_UART4_PMU>, <&pmucru PCLK_UART4_PMU>;
interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH 0>;
reg-shift = <2>;
reg-io-width = <4>;
pinctrl-0 = <&uart4_xfer>;
- i2c0: i2c@ff3c0000 {
reg = <0x0 0xff3c0000 0x0 0x1000>;
assigned-clocks = <&pmucru SCLK_I2C0_PMU>;
clocks = <&pmucru SCLK_I2C0_PMU>, <&pmucru PCLK_I2C0_PMU>;
interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c0_xfer>;
#size-cells = <0>;
- i2c4: i2c@ff3d0000 {
reg = <0x0 0xff3d0000 0x0 0x1000>;
assigned-clocks = <&pmucru SCLK_I2C4_PMU>;
clocks = <&pmucru SCLK_I2C4_PMU>, <&pmucru PCLK_I2C4_PMU>;
interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c4_xfer>;
#size-cells = <0>;
- i2c8: i2c@ff3e0000 {
reg = <0x0 0xff3e0000 0x0 0x1000>;
assigned-clocks = <&pmucru SCLK_I2C8_PMU>;
clocks = <&pmucru SCLK_I2C8_PMU>, <&pmucru PCLK_I2C8_PMU>;
interrupts = <GIC_SPI 58 IRQ_TYPE_LEVEL_HIGH 0>;
pinctrl-0 = <&i2c8_xfer>;
#size-cells = <0>;
- pwm0: pwm@ff420000 {
compatible = "rockchip,rk3399-pwm", "rockchip,rk3288-pwm";
reg = <0x0 0xff420000 0x0 0x10>;
#pwm-cells = <3>;
pinctrl-0 = <&pwm0_pin>;
clocks = <&pmucru PCLK_RKPWM_PMU>;
- pwm1: pwm@ff420010 {
reg = <0x0 0xff420010 0x0 0x10>;
#pwm-cells = <3>;
pinctrl-0 = <&pwm1_pin>;
- pwm2: pwm@ff420020 {
reg = <0x0 0xff420020 0x0 0x10>;
#pwm-cells = <3>;
pinctrl-0 = <&pwm2_pin>;
- pwm3: pwm@ff420030 {
reg = <0x0 0xff420030 0x0 0x10>;
#pwm-cells = <3>;
pinctrl-0 = <&pwm3a_pin>;
- dfi: dfi@ff630000 {
reg = <0x00 0xff630000 0x00 0x4000>;
compatible = "rockchip,rk3399-dfi";
interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru PCLK_DDR_MON>;
clock-names = "pclk_ddr_mon";
- vpu: video-codec@ff650000 {
compatible = "rockchip,rk3399-vpu";
reg = <0x0 0xff650000 0x0 0x800>;
interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 113 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "vepu", "vdpu";
clocks = <&cru ACLK_VCODEC>, <&cru HCLK_VCODEC>;
clock-names = "aclk", "hclk";
iommus = <&vpu_mmu>;
power-domains = <&power RK3399_PD_VCODEC>;
- vpu_mmu: iommu@ff650800 {
compatible = "rockchip,iommu";
reg = <0x0 0xff650800 0x0 0x40>;
interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH 0>;
clock-names = "aclk", "iface";
#iommu-cells = <0>;
- vdec: video-codec@ff660000 {
compatible = "rockchip,rk3399-vdec";
reg = <0x0 0xff660000 0x0 0x480>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>,
<&cru SCLK_VDU_CA>, <&cru SCLK_VDU_CORE>;
clock-names = "axi", "ahb", "cabac", "core";
iommus = <&vdec_mmu>;
power-domains = <&power RK3399_PD_VDU>;
- vdec_mmu: iommu@ff660480 {
reg = <0x0 0xff660480 0x0 0x40>, <0x0 0xff6604c0 0x0 0x40>;
interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru ACLK_VDU>, <&cru HCLK_VDU>;
#iommu-cells = <0>;
- iep_mmu: iommu@ff670800 {
reg = <0x0 0xff670800 0x0 0x40>;
interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru ACLK_IEP>, <&cru HCLK_IEP>;
#iommu-cells = <0>;
- rga: rga@ff680000 {
compatible = "rockchip,rk3399-rga";
reg = <0x0 0xff680000 0x0 0x10000>;
interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru SCLK_RGA_CORE>;
clock-names = "aclk", "hclk", "sclk";
resets = <&cru SRST_RGA_CORE>, <&cru SRST_A_RGA>, <&cru SRST_H_RGA>;
reset-names = "core", "axi", "ahb";
power-domains = <&power RK3399_PD_RGA>;
- efuse0: efuse@ff690000 {
compatible = "rockchip,rk3399-efuse";
reg = <0x0 0xff690000 0x0 0x80>;
#size-cells = <1>;
clocks = <&cru PCLK_EFUSE1024NS>;
clock-names = "pclk_efuse";
/* Data cells */
cpu_id: cpu-id@7 {
reg = <0x07 0x10>;
cpub_leakage: cpu-leakage@17 {
reg = <0x17 0x1>;
gpu_leakage: gpu-leakage@18 {
reg = <0x18 0x1>;
center_leakage: center-leakage@19 {
reg = <0x19 0x1>;
cpul_leakage: cpu-leakage@1a {
reg = <0x1a 0x1>;
logic_leakage: logic-leakage@1b {
reg = <0x1b 0x1>;
wafer_info: wafer-info@1c {
reg = <0x1c 0x1>;
- dmac_bus: dma-controller@ff6d0000 {
compatible = "arm,pl330", "arm,primecell";
reg = <0x0 0xff6d0000 0x0 0x4000>;
interrupts = <GIC_SPI 5 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 6 IRQ_TYPE_LEVEL_HIGH 0>;
#dma-cells = <1>;
arm,pl330-periph-burst;
clocks = <&cru ACLK_DMAC0_PERILP>;
- dmac_peri: dma-controller@ff6e0000 {
reg = <0x0 0xff6e0000 0x0 0x4000>;
interrupts = <GIC_SPI 7 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 8 IRQ_TYPE_LEVEL_HIGH 0>;
#dma-cells = <1>;
clocks = <&cru ACLK_DMAC1_PERILP>;
- pmucru: clock-controller@ff750000 {
compatible = "rockchip,rk3399-pmucru";
reg = <0x0 0xff750000 0x0 0x1000>;
clocks = <&xin24m>;
clock-names = "xin24m";
rockchip,grf = <&pmugrf>;
#clock-cells = <1>;
#reset-cells = <1>;
assigned-clocks = <&pmucru PLL_PPLL>;
assigned-clock-rates = <676000000>;
- cru: clock-controller@ff760000 {
compatible = "rockchip,rk3399-cru";
reg = <0x0 0xff760000 0x0 0x1000>;
clocks = <&xin24m>;
#clock-cells = <1>;
#reset-cells = <1>;
assigned-clocks =
<&cru PLL_GPLL>, <&cru PLL_CPLL>,
<&cru PLL_NPLL>,
<&cru ACLK_PERIHP>, <&cru HCLK_PERIHP>,
<&cru PCLK_PERIHP>,
<&cru ACLK_PERILP0>, <&cru HCLK_PERILP0>,
<&cru PCLK_PERILP0>, <&cru ACLK_CCI>,
<&cru HCLK_PERILP1>, <&cru PCLK_PERILP1>,
<&cru ACLK_VIO>, <&cru ACLK_HDCP>,
<&cru ACLK_GIC_PRE>,
<&cru PCLK_DDR>,
<&cru ACLK_VDU>;
<594000000>, <800000000>,
<1000000000>,
<150000000>, <75000000>,
<37500000>,
<100000000>, <100000000>,
<50000000>, <600000000>,
<100000000>, <50000000>,
<400000000>, <400000000>,
<200000000>,
<200000000>,
<400000000>;
- grf: syscon@ff770000 {
compatible = "rockchip,rk3399-grf", "syscon", "simple-mfd";
reg = <0x0 0xff770000 0x0 0x10000>;
#size-cells = <1>;
compatible = "rockchip,rk3399-io-voltage-domain";
mipi_dphy_rx0: mipi-dphy-rx0 {
compatible = "rockchip,rk3399-mipi-dphy-rx0";
clocks = <&cru SCLK_MIPIDPHY_REF>,
<&cru SCLK_DPHY_RX0_CFG>,
clock-names = "dphy-ref", "dphy-cfg", "grf";
power-domains = <&power RK3399_PD_VIO>;
#phy-cells = <0>;
u2phy0: usb2phy@e450 {
compatible = "rockchip,rk3399-usb2phy";
reg = <0xe450 0x10>;
clocks = <&cru SCLK_USB2PHY0_REF>;
clock-names = "phyclk";
#clock-cells = <0>;
clock-output-names = "clk_usbphy0_480m";
#phy-cells = <0>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "linestate";
u2phy0_otg: otg-port {
#phy-cells = <0>;
interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "otg-bvalid", "otg-id",
"linestate";
u2phy1: usb2phy@e460 {
reg = <0xe460 0x10>;
clocks = <&cru SCLK_USB2PHY1_REF>;
#clock-cells = <0>;
clock-output-names = "clk_usbphy1_480m";
u2phy1_host: host-port {
#phy-cells = <0>;
interrupts = <GIC_SPI 31 IRQ_TYPE_LEVEL_HIGH 0>;
#phy-cells = <0>;
interrupts = <GIC_SPI 108 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 109 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 111 IRQ_TYPE_LEVEL_HIGH 0>;
"linestate";
emmc_phy: phy@f780 {
compatible = "rockchip,rk3399-emmc-phy";
reg = <0xf780 0x24>;
clocks = <&sdhci>;
clock-names = "emmcclk";
drive-impedance-ohm = <50>;
#phy-cells = <0>;
pcie_phy: pcie-phy {
compatible = "rockchip,rk3399-pcie-phy";
clocks = <&cru SCLK_PCIEPHY_REF>;
clock-names = "refclk";
#phy-cells = <1>;
resets = <&cru SRST_PCIEPHY>;
reset-names = "phy";
- tcphy0: phy@ff7c0000 {
compatible = "rockchip,rk3399-typec-phy";
reg = <0x0 0xff7c0000 0x0 0x40000>;
clock-names = "tcpdcore", "tcpdphy-ref";
assigned-clocks = <&cru SCLK_UPHY0_TCPDCORE>;
assigned-clock-rates = <50000000>;
power-domains = <&power RK3399_PD_TCPD0>;
resets = <&cru SRST_UPHY0>,
<&cru SRST_UPHY0_PIPE_L00>,
<&cru SRST_P_UPHY0_TCPHY>;
reset-names = "uphy", "uphy-pipe", "uphy-tcphy";
tcphy0_dp: dp-port {
#phy-cells = <0>;
tcphy0_usb3: usb3-port {
#phy-cells = <0>;
- tcphy1: phy@ff800000 {
reg = <0x0 0xff800000 0x0 0x40000>;
assigned-clocks = <&cru SCLK_UPHY1_TCPDCORE>;
power-domains = <&power RK3399_PD_TCPD1>;
resets = <&cru SRST_UPHY1>,
<&cru SRST_UPHY1_PIPE_L00>,
<&cru SRST_P_UPHY1_TCPHY>;
tcphy1_dp: dp-port {
#phy-cells = <0>;
tcphy1_usb3: usb3-port {
#phy-cells = <0>;
- watchdog@ff848000 {
compatible = "rockchip,rk3399-wdt", "snps,dw-wdt";
reg = <0x0 0xff848000 0x0 0x100>;
clocks = <&cru PCLK_WDT>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH 0>;
- rktimer: rktimer@ff850000 {
compatible = "rockchip,rk3399-timer";
reg = <0x0 0xff850000 0x0 0x1000>;
interrupts = <GIC_SPI 81 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru PCLK_TIMER0>, <&cru SCLK_TIMER00>;
clock-names = "pclk", "timer";
- spdif: spdif@ff870000 {
compatible = "rockchip,rk3399-spdif";
reg = <0x0 0xff870000 0x0 0x1000>;
interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 7>;
dma-names = "tx";
clock-names = "mclk", "hclk";
clocks = <&cru SCLK_SPDIF_8CH>, <&cru HCLK_SPDIF>;
pinctrl-0 = <&spdif_bus>;
#sound-dai-cells = <0>;
- i2s0: i2s@ff880000 {
compatible = "rockchip,rk3399-i2s", "rockchip,rk3066-i2s";
reg = <0x0 0xff880000 0x0 0x1000>;
interrupts = <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 0>, <&dmac_bus 1>;
clock-names = "i2s_clk", "i2s_hclk";
clocks = <&cru SCLK_I2S0_8CH>, <&cru HCLK_I2S0_8CH>;
pinctrl-names = "bclk_on", "bclk_off";
pinctrl-0 = <&i2s0_8ch_bus>;
pinctrl-1 = <&i2s0_8ch_bus_bclk_off>;
- i2s1: i2s@ff890000 {
reg = <0x0 0xff890000 0x0 0x1000>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 2>, <&dmac_bus 3>;
clocks = <&cru SCLK_I2S1_8CH>, <&cru HCLK_I2S1_8CH>;
pinctrl-0 = <&i2s1_2ch_bus>;
- i2s2: i2s@ff8a0000 {
reg = <0x0 0xff8a0000 0x0 0x1000>;
interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH 0>;
dmas = <&dmac_bus 4>, <&dmac_bus 5>;
clocks = <&cru SCLK_I2S2_8CH>, <&cru HCLK_I2S2_8CH>;
- vopl: vop@ff8f0000 {
compatible = "rockchip,rk3399-vop-lit";
reg = <0x0 0xff8f0000 0x0 0x2000>, <0x0 0xff8f2000 0x0 0x400>;
interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH 0>;
assigned-clocks = <&cru ACLK_VOP1>, <&cru HCLK_VOP1>;
assigned-clock-rates = <400000000>, <100000000>;
clocks = <&cru ACLK_VOP1>, <&cru DCLK_VOP1>, <&cru HCLK_VOP1>;
clock-names = "aclk_vop", "dclk_vop", "hclk_vop";
iommus = <&vopl_mmu>;
power-domains = <&power RK3399_PD_VOPL>;
resets = <&cru SRST_A_VOP1>, <&cru SRST_H_VOP1>, <&cru SRST_D_VOP1>;
reset-names = "axi", "ahb", "dclk";
vopl_out: port {
#size-cells = <0>;
vopl_out_mipi: endpoint@0 {
reg = <0>;
remote-endpoint = <&mipi_in_vopl>;
vopl_out_edp: endpoint@1 {
reg = <1>;
remote-endpoint = <&edp_in_vopl>;
vopl_out_hdmi: endpoint@2 {
reg = <2>;
remote-endpoint = <&hdmi_in_vopl>;
vopl_out_mipi1: endpoint@3 {
reg = <3>;
remote-endpoint = <&mipi1_in_vopl>;
vopl_out_dp: endpoint@4 {
reg = <4>;
remote-endpoint = <&dp_in_vopl>;
- vopl_mmu: iommu@ff8f3f00 {
reg = <0x0 0xff8f3f00 0x0 0x100>;
#iommu-cells = <0>;
- vopb: vop@ff900000 {
compatible = "rockchip,rk3399-vop-big";
reg = <0x0 0xff900000 0x0 0x2000>, <0x0 0xff902000 0x0 0x1000>;
interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH 0>;
assigned-clocks = <&cru ACLK_VOP0>, <&cru HCLK_VOP0>;
clocks = <&cru ACLK_VOP0>, <&cru DCLK_VOP0>, <&cru HCLK_VOP0>;
iommus = <&vopb_mmu>;
power-domains = <&power RK3399_PD_VOPB>;
resets = <&cru SRST_A_VOP0>, <&cru SRST_H_VOP0>, <&cru SRST_D_VOP0>;
vopb_out: port {
#size-cells = <0>;
vopb_out_edp: endpoint@0 {
reg = <0>;
remote-endpoint = <&edp_in_vopb>;
vopb_out_mipi: endpoint@1 {
reg = <1>;
remote-endpoint = <&mipi_in_vopb>;
vopb_out_hdmi: endpoint@2 {
reg = <2>;
remote-endpoint = <&hdmi_in_vopb>;
vopb_out_mipi1: endpoint@3 {
reg = <3>;
remote-endpoint = <&mipi1_in_vopb>;
vopb_out_dp: endpoint@4 {
reg = <4>;
remote-endpoint = <&dp_in_vopb>;
- vopb_mmu: iommu@ff903f00 {
reg = <0x0 0xff903f00 0x0 0x100>;
#iommu-cells = <0>;
- isp0: isp0@ff910000 {
compatible = "rockchip,rk3399-cif-isp";
reg = <0x0 0xff910000 0x0 0x4000>;
interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_ISP0>,
<&cru ACLK_ISP0_WRAPPER>,
<&cru HCLK_ISP0_WRAPPER>;
clock-names = "isp", "aclk", "hclk";
iommus = <&isp0_mmu>;
phys = <&mipi_dphy_rx0>;
phy-names = "dphy";
power-domains = <&power RK3399_PD_ISP0>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
- isp0_mmu: iommu@ff914000 {
reg = <0x0 0xff914000 0x0 0x100>, <0x0 0xff915000 0x0 0x100>;
clocks = <&cru ACLK_ISP0_WRAPPER>, <&cru HCLK_ISP0_WRAPPER>;
#iommu-cells = <0>;
rockchip,disable-mmu-reset;
- isp1: isp1@ff920000 {
reg = <0x0 0xff920000 0x0 0x4000>;
interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_ISP1>,
<&cru ACLK_ISP1_WRAPPER>,
<&cru HCLK_ISP1_WRAPPER>;
iommus = <&isp1_mmu>;
phys = <&mipi_dsi1>;
phy-names = "dphy";
power-domains = <&power RK3399_PD_ISP1>;
ports {
#size-cells = <0>;
port@0 {
reg = <0>;
#size-cells = <0>;
- isp1_mmu: iommu@ff924000 {
reg = <0x0 0xff924000 0x0 0x100>, <0x0 0xff925000 0x0 0x100>;
clocks = <&cru ACLK_ISP1_WRAPPER>, <&cru HCLK_ISP1_WRAPPER>;
#iommu-cells = <0>;
- hdmi_sound: hdmi-sound {
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,name = "hdmi-sound";
simple-audio-card,cpu {
sound-dai = <&i2s2>;
simple-audio-card,codec {
sound-dai = <&hdmi>;
- hdmi: hdmi@ff940000 {
compatible = "rockchip,rk3399-dw-hdmi";
reg = <0x0 0xff940000 0x0 0x20000>;
interrupts = <GIC_SPI 23 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru PCLK_HDMI_CTRL>,
<&cru SCLK_HDMI_SFR>,
<&cru SCLK_HDMI_CEC>,
<&cru PCLK_VIO_GRF>,
<&cru PLL_VPLL>;
clock-names = "iahb", "isfr", "cec", "grf", "ref";
reg-io-width = <4>;
ports {
hdmi_in: port {
#size-cells = <0>;
hdmi_in_vopb: endpoint@0 {
reg = <0>;
remote-endpoint = <&vopb_out_hdmi>;
hdmi_in_vopl: endpoint@1 {
reg = <1>;
remote-endpoint = <&vopl_out_hdmi>;
- mipi_dsi: dsi@ff960000 {
compatible = "rockchip,rk3399-mipi-dsi", "snps,dw-mipi-dsi";
reg = <0x0 0xff960000 0x0 0x8000>;
interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_DPHY_PLL>, <&cru PCLK_MIPI_DSI0>,
<&cru SCLK_DPHY_TX0_CFG>, <&cru PCLK_VIO_GRF>;
clock-names = "ref", "pclk", "phy_cfg", "grf";
resets = <&cru SRST_P_MIPI_DSI0>;
reset-names = "apb";
#size-cells = <0>;
ports {
#size-cells = <0>;
mipi_in: port@0 {
reg = <0>;
#size-cells = <0>;
mipi_in_vopb: endpoint@0 {
reg = <0>;
remote-endpoint = <&vopb_out_mipi>;
mipi_in_vopl: endpoint@1 {
reg = <1>;
remote-endpoint = <&vopl_out_mipi>;
mipi_out: port@1 {
reg = <1>;
- mipi_dsi1: dsi@ff968000 {
reg = <0x0 0xff968000 0x0 0x8000>;
interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_DPHY_PLL>, <&cru PCLK_MIPI_DSI1>,
<&cru SCLK_DPHY_TX1RX1_CFG>, <&cru PCLK_VIO_GRF>;
resets = <&cru SRST_P_MIPI_DSI1>;
#size-cells = <0>;
#phy-cells = <0>;
ports {
#size-cells = <0>;
mipi1_in: port@0 {
reg = <0>;
#size-cells = <0>;
mipi1_in_vopb: endpoint@0 {
reg = <0>;
remote-endpoint = <&vopb_out_mipi1>;
mipi1_in_vopl: endpoint@1 {
reg = <1>;
remote-endpoint = <&vopl_out_mipi1>;
mipi1_out: port@1 {
reg = <1>;
- edp: dp@ff970000 {
compatible = "rockchip,rk3399-edp";
reg = <0x0 0xff970000 0x0 0x8000>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru PCLK_EDP>, <&cru PCLK_EDP_CTRL>, <&cru PCLK_VIO_GRF>;
clock-names = "dp", "pclk", "grf";
pinctrl-0 = <&edp_hpd>;
power-domains = <&power RK3399_PD_EDP>;
resets = <&cru SRST_P_EDP_CTRL>;
reset-names = "dp";
ports {
#size-cells = <0>;
edp_in: port@0 {
reg = <0>;
#size-cells = <0>;
edp_in_vopb: endpoint@0 {
reg = <0>;
remote-endpoint = <&vopb_out_edp>;
edp_in_vopl: endpoint@1 {
reg = <1>;
remote-endpoint = <&vopl_out_edp>;
edp_out: port@1 {
reg = <1>;
- gpu: gpu@ff9a0000 {
compatible = "rockchip,rk3399-mali", "arm,mali-t860";
reg = <0x0 0xff9a0000 0x0 0x10000>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH 0>,
<GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH 0>;
interrupt-names = "job", "mmu", "gpu";
dynamic-power-coefficient = <2640>;
power-domains = <&power RK3399_PD_GPU>;
- pinctrl: pinctrl {
compatible = "rockchip,rk3399-pinctrl";
#size-cells = <2>;
ranges;
gpio0: gpio@ff720000 {
compatible = "rockchip,gpio-bank";
reg = <0x0 0xff720000 0x0 0x100>;
clocks = <&pmucru PCLK_GPIO0_PMU>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller;
#gpio-cells = <0x2>;
#interrupt-cells = <0x2>;
gpio1: gpio@ff730000 {
reg = <0x0 0xff730000 0x0 0x100>;
clocks = <&pmucru PCLK_GPIO1_PMU>;
interrupts = <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller;
gpio2: gpio@ff780000 {
reg = <0x0 0xff780000 0x0 0x100>;
clocks = <&cru PCLK_GPIO2>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller;
gpio3: gpio@ff788000 {
reg = <0x0 0xff788000 0x0 0x100>;
clocks = <&cru PCLK_GPIO3>;
interrupts = <GIC_SPI 17 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller;
gpio4: gpio@ff790000 {
reg = <0x0 0xff790000 0x0 0x100>;
clocks = <&cru PCLK_GPIO4>;
interrupts = <GIC_SPI 18 IRQ_TYPE_LEVEL_HIGH 0>;
gpio-controller;
pcfg_pull_up: pcfg-pull-up {
bias-pull-up;
pcfg_pull_down: pcfg-pull-down {
bias-pull-down;
pcfg_pull_none: pcfg-pull-none {
bias-disable;
pcfg_pull_none_12ma: pcfg-pull-none-12ma {
bias-disable;
drive-strength = <12>;
pcfg_pull_none_13ma: pcfg-pull-none-13ma {
bias-disable;
drive-strength = <13>;
pcfg_pull_none_18ma: pcfg-pull-none-18ma {
bias-disable;
drive-strength = <18>;
pcfg_pull_none_20ma: pcfg-pull-none-20ma {
bias-disable;
drive-strength = <20>;
pcfg_pull_up_2ma: pcfg-pull-up-2ma {
bias-pull-up;
drive-strength = <2>;
pcfg_pull_up_8ma: pcfg-pull-up-8ma {
bias-pull-up;
drive-strength = <8>;
pcfg_pull_up_18ma: pcfg-pull-up-18ma {
bias-pull-up;
pcfg_pull_up_20ma: pcfg-pull-up-20ma {
bias-pull-up;
pcfg_pull_down_4ma: pcfg-pull-down-4ma {
bias-pull-down;
drive-strength = <4>;
pcfg_pull_down_8ma: pcfg-pull-down-8ma {
bias-pull-down;
pcfg_pull_down_12ma: pcfg-pull-down-12ma {
bias-pull-down;
pcfg_pull_down_18ma: pcfg-pull-down-18ma {
bias-pull-down;
pcfg_pull_down_20ma: pcfg-pull-down-20ma {
bias-pull-down;
pcfg_output_high: pcfg-output-high {
output-high;
pcfg_output_low: pcfg-output-low {
output-low;
pcfg_input_enable: pcfg-input-enable {
input-enable;
pcfg_input_pull_up: pcfg-input-pull-up {
input-enable;
bias-pull-up;
pcfg_input_pull_down: pcfg-input-pull-down {
input-enable;
bias-pull-down;
clock {
clk_32k: clk-32k {
rockchip,pins = <0 RK_PA0 2 &pcfg_pull_none>;
cif {
cif_clkin: cif-clkin {
rockchip,pins =
<2 RK_PB2 3 &pcfg_pull_none>;
cif_clkouta: cif-clkouta {
rockchip,pins =
<2 RK_PB3 3 &pcfg_pull_none>;
edp {
edp_hpd: edp-hpd {
rockchip,pins =
<4 RK_PC7 2 &pcfg_pull_none>;
gmac {
rgmii_pins: rgmii-pins {
rockchip,pins =
/* mac_txclk */
<3 RK_PC1 1 &pcfg_pull_none_13ma>,
/* mac_rxclk */
<3 RK_PB6 1 &pcfg_pull_none>,
/* mac_mdio */
<3 RK_PB5 1 &pcfg_pull_none>,
/* mac_txen */
<3 RK_PB4 1 &pcfg_pull_none_13ma>,
/* mac_clk */
<3 RK_PB3 1 &pcfg_pull_none>,
/* mac_rxdv */
<3 RK_PB1 1 &pcfg_pull_none>,
/* mac_mdc */
<3 RK_PB0 1 &pcfg_pull_none>,
/* mac_rxd1 */
<3 RK_PA7 1 &pcfg_pull_none>,
/* mac_rxd0 */
<3 RK_PA6 1 &pcfg_pull_none>,
/* mac_txd1 */
<3 RK_PA5 1 &pcfg_pull_none_13ma>,
/* mac_txd0 */
<3 RK_PA4 1 &pcfg_pull_none_13ma>,
/* mac_rxd3 */
<3 RK_PA3 1 &pcfg_pull_none>,
/* mac_rxd2 */
<3 RK_PA2 1 &pcfg_pull_none>,
/* mac_txd3 */
<3 RK_PA1 1 &pcfg_pull_none_13ma>,
/* mac_txd2 */
<3 RK_PA0 1 &pcfg_pull_none_13ma>;
rmii_pins: rmii-pins {
rockchip,pins =
/* mac_mdio */
/* mac_txen */
/* mac_clk */
/* mac_rxer */
<3 RK_PB2 1 &pcfg_pull_none>,
/* mac_rxdv */
/* mac_mdc */
/* mac_rxd1 */
/* mac_rxd0 */
/* mac_txd1 */
/* mac_txd0 */
<3 RK_PA4 1 &pcfg_pull_none_13ma>;
i2c0 {
i2c0_xfer: i2c0-xfer {
rockchip,pins =
<1 RK_PB7 2 &pcfg_pull_none>,
<1 RK_PC0 2 &pcfg_pull_none>;
i2c1 {
i2c1_xfer: i2c1-xfer {
rockchip,pins =
<4 RK_PA2 1 &pcfg_pull_none>,
<4 RK_PA1 1 &pcfg_pull_none>;
i2c2 {
i2c2_xfer: i2c2-xfer {
rockchip,pins =
<2 RK_PA1 2 &pcfg_pull_none_12ma>,
<2 RK_PA0 2 &pcfg_pull_none_12ma>;
i2c3 {
i2c3_xfer: i2c3-xfer {
rockchip,pins =
<4 RK_PC1 1 &pcfg_pull_none>,
<4 RK_PC0 1 &pcfg_pull_none>;
i2c4 {
i2c4_xfer: i2c4-xfer {
rockchip,pins =
<1 RK_PB4 1 &pcfg_pull_none>,
<1 RK_PB3 1 &pcfg_pull_none>;
i2c5 {
i2c5_xfer: i2c5-xfer {
rockchip,pins =
<3 RK_PB3 2 &pcfg_pull_none>,
<3 RK_PB2 2 &pcfg_pull_none>;
i2c6 {
i2c6_xfer: i2c6-xfer {
rockchip,pins =
<2 RK_PB2 2 &pcfg_pull_none>,
<2 RK_PB1 2 &pcfg_pull_none>;
i2c7 {
i2c7_xfer: i2c7-xfer {
rockchip,pins =
<2 RK_PB0 2 &pcfg_pull_none>,
<2 RK_PA7 2 &pcfg_pull_none>;
i2c8 {
i2c8_xfer: i2c8-xfer {
rockchip,pins =
<1 RK_PC5 1 &pcfg_pull_none>,
<1 RK_PC4 1 &pcfg_pull_none>;
i2s0 {
i2s0_2ch_bus: i2s0-2ch-bus {
rockchip,pins =
<3 RK_PD0 1 &pcfg_pull_none>,
<3 RK_PD1 1 &pcfg_pull_none>,
<3 RK_PD2 1 &pcfg_pull_none>,
<3 RK_PD3 1 &pcfg_pull_none>,
<3 RK_PD7 1 &pcfg_pull_none>,
<4 RK_PA0 1 &pcfg_pull_none>;
i2s0_2ch_bus_bclk_off: i2s0-2ch-bus-bclk-off {
rockchip,pins =
<3 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>,
i2s0_8ch_bus: i2s0-8ch-bus {
rockchip,pins =
<3 RK_PD4 1 &pcfg_pull_none>,
<3 RK_PD5 1 &pcfg_pull_none>,
<3 RK_PD6 1 &pcfg_pull_none>,
i2s0_8ch_bus_bclk_off: i2s0-8ch-bus-bclk-off {
rockchip,pins =
i2s1 {
i2s1_2ch_bus: i2s1-2ch-bus {
rockchip,pins =
<4 RK_PA3 1 &pcfg_pull_none>,
<4 RK_PA4 1 &pcfg_pull_none>,
<4 RK_PA5 1 &pcfg_pull_none>,
<4 RK_PA6 1 &pcfg_pull_none>,
<4 RK_PA7 1 &pcfg_pull_none>;
i2s1_2ch_bus_bclk_off: i2s1-2ch-bus-bclk-off {
rockchip,pins =
<4 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>,
sdio0 {
sdio0_bus1: sdio0-bus1 {
rockchip,pins =
<2 RK_PC4 1 &pcfg_pull_up>;
sdio0_bus4: sdio0-bus4 {
rockchip,pins =
<2 RK_PC4 1 &pcfg_pull_up>,
<2 RK_PC5 1 &pcfg_pull_up>,
<2 RK_PC6 1 &pcfg_pull_up>,
<2 RK_PC7 1 &pcfg_pull_up>;
sdio0_cmd: sdio0-cmd {
rockchip,pins =
<2 RK_PD0 1 &pcfg_pull_up>;
sdio0_clk: sdio0-clk {
rockchip,pins =
<2 RK_PD1 1 &pcfg_pull_none>;
sdio0_cd: sdio0-cd {
rockchip,pins =
<2 RK_PD2 1 &pcfg_pull_up>;
sdio0_pwr: sdio0-pwr {
rockchip,pins =
<2 RK_PD3 1 &pcfg_pull_up>;
sdio0_bkpwr: sdio0-bkpwr {
rockchip,pins =
<2 RK_PD4 1 &pcfg_pull_up>;
sdio0_wp: sdio0-wp {
rockchip,pins =
<0 RK_PA3 1 &pcfg_pull_up>;
sdio0_int: sdio0-int {
rockchip,pins =
<0 RK_PA4 1 &pcfg_pull_up>;
sdmmc {
rockchip,pins =
<4 RK_PB0 1 &pcfg_pull_up>;
sdmmc_bus4: sdmmc-bus4 {
rockchip,pins =
<4 RK_PB0 1 &pcfg_pull_up>,
<4 RK_PB1 1 &pcfg_pull_up>,
<4 RK_PB2 1 &pcfg_pull_up>,
<4 RK_PB3 1 &pcfg_pull_up>;
sdmmc_clk: sdmmc-clk {
rockchip,pins =
<4 RK_PB4 1 &pcfg_pull_none>;
sdmmc_cmd: sdmmc-cmd {
rockchip,pins =
<4 RK_PB5 1 &pcfg_pull_up>;
sdmmc_cd: sdmmc-cd {
rockchip,pins =
<0 RK_PA7 1 &pcfg_pull_up>;
sdmmc_wp: sdmmc-wp {
rockchip,pins =
<0 RK_PB0 1 &pcfg_pull_up>;
suspend {
ap_pwroff: ap-pwroff {
rockchip,pins = <1 RK_PA5 1 &pcfg_pull_none>;
ddrio_pwroff: ddrio-pwroff {
rockchip,pins = <0 RK_PA1 1 &pcfg_pull_none>;
spdif {
spdif_bus: spdif-bus {
rockchip,pins =
<4 RK_PC5 1 &pcfg_pull_none>;
spdif_bus_1: spdif-bus-1 {
rockchip,pins =
<3 RK_PC0 3 &pcfg_pull_none>;
spi0 {
spi0_clk: spi0-clk {
rockchip,pins =
<3 RK_PA6 2 &pcfg_pull_up>;
spi0_cs0: spi0-cs0 {
rockchip,pins =
<3 RK_PA7 2 &pcfg_pull_up>;
spi0_cs1: spi0-cs1 {
rockchip,pins =
<3 RK_PB0 2 &pcfg_pull_up>;
spi0_tx: spi0-tx {
rockchip,pins =
<3 RK_PA5 2 &pcfg_pull_up>;
spi0_rx: spi0-rx {
rockchip,pins =
<3 RK_PA4 2 &pcfg_pull_up>;
spi1 {
spi1_clk: spi1-clk {
rockchip,pins =
<1 RK_PB1 2 &pcfg_pull_up>;
spi1_cs0: spi1-cs0 {
rockchip,pins =
<1 RK_PB2 2 &pcfg_pull_up>;
spi1_rx: spi1-rx {
rockchip,pins =
<1 RK_PA7 2 &pcfg_pull_up>;
spi1_tx: spi1-tx {
rockchip,pins =
<1 RK_PB0 2 &pcfg_pull_up>;
spi2 {
spi2_clk: spi2-clk {
rockchip,pins =
<2 RK_PB3 1 &pcfg_pull_up>;
spi2_cs0: spi2-cs0 {
rockchip,pins =
<2 RK_PB4 1 &pcfg_pull_up>;
spi2_rx: spi2-rx {
rockchip,pins =
<2 RK_PB1 1 &pcfg_pull_up>;
spi2_tx: spi2-tx {
rockchip,pins =
<2 RK_PB2 1 &pcfg_pull_up>;
spi3 {
spi3_clk: spi3-clk {
rockchip,pins =
<1 RK_PC1 1 &pcfg_pull_up>;
spi3_cs0: spi3-cs0 {
rockchip,pins =
<1 RK_PC2 1 &pcfg_pull_up>;
spi3_rx: spi3-rx {
rockchip,pins =
<1 RK_PB7 1 &pcfg_pull_up>;
spi3_tx: spi3-tx {
rockchip,pins =
<1 RK_PC0 1 &pcfg_pull_up>;
spi4 {
spi4_clk: spi4-clk {
rockchip,pins =
<3 RK_PA2 2 &pcfg_pull_up>;
spi4_cs0: spi4-cs0 {
rockchip,pins =
<3 RK_PA3 2 &pcfg_pull_up>;
spi4_rx: spi4-rx {
rockchip,pins =
<3 RK_PA0 2 &pcfg_pull_up>;
spi4_tx: spi4-tx {
rockchip,pins =
<3 RK_PA1 2 &pcfg_pull_up>;
spi5 {
spi5_clk: spi5-clk {
rockchip,pins =
<2 RK_PC6 2 &pcfg_pull_up>;
spi5_cs0: spi5-cs0 {
rockchip,pins =
<2 RK_PC7 2 &pcfg_pull_up>;
spi5_rx: spi5-rx {
rockchip,pins =
<2 RK_PC4 2 &pcfg_pull_up>;
spi5_tx: spi5-tx {
rockchip,pins =
<2 RK_PC5 2 &pcfg_pull_up>;
testclk {
test_clkout0: test-clkout0 {
rockchip,pins =
<0 RK_PA0 1 &pcfg_pull_none>;
test_clkout1: test-clkout1 {
rockchip,pins =
<2 RK_PD1 2 &pcfg_pull_none>;
test_clkout2: test-clkout2 {
rockchip,pins =
<0 RK_PB0 3 &pcfg_pull_none>;
tsadc {
otp_pin: otp-pin {
rockchip,pins = <1 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
otp_out: otp-out {
rockchip,pins = <1 RK_PA6 1 &pcfg_pull_none>;
uart0 {
uart0_xfer: uart0-xfer {
rockchip,pins =
<2 RK_PC0 1 &pcfg_pull_up>,
<2 RK_PC1 1 &pcfg_pull_none>;
uart0_cts: uart0-cts {
rockchip,pins =
<2 RK_PC2 1 &pcfg_pull_none>;
uart0_rts: uart0-rts {
rockchip,pins =
<2 RK_PC3 1 &pcfg_pull_none>;
uart1 {
uart1_xfer: uart1-xfer {
rockchip,pins =
<3 RK_PB4 2 &pcfg_pull_up>,
<3 RK_PB5 2 &pcfg_pull_none>;
uart2a {
uart2a_xfer: uart2a-xfer {
rockchip,pins =
<4 RK_PB0 2 &pcfg_pull_up>,
<4 RK_PB1 2 &pcfg_pull_none>;
uart2b {
uart2b_xfer: uart2b-xfer {
rockchip,pins =
<4 RK_PC0 2 &pcfg_pull_up>,
<4 RK_PC1 2 &pcfg_pull_none>;
uart2c {
uart2c_xfer: uart2c-xfer {
rockchip,pins =
<4 RK_PC3 1 &pcfg_pull_up>,
<4 RK_PC4 1 &pcfg_pull_none>;
uart3 {
uart3_xfer: uart3-xfer {
rockchip,pins =
<3 RK_PB6 2 &pcfg_pull_up>,
<3 RK_PB7 2 &pcfg_pull_none>;
uart3_cts: uart3-cts {
rockchip,pins =
<3 RK_PC0 2 &pcfg_pull_none>;
uart3_rts: uart3-rts {
rockchip,pins =
<3 RK_PC1 2 &pcfg_pull_none>;
uart4 {
uart4_xfer: uart4-xfer {
rockchip,pins =
<1 RK_PA7 1 &pcfg_pull_up>,
<1 RK_PB0 1 &pcfg_pull_none>;
uarthdcp {
uarthdcp_xfer: uarthdcp-xfer {
rockchip,pins =
<4 RK_PC5 2 &pcfg_pull_up>,
<4 RK_PC6 2 &pcfg_pull_none>;
pwm0 {
pwm0_pin: pwm0-pin {
rockchip,pins =
<4 RK_PC2 1 &pcfg_pull_none>;
pwm0_pin_pull_down: pwm0-pin-pull-down {
rockchip,pins =
<4 RK_PC2 1 &pcfg_pull_down>;
vop0_pwm_pin: vop0-pwm-pin {
rockchip,pins =
<4 RK_PC2 2 &pcfg_pull_none>;
vop1_pwm_pin: vop1-pwm-pin {
rockchip,pins =
<4 RK_PC2 3 &pcfg_pull_none>;
pwm1 {
pwm1_pin: pwm1-pin {
rockchip,pins =
<4 RK_PC6 1 &pcfg_pull_none>;
pwm1_pin_pull_down: pwm1-pin-pull-down {
rockchip,pins =
<4 RK_PC6 1 &pcfg_pull_down>;
pwm2 {
pwm2_pin: pwm2-pin {
rockchip,pins =
<1 RK_PC3 1 &pcfg_pull_none>;
pwm2_pin_pull_down: pwm2-pin-pull-down {
rockchip,pins =
<1 RK_PC3 1 &pcfg_pull_down>;
pwm3a {
pwm3a_pin: pwm3a-pin {
rockchip,pins =
<0 RK_PA6 1 &pcfg_pull_none>;
pwm3b {
pwm3b_pin: pwm3b-pin {
rockchip,pins =
<1 RK_PB6 1 &pcfg_pull_none>;
hdmi {
hdmi_i2c_xfer: hdmi-i2c-xfer {
rockchip,pins =
<4 RK_PC1 3 &pcfg_pull_none>,
<4 RK_PC0 3 &pcfg_pull_none>;
hdmi_cec: hdmi-cec {
rockchip,pins =
<4 RK_PC7 1 &pcfg_pull_none>;
pcie {
pcie_clkreqn_cpm: pci-clkreqn-cpm {
rockchip,pins =
<2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_clkreqnb_cpm: pci-clkreqnb-cpm {
rockchip,pins =
<4 RK_PD0 RK_FUNC_GPIO &pcfg_pull_none>;
-}; diff --git a/arch/arm/dts/rk3399pro-rock-pi-n10.dts b/arch/arm/dts/rk3399pro-rock-pi-n10.dts deleted file mode 100644 index bf026786fa92..000000000000 --- a/arch/arm/dts/rk3399pro-rock-pi-n10.dts +++ /dev/null @@ -1,22 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd
- Copyright (c) 2019 Radxa Limited
- Copyright (c) 2019 Amarula Solutions(India)
-/dts-v1/; -#include "rk3399.dtsi" -#include "rk3399-opp.dtsi" -#include <rockchip-radxa-dalang-carrier.dtsi> -#include "rk3399pro-vmarc-som.dtsi"
- model = "Radxa ROCK Pi N10";
- compatible = "radxa,rockpi-n10", "vamrs,rk3399pro-vmarc-som",
"rockchip,rk3399pro";
- chosen {
stdout-path = "serial2:1500000n8";
-}; diff --git a/arch/arm/dts/rk3399pro-vmarc-som.dtsi b/arch/arm/dts/rk3399pro-vmarc-som.dtsi deleted file mode 100644 index 8823c924dc1d..000000000000 --- a/arch/arm/dts/rk3399pro-vmarc-som.dtsi +++ /dev/null @@ -1,477 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2019 Vamrs Limited
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/pwm/pwm.h>
- compatible = "vamrs,rk3399pro-vmarc-som", "rockchip,rk3399pro";
- aliases {
ethernet0 = &gmac;
mmc0 = &sdhci;
mmc1 = &sdmmc;
- vcc3v3_pcie: vcc-pcie-regulator {
compatible = "regulator-fixed";
enable-active-high;
gpio = <&gpio4 RK_PD4 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie_pwr>;
regulator-name = "vcc3v3_pcie";
regulator-always-on;
regulator-boot-on;
vin-supply = <&vcc5v0_sys>;
-&cpu_l0 {
- cpu-supply = <&vdd_cpu_l>;
-&cpu_l1 {
-&cpu_l2 {
-&cpu_l3 {
-&emmc_phy {
- status = "okay";
-&gmac {
- assigned-clocks = <&cru SCLK_RMII_SRC>;
- phy-supply = <&vcc_lan>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
-&hdmi {
- ddc-i2c-bus = <&i2c3>;
- pinctrl-names = "default";
- pinctrl-0 = <&hdmi_cec>;
-&i2c0 {
- clock-frequency = <400000>;
- i2c-scl-falling-time-ns = <30>;
- i2c-scl-rising-time-ns = <180>;
- status = "okay";
- rk809: pmic@20 {
compatible = "rockchip,rk809";
reg = <0x20>;
interrupt-parent = <&gpio1>;
interrupts = <RK_PC2 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
clock-output-names = "rk808-clkout1", "rk808-clkout2";
pinctrl-0 = <&pmic_int_l>;
rockchip,system-power-controller;
wakeup-source;
vcc1-supply = <&vcc5v0_sys>;
vcc2-supply = <&vcc5v0_sys>;
vcc3-supply = <&vcc5v0_sys>;
vcc4-supply = <&vcc5v0_sys>;
vcc5-supply = <&vcc_buck5>;
vcc6-supply = <&vcc_buck5>;
vcc7-supply = <&vcc5v0_sys>;
vcc8-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc5v0_sys>;
regulators {
vdd_log: DCDC_REG1 {
regulator-name = "vdd_log";
regulator-boot-on;
regulator-min-microvolt = <750000>;
regulator-max-microvolt = <1350000>;
regulator-initial-mode = <0x2>;
regulator-state-mem {
regulator-off-in-suspend;
regulator-suspend-microvolt = <900000>;
vdd_cpu_l: DCDC_REG2 {
regulator-name = "vdd_cpu_l";
regulator-boot-on;
regulator-ramp-delay = <6001>;
vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr";
regulator-boot-on;
regulator-on-in-suspend;
vcc3v3_sys: DCDC_REG4 {
regulator-name = "vcc3v3_sys";
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-suspend-microvolt = <3300000>;
vcc_buck5: DCDC_REG5 {
regulator-name = "vcc_buck5";
regulator-boot-on;
regulator-min-microvolt = <2200000>;
regulator-max-microvolt = <2200000>;
regulator-suspend-microvolt = <2200000>;
vcca_0v9: LDO_REG1 {
regulator-name = "vcca_0v9";
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
vcc_1v8: LDO_REG2 {
regulator-name = "vcc_1v8";
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-suspend-microvolt = <1800000>;
vcc_0v9: LDO_REG3 {
regulator-name = "vcc_0v9";
regulator-boot-on;
vcca_1v8: LDO_REG4 {
regulator-name = "vcca_1v8";
regulator-boot-on;
regulator-min-microvolt = <1850000>;
regulator-max-microvolt = <1850000>;
regulator-suspend-microvolt = <1850000>;
* As per BSP, but schematic not showing any regulator
* pin for LD05.
vdd1v5_dvp: LDO_REG5 {
regulator-name = "vdd1v5_dvp";
regulator-boot-on;
regulator-min-microvolt = <1500000>;
regulator-max-microvolt = <1500000>;
vcc_1v5: LDO_REG6 {
regulator-name = "vcc_1v5";
regulator-boot-on;
vccio_3v0: LDO_REG7 {
regulator-name = "vccio_3v0";
regulator-boot-on;
regulator-min-microvolt = <3000000>;
regulator-max-microvolt = <3000000>;
vccio_sd: LDO_REG8 {
regulator-name = "vccio_sd";
regulator-boot-on;
* pin for LD09.
vcc_sd: LDO_REG9 {
regulator-name = "vcc_sd";
regulator-boot-on;
vcc5v0_usb2: SWITCH_REG1 {
regulator-name = "vcc5v0_usb2";
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
regulator-suspend-microvolt = <5000000>;
vccio_3v3: vcc_lan: SWITCH_REG2 {
regulator-name = "vccio_3v3";
regulator-boot-on;
-&i2c1 {
- i2c-scl-rising-time-ns = <140>;
- status = "okay";
-&i2c2 {
- status = "okay";
- hym8563: rtc@51 {
compatible = "haoyu,hym8563";
reg = <0x51>;
#clock-cells = <0>;
clock-output-names = "hym8563";
pinctrl-0 = <&hym8563_int>;
interrupts = <RK_PD6 IRQ_TYPE_LEVEL_LOW>;
-&i2c3 {
- i2c-scl-rising-time-ns = <450>;
- i2c-scl-falling-time-ns = <15>;
- status = "okay";
-&io_domains {
- status = "okay";
- bt656-supply = <&vcca_1v8>;
- gpio1830-supply = <&vccio_3v0>;
- sdmmc-supply = <&vccio_sd>;
-&pcie_phy {
- status = "okay";
-&pcie0 {
- ep-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>;
- num-lanes = <4>;
- pinctrl-0 = <&pcie_clkreqnb_cpm>;
- vpcie0v9-supply = <&vcca_0v9>; /* VCC_0V9_S0 */
- vpcie1v8-supply = <&vcca_1v8>; /* VCC_1V8_S0 */
- vpcie3v3-supply = <&vcc3v3_pcie>;
- status = "okay";
-&pinctrl {
- hym8563 {
hym8563_int: hym8563-int {
rockchip,pins = <4 RK_PD6 0 &pcfg_pull_up>;
- pcie {
pcie_pwr: pcie-pwr {
rockchip,pins = <4 RK_PD4 RK_FUNC_GPIO &pcfg_pull_up>;
- pmic {
pmic_int_l: pmic-int-l {
rockchip,pins = <1 RK_PC2 0 &pcfg_pull_up>;
- sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
rockchip,pins = <2 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
- vbus_host {
usb1_en_oc: usb1-en-oc {
rockchip,pins = <4 RK_PD1 RK_FUNC_GPIO &pcfg_pull_up>;
- vbus_typec {
usb0_en_oc: usb0-en-oc {
rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>;
-&pmu_io_domains {
- status = "okay";
- pmu1830-supply = <&vcc_1v8>;
-&sdio_pwrseq {
* On the module itself this is one of these (depending
* on the actual card populated):
* - SDIO_RESET_L_WL_REG_ON
* - PDN (power down when low)
- reset-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>;
-&sdhci {
- bus-width = <8>;
- mmc-hs400-1_8v;
- mmc-hs400-enhanced-strobe;
- non-removable;
- status = "okay";
-&sdmmc {
- cd-gpios = <&gpio0 RK_PA7 GPIO_ACTIVE_LOW>;
- max-frequency = <150000000>;
-&tcphy0 {
- status = "okay";
-&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <1>;
- status = "okay";
-&u2phy0 {
- status = "okay";
- u2phy0_otg: otg-port {
phy-supply = <&vbus_typec>;
status = "okay";
- u2phy0_host: host-port {
phy-supply = <&vbus_host>;
status = "okay";
-&u2phy1 {
- status = "okay";
- u2phy1_host: host-port {
status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usbdrd3_0 {
- status = "okay";
-&usbdrd_dwc3_0 {
- status = "okay";
-&vbus_host {
- enable-active-high;
- gpio = <&gpio4 RK_PD1 GPIO_ACTIVE_HIGH>; /* USB1_EN_OC# */
- pinctrl-0 = <&usb1_en_oc>;
-&vbus_typec {
- gpio = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; /* USB0_EN_OC# */
- pinctrl-0 = <&usb0_en_oc>;
-}; diff --git a/arch/arm/dts/rk3399pro.dtsi b/arch/arm/dts/rk3399pro.dtsi deleted file mode 100644 index bb5ebf6608b9..000000000000 --- a/arch/arm/dts/rk3399pro.dtsi +++ /dev/null @@ -1,22 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -// Copyright (c) 2019 Fuzhou Rockchip Electronics Co., Ltd.
- compatible = "rockchip,rk3399pro";
-/* Default to enabled since AP talk to NPU part over pcie */ -&pcie_phy {
- status = "okay";
-/* Default to enabled since AP talk to NPU part over pcie */ -&pcie0 {
- num-lanes = <4>;
- pinctrl-0 = <&pcie_clkreqn_cpm>;
- status = "okay";
-}; diff --git a/doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt b/doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt deleted file mode 100644 index 4a56f78f555b..000000000000 --- a/doc/device-tree-bindings/clock/rockchip,rk3399-dmc.txt +++ /dev/null @@ -1,42 +0,0 @@ -Rockchip Dynamic Memory Controller Driver -Required properties: -- compatible: "rockchip,rk3399-dmc", "syscon" -- rockchip,cru: this driver should access cru regs, so need get cru here -- rockchip,pmucru: this driver should access pmucru regs, so need get pmucru here -- rockchip,pmugrf: this driver should access pmugrf regs, so need get pmugrf here -- rockchip,pmusgrf: this driver should access pmusgrf regs, so need get pmusgrf here -- rockchip,cic: this driver should access cic regs, so need get cic here -- reg: dynamic ram protocol controller(PCTL) address, PHY Independent(PI) address, phy controller(PHYCTL) address and memory schedule(MSCH) address -- clock: must include clock specifiers corresponding to entries in the clock-names property.
- Must contain
dmc_clk: for ddr working frequency
-- rockchip,sdram-params: SDRAM parameters, including all the information by ddr driver:
- Must contain
Genarate by vendor tool and adjust for U-Boot dtsi.
-Example:
- dmc: dmc {
bootph-all;
interrupts = <GIC_SPI 1 IRQ_TYPE_LEVEL_HIGH 0>;
clocks = <&cru SCLK_DDRCLK>;
reg = <0x0 0xffa80000 0x0 0x0800
0x0 0xffa80800 0x0 0x1800
0x0 0xffa82000 0x0 0x2000
0x0 0xffa84000 0x0 0x1000
0x0 0xffa88000 0x0 0x0800
0x0 0xffa88800 0x0 0x1800
0x0 0xffa8a000 0x0 0x2000
0x0 0xffa8c000 0x0 0x1000>;
- &dmc {
rockchip,sdram-params = <
0x2
0xa
0x3
diff --git a/include/dt-bindings/clock/rk3399-cru.h b/include/dt-bindings/clock/rk3399-cru.h deleted file mode 100644 index 39169d94a44e..000000000000 --- a/include/dt-bindings/clock/rk3399-cru.h +++ /dev/null @@ -1,751 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-or-later */ -/*
- Copyright (c) 2016 Rockchip Electronics Co. Ltd.
- Author: Xing Zheng zhengxing@rock-chips.com
-#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3399_H
-/* core clocks */ -#define PLL_APLLL 1 -#define PLL_APLLB 2 -#define PLL_DPLL 3 -#define PLL_CPLL 4 -#define PLL_GPLL 5 -#define PLL_NPLL 6 -#define PLL_VPLL 7 -#define ARMCLKL 8 -#define ARMCLKB 9
-/* sclk gates (special clocks) */ -#define SCLK_I2C1 65 -#define SCLK_I2C2 66 -#define SCLK_I2C3 67 -#define SCLK_I2C5 68 -#define SCLK_I2C6 69 -#define SCLK_I2C7 70 -#define SCLK_SPI0 71 -#define SCLK_SPI1 72 -#define SCLK_SPI2 73 -#define SCLK_SPI4 74 -#define SCLK_SPI5 75 -#define SCLK_SDMMC 76 -#define SCLK_SDIO 77 -#define SCLK_EMMC 78 -#define SCLK_TSADC 79 -#define SCLK_SARADC 80 -#define SCLK_UART0 81 -#define SCLK_UART1 82 -#define SCLK_UART2 83 -#define SCLK_UART3 84 -#define SCLK_SPDIF_8CH 85 -#define SCLK_I2S0_8CH 86 -#define SCLK_I2S1_8CH 87 -#define SCLK_I2S2_8CH 88 -#define SCLK_I2S_8CH_OUT 89 -#define SCLK_TIMER00 90 -#define SCLK_TIMER01 91 -#define SCLK_TIMER02 92 -#define SCLK_TIMER03 93 -#define SCLK_TIMER04 94 -#define SCLK_TIMER05 95 -#define SCLK_TIMER06 96 -#define SCLK_TIMER07 97 -#define SCLK_TIMER08 98 -#define SCLK_TIMER09 99 -#define SCLK_TIMER10 100 -#define SCLK_TIMER11 101 -#define SCLK_MACREF 102 -#define SCLK_MAC_RX 103 -#define SCLK_MAC_TX 104 -#define SCLK_MAC 105 -#define SCLK_MACREF_OUT 106 -#define SCLK_VOP0_PWM 107 -#define SCLK_VOP1_PWM 108 -#define SCLK_RGA_CORE 109 -#define SCLK_ISP0 110 -#define SCLK_ISP1 111 -#define SCLK_HDMI_CEC 112 -#define SCLK_HDMI_SFR 113 -#define SCLK_DP_CORE 114 -#define SCLK_PVTM_CORE_L 115 -#define SCLK_PVTM_CORE_B 116 -#define SCLK_PVTM_GPU 117 -#define SCLK_PVTM_DDR 118 -#define SCLK_MIPIDPHY_REF 119 -#define SCLK_MIPIDPHY_CFG 120 -#define SCLK_HSICPHY 121 -#define SCLK_USBPHY480M 122 -#define SCLK_USB2PHY0_REF 123 -#define SCLK_USB2PHY1_REF 124 -#define SCLK_UPHY0_TCPDPHY_REF 125 -#define SCLK_UPHY0_TCPDCORE 126 -#define SCLK_UPHY1_TCPDPHY_REF 127 -#define SCLK_UPHY1_TCPDCORE 128 -#define SCLK_USB3OTG0_REF 129 -#define SCLK_USB3OTG1_REF 130 -#define SCLK_USB3OTG0_SUSPEND 131 -#define SCLK_USB3OTG1_SUSPEND 132 -#define SCLK_CRYPTO0 133 -#define SCLK_CRYPTO1 134 -#define SCLK_CCI_TRACE 135 -#define SCLK_CS 136 -#define SCLK_CIF_OUT 137 -#define SCLK_PCIEPHY_REF 138 -#define SCLK_PCIE_CORE 139 -#define SCLK_M0_PERILP 140 -#define SCLK_M0_PERILP_DEC 141 -#define SCLK_CM0S 142 -#define SCLK_DBG_NOC 143 -#define SCLK_DBG_PD_CORE_B 144 -#define SCLK_DBG_PD_CORE_L 145 -#define SCLK_DFIMON0_TIMER 146 -#define SCLK_DFIMON1_TIMER 147 -#define SCLK_INTMEM0 148 -#define SCLK_INTMEM1 149 -#define SCLK_INTMEM2 150 -#define SCLK_INTMEM3 151 -#define SCLK_INTMEM4 152 -#define SCLK_INTMEM5 153 -#define SCLK_SDMMC_DRV 154 -#define SCLK_SDMMC_SAMPLE 155 -#define SCLK_SDIO_DRV 156 -#define SCLK_SDIO_SAMPLE 157 -#define SCLK_VDU_CORE 158 -#define SCLK_VDU_CA 159 -#define SCLK_PCIE_PM 160 -#define SCLK_SPDIF_REC_DPTX 161 -#define SCLK_DPHY_PLL 162 -#define SCLK_DPHY_TX0_CFG 163 -#define SCLK_DPHY_TX1RX1_CFG 164 -#define SCLK_DPHY_RX0_CFG 165 -#define SCLK_RMII_SRC 166 -#define SCLK_PCIEPHY_REF100M 167 -#define SCLK_DDRC 168 -#define SCLK_TESTCLKOUT1 169 -#define SCLK_TESTCLKOUT2 170
-#define DCLK_VOP0 180 -#define DCLK_VOP1 181 -#define DCLK_VOP0_DIV 182 -#define DCLK_VOP1_DIV 183 -#define DCLK_M0_PERILP 184 -#define DCLK_VOP0_FRAC 185 -#define DCLK_VOP1_FRAC 186
-#define FCLK_CM0S 190
-/* aclk gates */ -#define ACLK_PERIHP 192 -#define ACLK_PERIHP_NOC 193 -#define ACLK_PERILP0 194 -#define ACLK_PERILP0_NOC 195 -#define ACLK_PERF_PCIE 196 -#define ACLK_PCIE 197 -#define ACLK_INTMEM 198 -#define ACLK_TZMA 199 -#define ACLK_DCF 200 -#define ACLK_CCI 201 -#define ACLK_CCI_NOC0 202 -#define ACLK_CCI_NOC1 203 -#define ACLK_CCI_GRF 204 -#define ACLK_CENTER 205 -#define ACLK_CENTER_MAIN_NOC 206 -#define ACLK_CENTER_PERI_NOC 207 -#define ACLK_GPU 208 -#define ACLK_PERF_GPU 209 -#define ACLK_GPU_GRF 210 -#define ACLK_DMAC0_PERILP 211 -#define ACLK_DMAC1_PERILP 212 -#define ACLK_GMAC 213 -#define ACLK_GMAC_NOC 214 -#define ACLK_PERF_GMAC 215 -#define ACLK_VOP0_NOC 216 -#define ACLK_VOP0 217 -#define ACLK_VOP1_NOC 218 -#define ACLK_VOP1 219 -#define ACLK_RGA 220 -#define ACLK_RGA_NOC 221 -#define ACLK_HDCP 222 -#define ACLK_HDCP_NOC 223 -#define ACLK_HDCP22 224 -#define ACLK_IEP 225 -#define ACLK_IEP_NOC 226 -#define ACLK_VIO 227 -#define ACLK_VIO_NOC 228 -#define ACLK_ISP0 229 -#define ACLK_ISP1 230 -#define ACLK_ISP0_NOC 231 -#define ACLK_ISP1_NOC 232 -#define ACLK_ISP0_WRAPPER 233 -#define ACLK_ISP1_WRAPPER 234 -#define ACLK_VCODEC 235 -#define ACLK_VCODEC_NOC 236 -#define ACLK_VDU 237 -#define ACLK_VDU_NOC 238 -#define ACLK_PERI 239 -#define ACLK_EMMC 240 -#define ACLK_EMMC_CORE 241 -#define ACLK_EMMC_NOC 242 -#define ACLK_EMMC_GRF 243 -#define ACLK_USB3 244 -#define ACLK_USB3_NOC 245 -#define ACLK_USB3OTG0 246 -#define ACLK_USB3OTG1 247 -#define ACLK_USB3_RKSOC_AXI_PERF 248 -#define ACLK_USB3_GRF 249 -#define ACLK_GIC 250 -#define ACLK_GIC_NOC 251 -#define ACLK_GIC_ADB400_CORE_L_2_GIC 252 -#define ACLK_GIC_ADB400_CORE_B_2_GIC 253 -#define ACLK_GIC_ADB400_GIC_2_CORE_L 254 -#define ACLK_GIC_ADB400_GIC_2_CORE_B 255 -#define ACLK_CORE_ADB400_CORE_L_2_CCI500 256 -#define ACLK_CORE_ADB400_CORE_B_2_CCI500 257 -#define ACLK_ADB400M_PD_CORE_L 258 -#define ACLK_ADB400M_PD_CORE_B 259 -#define ACLK_PERF_CORE_L 260 -#define ACLK_PERF_CORE_B 261 -#define ACLK_GIC_PRE 262 -#define ACLK_VOP0_PRE 263 -#define ACLK_VOP1_PRE 264
-/* pclk gates */ -#define PCLK_PERIHP 320 -#define PCLK_PERIHP_NOC 321 -#define PCLK_PERILP0 322 -#define PCLK_PERILP1 323 -#define PCLK_PERILP1_NOC 324 -#define PCLK_PERILP_SGRF 325 -#define PCLK_PERIHP_GRF 326 -#define PCLK_PCIE 327 -#define PCLK_SGRF 328 -#define PCLK_INTR_ARB 329 -#define PCLK_CENTER_MAIN_NOC 330 -#define PCLK_CIC 331 -#define PCLK_COREDBG_B 332 -#define PCLK_COREDBG_L 333 -#define PCLK_DBG_CXCS_PD_CORE_B 334 -#define PCLK_DCF 335 -#define PCLK_GPIO2 336 -#define PCLK_GPIO3 337 -#define PCLK_GPIO4 338 -#define PCLK_GRF 339 -#define PCLK_HSICPHY 340 -#define PCLK_I2C1 341 -#define PCLK_I2C2 342 -#define PCLK_I2C3 343 -#define PCLK_I2C5 344 -#define PCLK_I2C6 345 -#define PCLK_I2C7 346 -#define PCLK_SPI0 347 -#define PCLK_SPI1 348 -#define PCLK_SPI2 349 -#define PCLK_SPI4 350 -#define PCLK_SPI5 351 -#define PCLK_UART0 352 -#define PCLK_UART1 353 -#define PCLK_UART2 354 -#define PCLK_UART3 355 -#define PCLK_TSADC 356 -#define PCLK_SARADC 357 -#define PCLK_GMAC 358 -#define PCLK_GMAC_NOC 359 -#define PCLK_TIMER0 360 -#define PCLK_TIMER1 361 -#define PCLK_EDP 362 -#define PCLK_EDP_NOC 363 -#define PCLK_EDP_CTRL 364 -#define PCLK_VIO 365 -#define PCLK_VIO_NOC 366 -#define PCLK_VIO_GRF 367 -#define PCLK_MIPI_DSI0 368 -#define PCLK_MIPI_DSI1 369 -#define PCLK_HDCP 370 -#define PCLK_HDCP_NOC 371 -#define PCLK_HDMI_CTRL 372 -#define PCLK_DP_CTRL 373 -#define PCLK_HDCP22 374 -#define PCLK_GASKET 375 -#define PCLK_DDR 376 -#define PCLK_DDR_MON 377 -#define PCLK_DDR_SGRF 378 -#define PCLK_ISP1_WRAPPER 379 -#define PCLK_WDT 380 -#define PCLK_EFUSE1024NS 381 -#define PCLK_EFUSE1024S 382 -#define PCLK_PMU_INTR_ARB 383 -#define PCLK_MAILBOX0 384 -#define PCLK_USBPHY_MUX_G 385 -#define PCLK_UPHY0_TCPHY_G 386 -#define PCLK_UPHY0_TCPD_G 387 -#define PCLK_UPHY1_TCPHY_G 388 -#define PCLK_UPHY1_TCPD_G 389 -#define PCLK_ALIVE 390
-/* hclk gates */ -#define HCLK_PERIHP 448 -#define HCLK_PERILP0 449 -#define HCLK_PERILP1 450 -#define HCLK_PERILP0_NOC 451 -#define HCLK_PERILP1_NOC 452 -#define HCLK_M0_PERILP 453 -#define HCLK_M0_PERILP_NOC 454 -#define HCLK_AHB1TOM 455 -#define HCLK_HOST0 456 -#define HCLK_HOST0_ARB 457 -#define HCLK_HOST1 458 -#define HCLK_HOST1_ARB 459 -#define HCLK_HSIC 460 -#define HCLK_SD 461 -#define HCLK_SDMMC 462 -#define HCLK_SDMMC_NOC 463 -#define HCLK_M_CRYPTO0 464 -#define HCLK_M_CRYPTO1 465 -#define HCLK_S_CRYPTO0 466 -#define HCLK_S_CRYPTO1 467 -#define HCLK_I2S0_8CH 468 -#define HCLK_I2S1_8CH 469 -#define HCLK_I2S2_8CH 470 -#define HCLK_SPDIF 471 -#define HCLK_VOP0_NOC 472 -#define HCLK_VOP0 473 -#define HCLK_VOP1_NOC 474 -#define HCLK_VOP1 475 -#define HCLK_ROM 476 -#define HCLK_IEP 477 -#define HCLK_IEP_NOC 478 -#define HCLK_ISP0 479 -#define HCLK_ISP1 480 -#define HCLK_ISP0_NOC 481 -#define HCLK_ISP1_NOC 482 -#define HCLK_ISP0_WRAPPER 483 -#define HCLK_ISP1_WRAPPER 484 -#define HCLK_RGA 485 -#define HCLK_RGA_NOC 486 -#define HCLK_HDCP 487 -#define HCLK_HDCP_NOC 488 -#define HCLK_HDCP22 489 -#define HCLK_VCODEC 490 -#define HCLK_VCODEC_NOC 491 -#define HCLK_VDU 492 -#define HCLK_VDU_NOC 493 -#define HCLK_SDIO 494 -#define HCLK_SDIO_NOC 495 -#define HCLK_SDIOAUDIO_NOC 496
-#define CLK_NR_CLKS (HCLK_SDIOAUDIO_NOC + 1)
-/* pmu-clocks indices */
-#define PLL_PPLL 1
-#define SCLK_32K_SUSPEND_PMU 2 -#define SCLK_SPI3_PMU 3 -#define SCLK_TIMER12_PMU 4 -#define SCLK_TIMER13_PMU 5 -#define SCLK_UART4_PMU 6 -#define SCLK_PVTM_PMU 7 -#define SCLK_WIFI_PMU 8 -#define SCLK_I2C0_PMU 9 -#define SCLK_I2C4_PMU 10 -#define SCLK_I2C8_PMU 11
-#define PCLK_SRC_PMU 19 -#define PCLK_PMU 20 -#define PCLK_PMUGRF_PMU 21 -#define PCLK_INTMEM1_PMU 22 -#define PCLK_GPIO0_PMU 23 -#define PCLK_GPIO1_PMU 24 -#define PCLK_SGRF_PMU 25 -#define PCLK_NOC_PMU 26 -#define PCLK_I2C0_PMU 27 -#define PCLK_I2C4_PMU 28 -#define PCLK_I2C8_PMU 29 -#define PCLK_RKPWM_PMU 30 -#define PCLK_SPI3_PMU 31 -#define PCLK_TIMER_PMU 32 -#define PCLK_MAILBOX_PMU 33 -#define PCLK_UART4_PMU 34 -#define PCLK_WDT_M0_PMU 35
-#define FCLK_CM0S_SRC_PMU 44 -#define FCLK_CM0S_PMU 45 -#define SCLK_CM0S_PMU 46 -#define HCLK_CM0S_PMU 47 -#define DCLK_CM0S_PMU 48 -#define PCLK_INTR_ARB_PMU 49 -#define HCLK_NOC_PMU 50
-#define CLKPMU_NR_CLKS (HCLK_NOC_PMU + 1)
-/* soft-reset indices */
-/* cru_softrst_con0 */ -#define SRST_CORE_L0 0 -#define SRST_CORE_B0 1 -#define SRST_CORE_PO_L0 2 -#define SRST_CORE_PO_B0 3 -#define SRST_L2_L 4 -#define SRST_L2_B 5 -#define SRST_ADB_L 6 -#define SRST_ADB_B 7 -#define SRST_A_CCI 8 -#define SRST_A_CCIM0_NOC 9 -#define SRST_A_CCIM1_NOC 10 -#define SRST_DBG_NOC 11
-/* cru_softrst_con1 */ -#define SRST_CORE_L0_T 16 -#define SRST_CORE_L1 17 -#define SRST_CORE_L2 18 -#define SRST_CORE_L3 19 -#define SRST_CORE_PO_L0_T 20 -#define SRST_CORE_PO_L1 21 -#define SRST_CORE_PO_L2 22 -#define SRST_CORE_PO_L3 23 -#define SRST_A_ADB400_GIC2COREL 24 -#define SRST_A_ADB400_COREL2GIC 25 -#define SRST_P_DBG_L 26 -#define SRST_L2_L_T 28 -#define SRST_ADB_L_T 29 -#define SRST_A_RKPERF_L 30 -#define SRST_PVTM_CORE_L 31
-/* cru_softrst_con2 */ -#define SRST_CORE_B0_T 32 -#define SRST_CORE_B1 33 -#define SRST_CORE_PO_B0_T 36 -#define SRST_CORE_PO_B1 37 -#define SRST_A_ADB400_GIC2COREB 40 -#define SRST_A_ADB400_COREB2GIC 41 -#define SRST_P_DBG_B 42 -#define SRST_L2_B_T 43 -#define SRST_ADB_B_T 45 -#define SRST_A_RKPERF_B 46 -#define SRST_PVTM_CORE_B 47
-/* cru_softrst_con3 */ -#define SRST_A_CCI_T 50 -#define SRST_A_CCIM0_NOC_T 51 -#define SRST_A_CCIM1_NOC_T 52 -#define SRST_A_ADB400M_PD_CORE_B_T 53 -#define SRST_A_ADB400M_PD_CORE_L_T 54 -#define SRST_DBG_NOC_T 55 -#define SRST_DBG_CXCS 56 -#define SRST_CCI_TRACE 57 -#define SRST_P_CCI_GRF 58
-/* cru_softrst_con4 */ -#define SRST_A_CENTER_MAIN_NOC 64 -#define SRST_A_CENTER_PERI_NOC 65 -#define SRST_P_CENTER_MAIN 66 -#define SRST_P_DDRMON 67 -#define SRST_P_CIC 68 -#define SRST_P_CENTER_SGRF 69 -#define SRST_DDR0_MSCH 70 -#define SRST_DDRCFG0_MSCH 71 -#define SRST_DDR0 72 -#define SRST_DDRPHY0 73 -#define SRST_DDR1_MSCH 74 -#define SRST_DDRCFG1_MSCH 75 -#define SRST_DDR1 76 -#define SRST_DDRPHY1 77 -#define SRST_DDR_CIC 78 -#define SRST_PVTM_DDR 79
-/* cru_softrst_con5 */ -#define SRST_A_VCODEC_NOC 80 -#define SRST_A_VCODEC 81 -#define SRST_H_VCODEC_NOC 82 -#define SRST_H_VCODEC 83 -#define SRST_A_VDU_NOC 88 -#define SRST_A_VDU 89 -#define SRST_H_VDU_NOC 90 -#define SRST_H_VDU 91 -#define SRST_VDU_CORE 92 -#define SRST_VDU_CA 93
-/* cru_softrst_con6 */ -#define SRST_A_IEP_NOC 96 -#define SRST_A_VOP_IEP 97 -#define SRST_A_IEP 98 -#define SRST_H_IEP_NOC 99 -#define SRST_H_IEP 100 -#define SRST_A_RGA_NOC 102 -#define SRST_A_RGA 103 -#define SRST_H_RGA_NOC 104 -#define SRST_H_RGA 105 -#define SRST_RGA_CORE 106 -#define SRST_EMMC_NOC 108 -#define SRST_EMMC 109 -#define SRST_EMMC_GRF 110
-/* cru_softrst_con7 */ -#define SRST_A_PERIHP_NOC 112 -#define SRST_P_PERIHP_GRF 113 -#define SRST_H_PERIHP_NOC 114 -#define SRST_USBHOST0 115 -#define SRST_HOSTC0_AUX 116 -#define SRST_HOST0_ARB 117 -#define SRST_USBHOST1 118 -#define SRST_HOSTC1_AUX 119 -#define SRST_HOST1_ARB 120 -#define SRST_SDIO0 121 -#define SRST_SDMMC 122 -#define SRST_HSIC 123 -#define SRST_HSIC_AUX 124 -#define SRST_AHB1TOM 125 -#define SRST_P_PERIHP_NOC 126 -#define SRST_HSICPHY 127
-/* cru_softrst_con8 */ -#define SRST_A_PCIE 128 -#define SRST_P_PCIE 129 -#define SRST_PCIE_CORE 130 -#define SRST_PCIE_MGMT 131 -#define SRST_PCIE_MGMT_STICKY 132 -#define SRST_PCIE_PIPE 133 -#define SRST_PCIE_PM 134 -#define SRST_PCIEPHY 135 -#define SRST_A_GMAC_NOC 136 -#define SRST_A_GMAC 137 -#define SRST_P_GMAC_NOC 138 -#define SRST_P_GMAC_GRF 140 -#define SRST_HSICPHY_POR 142 -#define SRST_HSICPHY_UTMI 143
-/* cru_softrst_con9 */ -#define SRST_USB2PHY0_POR 144 -#define SRST_USB2PHY0_UTMI_PORT0 145 -#define SRST_USB2PHY0_UTMI_PORT1 146 -#define SRST_USB2PHY0_EHCIPHY 147 -#define SRST_UPHY0_PIPE_L00 148 -#define SRST_UPHY0 149 -#define SRST_UPHY0_TCPDPWRUP 150 -#define SRST_USB2PHY1_POR 152 -#define SRST_USB2PHY1_UTMI_PORT0 153 -#define SRST_USB2PHY1_UTMI_PORT1 154 -#define SRST_USB2PHY1_EHCIPHY 155 -#define SRST_UPHY1_PIPE_L00 156 -#define SRST_UPHY1 157 -#define SRST_UPHY1_TCPDPWRUP 158
-/* cru_softrst_con10 */ -#define SRST_A_PERILP0_NOC 160 -#define SRST_A_DCF 161 -#define SRST_GIC500 162 -#define SRST_DMAC0_PERILP0 163 -#define SRST_DMAC1_PERILP0 164 -#define SRST_TZMA 165 -#define SRST_INTMEM 166 -#define SRST_ADB400_MST0 167 -#define SRST_ADB400_MST1 168 -#define SRST_ADB400_SLV0 169 -#define SRST_ADB400_SLV1 170 -#define SRST_H_PERILP0 171 -#define SRST_H_PERILP0_NOC 172 -#define SRST_ROM 173 -#define SRST_CRYPTO0_S 174 -#define SRST_CRYPTO0_M 175
-/* cru_softrst_con11 */ -#define SRST_P_DCF 176 -#define SRST_CM0S_NOC 177 -#define SRST_CM0S 178 -#define SRST_CM0S_DBG 179 -#define SRST_CM0S_PO 180 -#define SRST_CRYPTO0 181 -#define SRST_P_PERILP1_SGRF 182 -#define SRST_P_PERILP1_GRF 183 -#define SRST_CRYPTO1_S 184 -#define SRST_CRYPTO1_M 185 -#define SRST_CRYPTO1 186 -#define SRST_GIC_NOC 188 -#define SRST_SD_NOC 189 -#define SRST_SDIOAUDIO_BRG 190
-/* cru_softrst_con12 */ -#define SRST_H_PERILP1 192 -#define SRST_H_PERILP1_NOC 193 -#define SRST_H_I2S0_8CH 194 -#define SRST_H_I2S1_8CH 195 -#define SRST_H_I2S2_8CH 196 -#define SRST_H_SPDIF_8CH 197 -#define SRST_P_PERILP1_NOC 198 -#define SRST_P_EFUSE_1024 199 -#define SRST_P_EFUSE_1024S 200 -#define SRST_P_I2C0 201 -#define SRST_P_I2C1 202 -#define SRST_P_I2C2 203 -#define SRST_P_I2C3 204 -#define SRST_P_I2C4 205 -#define SRST_P_I2C5 206 -#define SRST_P_MAILBOX0 207
-/* cru_softrst_con13 */ -#define SRST_P_UART0 208 -#define SRST_P_UART1 209 -#define SRST_P_UART2 210 -#define SRST_P_UART3 211 -#define SRST_P_SARADC 212 -#define SRST_P_TSADC 213 -#define SRST_P_SPI0 214 -#define SRST_P_SPI1 215 -#define SRST_P_SPI2 216 -#define SRST_P_SPI3 217 -#define SRST_P_SPI4 218 -#define SRST_SPI0 219 -#define SRST_SPI1 220 -#define SRST_SPI2 221 -#define SRST_SPI3 222 -#define SRST_SPI4 223
-/* cru_softrst_con14 */ -#define SRST_I2S0_8CH 224 -#define SRST_I2S1_8CH 225 -#define SRST_I2S2_8CH 226 -#define SRST_SPDIF_8CH 227 -#define SRST_UART0 228 -#define SRST_UART1 229 -#define SRST_UART2 230 -#define SRST_UART3 231 -#define SRST_TSADC 232 -#define SRST_I2C0 233 -#define SRST_I2C1 234 -#define SRST_I2C2 235 -#define SRST_I2C3 236 -#define SRST_I2C4 237 -#define SRST_I2C5 238 -#define SRST_SDIOAUDIO_NOC 239
-/* cru_softrst_con15 */ -#define SRST_A_VIO_NOC 240 -#define SRST_A_HDCP_NOC 241 -#define SRST_A_HDCP 242 -#define SRST_H_HDCP_NOC 243 -#define SRST_H_HDCP 244 -#define SRST_P_HDCP_NOC 245 -#define SRST_P_HDCP 246 -#define SRST_P_HDMI_CTRL 247 -#define SRST_P_DP_CTRL 248 -#define SRST_S_DP_CTRL 249 -#define SRST_C_DP_CTRL 250 -#define SRST_P_MIPI_DSI0 251 -#define SRST_P_MIPI_DSI1 252 -#define SRST_DP_CORE 253 -#define SRST_DP_I2S 254
-/* cru_softrst_con16 */ -#define SRST_GASKET 256 -#define SRST_VIO_GRF 258 -#define SRST_DPTX_SPDIF_REC 259 -#define SRST_HDMI_CTRL 260 -#define SRST_HDCP_CTRL 261 -#define SRST_A_ISP0_NOC 262 -#define SRST_A_ISP1_NOC 263 -#define SRST_H_ISP0_NOC 266 -#define SRST_H_ISP1_NOC 267 -#define SRST_H_ISP0 268 -#define SRST_H_ISP1 269 -#define SRST_ISP0 270 -#define SRST_ISP1 271
-/* cru_softrst_con17 */ -#define SRST_A_VOP0_NOC 272 -#define SRST_A_VOP1_NOC 273 -#define SRST_A_VOP0 274 -#define SRST_A_VOP1 275 -#define SRST_H_VOP0_NOC 276 -#define SRST_H_VOP1_NOC 277 -#define SRST_H_VOP0 278 -#define SRST_H_VOP1 279 -#define SRST_D_VOP0 280 -#define SRST_D_VOP1 281 -#define SRST_VOP0_PWM 282 -#define SRST_VOP1_PWM 283 -#define SRST_P_EDP_NOC 284 -#define SRST_P_EDP_CTRL 285
-/* cru_softrst_con18 */ -#define SRST_A_GPU 288 -#define SRST_A_GPU_NOC 289 -#define SRST_A_GPU_GRF 290 -#define SRST_PVTM_GPU 291 -#define SRST_A_USB3_NOC 292 -#define SRST_A_USB3_OTG0 293 -#define SRST_A_USB3_OTG1 294 -#define SRST_A_USB3_GRF 295 -#define SRST_PMU 296
-/* cru_softrst_con19 */ -#define SRST_P_TIMER0_5 304 -#define SRST_TIMER0 305 -#define SRST_TIMER1 306 -#define SRST_TIMER2 307 -#define SRST_TIMER3 308 -#define SRST_TIMER4 309 -#define SRST_TIMER5 310 -#define SRST_P_TIMER6_11 311 -#define SRST_TIMER6 312 -#define SRST_TIMER7 313 -#define SRST_TIMER8 314 -#define SRST_TIMER9 315 -#define SRST_TIMER10 316 -#define SRST_TIMER11 317 -#define SRST_P_INTR_ARB_PMU 318 -#define SRST_P_ALIVE_SGRF 319
-/* cru_softrst_con20 */ -#define SRST_P_GPIO2 320 -#define SRST_P_GPIO3 321 -#define SRST_P_GPIO4 322 -#define SRST_P_GRF 323 -#define SRST_P_ALIVE_NOC 324 -#define SRST_P_WDT0 325 -#define SRST_P_WDT1 326 -#define SRST_P_INTR_ARB 327 -#define SRST_P_UPHY0_DPTX 328 -#define SRST_P_UPHY0_APB 330 -#define SRST_P_UPHY0_TCPHY 332 -#define SRST_P_UPHY1_TCPHY 333 -#define SRST_P_UPHY0_TCPDCTRL 334 -#define SRST_P_UPHY1_TCPDCTRL 335
-/* pmu soft-reset indices */
-/* pmu_cru_softrst_con0 */ -#define SRST_P_NOC 0 -#define SRST_P_INTMEM 1 -#define SRST_H_CM0S 2 -#define SRST_H_CM0S_NOC 3 -#define SRST_DBG_CM0S 4 -#define SRST_PO_CM0S 5 -#define SRST_P_SPI6 6 -#define SRST_SPI6 7 -#define SRST_P_TIMER_0_1 8 -#define SRST_P_TIMER_0 9 -#define SRST_P_TIMER_1 10 -#define SRST_P_UART4 11 -#define SRST_UART4 12 -#define SRST_P_WDT 13
-/* pmu_cru_softrst_con1 */ -#define SRST_P_I2C6 16 -#define SRST_P_I2C7 17 -#define SRST_P_I2C8 18 -#define SRST_P_MAILBOX 19 -#define SRST_P_RKPWM 20 -#define SRST_P_PMUGRF 21 -#define SRST_P_SGRF 22 -#define SRST_P_GPIO0 23 -#define SRST_P_GPIO1 24 -#define SRST_P_CRU 25 -#define SRST_P_INTR 26 -#define SRST_PVTM 27 -#define SRST_I2C6 28 -#define SRST_I2C7 29 -#define SRST_I2C8 30
-#endif diff --git a/include/dt-bindings/power/rk3399-power.h b/include/dt-bindings/power/rk3399-power.h deleted file mode 100644 index 168b3bfbd6f5..000000000000 --- a/include/dt-bindings/power/rk3399-power.h +++ /dev/null @@ -1,53 +0,0 @@ -#ifndef __DT_BINDINGS_POWER_RK3399_POWER_H__ -#define __DT_BINDINGS_POWER_RK3399_POWER_H__
-/* VD_CORE_L */ -#define RK3399_PD_A53_L0 0 -#define RK3399_PD_A53_L1 1 -#define RK3399_PD_A53_L2 2 -#define RK3399_PD_A53_L3 3 -#define RK3399_PD_SCU_L 4
-/* VD_CORE_B */ -#define RK3399_PD_A72_B0 5 -#define RK3399_PD_A72_B1 6 -#define RK3399_PD_SCU_B 7
-/* VD_LOGIC */ -#define RK3399_PD_TCPD0 8 -#define RK3399_PD_TCPD1 9 -#define RK3399_PD_CCI 10 -#define RK3399_PD_CCI0 11 -#define RK3399_PD_CCI1 12 -#define RK3399_PD_PERILP 13 -#define RK3399_PD_PERIHP 14 -#define RK3399_PD_VIO 15 -#define RK3399_PD_VO 16 -#define RK3399_PD_VOPB 17 -#define RK3399_PD_VOPL 18 -#define RK3399_PD_ISP0 19 -#define RK3399_PD_ISP1 20 -#define RK3399_PD_HDCP 21 -#define RK3399_PD_GMAC 22 -#define RK3399_PD_EMMC 23 -#define RK3399_PD_USB3 24 -#define RK3399_PD_EDP 25 -#define RK3399_PD_GIC 26 -#define RK3399_PD_SD 27 -#define RK3399_PD_SDIOAUDIO 28 -#define RK3399_PD_ALIVE 29
-/* VD_CENTER */ -#define RK3399_PD_CENTER 30 -#define RK3399_PD_VCODEC 31 -#define RK3399_PD_VDU 32 -#define RK3399_PD_RGA 33 -#define RK3399_PD_IEP 34
-/* VD_GPU */ -#define RK3399_PD_GPU 35
-/* VD_PMU */ -#define RK3399_PD_PMU 36
-#endif
Add a <CONFIG_SYS_SOC>-u-boot.dtsi file that gets included by default for RK356x boards when a board specific u-boot.dtsi file dont exists.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3568-u-boot.dtsi | 3 +++ 1 file changed, 3 insertions(+) create mode 100644 arch/arm/dts/rk3568-u-boot.dtsi
diff --git a/arch/arm/dts/rk3568-u-boot.dtsi b/arch/arm/dts/rk3568-u-boot.dtsi new file mode 100644 index 000000000000..6e8307e3bdf6 --- /dev/null +++ b/arch/arm/dts/rk3568-u-boot.dtsi @@ -0,0 +1,3 @@ +// SPDX-License-Identifier: (GPL-2.0+ OR MIT) + +#include "rk356x-u-boot.dtsi"
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
Migrate RK356x boards that exists in Linux v6.8 to use OF_UPSTREAM.
