[PATCH] pci: Handle failed calloc in decode_regions()
Add a check for calloc() failing to allocate the requested memory.
Make decode_regions() return an error code.
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Signed-off-by: Pierre-Clément Tosi ptosi@google.com --- drivers/pci/pci-uclass.c | 15 ++++++++++----- 1 file changed, 10 insertions(+), 5 deletions(-)
diff --git a/drivers/pci/pci-uclass.c b/drivers/pci/pci-uclass.c index 970ee1adf1..2c85e78a13 100644 --- a/drivers/pci/pci-uclass.c +++ b/drivers/pci/pci-uclass.c @@ -954,7 +954,7 @@ int pci_bind_bus_devices(struct udevice *bus) return 0; }
-static void decode_regions(struct pci_controller *hose, ofnode parent_node, +static int decode_regions(struct pci_controller *hose, ofnode parent_node, ofnode node) { int pci_addr_cells, addr_cells, size_cells; @@ -968,7 +968,7 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, prop = ofnode_get_property(node, "ranges", &len); if (!prop) { debug("%s: Cannot decode regions\n", __func__); - return; + return -EINVAL; }
pci_addr_cells = ofnode_read_simple_addr_cells(node); @@ -986,6 +986,8 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, max_regions = len / cells_per_record + CONFIG_NR_DRAM_BANKS; hose->regions = (struct pci_region *) calloc(1, max_regions * sizeof(struct pci_region)); + if (!hose->regions) + return -ENOMEM;
for (i = 0; i < max_regions; i++, len -= cells_per_record) { u64 pci_addr, addr, size; @@ -1053,7 +1055,7 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, /* Add a region for our local memory */ bd = gd->bd; if (!bd) - return; + return 0;
for (i = 0; i < CONFIG_NR_DRAM_BANKS; ++i) { if (bd->bi_dram[i].size) { @@ -1068,7 +1070,7 @@ static void decode_regions(struct pci_controller *hose, ofnode parent_node, } }
- return; + return 0; }
static int pci_uclass_pre_probe(struct udevice *bus) @@ -1097,7 +1099,10 @@ static int pci_uclass_pre_probe(struct udevice *bus) /* For bridges, use the top-level PCI controller */ if (!device_is_on_pci_bus(bus)) { hose->ctlr = bus; - decode_regions(hose, dev_ofnode(bus->parent), dev_ofnode(bus)); + ret = decode_regions(hose, dev_ofnode(bus->parent), + dev_ofnode(bus)); + if (ret) + return ret; } else { struct pci_controller *parent_hose;
Thanks, Stefan
return;
return -EINVAL;
if (!hose->regions)
return -ENOMEM;
return;
- return;
return 0; }
dev_ofnode(bus));
if (ret)
} else { struct pci_controller *parent_hose;return ret;
Viele Grüße, Stefan Roese
Cc: Bin Meng bmeng.cn@gmail.com Cc: Simon Glass sjg@chromium.org Cc: Stefan Roese sr@denx.de Signed-off-by: Pierre-Clément Tosi ptosi@google.com Reviewed-by: Stefan Roese sr@denx.de
Quoting Pierre-Clément Tosi ptosi@google.com:
We upgraded from v2022.04 -> v2022.10, and this PATCH breaks PCI (scsi/sata) support for x86_64. I have seen this in qemu, i havn't had the time to test this on real hardware.
Steps to reproduce: $ make efi-x86_payload64_defconfig && make -j32 && scripts/build-efi.sh -sPrp
Br, /Sean
return;
return -EINVAL;
if (!hose->regions)
return -ENOMEM;
return;
- return;
dev_ofnode(bus));
if (ret)
-- 2.36.1.124.g0e6072fb45-goog
Decompiling the resulting u-boot.dtb shows
pci { compatible = "pci-x86"; u-boot,dm-pre-reloc; };
which isn't supported by the patch as we return -EINVAL when missing "ranges". The rationale here was that the property seemed mandatory (see [1] and [2]); was this a misunderstanding of potential corner cases?
OTOH, I see that most DTS using "pci-x86" (a pseudo-device intended to act as a PCI bus) actually provide "ranges". In particular, a comment added by 0ced70a0bb7a ("x86: tpl: Add a fake PCI bus") states that
The BARs are allocated statically in the device tree.
So I'll let others comment on this but either:
- arch/x86/dts/efi-x86_payload.dts (and a few other DTS) is missing "ranges"; or - pci_uclass_pre_probe() should treat UCLASS_SIMPLE_BUS differently.
[1]: https://www.kernel.org/doc/Documentation/devicetree/bindings/pci/host-generi... [2]: IEEE Std 1275-1994
Br, /Sean
return;
return -EINVAL;
if (!hose->regions)
return -ENOMEM;
return;
- return;
dev_ofnode(bus));
if (ret)
Am So., 4. Dez. 2022 um 22:22 Uhr schrieb Pierre-Clément Tosi ptosi@google.com:
Breaks my use case too and is basically a revert of https://source.denx.de/u-boot/u-boot/-/commit/f2825f6ec0bb50e7bd9376828a3221... In my use case we are using coreboot for different Intel SoCs with a generic U-Boot payload.
Yes.. that is what can be found here: https://source.denx.de/u-boot/u-boot/-/blob/master/arch/x86/dts/coreboot.dts...
At the moment I would like to revert this change.
Br, /Sean
return;
return -EINVAL;
if (!hose->regions)
return -ENOMEM;
return;
- return;
dev_ofnode(bus));
if (ret)
-- Pierre
Thanks for sharing such a corner case.
IMO, normal operation shouldn't rely on errors being silently skipped because return values are being blindly ignored. Instead, we could limit EINVAL to libfdt errors that aren't FDT_ERR_NOTFOUND, which would address your use-case, where "ranges" is missing from the DT node.
Is your issue fixed by this patch:
https://patchwork.ozlabs.org/project/uboot/patch/20230220194927.476708-8-sjg...
Br, /Sean
return;
return -EINVAL;
if (!hose->regions)
return -ENOMEM;
return;
- return;
dev_ofnode(bus));
if (ret)
-- Pierre
-- greets -- Christian Gmeiner, MSc
Thanks
Hi
Yes .. the regression is fixed with this patch \o/
participants (5)
Christian Gmeiner
Pierre-Clément Tosi
sean@geanix.com
Stefan Roese
