[U-Boot] arm: sunxi: Bananapi_M2_Ultra not working with DM_MMC
A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I found that it wasn't booting, 2019.01 was working ok. Bisecting indicated that the problem was after http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef...
Here's what I see when booting:
U-Boot SPL 2019.04-rc4 (Apr 02 2019 - 16:17:43 +0000) DRAM: 2048 MiB Trying to boot from MMC1
U-Boot 2019.04-rc4 (Apr 02 2019 - 16:17:43 +0000) Allwinner Technology
CPU: Allwinner R40 (SUN8I 1701) Model: Banana Pi BPI-M2-Ultra I2C: ready DRAM: 2 GiB MMC: Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... ** No valid partitions found ** In: serial@1c28000 Out: serial@1c28000 Err: serial@1c28000 SCSI: Target spinup took 0 ms. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net: phy interface7 eth0: ethernet@1c50000 starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... switch to partitions #0, OK mmc1(part 0) is current device ** Invalid partition 1 ** scanning bus for devices... data abort pc : [<bff9c6da>] lr : [<bff98991>] reloc pc : [<4a01a6da>] lr : [<4a016991>] sp : bbf5d620 ip : 0000001c fp : 000000c0 r10: 00000000 r9 : bbf61ed8 r8 : 00000000 r7 : bbf5d8a0 r6 : bffdbff0 r5 : bffdbff0 r4 : bffdbff0 r3 : 00000000 r2 : 00000000 r1 : ea000016 r0 : bffdbff0 Flags: nZcv IRQs off FIQs off Mode SVC_32 Code: e92dbd10 f8d045f0 b0858080 1000f8d8 (f8d14604) Resetting CPU ...
resetting ...
Any pointers on what to text next?
Thanks. Pablo.
I think the patch should be reverted ASAP since it obviously breaks some supported configs. Sadly, the offending commit doesn't say anything about the test coverage for the change and what the status is after it. There is probably a reason why it was enabled for sun4i only before and there must have been a motivation for doing this on all sunxi platforms, but then again, the commit message says nothing about those underlying reasons.
I believe we should be more strict on patch review and not let any change bringing such a major change get applied with a commit message that provides no context about why the change is okay and how it was tested.
Cheers,
Paul
resetting ...
Thanks. Pablo.
Hi Paul,
On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
Appropriate your concern.
If you please list what all boards are not working with this effect, please write back. we will defiantly look into it. All these changes were merged in MW which is 2.5 months back, commenting in final stage like this is not the professional way.
Jagan.
Le lundi 08 avril 2019 à 18:23 +0530, Jagan Teki a écrit :
Hi Paul,
I really do not think this is a sane approach to follow. You can't make a change like this, with no context whatsoever in the commit message, which ends up breaking other people's setups and wait for others to debug subsequent issues it introduces that you don't encounter.
Sorry but your commit should never have been merged. Sure, I wasn't there to review it either, but the code review process definitely did not go as planned here.
The commit you made was not appropriate when you submitted it, it turns out it broke something and it should be fixed. As for professionalism, are you actually suggesting that we void fixing your commit as a courtesy because it went through patch review already? That makes no sense to me.
Clearly, your work was the issue here so please don't try and dodge the bullet. I already had the occasion to tell you that your commit messages are not appropriate when reviewing other patches and this is a clear result of what happens when a patch skips through patch review and nobody pushed you to produce a proper commit message. It would be great if you could take this as a clear example why this is a problem.
Cheers,
Paul
On Mon, Apr 8, 2019 at 6:40 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
Hi Paul,
Which commit message your referring to? are you referring this patch[1] commit message. let me point what exactly is the issue?
[1] http://git.denx.de/?p=u-boot.git;a=commit;h=a7cca5793774ee139b75a704d6efaa4d...
Hi Paul,
Yes, that message right there does not say what boards nor SoCs you tested the conversion on, and is not a great commit message for such a large scale change.
Hi Paul,
Let me explains what I though when I prepare the patch.
