[PATCH] pinctrl: pinctrl_stm32: Add slew rate support for stm32_pinctrl_get_pin_muxing()
For debug purpose, it should be useful to indicate the slew rate for each pins. Add ospeed register information for pins which are configured in either alternate function or gpio output.
Signed-off-by: Patrice Chotard patrice.chotard@foss.st.com ---
drivers/pinctrl/pinctrl_stm32.c | 19 +++++++++++++++---- 1 file changed, 15 insertions(+), 4 deletions(-)
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index b755fa42b4f..b06da50b2cd 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -61,6 +61,13 @@ static const char * const pinmux_otype[] = { [STM32_GPIO_OTYPE_OD] = "open-drain", };
+static const char * const pinmux_speed[] = { + [STM32_GPIO_SPEED_2M] = "Low speed", + [STM32_GPIO_SPEED_25M] = "Medium speed", + [STM32_GPIO_SPEED_50M] = "High speed", + [STM32_GPIO_SPEED_100M] = "Very-high speed", +}; + static int stm32_pinctrl_get_af(struct udevice *dev, unsigned int offset) { struct stm32_gpio_priv *priv = dev_get_priv(dev); @@ -201,6 +208,7 @@ static int stm32_pinctrl_get_pin_muxing(struct udevice *dev, int af_num; unsigned int gpio_idx; u32 pupd, otype; + u8 speed;
/* look up for the bank which owns the requested pin */ gpio_dev = stm32_pinctrl_get_gpio_dev(dev, selector, &gpio_idx); @@ -214,6 +222,7 @@ static int stm32_pinctrl_get_pin_muxing(struct udevice *dev, priv = dev_get_priv(gpio_dev); pupd = (readl(&priv->regs->pupdr) >> (gpio_idx * 2)) & PUPD_MASK; otype = (readl(&priv->regs->otyper) >> gpio_idx) & OTYPE_MSK; + speed = (readl(&priv->regs->ospeedr) >> gpio_idx * 2) & OSPEED_MASK;
switch (mode) { case GPIOF_UNKNOWN: @@ -222,13 +231,15 @@ static int stm32_pinctrl_get_pin_muxing(struct udevice *dev, break; case GPIOF_FUNC: af_num = stm32_pinctrl_get_af(gpio_dev, gpio_idx); - snprintf(buf, size, "%s %d %s %s", pinmux_mode[mode], af_num, - pinmux_otype[otype], pinmux_bias[pupd]); + snprintf(buf, size, "%s %d %s %s %s", pinmux_mode[mode], af_num, + pinmux_otype[otype], pinmux_bias[pupd], + pinmux_speed[speed]); break; case GPIOF_OUTPUT: - snprintf(buf, size, "%s %s %s %s", + snprintf(buf, size, "%s %s %s %s %s", pinmux_mode[mode], pinmux_otype[otype], - pinmux_bias[pupd], label ? label : ""); + pinmux_bias[pupd], label ? label : "", + pinmux_speed[speed]); break; case GPIOF_INPUT: snprintf(buf, size, "%s %s %s", pinmux_mode[mode],
- [STM32_GPIO_SPEED_2M] = "Low speed",
- [STM32_GPIO_SPEED_25M] = "Medium speed",
- [STM32_GPIO_SPEED_50M] = "High speed",
- [STM32_GPIO_SPEED_100M] = "Very-high speed",
- static int stm32_pinctrl_get_af(struct udevice *dev, unsigned int offset) { struct stm32_gpio_priv *priv = dev_get_priv(dev);
u8 speed;
break; case GPIOF_OUTPUT:pinmux_speed[speed]);
break; case GPIOF_INPUT: snprintf(buf, size, "%s %s %s", pinmux_mode[mode],pinmux_speed[speed]);
Reviewed-by: Patrick Delaunay patrick.delaunay@foss.st.com
Thanks Patrick
diff --git a/drivers/pinctrl/pinctrl_stm32.c b/drivers/pinctrl/pinctrl_stm32.c index b755fa42b4f..b06da50b2cd 100644 --- a/drivers/pinctrl/pinctrl_stm32.c +++ b/drivers/pinctrl/pinctrl_stm32.c @@ -61,6 +61,13 @@ static const char * const pinmux_otype[] = { [STM32_GPIO_OTYPE_OD] = "open-drain", }; +static const char * const pinmux_speed[] = { + [STM32_GPIO_SPEED_2M] = "Low speed", + [STM32_GPIO_SPEED_25M] = "Medium speed", + [STM32_GPIO_SPEED_50M] = "High speed", + [STM32_GPIO_SPEED_100M] = "Very-high speed", +};
static int stm32_pinctrl_get_af(struct udevice *dev, unsigned int offset) { struct stm32_gpio_priv *priv = dev_get_priv(dev); @@ -201,6 +208,7 @@ static int stm32_pinctrl_get_pin_muxing(struct udevice *dev, int af_num; unsigned int gpio_idx; u32 pupd, otype; + u8 speed; /* look up for the bank which owns the requested pin */ gpio_dev = stm32_pinctrl_get_gpio_dev(dev, selector, &gpio_idx); @@ -214,6 +222,7 @@ static int stm32_pinctrl_get_pin_muxing(struct udevice *dev, priv = dev_get_priv(gpio_dev); pupd = (readl(&priv->regs->pupdr) >> (gpio_idx * 2)) & PUPD_MASK; otype = (readl(&priv->regs->otyper) >> gpio_idx) & OTYPE_MSK; + speed = (readl(&priv->regs->ospeedr) >> gpio_idx * 2) & OSPEED_MASK; switch (mode) { case GPIOF_UNKNOWN: @@ -222,13 +231,15 @@ static int stm32_pinctrl_get_pin_muxing(struct udevice *dev, break; case GPIOF_FUNC: af_num = stm32_pinctrl_get_af(gpio_dev, gpio_idx); - snprintf(buf, size, "%s %d %s %s", pinmux_mode[mode], af_num, - pinmux_otype[otype], pinmux_bias[pupd]); + snprintf(buf, size, "%s %d %s %s %s", pinmux_mode[mode], af_num, + pinmux_otype[otype], pinmux_bias[pupd], + pinmux_speed[speed]); break; case GPIOF_OUTPUT: - snprintf(buf, size, "%s %s %s %s", + snprintf(buf, size, "%s %s %s %s %s", pinmux_mode[mode], pinmux_otype[otype], - pinmux_bias[pupd], label ? label : ""); + pinmux_bias[pupd], label ? label : "", + pinmux_speed[speed]); break; case GPIOF_INPUT: snprintf(buf, size, "%s %s %s", pinmux_mode[mode],
Thanks Patrick
Applied on u-boot-stm/master, thanks.
Patrice
Patrice CHOTARD
Patrice Chotard
Patrick DELAUNAY
