[U-Boot] [PATCH 1/6] sf: Simplify fastest read cmd code
Fastest read command code look for fastest read command taking inputs from spi->mode_rx and flags from param table and controller mode_rx is always been a priority.
Since mode_rx is always set from controller side this optimized code doesn't require much and this code required exctra overhead like 1) Maintain e_rx_cmd in param table 2) Maintain mode_rx in spi_slave {}
Hence removed this code, and look for read command from normal spi->mode from spi_slave{} and params->flags
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 4 ++++ drivers/mtd/spi/spi_flash.c | 28 ++++++++++------------------ 2 files changed, 14 insertions(+), 18 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index da2bb7b..c5cb791 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -46,6 +46,10 @@ enum { E_FSR = BIT(2), SST_WR = BIT(3), WR_QPP = BIT(4), + RD_QUAD = BIT(5), + RD_DUAL = BIT(6), + RD_QUADIO = BIT(7), + RD_DUALIO = BIT(8), };
enum spi_nor_option_flags { diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 64d4e0f..5fd408c 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1013,15 +1013,8 @@ int spi_flash_scan(struct spi_flash *flash) struct spi_slave *spi = flash->spi; const struct spi_flash_params *params; u16 jedec, ext_jedec; - u8 cmd, idcode[5]; + u8 idcode[5]; int ret; - static u8 spi_read_cmds_array[] = { - CMD_READ_ARRAY_SLOW, - CMD_READ_ARRAY_FAST, - CMD_READ_DUAL_OUTPUT_FAST, - CMD_READ_QUAD_OUTPUT_FAST, - CMD_READ_DUAL_IO_FAST, - CMD_READ_QUAD_IO_FAST };
/* Read the ID codes */ ret = spi_flash_cmd(spi, CMD_READ_ID, idcode, sizeof(idcode)); @@ -1177,17 +1170,16 @@ int spi_flash_scan(struct spi_flash *flash) /* Now erase size becomes valid sector size */ flash->sector_size = flash->erase_size;
- /* Look for the fastest read cmd */ - cmd = fls(params->e_rd_cmd & spi->mode_rx); - if (cmd) { - cmd = spi_read_cmds_array[cmd - 1]; - flash->read_cmd = cmd; - } else { - /* Go for default supported read cmd */ - flash->read_cmd = CMD_READ_ARRAY_FAST; - } + /* Look for read commands */ + flash->read_cmd = CMD_READ_ARRAY_FAST; + if (spi->mode_rx & SPI_RX_SLOW) + flash->read_cmd = CMD_READ_ARRAY_SLOW; + else if (spi->mode_rx & SPI_RX_QUAD && params->flags & RD_QUAD) + flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; + else if (spi->mode_rx & SPI_RX_DUAL && params->flags & RD_DUAL) + flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST;
- /* Not require to look for fastest only two write cmds yet */ + /* Look for write commands */ if (params->flags & WR_QPP && spi->mode & SPI_TX_QUAD) flash->write_cmd = CMD_QUAD_PAGE_PROGRAM; else
e_rd_cmd is maintained separately for fastest read command code, since the read commands are computed normally this e_rd_cmd is not required in spi_flash_params table.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 18 +--- drivers/mtd/spi/sf_params.c | 200 +++++++++++++++++++++--------------------- 2 files changed, 101 insertions(+), 117 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index c5cb791..71ba1a6 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -20,21 +20,6 @@ enum spi_dual_flash { SF_DUAL_PARALLEL_FLASH = BIT(1), };
