[U-Boot] [PATCH 1/3] Remove HMI10 board support
Recent changes caused that the HMI10 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time:
ps2ser.c: In function 'ps2ser_init': ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function) ps2ser.c:155: error: (Each undeclared identifier is reported only once ps2ser.c:155: error: for each function it appears in.) ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function) ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function) ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function) ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function) ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function) ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function) ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_putc': ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_getc_hw': ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_interrupt': ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function)
The board is orphaned, and AFAICT has reached EOL. Drop support for it.
Signed-off-by: Wolfgang Denk wd@denx.de --- board/mbx8xx/pcmcia.c | 4 - board/tqc/tqm8xx/tqm8xx.c | 23 -- boards.cfg | 1 - common/cmd_ide.c | 11 +- drivers/input/ps2ser.c | 109 ++-------- drivers/pcmcia/mpc8xx_pcmcia.c | 29 --- drivers/pcmcia/tqm8xx_pcmcia.c | 42 ---- include/configs/HMI10.h | 504 ---------------------------------------- include/status_led.h | 17 +-- 9 files changed, 23 insertions(+), 717 deletions(-) delete mode 100644 include/configs/HMI10.h
diff --git a/board/mbx8xx/pcmcia.c b/board/mbx8xx/pcmcia.c index 69368d8..e672d8c 100644 --- a/board/mbx8xx/pcmcia.c +++ b/board/mbx8xx/pcmcia.c @@ -117,11 +117,7 @@ int pcmcia_hardware_enable (int slot) debug ("[%d] %s: PIPR(%p)=0x%x\n", __LINE__,__FUNCTION__, &(pcmp->pcmc_pipr),pcmp->pcmc_pipr); -#ifndef CONFIG_HMI10 - if (pcmp->pcmc_pipr & (0x18000000 >> (slot << 4))) { -#else if (pcmp->pcmc_pipr & (0x10000000 >> (slot << 4))) { -#endif /* CONFIG_HMI10 */ printf (" No Card found\n"); return (1); } diff --git a/board/tqc/tqm8xx/tqm8xx.c b/board/tqc/tqm8xx/tqm8xx.c index cde780b..940cc8f 100644 --- a/board/tqc/tqm8xx/tqm8xx.c +++ b/board/tqc/tqm8xx/tqm8xx.c @@ -430,29 +430,6 @@ static long int dram_size (long int mamr_value, long int *base, long int maxsize
-#ifdef CONFIG_PS2MULT - -#ifdef CONFIG_HMI10 -#define BASE_BAUD ( 1843200 / 16 ) -struct serial_state rs_table[] = { - { BASE_BAUD, 4, (void*)0xec140000 }, - { BASE_BAUD, 2, (void*)0xec150000 }, - { BASE_BAUD, 6, (void*)0xec160000 }, - { BASE_BAUD, 10, (void*)0xec170000 }, -}; - -#ifdef CONFIG_BOARD_EARLY_INIT_R -int board_early_init_r (void) -{ - ps2mult_early_init(); - return (0); -} -#endif -#endif /* CONFIG_HMI10 */ - -#endif /* CONFIG_PS2MULT */ - - #ifdef CONFIG_MISC_INIT_R extern void load_sernum_ethaddr(void); int misc_init_r (void) diff --git a/boards.cfg b/boards.cfg index 0bf9c93..25a58f4 100644 --- a/boards.cfg +++ b/boards.cfg @@ -170,7 +170,6 @@ QS823 powerpc mpc8xx qs850 snmc QS850 powerpc mpc8xx qs850 snmc QS860T powerpc mpc8xx qs860t snmc stxxtc powerpc mpc8xx stxxtc stx -HMI10 powerpc mpc8xx tqm8xx tqc SM850 powerpc mpc8xx tqm8xx tqc AMX860 powerpc mpc8xx amx860 westel csb272 powerpc ppc4xx diff --git a/common/cmd_ide.c b/common/cmd_ide.c index 6aeca76..ea0f4a7 100644 --- a/common/cmd_ide.c +++ b/common/cmd_ide.c @@ -818,7 +818,7 @@ set_pcmcia_timing (int pmode) static void input_swap_data(int dev, ulong *sect_buf, int words) { -#if defined(CONFIG_HMI10) || defined(CONFIG_CPC45) +#if defined(CONFIG_CPC45) uchar i; volatile uchar *pbuf_even = (uchar *)(ATA_CURR_BASE(dev)+ATA_DATA_EVEN); volatile uchar *pbuf_odd = (uchar *)(ATA_CURR_BASE(dev)+ATA_DATA_ODD); @@ -858,7 +858,7 @@ input_swap_data(int dev, ulong *sect_buf, int words) static void output_data(int dev, ulong *sect_buf, int words) { -#if defined(CONFIG_HMI10) || defined(CONFIG_CPC45) +#if defined(CONFIG_CPC45) uchar *dbuf; volatile uchar *pbuf_even; volatile uchar *pbuf_odd; @@ -910,7 +910,7 @@ output_data(int dev, ulong *sect_buf, int words) static void input_data(int dev, ulong *sect_buf, int words) { -#if defined(CONFIG_HMI10) || defined(CONFIG_CPC45) +#if defined(CONFIG_CPC45) uchar *dbuf; volatile uchar *pbuf_even; volatile uchar *pbuf_odd; @@ -1544,7 +1544,6 @@ static void ide_reset (void)
#if defined(CONFIG_IDE_LED) && \ !defined(CONFIG_CPC45) && \ - !defined(CONFIG_HMI10) && \ !defined(CONFIG_KUP4K) && \ !defined(CONFIG_KUP4X)
@@ -1586,7 +1585,7 @@ int ide_device_present(int dev) static void output_data_shorts(int dev, ushort *sect_buf, int shorts) { -#if defined(CONFIG_HMI10) || defined(CONFIG_CPC45) +#if defined(CONFIG_CPC45) uchar *dbuf; volatile uchar *pbuf_even; volatile uchar *pbuf_odd; @@ -1618,7 +1617,7 @@ output_data_shorts(int dev, ushort *sect_buf, int shorts) static void input_data_shorts(int dev, ushort *sect_buf, int shorts) { -#if defined(CONFIG_HMI10) || defined(CONFIG_CPC45) +#if defined(CONFIG_CPC45) uchar *dbuf; volatile uchar *pbuf_even; volatile uchar *pbuf_odd; diff --git a/drivers/input/ps2ser.c b/drivers/input/ps2ser.c index 8d0b6d6..a655a16 100644 --- a/drivers/input/ps2ser.c +++ b/drivers/input/ps2ser.c @@ -46,8 +46,7 @@ DECLARE_GLOBAL_DATA_PTR; #error CONFIG_PS2SERIAL must be in 1 ... 6 #endif
-#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) +#else
#if CONFIG_PS2SERIAL == 1 #define COM_BASE (CONFIG_SYS_CCSRBAR+0x4500) @@ -57,17 +56,12 @@ DECLARE_GLOBAL_DATA_PTR; #error CONFIG_PS2SERIAL must be in 1 ... 2 #endif
