[U-Boot] [PATCH 1/5][v6] arch: powerpc: Move CONFIG_FSL_IFC to Kconfig
Enable IFC from Kconfig.
Signed-off-by: Prabhakar Kushwaha prabhakar.kushwaha@nxp.com --- Changes for v5: Added first time Changes for v6: Sending as it is
arch/powerpc/cpu/mpc85xx/Kconfig | 17 +++++++++++++++++ include/configs/B4860QDS.h | 1 - include/configs/BSC9131RDB.h | 1 - include/configs/BSC9132QDS.h | 1 - include/configs/C29XPCIE.h | 1 - include/configs/P1010RDB.h | 1 - include/configs/T102xQDS.h | 1 - include/configs/T102xRDB.h | 1 - include/configs/T1040QDS.h | 1 - include/configs/T104xRDB.h | 1 - include/configs/T208xQDS.h | 1 - include/configs/T208xRDB.h | 1 - include/configs/T4240RDB.h | 1 - include/configs/t4qds.h | 1 - 14 files changed, 17 insertions(+), 13 deletions(-)
diff --git a/arch/powerpc/cpu/mpc85xx/Kconfig b/arch/powerpc/cpu/mpc85xx/Kconfig index 704f65b..c67b6b0 100644 --- a/arch/powerpc/cpu/mpc85xx/Kconfig +++ b/arch/powerpc/cpu/mpc85xx/Kconfig @@ -349,6 +349,7 @@ config ARCH_B4420 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_B4860 bool @@ -372,6 +373,7 @@ config ARCH_B4860 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_BSC9131 bool @@ -384,6 +386,7 @@ config ARCH_BSC9131 select SYS_FSL_HAS_SEC select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 + select FSL_IFC
config ARCH_BSC9132 bool @@ -400,6 +403,7 @@ config ARCH_BSC9132 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_IFC
config ARCH_C29X bool @@ -412,6 +416,7 @@ config ARCH_C29X select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_6 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_IFC
config ARCH_MPC8536 bool @@ -527,6 +532,7 @@ config ARCH_P1010 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC_E500_USE_DEBUG_TLB + select FSL_IFC
config ARCH_P1011 bool @@ -769,6 +775,7 @@ config ARCH_T1023 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T1024 bool @@ -785,6 +792,7 @@ config ARCH_T1024 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T1040 bool @@ -802,6 +810,7 @@ config ARCH_T1040 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T1042 bool @@ -819,6 +828,7 @@ config ARCH_T1042 select SYS_FSL_QORIQ_CHASSIS2 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_5 + select FSL_IFC
config ARCH_T2080 bool @@ -838,6 +848,7 @@ config ARCH_T2080 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_T2081 bool @@ -857,6 +868,7 @@ config ARCH_T2081 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_T4160 bool @@ -877,6 +889,7 @@ config ARCH_T4160 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config ARCH_T4240 bool @@ -898,6 +911,7 @@ config ARCH_T4240 select SYS_FSL_SEC_BE select SYS_FSL_SEC_COMPAT_4 select SYS_PPC64 + select FSL_IFC
config BOOKE bool @@ -1224,6 +1238,9 @@ config SYS_PPC64 config SYS_PPC_E500_USE_DEBUG_TLB bool
+config FSL_IFC + bool + config SYS_PPC_E500_DEBUG_TLB int "Temporary TLB entry for external debugger" depends on SYS_PPC_E500_USE_DEBUG_TLB diff --git a/include/configs/B4860QDS.h b/include/configs/B4860QDS.h index 3ad9f80..4267d81 100644 --- a/include/configs/B4860QDS.h +++ b/include/configs/B4860QDS.h @@ -63,7 +63,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_FSL_PCI_INIT /* Use common FSL init code */ diff --git a/include/configs/BSC9131RDB.h b/include/configs/BSC9131RDB.h index a6f73f2..1fe22b6 100644 --- a/include/configs/BSC9131RDB.h +++ b/include/configs/BSC9131RDB.h @@ -46,7 +46,6 @@ #endif