This patch is the last patch of the series, that means all the preceding patches are supporting DM_MMC on respective or missing SoC's and boards[2]. as a final patch I enable DM_MMC for Allwinner globally.
commit message: " arm: sunxi: Enable DM_MMC
Enable DM_MMC for all Allwinner SoCs, this will eventually enable BLK. "
the commit head says it enable DM_MMC all the SoC's in Allwinner globally. Since the series is part of DM_MMC migration and previous commits has enough information of what boards its's been tested. Do we need to mentioned all the tested board information in this commit message?
[2] http://git.denx.de/?p=u-boot.git;a=log;h=a7cca5793774ee139b75a704d6efaa4d29f...
Hi Paul,
Yes, this is the patch I'm talking about.
The issue with it is that the commit message is totally redundant: the description does not say more than what the diff does.
A git commit description should provide context about what the change does above the modified lines: what problem it tries to resolve and how , on what hardware, how it was tested, etc. Especially for a commit making such a big change, the commit message must have all this information.
Do you see why I think it's a problem?
Cheers,
Paul
On Mon, Apr 8, 2019 at 7:06 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
Hi Paul,
I can't agree if we consider the series of changes in one set. As I mentioned in another mail, this patch is last from the DM_MMC migration series and as the last one it enable the DM_MMC global to Allwinner (not respective to board). The previous patches are trying to support and fix DM_MMC on respective SoC's and board. ie the reason I didn't mention any thing related to board or any other information since It is global SoC change.
Hi Paul,
On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > found that it wasn't booting, 2019.01 was working ok. > Bisecting indicated that the problem was after > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef...
I don't think this is relevant. You can't expect people to go through the list archive, find which series this commit was attached to, etc. Especially when running a bisect, where you'll end up with a single offending commit.
You need to make sure that each commit message provides context about what it's doing, and not just rephrase the diff.
In order words, it's *never* okay to just re-work the diff, you *always* need to describe the context. That's not something optional to only do on special occasions.
Cheers,
Paul
On Mon, Apr 8, 2019 at 7:31 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote:
Hi Paul,
On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote: > Hi, > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > > found that it wasn't booting, 2019.01 was working ok. > > Bisecting indicated that the problem was after > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... > > I think the patch should be reverted ASAP since it obviously breaks > some supported configs. Sadly, the offending commit doesn't say > anything about the test coverage for the change and what the status is > after it. There is probably a reason why it was enabled for sun4i only > before and there must have been a motivation for doing this on all > sunxi platforms, but then again, the commit message says nothing about > those underlying reasons. > > I believe we should be more strict on patch review and not let any > change bringing such a major change get applied with a commit message > that provides no context about why the change is okay and how it was > tested.
Do you still think this message shows the diff? The change is as simple as enable DM_MMC for Allwinner and doesn't make any direct changes to underlying boards on the same change.
"Enable DM_MMC for all Allwinner SoCs, this will eventually enable BLK."
Mentioning again, I don't see any point to mention board information for this commit since the diff or change clearly focusing on global Allwinner platform enablement for DM_MMC and the same mentioned in the body.
Le lundi 08 avril 2019 à 18:23 +0530, Jagan Teki a écrit : > Hi Paul, > > On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski > paul.kocialkowski@bootlin.com wrote: > > Hi, > > > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > > > found that it wasn't booting, 2019.01 was working ok. > > > Bisecting indicated that the problem was after > > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... > > > > I think the patch should be reverted ASAP since it obviously breaks > > some supported configs. Sadly, the offending commit doesn't say > > anything about the test coverage for the change and what the status is > > after it. There is probably a reason why it was enabled for sun4i only > > before and there must have been a motivation for doing this on all > > sunxi platforms, but then again, the commit message says nothing about > > those underlying reasons. > > > > I believe we should be more strict on patch review and not let any > > change bringing such a major change get applied with a commit message > > that provides no context about why the change is okay and how it was > > tested. > > Appropriate your concern. > > If you please list what all boards are not working with this effect, > please write back. we will defiantly look into it. All these changes > were merged in MW which is 2.5 months back, commenting in final stage > like this is not the professional way.
Of course! Enabling DM_MMC is a major change to Allwinner MMC support and it is not "as simple as enable DM_MMC for Allwinner". You need to think about the context and implications of the change, beyond the change itself and present that. That's the whole point of having git commit messages: to present changes and their implications.