Following targets is not migrated to use OF_UPSTREAM: - anbernic-rgxx3-rk3566: Multi device target - generic-rk3568: Generic target only meant for U-Boot use - pinetab2-rk3566: Merged in v6.9-rc1
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/Makefile | 20 -------------------- arch/arm/mach-rockchip/Kconfig | 1 + configs/anbernic-rgxx3-rk3566_defconfig | 1 + configs/bpi-r2-pro-rk3568_defconfig | 2 +- configs/evb-rk3568_defconfig | 4 ++-- configs/generic-rk3568_defconfig | 1 + configs/lubancat-2-rk3568_defconfig | 2 +- configs/nanopi-r5c-rk3568_defconfig | 2 +- configs/nanopi-r5s-rk3568_defconfig | 2 +- configs/odroid-m1-rk3568_defconfig | 2 +- configs/pinetab2-rk3566_defconfig | 1 + configs/quartz64-a-rk3566_defconfig | 2 +- configs/quartz64-b-rk3566_defconfig | 2 +- configs/radxa-cm3-io-rk3566_defconfig | 2 +- configs/radxa-e25-rk3568_defconfig | 2 +- configs/rock-3a-rk3568_defconfig | 2 +- configs/soquartz-blade-rk3566_defconfig | 2 +- configs/soquartz-cm4-rk3566_defconfig | 2 +- configs/soquartz-model-a-rk3566_defconfig | 2 +- 19 files changed, 19 insertions(+), 35 deletions(-)
diff --git a/arch/arm/dts/Makefile b/arch/arm/dts/Makefile index 7a65d98635ae..1dfcc05a14be 100644 --- a/arch/arm/dts/Makefile +++ b/arch/arm/dts/Makefile @@ -98,26 +98,6 @@ dtb-$(CONFIG_ROCKCHIP_RK3368) += \ rk3368-geekbox.dtb \ rk3368-px5-evb.dtb \
-dtb-$(CONFIG_ROCKCHIP_RK3568) += \ - rk3566-anbernic-rgxx3.dtb \ - rk3566-pinetab2-v0.1.dtb \ - rk3566-pinetab2-v2.0.dtb \ - rk3566-quartz64-a.dtb \ - rk3566-quartz64-b.dtb \ - rk3566-radxa-cm3-io.dtb \ - rk3566-soquartz-blade.dtb \ - rk3566-soquartz-cm4.dtb \ - rk3566-soquartz-model-a.dtb \ - rk3568-bpi-r2-pro.dtb \ - rk3568-evb.dtb \ - rk3568-generic.dtb \ - rk3568-lubancat-2.dtb \ - rk3568-nanopi-r5c.dtb \ - rk3568-nanopi-r5s.dtb \ - rk3568-odroid-m1.dtb \ - rk3568-radxa-e25.dtb \ - rk3568-rock-3a.dtb - dtb-$(CONFIG_ROCKCHIP_RK3588) += \ rk3588s-coolpi-4b.dtb \ rk3588-coolpi-cm5-evb.dtb \ diff --git a/arch/arm/mach-rockchip/Kconfig b/arch/arm/mach-rockchip/Kconfig index a2c81489452e..03f6bf43fdf4 100644 --- a/arch/arm/mach-rockchip/Kconfig +++ b/arch/arm/mach-rockchip/Kconfig @@ -322,6 +322,7 @@ config ROCKCHIP_RK3568 imply MISC_INIT_R imply MMC_HS200_SUPPORT if MMC_SDHCI_ROCKCHIP imply OF_LIBFDT_OVERLAY + imply OF_UPSTREAM imply PHY_GIGE if DWC_ETH_QOS_ROCKCHIP imply RNG_ROCKCHIP imply ROCKCHIP_COMMON_BOARD diff --git a/configs/anbernic-rgxx3-rk3566_defconfig b/configs/anbernic-rgxx3-rk3566_defconfig index fcade9172b71..a03509bf4671 100644 --- a/configs/anbernic-rgxx3-rk3566_defconfig +++ b/configs/anbernic-rgxx3-rk3566_defconfig @@ -38,6 +38,7 @@ CONFIG_CMD_MMC=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y +# CONFIG_OF_UPSTREAM is not set CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_ENV_VARS_UBOOT_RUNTIME_CONFIG=y # CONFIG_NET is not set diff --git a/configs/bpi-r2-pro-rk3568_defconfig b/configs/bpi-r2-pro-rk3568_defconfig index a0caa367f9db..eccc15a0ae51 100644 --- a/configs/bpi-r2-pro-rk3568_defconfig +++ b/configs/bpi-r2-pro-rk3568_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3568-bpi-r2-pro" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-bpi-r2-pro" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_DEBUG_UART_BASE=0xFE660000 diff --git a/configs/evb-rk3568_defconfig b/configs/evb-rk3568_defconfig index e71d6705568f..2076f55122be 100644 --- a/configs/evb-rk3568_defconfig +++ b/configs/evb-rk3568_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3568-evb" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-evb1-v10" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_DEBUG_UART_BASE=0xFE660000 @@ -14,7 +14,7 @@ CONFIG_FIT_VERBOSE=y CONFIG_SPL_FIT_SIGNATURE=y CONFIG_SPL_LOAD_FIT=y CONFIG_LEGACY_IMAGE_FORMAT=y -CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-evb.dtb" +CONFIG_DEFAULT_FDT_FILE="rockchip/rk3568-evb1-v10.dtb" # CONFIG_DISPLAY_CPUINFO is not set CONFIG_DISPLAY_BOARDINFO_LATE=y CONFIG_SPL_MAX_SIZE=0x40000 diff --git a/configs/generic-rk3568_defconfig b/configs/generic-rk3568_defconfig index 033702fd149f..66a33afbbaf0 100644 --- a/configs/generic-rk3568_defconfig +++ b/configs/generic-rk3568_defconfig @@ -37,6 +37,7 @@ CONFIG_CMD_USB_MASS_STORAGE=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y +# CONFIG_OF_UPSTREAM is not set CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SYS_RELOC_GD_ENV_ADDR=y # CONFIG_NET is not set diff --git a/configs/lubancat-2-rk3568_defconfig b/configs/lubancat-2-rk3568_defconfig index ea67b6a72864..88593bfa7051 100644 --- a/configs/lubancat-2-rk3568_defconfig +++ b/configs/lubancat-2-rk3568_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3568-lubancat-2" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-lubancat-2" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_DEBUG_UART_BASE=0xFE660000 diff --git a/configs/nanopi-r5c-rk3568_defconfig b/configs/nanopi-r5c-rk3568_defconfig index 00743b7f926c..4a6c320faf5c 100644 --- a/configs/nanopi-r5c-rk3568_defconfig +++ b/configs/nanopi-r5c-rk3568_defconfig @@ -3,7 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3568-nanopi-r5c" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-nanopi-r5c" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_DEBUG_UART_BASE=0xFE660000 diff --git a/configs/nanopi-r5s-rk3568_defconfig b/configs/nanopi-r5s-rk3568_defconfig index 91e3a19dea6d..7ab12e619acf 100644 --- a/configs/nanopi-r5s-rk3568_defconfig +++ b/configs/nanopi-r5s-rk3568_defconfig @@ -3,7 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3568-nanopi-r5s" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-nanopi-r5s" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_DEBUG_UART_BASE=0xFE660000 diff --git a/configs/odroid-m1-rk3568_defconfig b/configs/odroid-m1-rk3568_defconfig index e749f9af9d23..b5263caff6dc 100644 --- a/configs/odroid-m1-rk3568_defconfig +++ b/configs/odroid-m1-rk3568_defconfig @@ -4,7 +4,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SF_DEFAULT_MODE=0x1000 -CONFIG_DEFAULT_DEVICE_TREE="rk3568-odroid-m1" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-odroid-m1" CONFIG_ROCKCHIP_RK3568=y CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_SPL_SERIAL=y diff --git a/configs/pinetab2-rk3566_defconfig b/configs/pinetab2-rk3566_defconfig index ad237edf8d93..e46acf3a3b58 100644 --- a/configs/pinetab2-rk3566_defconfig +++ b/configs/pinetab2-rk3566_defconfig @@ -47,6 +47,7 @@ CONFIG_CMD_REGULATOR=y # CONFIG_SPL_DOS_PARTITION is not set CONFIG_SPL_OF_CONTROL=y CONFIG_OF_LIVE=y +# CONFIG_OF_UPSTREAM is not set CONFIG_OF_LIST="rk3566-pinetab2-v0.1 rk3566-pinetab2-v2.0" CONFIG_OF_SPL_REMOVE_PROPS="clock-names interrupt-parent assigned-clocks assigned-clock-rates assigned-clock-parents" CONFIG_SPL_DM_SEQ_ALIAS=y diff --git a/configs/quartz64-a-rk3566_defconfig b/configs/quartz64-a-rk3566_defconfig index 535e34fb9903..1ea8e0f40cc4 100644 --- a/configs/quartz64-a-rk3566_defconfig +++ b/configs/quartz64-a-rk3566_defconfig @@ -5,7 +5,7 @@ CONFIG_ARCH_ROCKCHIP=y CONFIG_SPL_GPIO=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SF_DEFAULT_MODE=0x2000 -CONFIG_DEFAULT_DEVICE_TREE="rk3566-quartz64-a" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-quartz64-a" CONFIG_ROCKCHIP_RK3568=y CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_SPL_SERIAL=y diff --git a/configs/quartz64-b-rk3566_defconfig b/configs/quartz64-b-rk3566_defconfig index e197defd3af3..f61b2c181a1f 100644 --- a/configs/quartz64-b-rk3566_defconfig +++ b/configs/quartz64-b-rk3566_defconfig @@ -4,7 +4,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SF_DEFAULT_MODE=0x2000 -CONFIG_DEFAULT_DEVICE_TREE="rk3566-quartz64-b" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-quartz64-b" CONFIG_ROCKCHIP_RK3568=y CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_SPL_SERIAL=y diff --git a/configs/radxa-cm3-io-rk3566_defconfig b/configs/radxa-cm3-io-rk3566_defconfig index d23ab57ada57..48c8fcf5a66b 100644 --- a/configs/radxa-cm3-io-rk3566_defconfig +++ b/configs/radxa-cm3-io-rk3566_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3566-radxa-cm3-io" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-radxa-cm3-io" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_DEBUG_UART_BASE=0xFE660000 diff --git a/configs/radxa-e25-rk3568_defconfig b/configs/radxa-e25-rk3568_defconfig index dbb77b85f5d9..496fee0e0a44 100644 --- a/configs/radxa-e25-rk3568_defconfig +++ b/configs/radxa-e25-rk3568_defconfig @@ -3,7 +3,7 @@ CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_SYS_HAS_NONCACHED_MEMORY=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3568-radxa-e25" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-radxa-e25" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_DEBUG_UART_BASE=0xFE660000 diff --git a/configs/rock-3a-rk3568_defconfig b/configs/rock-3a-rk3568_defconfig index b06b57fe0bf3..66ac2f6d7aac 100644 --- a/configs/rock-3a-rk3568_defconfig +++ b/configs/rock-3a-rk3568_defconfig @@ -4,7 +4,7 @@ CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y CONFIG_SF_DEFAULT_SPEED=24000000 CONFIG_SF_DEFAULT_MODE=0x2000 -CONFIG_DEFAULT_DEVICE_TREE="rk3568-rock-3a" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3568-rock-3a" CONFIG_ROCKCHIP_RK3568=y CONFIG_ROCKCHIP_SPI_IMAGE=y CONFIG_SPL_SERIAL=y diff --git a/configs/soquartz-blade-rk3566_defconfig b/configs/soquartz-blade-rk3566_defconfig index 9d565c162ef2..82910daf7cc6 100644 --- a/configs/soquartz-blade-rk3566_defconfig +++ b/configs/soquartz-blade-rk3566_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3566-soquartz-blade" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-soquartz-blade" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_TARGET_QUARTZ64_RK3566=y diff --git a/configs/soquartz-cm4-rk3566_defconfig b/configs/soquartz-cm4-rk3566_defconfig index fe2c771db71b..5744f1baa81a 100644 --- a/configs/soquartz-cm4-rk3566_defconfig +++ b/configs/soquartz-cm4-rk3566_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3566-soquartz-cm4" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-soquartz-cm4" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_TARGET_QUARTZ64_RK3566=y diff --git a/configs/soquartz-model-a-rk3566_defconfig b/configs/soquartz-model-a-rk3566_defconfig index db9eee217514..920df9b622d7 100644 --- a/configs/soquartz-model-a-rk3566_defconfig +++ b/configs/soquartz-model-a-rk3566_defconfig @@ -2,7 +2,7 @@ CONFIG_ARM=y CONFIG_SKIP_LOWLEVEL_INIT=y CONFIG_COUNTER_FREQUENCY=24000000 CONFIG_ARCH_ROCKCHIP=y -CONFIG_DEFAULT_DEVICE_TREE="rk3566-soquartz-model-a" +CONFIG_DEFAULT_DEVICE_TREE="rockchip/rk3566-soquartz-model-a" CONFIG_ROCKCHIP_RK3568=y CONFIG_SPL_SERIAL=y CONFIG_TARGET_QUARTZ64_RK3566=y
Thanks, - Kever
- rk3568-evb.dtb \
- imply OF_UPSTREAM imply PHY_GIGE if DWC_ETH_QOS_ROCKCHIP imply RNG_ROCKCHIP imply ROCKCHIP_COMMON_BOARD
Remove redundant device tree files now that RK356x boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se --- arch/arm/dts/rk3566-anbernic-rgxx3.dtsi | 788 ------ arch/arm/dts/rk3566-quartz64-a.dts | 838 ------ arch/arm/dts/rk3566-quartz64-b.dts | 737 ----- arch/arm/dts/rk3566-radxa-cm3-io.dts | 281 -- arch/arm/dts/rk3566-radxa-cm3.dtsi | 425 --- arch/arm/dts/rk3566-soquartz-blade.dts | 198 -- arch/arm/dts/rk3566-soquartz-cm4.dts | 196 -- arch/arm/dts/rk3566-soquartz-model-a.dts | 236 -- arch/arm/dts/rk3566-soquartz.dtsi | 684 ----- arch/arm/dts/rk3566.dtsi | 35 - arch/arm/dts/rk3568-bpi-r2-pro.dts | 852 ------ arch/arm/dts/rk3568-evb.dts | 689 ----- arch/arm/dts/rk3568-lubancat-2.dts | 730 ----- arch/arm/dts/rk3568-nanopi-r5c.dts | 112 - arch/arm/dts/rk3568-nanopi-r5s.dts | 136 - arch/arm/dts/rk3568-nanopi-r5s.dtsi | 587 ---- arch/arm/dts/rk3568-odroid-m1.dts | 741 ----- arch/arm/dts/rk3568-pinctrl.dtsi | 3214 ---------------------- arch/arm/dts/rk3568-radxa-cm3i.dtsi | 412 --- arch/arm/dts/rk3568-radxa-e25.dts | 236 -- arch/arm/dts/rk3568-rock-3a.dts | 859 ------ arch/arm/dts/rk3568.dtsi | 267 -- arch/arm/dts/rk356x.dtsi | 1886 ------------- include/dt-bindings/clock/rk3568-cru.h | 926 ------- include/dt-bindings/power/rk3568-power.h | 32 - 25 files changed, 16097 deletions(-) delete mode 100644 arch/arm/dts/rk3566-anbernic-rgxx3.dtsi delete mode 100644 arch/arm/dts/rk3566-quartz64-a.dts delete mode 100644 arch/arm/dts/rk3566-quartz64-b.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3-io.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3.dtsi delete mode 100644 arch/arm/dts/rk3566-soquartz-blade.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-cm4.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-model-a.dts delete mode 100644 arch/arm/dts/rk3566-soquartz.dtsi delete mode 100644 arch/arm/dts/rk3566.dtsi delete mode 100644 arch/arm/dts/rk3568-bpi-r2-pro.dts delete mode 100644 arch/arm/dts/rk3568-evb.dts delete mode 100644 arch/arm/dts/rk3568-lubancat-2.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5c.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dtsi delete mode 100644 arch/arm/dts/rk3568-odroid-m1.dts delete mode 100644 arch/arm/dts/rk3568-pinctrl.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-cm3i.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-e25.dts delete mode 100644 arch/arm/dts/rk3568-rock-3a.dts delete mode 100644 arch/arm/dts/rk3568.dtsi delete mode 100644 arch/arm/dts/rk356x.dtsi delete mode 100644 include/dt-bindings/clock/rk3568-cru.h delete mode 100644 include/dt-bindings/power/rk3568-power.h
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi deleted file mode 100644 index 8cbf3d9a4f22..000000000000 --- a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi +++ /dev/null @@ -1,788 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi" - -/ { - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - adc-joystick { - compatible = "adc-joystick"; - io-channels = <&adc_mux 0>, - <&adc_mux 1>, - <&adc_mux 2>, - <&adc_mux 3>; - pinctrl-0 = <&joy_mux_en>; - pinctrl-names = "default"; - poll-interval = <60>; - #address-cells = <1>; - #size-cells = <0>; - - axis@0 { - reg = <0>; - abs-flat = <32>; - abs-fuzz = <32>; - abs-range = <1023 15>; - linux,code = <ABS_X>; - }; - - axis@1 { - reg = <1>; - abs-flat = <32>; - abs-fuzz = <32>; - abs-range = <15 1023>; - linux,code = <ABS_RX>; - }; - - axis@2 { - reg = <2>; - abs-flat = <32>; - abs-fuzz = <32>; - abs-range = <15 1023>; - linux,code = <ABS_Y>; - }; - - axis@3 { - reg = <3>; - abs-flat = <32>; - abs-fuzz = <32>; - abs-range = <1023 15>; - linux,code = <ABS_RY>; - }; - }; - - adc_keys: adc-keys { - compatible = "adc-keys"; - io-channels = <&saradc 0>; - io-channel-names = "buttons"; - keyup-threshold-microvolt = <1800000>; - poll-interval = <60>; - - /* - * Button is mapped to F key in BSP kernel, but - * according to input guidelines it should be mode. - */ - button-mode { - label = "MODE"; - linux,code = <BTN_MODE>; - press-threshold-microvolt = <1750>; - }; - }; - - adc_mux: adc-mux { - compatible = "io-channel-mux"; - channels = "left_x", "right_x", "left_y", "right_y"; - #io-channel-cells = <1>; - io-channels = <&saradc 3>; - io-channel-names = "parent"; - mux-controls = <&gpio_mux>; - settle-time-us = <100>; - }; - - gpio_keys_control: gpio-keys-control { - compatible = "gpio-keys"; - pinctrl-0 = <&btn_pins_ctrl>; - pinctrl-names = "default"; - - button-b { - gpios = <&gpio3 RK_PC3 GPIO_ACTIVE_LOW>; - label = "SOUTH"; - linux,code = <BTN_SOUTH>; - }; - - button-down { - gpios = <&gpio3 RK_PA4 GPIO_ACTIVE_LOW>; - label = "DPAD-DOWN"; - linux,code = <BTN_DPAD_DOWN>; - }; - - button-l1 { - gpios = <&gpio3 RK_PB1 GPIO_ACTIVE_LOW>; - label = "TL"; - linux,code = <BTN_TL>; - }; - - button-l2 { - gpios = <&gpio3 RK_PB2 GPIO_ACTIVE_LOW>; - label = "TL2"; - linux,code = <BTN_TL2>; - }; - - button-select { - gpios = <&gpio3 RK_PB6 GPIO_ACTIVE_LOW>; - label = "SELECT"; - linux,code = <BTN_SELECT>; - }; - - button-start { - gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_LOW>; - label = "START"; - linux,code = <BTN_START>; - }; - - button-thumbl { - gpios = <&gpio3 RK_PA1 GPIO_ACTIVE_LOW>; - label = "THUMBL"; - linux,code = <BTN_THUMBL>; - }; - - button-thumbr { - gpios = <&gpio3 RK_PA2 GPIO_ACTIVE_LOW>; - label = "THUMBR"; - linux,code = <BTN_THUMBR>; - }; - - button-up { - gpios = <&gpio3 RK_PA3 GPIO_ACTIVE_LOW>; - label = "DPAD-UP"; - linux,code = <BTN_DPAD_UP>; - }; - - button-x { - gpios = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>; - label = "NORTH"; - linux,code = <BTN_NORTH>; - }; - }; - - gpio_keys_vol: gpio-keys-vol { - compatible = "gpio-keys"; - autorepeat; - pinctrl-0 = <&btn_pins_vol>; - pinctrl-names = "default"; - - button-vol-down { - gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>; - label = "VOLUMEDOWN"; - linux,code = <KEY_VOLUMEDOWN>; - }; - - button-vol-up { - gpios = <&gpio3 RK_PA7 GPIO_ACTIVE_LOW>; - label = "VOLUMEUP"; - linux,code = <KEY_VOLUMEUP>; - }; - }; - - gpio_mux: mux-controller { - compatible = "gpio-mux"; - mux-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_LOW>, - <&gpio0 RK_PB7 GPIO_ACTIVE_LOW>; - #mux-control-cells = <0>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - ddc-i2c-bus = <&i2c5>; - type = "c"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - leds: pwm-leds { - compatible = "pwm-leds"; - - green_led: led-0 { - color = <LED_COLOR_ID_GREEN>; - default-state = "on"; - function = LED_FUNCTION_POWER; - max-brightness = <255>; - pwms = <&pwm6 0 25000 0>; - }; - - amber_led: led-1 { - color = <LED_COLOR_ID_AMBER>; - function = LED_FUNCTION_CHARGING; - max-brightness = <255>; - pwms = <&pwm7 0 25000 0>; - }; - - red_led: led-2 { - color = <LED_COLOR_ID_RED>; - default-state = "off"; - function = LED_FUNCTION_STATUS; - max-brightness = <255>; - pwms = <&pwm0 0 25000 0>; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk817 1>; - clock-names = "ext_clock"; - pinctrl-0 = <&wifi_enable_h>; - pinctrl-names = "default"; - post-power-on-delay-ms = <200>; - reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_LOW>; - }; - - vcc3v3_lcd0_n: regulator-vcc3v3-lcd0 { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PC2 GPIO_ACTIVE_HIGH>; - enable-active-high; - pinctrl-0 = <&vcc_lcd_h>; - pinctrl-names = "default"; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc3v3_lcd0_n"; - vin-supply = <&vcc_3v3>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_sys: regulator-vcc-sys { - compatible = "regulator-fixed"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3800000>; - regulator-max-microvolt = <3800000>; - regulator-name = "vcc_sys"; - }; - - vcc_wifi: regulator-vcc-wifi { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&vcc_wifi_h>; - pinctrl-names = "default"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc_wifi"; - }; - - vibrator: pwm-vibrator { - compatible = "pwm-vibrator"; - pwm-names = "enable"; - pwms = <&pwm5 0 1000000000 0>; - }; -}; - -&combphy1 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - ddc-i2c-bus = <&i2c5>; - pinctrl-0 = <&hdmitxm0_cec>; - pinctrl-names = "default"; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - rk817: pmic@20 { - compatible = "rockchip,rk817"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - #clock-cells = <1>; - #sound-dai-cells = <0>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s1m0_mclk>, <&pmic_int_l>; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_sys>; - vcc9-supply = <&dcdc_boost>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_logic"; - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_gpu"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_3v3: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-initial-mode = <0x2>; - regulator-name = "vcc_3v3"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca1v8_pmu: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca1v8_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda_0v9"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda0v9_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_acodec"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc3v3_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_1v8: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_1v8"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_dvp: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc1v8_dvp"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc2v8_dvp: LDO_REG9 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-name = "vcc2v8_dvp"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - dcdc_boost: BOOST { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <4700000>; - regulator-max-microvolt = <5400000>; - regulator-name = "boost"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - otg_switch: OTG_SWITCH { - regulator-name = "otg_switch"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; - - vdd_cpu: regulator@40 { - compatible = "fcs,fan53555"; - reg = <0x40>; - fcs,suspend-voltage-selector = <1>; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1390000>; - regulator-name = "vdd_cpu"; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc_sys>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&i2c1 { - /* Unknown/unused device at 0x3c */ - status = "disabled"; -}; - -&i2c5 { - pinctrl-0 = <&i2c5m1_xfer>; - pinctrl-names = "default"; - status = "okay"; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&i2s1_8ch { - pinctrl-0 = <&i2s1m0_sclktx - &i2s1m0_lrcktx - &i2s1m0_sdi0 - &i2s1m0_sdo0>; - pinctrl-names = "default"; - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&pinctrl { - gpio-btns { - btn_pins_ctrl: btn-pins-ctrl { - rockchip,pins = - <3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PB4 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PC1 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PC3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - - btn_pins_vol: btn-pins-vol { - rockchip,pins = - <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>, - <3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - joy-mux { - joy_mux_en: joy-mux-en { - rockchip,pins = - <0 RK_PB5 RK_FUNC_GPIO &pcfg_output_low>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = - <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = - <4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - vcc3v3-lcd { - vcc_lcd_h: vcc-lcd-h { - rockchip,pins = - <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - vcc-wifi { - vcc_wifi_h: vcc-wifi-h { - rockchip,pins = - <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - status = "okay"; - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc1v8_dvp>; - vccio7-supply = <&vcc_3v3>; -}; - -&pwm0 { - pinctrl-0 = <&pwm0m1_pins>; - pinctrl-names = "default"; - status = "okay"; -}; - -&pwm5 { - status = "okay"; -}; - -&pwm6 { - status = "okay"; -}; - -&pwm7 { - status = "okay"; -}; - -&saradc { - vref-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - pinctrl-names = "default"; - sd-uhs-sdr104; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&sdmmc1 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio2 RK_PB2 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk &sdmmc1_det>; - pinctrl-names = "default"; - sd-uhs-sdr104; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc1v8_dvp>; - status = "okay"; -}; - -&sdmmc2 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-0 = <&sdmmc2m0_bus4 &sdmmc2m0_cmd &sdmmc2m0_clk>; - pinctrl-names = "default"; - vmmc-supply = <&vcc_wifi>; - vqmmc-supply = <&vcca1v8_pmu>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart1 { - pinctrl-0 = <&uart1m1_xfer &uart1m1_ctsn &uart1m1_rtsn>; - pinctrl-names = "default"; - uart-has-rtscts; - status = "okay"; - - bluetooth { - compatible = "realtek,rtl8821cs-bt", "realtek,rtl8723bs-bt"; - device-wake-gpios = <&gpio4 4 GPIO_ACTIVE_HIGH>; - enable-gpios = <&gpio4 3 GPIO_ACTIVE_HIGH>; - host-wake-gpios = <&gpio4 5 GPIO_ACTIVE_HIGH>; - }; -}; - -&uart2 { - status = "okay"; -}; - -/* - * Lack the schematics to verify, but port works as a peripheral - * (and not a host or OTG port). - */ -&usb_host0_xhci { - dr_mode = "peripheral"; - phys = <&usb2phy0_otg>; - phy-names = "usb2-phy"; - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb_host1_xhci { - phy-names = "usb2-phy", "usb3-phy"; - phys = <&usb2phy1_host>, <&combphy1 PHY_TYPE_USB3>; - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_otg { - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_host { - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3566-quartz64-a.dts b/arch/arm/dts/rk3566-quartz64-a.dts deleted file mode 100644 index 59843a7a199c..000000000000 --- a/arch/arm/dts/rk3566-quartz64-a.dts +++ /dev/null @@ -1,838 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi" - -/ { - model = "Pine64 RK3566 Quartz64-A Board"; - compatible = "pine64,quartz64-a", "rockchip,rk3566"; - - aliases { - ethernet0 = &gmac1; - mmc0 = &sdmmc0; - mmc1 = &sdhci; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac1_clkin: external-gmac1-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac1_clkin"; - #clock-cells = <0>; - }; - - fan: gpio_fan { - compatible = "gpio-fan"; - gpios = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>; - gpio-fan,speed-map = - < 0 0>, - <4500 1>; - pinctrl-names = "default"; - pinctrl-0 = <&fan_en_h>; - #cooling-cells = <2>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - leds { - compatible = "gpio-leds"; - - led-work { - label = "work-led"; - default-state = "off"; - gpios = <&gpio0 RK_PD3 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&work_led_enable_h>; - retain-state-suspended; - }; - - led-diy { - label = "diy-led"; - default-state = "on"; - gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&diy_led_enable_h>; - retain-state-suspended; - }; - }; - - rk817-sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,name = "Analog RK817"; - simple-audio-card,mclk-fs = <256>; - - simple-audio-card,cpu { - sound-dai = <&i2s1_8ch>; - }; - - simple-audio-card,codec { - sound-dai = <&rk817>; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk817 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - post-power-on-delay-ms = <100>; - power-off-delay-us = <5000000>; - reset-gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_LOW>; - }; - - spdif_dit: spdif-dit { - compatible = "linux,spdif-dit"; - #sound-dai-cells = <0>; - }; - - spdif_sound: spdif-sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "SPDIF"; - - simple-audio-card,cpu { - sound-dai = <&spdif>; - }; - - simple-audio-card,codec { - sound-dai = <&spdif_dit>; - }; - }; - - vcc12v_dcin: vcc12v_dcin { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - /* vbus feeds the rk817 usb input. - * With no battery attached, also feeds vcc_bat+ - * via ON/OFF_BAT jumper - */ - vbus: vbus { - compatible = "regulator-fixed"; - regulator-name = "vbus"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc3v3_pcie_p: vcc3v3-pcie-p-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_enable_h>; - regulator-name = "vcc3v3_pcie_p"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_3v3>; - }; - - vcc5v0_usb: vcc5v0_usb { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - /* all four ports are controlled by one gpio - * the host ports are sourced from vcc5v0_usb - * the otg port is sourced from vcc5v0_midu - */ - vcc5v0_usb20_host: vcc5v0_usb20_host { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb20_host_en>; - regulator-name = "vcc5v0_usb20_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_usb20_otg: vcc5v0_usb20_otg { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>; - regulator-name = "vcc5v0_usb20_otg"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dcdc_boost>; - }; - - vcc3v3_sd: vcc3v3_sd { - compatible = "regulator-fixed"; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc_sd_h>; - regulator-boot-on; - regulator-name = "vcc3v3_sd"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_3v3>; - }; - - /* sourced from vbus and vcc_bat+ via rk817 sw5 */ - vcc_sys: vcc_sys { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <4400000>; - regulator-max-microvolt = <4400000>; - vin-supply = <&vbus>; - }; - - /* sourced from vcc_sys, sdio module operates internally at 3.3v */ - vcc_wl: vcc_wl { - compatible = "regulator-fixed"; - regulator-name = "vcc_wl"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_sys>; - }; -}; - -&combphy1 { - status = "okay"; -}; - -&combphy2 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu_thermal { - trips { - cpu_hot: cpu_hot { - temperature = <55000>; - hysteresis = <2000>; - type = "active"; - }; - }; - - cooling-maps { - map1 { - trip = <&cpu_hot>; - cooling-device = <&fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; -}; - -&gmac1 { - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>, <&gmac1_clkin>; - clock_in_out = "input"; - phy-supply = <&vcc_3v3>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m0_miim - &gmac1m0_tx_bus2 - &gmac1m0_rx_bus2 - &gmac1m0_rgmii_clk - &gmac1m0_clkinout - &gmac1m0_rgmii_bus>; - snps,reset-gpio = <&gpio0 RK_PC3 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f */ - snps,reset-delays-us = <0 20000 100000>; - tx_delay = <0x30>; - rx_delay = <0x10>; - phy-handle = <&rgmii_phy1>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda_0v9>; - avdd-1v8-supply = <&vcc_1v8>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk817: pmic@20 { - compatible = "rockchip,rk817"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - #clock-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>, <&i2s1m0_mclk>; - rockchip,system-power-controller; - #sound-dai-cells = <0>; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - vcc8-supply = <&vcc_sys>; - vcc9-supply = <&dcdc_boost>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_logic"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_gpu"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc_3v3: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-initial-mode = <0x2>; - regulator-name = "vcc_3v3"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca1v8_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda_0v9"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda0v9_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_acodec"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc3v3_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_1v8: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc_1v8"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_dvp: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcc1v8_dvp"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc2v8_dvp: LDO_REG9 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-name = "vcc2v8_dvp"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - dcdc_boost: BOOST { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - regulator-name = "boost"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - otg_switch: OTG_SWITCH { - regulator-name = "otg_switch"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -/* i2c3 is exposed on con40 - * pin 3 - i2c3_sda_m0, pullup to vcc_3v3 - * pin 5 - i2c3_scl_m0, pullup to vcc_3v3 - */ -&i2c3 { - status = "okay"; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&i2s1_8ch { - pinctrl-names = "default"; - pinctrl-0 = <&i2s1m0_sclktx - &i2s1m0_lrcktx - &i2s1m0_sdi0 - &i2s1m0_sdo0>; - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&mdio1 { - rgmii_phy1: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - }; -}; - -&pcie2x1 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie_reset_h>; - reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie_p>; - status = "okay"; -}; - -&pinctrl { - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - fan { - fan_en_h: fan-en-h { - rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - work_led_enable_h: work-led-enable-h { - rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - diy_led_enable_h: diy-led-enable-h { - rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_enable_h: pcie-enable-h { - rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_reset_h: pcie-reset-h { - rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb2 { - vcc5v0_usb20_host_en: vcc5v0-usb20-host-en { - rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - vcc_sd { - vcc_sd_h: vcc-sd-h { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc1v8_dvp>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&sdmmc1 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk>; - sd-uhs-sdr104; - vmmc-supply = <&vcc_wl>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sfc { - pinctrl-0 = <&fspi_pins>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <24000000>; - spi-rx-bus-width = <4>; - spi-tx-bus-width = <1>; - }; -}; - -/* spdif is exposed on con40 pin 18 */ -&spdif { - status = "okay"; -}; - -/* spi1 is exposed on con40 - * pin 11 - spi1_mosi_m1 - * pin 13 - spi1_miso_m1 - * pin 15 - spi1_clk_m1 - * pin 17 - spi1_cs0_m1 - */ -&spi1 { - pinctrl-names = "default"; - pinctrl-0 = <&spi1m1_cs0 &spi1m1_pins>; -}; - -&tsadc { - /* tshut mode 0:CRU 1:GPIO */ - rockchip,hw-tshut-mode = <1>; - /* tshut polarity 0:LOW 1:HIGH */ - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -/* uart0 is exposed on con40 - * pin 12 - uart0_tx - * pin 14 - uart0_rx - */ -&uart0 { - pinctrl-names = "default"; - pinctrl-0 = <&uart0_xfer>; - status = "okay"; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>; - status = "okay"; - uart-has-rtscts; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk817 1>; - clock-names = "lpo"; - host-wakeup-gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>; - device-wakeup-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc_sys>; - vddio-supply = <&vcca1v8_pmu>; - max-speed = <3000000>; - }; -}; - -/* uart2 is exposed on con40 - * pin 8 - uart2_tx_m0_debug - * pin 10 - uart2_rx_m0_debug - */ -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - dr_mode = "host"; - status = "okay"; -}; - -/* usb3 controller is muxed with sata1 */ -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb20_host>; - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_usb20_otg>; - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_host { - phy-supply = <&vcc5v0_usb20_host>; - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc5v0_usb20_host>; - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3566-quartz64-b.dts b/arch/arm/dts/rk3566-quartz64-b.dts deleted file mode 100644 index 2d92713be2a0..000000000000 --- a/arch/arm/dts/rk3566-quartz64-b.dts +++ /dev/null @@ -1,737 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi" - -/ { - model = "Pine64 RK3566 Quartz64-B Board"; - compatible = "pine64,quartz64-b", "rockchip,rk3566"; - - aliases { - ethernet0 = &gmac1; - mmc0 = &sdmmc0; - mmc1 = &sdhci; - mmc2 = &sdmmc1; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac1_clkin: external-gmac1-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac1_clkin"; - #clock-cells = <0>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - leds { - compatible = "gpio-leds"; - - led-user { - label = "user-led"; - default-state = "on"; - gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&user_led_enable_h>; - retain-state-suspended; - }; - }; - - sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,name = "Analog RK809"; - simple-audio-card,mclk-fs = <256>; - - simple-audio-card,cpu { - sound-dai = <&i2s1_8ch>; - }; - - simple-audio-card,codec { - sound-dai = <&rk809>; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - status = "okay"; - compatible = "mmc-pwrseq-simple"; - clocks = <&rk809 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_LOW>; - post-power-on-delay-ms = <100>; - power-off-delay-us = <5000000>; - }; - - vcc3v3_pcie_p: vcc3v3-pcie-p-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_enable_h>; - regulator-name = "vcc3v3_pcie_p"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc_3v3>; - }; - - vcc5v0_in: vcc5v0-in-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_in"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_in>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-always-on; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_usb30_host: vcc5v0-usb30-host-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb30_host"; - enable-active-high; - gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb30_host_en_h>; - regulator-always-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb_otg"; - enable-active-high; - gpio = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_otg_en_h>; - regulator-always-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&combphy1 { - status = "okay"; -}; - -&combphy2 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gmac1 { - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>, <&gmac1_clkin>; - clock_in_out = "input"; - phy-mode = "rgmii"; - phy-supply = <&vcc_3v3>; - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m1_miim - &gmac1m1_tx_bus2 - &gmac1m1_rx_bus2 - &gmac1m1_rgmii_clk - &gmac1m1_clkinout - &gmac1m1_rgmii_bus>; - snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f, also works well here */ - snps,reset-delays-us = <0 20000 100000>; - tx_delay = <0x4f>; - rx_delay = <0x24>; - phy-handle = <&rgmii_phy1>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>, <&i2s1m0_mclk>; - rockchip,system-power-controller; - #sound-dai-cells = <0>; - wakeup-source; - #clock-cells = <1>; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - - regulators { - vdd_log: DCDC_REG1 { - regulator-name = "vdd_log"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <1350000>; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-boot-on; - regulator-name = "vcc_3v3"; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - }; - }; - }; -}; - -/* i2c2_m1 exposed on csi port, pulled up to vcc_3v3 */ -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2m1_xfer>; - status = "okay"; -}; - -/* i2c3_m1 exposed on dsi port, pulled up to vcc_3v3 */ -&i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c3m1_xfer>; - status = "okay"; -}; - -/* - * i2c4_m0 is exposed on PI40, pulled up to vcc_3v3 - * pin 27 - i2c4_sda_m0 - * pin 28 - i2c4_scl_m0 - */ -&i2c4 { - status = "okay"; -}; - -/* - * i2c5_m0 is exposed on PI40 - * pin 29 - i2c5_scl_m0 - * pin 31 - i2c5_sda_m0 - */ -&i2c5 { - status = "disabled"; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&i2s1_8ch { - pinctrl-names = "default"; - pinctrl-0 = <&i2s1m0_sclktx - &i2s1m0_lrcktx - &i2s1m0_sdi0 - &i2s1m0_sdo0>; - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&mdio1 { - rgmii_phy1: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x1>; - }; -}; - -&pcie2x1 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie_reset_h>; - reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie_p>; - status = "okay"; -}; - -&pinctrl { - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - user_led_enable_h: user-led-enable-h { - rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_enable_h: pcie-enable-h { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_reset_h: pcie-reset-h { - rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic_int { - rockchip,pins = - <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <0 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - vcc5v0_usb30_host_en_h: vcc5v0-usb30-host-en_h { - rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_usb_otg_en_h: vcc5v0-usb-otg-en_h { - rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - status = "okay"; - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcca1v8_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcca1v8_pmu>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_3v3>; - vccio7-supply = <&vcc_3v3>; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - sd-uhs-sdr50; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&sdmmc1 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk>; - vmmc-supply = <&vcc3v3_sys>; - vqmmc-supply = <&vcca1v8_pmu>; - status = "okay"; -}; - -&sfc { - pinctrl-0 = <&fspi_pins>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <24000000>; - spi-rx-bus-width = <4>; - spi-tx-bus-width = <1>; - }; -}; - -&tsadc { - status = "okay"; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>; - status = "okay"; - uart-has-rtscts; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk809 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcca1v8_pmu>; - }; -}; - -/* - * uart2_m0 is exposed on PI40 - * pin 8 - uart2_tx_m0 - * pin 10 - uart2_rx_m0 - */ -&uart2 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb30_host>; - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_usb_otg>; - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc5v0_usb30_host>; - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb_host0_xhci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3566-radxa-cm3-io.dts b/arch/arm/dts/rk3566-radxa-cm3-io.dts deleted file mode 100644 index 3ae24e39450a..000000000000 --- a/arch/arm/dts/rk3566-radxa-cm3-io.dts +++ /dev/null @@ -1,281 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2022 Radxa Limited - * Copyright (c) 2022 Amarula Solutions(India) - */ - -/dts-v1/; -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi" -#include "rk3566-radxa-cm3.dtsi" - -/ { - model = "Radxa Compute Module 3(CM3) IO Board"; - compatible = "radxa,cm3-io", "radxa,cm3", "rockchip,rk3566"; - - aliases { - ethernet0 = &gmac1; - mmc1 = &sdmmc0; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac1_clkin: external-gmac1-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac1_clkin"; - #clock-cells = <0>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - leds { - compatible = "gpio-leds"; - - led-1 { - gpios = <&gpio4 RK_PA4 GPIO_ACTIVE_LOW>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_ACTIVITY; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&pi_nled_activity>; - }; - }; - - vcc5v0_usb30: vcc5v0-usb30-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb30"; - enable-active-high; - gpio = <&gpio3 RK_PC2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb30_en_h>; - regulator-always-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc_sys>; - }; - - vcca1v8_image: vcca1v8-image-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcca1v8_image"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8_p>; - }; - - vdda0v9_image: vdda0v9-image-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcca0v9_image"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vdda_0v9>; - }; -}; - -&combphy1 { - status = "okay"; -}; - -&gmac1 { - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>; - assigned-clock-rates = <0>, <125000000>; - clock_in_out = "input"; - phy-handle = <&rgmii_phy1>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m0_miim - &gmac1m0_tx_bus2 - &gmac1m0_rx_bus2 - &gmac1m0_rgmii_clk - &gmac1m0_rgmii_bus - &gmac1m0_clkinout>; - snps,reset-gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f */ - snps,reset-delays-us = <0 20000 100000>; - tx_delay = <0x46>; - rx_delay = <0x2e>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&mdio1 { - rgmii_phy1: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - }; -}; - -&pinctrl { - gmac1 { - gmac1m0_miim: gmac1m0-miim { - rockchip,pins = - /* gmac1_mdcm0 */ - <3 RK_PC4 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_mdiom0 */ - <3 RK_PC5 3 &pcfg_pull_none_drv_level_15>; - }; - - gmac1m0_rx_bus2: gmac1m0-rx-bus2 { - rockchip,pins = - /* gmac1_rxd0m0 */ - <3 RK_PB1 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_rxd1m0 */ - <3 RK_PB2 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_rxdvcrsm0 */ - <3 RK_PB3 3 &pcfg_pull_none_drv_level_15>; - }; - - gmac1m0_tx_bus2: gmac1m0-tx-bus2 { - rockchip,pins = - /* gmac1_txd0m0 */ - <3 RK_PB5 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_txd1m0 */ - <3 RK_PB6 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_txenm0 */ - <3 RK_PB7 3 &pcfg_pull_none_drv_level_15>; - }; - - gmac1m0_rgmii_clk: gmac1m0-rgmii-clk { - rockchip,pins = - /* gmac1_rxclkm0 */ - <3 RK_PA7 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_txclkm0 */ - <3 RK_PA6 3 &pcfg_pull_none_drv_level_15>; - }; - - gmac1m0_rgmii_bus: gmac1m0-rgmii-bus { - rockchip,pins = - /* gmac1_rxd2m0 */ - <3 RK_PA4 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_rxd3m0 */ - <3 RK_PA5 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_txd2m0 */ - <3 RK_PA2 3 &pcfg_pull_none_drv_level_15>, - /* gmac1_txd3m0 */ - <3 RK_PA3 3 &pcfg_pull_none_drv_level_15>; - }; - - gmac1m0_clkinout: gmac1m0-clkinout { - rockchip,pins = - /* gmac1_mclkinoutm0 */ - <3 RK_PC0 3 &pcfg_pull_none_drv_level_15>; - }; - }; - - leds { - pi_nled_activity: pi-nled-activity { - rockchip,pins = <4 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdcard { - sdmmc_pwren: sdmmc-pwren { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - vcc5v0_usb30_en_h: vcc5v0-host-en-h { - rockchip,pins = <3 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&sdmmc0 { - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; - vqmmc-supply = <&vccio_sd>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det &sdmmc0_pwren>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb30>; - status = "okay"; -}; - -&usb2phy1_host { - status = "okay"; -}; - -&usb2phy1_otg { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0_otg { - status = "okay"; -}; - -&usb_host0_xhci { - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3566-radxa-cm3.dtsi b/arch/arm/dts/rk3566-radxa-cm3.dtsi deleted file mode 100644 index 45de2630bb50..000000000000 --- a/arch/arm/dts/rk3566-radxa-cm3.dtsi +++ /dev/null @@ -1,425 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2022 Radxa Limited - * Copyright (c) 2022 Amarula Solutions(India) - */ - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> - -/ { - compatible = "radxa,cm3", "rockchip,rk3566"; - - aliases { - mmc0 = &sdhci; - }; - - leds { - compatible = "gpio-leds"; - - led-0 { - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_STATUS; - linux,default-trigger = "timer"; - default-state = "on"; - pinctrl-names = "default"; - pinctrl-0 = <&user_led2>; - }; - }; - - vcc_sys: vcc-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc_1v8: vcc-1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8_p>; - }; - - vcc_3v3: vcc-3v3-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcca_1v8: vcca-1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc_1v8_p>; - }; - - sdio_pwrseq: pwrseq-sdio { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk817 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_reg_on_h>; - reset-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_LOW>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gpu { - mali-supply = <&vdd_gpu_npu>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <712500>; - regulator-max-microvolt = <1390000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk817: pmic@20 { - compatible = "rockchip,rk817"; - reg = <0x20>; - #clock-cells = <1>; - clock-output-names = "rk817-clkout1", "rk817-clkout2"; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc_sys>; - vcc2-supply = <&vcc_sys>; - vcc3-supply = <&vcc_sys>; - vcc4-supply = <&vcc_sys>; - vcc5-supply = <&vcc_sys>; - vcc6-supply = <&vcc_sys>; - vcc7-supply = <&vcc_sys>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_gpu_npu: DCDC_REG2 { - regulator-name = "vdd_gpu_npu"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vcc3v3_sys: DCDC_REG4 { - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca1v8_pmu: LDO_REG1 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcc_1v8_p: LDO_REG7 { - regulator-name = "vcc_1v8_p"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc1v8_dvp: LDO_REG8 { - regulator-name = "vcc1v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc2v8_dvp: LDO_REG9 { - regulator-name = "vcc2v8_dvp"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <2800000>; - regulator-max-microvolt = <2800000>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - }; - }; -}; - -&pinctrl { - bluetooth { - bt_host_wake_h: bt-host-wake-h { - rockchip,pins = <2 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_reg_on_h: bt-reg-on-h { - rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_wake_host_h: bt-wake-host-h { - rockchip,pins = <2 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - user_led2: user-led2 { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - wifi { - wifi_reg_on_h: wifi-reg-on-h { - rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wifi_host_wake_h: wifi-host-wake-h { - rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc_3v3>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_3v3>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sdmmc1 { - #address-cells = <1>; - #size-cells = <0>; - bus-width = <4>; - disable-wp; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_clk &sdmmc1_cmd>; - sd-uhs-sdr104; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; - - wifi@1 { - compatible = "brcm,bcm43455-fmac"; - reg = <1>; - interrupt-parent = <&gpio2>; - interrupts = <RK_PC1 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "host-wake"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_host_wake_h>; - }; -}; - -&sdhci { - bus-width = <8>; - max-frequency = <200000000>; - mmc-hs200-1_8v; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&uart1m0_ctsn &uart1m0_rtsn &uart1m0_xfer>; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm4345c5"; - clocks = <&rk817 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PB2 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio2 RK_PB1 GPIO_ACTIVE_HIGH>; - reset-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_h &bt_reg_on_h &bt_wake_host_h>; - vbat-supply = <&vcc_3v3>; - vddio-supply = <&vcc_1v8>; - }; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3566-soquartz-blade.dts b/arch/arm/dts/rk3566-soquartz-blade.dts deleted file mode 100644 index fdbf1c783242..000000000000 --- a/arch/arm/dts/rk3566-soquartz-blade.dts +++ /dev/null @@ -1,198 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> - -#include "rk3566-soquartz.dtsi" - -/ { - model = "PINE64 RK3566 SOQuartz on Blade carrier board"; - compatible = "pine64,soquartz-blade", "pine64,soquartz", "rockchip,rk3566"; - - aliases { - ethernet0 = &gmac1; - }; - - /* labeled VCC3V0_SD in schematic to not conflict with PMIC regulator */ - vcc3v0_sd: vcc3v0-sd-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v0_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - /* labeled VCC_SSD in schematic */ - vcc3v3_pcie_p: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pcie_p"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vbus>; - }; - - vcc5v_dcin: vcc5v-dcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; -}; - -&combphy2 { - phy-supply = <&vcc3v3_sys>; - status = "okay"; -}; - -&gmac1 { - status = "okay"; -}; - -/* - * i2c1 is exposed on CM1 / Module1A - * pin 80 - SCL0 - i2c1_scl_m0, pullup to vcc3v3_pmu - * pin 82 - SDA0 - i2c1_sda_m0, pullup to vcc3v3_pmu - */ -&i2c1 { - status = "okay"; - -}; - -/* - * i2c2 is exposed on CM1 / Module1A - to PI40 - * pin 56 - GPIO3 - i2c2_scl_m1, pullup to vcc_3v3, shared with i2s1_8ch - * pin 58 - GPIO2 - i2c2_sda_m1, pullup to vcc_3v3 - */ -&i2c2 { - status = "disabled"; -}; - -/* - * i2c3 is exposed on CM1 / Module1A - to PI40 - * pin 35 - ID_SC(GPIO28) - i2c3_scl_m0, pullup to vcc_3v3 - * pin 36 - ID_SD(GPIO27) - i2c3_sda_m0, pullup to vcc_3v3 - */ -&i2c3 { - status = "disabled"; -}; - -/* - * i2c4 is exposed on CM2 / Module1B - to PI40 - * pin 45 - GPIO24 - i2c4_scl_m1 - * pin 47 - GPIO23 - i2c4_sda_m1 - */ -&i2c4 { - status = "disabled"; -}; - -/* - * i2s1_8ch is exposed on CM1 / Module1A - to PI40 - * pin 24 - GPIO26 - i2s1_sdi1_m1 - * pin 25 - GPIO21 - i2s1_sdo0_m1 - * pin 26 - GPIO19 - i2s1_lrck_tx_m1 - * pin 27 - GPIO20 - i2s1_sdi0_m1 - * pin 29 - GPIO16 - i2s1_sdi3_m1 - * pin 30 - GPIO6 - i2s1_sdi2_m1 - * pin 40 - GPIO9 - i2s1_sdo1_m1, shared with spi3 - * pin 41 - GPIO25 - i2s1_sdo2_m1 - * pin 49 - GPIO18 - i2s1_sclk_tx_m1 - * pin 50 - GPIO17 - i2s1_mclk_m1 - * pin 56 - GPIO3 - i2s1_sdo3_m1, shared with i2c2 - */ -&i2s1_8ch { - status = "disabled"; -}; - -&led_diy { - color = <LED_COLOR_ID_RED>; - function = LED_FUNCTION_DISK_ACTIVITY; - linux,default-trigger = "disk-activity"; - status = "okay"; -}; - -&led_work { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_STATUS; - linux,default-trigger = "heartbeat"; - status = "okay"; -}; - -&pcie2x1 { - vpcie3v3-supply = <&vcc3v3_pcie_p>; - status = "okay"; -}; - -&rgmii_phy1 { - status = "okay"; -}; - -/* - * saradc is exposed on CM1 / Module1A - to J2 - * pin 94 - AIN1 - saradc_vin3 - * pin 96 - AIN0 - saradc_vin2 - */ -&saradc { - status = "disabled"; -}; - -&sdmmc0 { - vmmc-supply = <&vcc3v0_sd>; - status = "okay"; -}; - -/* - * spi3 is exposed on CM1 / Module1A - to PI40 - * pin 37 - GPIO7 - spi3_cs1_m0 - * pin 38 - GPIO11 - spi3_clk_m0 - * pin 39 - GPIO8 - spi3_cs0_m0 - * pin 40 - GPIO9 - spi3_miso_m0, shared with i2s1_8ch - * pin 44 - GPIO10 - spi3_mosi_m0 - */ -&spi3 { - status = "disabled"; -}; - -/* - * uart2 is exposed on CM1 / Module1A - to PI40 - * pin 51 - GPIO15 - uart2_rx_m0 - * pin 55 - GPIO14 - uart2_tx_m0 - */ -&uart2 { - status = "okay"; -}; - -/* - * uart7 is exposed on CM1 / Module1A - to PI40 - * pin 46 - GPIO22 - uart7_tx_m2 - * pin 47 - GPIO23 - uart7_rx_m2 - */ -&uart7 { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vbus>; - status = "okay"; -}; - -&usb_host0_xhci { - status = "okay"; -}; - -&vbus { - vin-supply = <&vcc5v_dcin>; -}; diff --git a/arch/arm/dts/rk3566-soquartz-cm4.dts b/arch/arm/dts/rk3566-soquartz-cm4.dts deleted file mode 100644 index 6ed3fa4aee34..000000000000 --- a/arch/arm/dts/rk3566-soquartz-cm4.dts +++ /dev/null @@ -1,196 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include "rk3566-soquartz.dtsi" - -/ { - model = "Pine64 RK3566 SoQuartz with CM4-IO Carrier Board"; - compatible = "pine64,soquartz-cm4io", "pine64,soquartz", "rockchip,rk3566"; - - aliases { - ethernet0 = &gmac1; - }; - - /* labeled +12v in schematic */ - vcc12v_dcin: vcc12v-dcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - /* labeled +5v in schematic */ - vcc_5v: vcc-5v-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_5v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc_sd_pwr: vcc-sd-pwr-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc_sd_pwr"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; -}; - -/* phy for pcie */ -&combphy2 { - phy-supply = <&vcc3v3_sys>; - status = "okay"; -}; - -&gmac1 { - status = "okay"; -}; - -/* - * i2c1 is exposed on CM1 / Module1A - * pin 80 - SCL0 - i2c1_scl_m0, pullup to vcc3v3_pmu - * pin 82 - SDA0 - i2c1_sda_m0, pullup to vcc3v3_pmu - */ -&i2c1 { - status = "okay"; - - /* - * the rtc interrupt is tied to PMIC_PWRON, - * it will force reset the board if triggered. - */ - pcf85063: rtc@51 { - compatible = "nxp,pcf85063"; - reg = <0x51>; - }; -}; - -/* - * i2c2 is exposed on CM1 / Module1A - to PI40 - * pin 56 - GPIO3 - i2c2_scl_m1, pullup to vcc_3v3, shared with i2s1_8ch - * pin 58 - GPIO2 - i2c2_sda_m1, pullup to vcc_3v3 - */ -&i2c2 { - status = "disabled"; -}; - -/* - * i2c3 is exposed on CM1 / Module1A - to PI40 - * pin 35 - ID_SC(GPIO28) - i2c3_scl_m0, pullup to vcc_3v3 - * pin 36 - ID_SD(GPIO27) - i2c3_sda_m0, pullup to vcc_3v3 - */ -&i2c3 { - status = "disabled"; -}; - -/* - * i2c4 is exposed on CM2 / Module1B - to PI40 - * pin 45 - GPIO24 - i2c4_scl_m1 - * pin 47 - GPIO23 - i2c4_sda_m1 - */ -&i2c4 { - status = "disabled"; -}; - -/* - * i2s1_8ch is exposed on CM1 / Module1A - to PI40 - * pin 24 - GPIO26 - i2s1_sdi1_m1 - * pin 25 - GPIO21 - i2s1_sdo0_m1 - * pin 26 - GPIO19 - i2s1_lrck_tx_m1 - * pin 27 - GPIO20 - i2s1_sdi0_m1 - * pin 29 - GPIO16 - i2s1_sdi3_m1 - * pin 30 - GPIO6 - i2s1_sdi2_m1 - * pin 40 - GPIO9 - i2s1_sdo1_m1, shared with spi3 - * pin 41 - GPIO25 - i2s1_sdo2_m1 - * pin 49 - GPIO18 - i2s1_sclk_tx_m1 - * pin 50 - GPIO17 - i2s1_mclk_m1 - * pin 56 - GPIO3 - i2s1_sdo3_m1, shared with i2c2 - */ -&i2s1_8ch { - status = "disabled"; -}; - -&led_diy { - status = "okay"; -}; - -&led_work { - status = "okay"; -}; - -&pcie2x1 { - vpcie3v3-supply = <&vcc_3v3>; - status = "okay"; -}; - -&rgmii_phy1 { - status = "okay"; -}; - -/* - * saradc is exposed on CM1 / Module1A - to J2 - * pin 94 - AIN1 - saradc_vin3 - * pin 96 - AIN0 - saradc_vin2 - */ -&saradc { - status = "disabled"; -}; - -&sdmmc0 { - vmmc-supply = <&vcc_sd_pwr>; - status = "okay"; -}; - -/* - * spi3 is exposed on CM1 / Module1A - to PI40 - * pin 37 - GPIO7 - spi3_cs1_m0 - * pin 38 - GPIO11 - spi3_clk_m0 - * pin 39 - GPIO8 - spi3_cs0_m0 - * pin 40 - GPIO9 - spi3_miso_m0, shared with i2s1_8ch - * pin 44 - GPIO10 - spi3_mosi_m0 - */ -&spi3 { - status = "disabled"; -}; - -/* - * uart2 is exposed on CM1 / Module1A - to PI40 - * pin 51 - GPIO15 - uart2_rx_m0 - * pin 55 - GPIO14 - uart2_tx_m0 - */ -&uart2 { - status = "okay"; -}; - -/* - * uart7 is exposed on CM1 / Module1A - to PI40 - * pin 46 - GPIO22 - uart7_tx_m2 - * pin 47 - GPIO23 - uart7_rx_m2 - */ -&uart7 { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc_5v>; - status = "okay"; -}; - -&usb_host0_xhci { - status = "okay"; -}; - -&vbus { - vin-supply = <&vcc_5v>; -}; diff --git a/arch/arm/dts/rk3566-soquartz-model-a.dts b/arch/arm/dts/rk3566-soquartz-model-a.dts deleted file mode 100644 index f2095dfa4eaf..000000000000 --- a/arch/arm/dts/rk3566-soquartz-model-a.dts +++ /dev/null @@ -1,236 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include "rk3566-soquartz.dtsi" - -/ { - model = "PINE64 RK3566 SOQuartz on Model A carrier board"; - compatible = "pine64,soquartz-model-a", "pine64,soquartz", "rockchip,rk3566"; - - aliases { - ethernet0 = &gmac1; - }; - - /* labeled DCIN_12V in schematic */ - vcc12v_dcin: vcc12v-dcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - vcc5v0_usb: vcc5v0-usb-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - /* - * Labelled VCC3V0_SD in schematic to not conflict with PMIC - * regulator, it's 3.3v in actuality - */ - vcc3v0_sd: vcc3v0-sd-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v0_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pcie"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc12v_pcie: vcc12v-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_pcie"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - vin-supply = <&vcc12v_dcin>; - }; -}; - -/* phy for pcie */ -&combphy2 { - phy-supply = <&vcc3v3_sys>; - status = "okay"; -}; - -&gmac1 { - status = "okay"; -}; - -/* - * i2c1 is exposed on CM1 / Module1A - * pin 80 - SCL0 - i2c1_scl_m0, pullup to vcc3v3_pmu - * pin 82 - SDA0 - i2c1_sda_m0, pullup to vcc3v3_pmu - */ -&i2c1 { - status = "okay"; - - /* - * the rtc interrupt is tied to PMIC_PWRON, - * it will force reset the board if triggered. - */ - pcf85063: rtc@51 { - compatible = "nxp,pcf85063"; - reg = <0x51>; - }; -}; - -/* - * i2c2 is exposed on CM1 / Module1A - to PI40 - * pin 56 - GPIO3 - i2c2_scl_m1, pullup to vcc_3v3, shared with i2s1_8ch - * pin 58 - GPIO2 - i2c2_sda_m1, pullup to vcc_3v3 - */ -&i2c2 { - status = "disabled"; -}; - -/* - * i2c3 is exposed on CM1 / Module1A - to PI40 - * pin 35 - ID_SC(GPIO28) - i2c3_scl_m0, pullup to vcc_3v3 - * pin 36 - ID_SD(GPIO27) - i2c3_sda_m0, pullup to vcc_3v3 - */ -&i2c3 { - status = "disabled"; -}; - -/* - * i2c4 is exposed on CM2 / Module1B - to PI40 - * pin 45 - GPIO24 - i2c4_scl_m1 - * pin 47 - GPIO23 - i2c4_sda_m1 - */ -&i2c4 { - status = "disabled"; -}; - -/* - * i2s1_8ch is exposed on CM1 / Module1A - to PI40 - * pin 24 - GPIO26 - i2s1_sdi1_m1 - * pin 25 - GPIO21 - i2s1_sdo0_m1 - * pin 26 - GPIO19 - i2s1_lrck_tx_m1 - * pin 27 - GPIO20 - i2s1_sdi0_m1 - * pin 29 - GPIO16 - i2s1_sdi3_m1 - * pin 30 - GPIO6 - i2s1_sdi2_m1 - * pin 40 - GPIO9 - i2s1_sdo1_m1, shared with spi3 - * pin 41 - GPIO25 - i2s1_sdo2_m1 - * pin 49 - GPIO18 - i2s1_sclk_tx_m1 - * pin 50 - GPIO17 - i2s1_mclk_m1 - * pin 56 - GPIO3 - i2s1_sdo3_m1, shared with i2c2 - */ -&i2s1_8ch { - status = "disabled"; -}; - -&led_diy { - status = "okay"; -}; - -&led_work { - status = "okay"; -}; - -&pcie2x1 { - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&rgmii_phy1 { - status = "okay"; -}; - -&rgmii_phy1 { - status = "okay"; -}; - -/* - * saradc is exposed on CM1 / Module1A - to J2 - * pin 94 - AIN1 - saradc_vin3 - * pin 96 - AIN0 - saradc_vin2 - */ -&saradc { - status = "disabled"; -}; - -/* - * vmmc-supply is vcc3v3_sd on v1.0 and vcc3v0_sd on v1.1+ - * the soquartz SoM has SDMMC_PWR (CM1 pin 75) hardwired to vcc3v3_sys, - * so we use vcc3v3_sd here to ensure the regulator is enabled on older boards. - */ -&sdmmc0 { - vmmc-supply = <&vcc3v3_sd>; - status = "okay"; -}; - -/* - * spi3 is exposed on CM1 / Module1A - to PI40 - * pin 37 - GPIO7 - spi3_cs1_m0 - * pin 38 - GPIO11 - spi3_clk_m0 - * pin 39 - GPIO8 - spi3_cs0_m0 - * pin 40 - GPIO9 - spi3_miso_m0, shared with i2s1_8ch - * pin 44 - GPIO10 - spi3_mosi_m0 - */ -&spi3 { - status = "disabled"; -}; - -/* - * uart2 is exposed on CM1 / Module1A - to PI40 - * pin 51 - GPIO15 - uart2_rx_m0 - * pin 55 - GPIO14 - uart2_tx_m0 - */ -&uart2 { - status = "okay"; -}; - -/* - * uart7 is exposed on CM1 / Module1A - to PI40 - * pin 46 - GPIO22 - uart7_tx_m2 - * pin 47 - GPIO23 - uart7_rx_m2 - */ -&uart7 { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_usb>; - status = "okay"; -}; - -&usb_host0_xhci { - status = "okay"; -}; - -&vbus { - vin-supply = <&vcc5v0_usb>; -}; - -&vcc3v3_sd { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3566-soquartz.dtsi b/arch/arm/dts/rk3566-soquartz.dtsi deleted file mode 100644 index bfb7b952f4c5..000000000000 --- a/arch/arm/dts/rk3566-soquartz.dtsi +++ /dev/null @@ -1,684 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi" - -/ { - model = "Pine64 RK3566 SoQuartz SOM"; - compatible = "pine64,soquartz", "rockchip,rk3566"; - - aliases { - mmc0 = &sdmmc0; - mmc1 = &sdhci; - mmc2 = &sdmmc1; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - gmac1_clkin: external-gmac1-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac1_clkin"; - #clock-cells = <0>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - leds { - compatible = "gpio-leds"; - - led_diy: led-diy { - label = "diy-led"; - default-state = "on"; - gpios = <&gpio0 RK_PC1 GPIO_ACTIVE_LOW>; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&diy_led_enable_h>; - retain-state-suspended; - status = "disabled"; - }; - - led_work: led-work { - label = "work-led"; - default-state = "off"; - gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&work_led_enable_h>; - retain-state-suspended; - status = "disabled"; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - status = "okay"; - compatible = "mmc-pwrseq-simple"; - clocks = <&rk809 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable_h>; - reset-gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_LOW>; - }; - - vbus: vbus-regulator { - compatible = "regulator-fixed"; - regulator-name = "vbus"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - /* sourced from vbus, vbus is provided by the carrier board */ - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vbus>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gmac1 { - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>, <&gmac1_clkin>; - clock_in_out = "input"; - phy-supply = <&vcc_3v3>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m0_miim - &gmac1m0_tx_bus2 - &gmac1m0_rx_bus2 - &gmac1m0_rgmii_clk - &gmac1m0_clkinout - &gmac1m0_rgmii_bus>; - snps,reset-gpio = <&gpio0 RK_PC3 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f, also works well here */ - snps,reset-delays-us = <0 20000 100000>; - tx_delay = <0x30>; - rx_delay = <0x10>; - phy-handle = <&rgmii_phy1>; - status = "disabled"; -}; - -&gpio0 { - nextrst-hog { - gpio-hog; - /* - * GPIO_ACTIVE_LOW + output-low here means that the pin is set - * to high, because output-low decides the value pre-inversion. - */ - gpios = <RK_PA5 GPIO_ACTIVE_LOW>; - line-name = "nEXTRST"; - output-low; - }; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - regulator-always-on; - regulator-boot-on; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - clock-output-names = "rk808-clkout1", "rk808-clkout2"; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-name = "vcc_ddr"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-initial-mode = <0x2>; - regulator-name = "vdd_npu"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda0v9_image"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda_0v9"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - regulator-name = "vdda0v9_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_acodec"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vccio_sd"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - regulator-name = "vcc3v3_pmu"; - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca_1v8"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca1v8_pmu"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - regulator-name = "vcca1v8_image"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - status = "disabled"; - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - }; - }; -}; - -/* - * i2c1 is exposed on CM1 / Module1A - * pin 80 - i2c1_scl_m0, pullup to vcc3v3_pmu - * pin 82 - i2c1_sda_m0, pullup to vcc3v3_pmu - */ -&i2c1 { - status = "disabled"; -}; - -/* - * i2c2 is exposed on CM1 / Module1A - * pin 56 - i2c2_scl_m1, pullup to vcc_3v3, shared with i2s1_8ch - * pin 58 - i2c2_sda_m1, pullup to vcc_3v3 - */ -&i2c2 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c2m1_xfer>; - status = "disabled"; -}; - -/* - * i2c3 is exposed on CM1 / Module1A - * pin 35 - i2c3_scl_m0, pullup to vcc_3v3 - * pin 36 - i2c3_sda_m0, pullup to vcc_3v3 - */ -&i2c3 { - status = "disabled"; -}; - -/* - * i2c4 is exposed on CM2 / Module1B - * pin 45 - i2c4_scl_m1 - * pin 47 - i2c4_sda_m1 - */ -&i2c4 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c4m1_xfer>; - status = "disabled"; -}; - -&i2s0_8ch { - status = "okay"; -}; - -/* - * i2s1_8ch is exposed on CM1 / Module1A - * pin 24 - i2s1_sdi1_m1 - * pin 25 - i2s1_sdo0_m1 - * pin 26 - i2s1_lrck_tx_m1 - * pin 27 - i2s1_sdi0_m1 - * pin 29 - i2s1_sdi3_m1 - * pin 30 - i2s1_sdi2_m1 - * pin 40 - i2s1_sdo1_m1, shared with spi3 - * pin 41 - i2s1_sdo2_m1 - * pin 49 - i2s1_sclk_tx_m1 - * pin 50 - i2s1_mclk_m1 - * pin 56 - i2s1_sdo3_m1, shared with i2c2 - */ -&i2s1_8ch { - pinctrl-names = "default"; - pinctrl-0 = <&i2s1m1_sclktx &i2s1m1_sclkrx - &i2s1m1_lrcktx &i2s1m1_lrckrx - &i2s1m1_sdi0 &i2s1m1_sdi1 - &i2s1m1_sdi2 &i2s1m1_sdi3 - &i2s1m1_sdo0 &i2s1m1_sdo1 - &i2s1m1_sdo2 &i2s1m1_sdo3>; - status = "disabled"; -}; - -&mdio1 { - rgmii_phy1: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0>; - status = "disabled"; - }; -}; - -&pcie2x1 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie_reset_h>; - reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; -}; - -&pinctrl { - bt { - bt_enable_h: bt-enable-h { - rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake_l: bt-host-wake-l { - rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - bt_wake_l: bt-wake-l { - rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - work_led_enable_h: work-led-enable-h { - rockchip,pins = <0 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - diy_led_enable_h: diy-led-enable-h { - rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_clkreq_h: pcie-clkreq-h { - rockchip,pins = <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - pcie_reset_h: pcie-reset-h { - rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - sdio-pwrseq { - wifi_enable_h: wifi-enable-h { - rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vcc_3v3>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_3v3>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -/* - * saradc is exposed on CM1 / Module1A - * pin 94 - saradc_vin3 - * pin 96 - saradc_vin2 - */ -&saradc { - vref-supply = <&vcca_1v8>; - status = "disabled"; -}; - -&sdhci { - bus-width = <8>; - mmc-hs200-1_8v; - non-removable; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc0 { - broken-cd; - bus-width = <4>; - cap-sd-highspeed; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - vqmmc-supply = <&vccio_sd>; - status = "disabled"; -}; - -&sdmmc1 { - bus-width = <4>; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk>; - sd-uhs-sdr50; - vmmc-supply = <&vcc3v3_sys>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -/* - * spi3 is exposed on CM1 / Module1A - * pin 37 - spi3_cs1_m0 - * pin 38 - spi3_clk_m0 - * pin 39 - spi3_cs0_m0 - * pin 40 - spi3_miso_m0, shared with i2s1_8ch - * pin 44 - spi3_mosi_m0 - */ -&spi3 { - status = "disabled"; -}; - -&tsadc { - status = "okay"; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>; - uart-has-rtscts; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk809 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcca1v8_pmu>; - }; -}; - -/* - * uart2 is exposed on CM1 / Module1A - * pin 51 - uart2_rx_m0 - * pin 55 - uart2_tx_m0 - */ -&uart2 { - status = "disabled"; -}; - -/* - * uart7 is exposed on CM1 / Module1A - * pin 46 - uart7_tx_m2 - * pin 47 - uart7_rx_m2 - */ -&uart7 { - pinctrl-names = "default"; - pinctrl-0 = <&uart7m2_xfer>; - status = "disabled"; -}; - -/* dwc3_otg is the only usb port available */ -&usb2phy0 { - status = "disabled"; -}; - -&usb2phy0_otg { - status = "disabled"; -}; - -&usb_host0_xhci { - status = "disabled"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3566.dtsi b/arch/arm/dts/rk3566.dtsi deleted file mode 100644 index 6c4b17d27bdc..000000000000 --- a/arch/arm/dts/rk3566.dtsi +++ /dev/null @@ -1,35 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -#include "rk356x.dtsi" - -/ { - compatible = "rockchip,rk3566"; -}; - -&pipegrf { - compatible = "rockchip,rk3566-pipe-grf", "syscon"; -}; - -&power { - power-domain@RK3568_PD_PIPE { - reg = <RK3568_PD_PIPE>; - clocks = <&cru PCLK_PIPE>; - pm_qos = <&qos_pcie2x1>, - <&qos_sata1>, - <&qos_sata2>, - <&qos_usb3_0>, - <&qos_usb3_1>; - #power-domain-cells = <0>; - }; -}; - -&usb_host0_xhci { - phys = <&usb2phy0_otg>; - phy-names = "usb2-phy"; - extcon = <&usb2phy0>; - maximum-speed = "high-speed"; -}; - -&vop { - compatible = "rockchip,rk3566-vop"; -}; diff --git a/arch/arm/dts/rk3568-bpi-r2-pro.dts b/arch/arm/dts/rk3568-bpi-r2-pro.dts deleted file mode 100644 index f9127ddfbb7d..000000000000 --- a/arch/arm/dts/rk3568-bpi-r2-pro.dts +++ /dev/null @@ -1,852 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Author: Frank Wunderlich frank-w@public-files.de - * - */ - -/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi" - -/ { - model = "Bananapi-R2 Pro (RK3568) DDR4 Board"; - compatible = "rockchip,rk3568-bpi-r2pro", "rockchip,rk3568"; - - aliases { - ethernet0 = &gmac0; - ethernet1 = &gmac1; - mmc0 = &sdmmc0; - mmc1 = &sdhci; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&blue_led_pin &green_led_pin>; - - blue_led: led-0 { - color = <LED_COLOR_ID_BLUE>; - default-state = "off"; - function = LED_FUNCTION_STATUS; - gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>; - }; - - green_led: led-1 { - color = <LED_COLOR_ID_GREEN>; - default-state = "on"; - function = LED_FUNCTION_POWER; - gpios = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>; - }; - }; - - dc_12v: dc-12v-regulator { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PC2 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_receiver_pin>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - pcie30_avdd0v9: pcie30-avdd0v9-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; - - pcie30_avdd1v8: pcie30-avdd1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - }; - - /* pi6c pcie clock generator feeds both ports */ - vcc3v3_pi6c_05: vcc3v3-pi6c-05-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; - startup-delay-us = <200000>; - vin-supply = <&vcc5v0_sys>; - }; - - /* actually fed by vcc3v3_sys, dependent on pi6c clock generator */ - vcc3v3_minipcie: vcc3v3-minipcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_minipcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - gpio = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&minipcie_enable_h>; - startup-delay-us = <50000>; - vin-supply = <&vcc3v3_pi6c_05>; - }; - - /* actually fed by vcc3v3_sys, dependent on pi6c clock generator */ - vcc3v3_ngff: vcc3v3-ngff-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_ngff"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - gpio = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&ngffpcie_enable_h>; - startup-delay-us = <50000>; - vin-supply = <&vcc3v3_pi6c_05>; - }; - - vcc5v0_usb: vcc5v0-usb-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_usb_host: vcc5v0-usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_host_en>; - regulator-name = "vcc5v0_usb_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_otg_en>; - regulator-name = "vcc5v0_usb_otg"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; -}; - -&combphy0 { - /* used for USB3 */ - status = "okay"; -}; - -&combphy1 { - /* used for USB3 */ - status = "okay"; -}; - -&combphy2 { - /* used for SATA */ - status = "okay"; -}; - -&gmac0 { - assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; - assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>; - clock_in_out = "input"; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac0_miim - &gmac0_tx_bus2 - &gmac0_rx_bus2 - &gmac0_rgmii_clk - &gmac0_rgmii_bus>; - snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f */ - snps,reset-delays-us = <0 20000 100000>; - tx_delay = <0x4f>; - rx_delay = <0x0f>; - status = "okay"; - - fixed-link { - speed = <1000>; - full-duplex; - pause; - }; -}; - -&gmac1 { - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>; - clock_in_out = "output"; - phy-handle = <&rgmii_phy1>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m1_miim - &gmac1m1_tx_bus2 - &gmac1m1_rx_bus2 - &gmac1m1_rgmii_clk - &gmac1m1_rgmii_bus>; - - snps,reset-gpio = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f */ - snps,reset-delays-us = <0 20000 100000>; - - tx_delay = <0x3c>; - rx_delay = <0x2f>; - - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>; - rockchip,system-power-controller; - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - wakeup-source; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-always-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - regulator-always-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&i2c3 { - status = "okay"; - - hym8563: rtc@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PD3 IRQ_TYPE_EDGE_FALLING>; - #clock-cells = <0>; - clock-output-names = "rtcic_32kout"; - pinctrl-names = "default"; - pinctrl-0 = <&hym8563_int>; - wakeup-source; - }; -}; - -&i2c5 { - /* pin 3 (SDA) + 4 (SCL) of header con2 */ - status = "disabled"; -}; - -&i2s0_8ch { - /* hdmi sound */ - status = "okay"; -}; - -&mdio0 { - #address-cells = <1>; - #size-cells = <0>; - - switch@0 { - compatible = "mediatek,mt7531"; - reg = <0>; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - port@1 { - reg = <1>; - label = "lan0"; - }; - - port@2 { - reg = <2>; - label = "lan1"; - }; - - port@3 { - reg = <3>; - label = "lan2"; - }; - - port@4 { - reg = <4>; - label = "lan3"; - }; - - port@5 { - reg = <5>; - label = "cpu"; - ethernet = <&gmac0>; - phy-mode = "rgmii"; - - fixed-link { - speed = <1000>; - full-duplex; - pause; - }; - }; - }; - }; -}; - -&mdio1 { - rgmii_phy1: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - }; -}; - -&pcie30phy { - data-lanes = <1 2>; - phy-supply = <&vcc3v3_pi6c_05>; - status = "okay"; -}; - -&pcie3x1 { - /* M.2 slot */ - num-lanes = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&ngffpcie_reset_h>; - reset-gpios = <&gpio3 RK_PA1 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_ngff>; - status = "okay"; -}; - -&pcie3x2 { - /* mPCIe slot */ - num-lanes = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&minipcie_reset_h>; - reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_minipcie>; - status = "okay"; -}; - -&pinctrl { - leds { - blue_led_pin: blue-led-pin { - rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - green_led_pin: green-led-pin { - rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - hym8563 { - hym8563_int: hym8563-int { - rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - ir-receiver { - ir_receiver_pin: ir-receiver-pin { - rockchip,pins = <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - minipcie_enable_h: minipcie-enable-h { - rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>; - }; - - ngffpcie_enable_h: ngffpcie-enable-h { - rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>; - }; - - minipcie_reset_h: minipcie-reset-h { - rockchip,pins = <2 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>; - }; - - ngffpcie_reset_h: ngffpcie-reset-h { - rockchip,pins = <3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>; - }; - }; - - pmic { - pmic_int: pmic_int { - rockchip,pins = - <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb { - vcc5v0_usb_host_en: vcc5v0_usb_host_en { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_usb_otg_en: vcc5v0_usb_otg_en { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_3v3>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&pwm8 { - /* fan 5v - gnd - pwm */ - status = "okay"; -}; - -&pwm10 { - /* pin 7 of header con2 */ - status = "disabled"; -}; - -&pwm11 { - /* pin 15 of header con2 */ - status = "disabled"; -}; - -&pwm12 { - /* pin 21 of header con2 */ - /* shared with uart9 + spi3 */ - pinctrl-0 = <&pwm12m1_pins>; - status = "disabled"; -}; - -&pwm13 { - /* pin 24 of header con2 */ - /* shared with uart9 */ - pinctrl-0 = <&pwm13m1_pins>; - status = "disabled"; -}; - -&pwm14 { - /* pin 23 of header con2 */ - /* shared with spi3 */ - pinctrl-0 = <&pwm14m1_pins>; - status = "disabled"; -}; - -&pwm15 { - /* pin 19 of header con2 */ - /* shared with spi3 */ - pinctrl-0 = <&pwm15m1_pins>; - status = "disabled"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sata2 { - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&spi3 { - /* pin 19 (MO) + 21 (MI) + 23 (CK) of header con2 */ - /* shared with pwm12/14/15 and uart9 */ - pinctrl-0 = <&spi3m1_pins>; - status = "disabled"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart0 { - /* pin 8 (TX) + 10 (RX) (RTS:16, CTS:18) of header con2 */ - status = "disabled"; -}; - -&uart2 { - /* debug-uart */ - status = "okay"; -}; - -&uart7 { - /* pin 11 (TX) + 13 (RX) of header con2 */ - pinctrl-0 = <&uart7m1_xfer>; - status = "disabled"; -}; - -&uart9 { - /* pin 21 (TX) + 24 (RX) of header con2 */ - /* shared with pwm13 and pwm12/spi3 */ - pinctrl-0 = <&uart9m1_xfer>; - status = "disabled"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - dr_mode = "host"; - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_usb_otg>; - status = "okay"; -}; - -&usb2phy1 { - /* USB for PCIe/M2 */ - status = "okay"; -}; - -&usb2phy1_host { - status = "okay"; -}; - -&usb2phy1_otg { - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3568-evb.dts b/arch/arm/dts/rk3568-evb.dts deleted file mode 100644 index 19f8fc369b13..000000000000 --- a/arch/arm/dts/rk3568-evb.dts +++ /dev/null @@ -1,689 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2021 Rockchip Electronics Co., Ltd. - * - */ - -/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi" - -/ { - model = "Rockchip RK3568 EVB1 DDR4 V10 Board"; - compatible = "rockchip,rk3568-evb1-v10", "rockchip,rk3568"; - - aliases { - ethernet0 = &gmac0; - ethernet1 = &gmac1; - mmc0 = &sdmmc0; - mmc1 = &sdhci; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - dc_12v: dc-12v { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - leds { - compatible = "gpio-leds"; - - led_work: led-0 { - gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_HEARTBEAT; - color = <LED_COLOR_ID_BLUE>; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&led_work_en>; - }; - }; - - rk809-sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,name = "Analog RK809"; - simple-audio-card,mclk-fs = <256>; - - simple-audio-card,cpu { - sound-dai = <&i2s1_8ch>; - }; - simple-audio-card,codec { - sound-dai = <&rk809>; - }; - }; - - vcc3v3_sys: vcc3v3-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_sys: vcc5v0-sys { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_usb: vcc5v0-usb { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_usb_host: vcc5v0-usb-host { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_host_en>; - regulator-name = "vcc5v0_usb_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_usb_otg: vcc5v0-usb-otg { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_otg_en>; - regulator-name = "vcc5v0_usb_otg"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc3v3_lcd0_n: vcc3v3-lcd0-n { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_lcd0_n"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - gpio = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>; - vin-supply = <&vcc3v3_sys>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc3v3_lcd0_n_en>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_lcd1_n: vcc3v3-lcd1-n { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_lcd1_n"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; - vin-supply = <&vcc3v3_sys>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc3v3_lcd1_n_en>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&combphy0 { - status = "okay"; -}; - -&combphy1 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gmac0 { - assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; - assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>; - assigned-clock-rates = <0>, <125000000>; - clock_in_out = "output"; - phy-handle = <&rgmii_phy0>; - phy-mode = "rgmii-id"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac0_miim - &gmac0_tx_bus2 - &gmac0_rx_bus2 - &gmac0_rgmii_clk - &gmac0_rgmii_bus>; - status = "okay"; -}; - -&gmac1 { - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>; - assigned-clock-rates = <0>, <125000000>; - clock_in_out = "output"; - phy-handle = <&rgmii_phy1>; - phy-mode = "rgmii-id"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m1_miim - &gmac1m1_tx_bus2 - &gmac1m1_rx_bus2 - &gmac1m1_rgmii_clk - &gmac1m1_rgmii_bus>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - #clock-cells = <1>; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>, <&i2s1m0_mclk>; - rockchip,system-power-controller; - #sound-dai-cells = <0>; - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - wakeup-source; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - - codec { - mic-in-differential; - }; - }; -}; - -&i2c1 { - status = "okay"; - - touchscreen0: goodix@14 { - compatible = "goodix,gt1151"; - reg = <0x14>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PB5 IRQ_TYPE_EDGE_FALLING>; - AVDD28-supply = <&vcc3v3_lcd0_n>; - irq-gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&touch_int &touch_rst>; - reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; - VDDIO-supply = <&vcc3v3_lcd0_n>; - }; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&i2s1_8ch { - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&mdio0 { - rgmii_phy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - reset-assert-us = <20000>; - reset-deassert-us = <100000>; - reset-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>; - }; -}; - -&mdio1 { - rgmii_phy1: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - reset-assert-us = <20000>; - reset-deassert-us = <100000>; - reset-gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_LOW>; - }; -}; - -&pinctrl { - display { - vcc3v3_lcd0_n_en: vcc3v3_lcd0_n_en { - rockchip,pins = <0 RK_PC7 0 &pcfg_pull_none>; - }; - vcc3v3_lcd1_n_en: vcc3v3_lcd1_n_en { - rockchip,pins = <0 RK_PC5 0 &pcfg_pull_none>; - }; - }; - - leds { - led_work_en: led_work_en { - rockchip,pins = <0 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic_int { - rockchip,pins = - <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - touchscreen { - touch_int: touch_int { - rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>; - }; - touch_rst: touch_rst { - rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - vcc5v0_usb_host_en: vcc5v0_usb_host_en { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - vcc5v0_usb_otg_en: vcc5v0_usb_otg_en { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - extcon = <&usb2phy0>; - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_usb_otg>; - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3568-lubancat-2.dts b/arch/arm/dts/rk3568-lubancat-2.dts deleted file mode 100644 index a8a4cc190eb3..000000000000 --- a/arch/arm/dts/rk3568-lubancat-2.dts +++ /dev/null @@ -1,730 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/* - * Copyright (c) 2021 Rockchip Electronics Co., Ltd. - * Copyright (c) 2022 EmbedFire embedfire@embedfire.com - */ - -/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi" - -/ { - model = "EmbedFire LubanCat 2"; - compatible = "embedfire,lubancat-2", "rockchip,rk3568"; - - aliases { - ethernet0 = &gmac0; - ethernet1 = &gmac1; - mmc0 = &sdmmc0; - mmc1 = &sdhci; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - leds { - compatible = "gpio-leds"; - - user_led: user-led { - label = "user_led"; - linux,default-trigger = "heartbeat"; - default-state = "on"; - gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&user_led_pin>; - }; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - dc_5v: dc-5v-regulator { - compatible = "regulator-fixed"; - regulator-name = "dc_5v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_5v>; - }; - - vcc3v3_m2_pcie: vcc3v3-m2-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "m2_pcie_3v3"; - enable-active-high; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&vcc3v3_m2_pcie_en>; - pinctrl-names = "default"; - startup-delay-us = <200000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_mini_pcie: vcc3v3-mini-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "minipcie_3v3"; - enable-active-high; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - gpio = <&gpio3 RK_PC3 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&vcc3v3_mini_pcie_en>; - pinctrl-names = "default"; - startup-delay-us = <5000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_usb20_host: vcc5v0-usb20-host-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb20_host"; - enable-active-high; - gpio = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&vcc5v0_usb20_host_en>; - pinctrl-names = "default"; - }; - - vcc5v0_usb30_host: vcc5v0-usb30-host-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb30_host"; - enable-active-high; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&vcc5v0_usb30_host_en>; - pinctrl-names = "default"; - }; - - vcc5v0_otg_vbus: vcc5v0-otg-vbus-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_otg_vbus"; - enable-active-high; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - gpio = <&gpio0 RK_PD3 GPIO_ACTIVE_HIGH>; - pinctrl-0 = <&vcc5v0_otg_vbus_en>; - pinctrl-names = "default"; - }; -}; - -&combphy0 { - status = "okay"; -}; - -&combphy1 { - status = "okay"; -}; - -&combphy2 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - #clock-cells = <1>; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>; - rockchip,system-power-controller; - #sound-dai-cells = <0>; - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - wakeup-source; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-boot-on; - regulator-always-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&i2s1_8ch { - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&gmac0 { - phy-mode = "rgmii"; - clock_in_out = "output"; - - snps,reset-gpio = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f */ - snps,reset-delays-us = <0 20000 100000>; - - assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; - assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>; - - pinctrl-names = "default"; - pinctrl-0 = <&gmac0_miim - &gmac0_tx_bus2 - &gmac0_rx_bus2 - &gmac0_rgmii_clk - &gmac0_rgmii_bus>; - - tx_delay = <0x22>; - rx_delay = <0x0e>; - - phy-handle = <&rgmii_phy0>; - status = "okay"; -}; - -&mdio0 { - rgmii_phy0: phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - }; -}; - -&gmac1 { - phy-mode = "rgmii"; - clock_in_out = "output"; - - snps,reset-gpio = <&gpio3 RK_PA2 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 20ms, 100ms for rtl8211f */ - snps,reset-delays-us = <0 20000 100000>; - - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>; - - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m1_miim - &gmac1m1_tx_bus2 - &gmac1m1_rx_bus2 - &gmac1m1_rgmii_clk - &gmac1m1_rgmii_bus>; - - tx_delay = <0x21>; - rx_delay = <0x0e>; - - phy-handle = <&rgmii_phy1>; - status = "okay"; -}; - -&mdio1 { - rgmii_phy1: phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - }; -}; - -&gic { - mbi-ranges = <94 31>, <229 31>, <289 31>; -}; - -&pcie30phy { - status = "okay"; -}; - -&pcie3x2 { - reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_m2_pcie>; - status = "okay"; -}; - -&pcie2x1 { - reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>; - disable-gpios = <&gpio3 RK_PC2 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_mini_pcie>; - status = "okay"; -}; - -&pmu_io_domains { - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&pwm8 { - status = "okay"; -}; - -&pwm9 { - status = "disabled"; -}; - -&pwm10 { - status = "disabled"; -}; - -&pwm14 { - status = "disabled"; -}; - -&spi3 { - pinctrl-0 = <&spi3m1_pins>; - status = "disabled"; -}; - -&uart2 { - status = "okay"; -}; - -&uart3 { - pinctrl-names = "default"; - pinctrl-0 = <&uart3m1_xfer>; - status = "disabled"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&sdhci { - assigned-clocks = <&cru BCLK_EMMC>, <&cru TCLK_EMMC>, <&cru CCLK_EMMC>; - assigned-clock-rates = <200000000>, <24000000>, <200000000>; - bus-width = <8>; - max-frequency = <200000000>; - mmc-hs200-1_8v; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd>; - supports-emmc; - status = "okay"; -}; - -&sdmmc0 { - max-frequency = <150000000>; - no-sdio; - no-mmc; - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - status = "okay"; -}; - -/* USB OTG/USB Host_1 USB 2.0 Comb */ -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb30_host>; - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_otg_vbus>; - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -/* USB Host_2/USB Host_3 USB 2.0 Comb */ -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_host { - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc5v0_usb20_host>; - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -/* MULTI_PHY0 For SATA0, USB3.0 OTG Only USB2.0 */ -&usb_host0_xhci { - phys = <&usb2phy0_otg>; - phy-names = "usb2-phy"; - extcon = <&usb2phy0>; - maximum-speed = "high-speed"; - dr_mode = "host"; - status = "okay"; -}; - -&sata0 { - status = "okay"; -}; - -/* USB3.0 Host */ -&usb_host1_xhci { - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; - -&pinctrl { - leds { - user_led_pin: user-status-led-pin { - rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - vcc5v0_usb20_host_en: vcc5v0-usb20-host-en { - rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_usb30_host_en: vcc5v0-usb30-host-en { - rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_otg_vbus_en: vcc5v0-otg-vbus-en { - rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - vcc3v3_m2_pcie_en: vcc3v3-m2-pcie-en { - rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc3v3_mini_pcie_en: vcc3v3-mini-pcie-en { - rockchip,pins = <3 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; diff --git a/arch/arm/dts/rk3568-nanopi-r5c.dts b/arch/arm/dts/rk3568-nanopi-r5c.dts deleted file mode 100644 index c718b8dbb9c6..000000000000 --- a/arch/arm/dts/rk3568-nanopi-r5c.dts +++ /dev/null @@ -1,112 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/* - * Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyelec.com) - * - * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com - */ - -/dts-v1/; -#include "rk3568-nanopi-r5s.dtsi" - -/ { - model = "FriendlyElec NanoPi R5C"; - compatible = "friendlyarm,nanopi-r5c", "rockchip,rk3568"; - - gpio-keys { - compatible = "gpio-keys"; - pinctrl-names = "default"; - pinctrl-0 = <&reset_button_pin>; - - button-reset { - debounce-interval = <50>; - gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_LOW>; - label = "reset"; - linux,code = <KEY_RESTART>; - }; - }; - - gpio-leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&lan_led_pin>, <&power_led_pin>, <&wan_led_pin>, <&wlan_led_pin>; - - led-lan { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_LAN; - gpios = <&gpio3 RK_PA3 GPIO_ACTIVE_HIGH>; - }; - - power_led: led-power { - color = <LED_COLOR_ID_RED>; - function = LED_FUNCTION_POWER; - linux,default-trigger = "heartbeat"; - gpios = <&gpio3 RK_PA2 GPIO_ACTIVE_HIGH>; - }; - - led-wan { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_WAN; - gpios = <&gpio3 RK_PA4 GPIO_ACTIVE_HIGH>; - }; - - led-wlan { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_WLAN; - gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>; - }; - }; -}; - -&pcie2x1 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie20_reset_pin>; - reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>; - status = "okay"; -}; - -&pcie3x1 { - num-lanes = <1>; - reset-gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pcie3x2 { - num-lanes = <1>; - reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pinctrl { - gpio-leds { - lan_led_pin: lan-led-pin { - rockchip,pins = <3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - power_led_pin: power-led-pin { - rockchip,pins = <3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wan_led_pin: wan-led-pin { - rockchip,pins = <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wlan_led_pin: wlan-led-pin { - rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie20_reset_pin: pcie20-reset-pin { - rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - rockchip-key { - reset_button_pin: reset-button-pin { - rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; diff --git a/arch/arm/dts/rk3568-nanopi-r5s.dts b/arch/arm/dts/rk3568-nanopi-r5s.dts deleted file mode 100644 index b6ad8328c7eb..000000000000 --- a/arch/arm/dts/rk3568-nanopi-r5s.dts +++ /dev/null @@ -1,136 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/* - * Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyelec.com) - * - * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com - */ - -/dts-v1/; -#include "rk3568-nanopi-r5s.dtsi" - -/ { - model = "FriendlyElec NanoPi R5S"; - compatible = "friendlyarm,nanopi-r5s", "rockchip,rk3568"; - - aliases { - ethernet0 = &gmac0; - }; - - gpio-leds { - compatible = "gpio-leds"; - pinctrl-names = "default"; - pinctrl-0 = <&lan1_led_pin>, <&lan2_led_pin>, <&power_led_pin>, <&wan_led_pin>; - - led-lan1 { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_LAN; - function-enumerator = <1>; - gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>; - }; - - led-lan2 { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_LAN; - function-enumerator = <2>; - gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_HIGH>; - }; - - power_led: led-power { - color = <LED_COLOR_ID_RED>; - function = LED_FUNCTION_POWER; - linux,default-trigger = "heartbeat"; - gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>; - }; - - led-wan { - color = <LED_COLOR_ID_GREEN>; - function = LED_FUNCTION_WAN; - gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>; - }; - }; -}; - -&gmac0 { - assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; - assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>; - assigned-clock-rates = <0>, <125000000>; - clock_in_out = "output"; - phy-handle = <&rgmii_phy0>; - phy-mode = "rgmii"; - pinctrl-names = "default"; - pinctrl-0 = <&gmac0_miim - &gmac0_tx_bus2 - &gmac0_rx_bus2 - &gmac0_rgmii_clk - &gmac0_rgmii_bus>; - snps,reset-gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_LOW>; - snps,reset-active-low; - /* Reset time is 15ms, 50ms for rtl8211f */ - snps,reset-delays-us = <0 15000 50000>; - tx_delay = <0x3c>; - rx_delay = <0x2f>; - status = "okay"; -}; - -&mdio0 { - rgmii_phy0: ethernet-phy@1 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <1>; - pinctrl-0 = <ð_phy0_reset_pin>; - pinctrl-names = "default"; - }; -}; - -&pcie2x1 { - num-lanes = <1>; - reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>; - status = "okay"; -}; - -&pcie30phy { - data-lanes = <1 2>; - status = "okay"; -}; - -&pcie3x1 { - num-lanes = <1>; - reset-gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pcie3x2 { - num-lanes = <1>; - num-ib-windows = <8>; - num-ob-windows = <8>; - reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pinctrl { - gmac0 { - eth_phy0_reset_pin: eth-phy0-reset-pin { - rockchip,pins = <0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - gpio-leds { - lan1_led_pin: lan1-led-pin { - rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - lan2_led_pin: lan2-led-pin { - rockchip,pins = <3 RK_PD7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - power_led_pin: power-led-pin { - rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - wan_led_pin: wan-led-pin { - rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; diff --git a/arch/arm/dts/rk3568-nanopi-r5s.dtsi b/arch/arm/dts/rk3568-nanopi-r5s.dtsi deleted file mode 100644 index 93189f830640..000000000000 --- a/arch/arm/dts/rk3568-nanopi-r5s.dtsi +++ /dev/null @@ -1,587 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/* - * Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd. - * (http://www.friendlyelec.com) - * - * Copyright (c) 2023 Tianling Shen cnsztl@gmail.com - */ - -/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi" - -/ { - aliases { - mmc0 = &sdmmc0; - mmc1 = &sdhci; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - vdd_usbc: vdd-usbc-regulator { - compatible = "regulator-fixed"; - regulator-name = "vdd_usbc"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vdd_usbc>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vdd_usbc>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - enable-active-high; - gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; - startup-delay-us = <200000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_usb: vcc5v0-usb-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vdd_usbc>; - }; - - vcc5v0_usb_host: vcc5v0-usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_host_en>; - regulator-name = "vcc5v0_usb_host"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_otg_en>; - regulator-name = "vcc5v0_usb_otg"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - pcie30_avdd0v9: pcie30-avdd0v9-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; - - pcie30_avdd1v8: pcie30-avdd1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - }; -}; - -&combphy0 { - status = "okay"; -}; - -&combphy1 { - status = "okay"; -}; - -&combphy2 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>; - rockchip,system-power-controller; - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - wakeup-source; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-min-microvolt = <950000>; - regulator-max-microvolt = <950000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - - }; -}; - -&i2c5 { - status = "okay"; - - hym8563: rtc@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <0>; - clock-output-names = "rtcic_32kout"; - pinctrl-names = "default"; - pinctrl-0 = <&hym8563_int>; - wakeup-source; - }; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&pcie30phy { - data-lanes = <1 2>; - status = "okay"; -}; - -&pinctrl { - hym8563 { - hym8563_int: hym8563-int { - rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - pmic { - pmic_int: pmic-int { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb { - vcc5v0_usb_host_en: vcc5v0-usb-host-en { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vcc5v0_usb_otg_en: vcc5v0-usb-otg-en { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd>; - status = "okay"; -}; - -&sdmmc0 { - max-frequency = <150000000>; - no-sdio; - no-mmc; - bus-width = <4>; - cap-mmc-highspeed; - cap-sd-highspeed; - disable-wp; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - extcon = <&usb2phy0>; - dr_mode = "host"; - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy0_otg { - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_host { - phy-supply = <&vcc5v0_usb_otg>; - status = "okay"; -}; - -&usb2phy1_otg { - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3568-odroid-m1.dts b/arch/arm/dts/rk3568-odroid-m1.dts deleted file mode 100644 index a337f547caf5..000000000000 --- a/arch/arm/dts/rk3568-odroid-m1.dts +++ /dev/null @@ -1,741 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2022 Hardkernel Co., Ltd. - * - */ - -/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi" - -/ { - model = "Hardkernel ODROID-M1"; - compatible = "rockchip,rk3568-odroid-m1", "rockchip,rk3568"; - - aliases { - ethernet0 = &gmac0; - i2c0 = &i2c3; - i2c3 = &i2c0; - mmc0 = &sdhci; - mmc1 = &sdmmc0; - serial0 = &uart1; - serial1 = &uart0; - }; - - chosen { - stdout-path = "serial2:1500000n8"; - }; - - dc_12v: dc-12v-regulator { - compatible = "regulator-fixed"; - regulator-name = "dc_12v"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <12000000>; - regulator-max-microvolt = <12000000>; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - ir-receiver { - compatible = "gpio-ir-receiver"; - gpios = <&gpio0 RK_PC2 GPIO_ACTIVE_LOW>; - pinctrl-names = "default"; - pinctrl-0 = <&ir_receiver_pin>; - }; - - leds { - compatible = "gpio-leds"; - - led_power: led-0 { - gpios = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_POWER; - color = <LED_COLOR_ID_RED>; - default-state = "keep"; - linux,default-trigger = "default-on"; - pinctrl-names = "default"; - pinctrl-0 = <&led_power_pin>; - }; - led_work: led-1 { - gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_HEARTBEAT; - color = <LED_COLOR_ID_BLUE>; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&led_work_pin>; - }; - }; - - rk809-sound { - compatible = "simple-audio-card"; - pinctrl-names = "default"; - pinctrl-0 = <&hp_det_pin>; - simple-audio-card,name = "Analog RK817"; - simple-audio-card,format = "i2s"; - simple-audio-card,hp-det-gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>; - simple-audio-card,mclk-fs = <256>; - simple-audio-card,widgets = - "Headphone", "Headphones", - "Speaker", "Speaker"; - simple-audio-card,routing = - "Headphones", "HPOL", - "Headphones", "HPOR", - "Speaker", "SPKO"; - - simple-audio-card,cpu { - sound-dai = <&i2s1_8ch>; - }; - - simple-audio-card,codec { - sound-dai = <&rk809>; - }; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pcie"; - enable-active-high; - gpio = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc3v3_pcie_en_pin>; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - startup-delay-us = <5000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&dc_12v>; - }; - - vcc5v0_usb_host: vcc5v0-usb-host-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb_host"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_host_en_pin>; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb_otg"; - enable-active-high; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_otg_en_pin>; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&combphy0 { - /* Used for USB3 */ - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&combphy1 { - /* Used for USB3 */ - phy-supply = <&vcc5v0_usb_otg>; - status = "okay"; -}; - -&combphy2 { - /* used for SATA */ - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gmac0 { - assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>; - assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>; - assigned-clock-rates = <0>, <125000000>; - clock_in_out = "output"; - phy-handle = <&rgmii_phy0>; - phy-mode = "rgmii"; - phy-supply = <&vcc3v3_sys>; - pinctrl-names = "default"; - pinctrl-0 = <&gmac0_miim - &gmac0_tx_bus2 - &gmac0_rx_bus2 - &gmac0_rgmii_clk - &gmac0_rgmii_bus>; - status = "okay"; - - tx_delay = <0x4f>; - rx_delay = <0x2d>; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - #clock-cells = <1>; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int_l>, <&i2s1m0_mclk>; - rockchip,system-power-controller; - #sound-dai-cells = <0>; - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - wakeup-source; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-always-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-always-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&i2s1_8ch { - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&mdio0 { - rgmii_phy0: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - reset-assert-us = <20000>; - reset-deassert-us = <100000>; - reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>; - }; -}; - -&pcie30phy { - status = "okay"; -}; - -&pcie3x2 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie_reset_pin>; - reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pinctrl { - fspi { - fspi_dual_io_pins: fspi-dual-io-pins { - rockchip,pins = - /* fspi_clk */ - <1 RK_PD0 1 &pcfg_pull_none>, - /* fspi_cs0n */ - <1 RK_PD3 1 &pcfg_pull_none>, - /* fspi_d0 */ - <1 RK_PD1 1 &pcfg_pull_none>, - /* fspi_d1 */ - <1 RK_PD2 1 &pcfg_pull_none>; - }; - }; - - ir-receiver { - ir_receiver_pin: ir-receiver-pin { - /* external pullup to VCC3V3_SYS */ - rockchip,pins = <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - leds { - led_power_pin: led-power-pin { - rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - led_work_pin: led-work-pin { - rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_reset_pin: pcie-reset-pin { - rockchip,pins = <2 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - vcc3v3_pcie_en_pin: vcc3v3-pcie-en-pin { - rockchip,pins = <4 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int_l: pmic-int-l { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - rk809 { - hp_det_pin: hp-det-pin { - rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - vcc5v0_usb_host_en_pin: vcc5v0-usb-host-en-pin { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - vcc5v0_usb_otg_en_pin: vcc5v0-usb-dr-en-pin { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_3v3>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sata2 { - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe &emmc_rstnout>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - sd-uhs-sdr50; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&sfc { - /* Dual I/O mode as the D2 pin conflicts with the eMMC */ - pinctrl-0 = <&fspi_dual_io_pins>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "okay"; - - flash@0 { - compatible = "jedec,spi-nor"; - reg = <0>; - spi-max-frequency = <100000000>; - spi-rx-bus-width = <2>; - spi-tx-bus-width = <1>; - - partitions { - compatible = "fixed-partitions"; - #address-cells = <1>; - #size-cells = <1>; - - partition@0 { - label = "SPL"; - reg = <0x0 0xe0000>; - }; - partition@e0000 { - label = "U-Boot Env"; - reg = <0xe0000 0x20000>; - }; - partition@100000 { - label = "U-Boot"; - reg = <0x100000 0x200000>; - }; - partition@300000 { - label = "splash"; - reg = <0x300000 0x100000>; - }; - partition@400000 { - label = "Filesystem"; - reg = <0x400000 0xc00000>; - }; - }; - }; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - dr_mode = "host"; - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_usb_otg>; - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3568-pinctrl.dtsi b/arch/arm/dts/rk3568-pinctrl.dtsi deleted file mode 100644 index 0a979bfb63d9..000000000000 --- a/arch/arm/dts/rk3568-pinctrl.dtsi +++ /dev/null @@ -1,3214 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2021 Rockchip Electronics Co., Ltd. - */ - -#include <dt-bindings/pinctrl/rockchip.h> -#include "rockchip-pinconf.dtsi" - -/* - * This file is auto generated by pin2dts tool, please keep these code - * by adding changes at end of this file. - */ -&pinctrl { - acodec { - /omit-if-no-ref/ - acodec_pins: acodec-pins { - rockchip,pins = - /* acodec_adc_sync */ - <1 RK_PB1 5 &pcfg_pull_none>, - /* acodec_adcclk */ - <1 RK_PA1 5 &pcfg_pull_none>, - /* acodec_adcdata */ - <1 RK_PA0 5 &pcfg_pull_none>, - /* acodec_dac_datal */ - <1 RK_PA7 5 &pcfg_pull_none>, - /* acodec_dac_datar */ - <1 RK_PB0 5 &pcfg_pull_none>, - /* acodec_dacclk */ - <1 RK_PA3 5 &pcfg_pull_none>, - /* acodec_dacsync */ - <1 RK_PA5 5 &pcfg_pull_none>; - }; - }; - - audiopwm { - /omit-if-no-ref/ - audiopwm_lout: audiopwm-lout { - rockchip,pins = - /* audiopwm_lout */ - <1 RK_PA0 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - audiopwm_loutn: audiopwm-loutn { - rockchip,pins = - /* audiopwm_loutn */ - <1 RK_PA1 6 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - audiopwm_loutp: audiopwm-loutp { - rockchip,pins = - /* audiopwm_loutp */ - <1 RK_PA0 6 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - audiopwm_rout: audiopwm-rout { - rockchip,pins = - /* audiopwm_rout */ - <1 RK_PA1 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - audiopwm_routn: audiopwm-routn { - rockchip,pins = - /* audiopwm_routn */ - <1 RK_PA7 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - audiopwm_routp: audiopwm-routp { - rockchip,pins = - /* audiopwm_routp */ - <1 RK_PA6 4 &pcfg_pull_none>; - }; - }; - - bt656 { - /omit-if-no-ref/ - bt656m0_pins: bt656m0-pins { - rockchip,pins = - /* bt656_clkm0 */ - <3 RK_PA0 2 &pcfg_pull_none>, - /* bt656_d0m0 */ - <2 RK_PD0 2 &pcfg_pull_none>, - /* bt656_d1m0 */ - <2 RK_PD1 2 &pcfg_pull_none>, - /* bt656_d2m0 */ - <2 RK_PD2 2 &pcfg_pull_none>, - /* bt656_d3m0 */ - <2 RK_PD3 2 &pcfg_pull_none>, - /* bt656_d4m0 */ - <2 RK_PD4 2 &pcfg_pull_none>, - /* bt656_d5m0 */ - <2 RK_PD5 2 &pcfg_pull_none>, - /* bt656_d6m0 */ - <2 RK_PD6 2 &pcfg_pull_none>, - /* bt656_d7m0 */ - <2 RK_PD7 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - bt656m1_pins: bt656m1-pins { - rockchip,pins = - /* bt656_clkm1 */ - <4 RK_PB4 5 &pcfg_pull_none>, - /* bt656_d0m1 */ - <3 RK_PC6 5 &pcfg_pull_none>, - /* bt656_d1m1 */ - <3 RK_PC7 5 &pcfg_pull_none>, - /* bt656_d2m1 */ - <3 RK_PD0 5 &pcfg_pull_none>, - /* bt656_d3m1 */ - <3 RK_PD1 5 &pcfg_pull_none>, - /* bt656_d4m1 */ - <3 RK_PD2 5 &pcfg_pull_none>, - /* bt656_d5m1 */ - <3 RK_PD3 5 &pcfg_pull_none>, - /* bt656_d6m1 */ - <3 RK_PD4 5 &pcfg_pull_none>, - /* bt656_d7m1 */ - <3 RK_PD5 5 &pcfg_pull_none>; - }; - }; - - bt1120 { - /omit-if-no-ref/ - bt1120_pins: bt1120-pins { - rockchip,pins = - /* bt1120_clk */ - <3 RK_PA6 2 &pcfg_pull_none>, - /* bt1120_d0 */ - <3 RK_PA1 2 &pcfg_pull_none>, - /* bt1120_d1 */ - <3 RK_PA2 2 &pcfg_pull_none>, - /* bt1120_d2 */ - <3 RK_PA3 2 &pcfg_pull_none>, - /* bt1120_d3 */ - <3 RK_PA4 2 &pcfg_pull_none>, - /* bt1120_d4 */ - <3 RK_PA5 2 &pcfg_pull_none>, - /* bt1120_d5 */ - <3 RK_PA7 2 &pcfg_pull_none>, - /* bt1120_d6 */ - <3 RK_PB0 2 &pcfg_pull_none>, - /* bt1120_d7 */ - <3 RK_PB1 2 &pcfg_pull_none>, - /* bt1120_d8 */ - <3 RK_PB2 2 &pcfg_pull_none>, - /* bt1120_d9 */ - <3 RK_PB3 2 &pcfg_pull_none>, - /* bt1120_d10 */ - <3 RK_PB4 2 &pcfg_pull_none>, - /* bt1120_d11 */ - <3 RK_PB5 2 &pcfg_pull_none>, - /* bt1120_d12 */ - <3 RK_PB6 2 &pcfg_pull_none>, - /* bt1120_d13 */ - <3 RK_PC1 2 &pcfg_pull_none>, - /* bt1120_d14 */ - <3 RK_PC2 2 &pcfg_pull_none>, - /* bt1120_d15 */ - <3 RK_PC3 2 &pcfg_pull_none>; - }; - }; - - cam { - /omit-if-no-ref/ - cam_clkout0: cam-clkout0 { - rockchip,pins = - /* cam_clkout0 */ - <4 RK_PA7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - cam_clkout1: cam-clkout1 { - rockchip,pins = - /* cam_clkout1 */ - <4 RK_PB0 1 &pcfg_pull_none>; - }; - }; - - can0 { - /omit-if-no-ref/ - can0m0_pins: can0m0-pins { - rockchip,pins = - /* can0_rxm0 */ - <0 RK_PB4 2 &pcfg_pull_none>, - /* can0_txm0 */ - <0 RK_PB3 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - can0m1_pins: can0m1-pins { - rockchip,pins = - /* can0_rxm1 */ - <2 RK_PA2 4 &pcfg_pull_none>, - /* can0_txm1 */ - <2 RK_PA1 4 &pcfg_pull_none>; - }; - }; - - can1 { - /omit-if-no-ref/ - can1m0_pins: can1m0-pins { - rockchip,pins = - /* can1_rxm0 */ - <1 RK_PA0 3 &pcfg_pull_none>, - /* can1_txm0 */ - <1 RK_PA1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - can1m1_pins: can1m1-pins { - rockchip,pins = - /* can1_rxm1 */ - <4 RK_PC2 3 &pcfg_pull_none>, - /* can1_txm1 */ - <4 RK_PC3 3 &pcfg_pull_none>; - }; - }; - - can2 { - /omit-if-no-ref/ - can2m0_pins: can2m0-pins { - rockchip,pins = - /* can2_rxm0 */ - <4 RK_PB4 3 &pcfg_pull_none>, - /* can2_txm0 */ - <4 RK_PB5 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - can2m1_pins: can2m1-pins { - rockchip,pins = - /* can2_rxm1 */ - <2 RK_PB1 4 &pcfg_pull_none>, - /* can2_txm1 */ - <2 RK_PB2 4 &pcfg_pull_none>; - }; - }; - - cif { - /omit-if-no-ref/ - cif_clk: cif-clk { - rockchip,pins = - /* cif_clkout */ - <4 RK_PC0 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - cif_dvp_clk: cif-dvp-clk { - rockchip,pins = - /* cif_clkin */ - <4 RK_PC1 1 &pcfg_pull_none>, - /* cif_href */ - <4 RK_PB6 1 &pcfg_pull_none>, - /* cif_vsync */ - <4 RK_PB7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - cif_dvp_bus16: cif-dvp-bus16 { - rockchip,pins = - /* cif_d8 */ - <3 RK_PD6 1 &pcfg_pull_none>, - /* cif_d9 */ - <3 RK_PD7 1 &pcfg_pull_none>, - /* cif_d10 */ - <4 RK_PA0 1 &pcfg_pull_none>, - /* cif_d11 */ - <4 RK_PA1 1 &pcfg_pull_none>, - /* cif_d12 */ - <4 RK_PA2 1 &pcfg_pull_none>, - /* cif_d13 */ - <4 RK_PA3 1 &pcfg_pull_none>, - /* cif_d14 */ - <4 RK_PA4 1 &pcfg_pull_none>, - /* cif_d15 */ - <4 RK_PA5 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - cif_dvp_bus8: cif-dvp-bus8 { - rockchip,pins = - /* cif_d0 */ - <3 RK_PC6 1 &pcfg_pull_none>, - /* cif_d1 */ - <3 RK_PC7 1 &pcfg_pull_none>, - /* cif_d2 */ - <3 RK_PD0 1 &pcfg_pull_none>, - /* cif_d3 */ - <3 RK_PD1 1 &pcfg_pull_none>, - /* cif_d4 */ - <3 RK_PD2 1 &pcfg_pull_none>, - /* cif_d5 */ - <3 RK_PD3 1 &pcfg_pull_none>, - /* cif_d6 */ - <3 RK_PD4 1 &pcfg_pull_none>, - /* cif_d7 */ - <3 RK_PD5 1 &pcfg_pull_none>; - }; - }; - - clk32k { - /omit-if-no-ref/ - clk32k_in: clk32k-in { - rockchip,pins = - /* clk32k_in */ - <0 RK_PB0 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - clk32k_out0: clk32k-out0 { - rockchip,pins = - /* clk32k_out0 */ - <0 RK_PB0 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - clk32k_out1: clk32k-out1 { - rockchip,pins = - /* clk32k_out1 */ - <2 RK_PC6 1 &pcfg_pull_none>; - }; - }; - - cpu { - /omit-if-no-ref/ - cpu_pins: cpu-pins { - rockchip,pins = - /* cpu_avs */ - <0 RK_PB7 2 &pcfg_pull_none>; - }; - }; - - ebc { - /omit-if-no-ref/ - ebc_extern: ebc-extern { - rockchip,pins = - /* ebc_sdce1 */ - <4 RK_PA7 2 &pcfg_pull_none>, - /* ebc_sdce2 */ - <4 RK_PB0 2 &pcfg_pull_none>, - /* ebc_sdce3 */ - <4 RK_PB1 2 &pcfg_pull_none>, - /* ebc_sdshr */ - <4 RK_PB5 2 &pcfg_pull_none>, - /* ebc_vcom */ - <4 RK_PB2 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - ebc_pins: ebc-pins { - rockchip,pins = - /* ebc_gdclk */ - <4 RK_PC0 2 &pcfg_pull_none>, - /* ebc_gdoe */ - <4 RK_PB3 2 &pcfg_pull_none>, - /* ebc_gdsp */ - <4 RK_PB4 2 &pcfg_pull_none>, - /* ebc_sdce0 */ - <4 RK_PA6 2 &pcfg_pull_none>, - /* ebc_sdclk */ - <4 RK_PC1 2 &pcfg_pull_none>, - /* ebc_sddo0 */ - <3 RK_PC6 2 &pcfg_pull_none>, - /* ebc_sddo1 */ - <3 RK_PC7 2 &pcfg_pull_none>, - /* ebc_sddo2 */ - <3 RK_PD0 2 &pcfg_pull_none>, - /* ebc_sddo3 */ - <3 RK_PD1 2 &pcfg_pull_none>, - /* ebc_sddo4 */ - <3 RK_PD2 2 &pcfg_pull_none>, - /* ebc_sddo5 */ - <3 RK_PD3 2 &pcfg_pull_none>, - /* ebc_sddo6 */ - <3 RK_PD4 2 &pcfg_pull_none>, - /* ebc_sddo7 */ - <3 RK_PD5 2 &pcfg_pull_none>, - /* ebc_sddo8 */ - <3 RK_PD6 2 &pcfg_pull_none>, - /* ebc_sddo9 */ - <3 RK_PD7 2 &pcfg_pull_none>, - /* ebc_sddo10 */ - <4 RK_PA0 2 &pcfg_pull_none>, - /* ebc_sddo11 */ - <4 RK_PA1 2 &pcfg_pull_none>, - /* ebc_sddo12 */ - <4 RK_PA2 2 &pcfg_pull_none>, - /* ebc_sddo13 */ - <4 RK_PA3 2 &pcfg_pull_none>, - /* ebc_sddo14 */ - <4 RK_PA4 2 &pcfg_pull_none>, - /* ebc_sddo15 */ - <4 RK_PA5 2 &pcfg_pull_none>, - /* ebc_sdle */ - <4 RK_PB6 2 &pcfg_pull_none>, - /* ebc_sdoe */ - <4 RK_PB7 2 &pcfg_pull_none>; - }; - }; - - edpdp { - /omit-if-no-ref/ - edpdpm0_pins: edpdpm0-pins { - rockchip,pins = - /* edpdp_hpdinm0 */ - <4 RK_PC4 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - edpdpm1_pins: edpdpm1-pins { - rockchip,pins = - /* edpdp_hpdinm1 */ - <0 RK_PC2 2 &pcfg_pull_none>; - }; - }; - - emmc { - /omit-if-no-ref/ - emmc_rstnout: emmc-rstnout { - rockchip,pins = - /* emmc_rstn */ - <1 RK_PC7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - emmc_bus8: emmc-bus8 { - rockchip,pins = - /* emmc_d0 */ - <1 RK_PB4 1 &pcfg_pull_up_drv_level_2>, - /* emmc_d1 */ - <1 RK_PB5 1 &pcfg_pull_up_drv_level_2>, - /* emmc_d2 */ - <1 RK_PB6 1 &pcfg_pull_up_drv_level_2>, - /* emmc_d3 */ - <1 RK_PB7 1 &pcfg_pull_up_drv_level_2>, - /* emmc_d4 */ - <1 RK_PC0 1 &pcfg_pull_up_drv_level_2>, - /* emmc_d5 */ - <1 RK_PC1 1 &pcfg_pull_up_drv_level_2>, - /* emmc_d6 */ - <1 RK_PC2 1 &pcfg_pull_up_drv_level_2>, - /* emmc_d7 */ - <1 RK_PC3 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - emmc_clk: emmc-clk { - rockchip,pins = - /* emmc_clkout */ - <1 RK_PC5 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - emmc_cmd: emmc-cmd { - rockchip,pins = - /* emmc_cmd */ - <1 RK_PC4 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - emmc_datastrobe: emmc-datastrobe { - rockchip,pins = - /* emmc_datastrobe */ - <1 RK_PC6 1 &pcfg_pull_none>; - }; - }; - - eth0 { - /omit-if-no-ref/ - eth0_pins: eth0-pins { - rockchip,pins = - /* eth0_refclko25m */ - <2 RK_PC1 2 &pcfg_pull_none>; - }; - }; - - eth1 { - /omit-if-no-ref/ - eth1m0_pins: eth1m0-pins { - rockchip,pins = - /* eth1_refclko25mm0 */ - <3 RK_PB0 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - eth1m1_pins: eth1m1-pins { - rockchip,pins = - /* eth1_refclko25mm1 */ - <4 RK_PB3 3 &pcfg_pull_none>; - }; - }; - - flash { - /omit-if-no-ref/ - flash_pins: flash-pins { - rockchip,pins = - /* flash_ale */ - <1 RK_PD0 2 &pcfg_pull_none>, - /* flash_cle */ - <1 RK_PC6 3 &pcfg_pull_none>, - /* flash_cs0n */ - <1 RK_PD3 2 &pcfg_pull_none>, - /* flash_cs1n */ - <1 RK_PD4 2 &pcfg_pull_none>, - /* flash_d0 */ - <1 RK_PB4 2 &pcfg_pull_none>, - /* flash_d1 */ - <1 RK_PB5 2 &pcfg_pull_none>, - /* flash_d2 */ - <1 RK_PB6 2 &pcfg_pull_none>, - /* flash_d3 */ - <1 RK_PB7 2 &pcfg_pull_none>, - /* flash_d4 */ - <1 RK_PC0 2 &pcfg_pull_none>, - /* flash_d5 */ - <1 RK_PC1 2 &pcfg_pull_none>, - /* flash_d6 */ - <1 RK_PC2 2 &pcfg_pull_none>, - /* flash_d7 */ - <1 RK_PC3 2 &pcfg_pull_none>, - /* flash_dqs */ - <1 RK_PC5 2 &pcfg_pull_none>, - /* flash_rdn */ - <1 RK_PD2 2 &pcfg_pull_none>, - /* flash_rdy */ - <1 RK_PD1 2 &pcfg_pull_none>, - /* flash_volsel */ - <0 RK_PA7 1 &pcfg_pull_none>, - /* flash_wpn */ - <1 RK_PC7 3 &pcfg_pull_none>, - /* flash_wrn */ - <1 RK_PC4 2 &pcfg_pull_none>; - }; - }; - - fspi { - /omit-if-no-ref/ - fspi_pins: fspi-pins { - rockchip,pins = - /* fspi_clk */ - <1 RK_PD0 1 &pcfg_pull_none>, - /* fspi_cs0n */ - <1 RK_PD3 1 &pcfg_pull_none>, - /* fspi_d0 */ - <1 RK_PD1 1 &pcfg_pull_none>, - /* fspi_d1 */ - <1 RK_PD2 1 &pcfg_pull_none>, - /* fspi_d2 */ - <1 RK_PC7 2 &pcfg_pull_none>, - /* fspi_d3 */ - <1 RK_PD4 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - fspi_cs1: fspi-cs1 { - rockchip,pins = - /* fspi_cs1n */ - <1 RK_PC6 2 &pcfg_pull_up>; - }; - }; - - gmac0 { - /omit-if-no-ref/ - gmac0_miim: gmac0-miim { - rockchip,pins = - /* gmac0_mdc */ - <2 RK_PC3 2 &pcfg_pull_none>, - /* gmac0_mdio */ - <2 RK_PC4 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac0_clkinout: gmac0-clkinout { - rockchip,pins = - /* gmac0_mclkinout */ - <2 RK_PC2 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac0_rx_er: gmac0-rx-er { - rockchip,pins = - /* gmac0_rxer */ - <2 RK_PC5 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac0_rx_bus2: gmac0-rx-bus2 { - rockchip,pins = - /* gmac0_rxd0 */ - <2 RK_PB6 1 &pcfg_pull_none>, - /* gmac0_rxd1 */ - <2 RK_PB7 2 &pcfg_pull_none>, - /* gmac0_rxdvcrs */ - <2 RK_PC0 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac0_tx_bus2: gmac0-tx-bus2 { - rockchip,pins = - /* gmac0_txd0 */ - <2 RK_PB3 1 &pcfg_pull_none_drv_level_2>, - /* gmac0_txd1 */ - <2 RK_PB4 1 &pcfg_pull_none_drv_level_2>, - /* gmac0_txen */ - <2 RK_PB5 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac0_rgmii_clk: gmac0-rgmii-clk { - rockchip,pins = - /* gmac0_rxclk */ - <2 RK_PA5 2 &pcfg_pull_none>, - /* gmac0_txclk */ - <2 RK_PB0 2 &pcfg_pull_none_drv_level_1>; - }; - - /omit-if-no-ref/ - gmac0_rgmii_bus: gmac0-rgmii-bus { - rockchip,pins = - /* gmac0_rxd2 */ - <2 RK_PA3 2 &pcfg_pull_none>, - /* gmac0_rxd3 */ - <2 RK_PA4 2 &pcfg_pull_none>, - /* gmac0_txd2 */ - <2 RK_PA6 2 &pcfg_pull_none_drv_level_2>, - /* gmac0_txd3 */ - <2 RK_PA7 2 &pcfg_pull_none_drv_level_2>; - }; - }; - - gmac1 { - /omit-if-no-ref/ - gmac1m0_miim: gmac1m0-miim { - rockchip,pins = - /* gmac1_mdcm0 */ - <3 RK_PC4 3 &pcfg_pull_none>, - /* gmac1_mdiom0 */ - <3 RK_PC5 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m0_clkinout: gmac1m0-clkinout { - rockchip,pins = - /* gmac1_mclkinoutm0 */ - <3 RK_PC0 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m0_rx_er: gmac1m0-rx-er { - rockchip,pins = - /* gmac1_rxerm0 */ - <3 RK_PB4 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m0_rx_bus2: gmac1m0-rx-bus2 { - rockchip,pins = - /* gmac1_rxd0m0 */ - <3 RK_PB1 3 &pcfg_pull_none>, - /* gmac1_rxd1m0 */ - <3 RK_PB2 3 &pcfg_pull_none>, - /* gmac1_rxdvcrsm0 */ - <3 RK_PB3 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m0_tx_bus2: gmac1m0-tx-bus2 { - rockchip,pins = - /* gmac1_txd0m0 */ - <3 RK_PB5 3 &pcfg_pull_none_drv_level_2>, - /* gmac1_txd1m0 */ - <3 RK_PB6 3 &pcfg_pull_none_drv_level_2>, - /* gmac1_txenm0 */ - <3 RK_PB7 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m0_rgmii_clk: gmac1m0-rgmii-clk { - rockchip,pins = - /* gmac1_rxclkm0 */ - <3 RK_PA7 3 &pcfg_pull_none>, - /* gmac1_txclkm0 */ - <3 RK_PA6 3 &pcfg_pull_none_drv_level_1>; - }; - - /omit-if-no-ref/ - gmac1m0_rgmii_bus: gmac1m0-rgmii-bus { - rockchip,pins = - /* gmac1_rxd2m0 */ - <3 RK_PA4 3 &pcfg_pull_none>, - /* gmac1_rxd3m0 */ - <3 RK_PA5 3 &pcfg_pull_none>, - /* gmac1_txd2m0 */ - <3 RK_PA2 3 &pcfg_pull_none_drv_level_2>, - /* gmac1_txd3m0 */ - <3 RK_PA3 3 &pcfg_pull_none_drv_level_2>; - }; - - /omit-if-no-ref/ - gmac1m1_miim: gmac1m1-miim { - rockchip,pins = - /* gmac1_mdcm1 */ - <4 RK_PB6 3 &pcfg_pull_none>, - /* gmac1_mdiom1 */ - <4 RK_PB7 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m1_clkinout: gmac1m1-clkinout { - rockchip,pins = - /* gmac1_mclkinoutm1 */ - <4 RK_PC1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m1_rx_er: gmac1m1-rx-er { - rockchip,pins = - /* gmac1_rxerm1 */ - <4 RK_PB2 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m1_rx_bus2: gmac1m1-rx-bus2 { - rockchip,pins = - /* gmac1_rxd0m1 */ - <4 RK_PA7 3 &pcfg_pull_none>, - /* gmac1_rxd1m1 */ - <4 RK_PB0 3 &pcfg_pull_none>, - /* gmac1_rxdvcrsm1 */ - <4 RK_PB1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m1_tx_bus2: gmac1m1-tx-bus2 { - rockchip,pins = - /* gmac1_txd0m1 */ - <4 RK_PA4 3 &pcfg_pull_none_drv_level_2>, - /* gmac1_txd1m1 */ - <4 RK_PA5 3 &pcfg_pull_none_drv_level_2>, - /* gmac1_txenm1 */ - <4 RK_PA6 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m1_rgmii_clk: gmac1m1-rgmii-clk { - rockchip,pins = - /* gmac1_rxclkm1 */ - <4 RK_PA3 3 &pcfg_pull_none>, - /* gmac1_txclkm1 */ - <4 RK_PA0 3 &pcfg_pull_none_drv_level_1>; - }; - - /omit-if-no-ref/ - gmac1m1_rgmii_bus: gmac1m1-rgmii-bus { - rockchip,pins = - /* gmac1_rxd2m1 */ - <4 RK_PA1 3 &pcfg_pull_none>, - /* gmac1_rxd3m1 */ - <4 RK_PA2 3 &pcfg_pull_none>, - /* gmac1_txd2m1 */ - <3 RK_PD6 3 &pcfg_pull_none_drv_level_2>, - /* gmac1_txd3m1 */ - <3 RK_PD7 3 &pcfg_pull_none_drv_level_2>; - }; - }; - - gpu { - /omit-if-no-ref/ - gpu_pins: gpu-pins { - rockchip,pins = - /* gpu_avs */ - <0 RK_PC0 2 &pcfg_pull_none>, - /* gpu_pwren */ - <0 RK_PA6 4 &pcfg_pull_none>; - }; - }; - - hdmitx { - /omit-if-no-ref/ - hdmitxm0_cec: hdmitxm0-cec { - rockchip,pins = - /* hdmitxm0_cec */ - <4 RK_PD1 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - hdmitxm1_cec: hdmitxm1-cec { - rockchip,pins = - /* hdmitxm1_cec */ - <0 RK_PC7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - hdmitx_scl: hdmitx-scl { - rockchip,pins = - /* hdmitx_scl */ - <4 RK_PC7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - hdmitx_sda: hdmitx-sda { - rockchip,pins = - /* hdmitx_sda */ - <4 RK_PD0 1 &pcfg_pull_none>; - }; - }; - - i2c0 { - /omit-if-no-ref/ - i2c0_xfer: i2c0-xfer { - rockchip,pins = - /* i2c0_scl */ - <0 RK_PB1 1 &pcfg_pull_none_smt>, - /* i2c0_sda */ - <0 RK_PB2 1 &pcfg_pull_none_smt>; - }; - }; - - i2c1 { - /omit-if-no-ref/ - i2c1_xfer: i2c1-xfer { - rockchip,pins = - /* i2c1_scl */ - <0 RK_PB3 1 &pcfg_pull_none_smt>, - /* i2c1_sda */ - <0 RK_PB4 1 &pcfg_pull_none_smt>; - }; - }; - - i2c2 { - /omit-if-no-ref/ - i2c2m0_xfer: i2c2m0-xfer { - rockchip,pins = - /* i2c2_sclm0 */ - <0 RK_PB5 1 &pcfg_pull_none_smt>, - /* i2c2_sdam0 */ - <0 RK_PB6 1 &pcfg_pull_none_smt>; - }; - - /omit-if-no-ref/ - i2c2m1_xfer: i2c2m1-xfer { - rockchip,pins = - /* i2c2_sclm1 */ - <4 RK_PB5 1 &pcfg_pull_none_smt>, - /* i2c2_sdam1 */ - <4 RK_PB4 1 &pcfg_pull_none_smt>; - }; - }; - - i2c3 { - /omit-if-no-ref/ - i2c3m0_xfer: i2c3m0-xfer { - rockchip,pins = - /* i2c3_sclm0 */ - <1 RK_PA1 1 &pcfg_pull_none_smt>, - /* i2c3_sdam0 */ - <1 RK_PA0 1 &pcfg_pull_none_smt>; - }; - - /omit-if-no-ref/ - i2c3m1_xfer: i2c3m1-xfer { - rockchip,pins = - /* i2c3_sclm1 */ - <3 RK_PB5 4 &pcfg_pull_none_smt>, - /* i2c3_sdam1 */ - <3 RK_PB6 4 &pcfg_pull_none_smt>; - }; - }; - - i2c4 { - /omit-if-no-ref/ - i2c4m0_xfer: i2c4m0-xfer { - rockchip,pins = - /* i2c4_sclm0 */ - <4 RK_PB3 1 &pcfg_pull_none_smt>, - /* i2c4_sdam0 */ - <4 RK_PB2 1 &pcfg_pull_none_smt>; - }; - - /omit-if-no-ref/ - i2c4m1_xfer: i2c4m1-xfer { - rockchip,pins = - /* i2c4_sclm1 */ - <2 RK_PB2 2 &pcfg_pull_none_smt>, - /* i2c4_sdam1 */ - <2 RK_PB1 2 &pcfg_pull_none_smt>; - }; - }; - - i2c5 { - /omit-if-no-ref/ - i2c5m0_xfer: i2c5m0-xfer { - rockchip,pins = - /* i2c5_sclm0 */ - <3 RK_PB3 4 &pcfg_pull_none_smt>, - /* i2c5_sdam0 */ - <3 RK_PB4 4 &pcfg_pull_none_smt>; - }; - - /omit-if-no-ref/ - i2c5m1_xfer: i2c5m1-xfer { - rockchip,pins = - /* i2c5_sclm1 */ - <4 RK_PC7 2 &pcfg_pull_none_smt>, - /* i2c5_sdam1 */ - <4 RK_PD0 2 &pcfg_pull_none_smt>; - }; - }; - - i2s1 { - /omit-if-no-ref/ - i2s1m0_lrckrx: i2s1m0-lrckrx { - rockchip,pins = - /* i2s1m0_lrckrx */ - <1 RK_PA6 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_lrcktx: i2s1m0-lrcktx { - rockchip,pins = - /* i2s1m0_lrcktx */ - <1 RK_PA5 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_mclk: i2s1m0-mclk { - rockchip,pins = - /* i2s1m0_mclk */ - <1 RK_PA2 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sclkrx: i2s1m0-sclkrx { - rockchip,pins = - /* i2s1m0_sclkrx */ - <1 RK_PA4 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sclktx: i2s1m0-sclktx { - rockchip,pins = - /* i2s1m0_sclktx */ - <1 RK_PA3 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdi0: i2s1m0-sdi0 { - rockchip,pins = - /* i2s1m0_sdi0 */ - <1 RK_PB3 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdi1: i2s1m0-sdi1 { - rockchip,pins = - /* i2s1m0_sdi1 */ - <1 RK_PB2 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdi2: i2s1m0-sdi2 { - rockchip,pins = - /* i2s1m0_sdi2 */ - <1 RK_PB1 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdi3: i2s1m0-sdi3 { - rockchip,pins = - /* i2s1m0_sdi3 */ - <1 RK_PB0 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdo0: i2s1m0-sdo0 { - rockchip,pins = - /* i2s1m0_sdo0 */ - <1 RK_PA7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdo1: i2s1m0-sdo1 { - rockchip,pins = - /* i2s1m0_sdo1 */ - <1 RK_PB0 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdo2: i2s1m0-sdo2 { - rockchip,pins = - /* i2s1m0_sdo2 */ - <1 RK_PB1 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m0_sdo3: i2s1m0-sdo3 { - rockchip,pins = - /* i2s1m0_sdo3 */ - <1 RK_PB2 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_lrckrx: i2s1m1-lrckrx { - rockchip,pins = - /* i2s1m1_lrckrx */ - <4 RK_PA7 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_lrcktx: i2s1m1-lrcktx { - rockchip,pins = - /* i2s1m1_lrcktx */ - <3 RK_PD0 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_mclk: i2s1m1-mclk { - rockchip,pins = - /* i2s1m1_mclk */ - <3 RK_PC6 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sclkrx: i2s1m1-sclkrx { - rockchip,pins = - /* i2s1m1_sclkrx */ - <4 RK_PA6 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sclktx: i2s1m1-sclktx { - rockchip,pins = - /* i2s1m1_sclktx */ - <3 RK_PC7 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdi0: i2s1m1-sdi0 { - rockchip,pins = - /* i2s1m1_sdi0 */ - <3 RK_PD2 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdi1: i2s1m1-sdi1 { - rockchip,pins = - /* i2s1m1_sdi1 */ - <3 RK_PD3 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdi2: i2s1m1-sdi2 { - rockchip,pins = - /* i2s1m1_sdi2 */ - <3 RK_PD4 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdi3: i2s1m1-sdi3 { - rockchip,pins = - /* i2s1m1_sdi3 */ - <3 RK_PD5 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdo0: i2s1m1-sdo0 { - rockchip,pins = - /* i2s1m1_sdo0 */ - <3 RK_PD1 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdo1: i2s1m1-sdo1 { - rockchip,pins = - /* i2s1m1_sdo1 */ - <4 RK_PB0 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdo2: i2s1m1-sdo2 { - rockchip,pins = - /* i2s1m1_sdo2 */ - <4 RK_PB1 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m1_sdo3: i2s1m1-sdo3 { - rockchip,pins = - /* i2s1m1_sdo3 */ - <4 RK_PB5 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_lrckrx: i2s1m2-lrckrx { - rockchip,pins = - /* i2s1m2_lrckrx */ - <3 RK_PC5 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_lrcktx: i2s1m2-lrcktx { - rockchip,pins = - /* i2s1m2_lrcktx */ - <2 RK_PD2 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_mclk: i2s1m2-mclk { - rockchip,pins = - /* i2s1m2_mclk */ - <2 RK_PD0 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sclkrx: i2s1m2-sclkrx { - rockchip,pins = - /* i2s1m2_sclkrx */ - <3 RK_PC3 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sclktx: i2s1m2-sclktx { - rockchip,pins = - /* i2s1m2_sclktx */ - <2 RK_PD1 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdi0: i2s1m2-sdi0 { - rockchip,pins = - /* i2s1m2_sdi0 */ - <2 RK_PD3 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdi1: i2s1m2-sdi1 { - rockchip,pins = - /* i2s1m2_sdi1 */ - <2 RK_PD4 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdi2: i2s1m2-sdi2 { - rockchip,pins = - /* i2s1m2_sdi2 */ - <2 RK_PD5 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdi3: i2s1m2-sdi3 { - rockchip,pins = - /* i2s1m2_sdi3 */ - <2 RK_PD6 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdo0: i2s1m2-sdo0 { - rockchip,pins = - /* i2s1m2_sdo0 */ - <2 RK_PD7 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdo1: i2s1m2-sdo1 { - rockchip,pins = - /* i2s1m2_sdo1 */ - <3 RK_PA0 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdo2: i2s1m2-sdo2 { - rockchip,pins = - /* i2s1m2_sdo2 */ - <3 RK_PC1 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s1m2_sdo3: i2s1m2-sdo3 { - rockchip,pins = - /* i2s1m2_sdo3 */ - <3 RK_PC2 5 &pcfg_pull_none>; - }; - }; - - i2s2 { - /omit-if-no-ref/ - i2s2m0_lrckrx: i2s2m0-lrckrx { - rockchip,pins = - /* i2s2m0_lrckrx */ - <2 RK_PC0 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m0_lrcktx: i2s2m0-lrcktx { - rockchip,pins = - /* i2s2m0_lrcktx */ - <2 RK_PC3 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m0_mclk: i2s2m0-mclk { - rockchip,pins = - /* i2s2m0_mclk */ - <2 RK_PC1 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m0_sclkrx: i2s2m0-sclkrx { - rockchip,pins = - /* i2s2m0_sclkrx */ - <2 RK_PB7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m0_sclktx: i2s2m0-sclktx { - rockchip,pins = - /* i2s2m0_sclktx */ - <2 RK_PC2 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m0_sdi: i2s2m0-sdi { - rockchip,pins = - /* i2s2m0_sdi */ - <2 RK_PC5 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m0_sdo: i2s2m0-sdo { - rockchip,pins = - /* i2s2m0_sdo */ - <2 RK_PC4 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m1_lrckrx: i2s2m1-lrckrx { - rockchip,pins = - /* i2s2m1_lrckrx */ - <4 RK_PA5 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m1_lrcktx: i2s2m1-lrcktx { - rockchip,pins = - /* i2s2m1_lrcktx */ - <4 RK_PA4 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m1_mclk: i2s2m1-mclk { - rockchip,pins = - /* i2s2m1_mclk */ - <4 RK_PB6 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m1_sclkrx: i2s2m1-sclkrx { - rockchip,pins = - /* i2s2m1_sclkrx */ - <4 RK_PC1 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m1_sclktx: i2s2m1-sclktx { - rockchip,pins = - /* i2s2m1_sclktx */ - <4 RK_PB7 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m1_sdi: i2s2m1-sdi { - rockchip,pins = - /* i2s2m1_sdi */ - <4 RK_PB2 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s2m1_sdo: i2s2m1-sdo { - rockchip,pins = - /* i2s2m1_sdo */ - <4 RK_PB3 5 &pcfg_pull_none>; - }; - }; - - i2s3 { - /omit-if-no-ref/ - i2s3m0_lrck: i2s3m0-lrck { - rockchip,pins = - /* i2s3m0_lrck */ - <3 RK_PA4 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m0_mclk: i2s3m0-mclk { - rockchip,pins = - /* i2s3m0_mclk */ - <3 RK_PA2 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m0_sclk: i2s3m0-sclk { - rockchip,pins = - /* i2s3m0_sclk */ - <3 RK_PA3 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m0_sdi: i2s3m0-sdi { - rockchip,pins = - /* i2s3m0_sdi */ - <3 RK_PA6 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m0_sdo: i2s3m0-sdo { - rockchip,pins = - /* i2s3m0_sdo */ - <3 RK_PA5 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m1_lrck: i2s3m1-lrck { - rockchip,pins = - /* i2s3m1_lrck */ - <4 RK_PC4 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m1_mclk: i2s3m1-mclk { - rockchip,pins = - /* i2s3m1_mclk */ - <4 RK_PC2 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m1_sclk: i2s3m1-sclk { - rockchip,pins = - /* i2s3m1_sclk */ - <4 RK_PC3 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m1_sdi: i2s3m1-sdi { - rockchip,pins = - /* i2s3m1_sdi */ - <4 RK_PC6 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - i2s3m1_sdo: i2s3m1-sdo { - rockchip,pins = - /* i2s3m1_sdo */ - <4 RK_PC5 5 &pcfg_pull_none>; - }; - }; - - isp { - /omit-if-no-ref/ - isp_pins: isp-pins { - rockchip,pins = - /* isp_flashtrigin */ - <4 RK_PB4 4 &pcfg_pull_none>, - /* isp_flashtrigout */ - <4 RK_PA6 1 &pcfg_pull_none>, - /* isp_prelighttrig */ - <4 RK_PB1 1 &pcfg_pull_none>; - }; - }; - - jtag { - /omit-if-no-ref/ - jtag_pins: jtag-pins { - rockchip,pins = - /* jtag_tck */ - <1 RK_PD7 2 &pcfg_pull_none>, - /* jtag_tms */ - <2 RK_PA0 2 &pcfg_pull_none>; - }; - }; - - lcdc { - /omit-if-no-ref/ - lcdc_ctl: lcdc-ctl { - rockchip,pins = - /* lcdc_clk */ - <3 RK_PA0 1 &pcfg_pull_none>, - /* lcdc_d0 */ - <2 RK_PD0 1 &pcfg_pull_none>, - /* lcdc_d1 */ - <2 RK_PD1 1 &pcfg_pull_none>, - /* lcdc_d2 */ - <2 RK_PD2 1 &pcfg_pull_none>, - /* lcdc_d3 */ - <2 RK_PD3 1 &pcfg_pull_none>, - /* lcdc_d4 */ - <2 RK_PD4 1 &pcfg_pull_none>, - /* lcdc_d5 */ - <2 RK_PD5 1 &pcfg_pull_none>, - /* lcdc_d6 */ - <2 RK_PD6 1 &pcfg_pull_none>, - /* lcdc_d7 */ - <2 RK_PD7 1 &pcfg_pull_none>, - /* lcdc_d8 */ - <3 RK_PA1 1 &pcfg_pull_none>, - /* lcdc_d9 */ - <3 RK_PA2 1 &pcfg_pull_none>, - /* lcdc_d10 */ - <3 RK_PA3 1 &pcfg_pull_none>, - /* lcdc_d11 */ - <3 RK_PA4 1 &pcfg_pull_none>, - /* lcdc_d12 */ - <3 RK_PA5 1 &pcfg_pull_none>, - /* lcdc_d13 */ - <3 RK_PA6 1 &pcfg_pull_none>, - /* lcdc_d14 */ - <3 RK_PA7 1 &pcfg_pull_none>, - /* lcdc_d15 */ - <3 RK_PB0 1 &pcfg_pull_none>, - /* lcdc_d16 */ - <3 RK_PB1 1 &pcfg_pull_none>, - /* lcdc_d17 */ - <3 RK_PB2 1 &pcfg_pull_none>, - /* lcdc_d18 */ - <3 RK_PB3 1 &pcfg_pull_none>, - /* lcdc_d19 */ - <3 RK_PB4 1 &pcfg_pull_none>, - /* lcdc_d20 */ - <3 RK_PB5 1 &pcfg_pull_none>, - /* lcdc_d21 */ - <3 RK_PB6 1 &pcfg_pull_none>, - /* lcdc_d22 */ - <3 RK_PB7 1 &pcfg_pull_none>, - /* lcdc_d23 */ - <3 RK_PC0 1 &pcfg_pull_none>, - /* lcdc_den */ - <3 RK_PC3 1 &pcfg_pull_none>, - /* lcdc_hsync */ - <3 RK_PC1 1 &pcfg_pull_none>, - /* lcdc_vsync */ - <3 RK_PC2 1 &pcfg_pull_none>; - }; - }; - - mcu { - /omit-if-no-ref/ - mcu_pins: mcu-pins { - rockchip,pins = - /* mcu_jtagtck */ - <0 RK_PB4 4 &pcfg_pull_none>, - /* mcu_jtagtdi */ - <0 RK_PC1 4 &pcfg_pull_none>, - /* mcu_jtagtdo */ - <0 RK_PB3 4 &pcfg_pull_none>, - /* mcu_jtagtms */ - <0 RK_PC2 4 &pcfg_pull_none>, - /* mcu_jtagtrstn */ - <0 RK_PC3 4 &pcfg_pull_none>; - }; - }; - - npu { - /omit-if-no-ref/ - npu_pins: npu-pins { - rockchip,pins = - /* npu_avs */ - <0 RK_PC1 2 &pcfg_pull_none>; - }; - }; - - pcie20 { - /omit-if-no-ref/ - pcie20m0_pins: pcie20m0-pins { - rockchip,pins = - /* pcie20_clkreqnm0 */ - <0 RK_PA5 3 &pcfg_pull_none>, - /* pcie20_perstnm0 */ - <0 RK_PB6 3 &pcfg_pull_none>, - /* pcie20_wakenm0 */ - <0 RK_PB5 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie20m1_pins: pcie20m1-pins { - rockchip,pins = - /* pcie20_clkreqnm1 */ - <2 RK_PD0 4 &pcfg_pull_none>, - /* pcie20_perstnm1 */ - <3 RK_PC1 4 &pcfg_pull_none>, - /* pcie20_wakenm1 */ - <2 RK_PD1 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie20m2_pins: pcie20m2-pins { - rockchip,pins = - /* pcie20_clkreqnm2 */ - <1 RK_PB0 4 &pcfg_pull_none>, - /* pcie20_perstnm2 */ - <1 RK_PB2 4 &pcfg_pull_none>, - /* pcie20_wakenm2 */ - <1 RK_PB1 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie20_buttonrstn: pcie20-buttonrstn { - rockchip,pins = - /* pcie20_buttonrstn */ - <0 RK_PB4 3 &pcfg_pull_none>; - }; - }; - - pcie30x1 { - /omit-if-no-ref/ - pcie30x1m0_pins: pcie30x1m0-pins { - rockchip,pins = - /* pcie30x1_clkreqnm0 */ - <0 RK_PA4 3 &pcfg_pull_none>, - /* pcie30x1_perstnm0 */ - <0 RK_PC3 3 &pcfg_pull_none>, - /* pcie30x1_wakenm0 */ - <0 RK_PC2 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie30x1m1_pins: pcie30x1m1-pins { - rockchip,pins = - /* pcie30x1_clkreqnm1 */ - <2 RK_PD2 4 &pcfg_pull_none>, - /* pcie30x1_perstnm1 */ - <3 RK_PA1 4 &pcfg_pull_none>, - /* pcie30x1_wakenm1 */ - <2 RK_PD3 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie30x1m2_pins: pcie30x1m2-pins { - rockchip,pins = - /* pcie30x1_clkreqnm2 */ - <1 RK_PA5 4 &pcfg_pull_none>, - /* pcie30x1_perstnm2 */ - <1 RK_PA2 4 &pcfg_pull_none>, - /* pcie30x1_wakenm2 */ - <1 RK_PA3 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie30x1_buttonrstn: pcie30x1-buttonrstn { - rockchip,pins = - /* pcie30x1_buttonrstn */ - <0 RK_PB3 3 &pcfg_pull_none>; - }; - }; - - pcie30x2 { - /omit-if-no-ref/ - pcie30x2m0_pins: pcie30x2m0-pins { - rockchip,pins = - /* pcie30x2_clkreqnm0 */ - <0 RK_PA6 2 &pcfg_pull_none>, - /* pcie30x2_perstnm0 */ - <0 RK_PC6 3 &pcfg_pull_none>, - /* pcie30x2_wakenm0 */ - <0 RK_PC5 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie30x2m1_pins: pcie30x2m1-pins { - rockchip,pins = - /* pcie30x2_clkreqnm1 */ - <2 RK_PD4 4 &pcfg_pull_none>, - /* pcie30x2_perstnm1 */ - <2 RK_PD6 4 &pcfg_pull_none>, - /* pcie30x2_wakenm1 */ - <2 RK_PD5 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie30x2m2_pins: pcie30x2m2-pins { - rockchip,pins = - /* pcie30x2_clkreqnm2 */ - <4 RK_PC2 4 &pcfg_pull_none>, - /* pcie30x2_perstnm2 */ - <4 RK_PC4 4 &pcfg_pull_none>, - /* pcie30x2_wakenm2 */ - <4 RK_PC3 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pcie30x2_buttonrstn: pcie30x2-buttonrstn { - rockchip,pins = - /* pcie30x2_buttonrstn */ - <0 RK_PB0 3 &pcfg_pull_none>; - }; - }; - - pdm { - /omit-if-no-ref/ - pdmm0_clk: pdmm0-clk { - rockchip,pins = - /* pdm_clk0m0 */ - <1 RK_PA6 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm0_clk1: pdmm0-clk1 { - rockchip,pins = - /* pdmm0_clk1 */ - <1 RK_PA4 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm0_sdi0: pdmm0-sdi0 { - rockchip,pins = - /* pdmm0_sdi0 */ - <1 RK_PB3 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm0_sdi1: pdmm0-sdi1 { - rockchip,pins = - /* pdmm0_sdi1 */ - <1 RK_PB2 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm0_sdi2: pdmm0-sdi2 { - rockchip,pins = - /* pdmm0_sdi2 */ - <1 RK_PB1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm0_sdi3: pdmm0-sdi3 { - rockchip,pins = - /* pdmm0_sdi3 */ - <1 RK_PB0 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm1_clk: pdmm1-clk { - rockchip,pins = - /* pdm_clk0m1 */ - <3 RK_PD6 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm1_clk1: pdmm1-clk1 { - rockchip,pins = - /* pdmm1_clk1 */ - <4 RK_PA0 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm1_sdi0: pdmm1-sdi0 { - rockchip,pins = - /* pdmm1_sdi0 */ - <3 RK_PD7 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm1_sdi1: pdmm1-sdi1 { - rockchip,pins = - /* pdmm1_sdi1 */ - <4 RK_PA1 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm1_sdi2: pdmm1-sdi2 { - rockchip,pins = - /* pdmm1_sdi2 */ - <4 RK_PA2 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm1_sdi3: pdmm1-sdi3 { - rockchip,pins = - /* pdmm1_sdi3 */ - <4 RK_PA3 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm2_clk1: pdmm2-clk1 { - rockchip,pins = - /* pdmm2_clk1 */ - <3 RK_PC4 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm2_sdi0: pdmm2-sdi0 { - rockchip,pins = - /* pdmm2_sdi0 */ - <3 RK_PB3 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm2_sdi1: pdmm2-sdi1 { - rockchip,pins = - /* pdmm2_sdi1 */ - <3 RK_PB4 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm2_sdi2: pdmm2-sdi2 { - rockchip,pins = - /* pdmm2_sdi2 */ - <3 RK_PB7 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pdmm2_sdi3: pdmm2-sdi3 { - rockchip,pins = - /* pdmm2_sdi3 */ - <3 RK_PC0 5 &pcfg_pull_none>; - }; - }; - - pmic { - /omit-if-no-ref/ - pmic_pins: pmic-pins { - rockchip,pins = - /* pmic_sleep */ - <0 RK_PA2 1 &pcfg_pull_none>; - }; - }; - - pmu { - /omit-if-no-ref/ - pmu_pins: pmu-pins { - rockchip,pins = - /* pmu_debug0 */ - <0 RK_PA5 4 &pcfg_pull_none>, - /* pmu_debug1 */ - <0 RK_PA6 3 &pcfg_pull_none>, - /* pmu_debug2 */ - <0 RK_PC4 4 &pcfg_pull_none>, - /* pmu_debug3 */ - <0 RK_PC5 4 &pcfg_pull_none>, - /* pmu_debug4 */ - <0 RK_PC6 4 &pcfg_pull_none>, - /* pmu_debug5 */ - <0 RK_PC7 4 &pcfg_pull_none>; - }; - }; - - pwm0 { - /omit-if-no-ref/ - pwm0m0_pins: pwm0m0-pins { - rockchip,pins = - /* pwm0_m0 */ - <0 RK_PB7 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm0m1_pins: pwm0m1-pins { - rockchip,pins = - /* pwm0_m1 */ - <0 RK_PC7 2 &pcfg_pull_none>; - }; - }; - - pwm1 { - /omit-if-no-ref/ - pwm1m0_pins: pwm1m0-pins { - rockchip,pins = - /* pwm1_m0 */ - <0 RK_PC0 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm1m1_pins: pwm1m1-pins { - rockchip,pins = - /* pwm1_m1 */ - <0 RK_PB5 4 &pcfg_pull_none>; - }; - }; - - pwm2 { - /omit-if-no-ref/ - pwm2m0_pins: pwm2m0-pins { - rockchip,pins = - /* pwm2_m0 */ - <0 RK_PC1 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm2m1_pins: pwm2m1-pins { - rockchip,pins = - /* pwm2_m1 */ - <0 RK_PB6 4 &pcfg_pull_none>; - }; - }; - - pwm3 { - /omit-if-no-ref/ - pwm3_pins: pwm3-pins { - rockchip,pins = - /* pwm3_ir */ - <0 RK_PC2 1 &pcfg_pull_none>; - }; - }; - - pwm4 { - /omit-if-no-ref/ - pwm4_pins: pwm4-pins { - rockchip,pins = - /* pwm4 */ - <0 RK_PC3 1 &pcfg_pull_none>; - }; - }; - - pwm5 { - /omit-if-no-ref/ - pwm5_pins: pwm5-pins { - rockchip,pins = - /* pwm5 */ - <0 RK_PC4 1 &pcfg_pull_none>; - }; - }; - - pwm6 { - /omit-if-no-ref/ - pwm6_pins: pwm6-pins { - rockchip,pins = - /* pwm6 */ - <0 RK_PC5 1 &pcfg_pull_none>; - }; - }; - - pwm7 { - /omit-if-no-ref/ - pwm7_pins: pwm7-pins { - rockchip,pins = - /* pwm7_ir */ - <0 RK_PC6 1 &pcfg_pull_none>; - }; - }; - - pwm8 { - /omit-if-no-ref/ - pwm8m0_pins: pwm8m0-pins { - rockchip,pins = - /* pwm8_m0 */ - <3 RK_PB1 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm8m1_pins: pwm8m1-pins { - rockchip,pins = - /* pwm8_m1 */ - <1 RK_PD5 4 &pcfg_pull_none>; - }; - }; - - pwm9 { - /omit-if-no-ref/ - pwm9m0_pins: pwm9m0-pins { - rockchip,pins = - /* pwm9_m0 */ - <3 RK_PB2 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm9m1_pins: pwm9m1-pins { - rockchip,pins = - /* pwm9_m1 */ - <1 RK_PD6 4 &pcfg_pull_none>; - }; - }; - - pwm10 { - /omit-if-no-ref/ - pwm10m0_pins: pwm10m0-pins { - rockchip,pins = - /* pwm10_m0 */ - <3 RK_PB5 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm10m1_pins: pwm10m1-pins { - rockchip,pins = - /* pwm10_m1 */ - <2 RK_PA1 2 &pcfg_pull_none>; - }; - }; - - pwm11 { - /omit-if-no-ref/ - pwm11m0_pins: pwm11m0-pins { - rockchip,pins = - /* pwm11_irm0 */ - <3 RK_PB6 5 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm11m1_pins: pwm11m1-pins { - rockchip,pins = - /* pwm11_irm1 */ - <4 RK_PC0 3 &pcfg_pull_none>; - }; - }; - - pwm12 { - /omit-if-no-ref/ - pwm12m0_pins: pwm12m0-pins { - rockchip,pins = - /* pwm12_m0 */ - <3 RK_PB7 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm12m1_pins: pwm12m1-pins { - rockchip,pins = - /* pwm12_m1 */ - <4 RK_PC5 1 &pcfg_pull_none>; - }; - }; - - pwm13 { - /omit-if-no-ref/ - pwm13m0_pins: pwm13m0-pins { - rockchip,pins = - /* pwm13_m0 */ - <3 RK_PC0 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm13m1_pins: pwm13m1-pins { - rockchip,pins = - /* pwm13_m1 */ - <4 RK_PC6 1 &pcfg_pull_none>; - }; - }; - - pwm14 { - /omit-if-no-ref/ - pwm14m0_pins: pwm14m0-pins { - rockchip,pins = - /* pwm14_m0 */ - <3 RK_PC4 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm14m1_pins: pwm14m1-pins { - rockchip,pins = - /* pwm14_m1 */ - <4 RK_PC2 1 &pcfg_pull_none>; - }; - }; - - pwm15 { - /omit-if-no-ref/ - pwm15m0_pins: pwm15m0-pins { - rockchip,pins = - /* pwm15_irm0 */ - <3 RK_PC5 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - pwm15m1_pins: pwm15m1-pins { - rockchip,pins = - /* pwm15_irm1 */ - <4 RK_PC3 1 &pcfg_pull_none>; - }; - }; - - refclk { - /omit-if-no-ref/ - refclk_pins: refclk-pins { - rockchip,pins = - /* refclk_ou */ - <0 RK_PA0 1 &pcfg_pull_none>; - }; - }; - - sata { - /omit-if-no-ref/ - sata_pins: sata-pins { - rockchip,pins = - /* sata_cpdet */ - <0 RK_PA4 2 &pcfg_pull_none>, - /* sata_cppod */ - <0 RK_PA6 1 &pcfg_pull_none>, - /* sata_mpswitch */ - <0 RK_PA5 2 &pcfg_pull_none>; - }; - }; - - sata0 { - /omit-if-no-ref/ - sata0_pins: sata0-pins { - rockchip,pins = - /* sata0_actled */ - <4 RK_PC6 3 &pcfg_pull_none>; - }; - }; - - sata1 { - /omit-if-no-ref/ - sata1_pins: sata1-pins { - rockchip,pins = - /* sata1_actled */ - <4 RK_PC5 3 &pcfg_pull_none>; - }; - }; - - sata2 { - /omit-if-no-ref/ - sata2_pins: sata2-pins { - rockchip,pins = - /* sata2_actled */ - <4 RK_PC4 3 &pcfg_pull_none>; - }; - }; - - scr { - /omit-if-no-ref/ - scr_pins: scr-pins { - rockchip,pins = - /* scr_clk */ - <1 RK_PA2 3 &pcfg_pull_none>, - /* scr_det */ - <1 RK_PA7 3 &pcfg_pull_up>, - /* scr_io */ - <1 RK_PA3 3 &pcfg_pull_up>, - /* scr_rst */ - <1 RK_PA5 3 &pcfg_pull_none>; - }; - }; - - sdmmc0 { - /omit-if-no-ref/ - sdmmc0_bus4: sdmmc0-bus4 { - rockchip,pins = - /* sdmmc0_d0 */ - <1 RK_PD5 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc0_d1 */ - <1 RK_PD6 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc0_d2 */ - <1 RK_PD7 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc0_d3 */ - <2 RK_PA0 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc0_clk: sdmmc0-clk { - rockchip,pins = - /* sdmmc0_clk */ - <2 RK_PA2 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc0_cmd: sdmmc0-cmd { - rockchip,pins = - /* sdmmc0_cmd */ - <2 RK_PA1 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc0_det: sdmmc0-det { - rockchip,pins = - /* sdmmc0_det */ - <0 RK_PA4 1 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - sdmmc0_pwren: sdmmc0-pwren { - rockchip,pins = - /* sdmmc0_pwren */ - <0 RK_PA5 1 &pcfg_pull_none>; - }; - }; - - sdmmc1 { - /omit-if-no-ref/ - sdmmc1_bus4: sdmmc1-bus4 { - rockchip,pins = - /* sdmmc1_d0 */ - <2 RK_PA3 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc1_d1 */ - <2 RK_PA4 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc1_d2 */ - <2 RK_PA5 1 &pcfg_pull_up_drv_level_2>, - /* sdmmc1_d3 */ - <2 RK_PA6 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc1_clk: sdmmc1-clk { - rockchip,pins = - /* sdmmc1_clk */ - <2 RK_PB0 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc1_cmd: sdmmc1-cmd { - rockchip,pins = - /* sdmmc1_cmd */ - <2 RK_PA7 1 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc1_det: sdmmc1-det { - rockchip,pins = - /* sdmmc1_det */ - <2 RK_PB2 1 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - sdmmc1_pwren: sdmmc1-pwren { - rockchip,pins = - /* sdmmc1_pwren */ - <2 RK_PB1 1 &pcfg_pull_none>; - }; - }; - - sdmmc2 { - /omit-if-no-ref/ - sdmmc2m0_bus4: sdmmc2m0-bus4 { - rockchip,pins = - /* sdmmc2_d0m0 */ - <3 RK_PC6 3 &pcfg_pull_up_drv_level_2>, - /* sdmmc2_d1m0 */ - <3 RK_PC7 3 &pcfg_pull_up_drv_level_2>, - /* sdmmc2_d2m0 */ - <3 RK_PD0 3 &pcfg_pull_up_drv_level_2>, - /* sdmmc2_d3m0 */ - <3 RK_PD1 3 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc2m0_clk: sdmmc2m0-clk { - rockchip,pins = - /* sdmmc2_clkm0 */ - <3 RK_PD3 3 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc2m0_cmd: sdmmc2m0-cmd { - rockchip,pins = - /* sdmmc2_cmdm0 */ - <3 RK_PD2 3 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc2m0_det: sdmmc2m0-det { - rockchip,pins = - /* sdmmc2_detm0 */ - <3 RK_PD4 3 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - sdmmc2m0_pwren: sdmmc2m0-pwren { - rockchip,pins = - /* sdmmc2m0_pwren */ - <3 RK_PD5 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - sdmmc2m1_bus4: sdmmc2m1-bus4 { - rockchip,pins = - /* sdmmc2_d0m1 */ - <3 RK_PA1 5 &pcfg_pull_up_drv_level_2>, - /* sdmmc2_d1m1 */ - <3 RK_PA2 5 &pcfg_pull_up_drv_level_2>, - /* sdmmc2_d2m1 */ - <3 RK_PA3 5 &pcfg_pull_up_drv_level_2>, - /* sdmmc2_d3m1 */ - <3 RK_PA4 5 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc2m1_clk: sdmmc2m1-clk { - rockchip,pins = - /* sdmmc2_clkm1 */ - <3 RK_PA6 5 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc2m1_cmd: sdmmc2m1-cmd { - rockchip,pins = - /* sdmmc2_cmdm1 */ - <3 RK_PA5 5 &pcfg_pull_up_drv_level_2>; - }; - - /omit-if-no-ref/ - sdmmc2m1_det: sdmmc2m1-det { - rockchip,pins = - /* sdmmc2_detm1 */ - <3 RK_PA7 4 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - sdmmc2m1_pwren: sdmmc2m1-pwren { - rockchip,pins = - /* sdmmc2m1_pwren */ - <3 RK_PB0 4 &pcfg_pull_none>; - }; - }; - - spdif { - /omit-if-no-ref/ - spdifm0_tx: spdifm0-tx { - rockchip,pins = - /* spdifm0_tx */ - <1 RK_PA4 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spdifm1_tx: spdifm1-tx { - rockchip,pins = - /* spdifm1_tx */ - <3 RK_PC5 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spdifm2_tx: spdifm2-tx { - rockchip,pins = - /* spdifm2_tx */ - <4 RK_PC4 2 &pcfg_pull_none>; - }; - }; - - spi0 { - /omit-if-no-ref/ - spi0m0_pins: spi0m0-pins { - rockchip,pins = - /* spi0_clkm0 */ - <0 RK_PB5 2 &pcfg_pull_none>, - /* spi0_misom0 */ - <0 RK_PC5 2 &pcfg_pull_none>, - /* spi0_mosim0 */ - <0 RK_PB6 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi0m0_cs0: spi0m0-cs0 { - rockchip,pins = - /* spi0_cs0m0 */ - <0 RK_PC6 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi0m0_cs1: spi0m0-cs1 { - rockchip,pins = - /* spi0_cs1m0 */ - <0 RK_PC4 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi0m1_pins: spi0m1-pins { - rockchip,pins = - /* spi0_clkm1 */ - <2 RK_PD3 3 &pcfg_pull_none>, - /* spi0_misom1 */ - <2 RK_PD0 3 &pcfg_pull_none>, - /* spi0_mosim1 */ - <2 RK_PD1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi0m1_cs0: spi0m1-cs0 { - rockchip,pins = - /* spi0_cs0m1 */ - <2 RK_PD2 3 &pcfg_pull_none>; - }; - }; - - spi1 { - /omit-if-no-ref/ - spi1m0_pins: spi1m0-pins { - rockchip,pins = - /* spi1_clkm0 */ - <2 RK_PB5 3 &pcfg_pull_none>, - /* spi1_misom0 */ - <2 RK_PB6 3 &pcfg_pull_none>, - /* spi1_mosim0 */ - <2 RK_PB7 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi1m0_cs0: spi1m0-cs0 { - rockchip,pins = - /* spi1_cs0m0 */ - <2 RK_PC0 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi1m0_cs1: spi1m0-cs1 { - rockchip,pins = - /* spi1_cs1m0 */ - <2 RK_PC6 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi1m1_pins: spi1m1-pins { - rockchip,pins = - /* spi1_clkm1 */ - <3 RK_PC3 3 &pcfg_pull_none>, - /* spi1_misom1 */ - <3 RK_PC2 3 &pcfg_pull_none>, - /* spi1_mosim1 */ - <3 RK_PC1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi1m1_cs0: spi1m1-cs0 { - rockchip,pins = - /* spi1_cs0m1 */ - <3 RK_PA1 3 &pcfg_pull_none>; - }; - }; - - spi2 { - /omit-if-no-ref/ - spi2m0_pins: spi2m0-pins { - rockchip,pins = - /* spi2_clkm0 */ - <2 RK_PC1 4 &pcfg_pull_none>, - /* spi2_misom0 */ - <2 RK_PC2 4 &pcfg_pull_none>, - /* spi2_mosim0 */ - <2 RK_PC3 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi2m0_cs0: spi2m0-cs0 { - rockchip,pins = - /* spi2_cs0m0 */ - <2 RK_PC4 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi2m0_cs1: spi2m0-cs1 { - rockchip,pins = - /* spi2_cs1m0 */ - <2 RK_PC5 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi2m1_pins: spi2m1-pins { - rockchip,pins = - /* spi2_clkm1 */ - <3 RK_PA0 3 &pcfg_pull_none>, - /* spi2_misom1 */ - <2 RK_PD7 3 &pcfg_pull_none>, - /* spi2_mosim1 */ - <2 RK_PD6 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi2m1_cs0: spi2m1-cs0 { - rockchip,pins = - /* spi2_cs0m1 */ - <2 RK_PD5 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi2m1_cs1: spi2m1-cs1 { - rockchip,pins = - /* spi2_cs1m1 */ - <2 RK_PD4 3 &pcfg_pull_none>; - }; - }; - - spi3 { - /omit-if-no-ref/ - spi3m0_pins: spi3m0-pins { - rockchip,pins = - /* spi3_clkm0 */ - <4 RK_PB3 4 &pcfg_pull_none>, - /* spi3_misom0 */ - <4 RK_PB0 4 &pcfg_pull_none>, - /* spi3_mosim0 */ - <4 RK_PB2 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi3m0_cs0: spi3m0-cs0 { - rockchip,pins = - /* spi3_cs0m0 */ - <4 RK_PA6 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi3m0_cs1: spi3m0-cs1 { - rockchip,pins = - /* spi3_cs1m0 */ - <4 RK_PA7 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi3m1_pins: spi3m1-pins { - rockchip,pins = - /* spi3_clkm1 */ - <4 RK_PC2 2 &pcfg_pull_none>, - /* spi3_misom1 */ - <4 RK_PC5 2 &pcfg_pull_none>, - /* spi3_mosim1 */ - <4 RK_PC3 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi3m1_cs0: spi3m1-cs0 { - rockchip,pins = - /* spi3_cs0m1 */ - <4 RK_PC6 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - spi3m1_cs1: spi3m1-cs1 { - rockchip,pins = - /* spi3_cs1m1 */ - <4 RK_PD1 2 &pcfg_pull_none>; - }; - }; - - tsadc { - /omit-if-no-ref/ - tsadcm0_shut: tsadcm0-shut { - rockchip,pins = - /* tsadcm0_shut */ - <0 RK_PA1 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - tsadcm1_shut: tsadcm1-shut { - rockchip,pins = - /* tsadcm1_shut */ - <0 RK_PA2 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - tsadc_shutorg: tsadc-shutorg { - rockchip,pins = - /* tsadc_shutorg */ - <0 RK_PA1 2 &pcfg_pull_none>; - }; - }; - - uart0 { - /omit-if-no-ref/ - uart0_xfer: uart0-xfer { - rockchip,pins = - /* uart0_rx */ - <0 RK_PC0 3 &pcfg_pull_up>, - /* uart0_tx */ - <0 RK_PC1 3 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart0_ctsn: uart0-ctsn { - rockchip,pins = - /* uart0_ctsn */ - <0 RK_PC7 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart0_rtsn: uart0-rtsn { - rockchip,pins = - /* uart0_rtsn */ - <0 RK_PC4 3 &pcfg_pull_none>; - }; - }; - - uart1 { - /omit-if-no-ref/ - uart1m0_xfer: uart1m0-xfer { - rockchip,pins = - /* uart1_rxm0 */ - <2 RK_PB3 2 &pcfg_pull_up>, - /* uart1_txm0 */ - <2 RK_PB4 2 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart1m0_ctsn: uart1m0-ctsn { - rockchip,pins = - /* uart1m0_ctsn */ - <2 RK_PB6 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart1m0_rtsn: uart1m0-rtsn { - rockchip,pins = - /* uart1m0_rtsn */ - <2 RK_PB5 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart1m1_xfer: uart1m1-xfer { - rockchip,pins = - /* uart1_rxm1 */ - <3 RK_PD7 4 &pcfg_pull_up>, - /* uart1_txm1 */ - <3 RK_PD6 4 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart1m1_ctsn: uart1m1-ctsn { - rockchip,pins = - /* uart1m1_ctsn */ - <4 RK_PC1 4 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart1m1_rtsn: uart1m1-rtsn { - rockchip,pins = - /* uart1m1_rtsn */ - <4 RK_PB6 4 &pcfg_pull_none>; - }; - }; - - uart2 { - /omit-if-no-ref/ - uart2m0_xfer: uart2m0-xfer { - rockchip,pins = - /* uart2_rxm0 */ - <0 RK_PD0 1 &pcfg_pull_up>, - /* uart2_txm0 */ - <0 RK_PD1 1 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart2m1_xfer: uart2m1-xfer { - rockchip,pins = - /* uart2_rxm1 */ - <1 RK_PD6 2 &pcfg_pull_up>, - /* uart2_txm1 */ - <1 RK_PD5 2 &pcfg_pull_up>; - }; - }; - - uart3 { - /omit-if-no-ref/ - uart3m0_xfer: uart3m0-xfer { - rockchip,pins = - /* uart3_rxm0 */ - <1 RK_PA0 2 &pcfg_pull_up>, - /* uart3_txm0 */ - <1 RK_PA1 2 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart3m0_ctsn: uart3m0-ctsn { - rockchip,pins = - /* uart3m0_ctsn */ - <1 RK_PA3 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart3m0_rtsn: uart3m0-rtsn { - rockchip,pins = - /* uart3m0_rtsn */ - <1 RK_PA2 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart3m1_xfer: uart3m1-xfer { - rockchip,pins = - /* uart3_rxm1 */ - <3 RK_PC0 4 &pcfg_pull_up>, - /* uart3_txm1 */ - <3 RK_PB7 4 &pcfg_pull_up>; - }; - }; - - uart4 { - /omit-if-no-ref/ - uart4m0_xfer: uart4m0-xfer { - rockchip,pins = - /* uart4_rxm0 */ - <1 RK_PA4 2 &pcfg_pull_up>, - /* uart4_txm0 */ - <1 RK_PA6 2 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart4m0_ctsn: uart4m0-ctsn { - rockchip,pins = - /* uart4m0_ctsn */ - <1 RK_PA7 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart4m0_rtsn: uart4m0-rtsn { - rockchip,pins = - /* uart4m0_rtsn */ - <1 RK_PA5 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart4m1_xfer: uart4m1-xfer { - rockchip,pins = - /* uart4_rxm1 */ - <3 RK_PB1 4 &pcfg_pull_up>, - /* uart4_txm1 */ - <3 RK_PB2 4 &pcfg_pull_up>; - }; - }; - - uart5 { - /omit-if-no-ref/ - uart5m0_xfer: uart5m0-xfer { - rockchip,pins = - /* uart5_rxm0 */ - <2 RK_PA1 3 &pcfg_pull_up>, - /* uart5_txm0 */ - <2 RK_PA2 3 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart5m0_ctsn: uart5m0-ctsn { - rockchip,pins = - /* uart5m0_ctsn */ - <1 RK_PD7 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart5m0_rtsn: uart5m0-rtsn { - rockchip,pins = - /* uart5m0_rtsn */ - <2 RK_PA0 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart5m1_xfer: uart5m1-xfer { - rockchip,pins = - /* uart5_rxm1 */ - <3 RK_PC3 4 &pcfg_pull_up>, - /* uart5_txm1 */ - <3 RK_PC2 4 &pcfg_pull_up>; - }; - }; - - uart6 { - /omit-if-no-ref/ - uart6m0_xfer: uart6m0-xfer { - rockchip,pins = - /* uart6_rxm0 */ - <2 RK_PA3 3 &pcfg_pull_up>, - /* uart6_txm0 */ - <2 RK_PA4 3 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart6m0_ctsn: uart6m0-ctsn { - rockchip,pins = - /* uart6m0_ctsn */ - <2 RK_PC0 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart6m0_rtsn: uart6m0-rtsn { - rockchip,pins = - /* uart6m0_rtsn */ - <2 RK_PB7 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart6m1_xfer: uart6m1-xfer { - rockchip,pins = - /* uart6_rxm1 */ - <1 RK_PD6 3 &pcfg_pull_up>, - /* uart6_txm1 */ - <1 RK_PD5 3 &pcfg_pull_up>; - }; - }; - - uart7 { - /omit-if-no-ref/ - uart7m0_xfer: uart7m0-xfer { - rockchip,pins = - /* uart7_rxm0 */ - <2 RK_PA5 3 &pcfg_pull_up>, - /* uart7_txm0 */ - <2 RK_PA6 3 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart7m0_ctsn: uart7m0-ctsn { - rockchip,pins = - /* uart7m0_ctsn */ - <2 RK_PC2 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart7m0_rtsn: uart7m0-rtsn { - rockchip,pins = - /* uart7m0_rtsn */ - <2 RK_PC1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart7m1_xfer: uart7m1-xfer { - rockchip,pins = - /* uart7_rxm1 */ - <3 RK_PC5 4 &pcfg_pull_up>, - /* uart7_txm1 */ - <3 RK_PC4 4 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart7m2_xfer: uart7m2-xfer { - rockchip,pins = - /* uart7_rxm2 */ - <4 RK_PA3 4 &pcfg_pull_up>, - /* uart7_txm2 */ - <4 RK_PA2 4 &pcfg_pull_up>; - }; - }; - - uart8 { - /omit-if-no-ref/ - uart8m0_xfer: uart8m0-xfer { - rockchip,pins = - /* uart8_rxm0 */ - <2 RK_PC6 2 &pcfg_pull_up>, - /* uart8_txm0 */ - <2 RK_PC5 3 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart8m0_ctsn: uart8m0-ctsn { - rockchip,pins = - /* uart8m0_ctsn */ - <2 RK_PB2 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart8m0_rtsn: uart8m0-rtsn { - rockchip,pins = - /* uart8m0_rtsn */ - <2 RK_PB1 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart8m1_xfer: uart8m1-xfer { - rockchip,pins = - /* uart8_rxm1 */ - <3 RK_PA0 4 &pcfg_pull_up>, - /* uart8_txm1 */ - <2 RK_PD7 4 &pcfg_pull_up>; - }; - }; - - uart9 { - /omit-if-no-ref/ - uart9m0_xfer: uart9m0-xfer { - rockchip,pins = - /* uart9_rxm0 */ - <2 RK_PA7 3 &pcfg_pull_up>, - /* uart9_txm0 */ - <2 RK_PB0 3 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart9m0_ctsn: uart9m0-ctsn { - rockchip,pins = - /* uart9m0_ctsn */ - <2 RK_PC4 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart9m0_rtsn: uart9m0-rtsn { - rockchip,pins = - /* uart9m0_rtsn */ - <2 RK_PC3 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - uart9m1_xfer: uart9m1-xfer { - rockchip,pins = - /* uart9_rxm1 */ - <4 RK_PC6 4 &pcfg_pull_up>, - /* uart9_txm1 */ - <4 RK_PC5 4 &pcfg_pull_up>; - }; - - /omit-if-no-ref/ - uart9m2_xfer: uart9m2-xfer { - rockchip,pins = - /* uart9_rxm2 */ - <4 RK_PA5 4 &pcfg_pull_up>, - /* uart9_txm2 */ - <4 RK_PA4 4 &pcfg_pull_up>; - }; - }; - - vop { - /omit-if-no-ref/ - vopm0_pins: vopm0-pins { - rockchip,pins = - /* vop_pwmm0 */ - <0 RK_PC3 2 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - vopm1_pins: vopm1-pins { - rockchip,pins = - /* vop_pwmm1 */ - <3 RK_PC4 2 &pcfg_pull_none>; - }; - }; -}; - -/* - * This part is edited handly. - */ -&pinctrl { - spi0-hs { - /omit-if-no-ref/ - spi0m0_pins_hs: spi0m0-pins { - rockchip,pins = - /* spi0_clkm0 */ - <0 RK_PB5 2 &pcfg_pull_up_drv_level_1>, - /* spi0_misom0 */ - <0 RK_PC5 2 &pcfg_pull_up_drv_level_1>, - /* spi0_mosim0 */ - <0 RK_PB6 2 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi0m0_cs0_hs: spi0m0-cs0 { - rockchip,pins = - /* spi0_cs0m0 */ - <0 RK_PC6 2 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi0m0_cs1_hs: spi0m0-cs1 { - rockchip,pins = - /* spi0_cs1m0 */ - <0 RK_PC4 2 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi0m1_pins_hs: spi0m1-pins { - rockchip,pins = - /* spi0_clkm1 */ - <2 RK_PD3 3 &pcfg_pull_up_drv_level_1>, - /* spi0_misom1 */ - <2 RK_PD0 3 &pcfg_pull_up_drv_level_1>, - /* spi0_mosim1 */ - <2 RK_PD1 3 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi0m1_cs0_hs: spi0m1-cs0 { - rockchip,pins = - /* spi0_cs0m1 */ - <2 RK_PD2 3 &pcfg_pull_up_drv_level_1>; - }; - }; - - spi1-hs { - /omit-if-no-ref/ - spi1m0_pins_hs: spi1m0-pins { - rockchip,pins = - /* spi1_clkm0 */ - <2 RK_PB5 3 &pcfg_pull_up_drv_level_1>, - /* spi1_misom0 */ - <2 RK_PB6 3 &pcfg_pull_up_drv_level_1>, - /* spi1_mosim0 */ - <2 RK_PB7 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi1m0_cs0_hs: spi1m0-cs0 { - rockchip,pins = - /* spi1_cs0m0 */ - <2 RK_PC0 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi1m0_cs1_hs: spi1m0-cs1 { - rockchip,pins = - /* spi1_cs1m0 */ - <2 RK_PC6 3 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi1m1_pins_hs: spi1m1-pins { - rockchip,pins = - /* spi1_clkm1 */ - <3 RK_PC3 3 &pcfg_pull_up_drv_level_1>, - /* spi1_misom1 */ - <3 RK_PC2 3 &pcfg_pull_up_drv_level_1>, - /* spi1_mosim1 */ - <3 RK_PC1 3 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi1m1_cs0_hs: spi1m1-cs0 { - rockchip,pins = - /* spi1_cs0m1 */ - <3 RK_PA1 3 &pcfg_pull_up_drv_level_1>; - }; - }; - - spi2-hs { - /omit-if-no-ref/ - spi2m0_pins_hs: spi2m0-pins { - rockchip,pins = - /* spi2_clkm0 */ - <2 RK_PC1 4 &pcfg_pull_up_drv_level_1>, - /* spi2_misom0 */ - <2 RK_PC2 4 &pcfg_pull_up_drv_level_1>, - /* spi2_mosim0 */ - <2 RK_PC3 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi2m0_cs0_hs: spi2m0-cs0 { - rockchip,pins = - /* spi2_cs0m0 */ - <2 RK_PC4 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi2m0_cs1_hs: spi2m0-cs1 { - rockchip,pins = - /* spi2_cs1m0 */ - <2 RK_PC5 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi2m1_pins_hs: spi2m1-pins { - rockchip,pins = - /* spi2_clkm1 */ - <3 RK_PA0 3 &pcfg_pull_up_drv_level_1>, - /* spi2_misom1 */ - <2 RK_PD7 3 &pcfg_pull_up_drv_level_1>, - /* spi2_mosim1 */ - <2 RK_PD6 3 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi2m1_cs0_hs: spi2m1-cs0 { - rockchip,pins = - /* spi2_cs0m1 */ - <2 RK_PD5 3 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi2m1_cs1_hs: spi2m1-cs1 { - rockchip,pins = - /* spi2_cs1m1 */ - <2 RK_PD4 3 &pcfg_pull_up_drv_level_1>; - }; - }; - - spi3-hs { - /omit-if-no-ref/ - spi3m0_pins_hs: spi3m0-pins { - rockchip,pins = - /* spi3_clkm0 */ - <4 RK_PB3 4 &pcfg_pull_up_drv_level_1>, - /* spi3_misom0 */ - <4 RK_PB0 4 &pcfg_pull_up_drv_level_1>, - /* spi3_mosim0 */ - <4 RK_PB2 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi3m0_cs0_hs: spi3m0-cs0 { - rockchip,pins = - /* spi3_cs0m0 */ - <4 RK_PA6 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi3m0_cs1_hs: spi3m0-cs1 { - rockchip,pins = - /* spi3_cs1m0 */ - <4 RK_PA7 4 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi3m1_pins_hs: spi3m1-pins { - rockchip,pins = - /* spi3_clkm1 */ - <4 RK_PC2 2 &pcfg_pull_up_drv_level_1>, - /* spi3_misom1 */ - <4 RK_PC5 2 &pcfg_pull_up_drv_level_1>, - /* spi3_mosim1 */ - <4 RK_PC3 2 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi3m1_cs0_hs: spi3m1-cs0 { - rockchip,pins = - /* spi3_cs0m1 */ - <4 RK_PC6 2 &pcfg_pull_up_drv_level_1>; - }; - - /omit-if-no-ref/ - spi3m1_cs1_hs: spi3m1-cs1 { - rockchip,pins = - /* spi3_cs1m1 */ - <4 RK_PD1 2 &pcfg_pull_up_drv_level_1>; - }; - }; - - gmac-txd-level3 { - /omit-if-no-ref/ - gmac0_tx_bus2_level3: gmac0-tx-bus2-level3 { - rockchip,pins = - /* gmac0_txd0 */ - <2 RK_PB3 1 &pcfg_pull_none_drv_level_3>, - /* gmac0_txd1 */ - <2 RK_PB4 1 &pcfg_pull_none_drv_level_3>, - /* gmac0_txen */ - <2 RK_PB5 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac0_rgmii_bus_level3: gmac0-rgmii-bus-level3 { - rockchip,pins = - /* gmac0_rxd2 */ - <2 RK_PA3 2 &pcfg_pull_none>, - /* gmac0_rxd3 */ - <2 RK_PA4 2 &pcfg_pull_none>, - /* gmac0_txd2 */ - <2 RK_PA6 2 &pcfg_pull_none_drv_level_3>, - /* gmac0_txd3 */ - <2 RK_PA7 2 &pcfg_pull_none_drv_level_3>; - }; - - /omit-if-no-ref/ - gmac1m0_tx_bus2_level3: gmac1m0-tx-bus2-level3 { - rockchip,pins = - /* gmac1_txd0m0 */ - <3 RK_PB5 3 &pcfg_pull_none_drv_level_3>, - /* gmac1_txd1m0 */ - <3 RK_PB6 3 &pcfg_pull_none_drv_level_3>, - /* gmac1_txenm0 */ - <3 RK_PB7 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m0_rgmii_bus_level3: gmac1m0-rgmii-bus-level3 { - rockchip,pins = - /* gmac1_rxd2m0 */ - <3 RK_PA4 3 &pcfg_pull_none>, - /* gmac1_rxd3m0 */ - <3 RK_PA5 3 &pcfg_pull_none>, - /* gmac1_txd2m0 */ - <3 RK_PA2 3 &pcfg_pull_none_drv_level_3>, - /* gmac1_txd3m0 */ - <3 RK_PA3 3 &pcfg_pull_none_drv_level_3>; - }; - - /omit-if-no-ref/ - gmac1m1_tx_bus2_level3: gmac1m1-tx-bus2-level3 { - rockchip,pins = - /* gmac1_txd0m1 */ - <4 RK_PA4 3 &pcfg_pull_none_drv_level_3>, - /* gmac1_txd1m1 */ - <4 RK_PA5 3 &pcfg_pull_none_drv_level_3>, - /* gmac1_txenm1 */ - <4 RK_PA6 3 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - gmac1m1_rgmii_bus_level3: gmac1m1-rgmii-bus-level3 { - rockchip,pins = - /* gmac1_rxd2m1 */ - <4 RK_PA1 3 &pcfg_pull_none>, - /* gmac1_rxd3m1 */ - <4 RK_PA2 3 &pcfg_pull_none>, - /* gmac1_txd2m1 */ - <3 RK_PD6 3 &pcfg_pull_none_drv_level_3>, - /* gmac1_txd3m1 */ - <3 RK_PD7 3 &pcfg_pull_none_drv_level_3>; - }; - }; - - gmac-txc-level2 { - /omit-if-no-ref/ - gmac0_rgmii_clk_level2: gmac0-rgmii-clk-level2 { - rockchip,pins = - /* gmac0_rxclk */ - <2 RK_PA5 2 &pcfg_pull_none>, - /* gmac0_txclk */ - <2 RK_PB0 2 &pcfg_pull_none_drv_level_2>; - }; - - /omit-if-no-ref/ - gmac1m0_rgmii_clk_level2: gmac1m0-rgmii-clk-level2 { - rockchip,pins = - /* gmac1_rxclkm0 */ - <3 RK_PA7 3 &pcfg_pull_none>, - /* gmac1_txclkm0 */ - <3 RK_PA6 3 &pcfg_pull_none_drv_level_2>; - }; - - /omit-if-no-ref/ - gmac1m1_rgmii_clk_level2: gmac1m1-rgmii-clk-level2 { - rockchip,pins = - /* gmac1_rxclkm1 */ - <4 RK_PA3 3 &pcfg_pull_none>, - /* gmac1_txclkm1 */ - <4 RK_PA0 3 &pcfg_pull_none_drv_level_2>; - }; - }; - - tsadc { - /omit-if-no-ref/ - tsadc_pin: tsadc-pin { - rockchip,pins = - /* tsadc_pin */ - <0 RK_PA1 0 &pcfg_pull_none>; - }; - }; - - lcdc { - /omit-if-no-ref/ - lcdc_clock: lcdc-clock { - rockchip,pins = - /* lcdc_clk */ - <3 RK_PA0 1 &pcfg_pull_none>, - /* lcdc_den */ - <3 RK_PC3 1 &pcfg_pull_none>, - /* lcdc_hsync */ - <3 RK_PC1 1 &pcfg_pull_none>, - /* lcdc_vsync */ - <3 RK_PC2 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - lcdc_data16: lcdc-data16 { - rockchip,pins = - /* lcdc_d3 */ - <2 RK_PD3 1 &pcfg_pull_none>, - /* lcdc_d4 */ - <2 RK_PD4 1 &pcfg_pull_none>, - /* lcdc_d5 */ - <2 RK_PD5 1 &pcfg_pull_none>, - /* lcdc_d6 */ - <2 RK_PD6 1 &pcfg_pull_none>, - /* lcdc_d7 */ - <2 RK_PD7 1 &pcfg_pull_none>, - /* lcdc_d10 */ - <3 RK_PA3 1 &pcfg_pull_none>, - /* lcdc_d11 */ - <3 RK_PA4 1 &pcfg_pull_none>, - /* lcdc_d12 */ - <3 RK_PA5 1 &pcfg_pull_none>, - /* lcdc_d13 */ - <3 RK_PA6 1 &pcfg_pull_none>, - /* lcdc_d14 */ - <3 RK_PA7 1 &pcfg_pull_none>, - /* lcdc_d15 */ - <3 RK_PB0 1 &pcfg_pull_none>, - /* lcdc_d19 */ - <3 RK_PB4 1 &pcfg_pull_none>, - /* lcdc_d20 */ - <3 RK_PB5 1 &pcfg_pull_none>, - /* lcdc_d21 */ - <3 RK_PB6 1 &pcfg_pull_none>, - /* lcdc_d22 */ - <3 RK_PB7 1 &pcfg_pull_none>, - /* lcdc_d23 */ - <3 RK_PC0 1 &pcfg_pull_none>; - }; - - /omit-if-no-ref/ - lcdc_data18: lcdc-data18 { - rockchip,pins = - /* lcdc_d2 */ - <2 RK_PD2 1 &pcfg_pull_none>, - /* lcdc_d3 */ - <2 RK_PD3 1 &pcfg_pull_none>, - /* lcdc_d4 */ - <2 RK_PD4 1 &pcfg_pull_none>, - /* lcdc_d5 */ - <2 RK_PD5 1 &pcfg_pull_none>, - /* lcdc_d6 */ - <2 RK_PD6 1 &pcfg_pull_none>, - /* lcdc_d7 */ - <2 RK_PD7 1 &pcfg_pull_none>, - /* lcdc_d10 */ - <3 RK_PA3 1 &pcfg_pull_none>, - /* lcdc_d11 */ - <3 RK_PA4 1 &pcfg_pull_none>, - /* lcdc_d12 */ - <3 RK_PA5 1 &pcfg_pull_none>, - /* lcdc_d13 */ - <3 RK_PA6 1 &pcfg_pull_none>, - /* lcdc_d14 */ - <3 RK_PA7 1 &pcfg_pull_none>, - /* lcdc_d15 */ - <3 RK_PB0 1 &pcfg_pull_none>, - /* lcdc_d18 */ - <3 RK_PB3 1 &pcfg_pull_none>, - /* lcdc_d19 */ - <3 RK_PB4 1 &pcfg_pull_none>, - /* lcdc_d20 */ - <3 RK_PB5 1 &pcfg_pull_none>, - /* lcdc_d21 */ - <3 RK_PB6 1 &pcfg_pull_none>, - /* lcdc_d22 */ - <3 RK_PB7 1 &pcfg_pull_none>, - /* lcdc_d23 */ - <3 RK_PC0 1 &pcfg_pull_none>; - }; - }; - -}; diff --git a/arch/arm/dts/rk3568-radxa-cm3i.dtsi b/arch/arm/dts/rk3568-radxa-cm3i.dtsi deleted file mode 100644 index 45b03dcbbad4..000000000000 --- a/arch/arm/dts/rk3568-radxa-cm3i.dtsi +++ /dev/null @@ -1,412 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include "rk3568.dtsi" - -/ { - compatible = "radxa,cm3i", "rockchip,rk3568"; - - aliases { - mmc0 = &sdhci; - }; - - chosen { - stdout-path = "serial2:115200n8"; - }; - - gpio-leds { - compatible = "gpio-leds"; - - led_user: led-0 { - gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_HEARTBEAT; - color = <LED_COLOR_ID_GREEN>; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&led_user_en>; - }; - }; - - pcie30_avdd0v9: pcie30-avdd0v9-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; - - pcie30_avdd1v8: pcie30-avdd1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v_input>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v_input>; - }; - - /* labeled +5v_input in schematic */ - vcc5v_input: vcc5v-input-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v_input"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - }; -}; - -&combphy0 { - status = "okay"; -}; - -&combphy1 { - status = "okay"; -}; - -&combphy2 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&display_subsystem { - status = "disabled"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc5v_input>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>; - rockchip,system-power-controller; - wakeup-source; - - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - }; -}; - -&pinctrl { - leds { - led_user_en: led_user_en { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic_int { - rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart2 { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb_host0_xhci { - extcon = <&usb2phy0>; -}; diff --git a/arch/arm/dts/rk3568-radxa-e25.dts b/arch/arm/dts/rk3568-radxa-e25.dts deleted file mode 100644 index 72ad74c38a2b..000000000000 --- a/arch/arm/dts/rk3568-radxa-e25.dts +++ /dev/null @@ -1,236 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; -#include "rk3568-radxa-cm3i.dtsi" - -/ { - model = "Radxa E25 Carrier Board"; - compatible = "radxa,e25", "radxa,cm3i", "rockchip,rk3568"; - - aliases { - mmc1 = &sdmmc0; - }; - - pwm-leds { - compatible = "pwm-leds-multicolor"; - - multi-led { - color = <LED_COLOR_ID_RGB>; - max-brightness = <255>; - - led-red { - color = <LED_COLOR_ID_RED>; - pwms = <&pwm1 0 1000000 0>; - }; - - led-green { - color = <LED_COLOR_ID_GREEN>; - pwms = <&pwm2 0 1000000 0>; - }; - - led-blue { - color = <LED_COLOR_ID_BLUE>; - pwms = <&pwm12 0 1000000 0>; - }; - }; - }; - - vbus_typec: vbus-typec-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vbus_typec_en>; - regulator-name = "vbus_typec"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_sys>; - }; - - /* actually fed by vcc5v0_sys, dependent - * on pi6c clock generator - */ - vcc3v3_minipcie: vcc3v3-minipcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&minipcie_enable_h>; - regulator-name = "vcc3v3_minipcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_pi6c_05>; - }; - - vcc3v3_ngff: vcc3v3-ngff-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&ngffpcie_enable_h>; - regulator-name = "vcc3v3_ngff"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_pcie30x1: vcc3v3-pcie30x1-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie30x1_enable_h>; - regulator-name = "vcc3v3_pcie30x1"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_pi6c_05: vcc3v3-pi6c-05-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_enable_h>; - regulator-name = "vcc3v3_pcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; -}; - -&combphy1 { - phy-supply = <&vcc3v3_pcie30x1>; -}; - -&pcie2x1 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie20_reset_h>; - reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pi6c_05>; - status = "okay"; -}; - -&pcie30phy { - data-lanes = <1 2>; - status = "okay"; -}; - -&pcie3x1 { - num-lanes = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie30x1m0_pins>; - reset-gpios = <&gpio0 RK_PC3 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_minipcie>; - status = "okay"; -}; - -&pcie3x2 { - num-lanes = <1>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie30x2_reset_h>; - reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pi6c_05>; - status = "okay"; -}; - -&pinctrl { - pcie { - pcie20_reset_h: pcie20-reset-h { - rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie30x1_enable_h: pcie30x1-enable-h { - rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie30x2_reset_h: pcie30x2-reset-h { - rockchip,pins = <2 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_enable_h: pcie-enable-h { - rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - usb { - minipcie_enable_h: minipcie-enable-h { - rockchip,pins = <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - ngffpcie_enable_h: ngffpcie-enable-h { - rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - vbus_typec_en: vbus_typec_en { - rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pwm1 { - status = "okay"; -}; - -&pwm2 { - status = "okay"; -}; - -&pwm12 { - pinctrl-names = "default"; - pinctrl-0 = <&pwm12m1_pins>; - status = "okay"; -}; - -&sata1 { - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - /* Also used in pcie30x1_clkreqnm0 */ - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd>; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vbus_typec>; - status = "okay"; -}; - -&usb2phy1_host { - phy-supply = <&vcc3v3_minipcie>; - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc3v3_ngff>; - status = "okay"; -}; diff --git a/arch/arm/dts/rk3568-rock-3a.dts b/arch/arm/dts/rk3568-rock-3a.dts deleted file mode 100644 index a5e974ea659e..000000000000 --- a/arch/arm/dts/rk3568-rock-3a.dts +++ /dev/null @@ -1,859 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) - -/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi" - -/ { - model = "Radxa ROCK3 Model A"; - compatible = "radxa,rock3a", "rockchip,rk3568"; - - aliases { - ethernet0 = &gmac1; - mmc0 = &sdhci; - mmc1 = &sdmmc0; - mmc2 = &sdmmc2; - }; - - chosen: chosen { - stdout-path = "serial2:1500000n8"; - }; - - hdmi-con { - compatible = "hdmi-connector"; - type = "a"; - - port { - hdmi_con_in: endpoint { - remote-endpoint = <&hdmi_out_con>; - }; - }; - }; - - gmac1_clkin: external-gmac1-clock { - compatible = "fixed-clock"; - clock-frequency = <125000000>; - clock-output-names = "gmac1_clkin"; - #clock-cells = <0>; - }; - - leds { - compatible = "gpio-leds"; - - led_user: led-0 { - gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>; - function = LED_FUNCTION_HEARTBEAT; - color = <LED_COLOR_ID_BLUE>; - linux,default-trigger = "heartbeat"; - pinctrl-names = "default"; - pinctrl-0 = <&led_user_en>; - }; - }; - - rk809-sound { - compatible = "simple-audio-card"; - simple-audio-card,format = "i2s"; - simple-audio-card,name = "Analog RK809"; - simple-audio-card,mclk-fs = <256>; - - simple-audio-card,cpu { - sound-dai = <&i2s1_8ch>; - }; - - simple-audio-card,codec { - sound-dai = <&rk809>; - }; - }; - - sdio_pwrseq: sdio-pwrseq { - compatible = "mmc-pwrseq-simple"; - clocks = <&rk809 1>; - clock-names = "ext_clock"; - pinctrl-names = "default"; - pinctrl-0 = <&wifi_enable>; - post-power-on-delay-ms = <100>; - power-off-delay-us = <5000000>; - reset-gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_LOW>; - }; - - vcc12v_dcin: vcc12v-dcin-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc12v_dcin"; - regulator-always-on; - regulator-boot-on; - }; - - pcie30_avdd0v9: pcie30-avdd0v9-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - vin-supply = <&vcc3v3_sys>; - }; - - pcie30_avdd1v8: pcie30-avdd1v8-regulator { - compatible = "regulator-fixed"; - regulator-name = "pcie30_avdd1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - vin-supply = <&vcc3v3_sys>; - }; - - /* pi6c pcie clock generator */ - vcc3v3_pi6c_03: vcc3v3-pi6c-03-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_pi6c_03"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_pcie: vcc3v3-pcie-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&pcie_enable_h>; - regulator-name = "vcc3v3_pcie"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc5v0_sys>; - }; - - vcc3v3_sys: vcc3v3-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc3v3_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc5v0_sys: vcc5v0-sys-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_sys"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc5v0_usb: vcc5v0-usb-regulator { - compatible = "regulator-fixed"; - regulator-name = "vcc5v0_usb"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc12v_dcin>; - }; - - vcc5v0_usb_host: vcc5v0-usb-host-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_host_en>; - regulator-name = "vcc5v0_usb_host"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_usb_hub: vcc5v0-usb-hub-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_hub_en>; - regulator-name = "vcc5v0_usb_hub"; - regulator-always-on; - vin-supply = <&vcc5v0_usb>; - }; - - vcc5v0_usb_otg: vcc5v0-usb-otg-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc5v0_usb_otg_en>; - regulator-name = "vcc5v0_usb_otg"; - regulator-min-microvolt = <5000000>; - regulator-max-microvolt = <5000000>; - vin-supply = <&vcc5v0_usb>; - }; - - vcc_cam: vcc-cam-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc_cam_en>; - regulator-name = "vcc_cam"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_mipi: vcc-mipi-regulator { - compatible = "regulator-fixed"; - enable-active-high; - gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&vcc_mipi_en>; - regulator-name = "vcc_mipi"; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - vin-supply = <&vcc3v3_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; -}; - -&combphy0 { - status = "okay"; -}; - -&combphy1 { - status = "okay"; -}; - -&combphy2 { - status = "okay"; -}; - -&cpu0 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu1 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu2 { - cpu-supply = <&vdd_cpu>; -}; - -&cpu3 { - cpu-supply = <&vdd_cpu>; -}; - -&gmac1 { - assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>; - assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>; - clock_in_out = "input"; - phy-handle = <&rgmii_phy1>; - phy-mode = "rgmii-id"; - phy-supply = <&vcc_3v3>; - pinctrl-names = "default"; - pinctrl-0 = <&gmac1m1_miim - &gmac1m1_tx_bus2 - &gmac1m1_rx_bus2 - &gmac1m1_rgmii_clk - &gmac1m1_clkinout - &gmac1m1_rgmii_bus>; - status = "okay"; -}; - -&gpu { - mali-supply = <&vdd_gpu>; - status = "okay"; -}; - -&hdmi { - avdd-0v9-supply = <&vdda0v9_image>; - avdd-1v8-supply = <&vcca1v8_image>; - pinctrl-names = "default"; - pinctrl-0 = <&hdmitx_scl &hdmitx_sda &hdmitxm1_cec>; - status = "okay"; -}; - -&hdmi_in { - hdmi_in_vp0: endpoint { - remote-endpoint = <&vp0_out_hdmi>; - }; -}; - -&hdmi_out { - hdmi_out_con: endpoint { - remote-endpoint = <&hdmi_con_in>; - }; -}; - -&hdmi_sound { - status = "okay"; -}; - -&i2c0 { - status = "okay"; - - vdd_cpu: regulator@1c { - compatible = "tcs,tcs4525"; - reg = <0x1c>; - fcs,suspend-voltage-selector = <1>; - regulator-name = "vdd_cpu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <800000>; - regulator-max-microvolt = <1150000>; - regulator-ramp-delay = <2300>; - vin-supply = <&vcc5v0_sys>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - rk809: pmic@20 { - compatible = "rockchip,rk809"; - reg = <0x20>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>; - assigned-clocks = <&cru I2S1_MCLKOUT_TX>; - assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>; - #clock-cells = <1>; - clock-names = "mclk"; - clocks = <&cru I2S1_MCLKOUT_TX>; - pinctrl-names = "default"; - pinctrl-0 = <&pmic_int>, <&i2s1m0_mclk>; - rockchip,system-power-controller; - #sound-dai-cells = <0>; - vcc1-supply = <&vcc3v3_sys>; - vcc2-supply = <&vcc3v3_sys>; - vcc3-supply = <&vcc3v3_sys>; - vcc4-supply = <&vcc3v3_sys>; - vcc5-supply = <&vcc3v3_sys>; - vcc6-supply = <&vcc3v3_sys>; - vcc7-supply = <&vcc3v3_sys>; - vcc8-supply = <&vcc3v3_sys>; - vcc9-supply = <&vcc3v3_sys>; - wakeup-source; - - regulators { - vdd_logic: DCDC_REG1 { - regulator-name = "vdd_logic"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdd_gpu: DCDC_REG2 { - regulator-name = "vdd_gpu"; - regulator-always-on; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_ddr: DCDC_REG3 { - regulator-name = "vcc_ddr"; - regulator-always-on; - regulator-boot-on; - regulator-initial-mode = <0x2>; - - regulator-state-mem { - regulator-on-in-suspend; - }; - }; - - vdd_npu: DCDC_REG4 { - regulator-name = "vdd_npu"; - regulator-initial-mode = <0x2>; - regulator-min-microvolt = <500000>; - regulator-max-microvolt = <1350000>; - regulator-ramp-delay = <6001>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_1v8: DCDC_REG5 { - regulator-name = "vcc_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_image: LDO_REG1 { - regulator-name = "vdda0v9_image"; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda_0v9: LDO_REG2 { - regulator-name = "vdda_0v9"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vdda0v9_pmu: LDO_REG3 { - regulator-name = "vdda0v9_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <900000>; - regulator-max-microvolt = <900000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <900000>; - }; - }; - - vccio_acodec: LDO_REG4 { - regulator-name = "vccio_acodec"; - regulator-always-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vccio_sd: LDO_REG5 { - regulator-name = "vccio_sd"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_pmu: LDO_REG6 { - regulator-name = "vcc3v3_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <3300000>; - regulator-max-microvolt = <3300000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <3300000>; - }; - }; - - vcca_1v8: LDO_REG7 { - regulator-name = "vcca_1v8"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcca1v8_pmu: LDO_REG8 { - regulator-name = "vcca1v8_pmu"; - regulator-always-on; - regulator-boot-on; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-on-in-suspend; - regulator-suspend-microvolt = <1800000>; - }; - }; - - vcca1v8_image: LDO_REG9 { - regulator-name = "vcca1v8_image"; - regulator-min-microvolt = <1800000>; - regulator-max-microvolt = <1800000>; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc_3v3: SWITCH_REG1 { - regulator-name = "vcc_3v3"; - regulator-always-on; - regulator-boot-on; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - - vcc3v3_sd: SWITCH_REG2 { - regulator-name = "vcc3v3_sd"; - - regulator-state-mem { - regulator-off-in-suspend; - }; - }; - }; - - codec { - mic-in-differential; - }; - }; -}; - -&i2c3 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c3m1_xfer>; - status = "disabled"; -}; - -&i2c4 { - pinctrl-names = "default"; - pinctrl-0 = <&i2c4m1_xfer>; - status = "disabled"; -}; - -&i2c5 { - status = "okay"; - - hym8563: rtc@51 { - compatible = "haoyu,hym8563"; - reg = <0x51>; - interrupt-parent = <&gpio0>; - interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>; - #clock-cells = <0>; - clock-output-names = "rtcic_32kout"; - pinctrl-names = "default"; - pinctrl-0 = <&hym8563_int>; - wakeup-source; - }; -}; - -&i2s0_8ch { - status = "okay"; -}; - -&i2s1_8ch { - pinctrl-names = "default"; - pinctrl-0 = <&i2s1m0_sclktx &i2s1m0_lrcktx &i2s1m0_sdi0 &i2s1m0_sdo0>; - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&i2s2_2ch { - rockchip,trcm-sync-tx-only; - status = "okay"; -}; - -&mdio1 { - rgmii_phy1: ethernet-phy@0 { - compatible = "ethernet-phy-ieee802.3-c22"; - reg = <0x0>; - pinctrl-names = "default"; - pinctrl-0 = <ð_phy_rst>; - reset-assert-us = <20000>; - reset-deassert-us = <100000>; - reset-gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>; - }; -}; - -&pcie2x1 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie_reset_h>; - reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pcie30phy { - phy-supply = <&vcc3v3_pi6c_03>; - status = "okay"; -}; - -&pcie3x2 { - pinctrl-names = "default"; - pinctrl-0 = <&pcie30x2m1_pins>; - reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>; - vpcie3v3-supply = <&vcc3v3_pcie>; - status = "okay"; -}; - -&pinctrl { - cam { - vcc_cam_en: vcc_cam_en { - rockchip,pins = <1 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - display { - vcc_mipi_en: vcc_mipi_en { - rockchip,pins = <3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - ethernet { - eth_phy_rst: eth_phy_rst { - rockchip,pins = <3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - hym8563 { - hym8563_int: hym8563-int { - rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - leds { - led_user_en: led_user_en { - rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pcie { - pcie_enable_h: pcie-enable-h { - rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - pcie_reset_h: pcie-reset-h { - rockchip,pins = <3 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - pmic { - pmic_int: pmic_int { - rockchip,pins = - <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>; - }; - }; - - usb { - vcc5v0_usb_host_en: vcc5v0_usb_host_en { - rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>; - }; - vcc5v0_usb_hub_en: vcc5v0_usb_hub_en { - rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - vcc5v0_usb_otg_en: vcc5v0_usb_otg_en { - rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - bt { - bt_enable: bt-enable { - rockchip,pins = <4 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>; - }; - - bt_host_wake: bt-host-wake { - rockchip,pins = <4 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>; - }; - - bt_wake: bt-wake { - rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; - - sdio-pwrseq { - wifi_enable: wifi-enable { - rockchip,pins = <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>; - }; - }; -}; - -&pmu_io_domains { - pmuio1-supply = <&vcc3v3_pmu>; - pmuio2-supply = <&vcc3v3_pmu>; - vccio1-supply = <&vccio_acodec>; - vccio2-supply = <&vcc_1v8>; - vccio3-supply = <&vccio_sd>; - vccio4-supply = <&vcc_1v8>; - vccio5-supply = <&vcc_3v3>; - vccio6-supply = <&vcc_1v8>; - vccio7-supply = <&vcc_3v3>; - status = "okay"; -}; - -&saradc { - vref-supply = <&vcca_1v8>; - status = "okay"; -}; - -&sdhci { - bus-width = <8>; - max-frequency = <200000000>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>; - vmmc-supply = <&vcc_3v3>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&sdmmc0 { - bus-width = <4>; - cap-sd-highspeed; - cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>; - disable-wp; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>; - sd-uhs-sdr50; - vmmc-supply = <&vcc3v3_sd>; - vqmmc-supply = <&vccio_sd>; - status = "okay"; -}; - -&sdmmc2 { - bus-width = <4>; - disable-wp; - cap-sd-highspeed; - cap-sdio-irq; - keep-power-in-suspend; - mmc-pwrseq = <&sdio_pwrseq>; - non-removable; - pinctrl-names = "default"; - pinctrl-0 = <&sdmmc2m0_bus4 &sdmmc2m0_cmd &sdmmc2m0_clk>; - sd-uhs-sdr12; - sd-uhs-sdr25; - sd-uhs-sdr50; - sd-uhs-sdr104; - vmmc-supply = <&vcc3v3_sys>; - vqmmc-supply = <&vcc_1v8>; - status = "okay"; -}; - -&tsadc { - rockchip,hw-tshut-mode = <1>; - rockchip,hw-tshut-polarity = <0>; - status = "okay"; -}; - -&uart1 { - pinctrl-names = "default"; - pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>; - uart-has-rtscts; - status = "okay"; - - bluetooth { - compatible = "brcm,bcm43438-bt"; - clocks = <&rk809 1>; - clock-names = "lpo"; - device-wakeup-gpios = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>; - host-wakeup-gpios = <&gpio4 RK_PB4 GPIO_ACTIVE_HIGH>; - shutdown-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_HIGH>; - pinctrl-names = "default"; - pinctrl-0 = <&bt_host_wake &bt_wake &bt_enable>; - vbat-supply = <&vcc3v3_sys>; - vddio-supply = <&vcc_1v8>; - /* vddio comes from regulator on module, use IO bank voltage instead */ - }; -}; - -&uart2 { - status = "okay"; -}; - -&usb_host0_ehci { - status = "okay"; -}; - -&usb_host0_ohci { - status = "okay"; -}; - -&usb_host0_xhci { - extcon = <&usb2phy0>; - status = "okay"; -}; - -&usb_host1_ehci { - status = "okay"; -}; - -&usb_host1_ohci { - status = "okay"; -}; - -&usb_host1_xhci { - status = "okay"; -}; - -&usb2phy0 { - status = "okay"; -}; - -&usb2phy0_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy0_otg { - phy-supply = <&vcc5v0_usb_otg>; - status = "okay"; -}; - -&usb2phy1 { - status = "okay"; -}; - -&usb2phy1_host { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&usb2phy1_otg { - phy-supply = <&vcc5v0_usb_host>; - status = "okay"; -}; - -&vop { - assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>; - assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>; - status = "okay"; -}; - -&vop_mmu { - status = "okay"; -}; - -&vp0 { - vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 { - reg = <ROCKCHIP_VOP2_EP_HDMI0>; - remote-endpoint = <&hdmi_in_vp0>; - }; -}; diff --git a/arch/arm/dts/rk3568.dtsi b/arch/arm/dts/rk3568.dtsi deleted file mode 100644 index f1be76a54ceb..000000000000 --- a/arch/arm/dts/rk3568.dtsi +++ /dev/null @@ -1,267 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2021 Rockchip Electronics Co., Ltd. - */ - -#include "rk356x.dtsi" - -/ { - compatible = "rockchip,rk3568"; - - sata0: sata@fc000000 { - compatible = "rockchip,rk3568-dwc-ahci", "snps,dwc-ahci"; - reg = <0 0xfc000000 0 0x1000>; - clocks = <&cru ACLK_SATA0>, <&cru CLK_SATA0_PMALIVE>, - <&cru CLK_SATA0_RXOOB>; - clock-names = "sata", "pmalive", "rxoob"; - interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>; - phys = <&combphy0 PHY_TYPE_SATA>; - phy-names = "sata-phy"; - ports-implemented = <0x1>; - power-domains = <&power RK3568_PD_PIPE>; - status = "disabled"; - }; - - pipe_phy_grf0: syscon@fdc70000 { - compatible = "rockchip,rk3568-pipe-phy-grf", "syscon"; - reg = <0x0 0xfdc70000 0x0 0x1000>; - }; - - qos_pcie3x1: qos@fe190080 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190080 0x0 0x20>; - }; - - qos_pcie3x2: qos@fe190100 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190100 0x0 0x20>; - }; - - qos_sata0: qos@fe190200 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190200 0x0 0x20>; - }; - - pcie30_phy_grf: syscon@fdcb8000 { - compatible = "rockchip,rk3568-pcie3-phy-grf", "syscon"; - reg = <0x0 0xfdcb8000 0x0 0x10000>; - }; - - pcie30phy: phy@fe8c0000 { - compatible = "rockchip,rk3568-pcie3-phy"; - reg = <0x0 0xfe8c0000 0x0 0x20000>; - #phy-cells = <0>; - clocks = <&pmucru CLK_PCIE30PHY_REF_M>, <&pmucru CLK_PCIE30PHY_REF_N>, - <&cru PCLK_PCIE30PHY>; - clock-names = "refclk_m", "refclk_n", "pclk"; - resets = <&cru SRST_PCIE30PHY>; - reset-names = "phy"; - rockchip,phy-grf = <&pcie30_phy_grf>; - status = "disabled"; - }; - - pcie3x1: pcie@fe270000 { - compatible = "rockchip,rk3568-pcie"; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x0 0xf>; - clocks = <&cru ACLK_PCIE30X1_MST>, <&cru ACLK_PCIE30X1_SLV>, - <&cru ACLK_PCIE30X1_DBI>, <&cru PCLK_PCIE30X1>, - <&cru CLK_PCIE30X1_AUX_NDFT>; - clock-names = "aclk_mst", "aclk_slv", - "aclk_dbi", "pclk", "aux"; - device_type = "pci"; - interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "sys", "pmc", "msg", "legacy", "err"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pcie3x1_intc 0>, - <0 0 0 2 &pcie3x1_intc 1>, - <0 0 0 3 &pcie3x1_intc 2>, - <0 0 0 4 &pcie3x1_intc 3>; - linux,pci-domain = <1>; - num-ib-windows = <6>; - num-ob-windows = <2>; - max-link-speed = <3>; - msi-map = <0x0 &gic 0x1000 0x1000>; - num-lanes = <1>; - phys = <&pcie30phy>; - phy-names = "pcie-phy"; - power-domains = <&power RK3568_PD_PIPE>; - reg = <0x3 0xc0400000 0x0 0x00400000>, - <0x0 0xfe270000 0x0 0x00010000>, - <0x0 0xf2000000 0x0 0x00100000>; - ranges = <0x01000000 0x0 0xf2100000 0x0 0xf2100000 0x0 0x00100000>, - <0x02000000 0x0 0xf2200000 0x0 0xf2200000 0x0 0x01e00000>, - <0x03000000 0x0 0x40000000 0x3 0x40000000 0x0 0x40000000>; - reg-names = "dbi", "apb", "config"; - resets = <&cru SRST_PCIE30X1_POWERUP>; - reset-names = "pipe"; - /* bifurcation; lane1 when using 1+1 */ - status = "disabled"; - - pcie3x1_intc: legacy-interrupt-controller { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <1>; - interrupt-parent = <&gic>; - interrupts = <GIC_SPI 157 IRQ_TYPE_EDGE_RISING>; - }; - }; - - pcie3x2: pcie@fe280000 { - compatible = "rockchip,rk3568-pcie"; - #address-cells = <3>; - #size-cells = <2>; - bus-range = <0x0 0xf>; - clocks = <&cru ACLK_PCIE30X2_MST>, <&cru ACLK_PCIE30X2_SLV>, - <&cru ACLK_PCIE30X2_DBI>, <&cru PCLK_PCIE30X2>, - <&cru CLK_PCIE30X2_AUX_NDFT>; - clock-names = "aclk_mst", "aclk_slv", - "aclk_dbi", "pclk", "aux"; - device_type = "pci"; - interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "sys", "pmc", "msg", "legacy", "err"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pcie3x2_intc 0>, - <0 0 0 2 &pcie3x2_intc 1>, - <0 0 0 3 &pcie3x2_intc 2>, - <0 0 0 4 &pcie3x2_intc 3>; - linux,pci-domain = <2>; - num-ib-windows = <6>; - num-ob-windows = <2>; - max-link-speed = <3>; - msi-map = <0x0 &gic 0x2000 0x1000>; - num-lanes = <2>; - phys = <&pcie30phy>; - phy-names = "pcie-phy"; - power-domains = <&power RK3568_PD_PIPE>; - reg = <0x3 0xc0800000 0x0 0x00400000>, - <0x0 0xfe280000 0x0 0x00010000>, - <0x0 0xf0000000 0x0 0x00100000>; - ranges = <0x01000000 0x0 0xf0100000 0x0 0xf0100000 0x0 0x00100000>, - <0x02000000 0x0 0xf0200000 0x0 0xf0200000 0x0 0x01e00000>, - <0x03000000 0x0 0x40000000 0x3 0x80000000 0x0 0x40000000>; - reg-names = "dbi", "apb", "config"; - resets = <&cru SRST_PCIE30X2_POWERUP>; - reset-names = "pipe"; - /* bifurcation; lane0 when using 1+1 */ - status = "disabled"; - - pcie3x2_intc: legacy-interrupt-controller { - interrupt-controller; - #address-cells = <0>; - #interrupt-cells = <1>; - interrupt-parent = <&gic>; - interrupts = <GIC_SPI 162 IRQ_TYPE_EDGE_RISING>; - }; - }; - - gmac0: ethernet@fe2a0000 { - compatible = "rockchip,rk3568-gmac", "snps,dwmac-4.20a"; - reg = <0x0 0xfe2a0000 0x0 0x10000>; - interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq", "eth_wake_irq"; - clocks = <&cru SCLK_GMAC0>, <&cru SCLK_GMAC0_RX_TX>, - <&cru SCLK_GMAC0_RX_TX>, <&cru CLK_MAC0_REFOUT>, - <&cru ACLK_GMAC0>, <&cru PCLK_GMAC0>, - <&cru SCLK_GMAC0_RX_TX>, <&cru CLK_GMAC0_PTP_REF>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_refout", - "aclk_mac", "pclk_mac", - "clk_mac_speed", "ptp_ref"; - resets = <&cru SRST_A_GMAC0>; - reset-names = "stmmaceth"; - rockchip,grf = <&grf>; - snps,axi-config = <&gmac0_stmmac_axi_setup>; - snps,mixed-burst; - snps,mtl-rx-config = <&gmac0_mtl_rx_setup>; - snps,mtl-tx-config = <&gmac0_mtl_tx_setup>; - snps,tso; - status = "disabled"; - - mdio0: mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <0x1>; - #size-cells = <0x0>; - }; - - gmac0_stmmac_axi_setup: stmmac-axi-config { - snps,blen = <0 0 0 0 16 8 4>; - snps,rd_osr_lmt = <8>; - snps,wr_osr_lmt = <4>; - }; - - gmac0_mtl_rx_setup: rx-queues-config { - snps,rx-queues-to-use = <1>; - queue0 {}; - }; - - gmac0_mtl_tx_setup: tx-queues-config { - snps,tx-queues-to-use = <1>; - queue0 {}; - }; - }; - - combphy0: phy@fe820000 { - compatible = "rockchip,rk3568-naneng-combphy"; - reg = <0x0 0xfe820000 0x0 0x100>; - clocks = <&pmucru CLK_PCIEPHY0_REF>, - <&cru PCLK_PIPEPHY0>, - <&cru PCLK_PIPE>; - clock-names = "ref", "apb", "pipe"; - assigned-clocks = <&pmucru CLK_PCIEPHY0_REF>; - assigned-clock-rates = <100000000>; - resets = <&cru SRST_PIPEPHY0>; - rockchip,pipe-grf = <&pipegrf>; - rockchip,pipe-phy-grf = <&pipe_phy_grf0>; - #phy-cells = <1>; - status = "disabled"; - }; -}; - -&cpu0_opp_table { - opp-1992000000 { - opp-hz = /bits/ 64 <1992000000>; - opp-microvolt = <1150000 1150000 1150000>; - }; -}; - -&pipegrf { - compatible = "rockchip,rk3568-pipe-grf", "syscon"; -}; - -&power { - power-domain@RK3568_PD_PIPE { - reg = <RK3568_PD_PIPE>; - clocks = <&cru PCLK_PIPE>; - pm_qos = <&qos_pcie2x1>, - <&qos_pcie3x1>, - <&qos_pcie3x2>, - <&qos_sata0>, - <&qos_sata1>, - <&qos_sata2>, - <&qos_usb3_0>, - <&qos_usb3_1>; - #power-domain-cells = <0>; - }; -}; - -&usb_host0_xhci { - phys = <&usb2phy0_otg>, <&combphy0 PHY_TYPE_USB3>; - phy-names = "usb2-phy", "usb3-phy"; -}; - -&vop { - compatible = "rockchip,rk3568-vop"; -}; diff --git a/arch/arm/dts/rk356x.dtsi b/arch/arm/dts/rk356x.dtsi deleted file mode 100644 index c19c0f1b3778..000000000000 --- a/arch/arm/dts/rk356x.dtsi +++ /dev/null @@ -1,1886 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/* - * Copyright (c) 2021 Rockchip Electronics Co., Ltd. - */ - -#include <dt-bindings/clock/rk3568-cru.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/phy/phy.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rk3568-power.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> -#include <dt-bindings/thermal/thermal.h> - -/ { - interrupt-parent = <&gic>; - #address-cells = <2>; - #size-cells = <2>; - - aliases { - gpio0 = &gpio0; - gpio1 = &gpio1; - gpio2 = &gpio2; - gpio3 = &gpio3; - gpio4 = &gpio4; - i2c0 = &i2c0; - i2c1 = &i2c1; - i2c2 = &i2c2; - i2c3 = &i2c3; - i2c4 = &i2c4; - i2c5 = &i2c5; - serial0 = &uart0; - serial1 = &uart1; - serial2 = &uart2; - serial3 = &uart3; - serial4 = &uart4; - serial5 = &uart5; - serial6 = &uart6; - serial7 = &uart7; - serial8 = &uart8; - serial9 = &uart9; - spi0 = &spi0; - spi1 = &spi1; - spi2 = &spi2; - spi3 = &spi3; - }; - - cpus { - #address-cells = <2>; - #size-cells = <0>; - - cpu0: cpu@0 { - device_type = "cpu"; - compatible = "arm,cortex-a55"; - reg = <0x0 0x0>; - clocks = <&scmi_clk 0>; - #cooling-cells = <2>; - enable-method = "psci"; - operating-points-v2 = <&cpu0_opp_table>; - }; - - cpu1: cpu@100 { - device_type = "cpu"; - compatible = "arm,cortex-a55"; - reg = <0x0 0x100>; - #cooling-cells = <2>; - enable-method = "psci"; - operating-points-v2 = <&cpu0_opp_table>; - }; - - cpu2: cpu@200 { - device_type = "cpu"; - compatible = "arm,cortex-a55"; - reg = <0x0 0x200>; - #cooling-cells = <2>; - enable-method = "psci"; - operating-points-v2 = <&cpu0_opp_table>; - }; - - cpu3: cpu@300 { - device_type = "cpu"; - compatible = "arm,cortex-a55"; - reg = <0x0 0x300>; - #cooling-cells = <2>; - enable-method = "psci"; - operating-points-v2 = <&cpu0_opp_table>; - }; - }; - - cpu0_opp_table: opp-table-0 { - compatible = "operating-points-v2"; - opp-shared; - - opp-408000000 { - opp-hz = /bits/ 64 <408000000>; - opp-microvolt = <900000 900000 1150000>; - clock-latency-ns = <40000>; - }; - - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <900000 900000 1150000>; - }; - - opp-816000000 { - opp-hz = /bits/ 64 <816000000>; - opp-microvolt = <900000 900000 1150000>; - opp-suspend; - }; - - opp-1104000000 { - opp-hz = /bits/ 64 <1104000000>; - opp-microvolt = <900000 900000 1150000>; - }; - - opp-1416000000 { - opp-hz = /bits/ 64 <1416000000>; - opp-microvolt = <900000 900000 1150000>; - }; - - opp-1608000000 { - opp-hz = /bits/ 64 <1608000000>; - opp-microvolt = <975000 975000 1150000>; - }; - - opp-1800000000 { - opp-hz = /bits/ 64 <1800000000>; - opp-microvolt = <1050000 1050000 1150000>; - }; - }; - - display_subsystem: display-subsystem { - compatible = "rockchip,display-subsystem"; - ports = <&vop_out>; - }; - - firmware { - scmi: scmi { - compatible = "arm,scmi-smc"; - arm,smc-id = <0x82000010>; - shmem = <&scmi_shmem>; - #address-cells = <1>; - #size-cells = <0>; - - scmi_clk: protocol@14 { - reg = <0x14>; - #clock-cells = <1>; - }; - }; - }; - - gpu_opp_table: opp-table-1 { - compatible = "operating-points-v2"; - - opp-200000000 { - opp-hz = /bits/ 64 <200000000>; - opp-microvolt = <825000>; - }; - - opp-300000000 { - opp-hz = /bits/ 64 <300000000>; - opp-microvolt = <825000>; - }; - - opp-400000000 { - opp-hz = /bits/ 64 <400000000>; - opp-microvolt = <825000>; - }; - - opp-600000000 { - opp-hz = /bits/ 64 <600000000>; - opp-microvolt = <825000>; - }; - - opp-700000000 { - opp-hz = /bits/ 64 <700000000>; - opp-microvolt = <900000>; - }; - - opp-800000000 { - opp-hz = /bits/ 64 <800000000>; - opp-microvolt = <1000000>; - }; - }; - - hdmi_sound: hdmi-sound { - compatible = "simple-audio-card"; - simple-audio-card,name = "HDMI"; - simple-audio-card,format = "i2s"; - simple-audio-card,mclk-fs = <256>; - status = "disabled"; - - simple-audio-card,codec { - sound-dai = <&hdmi>; - }; - - simple-audio-card,cpu { - sound-dai = <&i2s0_8ch>; - }; - }; - - pmu { - compatible = "arm,cortex-a55-pmu"; - interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>; - interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>; - }; - - psci { - compatible = "arm,psci-1.0"; - method = "smc"; - }; - - timer { - compatible = "arm,armv8-timer"; - interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_HIGH>, - <GIC_PPI 14 IRQ_TYPE_LEVEL_HIGH>, - <GIC_PPI 11 IRQ_TYPE_LEVEL_HIGH>, - <GIC_PPI 10 IRQ_TYPE_LEVEL_HIGH>; - arm,no-tick-in-suspend; - }; - - xin24m: xin24m { - compatible = "fixed-clock"; - clock-frequency = <24000000>; - clock-output-names = "xin24m"; - #clock-cells = <0>; - }; - - xin32k: xin32k { - compatible = "fixed-clock"; - clock-frequency = <32768>; - clock-output-names = "xin32k"; - pinctrl-0 = <&clk32k_out0>; - pinctrl-names = "default"; - #clock-cells = <0>; - }; - - sram@10f000 { - compatible = "mmio-sram"; - reg = <0x0 0x0010f000 0x0 0x100>; - #address-cells = <1>; - #size-cells = <1>; - ranges = <0 0x0 0x0010f000 0x100>; - - scmi_shmem: sram@0 { - compatible = "arm,scmi-shmem"; - reg = <0x0 0x100>; - }; - }; - - sata1: sata@fc400000 { - compatible = "rockchip,rk3568-dwc-ahci", "snps,dwc-ahci"; - reg = <0 0xfc400000 0 0x1000>; - clocks = <&cru ACLK_SATA1>, <&cru CLK_SATA1_PMALIVE>, - <&cru CLK_SATA1_RXOOB>; - clock-names = "sata", "pmalive", "rxoob"; - interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>; - phys = <&combphy1 PHY_TYPE_SATA>; - phy-names = "sata-phy"; - ports-implemented = <0x1>; - power-domains = <&power RK3568_PD_PIPE>; - status = "disabled"; - }; - - sata2: sata@fc800000 { - compatible = "rockchip,rk3568-dwc-ahci", "snps,dwc-ahci"; - reg = <0 0xfc800000 0 0x1000>; - clocks = <&cru ACLK_SATA2>, <&cru CLK_SATA2_PMALIVE>, - <&cru CLK_SATA2_RXOOB>; - clock-names = "sata", "pmalive", "rxoob"; - interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>; - phys = <&combphy2 PHY_TYPE_SATA>; - phy-names = "sata-phy"; - ports-implemented = <0x1>; - power-domains = <&power RK3568_PD_PIPE>; - status = "disabled"; - }; - - usb_host0_xhci: usb@fcc00000 { - compatible = "rockchip,rk3568-dwc3", "snps,dwc3"; - reg = <0x0 0xfcc00000 0x0 0x400000>; - interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_USB3OTG0_REF>, <&cru CLK_USB3OTG0_SUSPEND>, - <&cru ACLK_USB3OTG0>; - clock-names = "ref_clk", "suspend_clk", - "bus_clk"; - dr_mode = "otg"; - phy_type = "utmi_wide"; - power-domains = <&power RK3568_PD_PIPE>; - resets = <&cru SRST_USB3OTG0>; - snps,dis_u2_susphy_quirk; - status = "disabled"; - }; - - usb_host1_xhci: usb@fd000000 { - compatible = "rockchip,rk3568-dwc3", "snps,dwc3"; - reg = <0x0 0xfd000000 0x0 0x400000>; - interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_USB3OTG1_REF>, <&cru CLK_USB3OTG1_SUSPEND>, - <&cru ACLK_USB3OTG1>; - clock-names = "ref_clk", "suspend_clk", - "bus_clk"; - dr_mode = "host"; - phys = <&usb2phy0_host>, <&combphy1 PHY_TYPE_USB3>; - phy-names = "usb2-phy", "usb3-phy"; - phy_type = "utmi_wide"; - power-domains = <&power RK3568_PD_PIPE>; - resets = <&cru SRST_USB3OTG1>; - snps,dis_u2_susphy_quirk; - status = "disabled"; - }; - - gic: interrupt-controller@fd400000 { - compatible = "arm,gic-v3"; - reg = <0x0 0xfd400000 0 0x10000>, /* GICD */ - <0x0 0xfd460000 0 0x80000>; /* GICR */ - interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>; - interrupt-controller; - #interrupt-cells = <3>; - mbi-alias = <0x0 0xfd410000>; - mbi-ranges = <296 24>; - msi-controller; - }; - - usb_host0_ehci: usb@fd800000 { - compatible = "generic-ehci"; - reg = <0x0 0xfd800000 0x0 0x40000>; - interrupts = <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_USB2HOST0>, <&cru HCLK_USB2HOST0_ARB>, - <&cru PCLK_USB>; - phys = <&usb2phy1_otg>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host0_ohci: usb@fd840000 { - compatible = "generic-ohci"; - reg = <0x0 0xfd840000 0x0 0x40000>; - interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_USB2HOST0>, <&cru HCLK_USB2HOST0_ARB>, - <&cru PCLK_USB>; - phys = <&usb2phy1_otg>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host1_ehci: usb@fd880000 { - compatible = "generic-ehci"; - reg = <0x0 0xfd880000 0x0 0x40000>; - interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_USB2HOST1>, <&cru HCLK_USB2HOST1_ARB>, - <&cru PCLK_USB>; - phys = <&usb2phy1_host>; - phy-names = "usb"; - status = "disabled"; - }; - - usb_host1_ohci: usb@fd8c0000 { - compatible = "generic-ohci"; - reg = <0x0 0xfd8c0000 0x0 0x40000>; - interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_USB2HOST1>, <&cru HCLK_USB2HOST1_ARB>, - <&cru PCLK_USB>; - phys = <&usb2phy1_host>; - phy-names = "usb"; - status = "disabled"; - }; - - pmugrf: syscon@fdc20000 { - compatible = "rockchip,rk3568-pmugrf", "syscon", "simple-mfd"; - reg = <0x0 0xfdc20000 0x0 0x10000>; - - pmu_io_domains: io-domains { - compatible = "rockchip,rk3568-pmu-io-voltage-domain"; - status = "disabled"; - }; - }; - - pipegrf: syscon@fdc50000 { - reg = <0x0 0xfdc50000 0x0 0x1000>; - }; - - grf: syscon@fdc60000 { - compatible = "rockchip,rk3568-grf", "syscon", "simple-mfd"; - reg = <0x0 0xfdc60000 0x0 0x10000>; - }; - - pipe_phy_grf1: syscon@fdc80000 { - compatible = "rockchip,rk3568-pipe-phy-grf", "syscon"; - reg = <0x0 0xfdc80000 0x0 0x1000>; - }; - - pipe_phy_grf2: syscon@fdc90000 { - compatible = "rockchip,rk3568-pipe-phy-grf", "syscon"; - reg = <0x0 0xfdc90000 0x0 0x1000>; - }; - - usb2phy0_grf: syscon@fdca0000 { - compatible = "rockchip,rk3568-usb2phy-grf", "syscon"; - reg = <0x0 0xfdca0000 0x0 0x8000>; - }; - - usb2phy1_grf: syscon@fdca8000 { - compatible = "rockchip,rk3568-usb2phy-grf", "syscon"; - reg = <0x0 0xfdca8000 0x0 0x8000>; - }; - - pmucru: clock-controller@fdd00000 { - compatible = "rockchip,rk3568-pmucru"; - reg = <0x0 0xfdd00000 0x0 0x1000>; - #clock-cells = <1>; - #reset-cells = <1>; - }; - - cru: clock-controller@fdd20000 { - compatible = "rockchip,rk3568-cru"; - reg = <0x0 0xfdd20000 0x0 0x1000>; - clocks = <&xin24m>; - clock-names = "xin24m"; - #clock-cells = <1>; - #reset-cells = <1>; - assigned-clocks = <&pmucru CLK_RTC_32K>, <&cru PLL_GPLL>, <&pmucru PLL_PPLL>; - assigned-clock-rates = <32768>, <1200000000>, <200000000>; - assigned-clock-parents = <&pmucru CLK_RTC32K_FRAC>; - rockchip,grf = <&grf>; - }; - - i2c0: i2c@fdd40000 { - compatible = "rockchip,rk3568-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xfdd40000 0x0 0x1000>; - interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pmucru CLK_I2C0>, <&pmucru PCLK_I2C0>; - clock-names = "i2c", "pclk"; - pinctrl-0 = <&i2c0_xfer>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - uart0: serial@fdd50000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfdd50000 0x0 0x100>; - interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pmucru SCLK_UART0>, <&pmucru PCLK_UART0>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 0>, <&dmac0 1>; - pinctrl-0 = <&uart0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - pwm0: pwm@fdd70000 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfdd70000 0x0 0x10>; - clocks = <&pmucru CLK_PWM0>, <&pmucru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm0m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm1: pwm@fdd70010 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfdd70010 0x0 0x10>; - clocks = <&pmucru CLK_PWM0>, <&pmucru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm1m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm2: pwm@fdd70020 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfdd70020 0x0 0x10>; - clocks = <&pmucru CLK_PWM0>, <&pmucru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm2m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm3: pwm@fdd70030 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfdd70030 0x0 0x10>; - clocks = <&pmucru CLK_PWM0>, <&pmucru PCLK_PWM0>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm3_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pmu: power-management@fdd90000 { - compatible = "rockchip,rk3568-pmu", "syscon", "simple-mfd"; - reg = <0x0 0xfdd90000 0x0 0x1000>; - - power: power-controller { - compatible = "rockchip,rk3568-power-controller"; - #power-domain-cells = <1>; - #address-cells = <1>; - #size-cells = <0>; - - /* These power domains are grouped by VD_GPU */ - power-domain@RK3568_PD_GPU { - reg = <RK3568_PD_GPU>; - clocks = <&cru ACLK_GPU_PRE>, - <&cru PCLK_GPU_PRE>; - pm_qos = <&qos_gpu>; - #power-domain-cells = <0>; - }; - - /* These power domains are grouped by VD_LOGIC */ - power-domain@RK3568_PD_VI { - reg = <RK3568_PD_VI>; - clocks = <&cru HCLK_VI>, - <&cru PCLK_VI>; - pm_qos = <&qos_isp>, - <&qos_vicap0>, - <&qos_vicap1>; - #power-domain-cells = <0>; - }; - - power-domain@RK3568_PD_VO { - reg = <RK3568_PD_VO>; - clocks = <&cru HCLK_VO>, - <&cru PCLK_VO>, - <&cru ACLK_VOP_PRE>; - pm_qos = <&qos_hdcp>, - <&qos_vop_m0>, - <&qos_vop_m1>; - #power-domain-cells = <0>; - }; - - power-domain@RK3568_PD_RGA { - reg = <RK3568_PD_RGA>; - clocks = <&cru HCLK_RGA_PRE>, - <&cru PCLK_RGA_PRE>; - pm_qos = <&qos_ebc>, - <&qos_iep>, - <&qos_jpeg_dec>, - <&qos_jpeg_enc>, - <&qos_rga_rd>, - <&qos_rga_wr>; - #power-domain-cells = <0>; - }; - - power-domain@RK3568_PD_VPU { - reg = <RK3568_PD_VPU>; - clocks = <&cru HCLK_VPU_PRE>; - pm_qos = <&qos_vpu>; - #power-domain-cells = <0>; - }; - - power-domain@RK3568_PD_RKVDEC { - clocks = <&cru HCLK_RKVDEC_PRE>; - reg = <RK3568_PD_RKVDEC>; - pm_qos = <&qos_rkvdec>; - #power-domain-cells = <0>; - }; - - power-domain@RK3568_PD_RKVENC { - reg = <RK3568_PD_RKVENC>; - clocks = <&cru HCLK_RKVENC_PRE>; - pm_qos = <&qos_rkvenc_rd_m0>, - <&qos_rkvenc_rd_m1>, - <&qos_rkvenc_wr_m0>; - #power-domain-cells = <0>; - }; - }; - }; - - gpu: gpu@fde60000 { - compatible = "rockchip,rk3568-mali", "arm,mali-bifrost"; - reg = <0x0 0xfde60000 0x0 0x4000>; - interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "job", "mmu", "gpu"; - clocks = <&scmi_clk 1>, <&cru CLK_GPU>; - clock-names = "gpu", "bus"; - #cooling-cells = <2>; - operating-points-v2 = <&gpu_opp_table>; - power-domains = <&power RK3568_PD_GPU>; - status = "disabled"; - }; - - vpu: video-codec@fdea0400 { - compatible = "rockchip,rk3568-vpu"; - reg = <0x0 0xfdea0000 0x0 0x800>; - interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; - clock-names = "aclk", "hclk"; - iommus = <&vdpu_mmu>; - power-domains = <&power RK3568_PD_VPU>; - }; - - vdpu_mmu: iommu@fdea0800 { - compatible = "rockchip,rk3568-iommu"; - reg = <0x0 0xfdea0800 0x0 0x40>; - interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>; - clock-names = "aclk", "iface"; - clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>; - power-domains = <&power RK3568_PD_VPU>; - #iommu-cells = <0>; - }; - - rga: rga@fdeb0000 { - compatible = "rockchip,rk3568-rga", "rockchip,rk3288-rga"; - reg = <0x0 0xfdeb0000 0x0 0x180>; - interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru CLK_RGA_CORE>; - clock-names = "aclk", "hclk", "sclk"; - resets = <&cru SRST_RGA_CORE>, <&cru SRST_A_RGA>, <&cru SRST_H_RGA>; - reset-names = "core", "axi", "ahb"; - power-domains = <&power RK3568_PD_RGA>; - }; - - vepu: video-codec@fdee0000 { - compatible = "rockchip,rk3568-vepu"; - reg = <0x0 0xfdee0000 0x0 0x800>; - interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_JENC>, <&cru HCLK_JENC>; - clock-names = "aclk", "hclk"; - iommus = <&vepu_mmu>; - power-domains = <&power RK3568_PD_RGA>; - }; - - vepu_mmu: iommu@fdee0800 { - compatible = "rockchip,rk3568-iommu"; - reg = <0x0 0xfdee0800 0x0 0x40>; - interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_JENC>, <&cru HCLK_JENC>; - clock-names = "aclk", "iface"; - power-domains = <&power RK3568_PD_RGA>; - #iommu-cells = <0>; - }; - - sdmmc2: mmc@fe000000 { - compatible = "rockchip,rk3568-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xfe000000 0x0 0x4000>; - interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDMMC2>, <&cru CLK_SDMMC2>, - <&cru SCLK_SDMMC2_DRV>, <&cru SCLK_SDMMC2_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - resets = <&cru SRST_SDMMC2>; - reset-names = "reset"; - status = "disabled"; - }; - - gmac1: ethernet@fe010000 { - compatible = "rockchip,rk3568-gmac", "snps,dwmac-4.20a"; - reg = <0x0 0xfe010000 0x0 0x10000>; - interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "macirq", "eth_wake_irq"; - clocks = <&cru SCLK_GMAC1>, <&cru SCLK_GMAC1_RX_TX>, - <&cru SCLK_GMAC1_RX_TX>, <&cru CLK_MAC1_REFOUT>, - <&cru ACLK_GMAC1>, <&cru PCLK_GMAC1>, - <&cru SCLK_GMAC1_RX_TX>, <&cru CLK_GMAC1_PTP_REF>; - clock-names = "stmmaceth", "mac_clk_rx", - "mac_clk_tx", "clk_mac_refout", - "aclk_mac", "pclk_mac", - "clk_mac_speed", "ptp_ref"; - resets = <&cru SRST_A_GMAC1>; - reset-names = "stmmaceth"; - rockchip,grf = <&grf>; - snps,axi-config = <&gmac1_stmmac_axi_setup>; - snps,mixed-burst; - snps,mtl-rx-config = <&gmac1_mtl_rx_setup>; - snps,mtl-tx-config = <&gmac1_mtl_tx_setup>; - snps,tso; - status = "disabled"; - - mdio1: mdio { - compatible = "snps,dwmac-mdio"; - #address-cells = <0x1>; - #size-cells = <0x0>; - }; - - gmac1_stmmac_axi_setup: stmmac-axi-config { - snps,blen = <0 0 0 0 16 8 4>; - snps,rd_osr_lmt = <8>; - snps,wr_osr_lmt = <4>; - }; - - gmac1_mtl_rx_setup: rx-queues-config { - snps,rx-queues-to-use = <1>; - queue0 {}; - }; - - gmac1_mtl_tx_setup: tx-queues-config { - snps,tx-queues-to-use = <1>; - queue0 {}; - }; - }; - - vop: vop@fe040000 { - reg = <0x0 0xfe040000 0x0 0x3000>, <0x0 0xfe044000 0x0 0x1000>; - reg-names = "vop", "gamma-lut"; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>, <&cru DCLK_VOP0>, - <&cru DCLK_VOP1>, <&cru DCLK_VOP2>; - clock-names = "aclk", "hclk", "dclk_vp0", "dclk_vp1", "dclk_vp2"; - iommus = <&vop_mmu>; - power-domains = <&power RK3568_PD_VO>; - rockchip,grf = <&grf>; - status = "disabled"; - - vop_out: ports { - #address-cells = <1>; - #size-cells = <0>; - - vp0: port@0 { - reg = <0>; - #address-cells = <1>; - #size-cells = <0>; - }; - - vp1: port@1 { - reg = <1>; - #address-cells = <1>; - #size-cells = <0>; - }; - - vp2: port@2 { - reg = <2>; - #address-cells = <1>; - #size-cells = <0>; - }; - }; - }; - - vop_mmu: iommu@fe043e00 { - compatible = "rockchip,rk3568-iommu"; - reg = <0x0 0xfe043e00 0x0 0x100>, <0x0 0xfe043f00 0x0 0x100>; - interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>; - clock-names = "aclk", "iface"; - #iommu-cells = <0>; - status = "disabled"; - }; - - dsi0: dsi@fe060000 { - compatible = "rockchip,rk3568-mipi-dsi", "snps,dw-mipi-dsi"; - reg = <0x00 0xfe060000 0x00 0x10000>; - interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>; - clock-names = "pclk"; - clocks = <&cru PCLK_DSITX_0>; - phy-names = "dphy"; - phys = <&dsi_dphy0>; - power-domains = <&power RK3568_PD_VO>; - reset-names = "apb"; - resets = <&cru SRST_P_DSITX_0>; - rockchip,grf = <&grf>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - dsi0_in: port@0 { - reg = <0>; - }; - - dsi0_out: port@1 { - reg = <1>; - }; - }; - }; - - dsi1: dsi@fe070000 { - compatible = "rockchip,rk3568-mipi-dsi", "snps,dw-mipi-dsi"; - reg = <0x0 0xfe070000 0x0 0x10000>; - interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>; - clock-names = "pclk"; - clocks = <&cru PCLK_DSITX_1>; - phy-names = "dphy"; - phys = <&dsi_dphy1>; - power-domains = <&power RK3568_PD_VO>; - reset-names = "apb"; - resets = <&cru SRST_P_DSITX_1>; - rockchip,grf = <&grf>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - dsi1_in: port@0 { - reg = <0>; - }; - - dsi1_out: port@1 { - reg = <1>; - }; - }; - }; - - hdmi: hdmi@fe0a0000 { - compatible = "rockchip,rk3568-dw-hdmi"; - reg = <0x0 0xfe0a0000 0x0 0x20000>; - interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_HDMI_HOST>, - <&cru CLK_HDMI_SFR>, - <&cru CLK_HDMI_CEC>, - <&pmucru CLK_HDMI_REF>, - <&cru HCLK_VO>; - clock-names = "iahb", "isfr", "cec", "ref"; - pinctrl-names = "default"; - pinctrl-0 = <&hdmitx_scl &hdmitx_sda &hdmitxm0_cec>; - power-domains = <&power RK3568_PD_VO>; - reg-io-width = <4>; - rockchip,grf = <&grf>; - #sound-dai-cells = <0>; - status = "disabled"; - - ports { - #address-cells = <1>; - #size-cells = <0>; - - hdmi_in: port@0 { - reg = <0>; - }; - - hdmi_out: port@1 { - reg = <1>; - }; - }; - }; - - qos_gpu: qos@fe128000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe128000 0x0 0x20>; - }; - - qos_rkvenc_rd_m0: qos@fe138080 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe138080 0x0 0x20>; - }; - - qos_rkvenc_rd_m1: qos@fe138100 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe138100 0x0 0x20>; - }; - - qos_rkvenc_wr_m0: qos@fe138180 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe138180 0x0 0x20>; - }; - - qos_isp: qos@fe148000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe148000 0x0 0x20>; - }; - - qos_vicap0: qos@fe148080 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe148080 0x0 0x20>; - }; - - qos_vicap1: qos@fe148100 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe148100 0x0 0x20>; - }; - - qos_vpu: qos@fe150000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe150000 0x0 0x20>; - }; - - qos_ebc: qos@fe158000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe158000 0x0 0x20>; - }; - - qos_iep: qos@fe158100 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe158100 0x0 0x20>; - }; - - qos_jpeg_dec: qos@fe158180 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe158180 0x0 0x20>; - }; - - qos_jpeg_enc: qos@fe158200 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe158200 0x0 0x20>; - }; - - qos_rga_rd: qos@fe158280 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe158280 0x0 0x20>; - }; - - qos_rga_wr: qos@fe158300 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe158300 0x0 0x20>; - }; - - qos_npu: qos@fe180000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe180000 0x0 0x20>; - }; - - qos_pcie2x1: qos@fe190000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190000 0x0 0x20>; - }; - - qos_sata1: qos@fe190280 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190280 0x0 0x20>; - }; - - qos_sata2: qos@fe190300 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190300 0x0 0x20>; - }; - - qos_usb3_0: qos@fe190380 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190380 0x0 0x20>; - }; - - qos_usb3_1: qos@fe190400 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe190400 0x0 0x20>; - }; - - qos_rkvdec: qos@fe198000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe198000 0x0 0x20>; - }; - - qos_hdcp: qos@fe1a8000 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe1a8000 0x0 0x20>; - }; - - qos_vop_m0: qos@fe1a8080 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe1a8080 0x0 0x20>; - }; - - qos_vop_m1: qos@fe1a8100 { - compatible = "rockchip,rk3568-qos", "syscon"; - reg = <0x0 0xfe1a8100 0x0 0x20>; - }; - - dfi: dfi@fe230000 { - compatible = "rockchip,rk3568-dfi"; - reg = <0x00 0xfe230000 0x00 0x400>; - interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>; - rockchip,pmu = <&pmugrf>; - }; - - pcie2x1: pcie@fe260000 { - compatible = "rockchip,rk3568-pcie"; - reg = <0x3 0xc0000000 0x0 0x00400000>, - <0x0 0xfe260000 0x0 0x00010000>, - <0x0 0xf4000000 0x0 0x00100000>; - reg-names = "dbi", "apb", "config"; - interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>; - interrupt-names = "sys", "pmc", "msg", "legacy", "err"; - bus-range = <0x0 0xf>; - clocks = <&cru ACLK_PCIE20_MST>, <&cru ACLK_PCIE20_SLV>, - <&cru ACLK_PCIE20_DBI>, <&cru PCLK_PCIE20>, - <&cru CLK_PCIE20_AUX_NDFT>; - clock-names = "aclk_mst", "aclk_slv", - "aclk_dbi", "pclk", "aux"; - device_type = "pci"; - #interrupt-cells = <1>; - interrupt-map-mask = <0 0 0 7>; - interrupt-map = <0 0 0 1 &pcie_intc 0>, - <0 0 0 2 &pcie_intc 1>, - <0 0 0 3 &pcie_intc 2>, - <0 0 0 4 &pcie_intc 3>; - linux,pci-domain = <0>; - num-ib-windows = <6>; - num-ob-windows = <2>; - max-link-speed = <2>; - msi-map = <0x0 &gic 0x0 0x1000>; - num-lanes = <1>; - phys = <&combphy2 PHY_TYPE_PCIE>; - phy-names = "pcie-phy"; - power-domains = <&power RK3568_PD_PIPE>; - ranges = <0x01000000 0x0 0xf4100000 0x0 0xf4100000 0x0 0x00100000>, - <0x02000000 0x0 0xf4200000 0x0 0xf4200000 0x0 0x01e00000>, - <0x03000000 0x0 0x40000000 0x3 0x00000000 0x0 0x40000000>; - resets = <&cru SRST_PCIE20_POWERUP>; - reset-names = "pipe"; - #address-cells = <3>; - #size-cells = <2>; - status = "disabled"; - - pcie_intc: legacy-interrupt-controller { - #address-cells = <0>; - #interrupt-cells = <1>; - interrupt-controller; - interrupt-parent = <&gic>; - interrupts = <GIC_SPI 72 IRQ_TYPE_EDGE_RISING>; - }; - }; - - sdmmc0: mmc@fe2b0000 { - compatible = "rockchip,rk3568-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xfe2b0000 0x0 0x4000>; - interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDMMC0>, <&cru CLK_SDMMC0>, - <&cru SCLK_SDMMC0_DRV>, <&cru SCLK_SDMMC0_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - resets = <&cru SRST_SDMMC0>; - reset-names = "reset"; - status = "disabled"; - }; - - sdmmc1: mmc@fe2c0000 { - compatible = "rockchip,rk3568-dw-mshc", "rockchip,rk3288-dw-mshc"; - reg = <0x0 0xfe2c0000 0x0 0x4000>; - interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru HCLK_SDMMC1>, <&cru CLK_SDMMC1>, - <&cru SCLK_SDMMC1_DRV>, <&cru SCLK_SDMMC1_SAMPLE>; - clock-names = "biu", "ciu", "ciu-drive", "ciu-sample"; - fifo-depth = <0x100>; - max-frequency = <150000000>; - resets = <&cru SRST_SDMMC1>; - reset-names = "reset"; - status = "disabled"; - }; - - sfc: spi@fe300000 { - compatible = "rockchip,sfc"; - reg = <0x0 0xfe300000 0x0 0x4000>; - interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_SFC>, <&cru HCLK_SFC>; - clock-names = "clk_sfc", "hclk_sfc"; - pinctrl-0 = <&fspi_pins>; - pinctrl-names = "default"; - status = "disabled"; - }; - - sdhci: mmc@fe310000 { - compatible = "rockchip,rk3568-dwcmshc"; - reg = <0x0 0xfe310000 0x0 0x10000>; - interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>; - assigned-clocks = <&cru BCLK_EMMC>, <&cru TCLK_EMMC>; - assigned-clock-rates = <200000000>, <24000000>; - clocks = <&cru CCLK_EMMC>, <&cru HCLK_EMMC>, - <&cru ACLK_EMMC>, <&cru BCLK_EMMC>, - <&cru TCLK_EMMC>; - clock-names = "core", "bus", "axi", "block", "timer"; - status = "disabled"; - }; - - i2s0_8ch: i2s@fe400000 { - compatible = "rockchip,rk3568-i2s-tdm"; - reg = <0x0 0xfe400000 0x0 0x1000>; - interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>; - assigned-clocks = <&cru CLK_I2S0_8CH_TX_SRC>, <&cru CLK_I2S0_8CH_RX_SRC>; - assigned-clock-rates = <1188000000>, <1188000000>; - clocks = <&cru MCLK_I2S0_8CH_TX>, <&cru MCLK_I2S0_8CH_RX>, <&cru HCLK_I2S0_8CH>; - clock-names = "mclk_tx", "mclk_rx", "hclk"; - dmas = <&dmac1 0>; - dma-names = "tx"; - resets = <&cru SRST_M_I2S0_8CH_TX>, <&cru SRST_M_I2S0_8CH_RX>; - reset-names = "tx-m", "rx-m"; - rockchip,grf = <&grf>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s1_8ch: i2s@fe410000 { - compatible = "rockchip,rk3568-i2s-tdm"; - reg = <0x0 0xfe410000 0x0 0x1000>; - interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>; - assigned-clocks = <&cru CLK_I2S1_8CH_TX_SRC>, <&cru CLK_I2S1_8CH_RX_SRC>; - assigned-clock-rates = <1188000000>, <1188000000>; - clocks = <&cru MCLK_I2S1_8CH_TX>, <&cru MCLK_I2S1_8CH_RX>, - <&cru HCLK_I2S1_8CH>; - clock-names = "mclk_tx", "mclk_rx", "hclk"; - dmas = <&dmac1 3>, <&dmac1 2>; - dma-names = "rx", "tx"; - resets = <&cru SRST_M_I2S1_8CH_TX>, <&cru SRST_M_I2S1_8CH_RX>; - reset-names = "tx-m", "rx-m"; - rockchip,grf = <&grf>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s1m0_sclktx &i2s1m0_sclkrx - &i2s1m0_lrcktx &i2s1m0_lrckrx - &i2s1m0_sdi0 &i2s1m0_sdi1 - &i2s1m0_sdi2 &i2s1m0_sdi3 - &i2s1m0_sdo0 &i2s1m0_sdo1 - &i2s1m0_sdo2 &i2s1m0_sdo3>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s2_2ch: i2s@fe420000 { - compatible = "rockchip,rk3568-i2s-tdm"; - reg = <0x0 0xfe420000 0x0 0x1000>; - interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>; - assigned-clocks = <&cru CLK_I2S2_2CH_SRC>; - assigned-clock-rates = <1188000000>; - clocks = <&cru MCLK_I2S2_2CH>, <&cru MCLK_I2S2_2CH>, <&cru HCLK_I2S2_2CH>; - clock-names = "mclk_tx", "mclk_rx", "hclk"; - dmas = <&dmac1 4>, <&dmac1 5>; - dma-names = "tx", "rx"; - resets = <&cru SRST_M_I2S2_2CH>; - reset-names = "m"; - rockchip,grf = <&grf>; - pinctrl-names = "default"; - pinctrl-0 = <&i2s2m0_sclktx - &i2s2m0_lrcktx - &i2s2m0_sdi - &i2s2m0_sdo>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - i2s3_2ch: i2s@fe430000 { - compatible = "rockchip,rk3568-i2s-tdm"; - reg = <0x0 0xfe430000 0x0 0x1000>; - interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru MCLK_I2S3_2CH_TX>, <&cru MCLK_I2S3_2CH_RX>, - <&cru HCLK_I2S3_2CH>; - clock-names = "mclk_tx", "mclk_rx", "hclk"; - dmas = <&dmac1 6>, <&dmac1 7>; - dma-names = "tx", "rx"; - resets = <&cru SRST_M_I2S3_2CH_TX>, <&cru SRST_M_I2S3_2CH_RX>; - reset-names = "tx-m", "rx-m"; - rockchip,grf = <&grf>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - pdm: pdm@fe440000 { - compatible = "rockchip,rk3568-pdm"; - reg = <0x0 0xfe440000 0x0 0x1000>; - interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru MCLK_PDM>, <&cru HCLK_PDM>; - clock-names = "pdm_clk", "pdm_hclk"; - dmas = <&dmac1 9>; - dma-names = "rx"; - pinctrl-0 = <&pdmm0_clk - &pdmm0_clk1 - &pdmm0_sdi0 - &pdmm0_sdi1 - &pdmm0_sdi2 - &pdmm0_sdi3>; - pinctrl-names = "default"; - resets = <&cru SRST_M_PDM>; - reset-names = "pdm-m"; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - spdif: spdif@fe460000 { - compatible = "rockchip,rk3568-spdif"; - reg = <0x0 0xfe460000 0x0 0x1000>; - interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>; - clock-names = "mclk", "hclk"; - clocks = <&cru MCLK_SPDIF_8CH>, <&cru HCLK_SPDIF_8CH>; - dmas = <&dmac1 1>; - dma-names = "tx"; - pinctrl-names = "default"; - pinctrl-0 = <&spdifm0_tx>; - #sound-dai-cells = <0>; - status = "disabled"; - }; - - dmac0: dma-controller@fe530000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xfe530000 0x0 0x4000>; - interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_BUS>; - clock-names = "apb_pclk"; - #dma-cells = <1>; - }; - - dmac1: dma-controller@fe550000 { - compatible = "arm,pl330", "arm,primecell"; - reg = <0x0 0xfe550000 0x0 0x4000>; - interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>, - <GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>; - arm,pl330-periph-burst; - clocks = <&cru ACLK_BUS>; - clock-names = "apb_pclk"; - #dma-cells = <1>; - }; - - i2c1: i2c@fe5a0000 { - compatible = "rockchip,rk3568-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xfe5a0000 0x0 0x1000>; - interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_I2C1>, <&cru PCLK_I2C1>; - clock-names = "i2c", "pclk"; - pinctrl-0 = <&i2c1_xfer>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c2: i2c@fe5b0000 { - compatible = "rockchip,rk3568-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xfe5b0000 0x0 0x1000>; - interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_I2C2>, <&cru PCLK_I2C2>; - clock-names = "i2c", "pclk"; - pinctrl-0 = <&i2c2m0_xfer>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c3: i2c@fe5c0000 { - compatible = "rockchip,rk3568-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xfe5c0000 0x0 0x1000>; - interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_I2C3>, <&cru PCLK_I2C3>; - clock-names = "i2c", "pclk"; - pinctrl-0 = <&i2c3m0_xfer>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c4: i2c@fe5d0000 { - compatible = "rockchip,rk3568-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xfe5d0000 0x0 0x1000>; - interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_I2C4>, <&cru PCLK_I2C4>; - clock-names = "i2c", "pclk"; - pinctrl-0 = <&i2c4m0_xfer>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - i2c5: i2c@fe5e0000 { - compatible = "rockchip,rk3568-i2c", "rockchip,rk3399-i2c"; - reg = <0x0 0xfe5e0000 0x0 0x1000>; - interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_I2C5>, <&cru PCLK_I2C5>; - clock-names = "i2c", "pclk"; - pinctrl-0 = <&i2c5m0_xfer>; - pinctrl-names = "default"; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - wdt: watchdog@fe600000 { - compatible = "rockchip,rk3568-wdt", "snps,dw-wdt"; - reg = <0x0 0xfe600000 0x0 0x100>; - interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru TCLK_WDT_NS>, <&cru PCLK_WDT_NS>; - clock-names = "tclk", "pclk"; - }; - - spi0: spi@fe610000 { - compatible = "rockchip,rk3568-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xfe610000 0x0 0x1000>; - interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_SPI0>, <&cru PCLK_SPI0>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac0 20>, <&dmac0 21>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi0m0_cs0 &spi0m0_cs1 &spi0m0_pins>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi1: spi@fe620000 { - compatible = "rockchip,rk3568-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xfe620000 0x0 0x1000>; - interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_SPI1>, <&cru PCLK_SPI1>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac0 22>, <&dmac0 23>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi1m0_cs0 &spi1m0_cs1 &spi1m0_pins>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi2: spi@fe630000 { - compatible = "rockchip,rk3568-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xfe630000 0x0 0x1000>; - interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_SPI2>, <&cru PCLK_SPI2>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac0 24>, <&dmac0 25>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi2m0_cs0 &spi2m0_cs1 &spi2m0_pins>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - spi3: spi@fe640000 { - compatible = "rockchip,rk3568-spi", "rockchip,rk3066-spi"; - reg = <0x0 0xfe640000 0x0 0x1000>; - interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_SPI3>, <&cru PCLK_SPI3>; - clock-names = "spiclk", "apb_pclk"; - dmas = <&dmac0 26>, <&dmac0 27>; - dma-names = "tx", "rx"; - pinctrl-names = "default"; - pinctrl-0 = <&spi3m0_cs0 &spi3m0_cs1 &spi3m0_pins>; - #address-cells = <1>; - #size-cells = <0>; - status = "disabled"; - }; - - uart1: serial@fe650000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe650000 0x0 0x100>; - interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 2>, <&dmac0 3>; - pinctrl-0 = <&uart1m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart2: serial@fe660000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe660000 0x0 0x100>; - interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 4>, <&dmac0 5>; - pinctrl-0 = <&uart2m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart3: serial@fe670000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe670000 0x0 0x100>; - interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 6>, <&dmac0 7>; - pinctrl-0 = <&uart3m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart4: serial@fe680000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe680000 0x0 0x100>; - interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 8>, <&dmac0 9>; - pinctrl-0 = <&uart4m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart5: serial@fe690000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe690000 0x0 0x100>; - interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART5>, <&cru PCLK_UART5>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 10>, <&dmac0 11>; - pinctrl-0 = <&uart5m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart6: serial@fe6a0000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe6a0000 0x0 0x100>; - interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART6>, <&cru PCLK_UART6>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 12>, <&dmac0 13>; - pinctrl-0 = <&uart6m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart7: serial@fe6b0000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe6b0000 0x0 0x100>; - interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART7>, <&cru PCLK_UART7>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 14>, <&dmac0 15>; - pinctrl-0 = <&uart7m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart8: serial@fe6c0000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe6c0000 0x0 0x100>; - interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART8>, <&cru PCLK_UART8>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 16>, <&dmac0 17>; - pinctrl-0 = <&uart8m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - uart9: serial@fe6d0000 { - compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart"; - reg = <0x0 0xfe6d0000 0x0 0x100>; - interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru SCLK_UART9>, <&cru PCLK_UART9>; - clock-names = "baudclk", "apb_pclk"; - dmas = <&dmac0 18>, <&dmac0 19>; - pinctrl-0 = <&uart9m0_xfer>; - pinctrl-names = "default"; - reg-io-width = <4>; - reg-shift = <2>; - status = "disabled"; - }; - - thermal_zones: thermal-zones { - cpu_thermal: cpu-thermal { - polling-delay-passive = <100>; - polling-delay = <1000>; - - thermal-sensors = <&tsadc 0>; - - trips { - cpu_alert0: cpu_alert0 { - temperature = <70000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu_alert1: cpu_alert1 { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - cpu_crit: cpu_crit { - temperature = <95000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&cpu_alert0>; - cooling-device = - <&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>, - <&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - - gpu_thermal: gpu-thermal { - polling-delay-passive = <20>; /* milliseconds */ - polling-delay = <1000>; /* milliseconds */ - - thermal-sensors = <&tsadc 1>; - - trips { - gpu_threshold: gpu-threshold { - temperature = <70000>; - hysteresis = <2000>; - type = "passive"; - }; - gpu_target: gpu-target { - temperature = <75000>; - hysteresis = <2000>; - type = "passive"; - }; - gpu_crit: gpu-crit { - temperature = <95000>; - hysteresis = <2000>; - type = "critical"; - }; - }; - - cooling-maps { - map0 { - trip = <&gpu_target>; - cooling-device = - <&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>; - }; - }; - }; - }; - - tsadc: tsadc@fe710000 { - compatible = "rockchip,rk3568-tsadc"; - reg = <0x0 0xfe710000 0x0 0x100>; - interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>; - assigned-clocks = <&cru CLK_TSADC_TSEN>, <&cru CLK_TSADC>; - assigned-clock-rates = <17000000>, <700000>; - clocks = <&cru CLK_TSADC>, <&cru PCLK_TSADC>; - clock-names = "tsadc", "apb_pclk"; - resets = <&cru SRST_P_TSADC>, <&cru SRST_TSADC>, - <&cru SRST_TSADCPHY>; - rockchip,grf = <&grf>; - rockchip,hw-tshut-temp = <95000>; - pinctrl-names = "init", "default", "sleep"; - pinctrl-0 = <&tsadc_pin>; - pinctrl-1 = <&tsadc_shutorg>; - pinctrl-2 = <&tsadc_pin>; - #thermal-sensor-cells = <1>; - status = "disabled"; - }; - - saradc: saradc@fe720000 { - compatible = "rockchip,rk3568-saradc", "rockchip,rk3399-saradc"; - reg = <0x0 0xfe720000 0x0 0x100>; - interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru CLK_SARADC>, <&cru PCLK_SARADC>; - clock-names = "saradc", "apb_pclk"; - resets = <&cru SRST_P_SARADC>; - reset-names = "saradc-apb"; - #io-channel-cells = <1>; - status = "disabled"; - }; - - pwm4: pwm@fe6e0000 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6e0000 0x0 0x10>; - clocks = <&cru CLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm4_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm5: pwm@fe6e0010 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6e0010 0x0 0x10>; - clocks = <&cru CLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm5_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm6: pwm@fe6e0020 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6e0020 0x0 0x10>; - clocks = <&cru CLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm6_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm7: pwm@fe6e0030 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6e0030 0x0 0x10>; - clocks = <&cru CLK_PWM1>, <&cru PCLK_PWM1>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm7_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm8: pwm@fe6f0000 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6f0000 0x0 0x10>; - clocks = <&cru CLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm8m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm9: pwm@fe6f0010 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6f0010 0x0 0x10>; - clocks = <&cru CLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm9m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm10: pwm@fe6f0020 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6f0020 0x0 0x10>; - clocks = <&cru CLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm10m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm11: pwm@fe6f0030 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe6f0030 0x0 0x10>; - clocks = <&cru CLK_PWM2>, <&cru PCLK_PWM2>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm11m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm12: pwm@fe700000 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe700000 0x0 0x10>; - clocks = <&cru CLK_PWM3>, <&cru PCLK_PWM3>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm12m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm13: pwm@fe700010 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe700010 0x0 0x10>; - clocks = <&cru CLK_PWM3>, <&cru PCLK_PWM3>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm13m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm14: pwm@fe700020 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe700020 0x0 0x10>; - clocks = <&cru CLK_PWM3>, <&cru PCLK_PWM3>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm14m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - pwm15: pwm@fe700030 { - compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm"; - reg = <0x0 0xfe700030 0x0 0x10>; - clocks = <&cru CLK_PWM3>, <&cru PCLK_PWM3>; - clock-names = "pwm", "pclk"; - pinctrl-0 = <&pwm15m0_pins>; - pinctrl-names = "default"; - #pwm-cells = <3>; - status = "disabled"; - }; - - combphy1: phy@fe830000 { - compatible = "rockchip,rk3568-naneng-combphy"; - reg = <0x0 0xfe830000 0x0 0x100>; - clocks = <&pmucru CLK_PCIEPHY1_REF>, - <&cru PCLK_PIPEPHY1>, - <&cru PCLK_PIPE>; - clock-names = "ref", "apb", "pipe"; - assigned-clocks = <&pmucru CLK_PCIEPHY1_REF>; - assigned-clock-rates = <100000000>; - resets = <&cru SRST_PIPEPHY1>; - rockchip,pipe-grf = <&pipegrf>; - rockchip,pipe-phy-grf = <&pipe_phy_grf1>; - #phy-cells = <1>; - status = "disabled"; - }; - - combphy2: phy@fe840000 { - compatible = "rockchip,rk3568-naneng-combphy"; - reg = <0x0 0xfe840000 0x0 0x100>; - clocks = <&pmucru CLK_PCIEPHY2_REF>, - <&cru PCLK_PIPEPHY2>, - <&cru PCLK_PIPE>; - clock-names = "ref", "apb", "pipe"; - assigned-clocks = <&pmucru CLK_PCIEPHY2_REF>; - assigned-clock-rates = <100000000>; - resets = <&cru SRST_PIPEPHY2>; - rockchip,pipe-grf = <&pipegrf>; - rockchip,pipe-phy-grf = <&pipe_phy_grf2>; - #phy-cells = <1>; - status = "disabled"; - }; - - csi_dphy: phy@fe870000 { - compatible = "rockchip,rk3568-csi-dphy"; - reg = <0x0 0xfe870000 0x0 0x10000>; - clocks = <&cru PCLK_MIPICSIPHY>; - clock-names = "pclk"; - #phy-cells = <0>; - resets = <&cru SRST_P_MIPICSIPHY>; - reset-names = "apb"; - rockchip,grf = <&grf>; - status = "disabled"; - }; - - dsi_dphy0: mipi-dphy@fe850000 { - compatible = "rockchip,rk3568-dsi-dphy"; - reg = <0x0 0xfe850000 0x0 0x10000>; - clock-names = "ref", "pclk"; - clocks = <&pmucru CLK_MIPIDSIPHY0_REF>, <&cru PCLK_MIPIDSIPHY0>; - #phy-cells = <0>; - power-domains = <&power RK3568_PD_VO>; - reset-names = "apb"; - resets = <&cru SRST_P_MIPIDSIPHY0>; - status = "disabled"; - }; - - dsi_dphy1: mipi-dphy@fe860000 { - compatible = "rockchip,rk3568-dsi-dphy"; - reg = <0x0 0xfe860000 0x0 0x10000>; - clock-names = "ref", "pclk"; - clocks = <&pmucru CLK_MIPIDSIPHY1_REF>, <&cru PCLK_MIPIDSIPHY1>; - #phy-cells = <0>; - power-domains = <&power RK3568_PD_VO>; - reset-names = "apb"; - resets = <&cru SRST_P_MIPIDSIPHY1>; - status = "disabled"; - }; - - usb2phy0: usb2phy@fe8a0000 { - compatible = "rockchip,rk3568-usb2phy"; - reg = <0x0 0xfe8a0000 0x0 0x10000>; - clocks = <&pmucru CLK_USBPHY0_REF>; - clock-names = "phyclk"; - clock-output-names = "clk_usbphy0_480m"; - interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>; - rockchip,usbgrf = <&usb2phy0_grf>; - #clock-cells = <0>; - status = "disabled"; - - usb2phy0_host: host-port { - #phy-cells = <0>; - status = "disabled"; - }; - - usb2phy0_otg: otg-port { - #phy-cells = <0>; - status = "disabled"; - }; - }; - - usb2phy1: usb2phy@fe8b0000 { - compatible = "rockchip,rk3568-usb2phy"; - reg = <0x0 0xfe8b0000 0x0 0x10000>; - clocks = <&pmucru CLK_USBPHY1_REF>; - clock-names = "phyclk"; - clock-output-names = "clk_usbphy1_480m"; - interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>; - rockchip,usbgrf = <&usb2phy1_grf>; - #clock-cells = <0>; - status = "disabled"; - - usb2phy1_host: host-port { - #phy-cells = <0>; - status = "disabled"; - }; - - usb2phy1_otg: otg-port { - #phy-cells = <0>; - status = "disabled"; - }; - }; - - pinctrl: pinctrl { - compatible = "rockchip,rk3568-pinctrl"; - rockchip,grf = <&grf>; - rockchip,pmu = <&pmugrf>; - #address-cells = <2>; - #size-cells = <2>; - ranges; - - gpio0: gpio@fdd60000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xfdd60000 0x0 0x100>; - interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&pmucru PCLK_GPIO0>, <&pmucru DBCLK_GPIO0>; - gpio-controller; - gpio-ranges = <&pinctrl 0 0 32>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio1: gpio@fe740000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xfe740000 0x0 0x100>; - interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO1>, <&cru DBCLK_GPIO1>; - gpio-controller; - gpio-ranges = <&pinctrl 0 32 32>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio2: gpio@fe750000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xfe750000 0x0 0x100>; - interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO2>, <&cru DBCLK_GPIO2>; - gpio-controller; - gpio-ranges = <&pinctrl 0 64 32>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio3: gpio@fe760000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xfe760000 0x0 0x100>; - interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO3>, <&cru DBCLK_GPIO3>; - gpio-controller; - gpio-ranges = <&pinctrl 0 96 32>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - - gpio4: gpio@fe770000 { - compatible = "rockchip,gpio-bank"; - reg = <0x0 0xfe770000 0x0 0x100>; - interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>; - clocks = <&cru PCLK_GPIO4>, <&cru DBCLK_GPIO4>; - gpio-controller; - gpio-ranges = <&pinctrl 0 128 32>; - #gpio-cells = <2>; - interrupt-controller; - #interrupt-cells = <2>; - }; - }; -}; - -#include "rk3568-pinctrl.dtsi" diff --git a/include/dt-bindings/clock/rk3568-cru.h b/include/dt-bindings/clock/rk3568-cru.h deleted file mode 100644 index d29890865150..000000000000 --- a/include/dt-bindings/clock/rk3568-cru.h +++ /dev/null @@ -1,926 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/* - * Copyright (c) 2021 Rockchip Electronics Co. Ltd. - * Author: Elaine Zhang zhangqing@rock-chips.com - */ - -#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H - -/* pmucru-clocks indices */ - -/* pmucru plls */ -#define PLL_PPLL 1 -#define PLL_HPLL 2 - -/* pmucru clocks */ -#define XIN_OSC0_DIV 4 -#define CLK_RTC_32K 5 -#define CLK_PMU 6 -#define CLK_I2C0 7 -#define CLK_RTC32K_FRAC 8 -#define CLK_UART0_DIV 9 -#define CLK_UART0_FRAC 10 -#define SCLK_UART0 11 -#define DBCLK_GPIO0 12 -#define CLK_PWM0 13 -#define CLK_CAPTURE_PWM0_NDFT 14 -#define CLK_PMUPVTM 15 -#define CLK_CORE_PMUPVTM 16 -#define CLK_REF24M 17 -#define XIN_OSC0_USBPHY0_G 18 -#define CLK_USBPHY0_REF 19 -#define XIN_OSC0_USBPHY1_G 20 -#define CLK_USBPHY1_REF 21 -#define XIN_OSC0_MIPIDSIPHY0_G 22 -#define CLK_MIPIDSIPHY0_REF 23 -#define XIN_OSC0_MIPIDSIPHY1_G 24 -#define CLK_MIPIDSIPHY1_REF 25 -#define CLK_WIFI_DIV 26 -#define CLK_WIFI_OSC0 27 -#define CLK_WIFI 28 -#define CLK_PCIEPHY0_DIV 29 -#define CLK_PCIEPHY0_OSC0 30 -#define CLK_PCIEPHY0_REF 31 -#define CLK_PCIEPHY1_DIV 32 -#define CLK_PCIEPHY1_OSC0 33 -#define CLK_PCIEPHY1_REF 34 -#define CLK_PCIEPHY2_DIV 35 -#define CLK_PCIEPHY2_OSC0 36 -#define CLK_PCIEPHY2_REF 37 -#define CLK_PCIE30PHY_REF_M 38 -#define CLK_PCIE30PHY_REF_N 39 -#define CLK_HDMI_REF 40 -#define XIN_OSC0_EDPPHY_G 41 -#define PCLK_PDPMU 42 -#define PCLK_PMU 43 -#define PCLK_UART0 44 -#define PCLK_I2C0 45 -#define PCLK_GPIO0 46 -#define PCLK_PMUPVTM 47 -#define PCLK_PWM0 48 -#define CLK_PDPMU 49 -#define SCLK_32K_IOE 50 - -#define CLKPMU_NR_CLKS (SCLK_32K_IOE + 1) - -/* cru-clocks indices */ - -/* cru plls */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_VPLL 5 -#define PLL_NPLL 6 - -/* cru clocks */ -#define CPLL_333M 9 -#define ARMCLK 10 -#define USB480M 11 -#define ACLK_CORE_NIU2BUS 18 -#define CLK_CORE_PVTM 19 -#define CLK_CORE_PVTM_CORE 20 -#define CLK_CORE_PVTPLL 21 -#define CLK_GPU_SRC 22 -#define CLK_GPU_PRE_NDFT 23 -#define CLK_GPU_PRE_MUX 24 -#define ACLK_GPU_PRE 25 -#define PCLK_GPU_PRE 26 -#define CLK_GPU 27 -#define CLK_GPU_NP5 28 -#define PCLK_GPU_PVTM 29 -#define CLK_GPU_PVTM 30 -#define CLK_GPU_PVTM_CORE 31 -#define CLK_GPU_PVTPLL 32 -#define CLK_NPU_SRC 33 -#define CLK_NPU_PRE_NDFT 34 -#define CLK_NPU 35 -#define CLK_NPU_NP5 36 -#define HCLK_NPU_PRE 37 -#define PCLK_NPU_PRE 38 -#define ACLK_NPU_PRE 39 -#define ACLK_NPU 40 -#define HCLK_NPU 41 -#define PCLK_NPU_PVTM 42 -#define CLK_NPU_PVTM 43 -#define CLK_NPU_PVTM_CORE 44 -#define CLK_NPU_PVTPLL 45 -#define CLK_DDRPHY1X_SRC 46 -#define CLK_DDRPHY1X_HWFFC_SRC 47 -#define CLK_DDR1X 48 -#define CLK_MSCH 49 -#define CLK24_DDRMON 50 -#define ACLK_GIC_AUDIO 51 -#define HCLK_GIC_AUDIO 52 -#define HCLK_SDMMC_BUFFER 53 -#define DCLK_SDMMC_BUFFER 54 -#define ACLK_GIC600 55 -#define ACLK_SPINLOCK 56 -#define HCLK_I2S0_8CH 57 -#define HCLK_I2S1_8CH 58 -#define HCLK_I2S2_2CH 59 -#define HCLK_I2S3_2CH 60 -#define CLK_I2S0_8CH_TX_SRC 61 -#define CLK_I2S0_8CH_TX_FRAC 62 -#define MCLK_I2S0_8CH_TX 63 -#define I2S0_MCLKOUT_TX 64 -#define CLK_I2S0_8CH_RX_SRC 65 -#define CLK_I2S0_8CH_RX_FRAC 66 -#define MCLK_I2S0_8CH_RX 67 -#define I2S0_MCLKOUT_RX 68 -#define CLK_I2S1_8CH_TX_SRC 69 -#define CLK_I2S1_8CH_TX_FRAC 70 -#define MCLK_I2S1_8CH_TX 71 -#define I2S1_MCLKOUT_TX 72 -#define CLK_I2S1_8CH_RX_SRC 73 -#define CLK_I2S1_8CH_RX_FRAC 74 -#define MCLK_I2S1_8CH_RX 75 -#define I2S1_MCLKOUT_RX 76 -#define CLK_I2S2_2CH_SRC 77 -#define CLK_I2S2_2CH_FRAC 78 -#define MCLK_I2S2_2CH 79 -#define I2S2_MCLKOUT 80 -#define CLK_I2S3_2CH_TX_SRC 81 -#define CLK_I2S3_2CH_TX_FRAC 82 -#define MCLK_I2S3_2CH_TX 83 -#define I2S3_MCLKOUT_TX 84 -#define CLK_I2S3_2CH_RX_SRC 85 -#define CLK_I2S3_2CH_RX_FRAC 86 -#define MCLK_I2S3_2CH_RX 87 -#define I2S3_MCLKOUT_RX 88 -#define HCLK_PDM 89 -#define MCLK_PDM 90 -#define HCLK_VAD 91 -#define HCLK_SPDIF_8CH 92 -#define MCLK_SPDIF_8CH_SRC 93 -#define MCLK_SPDIF_8CH_FRAC 94 -#define MCLK_SPDIF_8CH 95 -#define HCLK_AUDPWM 96 -#define SCLK_AUDPWM_SRC 97 -#define SCLK_AUDPWM_FRAC 98 -#define SCLK_AUDPWM 99 -#define HCLK_ACDCDIG 100 -#define CLK_ACDCDIG_I2C 101 -#define CLK_ACDCDIG_DAC 102 -#define CLK_ACDCDIG_ADC 103 -#define ACLK_SECURE_FLASH 104 -#define HCLK_SECURE_FLASH 105 -#define ACLK_CRYPTO_NS 106 -#define HCLK_CRYPTO_NS 107 -#define CLK_CRYPTO_NS_CORE 108 -#define CLK_CRYPTO_NS_PKA 109 -#define CLK_CRYPTO_NS_RNG 110 -#define HCLK_TRNG_NS 111 -#define CLK_TRNG_NS 112 -#define PCLK_OTPC_NS 113 -#define CLK_OTPC_NS_SBPI 114 -#define CLK_OTPC_NS_USR 115 -#define HCLK_NANDC 116 -#define NCLK_NANDC 117 -#define HCLK_SFC 118 -#define HCLK_SFC_XIP 119 -#define SCLK_SFC 120 -#define ACLK_EMMC 121 -#define HCLK_EMMC 122 -#define BCLK_EMMC 123 -#define CCLK_EMMC 124 -#define TCLK_EMMC 125 -#define ACLK_PIPE 126 -#define PCLK_PIPE 127 -#define PCLK_PIPE_GRF 128 -#define ACLK_PCIE20_MST 129 -#define ACLK_PCIE20_SLV 130 -#define ACLK_PCIE20_DBI 131 -#define PCLK_PCIE20 132 -#define CLK_PCIE20_AUX_NDFT 133 -#define CLK_PCIE20_AUX_DFT 134 -#define CLK_PCIE20_PIPE_DFT 135 -#define ACLK_PCIE30X1_MST 136 -#define ACLK_PCIE30X1_SLV 137 -#define ACLK_PCIE30X1_DBI 138 -#define PCLK_PCIE30X1 139 -#define CLK_PCIE30X1_AUX_NDFT 140 -#define CLK_PCIE30X1_AUX_DFT 141 -#define CLK_PCIE30X1_PIPE_DFT 142 -#define ACLK_PCIE30X2_MST 143 -#define ACLK_PCIE30X2_SLV 144 -#define ACLK_PCIE30X2_DBI 145 -#define PCLK_PCIE30X2 146 -#define CLK_PCIE30X2_AUX_NDFT 147 -#define CLK_PCIE30X2_AUX_DFT 148 -#define CLK_PCIE30X2_PIPE_DFT 149 -#define ACLK_SATA0 150 -#define CLK_SATA0_PMALIVE 151 -#define CLK_SATA0_RXOOB 152 -#define CLK_SATA0_PIPE_NDFT 153 -#define CLK_SATA0_PIPE_DFT 154 -#define ACLK_SATA1 155 -#define CLK_SATA1_PMALIVE 156 -#define CLK_SATA1_RXOOB 157 -#define CLK_SATA1_PIPE_NDFT 158 -#define CLK_SATA1_PIPE_DFT 159 -#define ACLK_SATA2 160 -#define CLK_SATA2_PMALIVE 161 -#define CLK_SATA2_RXOOB 162 -#define CLK_SATA2_PIPE_NDFT 163 -#define CLK_SATA2_PIPE_DFT 164 -#define ACLK_USB3OTG0 165 -#define CLK_USB3OTG0_REF 166 -#define CLK_USB3OTG0_SUSPEND 167 -#define ACLK_USB3OTG1 168 -#define CLK_USB3OTG1_REF 169 -#define CLK_USB3OTG1_SUSPEND 170 -#define CLK_XPCS_EEE 171 -#define PCLK_XPCS 172 -#define ACLK_PHP 173 -#define HCLK_PHP 174 -#define PCLK_PHP 175 -#define HCLK_SDMMC0 176 -#define CLK_SDMMC0 177 -#define HCLK_SDMMC1 178 -#define CLK_SDMMC1 179 -#define ACLK_GMAC0 180 -#define PCLK_GMAC0 181 -#define CLK_MAC0_2TOP 182 -#define CLK_MAC0_OUT 183 -#define CLK_MAC0_REFOUT 184 -#define CLK_GMAC0_PTP_REF 185 -#define ACLK_USB 186 -#define HCLK_USB 187 -#define PCLK_USB 188 -#define HCLK_USB2HOST0 189 -#define HCLK_USB2HOST0_ARB 190 -#define HCLK_USB2HOST1 191 -#define HCLK_USB2HOST1_ARB 192 -#define HCLK_SDMMC2 193 -#define CLK_SDMMC2 194 -#define ACLK_GMAC1 195 -#define PCLK_GMAC1 196 -#define CLK_MAC1_2TOP 197 -#define CLK_MAC1_OUT 198 -#define CLK_MAC1_REFOUT 199 -#define CLK_GMAC1_PTP_REF 200 -#define ACLK_PERIMID 201 -#define HCLK_PERIMID 202 -#define ACLK_VI 203 -#define HCLK_VI 204 -#define PCLK_VI 205 -#define ACLK_VICAP 206 -#define HCLK_VICAP 207 -#define DCLK_VICAP 208 -#define ICLK_VICAP_G 209 -#define ACLK_ISP 210 -#define HCLK_ISP 211 -#define CLK_ISP 212 -#define PCLK_CSI2HOST1 213 -#define CLK_CIF_OUT 214 -#define CLK_CAM0_OUT 215 -#define CLK_CAM1_OUT 216 -#define ACLK_VO 217 -#define HCLK_VO 218 -#define PCLK_VO 219 -#define ACLK_VOP_PRE 220 -#define ACLK_VOP 221 -#define HCLK_VOP 222 -#define DCLK_VOP0 223 -#define DCLK_VOP1 224 -#define DCLK_VOP2 225 -#define CLK_VOP_PWM 226 -#define ACLK_HDCP 227 -#define HCLK_HDCP 228 -#define PCLK_HDCP 229 -#define PCLK_HDMI_HOST 230 -#define CLK_HDMI_SFR 231 -#define PCLK_DSITX_0 232 -#define PCLK_DSITX_1 233 -#define PCLK_EDP_CTRL 234 -#define CLK_EDP_200M 235 -#define ACLK_VPU_PRE 236 -#define HCLK_VPU_PRE 237 -#define ACLK_VPU 238 -#define HCLK_VPU 239 -#define ACLK_RGA_PRE 240 -#define HCLK_RGA_PRE 241 -#define PCLK_RGA_PRE 242 -#define ACLK_RGA 243 -#define HCLK_RGA 244 -#define CLK_RGA_CORE 245 -#define ACLK_IEP 246 -#define HCLK_IEP 247 -#define CLK_IEP_CORE 248 -#define HCLK_EBC 249 -#define DCLK_EBC 250 -#define ACLK_JDEC 251 -#define HCLK_JDEC 252 -#define ACLK_JENC 253 -#define HCLK_JENC 254 -#define PCLK_EINK 255 -#define HCLK_EINK 256 -#define ACLK_RKVENC_PRE 257 -#define HCLK_RKVENC_PRE 258 -#define ACLK_RKVENC 259 -#define HCLK_RKVENC 260 -#define CLK_RKVENC_CORE 261 -#define ACLK_RKVDEC_PRE 262 -#define HCLK_RKVDEC_PRE 263 -#define ACLK_RKVDEC 264 -#define HCLK_RKVDEC 265 -#define CLK_RKVDEC_CA 266 -#define CLK_RKVDEC_CORE 267 -#define CLK_RKVDEC_HEVC_CA 268 -#define ACLK_BUS 269 -#define PCLK_BUS 270 -#define PCLK_TSADC 271 -#define CLK_TSADC_TSEN 272 -#define CLK_TSADC 273 -#define PCLK_SARADC 274 -#define CLK_SARADC 275 -#define PCLK_SCR 276 -#define PCLK_WDT_NS 277 -#define TCLK_WDT_NS 278 -#define ACLK_DMAC0 279 -#define ACLK_DMAC1 280 -#define ACLK_MCU 281 -#define PCLK_INTMUX 282 -#define PCLK_MAILBOX 283 -#define PCLK_UART1 284 -#define CLK_UART1_SRC 285 -#define CLK_UART1_FRAC 286 -#define SCLK_UART1 287 -#define PCLK_UART2 288 -#define CLK_UART2_SRC 289 -#define CLK_UART2_FRAC 290 -#define SCLK_UART2 291 -#define PCLK_UART3 292 -#define CLK_UART3_SRC 293 -#define CLK_UART3_FRAC 294 -#define SCLK_UART3 295 -#define PCLK_UART4 296 -#define CLK_UART4_SRC 297 -#define CLK_UART4_FRAC 298 -#define SCLK_UART4 299 -#define PCLK_UART5 300 -#define CLK_UART5_SRC 301 -#define CLK_UART5_FRAC 302 -#define SCLK_UART5 303 -#define PCLK_UART6 304 -#define CLK_UART6_SRC 305 -#define CLK_UART6_FRAC 306 -#define SCLK_UART6 307 -#define PCLK_UART7 308 -#define CLK_UART7_SRC 309 -#define CLK_UART7_FRAC 310 -#define SCLK_UART7 311 -#define PCLK_UART8 312 -#define CLK_UART8_SRC 313 -#define CLK_UART8_FRAC 314 -#define SCLK_UART8 315 -#define PCLK_UART9 316 -#define CLK_UART9_SRC 317 -#define CLK_UART9_FRAC 318 -#define SCLK_UART9 319 -#define PCLK_CAN0 320 -#define CLK_CAN0 321 -#define PCLK_CAN1 322 -#define CLK_CAN1 323 -#define PCLK_CAN2 324 -#define CLK_CAN2 325 -#define CLK_I2C 326 -#define PCLK_I2C1 327 -#define CLK_I2C1 328 -#define PCLK_I2C2 329 -#define CLK_I2C2 330 -#define PCLK_I2C3 331 -#define CLK_I2C3 332 -#define PCLK_I2C4 333 -#define CLK_I2C4 334 -#define PCLK_I2C5 335 -#define CLK_I2C5 336 -#define PCLK_SPI0 337 -#define CLK_SPI0 338 -#define PCLK_SPI1 339 -#define CLK_SPI1 340 -#define PCLK_SPI2 341 -#define CLK_SPI2 342 -#define PCLK_SPI3 343 -#define CLK_SPI3 344 -#define PCLK_PWM1 345 -#define CLK_PWM1 346 -#define CLK_PWM1_CAPTURE 347 -#define PCLK_PWM2 348 -#define CLK_PWM2 349 -#define CLK_PWM2_CAPTURE 350 -#define PCLK_PWM3 351 -#define CLK_PWM3 352 -#define CLK_PWM3_CAPTURE 353 -#define DBCLK_GPIO 354 -#define PCLK_GPIO1 355 -#define DBCLK_GPIO1 356 -#define PCLK_GPIO2 357 -#define DBCLK_GPIO2 358 -#define PCLK_GPIO3 359 -#define DBCLK_GPIO3 360 -#define PCLK_GPIO4 361 -#define DBCLK_GPIO4 362 -#define OCC_SCAN_CLK_GPIO 363 -#define PCLK_TIMER 364 -#define CLK_TIMER0 365 -#define CLK_TIMER1 366 -#define CLK_TIMER2 367 -#define CLK_TIMER3 368 -#define CLK_TIMER4 369 -#define CLK_TIMER5 370 -#define ACLK_TOP_HIGH 371 -#define ACLK_TOP_LOW 372 -#define HCLK_TOP 373 -#define PCLK_TOP 374 -#define PCLK_PCIE30PHY 375 -#define CLK_OPTC_ARB 376 -#define PCLK_MIPICSIPHY 377 -#define PCLK_MIPIDSIPHY0 378 -#define PCLK_MIPIDSIPHY1 379 -#define PCLK_PIPEPHY0 380 -#define PCLK_PIPEPHY1 381 -#define PCLK_PIPEPHY2 382 -#define PCLK_CPU_BOOST 383 -#define CLK_CPU_BOOST 384 -#define PCLK_OTPPHY 385 -#define SCLK_GMAC0 386 -#define SCLK_GMAC0_RGMII_SPEED 387 -#define SCLK_GMAC0_RMII_SPEED 388 -#define SCLK_GMAC0_RX_TX 389 -#define SCLK_GMAC1 390 -#define SCLK_GMAC1_RGMII_SPEED 391 -#define SCLK_GMAC1_RMII_SPEED 392 -#define SCLK_GMAC1_RX_TX 393 -#define SCLK_SDMMC0_DRV 394 -#define SCLK_SDMMC0_SAMPLE 395 -#define SCLK_SDMMC1_DRV 396 -#define SCLK_SDMMC1_SAMPLE 397 -#define SCLK_SDMMC2_DRV 398 -#define SCLK_SDMMC2_SAMPLE 399 -#define SCLK_EMMC_DRV 400 -#define SCLK_EMMC_SAMPLE 401 -#define PCLK_EDPPHY_GRF 402 -#define CLK_HDMI_CEC 403 -#define CLK_I2S0_8CH_TX 404 -#define CLK_I2S0_8CH_RX 405 -#define CLK_I2S1_8CH_TX 406 -#define CLK_I2S1_8CH_RX 407 -#define CLK_I2S2_2CH 408 -#define CLK_I2S3_2CH_TX 409 -#define CLK_I2S3_2CH_RX 410 -#define CPLL_500M 411 -#define CPLL_250M 412 -#define CPLL_125M 413 -#define CPLL_62P5M 414 -#define CPLL_50M 415 -#define CPLL_25M 416 -#define CPLL_100M 417 -#define SCLK_DDRCLK 418 - -#define PCLK_CORE_PVTM 450 - -#define CLK_NR_CLKS (PCLK_CORE_PVTM + 1) - -/* pmu soft-reset indices */ -/* pmucru_softrst_con0 */ -#define SRST_P_PDPMU_NIU 0 -#define SRST_P_PMUCRU 1 -#define SRST_P_PMUGRF 2 -#define SRST_P_I2C0 3 -#define SRST_I2C0 4 -#define SRST_P_UART0 5 -#define SRST_S_UART0 6 -#define SRST_P_PWM0 7 -#define SRST_PWM0 8 -#define SRST_P_GPIO0 9 -#define SRST_GPIO0 10 -#define SRST_P_PMUPVTM 11 -#define SRST_PMUPVTM 12 - -/* soft-reset indices */ - -/* cru_softrst_con0 */ -#define SRST_NCORERESET0 0 -#define SRST_NCORERESET1 1 -#define SRST_NCORERESET2 2 -#define SRST_NCORERESET3 3 -#define SRST_NCPUPORESET0 4 -#define SRST_NCPUPORESET1 5 -#define SRST_NCPUPORESET2 6 -#define SRST_NCPUPORESET3 7 -#define SRST_NSRESET 8 -#define SRST_NSPORESET 9 -#define SRST_NATRESET 10 -#define SRST_NGICRESET 11 -#define SRST_NPRESET 12 -#define SRST_NPERIPHRESET 13 - -/* cru_softrst_con1 */ -#define SRST_A_CORE_NIU2DDR 16 -#define SRST_A_CORE_NIU2BUS 17 -#define SRST_P_DBG_NIU 18 -#define SRST_P_DBG 19 -#define SRST_P_DBG_DAPLITE 20 -#define SRST_DAP 21 -#define SRST_A_ADB400_CORE2GIC 22 -#define SRST_A_ADB400_GIC2CORE 23 -#define SRST_P_CORE_GRF 24 -#define SRST_P_CORE_PVTM 25 -#define SRST_CORE_PVTM 26 -#define SRST_CORE_PVTPLL 27 - -/* cru_softrst_con2 */ -#define SRST_GPU 32 -#define SRST_A_GPU_NIU 33 -#define SRST_P_GPU_NIU 34 -#define SRST_P_GPU_PVTM 35 -#define SRST_GPU_PVTM 36 -#define SRST_GPU_PVTPLL 37 -#define SRST_A_NPU_NIU 40 -#define SRST_H_NPU_NIU 41 -#define SRST_P_NPU_NIU 42 -#define SRST_A_NPU 43 -#define SRST_H_NPU 44 -#define SRST_P_NPU_PVTM 45 -#define SRST_NPU_PVTM 46 -#define SRST_NPU_PVTPLL 47 - -/* cru_softrst_con3 */ -#define SRST_A_MSCH 51 -#define SRST_HWFFC_CTRL 52 -#define SRST_DDR_ALWAYSON 53 -#define SRST_A_DDRSPLIT 54 -#define SRST_DDRDFI_CTL 55 -#define SRST_A_DMA2DDR 57 - -/* cru_softrst_con4 */ -#define SRST_A_PERIMID_NIU 64 -#define SRST_H_PERIMID_NIU 65 -#define SRST_A_GIC_AUDIO_NIU 66 -#define SRST_H_GIC_AUDIO_NIU 67 -#define SRST_A_GIC600 68 -#define SRST_A_GIC600_DEBUG 69 -#define SRST_A_GICADB_CORE2GIC 70 -#define SRST_A_GICADB_GIC2CORE 71 -#define SRST_A_SPINLOCK 72 -#define SRST_H_SDMMC_BUFFER 73 -#define SRST_D_SDMMC_BUFFER 74 -#define SRST_H_I2S0_8CH 75 -#define SRST_H_I2S1_8CH 76 -#define SRST_H_I2S2_2CH 77 -#define SRST_H_I2S3_2CH 78 - -/* cru_softrst_con5 */ -#define SRST_M_I2S0_8CH_TX 80 -#define SRST_M_I2S0_8CH_RX 81 -#define SRST_M_I2S1_8CH_TX 82 -#define SRST_M_I2S1_8CH_RX 83 -#define SRST_M_I2S2_2CH 84 -#define SRST_M_I2S3_2CH_TX 85 -#define SRST_M_I2S3_2CH_RX 86 -#define SRST_H_PDM 87 -#define SRST_M_PDM 88 -#define SRST_H_VAD 89 -#define SRST_H_SPDIF_8CH 90 -#define SRST_M_SPDIF_8CH 91 -#define SRST_H_AUDPWM 92 -#define SRST_S_AUDPWM 93 -#define SRST_H_ACDCDIG 94 -#define SRST_ACDCDIG 95 - -/* cru_softrst_con6 */ -#define SRST_A_SECURE_FLASH_NIU 96 -#define SRST_H_SECURE_FLASH_NIU 97 -#define SRST_A_CRYPTO_NS 103 -#define SRST_H_CRYPTO_NS 104 -#define SRST_CRYPTO_NS_CORE 105 -#define SRST_CRYPTO_NS_PKA 106 -#define SRST_CRYPTO_NS_RNG 107 -#define SRST_H_TRNG_NS 108 -#define SRST_TRNG_NS 109 - -/* cru_softrst_con7 */ -#define SRST_H_NANDC 112 -#define SRST_N_NANDC 113 -#define SRST_H_SFC 114 -#define SRST_H_SFC_XIP 115 -#define SRST_S_SFC 116 -#define SRST_A_EMMC 117 -#define SRST_H_EMMC 118 -#define SRST_B_EMMC 119 -#define SRST_C_EMMC 120 -#define SRST_T_EMMC 121 - -/* cru_softrst_con8 */ -#define SRST_A_PIPE_NIU 128 -#define SRST_P_PIPE_NIU 130 -#define SRST_P_PIPE_GRF 133 -#define SRST_A_SATA0 134 -#define SRST_SATA0_PIPE 135 -#define SRST_SATA0_PMALIVE 136 -#define SRST_SATA0_RXOOB 137 -#define SRST_A_SATA1 138 -#define SRST_SATA1_PIPE 139 -#define SRST_SATA1_PMALIVE 140 -#define SRST_SATA1_RXOOB 141 - -/* cru_softrst_con9 */ -#define SRST_A_SATA2 144 -#define SRST_SATA2_PIPE 145 -#define SRST_SATA2_PMALIVE 146 -#define SRST_SATA2_RXOOB 147 -#define SRST_USB3OTG0 148 -#define SRST_USB3OTG1 149 -#define SRST_XPCS 150 -#define SRST_XPCS_TX_DIV10 151 -#define SRST_XPCS_RX_DIV10 152 -#define SRST_XPCS_XGXS_RX 153 - -/* cru_softrst_con10 */ -#define SRST_P_PCIE20 160 -#define SRST_PCIE20_POWERUP 161 -#define SRST_MSTR_ARESET_PCIE20 162 -#define SRST_SLV_ARESET_PCIE20 163 -#define SRST_DBI_ARESET_PCIE20 164 -#define SRST_BRESET_PCIE20 165 -#define SRST_PERST_PCIE20 166 -#define SRST_CORE_RST_PCIE20 167 -#define SRST_NSTICKY_RST_PCIE20 168 -#define SRST_STICKY_RST_PCIE20 169 -#define SRST_PWR_RST_PCIE20 170 - -/* cru_softrst_con11 */ -#define SRST_P_PCIE30X1 176 -#define SRST_PCIE30X1_POWERUP 177 -#define SRST_M_ARESET_PCIE30X1 178 -#define SRST_S_ARESET_PCIE30X1 179 -#define SRST_D_ARESET_PCIE30X1 180 -#define SRST_BRESET_PCIE30X1 181 -#define SRST_PERST_PCIE30X1 182 -#define SRST_CORE_RST_PCIE30X1 183 -#define SRST_NSTC_RST_PCIE30X1 184 -#define SRST_STC_RST_PCIE30X1 185 -#define SRST_PWR_RST_PCIE30X1 186 - -/* cru_softrst_con12 */ -#define SRST_P_PCIE30X2 192 -#define SRST_PCIE30X2_POWERUP 193 -#define SRST_M_ARESET_PCIE30X2 194 -#define SRST_S_ARESET_PCIE30X2 195 -#define SRST_D_ARESET_PCIE30X2 196 -#define SRST_BRESET_PCIE30X2 197 -#define SRST_PERST_PCIE30X2 198 -#define SRST_CORE_RST_PCIE30X2 199 -#define SRST_NSTC_RST_PCIE30X2 200 -#define SRST_STC_RST_PCIE30X2 201 -#define SRST_PWR_RST_PCIE30X2 202 - -/* cru_softrst_con13 */ -#define SRST_A_PHP_NIU 208 -#define SRST_H_PHP_NIU 209 -#define SRST_P_PHP_NIU 210 -#define SRST_H_SDMMC0 211 -#define SRST_SDMMC0 212 -#define SRST_H_SDMMC1 213 -#define SRST_SDMMC1 214 -#define SRST_A_GMAC0 215 -#define SRST_GMAC0_TIMESTAMP 216 - -/* cru_softrst_con14 */ -#define SRST_A_USB_NIU 224 -#define SRST_H_USB_NIU 225 -#define SRST_P_USB_NIU 226 -#define SRST_P_USB_GRF 227 -#define SRST_H_USB2HOST0 228 -#define SRST_H_USB2HOST0_ARB 229 -#define SRST_USB2HOST0_UTMI 230 -#define SRST_H_USB2HOST1 231 -#define SRST_H_USB2HOST1_ARB 232 -#define SRST_USB2HOST1_UTMI 233 -#define SRST_H_SDMMC2 234 -#define SRST_SDMMC2 235 -#define SRST_A_GMAC1 236 -#define SRST_GMAC1_TIMESTAMP 237 - -/* cru_softrst_con15 */ -#define SRST_A_VI_NIU 240 -#define SRST_H_VI_NIU 241 -#define SRST_P_VI_NIU 242 -#define SRST_A_VICAP 247 -#define SRST_H_VICAP 248 -#define SRST_D_VICAP 249 -#define SRST_I_VICAP 250 -#define SRST_P_VICAP 251 -#define SRST_H_ISP 252 -#define SRST_ISP 253 -#define SRST_P_CSI2HOST1 255 - -/* cru_softrst_con16 */ -#define SRST_A_VO_NIU 256 -#define SRST_H_VO_NIU 257 -#define SRST_P_VO_NIU 258 -#define SRST_A_VOP_NIU 259 -#define SRST_A_VOP 260 -#define SRST_H_VOP 261 -#define SRST_VOP0 262 -#define SRST_VOP1 263 -#define SRST_VOP2 264 -#define SRST_VOP_PWM 265 -#define SRST_A_HDCP 266 -#define SRST_H_HDCP 267 -#define SRST_P_HDCP 268 -#define SRST_P_HDMI_HOST 270 -#define SRST_HDMI_HOST 271 - -/* cru_softrst_con17 */ -#define SRST_P_DSITX_0 272 -#define SRST_P_DSITX_1 273 -#define SRST_P_EDP_CTRL 274 -#define SRST_EDP_24M 275 -#define SRST_A_VPU_NIU 280 -#define SRST_H_VPU_NIU 281 -#define SRST_A_VPU 282 -#define SRST_H_VPU 283 -#define SRST_H_EINK 286 -#define SRST_P_EINK 287 - -/* cru_softrst_con18 */ -#define SRST_A_RGA_NIU 288 -#define SRST_H_RGA_NIU 289 -#define SRST_P_RGA_NIU 290 -#define SRST_A_RGA 292 -#define SRST_H_RGA 293 -#define SRST_RGA_CORE 294 -#define SRST_A_IEP 295 -#define SRST_H_IEP 296 -#define SRST_IEP_CORE 297 -#define SRST_H_EBC 298 -#define SRST_D_EBC 299 -#define SRST_A_JDEC 300 -#define SRST_H_JDEC 301 -#define SRST_A_JENC 302 -#define SRST_H_JENC 303 - -/* cru_softrst_con19 */ -#define SRST_A_VENC_NIU 304 -#define SRST_H_VENC_NIU 305 -#define SRST_A_RKVENC 307 -#define SRST_H_RKVENC 308 -#define SRST_RKVENC_CORE 309 - -/* cru_softrst_con20 */ -#define SRST_A_RKVDEC_NIU 320 -#define SRST_H_RKVDEC_NIU 321 -#define SRST_A_RKVDEC 322 -#define SRST_H_RKVDEC 323 -#define SRST_RKVDEC_CA 324 -#define SRST_RKVDEC_CORE 325 -#define SRST_RKVDEC_HEVC_CA 326 - -/* cru_softrst_con21 */ -#define SRST_A_BUS_NIU 336 -#define SRST_P_BUS_NIU 338 -#define SRST_P_CAN0 340 -#define SRST_CAN0 341 -#define SRST_P_CAN1 342 -#define SRST_CAN1 343 -#define SRST_P_CAN2 344 -#define SRST_CAN2 345 -#define SRST_P_GPIO1 346 -#define SRST_GPIO1 347 -#define SRST_P_GPIO2 348 -#define SRST_GPIO2 349 -#define SRST_P_GPIO3 350 -#define SRST_GPIO3 351 - -/* cru_softrst_con22 */ -#define SRST_P_GPIO4 352 -#define SRST_GPIO4 353 -#define SRST_P_I2C1 354 -#define SRST_I2C1 355 -#define SRST_P_I2C2 356 -#define SRST_I2C2 357 -#define SRST_P_I2C3 358 -#define SRST_I2C3 359 -#define SRST_P_I2C4 360 -#define SRST_I2C4 361 -#define SRST_P_I2C5 362 -#define SRST_I2C5 363 -#define SRST_P_OTPC_NS 364 -#define SRST_OTPC_NS_SBPI 365 -#define SRST_OTPC_NS_USR 366 - -/* cru_softrst_con23 */ -#define SRST_P_PWM1 368 -#define SRST_PWM1 369 -#define SRST_P_PWM2 370 -#define SRST_PWM2 371 -#define SRST_P_PWM3 372 -#define SRST_PWM3 373 -#define SRST_P_SPI0 374 -#define SRST_SPI0 375 -#define SRST_P_SPI1 376 -#define SRST_SPI1 377 -#define SRST_P_SPI2 378 -#define SRST_SPI2 379 -#define SRST_P_SPI3 380 -#define SRST_SPI3 381 - -/* cru_softrst_con24 */ -#define SRST_P_SARADC 384 -#define SRST_P_TSADC 385 -#define SRST_TSADC 386 -#define SRST_P_TIMER 387 -#define SRST_TIMER0 388 -#define SRST_TIMER1 389 -#define SRST_TIMER2 390 -#define SRST_TIMER3 391 -#define SRST_TIMER4 392 -#define SRST_TIMER5 393 -#define SRST_P_UART1 394 -#define SRST_S_UART1 395 - -/* cru_softrst_con25 */ -#define SRST_P_UART2 400 -#define SRST_S_UART2 401 -#define SRST_P_UART3 402 -#define SRST_S_UART3 403 -#define SRST_P_UART4 404 -#define SRST_S_UART4 405 -#define SRST_P_UART5 406 -#define SRST_S_UART5 407 -#define SRST_P_UART6 408 -#define SRST_S_UART6 409 -#define SRST_P_UART7 410 -#define SRST_S_UART7 411 -#define SRST_P_UART8 412 -#define SRST_S_UART8 413 -#define SRST_P_UART9 414 -#define SRST_S_UART9 415 - -/* cru_softrst_con26 */ -#define SRST_P_GRF 416 -#define SRST_P_GRF_VCCIO12 417 -#define SRST_P_GRF_VCCIO34 418 -#define SRST_P_GRF_VCCIO567 419 -#define SRST_P_SCR 420 -#define SRST_P_WDT_NS 421 -#define SRST_T_WDT_NS 422 -#define SRST_P_DFT2APB 423 -#define SRST_A_MCU 426 -#define SRST_P_INTMUX 427 -#define SRST_P_MAILBOX 428 - -/* cru_softrst_con27 */ -#define SRST_A_TOP_HIGH_NIU 432 -#define SRST_A_TOP_LOW_NIU 433 -#define SRST_H_TOP_NIU 434 -#define SRST_P_TOP_NIU 435 -#define SRST_P_TOP_CRU 438 -#define SRST_P_DDRPHY 439 -#define SRST_DDRPHY 440 -#define SRST_P_MIPICSIPHY 442 -#define SRST_P_MIPIDSIPHY0 443 -#define SRST_P_MIPIDSIPHY1 444 -#define SRST_P_PCIE30PHY 445 -#define SRST_PCIE30PHY 446 -#define SRST_P_PCIE30PHY_GRF 447 - -/* cru_softrst_con28 */ -#define SRST_P_APB2ASB_LEFT 448 -#define SRST_P_APB2ASB_BOTTOM 449 -#define SRST_P_ASB2APB_LEFT 450 -#define SRST_P_ASB2APB_BOTTOM 451 -#define SRST_P_PIPEPHY0 452 -#define SRST_PIPEPHY0 453 -#define SRST_P_PIPEPHY1 454 -#define SRST_PIPEPHY1 455 -#define SRST_P_PIPEPHY2 456 -#define SRST_PIPEPHY2 457 -#define SRST_P_USB2PHY0_GRF 458 -#define SRST_P_USB2PHY1_GRF 459 -#define SRST_P_CPU_BOOST 460 -#define SRST_CPU_BOOST 461 -#define SRST_P_OTPPHY 462 -#define SRST_OTPPHY 463 - -/* cru_softrst_con29 */ -#define SRST_USB2PHY0_POR 464 -#define SRST_USB2PHY0_USB3OTG0 465 -#define SRST_USB2PHY0_USB3OTG1 466 -#define SRST_USB2PHY1_POR 467 -#define SRST_USB2PHY1_USB2HOST0 468 -#define SRST_USB2PHY1_USB2HOST1 469 -#define SRST_P_EDPPHY_GRF 470 -#define SRST_TSADCPHY 471 -#define SRST_GMAC0_DELAYLINE 472 -#define SRST_GMAC1_DELAYLINE 473 -#define SRST_OTPC_ARB 474 -#define SRST_P_PIPEPHY0_GRF 475 -#define SRST_P_PIPEPHY1_GRF 476 -#define SRST_P_PIPEPHY2_GRF 477 - -#endif diff --git a/include/dt-bindings/power/rk3568-power.h b/include/dt-bindings/power/rk3568-power.h deleted file mode 100644 index 6cc1af1a9d26..000000000000 --- a/include/dt-bindings/power/rk3568-power.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3568_POWER_H__ -#define __DT_BINDINGS_POWER_RK3568_POWER_H__ - -/* VD_CORE */ -#define RK3568_PD_CPU_0 0 -#define RK3568_PD_CPU_1 1 -#define RK3568_PD_CPU_2 2 -#define RK3568_PD_CPU_3 3 -#define RK3568_PD_CORE_ALIVE 4 - -/* VD_PMU */ -#define RK3568_PD_PMU 5 - -/* VD_NPU */ -#define RK3568_PD_NPU 6 - -/* VD_GPU */ -#define RK3568_PD_GPU 7 - -/* VD_LOGIC */ -#define RK3568_PD_VI 8 -#define RK3568_PD_VO 9 -#define RK3568_PD_RGA 10 -#define RK3568_PD_VPU 11 -#define RK3568_PD_CENTER 12 -#define RK3568_PD_RKVDEC 13 -#define RK3568_PD_RKVENC 14 -#define RK3568_PD_PIPE 15 -#define RK3568_PD_LOGIC_ALIVE 16 - -#endif
On Sat, May 04, 2024 at 07:43:01PM +0000, Jonas Karlman wrote:
Remove redundant device tree files now that RK356x boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se
arch/arm/dts/rk3566-anbernic-rgxx3.dtsi | 788 ------ arch/arm/dts/rk3566-quartz64-a.dts | 838 ------ arch/arm/dts/rk3566-quartz64-b.dts | 737 ----- arch/arm/dts/rk3566-radxa-cm3-io.dts | 281 -- arch/arm/dts/rk3566-radxa-cm3.dtsi | 425 --- arch/arm/dts/rk3566-soquartz-blade.dts | 198 -- arch/arm/dts/rk3566-soquartz-cm4.dts | 196 -- arch/arm/dts/rk3566-soquartz-model-a.dts | 236 -- arch/arm/dts/rk3566-soquartz.dtsi | 684 ----- arch/arm/dts/rk3566.dtsi | 35 - arch/arm/dts/rk3568-bpi-r2-pro.dts | 852 ------ arch/arm/dts/rk3568-evb.dts | 689 ----- arch/arm/dts/rk3568-lubancat-2.dts | 730 ----- arch/arm/dts/rk3568-nanopi-r5c.dts | 112 - arch/arm/dts/rk3568-nanopi-r5s.dts | 136 - arch/arm/dts/rk3568-nanopi-r5s.dtsi | 587 ---- arch/arm/dts/rk3568-odroid-m1.dts | 741 ----- arch/arm/dts/rk3568-pinctrl.dtsi | 3214 ---------------------- arch/arm/dts/rk3568-radxa-cm3i.dtsi | 412 --- arch/arm/dts/rk3568-radxa-e25.dts | 236 -- arch/arm/dts/rk3568-rock-3a.dts | 859 ------ arch/arm/dts/rk3568.dtsi | 267 -- arch/arm/dts/rk356x.dtsi | 1886 ------------- include/dt-bindings/clock/rk3568-cru.h | 926 ------- include/dt-bindings/power/rk3568-power.h | 32 - 25 files changed, 16097 deletions(-) delete mode 100644 arch/arm/dts/rk3566-anbernic-rgxx3.dtsi delete mode 100644 arch/arm/dts/rk3566-quartz64-a.dts delete mode 100644 arch/arm/dts/rk3566-quartz64-b.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3-io.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3.dtsi delete mode 100644 arch/arm/dts/rk3566-soquartz-blade.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-cm4.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-model-a.dts delete mode 100644 arch/arm/dts/rk3566-soquartz.dtsi delete mode 100644 arch/arm/dts/rk3566.dtsi delete mode 100644 arch/arm/dts/rk3568-bpi-r2-pro.dts delete mode 100644 arch/arm/dts/rk3568-evb.dts delete mode 100644 arch/arm/dts/rk3568-lubancat-2.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5c.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dtsi delete mode 100644 arch/arm/dts/rk3568-odroid-m1.dts delete mode 100644 arch/arm/dts/rk3568-pinctrl.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-cm3i.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-e25.dts delete mode 100644 arch/arm/dts/rk3568-rock-3a.dts delete mode 100644 arch/arm/dts/rk3568.dtsi delete mode 100644 arch/arm/dts/rk356x.dtsi delete mode 100644 include/dt-bindings/clock/rk3568-cru.h delete mode 100644 include/dt-bindings/power/rk3568-power.h
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi deleted file mode 100644
Can we remove this since a non-upstream device tree depends on it?
Thank you, Chris
index 8cbf3d9a4f22..000000000000 --- a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi +++ /dev/null @@ -1,788 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi"
- chosen: chosen {
stdout-path = "serial2:1500000n8";
- adc-joystick {
compatible = "adc-joystick";
io-channels = <&adc_mux 0>,
<&adc_mux 1>,
<&adc_mux 2>,
<&adc_mux 3>;
pinctrl-0 = <&joy_mux_en>;
poll-interval = <60>;
#size-cells = <0>;
axis@0 {
reg = <0>;
abs-flat = <32>;
abs-fuzz = <32>;
abs-range = <1023 15>;
linux,code = <ABS_X>;
axis@1 {
reg = <1>;
abs-flat = <32>;
abs-fuzz = <32>;
abs-range = <15 1023>;
linux,code = <ABS_RX>;
axis@2 {
reg = <2>;
abs-flat = <32>;
abs-fuzz = <32>;
linux,code = <ABS_Y>;
axis@3 {
reg = <3>;
abs-flat = <32>;
abs-fuzz = <32>;
linux,code = <ABS_RY>;
- adc_keys: adc-keys {
compatible = "adc-keys";
io-channels = <&saradc 0>;
io-channel-names = "buttons";
keyup-threshold-microvolt = <1800000>;
* Button is mapped to F key in BSP kernel, but
* according to input guidelines it should be mode.
button-mode {
label = "MODE";
linux,code = <BTN_MODE>;
press-threshold-microvolt = <1750>;
- adc_mux: adc-mux {
compatible = "io-channel-mux";
channels = "left_x", "right_x", "left_y", "right_y";
io-channels = <&saradc 3>;
io-channel-names = "parent";
mux-controls = <&gpio_mux>;
settle-time-us = <100>;
- gpio_keys_control: gpio-keys-control {
compatible = "gpio-keys";
pinctrl-0 = <&btn_pins_ctrl>;
button-b {
gpios = <&gpio3 RK_PC3 GPIO_ACTIVE_LOW>;
label = "SOUTH";
linux,code = <BTN_SOUTH>;
button-down {
gpios = <&gpio3 RK_PA4 GPIO_ACTIVE_LOW>;
label = "DPAD-DOWN";
linux,code = <BTN_DPAD_DOWN>;
button-l1 {
gpios = <&gpio3 RK_PB1 GPIO_ACTIVE_LOW>;
label = "TL";
linux,code = <BTN_TL>;
button-l2 {
gpios = <&gpio3 RK_PB2 GPIO_ACTIVE_LOW>;
label = "TL2";
linux,code = <BTN_TL2>;
button-select {
gpios = <&gpio3 RK_PB6 GPIO_ACTIVE_LOW>;
label = "SELECT";
linux,code = <BTN_SELECT>;
button-start {
gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_LOW>;
label = "START";
linux,code = <BTN_START>;
button-thumbl {
gpios = <&gpio3 RK_PA1 GPIO_ACTIVE_LOW>;
label = "THUMBL";
linux,code = <BTN_THUMBL>;
button-thumbr {
gpios = <&gpio3 RK_PA2 GPIO_ACTIVE_LOW>;
label = "THUMBR";
linux,code = <BTN_THUMBR>;
button-up {
gpios = <&gpio3 RK_PA3 GPIO_ACTIVE_LOW>;
label = "DPAD-UP";
linux,code = <BTN_DPAD_UP>;
button-x {
gpios = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>;
label = "NORTH";
linux,code = <BTN_NORTH>;
- gpio_keys_vol: gpio-keys-vol {
autorepeat;
pinctrl-0 = <&btn_pins_vol>;
button-vol-down {
gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>;
label = "VOLUMEDOWN";
linux,code = <KEY_VOLUMEDOWN>;
button-vol-up {
gpios = <&gpio3 RK_PA7 GPIO_ACTIVE_LOW>;
label = "VOLUMEUP";
linux,code = <KEY_VOLUMEUP>;
- gpio_mux: mux-controller {
compatible = "gpio-mux";
mux-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_LOW>,
<&gpio0 RK_PB7 GPIO_ACTIVE_LOW>;
#mux-control-cells = <0>;
- hdmi-con {
compatible = "hdmi-connector";
ddc-i2c-bus = <&i2c5>;
type = "c";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&hdmi_out_con>;
- leds: pwm-leds {
compatible = "pwm-leds";
green_led: led-0 {
color = <LED_COLOR_ID_GREEN>;
default-state = "on";
function = LED_FUNCTION_POWER;
max-brightness = <255>;
pwms = <&pwm6 0 25000 0>;
amber_led: led-1 {
color = <LED_COLOR_ID_AMBER>;
function = LED_FUNCTION_CHARGING;
pwms = <&pwm7 0 25000 0>;
red_led: led-2 {
color = <LED_COLOR_ID_RED>;
default-state = "off";
function = LED_FUNCTION_STATUS;
pwms = <&pwm0 0 25000 0>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk817 1>;
clock-names = "ext_clock";
pinctrl-0 = <&wifi_enable_h>;
post-power-on-delay-ms = <200>;
reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_LOW>;
- vcc3v3_lcd0_n: regulator-vcc3v3-lcd0 {
compatible = "regulator-fixed";
gpio = <&gpio0 RK_PC2 GPIO_ACTIVE_HIGH>;
enable-active-high;
pinctrl-0 = <&vcc_lcd_h>;
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-name = "vcc3v3_lcd0_n";
vin-supply = <&vcc_3v3>;
regulator-state-mem {
regulator-off-in-suspend;
- vcc_sys: regulator-vcc-sys {
regulator-always-on;
regulator-boot-on;
regulator-min-microvolt = <3800000>;
regulator-max-microvolt = <3800000>;
regulator-name = "vcc_sys";
- vcc_wifi: regulator-vcc-wifi {
enable-active-high;
gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc_wifi_h>;
regulator-boot-on;
regulator-name = "vcc_wifi";
- vibrator: pwm-vibrator {
compatible = "pwm-vibrator";
pwm-names = "enable";
pwms = <&pwm5 0 1000000000 0>;
-&combphy1 {
- status = "okay";
-&cpu0 {
- cpu-supply = <&vdd_cpu>;
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
-&hdmi {
- ddc-i2c-bus = <&i2c5>;
- pinctrl-0 = <&hdmitxm0_cec>;
- status = "okay";
-&hdmi_in {
- hdmi_in_vp0: endpoint {
remote-endpoint = <&vp0_out_hdmi>;
-&hdmi_out {
- hdmi_out_con: endpoint {
remote-endpoint = <&hdmi_con_in>;
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk817: pmic@20 {
compatible = "rockchip,rk817";
reg = <0x20>;
interrupt-parent = <&gpio0>;
interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>;
clock-output-names = "rk808-clkout1", "rk808-clkout2";
clock-names = "mclk";
clocks = <&cru I2S1_MCLKOUT_TX>;
assigned-clocks = <&cru I2S1_MCLKOUT_TX>;
assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>;
#clock-cells = <1>;
pinctrl-0 = <&i2s1m0_mclk>, <&pmic_int_l>;
wakeup-source;
vcc1-supply = <&vcc_sys>;
vcc2-supply = <&vcc_sys>;
vcc3-supply = <&vcc_sys>;
vcc4-supply = <&vcc_sys>;
vcc5-supply = <&vcc_sys>;
vcc6-supply = <&vcc_sys>;
vcc7-supply = <&vcc_sys>;
vcc8-supply = <&vcc_sys>;
vcc9-supply = <&dcdc_boost>;
regulators {
vdd_logic: DCDC_REG1 {
regulator-boot-on;
regulator-min-microvolt = <500000>;
regulator-max-microvolt = <1350000>;
regulator-ramp-delay = <6001>;
regulator-initial-mode = <0x2>;
regulator-name = "vdd_logic";
regulator-suspend-microvolt = <900000>;
vdd_gpu: DCDC_REG2 {
regulator-boot-on;
regulator-name = "vdd_gpu";
vcc_ddr: DCDC_REG3 {
regulator-boot-on;
regulator-name = "vcc_ddr";
regulator-on-in-suspend;
vcc_3v3: DCDC_REG4 {
regulator-boot-on;
regulator-name = "vcc_3v3";
regulator-suspend-microvolt = <3300000>;
vcca1v8_pmu: LDO_REG1 {
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-name = "vcca1v8_pmu";
regulator-suspend-microvolt = <1800000>;
vdda_0v9: LDO_REG2 {
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
regulator-name = "vdda_0v9";
vdda0v9_pmu: LDO_REG3 {
regulator-boot-on;
regulator-name = "vdda0v9_pmu";
vccio_acodec: LDO_REG4 {
regulator-boot-on;
regulator-name = "vccio_acodec";
vccio_sd: LDO_REG5 {
regulator-boot-on;
regulator-name = "vccio_sd";
vcc3v3_pmu: LDO_REG6 {
regulator-boot-on;
regulator-name = "vcc3v3_pmu";
vcc_1v8: LDO_REG7 {
regulator-boot-on;
regulator-name = "vcc_1v8";
vcc1v8_dvp: LDO_REG8 {
regulator-boot-on;
regulator-name = "vcc1v8_dvp";
vcc2v8_dvp: LDO_REG9 {
regulator-boot-on;
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
regulator-name = "vcc2v8_dvp";
dcdc_boost: BOOST {
regulator-boot-on;
regulator-min-microvolt = <4700000>;
regulator-max-microvolt = <5400000>;
regulator-name = "boost";
otg_switch: OTG_SWITCH {
regulator-name = "otg_switch";
- vdd_cpu: regulator@40 {
compatible = "fcs,fan53555";
reg = <0x40>;
fcs,suspend-voltage-selector = <1>;
regulator-boot-on;
regulator-min-microvolt = <712500>;
regulator-max-microvolt = <1390000>;
regulator-name = "vdd_cpu";
regulator-ramp-delay = <2300>;
vin-supply = <&vcc_sys>;
-&i2c1 {
- /* Unknown/unused device at 0x3c */
-&i2c5 {
- pinctrl-0 = <&i2c5m1_xfer>;
- status = "okay";
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
- rockchip,trcm-sync-tx-only;
- status = "okay";
-&pinctrl {
- gpio-btns {
btn_pins_ctrl: btn-pins-ctrl {
rockchip,pins =
<3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB4 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC1 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC3 RK_FUNC_GPIO &pcfg_pull_up>;
btn_pins_vol: btn-pins-vol {
rockchip,pins =
<3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
- joy-mux {
joy_mux_en: joy-mux-en {
rockchip,pins =
<0 RK_PB5 RK_FUNC_GPIO &pcfg_output_low>;
- pmic {
pmic_int_l: pmic-int-l {
rockchip,pins =
<0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
rockchip,pins =
<4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- vcc3v3-lcd {
vcc_lcd_h: vcc-lcd-h {
rockchip,pins =
<0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
- vcc-wifi {
vcc_wifi_h: vcc-wifi-h {
rockchip,pins =
<0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
-&pmu_io_domains {
- status = "okay";
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_1v8>;
- vccio5-supply = <&vcc_3v3>;
- vccio6-supply = <&vcc1v8_dvp>;
- vccio7-supply = <&vcc_3v3>;
-&pwm0 {
- pinctrl-0 = <&pwm0m1_pins>;
- status = "okay";
-&pwm5 {
- status = "okay";
-&pwm6 {
- status = "okay";
-&pwm7 {
- status = "okay";
-&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
- disable-wp;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_3v3>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
-&sdmmc1 {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio2 RK_PB2 GPIO_ACTIVE_LOW>;
- disable-wp;
- pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk &sdmmc1_det>;
- sd-uhs-sdr104;
- vqmmc-supply = <&vcc1v8_dvp>;
- status = "okay";
-&sdmmc2 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdmmc2m0_bus4 &sdmmc2m0_cmd &sdmmc2m0_clk>;
- vmmc-supply = <&vcc_wifi>;
- vqmmc-supply = <&vcca1v8_pmu>;
- status = "okay";
-&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
-&uart1 {
- pinctrl-0 = <&uart1m1_xfer &uart1m1_ctsn &uart1m1_rtsn>;
- uart-has-rtscts;
- status = "okay";
- bluetooth {
compatible = "realtek,rtl8821cs-bt", "realtek,rtl8723bs-bt";
device-wake-gpios = <&gpio4 4 GPIO_ACTIVE_HIGH>;
enable-gpios = <&gpio4 3 GPIO_ACTIVE_HIGH>;
host-wake-gpios = <&gpio4 5 GPIO_ACTIVE_HIGH>;
-&uart2 {
- status = "okay";
- Lack the schematics to verify, but port works as a peripheral
- (and not a host or OTG port).
-&usb_host0_xhci {
- dr_mode = "peripheral";
- phys = <&usb2phy0_otg>;
- phy-names = "usb2-phy";
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host1_xhci {
- phy-names = "usb2-phy", "usb3-phy";
- phys = <&usb2phy1_host>, <&combphy1 PHY_TYPE_USB3>;
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&vop {
- assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
- assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
- vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 {
reg = <ROCKCHIP_VOP2_EP_HDMI0>;
remote-endpoint = <&hdmi_in_vp0>;
-}; diff --git a/arch/arm/dts/rk3566-quartz64-a.dts b/arch/arm/dts/rk3566-quartz64-a.dts deleted file mode 100644 index 59843a7a199c..000000000000 --- a/arch/arm/dts/rk3566-quartz64-a.dts +++ /dev/null @@ -1,838 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi"
- model = "Pine64 RK3566 Quartz64-A Board";
- compatible = "pine64,quartz64-a", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
- gmac1_clkin: external-gmac1-clock {
compatible = "fixed-clock";
clock-frequency = <125000000>;
clock-output-names = "gmac1_clkin";
#clock-cells = <0>;
- fan: gpio_fan {
compatible = "gpio-fan";
gpios = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>;
gpio-fan,speed-map =
< 0 0>,
<4500 1>;
pinctrl-0 = <&fan_en_h>;
#cooling-cells = <2>;
- hdmi-con {
type = "a";
port {
- leds {
compatible = "gpio-leds";
led-work {
label = "work-led";
gpios = <&gpio0 RK_PD3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&work_led_enable_h>;
retain-state-suspended;
led-diy {
label = "diy-led";
gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
pinctrl-0 = <&diy_led_enable_h>;
- rk817-sound {
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,name = "Analog RK817";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,cpu {
sound-dai = <&i2s1_8ch>;
simple-audio-card,codec {
sound-dai = <&rk817>;
post-power-on-delay-ms = <100>;
power-off-delay-us = <5000000>;
reset-gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_LOW>;
- spdif_dit: spdif-dit {
compatible = "linux,spdif-dit";
#sound-dai-cells = <0>;
- spdif_sound: spdif-sound {
simple-audio-card,name = "SPDIF";
sound-dai = <&spdif>;
sound-dai = <&spdif_dit>;
- vcc12v_dcin: vcc12v_dcin {
regulator-name = "vcc12v_dcin";
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
- /* vbus feeds the rk817 usb input.
* With no battery attached, also feeds vcc_bat+
* via ON/OFF_BAT jumper
- vbus: vbus {
regulator-name = "vbus";
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vin-supply = <&vcc12v_dcin>;
- vcc3v3_pcie_p: vcc3v3-pcie-p-regulator {
enable-active-high;
gpio = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie_enable_h>;
regulator-name = "vcc3v3_pcie_p";
- vcc5v0_usb: vcc5v0_usb {
regulator-name = "vcc5v0_usb";
regulator-boot-on;
- /* all four ports are controlled by one gpio
* the host ports are sourced from vcc5v0_usb
* the otg port is sourced from vcc5v0_midu
- vcc5v0_usb20_host: vcc5v0_usb20_host {
enable-active-high;
gpio = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb20_host_en>;
regulator-name = "vcc5v0_usb20_host";
vin-supply = <&vcc5v0_usb>;
- vcc5v0_usb20_otg: vcc5v0_usb20_otg {
enable-active-high;
regulator-name = "vcc5v0_usb20_otg";
vin-supply = <&dcdc_boost>;
- vcc3v3_sd: vcc3v3_sd {
gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&vcc_sd_h>;
regulator-boot-on;
regulator-name = "vcc3v3_sd";
- /* sourced from vbus and vcc_bat+ via rk817 sw5 */
- vcc_sys: vcc_sys {
regulator-boot-on;
regulator-min-microvolt = <4400000>;
regulator-max-microvolt = <4400000>;
vin-supply = <&vbus>;
- /* sourced from vcc_sys, sdio module operates internally at 3.3v */
- vcc_wl: vcc_wl {
regulator-name = "vcc_wl";
regulator-boot-on;
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&cpu_thermal {
- trips {
cpu_hot: cpu_hot {
temperature = <55000>;
type = "active";
- cooling-maps {
map1 {
trip = <&cpu_hot>;
cooling-device = <&fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
-&gmac1 {
- assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>;
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>, <&gmac1_clkin>;
- clock_in_out = "input";
- phy-supply = <&vcc_3v3>;
- phy-mode = "rgmii";
- pinctrl-0 = <&gmac1m0_miim
&gmac1m0_tx_bus2
&gmac1m0_rx_bus2
&gmac1m0_rgmii_clk
&gmac1m0_clkinout
&gmac1m0_rgmii_bus>;
- snps,reset-gpio = <&gpio0 RK_PC3 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- /* Reset time is 20ms, 100ms for rtl8211f */
- snps,reset-delays-us = <0 20000 100000>;
- tx_delay = <0x30>;
- rx_delay = <0x10>;
- phy-handle = <&rgmii_phy1>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- avdd-0v9-supply = <&vdda_0v9>;
- avdd-1v8-supply = <&vcc_1v8>;
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- vdd_cpu: regulator@1c {
compatible = "tcs,tcs4525";
reg = <0x1c>;
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1150000>;
regulator-boot-on;
- rk817: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
pinctrl-0 = <&pmic_int_l>, <&i2s1m0_mclk>;
rockchip,system-power-controller;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG7 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
dcdc_boost: BOOST {
regulator-boot-on;
-/* i2c3 is exposed on con40
- pin 3 - i2c3_sda_m0, pullup to vcc_3v3
- pin 5 - i2c3_scl_m0, pullup to vcc_3v3
-&i2c3 {
- status = "okay";
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
- pinctrl-0 = <&i2s1m0_sclktx
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
- status = "okay";
-&mdio1 {
- rgmii_phy1: ethernet-phy@0 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0>;
-&pcie2x1 {
- pinctrl-0 = <&pcie_reset_h>;
- reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie_p>;
- status = "okay";
-&pinctrl {
- bt {
bt_enable_h: bt-enable-h {
rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake_l: bt-host-wake-l {
rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_down>;
bt_wake_l: bt-wake-l {
rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
- fan {
fan_en_h: fan-en-h {
rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
- leds {
work_led_enable_h: work-led-enable-h {
rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
diy_led_enable_h: diy-led-enable-h {
rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
pcie_enable_h: pcie-enable-h {
rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_reset_h: pcie-reset-h {
rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- usb2 {
vcc5v0_usb20_host_en: vcc5v0-usb20-host-en {
rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
- vcc_sd {
vcc_sd_h: vcc-sd-h {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
-&pmu_io_domains {
- vccio2-supply = <&vcc_1v8>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- vqmmc-supply = <&vcc_1v8>;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v3_sd>;
- status = "okay";
-&sdmmc1 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_wl>;
- status = "okay";
-&sfc {
- pinctrl-0 = <&fspi_pins>;
- #address-cells = <1>;
- #size-cells = <0>;
- flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <24000000>;
spi-rx-bus-width = <4>;
spi-tx-bus-width = <1>;
-/* spdif is exposed on con40 pin 18 */ -&spdif {
- status = "okay";
-/* spi1 is exposed on con40
- pin 11 - spi1_mosi_m1
- pin 13 - spi1_miso_m1
- pin 15 - spi1_clk_m1
- pin 17 - spi1_cs0_m1
-&spi1 {
- pinctrl-0 = <&spi1m1_cs0 &spi1m1_pins>;
-&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- /* tshut polarity 0:LOW 1:HIGH */
- status = "okay";
-/* uart0 is exposed on con40
- pin 12 - uart0_tx
- pin 14 - uart0_rx
-&uart0 {
- pinctrl-0 = <&uart0_xfer>;
- status = "okay";
-&uart1 {
- pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>;
- status = "okay";
- uart-has-rtscts;
- bluetooth {
compatible = "brcm,bcm43438-bt";
clock-names = "lpo";
host-wakeup-gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>;
device-wakeup-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>;
shutdown-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&bt_host_wake_l &bt_wake_l &bt_enable_h>;
vbat-supply = <&vcc_sys>;
vddio-supply = <&vcca1v8_pmu>;
max-speed = <3000000>;
-/* uart2 is exposed on con40
- pin 8 - uart2_tx_m0_debug
- pin 10 - uart2_rx_m0_debug
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host0_xhci {
- dr_mode = "host";
- status = "okay";
-/* usb3 controller is muxed with sata1 */ -&usb_host1_xhci {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- phy-supply = <&vcc5v0_usb20_host>;
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vcc5v0_usb20_otg>;
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-}; diff --git a/arch/arm/dts/rk3566-quartz64-b.dts b/arch/arm/dts/rk3566-quartz64-b.dts deleted file mode 100644 index 2d92713be2a0..000000000000 --- a/arch/arm/dts/rk3566-quartz64-b.dts +++ /dev/null @@ -1,737 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
- model = "Pine64 RK3566 Quartz64-B Board";
- compatible = "pine64,quartz64-b", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
mmc0 = &sdmmc0;
mmc1 = &sdhci;
mmc2 = &sdmmc1;
- chosen: chosen {
#clock-cells = <0>;
- hdmi-con {
type = "a";
port {
- leds {
led-user {
label = "user-led";
gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&user_led_enable_h>;
- sound {
simple-audio-card,name = "Analog RK809";
sound-dai = <&rk809>;
status = "okay";
clocks = <&rk809 1>;
reset-gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_LOW>;
enable-active-high;
gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
- vcc5v0_in: vcc5v0-in-regulator {
regulator-name = "vcc5v0_in";
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-name = "vcc5v0_sys";
regulator-boot-on;
vin-supply = <&vcc5v0_in>;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-name = "vcc3v3_sys";
vin-supply = <&vcc5v0_sys>;
- vcc5v0_usb30_host: vcc5v0-usb30-host-regulator {
regulator-name = "vcc5v0_usb30_host";
enable-active-high;
gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb30_host_en_h>;
- vcc5v0_usb_otg: vcc5v0-usb-otg-regulator {
regulator-name = "vcc5v0_usb_otg";
enable-active-high;
pinctrl-0 = <&vcc5v0_usb_otg_en_h>;
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gmac1 {
- pinctrl-0 = <&gmac1m1_miim
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
&gmac1m1_clkinout
&gmac1m1_rgmii_bus>;
- snps,reset-gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>;
- /* Reset time is 20ms, 100ms for rtl8211f, also works well here */
- tx_delay = <0x4f>;
- rx_delay = <0x24>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- avdd-0v9-supply = <&vdda0v9_image>;
- avdd-1v8-supply = <&vcca1v8_image>;
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
compatible = "rockchip,rk809";
reg = <0x20>;
pinctrl-0 = <&pmic_int>, <&i2s1m0_mclk>;
wakeup-source;
#clock-cells = <1>;
vcc1-supply = <&vcc3v3_sys>;
vcc2-supply = <&vcc3v3_sys>;
vcc3-supply = <&vcc3v3_sys>;
vcc4-supply = <&vcc3v3_sys>;
vcc5-supply = <&vcc3v3_sys>;
vcc6-supply = <&vcc3v3_sys>;
vcc7-supply = <&vcc3v3_sys>;
vcc8-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc3v3_sys>;
regulators {
vdd_log: DCDC_REG1 {
regulator-name = "vdd_log";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vdd_npu: DCDC_REG4 {
regulator-name = "vdd_npu";
vcc_1v8: DCDC_REG5 {
regulator-boot-on;
vdda0v9_image: LDO_REG1 {
regulator-name = "vdda0v9_image";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcca_1v8: LDO_REG7 {
regulator-name = "vcca_1v8";
regulator-boot-on;
vcca1v8_pmu: LDO_REG8 {
regulator-boot-on;
vcca1v8_image: LDO_REG9 {
regulator-name = "vcca1v8_image";
regulator-boot-on;
vcc_3v3: SWITCH_REG1 {
regulator-boot-on;
vcc3v3_sd: SWITCH_REG2 {
-/* i2c2_m1 exposed on csi port, pulled up to vcc_3v3 */ -&i2c2 {
- pinctrl-0 = <&i2c2m1_xfer>;
- status = "okay";
-/* i2c3_m1 exposed on dsi port, pulled up to vcc_3v3 */ -&i2c3 {
- pinctrl-0 = <&i2c3m1_xfer>;
- status = "okay";
- i2c4_m0 is exposed on PI40, pulled up to vcc_3v3
- pin 27 - i2c4_sda_m0
- pin 28 - i2c4_scl_m0
-&i2c4 {
- status = "okay";
- i2c5_m0 is exposed on PI40
- pin 29 - i2c5_scl_m0
- pin 31 - i2c5_sda_m0
-&i2c5 {
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
- status = "okay";
-&mdio1 {
- rgmii_phy1: ethernet-phy@1 {
reg = <0x1>;
-&pcie2x1 {
- status = "okay";
-&pinctrl {
- bt {
rockchip,pins = <0 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <0 RK_PB3 RK_FUNC_GPIO &pcfg_pull_down>;
rockchip,pins = <0 RK_PB4 RK_FUNC_GPIO &pcfg_pull_none>;
- leds {
user_led_enable_h: user-led-enable-h {
rockchip,pins = <0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
pmic_int: pmic_int {
rockchip,pins =
- sdio-pwrseq {
rockchip,pins = <0 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>;
- usb {
vcc5v0_usb30_host_en_h: vcc5v0-usb30-host-en_h {
rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
vcc5v0_usb_otg_en_h: vcc5v0-usb-otg-en_h {
-&pmu_io_domains {
- status = "okay";
- pmuio2-supply = <&vcca1v8_pmu>;
- vccio4-supply = <&vcca1v8_pmu>;
- vccio6-supply = <&vcc_3v3>;
-&saradc {
- vref-supply = <&vcca_1v8>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- sd-uhs-sdr50;
- status = "okay";
-&sdmmc1 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- vmmc-supply = <&vcc3v3_sys>;
- status = "okay";
-&sfc {
- status = "okay";
- flash@0 {
reg = <0>;
-&tsadc {
- status = "okay";
-&uart1 {
- status = "okay";
- uart-has-rtscts;
- bluetooth {
compatible = "brcm,bcm4345c5";
device-wakeup-gpios = <&gpio0 RK_PB4 GPIO_ACTIVE_HIGH>;
host-wakeup-gpios = <&gpio0 RK_PB3 GPIO_ACTIVE_HIGH>;
shutdown-gpios = <&gpio0 RK_PC1 GPIO_ACTIVE_HIGH>;
vbat-supply = <&vcc3v3_sys>;
- uart2_m0 is exposed on PI40
-&uart2 {
- status = "okay";
-&usb2phy0_host {
- phy-supply = <&vcc5v0_usb30_host>;
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vcc5v0_usb_otg>;
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-}; diff --git a/arch/arm/dts/rk3566-radxa-cm3-io.dts b/arch/arm/dts/rk3566-radxa-cm3-io.dts deleted file mode 100644 index 3ae24e39450a..000000000000 --- a/arch/arm/dts/rk3566-radxa-cm3-io.dts +++ /dev/null @@ -1,281 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2022 Radxa Limited
- Copyright (c) 2022 Amarula Solutions(India)
-/dts-v1/; -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi" -#include "rk3566-radxa-cm3.dtsi"
- model = "Radxa Compute Module 3(CM3) IO Board";
- compatible = "radxa,cm3-io", "radxa,cm3", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
mmc1 = &sdmmc0;
- chosen: chosen {
#clock-cells = <0>;
- hdmi-con {
type = "a";
port {
- leds {
led-1 {
gpios = <&gpio4 RK_PA4 GPIO_ACTIVE_LOW>;
function = LED_FUNCTION_ACTIVITY;
pinctrl-names = "default";
pinctrl-0 = <&pi_nled_activity>;
- vcc5v0_usb30: vcc5v0-usb30-regulator {
regulator-name = "vcc5v0_usb30";
enable-active-high;
gpio = <&gpio3 RK_PC2 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb30_en_h>;
- vcca1v8_image: vcca1v8-image-regulator {
regulator-boot-on;
vin-supply = <&vcc_1v8_p>;
- vdda0v9_image: vdda0v9-image-regulator {
regulator-name = "vcca0v9_image";
regulator-boot-on;
vin-supply = <&vdda_0v9>;
-&combphy1 {
- status = "okay";
-&gmac1 {
- assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>;
- assigned-clock-rates = <0>, <125000000>;
- pinctrl-names = "default";
&gmac1m0_tx_bus2
&gmac1m0_rx_bus2
&gmac1m0_rgmii_clk
&gmac1m0_rgmii_bus
&gmac1m0_clkinout>;
- snps,reset-gpio = <&gpio4 RK_PC2 GPIO_ACTIVE_LOW>;
- tx_delay = <0x46>;
- rx_delay = <0x2e>;
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&mdio1 {
reg = <0x0>;
-&pinctrl {
- gmac1 {
gmac1m0_miim: gmac1m0-miim {
rockchip,pins =
/* gmac1_mdcm0 */
<3 RK_PC4 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_mdiom0 */
<3 RK_PC5 3 &pcfg_pull_none_drv_level_15>;
gmac1m0_rx_bus2: gmac1m0-rx-bus2 {
rockchip,pins =
/* gmac1_rxd0m0 */
<3 RK_PB1 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_rxd1m0 */
<3 RK_PB2 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_rxdvcrsm0 */
<3 RK_PB3 3 &pcfg_pull_none_drv_level_15>;
gmac1m0_tx_bus2: gmac1m0-tx-bus2 {
rockchip,pins =
/* gmac1_txd0m0 */
<3 RK_PB5 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_txd1m0 */
<3 RK_PB6 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_txenm0 */
<3 RK_PB7 3 &pcfg_pull_none_drv_level_15>;
gmac1m0_rgmii_clk: gmac1m0-rgmii-clk {
rockchip,pins =
/* gmac1_rxclkm0 */
<3 RK_PA7 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_txclkm0 */
<3 RK_PA6 3 &pcfg_pull_none_drv_level_15>;
gmac1m0_rgmii_bus: gmac1m0-rgmii-bus {
rockchip,pins =
/* gmac1_rxd2m0 */
<3 RK_PA4 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_rxd3m0 */
<3 RK_PA5 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_txd2m0 */
<3 RK_PA2 3 &pcfg_pull_none_drv_level_15>,
/* gmac1_txd3m0 */
<3 RK_PA3 3 &pcfg_pull_none_drv_level_15>;
gmac1m0_clkinout: gmac1m0-clkinout {
rockchip,pins =
/* gmac1_mclkinoutm0 */
<3 RK_PC0 3 &pcfg_pull_none_drv_level_15>;
- leds {
pi_nled_activity: pi-nled-activity {
rockchip,pins = <4 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
- sdcard {
sdmmc_pwren: sdmmc-pwren {
- usb {
vcc5v0_usb30_en_h: vcc5v0-host-en-h {
rockchip,pins = <3 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
-&sdmmc0 {
- bus-width = <4>;
- cap-mmc-highspeed;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det &sdmmc0_pwren>;
- status = "okay";
-&uart2 {
- status = "okay";
-&usb2phy0_host {
- phy-supply = <&vcc5v0_usb30>;
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-}; diff --git a/arch/arm/dts/rk3566-radxa-cm3.dtsi b/arch/arm/dts/rk3566-radxa-cm3.dtsi deleted file mode 100644 index 45de2630bb50..000000000000 --- a/arch/arm/dts/rk3566-radxa-cm3.dtsi +++ /dev/null @@ -1,425 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h>
- compatible = "radxa,cm3", "rockchip,rk3566";
- aliases {
mmc0 = &sdhci;
- leds {
led-0 {
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "timer";
pinctrl-0 = <&user_led2>;
- vcc_sys: vcc-sys-regulator {
regulator-boot-on;
- vcc_1v8: vcc-1v8-regulator {
regulator-boot-on;
- vcc_3v3: vcc-3v3-regulator {
regulator-boot-on;
vin-supply = <&vcc3v3_sys>;
- vcca_1v8: vcca-1v8-regulator {
regulator-boot-on;
- sdio_pwrseq: pwrseq-sdio {
pinctrl-0 = <&wifi_reg_on_h>;
reset-gpios = <&gpio2 RK_PB7 GPIO_ACTIVE_LOW>;
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gpu {
- mali-supply = <&vdd_gpu_npu>;
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
regulator-boot-on;
- rk817: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
clock-output-names = "rk817-clkout1", "rk817-clkout2";
pinctrl-0 = <&pmic_int_l>;
wakeup-source;
regulators {
regulator-boot-on;
vdd_gpu_npu: DCDC_REG2 {
regulator-name = "vdd_gpu_npu";
regulator-boot-on;
regulator-boot-on;
vcc3v3_sys: DCDC_REG4 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8_p: LDO_REG7 {
regulator-name = "vcc_1v8_p";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&pinctrl {
- bluetooth {
bt_host_wake_h: bt-host-wake-h {
rockchip,pins = <2 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
bt_reg_on_h: bt-reg-on-h {
rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>;
bt_wake_host_h: bt-wake-host-h {
rockchip,pins = <2 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
- leds {
user_led2: user-led2 {
- wifi {
wifi_reg_on_h: wifi-reg-on-h {
wifi_host_wake_h: wifi-host-wake-h {
-&pmu_io_domains {
- pmuio2-supply = <&vcc_3v3>;
- status = "okay";
-&saradc {
- status = "okay";
-&sdmmc1 {
- bus-width = <4>;
- disable-wp;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_clk &sdmmc1_cmd>;
- sd-uhs-sdr104;
- status = "okay";
- wifi@1 {
compatible = "brcm,bcm43455-fmac";
reg = <1>;
interrupt-parent = <&gpio2>;
interrupts = <RK_PC1 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "host-wake";
pinctrl-0 = <&wifi_host_wake_h>;
-&sdhci {
- bus-width = <8>;
- max-frequency = <200000000>;
- mmc-hs200-1_8v;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>;
- status = "okay";
-&uart1 {
- pinctrl-0 = <&uart1m0_ctsn &uart1m0_rtsn &uart1m0_xfer>;
- status = "okay";
- bluetooth {
device-wakeup-gpios = <&gpio2 RK_PB2 GPIO_ACTIVE_HIGH>;
host-wakeup-gpios = <&gpio2 RK_PB1 GPIO_ACTIVE_HIGH>;
reset-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&bt_host_wake_h &bt_reg_on_h &bt_wake_host_h>;
vbat-supply = <&vcc_3v3>;
vddio-supply = <&vcc_1v8>;
-&usb2phy0 {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&tsadc {
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3566-soquartz-blade.dts b/arch/arm/dts/rk3566-soquartz-blade.dts deleted file mode 100644 index fdbf1c783242..000000000000 --- a/arch/arm/dts/rk3566-soquartz-blade.dts +++ /dev/null @@ -1,198 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h>
-#include "rk3566-soquartz.dtsi"
- model = "PINE64 RK3566 SOQuartz on Blade carrier board";
- compatible = "pine64,soquartz-blade", "pine64,soquartz", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
- /* labeled VCC3V0_SD in schematic to not conflict with PMIC regulator */
- vcc3v0_sd: vcc3v0-sd-regulator {
regulator-name = "vcc3v0_sd";
regulator-boot-on;
- /* labeled VCC_SSD in schematic */
- vcc3v3_pcie_p: vcc3v3-pcie-regulator {
regulator-boot-on;
- vcc5v_dcin: vcc5v-dcin-regulator {
regulator-name = "vcc5v_dcin";
regulator-boot-on;
-&combphy2 {
- phy-supply = <&vcc3v3_sys>;
- status = "okay";
-&gmac1 {
- status = "okay";
- i2c1 is exposed on CM1 / Module1A
- pin 80 - SCL0 - i2c1_scl_m0, pullup to vcc3v3_pmu
- pin 82 - SDA0 - i2c1_sda_m0, pullup to vcc3v3_pmu
-&i2c1 {
- status = "okay";
- i2c2 is exposed on CM1 / Module1A - to PI40
- pin 56 - GPIO3 - i2c2_scl_m1, pullup to vcc_3v3, shared with i2s1_8ch
- pin 58 - GPIO2 - i2c2_sda_m1, pullup to vcc_3v3
-&i2c2 {
- status = "disabled";
- i2c3 is exposed on CM1 / Module1A - to PI40
- pin 35 - ID_SC(GPIO28) - i2c3_scl_m0, pullup to vcc_3v3
- pin 36 - ID_SD(GPIO27) - i2c3_sda_m0, pullup to vcc_3v3
-&i2c3 {
- i2c4 is exposed on CM2 / Module1B - to PI40
- pin 45 - GPIO24 - i2c4_scl_m1
- pin 47 - GPIO23 - i2c4_sda_m1
-&i2c4 {
- i2s1_8ch is exposed on CM1 / Module1A - to PI40
- pin 24 - GPIO26 - i2s1_sdi1_m1
- pin 25 - GPIO21 - i2s1_sdo0_m1
- pin 26 - GPIO19 - i2s1_lrck_tx_m1
- pin 27 - GPIO20 - i2s1_sdi0_m1
- pin 29 - GPIO16 - i2s1_sdi3_m1
- pin 30 - GPIO6 - i2s1_sdi2_m1
- pin 40 - GPIO9 - i2s1_sdo1_m1, shared with spi3
- pin 41 - GPIO25 - i2s1_sdo2_m1
- pin 49 - GPIO18 - i2s1_sclk_tx_m1
- pin 50 - GPIO17 - i2s1_mclk_m1
- pin 56 - GPIO3 - i2s1_sdo3_m1, shared with i2c2
-&i2s1_8ch {
-&led_diy {
- color = <LED_COLOR_ID_RED>;
- function = LED_FUNCTION_DISK_ACTIVITY;
- linux,default-trigger = "disk-activity";
- status = "okay";
-&led_work {
- color = <LED_COLOR_ID_GREEN>;
- function = LED_FUNCTION_STATUS;
- linux,default-trigger = "heartbeat";
- status = "okay";
-&pcie2x1 {
- status = "okay";
-&rgmii_phy1 {
- status = "okay";
- saradc is exposed on CM1 / Module1A - to J2
- pin 94 - AIN1 - saradc_vin3
- pin 96 - AIN0 - saradc_vin2
-&saradc {
-&sdmmc0 {
- vmmc-supply = <&vcc3v0_sd>;
- status = "okay";
- spi3 is exposed on CM1 / Module1A - to PI40
- pin 37 - GPIO7 - spi3_cs1_m0
- pin 38 - GPIO11 - spi3_clk_m0
- pin 39 - GPIO8 - spi3_cs0_m0
- pin 40 - GPIO9 - spi3_miso_m0, shared with i2s1_8ch
- pin 44 - GPIO10 - spi3_mosi_m0
-&spi3 {
- uart2 is exposed on CM1 / Module1A - to PI40
- pin 51 - GPIO15 - uart2_rx_m0
- pin 55 - GPIO14 - uart2_tx_m0
-&uart2 {
- status = "okay";
- uart7 is exposed on CM1 / Module1A - to PI40
- pin 46 - GPIO22 - uart7_tx_m2
- pin 47 - GPIO23 - uart7_rx_m2
-&uart7 {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vbus>;
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&vbus {
- vin-supply = <&vcc5v_dcin>;
-}; diff --git a/arch/arm/dts/rk3566-soquartz-cm4.dts b/arch/arm/dts/rk3566-soquartz-cm4.dts deleted file mode 100644 index 6ed3fa4aee34..000000000000 --- a/arch/arm/dts/rk3566-soquartz-cm4.dts +++ /dev/null @@ -1,196 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
- model = "Pine64 RK3566 SoQuartz with CM4-IO Carrier Board";
- compatible = "pine64,soquartz-cm4io", "pine64,soquartz", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
- /* labeled +12v in schematic */
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-boot-on;
- /* labeled +5v in schematic */
- vcc_5v: vcc-5v-regulator {
regulator-name = "vcc_5v";
regulator-boot-on;
- vcc_sd_pwr: vcc-sd-pwr-regulator {
regulator-name = "vcc_sd_pwr";
regulator-boot-on;
-/* phy for pcie */ -&combphy2 {
- status = "okay";
-&gmac1 {
- status = "okay";
-&i2c1 {
- status = "okay";
* the rtc interrupt is tied to PMIC_PWRON,
* it will force reset the board if triggered.
- pcf85063: rtc@51 {
compatible = "nxp,pcf85063";
reg = <0x51>;
-&i2c2 {
-&i2c3 {
-&i2c4 {
-&i2s1_8ch {
-&led_diy {
- status = "okay";
-&led_work {
- status = "okay";
-&pcie2x1 {
- vpcie3v3-supply = <&vcc_3v3>;
- status = "okay";
-&rgmii_phy1 {
- status = "okay";
-&saradc {
-&sdmmc0 {
- vmmc-supply = <&vcc_sd_pwr>;
- status = "okay";
-&spi3 {
-&uart2 {
- status = "okay";
-&uart7 {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vcc_5v>;
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&vbus {
- vin-supply = <&vcc_5v>;
-}; diff --git a/arch/arm/dts/rk3566-soquartz-model-a.dts b/arch/arm/dts/rk3566-soquartz-model-a.dts deleted file mode 100644 index f2095dfa4eaf..000000000000 --- a/arch/arm/dts/rk3566-soquartz-model-a.dts +++ /dev/null @@ -1,236 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
- model = "PINE64 RK3566 SOQuartz on Model A carrier board";
- compatible = "pine64,soquartz-model-a", "pine64,soquartz", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
- /* labeled DCIN_12V in schematic */
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-boot-on;
* Labelled VCC3V0_SD in schematic to not conflict with PMIC
* regulator, it's 3.3v in actuality
regulator-boot-on;
- vcc3v3_pcie: vcc3v3-pcie-regulator {
regulator-name = "vcc3v3_pcie";
regulator-boot-on;
- vcc12v_pcie: vcc12v-pcie-regulator {
regulator-name = "vcc12v_pcie";
regulator-boot-on;
- status = "okay";
-&gmac1 {
- status = "okay";
-&i2c1 {
- status = "okay";
reg = <0x51>;
-&i2c2 {
-&i2c3 {
-&i2c4 {
-&i2s1_8ch {
-&led_diy {
- status = "okay";
-&led_work {
- status = "okay";
-&pcie2x1 {
- vpcie3v3-supply = <&vcc3v3_pcie>;
- status = "okay";
-&rgmii_phy1 {
- status = "okay";
-&rgmii_phy1 {
- status = "okay";
-&saradc {
- vmmc-supply is vcc3v3_sd on v1.0 and vcc3v0_sd on v1.1+
- the soquartz SoM has SDMMC_PWR (CM1 pin 75) hardwired to vcc3v3_sys,
- so we use vcc3v3_sd here to ensure the regulator is enabled on older boards.
