[PATCH] ARM: dts: at91: sama7g5: fix signal name of pin PD8
The signal name of pin PD8 with function D is A22_NANDCLE as it is defined in the datasheet.
Fixes: 558378a4cd ("ARM: mach-at91: add support for new SoC sama7g5") Signed-off-by: Mihai Sain mihai.sain@microchip.com --- arch/arm/dts/sama7g5-pinfunc.h | 2 +- 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/dts/sama7g5-pinfunc.h b/arch/arm/dts/sama7g5-pinfunc.h index b77185f8ed..a17707ba60 100644 --- a/arch/arm/dts/sama7g5-pinfunc.h +++ b/arch/arm/dts/sama7g5-pinfunc.h @@ -673,7 +673,7 @@ #define PIN_PD8__GPIO PINMUX_PIN(PIN_PD8, 0, 0) #define PIN_PD8__SDMMC2_DAT3 PINMUX_PIN(PIN_PD8, 1, 1) #define PIN_PD8__I2SMCC0_DIN0 PINMUX_PIN(PIN_PD8, 3, 1) -#define PIN_PD8__A11_NANDCLE PINMUX_PIN(PIN_PD8, 4, 2) +#define PIN_PD8__A22_NANDCLE PINMUX_PIN(PIN_PD8, 4, 2) #define PIN_PD8__TIOA2 PINMUX_PIN(PIN_PD8, 5, 2) #define PIN_PD8__FLEXCOM11_IO0 PINMUX_PIN(PIN_PD8, 6, 5) #define PIN_PD9 105
Applied to u-boot-at91/master, thanks !
Eugen.Hristev@microchip.com
Mihai Sain
