[U-Boot] Pull request: u-boot-mmc 1/08/2014
Hi Tom,
The following changes since commit 25b4adbba018633b943a99322bfb2fb819c0bafb:
include: remove CONFIG_SPL/CONFIG_TPL definition in config headers (2014-07-30 14:42:03 -0400)
git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 6e7b7df4df435742fcfde5f384760ae1bda2e39c:
env_mmc: support env partition setup in runtime (2014-08-01 20:12:15 +0300)
---------------------------------------------------------------- Bo Shen (3): MMC: atmel_mci: refactor setting the mode register MMC: atmel_mci: add configuration register definition MMC: atmel_mci: enable high speed mode support
Chin Liang See (1): mmc/dw_mmc: Fix clock divider calculation error for bypass mode
Dmitry Lifshitz (2): env_mmc: add mmc_get_env_addr() prototype env_mmc: support env partition setup in runtime
DrEagle (1): ARM: kirkwood: add mvsdio driver
Lubomir Rintel (1): bcm2835_sdhci: Add SDHCI_QUIRK_NO_HISPD_BIT flag
Marek Vasut (2): arm: s3c: Unify the S3C24xx SDI structure mmc: s3c: Add SD driver
arch/arm/cpu/arm926ejs/kirkwood/cpu.c | 9 +++ arch/arm/include/asm/arch-kirkwood/kirkwood.h | 1 + arch/arm/include/asm/arch-s3c24x0/s3c2410.h | 4 +- arch/arm/include/asm/arch-s3c24x0/s3c2440.h | 4 +- arch/arm/include/asm/arch-s3c24x0/s3c24x0.h | 19 +++-- common/env_mmc.c | 35 ++++++--- drivers/mmc/Makefile | 2 + drivers/mmc/bcm2835_sdhci.c | 2 +- drivers/mmc/dw_mmc.c | 5 +- drivers/mmc/gen_atmel_mci.c | 63 +++++++++++---- drivers/mmc/mvebu_mmc.c | 361 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ drivers/mmc/s3c_sdi.c | 321 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/atmel_mci.h | 18 ++++- include/configs/openrd.h | 8 ++ include/configs/sheevaplug.h | 11 +++ include/environment.h | 9 +++ include/mvebu_mmc.h | 278 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 17 files changed, 1109 insertions(+), 41 deletions(-) create mode 100644 drivers/mmc/mvebu_mmc.c create mode 100644 drivers/mmc/s3c_sdi.c create mode 100644 include/mvebu_mmc.h
Regards
-- Pantelis
On Friday, August 01, 2014 at 07:21:23 PM, Pantelis Antoniou wrote:
Hi Tom,
DrEagle (1):
What is this nickname doing here ? Where is the full name of this person ?
Best regards, Marek Vasut
Hi Tom,
DrEagle (1):
I do not know that nickname was forbidden to contribute. My Real name is Gérald Kerma.
Enjoy, Gérald
Hi Tom,
25b4adbba018633b943a99322bfb2fb819c0bafb: include: remove CONFIG_SPL/CONFIG_TPL definition in config headers
are available in the git repository at: git://git.denx.de/u-boot-mmc.git master
for you to fetch changes up to 6e7b7df4df435742fcfde5f384760ae1bda2e39c: env_mmc: support env partition setup in runtime (2014-08-01 20:12:15
+0300)
DrEagle (1):
http://lwn.net/Articles/195643/ this is where it all started. I'd suggest you to read up on it. It's good the patch at least has a proper SoB line, so it's not _that_ big of a deal.
Dear Pantelis Antoniou,
On 08/01/2014 07:21 PM, Pantelis Antoniou wrote:
Hi Tom,
I'd love if you could wait for some ACK from me when applying atmel patches. This change affects avr32 and I doubt Bo has checked this architecture. I just had no time to run the tests from 31.07.2014 8:39 AM to 01.08.2014 6:59 PM.
I'm just back to office and will run the tests now.
Best regards
Andreas Bießmann
On Fri, Aug 01, 2014 at 08:21:23PM +0300, Pantelis Antoniou wrote:
Hi Tom,
participants (5)
Andreas Bießmann
drEagle
Pantelis Antoniou