/* High Level Configuration Options */ -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */
#define CONFIG_TSEC_ENET diff --git a/include/configs/BSC9132QDS.h b/include/configs/BSC9132QDS.h index 8aec315..ef84ee7 100644 --- a/include/configs/BSC9132QDS.h +++ b/include/configs/BSC9132QDS.h @@ -68,7 +68,6 @@ #endif
/* High Level Configuration Options */ -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_SYS_HAS_SERDES /* common SERDES init code */
diff --git a/include/configs/C29XPCIE.h b/include/configs/C29XPCIE.h index 53ee98c..269cd49 100644 --- a/include/configs/C29XPCIE.h +++ b/include/configs/C29XPCIE.h @@ -68,7 +68,6 @@ #endif
diff --git a/include/configs/P1010RDB.h b/include/configs/P1010RDB.h index cd9cd9a..d043888 100644 --- a/include/configs/P1010RDB.h +++ b/include/configs/P1010RDB.h @@ -130,7 +130,6 @@ #endif
diff --git a/include/configs/T102xQDS.h b/include/configs/T102xQDS.h index c9a1334..4e46196 100644 --- a/include/configs/T102xQDS.h +++ b/include/configs/T102xQDS.h @@ -23,7 +23,6 @@
#define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/T102xRDB.h b/include/configs/T102xRDB.h index 36eba4e..9b3d298 100644 --- a/include/configs/T102xRDB.h +++ b/include/configs/T102xRDB.h @@ -23,7 +23,6 @@
diff --git a/include/configs/T1040QDS.h b/include/configs/T1040QDS.h index 8d6d986..e1aceb6 100644 --- a/include/configs/T1040QDS.h +++ b/include/configs/T1040QDS.h @@ -54,7 +54,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_PCIE1 /* PCIE controller 1 */ diff --git a/include/configs/T104xRDB.h b/include/configs/T104xRDB.h index d574bbb..7c8ff5e 100644 --- a/include/configs/T104xRDB.h +++ b/include/configs/T104xRDB.h @@ -165,7 +165,6 @@ $(SRCTREE)/board/freescale/t104xrdb/t1042d4_sd_rcw.cfg
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCI_INDIRECT_BRIDGE #define CONFIG_PCIE1 /* PCIE controller 1 */ diff --git a/include/configs/T208xQDS.h b/include/configs/T208xQDS.h index 210d8d8..9ec326a 100644 --- a/include/configs/T208xQDS.h +++ b/include/configs/T208xQDS.h @@ -33,7 +33,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_ENV_OVERWRITE
diff --git a/include/configs/T208xRDB.h b/include/configs/T208xRDB.h index 1941188..b114234 100644 --- a/include/configs/T208xRDB.h +++ b/include/configs/T208xRDB.h @@ -27,7 +27,6 @@
diff --git a/include/configs/T4240RDB.h b/include/configs/T4240RDB.h index e15b0ea..9136bf0 100644 --- a/include/configs/T4240RDB.h +++ b/include/configs/T4240RDB.h @@ -73,7 +73,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_FSL_CAAM /* Enable SEC/CAAM */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ diff --git a/include/configs/t4qds.h b/include/configs/t4qds.h index 0f59eb1..82e4691 100644 --- a/include/configs/t4qds.h +++ b/include/configs/t4qds.h @@ -26,7 +26,6 @@
#define CONFIG_SYS_FSL_CPC /* Corenet Platform Cache */ #define CONFIG_SYS_NUM_CPC CONFIG_SYS_NUM_DDR_CTLRS -#define CONFIG_FSL_IFC /* Enable IFC Support */ #define CONFIG_PCIE1 /* PCIE controller 1 */ #define CONFIG_PCIE2 /* PCIE controller 2 */ #define CONFIG_PCIE3 /* PCIE controller 3 */
Prabhakar Kushwaha