I don't see how I could make myself any more clear here, so let me give you a simple example. Consider the following code:
void foo(int *bar, int *baz) { if (bar && baz) *bar = *baz; else if (baz) *baz = 2; }
Now we change that to:
void foo(int *bar, int *baz) { if (bar) *bar = *baz; else if (baz) *baz = 2; }
Here is one commit message about it:
"Remove check before dereferencing baz
The check on baz is removed from the if."
Here is another commit message about it:
The core (which is by design the only caller to this function) guarantees that whenever foo is called and bar is non-NULL, baz is also a valid pointer. Drop the check on baz since it is redundant."
Now in the first case, we have no context or explanation and we have no idea why the change is okay. In the second one, we know precisely why we can remove the check on baz and why it's safe to reference it.
Without knowing this, it's impossible to tell if the patch is just wrong (it removes a check on a pointer before dereferencing it) or if it is legitimate and makes sense.
Do you see my point?
That's the point: of course you don't see why need to explain things because they are already obvious to you as the author of the path. You must think about everyone else who is not you and who will read the patch with no other context. They must be able to understand what is going on just by reading the patch. This is one of the most important areas to contributing to public free software projects and it is what allows us to keep sane code bases, understand previous decisions, etc.
Cheers,
Paul
Here's the problem. None of the commits in the series say what hardware you tested this on. If it's not in the commit message then it's not preserved for easy access. You _need_ to say what combinations of hardware you tested changes on in the commit message. Yes, some of the previous commits are about a specific SoC but that doesn't enumerate what it was all tested on.
On Mon, Apr 8, 2019 at 6:40 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote: > Hi, > > Le lundi 08 avril 2019 à 18:23 +0530, Jagan Teki a écrit : > > Hi Paul, > > > > On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski > > paul.kocialkowski@bootlin.com wrote: > > > Hi, > > > > > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > > > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > > > > found that it wasn't booting, 2019.01 was working ok. > > > > Bisecting indicated that the problem was after > > > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... > > > > > > I think the patch should be reverted ASAP since it obviously breaks > > > some supported configs. Sadly, the offending commit doesn't say > > > anything about the test coverage for the change and what the status is > > > after it. There is probably a reason why it was enabled for sun4i only > > > before and there must have been a motivation for doing this on all > > > sunxi platforms, but then again, the commit message says nothing about > > > those underlying reasons. > > > > > > I believe we should be more strict on patch review and not let any > > > change bringing such a major change get applied with a commit message > > > that provides no context about why the change is okay and how it was > > > tested. > > > > Appropriate your concern. > > > > If you please list what all boards are not working with this effect, > > please write back. we will defiantly look into it. All these changes > > were merged in MW which is 2.5 months back, commenting in final stage > > like this is not the professional way. > > I really do not think this is a sane approach to follow. You can't make > a change like this, with no context whatsoever in the commit message, > which ends up breaking other people's setups and wait for others to > debug subsequent issues it introduces that you don't encounter. > > Sorry but your commit should never have been merged. Sure, I wasn't > there to review it either, but the code review process definitely did > not go as planned here.
First of all, how can I or anyone mention the tested board information on the commit messaged w/o Tested-by. This seems new to community, atleast as I saw from my experience. I didn't aware of any commit show this kind of information and last but not least the commit that support any new change may not require to mention the board or hardware information intentionally it is by default that the commit tested on respective changes with effecting hardware.
Hope it clear.
Hi
Let me try to go back to the topic. We have one setup that does not work and it was working. It's not first time that this happen and every time that large changes are merged sometime some setup stop to work even for multiple releases. If this change will be reverted we just give a commit message that explain the reason why needs to be reverted, including all the information.
Michael
-- Tom _______________________________________________ U-Boot mailing list U-Boot@Let's give a summer. You think that commit message was not having enough description even was part
on some large change and that now is braking one board. This is not the first time that is happen and I don't see such long thread in the past. Right now we know that it breaks one setup and your suggestion is to revert. I think that such things happen and it's part of uboot update. Can we go back to initial email?