-/* Enum list - Full read commands */ -enum spi_read_cmds { - ARRAY_SLOW = BIT(0), - ARRAY_FAST = BIT(1), - DUAL_OUTPUT_FAST = BIT(2), - QUAD_OUTPUT_FAST = BIT(3), - DUAL_IO_FAST = BIT(4), - QUAD_IO_FAST = BIT(5), -}; - -/* Normal - Extended - Full command set */ -#define RD_NORM (ARRAY_SLOW | ARRAY_FAST) -#define RD_EXTN (RD_NORM | DUAL_OUTPUT_FAST | DUAL_IO_FAST) -#define RD_FULL (RD_EXTN | QUAD_OUTPUT_FAST | QUAD_IO_FAST) - /* sf param flags */ enum { #ifndef CONFIG_SPI_FLASH_USE_4K_SECTORS @@ -51,6 +36,7 @@ enum { RD_QUADIO = BIT(7), RD_DUALIO = BIT(8), }; +#define RD_FULL RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO
enum spi_nor_option_flags { SNOR_F_SST_WR = BIT(0), @@ -145,7 +131,6 @@ int sst_write_bp(struct spi_flash *flash, u32 offset, size_t len, * @sector_size: Isn't necessarily a sector size from vendor, * the size listed here is what works with CMD_ERASE_64K * @nr_sectors: No.of sectors on this device - * @e_rd_cmd: Enum list for read commands * @flags: Important param, for flash specific behaviour */ struct spi_flash_params { @@ -154,7 +139,6 @@ struct spi_flash_params { u16 ext_jedec; u32 sector_size; u32 nr_sectors; - u8 e_rd_cmd; u16 flags; };
diff --git a/drivers/mtd/spi/sf_params.c b/drivers/mtd/spi/sf_params.c index 70ca236..5b50114 100644 --- a/drivers/mtd/spi/sf_params.c +++ b/drivers/mtd/spi/sf_params.c @@ -15,122 +15,122 @@ /* SPI/QSPI flash device params structure */ const struct spi_flash_params spi_flash_params_table[] = { #ifdef CONFIG_SPI_FLASH_ATMEL /* ATMEL */ - {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, RD_NORM, SECT_4K}, - {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K}, - {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K}, - {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"AT25DF321A", 0x1f4701, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"AT25DF321", 0x1f4700, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"AT26DF081A", 0x1f4501, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K}, + {"AT45DB011D", 0x1f2200, 0x0, 64 * 1024, 4, SECT_4K}, + {"AT45DB021D", 0x1f2300, 0x0, 64 * 1024, 8, SECT_4K}, + {"AT45DB041D", 0x1f2400, 0x0, 64 * 1024, 8, SECT_4K}, + {"AT45DB081D", 0x1f2500, 0x0, 64 * 1024, 16, SECT_4K}, + {"AT45DB161D", 0x1f2600, 0x0, 64 * 1024, 32, SECT_4K}, + {"AT45DB321D", 0x1f2700, 0x0, 64 * 1024, 64, SECT_4K}, + {"AT45DB641D", 0x1f2800, 0x0, 64 * 1024, 128, SECT_4K}, + {"AT25DF321A", 0x1f4701, 0x0, 64 * 1024, 64, SECT_4K}, + {"AT25DF321", 0x1f4700, 0x0, 64 * 1024, 64, SECT_4K}, + {"AT26DF081A", 0x1f4501, 0x0, 64 * 1024, 16, SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_EON /* EON */ - {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, RD_NORM, 0}, - {"EN25S64", 0x1c3817, 0x0, 64 * 1024, 128, RD_NORM, 0}, + {"EN25Q32B", 0x1c3016, 0x0, 64 * 1024, 64, 0}, + {"EN25Q64", 0x1c3017, 0x0, 64 * 1024, 128, SECT_4K}, + {"EN25Q128B", 0x1c3018, 0x0, 64 * 1024, 256, 0}, + {"EN25S64", 0x1c3817, 0x0, 64 * 1024, 128, 0}, #endif #ifdef CONFIG_SPI_FLASH_GIGADEVICE /* GIGADEVICE */ - {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, + {"GD25Q64B", 0xc84017, 0x0, 64 * 1024, 128, SECT_4K}, + {"GD25LQ32", 0xc86016, 0x0, 64 * 1024, 64, SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_ISSI /* ISSI */ - {"IS25LP032", 0x9d6016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"IS25LP064", 0x9d6017, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"IS25LP128", 0x9d6018, 0x0, 64 * 1024, 256, RD_NORM, 0}, + {"IS25LP032", 0x9d6016, 0x0, 64 * 1024, 64, 0}, + {"IS25LP064", 0x9d6017, 0x0, 64 * 1024, 128, 0}, + {"IS25LP128", 0x9d6018, 0x0, 64 * 1024, 256, 