-&sdmmc0 {
- status = "okay";
-&spi3 {
-&uart2 {
- status = "okay";
-&uart7 {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vcc5v0_usb>;
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&vbus {
- vin-supply = <&vcc5v0_usb>;
-&vcc3v3_sd {
- regulator-always-on;
- regulator-boot-on;
- regulator-min-microvolt = <3300000>;
- regulator-max-microvolt = <3300000>;
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3566-soquartz.dtsi b/arch/arm/dts/rk3566-soquartz.dtsi deleted file mode 100644 index bfb7b952f4c5..000000000000 --- a/arch/arm/dts/rk3566-soquartz.dtsi +++ /dev/null @@ -1,684 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
- model = "Pine64 RK3566 SoQuartz SOM";
- compatible = "pine64,soquartz", "rockchip,rk3566";
- aliases {
mmc0 = &sdmmc0;
mmc1 = &sdhci;
mmc2 = &sdmmc1;
- chosen: chosen {
#clock-cells = <0>;
- hdmi-con {
type = "a";
port {
- leds {
led_diy: led-diy {
label = "diy-led";
gpios = <&gpio0 RK_PC1 GPIO_ACTIVE_LOW>;
led_work: led-work {
label = "work-led";
status = "okay";
- vbus: vbus-regulator {
regulator-boot-on;
- /* sourced from vbus, vbus is provided by the carrier board */
regulator-boot-on;
regulator-boot-on;
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gmac1 {
&gmac1m0_tx_bus2
&gmac1m0_rx_bus2
&gmac1m0_rgmii_clk
&gmac1m0_clkinout
-&gpio0 {
- nextrst-hog {
gpio-hog;
* GPIO_ACTIVE_LOW + output-low here means that the pin is set
* to high, because output-low decides the value pre-inversion.
gpios = <RK_PA5 GPIO_ACTIVE_LOW>;
line-name = "nEXTRST";
output-low;
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- pin 80 - i2c1_scl_m0, pullup to vcc3v3_pmu
- pin 82 - i2c1_sda_m0, pullup to vcc3v3_pmu
-&i2c1 {
- pin 56 - i2c2_scl_m1, pullup to vcc_3v3, shared with i2s1_8ch
- pin 58 - i2c2_sda_m1, pullup to vcc_3v3
-&i2c2 {
- pin 35 - i2c3_scl_m0, pullup to vcc_3v3
- pin 36 - i2c3_sda_m0, pullup to vcc_3v3
-&i2c3 {
- pin 45 - i2c4_scl_m1
- pin 47 - i2c4_sda_m1
-&i2c4 {
- pinctrl-0 = <&i2c4m1_xfer>;
-&i2s0_8ch {
- status = "okay";
- pin 24 - i2s1_sdi1_m1
- pin 25 - i2s1_sdo0_m1
- pin 26 - i2s1_lrck_tx_m1
- pin 27 - i2s1_sdi0_m1
- pin 29 - i2s1_sdi3_m1
- pin 30 - i2s1_sdi2_m1
- pin 40 - i2s1_sdo1_m1, shared with spi3
- pin 41 - i2s1_sdo2_m1
- pin 49 - i2s1_sclk_tx_m1
- pin 50 - i2s1_mclk_m1
- pin 56 - i2s1_sdo3_m1, shared with i2c2
-&i2s1_8ch {
- pinctrl-0 = <&i2s1m1_sclktx &i2s1m1_sclkrx
&i2s1m1_lrcktx &i2s1m1_lrckrx
&i2s1m1_sdi0 &i2s1m1_sdi1
&i2s1m1_sdi2 &i2s1m1_sdi3
&i2s1m1_sdo0 &i2s1m1_sdo1
&i2s1m1_sdo2 &i2s1m1_sdo3>;
-&mdio1 {
reg = <0>;
-&pcie2x1 {
-&pinctrl {
- bt {
- leds {
- pcie {
pcie_clkreq_h: pcie-clkreq-h {
rockchip,pins = <1 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
- sdio-pwrseq {
-&pmu_io_domains {
- vccio1-supply = <&vcc_3v3>;
- status = "okay";
- pin 94 - saradc_vin3
- pin 96 - saradc_vin2
-&saradc {
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- status = "okay";
-&sdmmc0 {
- broken-cd;
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
-&sdmmc1 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- sd-uhs-sdr50;
- status = "okay";
- pin 37 - spi3_cs1_m0
- pin 38 - spi3_clk_m0
- pin 39 - spi3_cs0_m0
- pin 40 - spi3_miso_m0, shared with i2s1_8ch
- pin 44 - spi3_mosi_m0
-&spi3 {
-&tsadc {
- status = "okay";
-&uart1 {
- uart-has-rtscts;
- status = "okay";
- bluetooth {
device-wakeup-gpios = <&gpio2 RK_PC1 GPIO_ACTIVE_HIGH>;
host-wakeup-gpios = <&gpio2 RK_PC0 GPIO_ACTIVE_HIGH>;
- pin 51 - uart2_rx_m0
- pin 55 - uart2_tx_m0
-&uart2 {
- pin 46 - uart7_tx_m2
- pin 47 - uart7_rx_m2
-&uart7 {
- pinctrl-0 = <&uart7m2_xfer>;
-/* dwc3_otg is the only usb port available */ -&usb2phy0 {
-&usb2phy0_otg {
-&usb_host0_xhci {
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-}; diff --git a/arch/arm/dts/rk3566.dtsi b/arch/arm/dts/rk3566.dtsi deleted file mode 100644 index 6c4b17d27bdc..000000000000 --- a/arch/arm/dts/rk3566.dtsi +++ /dev/null @@ -1,35 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-#include "rk356x.dtsi"
- compatible = "rockchip,rk3566";
-&pipegrf {
- compatible = "rockchip,rk3566-pipe-grf", "syscon";
-&power {
- power-domain@RK3568_PD_PIPE {
reg = <RK3568_PD_PIPE>;
clocks = <&cru PCLK_PIPE>;
pm_qos = <&qos_pcie2x1>,
<&qos_sata1>,
<&qos_sata2>,
<&qos_usb3_0>,
<&qos_usb3_1>;
#power-domain-cells = <0>;
-&usb_host0_xhci {
- extcon = <&usb2phy0>;
- maximum-speed = "high-speed";
-&vop {
- compatible = "rockchip,rk3566-vop";
-}; diff --git a/arch/arm/dts/rk3568-bpi-r2-pro.dts b/arch/arm/dts/rk3568-bpi-r2-pro.dts deleted file mode 100644 index f9127ddfbb7d..000000000000 --- a/arch/arm/dts/rk3568-bpi-r2-pro.dts +++ /dev/null @@ -1,852 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Author: Frank Wunderlich frank-w@public-files.de
-/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi"
- model = "Bananapi-R2 Pro (RK3568) DDR4 Board";
- compatible = "rockchip,rk3568-bpi-r2pro", "rockchip,rk3568";
- aliases {
ethernet0 = &gmac0;
ethernet1 = &gmac1;
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
- leds {
pinctrl-0 = <&blue_led_pin &green_led_pin>;
blue_led: led-0 {
color = <LED_COLOR_ID_BLUE>;
gpios = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
green_led: led-1 {
- dc_12v: dc-12v-regulator {
regulator-name = "dc_12v";
regulator-boot-on;
- hdmi-con {
type = "a";
port {
- ir-receiver {
compatible = "gpio-ir-receiver";
gpios = <&gpio0 RK_PC2 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&ir_receiver_pin>;
regulator-boot-on;
vin-supply = <&dc_12v>;
regulator-boot-on;
- pcie30_avdd0v9: pcie30-avdd0v9-regulator {
regulator-name = "pcie30_avdd0v9";
regulator-boot-on;
- pcie30_avdd1v8: pcie30-avdd1v8-regulator {
regulator-name = "pcie30_avdd1v8";
regulator-boot-on;
- /* pi6c pcie clock generator feeds both ports */
- vcc3v3_pi6c_05: vcc3v3-pi6c-05-regulator {
enable-active-high;
startup-delay-us = <200000>;
- /* actually fed by vcc3v3_sys, dependent on pi6c clock generator */
- vcc3v3_minipcie: vcc3v3-minipcie-regulator {
regulator-name = "vcc3v3_minipcie";
enable-active-high;
pinctrl-0 = <&minipcie_enable_h>;
startup-delay-us = <50000>;
vin-supply = <&vcc3v3_pi6c_05>;
- vcc3v3_ngff: vcc3v3-ngff-regulator {
regulator-name = "vcc3v3_ngff";
enable-active-high;
gpio = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&ngffpcie_enable_h>;
regulator-boot-on;
- vcc5v0_usb_host: vcc5v0-usb-host-regulator {
enable-active-high;
pinctrl-0 = <&vcc5v0_usb_host_en>;
regulator-name = "vcc5v0_usb_host";
enable-active-high;
gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb_otg_en>;
-&combphy0 {
- /* used for USB3 */
- status = "okay";
-&combphy1 {
- status = "okay";
-&combphy2 {
- /* used for SATA */
- status = "okay";
-&gmac0 {
- assigned-clocks = <&cru SCLK_GMAC0_RX_TX>, <&cru SCLK_GMAC0>;
- assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>, <&cru CLK_MAC0_2TOP>;
- pinctrl-0 = <&gmac0_miim
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- snps,reset-gpio = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
- rx_delay = <0x0f>;
- status = "okay";
- fixed-link {
speed = <1000>;
full-duplex;
pause;
-&gmac1 {
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru CLK_MAC1_2TOP>;
- clock_in_out = "output";
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
- snps,reset-gpio = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>;
- tx_delay = <0x3c>;
- rx_delay = <0x2f>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
pinctrl-0 = <&pmic_int>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&i2c3 {
- status = "okay";
- hym8563: rtc@51 {
compatible = "haoyu,hym8563";
reg = <0x51>;
interrupts = <RK_PD3 IRQ_TYPE_EDGE_FALLING>;
#clock-cells = <0>;
clock-output-names = "rtcic_32kout";
pinctrl-0 = <&hym8563_int>;
wakeup-source;
-&i2c5 {
- /* pin 3 (SDA) + 4 (SCL) of header con2 */
-&i2s0_8ch {
- /* hdmi sound */
- status = "okay";
-&mdio0 {
- switch@0 {
compatible = "mediatek,mt7531";
reg = <0>;
ports {
#size-cells = <0>;
port@1 {
reg = <1>;
label = "lan0";
port@2 {
reg = <2>;
label = "lan1";
port@3 {
reg = <3>;
label = "lan2";
port@4 {
reg = <4>;
label = "lan3";
port@5 {
reg = <5>;
label = "cpu";
ethernet = <&gmac0>;
phy-mode = "rgmii";
fixed-link {
speed = <1000>;
full-duplex;
pause;
-&mdio1 {
reg = <0x0>;
-&pcie30phy {
- data-lanes = <1 2>;
- phy-supply = <&vcc3v3_pi6c_05>;
- status = "okay";
-&pcie3x1 {
- /* M.2 slot */
- num-lanes = <1>;
- pinctrl-0 = <&ngffpcie_reset_h>;
- reset-gpios = <&gpio3 RK_PA1 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_ngff>;
- status = "okay";
-&pcie3x2 {
- /* mPCIe slot */
- num-lanes = <1>;
- pinctrl-0 = <&minipcie_reset_h>;
- reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_minipcie>;
- status = "okay";
-&pinctrl {
- leds {
blue_led_pin: blue-led-pin {
rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
green_led_pin: green-led-pin {
- hym8563 {
hym8563_int: hym8563-int {
- ir-receiver {
ir_receiver_pin: ir-receiver-pin {
rockchip,pins = <0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
minipcie_enable_h: minipcie-enable-h {
rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>;
ngffpcie_enable_h: ngffpcie-enable-h {
rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>;
minipcie_reset_h: minipcie-reset-h {
rockchip,pins = <2 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>;
ngffpcie_reset_h: ngffpcie-reset-h {
rockchip,pins = <3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_none_drv_level_5>;
- pmic {
rockchip,pins =
- usb {
vcc5v0_usb_host_en: vcc5v0_usb_host_en {
vcc5v0_usb_otg_en: vcc5v0_usb_otg_en {
-&pmu_io_domains {
- vccio4-supply = <&vcc_3v3>;
- vccio6-supply = <&vcc_1v8>;
- status = "okay";
-&pwm8 {
- /* fan 5v - gnd - pwm */
- status = "okay";
-&pwm10 {
- /* pin 7 of header con2 */
-&pwm11 {
- /* pin 15 of header con2 */
-&pwm12 {
- /* pin 21 of header con2 */
- /* shared with uart9 + spi3 */
- pinctrl-0 = <&pwm12m1_pins>;
-&pwm13 {
- /* pin 24 of header con2 */
- /* shared with uart9 */
- pinctrl-0 = <&pwm13m1_pins>;
-&pwm14 {
- /* pin 23 of header con2 */
- /* shared with spi3 */
- pinctrl-0 = <&pwm14m1_pins>;
-&pwm15 {
- /* pin 19 of header con2 */
- pinctrl-0 = <&pwm15m1_pins>;
-&saradc {
- status = "okay";
-&sata2 {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- non-removable;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- sd-uhs-sdr104;
- status = "okay";
-&spi3 {
- /* pin 19 (MO) + 21 (MI) + 23 (CK) of header con2 */
- /* shared with pwm12/14/15 and uart9 */
- pinctrl-0 = <&spi3m1_pins>;
-&tsadc {
- status = "okay";
-&uart0 {
- /* pin 8 (TX) + 10 (RX) (RTS:16, CTS:18) of header con2 */
-&uart2 {
- /* debug-uart */
- status = "okay";
-&uart7 {
- /* pin 11 (TX) + 13 (RX) of header con2 */
- pinctrl-0 = <&uart7m1_xfer>;
-&uart9 {
- /* pin 21 (TX) + 24 (RX) of header con2 */
- /* shared with pwm13 and pwm12/spi3 */
- pinctrl-0 = <&uart9m1_xfer>;
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host0_xhci {
- dr_mode = "host";
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- phy-supply = <&vcc5v0_usb_host>;
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb2phy1 {
- /* USB for PCIe/M2 */
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-}; diff --git a/arch/arm/dts/rk3568-evb.dts b/arch/arm/dts/rk3568-evb.dts deleted file mode 100644 index 19f8fc369b13..000000000000 --- a/arch/arm/dts/rk3568-evb.dts +++ /dev/null @@ -1,689 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2021 Rockchip Electronics Co., Ltd.
- model = "Rockchip RK3568 EVB1 DDR4 V10 Board";
- compatible = "rockchip,rk3568-evb1-v10", "rockchip,rk3568";
- aliases {
ethernet0 = &gmac0;
ethernet1 = &gmac1;
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
- dc_12v: dc-12v {
regulator-boot-on;
- hdmi-con {
type = "a";
port {
- leds {
led_work: led-0 {
gpios = <&gpio0 RK_PC0 GPIO_ACTIVE_HIGH>;
function = LED_FUNCTION_HEARTBEAT;
pinctrl-0 = <&led_work_en>;
- rk809-sound {
- vcc3v3_sys: vcc3v3-sys {
regulator-boot-on;
- vcc5v0_sys: vcc5v0-sys {
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb {
regulator-boot-on;
- vcc5v0_usb_host: vcc5v0-usb-host {
enable-active-high;
- vcc5v0_usb_otg: vcc5v0-usb-otg {
enable-active-high;
- vcc3v3_lcd0_n: vcc3v3-lcd0-n {
enable-active-high;
gpio = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc3v3_lcd0_n_en>;
- vcc3v3_lcd1_n: vcc3v3-lcd1-n {
regulator-name = "vcc3v3_lcd1_n";
enable-active-high;
pinctrl-0 = <&vcc3v3_lcd1_n_en>;
-&combphy0 {
- status = "okay";
-&combphy1 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gmac0 {
- assigned-clock-parents = <&cru SCLK_GMAC0_RGMII_SPEED>;
- phy-handle = <&rgmii_phy0>;
- phy-mode = "rgmii-id";
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- status = "okay";
-&gmac1 {
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>;
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
codec {
mic-in-differential;
-&i2c1 {
- status = "okay";
- touchscreen0: goodix@14 {
compatible = "goodix,gt1151";
reg = <0x14>;
interrupts = <RK_PB5 IRQ_TYPE_EDGE_FALLING>;
AVDD28-supply = <&vcc3v3_lcd0_n>;
irq-gpios = <&gpio0 RK_PB5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&touch_int &touch_rst>;
reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>;
VDDIO-supply = <&vcc3v3_lcd0_n>;
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
- status = "okay";
-&mdio0 {
- rgmii_phy0: ethernet-phy@0 {
reg = <0x0>;
reset-assert-us = <20000>;
reset-deassert-us = <100000>;
reset-gpios = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>;
-&mdio1 {
reg = <0x0>;
reset-gpios = <&gpio2 RK_PD1 GPIO_ACTIVE_LOW>;
-&pinctrl {
- display {
vcc3v3_lcd0_n_en: vcc3v3_lcd0_n_en {
rockchip,pins = <0 RK_PC7 0 &pcfg_pull_none>;
vcc3v3_lcd1_n_en: vcc3v3_lcd1_n_en {
rockchip,pins = <0 RK_PC5 0 &pcfg_pull_none>;
- leds {
led_work_en: led_work_en {
- pmic {
rockchip,pins =
- touchscreen {
touch_int: touch_int {
rockchip,pins = <0 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>;
touch_rst: touch_rst {
rockchip,pins = <0 RK_PB6 RK_FUNC_GPIO &pcfg_pull_none>;
- usb {
-&pmu_io_domains {
- status = "okay";
-&saradc {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- non-removable;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- sd-uhs-sdr104;
- status = "okay";
-&tsadc {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-}; diff --git a/arch/arm/dts/rk3568-lubancat-2.dts b/arch/arm/dts/rk3568-lubancat-2.dts deleted file mode 100644 index a8a4cc190eb3..000000000000 --- a/arch/arm/dts/rk3568-lubancat-2.dts +++ /dev/null @@ -1,730 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
- Copyright (c) 2022 EmbedFire embedfire@embedfire.com
- model = "EmbedFire LubanCat 2";
- compatible = "embedfire,lubancat-2", "rockchip,rk3568";
- aliases {
ethernet0 = &gmac0;
ethernet1 = &gmac1;
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
- leds {
user_led: user-led {
label = "user_led";
gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&user_led_pin>;
- hdmi-con {
type = "a";
port {
- dc_5v: dc-5v-regulator {
regulator-name = "dc_5v";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vin-supply = <&dc_5v>;
- vcc3v3_m2_pcie: vcc3v3-m2-pcie-regulator {
regulator-name = "m2_pcie_3v3";
enable-active-high;
pinctrl-0 = <&vcc3v3_m2_pcie_en>;
- vcc3v3_mini_pcie: vcc3v3-mini-pcie-regulator {
regulator-name = "minipcie_3v3";
enable-active-high;
gpio = <&gpio3 RK_PC3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc3v3_mini_pcie_en>;
startup-delay-us = <5000>;
- vcc5v0_usb20_host: vcc5v0-usb20-host-regulator {
enable-active-high;
gpio = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>;
enable-active-high;
gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb30_host_en>;
- vcc5v0_otg_vbus: vcc5v0-otg-vbus-regulator {
regulator-name = "vcc5v0_otg_vbus";
enable-active-high;
gpio = <&gpio0 RK_PD3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_otg_vbus_en>;
-&combphy0 {
- status = "okay";
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
regulator-boot-on;
- rk809: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&i2s1_8ch {
- status = "okay";
-&gmac0 {
- snps,reset-gpio = <&gpio2 RK_PD3 GPIO_ACTIVE_LOW>;
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- tx_delay = <0x22>;
- rx_delay = <0x0e>;
- status = "okay";
-&mdio0 {
- rgmii_phy0: phy@0 {
reg = <0x0>;
-&gmac1 {
- snps,reset-gpio = <&gpio3 RK_PA2 GPIO_ACTIVE_LOW>;
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
- tx_delay = <0x21>;
- status = "okay";
-&mdio1 {
- rgmii_phy1: phy@0 {
reg = <0x0>;
-&gic {
- mbi-ranges = <94 31>, <229 31>, <289 31>;
-&pcie30phy {
- status = "okay";
-&pcie3x2 {
- vpcie3v3-supply = <&vcc3v3_m2_pcie>;
- status = "okay";
-&pcie2x1 {
- reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>;
- disable-gpios = <&gpio3 RK_PC2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_mini_pcie>;
- status = "okay";
-&pmu_io_domains {
- status = "okay";
-&pwm8 {
- status = "okay";
-&pwm9 {
-&pwm10 {
-&pwm14 {
-&spi3 {
-&uart2 {
- status = "okay";
-&uart3 {
- pinctrl-0 = <&uart3m1_xfer>;
-&saradc {
- status = "okay";
-&tsadc {
- status = "okay";
-&sdhci {
- assigned-clocks = <&cru BCLK_EMMC>, <&cru TCLK_EMMC>, <&cru CCLK_EMMC>;
- assigned-clock-rates = <200000000>, <24000000>, <200000000>;
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd>;
- supports-emmc;
- status = "okay";
-&sdmmc0 {
- max-frequency = <150000000>;
- no-sdio;
- no-mmc;
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- sd-uhs-sdr104;
- status = "okay";
-/* USB OTG/USB Host_1 USB 2.0 Comb */ -&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vcc5v0_otg_vbus>;
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-/* USB Host_2/USB Host_3 USB 2.0 Comb */ -&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-/* MULTI_PHY0 For SATA0, USB3.0 OTG Only USB2.0 */ -&usb_host0_xhci {
- dr_mode = "host";
- status = "okay";
-&sata0 {
- status = "okay";
-/* USB3.0 Host */ -&usb_host1_xhci {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-&pinctrl {
- leds {
user_led_pin: user-status-led-pin {
rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>;
- usb {
vcc5v0_usb30_host_en: vcc5v0-usb30-host-en {
vcc5v0_otg_vbus_en: vcc5v0-otg-vbus-en {
- pcie {
vcc3v3_m2_pcie_en: vcc3v3-m2-pcie-en {
vcc3v3_mini_pcie_en: vcc3v3-mini-pcie-en {
rockchip,pins = <3 RK_PC3 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
pmic_int: pmic-int {
-}; diff --git a/arch/arm/dts/rk3568-nanopi-r5c.dts b/arch/arm/dts/rk3568-nanopi-r5c.dts deleted file mode 100644 index c718b8dbb9c6..000000000000 --- a/arch/arm/dts/rk3568-nanopi-r5c.dts +++ /dev/null @@ -1,112 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/*
- Copyright (c) 2022 FriendlyElec Computer Tech. Co., Ltd.
- Copyright (c) 2023 Tianling Shen cnsztl@gmail.com
-/dts-v1/; -#include "rk3568-nanopi-r5s.dtsi"
- model = "FriendlyElec NanoPi R5C";
- compatible = "friendlyarm,nanopi-r5c", "rockchip,rk3568";
- gpio-keys {
compatible = "gpio-keys";
pinctrl-0 = <&reset_button_pin>;
button-reset {
debounce-interval = <50>;
gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_LOW>;
label = "reset";
linux,code = <KEY_RESTART>;
- gpio-leds {
pinctrl-0 = <&lan_led_pin>, <&power_led_pin>, <&wan_led_pin>, <&wlan_led_pin>;
led-lan {
function = LED_FUNCTION_LAN;
gpios = <&gpio3 RK_PA3 GPIO_ACTIVE_HIGH>;
power_led: led-power {
gpios = <&gpio3 RK_PA2 GPIO_ACTIVE_HIGH>;
led-wan {
function = LED_FUNCTION_WAN;
gpios = <&gpio3 RK_PA4 GPIO_ACTIVE_HIGH>;
led-wlan {
function = LED_FUNCTION_WLAN;
gpios = <&gpio3 RK_PA5 GPIO_ACTIVE_HIGH>;
-&pcie2x1 {
- pinctrl-0 = <&pcie20_reset_pin>;
- status = "okay";
-&pcie3x1 {
- num-lanes = <1>;
- reset-gpios = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>;
- status = "okay";
-&pcie3x2 {
- num-lanes = <1>;
- reset-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_HIGH>;
- status = "okay";
-&pinctrl {
- gpio-leds {
lan_led_pin: lan-led-pin {
rockchip,pins = <3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_none>;
power_led_pin: power-led-pin {
rockchip,pins = <3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
wan_led_pin: wan-led-pin {
rockchip,pins = <3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_none>;
wlan_led_pin: wlan-led-pin {
rockchip,pins = <3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
pcie20_reset_pin: pcie20-reset-pin {
rockchip,pins = <2 RK_PD2 RK_FUNC_GPIO &pcfg_pull_up>;
- rockchip-key {
reset_button_pin: reset-button-pin {
rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_up>;
-}; diff --git a/arch/arm/dts/rk3568-nanopi-r5s.dts b/arch/arm/dts/rk3568-nanopi-r5s.dts deleted file mode 100644 index b6ad8328c7eb..000000000000 --- a/arch/arm/dts/rk3568-nanopi-r5s.dts +++ /dev/null @@ -1,136 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/*
- model = "FriendlyElec NanoPi R5S";
- compatible = "friendlyarm,nanopi-r5s", "rockchip,rk3568";
- aliases {
ethernet0 = &gmac0;
- gpio-leds {
pinctrl-0 = <&lan1_led_pin>, <&lan2_led_pin>, <&power_led_pin>, <&wan_led_pin>;
led-lan1 {
function-enumerator = <1>;
gpios = <&gpio3 RK_PD6 GPIO_ACTIVE_HIGH>;
led-lan2 {
function-enumerator = <2>;
gpios = <&gpio3 RK_PD7 GPIO_ACTIVE_HIGH>;
function = LED_FUNCTION_POWER;
gpios = <&gpio4 RK_PD2 GPIO_ACTIVE_HIGH>;
led-wan {
-&gmac0 {
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- snps,reset-gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_LOW>;
- /* Reset time is 15ms, 50ms for rtl8211f */
- snps,reset-delays-us = <0 15000 50000>;
- status = "okay";
-&mdio0 {
- rgmii_phy0: ethernet-phy@1 {
reg = <1>;
pinctrl-0 = <ð_phy0_reset_pin>;
-&pcie2x1 {
- num-lanes = <1>;
- status = "okay";
-&pcie30phy {
- status = "okay";
-&pcie3x1 {
- num-lanes = <1>;
- status = "okay";
-&pcie3x2 {
- num-lanes = <1>;
- num-ib-windows = <8>;
- num-ob-windows = <8>;
- status = "okay";
-&pinctrl {
- gmac0 {
eth_phy0_reset_pin: eth-phy0-reset-pin {
rockchip,pins = <0 RK_PC4 RK_FUNC_GPIO &pcfg_pull_up>;
- gpio-leds {
lan1_led_pin: lan1-led-pin {
rockchip,pins = <3 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
lan2_led_pin: lan2-led-pin {
rockchip,pins = <3 RK_PD7 RK_FUNC_GPIO &pcfg_pull_none>;
rockchip,pins = <4 RK_PD2 RK_FUNC_GPIO &pcfg_pull_none>;
-}; diff --git a/arch/arm/dts/rk3568-nanopi-r5s.dtsi b/arch/arm/dts/rk3568-nanopi-r5s.dtsi deleted file mode 100644 index 93189f830640..000000000000 --- a/arch/arm/dts/rk3568-nanopi-r5s.dtsi +++ /dev/null @@ -1,587 +0,0 @@ -// SPDX-License-Identifier: GPL-2.0-or-later OR MIT -/*
-/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/input.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi"
- aliases {
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
stdout-path = "serial2:1500000n8";
- hdmi-con {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&hdmi_out_con>;
- vdd_usbc: vdd-usbc-regulator {
compatible = "regulator-fixed";
regulator-name = "vdd_usbc";
regulator-boot-on;
regulator-boot-on;
vin-supply = <&vdd_usbc>;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
enable-active-high;
regulator-boot-on;
regulator-boot-on;
-&combphy0 {
- status = "okay";
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
- cpu-supply = <&vdd_cpu>;
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
- hdmi_in_vp0: endpoint {
remote-endpoint = <&vp0_out_hdmi>;
-&hdmi_out {
- hdmi_out_con: endpoint {
remote-endpoint = <&hdmi_con_in>;
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
regulator-boot-on;
regulator-state-mem {
regulator-off-in-suspend;
- rk809: pmic@20 {
reg = <0x20>;
interrupt-parent = <&gpio0>;
interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
wakeup-source;
regulators {
vdd_logic: DCDC_REG1 {
regulator-name = "vdd_logic";
regulator-boot-on;
regulator-initial-mode = <0x2>;
regulator-min-microvolt = <500000>;
regulator-max-microvolt = <1350000>;
regulator-ramp-delay = <6001>;
vdd_gpu: DCDC_REG2 {
regulator-name = "vdd_gpu";
vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr";
regulator-boot-on;
regulator-on-in-suspend;
regulator-name = "vcc_1v8";
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-min-microvolt = <950000>;
regulator-max-microvolt = <950000>;
vdda_0v9: LDO_REG2 {
regulator-name = "vdda_0v9";
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
vdda0v9_pmu: LDO_REG3 {
regulator-name = "vdda0v9_pmu";
regulator-boot-on;
regulator-suspend-microvolt = <900000>;
vccio_acodec: LDO_REG4 {
regulator-name = "vccio_acodec";
vccio_sd: LDO_REG5 {
regulator-name = "vccio_sd";
vcc3v3_pmu: LDO_REG6 {
regulator-name = "vcc3v3_pmu";
regulator-boot-on;
regulator-suspend-microvolt = <3300000>;
regulator-boot-on;
regulator-name = "vcca1v8_pmu";
regulator-boot-on;
regulator-suspend-microvolt = <1800000>;
regulator-name = "vcc_3v3";
regulator-boot-on;
regulator-boot-on;
-&i2c5 {
- status = "okay";
- hym8563: rtc@51 {
reg = <0x51>;
interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <0>;
wakeup-source;
-&i2s0_8ch {
- status = "okay";
-&pcie30phy {
- status = "okay";
-&pinctrl {
- hym8563 {
rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>;
- pmic {
- usb {
vcc5v0_usb_host_en: vcc5v0-usb-host-en {
vcc5v0_usb_otg_en: vcc5v0-usb-otg-en {
-&pmu_io_domains {
- status = "okay";
-&saradc {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- non-removable;
- status = "okay";
-&sdmmc0 {
- no-sdio;
- no-mmc;
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- status = "okay";
-&tsadc {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host0_xhci {
- dr_mode = "host";
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&vop {
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
-}; diff --git a/arch/arm/dts/rk3568-odroid-m1.dts b/arch/arm/dts/rk3568-odroid-m1.dts deleted file mode 100644 index a337f547caf5..000000000000 --- a/arch/arm/dts/rk3568-odroid-m1.dts +++ /dev/null @@ -1,741 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2022 Hardkernel Co., Ltd.
- model = "Hardkernel ODROID-M1";
- compatible = "rockchip,rk3568-odroid-m1", "rockchip,rk3568";
- aliases {
ethernet0 = &gmac0;
i2c0 = &i2c3;
i2c3 = &i2c0;
mmc0 = &sdhci;
mmc1 = &sdmmc0;
serial0 = &uart1;
serial1 = &uart0;
- chosen {
regulator-boot-on;
- hdmi-con {
type = "a";
port {
- ir-receiver {
- leds {
led_power: led-0 {
gpios = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>;
default-state = "keep";
linux,default-trigger = "default-on";
pinctrl-0 = <&led_power_pin>;
led_work: led-1 {
gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&led_work_pin>;
- rk809-sound {
pinctrl-0 = <&hp_det_pin>;
simple-audio-card,hp-det-gpio = <&gpio0 RK_PB0 GPIO_ACTIVE_HIGH>;
simple-audio-card,widgets =
"Headphone", "Headphones",
"Speaker", "Speaker";
simple-audio-card,routing =
"Headphones", "HPOL",
"Headphones", "HPOR",
"Speaker", "SPKO";
enable-active-high;
gpio = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc3v3_pcie_en_pin>;
regulator-boot-on;
regulator-boot-on;
enable-active-high;
pinctrl-0 = <&vcc5v0_usb_host_en_pin>;
enable-active-high;
pinctrl-0 = <&vcc5v0_usb_otg_en_pin>;
-&combphy0 {
- /* Used for USB3 */
- status = "okay";
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gmac0 {
&gmac0_tx_bus2
&gmac0_rx_bus2
&gmac0_rgmii_clk
&gmac0_rgmii_bus>;
- status = "okay";
- rx_delay = <0x2d>;
-&gpu {
- status = "okay";
-&hdmi {
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
fcs,suspend-voltage-selector = <1>;
regulator-name = "vdd_cpu";
regulator-boot-on;
regulator-ramp-delay = <2300>;
- rk809: pmic@20 {
reg = <0x20>;
assigned-clocks = <&cru I2S1_MCLKOUT_TX>;
assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>;
#clock-cells = <1>;
clock-names = "mclk";
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
- rockchip,trcm-sync-tx-only;
- status = "okay";
-&mdio0 {
reg = <0x0>;
reset-gpios = <&gpio3 RK_PB7 GPIO_ACTIVE_LOW>;
-&pcie30phy {
- status = "okay";
-&pcie3x2 {
- pinctrl-0 = <&pcie_reset_pin>;
- status = "okay";
-&pinctrl {
- fspi {
fspi_dual_io_pins: fspi-dual-io-pins {
rockchip,pins =
/* fspi_clk */
<1 RK_PD0 1 &pcfg_pull_none>,
/* fspi_cs0n */
<1 RK_PD3 1 &pcfg_pull_none>,
/* fspi_d0 */
<1 RK_PD1 1 &pcfg_pull_none>,
/* fspi_d1 */
<1 RK_PD2 1 &pcfg_pull_none>;
- ir-receiver {
/* external pullup to VCC3V3_SYS */
- leds {
led_power_pin: led-power-pin {
led_work_pin: led-work-pin {
rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
pcie_reset_pin: pcie-reset-pin {
rockchip,pins = <2 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
vcc3v3_pcie_en_pin: vcc3v3-pcie-en-pin {
rockchip,pins = <4 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
pmic_int_l: pmic-int-l {
- rk809 {
hp_det_pin: hp-det-pin {
rockchip,pins = <0 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
- usb {
vcc5v0_usb_host_en_pin: vcc5v0-usb-host-en-pin {
vcc5v0_usb_otg_en_pin: vcc5v0-usb-dr-en-pin {
-&pmu_io_domains {
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_1v8>;
- vccio5-supply = <&vcc_3v3>;
- vccio7-supply = <&vcc_3v3>;
- status = "okay";
-&saradc {
- status = "okay";
-&sata2 {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- non-removable;
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe &emmc_rstnout>;
- vmmc-supply = <&vcc_3v3>;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
- disable-wp;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
- sd-uhs-sdr50;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
-&sfc {
- /* Dual I/O mode as the D2 pin conflicts with the eMMC */
- pinctrl-0 = <&fspi_dual_io_pins>;
- status = "okay";
- flash@0 {
reg = <0>;
spi-max-frequency = <100000000>;
spi-rx-bus-width = <2>;
partitions {
compatible = "fixed-partitions";
#size-cells = <1>;
partition@0 {
label = "SPL";
reg = <0x0 0xe0000>;
partition@e0000 {
label = "U-Boot Env";
reg = <0xe0000 0x20000>;
partition@100000 {
label = "U-Boot";
reg = <0x100000 0x200000>;
partition@300000 {
label = "splash";
reg = <0x300000 0x100000>;
partition@400000 {
label = "Filesystem";
reg = <0x400000 0xc00000>;
-&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host0_xhci {
- dr_mode = "host";
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&vop {
- assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
- assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
- vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 {
reg = <ROCKCHIP_VOP2_EP_HDMI0>;
remote-endpoint = <&hdmi_in_vp0>;
-}; diff --git a/arch/arm/dts/rk3568-pinctrl.dtsi b/arch/arm/dts/rk3568-pinctrl.dtsi deleted file mode 100644 index 0a979bfb63d9..000000000000 --- a/arch/arm/dts/rk3568-pinctrl.dtsi +++ /dev/null @@ -1,3214 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-#include <dt-bindings/pinctrl/rockchip.h> -#include "rockchip-pinconf.dtsi"
- This file is auto generated by pin2dts tool, please keep these code
- by adding changes at end of this file.
-&pinctrl {
- acodec {
/omit-if-no-ref/
acodec_pins: acodec-pins {
rockchip,pins =
/* acodec_adc_sync */
<1 RK_PB1 5 &pcfg_pull_none>,
/* acodec_adcclk */
<1 RK_PA1 5 &pcfg_pull_none>,
/* acodec_adcdata */
<1 RK_PA0 5 &pcfg_pull_none>,
/* acodec_dac_datal */
<1 RK_PA7 5 &pcfg_pull_none>,
/* acodec_dac_datar */
<1 RK_PB0 5 &pcfg_pull_none>,
/* acodec_dacclk */
<1 RK_PA3 5 &pcfg_pull_none>,
/* acodec_dacsync */
<1 RK_PA5 5 &pcfg_pull_none>;
- audiopwm {
/omit-if-no-ref/
audiopwm_lout: audiopwm-lout {
rockchip,pins =
/* audiopwm_lout */
<1 RK_PA0 4 &pcfg_pull_none>;
/omit-if-no-ref/
audiopwm_loutn: audiopwm-loutn {
rockchip,pins =
/* audiopwm_loutn */
<1 RK_PA1 6 &pcfg_pull_none>;
/omit-if-no-ref/
audiopwm_loutp: audiopwm-loutp {
rockchip,pins =
/* audiopwm_loutp */
<1 RK_PA0 6 &pcfg_pull_none>;
/omit-if-no-ref/
audiopwm_rout: audiopwm-rout {
rockchip,pins =
/* audiopwm_rout */
<1 RK_PA1 4 &pcfg_pull_none>;
/omit-if-no-ref/
audiopwm_routn: audiopwm-routn {
rockchip,pins =
/* audiopwm_routn */
<1 RK_PA7 4 &pcfg_pull_none>;
/omit-if-no-ref/
audiopwm_routp: audiopwm-routp {
rockchip,pins =
/* audiopwm_routp */
<1 RK_PA6 4 &pcfg_pull_none>;
- bt656 {
/omit-if-no-ref/
bt656m0_pins: bt656m0-pins {
rockchip,pins =
/* bt656_clkm0 */
<3 RK_PA0 2 &pcfg_pull_none>,
/* bt656_d0m0 */
<2 RK_PD0 2 &pcfg_pull_none>,
/* bt656_d1m0 */
<2 RK_PD1 2 &pcfg_pull_none>,
/* bt656_d2m0 */
<2 RK_PD2 2 &pcfg_pull_none>,
/* bt656_d3m0 */
<2 RK_PD3 2 &pcfg_pull_none>,
/* bt656_d4m0 */
<2 RK_PD4 2 &pcfg_pull_none>,
/* bt656_d5m0 */
<2 RK_PD5 2 &pcfg_pull_none>,
/* bt656_d6m0 */
<2 RK_PD6 2 &pcfg_pull_none>,
/* bt656_d7m0 */
<2 RK_PD7 2 &pcfg_pull_none>;
/omit-if-no-ref/
bt656m1_pins: bt656m1-pins {
rockchip,pins =
/* bt656_clkm1 */
<4 RK_PB4 5 &pcfg_pull_none>,
/* bt656_d0m1 */
<3 RK_PC6 5 &pcfg_pull_none>,
/* bt656_d1m1 */
<3 RK_PC7 5 &pcfg_pull_none>,
/* bt656_d2m1 */
<3 RK_PD0 5 &pcfg_pull_none>,
/* bt656_d3m1 */
<3 RK_PD1 5 &pcfg_pull_none>,
/* bt656_d4m1 */
<3 RK_PD2 5 &pcfg_pull_none>,
/* bt656_d5m1 */
<3 RK_PD3 5 &pcfg_pull_none>,
/* bt656_d6m1 */
<3 RK_PD4 5 &pcfg_pull_none>,
/* bt656_d7m1 */
<3 RK_PD5 5 &pcfg_pull_none>;
- bt1120 {
/omit-if-no-ref/
bt1120_pins: bt1120-pins {
rockchip,pins =
/* bt1120_clk */
<3 RK_PA6 2 &pcfg_pull_none>,
/* bt1120_d0 */
<3 RK_PA1 2 &pcfg_pull_none>,
/* bt1120_d1 */
<3 RK_PA2 2 &pcfg_pull_none>,
/* bt1120_d2 */
<3 RK_PA3 2 &pcfg_pull_none>,
/* bt1120_d3 */
<3 RK_PA4 2 &pcfg_pull_none>,
/* bt1120_d4 */
<3 RK_PA5 2 &pcfg_pull_none>,
/* bt1120_d5 */
<3 RK_PA7 2 &pcfg_pull_none>,
/* bt1120_d6 */
<3 RK_PB0 2 &pcfg_pull_none>,
/* bt1120_d7 */
<3 RK_PB1 2 &pcfg_pull_none>,
/* bt1120_d8 */
<3 RK_PB2 2 &pcfg_pull_none>,
/* bt1120_d9 */
<3 RK_PB3 2 &pcfg_pull_none>,
/* bt1120_d10 */
<3 RK_PB4 2 &pcfg_pull_none>,
/* bt1120_d11 */
<3 RK_PB5 2 &pcfg_pull_none>,
/* bt1120_d12 */
<3 RK_PB6 2 &pcfg_pull_none>,
/* bt1120_d13 */
<3 RK_PC1 2 &pcfg_pull_none>,
/* bt1120_d14 */
<3 RK_PC2 2 &pcfg_pull_none>,
/* bt1120_d15 */
<3 RK_PC3 2 &pcfg_pull_none>;
- cam {
/omit-if-no-ref/
cam_clkout0: cam-clkout0 {
rockchip,pins =
/* cam_clkout0 */
<4 RK_PA7 1 &pcfg_pull_none>;
/omit-if-no-ref/
cam_clkout1: cam-clkout1 {
rockchip,pins =
/* cam_clkout1 */
<4 RK_PB0 1 &pcfg_pull_none>;
- can0 {
/omit-if-no-ref/
can0m0_pins: can0m0-pins {
rockchip,pins =
/* can0_rxm0 */
<0 RK_PB4 2 &pcfg_pull_none>,
/* can0_txm0 */
<0 RK_PB3 2 &pcfg_pull_none>;
/omit-if-no-ref/
can0m1_pins: can0m1-pins {
rockchip,pins =
/* can0_rxm1 */
<2 RK_PA2 4 &pcfg_pull_none>,
/* can0_txm1 */
<2 RK_PA1 4 &pcfg_pull_none>;
- can1 {
/omit-if-no-ref/
can1m0_pins: can1m0-pins {
rockchip,pins =
/* can1_rxm0 */
<1 RK_PA0 3 &pcfg_pull_none>,
/* can1_txm0 */
<1 RK_PA1 3 &pcfg_pull_none>;
/omit-if-no-ref/
can1m1_pins: can1m1-pins {
rockchip,pins =
/* can1_rxm1 */
<4 RK_PC2 3 &pcfg_pull_none>,
/* can1_txm1 */
<4 RK_PC3 3 &pcfg_pull_none>;
- can2 {
/omit-if-no-ref/
can2m0_pins: can2m0-pins {
rockchip,pins =
/* can2_rxm0 */
<4 RK_PB4 3 &pcfg_pull_none>,
/* can2_txm0 */
<4 RK_PB5 3 &pcfg_pull_none>;
/omit-if-no-ref/
can2m1_pins: can2m1-pins {
rockchip,pins =
/* can2_rxm1 */
<2 RK_PB1 4 &pcfg_pull_none>,
/* can2_txm1 */
<2 RK_PB2 4 &pcfg_pull_none>;
- cif {
/omit-if-no-ref/
cif_clk: cif-clk {
rockchip,pins =
/* cif_clkout */
<4 RK_PC0 1 &pcfg_pull_none>;
/omit-if-no-ref/
cif_dvp_clk: cif-dvp-clk {
rockchip,pins =
/* cif_clkin */
<4 RK_PC1 1 &pcfg_pull_none>,
/* cif_href */
<4 RK_PB6 1 &pcfg_pull_none>,
/* cif_vsync */
<4 RK_PB7 1 &pcfg_pull_none>;
/omit-if-no-ref/
cif_dvp_bus16: cif-dvp-bus16 {
rockchip,pins =
/* cif_d8 */
<3 RK_PD6 1 &pcfg_pull_none>,
/* cif_d9 */
<3 RK_PD7 1 &pcfg_pull_none>,
/* cif_d10 */
<4 RK_PA0 1 &pcfg_pull_none>,
/* cif_d11 */
<4 RK_PA1 1 &pcfg_pull_none>,
/* cif_d12 */
<4 RK_PA2 1 &pcfg_pull_none>,
/* cif_d13 */
<4 RK_PA3 1 &pcfg_pull_none>,
/* cif_d14 */
<4 RK_PA4 1 &pcfg_pull_none>,
/* cif_d15 */
<4 RK_PA5 1 &pcfg_pull_none>;
/omit-if-no-ref/
cif_dvp_bus8: cif-dvp-bus8 {
rockchip,pins =
/* cif_d0 */
<3 RK_PC6 1 &pcfg_pull_none>,
/* cif_d1 */
<3 RK_PC7 1 &pcfg_pull_none>,
/* cif_d2 */
<3 RK_PD0 1 &pcfg_pull_none>,
/* cif_d3 */
<3 RK_PD1 1 &pcfg_pull_none>,
/* cif_d4 */
<3 RK_PD2 1 &pcfg_pull_none>,
/* cif_d5 */
<3 RK_PD3 1 &pcfg_pull_none>,
/* cif_d6 */
<3 RK_PD4 1 &pcfg_pull_none>,
/* cif_d7 */
<3 RK_PD5 1 &pcfg_pull_none>;
- clk32k {
/omit-if-no-ref/
clk32k_in: clk32k-in {
rockchip,pins =
/* clk32k_in */
<0 RK_PB0 1 &pcfg_pull_none>;
/omit-if-no-ref/
clk32k_out0: clk32k-out0 {
rockchip,pins =
/* clk32k_out0 */
<0 RK_PB0 2 &pcfg_pull_none>;
/omit-if-no-ref/
clk32k_out1: clk32k-out1 {
rockchip,pins =
/* clk32k_out1 */
<2 RK_PC6 1 &pcfg_pull_none>;
- cpu {
/omit-if-no-ref/
cpu_pins: cpu-pins {
rockchip,pins =
/* cpu_avs */
<0 RK_PB7 2 &pcfg_pull_none>;
- ebc {
/omit-if-no-ref/
ebc_extern: ebc-extern {
rockchip,pins =
/* ebc_sdce1 */
<4 RK_PA7 2 &pcfg_pull_none>,
/* ebc_sdce2 */
<4 RK_PB0 2 &pcfg_pull_none>,
/* ebc_sdce3 */
<4 RK_PB1 2 &pcfg_pull_none>,
/* ebc_sdshr */
<4 RK_PB5 2 &pcfg_pull_none>,
/* ebc_vcom */
<4 RK_PB2 2 &pcfg_pull_none>;
/omit-if-no-ref/
ebc_pins: ebc-pins {
rockchip,pins =
/* ebc_gdclk */
<4 RK_PC0 2 &pcfg_pull_none>,
/* ebc_gdoe */
<4 RK_PB3 2 &pcfg_pull_none>,
/* ebc_gdsp */
<4 RK_PB4 2 &pcfg_pull_none>,
/* ebc_sdce0 */
<4 RK_PA6 2 &pcfg_pull_none>,
/* ebc_sdclk */
<4 RK_PC1 2 &pcfg_pull_none>,
/* ebc_sddo0 */
<3 RK_PC6 2 &pcfg_pull_none>,
/* ebc_sddo1 */
<3 RK_PC7 2 &pcfg_pull_none>,
/* ebc_sddo2 */
<3 RK_PD0 2 &pcfg_pull_none>,
/* ebc_sddo3 */
<3 RK_PD1 2 &pcfg_pull_none>,
/* ebc_sddo4 */
<3 RK_PD2 2 &pcfg_pull_none>,
/* ebc_sddo5 */
<3 RK_PD3 2 &pcfg_pull_none>,
/* ebc_sddo6 */
<3 RK_PD4 2 &pcfg_pull_none>,
/* ebc_sddo7 */
<3 RK_PD5 2 &pcfg_pull_none>,
/* ebc_sddo8 */
<3 RK_PD6 2 &pcfg_pull_none>,
/* ebc_sddo9 */
<3 RK_PD7 2 &pcfg_pull_none>,
/* ebc_sddo10 */
<4 RK_PA0 2 &pcfg_pull_none>,
/* ebc_sddo11 */
<4 RK_PA1 2 &pcfg_pull_none>,
/* ebc_sddo12 */
<4 RK_PA2 2 &pcfg_pull_none>,
/* ebc_sddo13 */
<4 RK_PA3 2 &pcfg_pull_none>,
/* ebc_sddo14 */
<4 RK_PA4 2 &pcfg_pull_none>,
/* ebc_sddo15 */
<4 RK_PA5 2 &pcfg_pull_none>,
/* ebc_sdle */
<4 RK_PB6 2 &pcfg_pull_none>,
/* ebc_sdoe */
<4 RK_PB7 2 &pcfg_pull_none>;
- edpdp {
/omit-if-no-ref/
edpdpm0_pins: edpdpm0-pins {
rockchip,pins =
/* edpdp_hpdinm0 */
<4 RK_PC4 1 &pcfg_pull_none>;
/omit-if-no-ref/
edpdpm1_pins: edpdpm1-pins {
rockchip,pins =
/* edpdp_hpdinm1 */
<0 RK_PC2 2 &pcfg_pull_none>;
- emmc {
/omit-if-no-ref/
emmc_rstnout: emmc-rstnout {
rockchip,pins =
/* emmc_rstn */
<1 RK_PC7 1 &pcfg_pull_none>;
/omit-if-no-ref/
emmc_bus8: emmc-bus8 {
rockchip,pins =
/* emmc_d0 */
<1 RK_PB4 1 &pcfg_pull_up_drv_level_2>,
/* emmc_d1 */
<1 RK_PB5 1 &pcfg_pull_up_drv_level_2>,
/* emmc_d2 */
<1 RK_PB6 1 &pcfg_pull_up_drv_level_2>,
/* emmc_d3 */
<1 RK_PB7 1 &pcfg_pull_up_drv_level_2>,
/* emmc_d4 */
<1 RK_PC0 1 &pcfg_pull_up_drv_level_2>,
/* emmc_d5 */
<1 RK_PC1 1 &pcfg_pull_up_drv_level_2>,
/* emmc_d6 */
<1 RK_PC2 1 &pcfg_pull_up_drv_level_2>,
/* emmc_d7 */
<1 RK_PC3 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
emmc_clk: emmc-clk {
rockchip,pins =
/* emmc_clkout */
<1 RK_PC5 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
emmc_cmd: emmc-cmd {
rockchip,pins =
/* emmc_cmd */
<1 RK_PC4 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
emmc_datastrobe: emmc-datastrobe {
rockchip,pins =
/* emmc_datastrobe */
<1 RK_PC6 1 &pcfg_pull_none>;
- eth0 {
/omit-if-no-ref/
eth0_pins: eth0-pins {
rockchip,pins =
/* eth0_refclko25m */
<2 RK_PC1 2 &pcfg_pull_none>;
- eth1 {
/omit-if-no-ref/
eth1m0_pins: eth1m0-pins {
rockchip,pins =
/* eth1_refclko25mm0 */
<3 RK_PB0 3 &pcfg_pull_none>;
/omit-if-no-ref/
eth1m1_pins: eth1m1-pins {
rockchip,pins =
/* eth1_refclko25mm1 */
<4 RK_PB3 3 &pcfg_pull_none>;
- flash {
/omit-if-no-ref/
flash_pins: flash-pins {
rockchip,pins =
/* flash_ale */
<1 RK_PD0 2 &pcfg_pull_none>,
/* flash_cle */
<1 RK_PC6 3 &pcfg_pull_none>,
/* flash_cs0n */
<1 RK_PD3 2 &pcfg_pull_none>,
/* flash_cs1n */
<1 RK_PD4 2 &pcfg_pull_none>,
/* flash_d0 */
<1 RK_PB4 2 &pcfg_pull_none>,
/* flash_d1 */
<1 RK_PB5 2 &pcfg_pull_none>,
/* flash_d2 */
<1 RK_PB6 2 &pcfg_pull_none>,
/* flash_d3 */
<1 RK_PB7 2 &pcfg_pull_none>,
/* flash_d4 */
<1 RK_PC0 2 &pcfg_pull_none>,
/* flash_d5 */
<1 RK_PC1 2 &pcfg_pull_none>,
/* flash_d6 */
<1 RK_PC2 2 &pcfg_pull_none>,
/* flash_d7 */
<1 RK_PC3 2 &pcfg_pull_none>,
/* flash_dqs */
<1 RK_PC5 2 &pcfg_pull_none>,
/* flash_rdn */
<1 RK_PD2 2 &pcfg_pull_none>,
/* flash_rdy */
<1 RK_PD1 2 &pcfg_pull_none>,
/* flash_volsel */
<0 RK_PA7 1 &pcfg_pull_none>,
/* flash_wpn */
<1 RK_PC7 3 &pcfg_pull_none>,
/* flash_wrn */
<1 RK_PC4 2 &pcfg_pull_none>;
- fspi {
/omit-if-no-ref/
fspi_pins: fspi-pins {
rockchip,pins =
/* fspi_clk */
/* fspi_cs0n */
/* fspi_d0 */
/* fspi_d1 */
<1 RK_PD2 1 &pcfg_pull_none>,
/* fspi_d2 */
<1 RK_PC7 2 &pcfg_pull_none>,
/* fspi_d3 */
<1 RK_PD4 1 &pcfg_pull_none>;
/omit-if-no-ref/
fspi_cs1: fspi-cs1 {
rockchip,pins =
/* fspi_cs1n */
<1 RK_PC6 2 &pcfg_pull_up>;
- gmac0 {
/omit-if-no-ref/
gmac0_miim: gmac0-miim {
rockchip,pins =
/* gmac0_mdc */
<2 RK_PC3 2 &pcfg_pull_none>,
/* gmac0_mdio */
<2 RK_PC4 2 &pcfg_pull_none>;
/omit-if-no-ref/
gmac0_clkinout: gmac0-clkinout {
rockchip,pins =
/* gmac0_mclkinout */
<2 RK_PC2 2 &pcfg_pull_none>;
/omit-if-no-ref/
gmac0_rx_er: gmac0-rx-er {
rockchip,pins =
/* gmac0_rxer */
<2 RK_PC5 2 &pcfg_pull_none>;
/omit-if-no-ref/
gmac0_rx_bus2: gmac0-rx-bus2 {
rockchip,pins =
/* gmac0_rxd0 */
<2 RK_PB6 1 &pcfg_pull_none>,
/* gmac0_rxd1 */
<2 RK_PB7 2 &pcfg_pull_none>,
/* gmac0_rxdvcrs */
<2 RK_PC0 2 &pcfg_pull_none>;
/omit-if-no-ref/
gmac0_tx_bus2: gmac0-tx-bus2 {
rockchip,pins =
/* gmac0_txd0 */
<2 RK_PB3 1 &pcfg_pull_none_drv_level_2>,
/* gmac0_txd1 */
<2 RK_PB4 1 &pcfg_pull_none_drv_level_2>,
/* gmac0_txen */
<2 RK_PB5 1 &pcfg_pull_none>;
/omit-if-no-ref/
gmac0_rgmii_clk: gmac0-rgmii-clk {
rockchip,pins =
/* gmac0_rxclk */
<2 RK_PA5 2 &pcfg_pull_none>,
/* gmac0_txclk */
<2 RK_PB0 2 &pcfg_pull_none_drv_level_1>;
/omit-if-no-ref/
gmac0_rgmii_bus: gmac0-rgmii-bus {
rockchip,pins =
/* gmac0_rxd2 */
<2 RK_PA3 2 &pcfg_pull_none>,
/* gmac0_rxd3 */
<2 RK_PA4 2 &pcfg_pull_none>,
/* gmac0_txd2 */
<2 RK_PA6 2 &pcfg_pull_none_drv_level_2>,
/* gmac0_txd3 */
<2 RK_PA7 2 &pcfg_pull_none_drv_level_2>;
- gmac1 {
/omit-if-no-ref/
rockchip,pins =
/* gmac1_mdcm0 */
<3 RK_PC4 3 &pcfg_pull_none>,
/* gmac1_mdiom0 */
<3 RK_PC5 3 &pcfg_pull_none>;
/omit-if-no-ref/
rockchip,pins =
<3 RK_PC0 3 &pcfg_pull_none>;
/omit-if-no-ref/
gmac1m0_rx_er: gmac1m0-rx-er {
rockchip,pins =
/* gmac1_rxerm0 */
<3 RK_PB4 3 &pcfg_pull_none>;
/omit-if-no-ref/
rockchip,pins =
/* gmac1_rxd0m0 */
<3 RK_PB1 3 &pcfg_pull_none>,
/* gmac1_rxd1m0 */
<3 RK_PB2 3 &pcfg_pull_none>,
<3 RK_PB3 3 &pcfg_pull_none>;
/omit-if-no-ref/
rockchip,pins =
/* gmac1_txd0m0 */
<3 RK_PB5 3 &pcfg_pull_none_drv_level_2>,
/* gmac1_txd1m0 */
<3 RK_PB6 3 &pcfg_pull_none_drv_level_2>,
/* gmac1_txenm0 */
<3 RK_PB7 3 &pcfg_pull_none>;
/omit-if-no-ref/
rockchip,pins =
/* gmac1_rxclkm0 */
<3 RK_PA7 3 &pcfg_pull_none>,
/* gmac1_txclkm0 */
<3 RK_PA6 3 &pcfg_pull_none_drv_level_1>;
/omit-if-no-ref/
rockchip,pins =
/* gmac1_rxd2m0 */
<3 RK_PA4 3 &pcfg_pull_none>,
/* gmac1_rxd3m0 */
<3 RK_PA5 3 &pcfg_pull_none>,
/* gmac1_txd2m0 */
<3 RK_PA2 3 &pcfg_pull_none_drv_level_2>,
/* gmac1_txd3m0 */
<3 RK_PA3 3 &pcfg_pull_none_drv_level_2>;
/omit-if-no-ref/
gmac1m1_miim: gmac1m1-miim {
rockchip,pins =
/* gmac1_mdcm1 */
<4 RK_PB6 3 &pcfg_pull_none>,
/* gmac1_mdiom1 */
<4 RK_PB7 3 &pcfg_pull_none>;
/omit-if-no-ref/
gmac1m1_clkinout: gmac1m1-clkinout {
rockchip,pins =
/* gmac1_mclkinoutm1 */
<4 RK_PC1 3 &pcfg_pull_none>;
/omit-if-no-ref/
gmac1m1_rx_er: gmac1m1-rx-er {
rockchip,pins =
/* gmac1_rxerm1 */
<4 RK_PB2 3 &pcfg_pull_none>;
/omit-if-no-ref/
gmac1m1_rx_bus2: gmac1m1-rx-bus2 {
rockchip,pins =
/* gmac1_rxd0m1 */
<4 RK_PA7 3 &pcfg_pull_none>,
/* gmac1_rxd1m1 */
<4 RK_PB0 3 &pcfg_pull_none>,
/* gmac1_rxdvcrsm1 */
<4 RK_PB1 3 &pcfg_pull_none>;
/omit-if-no-ref/
gmac1m1_tx_bus2: gmac1m1-tx-bus2 {
rockchip,pins =
/* gmac1_txd0m1 */
<4 RK_PA4 3 &pcfg_pull_none_drv_level_2>,
/* gmac1_txd1m1 */
<4 RK_PA5 3 &pcfg_pull_none_drv_level_2>,
/* gmac1_txenm1 */
<4 RK_PA6 3 &pcfg_pull_none>;
/omit-if-no-ref/
gmac1m1_rgmii_clk: gmac1m1-rgmii-clk {
rockchip,pins =
/* gmac1_rxclkm1 */
<4 RK_PA3 3 &pcfg_pull_none>,
/* gmac1_txclkm1 */
<4 RK_PA0 3 &pcfg_pull_none_drv_level_1>;
/omit-if-no-ref/
gmac1m1_rgmii_bus: gmac1m1-rgmii-bus {
rockchip,pins =
/* gmac1_rxd2m1 */
<4 RK_PA1 3 &pcfg_pull_none>,
/* gmac1_rxd3m1 */
<4 RK_PA2 3 &pcfg_pull_none>,
/* gmac1_txd2m1 */
<3 RK_PD6 3 &pcfg_pull_none_drv_level_2>,
/* gmac1_txd3m1 */
<3 RK_PD7 3 &pcfg_pull_none_drv_level_2>;
- gpu {
/omit-if-no-ref/
gpu_pins: gpu-pins {
rockchip,pins =
/* gpu_avs */
<0 RK_PC0 2 &pcfg_pull_none>,
/* gpu_pwren */
<0 RK_PA6 4 &pcfg_pull_none>;
- hdmitx {
/omit-if-no-ref/
hdmitxm0_cec: hdmitxm0-cec {
rockchip,pins =
/* hdmitxm0_cec */
<4 RK_PD1 1 &pcfg_pull_none>;
/omit-if-no-ref/
hdmitxm1_cec: hdmitxm1-cec {
rockchip,pins =
/* hdmitxm1_cec */
<0 RK_PC7 1 &pcfg_pull_none>;
/omit-if-no-ref/
hdmitx_scl: hdmitx-scl {
rockchip,pins =
/* hdmitx_scl */
<4 RK_PC7 1 &pcfg_pull_none>;
/omit-if-no-ref/
hdmitx_sda: hdmitx-sda {
rockchip,pins =
/* hdmitx_sda */
<4 RK_PD0 1 &pcfg_pull_none>;
- i2c0 {
/omit-if-no-ref/
i2c0_xfer: i2c0-xfer {
rockchip,pins =
/* i2c0_scl */
<0 RK_PB1 1 &pcfg_pull_none_smt>,
/* i2c0_sda */
<0 RK_PB2 1 &pcfg_pull_none_smt>;
- i2c1 {
/omit-if-no-ref/
i2c1_xfer: i2c1-xfer {
rockchip,pins =
/* i2c1_scl */
<0 RK_PB3 1 &pcfg_pull_none_smt>,
/* i2c1_sda */
<0 RK_PB4 1 &pcfg_pull_none_smt>;
- i2c2 {
/omit-if-no-ref/
i2c2m0_xfer: i2c2m0-xfer {
rockchip,pins =
/* i2c2_sclm0 */
<0 RK_PB5 1 &pcfg_pull_none_smt>,
/* i2c2_sdam0 */
<0 RK_PB6 1 &pcfg_pull_none_smt>;
/omit-if-no-ref/
i2c2m1_xfer: i2c2m1-xfer {
rockchip,pins =
/* i2c2_sclm1 */
<4 RK_PB5 1 &pcfg_pull_none_smt>,
/* i2c2_sdam1 */
<4 RK_PB4 1 &pcfg_pull_none_smt>;
- i2c3 {
/omit-if-no-ref/
i2c3m0_xfer: i2c3m0-xfer {
rockchip,pins =
/* i2c3_sclm0 */
<1 RK_PA1 1 &pcfg_pull_none_smt>,
/* i2c3_sdam0 */
<1 RK_PA0 1 &pcfg_pull_none_smt>;
/omit-if-no-ref/
i2c3m1_xfer: i2c3m1-xfer {
rockchip,pins =
/* i2c3_sclm1 */
<3 RK_PB5 4 &pcfg_pull_none_smt>,
/* i2c3_sdam1 */
<3 RK_PB6 4 &pcfg_pull_none_smt>;
- i2c4 {
/omit-if-no-ref/
i2c4m0_xfer: i2c4m0-xfer {
rockchip,pins =
/* i2c4_sclm0 */
<4 RK_PB3 1 &pcfg_pull_none_smt>,
/* i2c4_sdam0 */
<4 RK_PB2 1 &pcfg_pull_none_smt>;
/omit-if-no-ref/
i2c4m1_xfer: i2c4m1-xfer {
rockchip,pins =
/* i2c4_sclm1 */
<2 RK_PB2 2 &pcfg_pull_none_smt>,
/* i2c4_sdam1 */
<2 RK_PB1 2 &pcfg_pull_none_smt>;
- i2c5 {
/omit-if-no-ref/
i2c5m0_xfer: i2c5m0-xfer {
rockchip,pins =
/* i2c5_sclm0 */
<3 RK_PB3 4 &pcfg_pull_none_smt>,
/* i2c5_sdam0 */
<3 RK_PB4 4 &pcfg_pull_none_smt>;
/omit-if-no-ref/
i2c5m1_xfer: i2c5m1-xfer {
rockchip,pins =
/* i2c5_sclm1 */
<4 RK_PC7 2 &pcfg_pull_none_smt>,
/* i2c5_sdam1 */
<4 RK_PD0 2 &pcfg_pull_none_smt>;
- i2s1 {
/omit-if-no-ref/
i2s1m0_lrckrx: i2s1m0-lrckrx {
rockchip,pins =
/* i2s1m0_lrckrx */
<1 RK_PA6 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_lrcktx: i2s1m0-lrcktx {
rockchip,pins =
/* i2s1m0_lrcktx */
<1 RK_PA5 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_mclk: i2s1m0-mclk {
rockchip,pins =
/* i2s1m0_mclk */
<1 RK_PA2 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sclkrx: i2s1m0-sclkrx {
rockchip,pins =
/* i2s1m0_sclkrx */
<1 RK_PA4 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sclktx: i2s1m0-sclktx {
rockchip,pins =
/* i2s1m0_sclktx */
<1 RK_PA3 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdi0: i2s1m0-sdi0 {
rockchip,pins =
/* i2s1m0_sdi0 */
<1 RK_PB3 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdi1: i2s1m0-sdi1 {
rockchip,pins =
/* i2s1m0_sdi1 */
<1 RK_PB2 2 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdi2: i2s1m0-sdi2 {
rockchip,pins =
/* i2s1m0_sdi2 */
<1 RK_PB1 2 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdi3: i2s1m0-sdi3 {
rockchip,pins =
/* i2s1m0_sdi3 */
<1 RK_PB0 2 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdo0: i2s1m0-sdo0 {
rockchip,pins =
/* i2s1m0_sdo0 */
<1 RK_PA7 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdo1: i2s1m0-sdo1 {
rockchip,pins =
/* i2s1m0_sdo1 */
<1 RK_PB0 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdo2: i2s1m0-sdo2 {
rockchip,pins =
/* i2s1m0_sdo2 */
<1 RK_PB1 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m0_sdo3: i2s1m0-sdo3 {
rockchip,pins =
/* i2s1m0_sdo3 */
<1 RK_PB2 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_lrckrx: i2s1m1-lrckrx {
rockchip,pins =
/* i2s1m1_lrckrx */
<4 RK_PA7 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_lrcktx: i2s1m1-lrcktx {
rockchip,pins =
/* i2s1m1_lrcktx */
<3 RK_PD0 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_mclk: i2s1m1-mclk {
rockchip,pins =
/* i2s1m1_mclk */
<3 RK_PC6 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sclkrx: i2s1m1-sclkrx {
rockchip,pins =
/* i2s1m1_sclkrx */
<4 RK_PA6 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sclktx: i2s1m1-sclktx {
rockchip,pins =
/* i2s1m1_sclktx */
<3 RK_PC7 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdi0: i2s1m1-sdi0 {
rockchip,pins =
/* i2s1m1_sdi0 */
<3 RK_PD2 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdi1: i2s1m1-sdi1 {
rockchip,pins =
/* i2s1m1_sdi1 */
<3 RK_PD3 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdi2: i2s1m1-sdi2 {
rockchip,pins =
/* i2s1m1_sdi2 */
<3 RK_PD4 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdi3: i2s1m1-sdi3 {
rockchip,pins =
/* i2s1m1_sdi3 */
<3 RK_PD5 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdo0: i2s1m1-sdo0 {
rockchip,pins =
/* i2s1m1_sdo0 */
<3 RK_PD1 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdo1: i2s1m1-sdo1 {
rockchip,pins =
/* i2s1m1_sdo1 */
<4 RK_PB0 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdo2: i2s1m1-sdo2 {
rockchip,pins =
/* i2s1m1_sdo2 */
<4 RK_PB1 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m1_sdo3: i2s1m1-sdo3 {
rockchip,pins =
/* i2s1m1_sdo3 */
<4 RK_PB5 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_lrckrx: i2s1m2-lrckrx {
rockchip,pins =
/* i2s1m2_lrckrx */
<3 RK_PC5 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_lrcktx: i2s1m2-lrcktx {
rockchip,pins =
/* i2s1m2_lrcktx */
<2 RK_PD2 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_mclk: i2s1m2-mclk {
rockchip,pins =
/* i2s1m2_mclk */
<2 RK_PD0 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sclkrx: i2s1m2-sclkrx {
rockchip,pins =
/* i2s1m2_sclkrx */
<3 RK_PC3 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sclktx: i2s1m2-sclktx {
rockchip,pins =
/* i2s1m2_sclktx */
<2 RK_PD1 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdi0: i2s1m2-sdi0 {
rockchip,pins =
/* i2s1m2_sdi0 */
<2 RK_PD3 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdi1: i2s1m2-sdi1 {
rockchip,pins =
/* i2s1m2_sdi1 */
<2 RK_PD4 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdi2: i2s1m2-sdi2 {
rockchip,pins =
/* i2s1m2_sdi2 */
<2 RK_PD5 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdi3: i2s1m2-sdi3 {
rockchip,pins =
/* i2s1m2_sdi3 */
<2 RK_PD6 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdo0: i2s1m2-sdo0 {
rockchip,pins =
/* i2s1m2_sdo0 */
<2 RK_PD7 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdo1: i2s1m2-sdo1 {
rockchip,pins =
/* i2s1m2_sdo1 */
<3 RK_PA0 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdo2: i2s1m2-sdo2 {
rockchip,pins =
/* i2s1m2_sdo2 */
<3 RK_PC1 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s1m2_sdo3: i2s1m2-sdo3 {
rockchip,pins =
/* i2s1m2_sdo3 */
<3 RK_PC2 5 &pcfg_pull_none>;
- i2s2 {
/omit-if-no-ref/
i2s2m0_lrckrx: i2s2m0-lrckrx {
rockchip,pins =
/* i2s2m0_lrckrx */
<2 RK_PC0 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m0_lrcktx: i2s2m0-lrcktx {
rockchip,pins =
/* i2s2m0_lrcktx */
<2 RK_PC3 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m0_mclk: i2s2m0-mclk {
rockchip,pins =
/* i2s2m0_mclk */
<2 RK_PC1 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m0_sclkrx: i2s2m0-sclkrx {
rockchip,pins =
/* i2s2m0_sclkrx */
<2 RK_PB7 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m0_sclktx: i2s2m0-sclktx {
rockchip,pins =
/* i2s2m0_sclktx */
<2 RK_PC2 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m0_sdi: i2s2m0-sdi {
rockchip,pins =
/* i2s2m0_sdi */
<2 RK_PC5 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m0_sdo: i2s2m0-sdo {
rockchip,pins =
/* i2s2m0_sdo */
<2 RK_PC4 1 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m1_lrckrx: i2s2m1-lrckrx {
rockchip,pins =
/* i2s2m1_lrckrx */
<4 RK_PA5 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m1_lrcktx: i2s2m1-lrcktx {
rockchip,pins =
/* i2s2m1_lrcktx */
<4 RK_PA4 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m1_mclk: i2s2m1-mclk {
rockchip,pins =
/* i2s2m1_mclk */
<4 RK_PB6 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m1_sclkrx: i2s2m1-sclkrx {
rockchip,pins =
/* i2s2m1_sclkrx */
<4 RK_PC1 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m1_sclktx: i2s2m1-sclktx {
rockchip,pins =
/* i2s2m1_sclktx */
<4 RK_PB7 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m1_sdi: i2s2m1-sdi {
rockchip,pins =
/* i2s2m1_sdi */
<4 RK_PB2 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s2m1_sdo: i2s2m1-sdo {
rockchip,pins =
/* i2s2m1_sdo */
<4 RK_PB3 5 &pcfg_pull_none>;
- i2s3 {
/omit-if-no-ref/
i2s3m0_lrck: i2s3m0-lrck {
rockchip,pins =
/* i2s3m0_lrck */
<3 RK_PA4 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m0_mclk: i2s3m0-mclk {
rockchip,pins =
/* i2s3m0_mclk */
<3 RK_PA2 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m0_sclk: i2s3m0-sclk {
rockchip,pins =
/* i2s3m0_sclk */
<3 RK_PA3 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m0_sdi: i2s3m0-sdi {
rockchip,pins =
/* i2s3m0_sdi */
<3 RK_PA6 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m0_sdo: i2s3m0-sdo {
rockchip,pins =
/* i2s3m0_sdo */
<3 RK_PA5 4 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m1_lrck: i2s3m1-lrck {
rockchip,pins =
/* i2s3m1_lrck */
<4 RK_PC4 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m1_mclk: i2s3m1-mclk {
rockchip,pins =
/* i2s3m1_mclk */
<4 RK_PC2 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m1_sclk: i2s3m1-sclk {
rockchip,pins =
/* i2s3m1_sclk */
<4 RK_PC3 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m1_sdi: i2s3m1-sdi {
rockchip,pins =
/* i2s3m1_sdi */
<4 RK_PC6 5 &pcfg_pull_none>;
/omit-if-no-ref/
i2s3m1_sdo: i2s3m1-sdo {
rockchip,pins =
/* i2s3m1_sdo */
<4 RK_PC5 5 &pcfg_pull_none>;
- isp {
/omit-if-no-ref/
isp_pins: isp-pins {
rockchip,pins =
/* isp_flashtrigin */
<4 RK_PB4 4 &pcfg_pull_none>,
/* isp_flashtrigout */
<4 RK_PA6 1 &pcfg_pull_none>,
/* isp_prelighttrig */
<4 RK_PB1 1 &pcfg_pull_none>;
- jtag {
/omit-if-no-ref/
jtag_pins: jtag-pins {
rockchip,pins =
/* jtag_tck */
<1 RK_PD7 2 &pcfg_pull_none>,
/* jtag_tms */
<2 RK_PA0 2 &pcfg_pull_none>;
- lcdc {
/omit-if-no-ref/
lcdc_ctl: lcdc-ctl {
rockchip,pins =
/* lcdc_clk */
<3 RK_PA0 1 &pcfg_pull_none>,
/* lcdc_d0 */
<2 RK_PD0 1 &pcfg_pull_none>,
/* lcdc_d1 */
<2 RK_PD1 1 &pcfg_pull_none>,
/* lcdc_d2 */
<2 RK_PD2 1 &pcfg_pull_none>,
/* lcdc_d3 */
<2 RK_PD3 1 &pcfg_pull_none>,
/* lcdc_d4 */
<2 RK_PD4 1 &pcfg_pull_none>,
/* lcdc_d5 */
<2 RK_PD5 1 &pcfg_pull_none>,
/* lcdc_d6 */
<2 RK_PD6 1 &pcfg_pull_none>,
/* lcdc_d7 */
<2 RK_PD7 1 &pcfg_pull_none>,
/* lcdc_d8 */
<3 RK_PA1 1 &pcfg_pull_none>,
/* lcdc_d9 */
<3 RK_PA2 1 &pcfg_pull_none>,
/* lcdc_d10 */
<3 RK_PA3 1 &pcfg_pull_none>,
/* lcdc_d11 */
<3 RK_PA4 1 &pcfg_pull_none>,
/* lcdc_d12 */
<3 RK_PA5 1 &pcfg_pull_none>,
/* lcdc_d13 */
<3 RK_PA6 1 &pcfg_pull_none>,
/* lcdc_d14 */
<3 RK_PA7 1 &pcfg_pull_none>,
/* lcdc_d15 */
<3 RK_PB0 1 &pcfg_pull_none>,
/* lcdc_d16 */
<3 RK_PB1 1 &pcfg_pull_none>,
/* lcdc_d17 */
<3 RK_PB2 1 &pcfg_pull_none>,
/* lcdc_d18 */
<3 RK_PB3 1 &pcfg_pull_none>,
/* lcdc_d19 */
<3 RK_PB4 1 &pcfg_pull_none>,
/* lcdc_d20 */
<3 RK_PB5 1 &pcfg_pull_none>,
/* lcdc_d21 */
<3 RK_PB6 1 &pcfg_pull_none>,
/* lcdc_d22 */
<3 RK_PB7 1 &pcfg_pull_none>,
/* lcdc_d23 */
<3 RK_PC0 1 &pcfg_pull_none>,
/* lcdc_den */
<3 RK_PC3 1 &pcfg_pull_none>,
/* lcdc_hsync */
<3 RK_PC1 1 &pcfg_pull_none>,
/* lcdc_vsync */
<3 RK_PC2 1 &pcfg_pull_none>;
- mcu {
/omit-if-no-ref/
mcu_pins: mcu-pins {
rockchip,pins =
/* mcu_jtagtck */
<0 RK_PB4 4 &pcfg_pull_none>,
/* mcu_jtagtdi */
<0 RK_PC1 4 &pcfg_pull_none>,
/* mcu_jtagtdo */
<0 RK_PB3 4 &pcfg_pull_none>,
/* mcu_jtagtms */
<0 RK_PC2 4 &pcfg_pull_none>,
/* mcu_jtagtrstn */
<0 RK_PC3 4 &pcfg_pull_none>;
- npu {
/omit-if-no-ref/
npu_pins: npu-pins {
rockchip,pins =
/* npu_avs */
<0 RK_PC1 2 &pcfg_pull_none>;
- pcie20 {
/omit-if-no-ref/
pcie20m0_pins: pcie20m0-pins {
rockchip,pins =
/* pcie20_clkreqnm0 */
<0 RK_PA5 3 &pcfg_pull_none>,
/* pcie20_perstnm0 */
<0 RK_PB6 3 &pcfg_pull_none>,
/* pcie20_wakenm0 */
<0 RK_PB5 3 &pcfg_pull_none>;
/omit-if-no-ref/
pcie20m1_pins: pcie20m1-pins {
rockchip,pins =
/* pcie20_clkreqnm1 */
<2 RK_PD0 4 &pcfg_pull_none>,
/* pcie20_perstnm1 */
<3 RK_PC1 4 &pcfg_pull_none>,
/* pcie20_wakenm1 */
<2 RK_PD1 4 &pcfg_pull_none>;
/omit-if-no-ref/
pcie20m2_pins: pcie20m2-pins {
rockchip,pins =
/* pcie20_clkreqnm2 */
<1 RK_PB0 4 &pcfg_pull_none>,
/* pcie20_perstnm2 */
<1 RK_PB2 4 &pcfg_pull_none>,
/* pcie20_wakenm2 */
<1 RK_PB1 4 &pcfg_pull_none>;
/omit-if-no-ref/
pcie20_buttonrstn: pcie20-buttonrstn {
rockchip,pins =
/* pcie20_buttonrstn */
<0 RK_PB4 3 &pcfg_pull_none>;
- pcie30x1 {
/omit-if-no-ref/
pcie30x1m0_pins: pcie30x1m0-pins {
rockchip,pins =
/* pcie30x1_clkreqnm0 */
<0 RK_PA4 3 &pcfg_pull_none>,
/* pcie30x1_perstnm0 */
<0 RK_PC3 3 &pcfg_pull_none>,
/* pcie30x1_wakenm0 */
<0 RK_PC2 3 &pcfg_pull_none>;
/omit-if-no-ref/
pcie30x1m1_pins: pcie30x1m1-pins {
rockchip,pins =
/* pcie30x1_clkreqnm1 */
<2 RK_PD2 4 &pcfg_pull_none>,
/* pcie30x1_perstnm1 */
<3 RK_PA1 4 &pcfg_pull_none>,
/* pcie30x1_wakenm1 */
<2 RK_PD3 4 &pcfg_pull_none>;
/omit-if-no-ref/
pcie30x1m2_pins: pcie30x1m2-pins {
rockchip,pins =
/* pcie30x1_clkreqnm2 */
<1 RK_PA5 4 &pcfg_pull_none>,
/* pcie30x1_perstnm2 */
<1 RK_PA2 4 &pcfg_pull_none>,
/* pcie30x1_wakenm2 */
<1 RK_PA3 4 &pcfg_pull_none>;
/omit-if-no-ref/
pcie30x1_buttonrstn: pcie30x1-buttonrstn {
rockchip,pins =
/* pcie30x1_buttonrstn */
<0 RK_PB3 3 &pcfg_pull_none>;
- pcie30x2 {
/omit-if-no-ref/
pcie30x2m0_pins: pcie30x2m0-pins {
rockchip,pins =
/* pcie30x2_clkreqnm0 */
<0 RK_PA6 2 &pcfg_pull_none>,
/* pcie30x2_perstnm0 */
<0 RK_PC6 3 &pcfg_pull_none>,
/* pcie30x2_wakenm0 */
<0 RK_PC5 3 &pcfg_pull_none>;
/omit-if-no-ref/
pcie30x2m1_pins: pcie30x2m1-pins {
rockchip,pins =
/* pcie30x2_clkreqnm1 */
<2 RK_PD4 4 &pcfg_pull_none>,
/* pcie30x2_perstnm1 */
<2 RK_PD6 4 &pcfg_pull_none>,
/* pcie30x2_wakenm1 */
<2 RK_PD5 4 &pcfg_pull_none>;
/omit-if-no-ref/
pcie30x2m2_pins: pcie30x2m2-pins {
rockchip,pins =
/* pcie30x2_clkreqnm2 */
<4 RK_PC2 4 &pcfg_pull_none>,
/* pcie30x2_perstnm2 */
<4 RK_PC4 4 &pcfg_pull_none>,
/* pcie30x2_wakenm2 */
<4 RK_PC3 4 &pcfg_pull_none>;
/omit-if-no-ref/
pcie30x2_buttonrstn: pcie30x2-buttonrstn {
rockchip,pins =
/* pcie30x2_buttonrstn */
<0 RK_PB0 3 &pcfg_pull_none>;
- pdm {
/omit-if-no-ref/
pdmm0_clk: pdmm0-clk {
rockchip,pins =
/* pdm_clk0m0 */
<1 RK_PA6 3 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm0_clk1: pdmm0-clk1 {
rockchip,pins =
/* pdmm0_clk1 */
<1 RK_PA4 3 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm0_sdi0: pdmm0-sdi0 {
rockchip,pins =
/* pdmm0_sdi0 */
<1 RK_PB3 2 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm0_sdi1: pdmm0-sdi1 {
rockchip,pins =
/* pdmm0_sdi1 */
<1 RK_PB2 3 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm0_sdi2: pdmm0-sdi2 {
rockchip,pins =
/* pdmm0_sdi2 */
<1 RK_PB1 3 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm0_sdi3: pdmm0-sdi3 {
rockchip,pins =
/* pdmm0_sdi3 */
<1 RK_PB0 3 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm1_clk: pdmm1-clk {
rockchip,pins =
/* pdm_clk0m1 */
<3 RK_PD6 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm1_clk1: pdmm1-clk1 {
rockchip,pins =
/* pdmm1_clk1 */
<4 RK_PA0 4 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm1_sdi0: pdmm1-sdi0 {
rockchip,pins =
/* pdmm1_sdi0 */
<3 RK_PD7 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm1_sdi1: pdmm1-sdi1 {
rockchip,pins =
/* pdmm1_sdi1 */
<4 RK_PA1 4 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm1_sdi2: pdmm1-sdi2 {
rockchip,pins =
/* pdmm1_sdi2 */
<4 RK_PA2 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm1_sdi3: pdmm1-sdi3 {
rockchip,pins =
/* pdmm1_sdi3 */
<4 RK_PA3 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm2_clk1: pdmm2-clk1 {
rockchip,pins =
/* pdmm2_clk1 */
<3 RK_PC4 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm2_sdi0: pdmm2-sdi0 {
rockchip,pins =
/* pdmm2_sdi0 */
<3 RK_PB3 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm2_sdi1: pdmm2-sdi1 {
rockchip,pins =
/* pdmm2_sdi1 */
<3 RK_PB4 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm2_sdi2: pdmm2-sdi2 {
rockchip,pins =
/* pdmm2_sdi2 */
<3 RK_PB7 5 &pcfg_pull_none>;
/omit-if-no-ref/
pdmm2_sdi3: pdmm2-sdi3 {
rockchip,pins =
/* pdmm2_sdi3 */
<3 RK_PC0 5 &pcfg_pull_none>;
- pmic {
/omit-if-no-ref/
pmic_pins: pmic-pins {
rockchip,pins =
/* pmic_sleep */
<0 RK_PA2 1 &pcfg_pull_none>;
- pmu {
/omit-if-no-ref/
pmu_pins: pmu-pins {
rockchip,pins =
/* pmu_debug0 */
<0 RK_PA5 4 &pcfg_pull_none>,
/* pmu_debug1 */
<0 RK_PA6 3 &pcfg_pull_none>,
/* pmu_debug2 */
<0 RK_PC4 4 &pcfg_pull_none>,
/* pmu_debug3 */
<0 RK_PC5 4 &pcfg_pull_none>,
/* pmu_debug4 */
<0 RK_PC6 4 &pcfg_pull_none>,
/* pmu_debug5 */
<0 RK_PC7 4 &pcfg_pull_none>;
- pwm0 {
/omit-if-no-ref/
pwm0m0_pins: pwm0m0-pins {
rockchip,pins =
/* pwm0_m0 */
<0 RK_PB7 1 &pcfg_pull_none>;
/omit-if-no-ref/
pwm0m1_pins: pwm0m1-pins {
rockchip,pins =
/* pwm0_m1 */
<0 RK_PC7 2 &pcfg_pull_none>;
- pwm1 {
/omit-if-no-ref/
pwm1m0_pins: pwm1m0-pins {
rockchip,pins =
/* pwm1_m0 */
<0 RK_PC0 1 &pcfg_pull_none>;
/omit-if-no-ref/
pwm1m1_pins: pwm1m1-pins {
rockchip,pins =
/* pwm1_m1 */
<0 RK_PB5 4 &pcfg_pull_none>;
- pwm2 {
/omit-if-no-ref/
pwm2m0_pins: pwm2m0-pins {
rockchip,pins =
/* pwm2_m0 */
<0 RK_PC1 1 &pcfg_pull_none>;
/omit-if-no-ref/
pwm2m1_pins: pwm2m1-pins {
rockchip,pins =
/* pwm2_m1 */
<0 RK_PB6 4 &pcfg_pull_none>;
- pwm3 {
/omit-if-no-ref/
pwm3_pins: pwm3-pins {
rockchip,pins =
/* pwm3_ir */
<0 RK_PC2 1 &pcfg_pull_none>;
- pwm4 {
/omit-if-no-ref/
pwm4_pins: pwm4-pins {
rockchip,pins =
/* pwm4 */
<0 RK_PC3 1 &pcfg_pull_none>;
- pwm5 {
/omit-if-no-ref/
pwm5_pins: pwm5-pins {
rockchip,pins =
/* pwm5 */
<0 RK_PC4 1 &pcfg_pull_none>;
- pwm6 {
/omit-if-no-ref/
pwm6_pins: pwm6-pins {
rockchip,pins =
/* pwm6 */
<0 RK_PC5 1 &pcfg_pull_none>;
- pwm7 {
/omit-if-no-ref/
pwm7_pins: pwm7-pins {
rockchip,pins =
/* pwm7_ir */
<0 RK_PC6 1 &pcfg_pull_none>;
- pwm8 {
/omit-if-no-ref/
pwm8m0_pins: pwm8m0-pins {
rockchip,pins =
/* pwm8_m0 */
<3 RK_PB1 5 &pcfg_pull_none>;
/omit-if-no-ref/
pwm8m1_pins: pwm8m1-pins {
rockchip,pins =
/* pwm8_m1 */
<1 RK_PD5 4 &pcfg_pull_none>;
- pwm9 {
/omit-if-no-ref/
pwm9m0_pins: pwm9m0-pins {
rockchip,pins =
/* pwm9_m0 */
<3 RK_PB2 5 &pcfg_pull_none>;
/omit-if-no-ref/
pwm9m1_pins: pwm9m1-pins {
rockchip,pins =
/* pwm9_m1 */
<1 RK_PD6 4 &pcfg_pull_none>;
- pwm10 {
/omit-if-no-ref/
pwm10m0_pins: pwm10m0-pins {
rockchip,pins =
/* pwm10_m0 */
<3 RK_PB5 5 &pcfg_pull_none>;
/omit-if-no-ref/
pwm10m1_pins: pwm10m1-pins {
rockchip,pins =
/* pwm10_m1 */
<2 RK_PA1 2 &pcfg_pull_none>;
- pwm11 {
/omit-if-no-ref/
pwm11m0_pins: pwm11m0-pins {
rockchip,pins =
/* pwm11_irm0 */
<3 RK_PB6 5 &pcfg_pull_none>;
/omit-if-no-ref/
pwm11m1_pins: pwm11m1-pins {
rockchip,pins =
/* pwm11_irm1 */
<4 RK_PC0 3 &pcfg_pull_none>;
- pwm12 {
/omit-if-no-ref/
pwm12m0_pins: pwm12m0-pins {
rockchip,pins =
/* pwm12_m0 */
<3 RK_PB7 2 &pcfg_pull_none>;
/omit-if-no-ref/
pwm12m1_pins: pwm12m1-pins {
rockchip,pins =
/* pwm12_m1 */
<4 RK_PC5 1 &pcfg_pull_none>;
- pwm13 {
/omit-if-no-ref/
pwm13m0_pins: pwm13m0-pins {
rockchip,pins =
/* pwm13_m0 */
<3 RK_PC0 2 &pcfg_pull_none>;
/omit-if-no-ref/
pwm13m1_pins: pwm13m1-pins {
rockchip,pins =
/* pwm13_m1 */
<4 RK_PC6 1 &pcfg_pull_none>;
- pwm14 {
/omit-if-no-ref/
pwm14m0_pins: pwm14m0-pins {
rockchip,pins =
/* pwm14_m0 */
<3 RK_PC4 1 &pcfg_pull_none>;
/omit-if-no-ref/
pwm14m1_pins: pwm14m1-pins {
rockchip,pins =
/* pwm14_m1 */
<4 RK_PC2 1 &pcfg_pull_none>;
- pwm15 {
/omit-if-no-ref/
pwm15m0_pins: pwm15m0-pins {
rockchip,pins =
/* pwm15_irm0 */
<3 RK_PC5 1 &pcfg_pull_none>;
/omit-if-no-ref/
pwm15m1_pins: pwm15m1-pins {
rockchip,pins =
/* pwm15_irm1 */
<4 RK_PC3 1 &pcfg_pull_none>;
- refclk {
/omit-if-no-ref/
refclk_pins: refclk-pins {
rockchip,pins =
/* refclk_ou */
<0 RK_PA0 1 &pcfg_pull_none>;
- sata {
/omit-if-no-ref/
sata_pins: sata-pins {
rockchip,pins =
/* sata_cpdet */
<0 RK_PA4 2 &pcfg_pull_none>,
/* sata_cppod */
<0 RK_PA6 1 &pcfg_pull_none>,
/* sata_mpswitch */
<0 RK_PA5 2 &pcfg_pull_none>;
- sata0 {
/omit-if-no-ref/
sata0_pins: sata0-pins {
rockchip,pins =
/* sata0_actled */
<4 RK_PC6 3 &pcfg_pull_none>;
- sata1 {
/omit-if-no-ref/
sata1_pins: sata1-pins {
rockchip,pins =
/* sata1_actled */
<4 RK_PC5 3 &pcfg_pull_none>;
- sata2 {
/omit-if-no-ref/
sata2_pins: sata2-pins {
rockchip,pins =
/* sata2_actled */
<4 RK_PC4 3 &pcfg_pull_none>;
- scr {
/omit-if-no-ref/
scr_pins: scr-pins {
rockchip,pins =
/* scr_clk */
<1 RK_PA2 3 &pcfg_pull_none>,
/* scr_det */
<1 RK_PA7 3 &pcfg_pull_up>,
/* scr_io */
<1 RK_PA3 3 &pcfg_pull_up>,
/* scr_rst */
<1 RK_PA5 3 &pcfg_pull_none>;
- sdmmc0 {
/omit-if-no-ref/
sdmmc0_bus4: sdmmc0-bus4 {
rockchip,pins =
/* sdmmc0_d0 */
<1 RK_PD5 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc0_d1 */
<1 RK_PD6 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc0_d2 */
<1 RK_PD7 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc0_d3 */
<2 RK_PA0 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc0_clk: sdmmc0-clk {
rockchip,pins =
/* sdmmc0_clk */
<2 RK_PA2 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc0_cmd: sdmmc0-cmd {
rockchip,pins =
/* sdmmc0_cmd */
<2 RK_PA1 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc0_det: sdmmc0-det {
rockchip,pins =
/* sdmmc0_det */
<0 RK_PA4 1 &pcfg_pull_up>;
/omit-if-no-ref/
sdmmc0_pwren: sdmmc0-pwren {
rockchip,pins =
/* sdmmc0_pwren */
<0 RK_PA5 1 &pcfg_pull_none>;
- sdmmc1 {
/omit-if-no-ref/
sdmmc1_bus4: sdmmc1-bus4 {
rockchip,pins =
/* sdmmc1_d0 */
<2 RK_PA3 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc1_d1 */
<2 RK_PA4 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc1_d2 */
<2 RK_PA5 1 &pcfg_pull_up_drv_level_2>,
/* sdmmc1_d3 */
<2 RK_PA6 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc1_clk: sdmmc1-clk {
rockchip,pins =
/* sdmmc1_clk */
<2 RK_PB0 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc1_cmd: sdmmc1-cmd {
rockchip,pins =
/* sdmmc1_cmd */
<2 RK_PA7 1 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc1_det: sdmmc1-det {
rockchip,pins =
/* sdmmc1_det */
<2 RK_PB2 1 &pcfg_pull_up>;
/omit-if-no-ref/
sdmmc1_pwren: sdmmc1-pwren {
rockchip,pins =
/* sdmmc1_pwren */
<2 RK_PB1 1 &pcfg_pull_none>;
- sdmmc2 {
/omit-if-no-ref/
sdmmc2m0_bus4: sdmmc2m0-bus4 {
rockchip,pins =
/* sdmmc2_d0m0 */
<3 RK_PC6 3 &pcfg_pull_up_drv_level_2>,
/* sdmmc2_d1m0 */
<3 RK_PC7 3 &pcfg_pull_up_drv_level_2>,
/* sdmmc2_d2m0 */
<3 RK_PD0 3 &pcfg_pull_up_drv_level_2>,
/* sdmmc2_d3m0 */
<3 RK_PD1 3 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc2m0_clk: sdmmc2m0-clk {
rockchip,pins =
/* sdmmc2_clkm0 */
<3 RK_PD3 3 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc2m0_cmd: sdmmc2m0-cmd {
rockchip,pins =
/* sdmmc2_cmdm0 */
<3 RK_PD2 3 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc2m0_det: sdmmc2m0-det {
rockchip,pins =
/* sdmmc2_detm0 */
<3 RK_PD4 3 &pcfg_pull_up>;
/omit-if-no-ref/
sdmmc2m0_pwren: sdmmc2m0-pwren {
rockchip,pins =
/* sdmmc2m0_pwren */
<3 RK_PD5 3 &pcfg_pull_none>;
/omit-if-no-ref/
sdmmc2m1_bus4: sdmmc2m1-bus4 {
rockchip,pins =
/* sdmmc2_d0m1 */
<3 RK_PA1 5 &pcfg_pull_up_drv_level_2>,
/* sdmmc2_d1m1 */
<3 RK_PA2 5 &pcfg_pull_up_drv_level_2>,
/* sdmmc2_d2m1 */
<3 RK_PA3 5 &pcfg_pull_up_drv_level_2>,
/* sdmmc2_d3m1 */
<3 RK_PA4 5 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc2m1_clk: sdmmc2m1-clk {
rockchip,pins =
/* sdmmc2_clkm1 */
<3 RK_PA6 5 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc2m1_cmd: sdmmc2m1-cmd {
rockchip,pins =
/* sdmmc2_cmdm1 */
<3 RK_PA5 5 &pcfg_pull_up_drv_level_2>;
/omit-if-no-ref/
sdmmc2m1_det: sdmmc2m1-det {
rockchip,pins =
/* sdmmc2_detm1 */
<3 RK_PA7 4 &pcfg_pull_up>;
/omit-if-no-ref/
sdmmc2m1_pwren: sdmmc2m1-pwren {
rockchip,pins =
/* sdmmc2m1_pwren */
<3 RK_PB0 4 &pcfg_pull_none>;
- spdif {
/omit-if-no-ref/
spdifm0_tx: spdifm0-tx {
rockchip,pins =
/* spdifm0_tx */
<1 RK_PA4 4 &pcfg_pull_none>;
/omit-if-no-ref/
spdifm1_tx: spdifm1-tx {
rockchip,pins =
/* spdifm1_tx */
<3 RK_PC5 2 &pcfg_pull_none>;
/omit-if-no-ref/
spdifm2_tx: spdifm2-tx {
rockchip,pins =
/* spdifm2_tx */
<4 RK_PC4 2 &pcfg_pull_none>;
- spi0 {
/omit-if-no-ref/
spi0m0_pins: spi0m0-pins {
rockchip,pins =
/* spi0_clkm0 */
<0 RK_PB5 2 &pcfg_pull_none>,
/* spi0_misom0 */
<0 RK_PC5 2 &pcfg_pull_none>,
/* spi0_mosim0 */
<0 RK_PB6 2 &pcfg_pull_none>;
/omit-if-no-ref/
spi0m0_cs0: spi0m0-cs0 {
rockchip,pins =
/* spi0_cs0m0 */
<0 RK_PC6 2 &pcfg_pull_none>;
/omit-if-no-ref/
spi0m0_cs1: spi0m0-cs1 {
rockchip,pins =
/* spi0_cs1m0 */
<0 RK_PC4 2 &pcfg_pull_none>;
/omit-if-no-ref/
spi0m1_pins: spi0m1-pins {
rockchip,pins =
/* spi0_clkm1 */
<2 RK_PD3 3 &pcfg_pull_none>,
/* spi0_misom1 */
<2 RK_PD0 3 &pcfg_pull_none>,
/* spi0_mosim1 */
<2 RK_PD1 3 &pcfg_pull_none>;
/omit-if-no-ref/
spi0m1_cs0: spi0m1-cs0 {
rockchip,pins =
/* spi0_cs0m1 */
<2 RK_PD2 3 &pcfg_pull_none>;
- spi1 {
/omit-if-no-ref/
spi1m0_pins: spi1m0-pins {
rockchip,pins =
/* spi1_clkm0 */
<2 RK_PB5 3 &pcfg_pull_none>,
/* spi1_misom0 */
<2 RK_PB6 3 &pcfg_pull_none>,
/* spi1_mosim0 */
<2 RK_PB7 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi1m0_cs0: spi1m0-cs0 {
rockchip,pins =
/* spi1_cs0m0 */
<2 RK_PC0 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi1m0_cs1: spi1m0-cs1 {
rockchip,pins =
/* spi1_cs1m0 */
<2 RK_PC6 3 &pcfg_pull_none>;
/omit-if-no-ref/
spi1m1_pins: spi1m1-pins {
rockchip,pins =
/* spi1_clkm1 */
<3 RK_PC3 3 &pcfg_pull_none>,
/* spi1_misom1 */
<3 RK_PC2 3 &pcfg_pull_none>,
/* spi1_mosim1 */
<3 RK_PC1 3 &pcfg_pull_none>;
/omit-if-no-ref/
spi1m1_cs0: spi1m1-cs0 {
rockchip,pins =
/* spi1_cs0m1 */
<3 RK_PA1 3 &pcfg_pull_none>;
- spi2 {
/omit-if-no-ref/
spi2m0_pins: spi2m0-pins {
rockchip,pins =
/* spi2_clkm0 */
<2 RK_PC1 4 &pcfg_pull_none>,
/* spi2_misom0 */
<2 RK_PC2 4 &pcfg_pull_none>,
/* spi2_mosim0 */
<2 RK_PC3 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi2m0_cs0: spi2m0-cs0 {
rockchip,pins =
/* spi2_cs0m0 */
<2 RK_PC4 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi2m0_cs1: spi2m0-cs1 {
rockchip,pins =
/* spi2_cs1m0 */
<2 RK_PC5 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi2m1_pins: spi2m1-pins {
rockchip,pins =
/* spi2_clkm1 */
<3 RK_PA0 3 &pcfg_pull_none>,
/* spi2_misom1 */
<2 RK_PD7 3 &pcfg_pull_none>,
/* spi2_mosim1 */
<2 RK_PD6 3 &pcfg_pull_none>;
/omit-if-no-ref/
spi2m1_cs0: spi2m1-cs0 {
rockchip,pins =
/* spi2_cs0m1 */
<2 RK_PD5 3 &pcfg_pull_none>;
/omit-if-no-ref/
spi2m1_cs1: spi2m1-cs1 {
rockchip,pins =
/* spi2_cs1m1 */
<2 RK_PD4 3 &pcfg_pull_none>;
- spi3 {
/omit-if-no-ref/
spi3m0_pins: spi3m0-pins {
rockchip,pins =
/* spi3_clkm0 */
<4 RK_PB3 4 &pcfg_pull_none>,
/* spi3_misom0 */
<4 RK_PB0 4 &pcfg_pull_none>,
/* spi3_mosim0 */
<4 RK_PB2 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi3m0_cs0: spi3m0-cs0 {
rockchip,pins =
/* spi3_cs0m0 */
<4 RK_PA6 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi3m0_cs1: spi3m0-cs1 {
rockchip,pins =
/* spi3_cs1m0 */
<4 RK_PA7 4 &pcfg_pull_none>;
/omit-if-no-ref/
spi3m1_pins: spi3m1-pins {
rockchip,pins =
/* spi3_clkm1 */
<4 RK_PC2 2 &pcfg_pull_none>,
/* spi3_misom1 */
<4 RK_PC5 2 &pcfg_pull_none>,
/* spi3_mosim1 */
<4 RK_PC3 2 &pcfg_pull_none>;
/omit-if-no-ref/
spi3m1_cs0: spi3m1-cs0 {
rockchip,pins =
/* spi3_cs0m1 */
<4 RK_PC6 2 &pcfg_pull_none>;
/omit-if-no-ref/
spi3m1_cs1: spi3m1-cs1 {
rockchip,pins =
/* spi3_cs1m1 */
<4 RK_PD1 2 &pcfg_pull_none>;
- tsadc {
/omit-if-no-ref/
tsadcm0_shut: tsadcm0-shut {
rockchip,pins =
/* tsadcm0_shut */
<0 RK_PA1 1 &pcfg_pull_none>;
/omit-if-no-ref/
tsadcm1_shut: tsadcm1-shut {
rockchip,pins =
/* tsadcm1_shut */
<0 RK_PA2 2 &pcfg_pull_none>;
/omit-if-no-ref/
tsadc_shutorg: tsadc-shutorg {
rockchip,pins =
/* tsadc_shutorg */
<0 RK_PA1 2 &pcfg_pull_none>;
- uart0 {
/omit-if-no-ref/
uart0_xfer: uart0-xfer {
rockchip,pins =
/* uart0_rx */
<0 RK_PC0 3 &pcfg_pull_up>,
/* uart0_tx */
<0 RK_PC1 3 &pcfg_pull_up>;
/omit-if-no-ref/
uart0_ctsn: uart0-ctsn {
rockchip,pins =
/* uart0_ctsn */
<0 RK_PC7 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart0_rtsn: uart0-rtsn {
rockchip,pins =
/* uart0_rtsn */
<0 RK_PC4 3 &pcfg_pull_none>;
- uart1 {
/omit-if-no-ref/
uart1m0_xfer: uart1m0-xfer {
rockchip,pins =
/* uart1_rxm0 */
<2 RK_PB3 2 &pcfg_pull_up>,
/* uart1_txm0 */
<2 RK_PB4 2 &pcfg_pull_up>;
/omit-if-no-ref/
uart1m0_ctsn: uart1m0-ctsn {
rockchip,pins =
/* uart1m0_ctsn */
<2 RK_PB6 2 &pcfg_pull_none>;
/omit-if-no-ref/
uart1m0_rtsn: uart1m0-rtsn {
rockchip,pins =
/* uart1m0_rtsn */
<2 RK_PB5 2 &pcfg_pull_none>;
/omit-if-no-ref/
uart1m1_xfer: uart1m1-xfer {
rockchip,pins =
/* uart1_rxm1 */
<3 RK_PD7 4 &pcfg_pull_up>,
/* uart1_txm1 */
<3 RK_PD6 4 &pcfg_pull_up>;
/omit-if-no-ref/
uart1m1_ctsn: uart1m1-ctsn {
rockchip,pins =
/* uart1m1_ctsn */
<4 RK_PC1 4 &pcfg_pull_none>;
/omit-if-no-ref/
uart1m1_rtsn: uart1m1-rtsn {
rockchip,pins =
/* uart1m1_rtsn */
<4 RK_PB6 4 &pcfg_pull_none>;
- uart2 {
/omit-if-no-ref/
uart2m0_xfer: uart2m0-xfer {
rockchip,pins =
/* uart2_rxm0 */
<0 RK_PD0 1 &pcfg_pull_up>,
/* uart2_txm0 */
<0 RK_PD1 1 &pcfg_pull_up>;
/omit-if-no-ref/
uart2m1_xfer: uart2m1-xfer {
rockchip,pins =
/* uart2_rxm1 */
<1 RK_PD6 2 &pcfg_pull_up>,
/* uart2_txm1 */
<1 RK_PD5 2 &pcfg_pull_up>;
- uart3 {
/omit-if-no-ref/
uart3m0_xfer: uart3m0-xfer {
rockchip,pins =
/* uart3_rxm0 */
<1 RK_PA0 2 &pcfg_pull_up>,
/* uart3_txm0 */
<1 RK_PA1 2 &pcfg_pull_up>;
/omit-if-no-ref/
uart3m0_ctsn: uart3m0-ctsn {
rockchip,pins =
/* uart3m0_ctsn */
<1 RK_PA3 2 &pcfg_pull_none>;
/omit-if-no-ref/
uart3m0_rtsn: uart3m0-rtsn {
rockchip,pins =
/* uart3m0_rtsn */
<1 RK_PA2 2 &pcfg_pull_none>;
/omit-if-no-ref/
uart3m1_xfer: uart3m1-xfer {
rockchip,pins =
/* uart3_rxm1 */
<3 RK_PC0 4 &pcfg_pull_up>,
/* uart3_txm1 */
<3 RK_PB7 4 &pcfg_pull_up>;
- uart4 {
/omit-if-no-ref/
uart4m0_xfer: uart4m0-xfer {
rockchip,pins =
/* uart4_rxm0 */
<1 RK_PA4 2 &pcfg_pull_up>,
/* uart4_txm0 */
<1 RK_PA6 2 &pcfg_pull_up>;
/omit-if-no-ref/
uart4m0_ctsn: uart4m0-ctsn {
rockchip,pins =
/* uart4m0_ctsn */
<1 RK_PA7 2 &pcfg_pull_none>;
/omit-if-no-ref/
uart4m0_rtsn: uart4m0-rtsn {
rockchip,pins =
/* uart4m0_rtsn */
<1 RK_PA5 2 &pcfg_pull_none>;
/omit-if-no-ref/
uart4m1_xfer: uart4m1-xfer {
rockchip,pins =
/* uart4_rxm1 */
<3 RK_PB1 4 &pcfg_pull_up>,
/* uart4_txm1 */
<3 RK_PB2 4 &pcfg_pull_up>;
- uart5 {
/omit-if-no-ref/
uart5m0_xfer: uart5m0-xfer {
rockchip,pins =
/* uart5_rxm0 */
<2 RK_PA1 3 &pcfg_pull_up>,
/* uart5_txm0 */
<2 RK_PA2 3 &pcfg_pull_up>;
/omit-if-no-ref/
uart5m0_ctsn: uart5m0-ctsn {
rockchip,pins =
/* uart5m0_ctsn */
<1 RK_PD7 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart5m0_rtsn: uart5m0-rtsn {
rockchip,pins =
/* uart5m0_rtsn */
<2 RK_PA0 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart5m1_xfer: uart5m1-xfer {
rockchip,pins =
/* uart5_rxm1 */
<3 RK_PC3 4 &pcfg_pull_up>,
/* uart5_txm1 */
<3 RK_PC2 4 &pcfg_pull_up>;
- uart6 {
/omit-if-no-ref/
uart6m0_xfer: uart6m0-xfer {
rockchip,pins =
/* uart6_rxm0 */
<2 RK_PA3 3 &pcfg_pull_up>,
/* uart6_txm0 */
<2 RK_PA4 3 &pcfg_pull_up>;
/omit-if-no-ref/
uart6m0_ctsn: uart6m0-ctsn {
rockchip,pins =
/* uart6m0_ctsn */
<2 RK_PC0 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart6m0_rtsn: uart6m0-rtsn {
rockchip,pins =
/* uart6m0_rtsn */
<2 RK_PB7 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart6m1_xfer: uart6m1-xfer {
rockchip,pins =
/* uart6_rxm1 */
<1 RK_PD6 3 &pcfg_pull_up>,
/* uart6_txm1 */
<1 RK_PD5 3 &pcfg_pull_up>;
- uart7 {
/omit-if-no-ref/
uart7m0_xfer: uart7m0-xfer {
rockchip,pins =
/* uart7_rxm0 */
<2 RK_PA5 3 &pcfg_pull_up>,
/* uart7_txm0 */
<2 RK_PA6 3 &pcfg_pull_up>;
/omit-if-no-ref/
uart7m0_ctsn: uart7m0-ctsn {
rockchip,pins =
/* uart7m0_ctsn */
<2 RK_PC2 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart7m0_rtsn: uart7m0-rtsn {
rockchip,pins =
/* uart7m0_rtsn */
<2 RK_PC1 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart7m1_xfer: uart7m1-xfer {
rockchip,pins =
/* uart7_rxm1 */
<3 RK_PC5 4 &pcfg_pull_up>,
/* uart7_txm1 */
<3 RK_PC4 4 &pcfg_pull_up>;
/omit-if-no-ref/
uart7m2_xfer: uart7m2-xfer {
rockchip,pins =
/* uart7_rxm2 */
<4 RK_PA3 4 &pcfg_pull_up>,
/* uart7_txm2 */
<4 RK_PA2 4 &pcfg_pull_up>;
- uart8 {
/omit-if-no-ref/
uart8m0_xfer: uart8m0-xfer {
rockchip,pins =
/* uart8_rxm0 */
<2 RK_PC6 2 &pcfg_pull_up>,
/* uart8_txm0 */
<2 RK_PC5 3 &pcfg_pull_up>;
/omit-if-no-ref/
uart8m0_ctsn: uart8m0-ctsn {
rockchip,pins =
/* uart8m0_ctsn */
<2 RK_PB2 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart8m0_rtsn: uart8m0-rtsn {
rockchip,pins =
/* uart8m0_rtsn */
<2 RK_PB1 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart8m1_xfer: uart8m1-xfer {
rockchip,pins =
/* uart8_rxm1 */
<3 RK_PA0 4 &pcfg_pull_up>,
/* uart8_txm1 */
<2 RK_PD7 4 &pcfg_pull_up>;
- uart9 {
/omit-if-no-ref/
uart9m0_xfer: uart9m0-xfer {
rockchip,pins =
/* uart9_rxm0 */
<2 RK_PA7 3 &pcfg_pull_up>,
/* uart9_txm0 */
<2 RK_PB0 3 &pcfg_pull_up>;
/omit-if-no-ref/
uart9m0_ctsn: uart9m0-ctsn {
rockchip,pins =
/* uart9m0_ctsn */
<2 RK_PC4 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart9m0_rtsn: uart9m0-rtsn {
rockchip,pins =
/* uart9m0_rtsn */
<2 RK_PC3 3 &pcfg_pull_none>;
/omit-if-no-ref/
uart9m1_xfer: uart9m1-xfer {
rockchip,pins =
/* uart9_rxm1 */
<4 RK_PC6 4 &pcfg_pull_up>,
/* uart9_txm1 */
<4 RK_PC5 4 &pcfg_pull_up>;
/omit-if-no-ref/
uart9m2_xfer: uart9m2-xfer {
rockchip,pins =
/* uart9_rxm2 */
<4 RK_PA5 4 &pcfg_pull_up>,
/* uart9_txm2 */
<4 RK_PA4 4 &pcfg_pull_up>;
- vop {
/omit-if-no-ref/
vopm0_pins: vopm0-pins {
rockchip,pins =
/* vop_pwmm0 */
<0 RK_PC3 2 &pcfg_pull_none>;
/omit-if-no-ref/
vopm1_pins: vopm1-pins {
rockchip,pins =
/* vop_pwmm1 */
<3 RK_PC4 2 &pcfg_pull_none>;
- This part is edited handly.