On Mon, Apr 08, 2019 at 06:23:29PM +0530, Jagan Teki wrote:
Hi Paul,
OK, but what platforms was this all tested on? Thanks!
+ Andre
Hi Paul,
We have tested DM_MMC all the Allwinner SoC platforms and I couldn't find any mmc issues so-far on my boards atleast.
Jagan.
On Mon, Apr 08, 2019 at 06:51:48PM +0530, Jagan Teki wrote:
- Andre
Hi Paul,
Sorry, let me try and be clearer. Which hardware platforms did you test this on? There's quite a lot of Allwinner SoCs, and it's not clear at all if Paul's problem is because of something on the SoC on the Bananapi M2 Ultra (because it's not clear if another platform with that same SoC was tested) or how the board is wired (DM MMC is fine on that SoC, but was tested on something where uSD/MMC are opposite of that platform or ...).
- Andre
Hi Paul,
For the record, it's not my setup that was broken but Pablo Sebastián Greco's. I suggested that we revert the offending patch for now and replace it with a proper one that provides some context about the change.
Cheers,
Paul
- Andre
Hi Paul,
Ah, thanks for clarifying.
- Andre
Hi Paul,
A13, A20, A83T, R40, H3, H6, A64.
- Andre
Hi Paul,
That's a list of SoCs and not boards that the SoCs are installed on. It also doesn't say of those boards which you tested uSD and/or eMMC on. All of which is really important to know and have recorded for history, even if we didn't have this problem right here right now.
- Andre
Hi Paul,
On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski paul.kocialkowski@bootlin.com wrote: > > Hi, > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > > found that it wasn't booting, 2019.01 was working ok. > > Bisecting indicated that the problem was after > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... > > I think the patch should be reverted ASAP since it obviously breaks > some supported configs. Sadly, the offending commit doesn't say > anything about the test coverage for the change and what the status is > after it. There is probably a reason why it was enabled for sun4i only > before and there must have been a motivation for doing this on all > sunxi platforms, but then again, the commit message says nothing about > those underlying reasons. > > I believe we should be more strict on patch review and not let any > change bringing such a major change get applied with a commit message > that provides no context about why the change is okay and how it was > tested.
You can consider one board on each SoC family. Since this series dealing with entire Allwinner family, I have mentioned respective tested families.
Hi Paul,
Being release day, here's my big concern. How bad is this? Is it a single platform? Later in the thread Jagan did enumerate the SoCs he tested the overall series on. But there's a lot of Allwinner SoCs and boards. I have a pine64 somewhere around here, but that's already been checked off. My other allwinner platform I took out of my testing loop due to it not being a reliable piece of hardware. So, does anyone have a feel for how many platforms may or may not be broken right now? Thanks!
Hi jagan
Hi Paul,
You have 13 to 15 boards. Can you just report all of them?
Michael
-- Tom _______________________________________________ U-Boot mailing list U-Boot@lists.denx.de https://lists.denx.de/listinfo/u-boot
On Tue, Apr 9, 2019 at 12:02 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote:
Hi jagan
Hi Paul,
Issue, seems to be on SCSI side. MMC is able to probe and boot (you may see initial logs on the thread). Enabling DM_MMC breaking SCSI reads, debugging same with Pablo will get back.
Hi jagan
Hi Paul,
OK, thanks, please keep us up to date!
Hi Tom,
Hi jagan
Hi Paul,
As expected, SCSI reads failing. DM_MMC is forcing BLK so which expecting boards to enable DM_SCSI. So the migration plan for DM_SCSI and DM_MMC should be in same line, as of now it's not.
On Tue, Apr 09, 2019 at 12:37:04AM +0530, Jagan Teki wrote:
Hi Tom,
Hi jagan
Hi Paul,
Ah, is the scsi driver for Allwinner DM-ified yet? And for the release I'd really like to do today can we just switch off DM_MMC on the DM_SCSI Allwinner platforms?
