[PATCH] arm: mach-k3: Remove ROM firewalls on GP devices
This isn't strictly needed as these firewalls should all be disabled on GP, but it also doesn't hurt, so do this unconditionally to remove this use of CONFIG_TI_SECURE_DEVICE.
Signed-off-by: Andrew Davis afd@ti.com --- arch/arm/mach-k3/am6_init.c | 4 ---- arch/arm/mach-k3/j721e_init.c | 4 ---- 2 files changed, 8 deletions(-)
diff --git a/arch/arm/mach-k3/am6_init.c b/arch/arm/mach-k3/am6_init.c index 7992918adc..ded034140f 100644 --- a/arch/arm/mach-k3/am6_init.c +++ b/arch/arm/mach-k3/am6_init.c @@ -28,7 +28,6 @@ DECLARE_GLOBAL_DATA_PTR;
#ifdef CONFIG_SPL_BUILD #ifdef CONFIG_K3_LOAD_SYSFW -#ifdef CONFIG_TI_SECURE_DEVICE struct fwl_data main_cbass_fwls[] = { { "MMCSD1_CFG", 2057, 1 }, { "MMCSD0_CFG", 2058, 1 }, @@ -45,7 +44,6 @@ struct fwl_data main_cbass_fwls[] = { { "MCU_CPSW0", 1220, 1 }, }; #endif -#endif
static void ctrl_mmr_unlock(void) { @@ -238,10 +236,8 @@ void board_init_f(ulong dummy) preloader_console_init();
/* Disable ROM configured firewalls right after loading sysfw */ -#ifdef CONFIG_TI_SECURE_DEVICE remove_fwl_configs(main_cbass_fwls, ARRAY_SIZE(main_cbass_fwls)); remove_fwl_configs(mcu_cbass_fwls, ARRAY_SIZE(mcu_cbass_fwls)); -#endif #else /* Prepare console output */ preloader_console_init(); diff --git a/arch/arm/mach-k3/j721e_init.c b/arch/arm/mach-k3/j721e_init.c index e56ca6d0f5..2000e8e29c 100644 --- a/arch/arm/mach-k3/j721e_init.c +++ b/arch/arm/mach-k3/j721e_init.c @@ -26,7 +26,6 @@
#ifdef CONFIG_SPL_BUILD #ifdef CONFIG_K3_LOAD_SYSFW -#ifdef CONFIG_TI_SECURE_DEVICE struct fwl_data cbass_hc_cfg0_fwls[] = { { "PCIE0_CFG", 2560, 8 }, { "PCIE1_CFG", 2561, 8 }, @@ -64,7 +63,6 @@ struct fwl_data cbass_hc_cfg0_fwls[] = { { "WKUP_CTRL_MMR0", 131, 16 }, }; #endif -#endif
static void ctrl_mmr_unlock(void) { @@ -255,7 +253,6 @@ void board_init_f(ulong dummy) preloader_console_init();
/* Disable ROM configured firewalls right after loading sysfw */ -#ifdef CONFIG_TI_SECURE_DEVICE remove_fwl_configs(cbass_hc_cfg0_fwls, ARRAY_SIZE(cbass_hc_cfg0_fwls)); remove_fwl_configs(cbass_hc0_fwls, ARRAY_SIZE(cbass_hc0_fwls)); remove_fwl_configs(cbass_rc_cfg0_fwls, ARRAY_SIZE(cbass_rc_cfg0_fwls)); @@ -263,7 +260,6 @@ void board_init_f(ulong dummy) remove_fwl_configs(infra_cbass0_fwls, ARRAY_SIZE(infra_cbass0_fwls)); remove_fwl_configs(mcu_cbass0_fwls, ARRAY_SIZE(mcu_cbass0_fwls)); remove_fwl_configs(wkup_cbass0_fwls, ARRAY_SIZE(wkup_cbass0_fwls)); -#endif #else /* Prepare console output */ preloader_console_init();
Signed-off-by: Andrew Davis afd@ti.com Reviewed-by: Tom Rini trini@konsulko.com
Andrew Davis