0}, #endif #ifdef CONFIG_SPI_FLASH_MACRONIX /* MACRONIX */ - {"MX25L2006E", 0xc22012, 0x0, 64 * 1024, 4, RD_NORM, 0}, - {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, RD_NORM, 0}, - {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP}, - {"MX25L51235F", 0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP}, - {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, + {"MX25L2006E", 0xc22012, 0x0, 64 * 1024, 4, 0}, + {"MX25L4005", 0xc22013, 0x0, 64 * 1024, 8, 0}, + {"MX25L8005", 0xc22014, 0x0, 64 * 1024, 16, 0}, + {"MX25L1605D", 0xc22015, 0x0, 64 * 1024, 32, 0}, + {"MX25L3205D", 0xc22016, 0x0, 64 * 1024, 64, 0}, + {"MX25L6405D", 0xc22017, 0x0, 64 * 1024, 128, 0}, + {"MX25L12805", 0xc22018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"MX25L25635F", 0xc22019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP}, + {"MX25L51235F", 0xc2201a, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP}, + {"MX25L12855E", 0xc22618, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, #endif #ifdef CONFIG_SPI_FLASH_SPANSION /* SPANSION */ - {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"S25FL116K", 0x014015, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"S25FL164K", 0x014017, 0x0140, 64 * 1024, 128, RD_NORM, 0}, - {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_FULL, WR_QPP}, - {"S25FL128S_256K", 0x012018, 0x4d00, 256 * 1024, 64, RD_FULL, WR_QPP}, - {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL256S_256K", 0x010219, 0x4d00, 256 * 1024, 128, RD_FULL, WR_QPP}, - {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_FULL, WR_QPP}, - {"S25FS512S", 0x010220, 0x4D00, 128 * 1024, 512, RD_FULL, WR_QPP}, - {"S25FL512S_256K", 0x010220, 0x4d00, 256 * 1024, 256, RD_FULL, WR_QPP}, - {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL, WR_QPP}, - {"S25FL512S_512K", 0x010220, 0x4f00, 256 * 1024, 256, RD_FULL, WR_QPP}, + {"S25FL008A", 0x010213, 0x0, 64 * 1024, 16, 0}, + {"S25FL016A", 0x010214, 0x0, 64 * 1024, 32, 0}, + {"S25FL032A", 0x010215, 0x0, 64 * 1024, 64, 0}, + {"S25FL064A", 0x010216, 0x0, 64 * 1024, 128, 0}, + {"S25FL116K", 0x014015, 0x0, 64 * 1024, 128, 0}, + {"S25FL164K", 0x014017, 0x0140, 64 * 1024, 128, 0}, + {"S25FL128P_256K", 0x012018, 0x0300, 256 * 1024, 64, RD_FULL | WR_QPP}, + {"S25FL128P_64K", 0x012018, 0x0301, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"S25FL032P", 0x010215, 0x4d00, 64 * 1024, 64, RD_FULL | WR_QPP}, + {"S25FL064P", 0x010216, 0x4d00, 64 * 1024, 128, RD_FULL | WR_QPP}, + {"S25FL128S_256K", 0x012018, 0x4d00, 256 * 1024, 64, RD_FULL | WR_QPP}, + {"S25FL128S_64K", 0x012018, 0x4d01, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"S25FL256S_256K", 0x010219, 0x4d00, 256 * 1024, 128, RD_FULL | WR_QPP}, + {"S25FL256S_64K", 0x010219, 0x4d01, 64 * 1024, 512, RD_FULL | WR_QPP}, + {"S25FS512S", 0x010220, 0x4D00, 128 * 1024, 512, RD_FULL | WR_QPP}, + {"S25FL512S_256K", 0x010220, 0x4d00, 256 * 1024, 256, RD_FULL | WR_QPP}, + {"S25FL512S_64K", 0x010220, 0x4d01, 64 * 1024, 1024, RD_FULL | WR_QPP}, + {"S25FL512S_512K", 0x010220, 0x4f00, 256 * 1024, 256, RD_FULL | WR_QPP}, #endif #ifdef CONFIG_SPI_FLASH_STMICRO /* STMICRO */ - {"M25P10", 0x202011, 0x0, 32 * 1024, 4, RD_NORM, 0}, - {"M25P20", 0x202012, 0x0, 64 * 1024, 4, RD_NORM, 0}, - {"M25P40", 0x202013, 0x0, 64 * 1024, 8, RD_NORM, 0}, - {"M25P80", 0x202014, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"M25P16", 