Hi Tom,
Hi jagan
On Mon, Apr 08, 2019 at 06:23:29PM +0530, Jagan Teki wrote: > Hi Paul, > > On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski > paul.kocialkowski@bootlin.com wrote: > > > > Hi, > > > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > > > found that it wasn't booting, 2019.01 was working ok. > > > Bisecting indicated that the problem was after > > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... > > > > I think the patch should be reverted ASAP since it obviously breaks > > some supported configs. Sadly, the offending commit doesn't say > > anything about the test coverage for the change and what the status is > > after it. There is probably a reason why it was enabled for sun4i only > > before and there must have been a motivation for doing this on all > > sunxi platforms, but then again, the commit message says nothing about > > those underlying reasons. > > > > I believe we should be more strict on patch review and not let any > > change bringing such a major change get applied with a commit message > > that provides no context about why the change is okay and how it was > > tested. > > Appropriate your concern. > > If you please list what all boards are not working with this effect, > please write back. we will defiantly look into it. All these changes > were merged in MW which is 2.5 months back, commenting in final stage > like this is not the professional way.
Since the migration plan still there for DM_SCSI (v2019.07) we haven't enabled DM_SCSI yet.
Hi Tom,
Hi jagan
On Mon., 8 Apr. 2019, 8:26 pm Tom Rini, trini@konsulko.com wrote: > > On Mon, Apr 08, 2019 at 06:23:29PM +0530, Jagan Teki wrote: > > Hi Paul, > > > > On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski > > paul.kocialkowski@bootlin.com wrote: > > > > > > Hi, > > > > > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > > > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > > > > found that it wasn't booting, 2019.01 was working ok. > > > > Bisecting indicated that the problem was after > > > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... > > > > > > I think the patch should be reverted ASAP since it obviously breaks > > > some supported configs. Sadly, the offending commit doesn't say > > > anything about the test coverage for the change and what the status is > > > after it. There is probably a reason why it was enabled for sun4i only > > > before and there must have been a motivation for doing this on all > > > sunxi platforms, but then again, the commit message says nothing about > > > those underlying reasons. > > > > > > I believe we should be more strict on patch review and not let any > > > change bringing such a major change get applied with a commit message > > > that provides no context about why the change is okay and how it was > > > tested. > > > > Appropriate your concern. > > > > If you please list what all boards are not working with this effect, > > please write back. we will defiantly look into it. All these changes > > were merged in MW which is 2.5 months back, commenting in final stage > > like this is not the professional way. > > Being release day, here's my big concern. How bad is this? Is it a > single platform? Later in the thread Jagan did enumerate the SoCs he > tested the overall series on. But there's a lot of Allwinner SoCs and > boards. I have a pine64 somewhere around here, but that's already been > checked off. My other allwinner platform I took out of my testing loop > due to it not being a reliable piece of hardware. So, does anyone have > a feel for how many platforms may or may not be broken right now? > Thanks!
Except on sun4i. But different driver then? But I guess for today we need to use: select DM_MMC if MMC && !(DM_SCSI && SCSI) ?
Hi Tom,
On Tue, Apr 9, 2019 at 12:02 AM Michael Nazzareno Trimarchi michael@amarulasolutions.com wrote: > > Hi jagan > > > On Mon., 8 Apr. 2019, 8:26 pm Tom Rini, trini@konsulko.com wrote: >> >> On Mon, Apr 08, 2019 at 06:23:29PM +0530, Jagan Teki wrote: >> > Hi Paul, >> > >> > On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski >> > paul.kocialkowski@bootlin.com wrote: >> > > >> > > Hi, >> > > >> > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: >> > > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I >> > > > found that it wasn't booting, 2019.01 was working ok. >> > > > Bisecting indicated that the problem was after >> > > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... >> > > >> > > I think the patch should be reverted ASAP since it obviously breaks >> > > some supported configs. Sadly, the offending commit doesn't say >> > > anything about the test coverage for the change and what the status is >> > > after it. There is probably a reason why it was enabled for sun4i only >> > > before and there must have been a motivation for doing this on all >> > > sunxi platforms, but then again, the commit message says nothing about >> > > those underlying reasons. >> > > >> > > I believe we should be more strict on patch review and not let any >> > > change bringing such a major change get applied with a commit message >> > > that provides no context about why the change is okay and how it was >> > > tested. >> > >> > Appropriate your concern. >> > >> > If you please list what all boards are not working with this effect, >> > please write back. we will defiantly look into it. All these changes >> > were merged in MW which is 2.5 months back, commenting in final stage >> > like this is not the professional way. >> >> Being release day, here's my big concern. How bad is this? Is it a >> single platform? Later in the thread Jagan did enumerate the SoCs he >> tested the overall series on. But there's a lot of Allwinner SoCs and >> boards. I have a pine64 somewhere around here, but that's already been >> checked off. My other allwinner platform I took out of my testing loop >> due to it not being a reliable piece of hardware. So, does anyone have >> a feel for how many platforms may or may not be broken right now? >> Thanks! > > > You have 13 to 15 boards. Can you just report all of them?
