[RESEND PATCH] bootstd: sata: bootdev scanning for ahci sata with no drive attached
It's normal to have no SATA drive attached to the controller, so return a successful status when there is no block device found after probing.
Note: this patch depends on the previous patch https://patchwork.ozlabs.org/project/uboot/patch/20230917230649.30357-1-mibo...
Resend the right patch.
Signed-off-by: Tony Dinh mibodhi@gmail.com ---
drivers/ata/sata.c | 6 ++++++ 1 file changed, 6 insertions(+)
diff --git a/drivers/ata/sata.c b/drivers/ata/sata.c index f126b84e05..dcb5fcf476 100644 --- a/drivers/ata/sata.c +++ b/drivers/ata/sata.c @@ -79,6 +79,12 @@ int sata_rescan(bool verbose)
ret = uclass_probe_all(UCLASS_AHCI);
+ if (ret == -ENODEV) { + if (verbose) + printf("No SATA block device found\n"); + return 0; + } + return ret; }
Thanks, Stefan
- if (ret == -ENODEV) {
if (verbose)
- return ret; }
Viele Grüße, Stefan Roese
Stefan Roese
Tony Dinh