-#endif /* CONFIG_MPC5xxx / CONFIG_MPC8540 / other */ +#endif /* CONFIG_MPC5xxx / other */
static int ps2ser_getc_hw(void); static void ps2ser_interrupt(void *dev_id);
extern struct serial_state rs_table[]; /* in serial.c */ -#if !defined(CONFIG_MPC5xxx) && !defined(CONFIG_MPC8540) && \ - !defined(CONFIG_MPC8541) && !defined(CONFIG_MPC8548) && \ - !defined(CONFIG_MPC8555) -static struct serial_state *state; -#endif
static u_char ps2buf[PS2BUF_SIZE]; static atomic_t ps2buf_cnt; @@ -111,8 +105,8 @@ int ps2ser_init(void) return (0); }
-#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) +#else + int ps2ser_init(void) { NS16550_t com_port = (NS16550_t)COM_BASE; @@ -128,76 +122,24 @@ int ps2ser_init(void) return (0); }
-#else /* !CONFIG_MPC5xxx && !CONFIG_MPC8540 / other */ - -static inline unsigned int ps2ser_in(int offset) -{ - return readb((unsigned long) state->iomem_base + offset); -} - -static inline void ps2ser_out(int offset, int value) -{ - writeb(value, (unsigned long) state->iomem_base + offset); -} - -int ps2ser_init(void) -{ - int quot; - unsigned cval; - - state = rs_table + CONFIG_PS2SERIAL; - - quot = state->baud_base / PS2SER_BAUD; - cval = 0x3; /* 8N1 - 8 data bits, no parity bits, 1 stop bit */ - - /* Set speed, enable interrupts, enable FIFO - */ - ps2ser_out(UART_LCR, cval | UART_LCR_DLAB); - ps2ser_out(UART_DLL, quot & 0xff); - ps2ser_out(UART_DLM, quot >> 8); - ps2ser_out(UART_LCR, cval); - ps2ser_out(UART_IER, UART_IER_RDI); - ps2ser_out(UART_MCR, UART_MCR_OUT2 | UART_MCR_DTR | UART_MCR_RTS); - ps2ser_out(UART_FCR, - UART_FCR_ENABLE_FIFO | UART_FCR_CLEAR_RCVR | UART_FCR_CLEAR_XMIT); - - /* If we read 0xff from the LSR, there is no UART here - */ - if (ps2ser_in(UART_LSR) == 0xff) { - printf ("ps2ser.c: no UART found\n"); - return -1; - } - - irq_install_handler(state->irq, ps2ser_interrupt, NULL); - - return 0; -} -#endif /* CONFIG_MPC5xxx / CONFIG_MPC8540 / other */ +#endif /* CONFIG_MPC5xxx / other */
void ps2ser_putc(int chr) { #ifdef CONFIG_MPC5xxx volatile struct mpc5xxx_psc *psc = (struct mpc5xxx_psc *)PSC_BASE; -#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) +#else NS16550_t com_port = (NS16550_t)COM_BASE; #endif -#ifdef DEBUG - printf(">>>> 0x%02x\n", chr); -#endif + debug(">>>> 0x%02x\n", chr);
#ifdef CONFIG_MPC5xxx while (!(psc->psc_status & PSC_SR_TXRDY));
psc->psc_buffer_8 = chr; -#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) +#else while ((com_port->lsr & UART_LSR_THRE) == 0); com_port->thr = chr; -#else - while (!(ps2ser_in(UART_LSR) & UART_LSR_THRE)); - - ps2ser_out(UART_TX, chr); #endif }
@@ -205,8 +147,7 @@ static int ps2ser_getc_hw(void) { #ifdef CONFIG_MPC5xxx volatile struct mpc5xxx_psc *psc = (struct mpc5xxx_psc *)PSC_BASE; -#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) +#else NS16550_t com_port = (NS16550_t)COM_BASE; #endif int res = -1; @@ -215,15 +156,10 @@ static int ps2ser_getc_hw(void) if (psc->psc_status & PSC_SR_RXRDY) { res = (psc->psc_buffer_8); } -#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) +#else if (com_port->lsr & UART_LSR_DR) { res = com_port->rbr; } -#else - if (ps2ser_in(UART_LSR) & UART_LSR_DR) { - res = (ps2ser_in(UART_RX)); - } #endif
return res; @@ -234,9 +170,7 @@ int ps2ser_getc(void) volatile int chr; int flags;
-#ifdef DEBUG - printf("<< "); -#endif + debug("<< ");
flags = disable_interrupts();
@@ -251,11 +185,10 @@ int ps2ser_getc(void) } while (chr < 0);
- if (flags) enable_interrupts(); + if (flags) + enable_interrupts();
-#ifdef DEBUG - printf("0x%02x\n", chr); -#endif + debug("0x%02x\n", chr);
return chr; } @@ -275,8 +208,7 @@ static void ps2ser_interrupt(void *dev_id) { #ifdef CONFIG_MPC5xxx volatile struct mpc5xxx_psc *psc = (struct mpc5xxx_psc *)PSC_BASE; -#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) +#else NS16550_t com_port = (NS16550_t)COM_BASE; #endif int chr; @@ -286,11 +218,8 @@ static void ps2ser_interrupt(void *dev_id) chr = ps2ser_getc_hw(); #ifdef CONFIG_MPC5xxx status = psc->psc_status; -#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) - status = com_port->lsr; #else - status = ps2ser_in(UART_IIR); + status = com_port->lsr; #endif if (chr < 0) continue;
@@ -303,13 +232,9 @@ static void ps2ser_interrupt(void *dev_id) } #ifdef CONFIG_MPC5xxx } while (status & PSC_SR_RXRDY); -#elif defined(CONFIG_MPC8540) || defined(CONFIG_MPC8541) || \ - defined(CONFIG_MPC8548) || defined(CONFIG_MPC8555) - } while (status & UART_LSR_DR); #else - } while (status & UART_IIR_RDI); + } while (status & UART_LSR_DR); #endif - if (atomic_read(&ps2buf_cnt)) { ps2mult_callback(atomic_read(&ps2buf_cnt)); } diff --git a/drivers/pcmcia/mpc8xx_pcmcia.c b/drivers/pcmcia/mpc8xx_pcmcia.c index 7030574..74a50f1 100644 --- a/drivers/pcmcia/mpc8xx_pcmcia.c +++ b/drivers/pcmcia/mpc8xx_pcmcia.c @@ -57,12 +57,6 @@ static const u_int m8xx_size_to_gray[M8XX_SIZES_NO] =
-#ifdef CONFIG_HMI10 -#define HMI10_FRAM_TIMING ( PCMCIA_SHT(2) \ - | PCMCIA_SST(2) \ - | PCMCIA_SL(4)) -#endif - #if defined(CONFIG_LWMON) || defined(CONFIG_NSCU) #define CONFIG_SYS_PCMCIA_TIMING ( PCMCIA_SHT(9) \ | PCMCIA_SST(3) \ @@ -106,17 +100,6 @@ int pcmcia_on (void) switch (i) { #ifdef CONFIG_IDE_8xx_PCCARD case 4: -#ifdef CONFIG_HMI10 - { /* map FRAM area */ - win->or = ( PCMCIA_BSIZE_256K - | PCMCIA_PPS_8 - | PCMCIA_PRS_ATTR - | slotbit - | PCMCIA_PV - | HMI10_FRAM_TIMING ); - break; - } -#endif case 0: { /* map attribute memory */ win->or = ( PCMCIA_BSIZE_64M | PCMCIA_PPS_8 @@ -147,18 +130,6 @@ int pcmcia_on (void) break; } #endif /* CONFIG_IDE_8xx_PCCARD */ -#ifdef CONFIG_HMI10 - case 3: { /* map I/O window for 4xUART data/ctrl */ - win->br += 0x40000; - win->or = ( PCMCIA_BSIZE_256K - | PCMCIA_PPS_8 - | PCMCIA_PRS_IO - | slotbit - | PCMCIA_PV - | CONFIG_SYS_PCMCIA_TIMING ); - break; - } -#endif /* CONFIG_HMI10 */ default: /* set to not valid */ win->or = 0; break; diff --git a/drivers/pcmcia/tqm8xx_pcmcia.c b/drivers/pcmcia/tqm8xx_pcmcia.c index 6ba8b5c..ca1a9fe 100644 --- a/drivers/pcmcia/tqm8xx_pcmcia.c +++ b/drivers/pcmcia/tqm8xx_pcmcia.c @@ -36,39 +36,6 @@ #define power_on_5_0(slot) do {} while (0) #define power_on_3_3(slot) do {} while (0)
