[U-Boot] Please pull u-.boot-marvell/master
Hi Tom,
please pull the first batch of Marvell related patches.
Thanks, Stefan
The following changes since commit 81cf7c8d45935a295991fe2cd1df286f0f47511f:
Merge git://git.denx.de/u-boot-ubi (2018-03-25 12:02:13 -0400)
git://www.denx.de/git/u-boot-marvell.git
for you to fetch changes up to 25db371e17d64c7a50f0f75e77a675651e5a2d4c:
arm64: a37xx: defconfigs: enable PCI_CMD and E1000 driver (2018-03-30 12:52:49 +0200)
---------------------------------------------------------------- Alexander Graf (1): kwbimage: Fix out of bounds access
Baruch Siach (1): configs: clearfog: enable random random MAC address
Igal Liberman (1): dm: pcie: designware: add correct ATU handling
Ken Ma (14): arm64: a37xx: dts: add gpio head file including arm64: a37xx: defconfig: Enable PINCTRL and GPIO support for ESPRESSOBin board arm64: a37xx: dts: Add pinctrl configuration for ESPRESSOBin board arm64: a37xx: dts: Add additional pinctrl definition arm64: a37xx: pinctrl: Fix number of pin in south bridge arm64: a37xx: dts: Fix the number of GPIO on south bridge arm64: a37xx: pinctrl: Fix the pin 23 on south bridge arm64: a37xx: pinctrl: Fix gpio pin offset in register arm64: a37xx: pinctrl: Correct mpp definitions arm64: a37xx: dts: Correct mpp definitions doc: a37xx: Introduce pinctrl device tree binding Revert "arm64: a37xx: dts: Add pin control nodes to DT" arm64: a37xx: remove old pinctrl implementation arm64: a37xx: defconfigs: enable PCI_CMD and E1000 driver
Mark Kettenis (1): arm64: mvebu: a8k: Add distro boot support
Wilson Ding (4): arm64: a37xx: populate pcie memory region arm64: a37xx: pci: add support for aardvark pcie driver arm64: a37xx: defconfigs: enable aardvark pcie driver arm64: a37xx: dts: enable pcie port
arch/arm/dts/armada-3720-db.dts | 14 +- arch/arm/dts/armada-3720-espressobin.dts | 15 + arch/arm/dts/armada-37xx.dtsi | 52 +- arch/arm/mach-mvebu/armada3700/cpu.c | 8 + board/Marvell/mvebu_armada-37xx/board.c | 23 - configs/clearfog_defconfig | 1 + configs/mvebu_db-88f3720_defconfig | 5 + configs/mvebu_espressobin-88f3720_defconfig | 9 + .../pinctrl/marvell,armada-37xx-pinctrl.txt | 186 ++++++ drivers/pci/Kconfig | 10 + drivers/pci/Makefile | 1 + drivers/pci/pci-aardvark.c | 690 +++++++++++++++++++++ drivers/pci/pcie_dw_mvebu.c | 91 ++- drivers/pinctrl/mvebu/pinctrl-armada-37xx.c | 52 +- include/configs/mvebu_armada-8k.h | 19 + tools/kwbimage.c | 4 + 16 files changed, 1088 insertions(+), 92 deletions(-) create mode 100644 doc/device-tree-bindings/pinctrl/marvell,armada-37xx-pinctrl.txt create mode 100644 drivers/pci/pci-aardvark.c
On Fri, Mar 30, 2018 at 04:17:31PM +0200, Stefan Roese wrote:
Hi Tom,
Thanks, Stefan
Stefan Roese