Yes, A10 has DM_SCSI
Above solutions seems to be 'recursive dependency' issue.
drivers/scsi/Kconfig:11:error: recursive dependency detected! drivers/scsi/Kconfig:11: symbol DM_SCSI depends on BLK drivers/block/Kconfig:4: symbol BLK depends on DM_MMC drivers/mmc/Kconfig:26: symbol DM_MMC is selected by DM_SCSI For a resolution refer to Documentation/kbuild/kconfig-language.txt subsection "Kconfig recursive dependency limitations"
Hi Tom,
On Tue, Apr 09, 2019 at 12:17:15AM +0530, Jagan Teki wrote: > On Tue, Apr 9, 2019 at 12:02 AM Michael Nazzareno Trimarchi > michael@amarulasolutions.com wrote: > > > > Hi jagan > > > > > > On Mon., 8 Apr. 2019, 8:26 pm Tom Rini, trini@konsulko.com wrote: > >> > >> On Mon, Apr 08, 2019 at 06:23:29PM +0530, Jagan Teki wrote: > >> > Hi Paul, > >> > > >> > On Mon, Apr 8, 2019 at 6:00 PM Paul Kocialkowski > >> > paul.kocialkowski@bootlin.com wrote: > >> > > > >> > > Hi, > >> > > > >> > > On Thu, 2019-04-04 at 05:51 -0300, Pablo Sebastián Greco wrote: > >> > > > A few days ago I tried to boot my Bananapi_M2_Ultra with 2019.04rc, I > >> > > > found that it wasn't booting, 2019.01 was working ok. > >> > > > Bisecting indicated that the problem was after > >> > > > http://git.denx.de/?p=u-boot.git;a=commitdiff;h=a7cca5793774ee139b75a704d6ef... > >> > > > >> > > I think the patch should be reverted ASAP since it obviously breaks > >> > > some supported configs. Sadly, the offending commit doesn't say > >> > > anything about the test coverage for the change and what the status is > >> > > after it. There is probably a reason why it was enabled for sun4i only > >> > > before and there must have been a motivation for doing this on all > >> > > sunxi platforms, but then again, the commit message says nothing about > >> > > those underlying reasons. > >> > > > >> > > I believe we should be more strict on patch review and not let any > >> > > change bringing such a major change get applied with a commit message > >> > > that provides no context about why the change is okay and how it was > >> > > tested. > >> > > >> > Appropriate your concern. > >> > > >> > If you please list what all boards are not working with this effect, > >> > please write back. we will defiantly look into it. All these changes > >> > were merged in MW which is 2.5 months back, commenting in final stage > >> > like this is not the professional way. > >> > >> Being release day, here's my big concern. How bad is this? Is it a > >> single platform? Later in the thread Jagan did enumerate the SoCs he > >> tested the overall series on. But there's a lot of Allwinner SoCs and > >> boards. I have a pine64 somewhere around here, but that's already been > >> checked off. My other allwinner platform I took out of my testing loop > >> due to it not being a reliable piece of hardware. So, does anyone have > >> a feel for how many platforms may or may not be broken right now? > >> Thanks! > > > > > > You have 13 to 15 boards. Can you just report all of them? > > Issue, seems to be on SCSI side. MMC is able to probe and boot (you > may see initial logs on the thread). Enabling DM_MMC breaking SCSI > reads, debugging same with Pablo will get back.