0x202015, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"M25PE16", 0x208015, 0x1000, 64 * 1024, 32, RD_NORM, 0}, - {"M25PX16", 0x207115, 0x1000, 64 * 1024, 32, RD_EXTN, 0}, - {"M25P32", 0x202016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"M25P64", 0x202017, 0x0, 64 * 1024, 128, RD_NORM, 0}, - {"M25P128", 0x202018, 0x0, 256 * 1024, 64, RD_NORM, 0}, - {"M25PX64", 0x207117, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"N25Q016A", 0x20bb15, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K}, - {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP}, - {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL, WR_QPP | E_FSR | SECT_4K}, - {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL, WR_QPP | E_FSR | SECT_4K}, + {"M25P10", 0x202011, 0x0, 32 * 1024, 4, 0}, + {"M25P20", 0x202012, 0x0, 64 * 1024, 4, 0}, + {"M25P40", 0x202013, 0x0, 64 * 1024, 8, 0}, + {"M25P80", 0x202014, 0x0, 64 * 1024, 16, 0}, + {"M25P16", 0x202015, 0x0, 64 * 1024, 32, 0}, + {"M25PE16", 0x208015, 0x1000, 64 * 1024, 32, 0}, + {"M25PX16", 0x207115, 0x1000, 64 * 1024, 32, RD_QUAD | RD_DUAL}, + {"M25P32", 0x202016, 0x0, 64 * 1024, 64, 0}, + {"M25P64", 0x202017, 0x0, 64 * 1024, 128, 0}, + {"M25P128", 0x202018, 0x0, 256 * 1024, 64, 0}, + {"M25PX64", 0x207117, 0x0, 64 * 1024, 128, SECT_4K}, + {"N25Q016A", 0x20bb15, 0x0, 64 * 1024, 32, SECT_4K}, + {"N25Q32", 0x20ba16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q32A", 0x20bb16, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q64", 0x20ba17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q64A", 0x20bb17, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q128", 0x20ba18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"N25Q128A", 0x20bb18, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP}, + {"N25Q256", 0x20ba19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q256A", 0x20bb19, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, + {"N25Q512", 0x20ba20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K}, + {"N25Q512A", 0x20bb20, 0x0, 64 * 1024, 1024, RD_FULL | WR_QPP | E_FSR | SECT_4K}, + {"N25Q1024", 0x20ba21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K}, + {"N25Q1024A", 0x20bb21, 0x0, 64 * 1024, 2048, RD_FULL | WR_QPP | E_FSR | SECT_4K}, #endif #ifdef CONFIG_SPI_FLASH_SST /* SST */ - {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K | SST_WR}, - {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K | SST_WR}, - {"SST25WF040B", 0x621613, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, RD_NORM, SECT_4K | SST_WR}, + {"SST25VF040B", 0xbf258d, 0x0, 64 * 1024, 8, SECT_4K | SST_WR}, + {"SST25VF080B", 0xbf258e, 0x0, 64 * 1024, 16, SECT_4K | SST_WR}, + {"SST25VF016B", 0xbf2541, 0x0, 64 * 1024, 32, SECT_4K | SST_WR}, + {"SST25VF032B", 0xbf254a, 0x0, 64 * 1024, 64, SECT_4K | SST_WR}, + {"SST25VF064C", 0xbf254b, 0x0, 64 * 1024, 128, SECT_4K}, + {"SST25WF512", 0xbf2501, 0x0, 64 * 1024, 1, SECT_4K | SST_WR}, + {"SST25WF010", 0xbf2502, 0x0, 64 * 1024, 2, SECT_4K | SST_WR}, + {"SST25WF020", 0xbf2503, 0x0, 64 * 1024, 4, SECT_4K | SST_WR}, + {"SST25WF040", 0xbf2504, 0x0, 64 * 1024, 8, SECT_4K | SST_WR}, + {"SST25WF040B", 0x621613, 0x0, 64 * 1024, 8, SECT_4K}, + {"SST25WF080", 0xbf2505, 0x0, 64 * 1024, 16, SECT_4K | SST_WR}, #endif #ifdef CONFIG_SPI_FLASH_WINBOND /* WINBOND */ - {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, RD_NORM, 0}, - {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, RD_NORM, 