[U-Boot] [PATCH] arm: mx5: Add LDB clock config code
Add code to configure PLL4, from which the LDB clock are directly derived.
Signed-off-by: Marek Vasut marex@denx.de Cc: Stefano Babic sbabic@denx.de --- arch/arm/include/asm/arch-mx5/clock.h | 1 + arch/arm/mach-imx/mx5/clock.c | 21 +++++++++++++++++++++ 2 files changed, 22 insertions(+)
diff --git a/arch/arm/include/asm/arch-mx5/clock.h b/arch/arm/include/asm/arch-mx5/clock.h index 0ecbdeede5..6f5ca5888a 100644 --- a/arch/arm/include/asm/arch-mx5/clock.h +++ b/arch/arm/include/asm/arch-mx5/clock.h @@ -38,6 +38,7 @@ enum mxc_clock { MXC_NFC_CLK, MXC_PERIPH_CLK, MXC_I2C_CLK, + MXC_LDB_CLK, };
u32 imx_get_uartclk(void); diff --git a/arch/arm/mach-imx/mx5/clock.c b/arch/arm/mach-imx/mx5/clock.c index 427cb12415..dcefc4276a 100644 --- a/arch/arm/mach-imx/mx5/clock.c +++ b/arch/arm/mach-imx/mx5/clock.c @@ -838,6 +838,23 @@ static int config_ddr_clk(u32 emi_clk) return 0; }
+static int config_ldb_clk(u32 ref, u32 freq) +{ + int ret = 0; + struct pll_param pll_param; + + memset(&pll_param, 0, sizeof(struct pll_param)); + + ret = calc_pll_params(ref, freq, &pll_param); + if (ret != 0) { + printf("Error:Can't find pll parameters: %d\n", + ret); + return ret; + } + + return config_pll_clk(PLL4_CLOCK, &pll_param); +} + /* * This function assumes the expected core clock has to be changed by * modifying the PLL. This is NOT true always but for most of the times, @@ -879,6 +896,10 @@ int mxc_set_clock(u32 ref, u32 freq, enum mxc_clock clk) if (config_nfc_clk(freq)) return -EINVAL; break; + case MXC_LDB_CLK: + if (config_ldb_clk(ref, freq)) + return -EINVAL; + break; default: printf("Warning:Unsupported or invalid clock type\n"); }
Hi Marek,
- MXC_LDB_CLK,
- int ret = 0;
- struct pll_param pll_param;
- memset(&pll_param, 0, sizeof(struct pll_param));
- ret = calc_pll_params(ref, freq, &pll_param);
- if (ret != 0) {
ret);
return ret;
- return config_pll_clk(PLL4_CLOCK, &pll_param);
This patch breaks the ts4800 board because this is not defined. Can you take a look please ?
- This function assumes the expected core clock has to be changed by
- modifying the PLL. This is NOT true always but for most of the times,
- case MXC_LDB_CLK:
return -EINVAL;
default: printf("Warning:Unsupported or invalid clock type\n"); }break;
Best regards, Stefano
On 10/09/2018 10:27 PM, Stefano Babic wrote:
Hi Marek,
- MXC_LDB_CLK,
- int ret = 0;
- if (ret != 0) {
ret);
return ret;
V2 is out.
Stefano Babic
