[PATCH 0/2] doc: update Sphinx build system
We require Sphinx 2.44. Adjust the coding accordingly.
In Linux the margins of Latex documents were fixed. Update our files accordingly.
Heinrich Schuchardt (2): doc: require Sphinx 2.44 doc: fix Latex margins
doc/conf.py | 108 ++++++++-------------------------------- doc/sphinx/kerneldoc.py | 26 ++-------- 2 files changed, 24 insertions(+), 110 deletions(-)
-- 2.30.2
Require Sphinx 2.44 to build the documentation. Remove all code related to earlier versions.
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/conf.py | 77 ++--------------------------------------- doc/sphinx/kerneldoc.py | 26 ++------------ 2 files changed, 5 insertions(+), 98 deletions(-)
diff --git a/doc/conf.py b/doc/conf.py index eb74b86aef..a375ad1b3a 100644 --- a/doc/conf.py +++ b/doc/conf.py @@ -31,7 +31,7 @@ from load_config import loadConfig # -- General configuration ------------------------------------------------
# If your documentation needs a minimal Sphinx version, state it here. -needs_sphinx = '1.3' +needs_sphinx = '2.44'
# Add any Sphinx extension module names here, as strings. They can be # extensions coming with Sphinx (named 'sphinx.ext.*') or your custom @@ -118,19 +118,12 @@ if major >= 3:
else: extensions.append('cdomain') - if major == 1 and minor < 7: - sys.stderr.write('WARNING: Sphinx 1.7 or greater will be required as of ' - 'the v2021.04 release\n')
# Ensure that autosectionlabel will produce unique names autosectionlabel_prefix_document = True autosectionlabel_maxdepth = 2
-# The name of the math extension changed on Sphinx 1.4 -if (major == 1 and minor > 3) or (major > 1): - extensions.append("sphinx.ext.imgmath") -else: - extensions.append("sphinx.ext.pngmath") +extensions.append("sphinx.ext.imgmath")
# Add any paths that contain templates here, relative to this directory. templates_path = ['_templates'] @@ -380,72 +373,6 @@ if cjk_cmd.find("Noto Sans CJK SC") >= 0: \setCJKmainfont{Noto Sans CJK SC} '''
-# Fix reference escape troubles with Sphinx 1.4.x -if major == 1 and minor > 3: - latex_elements['preamble'] += '\renewcommand*{\DUrole}[2]{ #2 }\n' - -if major == 1 and minor <= 4: - latex_elements['preamble'] += '\usepackage[margin=0.5in, top=1in, bottom=1in]{geometry}' -elif major == 1 and (minor > 5 or (minor == 5 and patch >= 3)): - latex_elements['sphinxsetup'] = 'hmargin=0.5in, vmargin=1in' - latex_elements['preamble'] += '\fvset{fontsize=auto}\n' - -# Customize notice background colors on Sphinx < 1.6: -if major == 1 and minor < 6: - latex_elements['preamble'] += ''' - \usepackage{ifthen} - - % Put notes in color and let them be inside a table - \definecolor{NoteColor}{RGB}{204,255,255} - \definecolor{WarningColor}{RGB}{255,204,204} - \definecolor{AttentionColor}{RGB}{255,255,204} - \definecolor{ImportantColor}{RGB}{192,255,204} - \definecolor{OtherColor}{RGB}{204,204,204} - \newlength{\mynoticelength} - \makeatletter\newenvironment{coloredbox}[1]{% - \setlength{\fboxrule}{1pt} - \setlength{\fboxsep}{7pt} - \setlength{\mynoticelength}{\linewidth} - \addtolength{\mynoticelength}{-2\fboxsep} - \addtolength{\mynoticelength}{-2\fboxrule} - \begin{lrbox}{\@tempboxa}\begin{minipage}{\mynoticelength}}{\end{minipage}\end{lrbox}% - \ifthenelse% - {\equal{\py@noticetype}{note}}% - {\colorbox{NoteColor}{\usebox{\@tempboxa}}}% - {% - \ifthenelse% - {\equal{\py@noticetype}{warning}}% - {\colorbox{WarningColor}{\usebox{\@tempboxa}}}% - {% - \ifthenelse% - {\equal{\py@noticetype}{attention}}% - {\colorbox{AttentionColor}{\usebox{\@tempboxa}}}% - {% - \ifthenelse% - {\equal{\py@noticetype}{important}}% - {\colorbox{ImportantColor}{\usebox{\@tempboxa}}}% - {\colorbox{OtherColor}{\usebox{\@tempboxa}}}% - }% - }% - }% - }\makeatother - - \makeatletter - \renewenvironment{notice}[2]{% - \def\py@noticetype{#1} - \begin{coloredbox}{#1} - \bf\it - \par\strong{#2} - \csname py@noticestart@#1\endcsname - } - { - \csname py@noticeend@\py@noticetype\endcsname - \end{coloredbox} - } - \makeatother - - ''' - # With Sphinx 1.6, it is possible to change the Bg color directly # by using: # \definecolor{sphinxnoteBgColor}{RGB}{204,255,255} diff --git a/doc/sphinx/kerneldoc.py b/doc/sphinx/kerneldoc.py index e9857ab904..8189c33b9d 100644 --- a/doc/sphinx/kerneldoc.py +++ b/doc/sphinx/kerneldoc.py @@ -37,18 +37,8 @@ import glob from docutils import nodes, statemachine from docutils.statemachine import ViewList from docutils.parsers.rst import directives, Directive - -# -# AutodocReporter is only good up to Sphinx 1.7 -# import sphinx - -Use_SSI = sphinx.__version__[:3] >= '1.7' -if Use_SSI: - from sphinx.util.docutils import switch_source_input -else: - from sphinx.ext.autodoc import AutodocReporter - +from sphinx.util.docutils import switch_source_input import kernellog
__version__ = '1.0' @@ -163,18 +153,8 @@ class KernelDocDirective(Directive): return [nodes.error(None, nodes.paragraph(text = "kernel-doc missing"))]
def do_parse(self, result, node): - if Use_SSI: - with switch_source_input(self.state, result): - self.state.nested_parse(result, 0, node, match_titles=1) - else: - save = self.state.memo.title_styles, self.state.memo.section_level, self.state.memo.reporter - self.state.memo.reporter = AutodocReporter(result, self.state.memo.reporter) - self.state.memo.title_styles, self.state.memo.section_level = [], 0 - try: - self.state.nested_parse(result, 0, node, match_titles=1) - finally: - self.state.memo.title_styles, self.state.memo.section_level, self.state.memo.reporter = save - + with switch_source_input(self.state, result): + self.state.nested_parse(result, 0, node, match_titles=1)
def setup(app): app.add_config_value('kerneldoc_bin', None, 'env') -- 2.30.2
But please add a motivation for this patch.
Adjust the Latex formatting to match Linux v5.13.1:
* add Latex margins * reformat the code in doc/conf.py to match Linux
Signed-off-by: Heinrich Schuchardt xypron.glpk@gmx.de --- doc/conf.py | 31 +++++++++++++++++++------------ 1 file changed, 19 insertions(+), 12 deletions(-)
diff --git a/doc/conf.py b/doc/conf.py index a375ad1b3a..c24a359859 100644 --- a/doc/conf.py +++ b/doc/conf.py @@ -338,27 +338,34 @@ htmlhelp_basename = 'TheUBootdoc' # -- Options for LaTeX output ---------------------------------------------
latex_elements = { -# The paper size ('letterpaper' or 'a4paper'). -'papersize': 'a4paper', + # The paper size ('letterpaper' or 'a4paper'). + 'papersize': 'a4paper',
-# The font size ('10pt', '11pt' or '12pt'). -'pointsize': '11pt', + # The font size ('10pt', '11pt' or '12pt'). + 'pointsize': '11pt',
-# Latex figure (float) alignment -#'figure_align': 'htbp', + # Latex figure (float) alignment + #'figure_align': 'htbp',
-# Don't mangle with UTF-8 chars -'inputenc': '', -'utf8extra': '', + # Don't mangle with UTF-8 chars + 'inputenc': '', + 'utf8extra': '',
-# Additional stuff for the LaTeX preamble. + # Set document margins + 'sphinxsetup': ''' + hmargin=0.5in, vmargin=1in, + parsedliteralwraps=true, + verbatimhintsturnover=false, + ''', + + # Additional stuff for the LaTeX preamble. 'preamble': ''' - % Use some font with UTF-8 support with XeLaTeX + % Use some font with UTF-8 support with XeLaTeX \usepackage{fontspec} \setsansfont{DejaVu Sans} \setromanfont{DejaVu Serif} \setmonofont{DejaVu Sans Mono} - ''' + ''', }
# At least one book (translations) may have Asian characters -- 2.30.2
- add Latex margins
- reformat the code in doc/conf.py to match Linux
Is a larger re-sync effort not warranted? Or are we not aiming to / needing to so closely follow the kernel here?
- add Latex margins
