[U-Boot] [for v2018.07 1/2] sunxi: Fix USB PHY index for H3 (missed chage)
This patch update the USB PHY index for Allwinner H3.
Same change[1] initially sent, by 'Chen-Yu Tai' but missed to apply due to recursive version changes on the same series.
[1] https://lists.denx.de/pipermail/u-boot/2018-January/318817.html
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- arch/arm/include/asm/arch-sunxi/clock_sun6i.h | 10 +++++++--- 1 file changed, 7 insertions(+), 3 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h index 8afeaf872e..3a59016955 100644 --- a/arch/arm/include/asm/arch-sunxi/clock_sun6i.h +++ b/arch/arm/include/asm/arch-sunxi/clock_sun6i.h @@ -275,9 +275,13 @@ struct sunxi_ccm_reg { * These are EHCI1 - EHCI3 in the datasheet (EHCI0 is for the OTG) we call * them 0 - 2 like they were called on older SoCs. */ +#define AHB_GATE_OFFSET_USB_OHCI3 31 +#define AHB_GATE_OFFSET_USB_OHCI2 30 +#define AHB_GATE_OFFSET_USB_OHCI1 29 #define AHB_GATE_OFFSET_USB_OHCI0 28 -#define AHB_GATE_OFFSET_USB_EHCI2 27 -#define AHB_GATE_OFFSET_USB_EHCI1 26 +#define AHB_GATE_OFFSET_USB_EHCI3 27 +#define AHB_GATE_OFFSET_USB_EHCI2 26 +#define AHB_GATE_OFFSET_USB_EHCI1 25 #define AHB_GATE_OFFSET_USB_EHCI0 24 #elif defined(CONFIG_MACH_SUN50I) #define AHB_GATE_OFFSET_USB_OHCI0 28 @@ -290,7 +294,7 @@ struct sunxi_ccm_reg { #define AHB_GATE_OFFSET_USB_EHCI1 27 #define AHB_GATE_OFFSET_USB_EHCI0 26 #endif -#ifdef CONFIG_MACH_SUN50I +#if defined(CONFIG_MACH_SUN50I) || defined(CONFIG_MACH_SUNXI_H3_H5) #define AHB_GATE_OFFSET_USB0 23 #elif !defined(CONFIG_MACH_SUN8I_R40) #define AHB_GATE_OFFSET_USB0 24
Masking clock gate, reset register bits based on the probed controller is proper only due to the assumption that masking should start with 0 even thought the controller has separate PHY or shared between OTG.
unfortunately these are fixed due to lack of separate clock, reset drivers.
Say for example EHCI1 - EHCI3 in the datasheet (EHCI0 is for the OTG) so we need to start reg_mask 0 - 2.
This patch calculated the mask, based on the register base so that we can get the proper bits to set with respect to probed controller.
We even do this masking by using PHY index specifier from dt, but dev_read_addr_size is failing for 64-bit boards.
Signed-off-by: Jagan Teki jagan@amarulasolutions.com --- Note: This is another version[1] via dt pharsing, but dev_read_addr_size failed in 64-bit boards. [1] https://paste.ubuntu.com/p/YRtJT4kzc3/
arch/arm/include/asm/arch-sunxi/cpu_sun4i.h | 9 +++++---- drivers/usb/host/ehci-sunxi.c | 8 ++++++-- drivers/usb/host/ohci-sunxi.c | 10 +++++++--- 3 files changed, 18 insertions(+), 9 deletions(-)
