[PATCH v2] misc: i2c_eeprom: implement different probe test eeprom offset
Because of this commit : 5ae84860b0 ("misc: i2c_eeprom: verify that the chip is functional at probe()") at probe time, each eeprom is tested for read at offset 0.
The Atmel AT24MAC402 eeprom has different mapping. One i2c slave address is used for the lower 0x80 bytes and another i2c slave address is used for the upper 0x80 bytes. Because of this basically the i2c master sees 2 different slaves. We need the upper bytes because we read the unique MAC address from this EEPROM area.
However this implies that our slave address will return error on reads from address 0x0 to 0x80.
To solve this, implemented an offset field inside platform data that is by default 0 (as it is used now), but can be changed in the compatible table.
The probe function will now read at this offset and use it, instead of blindly checking offset 0.
This will fix the regression noticed on these EEPROMs since the commit abovementioned that introduces the probe failed issue.
Signed-off-by: Eugen Hristev eugen.hristev@microchip.com ---
Please disregard patch [PATCH] misc: i2c_eeprom: implement different probe test eeprom offset
as that patch was mistakenly done on an older u-boot version. This v2 patch applies correctly on u-boot/master
Changes in v2: - adapt to latest changes in driver. v1 was done on u-boot 2020.01 accidentaly.
drivers/misc/i2c_eeprom.c | 8 +++++++- 1 file changed, 7 insertions(+), 1 deletion(-)
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index ef5f103c98..32a1b20856 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -17,6 +17,7 @@ struct i2c_eeprom_drv_data { u32 pagesize; /* page size in bytes */ u32 addr_offset_mask; /* bits in addr used for offset overflow */ u32 offset_len; /* size in bytes of offset */ + u32 start_offset; /* valid start offset inside memory, by default 0 */ };
int i2c_eeprom_read(struct udevice *dev, int offset, uint8_t *buf, int size) @@ -147,7 +148,11 @@ static int i2c_eeprom_std_probe(struct udevice *dev) i2c_set_chip_addr_offset_mask(dev, data->addr_offset_mask);
/* Verify that the chip is functional */ - ret = i2c_eeprom_read(dev, 0, &test_byte, 1); + /* + * Not all eeproms start from offset 0. Valid offset is available + * in the platform data struct. + */ + ret = i2c_eeprom_read(dev, data->start_offset, &test_byte, 1); if (ret) return -ENODEV;
@@ -215,6 +220,7 @@ static const struct i2c_eeprom_drv_data atmel24mac402_data = { .pagesize = 16, .addr_offset_mask = 0, .offset_len = 1, + .start_offset = 0x80, };
static const struct i2c_eeprom_drv_data atmel24c32_data = {
Hello Eugen,
Am 07.05.2020 um 10:53 schrieb Eugen Hristev:
Changes in v2:
Thanks for rebasing!
I prefer to fix the issue instead reverting commit:
Reviewed-by: Heiko Schocher hs@denx.de
@Baruch, is this Ok for you?
bye, Heiko
- ret = i2c_eeprom_read(dev, data->start_offset, &test_byte, 1); if (ret) return -ENODEV;
Hi Heiko,
Changes in v2:
According to the Linux driver there are more devices that need read offset. 24cs32 and 24cs64 are affected. This patch does not fix the regression for those devices.
Eugen, would it be possible for you to extend the fix to 24cs32/64 and test on real hardware?
baruch
- u32 start_offset; /* valid start offset inside memory, by default 0 */ }; int i2c_eeprom_read(struct udevice *dev, int offset, uint8_t *buf, int
size) @@ -147,7 +148,11 @@ static int i2c_eeprom_std_probe(struct udevice *dev) i2c_set_chip_addr_offset_mask(dev, data->addr_offset_mask); /* Verify that the chip is functional */
- ret = i2c_eeprom_read(dev, data->start_offset, &test_byte, 1); if (ret) return -ENODEV; @@ -215,6 +220,7 @@ static const struct i2c_eeprom_drv_data
- .start_offset = 0x80, }; static const struct i2c_eeprom_drv_data atmel24c32_data = {
On 07.05.2020 18:02, Baruch Siach wrote:
Hi Heiko,
Changes in v2:
Hi Baruch,
This patch fixes my issue at hand and the eeprom which I have at my disposal. I will look to see if I have those, but, most likely not. I can extend the fix, but I cannot test, so, I rather not go blind with it.
Eugen
baruch
-- ~. .~ Tk Open Systems =}------------------------------------------------ooO--U--Ooo------------{= - baruch@tkos.co.il - tel: +972.52.368.4656, http://www.tkos.co.il -
Hello Eugen,
Am 07.05.2020 um 17:08 schrieb Eugen.Hristev@microchip.com:
Hi Heiko,
Changes in v2:
Hi Baruch,
Any news here?
Thanks!
bye, HEiko
Eugen
baruch
On 28.05.2020 06:59, Heiko Schocher wrote:
Hello Eugen,
Hi Heiko,
Changes in v2:
accidentaly.
Hi Baruch,
Any news here?
Hello Heiko,
I do not have any other memory in the compatible list at my disposal right now. I assumed that you would take this patch as-is. If I hit the issue on another memory, I will send another patch. Right now with the lockdown this is the only memory I have.
Eugen
Thanks!
bye, HEiko
Eugen
baruch
diff --git a/drivers/misc/i2c_eeprom.c b/drivers/misc/i2c_eeprom.c index ef5f103c98..32a1b20856 100644 --- a/drivers/misc/i2c_eeprom.c +++ b/drivers/misc/i2c_eeprom.c @@ -17,6 +17,7 @@ struct i2c_eeprom_drv_data { u32 pagesize; /* page size in bytes */ u32 addr_offset_mask; /* bits in addr used for offset overflow */ u32 offset_len; /* size in bytes of offset */ + u32 start_offset; /* valid start offset inside memory, by default 0 */ }; int i2c_eeprom_read(struct udevice *dev, int offset, uint8_t *buf, int size) @@ -147,7 +148,11 @@ static int i2c_eeprom_std_probe(struct udevice *dev) i2c_set_chip_addr_offset_mask(dev, data->addr_offset_mask); /* Verify that the chip is functional */ - ret = i2c_eeprom_read(dev, 0, &test_byte, 1); + /* + * Not all eeproms start from offset 0. Valid offset is available + * in the platform data struct. + */ + ret = i2c_eeprom_read(dev, data->start_offset, &test_byte, 1); if (ret) return -ENODEV; @@ -215,6 +220,7 @@ static const struct i2c_eeprom_drv_data atmel24mac402_data = { .pagesize = 16, .addr_offset_mask = 0, .offset_len = 1, + .start_offset = 0x80, }; static const struct i2c_eeprom_drv_data atmel24c32_data = {
-- DENX Software Engineering GmbH, Managing Director: Wolfgang Denk HRB 165235 Munich, Office: Kirchenstr.5, D-82194 Groebenzell, Germany Phone: +49-8142-66989-52 Fax: +49-8142-66989-80 Email: hs@denx.de
Hello Eugen,
Changes in v2:
Applied to u-boot-i2c master
Thanks!
May we should rethink and look at what linux do, but as it fixes a bug it is ok for me.
bye, Heiko
Baruch Siach
Eugen Hristev
Heiko Schocher
