[PATCH] cli_hush.c: remove broken sanity check
This code is intended do prevent one from setting a shell variable abc by doing
abc=123
if an environment variable named abc already exists. However, the check is broken, since the env_get is done before the split on =, so we look up whether an environment variable "abc=123" exists, which is obviously never the case.
One could move the code to below the split on =, but instead, just remove it, saving a little .text: The check has never worked as intended (it goes all the way back to the initial git commit), and it would anyway not guard against one first setting the shell variable, then doing 'env set abc xyz'.
Signed-off-by: Rasmus Villemoes rasmus.villemoes@prevas.dk --- common/cli_hush.c | 8 -------- 1 file changed, 8 deletions(-)
diff --git a/common/cli_hush.c b/common/cli_hush.c index 5b1f119074..66995c255b 100644 --- a/common/cli_hush.c +++ b/common/cli_hush.c @@ -2170,14 +2170,6 @@ int set_local_var(const char *s, int flg_export)
name=strdup(s);
-#ifdef __U_BOOT__ - if (env_get(name) != NULL) { - printf ("ERROR: " - "There is a global environment variable with the same name.\n"); - free(name); - return -1; - } -#endif /* Assume when we enter this function that we are already in * NAME=VALUE format. So the first order of business is to * split 's' on the '=' into 'name' and 'value' */
abc=123
Rasmus Villemoes