0}, - {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, RD_NORM, 0}, - {"W25X40", 0xef3013, 0x0, 64 * 1024, 8, RD_NORM, SECT_4K}, - {"W25X16", 0xef3015, 0x0, 64 * 1024, 32, RD_NORM, SECT_4K}, - {"W25X32", 0xef3016, 0x0, 64 * 1024, 64, RD_NORM, SECT_4K}, - {"W25X64", 0xef3017, 0x0, 64 * 1024, 128, RD_NORM, SECT_4K}, - {"W25Q80BL", 0xef4014, 0x0, 64 * 1024, 16, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q16CL", 0xef4015, 0x0, 64 * 1024, 32, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q32BV", 0xef4016, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q64CV", 0xef4017, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q128BV", 0xef4018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q256", 0xef4019, 0x0, 64 * 1024, 512, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q80BW", 0xef5014, 0x0, 64 * 1024, 16, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q16DW", 0xef6015, 0x0, 64 * 1024, 32, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q32DW", 0xef6016, 0x0, 64 * 1024, 64, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q64DW", 0xef6017, 0x0, 64 * 1024, 128, RD_FULL, WR_QPP | SECT_4K}, - {"W25Q128FW", 0xef6018, 0x0, 64 * 1024, 256, RD_FULL, WR_QPP | SECT_4K}, + {"W25P80", 0xef2014, 0x0, 64 * 1024, 16, 0}, + {"W25P16", 0xef2015, 0x0, 64 * 1024, 32, 0}, + {"W25P32", 0xef2016, 0x0, 64 * 1024, 64, 0}, + {"W25X40", 0xef3013, 0x0, 64 * 1024, 8, SECT_4K}, + {"W25X16", 0xef3015, 0x0, 64 * 1024, 32, SECT_4K}, + {"W25X32", 0xef3016, 0x0, 64 * 1024, 64, SECT_4K}, + {"W25X64", 0xef3017, 0x0, 64 * 1024, 128, SECT_4K}, + {"W25Q80BL", 0xef4014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q16CL", 0xef4015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q32BV", 0xef4016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q64CV", 0xef4017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q128BV", 0xef4018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q256", 0xef4019, 0x0, 64 * 1024, 512, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q80BW", 0xef5014, 0x0, 64 * 1024, 16, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q16DW", 0xef6015, 0x0, 64 * 1024, 32, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q32DW", 0xef6016, 0x0, 64 * 1024, 64, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q64DW", 0xef6017, 0x0, 64 * 1024, 128, RD_FULL | WR_QPP | SECT_4K}, + {"W25Q128FW", 0xef6018, 0x0, 64 * 1024, 256, RD_FULL | WR_QPP | SECT_4K}, #endif {}, /* Empty entry to terminate the list */ /*
Make rx mode flags as generic to spi, earlier mode_rx is maintained separately becuase of some flash specific code.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/spi_flash.c | 6 +++--- drivers/spi/cadence_qspi.c | 2 +- drivers/spi/ich.c | 6 ++---- drivers/spi/spi-uclass.c | 11 ++++------- drivers/spi/ti_qspi.c | 6 +++--- include/spi.h | 14 ++++---------- 6 files changed, 17 insertions(+), 28 deletions(-)
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 5fd408c..041b64f 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1172,11 +1172,11 @@ int spi_flash_scan(struct spi_flash *flash)
/* Look for read commands */ flash->read_cmd = CMD_READ_ARRAY_FAST; - if (spi->mode_rx & SPI_RX_SLOW) + if (spi->mode & SPI_RX_SLOW) flash->read_cmd = CMD_READ_ARRAY_SLOW; - else if (spi->mode_rx & SPI_RX_QUAD && params->flags & RD_QUAD) + else if (spi->mode & SPI_RX_QUAD && params->flags & RD_QUAD) flash->read_cmd = CMD_READ_QUAD_OUTPUT_FAST; - else if (spi->mode_rx & SPI_RX_DUAL && params->flags & RD_DUAL) + else if (spi->mode & SPI_RX_DUAL && params->flags & RD_DUAL) flash->read_cmd = CMD_READ_DUAL_OUTPUT_FAST;