-#elif defined(CONFIG_HMI10) - -static inline void power_config(int slot) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - /* - * Configure Port B pins for - * 5 Volts Enable and 3 Volts enable - */ - immap->im_cpm.cp_pbpar &= ~(0x00000300); -} - -static inline void power_off(int slot) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - /* remove all power */ - immap->im_cpm.cp_pbdat |= 0x00000300; -} - -static inline void power_on_5_0(int slot) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - immap->im_cpm.cp_pbdat &= ~(0x0000100); - immap->im_cpm.cp_pbdir |= 0x00000300; -} - -static inline void power_on_3_3(int slot) -{ - volatile immap_t *immap = (immap_t *)CONFIG_SYS_IMMR; - immap->im_cpm.cp_pbdat &= ~(0x0000200); - immap->im_cpm.cp_pbdir |= 0x00000300; -} - #elif defined(CONFIG_VIRTLAB2)
#define power_config(slot) do {} while (0) @@ -128,21 +95,12 @@ static inline void power_on_3_3(int slot)
#endif
-#ifdef CONFIG_HMI10 -static inline int check_card_is_absent(int slot) -{ - volatile pcmconf8xx_t *pcmp = - (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); - return pcmp->pcmc_pipr & (0x10000000 >> (slot << 4)); -} -#else static inline int check_card_is_absent(int slot) { volatile pcmconf8xx_t *pcmp = (pcmconf8xx_t *)(&(((immap_t *)CONFIG_SYS_IMMR)->im_pcmcia)); return pcmp->pcmc_pipr & (0x18000000 >> (slot << 4)); } -#endif
#ifdef NSCU_OE_INV #define NSCU_GCRX_CXOE 0 diff --git a/include/configs/HMI10.h b/include/configs/HMI10.h deleted file mode 100644 index 2747d8c..0000000 --- a/include/configs/HMI10.h +++ /dev/null @@ -1,504 +0,0 @@ -/* - * (C) Copyright 2000-2008 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -/* - * board/config.h - configuration options, board specific - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_HMI10 -#define CONFIG_MPC823 1 /* This is a MPC823 CPU */ -#define CONFIG_TQM823L 1 /* ...on a TQM8xxL module */ - -#define CONFIG_LCD -#define CONFIG_NEC_NL6448BC33_54 /* NEC NL6448BC33_54 display */ - -#ifdef CONFIG_LCD /* with LCD controller ? */ -#define CONFIG_SPLASH_SCREEN /* ... with splashscreen support*/ -#endif - -#define CONFIG_8xx_CONS_SMC1 1 /* Console is on SMC1 */ -#define CONFIG_SYS_SMC_RXBUFLEN 128 -#define CONFIG_SYS_MAXIDLE 10 -#define CONFIG_BAUDRATE 115200 /* console baudrate = 115kbps */ - -#define CONFIG_PS2KBD /* AT-PS/2 Keyboard */ -#define CONFIG_PS2MULT /* .. on PS/2 Multiplexer */ -#define CONFIG_PS2SERIAL 2 /* .. on COM3 */ -#define CONFIG_PS2MULT_DELAY (CONFIG_SYS_HZ/2) /* Initial delay */ - -#define CONFIG_BOOTCOUNT_LIMIT - -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_BOARD_TYPES 1 /* support board types */ - -#define CONFIG_PREBOOT "echo;echo Type \"run flash_nfs\" to mount root filesystem over NFS;echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "rootpath=/opt/eldk/ppc_8xx\0" \ - "bootfile=/tftpboot/HMI10/uImage\0" \ - "kernel_addr=40040000\0" \ - "ramdisk_addr=40100000\0" \ - "" -#define CONFIG_BOOTCOMMAND "run flash_self" - -#define CONFIG_BOARD_EARLY_INIT_R 1 -#define CONFIG_MISC_INIT_R 1 - -#define CONFIG_LOADS_ECHO 1 /* echo on for serial download */ -#undef CONFIG_SYS_LOADS_BAUD_CHANGE /* don't allow baudrate change */ - -/* enable I2C and select the hardware/software driver */ -#undef CONFIG_HARD_I2C /* I2C with hardware support */ -#define CONFIG_SOFT_I2C 1 /* I2C bit-banged */ - -#define CONFIG_SYS_I2C_SPEED 40000 /* 40 kHz is supposed to work */ -#define CONFIG_SYS_I2C_SLAVE 0xFE - -/* Software (bit-bang) I2C driver configuration */ -#define PB_SCL 0x00000020 /* PB 26 */ -#define PB_SDA 0x00000010 /* PB 27 */ - -#define I2C_INIT (immr->im_cpm.cp_pbdir |= PB_SCL) -#define I2C_ACTIVE (immr->im_cpm.cp_pbdir |= PB_SDA) -#define I2C_TRISTATE (immr->im_cpm.cp_pbdir &= ~PB_SDA) -#define I2C_READ ((immr->im_cpm.cp_pbdat & PB_SDA) != 0) -#define I2C_SDA(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SDA; \ - else immr->im_cpm.cp_pbdat &= ~PB_SDA -#define I2C_SCL(bit) if(bit) immr->im_cpm.cp_pbdat |= PB_SCL; \ - else immr->im_cpm.cp_pbdat &= ~PB_SCL -#define I2C_DELAY udelay(5) /* 1/4 I2C clock duration */ - -#undef CONFIG_WATCHDOG /* watchdog disabled */ - -#define CONFIG_STATUS_LED 1 /* Status LED enabled */ - -#define CONFIG_CAN_DRIVER 1 /* CAN Driver support enabled */ - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_SUBNETMASK -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_BOOTFILESIZE - - -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION - -#define CONFIG_RTC_DS1337 /* Use ds1337 rtc via i2c */ -#define CONFIG_SYS_I2C_RTC_ADDR 0x68 /* at address 0x68 */ - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> - -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_FAT -#define CONFIG_CMD_I2C -#define CONFIG_CMD_IDE -#define CONFIG_CMD_NFS -#define CONFIG_CMD_SNTP - -#ifdef CONFIG_SPLASH_SCREEN - #define CONFIG_CMD_BMP -#endif - - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ - -#if 0 -#define CONFIG_SYS_HUSH_PARSER 1 /* use "hush" command parser */ -#endif -#ifdef CONFIG_SYS_HUSH_PARSER -#define CONFIG_SYS_PROMPT_HUSH_PS2 "> " -#endif - -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -#define CONFIG_SYS_MEMTEST_START 0x0400000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x0C00000 /* 4 ... 