[PATCH 1/1] doc: define html_context in conf.py
The dictionary html_context is not passed into conf.py but must be created there. See https://dev.readthedocs.io/en/latest/design/theme-context.html#customizing-t...
Fixes: df86796028df ("doc: enable ReadTheDocs addon management") Signed-off-by: Heinrich Schuchardt heinrich.schuchardt@canonical.com --- doc/conf.py | 4 +++- 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/doc/conf.py b/doc/conf.py index e79134cc3d7..ced3a6723fc 100644 --- a/doc/conf.py +++ b/doc/conf.py @@ -26,7 +26,9 @@ html_baseurl = os.environ.get("READTHEDOCS_CANONICAL_URL", "")
# Tell Jinja2 templates the build is running on Read the Docs if os.environ.get("READTHEDOCS", "") == "True": - html_context["READTHEDOCS"] = True + html_context = { + 'READTHEDOCS' : True, + }
# If extensions (or modules to document with autodoc) are in another directory, # add these directories to sys.path here. If the directory is relative to the
On Fri, 19 Jul 2024 at 22:23, Heinrich Schuchardt heinrich.schuchardt@canonical.com wrote:
- html_context = {
2.45.2