/* Look for write commands */ diff --git a/drivers/spi/cadence_qspi.c b/drivers/spi/cadence_qspi.c index a5244ff..1d50f13 100644 --- a/drivers/spi/cadence_qspi.c +++ b/drivers/spi/cadence_qspi.c @@ -251,7 +251,7 @@ static int cadence_spi_xfer(struct udevice *dev, unsigned int bitlen, break; case CQSPI_INDIRECT_READ: err = cadence_qspi_apb_indirect_read_setup(plat, - priv->cmd_len, dm_plat->mode_rx, cmd_buf); + priv->cmd_len, dm_plat->mode, cmd_buf); if (!err) { err = cadence_qspi_apb_indirect_read_execute (plat, data_bytes, din); diff --git a/drivers/spi/ich.c b/drivers/spi/ich.c index 00b2fed..caf0103 100644 --- a/drivers/spi/ich.c +++ b/drivers/spi/ich.c @@ -649,10 +649,8 @@ static int ich_spi_child_pre_probe(struct udevice *dev) * ICH 7 SPI controller only supports array read command * and byte program command for SST flash */ - if (plat->ich_version == ICHV_7) { - slave->mode_rx = SPI_RX_SLOW; - slave->mode = SPI_TX_BYTE; - } + if (plat->ich_version == ICHV_7) + slave->mode = SPI_RX_SLOW | SPI_TX_BYTE;
return 0; } diff --git a/drivers/spi/spi-uclass.c b/drivers/spi/spi-uclass.c index 247abfa..d9c49e4 100644 --- a/drivers/spi/spi-uclass.c +++ b/drivers/spi/spi-uclass.c @@ -164,7 +164,6 @@ static int spi_child_pre_probe(struct udevice *dev)
slave->max_hz = plat->max_hz; slave->mode = plat->mode; - slave->mode_rx = plat->mode_rx; slave->wordlen = SPI_DEFAULT_WORDLEN;
return 0; @@ -381,7 +380,7 @@ void spi_free_slave(struct spi_slave *slave) int spi_slave_ofdata_to_platdata(const void *blob, int node, struct dm_spi_slave_platdata *plat) { - int mode = 0, mode_rx = 0; + int mode = 0; int value;
plat->cs = fdtdec_get_int(blob, node, "reg", -1); @@ -413,24 +412,22 @@ int spi_slave_ofdata_to_platdata(const void *blob, int node, break; }
- plat->mode = mode; - value = fdtdec_get_uint(blob, node, "spi-rx-bus-width", 1); switch (value) { case 1: break; case 2: - mode_rx |= SPI_RX_DUAL; + mode |= SPI_RX_DUAL; break; case 4: - mode_rx |= SPI_RX_QUAD; + mode |= SPI_RX_QUAD; break; default: error("spi-rx-bus-width %d not supported\n", value); break; }
- plat->mode_rx = mode_rx; + plat->mode = mode;
return 0; } diff --git a/drivers/spi/ti_qspi.c b/drivers/spi/ti_qspi.c index bb72cb0..37dc64f 100644 --- a/drivers/spi/ti_qspi.c +++ b/drivers/spi/ti_qspi.c @@ -336,7 +336,7 @@ static void ti_spi_setup_spi_register(struct ti_qspi_priv *priv) QSPI_SETUP0_NUM_D_BYTES_8_BITS | QSPI_SETUP0_READ_QUAD | QSPI_CMD_WRITE | QSPI_NUM_DUMMY_BITS); - slave->mode_rx = SPI_RX_QUAD; + slave->mode |= SPI_RX_QUAD; #else memval |= QSPI_CMD_READ | QSPI_SETUP0_NUM_A_BYTES | QSPI_SETUP0_NUM_D_BYTES_NO_BITS | @@ -422,7 +422,7 @@ static void __ti_qspi_setup_memorymap(struct ti_qspi_priv *priv, bool enable) { u32 memval; - u32 mode = slave->mode_rx & (SPI_RX_QUAD | SPI_RX_DUAL); + u32 mode = slave->mode | SPI_RX_QUAD | SPI_RX_DUAL;