12 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ - -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200 } - -/* - * Low Level Configuration Settings - * (address mappings, register initial values, etc.) - * You should know what you are doing if you make changes here. - */ -/*----------------------------------------------------------------------- - * Internal Memory Mapped Register - */ -#define CONFIG_SYS_IMMR 0xFFF00000 - -/*----------------------------------------------------------------------- - * Definitions for initial stack pointer and data area (in DPRAM) - */ -#define CONFIG_SYS_INIT_RAM_ADDR CONFIG_SYS_IMMR -#define CONFIG_SYS_INIT_RAM_END 0x2F00 /* End of used area in DPRAM */ -#define CONFIG_SYS_GBL_DATA_SIZE 64 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -/*----------------------------------------------------------------------- - * Start addresses for the final memory configuration - * (Set up by the startup code) - * Please note that CONFIG_SYS_SDRAM_BASE _must_ start at 0 - */ -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_FLASH_BASE 0x40000000 -#define CONFIG_SYS_MONITOR_LEN (256 << 10) /* Reserve 256 kB for Monitor */ -#define CONFIG_SYS_MONITOR_BASE CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_MALLOC_LEN (128 << 10) /* Reserve 128 kB for malloc() */ - -/* - * For booting Linux, the board info and command line data - * have to be in the first 8 MB of memory, since this is - * the maximum mapped by the Linux kernel during initialization. - */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/*----------------------------------------------------------------------- - * FLASH organization - */ - -/* use CFI flash driver */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_FLASH_BASE } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_USE_BUFFER_WRITE 1 -#define CONFIG_SYS_MAX_FLASH_BANKS 2 /* max number of memory banks */ -#define CONFIG_SYS_MAX_FLASH_SECT 71 /* max number of sectors on one chip */ - -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_OFFSET 0x8000 /* Offset of Environment Sector */ -#define CONFIG_ENV_SIZE 0x4000 /* Total Size of Environment Sector */ - -/* Address and size of Redundant Environment Sector */ -#define CONFIG_ENV_OFFSET_REDUND (CONFIG_ENV_OFFSET+CONFIG_ENV_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -/*----------------------------------------------------------------------- - * Hardware Information Block - */ -#define CONFIG_SYS_HWINFO_OFFSET 0x0003FFC0 /* offset of HW Info block */ -#define CONFIG_SYS_HWINFO_SIZE 0x00000040 /* size of HW Info block */ -#define CONFIG_SYS_HWINFO_MAGIC 0x54514D38 /* 'TQM8' */ - -/*----------------------------------------------------------------------- - * Cache Configuration - */ -#define CONFIG_SYS_CACHELINE_SIZE 16 /* For all MPC8xx CPUs */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CACHELINE_SHIFT 4 /* log base 2 of the above value */ -#endif - -/*----------------------------------------------------------------------- - * SYPCR - System Protection Control 11-9 - * SYPCR can only be written once after reset! - *----------------------------------------------------------------------- - * Software & Bus Monitor Timer max, Bus Monitor enable, SW Watchdog freeze - */ -#if defined(CONFIG_WATCHDOG) -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | \ - SYPCR_SWE | SYPCR_SWRI| SYPCR_SWP) -#else -#define CONFIG_SYS_SYPCR (SYPCR_SWTC | SYPCR_BMT | SYPCR_BME | SYPCR_SWF | SYPCR_SWP) -#endif - -/*----------------------------------------------------------------------- - * SIUMCR - SIU Module Configuration 11-6 - *----------------------------------------------------------------------- - * PCMCIA config., multi-function pin tri-state - */ -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC00 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#else /* we must activate GPL5 in the SIUMCR for CAN */ -#define CONFIG_SYS_SIUMCR (SIUMCR_DBGC11 | SIUMCR_DBPC00 | SIUMCR_MLRC01) -#endif /* CONFIG_CAN_DRIVER */ - -/*----------------------------------------------------------------------- - * TBSCR - Time Base Status and Control 11-26 - *----------------------------------------------------------------------- - * Clear Reference Interrupt Status, Timebase freezing enabled - */ -#define CONFIG_SYS_TBSCR (TBSCR_REFA | TBSCR_REFB | TBSCR_TBF) - -/*----------------------------------------------------------------------- - * RTCSC - Real-Time Clock Status and Control Register 11-27 - *----------------------------------------------------------------------- - */ -#define CONFIG_SYS_RTCSC (RTCSC_SEC | RTCSC_ALR | RTCSC_RTF| RTCSC_RTE) - -/*----------------------------------------------------------------------- - * PISCR - Periodic Interrupt Status and Control 11-31 - *----------------------------------------------------------------------- - * Clear Periodic Interrupt Status, Interrupt Timer freezing enabled - */ -#define CONFIG_SYS_PISCR (PISCR_PS | PISCR_PITF) - -/*----------------------------------------------------------------------- - * PLPRCR - PLL, Low-Power, and Reset Control Register 15-30 - *----------------------------------------------------------------------- - * Reset PLL lock status sticky bit, timer expired status bit and timer - * interrupt