[U-Boot] [PATCH v2] mtd: nand: allow to skip BBT scanning during NAND inititialization
Since commit ff94bc40af34 (mtd, ubi, ubifs: resync with Linux-3.14), chip->scan_bbt() is called at the end of nand_scan_tail(). It means the first read access happens immediately after the generic NAND initialization process.
It causes a problem to some SoCs of UniPhier platform because some of their register values need to be fixed up after the general initialization procedure has been finished. Otherwise, read asccess fails. Such a fix-up is SoC-specific enough to be written in a board file rather than in driver code.
One of possible and clean enough ways to work around this issue is postpone the BBT scanning until necessary fix-up is done in board_late_init() or somewhere else.
CONFIG_MTD_NAND_SKIP_BBTSCAN, if enabled, allows to skip the BBT scanning at the end of nand_scan_tail().
Signed-off-by: Masahiro Yamada yamada.m@jp.panasonic.com Cc: Scott Wood scottwood@freescale.com ---
If this patch is accepted, I will turn on this config option for my boards.
Changes in v2: - Bug fix ( "config" was missing from v1)
drivers/mtd/nand/Kconfig | 13 +++++++++++++ drivers/mtd/nand/nand.c | 4 ++++ 2 files changed, 17 insertions(+)
diff --git a/drivers/mtd/nand/Kconfig b/drivers/mtd/nand/Kconfig index 75c2c06..e1d6fbc 100644 --- a/drivers/mtd/nand/Kconfig +++ b/drivers/mtd/nand/Kconfig @@ -2,6 +2,19 @@ menu "NAND Device Support"
if !SPL_BUILD
+config MTD_NAND_SKIP_BBTSCAN + bool "Skip BBT scanning" + help + The current implementation of nand_scan_tail() calls scan_bbt handler + at the end of itself to build a bad block table. It means the first + read access happens in the initizalization procedure. It causes a + problem on some SoCs that need some extra SoC-specific settings + before starting read/write access. + + If this option is enabled, bad block scanning is skipped during the + nand device initialization. You are resposible to build a bad block + table lator. + config NAND_DENALI bool "Support Denali NAND controller" help diff --git a/drivers/mtd/nand/nand.c b/drivers/mtd/nand/nand.c index 4cf4c1c..a249647 100644 --- a/drivers/mtd/nand/nand.c +++ b/drivers/mtd/nand/nand.c @@ -88,6 +88,10 @@ static void nand_init_chip(int i) mtd->priv = nand; nand->IO_ADDR_R = nand->IO_ADDR_W = (void __iomem *)base_addr;
+#ifdef CONFIG_MTD_NAND_SKIP_BBTSCAN + nand->options |= NAND_SKIP_BBTSCAN; +#endif + if (board_nand_init(nand)) return;
Rotislav Lisovy already posted a patch to fix the regression, but I don't think you should be relying on this for your problem. Why don't you want to put SoC-specific knowledge in the driver? At least make it a callback from the driver to an SoC file, rather than hoping the NAND won't be touched for a certain amount of time after the driver has told the subsystem "I'm here and ready to be used".
-Scott
Also, if you did have a valid reason to set NAND_SKIP_BBTSCAN, why would you want to set it from nand.c rather than from your driver's init function?
-Scott
Hi Scott,
If you are willing to apply Rostislav's patch, I am fine. There is no reason (at least) for me to insist on this patch any more.
There are two reasons:
[1] This problem occurs on some of Panasonic UniPhier SoCs. Denali driver (drivers/mtd/nand/denali.c) is used by SOCFPGA as well as UniPhier. I do not think it is a good idea to put dirty and SoC-specific work around into the driver.
[2] There is no good place to insert a callback to an SoC file. I need to write parameters such as page_size to hardware registers. (You can see my code, nand_denali_fixup() in arch/arm/cpu/armv7/uniphier/board_late_init.c)
The NAND init procedure of U-Boot is like this:
(1) board_nand_init() (drivers/mtd/nand/denali.c) (2) nand_scan_ident() (drivers/mtd/nand/nand_base.c) (3) nand_scan_tail() (drivers/mtd/nand/nand_base.c)
(2) detects the device size and set mtd->write_size, mtd->erase_size, mtd->oob_size. I need to set these values to the Denali hardware, but the Denali driver code is called at (1) which is called before the detection of the device size.
In Linux, nand_scan_ident() and nand_scan_tail() are called from each of NAND drivers, so we can use the values which have been set during nand_scan_ident().
In U-Boot, I think it is impossible.
-Scott
Best Regards Masahiro Yamada
If you use CONFIG_SYS_NAND_SELF_INIT you can insert code between nand_scan_ident() and nand_scan_tail(), just like in Linux.
-Scott
Hi Scott,
Thanks for your advice! I have posted patches: http://patchwork.ozlabs.org/patch/409429/ http://patchwork.ozlabs.org/patch/409428/
Masahiro Yamada
Scott Wood