if (!enable) { writel(0, &priv->base->setup0); @@ -436,7 +436,7 @@ static void __ti_qspi_setup_memorymap(struct ti_qspi_priv *priv, memval |= QSPI_CMD_READ_QUAD; memval |= QSPI_SETUP0_NUM_D_BYTES_8_BITS; memval |= QSPI_SETUP0_READ_QUAD; - slave->mode_rx = SPI_RX_QUAD; + slave->mode |= SPI_RX_QUAD; break; case SPI_RX_DUAL: memval |= QSPI_CMD_READ_DUAL; diff --git a/include/spi.h b/include/spi.h index ca96fa4..7d92ddc 100644 --- a/include/spi.h +++ b/include/spi.h @@ -26,12 +26,10 @@ #define SPI_TX_BYTE BIT(8) /* transmit with 1 wire byte */ #define SPI_TX_DUAL BIT(9) /* transmit with 2 wires */ #define SPI_TX_QUAD BIT(10) /* transmit with 4 wires */ - -/* SPI mode_rx flags */ -#define SPI_RX_SLOW BIT(0) /* receive with 1 wire slow */ -#define SPI_RX_FAST BIT(1) /* receive with 1 wire fast */ -#define SPI_RX_DUAL BIT(2) /* receive with 2 wires */ -#define SPI_RX_QUAD BIT(3) /* receive with 4 wires */ +#define SPI_RX_SLOW BIT(11) /* receive with 1 wire slow */ +#define SPI_RX_FAST BIT(12) /* receive with 1 wire fast */ +#define SPI_RX_DUAL BIT(12) /* receive with 2 wires */ +#define SPI_RX_QUAD BIT(13) /* receive with 4 wires */
/* SPI bus connection options - see enum spi_dual_flash */ #define SPI_CONN_DUAL_SHARED (1 << 0) @@ -61,13 +59,11 @@ struct dm_spi_bus { * @cs: Chip select number (0..n-1) * @max_hz: Maximum bus speed that this slave can tolerate * @mode: SPI mode to use for this device (see SPI mode flags) - * @mode_rx: SPI RX mode to use for this slave (see SPI mode_rx flags) */ struct dm_spi_slave_platdata { unsigned int cs; uint max_hz; uint mode; - u8 mode_rx; };
#endif /* CONFIG_DM_SPI */ @@ -94,7 +90,6 @@ struct dm_spi_slave_platdata { * bus (bus->seq) so does not need to be stored * @cs: ID of the chip select connected to the slave. * @mode: SPI mode to use for this slave (see SPI mode flags) - * @mode_rx: SPI RX mode to use for this slave (see SPI mode_rx flags) * @wordlen: Size of SPI word in number of bits * @max_write_size: If non-zero, the maximum number of bytes which can * be written at once, excluding command bytes. @@ -112,7 +107,6 @@ struct spi_slave { unsigned int cs; #endif uint mode; - u8 mode_rx; unsigned int wordlen; unsigned int max_write_size; void *memory_map;
SECT_32K never used anywhere in the code.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 16 +++++++--------- drivers/mtd/spi/spi_flash.c | 3 --- 2 files changed, 7 insertions(+), 12 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 71ba1a6..9eb0b84 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -27,14 +27,13 @@ enum { #else SECT_4K = BIT(0), #endif - SECT_32K = BIT(1), - E_FSR = BIT(2), - SST_WR = BIT(3), - WR_QPP = BIT(4), - RD_QUAD = BIT(5), - RD_DUAL = BIT(6), - RD_QUADIO = BIT(7), - RD_DUALIO = BIT(8), + E_FSR = BIT(1), + SST_WR = BIT(2), + WR_QPP = BIT(3), + RD_QUAD = BIT(4), + RD_DUAL = BIT(5), + RD_QUADIO = BIT(6), + RD_DUALIO = BIT(7), }; #define RD_FULL RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO
@@ -57,7 +56,6 @@ enum spi_nor_option_flags {
/* Erase commands */ #define CMD_ERASE_4K 0x20 -#define CMD_ERASE_32K 0x52 #define CMD_ERASE_CHIP 0xc7 #define CMD_ERASE_64K 0xd8
diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 041b64f..2b2a409 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1159,9 +1159,6 @@ int spi_flash_scan(struct spi_flash *flash) if (params->flags & SECT_4K) { flash->erase_cmd = CMD_ERASE_4K; flash->erase_size = 4096 << flash->shift; - } else if (params->flags & SECT_32K) { - flash->erase_cmd = CMD_ERASE_32K; - flash->erase_size = 32768 << flash->shift; } else { flash->erase_cmd = CMD_ERASE_64K; flash->erase_size = flash->sector_size;
Add CONFIG_SPI_FLASH_USE_4K_SECTORS in spi_flash code from header file.