Yeah, due to where we set it for SUN4I. Can you rework things a little so there's not a recursive dep? Perhaps move the DM_MMC if MMC line to each of the SoCs for today and for v2019.07 we'll have both DM_MMC and DM_SCSI top-line.
Hi jagan
Hi Paul,
2019.04rc, I
is
only
about
message
This looks like the same issue I reported a few weeks back, I never got back to it as I don't have an A20 and getting novices to git bisects is a level of time consuming I don't have, add in a bunch of travel etc.
Peter
On Thu, Apr 4, 2019 at 5:12 PM Pablo Sebastián Greco pgreco@centosproject.org wrote:
Is your SD partitioned?
resetting ...
Check the below logs? I have booted Linux and showed you all the devices been probed in u-boot.
U-Boot SPL 2019.04-rc4-00124-gafbc31948a (Apr 08 2019 - 18:10:42 +0530) DRAM: 2048 MiB Trying to boot from MMC1
U-Boot 2019.04-rc4-00124-gafbc31948a (Apr 08 2019 - 18:10:42 +0530) Allwinner Technology
CPU: Allwinner R40 (SUN8I 1701) Model: Banana Pi BPI-M2-Ultra I2C: ready DRAM: 2 GiB MMC: Device 'mmc@1c11000': seq 1 is in use by 'mmc@1c10000' mmc@1c0f000: 0, mmc@1c10000: 2, mmc@1c11000: 1 Loading Environment from FAT... Unable to use mmc 1:0... In: serial@1c28000 Out: serial@1c28000 Err: serial@1c28000 SCSI: SATA link 0 timeout. AHCI 0001.0100 32 slots 1 ports 3 Gbps 0x1 impl SATA mode flags: ncq stag pm led clo only pmp pio slum part ccc apst
Net: phy interface7 eth0: ethernet@1c50000 starting USB... No controllers found Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... Found /extlinux/extlinux.conf Retrieving file: /extlinux/extlinux.conf 157 bytes read in 0 ms 1: linux-4.18.0-rc3 Retrieving file: /zImage 4128984 bytes read in 186 ms (21.2 MiB/s) append: console=ttyS0,115200 earlyprintk root=/dev/mmcblk0p2 rootwait Retrieving file: /sun8i-r40-bananapi-m2-ultra.dtb 19613 bytes read in 5 ms (3.7 MiB/s) ## Flattened Device Tree blob at 43000000 Booting using the fdt blob at 0x43000000 Loading Device Tree to 49ff8000, end 49fffc9c ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 5.0.0-next-20190306-00055-g12f3f7e4961a-dirty (jagan@jagan-XPS-13-9350) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02) ) #51 SMP Fri Mar 22 23:18:35 IST 2019 [ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d [ 0.000000] CPU: div instructions available: patching division code [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: Banana Pi BPI-M2-Ultra
Net: phy interface7 eth0: ethernet@1c50000 starting USB... No controllers found Hit any key to stop autoboot: 0 => => mmc list mmc@1c0f000: 0 mmc@1c10000: 2 mmc@1c11000: 1 (eMMC) => mmc dev 0 switch to partitions #0, OK mmc0 is current device => fatls mmc 0:1 4128984 zImage extlinux/ 19613 sun8i-r40-bananapi-m2-ultra.dtb
2 file(s), 1 dir(s)
=> ext4ls mmc 0:2 <DIR> 1024 . <DIR> 1024 .. <DIR> 12288 lost+found <DIR> 1024 proc <DIR> 1024 etc <DIR> 1024 lib <DIR> 1024 media <DIR> 1024 tmp <DIR> 1024 dev <SYM> 3 lib32 <DIR> 1024 var <DIR> 1024 usr <DIR> 1024 run <DIR> 1024 sbin <DIR> 1024 root <DIR> 2048 bin <DIR> 1024 opt <DIR> 1024 mnt <SYM> 11 linuxrc <DIR> 1024 sys => mmc list mmc@1c0f000: 0 (SD) mmc@1c10000: 2 mmc@1c11000: 1 (eMMC) => mmc dev 1 switch to partitions #0, OK mmc1(part 0) is current device
participants (6)
Jagan Teki
Paul Kocialkowski
Peter Robinson