-&pinctrl {
- spi0-hs {
/omit-if-no-ref/
spi0m0_pins_hs: spi0m0-pins {
rockchip,pins =
/* spi0_clkm0 */
<0 RK_PB5 2 &pcfg_pull_up_drv_level_1>,
/* spi0_misom0 */
<0 RK_PC5 2 &pcfg_pull_up_drv_level_1>,
/* spi0_mosim0 */
<0 RK_PB6 2 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi0m0_cs0_hs: spi0m0-cs0 {
rockchip,pins =
/* spi0_cs0m0 */
<0 RK_PC6 2 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi0m0_cs1_hs: spi0m0-cs1 {
rockchip,pins =
/* spi0_cs1m0 */
<0 RK_PC4 2 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi0m1_pins_hs: spi0m1-pins {
rockchip,pins =
/* spi0_clkm1 */
<2 RK_PD3 3 &pcfg_pull_up_drv_level_1>,
/* spi0_misom1 */
<2 RK_PD0 3 &pcfg_pull_up_drv_level_1>,
/* spi0_mosim1 */
<2 RK_PD1 3 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi0m1_cs0_hs: spi0m1-cs0 {
rockchip,pins =
/* spi0_cs0m1 */
<2 RK_PD2 3 &pcfg_pull_up_drv_level_1>;
- spi1-hs {
/omit-if-no-ref/
spi1m0_pins_hs: spi1m0-pins {
rockchip,pins =
/* spi1_clkm0 */
<2 RK_PB5 3 &pcfg_pull_up_drv_level_1>,
/* spi1_misom0 */
<2 RK_PB6 3 &pcfg_pull_up_drv_level_1>,
/* spi1_mosim0 */
<2 RK_PB7 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi1m0_cs0_hs: spi1m0-cs0 {
rockchip,pins =
/* spi1_cs0m0 */
<2 RK_PC0 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi1m0_cs1_hs: spi1m0-cs1 {
rockchip,pins =
/* spi1_cs1m0 */
<2 RK_PC6 3 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi1m1_pins_hs: spi1m1-pins {
rockchip,pins =
/* spi1_clkm1 */
<3 RK_PC3 3 &pcfg_pull_up_drv_level_1>,
/* spi1_misom1 */
<3 RK_PC2 3 &pcfg_pull_up_drv_level_1>,
/* spi1_mosim1 */
<3 RK_PC1 3 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi1m1_cs0_hs: spi1m1-cs0 {
rockchip,pins =
/* spi1_cs0m1 */
<3 RK_PA1 3 &pcfg_pull_up_drv_level_1>;
- spi2-hs {
/omit-if-no-ref/
spi2m0_pins_hs: spi2m0-pins {
rockchip,pins =
/* spi2_clkm0 */
<2 RK_PC1 4 &pcfg_pull_up_drv_level_1>,
/* spi2_misom0 */
<2 RK_PC2 4 &pcfg_pull_up_drv_level_1>,
/* spi2_mosim0 */
<2 RK_PC3 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi2m0_cs0_hs: spi2m0-cs0 {
rockchip,pins =
/* spi2_cs0m0 */
<2 RK_PC4 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi2m0_cs1_hs: spi2m0-cs1 {
rockchip,pins =
/* spi2_cs1m0 */
<2 RK_PC5 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi2m1_pins_hs: spi2m1-pins {
rockchip,pins =
/* spi2_clkm1 */
<3 RK_PA0 3 &pcfg_pull_up_drv_level_1>,
/* spi2_misom1 */
<2 RK_PD7 3 &pcfg_pull_up_drv_level_1>,
/* spi2_mosim1 */
<2 RK_PD6 3 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi2m1_cs0_hs: spi2m1-cs0 {
rockchip,pins =
/* spi2_cs0m1 */
<2 RK_PD5 3 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi2m1_cs1_hs: spi2m1-cs1 {
rockchip,pins =
/* spi2_cs1m1 */
<2 RK_PD4 3 &pcfg_pull_up_drv_level_1>;
- spi3-hs {
/omit-if-no-ref/
spi3m0_pins_hs: spi3m0-pins {
rockchip,pins =
/* spi3_clkm0 */
<4 RK_PB3 4 &pcfg_pull_up_drv_level_1>,
/* spi3_misom0 */
<4 RK_PB0 4 &pcfg_pull_up_drv_level_1>,
/* spi3_mosim0 */
<4 RK_PB2 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi3m0_cs0_hs: spi3m0-cs0 {
rockchip,pins =
/* spi3_cs0m0 */
<4 RK_PA6 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi3m0_cs1_hs: spi3m0-cs1 {
rockchip,pins =
/* spi3_cs1m0 */
<4 RK_PA7 4 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi3m1_pins_hs: spi3m1-pins {
rockchip,pins =
/* spi3_clkm1 */
<4 RK_PC2 2 &pcfg_pull_up_drv_level_1>,
/* spi3_misom1 */
<4 RK_PC5 2 &pcfg_pull_up_drv_level_1>,
/* spi3_mosim1 */
<4 RK_PC3 2 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi3m1_cs0_hs: spi3m1-cs0 {
rockchip,pins =
/* spi3_cs0m1 */
<4 RK_PC6 2 &pcfg_pull_up_drv_level_1>;
/omit-if-no-ref/
spi3m1_cs1_hs: spi3m1-cs1 {
rockchip,pins =
/* spi3_cs1m1 */
<4 RK_PD1 2 &pcfg_pull_up_drv_level_1>;
- gmac-txd-level3 {
/omit-if-no-ref/
gmac0_tx_bus2_level3: gmac0-tx-bus2-level3 {
rockchip,pins =
/* gmac0_txd0 */
<2 RK_PB3 1 &pcfg_pull_none_drv_level_3>,
/* gmac0_txd1 */
<2 RK_PB4 1 &pcfg_pull_none_drv_level_3>,
/* gmac0_txen */
/omit-if-no-ref/
gmac0_rgmii_bus_level3: gmac0-rgmii-bus-level3 {
rockchip,pins =
/* gmac0_rxd2 */
/* gmac0_rxd3 */
/* gmac0_txd2 */
<2 RK_PA6 2 &pcfg_pull_none_drv_level_3>,
/* gmac0_txd3 */
<2 RK_PA7 2 &pcfg_pull_none_drv_level_3>;
/omit-if-no-ref/
gmac1m0_tx_bus2_level3: gmac1m0-tx-bus2-level3 {
rockchip,pins =
/* gmac1_txd0m0 */
<3 RK_PB5 3 &pcfg_pull_none_drv_level_3>,
/* gmac1_txd1m0 */
<3 RK_PB6 3 &pcfg_pull_none_drv_level_3>,
/* gmac1_txenm0 */
/omit-if-no-ref/
gmac1m0_rgmii_bus_level3: gmac1m0-rgmii-bus-level3 {
rockchip,pins =
/* gmac1_rxd2m0 */
/* gmac1_rxd3m0 */
/* gmac1_txd2m0 */
<3 RK_PA2 3 &pcfg_pull_none_drv_level_3>,
/* gmac1_txd3m0 */
<3 RK_PA3 3 &pcfg_pull_none_drv_level_3>;
/omit-if-no-ref/
gmac1m1_tx_bus2_level3: gmac1m1-tx-bus2-level3 {
rockchip,pins =
/* gmac1_txd0m1 */
<4 RK_PA4 3 &pcfg_pull_none_drv_level_3>,
/* gmac1_txd1m1 */
<4 RK_PA5 3 &pcfg_pull_none_drv_level_3>,
/* gmac1_txenm1 */
/omit-if-no-ref/
gmac1m1_rgmii_bus_level3: gmac1m1-rgmii-bus-level3 {
rockchip,pins =
/* gmac1_rxd2m1 */
/* gmac1_rxd3m1 */
/* gmac1_txd2m1 */
<3 RK_PD6 3 &pcfg_pull_none_drv_level_3>,
/* gmac1_txd3m1 */
<3 RK_PD7 3 &pcfg_pull_none_drv_level_3>;
- gmac-txc-level2 {
/omit-if-no-ref/
gmac0_rgmii_clk_level2: gmac0-rgmii-clk-level2 {
rockchip,pins =
/* gmac0_rxclk */
/* gmac0_txclk */
<2 RK_PB0 2 &pcfg_pull_none_drv_level_2>;
/omit-if-no-ref/
gmac1m0_rgmii_clk_level2: gmac1m0-rgmii-clk-level2 {
rockchip,pins =
/* gmac1_rxclkm0 */
/* gmac1_txclkm0 */
<3 RK_PA6 3 &pcfg_pull_none_drv_level_2>;
/omit-if-no-ref/
gmac1m1_rgmii_clk_level2: gmac1m1-rgmii-clk-level2 {
rockchip,pins =
/* gmac1_rxclkm1 */
/* gmac1_txclkm1 */
<4 RK_PA0 3 &pcfg_pull_none_drv_level_2>;
- tsadc {
/omit-if-no-ref/
tsadc_pin: tsadc-pin {
rockchip,pins =
/* tsadc_pin */
<0 RK_PA1 0 &pcfg_pull_none>;
- lcdc {
/omit-if-no-ref/
lcdc_clock: lcdc-clock {
rockchip,pins =
/* lcdc_clk */
/* lcdc_den */
/* lcdc_hsync */
/* lcdc_vsync */
/omit-if-no-ref/
lcdc_data16: lcdc-data16 {
rockchip,pins =
/* lcdc_d3 */
/* lcdc_d4 */
/* lcdc_d5 */
/* lcdc_d6 */
/* lcdc_d7 */
/* lcdc_d10 */
/* lcdc_d11 */
/* lcdc_d12 */
/* lcdc_d13 */
/* lcdc_d14 */
/* lcdc_d15 */
/* lcdc_d19 */
/* lcdc_d20 */
/* lcdc_d21 */
/* lcdc_d22 */
/* lcdc_d23 */
<3 RK_PC0 1 &pcfg_pull_none>;
/omit-if-no-ref/
lcdc_data18: lcdc-data18 {
rockchip,pins =
/* lcdc_d2 */
/* lcdc_d3 */
/* lcdc_d4 */
/* lcdc_d5 */
/* lcdc_d6 */
/* lcdc_d7 */
/* lcdc_d10 */
/* lcdc_d11 */
/* lcdc_d12 */
/* lcdc_d13 */
/* lcdc_d14 */
/* lcdc_d15 */
/* lcdc_d18 */
/* lcdc_d19 */
/* lcdc_d20 */
/* lcdc_d21 */
/* lcdc_d22 */
/* lcdc_d23 */
-}; diff --git a/arch/arm/dts/rk3568-radxa-cm3i.dtsi b/arch/arm/dts/rk3568-radxa-cm3i.dtsi deleted file mode 100644 index 45b03dcbbad4..000000000000 --- a/arch/arm/dts/rk3568-radxa-cm3i.dtsi +++ /dev/null @@ -1,412 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include "rk3568.dtsi"
- compatible = "radxa,cm3i", "rockchip,rk3568";
- aliases {
mmc0 = &sdhci;
- chosen {
stdout-path = "serial2:115200n8";
- gpio-leds {
compatible = "gpio-leds";
led_user: led-0 {
gpios = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
function = LED_FUNCTION_HEARTBEAT;
color = <LED_COLOR_ID_GREEN>;
linux,default-trigger = "heartbeat";
pinctrl-names = "default";
pinctrl-0 = <&led_user_en>;
- pcie30_avdd0v9: pcie30-avdd0v9-regulator {
compatible = "regulator-fixed";
regulator-name = "pcie30_avdd0v9";
regulator-always-on;
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
vin-supply = <&vcc3v3_sys>;
- pcie30_avdd1v8: pcie30-avdd1v8-regulator {
regulator-name = "pcie30_avdd1v8";
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
- vcc3v3_sys: vcc3v3-sys-regulator {
regulator-name = "vcc3v3_sys";
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vin-supply = <&vcc5v_input>;
- vcc5v0_sys: vcc5v0-sys-regulator {
regulator-name = "vcc5v0_sys";
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
- /* labeled +5v_input in schematic */
- vcc5v_input: vcc5v-input-regulator {
regulator-name = "vcc5v_input";
regulator-boot-on;
-&combphy0 {
- status = "okay";
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
- cpu-supply = <&vdd_cpu>;
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&display_subsystem {
- status = "disabled";
-&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
-&i2c0 {
- status = "okay";
- vdd_cpu: regulator@1c {
compatible = "tcs,tcs4525";
reg = <0x1c>;
regulator-boot-on;
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1150000>;
regulator-state-mem {
regulator-off-in-suspend;
- rk809: pmic@20 {
compatible = "rockchip,rk809";
reg = <0x20>;
interrupt-parent = <&gpio0>;
interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <1>;
pinctrl-0 = <&pmic_int>;
rockchip,system-power-controller;
wakeup-source;
vcc1-supply = <&vcc3v3_sys>;
vcc2-supply = <&vcc3v3_sys>;
vcc3-supply = <&vcc3v3_sys>;
vcc4-supply = <&vcc3v3_sys>;
vcc5-supply = <&vcc3v3_sys>;
vcc6-supply = <&vcc3v3_sys>;
vcc7-supply = <&vcc3v3_sys>;
vcc8-supply = <&vcc3v3_sys>;
vcc9-supply = <&vcc3v3_sys>;
regulators {
vdd_logic: DCDC_REG1 {
regulator-name = "vdd_logic";
regulator-boot-on;
regulator-initial-mode = <0x2>;
regulator-min-microvolt = <500000>;
regulator-max-microvolt = <1350000>;
regulator-ramp-delay = <6001>;
vdd_gpu: DCDC_REG2 {
regulator-name = "vdd_gpu";
vcc_ddr: DCDC_REG3 {
regulator-name = "vcc_ddr";
regulator-boot-on;
regulator-on-in-suspend;
vdd_npu: DCDC_REG4 {
regulator-name = "vdd_npu";
vcc_1v8: DCDC_REG5 {
regulator-name = "vcc_1v8";
regulator-boot-on;
vdda0v9_image: LDO_REG1 {
regulator-name = "vdda0v9_image";
vdda_0v9: LDO_REG2 {
regulator-name = "vdda_0v9";
regulator-boot-on;
vdda0v9_pmu: LDO_REG3 {
regulator-name = "vdda0v9_pmu";
regulator-boot-on;
regulator-suspend-microvolt = <900000>;
vccio_acodec: LDO_REG4 {
regulator-name = "vccio_acodec";
vccio_sd: LDO_REG5 {
regulator-name = "vccio_sd";
vcc3v3_pmu: LDO_REG6 {
regulator-name = "vcc3v3_pmu";
regulator-boot-on;
regulator-suspend-microvolt = <3300000>;
vcca_1v8: LDO_REG7 {
regulator-name = "vcca_1v8";
regulator-boot-on;
vcca1v8_pmu: LDO_REG8 {
regulator-name = "vcca1v8_pmu";
regulator-boot-on;
regulator-suspend-microvolt = <1800000>;
vcca1v8_image: LDO_REG9 {
regulator-name = "vcca1v8_image";
vcc_3v3: SWITCH_REG1 {
regulator-name = "vcc_3v3";
regulator-boot-on;
vcc3v3_sd: SWITCH_REG2 {
regulator-name = "vcc3v3_sd";
-&pinctrl {
- leds {
led_user_en: led_user_en {
rockchip,pins = <0 RK_PA6 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
pmic_int: pmic_int {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
-&pmu_io_domains {
- vccio2-supply = <&vcc_1v8>;
- vccio6-supply = <&vcc_1v8>;
- status = "okay";
-&saradc {
- vref-supply = <&vcca_1v8>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- max-frequency = <200000000>;
- non-removable;
- pinctrl-names = "default";
- pinctrl-0 = <&emmc_bus8 &emmc_clk &emmc_cmd &emmc_datastrobe>;
- vqmmc-supply = <&vcc_1v8>;
- status = "okay";
-&tsadc {
- status = "okay";
-&uart2 {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb_host0_xhci {
- extcon = <&usb2phy0>;
-}; diff --git a/arch/arm/dts/rk3568-radxa-e25.dts b/arch/arm/dts/rk3568-radxa-e25.dts deleted file mode 100644 index 72ad74c38a2b..000000000000 --- a/arch/arm/dts/rk3568-radxa-e25.dts +++ /dev/null @@ -1,236 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/; -#include "rk3568-radxa-cm3i.dtsi"
- model = "Radxa E25 Carrier Board";
- compatible = "radxa,e25", "radxa,cm3i", "rockchip,rk3568";
- aliases {
mmc1 = &sdmmc0;
- pwm-leds {
compatible = "pwm-leds-multicolor";
multi-led {
color = <LED_COLOR_ID_RGB>;
max-brightness = <255>;
led-red {
color = <LED_COLOR_ID_RED>;
pwms = <&pwm1 0 1000000 0>;
led-green {
pwms = <&pwm2 0 1000000 0>;
led-blue {
color = <LED_COLOR_ID_BLUE>;
pwms = <&pwm12 0 1000000 0>;
- vbus_typec: vbus-typec-regulator {
enable-active-high;
gpio = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vbus_typec_en>;
regulator-name = "vbus_typec";
vin-supply = <&vcc5v0_sys>;
- /* actually fed by vcc5v0_sys, dependent
* on pi6c clock generator
- vcc3v3_minipcie: vcc3v3-minipcie-regulator {
enable-active-high;
gpio = <&gpio3 RK_PA7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&minipcie_enable_h>;
regulator-name = "vcc3v3_minipcie";
vin-supply = <&vcc3v3_pi6c_05>;
- vcc3v3_ngff: vcc3v3-ngff-regulator {
enable-active-high;
gpio = <&gpio0 RK_PD6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&ngffpcie_enable_h>;
regulator-name = "vcc3v3_ngff";
- vcc3v3_pcie30x1: vcc3v3-pcie30x1-regulator {
enable-active-high;
gpio = <&gpio0 RK_PC5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie30x1_enable_h>;
regulator-name = "vcc3v3_pcie30x1";
- vcc3v3_pi6c_05: vcc3v3-pi6c-05-regulator {
enable-active-high;
gpios = <&gpio0 RK_PC7 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie_enable_h>;
regulator-name = "vcc3v3_pcie";
-&combphy1 {
- phy-supply = <&vcc3v3_pcie30x1>;
-&pcie2x1 {
- pinctrl-0 = <&pcie20_reset_h>;
- reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pi6c_05>;
- status = "okay";
-&pcie30phy {
- data-lanes = <1 2>;
- status = "okay";
-&pcie3x1 {
- num-lanes = <1>;
- pinctrl-0 = <&pcie30x1m0_pins>;
- reset-gpios = <&gpio0 RK_PC3 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_minipcie>;
- status = "okay";
-&pcie3x2 {
- num-lanes = <1>;
- pinctrl-0 = <&pcie30x2_reset_h>;
- reset-gpios = <&gpio2 RK_PD6 GPIO_ACTIVE_HIGH>;
- status = "okay";
-&pinctrl {
- pcie {
pcie20_reset_h: pcie20-reset-h {
rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
pcie30x1_enable_h: pcie30x1-enable-h {
rockchip,pins = <0 RK_PC5 RK_FUNC_GPIO &pcfg_pull_none>;
pcie30x2_reset_h: pcie30x2-reset-h {
rockchip,pins = <2 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_enable_h: pcie-enable-h {
rockchip,pins = <0 RK_PC7 RK_FUNC_GPIO &pcfg_pull_none>;
- usb {
minipcie_enable_h: minipcie-enable-h {
rockchip,pins = <3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_none>;
ngffpcie_enable_h: ngffpcie-enable-h {
rockchip,pins = <0 RK_PD6 RK_FUNC_GPIO &pcfg_pull_none>;
vbus_typec_en: vbus_typec_en {
rockchip,pins = <0 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
-&pwm1 {
- status = "okay";
-&pwm2 {
- status = "okay";
-&pwm12 {
- pinctrl-0 = <&pwm12m1_pins>;
- status = "okay";
-&sata1 {
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
- /* Also used in pcie30x1_clkreqnm0 */
- disable-wp;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v3_sd>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vbus_typec>;
- status = "okay";
-&usb2phy1_host {
- phy-supply = <&vcc3v3_minipcie>;
- status = "okay";
-&usb2phy1_otg {
- phy-supply = <&vcc3v3_ngff>;
- status = "okay";
-}; diff --git a/arch/arm/dts/rk3568-rock-3a.dts b/arch/arm/dts/rk3568-rock-3a.dts deleted file mode 100644 index a5e974ea659e..000000000000 --- a/arch/arm/dts/rk3568-rock-3a.dts +++ /dev/null @@ -1,859 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/; -#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3568.dtsi"
- model = "Radxa ROCK3 Model A";
- compatible = "radxa,rock3a", "rockchip,rk3568";
- aliases {
ethernet0 = &gmac1;
mmc0 = &sdhci;
mmc1 = &sdmmc0;
mmc2 = &sdmmc2;
- chosen: chosen {
stdout-path = "serial2:1500000n8";
- hdmi-con {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&hdmi_out_con>;
- gmac1_clkin: external-gmac1-clock {
compatible = "fixed-clock";
clock-frequency = <125000000>;
clock-output-names = "gmac1_clkin";
#clock-cells = <0>;
- leds {
led_user: led-0 {
gpios = <&gpio0 RK_PB7 GPIO_ACTIVE_HIGH>;
- rk809-sound {
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,name = "Analog RK809";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,cpu {
sound-dai = <&i2s1_8ch>;
simple-audio-card,codec {
sound-dai = <&rk809>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk809 1>;
clock-names = "ext_clock";
pinctrl-0 = <&wifi_enable>;
post-power-on-delay-ms = <100>;
power-off-delay-us = <5000000>;
reset-gpios = <&gpio3 RK_PD4 GPIO_ACTIVE_LOW>;
- vcc12v_dcin: vcc12v-dcin-regulator {
regulator-name = "vcc12v_dcin";
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
- /* pi6c pcie clock generator */
- vcc3v3_pi6c_03: vcc3v3-pi6c-03-regulator {
regulator-name = "vcc3v3_pi6c_03";
regulator-boot-on;
- vcc3v3_pcie: vcc3v3-pcie-regulator {
enable-active-high;
gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>;
regulator-boot-on;
vin-supply = <&vcc12v_dcin>;
regulator-boot-on;
- vcc5v0_usb: vcc5v0-usb-regulator {
regulator-name = "vcc5v0_usb";
regulator-boot-on;
- vcc5v0_usb_host: vcc5v0-usb-host-regulator {
enable-active-high;
gpio = <&gpio0 RK_PA6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb_host_en>;
regulator-name = "vcc5v0_usb_host";
vin-supply = <&vcc5v0_usb>;
- vcc5v0_usb_hub: vcc5v0-usb-hub-regulator {
enable-active-high;
gpio = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb_hub_en>;
regulator-name = "vcc5v0_usb_hub";
- vcc5v0_usb_otg: vcc5v0-usb-otg-regulator {
enable-active-high;
gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb_otg_en>;
regulator-name = "vcc5v0_usb_otg";
- vcc_cam: vcc-cam-regulator {
enable-active-high;
gpio = <&gpio1 RK_PB1 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc_cam_en>;
regulator-name = "vcc_cam";
- vcc_mipi: vcc-mipi-regulator {
enable-active-high;
gpio = <&gpio3 RK_PC0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc_mipi_en>;
regulator-name = "vcc_mipi";
-&combphy0 {
- status = "okay";
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gmac1 {
- assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1>;
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&gmac1_clkin>;
- clock_in_out = "input";
- phy-handle = <&rgmii_phy1>;
- phy-mode = "rgmii-id";
- phy-supply = <&vcc_3v3>;
- pinctrl-0 = <&gmac1m1_miim
&gmac1m1_tx_bus2
&gmac1m1_rx_bus2
&gmac1m1_rgmii_clk
&gmac1m1_clkinout
&gmac1m1_rgmii_bus>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- avdd-0v9-supply = <&vdda0v9_image>;
- avdd-1v8-supply = <&vcca1v8_image>;
- pinctrl-0 = <&hdmitx_scl &hdmitx_sda &hdmitxm1_cec>;
- status = "okay";
-&hdmi_in {
- hdmi_in_vp0: endpoint {
remote-endpoint = <&vp0_out_hdmi>;
-&hdmi_out {
- hdmi_out_con: endpoint {
remote-endpoint = <&hdmi_con_in>;
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
reg = <0x1c>;
fcs,suspend-voltage-selector = <1>;
regulator-name = "vdd_cpu";
regulator-boot-on;
regulator-ramp-delay = <2300>;
- rk809: pmic@20 {
reg = <0x20>;
assigned-clocks = <&cru I2S1_MCLKOUT_TX>;
assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>;
#clock-cells = <1>;
clock-names = "mclk";
pinctrl-0 = <&pmic_int>, <&i2s1m0_mclk>;
#sound-dai-cells = <0>;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
codec {
mic-in-differential;
-&i2c3 {
- pinctrl-0 = <&i2c3m1_xfer>;
-&i2c4 {
- pinctrl-0 = <&i2c4m1_xfer>;
-&i2c5 {
- status = "okay";
- hym8563: rtc@51 {
compatible = "haoyu,hym8563";
reg = <0x51>;
interrupts = <RK_PD3 IRQ_TYPE_LEVEL_LOW>;
#clock-cells = <0>;
clock-output-names = "rtcic_32kout";
pinctrl-0 = <&hym8563_int>;
wakeup-source;
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
- pinctrl-0 = <&i2s1m0_sclktx &i2s1m0_lrcktx &i2s1m0_sdi0 &i2s1m0_sdo0>;
- rockchip,trcm-sync-tx-only;
- status = "okay";
-&i2s2_2ch {
- status = "okay";
-&mdio1 {
- rgmii_phy1: ethernet-phy@0 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0x0>;
pinctrl-0 = <ð_phy_rst>;
reset-assert-us = <20000>;
reset-deassert-us = <100000>;
reset-gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>;
-&pcie2x1 {
- pinctrl-0 = <&pcie_reset_h>;
- reset-gpios = <&gpio3 RK_PC1 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie>;
- status = "okay";
-&pcie30phy {
- phy-supply = <&vcc3v3_pi6c_03>;
- status = "okay";
-&pcie3x2 {
- pinctrl-0 = <&pcie30x2m1_pins>;
- status = "okay";
-&pinctrl {
- cam {
vcc_cam_en: vcc_cam_en {
rockchip,pins = <1 RK_PB1 RK_FUNC_GPIO &pcfg_pull_none>;
- display {
vcc_mipi_en: vcc_mipi_en {
rockchip,pins = <3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_none>;
- ethernet {
eth_phy_rst: eth_phy_rst {
rockchip,pins = <3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_none>;
- hym8563 {
hym8563_int: hym8563-int {
rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_up>;
- leds {
- pcie {
rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_reset_h: pcie-reset-h {
rockchip,pins = <3 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins =
- usb {
vcc5v0_usb_host_en: vcc5v0_usb_host_en {
vcc5v0_usb_hub_en: vcc5v0_usb_hub_en {
rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
vcc5v0_usb_otg_en: vcc5v0_usb_otg_en {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
- bt {
bt_enable: bt-enable {
rockchip,pins = <4 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake: bt-host-wake {
rockchip,pins = <4 RK_PB4 RK_FUNC_GPIO &pcfg_pull_down>;
bt_wake: bt-wake {
rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
wifi_enable: wifi-enable {
rockchip,pins = <3 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
-&pmu_io_domains {
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_1v8>;
- vccio5-supply = <&vcc_3v3>;
- vccio7-supply = <&vcc_3v3>;
- status = "okay";
-&saradc {
- status = "okay";
-&sdhci {
- bus-width = <8>;
- non-removable;
- vmmc-supply = <&vcc_3v3>;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
- sd-uhs-sdr50;
- status = "okay";
-&sdmmc2 {
- bus-width = <4>;
- disable-wp;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdmmc2m0_bus4 &sdmmc2m0_cmd &sdmmc2m0_clk>;
- sd-uhs-sdr12;
- sd-uhs-sdr25;
- sd-uhs-sdr50;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v3_sys>;
- status = "okay";
-&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
-&uart1 {
- pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>;
- uart-has-rtscts;
- status = "okay";
- bluetooth {
compatible = "brcm,bcm43438-bt";
clock-names = "lpo";
device-wakeup-gpios = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>;
host-wakeup-gpios = <&gpio4 RK_PB4 GPIO_ACTIVE_HIGH>;
shutdown-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&bt_host_wake &bt_wake &bt_enable>;
vbat-supply = <&vcc3v3_sys>;
vddio-supply = <&vcc_1v8>;
/* vddio comes from regulator on module, use IO bank voltage instead */
-&uart2 {
- status = "okay";
-&usb_host0_ehci {
- status = "okay";
-&usb_host0_ohci {
- status = "okay";
-&usb_host0_xhci {
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host1_xhci {
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_host {
- phy-supply = <&vcc5v0_usb_host>;
- status = "okay";
-&usb2phy0_otg {
- phy-supply = <&vcc5v0_usb_otg>;
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&usb2phy1_otg {
- status = "okay";
-&vop {
- assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
- assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
- vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 {
reg = <ROCKCHIP_VOP2_EP_HDMI0>;
remote-endpoint = <&hdmi_in_vp0>;
-}; diff --git a/arch/arm/dts/rk3568.dtsi b/arch/arm/dts/rk3568.dtsi deleted file mode 100644 index f1be76a54ceb..000000000000 --- a/arch/arm/dts/rk3568.dtsi +++ /dev/null @@ -1,267 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
- Copyright (c) 2021 Rockchip Electronics Co., Ltd.
-#include "rk356x.dtsi"
- compatible = "rockchip,rk3568";
- sata0: sata@fc000000 {
compatible = "rockchip,rk3568-dwc-ahci", "snps,dwc-ahci";
reg = <0 0xfc000000 0 0x1000>;
clocks = <&cru ACLK_SATA0>, <&cru CLK_SATA0_PMALIVE>,
<&cru CLK_SATA0_RXOOB>;
clock-names = "sata", "pmalive", "rxoob";
interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>;
phys = <&combphy0 PHY_TYPE_SATA>;
phy-names = "sata-phy";
ports-implemented = <0x1>;
power-domains = <&power RK3568_PD_PIPE>;
- pipe_phy_grf0: syscon@fdc70000 {
compatible = "rockchip,rk3568-pipe-phy-grf", "syscon";
reg = <0x0 0xfdc70000 0x0 0x1000>;
- qos_pcie3x1: qos@fe190080 {
compatible = "rockchip,rk3568-qos", "syscon";
reg = <0x0 0xfe190080 0x0 0x20>;
- qos_pcie3x2: qos@fe190100 {
reg = <0x0 0xfe190100 0x0 0x20>;
- qos_sata0: qos@fe190200 {
reg = <0x0 0xfe190200 0x0 0x20>;
- pcie30_phy_grf: syscon@fdcb8000 {
compatible = "rockchip,rk3568-pcie3-phy-grf", "syscon";
reg = <0x0 0xfdcb8000 0x0 0x10000>;
- pcie30phy: phy@fe8c0000 {
compatible = "rockchip,rk3568-pcie3-phy";
reg = <0x0 0xfe8c0000 0x0 0x20000>;
#phy-cells = <0>;
clocks = <&pmucru CLK_PCIE30PHY_REF_M>, <&pmucru CLK_PCIE30PHY_REF_N>,
<&cru PCLK_PCIE30PHY>;
clock-names = "refclk_m", "refclk_n", "pclk";
resets = <&cru SRST_PCIE30PHY>;
reset-names = "phy";
rockchip,phy-grf = <&pcie30_phy_grf>;
- pcie3x1: pcie@fe270000 {
compatible = "rockchip,rk3568-pcie";
#address-cells = <3>;
#size-cells = <2>;
bus-range = <0x0 0xf>;
clocks = <&cru ACLK_PCIE30X1_MST>, <&cru ACLK_PCIE30X1_SLV>,
<&cru ACLK_PCIE30X1_DBI>, <&cru PCLK_PCIE30X1>,
<&cru CLK_PCIE30X1_AUX_NDFT>;
clock-names = "aclk_mst", "aclk_slv",
"aclk_dbi", "pclk", "aux";
device_type = "pci";
interrupts = <GIC_SPI 160 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 159 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 158 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 157 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 156 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "sys", "pmc", "msg", "legacy", "err";
#interrupt-cells = <1>;
interrupt-map-mask = <0 0 0 7>;
interrupt-map = <0 0 0 1 &pcie3x1_intc 0>,
<0 0 0 2 &pcie3x1_intc 1>,
<0 0 0 3 &pcie3x1_intc 2>,
<0 0 0 4 &pcie3x1_intc 3>;
linux,pci-domain = <1>;
num-ib-windows = <6>;
num-ob-windows = <2>;
max-link-speed = <3>;
msi-map = <0x0 &gic 0x1000 0x1000>;
num-lanes = <1>;
phys = <&pcie30phy>;
phy-names = "pcie-phy";
reg = <0x3 0xc0400000 0x0 0x00400000>,
<0x0 0xfe270000 0x0 0x00010000>,
<0x0 0xf2000000 0x0 0x00100000>;
ranges = <0x01000000 0x0 0xf2100000 0x0 0xf2100000 0x0 0x00100000>,
<0x02000000 0x0 0xf2200000 0x0 0xf2200000 0x0 0x01e00000>,
<0x03000000 0x0 0x40000000 0x3 0x40000000 0x0 0x40000000>;
reg-names = "dbi", "apb", "config";
resets = <&cru SRST_PCIE30X1_POWERUP>;
reset-names = "pipe";
/* bifurcation; lane1 when using 1+1 */
pcie3x1_intc: legacy-interrupt-controller {
interrupt-controller;
#address-cells = <0>;
interrupt-parent = <&gic>;
interrupts = <GIC_SPI 157 IRQ_TYPE_EDGE_RISING>;
- pcie3x2: pcie@fe280000 {
#size-cells = <2>;
clocks = <&cru ACLK_PCIE30X2_MST>, <&cru ACLK_PCIE30X2_SLV>,
<&cru ACLK_PCIE30X2_DBI>, <&cru PCLK_PCIE30X2>,
<&cru CLK_PCIE30X2_AUX_NDFT>;
interrupts = <GIC_SPI 165 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 164 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 163 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 162 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 161 IRQ_TYPE_LEVEL_HIGH>;
interrupt-map = <0 0 0 1 &pcie3x2_intc 0>,
<0 0 0 2 &pcie3x2_intc 1>,
<0 0 0 3 &pcie3x2_intc 2>,
<0 0 0 4 &pcie3x2_intc 3>;
linux,pci-domain = <2>;
msi-map = <0x0 &gic 0x2000 0x1000>;
num-lanes = <2>;
reg = <0x3 0xc0800000 0x0 0x00400000>,
<0x0 0xfe280000 0x0 0x00010000>,
<0x0 0xf0000000 0x0 0x00100000>;
ranges = <0x01000000 0x0 0xf0100000 0x0 0xf0100000 0x0 0x00100000>,
<0x02000000 0x0 0xf0200000 0x0 0xf0200000 0x0 0x01e00000>,
<0x03000000 0x0 0x40000000 0x3 0x80000000 0x0 0x40000000>;
resets = <&cru SRST_PCIE30X2_POWERUP>;
/* bifurcation; lane0 when using 1+1 */
pcie3x2_intc: legacy-interrupt-controller {
interrupts = <GIC_SPI 162 IRQ_TYPE_EDGE_RISING>;
- gmac0: ethernet@fe2a0000 {
compatible = "rockchip,rk3568-gmac", "snps,dwmac-4.20a";
reg = <0x0 0xfe2a0000 0x0 0x10000>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 24 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "macirq", "eth_wake_irq";
clocks = <&cru SCLK_GMAC0>, <&cru SCLK_GMAC0_RX_TX>,
<&cru SCLK_GMAC0_RX_TX>, <&cru CLK_MAC0_REFOUT>,
<&cru ACLK_GMAC0>, <&cru PCLK_GMAC0>,
<&cru SCLK_GMAC0_RX_TX>, <&cru CLK_GMAC0_PTP_REF>;
clock-names = "stmmaceth", "mac_clk_rx",
"mac_clk_tx", "clk_mac_refout",
"aclk_mac", "pclk_mac",
"clk_mac_speed", "ptp_ref";
resets = <&cru SRST_A_GMAC0>;
reset-names = "stmmaceth";
rockchip,grf = <&grf>;
snps,axi-config = <&gmac0_stmmac_axi_setup>;
snps,mixed-burst;
snps,mtl-rx-config = <&gmac0_mtl_rx_setup>;
snps,mtl-tx-config = <&gmac0_mtl_tx_setup>;
snps,tso;
mdio0: mdio {
compatible = "snps,dwmac-mdio";
#address-cells = <0x1>;
#size-cells = <0x0>;
gmac0_stmmac_axi_setup: stmmac-axi-config {
snps,blen = <0 0 0 0 16 8 4>;
snps,rd_osr_lmt = <8>;
snps,wr_osr_lmt = <4>;
gmac0_mtl_rx_setup: rx-queues-config {
snps,rx-queues-to-use = <1>;
queue0 {};
gmac0_mtl_tx_setup: tx-queues-config {
snps,tx-queues-to-use = <1>;
queue0 {};
- combphy0: phy@fe820000 {
compatible = "rockchip,rk3568-naneng-combphy";
reg = <0x0 0xfe820000 0x0 0x100>;
clocks = <&pmucru CLK_PCIEPHY0_REF>,
<&cru PCLK_PIPEPHY0>,
<&cru PCLK_PIPE>;
clock-names = "ref", "apb", "pipe";
assigned-clocks = <&pmucru CLK_PCIEPHY0_REF>;
assigned-clock-rates = <100000000>;
resets = <&cru SRST_PIPEPHY0>;
rockchip,pipe-grf = <&pipegrf>;
rockchip,pipe-phy-grf = <&pipe_phy_grf0>;
#phy-cells = <1>;
-&cpu0_opp_table {
- opp-1992000000 {
opp-hz = /bits/ 64 <1992000000>;
opp-microvolt = <1150000 1150000 1150000>;
-&pipegrf {
- compatible = "rockchip,rk3568-pipe-grf", "syscon";
-&power {
- power-domain@RK3568_PD_PIPE {
reg = <RK3568_PD_PIPE>;
clocks = <&cru PCLK_PIPE>;
pm_qos = <&qos_pcie2x1>,
<&qos_pcie3x1>,
<&qos_pcie3x2>,
<&qos_sata0>,
<&qos_sata1>,
<&qos_sata2>,
<&qos_usb3_0>,
<&qos_usb3_1>;
#power-domain-cells = <0>;
-&usb_host0_xhci {
- phys = <&usb2phy0_otg>, <&combphy0 PHY_TYPE_USB3>;
- phy-names = "usb2-phy", "usb3-phy";
-&vop {
- compatible = "rockchip,rk3568-vop";
-}; diff --git a/arch/arm/dts/rk356x.dtsi b/arch/arm/dts/rk356x.dtsi deleted file mode 100644 index c19c0f1b3778..000000000000 --- a/arch/arm/dts/rk356x.dtsi +++ /dev/null @@ -1,1886 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT) -/*
-#include <dt-bindings/clock/rk3568-cru.h> -#include <dt-bindings/interrupt-controller/arm-gic.h> -#include <dt-bindings/interrupt-controller/irq.h> -#include <dt-bindings/phy/phy.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/power/rk3568-power.h> -#include <dt-bindings/soc/rockchip,boot-mode.h> -#include <dt-bindings/thermal/thermal.h>
- interrupt-parent = <&gic>;
- #address-cells = <2>;
- #size-cells = <2>;
- aliases {
gpio0 = &gpio0;
gpio1 = &gpio1;
gpio2 = &gpio2;
gpio3 = &gpio3;
gpio4 = &gpio4;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c3 = &i2c3;
i2c4 = &i2c4;
i2c5 = &i2c5;
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
serial4 = &uart4;
serial5 = &uart5;
serial6 = &uart6;
serial7 = &uart7;
serial8 = &uart8;
serial9 = &uart9;
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
spi3 = &spi3;
- cpus {
#size-cells = <0>;
cpu0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a55";
reg = <0x0 0x0>;
clocks = <&scmi_clk 0>;
#cooling-cells = <2>;
enable-method = "psci";
operating-points-v2 = <&cpu0_opp_table>;
cpu1: cpu@100 {
reg = <0x0 0x100>;
cpu2: cpu@200 {
reg = <0x0 0x200>;
cpu3: cpu@300 {
reg = <0x0 0x300>;
- cpu0_opp_table: opp-table-0 {
compatible = "operating-points-v2";
opp-shared;
opp-408000000 {
opp-hz = /bits/ 64 <408000000>;
opp-microvolt = <900000 900000 1150000>;
clock-latency-ns = <40000>;
opp-600000000 {
opp-hz = /bits/ 64 <600000000>;
opp-816000000 {
opp-hz = /bits/ 64 <816000000>;
opp-suspend;
opp-1104000000 {
opp-hz = /bits/ 64 <1104000000>;
opp-1416000000 {
opp-hz = /bits/ 64 <1416000000>;
opp-1608000000 {
opp-hz = /bits/ 64 <1608000000>;
opp-microvolt = <975000 975000 1150000>;
opp-1800000000 {
opp-hz = /bits/ 64 <1800000000>;
opp-microvolt = <1050000 1050000 1150000>;
- display_subsystem: display-subsystem {
compatible = "rockchip,display-subsystem";
ports = <&vop_out>;
- firmware {
scmi: scmi {
compatible = "arm,scmi-smc";
arm,smc-id = <0x82000010>;
shmem = <&scmi_shmem>;
#address-cells = <1>;
#size-cells = <0>;
scmi_clk: protocol@14 {
reg = <0x14>;
#clock-cells = <1>;
- gpu_opp_table: opp-table-1 {
opp-200000000 {
opp-hz = /bits/ 64 <200000000>;
opp-microvolt = <825000>;
opp-300000000 {
opp-hz = /bits/ 64 <300000000>;
opp-400000000 {
opp-hz = /bits/ 64 <400000000>;
opp-600000000 {
opp-700000000 {
opp-hz = /bits/ 64 <700000000>;
opp-microvolt = <900000>;
opp-800000000 {
opp-hz = /bits/ 64 <800000000>;
opp-microvolt = <1000000>;
- hdmi_sound: hdmi-sound {
simple-audio-card,name = "HDMI";
sound-dai = <&hdmi>;
sound-dai = <&i2s0_8ch>;
- pmu {
compatible = "arm,cortex-a55-pmu";
interrupts = <GIC_SPI 228 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 229 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 230 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 231 IRQ_TYPE_LEVEL_HIGH>;
interrupt-affinity = <&cpu0>, <&cpu1>, <&cpu2>, <&cpu3>;
- psci {
compatible = "arm,psci-1.0";
method = "smc";
- timer {
compatible = "arm,armv8-timer";
interrupts = <GIC_PPI 13 IRQ_TYPE_LEVEL_HIGH>,
<GIC_PPI 14 IRQ_TYPE_LEVEL_HIGH>,
<GIC_PPI 11 IRQ_TYPE_LEVEL_HIGH>,
<GIC_PPI 10 IRQ_TYPE_LEVEL_HIGH>;
arm,no-tick-in-suspend;
- xin24m: xin24m {
clock-frequency = <24000000>;
clock-output-names = "xin24m";
#clock-cells = <0>;
- xin32k: xin32k {
clock-frequency = <32768>;
clock-output-names = "xin32k";
pinctrl-0 = <&clk32k_out0>;
#clock-cells = <0>;
- sram@10f000 {
compatible = "mmio-sram";
reg = <0x0 0x0010f000 0x0 0x100>;
#size-cells = <1>;
ranges = <0 0x0 0x0010f000 0x100>;
scmi_shmem: sram@0 {
compatible = "arm,scmi-shmem";
reg = <0x0 0x100>;
- sata1: sata@fc400000 {
reg = <0 0xfc400000 0 0x1000>;
clocks = <&cru ACLK_SATA1>, <&cru CLK_SATA1_PMALIVE>,
<&cru CLK_SATA1_RXOOB>;
interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
phys = <&combphy1 PHY_TYPE_SATA>;
- sata2: sata@fc800000 {
reg = <0 0xfc800000 0 0x1000>;
clocks = <&cru ACLK_SATA2>, <&cru CLK_SATA2_PMALIVE>,
<&cru CLK_SATA2_RXOOB>;
interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
phys = <&combphy2 PHY_TYPE_SATA>;
- usb_host0_xhci: usb@fcc00000 {
compatible = "rockchip,rk3568-dwc3", "snps,dwc3";
reg = <0x0 0xfcc00000 0x0 0x400000>;
interrupts = <GIC_SPI 169 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_USB3OTG0_REF>, <&cru CLK_USB3OTG0_SUSPEND>,
<&cru ACLK_USB3OTG0>;
clock-names = "ref_clk", "suspend_clk",
"bus_clk";
dr_mode = "otg";
phy_type = "utmi_wide";
resets = <&cru SRST_USB3OTG0>;
snps,dis_u2_susphy_quirk;
- usb_host1_xhci: usb@fd000000 {
reg = <0x0 0xfd000000 0x0 0x400000>;
interrupts = <GIC_SPI 170 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_USB3OTG1_REF>, <&cru CLK_USB3OTG1_SUSPEND>,
<&cru ACLK_USB3OTG1>;
"bus_clk";
dr_mode = "host";
phys = <&usb2phy0_host>, <&combphy1 PHY_TYPE_USB3>;
resets = <&cru SRST_USB3OTG1>;
- gic: interrupt-controller@fd400000 {
compatible = "arm,gic-v3";
reg = <0x0 0xfd400000 0 0x10000>, /* GICD */
<0x0 0xfd460000 0 0x80000>; /* GICR */
interrupts = <GIC_PPI 9 IRQ_TYPE_LEVEL_HIGH>;
#interrupt-cells = <3>;
mbi-alias = <0x0 0xfd410000>;
mbi-ranges = <296 24>;
msi-controller;
- usb_host0_ehci: usb@fd800000 {
compatible = "generic-ehci";
reg = <0x0 0xfd800000 0x0 0x40000>;
interrupts = <GIC_SPI 130 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_USB2HOST0>, <&cru HCLK_USB2HOST0_ARB>,
<&cru PCLK_USB>;
phys = <&usb2phy1_otg>;
phy-names = "usb";
- usb_host0_ohci: usb@fd840000 {
compatible = "generic-ohci";
reg = <0x0 0xfd840000 0x0 0x40000>;
interrupts = <GIC_SPI 131 IRQ_TYPE_LEVEL_HIGH>;
<&cru PCLK_USB>;
phy-names = "usb";
- usb_host1_ehci: usb@fd880000 {
reg = <0x0 0xfd880000 0x0 0x40000>;
interrupts = <GIC_SPI 133 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_USB2HOST1>, <&cru HCLK_USB2HOST1_ARB>,
<&cru PCLK_USB>;
phys = <&usb2phy1_host>;
phy-names = "usb";
- usb_host1_ohci: usb@fd8c0000 {
reg = <0x0 0xfd8c0000 0x0 0x40000>;
interrupts = <GIC_SPI 134 IRQ_TYPE_LEVEL_HIGH>;
<&cru PCLK_USB>;
phy-names = "usb";
- pmugrf: syscon@fdc20000 {
compatible = "rockchip,rk3568-pmugrf", "syscon", "simple-mfd";
reg = <0x0 0xfdc20000 0x0 0x10000>;
pmu_io_domains: io-domains {
compatible = "rockchip,rk3568-pmu-io-voltage-domain";
- pipegrf: syscon@fdc50000 {
reg = <0x0 0xfdc50000 0x0 0x1000>;
- grf: syscon@fdc60000 {
compatible = "rockchip,rk3568-grf", "syscon", "simple-mfd";
reg = <0x0 0xfdc60000 0x0 0x10000>;
- pipe_phy_grf1: syscon@fdc80000 {
reg = <0x0 0xfdc80000 0x0 0x1000>;
- pipe_phy_grf2: syscon@fdc90000 {
reg = <0x0 0xfdc90000 0x0 0x1000>;
- usb2phy0_grf: syscon@fdca0000 {
compatible = "rockchip,rk3568-usb2phy-grf", "syscon";
reg = <0x0 0xfdca0000 0x0 0x8000>;
- usb2phy1_grf: syscon@fdca8000 {
reg = <0x0 0xfdca8000 0x0 0x8000>;
- pmucru: clock-controller@fdd00000 {
compatible = "rockchip,rk3568-pmucru";
reg = <0x0 0xfdd00000 0x0 0x1000>;
#clock-cells = <1>;
#reset-cells = <1>;
- cru: clock-controller@fdd20000 {
compatible = "rockchip,rk3568-cru";
reg = <0x0 0xfdd20000 0x0 0x1000>;
clocks = <&xin24m>;
clock-names = "xin24m";
#clock-cells = <1>;
#reset-cells = <1>;
assigned-clocks = <&pmucru CLK_RTC_32K>, <&cru PLL_GPLL>, <&pmucru PLL_PPLL>;
assigned-clock-rates = <32768>, <1200000000>, <200000000>;
assigned-clock-parents = <&pmucru CLK_RTC32K_FRAC>;
- i2c0: i2c@fdd40000 {
compatible = "rockchip,rk3568-i2c", "rockchip,rk3399-i2c";
reg = <0x0 0xfdd40000 0x0 0x1000>;
interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&pmucru CLK_I2C0>, <&pmucru PCLK_I2C0>;
clock-names = "i2c", "pclk";
pinctrl-0 = <&i2c0_xfer>;
#size-cells = <0>;
- uart0: serial@fdd50000 {
compatible = "rockchip,rk3568-uart", "snps,dw-apb-uart";
reg = <0x0 0xfdd50000 0x0 0x100>;
interrupts = <GIC_SPI 116 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&pmucru SCLK_UART0>, <&pmucru PCLK_UART0>;
clock-names = "baudclk", "apb_pclk";
dmas = <&dmac0 0>, <&dmac0 1>;
pinctrl-0 = <&uart0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- pwm0: pwm@fdd70000 {
compatible = "rockchip,rk3568-pwm", "rockchip,rk3328-pwm";
reg = <0x0 0xfdd70000 0x0 0x10>;
clocks = <&pmucru CLK_PWM0>, <&pmucru PCLK_PWM0>;
clock-names = "pwm", "pclk";
pinctrl-0 = <&pwm0m0_pins>;
#pwm-cells = <3>;
- pwm1: pwm@fdd70010 {
reg = <0x0 0xfdd70010 0x0 0x10>;
pinctrl-0 = <&pwm1m0_pins>;
#pwm-cells = <3>;
- pwm2: pwm@fdd70020 {
reg = <0x0 0xfdd70020 0x0 0x10>;
pinctrl-0 = <&pwm2m0_pins>;
#pwm-cells = <3>;
- pwm3: pwm@fdd70030 {
reg = <0x0 0xfdd70030 0x0 0x10>;
pinctrl-0 = <&pwm3_pins>;
#pwm-cells = <3>;
- pmu: power-management@fdd90000 {
compatible = "rockchip,rk3568-pmu", "syscon", "simple-mfd";
reg = <0x0 0xfdd90000 0x0 0x1000>;
power: power-controller {
compatible = "rockchip,rk3568-power-controller";
#power-domain-cells = <1>;
#size-cells = <0>;
/* These power domains are grouped by VD_GPU */
power-domain@RK3568_PD_GPU {
reg = <RK3568_PD_GPU>;
clocks = <&cru ACLK_GPU_PRE>,
<&cru PCLK_GPU_PRE>;
pm_qos = <&qos_gpu>;
/* These power domains are grouped by VD_LOGIC */
power-domain@RK3568_PD_VI {
reg = <RK3568_PD_VI>;
clocks = <&cru HCLK_VI>,
<&cru PCLK_VI>;
pm_qos = <&qos_isp>,
<&qos_vicap0>,
<&qos_vicap1>;
power-domain@RK3568_PD_VO {
reg = <RK3568_PD_VO>;
clocks = <&cru HCLK_VO>,
<&cru PCLK_VO>,
<&cru ACLK_VOP_PRE>;
pm_qos = <&qos_hdcp>,
<&qos_vop_m0>,
<&qos_vop_m1>;
power-domain@RK3568_PD_RGA {
reg = <RK3568_PD_RGA>;
clocks = <&cru HCLK_RGA_PRE>,
<&cru PCLK_RGA_PRE>;
pm_qos = <&qos_ebc>,
<&qos_iep>,
<&qos_jpeg_dec>,
<&qos_jpeg_enc>,
<&qos_rga_rd>,
<&qos_rga_wr>;
power-domain@RK3568_PD_VPU {
reg = <RK3568_PD_VPU>;
clocks = <&cru HCLK_VPU_PRE>;
pm_qos = <&qos_vpu>;
power-domain@RK3568_PD_RKVDEC {
clocks = <&cru HCLK_RKVDEC_PRE>;
reg = <RK3568_PD_RKVDEC>;
pm_qos = <&qos_rkvdec>;
power-domain@RK3568_PD_RKVENC {
reg = <RK3568_PD_RKVENC>;
clocks = <&cru HCLK_RKVENC_PRE>;
pm_qos = <&qos_rkvenc_rd_m0>,
<&qos_rkvenc_rd_m1>,
<&qos_rkvenc_wr_m0>;
- gpu: gpu@fde60000 {
compatible = "rockchip,rk3568-mali", "arm,mali-bifrost";
reg = <0x0 0xfde60000 0x0 0x4000>;
interrupts = <GIC_SPI 40 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 39 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "job", "mmu", "gpu";
clocks = <&scmi_clk 1>, <&cru CLK_GPU>;
clock-names = "gpu", "bus";
operating-points-v2 = <&gpu_opp_table>;
power-domains = <&power RK3568_PD_GPU>;
- vpu: video-codec@fdea0400 {
compatible = "rockchip,rk3568-vpu";
reg = <0x0 0xfdea0000 0x0 0x800>;
interrupts = <GIC_SPI 139 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_VPU>, <&cru HCLK_VPU>;
clock-names = "aclk", "hclk";
iommus = <&vdpu_mmu>;
power-domains = <&power RK3568_PD_VPU>;
- vdpu_mmu: iommu@fdea0800 {
compatible = "rockchip,rk3568-iommu";
reg = <0x0 0xfdea0800 0x0 0x40>;
interrupts = <GIC_SPI 138 IRQ_TYPE_LEVEL_HIGH>;
clock-names = "aclk", "iface";
#iommu-cells = <0>;
- rga: rga@fdeb0000 {
compatible = "rockchip,rk3568-rga", "rockchip,rk3288-rga";
reg = <0x0 0xfdeb0000 0x0 0x180>;
interrupts = <GIC_SPI 90 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_RGA>, <&cru HCLK_RGA>, <&cru CLK_RGA_CORE>;
clock-names = "aclk", "hclk", "sclk";
resets = <&cru SRST_RGA_CORE>, <&cru SRST_A_RGA>, <&cru SRST_H_RGA>;
reset-names = "core", "axi", "ahb";
power-domains = <&power RK3568_PD_RGA>;
- vepu: video-codec@fdee0000 {
compatible = "rockchip,rk3568-vepu";
reg = <0x0 0xfdee0000 0x0 0x800>;
interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_JENC>, <&cru HCLK_JENC>;
iommus = <&vepu_mmu>;
- vepu_mmu: iommu@fdee0800 {
reg = <0x0 0xfdee0800 0x0 0x40>;
interrupts = <GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>;
#iommu-cells = <0>;
- sdmmc2: mmc@fe000000 {
compatible = "rockchip,rk3568-dw-mshc", "rockchip,rk3288-dw-mshc";
reg = <0x0 0xfe000000 0x0 0x4000>;
interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_SDMMC2>, <&cru CLK_SDMMC2>,
<&cru SCLK_SDMMC2_DRV>, <&cru SCLK_SDMMC2_SAMPLE>;
clock-names = "biu", "ciu", "ciu-drive", "ciu-sample";
fifo-depth = <0x100>;
max-frequency = <150000000>;
resets = <&cru SRST_SDMMC2>;
reset-names = "reset";
- gmac1: ethernet@fe010000 {
reg = <0x0 0xfe010000 0x0 0x10000>;
interrupts = <GIC_SPI 32 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 29 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_GMAC1>, <&cru SCLK_GMAC1_RX_TX>,
<&cru SCLK_GMAC1_RX_TX>, <&cru CLK_MAC1_REFOUT>,
<&cru ACLK_GMAC1>, <&cru PCLK_GMAC1>,
<&cru SCLK_GMAC1_RX_TX>, <&cru CLK_GMAC1_PTP_REF>;
resets = <&cru SRST_A_GMAC1>;
snps,axi-config = <&gmac1_stmmac_axi_setup>;
snps,mixed-burst;
snps,mtl-rx-config = <&gmac1_mtl_rx_setup>;
snps,mtl-tx-config = <&gmac1_mtl_tx_setup>;
snps,tso;
mdio1: mdio {
gmac1_stmmac_axi_setup: stmmac-axi-config {
gmac1_mtl_rx_setup: rx-queues-config {
queue0 {};
gmac1_mtl_tx_setup: tx-queues-config {
queue0 {};
- vop: vop@fe040000 {
reg = <0x0 0xfe040000 0x0 0x3000>, <0x0 0xfe044000 0x0 0x1000>;
reg-names = "vop", "gamma-lut";
interrupts = <GIC_SPI 148 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>, <&cru DCLK_VOP0>,
<&cru DCLK_VOP1>, <&cru DCLK_VOP2>;
clock-names = "aclk", "hclk", "dclk_vp0", "dclk_vp1", "dclk_vp2";
iommus = <&vop_mmu>;
power-domains = <&power RK3568_PD_VO>;
vop_out: ports {
#size-cells = <0>;
vp0: port@0 {
reg = <0>;
#size-cells = <0>;
vp1: port@1 {
reg = <1>;
#size-cells = <0>;
vp2: port@2 {
reg = <2>;
#size-cells = <0>;
- vop_mmu: iommu@fe043e00 {
reg = <0x0 0xfe043e00 0x0 0x100>, <0x0 0xfe043f00 0x0 0x100>;
clocks = <&cru ACLK_VOP>, <&cru HCLK_VOP>;
#iommu-cells = <0>;
- dsi0: dsi@fe060000 {
compatible = "rockchip,rk3568-mipi-dsi", "snps,dw-mipi-dsi";
reg = <0x00 0xfe060000 0x00 0x10000>;
interrupts = <GIC_SPI 68 IRQ_TYPE_LEVEL_HIGH>;
clock-names = "pclk";
clocks = <&cru PCLK_DSITX_0>;
phy-names = "dphy";
phys = <&dsi_dphy0>;
reset-names = "apb";
resets = <&cru SRST_P_DSITX_0>;
ports {
#size-cells = <0>;
dsi0_in: port@0 {
reg = <0>;
dsi0_out: port@1 {
reg = <1>;
- dsi1: dsi@fe070000 {
reg = <0x0 0xfe070000 0x0 0x10000>;
interrupts = <GIC_SPI 69 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_DSITX_1>;
phy-names = "dphy";
phys = <&dsi_dphy1>;
resets = <&cru SRST_P_DSITX_1>;
ports {
#size-cells = <0>;
dsi1_in: port@0 {
reg = <0>;
dsi1_out: port@1 {
reg = <1>;
- hdmi: hdmi@fe0a0000 {
compatible = "rockchip,rk3568-dw-hdmi";
reg = <0x0 0xfe0a0000 0x0 0x20000>;
interrupts = <GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_HDMI_HOST>,
<&cru CLK_HDMI_SFR>,
<&cru CLK_HDMI_CEC>,
<&pmucru CLK_HDMI_REF>,
<&cru HCLK_VO>;
clock-names = "iahb", "isfr", "cec", "ref";
pinctrl-0 = <&hdmitx_scl &hdmitx_sda &hdmitxm0_cec>;
reg-io-width = <4>;
ports {
#size-cells = <0>;
hdmi_in: port@0 {
reg = <0>;
hdmi_out: port@1 {
reg = <1>;
- qos_gpu: qos@fe128000 {
reg = <0x0 0xfe128000 0x0 0x20>;
- qos_rkvenc_rd_m0: qos@fe138080 {
reg = <0x0 0xfe138080 0x0 0x20>;
- qos_rkvenc_rd_m1: qos@fe138100 {
reg = <0x0 0xfe138100 0x0 0x20>;
- qos_rkvenc_wr_m0: qos@fe138180 {
reg = <0x0 0xfe138180 0x0 0x20>;
- qos_isp: qos@fe148000 {
reg = <0x0 0xfe148000 0x0 0x20>;
- qos_vicap0: qos@fe148080 {
reg = <0x0 0xfe148080 0x0 0x20>;
- qos_vicap1: qos@fe148100 {
reg = <0x0 0xfe148100 0x0 0x20>;
- qos_vpu: qos@fe150000 {
reg = <0x0 0xfe150000 0x0 0x20>;
- qos_ebc: qos@fe158000 {
reg = <0x0 0xfe158000 0x0 0x20>;
- qos_iep: qos@fe158100 {
reg = <0x0 0xfe158100 0x0 0x20>;
- qos_jpeg_dec: qos@fe158180 {
reg = <0x0 0xfe158180 0x0 0x20>;
- qos_jpeg_enc: qos@fe158200 {
reg = <0x0 0xfe158200 0x0 0x20>;
- qos_rga_rd: qos@fe158280 {
reg = <0x0 0xfe158280 0x0 0x20>;
- qos_rga_wr: qos@fe158300 {
reg = <0x0 0xfe158300 0x0 0x20>;
- qos_npu: qos@fe180000 {
reg = <0x0 0xfe180000 0x0 0x20>;
- qos_pcie2x1: qos@fe190000 {
reg = <0x0 0xfe190000 0x0 0x20>;
- qos_sata1: qos@fe190280 {
reg = <0x0 0xfe190280 0x0 0x20>;
- qos_sata2: qos@fe190300 {
reg = <0x0 0xfe190300 0x0 0x20>;
- qos_usb3_0: qos@fe190380 {
reg = <0x0 0xfe190380 0x0 0x20>;
- qos_usb3_1: qos@fe190400 {
reg = <0x0 0xfe190400 0x0 0x20>;
- qos_rkvdec: qos@fe198000 {
reg = <0x0 0xfe198000 0x0 0x20>;
- qos_hdcp: qos@fe1a8000 {
reg = <0x0 0xfe1a8000 0x0 0x20>;
- qos_vop_m0: qos@fe1a8080 {
reg = <0x0 0xfe1a8080 0x0 0x20>;
- qos_vop_m1: qos@fe1a8100 {
reg = <0x0 0xfe1a8100 0x0 0x20>;
- dfi: dfi@fe230000 {
compatible = "rockchip,rk3568-dfi";
reg = <0x00 0xfe230000 0x00 0x400>;
interrupts = <GIC_SPI 11 IRQ_TYPE_LEVEL_HIGH>;
rockchip,pmu = <&pmugrf>;
- pcie2x1: pcie@fe260000 {
reg = <0x3 0xc0000000 0x0 0x00400000>,
<0x0 0xfe260000 0x0 0x00010000>,
<0x0 0xf4000000 0x0 0x00100000>;
interrupts = <GIC_SPI 75 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 74 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 73 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 72 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 71 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru ACLK_PCIE20_MST>, <&cru ACLK_PCIE20_SLV>,
<&cru ACLK_PCIE20_DBI>, <&cru PCLK_PCIE20>,
<&cru CLK_PCIE20_AUX_NDFT>;
interrupt-map = <0 0 0 1 &pcie_intc 0>,
<0 0 0 2 &pcie_intc 1>,
<0 0 0 3 &pcie_intc 2>,
<0 0 0 4 &pcie_intc 3>;
linux,pci-domain = <0>;
max-link-speed = <2>;
msi-map = <0x0 &gic 0x0 0x1000>;
num-lanes = <1>;
phys = <&combphy2 PHY_TYPE_PCIE>;
ranges = <0x01000000 0x0 0xf4100000 0x0 0xf4100000 0x0 0x00100000>,
<0x02000000 0x0 0xf4200000 0x0 0xf4200000 0x0 0x01e00000>,
<0x03000000 0x0 0x40000000 0x3 0x00000000 0x0 0x40000000>;
resets = <&cru SRST_PCIE20_POWERUP>;
#size-cells = <2>;
pcie_intc: legacy-interrupt-controller {
interrupts = <GIC_SPI 72 IRQ_TYPE_EDGE_RISING>;
- sdmmc0: mmc@fe2b0000 {
reg = <0x0 0xfe2b0000 0x0 0x4000>;
interrupts = <GIC_SPI 98 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_SDMMC0>, <&cru CLK_SDMMC0>,
<&cru SCLK_SDMMC0_DRV>, <&cru SCLK_SDMMC0_SAMPLE>;
resets = <&cru SRST_SDMMC0>;
- sdmmc1: mmc@fe2c0000 {
reg = <0x0 0xfe2c0000 0x0 0x4000>;
interrupts = <GIC_SPI 99 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru HCLK_SDMMC1>, <&cru CLK_SDMMC1>,
<&cru SCLK_SDMMC1_DRV>, <&cru SCLK_SDMMC1_SAMPLE>;
resets = <&cru SRST_SDMMC1>;
- sfc: spi@fe300000 {
compatible = "rockchip,sfc";
reg = <0x0 0xfe300000 0x0 0x4000>;
interrupts = <GIC_SPI 101 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_SFC>, <&cru HCLK_SFC>;
clock-names = "clk_sfc", "hclk_sfc";
pinctrl-0 = <&fspi_pins>;
- sdhci: mmc@fe310000 {
compatible = "rockchip,rk3568-dwcmshc";
reg = <0x0 0xfe310000 0x0 0x10000>;
interrupts = <GIC_SPI 19 IRQ_TYPE_LEVEL_HIGH>;
assigned-clocks = <&cru BCLK_EMMC>, <&cru TCLK_EMMC>;
assigned-clock-rates = <200000000>, <24000000>;
clocks = <&cru CCLK_EMMC>, <&cru HCLK_EMMC>,
<&cru ACLK_EMMC>, <&cru BCLK_EMMC>,
<&cru TCLK_EMMC>;
clock-names = "core", "bus", "axi", "block", "timer";
- i2s0_8ch: i2s@fe400000 {
compatible = "rockchip,rk3568-i2s-tdm";
reg = <0x0 0xfe400000 0x0 0x1000>;
interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
assigned-clocks = <&cru CLK_I2S0_8CH_TX_SRC>, <&cru CLK_I2S0_8CH_RX_SRC>;
assigned-clock-rates = <1188000000>, <1188000000>;
clocks = <&cru MCLK_I2S0_8CH_TX>, <&cru MCLK_I2S0_8CH_RX>, <&cru HCLK_I2S0_8CH>;
clock-names = "mclk_tx", "mclk_rx", "hclk";
dmas = <&dmac1 0>;
dma-names = "tx";
resets = <&cru SRST_M_I2S0_8CH_TX>, <&cru SRST_M_I2S0_8CH_RX>;
reset-names = "tx-m", "rx-m";
- i2s1_8ch: i2s@fe410000 {
reg = <0x0 0xfe410000 0x0 0x1000>;
interrupts = <GIC_SPI 53 IRQ_TYPE_LEVEL_HIGH>;
assigned-clocks = <&cru CLK_I2S1_8CH_TX_SRC>, <&cru CLK_I2S1_8CH_RX_SRC>;
clocks = <&cru MCLK_I2S1_8CH_TX>, <&cru MCLK_I2S1_8CH_RX>,
<&cru HCLK_I2S1_8CH>;
dmas = <&dmac1 3>, <&dmac1 2>;
dma-names = "rx", "tx";
resets = <&cru SRST_M_I2S1_8CH_TX>, <&cru SRST_M_I2S1_8CH_RX>;
pinctrl-0 = <&i2s1m0_sclktx &i2s1m0_sclkrx
&i2s1m0_lrcktx &i2s1m0_lrckrx
&i2s1m0_sdi0 &i2s1m0_sdi1
&i2s1m0_sdi2 &i2s1m0_sdi3
&i2s1m0_sdo0 &i2s1m0_sdo1
&i2s1m0_sdo2 &i2s1m0_sdo3>;
- i2s2_2ch: i2s@fe420000 {
reg = <0x0 0xfe420000 0x0 0x1000>;
interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
assigned-clocks = <&cru CLK_I2S2_2CH_SRC>;
assigned-clock-rates = <1188000000>;
clocks = <&cru MCLK_I2S2_2CH>, <&cru MCLK_I2S2_2CH>, <&cru HCLK_I2S2_2CH>;
dmas = <&dmac1 4>, <&dmac1 5>;
dma-names = "tx", "rx";
resets = <&cru SRST_M_I2S2_2CH>;
reset-names = "m";
pinctrl-0 = <&i2s2m0_sclktx
&i2s2m0_lrcktx
&i2s2m0_sdi
&i2s2m0_sdo>;
- i2s3_2ch: i2s@fe430000 {
reg = <0x0 0xfe430000 0x0 0x1000>;
interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru MCLK_I2S3_2CH_TX>, <&cru MCLK_I2S3_2CH_RX>,
<&cru HCLK_I2S3_2CH>;
dmas = <&dmac1 6>, <&dmac1 7>;
resets = <&cru SRST_M_I2S3_2CH_TX>, <&cru SRST_M_I2S3_2CH_RX>;
- pdm: pdm@fe440000 {
compatible = "rockchip,rk3568-pdm";
reg = <0x0 0xfe440000 0x0 0x1000>;
interrupts = <GIC_SPI 76 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru MCLK_PDM>, <&cru HCLK_PDM>;
clock-names = "pdm_clk", "pdm_hclk";
dmas = <&dmac1 9>;
dma-names = "rx";
pinctrl-0 = <&pdmm0_clk
&pdmm0_clk1
&pdmm0_sdi0
&pdmm0_sdi1
&pdmm0_sdi2
&pdmm0_sdi3>;
resets = <&cru SRST_M_PDM>;
reset-names = "pdm-m";
- spdif: spdif@fe460000 {
compatible = "rockchip,rk3568-spdif";
reg = <0x0 0xfe460000 0x0 0x1000>;
interrupts = <GIC_SPI 102 IRQ_TYPE_LEVEL_HIGH>;
clock-names = "mclk", "hclk";
clocks = <&cru MCLK_SPDIF_8CH>, <&cru HCLK_SPDIF_8CH>;
dmas = <&dmac1 1>;
dma-names = "tx";
pinctrl-0 = <&spdifm0_tx>;
- dmac0: dma-controller@fe530000 {
compatible = "arm,pl330", "arm,primecell";
reg = <0x0 0xfe530000 0x0 0x4000>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 13 IRQ_TYPE_LEVEL_HIGH>;
arm,pl330-periph-burst;
clocks = <&cru ACLK_BUS>;
clock-names = "apb_pclk";
#dma-cells = <1>;
- dmac1: dma-controller@fe550000 {
reg = <0x0 0xfe550000 0x0 0x4000>;
interrupts = <GIC_SPI 16 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 15 IRQ_TYPE_LEVEL_HIGH>;
#dma-cells = <1>;
- i2c1: i2c@fe5a0000 {
reg = <0x0 0xfe5a0000 0x0 0x1000>;
interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_I2C1>, <&cru PCLK_I2C1>;
pinctrl-0 = <&i2c1_xfer>;
#size-cells = <0>;
- i2c2: i2c@fe5b0000 {
reg = <0x0 0xfe5b0000 0x0 0x1000>;
interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_I2C2>, <&cru PCLK_I2C2>;
pinctrl-0 = <&i2c2m0_xfer>;
#size-cells = <0>;
- i2c3: i2c@fe5c0000 {
reg = <0x0 0xfe5c0000 0x0 0x1000>;
interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_I2C3>, <&cru PCLK_I2C3>;
pinctrl-0 = <&i2c3m0_xfer>;
#size-cells = <0>;
- i2c4: i2c@fe5d0000 {
reg = <0x0 0xfe5d0000 0x0 0x1000>;
interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_I2C4>, <&cru PCLK_I2C4>;
pinctrl-0 = <&i2c4m0_xfer>;
#size-cells = <0>;
- i2c5: i2c@fe5e0000 {
reg = <0x0 0xfe5e0000 0x0 0x1000>;
interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_I2C5>, <&cru PCLK_I2C5>;
pinctrl-0 = <&i2c5m0_xfer>;
#size-cells = <0>;
- wdt: watchdog@fe600000 {
compatible = "rockchip,rk3568-wdt", "snps,dw-wdt";
reg = <0x0 0xfe600000 0x0 0x100>;
interrupts = <GIC_SPI 149 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru TCLK_WDT_NS>, <&cru PCLK_WDT_NS>;
clock-names = "tclk", "pclk";
- spi0: spi@fe610000 {
compatible = "rockchip,rk3568-spi", "rockchip,rk3066-spi";
reg = <0x0 0xfe610000 0x0 0x1000>;
interrupts = <GIC_SPI 103 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_SPI0>, <&cru PCLK_SPI0>;
clock-names = "spiclk", "apb_pclk";
dmas = <&dmac0 20>, <&dmac0 21>;
pinctrl-0 = <&spi0m0_cs0 &spi0m0_cs1 &spi0m0_pins>;
#size-cells = <0>;
- spi1: spi@fe620000 {
reg = <0x0 0xfe620000 0x0 0x1000>;
interrupts = <GIC_SPI 104 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_SPI1>, <&cru PCLK_SPI1>;
dmas = <&dmac0 22>, <&dmac0 23>;
pinctrl-0 = <&spi1m0_cs0 &spi1m0_cs1 &spi1m0_pins>;
#size-cells = <0>;
- spi2: spi@fe630000 {
reg = <0x0 0xfe630000 0x0 0x1000>;
interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_SPI2>, <&cru PCLK_SPI2>;
dmas = <&dmac0 24>, <&dmac0 25>;
pinctrl-0 = <&spi2m0_cs0 &spi2m0_cs1 &spi2m0_pins>;
#size-cells = <0>;
- spi3: spi@fe640000 {
reg = <0x0 0xfe640000 0x0 0x1000>;
interrupts = <GIC_SPI 106 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_SPI3>, <&cru PCLK_SPI3>;
dmas = <&dmac0 26>, <&dmac0 27>;
pinctrl-0 = <&spi3m0_cs0 &spi3m0_cs1 &spi3m0_pins>;
#size-cells = <0>;
- uart1: serial@fe650000 {
reg = <0x0 0xfe650000 0x0 0x100>;
interrupts = <GIC_SPI 117 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART1>, <&cru PCLK_UART1>;
dmas = <&dmac0 2>, <&dmac0 3>;
pinctrl-0 = <&uart1m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart2: serial@fe660000 {
reg = <0x0 0xfe660000 0x0 0x100>;
interrupts = <GIC_SPI 118 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART2>, <&cru PCLK_UART2>;
dmas = <&dmac0 4>, <&dmac0 5>;
pinctrl-0 = <&uart2m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart3: serial@fe670000 {
reg = <0x0 0xfe670000 0x0 0x100>;
interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART3>, <&cru PCLK_UART3>;
dmas = <&dmac0 6>, <&dmac0 7>;
pinctrl-0 = <&uart3m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart4: serial@fe680000 {
reg = <0x0 0xfe680000 0x0 0x100>;
interrupts = <GIC_SPI 120 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART4>, <&cru PCLK_UART4>;
dmas = <&dmac0 8>, <&dmac0 9>;
pinctrl-0 = <&uart4m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart5: serial@fe690000 {
reg = <0x0 0xfe690000 0x0 0x100>;
interrupts = <GIC_SPI 121 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART5>, <&cru PCLK_UART5>;
dmas = <&dmac0 10>, <&dmac0 11>;
pinctrl-0 = <&uart5m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart6: serial@fe6a0000 {
reg = <0x0 0xfe6a0000 0x0 0x100>;
interrupts = <GIC_SPI 122 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART6>, <&cru PCLK_UART6>;
dmas = <&dmac0 12>, <&dmac0 13>;
pinctrl-0 = <&uart6m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart7: serial@fe6b0000 {
reg = <0x0 0xfe6b0000 0x0 0x100>;
interrupts = <GIC_SPI 123 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART7>, <&cru PCLK_UART7>;
dmas = <&dmac0 14>, <&dmac0 15>;
pinctrl-0 = <&uart7m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart8: serial@fe6c0000 {
reg = <0x0 0xfe6c0000 0x0 0x100>;
interrupts = <GIC_SPI 124 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART8>, <&cru PCLK_UART8>;
dmas = <&dmac0 16>, <&dmac0 17>;
pinctrl-0 = <&uart8m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- uart9: serial@fe6d0000 {
reg = <0x0 0xfe6d0000 0x0 0x100>;
interrupts = <GIC_SPI 125 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru SCLK_UART9>, <&cru PCLK_UART9>;
dmas = <&dmac0 18>, <&dmac0 19>;
pinctrl-0 = <&uart9m0_xfer>;
reg-io-width = <4>;
reg-shift = <2>;
- thermal_zones: thermal-zones {
cpu_thermal: cpu-thermal {
polling-delay-passive = <100>;
polling-delay = <1000>;
thermal-sensors = <&tsadc 0>;
trips {
cpu_alert0: cpu_alert0 {
temperature = <70000>;
hysteresis = <2000>;
type = "passive";
cpu_alert1: cpu_alert1 {
temperature = <75000>;
type = "passive";
cpu_crit: cpu_crit {
temperature = <95000>;
type = "critical";
cooling-maps {
map0 {
trip = <&cpu_alert0>;
cooling-device =
<&cpu0 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu1 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu2 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>,
<&cpu3 THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
gpu_thermal: gpu-thermal {
polling-delay-passive = <20>; /* milliseconds */
polling-delay = <1000>; /* milliseconds */
thermal-sensors = <&tsadc 1>;
trips {
gpu_threshold: gpu-threshold {
type = "passive";
gpu_target: gpu-target {
type = "passive";
gpu_crit: gpu-crit {
type = "critical";
cooling-maps {
map0 {
trip = <&gpu_target>;
cooling-device =
<&gpu THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
- tsadc: tsadc@fe710000 {
compatible = "rockchip,rk3568-tsadc";
reg = <0x0 0xfe710000 0x0 0x100>;
interrupts = <GIC_SPI 115 IRQ_TYPE_LEVEL_HIGH>;
assigned-clocks = <&cru CLK_TSADC_TSEN>, <&cru CLK_TSADC>;
assigned-clock-rates = <17000000>, <700000>;
clocks = <&cru CLK_TSADC>, <&cru PCLK_TSADC>;
clock-names = "tsadc", "apb_pclk";
resets = <&cru SRST_P_TSADC>, <&cru SRST_TSADC>,
<&cru SRST_TSADCPHY>;
rockchip,hw-tshut-temp = <95000>;
pinctrl-names = "init", "default", "sleep";
pinctrl-0 = <&tsadc_pin>;
pinctrl-1 = <&tsadc_shutorg>;
pinctrl-2 = <&tsadc_pin>;
#thermal-sensor-cells = <1>;
- saradc: saradc@fe720000 {
compatible = "rockchip,rk3568-saradc", "rockchip,rk3399-saradc";
reg = <0x0 0xfe720000 0x0 0x100>;
interrupts = <GIC_SPI 93 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru CLK_SARADC>, <&cru PCLK_SARADC>;
clock-names = "saradc", "apb_pclk";
resets = <&cru SRST_P_SARADC>;
reset-names = "saradc-apb";
#io-channel-cells = <1>;
- pwm4: pwm@fe6e0000 {
reg = <0x0 0xfe6e0000 0x0 0x10>;
clocks = <&cru CLK_PWM1>, <&cru PCLK_PWM1>;
pinctrl-0 = <&pwm4_pins>;
#pwm-cells = <3>;
- pwm5: pwm@fe6e0010 {
reg = <0x0 0xfe6e0010 0x0 0x10>;
pinctrl-0 = <&pwm5_pins>;
#pwm-cells = <3>;
- pwm6: pwm@fe6e0020 {
reg = <0x0 0xfe6e0020 0x0 0x10>;
pinctrl-0 = <&pwm6_pins>;
#pwm-cells = <3>;
- pwm7: pwm@fe6e0030 {
reg = <0x0 0xfe6e0030 0x0 0x10>;
pinctrl-0 = <&pwm7_pins>;
#pwm-cells = <3>;
- pwm8: pwm@fe6f0000 {
reg = <0x0 0xfe6f0000 0x0 0x10>;
clocks = <&cru CLK_PWM2>, <&cru PCLK_PWM2>;
pinctrl-0 = <&pwm8m0_pins>;
#pwm-cells = <3>;
- pwm9: pwm@fe6f0010 {
reg = <0x0 0xfe6f0010 0x0 0x10>;
pinctrl-0 = <&pwm9m0_pins>;
#pwm-cells = <3>;
- pwm10: pwm@fe6f0020 {
reg = <0x0 0xfe6f0020 0x0 0x10>;
pinctrl-0 = <&pwm10m0_pins>;
#pwm-cells = <3>;
- pwm11: pwm@fe6f0030 {
reg = <0x0 0xfe6f0030 0x0 0x10>;
pinctrl-0 = <&pwm11m0_pins>;
#pwm-cells = <3>;
- pwm12: pwm@fe700000 {
reg = <0x0 0xfe700000 0x0 0x10>;
clocks = <&cru CLK_PWM3>, <&cru PCLK_PWM3>;
pinctrl-0 = <&pwm12m0_pins>;
#pwm-cells = <3>;
- pwm13: pwm@fe700010 {
reg = <0x0 0xfe700010 0x0 0x10>;
pinctrl-0 = <&pwm13m0_pins>;
#pwm-cells = <3>;
- pwm14: pwm@fe700020 {
reg = <0x0 0xfe700020 0x0 0x10>;
pinctrl-0 = <&pwm14m0_pins>;
#pwm-cells = <3>;
- pwm15: pwm@fe700030 {
reg = <0x0 0xfe700030 0x0 0x10>;
pinctrl-0 = <&pwm15m0_pins>;
#pwm-cells = <3>;
- combphy1: phy@fe830000 {
reg = <0x0 0xfe830000 0x0 0x100>;
clocks = <&pmucru CLK_PCIEPHY1_REF>,
<&cru PCLK_PIPEPHY1>,
<&cru PCLK_PIPE>;
assigned-clocks = <&pmucru CLK_PCIEPHY1_REF>;
resets = <&cru SRST_PIPEPHY1>;
rockchip,pipe-phy-grf = <&pipe_phy_grf1>;
#phy-cells = <1>;
- combphy2: phy@fe840000 {
reg = <0x0 0xfe840000 0x0 0x100>;
clocks = <&pmucru CLK_PCIEPHY2_REF>,
<&cru PCLK_PIPEPHY2>,
<&cru PCLK_PIPE>;
assigned-clocks = <&pmucru CLK_PCIEPHY2_REF>;
resets = <&cru SRST_PIPEPHY2>;
rockchip,pipe-phy-grf = <&pipe_phy_grf2>;
#phy-cells = <1>;
- csi_dphy: phy@fe870000 {
compatible = "rockchip,rk3568-csi-dphy";
reg = <0x0 0xfe870000 0x0 0x10000>;
clocks = <&cru PCLK_MIPICSIPHY>;
#phy-cells = <0>;
resets = <&cru SRST_P_MIPICSIPHY>;
- dsi_dphy0: mipi-dphy@fe850000 {
compatible = "rockchip,rk3568-dsi-dphy";
reg = <0x0 0xfe850000 0x0 0x10000>;
clock-names = "ref", "pclk";
clocks = <&pmucru CLK_MIPIDSIPHY0_REF>, <&cru PCLK_MIPIDSIPHY0>;
#phy-cells = <0>;
resets = <&cru SRST_P_MIPIDSIPHY0>;
- dsi_dphy1: mipi-dphy@fe860000 {
reg = <0x0 0xfe860000 0x0 0x10000>;
clocks = <&pmucru CLK_MIPIDSIPHY1_REF>, <&cru PCLK_MIPIDSIPHY1>;
#phy-cells = <0>;
resets = <&cru SRST_P_MIPIDSIPHY1>;
- usb2phy0: usb2phy@fe8a0000 {
compatible = "rockchip,rk3568-usb2phy";
reg = <0x0 0xfe8a0000 0x0 0x10000>;
clocks = <&pmucru CLK_USBPHY0_REF>;
clock-names = "phyclk";
clock-output-names = "clk_usbphy0_480m";
interrupts = <GIC_SPI 135 IRQ_TYPE_LEVEL_HIGH>;
rockchip,usbgrf = <&usb2phy0_grf>;
#clock-cells = <0>;
usb2phy0_host: host-port {
#phy-cells = <0>;
usb2phy0_otg: otg-port {
#phy-cells = <0>;
- usb2phy1: usb2phy@fe8b0000 {
reg = <0x0 0xfe8b0000 0x0 0x10000>;
clocks = <&pmucru CLK_USBPHY1_REF>;
clock-output-names = "clk_usbphy1_480m";
interrupts = <GIC_SPI 136 IRQ_TYPE_LEVEL_HIGH>;
rockchip,usbgrf = <&usb2phy1_grf>;
#clock-cells = <0>;
usb2phy1_host: host-port {
#phy-cells = <0>;
usb2phy1_otg: otg-port {
#phy-cells = <0>;
- pinctrl: pinctrl {
compatible = "rockchip,rk3568-pinctrl";
#size-cells = <2>;
ranges;
gpio0: gpio@fdd60000 {
compatible = "rockchip,gpio-bank";
reg = <0x0 0xfdd60000 0x0 0x100>;
interrupts = <GIC_SPI 33 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&pmucru PCLK_GPIO0>, <&pmucru DBCLK_GPIO0>;
gpio-controller;
gpio-ranges = <&pinctrl 0 0 32>;
#gpio-cells = <2>;
#interrupt-cells = <2>;
gpio1: gpio@fe740000 {
reg = <0x0 0xfe740000 0x0 0x100>;
interrupts = <GIC_SPI 34 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO1>, <&cru DBCLK_GPIO1>;
gpio-controller;
gpio-ranges = <&pinctrl 0 32 32>;
#gpio-cells = <2>;
gpio2: gpio@fe750000 {
reg = <0x0 0xfe750000 0x0 0x100>;
interrupts = <GIC_SPI 35 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO2>, <&cru DBCLK_GPIO2>;
gpio-controller;
gpio-ranges = <&pinctrl 0 64 32>;
#gpio-cells = <2>;
gpio3: gpio@fe760000 {
reg = <0x0 0xfe760000 0x0 0x100>;
interrupts = <GIC_SPI 36 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO3>, <&cru DBCLK_GPIO3>;
gpio-controller;
gpio-ranges = <&pinctrl 0 96 32>;
#gpio-cells = <2>;
gpio4: gpio@fe770000 {
reg = <0x0 0xfe770000 0x0 0x100>;
interrupts = <GIC_SPI 37 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&cru PCLK_GPIO4>, <&cru DBCLK_GPIO4>;
gpio-controller;
gpio-ranges = <&pinctrl 0 128 32>;
#gpio-cells = <2>;
-#include "rk3568-pinctrl.dtsi" diff --git a/include/dt-bindings/clock/rk3568-cru.h b/include/dt-bindings/clock/rk3568-cru.h deleted file mode 100644 index d29890865150..000000000000 --- a/include/dt-bindings/clock/rk3568-cru.h +++ /dev/null @@ -1,926 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -/*
- Copyright (c) 2021 Rockchip Electronics Co. Ltd.