status bit - * - * If this is a 80 MHz CPU, set PLL multiplication factor to 5 (5*16=80)! - */ -#define CONFIG_SYS_PLPRCR (PLPRCR_SPLSS | PLPRCR_TEXPS | PLPRCR_TMIST) - -/*----------------------------------------------------------------------- - * SCCR - System Clock and reset Control Register 15-27 - *----------------------------------------------------------------------- - * Set clock output, timebase and RTC source and divider, - * power management and some other internal clocks - */ -#define SCCR_MASK SCCR_EBDF11 -#define CONFIG_SYS_SCCR (SCCR_COM00 | SCCR_DFSYNC00 | SCCR_DFBRG00 | \ - SCCR_DFNL000 | SCCR_DFNH000 | SCCR_DFLCD000 | \ - SCCR_DFALCD00) - -/*----------------------------------------------------------------------- - * PCMCIA stuff - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_PCMCIA_MEM_ADDR (0xE0100000) -#define CONFIG_SYS_PCMCIA_MEM_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_DMA_ADDR (0xE4100000) -#define CONFIG_SYS_PCMCIA_DMA_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_ATTRB_ADDR (0xE8100000) -#define CONFIG_SYS_PCMCIA_ATTRB_SIZE ( 64 << 20 ) -#define CONFIG_SYS_PCMCIA_IO_ADDR (0xEC100000) -#define CONFIG_SYS_PCMCIA_IO_SIZE ( 64 << 20 ) -#define PCMCIA_MEM_WIN_NO 5 -#define NSCU_OE_INV 1 /* PCMCIA_GCRX_CXOE is inverted */ - -/*----------------------------------------------------------------------- - * IDE/ATA stuff (Supports IDE harddisk on PCMCIA Adapter) - *----------------------------------------------------------------------- - */ - -#define CONFIG_IDE_8xx_PCCARD 1 /* Use IDE with PC Card Adapter */ - -#undef CONFIG_IDE_8xx_DIRECT /* Direct IDE not supported */ -#undef CONFIG_IDE_RESET /* reset for ide not supported */ -#ifndef CONFIG_STATUS_LED /* Status and IDE LED's are mutually exclusive */ -#define CONFIG_IDE_LED 1 /* LED for ide supported */ -#endif - -#define CONFIG_SYS_IDE_MAXBUS 1 /* max. 1 IDE bus */ -#define CONFIG_SYS_IDE_MAXDEVICE 1 /* max. 1 drive per IDE bus */ - -#define CONFIG_SYS_ATA_IDE0_OFFSET 0x0000 - -#define CONFIG_SYS_ATA_BASE_ADDR CONFIG_SYS_PCMCIA_MEM_ADDR - -/* Offset for data I/O */ -#define CONFIG_SYS_ATA_DATA_OFFSET (CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for normal register accesses */ -#define CONFIG_SYS_ATA_REG_OFFSET (2 * CONFIG_SYS_PCMCIA_MEM_SIZE + 0x320) - -/* Offset for alternate registers */ -#define CONFIG_SYS_ATA_ALT_OFFSET 0x0100 - -/*----------------------------------------------------------------------- - * - *----------------------------------------------------------------------- - * - */ -#define CONFIG_SYS_DER 0 - -/* - * Init Memory Controller: - * - * BR0/1 and OR0/1 (FLASH) - */ - -#define FLASH_BASE0_PRELIM 0x40000000 /* FLASH bank #0 */ -#define FLASH_BASE1_PRELIM 0x60000000 /* FLASH bank #0 */ - -/* used to re-map FLASH both when starting from SRAM or FLASH: - * restrict access enough to keep SRAM working (if any) - * but not too much to meddle with FLASH accesses - */ -#define CONFIG_SYS_REMAP_OR_AM 0x80000000 /* OR addr mask */ -#define CONFIG_SYS_PRELIM_OR_AM 0xE0000000 /* OR addr mask */ - -/* - * FLASH timing: - */ -#define CONFIG_SYS_OR_TIMING_FLASH (OR_ACS_DIV1 | OR_TRLX | OR_CSNT_SAM | \ - OR_SCY_3_CLK | OR_EHTR | OR_BI) - -#define CONFIG_SYS_OR0_REMAP (CONFIG_SYS_REMAP_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_OR0_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_FLASH) -#define CONFIG_SYS_BR0_PRELIM ((FLASH_BASE0_PRELIM & BR_BA_MSK) | BR_V ) - -#define CONFIG_SYS_OR1_REMAP CONFIG_SYS_OR0_REMAP -#define CONFIG_SYS_OR1_PRELIM CONFIG_SYS_OR0_PRELIM -#define CONFIG_SYS_BR1_PRELIM ((FLASH_BASE1_PRELIM & BR_BA_MSK) | BR_V ) - -/* - * BR2/3 and OR2/3 (SDRAM) - * - */ -#define SDRAM_BASE2_PRELIM 0x00000000 /* SDRAM bank #0 */ -#define SDRAM_BASE3_PRELIM 0x20000000 /* SDRAM bank #1 */ -#define SDRAM_MAX_SIZE 0x04000000 /* max 64 MB per bank */ - -/* SDRAM timing: Multiplexed addresses, GPL5 output to GPL5_A (don't care) */ -#define CONFIG_SYS_OR_TIMING_SDRAM 0x00000A00 - -#define CONFIG_SYS_OR2_PRELIM (CONFIG_SYS_PRELIM_OR_AM | CONFIG_SYS_OR_TIMING_SDRAM ) -#define CONFIG_SYS_BR2_PRELIM ((SDRAM_BASE2_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) - -#ifndef CONFIG_CAN_DRIVER -#define CONFIG_SYS_OR3_PRELIM CONFIG_SYS_OR2_PRELIM -#define CONFIG_SYS_BR3_PRELIM ((SDRAM_BASE3_PRELIM & BR_BA_MSK) | BR_MS_UPMA | BR_V ) -#else /* CAN uses CS3#, so we can have only one SDRAM bank anyway */ -#define CONFIG_SYS_CAN_BASE 0xC0000000 /* CAN mapped at 0xC0000000 */ -#define CONFIG_SYS_CAN_OR_AM 0xFFFF8000 /* 32 kB address mask */ -#define CONFIG_SYS_OR3_CAN (CONFIG_SYS_CAN_OR_AM | OR_G5LA | OR_BI) -#define CONFIG_SYS_BR3_CAN ((CONFIG_SYS_CAN_BASE & BR_BA_MSK) | \ - BR_PS_8 | BR_MS_UPMB | BR_V ) -#endif /* CONFIG_CAN_DRIVER */ - -/* - * Memory Periodic Timer Prescaler - * - * The Divider for PTA (refresh timer) configuration is based on an - * example SDRAM configuration (64 MBit, one bank). The adjustment to - * the number of chip selects (NCS) and the actually needed refresh - * rate is done by setting MPTPR. - * - * PTA is calculated from - * PTA = (gclk * Trefresh) / ((2 ^ (2 * DFBRG)) * PTP * NCS) - * - * gclk CPU clock (not bus clock!) - * Trefresh Refresh cycle * 4 (four word bursts used) - * - * 4096 Rows from SDRAM example configuration - * 1000 factor s -> ms - * 32 PTP (pre-divider from MPTPR) from SDRAM example configuration - * 4 Number of refresh cycles per period - * 64 Refresh cycle in ms per number of rows - * -------------------------------------------- - * Divider = 4096 * 32 * 1000 / (4 * 