diff --git a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h index ee648366c7..02ce73954d 100644 --- a/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h +++ b/arch/arm/include/asm/arch-sunxi/cpu_sun4i.h @@ -63,10 +63,11 @@ #ifdef CONFIG_SUNXI_GEN_SUN6I #if defined(CONFIG_MACH_SUNXI_H3_H5) || defined(CONFIG_MACH_SUN50I) #define SUNXI_USBPHY_BASE 0x01c19000 -#define SUNXI_USB0_BASE 0x01c1a000 -#define SUNXI_USB1_BASE 0x01c1b000 -#define SUNXI_USB2_BASE 0x01c1c000 -#define SUNXI_USB3_BASE 0x01c1d000 +#define SUNXI_USB0_BASE SUNXI_USBPHY_BASE +#define SUNXI_USB1_BASE 0x01c1a000 +#define SUNXI_USB2_BASE 0x01c1b000 +#define SUNXI_USB3_BASE 0x01c1c000 +#define SUNXI_USB4_BASE 0x01c1d000 #else #define SUNXI_USB0_BASE 0x01c19000 #define SUNXI_USB1_BASE 0x01c1a000 diff --git a/drivers/usb/host/ehci-sunxi.c b/drivers/usb/host/ehci-sunxi.c index 97d06d5975..7a79931a97 100644 --- a/drivers/usb/host/ehci-sunxi.c +++ b/drivers/usb/host/ehci-sunxi.c @@ -17,8 +17,10 @@ #include <generic-phy.h>
#ifdef CONFIG_SUNXI_GEN_SUN4I +#define BASE_DIST 0x8000 #define AHB_CLK_DIST 2 #else +#define BASE_DIST 0x1000 #define AHB_CLK_DIST 1 #endif
@@ -47,6 +49,7 @@ static int ehci_usb_probe(struct udevice *dev) struct ehci_hccr *hccr = (struct ehci_hccr *)devfdt_get_addr(dev); struct ehci_hcor *hcor; int extra_ahb_gate_mask = 0; + u8 reg_mask = 0; int phys, ret;
priv->cfg = (const struct ehci_sunxi_cfg *)dev_get_driver_data(dev); @@ -86,10 +89,11 @@ no_phy: * This should go away once we've moved to the driver model for * clocks resp. phys. */ + reg_mask = ((uintptr_t)hccr - SUNXI_USB1_BASE) / BASE_DIST; priv->ahb_gate_mask = 1 << AHB_GATE_OFFSET_USB_EHCI0; extra_ahb_gate_mask = priv->cfg->extra_ahb_gate_mask; - priv->ahb_gate_mask <<= phys * AHB_CLK_DIST; - extra_ahb_gate_mask <<= phys * AHB_CLK_DIST; + priv->ahb_gate_mask <<= reg_mask * AHB_CLK_DIST; + extra_ahb_gate_mask <<= reg_mask * AHB_CLK_DIST;
setbits_le32(&priv->ccm->ahb_gate0, priv->ahb_gate_mask | extra_ahb_gate_mask); diff --git a/drivers/usb/host/ohci-sunxi.c b/drivers/usb/host/ohci-sunxi.c index db6f438275..0ddbdbe460 100644 --- a/drivers/usb/host/ohci-sunxi.c +++ b/drivers/usb/host/ohci-sunxi.c @@ -17,8 +17,10 @@ #include <generic-phy.h>
@@ -48,6 +50,7 @@ static int ohci_usb_probe(struct udevice *dev) struct ohci_sunxi_priv *priv = dev_get_priv(dev); struct ohci_regs *regs = (struct ohci_regs *)devfdt_get_addr(dev); int extra_ahb_gate_mask = 0; + u8 reg_mask = 0; int phys, ret;
priv->cfg = (const struct ohci_sunxi_cfg *)dev_get_driver_data(dev); @@ -89,12 +92,13 @@ no_phy: * This should go away once we've moved to the driver model for * clocks resp. phys. */ + reg_mask = ((uintptr_t)regs - (SUNXI_USB1_BASE + 0x400)) / BASE_DIST; priv->ahb_gate_mask = 1 << AHB_GATE_OFFSET_USB_OHCI0; extra_ahb_gate_mask = priv->cfg->extra_ahb_gate_mask; priv->usb_gate_mask = CCM_USB_CTRL_OHCI0_CLK; - priv->ahb_gate_mask <<= phys * AHB_CLK_DIST; - extra_ahb_gate_mask <<= phys * AHB_CLK_DIST; - priv->usb_gate_mask <<= phys; + priv->ahb_gate_mask <<= reg_mask * AHB_CLK_DIST; + extra_ahb_gate_mask <<= reg_mask * AHB_CLK_DIST; + priv->usb_gate_mask <<= reg_mask;
On Thu, Jun 28, 2018 at 07:40:46PM +0530, Jagan Teki wrote:
Masking clock gate, reset register bits based on the probed controller is proper only due to the assumption [...]
With this patch, both USB ports work correctly on Cubieboard (A10) and pcDuino3 Nano (A20). Thanks for the quick fix!
Tested-by: Adam Sampson ats@offog.org
Applied both
Adam Sampson
Jagan Teki