- Author: Elaine Zhang zhangqing@rock-chips.com
-#ifndef _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H -#define _DT_BINDINGS_CLK_ROCKCHIP_RK3568_H
-/* pmucru-clocks indices */
-/* pmucru plls */ -#define PLL_PPLL 1 -#define PLL_HPLL 2
-/* pmucru clocks */ -#define XIN_OSC0_DIV 4 -#define CLK_RTC_32K 5 -#define CLK_PMU 6 -#define CLK_I2C0 7 -#define CLK_RTC32K_FRAC 8 -#define CLK_UART0_DIV 9 -#define CLK_UART0_FRAC 10 -#define SCLK_UART0 11 -#define DBCLK_GPIO0 12 -#define CLK_PWM0 13 -#define CLK_CAPTURE_PWM0_NDFT 14 -#define CLK_PMUPVTM 15 -#define CLK_CORE_PMUPVTM 16 -#define CLK_REF24M 17 -#define XIN_OSC0_USBPHY0_G 18 -#define CLK_USBPHY0_REF 19 -#define XIN_OSC0_USBPHY1_G 20 -#define CLK_USBPHY1_REF 21 -#define XIN_OSC0_MIPIDSIPHY0_G 22 -#define CLK_MIPIDSIPHY0_REF 23 -#define XIN_OSC0_MIPIDSIPHY1_G 24 -#define CLK_MIPIDSIPHY1_REF 25 -#define CLK_WIFI_DIV 26 -#define CLK_WIFI_OSC0 27 -#define CLK_WIFI 28 -#define CLK_PCIEPHY0_DIV 29 -#define CLK_PCIEPHY0_OSC0 30 -#define CLK_PCIEPHY0_REF 31 -#define CLK_PCIEPHY1_DIV 32 -#define CLK_PCIEPHY1_OSC0 33 -#define CLK_PCIEPHY1_REF 34 -#define CLK_PCIEPHY2_DIV 35 -#define CLK_PCIEPHY2_OSC0 36 -#define CLK_PCIEPHY2_REF 37 -#define CLK_PCIE30PHY_REF_M 38 -#define CLK_PCIE30PHY_REF_N 39 -#define CLK_HDMI_REF 40 -#define XIN_OSC0_EDPPHY_G 41 -#define PCLK_PDPMU 42 -#define PCLK_PMU 43 -#define PCLK_UART0 44 -#define PCLK_I2C0 45 -#define PCLK_GPIO0 46 -#define PCLK_PMUPVTM 47 -#define PCLK_PWM0 48 -#define CLK_PDPMU 49 -#define SCLK_32K_IOE 50
-#define CLKPMU_NR_CLKS (SCLK_32K_IOE + 1)
-/* cru-clocks indices */
-/* cru plls */ -#define PLL_APLL 1 -#define PLL_DPLL 2 -#define PLL_CPLL 3 -#define PLL_GPLL 4 -#define PLL_VPLL 5 -#define PLL_NPLL 6
-/* cru clocks */ -#define CPLL_333M 9 -#define ARMCLK 10 -#define USB480M 11 -#define ACLK_CORE_NIU2BUS 18 -#define CLK_CORE_PVTM 19 -#define CLK_CORE_PVTM_CORE 20 -#define CLK_CORE_PVTPLL 21 -#define CLK_GPU_SRC 22 -#define CLK_GPU_PRE_NDFT 23 -#define CLK_GPU_PRE_MUX 24 -#define ACLK_GPU_PRE 25 -#define PCLK_GPU_PRE 26 -#define CLK_GPU 27 -#define CLK_GPU_NP5 28 -#define PCLK_GPU_PVTM 29 -#define CLK_GPU_PVTM 30 -#define CLK_GPU_PVTM_CORE 31 -#define CLK_GPU_PVTPLL 32 -#define CLK_NPU_SRC 33 -#define CLK_NPU_PRE_NDFT 34 -#define CLK_NPU 35 -#define CLK_NPU_NP5 36 -#define HCLK_NPU_PRE 37 -#define PCLK_NPU_PRE 38 -#define ACLK_NPU_PRE 39 -#define ACLK_NPU 40 -#define HCLK_NPU 41 -#define PCLK_NPU_PVTM 42 -#define CLK_NPU_PVTM 43 -#define CLK_NPU_PVTM_CORE 44 -#define CLK_NPU_PVTPLL 45 -#define CLK_DDRPHY1X_SRC 46 -#define CLK_DDRPHY1X_HWFFC_SRC 47 -#define CLK_DDR1X 48 -#define CLK_MSCH 49 -#define CLK24_DDRMON 50 -#define ACLK_GIC_AUDIO 51 -#define HCLK_GIC_AUDIO 52 -#define HCLK_SDMMC_BUFFER 53 -#define DCLK_SDMMC_BUFFER 54 -#define ACLK_GIC600 55 -#define ACLK_SPINLOCK 56 -#define HCLK_I2S0_8CH 57 -#define HCLK_I2S1_8CH 58 -#define HCLK_I2S2_2CH 59 -#define HCLK_I2S3_2CH 60 -#define CLK_I2S0_8CH_TX_SRC 61 -#define CLK_I2S0_8CH_TX_FRAC 62 -#define MCLK_I2S0_8CH_TX 63 -#define I2S0_MCLKOUT_TX 64 -#define CLK_I2S0_8CH_RX_SRC 65 -#define CLK_I2S0_8CH_RX_FRAC 66 -#define MCLK_I2S0_8CH_RX 67 -#define I2S0_MCLKOUT_RX 68 -#define CLK_I2S1_8CH_TX_SRC 69 -#define CLK_I2S1_8CH_TX_FRAC 70 -#define MCLK_I2S1_8CH_TX 71 -#define I2S1_MCLKOUT_TX 72 -#define CLK_I2S1_8CH_RX_SRC 73 -#define CLK_I2S1_8CH_RX_FRAC 74 -#define MCLK_I2S1_8CH_RX 75 -#define I2S1_MCLKOUT_RX 76 -#define CLK_I2S2_2CH_SRC 77 -#define CLK_I2S2_2CH_FRAC 78 -#define MCLK_I2S2_2CH 79 -#define I2S2_MCLKOUT 80 -#define CLK_I2S3_2CH_TX_SRC 81 -#define CLK_I2S3_2CH_TX_FRAC 82 -#define MCLK_I2S3_2CH_TX 83 -#define I2S3_MCLKOUT_TX 84 -#define CLK_I2S3_2CH_RX_SRC 85 -#define CLK_I2S3_2CH_RX_FRAC 86 -#define MCLK_I2S3_2CH_RX 87 -#define I2S3_MCLKOUT_RX 88 -#define HCLK_PDM 89 -#define MCLK_PDM 90 -#define HCLK_VAD 91 -#define HCLK_SPDIF_8CH 92 -#define MCLK_SPDIF_8CH_SRC 93 -#define MCLK_SPDIF_8CH_FRAC 94 -#define MCLK_SPDIF_8CH 95 -#define HCLK_AUDPWM 96 -#define SCLK_AUDPWM_SRC 97 -#define SCLK_AUDPWM_FRAC 98 -#define SCLK_AUDPWM 99 -#define HCLK_ACDCDIG 100 -#define CLK_ACDCDIG_I2C 101 -#define CLK_ACDCDIG_DAC 102 -#define CLK_ACDCDIG_ADC 103 -#define ACLK_SECURE_FLASH 104 -#define HCLK_SECURE_FLASH 105 -#define ACLK_CRYPTO_NS 106 -#define HCLK_CRYPTO_NS 107 -#define CLK_CRYPTO_NS_CORE 108 -#define CLK_CRYPTO_NS_PKA 109 -#define CLK_CRYPTO_NS_RNG 110 -#define HCLK_TRNG_NS 111 -#define CLK_TRNG_NS 112 -#define PCLK_OTPC_NS 113 -#define CLK_OTPC_NS_SBPI 114 -#define CLK_OTPC_NS_USR 115 -#define HCLK_NANDC 116 -#define NCLK_NANDC 117 -#define HCLK_SFC 118 -#define HCLK_SFC_XIP 119 -#define SCLK_SFC 120 -#define ACLK_EMMC 121 -#define HCLK_EMMC 122 -#define BCLK_EMMC 123 -#define CCLK_EMMC 124 -#define TCLK_EMMC 125 -#define ACLK_PIPE 126 -#define PCLK_PIPE 127 -#define PCLK_PIPE_GRF 128 -#define ACLK_PCIE20_MST 129 -#define ACLK_PCIE20_SLV 130 -#define ACLK_PCIE20_DBI 131 -#define PCLK_PCIE20 132 -#define CLK_PCIE20_AUX_NDFT 133 -#define CLK_PCIE20_AUX_DFT 134 -#define CLK_PCIE20_PIPE_DFT 135 -#define ACLK_PCIE30X1_MST 136 -#define ACLK_PCIE30X1_SLV 137 -#define ACLK_PCIE30X1_DBI 138 -#define PCLK_PCIE30X1 139 -#define CLK_PCIE30X1_AUX_NDFT 140 -#define CLK_PCIE30X1_AUX_DFT 141 -#define CLK_PCIE30X1_PIPE_DFT 142 -#define ACLK_PCIE30X2_MST 143 -#define ACLK_PCIE30X2_SLV 144 -#define ACLK_PCIE30X2_DBI 145 -#define PCLK_PCIE30X2 146 -#define CLK_PCIE30X2_AUX_NDFT 147 -#define CLK_PCIE30X2_AUX_DFT 148 -#define CLK_PCIE30X2_PIPE_DFT 149 -#define ACLK_SATA0 150 -#define CLK_SATA0_PMALIVE 151 -#define CLK_SATA0_RXOOB 152 -#define CLK_SATA0_PIPE_NDFT 153 -#define CLK_SATA0_PIPE_DFT 154 -#define ACLK_SATA1 155 -#define CLK_SATA1_PMALIVE 156 -#define CLK_SATA1_RXOOB 157 -#define CLK_SATA1_PIPE_NDFT 158 -#define CLK_SATA1_PIPE_DFT 159 -#define ACLK_SATA2 160 -#define CLK_SATA2_PMALIVE 161 -#define CLK_SATA2_RXOOB 162 -#define CLK_SATA2_PIPE_NDFT 163 -#define CLK_SATA2_PIPE_DFT 164 -#define ACLK_USB3OTG0 165 -#define CLK_USB3OTG0_REF 166 -#define CLK_USB3OTG0_SUSPEND 167 -#define ACLK_USB3OTG1 168 -#define CLK_USB3OTG1_REF 169 -#define CLK_USB3OTG1_SUSPEND 170 -#define CLK_XPCS_EEE 171 -#define PCLK_XPCS 172 -#define ACLK_PHP 173 -#define HCLK_PHP 174 -#define PCLK_PHP 175 -#define HCLK_SDMMC0 176 -#define CLK_SDMMC0 177 -#define HCLK_SDMMC1 178 -#define CLK_SDMMC1 179 -#define ACLK_GMAC0 180 -#define PCLK_GMAC0 181 -#define CLK_MAC0_2TOP 182 -#define CLK_MAC0_OUT 183 -#define CLK_MAC0_REFOUT 184 -#define CLK_GMAC0_PTP_REF 185 -#define ACLK_USB 186 -#define HCLK_USB 187 -#define PCLK_USB 188 -#define HCLK_USB2HOST0 189 -#define HCLK_USB2HOST0_ARB 190 -#define HCLK_USB2HOST1 191 -#define HCLK_USB2HOST1_ARB 192 -#define HCLK_SDMMC2 193 -#define CLK_SDMMC2 194 -#define ACLK_GMAC1 195 -#define PCLK_GMAC1 196 -#define CLK_MAC1_2TOP 197 -#define CLK_MAC1_OUT 198 -#define CLK_MAC1_REFOUT 199 -#define CLK_GMAC1_PTP_REF 200 -#define ACLK_PERIMID 201 -#define HCLK_PERIMID 202 -#define ACLK_VI 203 -#define HCLK_VI 204 -#define PCLK_VI 205 -#define ACLK_VICAP 206 -#define HCLK_VICAP 207 -#define DCLK_VICAP 208 -#define ICLK_VICAP_G 209 -#define ACLK_ISP 210 -#define HCLK_ISP 211 -#define CLK_ISP 212 -#define PCLK_CSI2HOST1 213 -#define CLK_CIF_OUT 214 -#define CLK_CAM0_OUT 215 -#define CLK_CAM1_OUT 216 -#define ACLK_VO 217 -#define HCLK_VO 218 -#define PCLK_VO 219 -#define ACLK_VOP_PRE 220 -#define ACLK_VOP 221 -#define HCLK_VOP 222 -#define DCLK_VOP0 223 -#define DCLK_VOP1 224 -#define DCLK_VOP2 225 -#define CLK_VOP_PWM 226 -#define ACLK_HDCP 227 -#define HCLK_HDCP 228 -#define PCLK_HDCP 229 -#define PCLK_HDMI_HOST 230 -#define CLK_HDMI_SFR 231 -#define PCLK_DSITX_0 232 -#define PCLK_DSITX_1 233 -#define PCLK_EDP_CTRL 234 -#define CLK_EDP_200M 235 -#define ACLK_VPU_PRE 236 -#define HCLK_VPU_PRE 237 -#define ACLK_VPU 238 -#define HCLK_VPU 239 -#define ACLK_RGA_PRE 240 -#define HCLK_RGA_PRE 241 -#define PCLK_RGA_PRE 242 -#define ACLK_RGA 243 -#define HCLK_RGA 244 -#define CLK_RGA_CORE 245 -#define ACLK_IEP 246 -#define HCLK_IEP 247 -#define CLK_IEP_CORE 248 -#define HCLK_EBC 249 -#define DCLK_EBC 250 -#define ACLK_JDEC 251 -#define HCLK_JDEC 252 -#define ACLK_JENC 253 -#define HCLK_JENC 254 -#define PCLK_EINK 255 -#define HCLK_EINK 256 -#define ACLK_RKVENC_PRE 257 -#define HCLK_RKVENC_PRE 258 -#define ACLK_RKVENC 259 -#define HCLK_RKVENC 260 -#define CLK_RKVENC_CORE 261 -#define ACLK_RKVDEC_PRE 262 -#define HCLK_RKVDEC_PRE 263 -#define ACLK_RKVDEC 264 -#define HCLK_RKVDEC 265 -#define CLK_RKVDEC_CA 266 -#define CLK_RKVDEC_CORE 267 -#define CLK_RKVDEC_HEVC_CA 268 -#define ACLK_BUS 269 -#define PCLK_BUS 270 -#define PCLK_TSADC 271 -#define CLK_TSADC_TSEN 272 -#define CLK_TSADC 273 -#define PCLK_SARADC 274 -#define CLK_SARADC 275 -#define PCLK_SCR 276 -#define PCLK_WDT_NS 277 -#define TCLK_WDT_NS 278 -#define ACLK_DMAC0 279 -#define ACLK_DMAC1 280 -#define ACLK_MCU 281 -#define PCLK_INTMUX 282 -#define PCLK_MAILBOX 283 -#define PCLK_UART1 284 -#define CLK_UART1_SRC 285 -#define CLK_UART1_FRAC 286 -#define SCLK_UART1 287 -#define PCLK_UART2 288 -#define CLK_UART2_SRC 289 -#define CLK_UART2_FRAC 290 -#define SCLK_UART2 291 -#define PCLK_UART3 292 -#define CLK_UART3_SRC 293 -#define CLK_UART3_FRAC 294 -#define SCLK_UART3 295 -#define PCLK_UART4 296 -#define CLK_UART4_SRC 297 -#define CLK_UART4_FRAC 298 -#define SCLK_UART4 299 -#define PCLK_UART5 300 -#define CLK_UART5_SRC 301 -#define CLK_UART5_FRAC 302 -#define SCLK_UART5 303 -#define PCLK_UART6 304 -#define CLK_UART6_SRC 305 -#define CLK_UART6_FRAC 306 -#define SCLK_UART6 307 -#define PCLK_UART7 308 -#define CLK_UART7_SRC 309 -#define CLK_UART7_FRAC 310 -#define SCLK_UART7 311 -#define PCLK_UART8 312 -#define CLK_UART8_SRC 313 -#define CLK_UART8_FRAC 314 -#define SCLK_UART8 315 -#define PCLK_UART9 316 -#define CLK_UART9_SRC 317 -#define CLK_UART9_FRAC 318 -#define SCLK_UART9 319 -#define PCLK_CAN0 320 -#define CLK_CAN0 321 -#define PCLK_CAN1 322 -#define CLK_CAN1 323 -#define PCLK_CAN2 324 -#define CLK_CAN2 325 -#define CLK_I2C 326 -#define PCLK_I2C1 327 -#define CLK_I2C1 328 -#define PCLK_I2C2 329 -#define CLK_I2C2 330 -#define PCLK_I2C3 331 -#define CLK_I2C3 332 -#define PCLK_I2C4 333 -#define CLK_I2C4 334 -#define PCLK_I2C5 335 -#define CLK_I2C5 336 -#define PCLK_SPI0 337 -#define CLK_SPI0 338 -#define PCLK_SPI1 339 -#define CLK_SPI1 340 -#define PCLK_SPI2 341 -#define CLK_SPI2 342 -#define PCLK_SPI3 343 -#define CLK_SPI3 344 -#define PCLK_PWM1 345 -#define CLK_PWM1 346 -#define CLK_PWM1_CAPTURE 347 -#define PCLK_PWM2 348 -#define CLK_PWM2 349 -#define CLK_PWM2_CAPTURE 350 -#define PCLK_PWM3 351 -#define CLK_PWM3 352 -#define CLK_PWM3_CAPTURE 353 -#define DBCLK_GPIO 354 -#define PCLK_GPIO1 355 -#define DBCLK_GPIO1 356 -#define PCLK_GPIO2 357 -#define DBCLK_GPIO2 358 -#define PCLK_GPIO3 359 -#define DBCLK_GPIO3 360 -#define PCLK_GPIO4 361 -#define DBCLK_GPIO4 362 -#define OCC_SCAN_CLK_GPIO 363 -#define PCLK_TIMER 364 -#define CLK_TIMER0 365 -#define CLK_TIMER1 366 -#define CLK_TIMER2 367 -#define CLK_TIMER3 368 -#define CLK_TIMER4 369 -#define CLK_TIMER5 370 -#define ACLK_TOP_HIGH 371 -#define ACLK_TOP_LOW 372 -#define HCLK_TOP 373 -#define PCLK_TOP 374 -#define PCLK_PCIE30PHY 375 -#define CLK_OPTC_ARB 376 -#define PCLK_MIPICSIPHY 377 -#define PCLK_MIPIDSIPHY0 378 -#define PCLK_MIPIDSIPHY1 379 -#define PCLK_PIPEPHY0 380 -#define PCLK_PIPEPHY1 381 -#define PCLK_PIPEPHY2 382 -#define PCLK_CPU_BOOST 383 -#define CLK_CPU_BOOST 384 -#define PCLK_OTPPHY 385 -#define SCLK_GMAC0 386 -#define SCLK_GMAC0_RGMII_SPEED 387 -#define SCLK_GMAC0_RMII_SPEED 388 -#define SCLK_GMAC0_RX_TX 389 -#define SCLK_GMAC1 390 -#define SCLK_GMAC1_RGMII_SPEED 391 -#define SCLK_GMAC1_RMII_SPEED 392 -#define SCLK_GMAC1_RX_TX 393 -#define SCLK_SDMMC0_DRV 394 -#define SCLK_SDMMC0_SAMPLE 395 -#define SCLK_SDMMC1_DRV 396 -#define SCLK_SDMMC1_SAMPLE 397 -#define SCLK_SDMMC2_DRV 398 -#define SCLK_SDMMC2_SAMPLE 399 -#define SCLK_EMMC_DRV 400 -#define SCLK_EMMC_SAMPLE 401 -#define PCLK_EDPPHY_GRF 402 -#define CLK_HDMI_CEC 403 -#define CLK_I2S0_8CH_TX 404 -#define CLK_I2S0_8CH_RX 405 -#define CLK_I2S1_8CH_TX 406 -#define CLK_I2S1_8CH_RX 407 -#define CLK_I2S2_2CH 408 -#define CLK_I2S3_2CH_TX 409 -#define CLK_I2S3_2CH_RX 410 -#define CPLL_500M 411 -#define CPLL_250M 412 -#define CPLL_125M 413 -#define CPLL_62P5M 414 -#define CPLL_50M 415 -#define CPLL_25M 416 -#define CPLL_100M 417 -#define SCLK_DDRCLK 418
-#define PCLK_CORE_PVTM 450
-#define CLK_NR_CLKS (PCLK_CORE_PVTM + 1)
-/* pmu soft-reset indices */ -/* pmucru_softrst_con0 */ -#define SRST_P_PDPMU_NIU 0 -#define SRST_P_PMUCRU 1 -#define SRST_P_PMUGRF 2 -#define SRST_P_I2C0 3 -#define SRST_I2C0 4 -#define SRST_P_UART0 5 -#define SRST_S_UART0 6 -#define SRST_P_PWM0 7 -#define SRST_PWM0 8 -#define SRST_P_GPIO0 9 -#define SRST_GPIO0 10 -#define SRST_P_PMUPVTM 11 -#define SRST_PMUPVTM 12
-/* soft-reset indices */
-/* cru_softrst_con0 */ -#define SRST_NCORERESET0 0 -#define SRST_NCORERESET1 1 -#define SRST_NCORERESET2 2 -#define SRST_NCORERESET3 3 -#define SRST_NCPUPORESET0 4 -#define SRST_NCPUPORESET1 5 -#define SRST_NCPUPORESET2 6 -#define SRST_NCPUPORESET3 7 -#define SRST_NSRESET 8 -#define SRST_NSPORESET 9 -#define SRST_NATRESET 10 -#define SRST_NGICRESET 11 -#define SRST_NPRESET 12 -#define SRST_NPERIPHRESET 13
-/* cru_softrst_con1 */ -#define SRST_A_CORE_NIU2DDR 16 -#define SRST_A_CORE_NIU2BUS 17 -#define SRST_P_DBG_NIU 18 -#define SRST_P_DBG 19 -#define SRST_P_DBG_DAPLITE 20 -#define SRST_DAP 21 -#define SRST_A_ADB400_CORE2GIC 22 -#define SRST_A_ADB400_GIC2CORE 23 -#define SRST_P_CORE_GRF 24 -#define SRST_P_CORE_PVTM 25 -#define SRST_CORE_PVTM 26 -#define SRST_CORE_PVTPLL 27
-/* cru_softrst_con2 */ -#define SRST_GPU 32 -#define SRST_A_GPU_NIU 33 -#define SRST_P_GPU_NIU 34 -#define SRST_P_GPU_PVTM 35 -#define SRST_GPU_PVTM 36 -#define SRST_GPU_PVTPLL 37 -#define SRST_A_NPU_NIU 40 -#define SRST_H_NPU_NIU 41 -#define SRST_P_NPU_NIU 42 -#define SRST_A_NPU 43 -#define SRST_H_NPU 44 -#define SRST_P_NPU_PVTM 45 -#define SRST_NPU_PVTM 46 -#define SRST_NPU_PVTPLL 47
-/* cru_softrst_con3 */ -#define SRST_A_MSCH 51 -#define SRST_HWFFC_CTRL 52 -#define SRST_DDR_ALWAYSON 53 -#define SRST_A_DDRSPLIT 54 -#define SRST_DDRDFI_CTL 55 -#define SRST_A_DMA2DDR 57
-/* cru_softrst_con4 */ -#define SRST_A_PERIMID_NIU 64 -#define SRST_H_PERIMID_NIU 65 -#define SRST_A_GIC_AUDIO_NIU 66 -#define SRST_H_GIC_AUDIO_NIU 67 -#define SRST_A_GIC600 68 -#define SRST_A_GIC600_DEBUG 69 -#define SRST_A_GICADB_CORE2GIC 70 -#define SRST_A_GICADB_GIC2CORE 71 -#define SRST_A_SPINLOCK 72 -#define SRST_H_SDMMC_BUFFER 73 -#define SRST_D_SDMMC_BUFFER 74 -#define SRST_H_I2S0_8CH 75 -#define SRST_H_I2S1_8CH 76 -#define SRST_H_I2S2_2CH 77 -#define SRST_H_I2S3_2CH 78
-/* cru_softrst_con5 */ -#define SRST_M_I2S0_8CH_TX 80 -#define SRST_M_I2S0_8CH_RX 81 -#define SRST_M_I2S1_8CH_TX 82 -#define SRST_M_I2S1_8CH_RX 83 -#define SRST_M_I2S2_2CH 84 -#define SRST_M_I2S3_2CH_TX 85 -#define SRST_M_I2S3_2CH_RX 86 -#define SRST_H_PDM 87 -#define SRST_M_PDM 88 -#define SRST_H_VAD 89 -#define SRST_H_SPDIF_8CH 90 -#define SRST_M_SPDIF_8CH 91 -#define SRST_H_AUDPWM 92 -#define SRST_S_AUDPWM 93 -#define SRST_H_ACDCDIG 94 -#define SRST_ACDCDIG 95
-/* cru_softrst_con6 */ -#define SRST_A_SECURE_FLASH_NIU 96 -#define SRST_H_SECURE_FLASH_NIU 97 -#define SRST_A_CRYPTO_NS 103 -#define SRST_H_CRYPTO_NS 104 -#define SRST_CRYPTO_NS_CORE 105 -#define SRST_CRYPTO_NS_PKA 106 -#define SRST_CRYPTO_NS_RNG 107 -#define SRST_H_TRNG_NS 108 -#define SRST_TRNG_NS 109
-/* cru_softrst_con7 */ -#define SRST_H_NANDC 112 -#define SRST_N_NANDC 113 -#define SRST_H_SFC 114 -#define SRST_H_SFC_XIP 115 -#define SRST_S_SFC 116 -#define SRST_A_EMMC 117 -#define SRST_H_EMMC 118 -#define SRST_B_EMMC 119 -#define SRST_C_EMMC 120 -#define SRST_T_EMMC 121
-/* cru_softrst_con8 */ -#define SRST_A_PIPE_NIU 128 -#define SRST_P_PIPE_NIU 130 -#define SRST_P_PIPE_GRF 133 -#define SRST_A_SATA0 134 -#define SRST_SATA0_PIPE 135 -#define SRST_SATA0_PMALIVE 136 -#define SRST_SATA0_RXOOB 137 -#define SRST_A_SATA1 138 -#define SRST_SATA1_PIPE 139 -#define SRST_SATA1_PMALIVE 140 -#define SRST_SATA1_RXOOB 141
-/* cru_softrst_con9 */ -#define SRST_A_SATA2 144 -#define SRST_SATA2_PIPE 145 -#define SRST_SATA2_PMALIVE 146 -#define SRST_SATA2_RXOOB 147 -#define SRST_USB3OTG0 148 -#define SRST_USB3OTG1 149 -#define SRST_XPCS 150 -#define SRST_XPCS_TX_DIV10 151 -#define SRST_XPCS_RX_DIV10 152 -#define SRST_XPCS_XGXS_RX 153
-/* cru_softrst_con10 */ -#define SRST_P_PCIE20 160 -#define SRST_PCIE20_POWERUP 161 -#define SRST_MSTR_ARESET_PCIE20 162 -#define SRST_SLV_ARESET_PCIE20 163 -#define SRST_DBI_ARESET_PCIE20 164 -#define SRST_BRESET_PCIE20 165 -#define SRST_PERST_PCIE20 166 -#define SRST_CORE_RST_PCIE20 167 -#define SRST_NSTICKY_RST_PCIE20 168 -#define SRST_STICKY_RST_PCIE20 169 -#define SRST_PWR_RST_PCIE20 170
-/* cru_softrst_con11 */ -#define SRST_P_PCIE30X1 176 -#define SRST_PCIE30X1_POWERUP 177 -#define SRST_M_ARESET_PCIE30X1 178 -#define SRST_S_ARESET_PCIE30X1 179 -#define SRST_D_ARESET_PCIE30X1 180 -#define SRST_BRESET_PCIE30X1 181 -#define SRST_PERST_PCIE30X1 182 -#define SRST_CORE_RST_PCIE30X1 183 -#define SRST_NSTC_RST_PCIE30X1 184 -#define SRST_STC_RST_PCIE30X1 185 -#define SRST_PWR_RST_PCIE30X1 186
-/* cru_softrst_con12 */ -#define SRST_P_PCIE30X2 192 -#define SRST_PCIE30X2_POWERUP 193 -#define SRST_M_ARESET_PCIE30X2 194 -#define SRST_S_ARESET_PCIE30X2 195 -#define SRST_D_ARESET_PCIE30X2 196 -#define SRST_BRESET_PCIE30X2 197 -#define SRST_PERST_PCIE30X2 198 -#define SRST_CORE_RST_PCIE30X2 199 -#define SRST_NSTC_RST_PCIE30X2 200 -#define SRST_STC_RST_PCIE30X2 201 -#define SRST_PWR_RST_PCIE30X2 202
-/* cru_softrst_con13 */ -#define SRST_A_PHP_NIU 208 -#define SRST_H_PHP_NIU 209 -#define SRST_P_PHP_NIU 210 -#define SRST_H_SDMMC0 211 -#define SRST_SDMMC0 212 -#define SRST_H_SDMMC1 213 -#define SRST_SDMMC1 214 -#define SRST_A_GMAC0 215 -#define SRST_GMAC0_TIMESTAMP 216
-/* cru_softrst_con14 */ -#define SRST_A_USB_NIU 224 -#define SRST_H_USB_NIU 225 -#define SRST_P_USB_NIU 226 -#define SRST_P_USB_GRF 227 -#define SRST_H_USB2HOST0 228 -#define SRST_H_USB2HOST0_ARB 229 -#define SRST_USB2HOST0_UTMI 230 -#define SRST_H_USB2HOST1 231 -#define SRST_H_USB2HOST1_ARB 232 -#define SRST_USB2HOST1_UTMI 233 -#define SRST_H_SDMMC2 234 -#define SRST_SDMMC2 235 -#define SRST_A_GMAC1 236 -#define SRST_GMAC1_TIMESTAMP 237
-/* cru_softrst_con15 */ -#define SRST_A_VI_NIU 240 -#define SRST_H_VI_NIU 241 -#define SRST_P_VI_NIU 242 -#define SRST_A_VICAP 247 -#define SRST_H_VICAP 248 -#define SRST_D_VICAP 249 -#define SRST_I_VICAP 250 -#define SRST_P_VICAP 251 -#define SRST_H_ISP 252 -#define SRST_ISP 253 -#define SRST_P_CSI2HOST1 255
-/* cru_softrst_con16 */ -#define SRST_A_VO_NIU 256 -#define SRST_H_VO_NIU 257 -#define SRST_P_VO_NIU 258 -#define SRST_A_VOP_NIU 259 -#define SRST_A_VOP 260 -#define SRST_H_VOP 261 -#define SRST_VOP0 262 -#define SRST_VOP1 263 -#define SRST_VOP2 264 -#define SRST_VOP_PWM 265 -#define SRST_A_HDCP 266 -#define SRST_H_HDCP 267 -#define SRST_P_HDCP 268 -#define SRST_P_HDMI_HOST 270 -#define SRST_HDMI_HOST 271
-/* cru_softrst_con17 */ -#define SRST_P_DSITX_0 272 -#define SRST_P_DSITX_1 273 -#define SRST_P_EDP_CTRL 274 -#define SRST_EDP_24M 275 -#define SRST_A_VPU_NIU 280 -#define SRST_H_VPU_NIU 281 -#define SRST_A_VPU 282 -#define SRST_H_VPU 283 -#define SRST_H_EINK 286 -#define SRST_P_EINK 287
-/* cru_softrst_con18 */ -#define SRST_A_RGA_NIU 288 -#define SRST_H_RGA_NIU 289 -#define SRST_P_RGA_NIU 290 -#define SRST_A_RGA 292 -#define SRST_H_RGA 293 -#define SRST_RGA_CORE 294 -#define SRST_A_IEP 295 -#define SRST_H_IEP 296 -#define SRST_IEP_CORE 297 -#define SRST_H_EBC 298 -#define SRST_D_EBC 299 -#define SRST_A_JDEC 300 -#define SRST_H_JDEC 301 -#define SRST_A_JENC 302 -#define SRST_H_JENC 303
-/* cru_softrst_con19 */ -#define SRST_A_VENC_NIU 304 -#define SRST_H_VENC_NIU 305 -#define SRST_A_RKVENC 307 -#define SRST_H_RKVENC 308 -#define SRST_RKVENC_CORE 309
-/* cru_softrst_con20 */ -#define SRST_A_RKVDEC_NIU 320 -#define SRST_H_RKVDEC_NIU 321 -#define SRST_A_RKVDEC 322 -#define SRST_H_RKVDEC 323 -#define SRST_RKVDEC_CA 324 -#define SRST_RKVDEC_CORE 325 -#define SRST_RKVDEC_HEVC_CA 326
-/* cru_softrst_con21 */ -#define SRST_A_BUS_NIU 336 -#define SRST_P_BUS_NIU 338 -#define SRST_P_CAN0 340 -#define SRST_CAN0 341 -#define SRST_P_CAN1 342 -#define SRST_CAN1 343 -#define SRST_P_CAN2 344 -#define SRST_CAN2 345 -#define SRST_P_GPIO1 346 -#define SRST_GPIO1 347 -#define SRST_P_GPIO2 348 -#define SRST_GPIO2 349 -#define SRST_P_GPIO3 350 -#define SRST_GPIO3 351
-/* cru_softrst_con22 */ -#define SRST_P_GPIO4 352 -#define SRST_GPIO4 353 -#define SRST_P_I2C1 354 -#define SRST_I2C1 355 -#define SRST_P_I2C2 356 -#define SRST_I2C2 357 -#define SRST_P_I2C3 358 -#define SRST_I2C3 359 -#define SRST_P_I2C4 360 -#define SRST_I2C4 361 -#define SRST_P_I2C5 362 -#define SRST_I2C5 363 -#define SRST_P_OTPC_NS 364 -#define SRST_OTPC_NS_SBPI 365 -#define SRST_OTPC_NS_USR 366
-/* cru_softrst_con23 */ -#define SRST_P_PWM1 368 -#define SRST_PWM1 369 -#define SRST_P_PWM2 370 -#define SRST_PWM2 371 -#define SRST_P_PWM3 372 -#define SRST_PWM3 373 -#define SRST_P_SPI0 374 -#define SRST_SPI0 375 -#define SRST_P_SPI1 376 -#define SRST_SPI1 377 -#define SRST_P_SPI2 378 -#define SRST_SPI2 379 -#define SRST_P_SPI3 380 -#define SRST_SPI3 381
-/* cru_softrst_con24 */ -#define SRST_P_SARADC 384 -#define SRST_P_TSADC 385 -#define SRST_TSADC 386 -#define SRST_P_TIMER 387 -#define SRST_TIMER0 388 -#define SRST_TIMER1 389 -#define SRST_TIMER2 390 -#define SRST_TIMER3 391 -#define SRST_TIMER4 392 -#define SRST_TIMER5 393 -#define SRST_P_UART1 394 -#define SRST_S_UART1 395
-/* cru_softrst_con25 */ -#define SRST_P_UART2 400 -#define SRST_S_UART2 401 -#define SRST_P_UART3 402 -#define SRST_S_UART3 403 -#define SRST_P_UART4 404 -#define SRST_S_UART4 405 -#define SRST_P_UART5 406 -#define SRST_S_UART5 407 -#define SRST_P_UART6 408 -#define SRST_S_UART6 409 -#define SRST_P_UART7 410 -#define SRST_S_UART7 411 -#define SRST_P_UART8 412 -#define SRST_S_UART8 413 -#define SRST_P_UART9 414 -#define SRST_S_UART9 415
-/* cru_softrst_con26 */ -#define SRST_P_GRF 416 -#define SRST_P_GRF_VCCIO12 417 -#define SRST_P_GRF_VCCIO34 418 -#define SRST_P_GRF_VCCIO567 419 -#define SRST_P_SCR 420 -#define SRST_P_WDT_NS 421 -#define SRST_T_WDT_NS 422 -#define SRST_P_DFT2APB 423 -#define SRST_A_MCU 426 -#define SRST_P_INTMUX 427 -#define SRST_P_MAILBOX 428
-/* cru_softrst_con27 */ -#define SRST_A_TOP_HIGH_NIU 432 -#define SRST_A_TOP_LOW_NIU 433 -#define SRST_H_TOP_NIU 434 -#define SRST_P_TOP_NIU 435 -#define SRST_P_TOP_CRU 438 -#define SRST_P_DDRPHY 439 -#define SRST_DDRPHY 440 -#define SRST_P_MIPICSIPHY 442 -#define SRST_P_MIPIDSIPHY0 443 -#define SRST_P_MIPIDSIPHY1 444 -#define SRST_P_PCIE30PHY 445 -#define SRST_PCIE30PHY 446 -#define SRST_P_PCIE30PHY_GRF 447
-/* cru_softrst_con28 */ -#define SRST_P_APB2ASB_LEFT 448 -#define SRST_P_APB2ASB_BOTTOM 449 -#define SRST_P_ASB2APB_LEFT 450 -#define SRST_P_ASB2APB_BOTTOM 451 -#define SRST_P_PIPEPHY0 452 -#define SRST_PIPEPHY0 453 -#define SRST_P_PIPEPHY1 454 -#define SRST_PIPEPHY1 455 -#define SRST_P_PIPEPHY2 456 -#define SRST_PIPEPHY2 457 -#define SRST_P_USB2PHY0_GRF 458 -#define SRST_P_USB2PHY1_GRF 459 -#define SRST_P_CPU_BOOST 460 -#define SRST_CPU_BOOST 461 -#define SRST_P_OTPPHY 462 -#define SRST_OTPPHY 463
-/* cru_softrst_con29 */ -#define SRST_USB2PHY0_POR 464 -#define SRST_USB2PHY0_USB3OTG0 465 -#define SRST_USB2PHY0_USB3OTG1 466 -#define SRST_USB2PHY1_POR 467 -#define SRST_USB2PHY1_USB2HOST0 468 -#define SRST_USB2PHY1_USB2HOST1 469 -#define SRST_P_EDPPHY_GRF 470 -#define SRST_TSADCPHY 471 -#define SRST_GMAC0_DELAYLINE 472 -#define SRST_GMAC1_DELAYLINE 473 -#define SRST_OTPC_ARB 474 -#define SRST_P_PIPEPHY0_GRF 475 -#define SRST_P_PIPEPHY1_GRF 476 -#define SRST_P_PIPEPHY2_GRF 477
-#endif diff --git a/include/dt-bindings/power/rk3568-power.h b/include/dt-bindings/power/rk3568-power.h deleted file mode 100644 index 6cc1af1a9d26..000000000000 --- a/include/dt-bindings/power/rk3568-power.h +++ /dev/null @@ -1,32 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0 */ -#ifndef __DT_BINDINGS_POWER_RK3568_POWER_H__ -#define __DT_BINDINGS_POWER_RK3568_POWER_H__
-/* VD_CORE */ -#define RK3568_PD_CPU_0 0 -#define RK3568_PD_CPU_1 1 -#define RK3568_PD_CPU_2 2 -#define RK3568_PD_CPU_3 3 -#define RK3568_PD_CORE_ALIVE 4
-/* VD_PMU */ -#define RK3568_PD_PMU 5
-/* VD_NPU */ -#define RK3568_PD_NPU 6
-/* VD_GPU */ -#define RK3568_PD_GPU 7
-/* VD_LOGIC */ -#define RK3568_PD_VI 8 -#define RK3568_PD_VO 9 -#define RK3568_PD_RGA 10 -#define RK3568_PD_VPU 11 -#define RK3568_PD_CENTER 12 -#define RK3568_PD_RKVDEC 13 -#define RK3568_PD_RKVENC 14 -#define RK3568_PD_PIPE 15 -#define RK3568_PD_LOGIC_ALIVE 16
-#endif
2.43.2
Hi Chris,
On 2024-05-04 22:51, Chris Morgan wrote:
On Sat, May 04, 2024 at 07:43:01PM +0000, Jonas Karlman wrote:
Remove redundant device tree files now that RK356x boards have been migrated to use OF_UPSTREAM.
Signed-off-by: Jonas Karlman jonas@kwiboo.se
arch/arm/dts/rk3566-anbernic-rgxx3.dtsi | 788 ------ arch/arm/dts/rk3566-quartz64-a.dts | 838 ------ arch/arm/dts/rk3566-quartz64-b.dts | 737 ----- arch/arm/dts/rk3566-radxa-cm3-io.dts | 281 -- arch/arm/dts/rk3566-radxa-cm3.dtsi | 425 --- arch/arm/dts/rk3566-soquartz-blade.dts | 198 -- arch/arm/dts/rk3566-soquartz-cm4.dts | 196 -- arch/arm/dts/rk3566-soquartz-model-a.dts | 236 -- arch/arm/dts/rk3566-soquartz.dtsi | 684 ----- arch/arm/dts/rk3566.dtsi | 35 - arch/arm/dts/rk3568-bpi-r2-pro.dts | 852 ------ arch/arm/dts/rk3568-evb.dts | 689 ----- arch/arm/dts/rk3568-lubancat-2.dts | 730 ----- arch/arm/dts/rk3568-nanopi-r5c.dts | 112 - arch/arm/dts/rk3568-nanopi-r5s.dts | 136 - arch/arm/dts/rk3568-nanopi-r5s.dtsi | 587 ---- arch/arm/dts/rk3568-odroid-m1.dts | 741 ----- arch/arm/dts/rk3568-pinctrl.dtsi | 3214 ---------------------- arch/arm/dts/rk3568-radxa-cm3i.dtsi | 412 --- arch/arm/dts/rk3568-radxa-e25.dts | 236 -- arch/arm/dts/rk3568-rock-3a.dts | 859 ------ arch/arm/dts/rk3568.dtsi | 267 -- arch/arm/dts/rk356x.dtsi | 1886 ------------- include/dt-bindings/clock/rk3568-cru.h | 926 ------- include/dt-bindings/power/rk3568-power.h | 32 - 25 files changed, 16097 deletions(-) delete mode 100644 arch/arm/dts/rk3566-anbernic-rgxx3.dtsi delete mode 100644 arch/arm/dts/rk3566-quartz64-a.dts delete mode 100644 arch/arm/dts/rk3566-quartz64-b.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3-io.dts delete mode 100644 arch/arm/dts/rk3566-radxa-cm3.dtsi delete mode 100644 arch/arm/dts/rk3566-soquartz-blade.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-cm4.dts delete mode 100644 arch/arm/dts/rk3566-soquartz-model-a.dts delete mode 100644 arch/arm/dts/rk3566-soquartz.dtsi delete mode 100644 arch/arm/dts/rk3566.dtsi delete mode 100644 arch/arm/dts/rk3568-bpi-r2-pro.dts delete mode 100644 arch/arm/dts/rk3568-evb.dts delete mode 100644 arch/arm/dts/rk3568-lubancat-2.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5c.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dts delete mode 100644 arch/arm/dts/rk3568-nanopi-r5s.dtsi delete mode 100644 arch/arm/dts/rk3568-odroid-m1.dts delete mode 100644 arch/arm/dts/rk3568-pinctrl.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-cm3i.dtsi delete mode 100644 arch/arm/dts/rk3568-radxa-e25.dts delete mode 100644 arch/arm/dts/rk3568-rock-3a.dts delete mode 100644 arch/arm/dts/rk3568.dtsi delete mode 100644 arch/arm/dts/rk356x.dtsi delete mode 100644 include/dt-bindings/clock/rk3568-cru.h delete mode 100644 include/dt-bindings/power/rk3568-power.h
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi deleted file mode 100644
Can we remove this since a non-upstream device tree depends on it?
I was a bit unsure what to do about this file, after this patch it gets included from dts/upstream/ correctly when building the anbernic-rgxx3-rk3566 target.
Not sure if it is better to keep a local copy in arch/arm/dts/ and manually sync it, or let it be included from dts/upstream/.
Let me know if you want me to keep the copy in arch/arm/dts/.
Regards, Jonas
Thank you, Chris
[snip]
Reviewed-by: Kever Yang kever.yang@rock-chips.com
Thanks, - Kever
diff --git a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi b/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi deleted file mode 100644 index 8cbf3d9a4f22..000000000000 --- a/arch/arm/dts/rk3566-anbernic-rgxx3.dtsi +++ /dev/null @@ -1,788 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/input/linux-event-codes.h> -#include <dt-bindings/leds/common.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi"
- chosen: chosen {
stdout-path = "serial2:1500000n8";
- adc-joystick {
compatible = "adc-joystick";
io-channels = <&adc_mux 0>,
<&adc_mux 1>,
<&adc_mux 2>,
<&adc_mux 3>;
pinctrl-0 = <&joy_mux_en>;
pinctrl-names = "default";
poll-interval = <60>;
#size-cells = <0>;
axis@0 {
reg = <0>;
abs-flat = <32>;
abs-fuzz = <32>;
abs-range = <1023 15>;
linux,code = <ABS_X>;
axis@1 {
reg = <1>;
abs-flat = <32>;
abs-fuzz = <32>;
abs-range = <15 1023>;
linux,code = <ABS_RX>;
axis@2 {
reg = <2>;
abs-flat = <32>;
abs-fuzz = <32>;
linux,code = <ABS_Y>;
axis@3 {
reg = <3>;
abs-flat = <32>;
abs-fuzz = <32>;
linux,code = <ABS_RY>;
- adc_keys: adc-keys {
compatible = "adc-keys";
io-channels = <&saradc 0>;
io-channel-names = "buttons";
keyup-threshold-microvolt = <1800000>;
* Button is mapped to F key in BSP kernel, but
* according to input guidelines it should be mode.
button-mode {
label = "MODE";
linux,code = <BTN_MODE>;
press-threshold-microvolt = <1750>;
- adc_mux: adc-mux {
compatible = "io-channel-mux";
channels = "left_x", "right_x", "left_y", "right_y";
io-channels = <&saradc 3>;
io-channel-names = "parent";
mux-controls = <&gpio_mux>;
settle-time-us = <100>;
- gpio_keys_control: gpio-keys-control {
compatible = "gpio-keys";
pinctrl-0 = <&btn_pins_ctrl>;
button-b {
gpios = <&gpio3 RK_PC3 GPIO_ACTIVE_LOW>;
label = "SOUTH";
linux,code = <BTN_SOUTH>;
button-down {
gpios = <&gpio3 RK_PA4 GPIO_ACTIVE_LOW>;
label = "DPAD-DOWN";
linux,code = <BTN_DPAD_DOWN>;
button-l1 {
gpios = <&gpio3 RK_PB1 GPIO_ACTIVE_LOW>;
label = "TL";
linux,code = <BTN_TL>;
button-l2 {
gpios = <&gpio3 RK_PB2 GPIO_ACTIVE_LOW>;
label = "TL2";
linux,code = <BTN_TL2>;
button-select {
gpios = <&gpio3 RK_PB6 GPIO_ACTIVE_LOW>;
label = "SELECT";
linux,code = <BTN_SELECT>;
button-start {
gpios = <&gpio3 RK_PB5 GPIO_ACTIVE_LOW>;
label = "START";
linux,code = <BTN_START>;
button-thumbl {
gpios = <&gpio3 RK_PA1 GPIO_ACTIVE_LOW>;
label = "THUMBL";
linux,code = <BTN_THUMBL>;
button-thumbr {
gpios = <&gpio3 RK_PA2 GPIO_ACTIVE_LOW>;
label = "THUMBR";
linux,code = <BTN_THUMBR>;
button-up {
gpios = <&gpio3 RK_PA3 GPIO_ACTIVE_LOW>;
label = "DPAD-UP";
linux,code = <BTN_DPAD_UP>;
button-x {
gpios = <&gpio3 RK_PC0 GPIO_ACTIVE_LOW>;
label = "NORTH";
linux,code = <BTN_NORTH>;
- gpio_keys_vol: gpio-keys-vol {
autorepeat;
pinctrl-0 = <&btn_pins_vol>;
button-vol-down {
gpios = <&gpio3 RK_PB0 GPIO_ACTIVE_LOW>;
label = "VOLUMEDOWN";
linux,code = <KEY_VOLUMEDOWN>;
button-vol-up {
gpios = <&gpio3 RK_PA7 GPIO_ACTIVE_LOW>;
label = "VOLUMEUP";
linux,code = <KEY_VOLUMEUP>;
- gpio_mux: mux-controller {
compatible = "gpio-mux";
mux-gpios = <&gpio0 RK_PB6 GPIO_ACTIVE_LOW>,
<&gpio0 RK_PB7 GPIO_ACTIVE_LOW>;
#mux-control-cells = <0>;
- hdmi-con {
compatible = "hdmi-connector";
ddc-i2c-bus = <&i2c5>;
type = "c";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&hdmi_out_con>;
- leds: pwm-leds {
compatible = "pwm-leds";
green_led: led-0 {
color = <LED_COLOR_ID_GREEN>;
default-state = "on";
function = LED_FUNCTION_POWER;
max-brightness = <255>;
pwms = <&pwm6 0 25000 0>;
amber_led: led-1 {
color = <LED_COLOR_ID_AMBER>;
function = LED_FUNCTION_CHARGING;
pwms = <&pwm7 0 25000 0>;
red_led: led-2 {
color = <LED_COLOR_ID_RED>;
default-state = "off";
function = LED_FUNCTION_STATUS;
pwms = <&pwm0 0 25000 0>;
- sdio_pwrseq: sdio-pwrseq {
compatible = "mmc-pwrseq-simple";
clocks = <&rk817 1>;
clock-names = "ext_clock";
pinctrl-0 = <&wifi_enable_h>;
post-power-on-delay-ms = <200>;
reset-gpios = <&gpio4 RK_PA2 GPIO_ACTIVE_LOW>;
- vcc3v3_lcd0_n: regulator-vcc3v3-lcd0 {
compatible = "regulator-fixed";
gpio = <&gpio0 RK_PC2 GPIO_ACTIVE_HIGH>;
enable-active-high;
pinctrl-0 = <&vcc_lcd_h>;
regulator-boot-on;
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
regulator-name = "vcc3v3_lcd0_n";
vin-supply = <&vcc_3v3>;
regulator-state-mem {
regulator-off-in-suspend;
- vcc_sys: regulator-vcc-sys {
regulator-always-on;
regulator-boot-on;
regulator-min-microvolt = <3800000>;
regulator-max-microvolt = <3800000>;
regulator-name = "vcc_sys";
- vcc_wifi: regulator-vcc-wifi {
enable-active-high;
gpio = <&gpio0 RK_PA0 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc_wifi_h>;
regulator-boot-on;
regulator-name = "vcc_wifi";
- vibrator: pwm-vibrator {
compatible = "pwm-vibrator";
pwm-names = "enable";
pwms = <&pwm5 0 1000000000 0>;
-&combphy1 {
- status = "okay";
-&cpu0 {
- cpu-supply = <&vdd_cpu>;
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&gpu {
- mali-supply = <&vdd_gpu>;
- status = "okay";
-&hdmi {
- ddc-i2c-bus = <&i2c5>;
- pinctrl-0 = <&hdmitxm0_cec>;
- pinctrl-names = "default";
- status = "okay";
-&hdmi_in {
- hdmi_in_vp0: endpoint {
remote-endpoint = <&vp0_out_hdmi>;
-&hdmi_out {
- hdmi_out_con: endpoint {
remote-endpoint = <&hdmi_con_in>;
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- rk817: pmic@20 {
compatible = "rockchip,rk817";
reg = <0x20>;
interrupt-parent = <&gpio0>;
interrupts = <RK_PA3 IRQ_TYPE_LEVEL_LOW>;
clock-output-names = "rk808-clkout1", "rk808-clkout2";
clock-names = "mclk";
clocks = <&cru I2S1_MCLKOUT_TX>;
assigned-clocks = <&cru I2S1_MCLKOUT_TX>;
assigned-clock-parents = <&cru CLK_I2S1_8CH_TX>;
#clock-cells = <1>;
#sound-dai-cells = <0>;
pinctrl-0 = <&i2s1m0_mclk>, <&pmic_int_l>;
wakeup-source;
vcc1-supply = <&vcc_sys>;
vcc2-supply = <&vcc_sys>;
vcc3-supply = <&vcc_sys>;
vcc4-supply = <&vcc_sys>;
vcc5-supply = <&vcc_sys>;
vcc6-supply = <&vcc_sys>;
vcc7-supply = <&vcc_sys>;
vcc8-supply = <&vcc_sys>;
vcc9-supply = <&dcdc_boost>;
regulators {
vdd_logic: DCDC_REG1 {
regulator-boot-on;
regulator-min-microvolt = <500000>;
regulator-max-microvolt = <1350000>;
regulator-ramp-delay = <6001>;
regulator-initial-mode = <0x2>;
regulator-name = "vdd_logic";
regulator-suspend-microvolt = <900000>;
vdd_gpu: DCDC_REG2 {
regulator-boot-on;
regulator-name = "vdd_gpu";
vcc_ddr: DCDC_REG3 {
regulator-boot-on;
regulator-name = "vcc_ddr";
regulator-on-in-suspend;
vcc_3v3: DCDC_REG4 {
regulator-boot-on;
regulator-name = "vcc_3v3";
regulator-suspend-microvolt = <3300000>;
vcca1v8_pmu: LDO_REG1 {
regulator-boot-on;
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
regulator-name = "vcca1v8_pmu";
regulator-suspend-microvolt = <1800000>;
vdda_0v9: LDO_REG2 {
regulator-boot-on;
regulator-min-microvolt = <900000>;
regulator-max-microvolt = <900000>;
regulator-name = "vdda_0v9";
vdda0v9_pmu: LDO_REG3 {
regulator-boot-on;
regulator-name = "vdda0v9_pmu";
vccio_acodec: LDO_REG4 {
regulator-boot-on;
regulator-name = "vccio_acodec";
vccio_sd: LDO_REG5 {
regulator-boot-on;
regulator-name = "vccio_sd";
vcc3v3_pmu: LDO_REG6 {
regulator-boot-on;
regulator-name = "vcc3v3_pmu";
vcc_1v8: LDO_REG7 {
regulator-boot-on;
regulator-name = "vcc_1v8";
vcc1v8_dvp: LDO_REG8 {
regulator-boot-on;
regulator-name = "vcc1v8_dvp";
vcc2v8_dvp: LDO_REG9 {
regulator-boot-on;
regulator-min-microvolt = <2800000>;
regulator-max-microvolt = <2800000>;
regulator-name = "vcc2v8_dvp";
dcdc_boost: BOOST {
regulator-boot-on;
regulator-min-microvolt = <4700000>;
regulator-max-microvolt = <5400000>;
regulator-name = "boost";
otg_switch: OTG_SWITCH {
regulator-name = "otg_switch";
- vdd_cpu: regulator@40 {
compatible = "fcs,fan53555";
reg = <0x40>;
fcs,suspend-voltage-selector = <1>;
regulator-boot-on;
regulator-min-microvolt = <712500>;
regulator-max-microvolt = <1390000>;
regulator-name = "vdd_cpu";
regulator-ramp-delay = <2300>;
vin-supply = <&vcc_sys>;
-&i2c1 {
- /* Unknown/unused device at 0x3c */
- status = "disabled";
-&i2c5 {
- pinctrl-0 = <&i2c5m1_xfer>;
- status = "okay";
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
- pinctrl-0 = <&i2s1m0_sclktx
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
- rockchip,trcm-sync-tx-only;
- status = "okay";
-&pinctrl {
- gpio-btns {
btn_pins_ctrl: btn-pins-ctrl {
rockchip,pins =
<3 RK_PA1 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA2 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA4 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA5 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PA6 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB1 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB2 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB3 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB4 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB5 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB6 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC0 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC1 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC2 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PC3 RK_FUNC_GPIO &pcfg_pull_up>;
btn_pins_vol: btn-pins-vol {
rockchip,pins =
<3 RK_PA7 RK_FUNC_GPIO &pcfg_pull_up>,
<3 RK_PB0 RK_FUNC_GPIO &pcfg_pull_up>;
- joy-mux {
joy_mux_en: joy-mux-en {
rockchip,pins =
<0 RK_PB5 RK_FUNC_GPIO &pcfg_output_low>;
- pmic {
pmic_int_l: pmic-int-l {
rockchip,pins =
<0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- sdio-pwrseq {
wifi_enable_h: wifi-enable-h {
rockchip,pins =
<4 RK_PA2 RK_FUNC_GPIO &pcfg_pull_none>;
- vcc3v3-lcd {
vcc_lcd_h: vcc-lcd-h {
rockchip,pins =
<0 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
- vcc-wifi {
vcc_wifi_h: vcc-wifi-h {
rockchip,pins =
<0 RK_PA0 RK_FUNC_GPIO &pcfg_pull_none>;
-&pmu_io_domains {
- status = "okay";
- pmuio1-supply = <&vcc3v3_pmu>;
- pmuio2-supply = <&vcc3v3_pmu>;
- vccio1-supply = <&vccio_acodec>;
- vccio3-supply = <&vccio_sd>;
- vccio4-supply = <&vcc_1v8>;
- vccio5-supply = <&vcc_3v3>;
- vccio6-supply = <&vcc1v8_dvp>;
- vccio7-supply = <&vcc_3v3>;
-&pwm0 {
- pinctrl-0 = <&pwm0m1_pins>;
- status = "okay";
-&pwm5 {
- status = "okay";
-&pwm6 {
- status = "okay";
-&pwm7 {
- status = "okay";
-&saradc {
- vref-supply = <&vcc_1v8>;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio0 RK_PA4 GPIO_ACTIVE_LOW>;
- disable-wp;
- pinctrl-0 = <&sdmmc0_bus4 &sdmmc0_clk &sdmmc0_cmd &sdmmc0_det>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_3v3>;
- vqmmc-supply = <&vccio_sd>;
- status = "okay";
-&sdmmc1 {
- bus-width = <4>;
- cap-sd-highspeed;
- cd-gpios = <&gpio2 RK_PB2 GPIO_ACTIVE_LOW>;
- disable-wp;
- pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk &sdmmc1_det>;
- sd-uhs-sdr104;
- vqmmc-supply = <&vcc1v8_dvp>;
- status = "okay";
-&sdmmc2 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- keep-power-in-suspend;
- mmc-pwrseq = <&sdio_pwrseq>;
- non-removable;
- pinctrl-0 = <&sdmmc2m0_bus4 &sdmmc2m0_cmd &sdmmc2m0_clk>;
- vmmc-supply = <&vcc_wifi>;
- vqmmc-supply = <&vcca1v8_pmu>;
- status = "okay";
-&tsadc {
- rockchip,hw-tshut-mode = <1>;
- rockchip,hw-tshut-polarity = <0>;
- status = "okay";
-&uart1 {
- pinctrl-0 = <&uart1m1_xfer &uart1m1_ctsn &uart1m1_rtsn>;
- uart-has-rtscts;
- status = "okay";
- bluetooth {
compatible = "realtek,rtl8821cs-bt", "realtek,rtl8723bs-bt";
device-wake-gpios = <&gpio4 4 GPIO_ACTIVE_HIGH>;
enable-gpios = <&gpio4 3 GPIO_ACTIVE_HIGH>;
host-wake-gpios = <&gpio4 5 GPIO_ACTIVE_HIGH>;
-&uart2 {
- status = "okay";
- Lack the schematics to verify, but port works as a peripheral
- (and not a host or OTG port).
-&usb_host0_xhci {
- dr_mode = "peripheral";
- phys = <&usb2phy0_otg>;
- phy-names = "usb2-phy";
- status = "okay";
-&usb_host1_ehci {
- status = "okay";
-&usb_host1_ohci {
- status = "okay";
-&usb_host1_xhci {
- phy-names = "usb2-phy", "usb3-phy";
- phys = <&usb2phy1_host>, <&combphy1 PHY_TYPE_USB3>;
- status = "okay";
-&usb2phy0 {
- status = "okay";
-&usb2phy0_otg {
- status = "okay";
-&usb2phy1 {
- status = "okay";
-&usb2phy1_host {
- status = "okay";
-&vop {
- assigned-clocks = <&cru DCLK_VOP0>, <&cru DCLK_VOP1>;
- assigned-clock-parents = <&pmucru PLL_HPLL>, <&cru PLL_VPLL>;
- status = "okay";
-&vop_mmu {
- status = "okay";
-&vp0 {
- vp0_out_hdmi: endpoint@ROCKCHIP_VOP2_EP_HDMI0 {
reg = <ROCKCHIP_VOP2_EP_HDMI0>;
remote-endpoint = <&hdmi_in_vp0>;
-}; diff --git a/arch/arm/dts/rk3566-quartz64-a.dts b/arch/arm/dts/rk3566-quartz64-a.dts deleted file mode 100644 index 59843a7a199c..000000000000 --- a/arch/arm/dts/rk3566-quartz64-a.dts +++ /dev/null @@ -1,838 +0,0 @@ -// SPDX-License-Identifier: (GPL-2.0+ OR MIT)
-/dts-v1/;
-#include <dt-bindings/gpio/gpio.h> -#include <dt-bindings/pinctrl/rockchip.h> -#include <dt-bindings/soc/rockchip,vop2.h> -#include "rk3566.dtsi"
- model = "Pine64 RK3566 Quartz64-A Board";
- compatible = "pine64,quartz64-a", "rockchip,rk3566";
- aliases {
ethernet0 = &gmac1;
mmc0 = &sdmmc0;
mmc1 = &sdhci;
- chosen: chosen {
- gmac1_clkin: external-gmac1-clock {
compatible = "fixed-clock";
clock-frequency = <125000000>;
clock-output-names = "gmac1_clkin";
#clock-cells = <0>;
- fan: gpio_fan {
compatible = "gpio-fan";
gpios = <&gpio0 RK_PD5 GPIO_ACTIVE_HIGH>;
gpio-fan,speed-map =
< 0 0>,
<4500 1>;
pinctrl-0 = <&fan_en_h>;
#cooling-cells = <2>;
- hdmi-con {
type = "a";
port {
- leds {
compatible = "gpio-leds";
led-work {
label = "work-led";
gpios = <&gpio0 RK_PD3 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&work_led_enable_h>;
retain-state-suspended;
led-diy {
label = "diy-led";
gpios = <&gpio0 RK_PD4 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
pinctrl-0 = <&diy_led_enable_h>;
- rk817-sound {
compatible = "simple-audio-card";
simple-audio-card,format = "i2s";
simple-audio-card,name = "Analog RK817";
simple-audio-card,mclk-fs = <256>;
simple-audio-card,cpu {
sound-dai = <&i2s1_8ch>;
simple-audio-card,codec {
sound-dai = <&rk817>;
post-power-on-delay-ms = <100>;
power-off-delay-us = <5000000>;
reset-gpios = <&gpio2 RK_PC2 GPIO_ACTIVE_LOW>;
- spdif_dit: spdif-dit {
compatible = "linux,spdif-dit";
- spdif_sound: spdif-sound {
simple-audio-card,name = "SPDIF";
sound-dai = <&spdif>;
sound-dai = <&spdif_dit>;
- vcc12v_dcin: vcc12v_dcin {
regulator-name = "vcc12v_dcin";
regulator-boot-on;
regulator-min-microvolt = <12000000>;
regulator-max-microvolt = <12000000>;
- /* vbus feeds the rk817 usb input.
* With no battery attached, also feeds vcc_bat+
* via ON/OFF_BAT jumper
- vbus: vbus {
regulator-name = "vbus";
regulator-boot-on;
regulator-min-microvolt = <5000000>;
regulator-max-microvolt = <5000000>;
vin-supply = <&vcc12v_dcin>;
- vcc3v3_pcie_p: vcc3v3-pcie-p-regulator {
enable-active-high;
gpio = <&gpio0 RK_PC6 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&pcie_enable_h>;
regulator-name = "vcc3v3_pcie_p";
- vcc5v0_usb: vcc5v0_usb {
regulator-name = "vcc5v0_usb";
regulator-boot-on;
- /* all four ports are controlled by one gpio
* the host ports are sourced from vcc5v0_usb
* the otg port is sourced from vcc5v0_midu
- vcc5v0_usb20_host: vcc5v0_usb20_host {
enable-active-high;
gpio = <&gpio4 RK_PB5 GPIO_ACTIVE_HIGH>;
pinctrl-0 = <&vcc5v0_usb20_host_en>;
regulator-name = "vcc5v0_usb20_host";
vin-supply = <&vcc5v0_usb>;
- vcc5v0_usb20_otg: vcc5v0_usb20_otg {
enable-active-high;
regulator-name = "vcc5v0_usb20_otg";
vin-supply = <&dcdc_boost>;
- vcc3v3_sd: vcc3v3_sd {
gpio = <&gpio0 RK_PA5 GPIO_ACTIVE_LOW>;
pinctrl-0 = <&vcc_sd_h>;
regulator-boot-on;
regulator-name = "vcc3v3_sd";
- /* sourced from vbus and vcc_bat+ via rk817 sw5 */
- vcc_sys: vcc_sys {
regulator-boot-on;
regulator-min-microvolt = <4400000>;
regulator-max-microvolt = <4400000>;
vin-supply = <&vbus>;
- /* sourced from vcc_sys, sdio module operates internally at 3.3v */
- vcc_wl: vcc_wl {
regulator-name = "vcc_wl";
regulator-boot-on;
-&combphy1 {
- status = "okay";
-&combphy2 {
- status = "okay";
-&cpu0 {
-&cpu1 {
-&cpu2 {
-&cpu3 {
-&cpu_thermal {
- trips {
cpu_hot: cpu_hot {
temperature = <55000>;
type = "active";
- cooling-maps {
map1 {
trip = <&cpu_hot>;
cooling-device = <&fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
-&gmac1 {
- assigned-clocks = <&cru SCLK_GMAC1_RX_TX>, <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>;
- assigned-clock-parents = <&cru SCLK_GMAC1_RGMII_SPEED>, <&cru SCLK_GMAC1>, <&gmac1_clkin>;
- clock_in_out = "input";
- phy-supply = <&vcc_3v3>;
- phy-mode = "rgmii";
- pinctrl-0 = <&gmac1m0_miim
&gmac1m0_tx_bus2
&gmac1m0_rx_bus2
&gmac1m0_rgmii_clk
&gmac1m0_clkinout
&gmac1m0_rgmii_bus>;
- snps,reset-gpio = <&gpio0 RK_PC3 GPIO_ACTIVE_LOW>;
- snps,reset-active-low;
- /* Reset time is 20ms, 100ms for rtl8211f */
- snps,reset-delays-us = <0 20000 100000>;
- tx_delay = <0x30>;
- rx_delay = <0x10>;
- phy-handle = <&rgmii_phy1>;
- status = "okay";
-&gpu {
- status = "okay";
-&hdmi {
- avdd-0v9-supply = <&vdda_0v9>;
- avdd-1v8-supply = <&vcc_1v8>;
- status = "okay";
-&hdmi_in {
-&hdmi_out {
-&hdmi_sound {
- status = "okay";
-&i2c0 {
- status = "okay";
- vdd_cpu: regulator@1c {
compatible = "tcs,tcs4525";
reg = <0x1c>;
regulator-min-microvolt = <800000>;
regulator-max-microvolt = <1150000>;
regulator-boot-on;
- rk817: pmic@20 {
reg = <0x20>;
#clock-cells = <1>;
pinctrl-0 = <&pmic_int_l>, <&i2s1m0_mclk>;
rockchip,system-power-controller;
wakeup-source;
regulators {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
vcc_1v8: LDO_REG7 {
regulator-boot-on;
regulator-boot-on;
regulator-boot-on;
dcdc_boost: BOOST {
regulator-boot-on;
-/* i2c3 is exposed on con40
- pin 3 - i2c3_sda_m0, pullup to vcc_3v3
- pin 5 - i2c3_scl_m0, pullup to vcc_3v3
-&i2c3 {
- status = "okay";
-&i2s0_8ch {
- status = "okay";
-&i2s1_8ch {
&i2s1m0_lrcktx
&i2s1m0_sdi0
&i2s1m0_sdo0>;
- status = "okay";
-&mdio1 {
- rgmii_phy1: ethernet-phy@0 {
compatible = "ethernet-phy-ieee802.3-c22";
reg = <0>;
-&pcie2x1 {
- pinctrl-0 = <&pcie_reset_h>;
- reset-gpios = <&gpio1 RK_PB2 GPIO_ACTIVE_HIGH>;
- vpcie3v3-supply = <&vcc3v3_pcie_p>;
- status = "okay";
-&pinctrl {
- bt {
bt_enable_h: bt-enable-h {
rockchip,pins = <2 RK_PB7 RK_FUNC_GPIO &pcfg_pull_none>;
bt_host_wake_l: bt-host-wake-l {
rockchip,pins = <2 RK_PC0 RK_FUNC_GPIO &pcfg_pull_down>;
bt_wake_l: bt-wake-l {
rockchip,pins = <2 RK_PC1 RK_FUNC_GPIO &pcfg_pull_none>;
- fan {
fan_en_h: fan-en-h {
rockchip,pins = <0 RK_PD5 RK_FUNC_GPIO &pcfg_pull_none>;
- leds {
work_led_enable_h: work-led-enable-h {
rockchip,pins = <0 RK_PD3 RK_FUNC_GPIO &pcfg_pull_none>;
diy_led_enable_h: diy-led-enable-h {
rockchip,pins = <0 RK_PD4 RK_FUNC_GPIO &pcfg_pull_none>;
- pcie {
pcie_enable_h: pcie-enable-h {
rockchip,pins = <0 RK_PC6 RK_FUNC_GPIO &pcfg_pull_none>;
pcie_reset_h: pcie-reset-h {
rockchip,pins = <1 RK_PB2 RK_FUNC_GPIO &pcfg_pull_none>;
- pmic {
rockchip,pins = <0 RK_PA3 RK_FUNC_GPIO &pcfg_pull_up>;
- usb2 {
vcc5v0_usb20_host_en: vcc5v0-usb20-host-en {
rockchip,pins = <4 RK_PB5 RK_FUNC_GPIO &pcfg_pull_none>;
- sdio-pwrseq {
rockchip,pins = <2 RK_PC2 RK_FUNC_GPIO &pcfg_pull_none>;
- vcc_sd {
vcc_sd_h: vcc-sd-h {
rockchip,pins = <0 RK_PA5 RK_FUNC_GPIO &pcfg_pull_none>;
-&pmu_io_domains {
- vccio2-supply = <&vcc_1v8>;
- status = "okay";
-&sdhci {
- bus-width = <8>;
- mmc-hs200-1_8v;
- non-removable;
- vqmmc-supply = <&vcc_1v8>;
- status = "okay";
-&sdmmc0 {
- bus-width = <4>;
- cap-sd-highspeed;
- disable-wp;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc3v3_sd>;
- status = "okay";
-&sdmmc1 {
- bus-width = <4>;
- cap-sd-highspeed;
- cap-sdio-irq;
- non-removable;
- pinctrl-0 = <&sdmmc1_bus4 &sdmmc1_cmd &sdmmc1_clk>;
- sd-uhs-sdr104;
- vmmc-supply = <&vcc_wl>;
- status = "okay";
-&sfc {
- pinctrl-0 = <&fspi_pins>;
- #address-cells = <1>;
- #size-cells = <0>;
- flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <24000000>;
spi-rx-bus-width = <4>;
spi-tx-bus-width = <1>;
-/* spdif is exposed on con40 pin 18 */ -&spdif {
- status = "okay";
-/* spi1 is exposed on con40
- pin 11 - spi1_mosi_m1
- pin 13 - spi1_miso_m1
- pin 15 - spi1_clk_m1
- pin 17 - spi1_cs0_m1
-&spi1 {
- pinctrl-0 = <&spi1m1_cs0 &spi1m1_pins>;
-&tsadc {
- /* tshut mode 0:CRU 1:GPIO */
- /* tshut polarity 0:LOW 1:HIGH */
- status = "okay";
-/* uart0 is exposed on con40
- pin 12 - uart0_tx
- pin 14 - uart0_rx
-&uart0 {
- pinctrl-0 = <&uart0_xfer>;
- status = "okay";
-&uart1 {
- pinctrl-0 = <&uart1m0_xfer &uart1m0_ctsn &uart1m0_rtsn>;
- status = "okay";
- uart-has-rtscts;
- bluetooth {
compatible = "brcm,bcm43438-bt";
clock