64) = 512000 - * - * 50 MHz => 50.000.000 / Divider = 98 - * 66 Mhz => 66.000.000 / Divider = 129 - * 80 Mhz => 80.000.000 / Divider = 156 - */ - -#define CONFIG_SYS_PTA_PER_CLK ((4096 * 32 * 1000) / (4 * 64)) -#define CONFIG_SYS_MAMR_PTA 98 - -/* - * For 16 MBit, refresh rates could be 31.3 us - * (= 64 ms / 2K = 125 / quad bursts). - * For a simpler initialization, 15.6 us is used instead. - * - * #define CONFIG_SYS_MPTPR_2BK_2K MPTPR_PTP_DIV32 for 2 banks - * #define CONFIG_SYS_MPTPR_1BK_2K MPTPR_PTP_DIV64 for 1 bank - */ -#define CONFIG_SYS_MPTPR_2BK_4K MPTPR_PTP_DIV16 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_4K MPTPR_PTP_DIV32 /* setting for 1 bank */ - -/* refresh rate 7.8 us (= 64 ms / 8K = 31.2 / quad bursts) for 256 MBit */ -#define CONFIG_SYS_MPTPR_2BK_8K MPTPR_PTP_DIV8 /* setting for 2 banks */ -#define CONFIG_SYS_MPTPR_1BK_8K MPTPR_PTP_DIV16 /* setting for 1 bank */ - -/* - * MAMR settings for SDRAM - */ - -/* 8 column SDRAM */ -#define CONFIG_SYS_MAMR_8COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_0 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A11 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) -/* 9 column SDRAM */ -#define CONFIG_SYS_MAMR_9COL ((CONFIG_SYS_MAMR_PTA << MAMR_PTA_SHIFT) | MAMR_PTAE | \ - MAMR_AMA_TYPE_1 | MAMR_DSA_1_CYCL | MAMR_G0CLA_A10 | \ - MAMR_RLFA_1X | MAMR_WLFA_1X | MAMR_TLFA_4X) - - -/* - * Internal Definitions - * - * Boot Flags - */ -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -/* pass open firmware flat tree */ -#define CONFIG_OF_LIBFDT 1 -#define CONFIG_OF_BOARD_SETUP 1 -#define CONFIG_HWCONFIG 1 - -#endif /* __CONFIG_H */ diff --git a/include/status_led.h b/include/status_led.h index f213595..b39ca64 100644 --- a/include/status_led.h +++ b/include/status_led.h @@ -43,7 +43,7 @@ void status_led_tick (unsigned long timestamp); void status_led_set (int led, int state);
/***** TQM8xxL ********************************************************/ -#if defined(CONFIG_TQM8xxL) && !defined(CONFIG_HMI10) +#if defined(CONFIG_TQM8xxL) # define STATUS_LED_PAR im_cpm.cp_pbpar # define STATUS_LED_DIR im_cpm.cp_pbdir # define STATUS_LED_ODR im_cpm.cp_pbodr @@ -318,21 +318,6 @@ void status_led_set (int led, int state);
# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */
-/***** HMI10 **********************************************************/ -#elif defined(CONFIG_HMI10) -# define STATUS_LED_PAR im_ioport.iop_papar -# define STATUS_LED_DIR im_ioport.iop_padir -# define STATUS_LED_ODR im_ioport.iop_paodr -# define STATUS_LED_DAT im_ioport.iop_padat - -# define STATUS_LED_BIT 0x00000001 /* LED is on PA15 */ -# define STATUS_LED_PERIOD (CONFIG_SYS_HZ / 2) -# define STATUS_LED_STATE STATUS_LED_BLINKING - -# define STATUS_LED_ACTIVE 1 /* LED on for bit == 1 */ - -# define STATUS_LED_BOOT 0 /* LED 0 used for boot status */ - /***** NetPhone ********************************************************/ #elif defined(CONFIG_NETPHONE) || defined(CONFIG_NETTA2) /* XXX empty just to avoid the error */
Recent changes caused that the smmaco4 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time:
mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized.
The board is orphaned. Drop support for it.
Signed-off-by: Wolfgang Denk wd@denx.de --- boards.cfg | 1 - include/configs/smmaco4.h | 379 --------------------------------------------- 2 files changed, 0 insertions(+), 380 deletions(-) delete mode 100644 include/configs/smmaco4.h
diff --git a/boards.cfg b/boards.cfg index 25a58f4..0ca4ce1 100644 --- a/boards.cfg +++ b/boards.cfg @@ -104,7 +104,6 @@ uc101 powerpc mpc5xxx v38b powerpc mpc5xxx pf5200 powerpc mpc5xxx - esd aev powerpc mpc5xxx tqm5200 tqc -smmaco4 powerpc mpc5xxx tqm5200 tqc spieval powerpc mpc5xxx tqm5200 tqc sorcery powerpc mpc8220 A3000 powerpc mpc824x a3000 diff --git a/include/configs/smmaco4.h b/include/configs/smmaco4.h deleted file mode 100644 index 060026b..0000000 --- a/include/configs/smmaco4.h +++ /dev/null @@ -1,379 +0,0 @@ -/* - * (C) Copyright 2003-2006 - * Wolfgang Denk, DENX Software Engineering, wd@denx.de. - * - * (C) Copyright 2004-2005 - * Martin Krause, TQ-Systems GmbH, martin.krause@tqs.de - * - * See file CREDITS for list of people who contributed to this - * project. - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; either version 2 of - * the License, or (at your option) any later version. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 59 Temple Place, Suite 330, Boston, - * MA 02111-1307 USA - */ - -#ifndef __CONFIG_H -#define __CONFIG_H - -/* - * High Level Configuration Options - * (easy to change) - */ - -#define CONFIG_MPC5xxx 1 /* This is an MPC5xxx CPU */ -#define CONFIG_MPC5200 1 /* (more precisely an MPC5200 CPU) */ -#define CONFIG_TQM5200 1 /* ... on TQM5200 module */ -#undef CONFIG_TQM5200_REV100 /* define for revision 100 modules */ - -#define CONFIG_SYS_MPC5XXX_CLKIN 33000000 /* ... running at 33.000000MHz */ - -#define BOOTFLAG_COLD 0x01 /* Normal Power-On: Boot from FLASH */ -#define BOOTFLAG_WARM 0x02 /* Software reboot */ - -#define CONFIG_HIGH_BATS 1 /* High BATs supported */ - -/* - * Serial console configuration - */ -#define CONFIG_PSC_CONSOLE 1 /* console is on PSC1 */ -#define CONFIG_BAUDRATE 115200 /* ... at 115200 bps */ -#define CONFIG_SYS_BAUDRATE_TABLE { 9600, 19200, 38400, 57600, 115200, 230400 } - -/* Partitions */ -#define CONFIG_MAC_PARTITION -#define CONFIG_DOS_PARTITION -#define CONFIG_ISO_PARTITION - -/* POST support */ -#define CONFIG_POST (CONFIG_SYS_POST_MEMORY | \ - CONFIG_SYS_POST_CPU | \ - CONFIG_SYS_POST_I2C) - -#ifdef CONFIG_POST -/* preserve space for the post_word at end of on-chip SRAM */ -#define MPC5XXX_SRAM_POST_SIZE MPC5XXX_SRAM_SIZE-4 -#endif - - -/* - * BOOTP options - */ -#define CONFIG_BOOTP_BOOTFILESIZE -#define CONFIG_BOOTP_BOOTPATH -#define CONFIG_BOOTP_GATEWAY -#define CONFIG_BOOTP_HOSTNAME - - -/* - * Command line configuration. - */ -#include <config_cmd_default.h> -#define CONFIG_CMD_ASKENV -#define CONFIG_CMD_DATE -#define CONFIG_CMD_DHCP -#define CONFIG_CMD_ECHO -#define CONFIG_CMD_EEPROM -#define CONFIG_CMD_I2C -#define CONFIG_CMD_JFFS2 -#define CONFIG_CMD_MII -#define CONFIG_CMD_NFS -#define CONFIG_CMD_PING -#define CONFIG_CMD_REGINFO -#define CONFIG_CMD_SNTP - -#ifdef CONFIG_POST -#define CONFIG_CMD_DIAG -#endif - - -#define CONFIG_TIMESTAMP /* display image timestamps */ - -#if (TEXT_BASE == 0xFC000000) /* Boot low */ -# define CONFIG_SYS_LOWBOOT 1 -#endif - -/* - * Autobooting - */ -#define CONFIG_BOOTDELAY 5 /* autoboot after 5 seconds */ - -#define CONFIG_PREBOOT "echo;" \ - "echo Type \"run flash_nfs\" to mount root filesystem over NFS;" \ - "echo" - -#undef CONFIG_BOOTARGS - -#define CONFIG_EXTRA_ENV_SETTINGS \ - "netdev=eth0\0" \ - "rootpath=/opt/eldk/ppc_6xx\0" \ - "ramargs=setenv bootargs root=/dev/ram rw\0" \ - "nfsargs=setenv bootargs root=/dev/nfs rw " \ - "nfsroot=${serverip}:${rootpath}\0" \ - "addip=setenv bootargs ${bootargs} " \ - "ip=${ipaddr}:${serverip}:${gatewayip}:${netmask}" \ - ":${hostname}:${netdev}:off panic=1\0" \ - "flash_self=run ramargs addip;" \ - "bootm ${kernel_addr} ${ramdisk_addr}\0" \ - "flash_nfs=run nfsargs addip;" \ - "bootm ${kernel_addr}\0" \ - "net_nfs=tftp 200000 ${bootfile};run nfsargs addip;bootm\0" \ - "bootfile=/tftpboot/smmaco4/uImage\0" \ - "load=tftp 200000 ${u-boot}\0" \ - "u-boot=/tftpboot/smmaco4/u-boot.bin\0" \ - "update=protect off FC000000 FC05FFFF;" \ - "erase FC000000 FC05FFFF;" \ - "cp.b 200000 FC000000 ${filesize};" \ - "protect on FC000000 FC05FFFF\0" \ - "" - -#define CONFIG_BOOTCOMMAND "run net_nfs" - -/* - * IPB Bus clocking configuration. - */ -#define CONFIG_SYS_IPBCLK_EQUALS_XLBCLK /* define for 133MHz speed */ - -#if defined(CONFIG_SYS_IPBCLK_EQUALS_XLBCLK) -/* - * PCI Bus clocking configuration - * - * Actually a PCI Clock of 66 MHz is only set (in cpu_init.c) if - * CONFIG_SYS_IPBCLK_EQUALS_XLBCLK is defined. This is because a PCI Clock - * of 66 MHz yet hasn't been tested with a IPB Bus Clock of 66 MHz. - */ -#define CONFIG_SYS_PCICLK_EQUALS_IPBCLK_DIV2 /* define for 66MHz speed */ -#endif - -/* - * I2C configuration - */ -#define CONFIG_HARD_I2C 1 /* I2C with hardware support */ -#ifdef CONFIG_TQM5200_REV100 -#define CONFIG_SYS_I2C_MODULE 1 /* Select I2C module #1 for rev. 100 board */ -#else -#define CONFIG_SYS_I2C_MODULE 2 /* Select I2C module #2 for all other revs */ -#endif - -/* - * I2C clock frequency - * - * Please notice, that the resulting clock frequency could differ from the - * configured value. This is because the I2C clock is derived from system - * clock over a frequency divider with only a few divider values. U-boot - * calculates the best approximation for CONFIG_SYS_I2C_SPEED. However the calculated - * approximation allways lies below the configured value, never above. - */ -#define CONFIG_SYS_I2C_SPEED 100000 /* 100 kHz */ -#define CONFIG_SYS_I2C_SLAVE 0x7F - -/* - * EEPROM configuration for onboard EEPROM M24C32 (M24C64 should work - * also). For other EEPROMs configuration should be verified. On Mini-FAP the - * EEPROM (24C64) is on the same I2C address (but on other I2C bus), so the - * same configuration could be used. - */ -#define CONFIG_SYS_I2C_EEPROM_ADDR 0x50 /* 1010000x */ -#define CONFIG_SYS_I2C_EEPROM_ADDR_LEN 2 -#define CONFIG_SYS_EEPROM_PAGE_WRITE_BITS 5 /* =32 Bytes per write */ -#define CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS 20 - -/* - * Flash configuration - */ -#define CONFIG_SYS_FLASH_BASE TEXT_BASE /* 0xFC000000 */ - -/* use CFI flash driver if no module variant is spezified */ -#define CONFIG_SYS_FLASH_CFI 1 /* Flash is CFI conformant */ -#define CONFIG_FLASH_CFI_DRIVER 1 /* Use the common driver */ -#define CONFIG_SYS_FLASH_BANKS_LIST { CONFIG_SYS_BOOTCS_START } -#define CONFIG_SYS_FLASH_EMPTY_INFO -#define CONFIG_SYS_FLASH_SIZE 0x04000000 /* 64 MByte */ -#define CONFIG_SYS_MAX_FLASH_SECT 512 /* max num of sects on one chip */ -#undef CONFIG_SYS_FLASH_USE_BUFFER_WRITE /* not supported yet for AMD */ - -#if !defined(CONFIG_SYS_LOWBOOT) -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00760000 + 0x00800000) -#else /* CONFIG_SYS_LOWBOOT */ -#define CONFIG_ENV_ADDR (CONFIG_SYS_FLASH_BASE + 0x00060000) -#endif /* CONFIG_SYS_LOWBOOT */ -#define CONFIG_SYS_MAX_FLASH_BANKS 1 /* max num of flash banks - (= chip selects) */ -#define CONFIG_SYS_FLASH_ERASE_TOUT 240000 /* Flash Erase Timeout (in ms) */ -#define CONFIG_SYS_FLASH_WRITE_TOUT 500 /* Flash Write Timeout (in ms) */ - -/* Dynamic MTD partition support */ -#define CONFIG_CMD_MTDPARTS -#define CONFIG_MTD_DEVICE /* needed for mtdparts commands */ -#define CONFIG_FLASH_CFI_MTD -#define MTDIDS_DEFAULT "nor0=TQM5200-0" -#define MTDPARTS_DEFAULT "mtdparts=TQM5200-0:640k(firmware)," \ - "1408k(kernel)," \ - "2m(initrd)," \ - "4m(small-fs)," \ - "16m(big-fs)," \ - "8m(misc)" - -/* - * Environment settings - */ -#define CONFIG_ENV_IS_IN_FLASH 1 -#define CONFIG_ENV_SIZE 0x10000 -#define CONFIG_ENV_SECT_SIZE 0x20000 -#define CONFIG_ENV_ADDR_REDUND (CONFIG_ENV_ADDR + CONFIG_ENV_SECT_SIZE) -#define CONFIG_ENV_SIZE_REDUND (CONFIG_ENV_SIZE) - -/* - * Memory map - */ -#define CONFIG_SYS_MBAR 0xF0000000 -#define CONFIG_SYS_SDRAM_BASE 0x00000000 -#define CONFIG_SYS_DEFAULT_MBAR 0x80000000 - -/* Use ON-Chip SRAM until RAM will be available */ -#define CONFIG_SYS_INIT_RAM_ADDR MPC5XXX_SRAM -#ifdef CONFIG_POST -/* preserve space for the post_word at end of on-chip SRAM */ -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_POST_SIZE -#else -#define CONFIG_SYS_INIT_RAM_END MPC5XXX_SRAM_SIZE -#endif - - -#define CONFIG_SYS_GBL_DATA_SIZE 128 /* size in bytes reserved for initial data */ -#define CONFIG_SYS_GBL_DATA_OFFSET (CONFIG_SYS_INIT_RAM_END - CONFIG_SYS_GBL_DATA_SIZE) -#define CONFIG_SYS_INIT_SP_OFFSET CONFIG_SYS_GBL_DATA_OFFSET - -#define CONFIG_SYS_MONITOR_BASE TEXT_BASE -#if (CONFIG_SYS_MONITOR_BASE < CONFIG_SYS_FLASH_BASE) -# define CONFIG_SYS_RAMBOOT 1 -#endif - -#define CONFIG_SYS_MONITOR_LEN (384 << 10) /* Reserve 384 kB for Monitor */ -#define CONFIG_SYS_MALLOC_LEN (256 << 10) /* Reserve 256 kB for malloc() */ -#define CONFIG_SYS_BOOTMAPSZ (8 << 20) /* Initial Memory map for Linux */ - -/* - * Ethernet configuration - */ -#define CONFIG_MPC5xxx_FEC 1 -/* - * Define CONFIG_FEC_10MBIT to force FEC at 10Mb - */ -/* #define CONFIG_FEC_10MBIT 1 */ -#define CONFIG_PHY_ADDR 0x00 - -/* - * GPIO configuration - * - * use pin gpio_wkup_6 as second SDRAM chip select (mem_cs1): - * Bit 0 (mask: 0x80000000): 1 - * use ALT CAN position: Bits 2-3 (mask: 0x30000000): - * 00 -> No Alternatives, CAN1/2 on PSC2 according to PSC2 setting. - * 01 -> CAN1 on I2C1, CAN2 on Tmr0/1. - * Use for REV200 STK52XX boards. Do not use with REV100 modules - * (because, there I2C1 is used as I2C bus) - * use PSC1 as UART: Bits 28-31 (mask: 0x00000007): 0100 - * use PSC2 as CAN: Bits 25:27 (mask: 0x00000030) - * 000 -> All PSC2 pins are GIOPs - * 001 -> CAN1/2 on PSC2 pins - * Use for REV100 STK52xx boards - * use PSC6: - * on STK52xx: - * use as UART. Pins PSC6_0 to PSC6_3 are used. - * Bits 9:11 (mask: 0x00700000): - * 101 -> PSC6 : Extended POST test is not available - * on MINI-FAP and TQM5200_IB: - * use PSC6_0 to PSC6_3 as GPIO: Bits 9:11 (mask: 0x00700000): - * 000 -> PSC6 could not be used as UART, CODEC or IrDA - * GPIO on PSC6_3 is used in post_hotkeys_pressed() to enable extended POST - * tests. - */ -#if defined (CONFIG_MINIFAP) -# define CONFIG_SYS_GPS_PORT_CONFIG 0x91000004 -#elif defined (CONFIG_STK52XX) -# if defined (CONFIG_STK52XX_REV100) -# define CONFIG_SYS_GPS_PORT_CONFIG 0x81500014 -# else /* STK52xx REV200 and above */ -# if defined (CONFIG_TQM5200_REV100) -# error TQM5200 REV100 not supported on STK52XX REV200 or above -# else/* TQM5200 REV200 and above */ -# define CONFIG_SYS_GPS_PORT_CONFIG 0x91500004 -# endif -# endif -#else /* TMQ5200 Inbetriebnahme-Board */ -# define CONFIG_SYS_GPS_PORT_CONFIG 0x81000004 -#endif - -/* - * RTC configuration - */ -#define CONFIG_RTC_MPC5200 1 /* use internal MPC5200 RTC */ - -/* - * Miscellaneous configurable options - */ -#define CONFIG_SYS_LONGHELP /* undef to save memory */ -#define CONFIG_SYS_PROMPT "=> " /* Monitor Command Prompt */ -#if defined(CONFIG_CMD_KGDB) -#define CONFIG_SYS_CBSIZE 1024 /* Console I/O Buffer Size */ -#else -#define CONFIG_SYS_CBSIZE 256 /* Console I/O Buffer Size */ -#endif -#define CONFIG_SYS_PBSIZE (CONFIG_SYS_CBSIZE+sizeof(CONFIG_SYS_PROMPT)+16) /* Print Buffer Size */ -#define CONFIG_SYS_MAXARGS 16 /* max number of command args */ -#define CONFIG_SYS_BARGSIZE CONFIG_SYS_CBSIZE /* Boot Argument Buffer Size */ - -/* Enable an alternate, more extensive memory test */ -#define CONFIG_SYS_ALT_MEMTEST - -#define CONFIG_SYS_MEMTEST_START 0x00100000 /* memtest works on */ -#define CONFIG_SYS_MEMTEST_END 0x00f00000 /* 1 ... 15 MB in DRAM */ - -#define CONFIG_SYS_LOAD_ADDR 0x100000 /* default load address */ - -#define CONFIG_SYS_HZ 1000 /* decrementer freq: 1 ms ticks */ - -#define CONFIG_SYS_CACHELINE_SIZE 32 /* For MPC5xxx CPUs */ -#if defined(CONFIG_CMD_KGDB) -# define CONFIG_SYS_CACHELINE_SHIFT 5 /* log base 2 of the above value */ -#endif - -/* - * Enable loopw command. - */ -#define CONFIG_LOOPW - -/* - * Various low-level settings - */ -#define CONFIG_SYS_HID0_INIT HID0_ICE | HID0_ICFI -#define CONFIG_SYS_HID0_FINAL HID0_ICE - -#define CONFIG_SYS_BOOTCS_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_BOOTCS_SIZE CONFIG_SYS_FLASH_SIZE -#ifdef CONFIG_SYS_PCICLK_EQUALS_IPBCLK_DIV2 -#define CONFIG_SYS_BOOTCS_CFG 0x0008DF30 /* for pci_clk = 66 MHz */ -#else -#define CONFIG_SYS_BOOTCS_CFG 0x0004DF30 /* for pci_clk = 33 MHz */ -#endif -#define CONFIG_SYS_CS0_START CONFIG_SYS_FLASH_BASE -#define CONFIG_SYS_CS0_SIZE CONFIG_SYS_FLASH_SIZE - -#define CONFIG_SYS_CS_BURST 0x00000000 -#define CONFIG_SYS_CS_DEADCYCLE 0x33333311 /* 1 dead cycle for flash and SM501 */ - -#define CONFIG_SYS_RESET_ADDRESS 0xff000000 - -#endif /* __CONFIG_H */
Recent changes caused that the spieval board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time:
mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized. mpc5xxx_fec.c:899:2: error: #error fec->xcv_type not initialized.
Signed-off-by: Wolfgang Denk wd@denx.de --- boards.cfg | 1 - 1 files changed, 0 insertions(+), 1 deletions(-)
diff --git a/boards.cfg b/boards.cfg index 0ca4ce1..0fe1c89 100644 --- a/boards.cfg +++ b/boards.cfg @@ -104,7 +104,6 @@ uc101 powerpc mpc5xxx v38b powerpc mpc5xxx pf5200 powerpc mpc5xxx - esd aev powerpc mpc5xxx tqm5200 tqc -spieval powerpc mpc5xxx tqm5200 tqc sorcery powerpc mpc8220 A3000 powerpc mpc824x a3000 barco powerpc mpc824x