Cc: Simon Glass sjg@chromium.org Cc: Bin Meng bmeng.cn@gmail.com Cc: Michal Simek michal.simek@xilinx.com Cc: Siva Durga Prasad Paladugu sivadur@xilinx.com Cc: Vignesh R vigneshr@ti.com Cc: Mugunthan V N mugunthanvnm@ti.com Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 4 ---- drivers/mtd/spi/spi_flash.c | 5 ++++- 2 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 9eb0b84..1301e48 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -22,11 +22,7 @@ enum spi_dual_flash {
/* sf param flags */ enum { -#ifndef CONFIG_SPI_FLASH_USE_4K_SECTORS - SECT_4K = 0, -#else SECT_4K = BIT(0), -#endif E_FSR = BIT(1), SST_WR = BIT(2), WR_QPP = BIT(3), diff --git a/drivers/mtd/spi/spi_flash.c b/drivers/mtd/spi/spi_flash.c index 2b2a409..7f6e9ae 100644 --- a/drivers/mtd/spi/spi_flash.c +++ b/drivers/mtd/spi/spi_flash.c @@ -1155,11 +1155,14 @@ int spi_flash_scan(struct spi_flash *flash) flash->size <<= 1; #endif
+#ifdef CONFIG_SPI_FLASH_USE_4K_SECTORS /* Compute erase sector and command */ if (params->flags & SECT_4K) { flash->erase_cmd = CMD_ERASE_4K; flash->erase_size = 4096 << flash->shift; - } else { + } else +#endif + { flash->erase_cmd = CMD_ERASE_64K; flash->erase_size = flash->sector_size; }
This patch moves flags macro's to respective member position on spi_flash_params{}, for better readabilty and finding the respective member macro's easily.
Signed-off-by: Jagan Teki jteki@openedev.com --- drivers/mtd/spi/sf_internal.h | 23 ++++++++++------------- 1 file changed, 10 insertions(+), 13 deletions(-)
diff --git a/drivers/mtd/spi/sf_internal.h b/drivers/mtd/spi/sf_internal.h index 1301e48..e5c38bf 100644 --- a/drivers/mtd/spi/sf_internal.h +++ b/drivers/mtd/spi/sf_internal.h @@ -20,19 +20,6 @@ enum spi_dual_flash { SF_DUAL_PARALLEL_FLASH = BIT(1), };
-/* sf param flags */ -enum { - SECT_4K = BIT(0), - E_FSR = BIT(1), - SST_WR = BIT(2), - WR_QPP = BIT(3), - RD_QUAD = BIT(4), - RD_DUAL = BIT(5), - RD_QUADIO = BIT(6), - RD_DUALIO = BIT(7), -}; -#define RD_FULL RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO - enum spi_nor_option_flags { SNOR_F_SST_WR = BIT(0), SNOR_F_USE_FSR = BIT(1), @@ -133,7 +120,17 @@ struct spi_flash_params { u16 ext_jedec; u32 sector_size; u32 nr_sectors; + u16 flags; +#define SECT_4K BIT(0) +#define E_FSR BIT(1) +#define SST_WR BIT(2) +#define WR_QPP BIT(3) +#define RD_QUAD BIT(4) +#define RD_DUAL BIT(5) +#define RD_QUADIO BIT(6) +#define RD_DUALIO BIT(7) +#define RD_FULL (RD_QUAD | RD_DUAL | RD_QUADIO | RD_DUALIO) };
extern const struct spi_flash_params spi_flash_params_table[];
Jagan Teki
